[GRASS-SVN] r61944 - in grass/trunk/lib/python: gunittest imaging pygrass pygrass/modules/interface pygrass/raster pygrass/shell pygrass/vector script
Sun Sep 14 06:47:40 PDT 2014
Author: lucadelu
Date: 2014-09-14 06:47:40 -0700 (Sun, 14 Sep 2014)
New Revision: 61944
   grass/trunk/lib/python/gunittest/case.py
   grass/trunk/lib/python/gunittest/gmodules.py
   grass/trunk/lib/python/imaging/images2gif.py
   grass/trunk/lib/python/imaging/images2swf.py
   grass/trunk/lib/python/pygrass/functions.py
   grass/trunk/lib/python/pygrass/modules/interface/flag.py
   grass/trunk/lib/python/pygrass/modules/interface/module.py
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/abstract.py
   grass/trunk/lib/python/pygrass/raster/category.py
   grass/trunk/lib/python/pygrass/shell/conversion.py
   grass/trunk/lib/python/pygrass/vector/__init__.py
   grass/trunk/lib/python/pygrass/vector/basic.py
   grass/trunk/lib/python/pygrass/vector/find.py
   grass/trunk/lib/python/pygrass/vector/geometry.py
   grass/trunk/lib/python/pygrass/vector/table.py
   grass/trunk/lib/python/script/db.py
   grass/trunk/lib/python/script/raster.py
   grass/trunk/lib/python/script/task.py
   grass/trunk/lib/python/script/utils.py
   grass/trunk/lib/python/script/vector.py
lib python: documentation cleanup, fix sphinx warning
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/gunittest/case.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -489,6 +489,7 @@
         Or in command line, use ``md5sum`` command if available:
         .. code-block:: sh
             md5sum some_file.txt
         Finaly, you can use Python ``hashlib`` to obtain MD5::
@@ -955,7 +956,7 @@
                                     errors=errors)
         # TODO: use this also in assert and apply when appropriate
         if expecting_stdout and not module.outputs.stdout.strip():
             if module.outputs.stderr:
                 errors = " The errors are:\n" + module.outputs.stderr
             else:
Modified: grass/trunk/lib/python/gunittest/gmodules.py
--- grass/trunk/lib/python/gunittest/gmodules.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/gunittest/gmodules.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -21,7 +21,7 @@
 class SimpleModule(Module):
     """Simple wrapper around pygrass.modules.Module to make sure that
-       run_, finish_, stdout and stderr are set correctly.
+    run\_, finish\_, stdout and stderr are set correctly.
     >>> mapcalc = SimpleModule('r.mapcalc', expression='test_a = 1',
     ...                        overwrite=True)
Modified: grass/trunk/lib/python/imaging/images2gif.py
--- grass/trunk/lib/python/imaging/images2gif.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/imaging/images2gif.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -35,10 +35,10 @@
 Note that since July 2004, all patents on the LZW compression patent have
 expired. Therefore the GIF format may now be used freely.
-Acknowledgements
+Acknowledgements:
 Many thanks to Ant1 for:
 * noting the use of "palette=PIL.Image.ADAPTIVE", which significantly
   improves the results.
 * the modifications to save each image with its own palette, or optionally
@@ -56,8 +56,8 @@
 distribution of PIL)
-Usefull links
+Usefull links:
   * http://tronche.com/computer-graphics/gif/
   * http://en.wikipedia.org/wiki/Graphics_Interchange_Format
   * http://www.w3.org/Graphics/GIF/spec-gif89a.txt
@@ -225,8 +225,8 @@
         """Graphics Control Extension. A sort of header at the start of
         each image. Specifies duration and transparancy.
-        Dispose
+        Dispose:
           * 0 - No disposal specified.
           * 1 - Do not dispose. The graphic is to be left in place.
           * 2 -	Restore to background color. The area used by the graphic
@@ -398,12 +398,12 @@
     def writeGifToFile(self, fp, images, durations, loops, xys, disposes):
         """ writeGifToFile(fp, images, durations, loops, xys, disposes)
         Given a set of images writes the bytes to the specified stream.
         Requires different handling of palette for PIL and Pillow:
         based on https://github.com/rec/echomesh/blob/master/
         code/python/external/images2gif.py
         # Obtain palette for all images and count each occurance
@@ -476,44 +476,39 @@
         fp.write(";")  # end gif
         return frames
-## Exposed functions
 def writeGif(filename, images, duration=0.1, repeat=True, dither=False,
              nq=0, subRectangles=True, dispose=None):
     """Write an animated gif from the specified images.
-    Parameters
-    filename : string
-        The name of the file to write the image to.
-    images : list
-        Should be a list consisting of PIL images or numpy arrays.
-        The latter should be between 0 and 255 for integer types, and
-        between 0 and 1 for float types.
-    duration : scalar or list of scalars
-        The duration for all frames, or (if a list) for each frame.
-    repeat : bool or integer
-        The amount of loops. If True, loops infinitetely.
-    dither : bool
-        Whether to apply dithering
-    nq : integer
-        If nonzero, applies the NeuQuant quantization algorithm to create
-        the color palette. This algorithm is superior, but slower than
-        the standard PIL algorithm. The value of nq is the quality
-        parameter. 1 represents the best quality. 10 is in general a
-        good tradeoff between quality and speed. When using this option,
-        better results are usually obtained when subRectangles is False.
-    subRectangles : False, True, or a list of 2-element tuples
-        Whether to use sub-rectangles. If True, the minimal rectangle that
-        is required to update each frame is automatically detected. This
-        can give significant reductions in file size, particularly if only
-        a part of the image changes. One can also give a list of x-y
-        coordinates if you want to do the cropping yourself. The default
-        is True.
-    dispose : int
-        How to dispose each frame. 1 means that each frame is to be left
-        in place. 2 means the background color should be restored after
-        each frame. 3 means the decoder should restore the previous frame.
-        If subRectangles==False, the default is 2, otherwise it is 1.
+    :param str filename: the name of the file to write the image to.
+    :param list images: should be a list consisting of PIL images or numpy
+                        arrays. The latter should be between 0 and 255 for
+                        integer types, and between 0 and 1 for float types.
+    :param duration: scalar or list of scalars The duration for all frames, or
+                     (if a list) for each frame.
+    :param repeat: bool or integer The amount of loops. If True, loops infinitetely.
+    :param bool dither: whether to apply dithering
+    :param int nq: If nonzero, applies the NeuQuant quantization algorithm to
+                   create the color palette. This algorithm is superior, but
+                   slower than the standard PIL algorithm. The value of nq is
+                   the quality parameter. 1 represents the best quality. 10 is
+                   in general a good tradeoff between quality and speed. When
+                   using this option, better results are usually obtained when
+                   subRectangles is False.
+    :param subRectangles: False, True, or a list of 2-element tuples
+                          Whether to use sub-rectangles. If True, the minimal
+                          rectangle that is required to update each frame is
+                          automatically detected. This can give significant
+                          reductions in file size, particularly if only a part
+                          of the image changes. One can also give a list of x-y
+                          coordinates if you want to do the cropping yourself.
+                          The default is True.
+    :param int dispose: how to dispose each frame. 1 means that each frame is
+                        to be left in place. 2 means the background color
+                        should be restored after each frame. 3 means the
+                        decoder should restore the previous frame. If
+                        subRectangles==False, the default is 2, otherwise it is 1.
@@ -636,8 +631,7 @@
     See also:
     http://members.ozemail.com.au/~dekker/NEUQUANT.HTML
-    License of the NeuQuant Neural-Net Quantization Algorithm
+    **License of the NeuQuant Neural-Net Quantization Algorithm**
     Copyright (c) 1994 Anthony Dekker
     Ported to python by Marius van Voorden in 2010
Modified: grass/trunk/lib/python/imaging/images2swf.py
--- grass/trunk/lib/python/imaging/images2swf.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/imaging/images2swf.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -55,6 +55,7 @@
 This module requires Python 2.x and numpy.
 sources and tools:
 - SWF on wikipedia
 - Adobes "SWF File Format Specification" version 10
   (http://www.adobe.com/devnet/swf/pdf/swf_file_format_spec_v10.pdf)
Modified: grass/trunk/lib/python/pygrass/functions.py
--- grass/trunk/lib/python/pygrass/functions.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/functions.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -48,6 +48,7 @@
 def findmaps(type, pattern=None, mapset='', location='', gisdbase=''):
     """Return a list of tuple contining the names of the:
         * map
         * mapset,
         * location,
@@ -118,17 +119,17 @@
 def getenv(env):
-    """Return the current grass environment variables ::
+    """Return the current grass environment variables
-        >>> getenv("MAPSET")
-        'user1'
+    >>> getenv("MAPSET")
+    'user1'
     return libgis.G__getenv(env)
 def get_mapset_raster(mapname, mapset=''):
-    """Return the mapset of the raster map ::
+    """Return the mapset of the raster map
     >>> get_mapset_raster('elevation')
     'PERMANENT'
@@ -138,7 +139,7 @@
 def get_mapset_vector(mapname, mapset=''):
-    """Return the mapset of the vector map ::
+    """Return the mapset of the vector map
     >>> get_mapset_vector('census')
     'PERMANENT'
@@ -148,7 +149,7 @@
 def is_clean_name(name):
-    """Return if the name is valid ::
+    """Return if the name is valid
     >>> is_clean_name('census')
     True
@@ -166,13 +167,14 @@
 def coor2pixel(coord, region):
-    """Convert coordinates into a pixel row and col ::
+    """Convert coordinates into a pixel row and col
-        >>> reg = Region()
-        >>> coor2pixel((reg.west, reg.north), reg)
-        (0.0, 0.0)
-        >>> coor2pixel((reg.east, reg.south), reg) == (reg.rows, reg.cols)
-        True
+    >>> reg = Region()
+    >>> coor2pixel((reg.west, reg.north), reg)
+    (0.0, 0.0)
+    >>> coor2pixel((reg.east, reg.south), reg) == (reg.rows, reg.cols)
+    True
     (east, north) = coord
     return (libraster.Rast_northing_to_row(north, region.c_region),
@@ -180,13 +182,14 @@
 def pixel2coor(pixel, region):
-    """Convert row and col of a pixel into a coordinates ::
+    """Convert row and col of a pixel into a coordinates
-        >>> pixel2coor((0, 0), reg) == (reg.north, reg.west)
-        True
-        >>> pixel2coor((reg.cols, reg.rows), reg) == (reg.south, reg.east)
-        True
+    >>> pixel2coor((0, 0), reg) == (reg.north, reg.west)
+    True
+    >>> pixel2coor((reg.cols, reg.rows), reg) == (reg.south, reg.east)
+    True
     (col, row) = pixel
     return (libraster.Rast_row_to_northing(row, region.c_region),
@@ -196,37 +199,33 @@
 def get_raster_for_points(poi_vector, raster, column=None):
     """Query a raster map for each point feature of a vector
-    Example ::
+    Example
-        >>> from grass.pygrass.vector import VectorTopo
-        >>> from grass.pygrass.raster import RasterRow
-        >>> ele = RasterRow('elevation')
-        >>> copy('schools','myschools','vect')
-        >>> sch = VectorTopo('myschools')
-        >>> sch.open()
-        >>> get_raster_for_points(sch, ele)               # doctest: +ELLIPSIS
-        [(1, 633649.2856743174, 221412.94434781274, 145.06602)...
