[GRASS-SVN] r65807 - grass-addons/grass7/raster/r.mcda.electre
Sat Aug 1 10:07:49 PDT 2015
Author: gianluca
Date: 2015-08-01 10:07:49 -0700 (Sat, 01 Aug 2015)
New Revision: 65807
Removed:
   grass-addons/grass7/raster/r.mcda.electre/Makefile~
   grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~
Deleted: grass-addons/grass7/raster/r.mcda.electre/Makefile~
--- grass-addons/grass7/raster/r.mcda.electre/Makefile~	2015-08-01 17:07:23 UTC (rev 65806)
+++ grass-addons/grass7/raster/r.mcda.electre/Makefile~	2015-08-01 17:07:49 UTC (rev 65807)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = r.mcda.roughset
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Deleted: grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~
--- grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~	2015-08-01 17:07:23 UTC (rev 65806)
+++ grass-addons/grass7/raster/r.mcda.electre/r.mcda.electre.py~	2015-08-01 17:07:49 UTC (rev 65807)
@@ -1,116 +0,0 @@
-#!/usr/bin/env python
-# MODULE:	   r.mcda.electre
-# AUTHOR:	   Gianluca Massei - Antonio Boggia
-# PURPOSE:	   Elaborate several criteria maps and gets concordance and
-#				discordance maps indices as a base for electre analysis
-# COPYRIGHT:  c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
-#					   Development Team. This program is free software under the
-#					   GNU General PublicLicense (>=v2). Read the file COPYING
-#					   that comes with GRASS for details.
-#%module
-#% description: Gets concordance and discordance maps indices for MCDA analysis
-#% keyword: raster
-#% keyword: criteria maps
-#% keyword: MCDA
-#%end
-#%option G_OPT_R_INPUTS
-#% key: criteria
-#% multiple: yes
-#% gisprompt: old,cell,raster
-#% key_desc: name
-#% description: Name of criteria raster maps
-#% required: yes
-#%end
-#%option
-#% key: weights
-#% type: double
-#% description: weights (w1,w2,...,wn)
-#% multiple: yes
-#% required: yes
-#%end
-#%option G_OPT_R_OUTPUT
-#% key: concordancemap
-#% type: string
-#% gisprompt: new_file,cell,output
-#% description: output concordance raster map
-#% answer:concordance
-#% required: yes
-#%end
-#% key: discordancemap
-#% type: string
-#% description: output discordance raster map
-#% answer:discordance
-#% required: yes
-#%end
-import sys
-import grass.script as gscript
-from grass.pygrass import raster
-def preprocessing(attributes,weights):
-	matrix=[]
-	for attribute in attributes:
-		c=[]
-		criteria = raster.RasterRowIO(str(attribute))
-		#criteria.is_open()
-		criteria.open('r')
-		for row in criteria:
-			c.append(row)
-		matrix.append(c)
-		criteria.close()
-	print len(matrix),weights
-	print dir(criteria)
-def concordance(attributes,weights,concordanceMap):
-	i=0
-	listMaps=[]
-	for attrRow,weight in zip(attributes,weights):
-		for attrCol in attributes:
-			concordanceMap="conc_%s" % str(i)
-			formula="%s=if(%s>%s,%s,0)" % (concordanceMap,attrRow.split('@')[0],attrCol.split('@')[0],weight)
-			gscript.mapcalc(formula,overwrite = True)
-			listMaps.append(concordanceMap)
-			i=i+1
-	endMap="%s=%s" % (concordanceMap,("+".join(listMaps)))
-	gscript.mapcalc(endMap,overwrite = True)
-	gscript.run_command("g.remove", type='raster',flags='f', name=",".join(listMaps))
-	return 0
-def discordance(attributes,discordanceMap):
-	i=0
-	listMaps=[]
-	for attrRow in attributes:
-			discordanceMap="conc_%s" % str(i)
-			formula="%s=if(%s>%s,%s-%s,0)" % (discordanceMap,attrRow.split('@')[0],attrCol.split('@')[0],attrRow.split('@')[0],attrCol.split('@')[0])
-			listraster.append(discordanceMap)
-			i=i+1
-	endMap="%s=max(%s)" % (discordanceMap,("+".join(listMaps)))
-	return 0
-def main():
-	options, flags = gscript.parser()
-	attributes = options['criteria'].split(',')
-	weights = options['weights'].split(',')
-	concordanceMap= options['concordancemap']
-	discordanceMap= options['discordancemap']
-	concordance(attributes,weights,concordanceMap)
-	discordance(attributes,discordanceMap)
-	return 0
-if __name__ == "__main__":
-    sys.exit(main())
