[GRASS-SVN] r62000 - in grass/trunk/temporal: t.connect/testsuite t.rast.accdetect t.rast.accdetect/testsuite t.rast.accumulate t.rast.accumulate/testsuite t.rast.accumulate/testsuite/data t.rast.aggregate/testsuite t.rast.aggregate.ds/testsuite t.rast.extract/testsuite t.rast.to.rast3/testsuite t.rast3d.list t.remove t.vect.mapcalc/testsuite t.vect.observe.strds/testsuite
Tue Sep 16 09:47:30 PDT 2014
Author: huhabla
Date: 2014-09-16 09:47:30 -0700 (Tue, 16 Sep 2014)
New Revision: 62000
Added:
   grass/trunk/temporal/t.rast.accumulate/testsuite/
   grass/trunk/temporal/t.rast.accumulate/testsuite/data/
   grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_1.ref
   grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_2.ref
   grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_3.ref
   grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_4.ref
   grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_5.ref
Removed:
   grass/trunk/temporal/t.rast.accumulate/test_suite/
   grass/trunk/temporal/t.rast.accumulate/testsuite/acc_1.ref
   grass/trunk/temporal/t.rast.accumulate/testsuite/acc_2.ref
   grass/trunk/temporal/t.rast.accumulate/testsuite/acc_3.ref
   grass/trunk/temporal/t.rast.accumulate/testsuite/acc_4.ref
   grass/trunk/temporal/t.rast.accumulate/testsuite/acc_5.ref
   grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
   grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
   grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
   grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
   grass/trunk/temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.reverse.sh
   grass/trunk/temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.sh
   grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
   grass/trunk/temporal/t.rast.accumulate/testsuite/test.t.rast.accumulate.sh
   grass/trunk/temporal/t.rast.aggregate.ds/testsuite/test.t.rast.aggregate.ds.sh
   grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.sh
   grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
   grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
   grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
   grass/trunk/temporal/t.remove/t.remove.py
   grass/trunk/temporal/t.vect.mapcalc/testsuite/test.t.vect.mapcalc.sh
   grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh
   grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh
   grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh
temporal modules: Improved tests, using g.mremove instead of g.remove to avoid buffer overflows when g.remove is called from within the gtestsuite framework.
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -45,7 +45,9 @@
         entries = list_string.split("\n")
-        t_list = SimpleModule("t.list", quiet=True, columns=["name","mapset,start_time","end_time","number_of_maps"],  type="strds")
+        t_list = SimpleModule("t.list", quiet=True,
+                                            columns=["name","mapset,start_time","end_time","number_of_maps"],
+                                            type="strds",  where='name = "A"')
         self.assertModule(t_list)
         out = t_list.outputs["stdout"].value
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -42,7 +42,9 @@
-        t_list = SimpleModule("t.list", quiet=True, columns=["name","mapset,start_time","end_time","number_of_maps"],  type="str3ds")
+                                            type="str3ds",  where='name = "A"')
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -44,7 +44,9 @@
-        t_list = SimpleModule("t.list", quiet=True, columns=["name","mapset,start_time","end_time","number_of_maps"],  type="stvds")
+                                           type="stvds",  where='name = "A"')
Modified: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
--- grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -418,7 +418,7 @@
     # Remove empty maps
     if len(empty_maps) > 0:
         for map in empty_maps:
-            grass.run_command("g.remove", rast=map.get_name(), quiet=True)
+            grass.run_command("g.mremove", type="rast",  pattern=map.get_name(), quiet=True)
Modified: grass/trunk/temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.reverse.sh
--- grass/trunk/temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.reverse.sh	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.reverse.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -31,7 +31,7 @@
 t.rast.list temp_occ col=name,start_time,min,max  > data/test_2_temp_occ.txt
 t.rast.list temp_indi col=name,start_time,min,max > data/test_2_temp_indi.txt
-t.remove -rf type=strds input=temp_abs1,temp_accumulation,temp_indi
+#t.remove -rf type=strds input=temp_abs1,temp_accumulation,temp_indi
 cd data
Modified: grass/trunk/temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.sh