-        >>> sch.table.columns.add('elevation','double precision')
-        >>> 'elevation' in sch.table.columns
-        True
-        >>> get_raster_for_points(sch, ele, 'elevation')
-        True
-        >>> sch.table.filters.select('NAMESHORT','elevation')
-        Filters(u'SELECT NAMESHORT, elevation FROM myschools;')
-        >>> cur = sch.table.execute()
-        >>> cur.fetchall()                                # doctest: +ELLIPSIS
-        [(u'SWIFT CREEK', 145.06602), ... (u'9TH GRADE CTR', None)]
-        >>> remove('myschools','vect')
+    >>> from grass.pygrass.vector import VectorTopo
+    >>> from grass.pygrass.raster import RasterRow
+    >>> ele = RasterRow('elevation')
+    >>> copy('schools','myschools','vect')
+    >>> sch = VectorTopo('myschools')
+    >>> sch.open()
+    >>> get_raster_for_points(sch, ele)               # doctest: +ELLIPSIS
+    [(1, 633649.2856743174, 221412.94434781274, 145.06602)...
+    >>> sch.table.columns.add('elevation','double precision')
+    >>> 'elevation' in sch.table.columns
+    True
+    >>> get_raster_for_points(sch, ele, 'elevation')
+    True
+    >>> sch.table.filters.select('NAMESHORT','elevation')
+    Filters(u'SELECT NAMESHORT, elevation FROM myschools;')
+    >>> cur = sch.table.execute()
+    >>> cur.fetchall()                                # doctest: +ELLIPSIS
+    [(u'SWIFT CREEK', 145.06602), ... (u'9TH GRADE CTR', None)]
+    >>> remove('myschools','vect')
-    Parameters
+    :param point: point vector object
+    :param raster: raster object
+    :param str column: column name to update
-    point: point vector object
-    raster: raster object
-    column: column name to update
     from math import isnan
     if not column:
@@ -268,9 +267,9 @@
 def get_lib_path(modname, libname):
-    """Return the path of the libname contained in the module. ::
+    """Return the path of the libname contained in the module.
-        >>> get_lib_path(modname='r.modis', libname='libmodis')
+    >>> get_lib_path(modname='r.modis', libname='libmodis')
     from os.path import isdir, join
     from os import getenv
@@ -338,9 +337,6 @@
     """Property attribute for docstrings.
     Took from: https://gist.github.com/bfroehle/4041015
-    Usage
     >>> class A(object):
     ...     '''Main docstring'''
     ...     def __init__(self, x):
Modified: grass/trunk/lib/python/pygrass/modules/interface/flag.py
--- grass/trunk/lib/python/pygrass/modules/interface/flag.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/modules/interface/flag.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -8,21 +8,21 @@
 class Flag(object):
     """The Flag object store all information about a flag of module.
-    It is possible to set flags of command using this object. ::
+    It is possible to set flags of command using this object.
-            >>> flag = Flag(diz=dict(name='a', description='Flag description',
-            ...                      default=True))
-            >>> flag.name
-            u'a'
-            >>> flag.special
-            False
-            >>> flag.description
-            u'Flag description'
-            >>> flag = Flag(diz=dict(name='overwrite'))
-            >>> flag.name
-            u'overwrite'
-            >>> flag.special
-            True
+    >>> flag = Flag(diz=dict(name='a', description='Flag description',
+    ...                      default=True))
+    >>> flag.name
+    u'a'
+    >>> flag.special
+    False
+    >>> flag.description
+    u'Flag description'
+    >>> flag = Flag(diz=dict(name='overwrite'))
+    >>> flag.name
+    u'overwrite'
+    >>> flag.special
+    True
     def __init__(self, xflag=None, diz=None):
         self.value = False
@@ -35,21 +35,21 @@
         self.guisection = diz.get('guisection', None)
     def get_bash(self):
-        """Return the BASH representation of a flag. ::
+        """Return the BASH representation of a flag.
-            >>> flag.get_bash()
-            u''
-            >>> flag.value = True
-            u'-a'
-            u''
-            u'--o'
+        >>> flag.get_bash()
+        u''
+        >>> flag.value = True
+        u'-a'
+        u''
+        u'--o'
         if self.value:
             if self.special:
@@ -60,21 +60,21 @@
             return ''
     def get_python(self):
-        """Return the python representation of a flag. ::
+        """Return the python representation of a flag.
-            >>> flag.get_python()
-            u''
-            u'a'
-            u''
-            u'overwrite=True'
+        >>> flag.get_python()
+        u''
+        u'a'
+        u''
+        u'overwrite=True'
         if self.value:
             return '%s=True' % self.name if self.special else self.name
@@ -95,20 +95,17 @@
         {name}: {default}
             {description}
+        >>> print(flag.__doc__)
+        a: True
+            Flag description
-            >>> print(flag.__doc__)
-            a: True
-                Flag description
+        overwrite: None
+            None
-            overwrite: None
-                None
         return read.DOC['flag'].format(name=self.name,
                                        default=repr(self.default),
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -23,51 +23,51 @@
 class ParallelModuleQueue(object):
     """This class is designed to run an arbitrary number of pygrass Module
-       processes in parallel.
+    processes in parallel.
-       Objects of type grass.pygrass.modules.Module can be put into the
-       queue using put() method. When the queue is full with the maximum
-       number of parallel processes it will wait for all processes to finish,
-       sets the stdout and stderr of the Module object and removes it
-       from the queue when its finished.
+    Objects of type grass.pygrass.modules.Module can be put into the
+    queue using put() method. When the queue is full with the maximum
+    number of parallel processes it will wait for all processes to finish,
+    sets the stdout and stderr of the Module object and removes it
+    from the queue when its finished.
-       This class will raise a GrassError in case a Module process exits
-       with a return code other than 0.
+    This class will raise a GrassError in case a Module process exits
+    with a return code other than 0.
-       Usage:
+    Usage:
-       >>> import copy
-       >>> from grass.pygrass.modules import Module, ParallelModuleQueue
-       >>> mapcalc_list = []
-       >>> mapcalc = Module("r.mapcalc", overwrite=True, run_=False)
-       >>> queue = ParallelModuleQueue(nprocs=3)
-       >>> for i in xrange(5):
-       ...     new_mapcalc = copy.deepcopy(mapcalc)
-       ...     mapcalc_list.append(new_mapcalc)
-       ...     new_mapcalc(expression="test_pygrass_%i = %i"%(i, i))
-       ...     queue.put(new_mapcalc)
-       Module('r.mapcalc')
+    >>> import copy
+    >>> from grass.pygrass.modules import Module, ParallelModuleQueue
+    >>> mapcalc_list = []
+    >>> mapcalc = Module("r.mapcalc", overwrite=True, run_=False)
+    >>> queue = ParallelModuleQueue(nprocs=3)
+    >>> for i in xrange(5):
+    ...     new_mapcalc = copy.deepcopy(mapcalc)
+    ...     mapcalc_list.append(new_mapcalc)
+    ...     new_mapcalc(expression="test_pygrass_%i = %i"%(i, i))
+    ...     queue.put(new_mapcalc)
+    Module('r.mapcalc')
-       >>> queue.wait()
-       >>> for mapcalc in mapcalc_list:
-       ...     print(mapcalc.popen.returncode)
-       0
-       0
-       0
-       0
-       0
+    >>> queue.wait()
+    >>> for mapcalc in mapcalc_list:
+    ...     print(mapcalc.popen.returncode)
+    0
+    0
+    0
+    0
+    0
     def __init__(self, nprocs=1):
         """Constructor
         :param nprocs: The maximum number of Module processes that
-                          can be run in parallel, defualt is 1, if None
-                          then use all the available CPUs.
+                       can be run in parallel, defualt is 1, if None
+                       then use all the available CPUs.
         :type nprocs: int
         nprocs = int(nprocs) if nprocs else cpu_count()
@@ -78,12 +78,12 @@
     def put(self, module):
         """Put the next Module object in the queue
-           To run the Module objects in parallel the run_ and finish_ options
-           of the Module must be set to False.
+        To run the Module objects in parallel the run\_ and finish\_ options
+        of the Module must be set to False.
