[GRASS-SVN] r65864 - grass/trunk/locale/po
Sat Aug 8 14:15:05 PDT 2015
Author: neteler
Date: 2015-08-08 14:15:05 -0700 (Sat, 08 Aug 2015)
New Revision: 65864
   grass/trunk/locale/po/grasslibs_fr.po
   grass/trunk/locale/po/grasswxpy_fr.po
Sylvain Maillard: FR translation cont'ed
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po	2015-08-08 14:38:16 UTC (rev 65863)
+++ grass/trunk/locale/po/grasslibs_fr.po	2015-08-08 21:15:05 UTC (rev 65864)
@@ -12,7 +12,7 @@
 "Project-Id-Version: grasslibs_fr\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2015-02-08 19:52+0100\n"
-"PO-Revision-Date: 2015-06-07 15:53+0100\n"
+"PO-Revision-Date: 2015-08-06 21:32+0100\n"
 "Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
 "Language-Team: French <grass-translations at lists.osgeo.org>\n"
 "Language: fr\n"
@@ -365,7 +365,7 @@
 #: ../lib/raster/history.c:235
 #, c-format
 msgid "generated by %s"
-msgstr ""
+msgstr "généré par %s"
 #: ../lib/raster/close.c:75 ../lib/raster/close.c:108
 #, fuzzy, c-format
@@ -495,7 +495,7 @@
 #: ../lib/raster/gdal.c:498
 #, c-format
 msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
-msgstr ""
+msgstr "Le pilote <%s> ne gère pas l'écriture directe. Utiliser le pilote MEM pour les données intermédiaires."
 #: ../lib/raster/gdal.c:504
 #, fuzzy
@@ -510,7 +510,7 @@
 #: ../lib/raster/gdal.c:515
 #, c-format
 msgid "Driver <%s> does not support creating rasters"
-msgstr ""
+msgstr "Le pilote <%s> ne gère pas la création de raster"
 #: ../lib/raster/gdal.c:531
 #, fuzzy
@@ -623,7 +623,7 @@
 #: ../lib/raster/open.c:256
 #, c-format
 msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
+msgstr "La carte raster <%s@%s> est un lien GDAL mais GRASS est compilé sans le support de GDAL"
 #: ../lib/raster/open.c:264
 #, fuzzy, c-format
@@ -657,7 +657,7 @@
 #: ../lib/raster/open.c:720
 msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
+msgstr "Rast_set_fp_type() : ne peut être appelé qu'avec FCELL_TYPE ou DCELL_TYPE"
 #: ../lib/raster/open.c:778
 #, c-format
@@ -686,12 +686,12 @@
 #: ../lib/raster/open.c:929
 msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
+msgstr "Rast_set_quant_rules() ne peut être appelé que sur une carte raster ouverte en lecture"
 #: ../lib/raster/color_rand.c:33
 #, c-format
 msgid "Rast_make_random_colors: min (%d) > max (%d)"
-msgstr ""
+msgstr "Rast_make_random_colors : min (%d) > max (%d)"
 #: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67 ../lib/segment/open.c:98
 #: ../lib/rst/interp_float/interp2d.c:121
@@ -775,7 +775,7 @@
 #: ../lib/ogsf/gp2.c:705
 msgid "Unknown icon marker, using \"sphere\""
-msgstr ""
+msgstr "Icône inconnue, utilisation de « sphère »"
 #: ../lib/ogsf/gp3.c:56 ../lib/ogsf/gp3.c:191 ../lib/ogsf/gv3.c:60
 #: ../lib/ogsf/gv3.c:333 ../lib/manage/do_rename.c:54
@@ -855,7 +855,7 @@
 #: ../lib/ogsf/gp3.c:288
 #, c-format
 msgid "%d points without category. Unable to determine color rules for features without category."
-msgstr ""
+msgstr "%d points sans catégorie. Impossible de déterminer les règles de couleurs pour les points sans catégorie."
 #: ../lib/ogsf/gsds.c:109
 msgid "Maximum number of datasets exceeded"
@@ -946,7 +946,7 @@
 #: ../lib/ogsf/gv3.c:414
 #, c-format
 msgid "%d features without category. Unable to determine color rules for features without category."
-msgstr ""
+msgstr "%d entités sans catégories. Impossible de déterminer les règles de couleurs pour les entités sans catégorie."