--- grass/trunk/temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.sh	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast.accdetect/testsuite/test.t.rast.accdetect.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -51,7 +51,7 @@
 t.rast.list temp_occ col=name,start_time,min,max          > data/test_1_temp_occ_b.txt
 t.rast.list temp_indi col=name,start_time,min,max         > data/test_1_temp_indi.txt
-t.remove -rf type=strds input=temp_abs1,temp_accumulation,temp_indi,minimum,maximum
+#t.remove -rf type=strds input=temp_abs1,temp_accumulation,temp_indi,minimum,maximum
 cd data
Modified: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
--- grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -500,7 +500,7 @@
     # Remove empty maps
 if __name__ == "__main__":
     options, flags = grass.parser()
Deleted: grass/trunk/temporal/t.rast.accumulate/testsuite/acc_1.ref
--- grass/trunk/temporal/t.rast.accumulate/test_suite/acc_1.ref	2014-09-16 08:05:08 UTC (rev 61990)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/acc_1.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -1,39 +0,0 @@
- +-------------------- Space Time Raster Dataset -----------------------------+
- +-------------------- Basic information -------------------------------------+
- | Name: ...................... precip_abs2
- | Creator: ................... soeren
- | Temporal type: ............. absolute
- | Semantic type:.............. mean
- +-------------------- Absolute time -----------------------------------------+
- | Start time:................. 2001-01-01 00:00:00
- | End time:................... 2002-01-01 00:00:00
- | Granularity:................ 4 months
- | Temporal type of maps:...... interval
- +-------------------- Spatial extent ----------------------------------------+
- | North:...................... 80.0
- | South:...................... 0.0
- | East:.. .................... 120.0
- | West:....................... 0.0
- | Top:........................ 0.0
- | Bottom:..................... 0.0
- +-------------------- Metadata information ----------------------------------+
- | North-South resolution min:. 10.0
- | North-South resolution max:. 10.0
- | East-west resolution min:... 10.0
- | East-west resolution max:... 10.0
- | Minimum value min:.......... 0.0
- | Minimum value max:.......... 0.0
- | Maximum value min:.......... 21.5
- | Maximum value max:.......... 60.0
- | Title:
- | A test
- | Description:
- | A test
- | Command history:
- | t.rast.accumulate input="precip_abs1"
- |     output="precip_abs2" base="prec_acc" limits="10,30" start="2001-01-01"
- |     gran="4 months" cycle="12 months"
Deleted: grass/trunk/temporal/t.rast.accumulate/testsuite/acc_2.ref
--- grass/trunk/temporal/t.rast.accumulate/test_suite/acc_2.ref	2014-09-16 08:05:08 UTC (rev 61990)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/acc_2.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -1,39 +0,0 @@
- | End time:................... 2001-09-01 00:00:00
- | Maximum value max:.......... 39.5
- | Title:
- | A test
- | Description:
- | A test
- |     stop="2002-01-01" gran="4 months" cycle="7 months"
Deleted: grass/trunk/temporal/t.rast.accumulate/testsuite/acc_3.ref
--- grass/trunk/temporal/t.rast.accumulate/test_suite/acc_3.ref	2014-09-16 08:05:08 UTC (rev 61990)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/acc_3.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -1,39 +0,0 @@
- | Granularity:................ 2 months
- | Maximum value min:.......... 24.0
- | Maximum value max:.......... 120.0
- | Title:
- | A test
- | Description:
- | A test
- |     gran="2 months" cycle="12 months"
Deleted: grass/trunk/temporal/t.rast.accumulate/testsuite/acc_4.ref
--- grass/trunk/temporal/t.rast.accumulate/test_suite/acc_4.ref	2014-09-16 08:05:08 UTC (rev 61990)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/acc_4.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -1,39 +0,0 @@
- | Granularity:................ 1 month
- | Maximum value max:.......... 240.0
- | Title:
- | A test
- | Description:
- | A test
- |     stop="2002-01-01" gran="1 months" cycle="12 months"
Deleted: grass/trunk/temporal/t.rast.accumulate/testsuite/acc_5.ref
--- grass/trunk/temporal/t.rast.accumulate/test_suite/acc_5.ref	2014-09-16 08:05:08 UTC (rev 61990)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/acc_5.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -1,40 +0,0 @@
- | Title:
- | A test
- | Description:
- | A test
- |     output="precip_abs2" base="prec_acc" limits="8,33" lower="lower"
- |     upper="upper" start="2001-01-01" stop="2002-01-01" gran="1 months"
- |     cycle="12 months"
Copied: grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_1.ref (from rev 61990, grass/trunk/temporal/t.rast.accumulate/test_suite/acc_1.ref)
--- grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_1.ref	                        (rev 0)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_1.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -0,0 +1,39 @@
+ +-------------------- Space Time Raster Dataset -----------------------------+