-           :param module: a preconfigured Module object with run_ and finish_
-                          set to False
-           :type module: Module object
+        :param module: a preconfigured Module object with run\_ and finish\_
+                       set to False
+        :type module: Module object
         self._list[self._proc_count] = module
         # Force that finish is False, otherwise the execution
@@ -98,9 +98,9 @@
     def get(self, num):
         """Get a Module object from the queue
-           :param num: the number of the object in queue
-           :type num: int
-           :returns: the Module object or None if num is not in the queue
+        :param num: the number of the object in queue
+        :type num: int
+        :returns: the Module object or None if num is not in the queue
         if num < self._num_procs:
             return self._list[num]
@@ -108,10 +108,10 @@
     def get_num_run_procs(self):
         """Get the number of Module processes that are in the queue running
-           or finished
+        or finished
-           :returns: the maximum number fo Module processes running/finished in
-                     the queue
+        :returns: the maximum number fo Module processes running/finished in
+                  the queue
         return len(self._list)
@@ -124,8 +124,8 @@
         """Set the maximum number of Module processes that should run
         in parallel
-        :param nprocs: The maximum number of Module processes that
+        :param nprocs: The maximum number of Module processes that can be
+                       run in parallel
         :type nprocs: int
         self._num_procs = int(nprocs)
@@ -133,7 +133,7 @@
     def wait(self):
         """Wait for all Module processes that are in the list to finish
-           and set the modules stdout and stderr output options
+        and set the modules stdout and stderr output options
         for proc in self._list:
             if proc:
@@ -155,130 +155,130 @@
     the ``--interface-description`` in order to understand which parameters
     are required which optionals. ::
-        >>> from subprocess import PIPE
-        >>> import copy
+    >>> from subprocess import PIPE
+    >>> import copy
-        >>> region = Module("g.region")
-        >>> region.flags.p = True  # set flags
-        >>> region.flags.u = True
-        >>> region.flags["3"].value = True  # set numeric flags
-        >>> region.get_bash()
-        u'g.region -p -3 -u'
-        >>> new_region = copy.deepcopy(region)
-        >>> new_region.inputs.res = "10"
-        >>> new_region.get_bash()
-        u'g.region res=10 -p -3 -u'
+    >>> region = Module("g.region")
+    >>> region.flags.p = True  # set flags
+    >>> region.flags.u = True
+    >>> region.flags["3"].value = True  # set numeric flags
+    >>> region.get_bash()
+    u'g.region -p -3 -u'
+    >>> new_region = copy.deepcopy(region)
+    >>> new_region.inputs.res = "10"
+    >>> new_region.get_bash()
+    u'g.region res=10 -p -3 -u'
-        >>> neighbors = Module("r.neighbors")
-        >>> neighbors.inputs.input = "mapA"
-        >>> neighbors.outputs.output = "mapB"
-        >>> neighbors.inputs.size = 5
-        >>> neighbors.inputs.quantile = 0.5
-        >>> neighbors.get_bash()
-        u'r.neighbors input=mapA method=average size=5 quantile=0.5 output=mapB'
+    >>> neighbors = Module("r.neighbors")
+    >>> neighbors.inputs.input = "mapA"
+    >>> neighbors.outputs.output = "mapB"
+    >>> neighbors.inputs.size = 5
+    >>> neighbors.inputs.quantile = 0.5
+    >>> neighbors.get_bash()
+    u'r.neighbors input=mapA method=average size=5 quantile=0.5 output=mapB'
-        >>> new_neighbors1 = copy.deepcopy(neighbors)
-        >>> new_neighbors1.inputs.input = "mapD"
-        >>> new_neighbors1.inputs.size = 3
-        >>> new_neighbors1.inputs.quantile = 0.5
-        >>> new_neighbors1.get_bash()
-        u'r.neighbors input=mapD method=average size=3 quantile=0.5 output=mapB'
+    >>> new_neighbors1 = copy.deepcopy(neighbors)
+    >>> new_neighbors1.inputs.input = "mapD"
+    >>> new_neighbors1.inputs.size = 3
+    >>> new_neighbors1.inputs.quantile = 0.5
+    >>> new_neighbors1.get_bash()
+    u'r.neighbors input=mapD method=average size=3 quantile=0.5 output=mapB'
-        >>> new_neighbors2 = copy.deepcopy(neighbors)
-        >>> new_neighbors2(input="mapD", size=3, run_=False)
-        Module('r.neighbors')
-        >>> new_neighbors2.get_bash()
+    >>> new_neighbors2 = copy.deepcopy(neighbors)
+    >>> new_neighbors2(input="mapD", size=3, run_=False)
+    Module('r.neighbors')
+    >>> new_neighbors2.get_bash()
-        u'r.neighbors method=average size=3'
+    u'r.neighbors method=average size=3'
-        >>> new_neighbors3 = copy.deepcopy(neighbors)
-        >>> new_neighbors3(input="mapA", size=3, output="mapB", run_=False)
-        >>> new_neighbors3.get_bash()
-        u'r.neighbors input=mapA method=average size=3 output=mapB'
+    >>> new_neighbors3 = copy.deepcopy(neighbors)
+    >>> new_neighbors3(input="mapA", size=3, output="mapB", run_=False)
+    >>> new_neighbors3.get_bash()
+    u'r.neighbors input=mapA method=average size=3 output=mapB'
-        >>> mapcalc = Module("r.mapcalc", expression="test_a = 1",
-        ...                  overwrite=True, run_=False)
-        >>> mapcalc.run()
-        >>> mapcalc.popen.returncode
-        0
+    >>> mapcalc = Module("r.mapcalc", expression="test_a = 1",
+    ...                  overwrite=True, run_=False)
+    >>> mapcalc.run()
+    >>> mapcalc.popen.returncode
+    0
-        >>> colors = Module("r.colors", map="test_a", rules="-",
-        ...                 run_=False, stdout_=PIPE,
-        ...                 stderr_=PIPE, stdin_="1 red")
-        >>> colors.run()
-        Module('r.colors')
-        >>> colors.popen.returncode
-        0
-        >>> colors.inputs["stdin"].value
-        u'1 red'
-        >>> colors.outputs["stdout"].value
-        u''
-        >>> colors.outputs["stderr"].value.strip()
-        "Color table for raster map <test_a> set to 'rules'"
+    >>> colors = Module("r.colors", map="test_a", rules="-",
+    ...                 run_=False, stdout_=PIPE,
+    ...                 stderr_=PIPE, stdin_="1 red")
+    >>> colors.run()
+    Module('r.colors')
+    >>> colors.popen.returncode
+    0
+    >>> colors.inputs["stdin"].value
+    u'1 red'
+    >>> colors.outputs["stdout"].value
+    u''
+    >>> colors.outputs["stderr"].value.strip()
+    "Color table for raster map <test_a> set to 'rules'"
-        ...                 run_=False, finish_=False, stdin_=PIPE)
-        >>> colors.run()
-        >>> stdout, stderr = colors.popen.communicate(input="1 red")
-        0
-        >>> stdout
-        >>> stderr
+    ...                 run_=False, finish_=False, stdin_=PIPE)
+    >>> colors.run()
+    >>> stdout, stderr = colors.popen.communicate(input="1 red")
+    0
+    >>> stdout
+    >>> stderr
-        ...                 stdin_=PIPE, stderr_=PIPE)
-        >>> colors.run()
-        0
-        >>> stdout
-        >>> stderr.strip()
+    ...                 stdin_=PIPE, stderr_=PIPE)
+    >>> colors.run()
+    0
+    >>> stdout
+    >>> stderr.strip()
-        Run a second time
-        >>> colors.run()
-        >>> stdout, stderr = colors.popen.communicate(input="1 blue")
-        0
-        >>> stdout
+    Run a second time
+    >>> colors.run()
+    >>> stdout, stderr = colors.popen.communicate(input="1 blue")
+    0
+    >>> stdout
-        Multiple run test
-        ...                                            color="ryb", run_=False)
-        >>> colors.run()
-        >>> colors(color="gyr")
-        >>> colors.run()
-        >>> colors(color="ryg")
-        >>> colors(stderr_=PIPE)
-        >>> colors.run()
-        >>> print(colors.outputs["stderr"].value.strip())
-        Color table for raster map <test_a> set to 'ryg'
-        >>> colors(color="byg")
-        >>> colors(stdout_=PIPE)
-        >>> colors.run()
-        Color table for raster map <test_a> set to 'byg'
+    Multiple run test
+    ...                                            color="ryb", run_=False)
+    >>> colors.run()
+    >>> colors(color="gyr")
+    >>> colors.run()
+    >>> colors(color="ryg")
+    >>> colors(stderr_=PIPE)
+    >>> colors.run()
+    >>> print(colors.outputs["stderr"].value.strip())
+    Color table for raster map <test_a> set to 'ryg'
+    >>> colors(color="byg")
+    >>> colors(stdout_=PIPE)
+    >>> colors.run()
+    Color table for raster map <test_a> set to 'byg'
     Often in the Module class you can find ``*args`` and ``kwargs`` annotation
     in methods, like in the __call__ method.
@@ -289,20 +289,20 @@
             for arg in args:
                 print arg
-    therefore if we call the function like: ::
+    therefore if we call the function like:
-        >>> f('grass', 'gis', 'modules')                     # doctest: +SKIP
-        grass
-        gis
-        modules
+    >>> f('grass', 'gis', 'modules')                     # doctest: +SKIP
+    grass
+    gis
+    modules
-    or we can define a new list: ::
+    or we can define a new list:
-        >>> words = ['grass', 'gis', 'modules']              # doctest: +SKIP
-        >>> f(*words)                                        # doctest: +SKIP
-        grass
-        gis
-        modules
+    >>> words = ['grass', 'gis', 'modules']              # doctest: +SKIP
+    >>> f(*words)                                        # doctest: +SKIP
+    grass
+    gis
+    modules
     we can do the same with keyword arguments, rewrite the above function: ::
@@ -312,27 +312,26 @@
             for key, value in kargs.items():
                 print "%s = %r" % (key, value)
-    now we can use the new function, with: ::
+    now we can use the new function, with:
-        >>> f('grass', 'gis', 'modules', os = 'linux', language = 'python')
-        ...                                                  # doctest: +SKIP
-        grass
-        gis
-        modules
-        os = 'linux'
-        language = 'python'
+    >>> f('grass', 'gis', 'modules', os = 'linux', language = 'python')
+    ...                                                  # doctest: +SKIP
+    grass
+    gis
+    modules
+    os = 'linux'
+    language = 'python'
     or, as before we can, define a dictionary and give the dictionary to
-    the function, like: ::
+    the function, like:
-        >>> keywords = {'os' : 'linux', 'language' : 'python'}
-        >>> f(*words, **keywords)                            # doctest: +SKIP
-        grass
-        gis
-        modules
-        os = 'linux'
+    >>> keywords = {'os' : 'linux', 'language' : 'python'}  # doctest: +SKIP
+    >>> f(*words, **keywords)                            # doctest: +SKIP
+    grass
+    gis
+    modules
+    os = 'linux'
     In the Module class we heavily use this language feature to pass arguments
     and keyword arguments to the grass module.
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -40,6 +40,7 @@
 class RasterRow(RasterAbstractBase):
     """Raster_row_access": Inherits: "Raster_abstract_base" and implements
     the default row access of the Rast library.
         * Implements row access using row id
         * The get_row() method must accept a Row object as argument that will
           be used for value storage, so no new buffer will be allocated
@@ -53,58 +54,57 @@
           object (only for rows), since r.mapcalc is more sophisticated and
           faster
-    Examples
+    Examples:
-        >>> elev = RasterRow('elevation')
-        >>> elev.exist()
-        True
-        >>> elev.is_open()
-        False
-        >>> elev.open()
-        True
-        >>> elev.has_cats()
-        False
-        >>> elev.mode
-        u'r'
-        >>> elev.mtype
-        'FCELL'
-        >>> elev.num_cats()
-        0
-        >>> elev.info.range
-        (56, 156)
-        >>> elev.info
-        elevation@
-        rows: 1350
-        cols: 1500
-        north: 228500.0 south: 215000.0 nsres:10.0
-        east:  645000.0 west: 630000.0 ewres:10.0
-        range: 56, 156
-        proj: 99
-        <BLANKLINE>
+    >>> elev = RasterRow('elevation')
+    >>> elev.exist()
+    True
+    >>> elev.is_open()
+    False
+    >>> elev.open()
+    True
+    >>> elev.has_cats()
+    False
+    >>> elev.mode
+    u'r'
+    >>> elev.mtype
+    'FCELL'
+    >>> elev.num_cats()
+    0
+    >>> elev.info.range
+    (56, 156)
+    >>> elev.info
+    elevation@
+    rows: 1350
+    cols: 1500
+    north: 228500.0 south: 215000.0 nsres:10.0
+    east:  645000.0 west: 630000.0 ewres:10.0
+    range: 56, 156
+    proj: 99
+    <BLANKLINE>
     Each Raster map have an attribute call ``cats`` that allow user
-    to interact with the raster categories. ::
+    to interact with the raster categories.
