[GRASS-SVN] r65038 - in	grass/branches/releasebranch_7_0/raster/r.li: . r.li.daemon
    svn_grass at osgeo.org
    Thu Apr  9 08:19:11 PDT 2015
Author: wenzeslaus
Date: 2015-04-09 08:19:11 -0700 (Thu, 09 Apr 2015)
New Revision: 65038
   grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c
   grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.h
   grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/r.li.daemon.html
   grass/branches/releasebranch_7_0/raster/r.li/r.li.html
change calculateIndex return value, so it can be used as process return code (backport of r64895)
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c	2015-04-09 15:15:29 UTC (rev 65037)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.c	2015-04-09 15:19:11 UTC (rev 65038)
@@ -177,7 +177,9 @@
 	G_done_msg("Result written to text file <%s>", out);
-    return 1;
+    /* This is only return in this function, so the documented 1 is
+       actually never returned. */
+    return 0;
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.h
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.h	2015-04-09 15:15:29 UTC (rev 65037)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/daemon.h	2015-04-09 15:19:11 UTC (rev 65038)
@@ -137,8 +137,14 @@
  * \param file name of setup file
  * \param f the function that defines the index
  * \param raster the raster file to analyze
- * \return 0 error occurs in calculating index
- * \return 1  otherwise
+ * \return 1 error occurs in calculating index
+ * \return 0 otherwise
+ * \note
+ * Unlike other function in r.li, this function returns return code
+ * usable as process return code rather than using true/false (1/0)
+ * idiom for success/failure. The interface was designed to accommodate
+ * common usage of this function in r.li modules.
 int calculateIndex(char *file, rli_func *f,
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/r.li.daemon.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/r.li.daemon.html	2015-04-09 15:15:29 UTC (rev 65037)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.daemon/r.li.daemon.html	2015-04-09 15:19:11 UTC (rev 65038)
@@ -1,6 +1,17 @@
 <!-- meta page description: Support for landscape index calculations on raster -->
 <h2>DESCRIPTION</h2>
+This documentation is focused on scientists and developers who wants to
+implement a new landscape index computation. Refer to the
+<a href="r.li.html">r.li</a> modules overview and
+<a href="g.gui.rlisetup.html">g.gui.rlisetup</a> module for user-focused
+documentation.
+<p>
+TODO: make this clear and rename daemon to library since it is library and not a daemon
+TODO: here can be just a really short intro and instructions how to get doxygen doc
 <em>r.li.daemon</em> provides support for landscape index calculations on raster
 maps. It hides the management of areas, defined using <a href="g.gui.rlisetup.html">g.gui.rlisetup</a>
 command. It is not used like a standalone program, but its functions are
@@ -16,21 +27,23 @@
 	<li>
 	Define a function and insert its declaration on file <b>index.h</b> in <em>r.li.daemon</em>
 	folder, which contains all index declarations. This function must be of this kind:
-	<br><div class="code"><pre>
+	<div class="code"><pre>
         int index(int fd, char ** par, area_des ad, double * result)
-	</pre></div><br>
+	</pre></div>
 	where: <ul>
 			<li><i>fd</i> is the raster map descriptor
 			<li><i>par</i> is a matrix for special parameter (like argv in main)
 			<li><i>ad</i> is the area descriptor
 			<li><i>result</i> is where to put the index calculation result
 		</ul>
-	This function has to return 1 on success and 0 otherwise. <br><br>
+	This function has to return 1 on success and 0 otherwise.
+    This function type is defined using typedef named <code>rli_func</code>.
 	<li>
 	Create a main for command line arguments parsing, and call the function
-        int calculateIndex(char * file, int f(int, char** area_des, double *), char **parameters, char *raster, char *output);
-	</pre></div><br>
+        int calculateIndex(char *file, rli_func *f,
+                           char **parameters, char *raster, char *output);
+	</pre></div>
 	from the <i>r.li</i> library, for starting raster analysis.<br>
 	It follows the meaning of parameters:
 	<ul>
@@ -43,6 +56,10 @@
 </ol>
 Compile it using a changed Makefile based on the file for <em>r.li.patchdensity</em>.
+<p>
+Refer to the <i>r.li</i> library documentation in the source code and
+implementation of <i>r.li</i> modules for details and examples.
 <h2>NOTES</h2>
 Using GRASS library function to access raster rows can slow down moving windows
Modified: grass/branches/releasebranch_7_0/raster/r.li/r.li.html
--- grass/branches/releasebranch_7_0/raster/r.li/r.li.html	2015-04-09 15:15:29 UTC (rev 65037)
+++ grass/branches/releasebranch_7_0/raster/r.li/r.li.html	2015-04-09 15:19:11 UTC (rev 65038)
@@ -170,16 +170,24 @@
 easy expandability. Every index is defined separately, placed in a
 directory along with its Makefile for compiling it and a file
 <module_name>.html which describes the index including a simple
-example of use.
+example of use. See <a href="r.li.daemon.html">r.li.daemon</a>
+for more information about development.
 <h2>REFERENCES</h2>
+<ul>
+<li>
 McGarigal, K., and B. J. Marks. 1995. FRAGSTATS: spatial pattern
 analysis program for quantifying landscape structure. USDA For. Serv.
 Gen. Tech. Rep. PNW-351
  (<a href="http://www.fs.fed.us/pnw/pubs/gtr_351.pdf">PDF</a>).
+<li>
+Baker, W.L. and Y. Cai. 1992. The r.le programs for multiscale analysis of
+landscape structure using the GRASS geographical information system.
+Landscape Ecology 7(4):291-302.
+</ul>
 <h2>AUTHORS</h2>