+ +-------------------- Basic information -------------------------------------+
+ | Name: ...................... precip_abs2
+ | Creator: ................... soeren
+ | Temporal type: ............. absolute
+ | Semantic type:.............. mean
+ +-------------------- Absolute time -----------------------------------------+
+ | Start time:................. 2001-01-01 00:00:00
+ | End time:................... 2002-01-01 00:00:00
+ | Granularity:................ 4 months
+ | Temporal type of maps:...... interval
+ +-------------------- Spatial extent ----------------------------------------+
+ | North:...................... 80.0
+ | South:...................... 0.0
+ | East:.. .................... 120.0
+ | West:....................... 0.0
+ | Top:........................ 0.0
+ | Bottom:..................... 0.0
+ +-------------------- Metadata information ----------------------------------+
+ | North-South resolution min:. 10.0
+ | North-South resolution max:. 10.0
+ | East-west resolution min:... 10.0
+ | East-west resolution max:... 10.0
+ | Minimum value min:.......... 0.0
+ | Minimum value max:.......... 0.0
+ | Maximum value min:.......... 21.5
+ | Maximum value max:.......... 60.0
+ | Title:
+ | A test
+ | Description:
+ | A test
+ | Command history:
+ | t.rast.accumulate input="precip_abs1"
+ |     output="precip_abs2" base="prec_acc" limits="10,30" start="2001-01-01"
+ |     gran="4 months" cycle="12 months"
Copied: grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_2.ref (from rev 61990, grass/trunk/temporal/t.rast.accumulate/test_suite/acc_2.ref)
--- grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_2.ref	                        (rev 0)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_2.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -0,0 +1,39 @@
+ | End time:................... 2001-09-01 00:00:00
+ | Maximum value max:.......... 39.5
+ | Title:
+ | A test
+ | Description:
+ | A test
+ |     stop="2002-01-01" gran="4 months" cycle="7 months"
Copied: grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_3.ref (from rev 61990, grass/trunk/temporal/t.rast.accumulate/test_suite/acc_3.ref)
--- grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_3.ref	                        (rev 0)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_3.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -0,0 +1,39 @@
+ | Granularity:................ 2 months
+ | Maximum value min:.......... 24.0
+ | Maximum value max:.......... 120.0
+ | Title:
+ | A test
+ | Description:
+ | A test
+ |     gran="2 months" cycle="12 months"
Copied: grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_4.ref (from rev 61990, grass/trunk/temporal/t.rast.accumulate/test_suite/acc_4.ref)
--- grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_4.ref	                        (rev 0)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_4.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -0,0 +1,39 @@
+ | Granularity:................ 1 month
+ | Maximum value max:.......... 240.0
+ | Title:
+ | A test
+ | Description:
+ | A test
+ |     stop="2002-01-01" gran="1 months" cycle="12 months"
Copied: grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_5.ref (from rev 61990, grass/trunk/temporal/t.rast.accumulate/test_suite/acc_5.ref)
--- grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_5.ref	                        (rev 0)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/data/acc_5.ref	2014-09-16 16:47:30 UTC (rev 62000)
@@ -0,0 +1,40 @@
+ | Title:
+ | A test
+ | Description:
+ | A test
+ |     output="precip_abs2" base="prec_acc" limits="8,33" lower="lower"
+ |     upper="upper" start="2001-01-01" stop="2002-01-01" gran="1 months"
+ |     cycle="12 months"
Modified: grass/trunk/temporal/t.rast.accumulate/testsuite/test.t.rast.accumulate.sh
--- grass/trunk/temporal/t.rast.accumulate/test_suite/test.t.rast.accumulate.sh	2014-09-16 08:05:08 UTC (rev 61990)
+++ grass/trunk/temporal/t.rast.accumulate/testsuite/test.t.rast.accumulate.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -27,25 +27,25 @@
 # We need to filter the identifier that may be different on different systems
 # like creation time and mapset
-t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > acc_1.txt
+t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > data/acc_1.txt
 t.rast.accumulate input=precip_abs1 output=precip_abs2 base=prec_acc \
     limits=10,30 start="2001-01-01" stop="2002-01-01" gran="4 months" \
     cycle="7 months"
-t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > acc_2.txt
+t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > data/acc_2.txt
     limits=10,30 start="2001-01-01" gran="2 months" \
     cycle="12 months"
-t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > acc_3.txt
+t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > data/acc_3.txt
     limits=10,30 start="2001-01-01" stop="2002-01-01" gran="1 months" \