-        >>> land = RasterRow('geology')
-        >>> land.open()
-        >>> land.cats               # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
-        [('Zml', 1, None),
-         ('Tpyw', 1832, None)]
+    >>> land = RasterRow('geology')
+    >>> land.open()
+    >>> land.cats               # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
+    [('Zml', 1, None),
+     ('Tpyw', 1832, None)]
-    Open a raster map using the *with statement*: ::
+    Open a raster map using the *with statement*:
-        >>> with RasterRow('elevation') as elev:
-        ...     for row in elev[:3]:
-        ...         row[:4]
-        Buffer([ 141.99613953,  141.27848816,  141.37904358,  142.29821777], dtype=float32)
-        Buffer([ 142.90461731,  142.39450073,  142.68611145,  143.59086609], dtype=float32)
-        Buffer([ 143.81854248,  143.54707336,  143.83972168,  144.59527588], dtype=float32)
-        False
+    >>> with RasterRow('elevation') as elev:
+    ...     for row in elev[:3]:
+    ...         row[:4]
+    Buffer([ 141.99613953,  141.27848816,  141.37904358,  142.29821777], dtype=float32)
+    Buffer([ 142.90461731,  142.39450073,  142.68611145,  143.59086609], dtype=float32)
+    Buffer([ 143.81854248,  143.54707336,  143.83972168,  144.59527588], dtype=float32)
+    False
     def __init__(self, name, mapset='', *args, **kargs):
@@ -148,24 +148,23 @@
     def open(self, mode=None, mtype=None, overwrite=None):
         """Open the raster if exist or created a new one.
-        :param mode: Specify if the map will be open with read or write mode
+        :param str mode: Specify if the map will be open with read or write mode
                      ('r', 'w')
-        :type mode: str
-        :param type: If a new map is open, specify the type of the map(`CELL`,
+        :param str type: If a new map is open, specify the type of the map(`CELL`,
                      `FCELL`, `DCELL`)
-        :type type: str
-        :param overwrite: Use this flag to set the overwrite mode of existing
+        :param bool overwrite: Use this flag to set the overwrite mode of existing
                           raster maps
-        :type overwrite: bool
+        if the map already exist, automatically check the type and set:
-        if the map already exist, automatically check the type and set:
             * self.mtype
         Set all the privite, attributes:
             * self._fd;
             * self._gtype
             * self._rows and self._cols
         self.mode = mode if mode else self.mode
         self.mtype = mtype if mtype else self.mtype
@@ -262,6 +261,7 @@
 class RasterSegment(RasterAbstractBase):
     """Raster_segment_access": Inherits "Raster_abstract_base" and uses the
     segment library for cached randomly reading and writing access.
         * Implements the [row][col] operator for read and write access using
           segement_get() and segment_put() functions internally
         * Implements row read and write access with the [row] operator using
@@ -274,6 +274,7 @@
         * No mathematical operation like __add__ and stuff for the Raster
           faster
     def __init__(self, name, srows=64, scols=64, maxmem=100,
                  *args, **kargs):
@@ -475,6 +476,7 @@
     """Raster_cached_narray": Inherits "Raster_abstract_base" and
     "numpy.memmap". Its purpose is to allow numpy narray like access to
     raster maps without loading the map into the main memory.
     * Behaves like a numpy array and supports all kind of mathematical
       operations: __add__, ...
     * Overrides the open and close methods
@@ -593,8 +595,8 @@
     def _read(self):
         """!Read raster map into array
-        @return 0 on success
-        @return non-zero code on failure
+        :return: 0 on success
+        :return: non-zero code on failure
         with RasterRow(self.name, self.mapset, mode='r') as rst:
             buff = rst[0]
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -167,6 +167,7 @@
 class RasterAbstractBase(object):
     """Raster_abstract_base: The base class from which all sub-classes
     inherit. It does not implement any row or map access methods:
     * Implements raster metadata information access (Type, ...)
     * Implements an open method that will be overwritten by the sub-classes
     * Implements the close method that might be overwritten by sub-classes
@@ -174,18 +175,19 @@
     * Implements get and set region methods
     * Implements color, history and category handling
     * Renaming, deletion, ...
     def __init__(self, name, mapset="", *aopen, **kwopen):
         """The constructor need at least the name of the map
-        *optional* field is the `mapset`. ::
+        *optional* field is the `mapset`.
-            >>> ele = RasterAbstractBase('elevation')
-            >>> ele.name
-            u'elevation'
-            >>> ele.exist()
-            True
-            >>> ele.mapset
-            'PERMANENT'
+        >>> ele = RasterAbstractBase('elevation')
+        >>> ele.name
+        u'elevation'
+        >>> ele.exist()
+        True
+        >>> ele.mapset
+        'PERMANENT'
@@ -320,11 +322,11 @@
         """Return True if the map already exist, and
         set the mapset if were not set.
-        call the C function `G_find_raster`. ::
+        call the C function `G_find_raster`.
-            >>> ele.exist()
-            True
+        >>> ele.exist()
+        True
         if self.name:
             if self.mapset == '':
@@ -336,11 +338,11 @@
             return False
     def is_open(self):
-        """Return True if the map is open False otherwise. ::
+        """Return True if the map is open False otherwise.
-            >>> ele.is_open()
-            False
+        >>> ele.is_open()
+        False
         return True if self._fd is not None and self._fd >= 0 else False
@@ -365,11 +367,11 @@
         return "{name}@{mapset}".format(name=self.name, mapset=self.mapset)
     def name_mapset(self, name=None, mapset=None):
-        """Return the full name of the Raster. ::
+        """Return the full name of the Raster.
-            >>> ele.name_mapset()
-            u'elevation at PERMANENT'
+        >>> ele.name_mapset()
+        u'elevation at PERMANENT'
         if name is None:
@@ -415,10 +417,7 @@
     def get_value(self, point, region=None):
         """This method returns the pixel value of a given pair of coordinates:
-        Parameters
-        point = pair of coordinates in tuple object
+        :param point: pair of coordinates in tuple object
         if not region:
             region = Region()
Modified: grass/trunk/lib/python/pygrass/raster/category.py
--- grass/trunk/lib/python/pygrass/raster/category.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/raster/category.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -297,11 +297,9 @@
             0.5:1.0:road
             1.0:1.5:urban
-        :param filename: the name of file with categories rules
-        :type filename: str
-        :param sep: the separator used to divide values and category
-        :type sep: str
+        :param str filename: the name of file with categories rules
+        :param str sep: the separator used to divide values and category
         self.reset()
         with open(filename, 'r') as f:
@@ -329,11 +327,8 @@
             0.5:1.0:road
             1.0:1.5:urban
-        :type sep: str
         with open(filename, 'w') as f:
             cats = []
Modified: grass/trunk/lib/python/pygrass/shell/conversion.py
--- grass/trunk/lib/python/pygrass/shell/conversion.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/shell/conversion.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -17,76 +17,61 @@
               vfmt='%s', vdec='', vfun=None):
     """Return a html repr of a dictionary.
-    Parameters
+    :param dict dic: dictionary or object with `keys` and `items` methods
+    :param keys: iterable objectwith only the keys that we want to display
+    :param str border: could be: "0", "1", etc.
+    :param str kfmt: string to format the key string (i.e. "%r", etc.)
+    :param str kdec: string to decorate the key (i.e. "b", "i", etc.)
+    :param str vfmt: string to format the value string (i.e. "%r", etc.)
+    :param str vdec: string to decorate the value (i.e. "b", "i", etc.)
-    dic: dictionary, required
-        Dictionary or object with `keys` and `items` methods
-    keys: iterable, optional
-        Iterable objectwith only the keys that we want to display
-    border: string, optional
-        Could be: "0", "1", etc.
-    kfmt: string, optional
-        String to format the key string (i.e. "%r", etc.)
-    kdec: string, optional
-        String to decorate the key (i.e. "b", "i", etc.)
-    vfmt: string, optional
-        String to format the value string (i.e. "%r", etc.)
-    vdec: string, optional
-        String to decorate the value (i.e. "b", "i", etc.)
-    Examples
-        >>> dic = {'key 0': 0, 'key 1': 1}
-        >>> print dict2html(dic)
-        <table>
-            <tr>
-              <td>key 0</td>
-              <td>0</td>
-            </tr>
-            <tr>
-              <td>key 1</td>
-              <td>1</td>
-            </tr>
-        </table>
-        >>> print dict2html(dic, border="1")
-        <table border='1'>
-            <tr>
-              <td>key 0</td>
-              <td>0</td>
-            </tr>
-            <tr>
-              <td>key 1</td>
-              <td>1</td>
-            </tr>
-        </table>
-        >>> print dict2html(dic, kdec='b', vfmt='%05d', vdec='i')
-        <table>
-            <tr>
-              <td><b>key 0</b></td>
-              <td><i>00000</i></td>
-            </tr>
-            <tr>
-              <td><b>key 1</b></td>
-              <td><i>00001</i></td>
-            </tr>
-        </table>
-        >>> dic = {'key 0': (2, 3), 'key 1': (10, 5)}
-        >>> print dict2html(dic, kdec='b', vdec='i',
-        ...                 vfun=lambda x: "%d<sup>%.1f</sup>" % x)
-        <table>
-            <tr>
-              <td><i>2<sup>3.0</sup></i></td>
-            </tr>
-            <tr>
-              <td><i>10<sup>5.0</sup></i></td>
-            </tr>
-        </table>
+    >>> dic = {'key 0': 0, 'key 1': 1}
+    >>> print dict2html(dic)
+    <table>
+        <tr>
+          <td>key 0</td>
+          <td>0</td>
+        </tr>
+        <tr>
+          <td>key 1</td>
+          <td>1</td>
+        </tr>
+    </table>
+    >>> print dict2html(dic, border="1")
+    <table border='1'>
+        <tr>
+          <td>key 0</td>
+          <td>0</td>
+        </tr>
+        <tr>
+          <td>key 1</td>
+          <td>1</td>
+        </tr>
+    </table>
+    >>> print dict2html(dic, kdec='b', vfmt='%05d', vdec='i')
+    <table>
+        <tr>
+          <td><b>key 0</b></td>
+          <td><i>00000</i></td>
+        </tr>
+        <tr>
+          <td><b>key 1</b></td>
+          <td><i>00001</i></td>
+        </tr>
+    </table>
+    >>> dic = {'key 0': (2, 3), 'key 1': (10, 5)}
+    >>> print dict2html(dic, kdec='b', vdec='i',
+    ...                 vfun=lambda x: "%d<sup>%.1f</sup>" % x)
+    <table>
+        <tr>
+          <td><i>2<sup>3.0</sup></i></td>
+        </tr>
+        <tr>
+          <td><i>10<sup>5.0</sup></i></td>
+        </tr>
+    </table>
     def fun(x):
         return x
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -471,33 +471,31 @@
     def read(self, feature_id):
         """Return a geometry object given the feature id.
-            :param feature_id: the id of feature to obtain
-            :type feature_id: int
+        :param int feature_id: the id of feature to obtain
+        >>> cens = VectorTopo('census')
+        >>> cens.open(mode='r')
+        >>> feature1 = cens.read(0)                     #doctest: +ELLIPSIS
+        Traceback (most recent call last):
+        ValueError: The index must be >0, 0 given.
