[GRASS-SVN] r65848 - in grass/trunk: raster/r.mode raster/r.quant raster/r.statistics raster/r.stats.zonal vector/v.outlier
Thu Aug 6 21:09:05 PDT 2015
Author: wenzeslaus
Date: 2015-08-06 21:09:05 -0700 (Thu, 06 Aug 2015)
New Revision: 65848
   grass/trunk/raster/r.mode/main.c
   grass/trunk/raster/r.quant/main.c
   grass/trunk/raster/r.statistics/main.c
   grass/trunk/raster/r.stats.zonal/main.c
   grass/trunk/vector/v.outlier/main.c
use statistics as second keyword, use zonal, add more to v.outlier
Modified: grass/trunk/raster/r.mode/main.c
--- grass/trunk/raster/r.mode/main.c	2015-08-07 04:07:12 UTC (rev 65847)
+++ grass/trunk/raster/r.mode/main.c	2015-08-07 04:09:05 UTC (rev 65848)
@@ -52,8 +52,8 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
+    G_add_keyword(_("statistics"));
     G_add_keyword(_("algebra"));
-    G_add_keyword(_("statistics"));
     module->description =
 	_("Finds the mode of values in a cover map within "
 	  "areas assigned the same category value in a "
Modified: grass/trunk/raster/r.quant/main.c
--- grass/trunk/raster/r.quant/main.c	2015-08-07 04:07:12 UTC (rev 65847)
+++ grass/trunk/raster/r.quant/main.c	2015-08-07 04:09:05 UTC (rev 65848)
@@ -45,8 +45,8 @@
     G_add_keyword(_("quantization"));
 	_("Produces the quantization file for a floating-point map.");
Modified: grass/trunk/raster/r.statistics/main.c
--- grass/trunk/raster/r.statistics/main.c	2015-08-07 04:07:12 UTC (rev 65847)
+++ grass/trunk/raster/r.statistics/main.c	2015-08-07 04:09:05 UTC (rev 65848)
@@ -54,6 +54,7 @@
+    G_add_keyword(_("zonal statistics"));
 	_("Calculates category or object oriented statistics.");
Modified: grass/trunk/raster/r.stats.zonal/main.c
--- grass/trunk/raster/r.stats.zonal/main.c	2015-08-07 04:07:12 UTC (rev 65847)
+++ grass/trunk/raster/r.stats.zonal/main.c	2015-08-07 04:09:05 UTC (rev 65848)
@@ -100,6 +100,7 @@
 	_("Calculates category or object oriented statistics (accumulator-based statistics).");
Modified: grass/trunk/vector/v.outlier/main.c
--- grass/trunk/vector/v.outlier/main.c	2015-08-07 04:07:12 UTC (rev 65847)
+++ grass/trunk/vector/v.outlier/main.c	2015-08-07 04:09:05 UTC (rev 65848)
@@ -68,6 +68,9 @@
     G_add_keyword(_("vector"));
+    G_add_keyword(_("extract"));
+    G_add_keyword(_("select"));
+    G_add_keyword(_("filter"));
     module->description = _("Removes outliers from vector point data.");
     spline_step_flag = G_define_flag();