     cycle="12 months"
-t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > acc_4.txt
+t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > data/acc_4.txt
 # Second test
@@ -62,10 +62,12 @@
     limits=8,33 lower=lower upper=upper start="2001-01-01" stop="2002-01-01" gran="1 months" \
     cycle="12 months"
-t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > acc_5.txt
+t.info input=precip_abs2 | grep -v \# | grep -v Creation | grep -v register | grep -v Id | grep -v Mapset > data/acc_5.txt
 t.remove -rf type=strds input=precip_abs1,precip_abs2,lower,upper
+cd data
 for i in `ls acc_*.txt` ; do
     diff $i "`basename $i .txt`.ref" >> out.diff
 done
Modified: grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.sh
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.sh	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test.t.rast.aggregate.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -48,5 +48,4 @@
 t.info type=strds input=precip_abs4
 t.rast.list input=precip_abs4
-#t.remove -rf type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
-t.remove -rf type=strds input=precip_abs1,precip_abs2
+t.remove -rf type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
Modified: grass/trunk/temporal/t.rast.aggregate.ds/testsuite/test.t.rast.aggregate.ds.sh
--- grass/trunk/temporal/t.rast.aggregate.ds/testsuite/test.t.rast.aggregate.ds.sh	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast.aggregate.ds/testsuite/test.t.rast.aggregate.ds.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -48,5 +48,5 @@
 t.rast.list input=precip_abs2 method=deltagap
 # @postprocess
-t.remove -rf type=stvds input=soil_abs1
+#t.remove -rf type=stvds input=soil_abs1
+#t.remove -rf type=strds input=precip_abs1,precip_abs2
Modified: grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -33,18 +33,18 @@
         """Create input data for transient groundwater flow computation
         # Use always the current mapset as temporal database
-        self.runModule("r.mapcalc", expression="prec_1 = 100")
-        self.runModule("r.mapcalc", expression="prec_2 = 200")
-        self.runModule("r.mapcalc", expression="prec_3 = 300")
-        self.runModule("r.mapcalc", expression="prec_4 = 400")
-        self.runModule("r.mapcalc", expression="prec_5 = 500")
-        self.runModule("r.mapcalc", expression="prec_6 = 600")
+        self.runModule("r.mapcalc", expression="prec_1 = 100",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_2 = 200",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_3 = 300",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_4 = 400",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_5 = 500",  overwrite=True)
+        self.runModule("r.mapcalc", expression="prec_6 = 600",  overwrite=True)
         self.runModule("t.create",  type="strds",  temporaltype="absolute",
-                                     output="precip_abs1",  title="A test",  description="A test")
+                                     output="precip_abs1",  title="A test",  description="A test",  overwrite=True)
         self.runModule("t.register",  flags="i",  type="rast",  input="precip_abs1",
                                      maps="prec_1,prec_2,prec_3,prec_4,prec_5,prec_6",
-                                     start="2001-01-01", increment="3 months")
+                                     start="2001-01-01", increment="3 months",  overwrite=True)
     def tearDown(self):
         """Remove generated data"""
@@ -87,7 +87,7 @@
         self.assertModule("t.rast.extract",  input="precip_abs1",  output="precip_abs2",
                                       where="start_time > '2001-06-01'",
                                       expression=" if(precip_abs1 > 400, precip_abs1, null())",
-                                      basename="new_prec",  nprocs=2)
+                                      basename="new_prec",  nprocs=2,  overwrite=True)
         #self.assertModule("t.info",  flags="g",  input="precip_abs2")
@@ -119,7 +119,7 @@
         """Perform r.mapcalc expression and register empty maps"""
         self.assertModule("t.rast.extract",  flags="n",  input="precip_abs1",  output="precip_abs2",
Modified: grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -79,76 +79,76 @@
         self.assertModule("t.rast.to.rast3",  input="precip_d",  output="precip_d")
         univar_string="""n=576
-						null_cells=0
-						cells=576
-						min=100
-						max=600
-						range=500
-						mean=350
-						mean_of_abs=350
-						stddev=170.782512765993
-						variance=29166.6666666667
-						coeff_var=48.7950036474267
-						sum=201600"""
+                        null_cells=0
+                        cells=576
+                        min=100
+                        max=600
+                        range=500
+                        mean=350
+                        mean_of_abs=350
+                        stddev=170.782512765993