+        >>> feature1 = cens.read(1)
+        >>> feature1
+        Boundary(v_id=1)
+        >>> feature1.length()
+        444.54490917696944
+        >>> cens.read(-1)
+        Centoid(642963.159711, 214994.016279)
+        >>> len(cens)
+        8920
+        >>> cens.read(8920)
+        >>> cens.read(8921)                             #doctest: +ELLIPSIS
+        IndexError: Index out of range
+        >>> cens.close()
-            >>> cens = VectorTopo('census')
-            >>> cens.open(mode='r')
-            >>> feature1 = cens.read(0)                     #doctest: +ELLIPSIS
-            Traceback (most recent call last):
-            ValueError: The index must be >0, 0 given.
-            >>> feature1 = cens.read(1)
-            >>> feature1
-            Boundary(v_id=1)
-            >>> feature1.length()
-            444.54490917696944
-            >>> cens.read(-1)
-            Centoid(642963.159711, 214994.016279)
-            >>> len(cens)
-            8920
-            >>> cens.read(8920)
-            >>> cens.read(8921)                             #doctest: +ELLIPSIS
-            IndexError: Index out of range
-            >>> cens.close()
         return read_line(feature_id, self.c_mapinfo, self.table, self.writable,
                          is2D=not self.is_3D())
Modified: grass/trunk/lib/python/pygrass/vector/basic.py
--- grass/trunk/lib/python/pygrass/vector/basic.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/vector/basic.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -14,27 +14,27 @@
 class Bbox(object):
     """Instantiate a Bounding Box class that contains
     a ctypes pointer to the C struct bound_box, that could be used
-    by C GRASS functions. ::
+    by C GRASS functions.
-        >>> bbox = Bbox()
-        >>> bbox
-        Bbox(0.0, 0.0, 0.0, 0.0)
+    >>> bbox = Bbox()
+    >>> bbox
+    Bbox(0.0, 0.0, 0.0, 0.0)
     The default parameters are 0. It is possible to set or change
-    the parameters later, with: ::
+    the parameters later, with:
-        >>> bbox.north = 10
-        >>> bbox.south = -10
-        >>> bbox.east = -20
-        >>> bbox.west = 20
-        >>> bbox
-        Bbox(10.0, -10.0, -20.0, 20.0)
+    >>> bbox.north = 10
+    >>> bbox.south = -10
+    >>> bbox.east = -20
+    >>> bbox.west = 20
+    >>> bbox
+    Bbox(10.0, -10.0, -20.0, 20.0)
-    Or directly istantiate the class with the values, with: ::
+    Or directly istantiate the class with the values, with:
-        >>> bbox = Bbox(north=100, south=0, east=0, west=100)
-        >>> bbox
-        Bbox(100.0, 0.0, 0.0, 100.0)
+    >>> bbox = Bbox(north=100, south=0, east=0, west=100)
+    >>> bbox
+    Bbox(100.0, 0.0, 0.0, 100.0)
@@ -351,7 +351,7 @@
         with a list of integers
         :param ilist: the ilist to append
-        :type ilist: a Ilist object
+        :type ilist: a Ilist object
         if isinstance(ilist, Ilist):
             libvect.Vect_list_append_list(self.c_ilist, ilist.ilist)
@@ -378,36 +378,35 @@
 class Cats(object):
     """Instantiate a Category class that contains a ctypes pointer
-    to the C line_cats struct. ::
+    to the C line_cats struct.
-        >>> cats = Cats()
-        >>> for cat in xrange(100, 110): cats.set(cat, layer=cat-50)
-        >>> cats.n_cats
-        10
-        >>> cats.cat
-        [100, 101, 102, 103, 104, 105, 106, 107, 108, 109]
-        >>> cats.layer
-        [50, 51, 52, 53, 54, 55, 56, 57, 58, 59]
-        >>> cats.get()  # default layer is 1
-        (-1, 0)
-        >>> cats.get(50)
-        (100, 1)
-        >>> cats.get(51)
-        (101, 1)
-        >>> cats.set(1001, 52)
-        >>> cats.cat
-        [100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 1001]
-        >>> cats.layer
-        [50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 52]
-        >>> cats.get(52)
-        (102, 2)
-        >>> cats.reset()
-        >>> cats.layer
-        >>> cats.cat
+    >>> cats = Cats()
+    >>> for cat in xrange(100, 110): cats.set(cat, layer=cat-50)
+    >>> cats.n_cats
+    10
+    >>> cats.cat
+    [100, 101, 102, 103, 104, 105, 106, 107, 108, 109]
+    >>> cats.layer
+    [50, 51, 52, 53, 54, 55, 56, 57, 58, 59]
+    >>> cats.get()  # default layer is 1
+    (-1, 0)
+    >>> cats.get(50)
+    (100, 1)
+    >>> cats.get(51)
+    (101, 1)
+    >>> cats.set(1001, 52)
+    >>> cats.cat
+    [100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 1001]
+    >>> cats.layer
+    [50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 52]
+    >>> cats.get(52)
+    (102, 2)
+    >>> cats.reset()
+    >>> cats.layer
+    >>> cats.cat
     @property
     def layer(self):
@@ -497,25 +496,25 @@
 class CatsList(object):
-        >>> cats_list = CatsList()
-        >>> cats_list.min
-        >>> cats_list.max
-        >>> cats_list.n_ranges
-        0
-        >>> cats_list.layer
-        0
-        >>> string = "2,3,5-9,20"
-        >>> cats_list.from_string(string)
-        >>> cats_list.min
-        [2, 3, 5, 20]
-        >>> cats_list.max
-        [2, 3, 9, 20]
-        4
+    >>> cats_list = CatsList()
+    >>> cats_list.min
+    >>> cats_list.max
+    >>> cats_list.n_ranges
+    0
+    >>> cats_list.layer
+    0
+    >>> string = "2,3,5-9,20"
+    >>> cats_list.from_string(string)
+    >>> cats_list.min
+    [2, 3, 5, 20]
+    >>> cats_list.max
+    [2, 3, 9, 20]
+    4
     @property
Modified: grass/trunk/lib/python/pygrass/vector/find.py
--- grass/trunk/lib/python/pygrass/vector/find.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/vector/find.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -36,39 +36,39 @@
 class PointFinder(AbstractFinder):
     """PointFinder
-    Find the geomtry features of a vector map that are close to a point. ::
-        >>> zipcodes = VectorTopo('zipcodes', 'PERMANENT')
-        >>> schools = VectorTopo('schools', 'PERMANENT')
-        >>> zipcodes.open('r')
-        >>> schools.open('r')
-        >>> result = []
-        >>> for school in schools:
-        ...     zipcode = zipcodes.find['by_point'].area(school)
-        ...     result.append((school.attrs['NAMESHORT'],
-        ...                    zipcode.attrs['ZIPCODE']))
-        >>> result[0]
-        (u'SWIFT CREEK', u'RALEIGH 27606')
-        >>> result[1]
-        (u'BRIARCLIFF', u'CARY 27511')
-        >>> result[2]
-        (u'FARMINGTON WOODS', u'CARY 27511')
-        >>> from grass.pygrass.vector.geometry import Point
-        >>> pnt = Point(631213.349291, 224684.900084)
-        >>> school = schools.find['by_point'].geo(pnt, maxdist=300.)
-        >>> school.attrs['NAMELONG']
-        u'ADAMS ELEMENTARY'
-        >>> for school in schools.find['by_point'].geos(pnt, maxdist=1000.):
-        ...     print school.attrs['NAMELONG']
-        CARY HIGH
-        EAST CARY MIDDLE SITE
-        ADAMS ELEMENTARY
-        >>> schools.close()
-        >>> zipcodes.close()
+    Find the geomtry features of a vector map that are close to a point.
+    >>> zipcodes = VectorTopo('zipcodes', 'PERMANENT')
+    >>> schools = VectorTopo('schools', 'PERMANENT')
+    >>> zipcodes.open('r')
+    >>> schools.open('r')
+    >>> result = []
+    >>> for school in schools:
+    ...     zipcode = zipcodes.find['by_point'].area(school)
+    ...     result.append((school.attrs['NAMESHORT'],
+    ...                    zipcode.attrs['ZIPCODE']))
+    >>> result[0]
+    (u'SWIFT CREEK', u'RALEIGH 27606')
+    >>> result[1]
+    (u'BRIARCLIFF', u'CARY 27511')
+    >>> result[2]
+    (u'FARMINGTON WOODS', u'CARY 27511')
+    >>> from grass.pygrass.vector.geometry import Point
+    >>> pnt = Point(631213.349291, 224684.900084)
+    >>> school = schools.find['by_point'].geo(pnt, maxdist=300.)
+    >>> school.attrs['NAMELONG']
+    u'ADAMS ELEMENTARY'
+    >>> for school in schools.find['by_point'].geos(pnt, maxdist=1000.):
+    ...     print school.attrs['NAMELONG']
+    CARY HIGH
+    EAST CARY MIDDLE SITE
+    ADAMS ELEMENTARY
+    >>> schools.close()
+    >>> zipcodes.close()
     def __init__(self, c_mapinfo, table=None, writable=False):
         """Find geometry feature around a point.
