[GRASS-SVN] r65085 - grass/trunk/temporal/t.connect
Fri Apr 17 02:10:45 PDT 2015
Author: martinl
Date: 2015-04-17 02:10:45 -0700 (Fri, 17 Apr 2015)
New Revision: 65085
   grass/trunk/temporal/t.connect/t.connect.html
t.connect: fix manual syntax typo
Modified: grass/trunk/temporal/t.connect/t.connect.html
--- grass/trunk/temporal/t.connect/t.connect.html	2015-04-17 09:08:54 UTC (rev 65084)
+++ grass/trunk/temporal/t.connect/t.connect.html	2015-04-17 09:10:45 UTC (rev 65085)
@@ -21,7 +21,7 @@
 TGIS connection parameters.
 A SQLite database "tgis/sqlite.db" will be created in the current mapset directory.
 It will be located in the "tgis" sub-directory to not
-interfere with the <em>sqlite3<em> database used for vector attribute storage.
+interfere with the <em>sqlite3</em> database used for vector attribute storage.
 <p>
 In case you have tens of thousands of maps to register in the
 temporal database or you need concurrent read and write access in the