+                        variance=29166.6666666667
+                        coeff_var=48.7950036474267
+                        sum=201600"""
         self.assertRaster3dFitsUnivar(raster="precip_i", reference=univar_string, precision=2)
         self.assertRaster3dFitsUnivar(raster="precip_f", reference=univar_string, precision=2)
         self.assertRaster3dFitsUnivar(raster="precip_d", reference=univar_string, precision=2)
         tinfo_string="""north=80
-						south=0
-						east=120
-						west=0
-						bottom=1213
-						top=1231
-						nsres=10
-						ewres=10
-						tbres=3
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						timestamp="1 Jan 2001 00:00:00 / 1 Jul 2002 00:00:00"
-						units="none"
-						vertical_units="months" """
+                        south=0
+                        east=120
+                        west=0
+                        bottom=1213
+                        top=1231
+                        nsres=10
+                        ewres=10
+                        tbres=3
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        timestamp="1 Jan 2001 00:00:00 / 1 Jul 2002 00:00:00"
+                        units="none"
+                        vertical_units="months" """
         self.assertRaster3dFitsInfo(raster="precip_i", reference=tinfo_string, precision=2)
-						south=0
-						east=120
-						west=0
-						bottom=1213
-						top=1231
-						nsres=10
-						ewres=10
-						tbres=3
-						rows=8
-						cols=12
-						depths=6
-						datatype="FCELL"
-						units="none"
+                        south=0
+                        east=120
+                        west=0
+                        bottom=1213
+                        top=1231
+                        nsres=10
+                        ewres=10
+                        tbres=3
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="FCELL"
+                        units="none"
         self.assertRaster3dFitsInfo(raster="precip_f", reference=tinfo_string, precision=2)
-						south=0
-						east=120
-						west=0
-						bottom=1213
-						top=1231
-						nsres=10
-						ewres=10
-						tbres=3
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						units="none"
+                        south=0
+                        east=120
+                        west=0
+                        bottom=1213
+                        top=1231
+                        nsres=10
+                        ewres=10
+                        tbres=3
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        units="none"
         self.assertRaster3dFitsInfo(raster="precip_d", reference=tinfo_string, precision=2)
@@ -162,75 +162,75 @@
         univar_string="""n=480
-						null_cells=96
-						cells=576
-						min=100
-						max=600
-						range=500
-						mean=360
-						mean_of_abs=360
-						stddev=185.472369909914
-						variance=34400
-						coeff_var=51.5201027527539
-						sum=172800"""
+                        null_cells=96
+                        cells=576
+                        min=100
+                        max=600
+                        range=500
+                        mean=360
+                        mean_of_abs=360
+                        stddev=185.472369909914
+                        variance=34400
+                        coeff_var=51.5201027527539
+                        sum=172800"""
         univar = SimpleModule("r3.univar", flags="g", map="precip_i")
         self.assertModuleKeyValue(module=univar, reference=univar_string, precision=2, sep="=")
-						south=0
-						east=120
-						west=0
-						bottom=1213
-						top=1231
-						nsres=10
-						ewres=10
-						tbres=3
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						units="none"
+                        south=0
+                        east=120
+                        west=0
+                        bottom=1213
+                        top=1231
+                        nsres=10
+                        ewres=10
+                        tbres=3
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        units="none"
-						south=0
-						east=120
-						west=0
-						bottom=1213
-						top=1231
-						nsres=10
-						ewres=10
-						tbres=3
-						rows=8
-						cols=12
-						depths=6
-						datatype="FCELL"
-						units="none"
+                        south=0
+                        east=120
+                        west=0
+                        bottom=1213
+                        top=1231
+                        nsres=10
+                        ewres=10
+                        tbres=3
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="FCELL"
+                        units="none"
-						south=0
-						east=120
-						west=0
-						bottom=1213
-						top=1231
-						nsres=10
-						ewres=10
-						tbres=3
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						units="none"
+                        south=0
+                        east=120
+                        west=0
