[GRASS-SVN] r62067 - grass/trunk/vector/v.select
Wed Sep 24 06:01:28 PDT 2014
Author: neteler
Date: 2014-09-24 06:01:28 -0700 (Wed, 24 Sep 2014)
New Revision: 62067
   grass/trunk/vector/v.select/select.c
v.select: msg if GEOS or GRASS GIS functions are used
Modified: grass/trunk/vector/v.select/select.c
--- grass/trunk/vector/v.select/select.c	2014-09-24 12:25:53 UTC (rev 62066)
+++ grass/trunk/vector/v.select/select.c	2014-09-24 13:01:28 UTC (rev 62067)
@@ -34,6 +34,10 @@
     LList = Vect_new_list();
     nalines = Vect_get_num_lines(aIn);
+    if (operator == OP_OVERLAP)
+	G_message("Using GRASS GIS operator...");
+    else
+	G_message("Using GEOS operator...");
     /* Lines in A. Go through all lines and mark those that meets condition */
     if (atype & (GV_POINTS | GV_LINES)) {