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -26,39 +26,43 @@
 def read_WKT(string):
     """Read the string and return a geometry object
-    WKT:
-    POINT(0 0)
-    LINESTRING(0 0,1 1,1 2)
-    POLYGON((0 0,4 0,4 4,0 4,0 0),(1 1, 2 1, 2 2, 1 2,1 1))
-    MULTIPOINT(0 0,1 2)
-    MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5 4))
-    MULTIPOLYGON(((0 0,4 0,4 4,0 4,0 0),(1 1,2 1,2 2,1 2,1 1)),
-                 ((-1 -1,-1 -2,-2 -2,-2 -1,-1 -1)))
-    GEOMETRYCOLLECTION(POINT(2 3),LINESTRING(2 3,3 4))
+    **WKT**:
+        POINT(0 0)
+        LINESTRING(0 0,1 1,1 2)
+        POLYGON((0 0,4 0,4 4,0 4,0 0),(1 1, 2 1, 2 2, 1 2,1 1))
+        MULTIPOINT(0 0,1 2)
+        MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5 4))
+        MULTIPOLYGON(((0 0,4 0,4 4,0 4,0 0),(1 1,2 1,2 2,1 2,1 1)),
+                     ((-1 -1,-1 -2,-2 -2,-2 -1,-1 -1)))
+        GEOMETRYCOLLECTION(POINT(2 3),LINESTRING(2 3,3 4))
-    EWKT:
-    POINT(0 0 0) -- XYZ
-    SRID=32632;POINT(0 0) -- XY with SRID
-    POINTM(0 0 0) -- XYM
-    POINT(0 0 0 0) -- XYZM
-    SRID=4326;MULTIPOINTM(0 0 0,1 2 1) -- XYM with SRID
-    MULTILINESTRING((0 0 0,1 1 0,1 2 1),(2 3 1,3 2 1,5 4 1))
-    POLYGON((0 0 0,4 0 0,4 4 0,0 4 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0))
-    MULTIPOLYGON(((0 0 0,4 0 0,4 4 0,0 4 0,0 0 0),
-                  (1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),
-                 ((-1 -1 0,-1 -2 0,-2 -2 0,-2 -1 0,-1 -1 0)))
-    GEOMETRYCOLLECTIONM( POINTM(2 3 9), LINESTRINGM(2 3 4, 3 4 5) )
-    MULTICURVE( (0 0, 5 5), CIRCULARSTRING(4 0, 4 4, 8 4) )
-    POLYHEDRALSURFACE( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
-                       ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)),
-                       ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),
-                       ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
-                       ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),
-                       ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1)) )
-    TRIANGLE ((0 0, 0 9, 9 0, 0 0))
-    TIN( ((0 0 0, 0 0 1, 0 1 0, 0 0 0)), ((0 0 0, 0 1 0, 1 1 0, 0 0 0)) )
+    **EWKT**:
+        POINT(0 0 0) -- XYZ
+        SRID=32632;POINT(0 0) -- XY with SRID
+        POINTM(0 0 0) -- XYM
+        POINT(0 0 0 0) -- XYZM
+        SRID=4326;MULTIPOINTM(0 0 0,1 2 1) -- XYM with SRID
+        MULTILINESTRING((0 0 0,1 1 0,1 2 1),(2 3 1,3 2 1,5 4 1))
+        POLYGON((0 0 0,4 0 0,4 4 0,0 4 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0))
+        MULTIPOLYGON(((0 0 0,4 0 0,4 4 0,0 4 0,0 0 0),
+                      (1 1 0,2 1 0,2 2 0,1 2 0,1 1 0)),
+                     ((-1 -1 0,-1 -2 0,-2 -2 0,-2 -1 0,-1 -1 0)))
+        GEOMETRYCOLLECTIONM( POINTM(2 3 9), LINESTRINGM(2 3 4, 3 4 5) )
+        MULTICURVE( (0 0, 5 5), CIRCULARSTRING(4 0, 4 4, 8 4) )
+        POLYHEDRALSURFACE( ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
+                           ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)),
+                           ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),
+                           ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
+                           ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),
+                           ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1)) )
+        TRIANGLE ((0 0, 0 9, 9 0, 0 0))
+        TIN( ((0 0 0, 0 0 1, 0 1 0, 0 0 0)), ((0 0 0, 0 1 0, 1 1 0, 0 0 0)) )
     for regexp, obj in WKT.items():
         if re.match(regexp, string):
@@ -72,12 +76,12 @@
 def intersects(lineA, lineB, with_z=False):
-    """Return a list of points ::
+    """Return a list of points
-        >>> lineA = Line([(0, 0), (4, 0)])
-        >>> lineB = Line([(2, 2), (2, -2)])
-        >>> intersects(lineA, lineB)
-        Line([Point(2.000000, 0.000000)])
+    >>> lineA = Line([(0, 0), (4, 0)])
+    >>> lineB = Line([(2, 2), (2, -2)])
+    >>> intersects(lineA, lineB)
+    Line([Point(2.000000, 0.000000)])
     line = Line()
     if libvect.Vect_line_get_intersections(lineA.c_points, lineB.c_points,
@@ -92,21 +96,20 @@
 def get_xyz(pnt):
-    """Return a tuple with: x, y, z. ::
+    """Return a tuple with: x, y, z.
-        >>> pnt = Point(0, 0)
-        >>> get_xyz(pnt)
-        (0.0, 0.0, 0.0)
-        >>> get_xyz((1, 1))
-        (1, 1, 0.0)
-        >>> get_xyz((1, 1, 2))
-        (1, 1, 2)
-        >>> get_xyz((1, 1, 2, 2))                          #doctest: +ELLIPSIS
-        ValueError: The the format of the point is not supported: (1, 1, 2, 2)
+    >>> pnt = Point(0, 0)
+    >>> get_xyz(pnt)
+    (0.0, 0.0, 0.0)
+    >>> get_xyz((1, 1))
+    (1, 1, 0.0)
+    >>> get_xyz((1, 1, 2))
+    (1, 1, 2)
+    >>> get_xyz((1, 1, 2, 2))                          #doctest: +ELLIPSIS
+    ValueError: The the format of the point is not supported: (1, 1, 2, 2)
     if isinstance(pnt, Point):
         if pnt.is2D:
@@ -147,17 +150,16 @@
                    doc="Set and obtain cat value")
     def __getitem__(self, key):
-        """Return the value stored in the attribute table. ::
+        """Return the value stored in the attribute table.
-            >>> schools = VectorTopo('schools')
-            >>> school = schools[1]
-            >>> attrs = Attrs(school.cat, schools.table)
-            >>> attrs['TAG']
-            u'568'
+        >>> schools = VectorTopo('schools')
+        >>> school = schools[1]
+        >>> attrs = Attrs(school.cat, schools.table)
+        >>> attrs['TAG']
+        u'568'
         #SELECT {cols} FROM {tname} WHERE {condition};
         try:
@@ -171,20 +173,20 @@
             return results[0] if len(results) == 1 else results
     def __setitem__(self, key, value):
-        """Set value of a given column of a table attribute. ::
+        """Set value of a given column of a table attribute.
-            >>> from grass.pygrass.functions import copy, remove
-            >>> copy('schools', 'myschools', 'vect')
-            >>> schools = VectorTopo('myschools')
-            >>> attrs = Attrs(school.cat, schools.table, True)
-            >>> attrs['TAG'] = 'New Label'
-            >>> attrs['TAG']
-            u'New Label'
-            >>> attrs.table.conn.close()
+        >>> from grass.pygrass.functions import copy, remove
+        >>> copy('schools', 'myschools', 'vect')
+        >>> schools = VectorTopo('myschools')
+        >>> attrs = Attrs(school.cat, schools.table, True)
+        >>> attrs['TAG'] = 'New Label'
+        >>> attrs['TAG']
+        u'New Label'
+        >>> attrs.table.conn.close()
         if self.writable:
             #UPDATE {tname} SET {new_col} = {old_col} WHERE {condition}
@@ -194,8 +196,7 @@
                                                        condition=self.cond))
             #self.table.conn.commit()
         else:
-            str_err = "You can only read the attributes if the map is \
-in another mapset"
+            str_err = "You can only read the attributes if the map is in another mapset"
             raise GrassError(str_err)
     def __dict__(self):
@@ -1252,9 +1253,6 @@
     def perimeter(self):
         """Return the perimeter value of an Isle.
-            double Vect_area_perimeter()
         border = self.points()
         return libvect.Vect_area_perimeter(border.c_points)
@@ -1297,30 +1295,31 @@
         .. warning::
             Not implemented yet.
         pass
 class Area(Geo):
-     'Vect_build_line_area',
-     'Vect_find_area',
-     'Vect_get_area_box',
-     'Vect_get_area_points_geos',
-     'Vect_get_centroid_area',
+    Vect_build_line_area,
+    Vect_find_area,
+    Vect_get_area_box,
+    Vect_get_area_points_geos,
+    Vect_get_centroid_area,
-     'Vect_get_isle_area',
-     'Vect_get_line_areas',
-     'Vect_get_num_areas',
-     'Vect_get_point_in_area',
-     'Vect_isle_find_area',
-     'Vect_point_in_area',
-     'Vect_point_in_area_outer_ring',
+    Vect_get_isle_area,
+    Vect_get_line_areas,
+    Vect_get_num_areas,
+    Vect_get_point_in_area,
+    Vect_isle_find_area,
+    Vect_point_in_area,
+    Vect_point_in_area_outer_ring,
-     'Vect_read_area_geos',
-     'Vect_remove_small_areas',
-     'Vect_select_areas_by_box',
-     'Vect_select_areas_by_polygon']
+    Vect_read_area_geos,
+    Vect_remove_small_areas,
+    Vect_select_areas_by_box,
+    Vect_select_areas_by_polygon
     # geometry type
     gtype = libvect.GV_AREA
@@ -1389,8 +1388,7 @@
     def area(self):
         """Returns area of area without areas of isles.
-        double Vect_get_area_area (const struct Map_info *Map, int area)
+        double Vect_get_area_area (const struct Map_info \*Map, int area)
         return libvect.Vect_get_area_area(self.c_mapinfo, self.id)
@@ -1451,8 +1449,8 @@
     def boundaries(self, ilist=False):
         """Creates list of boundaries for given area.
-        int Vect_get_area_boundaries(const struct Map_info *Map,
-                                     int area, struct ilist *List)
+        int Vect_get_area_boundaries(const struct Map_info \*Map,
+                                     int area, struct ilist \*List)
         ilst = Ilist()
         libvect.Vect_get_area_boundaries(self.c_mapinfo, self.id,
@@ -1474,7 +1472,7 @@
     def get_first_cat(self):
         """Find FIRST category of given field and area.
-        int Vect_get_area_cat(const struct Map_info *Map, int area, int field)
+        int Vect_get_area_cat(const struct Map_info \*Map, int area, int field)
         pass
@@ -1494,7 +1492,7 @@
         """Calculate area perimeter.
-        double Vect_area_perimeter (const struct line_pnts *Points)
+        :return: double Vect_area_perimeter (const struct line_pnts \*Points)
         border = self.get_points()
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/pygrass/vector/table.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -4,8 +4,6 @@
 @author: pietro
 from __future__ import (nested_scopes, generators, division, absolute_import,
                         with_statement, print_function, unicode_literals)
@@ -38,7 +36,7 @@
 def get_path(path):
     """Return the full path to the database; replacing environment variable
-    with real values ::
+    with real values
     >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
     >>> new_path = get_path(path)
@@ -60,19 +58,18 @@
 class Filters(object):
-    """Help user to build a simple sql query. ::
+    """Help user to build a simple sql query.
-        >>> filter = Filters('table')
-        >>> filter.get_sql()
-        u'SELECT * FROM table;'
-        >>> filter.where("area<10000").get_sql()
-        u'SELECT * FROM table WHERE area<10000;'
-        >>> filter.select("cat", "area").get_sql()
-        u'SELECT cat, area FROM table WHERE area<10000;'
-        >>> filter.order_by("area").limit(10).get_sql()
-        u'SELECT cat, area FROM table WHERE area<10000 ORDER BY area LIMIT 10;'
+    >>> filter = Filters('table')
+    >>> filter.get_sql()
+    u'SELECT * FROM table;'
+    >>> filter.where("area<10000").get_sql()
+    u'SELECT * FROM table WHERE area<10000;'
+    >>> filter.select("cat", "area").get_sql()
+    u'SELECT cat, area FROM table WHERE area<10000;'
+    >>> filter.order_by("area").limit(10).get_sql()
+    u'SELECT cat, area FROM table WHERE area<10000 ORDER BY area LIMIT 10;'
     def __init__(self, tname):
         self.tname = tname
@@ -168,24 +165,23 @@
     It is possible to instantiate a Columns object given the table name and
     the database connection.
