[GRASS-SVN] r61963 - grass/branches/releasebranch_7_0/scripts/v.rast.stats
Sun Sep 14 22:55:28 PDT 2014
Author: neteler
Date: 2014-09-14 22:55:28 -0700 (Sun, 14 Sep 2014)
New Revision: 61963
   grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.html
   grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py
v.rast.stats: manual updated by Stefan Blumentrath; msg cosmetics
Modified: grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.html
--- grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.html	2014-09-15 05:55:18 UTC (rev 61962)
+++ grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.html	2014-09-15 05:55:28 UTC (rev 61963)
@@ -5,15 +5,12 @@
 The vector map will be rasterized according to the raster map resolution.
 Then univariate statistics are calculated per vector category (cat) from
 the raster map and the results uploaded to the vector map attribute table.
-New columns are generated in the attribute table if not already present.
-<p>Nine columns are generated (n, min, max, range, mean, stddev, variance,
-coeff_var, sum) according to the output of <em>r.univar</em>.
-If the <b>-e</b> extended statistics flag is given the 1st quartile,
-median, 3rd quartile, and given percentile are also calculated.
+A new column is generated in the attribute table for each statistic requested
+in <b>method</b> (if not already present).
 <h2>NOTES</h2>
+<em>v.rast.stats</em> is only meaningful for lines or polygons.
+<p>
 The module may take a long time to run if the raster region contains a large
 number of cells. In this case the <b>--verbose</b> flag may be used to track
 progress.
@@ -29,12 +26,12 @@
 <p>If a MASK is present, it will be restored after the script finished.
 The script changes temporarily to the resolution of the given raster map.
 <p><!-- r.univar limitation -->
-Large amounts of system memory can be used when the <b>-e</b> extended
-statistics flag is used with a very large region setting. If the region
-is too large the module should display memory allocation errors.
-Basic statistics can be calculated using any size input region.
+Large amounts of system memory can be used when extended statistics
+(<em>first_quartile,median,third_quartile,percentile </em>) are being requested
+with a very large region setting. If the region is too large the module
+should display memory allocation errors. Basic statistics can be calculated
+using any size input region.
 <h2>EXAMPLES</h2>
 Example to upload DEM statistics to ZIP codes vector map
@@ -45,14 +42,15 @@
 # set computational region to DEM:
 g.region rast=elevation -p
 # calculate DEM statistics, upload to vector map table:
-v.rast.stats myzipcodes_wake raster=elevation colprefix=elev
+v.rast.stats myzipcodes_wake raster=elevation \
+  column_prefix=elev method=minimum,maximum,average,stddev,percentile \
+  percentile=95
 # verify results:
 v.info -c myzipcodes_wake
 v.db.select myzipcodes_wake
 v.univar myzipcodes_wake column=elev_range type=centroid
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py
--- grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py	2014-09-15 05:55:18 UTC (rev 61962)
+++ grass/branches/releasebranch_7_0/scripts/v.rast.stats/v.rast.stats.py	2014-09-15 05:55:28 UTC (rev 61963)
@@ -18,7 +18,7 @@
 #%module
-#% description: Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns.
+#% description: Calculates univariate statistics from a raster map based on a vector map and uploads statistics to new attribute columns.
 #% keywords: vector
 #% keywords: statistics
 #% keywords: raster
