[GRASS-SVN] r62105 - grass/trunk/lib/gis
Fri Sep 26 20:10:02 PDT 2014
Author: glynn
Date: 2014-09-26 20:10:02 -0700 (Fri, 26 Sep 2014)
New Revision: 62105
   grass/trunk/lib/gis/parser.c
Check that option names are valid
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2014-09-26 23:44:35 UTC (rev 62104)
+++ grass/trunk/lib/gis/parser.c	2014-09-27 03:10:02 UTC (rev 62105)
@@ -101,6 +101,7 @@
 /* local prototypes */
 static void set_flag(int);
 static int contains(const char *, int);
+static int valid_option_name(const char *);
 static int is_option(const char *);
 static void set_option(const char *);
 static void check_opts(void);
@@ -337,10 +338,13 @@
     /* Stash default answers */
     opt = &st->first_option;
-    while (opt) {
+    while (st->n_opts && opt) {
 	if (opt->required)
 	    st->has_required = 1;
+	if (!valid_option_name(opt->key))
+	    G_warning(_("BUG in option name, '%s' is not valid"), opt->key);
 	/* Parse options */
 	if (opt->options) {
 	    int cnt = 0;
@@ -655,7 +659,7 @@
-    while (opt) {
 	if (opt->answer && opt->answers && opt->answers[0]) {
 	    slen = strlen(opt->key) + strlen(opt->answers[0]) + 4;	/* +4 for: ' ' = " " */
 	    if (len + slen >= nalloced) {
@@ -871,6 +875,23 @@
     return FALSE;
+static int valid_option_name(const char *string)
+    int m = strlen(string);
+    int n = strspn(string, "abcdefghijklmnopqrstuvwxyz0123456789_");
+    if (!m)
+	return 0;
+    if (m != n)
+	return 0;
+    if (string[m-1] == '_')
+	return 0;
+    return 1;
 static int is_option(const char *string)