+                        bottom=1213
+                        top=1231
+                        nsres=10
+                        ewres=10
+                        tbres=3
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        units="none"
@@ -270,21 +270,21 @@
-						south=0
-						east=120
-						west=0
-						bottom=100
-						top=130
-						nsres=10
-						ewres=10
-						tbres=3
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						timestamp="1 Jan 2000 00:00:00 / 1 Jan 2030 00:00:00"
-						units="none"
-						vertical_units="years" """
+                        south=0
+                        east=120
+                        west=0
+                        bottom=100
+                        top=130
+                        nsres=10
+                        ewres=10
+                        tbres=3
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        timestamp="1 Jan 2000 00:00:00 / 1 Jan 2030 00:00:00"
+                        units="none"
+                        vertical_units="years" """
@@ -298,21 +298,21 @@
-						south=0
-						east=120
-						west=0
-						bottom=1201
-						top=1237
-						nsres=10
-						ewres=10
-						tbres=6
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						timestamp="1 Jan 2000 00:00:00 / 1 Jan 2003 00:00:00"
-						units="none"
+                        south=0
+                        east=120
+                        west=0
+                        bottom=1201
+                        top=1237
+                        nsres=10
+                        ewres=10
+                        tbres=6
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        timestamp="1 Jan 2000 00:00:00 / 1 Jan 2003 00:00:00"
+                        units="none"
@@ -327,21 +327,21 @@
         self.runModule("r3.info", map="precip_d")
-						south=0
-						east=120
-						west=0
-						bottom=36524
-						top=36566
-						nsres=10
-						ewres=10
-						tbres=7
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						timestamp="1 Jan 2000 00:00:00 / 12 Feb 2000 00:00:00"
-						units="none"
-						vertical_units="days" """
+                        south=0
+                        east=120
+                        west=0
+                        bottom=36524
+                        top=36566
+                        nsres=10
+                        ewres=10
+                        tbres=7
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        timestamp="1 Jan 2000 00:00:00 / 12 Feb 2000 00:00:00"
+                        units="none"
+                        vertical_units="days" """
@@ -356,21 +356,21 @@
-						south=0
-						east=120
-						west=0
-						bottom=36524
-						top=36524.8
-						nsres=10
-						ewres=10
-						tbres=0.125
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						timestamp="1 Jan 2000 00:00:00 / 1 Jan 2000 18:00:00"
-						units="none"
-						vertical_units="hours" """
+                        south=0
+                        east=120
+                        west=0
+                        bottom=36524
+                        top=36524.8
+                        nsres=10
+                        ewres=10
+                        tbres=0.125
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        timestamp="1 Jan 2000 00:00:00 / 1 Jan 2000 18:00:00"
+                        units="none"
+                        vertical_units="hours" """
@@ -385,21 +385,21 @@
-						south=0
-						east=120
-						west=0
-						bottom=36524
-						top=36524.1
-						nsres=10
-						ewres=10
-						tbres=0.0118056
-						rows=8
-						cols=12
-						depths=6
-						datatype="DCELL"
-						timestamp="1 Jan 2000 00:00:00 / 1 Jan 2000 01:42:00"
-						units="none"
-						vertical_units="minutes" """
+                        south=0
+                        east=120
+                        west=0
+                        bottom=36524
+                        top=36524.1
+                        nsres=10
+                        ewres=10
+                        tbres=0.0118056
+                        rows=8
+                        cols=12
+                        depths=6
+                        datatype="DCELL"
+                        timestamp="1 Jan 2000 00:00:00 / 1 Jan 2000 01:42:00"
+                        units="none"
+                        vertical_units="minutes" """
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -2,15 +2,15 @@
 # -*- coding: utf-8 -*-
-# MODULE:	t.rast3d.list
-# AUTHOR(S):	Soeren Gebbert
+# MODULE:   t.rast3d.list
+# AUTHOR(S):    Soeren Gebbert
-# PURPOSE:	List registered maps of a space time raster3d dataset
-# COPYRIGHT:	(C) 2011-2014, Soeren Gebbert and the GRASS Development Team
+# PURPOSE:  List registered maps of a space time raster3d dataset
+# COPYRIGHT:    (C) 2011-2014, Soeren Gebbert and the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (version 2). Read the file COPYING that comes with GRASS
-#		for details.