-    For a sqlite table: ::
+    For a sqlite table:
-        >>> import sqlite3
-        >>> path = '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
-        >>> cols_sqlite = Columns('census',
-        ...                       sqlite3.connect(get_path(path)))
-        >>> cols_sqlite.tname
-        u'census'
+    >>> import sqlite3
+    >>> path = '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
+    >>> cols_sqlite = Columns('census',
+    ...                       sqlite3.connect(get_path(path)))
+    >>> cols_sqlite.tname
+    u'census'
-    For a postgreSQL table: ::
+    For a postgreSQL table:
-        >>> import psycopg2 as pg                              #doctest: +SKIP
-        >>> cols_pg = Columns('boundary_municp_pg',
-        ...                   pg.connect('host=localhost dbname=grassdb')) #doctest: +SKIP
-        >>> cols_pg.tname #doctest: +SKIP
-        'boundary_municp_pg'                                   #doctest: +SKIP
+    >>> import psycopg2 as pg                              #doctest: +SKIP
+    >>> cols_pg = Columns('boundary_municp_pg',
+    ...                   pg.connect('host=localhost dbname=grassdb')) #doctest: +SKIP
+    >>> cols_pg.tname #doctest: +SKIP
+    'boundary_municp_pg'                                   #doctest: +SKIP
     def __init__(self, tname, connection, key='cat'):
         self.tname = tname
@@ -236,21 +232,20 @@
     __hash__ = object.__hash__
     def is_pg(self):
-        """Return True if is a psycopg connection. ::
+        """Return True if is a psycopg connection.
-            >>> cols_sqlite.is_pg()
-            False
-            >>> cols_pg.is_pg() #doctest: +SKIP
-            True
+        >>> cols_sqlite.is_pg()
+        False
+        >>> cols_pg.is_pg() #doctest: +SKIP
+        True
         return hasattr(self.conn, 'xid')
@@ -293,19 +288,19 @@
     def sql_descr(self, remove=None):
         """Return a string with description of columns.
-           Remove it is used to remove a columns.::
+        Remove it is used to remove a columns.
-            >>> cols_sqlite.sql_descr()                   # doctest: +ELLIPSIS
-            u'cat integer, OBJECTID integer, AREA double precision, ...'
-            >>> import psycopg2 as pg                         # doctest: +SKIP
-            ...                   pg.connect('host=localhost dbname=grassdb')) # doctest: +SKIP
-            >>> cols_pg.sql_descr()                 # doctest: +ELLIPSIS +SKIP
-            'cat int4, objectid int4, area float8, perimeter float8, ...'
+        >>> cols_sqlite.sql_descr()                   # doctest: +ELLIPSIS
+        u'cat integer, OBJECTID integer, AREA double precision, ...'
+        >>> import psycopg2 as pg                         # doctest: +SKIP
+        ...                   pg.connect('host=localhost dbname=grassdb')) # doctest: +SKIP
+        >>> cols_pg.sql_descr()                 # doctest: +ELLIPSIS +SKIP
+        'cat int4, objectid int4, area float8, perimeter float8, ...'
         if remove:
             return ', '.join(['%s %s' % (key, val) for key, val in self.items()
@@ -315,43 +310,39 @@
                               for key, val in self.items()])
     def types(self):
-        """Return a list with the column types. ::
+        """Return a list with the column types.
-            >>> cols_sqlite.types()                       # doctest: +ELLIPSIS
-            [u'integer', u'integer', ...]
-            >>> cols_pg.types()                     # doctest: +ELLIPSIS +SKIP
-            ['int4', 'int4', 'float8', 'float8', 'float8', ...]
+        >>> cols_sqlite.types()                       # doctest: +ELLIPSIS
+        [u'integer', u'integer', ...]
+        >>> cols_pg.types()                     # doctest: +ELLIPSIS +SKIP
+        ['int4', 'int4', 'float8', 'float8', 'float8', ...]
         return self.odict.values()
     def names(self, remove=None, unicod=True):
         """Return a list with the column names.
-            >>> cols_sqlite.names()                      # doctest: +ELLIPSIS
-            [u'cat', u'OBJECTID', u'AREA', u'PERIMETER', ...]
-            >>> cols_pg = Columns('boundary_municp_pg',       # doctest: +SKIP
-            >>> cols_pg.names()                     # doctest: +ELLIPSIS +SKIP
-            ['cat', 'objectid', 'area', 'perimeter', ...]
+        >>> cols_sqlite.names()                      # doctest: +ELLIPSIS
+        [u'cat', u'OBJECTID', u'AREA', u'PERIMETER', ...]
+        >>> cols_pg = Columns('boundary_municp_pg',       # doctest: +SKIP
+        >>> cols_pg.names()                     # doctest: +ELLIPSIS +SKIP
+        ['cat', 'objectid', 'area', 'perimeter', ...]
         if remove:
             nams = self.odict.keys()
@@ -364,21 +355,20 @@
             return [str(name) for name in nams]
     def items(self):
-        """Return a list of tuple with column name and column type.  ::
+        """Return a list of tuple with column name and column type.
-            >>> cols_sqlite.items()                       # doctest: +ELLIPSIS
-            [(u'cat', u'integer'), ...]
-            >>> cols_pg.items()                     # doctest: +ELLIPSIS +SKIP
-            [('cat', 'int4'), ('objectid', 'int4'), ('area', 'float8'), ...]
+        >>> cols_sqlite.items()                       # doctest: +ELLIPSIS
+        [(u'cat', u'integer'), ...]
+        >>> cols_pg.items()                     # doctest: +ELLIPSIS +SKIP
+        [('cat', 'int4'), ('objectid', 'int4'), ('area', 'float8'), ...]
         return self.odict.items()
@@ -389,26 +379,24 @@
         :type col_name: str
         :param col_type: the tipe of column to add
         :type col_type: str
-            >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
-            >>> copy('census','mycensus','vect')
-            >>> cols_sqlite = Columns('mycensus',
-            >>> cols_sqlite.add(['n_pizza'], ['INT'])
-            >>> 'n_pizza' in cols_sqlite
-            True
-            >>> cols_pg.add('n_pizza', 'INT')                 # doctest: +SKIP
-            >>> 'n_pizza' in cols_pg                          # doctest: +SKIP
-            True
-            >>> remove('mycensus', 'vect')
+        >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
+        >>> copy('census','mycensus','vect')
+        >>> cols_sqlite = Columns('mycensus',
+        >>> cols_sqlite.add(['n_pizza'], ['INT'])
+        >>> 'n_pizza' in cols_sqlite
+        True
+        >>> cols_pg.add('n_pizza', 'INT')                 # doctest: +SKIP
+        >>> 'n_pizza' in cols_pg                          # doctest: +SKIP
+        True
+        >>> remove('mycensus', 'vect')
         def check_col(col_type):
             """Check the column type if it is supported by GRASS
@@ -450,34 +438,32 @@
         :type old_name: str
         :param new_name: the name of new column
         :type new_name: str
-            True
-            >>> cols_sqlite.rename('n_pizza', 'n_pizzas')  # doctest: +ELLIPSIS
-            False
-            >>> 'n_pizzas' in cols_sqlite
-            True
+        True
+        >>> cols_sqlite.rename('n_pizza', 'n_pizzas')  # doctest: +ELLIPSIS
+        False
+        >>> 'n_pizzas' in cols_sqlite
+        True
-            >>> cols_pg.rename('n_pizza', 'n_pizzas')         # doctest: +SKIP
-            False
-            >>> 'n_pizzas' in cols_pg                         # doctest: +SKIP
-            True
+        >>> cols_pg.rename('n_pizza', 'n_pizzas')         # doctest: +SKIP
+        False
+        >>> 'n_pizzas' in cols_pg                         # doctest: +SKIP
+        True
         cur = self.conn.cursor()
         if self.is_pg():
@@ -506,31 +492,30 @@
         :type col_name: str
         :param new_type: the new type of column
         :type new_type: str
-            >>> cols_sqlite.add(['n_pizzas'], ['INT'])
-            >>> cols_sqlite.cast('n_pizzas', 'float8')  # doctest: +ELLIPSIS
-            DBError: SQLite does not support to cast columns.
-            >>> cols_pg.cast('n_pizzas', 'float8')            # doctest: +SKIP
-            >>> cols_pg['n_pizzas']                           # doctest: +SKIP
-            'float8'
+        >>> cols_sqlite.add(['n_pizzas'], ['INT'])
+        >>> cols_sqlite.cast('n_pizzas', 'float8')  # doctest: +ELLIPSIS
+        DBError: SQLite does not support to cast columns.
+        >>> cols_pg.cast('n_pizzas', 'float8')            # doctest: +SKIP
+        >>> cols_pg['n_pizzas']                           # doctest: +SKIP
+        'float8'
-            .. warning ::
+        .. warning ::
-               It is not possible to cast a column with sqlite
+           It is not possible to cast a column with sqlite
         if self.is_pg():
@@ -548,27 +533,25 @@
         :param col_name: the name of column to remove
         :type col_name: str
-            >>> cols_sqlite.drop('CHILD')                 # doctest: +ELLIPSIS
-            >>> 'CHILD' in cols_sqlite
-            False
+        >>> cols_sqlite.drop('CHILD')                 # doctest: +ELLIPSIS
+        >>> 'CHILD' in cols_sqlite
+        False
-            >>> cols_pg.drop('CHILD') # doctest: +SKIP
-            >>> 'CHILD' in cols_pg # doctest: +SKIP
-            False
-            >>> remove('mycensus','vect')
+        >>> cols_pg.drop('CHILD') # doctest: +SKIP
+        >>> 'CHILD' in cols_pg # doctest: +SKIP
+        False
+        >>> remove('mycensus','vect')
         if self.is_pg():
@@ -592,50 +575,48 @@
     """Define a Link between vector map and the attributes table.
     It is possible to define a Link object or given all the information
-    (layer, name, table name, key, database, driver): ::
+    (layer, name, table name, key, database, driver):
-        >>> link = Link(1, 'link0', 'census', 'cat',
-        ...             '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db', 'sqlite')
-        >>> link.layer
-        1
-        >>> link.name
-        'link0'
-        >>> link.table_name
-        'census'
-        >>> link.key
-        'cat'
-        >>> link.database
-        '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
-        >>> link.driver
-        'sqlite'
-        >>> link
-        Link(1, link0, sqlite)
+    >>> link = Link(1, 'link0', 'census', 'cat',
+    ...             '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db', 'sqlite')
+    >>> link.layer
+    1
+    >>> link.name
+    'link0'
+    >>> link.table_name
+    'census'
+    >>> link.key
+    'cat'
+    >>> link.database
+    '$GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db'
+    >>> link.driver
+    'sqlite'
+    >>> link
+    Link(1, link0, sqlite)
-    It is possible to change parameters with: ::
+    It is possible to change parameters with:
-        >>> link.driver = 'pg'                                # doctest: +SKIP
-        >>> link.driver                                       # doctest: +SKIP
-        'pg'
-        >>> link.driver = 'postgres'                # doctest: +ELLIPSIS +SKIP
-        TypeError: Driver not supported, use: sqlite, pg.
-        'pg'
-        >>> link.number = 0                         # doctest: +ELLIPSIS +SKIP
-        TypeError: Number must be positive and greater than 0.