+#       This program is free software under the GNU General Public
+#       License (version 2). Read the file COPYING that comes with GRASS
+#       for details.
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.remove/t.remove.py	2014-09-16 16:47:30 UTC (rev 62000)
@@ -2,15 +2,15 @@
-# MODULE:	t.remove
+# MODULE:   t.remove
-# PURPOSE:	Remove space time datasets from the temporal database
-# COPYRIGHT:	(C) 2011 by the GRASS Development Team
+# PURPOSE:  Remove space time datasets from the temporal database
+# COPYRIGHT:    (C) 2011 by the GRASS Development Team
-#		for details.
+#       for details.
@@ -106,8 +106,8 @@
     statement = ""
-    # Create the pygrass Module object for g.remove
-    remove = pyg.Module("g.remove", quiet=True, run_=False)
+    # Create the pygrass Module object for g.mremove
+    remove = pyg.Module("g.mremove", quiet=True, run_=False)
     for name in dataset_list:
         name = name.strip()
@@ -132,7 +132,7 @@
                 # Delete every 100 maps
                 if count%100 == 0:
                     dbif.execute_transaction(map_statement)
-                    remove(rast=name_list, run_=True)
+                    remove(type="rast",  pattern=name_list, run_=True)
                     map_statement = ""
                     name_list = []
@@ -140,11 +140,11 @@
             if name_list:
                 if type == "strds":
-                    remove(rast=",".join(name_list), run_=True)
+                    remove(type="rast",  pattern=",".join(name_list), run_=True)
                 if type == "stvds":
-                    remove(vect=",".join(name_list), run_=True)
+                    remove(type="vect",  pattern=",".join(name_list), run_=True)
                 if type == "str3ds":
-                    remove(rast3d=",".join(name_list), run_=True)
+                    remove(type="rast3d",  pattern=",".join(name_list), run_=True)
         statement += sp.delete(dbif=dbif, execute=False)
Modified: grass/trunk/temporal/t.vect.mapcalc/testsuite/test.t.vect.mapcalc.sh
--- grass/trunk/temporal/t.vect.mapcalc/testsuite/test.t.vect.mapcalc.sh	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.vect.mapcalc/testsuite/test.t.vect.mapcalc.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -5,33 +5,52 @@
 export GRASS_OVERWRITE=1
 # Test for temporal algebra in LatLon location.
-rm /tmp/vinput1_point_test.txt
-rm /tmp/vinput2_point_test.txt
-rm /tmp/vinput3_point_test.txt
-rm /tmp/vinput4_point_test.txt
-rm /tmp/vinput1_area_test.txt
-rm /tmp/vinput2_area_test.txt
-rm /tmp/vinput3_area_test.txt
-rm /tmp/vinput4_area_test.txt
+if test -f vinput1_point_test ; then
+    rm vinput1_point_test.txt
+fi
+    rm vinput2_point_test.txt
+fi
+    rm vinput3_point_test.txt
+fi
+    rm vinput4_point_test.txt
+fi
+    rm vinput1_area_test.txt
+fi
+    rm vinput2_area_test.txt
+fi
+    rm vinput3_area_test.txt
+fi
+    rm vinput4_area_test.txt
+fi
+LIST="1 2 3 4 5 6 7 8 9 0 10 11 12 13 14 15 16 17 18 19 20"
 # Create random area test maps.
-for i in {1..60}
+for i in ${LIST}
   do
-    if [[ "$i" -le 20 ]]; then
-      echo vtestpoint1_$i >> /tmp/vinput1_point_test.txt
-      echo vtestarea1_$i  >> /tmp/vinput1_area_test.txt
+    if test "$i" -le 10 ; then
+      echo vtestpoint1_$i >> vinput1_point_test.txt
+      echo vtestarea1_$i  >> vinput1_area_test.txt
       v.random --o -z output=vtestpoint1_$i n=3 seed=$i+1
       v.voronoi --o input=vtestpoint1_$i output=vtestarea1_$i
-    elif [ "$i" -gt 20 ] && [ "$i" -le 40 ]; then
-      echo vtestpoint2_$i >> /tmp/vinput2_point_test.txt
-      echo vtestarea2_$i  >> /tmp/vinput2_area_test.txt
+    elif test "$i" -gt 10  && test "$i" -le 15 ; then
+      echo vtestpoint2_$i >> vinput2_point_test.txt
+      echo vtestarea2_$i  >> vinput2_area_test.txt
       v.random --o -z output=vtestpoint2_$i n=3 seed=$i+1
       v.voronoi --o input=vtestpoint2_$i output=vtestarea2_$i
     else
-      echo vtestpoint3_$i >> /tmp/vinput3_point_test.txt
-      echo vtestpoint4_$i >> /tmp/vinput4_point_test.txt
-      echo vtestarea3_$i  >> /tmp/vinput3_area_test.txt
-      echo vtestarea4_$i  >> /tmp/vinput4_area_test.txt
+      echo vtestpoint3_$i >> vinput3_point_test.txt
+      echo vtestpoint4_$i >> vinput4_point_test.txt
+      echo vtestarea3_$i  >> vinput3_area_test.txt
+      echo vtestarea4_$i  >> vinput4_area_test.txt
       v.random --o -z output=vtestpoint3_$i n=3 seed=$i+1
       v.voronoi --o input=vtestpoint3_$i output=vtestarea3_$i
       v.random --o -z output=vtestpoint4_$i n=3 seed=$i+1
@@ -49,14 +68,14 @@
 t.create output=P3 type=stvds title="Point test dataset" descr="Point test dataset"
 t.create output=P4 type=stvds title="Point test dataset" descr="Point test dataset"
-t.register -i type=vect input=A1 file=/tmp/vinput1_area_test.txt increment="1 days" start="2013-01-01"
-t.register -i type=vect input=A2 file=/tmp/vinput2_area_test.txt increment="1 days" start="2013-01-10"
-t.register -i type=vect input=A3 file=/tmp/vinput3_area_test.txt increment="3 days" start="2013-01-01"
-t.register -i type=vect input=A4 file=/tmp/vinput4_area_test.txt increment="3 days" start="2013-01-10"
-t.register -i type=vect input=P1 file=/tmp/vinput1_point_test.txt increment="1 days" start="2013-01-01"
-t.register -i type=vect input=P2 file=/tmp/vinput2_point_test.txt increment="1 days" start="2013-01-10"
-t.register -i type=vect input=P3 file=/tmp/vinput3_point_test.txt increment="3 days" start="2013-01-01"
-t.register -i type=vect input=P4 file=/tmp/vinput4_point_test.txt increment="3 days" start="2013-01-10"
+t.register -i type=vect input=A1 file=vinput1_area_test.txt increment="1 days" start="2013-01-01"
+t.register -i type=vect input=A2 file=vinput2_area_test.txt increment="1 days" start="2013-01-10"
+t.register -i type=vect input=A3 file=vinput3_area_test.txt increment="3 days" start="2013-01-01"
+t.register -i type=vect input=A4 file=vinput4_area_test.txt increment="3 days" start="2013-01-10"
+t.register -i type=vect input=P1 file=vinput1_point_test.txt increment="1 days" start="2013-01-01"
+t.register -i type=vect input=P2 file=vinput2_point_test.txt increment="1 days" start="2013-01-10"
+t.register -i type=vect input=P3 file=vinput3_point_test.txt increment="3 days" start="2013-01-01"
+t.register -i type=vect input=P4 file=vinput4_point_test.txt increment="3 days" start="2013-01-10"
 # Test different options.
 t.vect.mapcalc expression='B1 = A1 & A2' basename="bmap1"
Modified: grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh
--- grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -37,4 +37,4 @@
 t.remove type=stvds input=prec_observer
 #g.remove vect=prec_observer
-g.mremove -f type=rast pattern=test_prec_*
+#g.mremove -f type=rast pattern=test_prec_*
Modified: grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh
--- grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -31,5 +31,5 @@
 t.unregister type=vect maps=prec_observer:1,prec_observer:2,prec_observer:3,prec_observer:4,prec_observer:5,prec_observer:6
-g.remove vect=prec_observer,test_extract
-g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+#g.remove vect=prec_observer,test_extract
+#g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh
--- grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh	2014-09-16 16:41:30 UTC (rev 61999)
+++ grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh	2014-09-16 16:47:30 UTC (rev 62000)
@@ -45,5 +45,5 @@
 t.vect.db.select input=test_1_observer columns=cat,test1,test2,test3
 # @postprocess
-t.remove -rf type=stvds input=prec_observer,test_1_observer
+#t.remove -rf type=stvds input=prec_observer,test_1_observer