+    >>> link.driver = 'pg'                                # doctest: +SKIP
+    >>> link.driver                                       # doctest: +SKIP
+    'pg'
+    >>> link.driver = 'postgres'                # doctest: +ELLIPSIS +SKIP
+    TypeError: Driver not supported, use: sqlite, pg.
+    'pg'
+    >>> link.number = 0                         # doctest: +ELLIPSIS +SKIP
+    TypeError: Number must be positive and greater than 0.
     Or given a c_fieldinfo object that is a ctypes pointer to the field_info C
     struct. ::
-        >>> link = Link(c_fieldinfo = ctypes.pointer(libvect.field_info()))
+    >>> link = Link(c_fieldinfo = ctypes.pointer(libvect.field_info()))
     def _get_layer(self):
         return self.c_fieldinfo.contents.number
@@ -742,22 +723,21 @@
     def connection(self):
-        """Return a connection object. ::
+        """Return a connection object.
-            ...             'sqlite')
-            >>> conn = link.connection()
-            >>> cur = conn.cursor()
-            >>> cur.execute("SELECT cat,TOTAL_POP,PERIMETER FROM %s" %
-            ...             link.table_name)              # doctest: +ELLIPSIS
-            <sqlite3.Cursor object at ...>
-            >>> cur.fetchone()
-            (1, 44, 757.669)
-            >>> cur.close()
-            >>> conn.close()
+        ...             'sqlite')
+        >>> conn = link.connection()
+        >>> cur = conn.cursor()
+        >>> cur.execute("SELECT cat,TOTAL_POP,PERIMETER FROM %s" %
+        ...             link.table_name)              # doctest: +ELLIPSIS
+        <sqlite3.Cursor object at ...>
+        >>> cur.fetchone()
+        (1, 44, 757.669)
+        >>> cur.close()
+        >>> conn.close()
         if self.driver == 'sqlite':
             import sqlite3
@@ -786,38 +766,36 @@
             raise TypeError(str_err)
     def table(self):
-        """Return a Table object. ::
+        """Return a Table object.
-            ...             'sqlite')
-            >>> table = link.table()
-            >>> table.filters.select('cat', 'TOTAL_POP', 'PERIMETER')
-            Filters(u'SELECT cat, TOTAL_POP, PERIMETER FROM census;')
-            >>> cur = table.execute()
-            (1, 44, 757.669)
-            >>> cur.close()
+        ...             'sqlite')
+        >>> table = link.table()
+        >>> table.filters.select('cat', 'TOTAL_POP', 'PERIMETER')
+        Filters(u'SELECT cat, TOTAL_POP, PERIMETER FROM census;')
+        >>> cur = table.execute()
+        (1, 44, 757.669)
+        >>> cur.close()
         return Table(self.table_name, self.connection(), self.key)
     def info(self):
-        """Print information of the link. ::
+        """Print information of the link.
-            ...             'sqlite')
-            >>> link.info()
-            layer:     1
-            name:      link0
-            table:     census
-            key:       cat
-            database:  $GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db
-            driver:    sqlite
+        ...             'sqlite')
+        >>> link.info()
+        layer:     1
+        name:      link0
+        table:     census
+        key:       cat
+        database:  $GISDBASE/$LOCATION_NAME/PERMANENT/sqlite/sqlite.db
+        driver:    sqlite
         print("layer:    ", self.layer)
         print("name:     ", self.name)
@@ -828,21 +806,20 @@
 class DBlinks(object):
-    """Interface containing link to the table DB. ::
+    """Interface containing link to the table DB.
-        >>> dblinks = DBlinks(cens.c_mapinfo)
-        >>> dblinks
-        DBlinks([Link(1, census, sqlite)])
-        >>> dblinks[0]
-        Link(1, census, sqlite)
-        >>> dblinks['census']
-        >>> cens.close()
+    >>> dblinks = DBlinks(cens.c_mapinfo)
+    >>> dblinks
+    DBlinks([Link(1, census, sqlite)])
+    >>> dblinks[0]
+    Link(1, census, sqlite)
+    >>> dblinks['census']
+    >>> cens.close()
     def __init__(self, c_mapinfo):
         self.c_mapinfo = c_mapinfo
@@ -965,22 +942,21 @@
 class Table(object):
-        >>> tab_sqlite = Table(name='census',
-        ...                    connection=sqlite3.connect(get_path(path)))
-        >>> tab_sqlite.name
-        u'census'
-        >>> import psycopg2                                   # doctest: +SKIP
-        >>> tab_pg = Table('boundary_municp_pg',
-        ...                psycopg2.connect('host=localhost dbname=grassdb',
-        ...                                 'pg'))            # doctest: +SKIP
-        >>> tab_pg.columns                          # doctest: +ELLIPSIS +SKIP
-        Columns([('cat', 'int4'), ...])
+    >>> tab_sqlite = Table(name='census',
+    ...                    connection=sqlite3.connect(get_path(path)))
+    >>> tab_sqlite.name
+    u'census'
+    >>> import psycopg2                                   # doctest: +SKIP
+    >>> tab_pg = Table('boundary_municp_pg',
+    ...                psycopg2.connect('host=localhost dbname=grassdb',
+    ...                                 'pg'))            # doctest: +SKIP
+    >>> tab_pg.columns                          # doctest: +ELLIPSIS +SKIP
+    Columns([('cat', 'int4'), ...])
     def _get_name(self):
         """Private method to return the name of table"""
@@ -1012,16 +988,15 @@
         self.filters = Filters(self.name)
     def __repr__(self):
-            >>> tab_sqlite
-            Table(u'census')
+        >>> tab_sqlite
+        Table(u'census')
         return "Table(%r)" % (self.name)
@@ -1111,9 +1086,9 @@
     def exist(self, cursor=None):
         """Return True if the table already exist in the DB, False otherwise
         :param cursor: the cursor to connect, if None it use the cursor
-                     of connection table object
-        :type cursor: Cursor object
+                       of connection table object
         cur = cursor if cursor else self.conn.cursor()
         return table_exist(cur, self.name)
@@ -1125,7 +1100,7 @@
                        more rows using a list of tuple and paramater `many`
         :type values: tuple
         :param many: True to run executemany function
         :type many: bool
Modified: grass/trunk/lib/python/script/db.py
--- grass/trunk/lib/python/script/db.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/script/db.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -1,7 +1,4 @@
-"""@package grass.script.db
- at brief GRASS Python scripting module (database functions)
 Database related functions to be used in Python scripts.
 Usage:
@@ -28,7 +25,7 @@
 def db_describe(table, **args):
     """Return the list of columns for a database table
-    (interface to `db.describe -c'). Example:
+    (interface to `db.describe -c`). Example:
     >>> run_command('g.copy', vect='firestations,myfirestations')
     0
@@ -94,7 +91,7 @@
 def db_connection():
     """Return the current database connection parameters
-    (interface to `db.connect -g'). Example:
+    (interface to `db.connect -g`). Example:
     >>> db_connection()
     {'group': '', 'schema': '', 'driver': 'sqlite', 'database': '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'}
Modified: grass/trunk/lib/python/script/raster.py
--- grass/trunk/lib/python/script/raster.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/script/raster.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -1,7 +1,4 @@
-"""@package grass.script.raster
- at brief GRASS Python scripting module (raster functions)
 Raster related functions to be used in Python scripts.
 Usage:
@@ -32,7 +29,7 @@
 def raster_history(map):
     """Set the command history for a raster map to the command used to
-    invoke the script (interface to `r.support').
+    invoke the script (interface to `r.support`).
     :param str map: map name
@@ -52,7 +49,7 @@
 def raster_info(map):
     """Return information about a raster map (interface to
-    `r.info -gre'). Example:
+    `r.info -gre`). Example:
     >>> raster_info('elevation') # doctest: +ELLIPSIS
     {'creator': '"helena"', 'cols': '1500' ... 'south': 215000.0}
Modified: grass/trunk/lib/python/script/task.py
--- grass/trunk/lib/python/script/task.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/script/task.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -30,17 +30,15 @@
 class grassTask:
-    """This class holds the structures needed for filling by the
-    parser
+    """This class holds the structures needed for filling by the parser
     Parameter blackList is a dictionary with fixed structure, eg.
-    blackList = {'items' : {'d.legend' : { 'flags' : ['m'], 'params' : [] }},
-                 'enabled': True}
+        blackList = {'items' : {'d.legend' : { 'flags' : ['m'], 'params' : [] }},
+                     'enabled': True}
     :param str path: full path
     :param blackList: hide some options in the GUI (dictionary)
Modified: grass/trunk/lib/python/script/utils.py
--- grass/trunk/lib/python/script/utils.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/script/utils.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -150,7 +150,7 @@
 def parse_key_val(s, sep='=', dflt=None, val_type=None, vsep=None):
     """Parse a string into a dictionary, where entries are separated
-    by newlines and the key and value are separated by `sep' (default: `=')
+    by newlines and the key and value are separated by `sep` (default: `=`)
     >>> parse_key_val('min=20\\nmax=50') == {'min': '20', 'max': '50'}
     True
Modified: grass/trunk/lib/python/script/vector.py
--- grass/trunk/lib/python/script/vector.py	2014-09-14 13:37:13 UTC (rev 61943)
+++ grass/trunk/lib/python/script/vector.py	2014-09-14 13:47:40 UTC (rev 61944)
@@ -28,7 +28,7 @@
 def vector_db(map, **args):
     """Return the database connection details for a vector map
-    (interface to `v.db.connect -g'). Example:
+    (interface to `v.db.connect -g`). Example:
     >>> vector_db('geology') # doctest: +ELLIPSIS, +NORMALIZE_WHITESPACE
     {1: {'layer': 1, ... 'table': 'geology'}}
@@ -87,8 +87,7 @@
 def vector_columns(map, layer=None, getDict=True, **args):
     """Return a dictionary (or a list) of the columns for the
-    database table connected to a vector map (interface to `v.info
-    -c').
+    database table connected to a vector map (interface to `v.info -c`).
     >>> vector_columns('geology', getDict=True) # doctest: +NORMALIZE_WHITESPACE
     {'PERIMETER': {'index': 2, 'type': 'DOUBLE PRECISION'}, 'GEOL250_':
@@ -136,7 +135,7 @@
 def vector_history(map):
     """Set the command history for a vector map to the command used to
-    invoke the script (interface to `v.support').
+    invoke the script (interface to `v.support`).
     :param str map: mapname
@@ -146,8 +145,8 @@
 def vector_info_topo(map):
-    """Return information about a vector map (interface to `v.info
-    -t'). Example:
+    """Return information about a vector map (interface to `v.info -t`).
+    Example:
     >>> vector_info_topo('geology') # doctest: +NORMALIZE_WHITESPACE
     {'lines': 0, 'centroids': 1832, 'boundaries': 3649, 'points': 0,
@@ -168,7 +167,7 @@
 def vector_info(map):
-    `v.info'). Example:
+    `v.info`). Example:
     >>> vector_info('geology') # doctest: +ELLIPSIS, +NORMALIZE_WHITESPACE
     {'comment': '', 'projection': 'Lambert Conformal Conic' ... 'south': 10875.8272320917}