 #: ../lib/ogsf/gs_bm.c:124
 msgid "Bitmap mismatch"
@@ -1049,7 +1049,7 @@
 #: ../lib/segment/format.c:144
 msgid "Please recompile with Large File Support (LFS)"
-msgstr ""
+msgstr "Merci de recompiler avec le support de grands fichiers (LFS)"
 #: ../lib/segment/open.c:53
 msgid "Segment file name is NULL"
@@ -1086,12 +1086,12 @@
 #: ../lib/cluster/c_begin.c:57
 #, c-format
 msgid "produced by i.cluster"
-msgstr ""
+msgstr "produit par i.cluster"
 #: ../lib/cluster/c_exec.c:44
 #, c-format
 msgid "Not enough data points (%d) in cluster"
-msgstr ""
+msgstr "Pas assez de points (%d) dans le groupe"
 #: ../lib/proj/get_proj.c:148
 #, c-format
@@ -1178,7 +1178,7 @@
 #: ../lib/vector/Vlib/rewind_ogr.c:71 ../lib/vector/Vlib/write_ogr.c:69
 #: ../lib/vector/Vlib/write_ogr.c:105 ../lib/vector/Vlib/write_ogr.c:145
 msgid "GRASS is not compiled with OGR support"
-msgstr ""
+msgstr "GRASS n'est pas compilé avec le support de OGR"
 #: ../lib/proj/convert.c:120
 msgid "Unable parse GRASS PROJ_INFO file"
@@ -1281,7 +1281,7 @@
 #: ../lib/db/dbmi_driver/d_error.c:35
 #, c-format
 msgid "DBMI-%s driver error:"
-msgstr ""
+msgstr "DBMI-%s erreur de pilote :"
 #: ../lib/db/dbmi_base/legal_dbname.c:38
 #, fuzzy, c-format
@@ -1305,7 +1305,7 @@
 #: ../lib/db/dbmi_base/error.c:91
 msgid "dbmi: Protocol error"
-msgstr ""
+msgstr "dbmi : erreur de protocole"
 #: ../lib/db/dbmi_base/error.c:136
 #, fuzzy
@@ -1315,36 +1315,36 @@
 #: ../lib/db/dbmi_base/error.c:149
 #, c-format
 msgid "dbmi: %s() not implemented"
-msgstr ""
+msgstr "dbmi : %s() non implémenté"
 #: ../lib/db/dbmi_base/error.c:163
 #, c-format
 msgid "dbmi: Invalid procedure %d"
-msgstr ""
+msgstr "dbmi : procédure %d invalide"
 #: ../lib/db/dbmi_base/valuefmt.c:52
 msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
-msgstr ""
+msgstr "db_convert_Cstring_to_value() : sqltype non reconnu"
 #: ../lib/db/dbmi_base/valuefmt.c:91
 msgid "db_convert_value_into_string(): unrecongized sqltype-type"
-msgstr ""
+msgstr "db_convert_value_into_string() : type sqltype non reconnu"
 #: ../lib/db/dbmi_base/xdrtable.c:109
 msgid "fetch: table has wrong number of columns"
-msgstr ""
+msgstr "chargement : la table a le mauvais nombre de colonnes"
 #: ../lib/db/dbmi_base/xdrvalue.c:82
 msgid "send data: invalid C-type"
-msgstr ""
+msgstr "envoi de données : type C invalide"
 #: ../lib/db/dbmi_base/index.c:180
 msgid "db_set_index_column_name(): invalid column number"
-msgstr ""
+msgstr "db_set_index_column_name() : numéro de colonne invalide"
 #: ../lib/db/dbmi_base/index.c:197
 msgid "db_get_index_column_name(): invalid column number"
-msgstr ""
+msgstr "db_get_index_column_name() : numéro de colonne invalide"
 #: ../lib/db/dbmi_base/test/test_main.c:47 ../lib/gmath/test/test_main.c:47
 #: ../lib/vector/rtree/test_suite/test_main.c:44
@@ -1404,12 +1404,16 @@
 "\n"
 "++ Run test copy column ++"
 msgstr ""
+"\n"
+"++ lancer le test de copie de colonne ++"
 #: ../lib/db/dbmi_base/test/test_columns.c:150
 msgid ""
 "\n"
 "++ Test copy column finished ++"
 msgstr ""
+"\n"
+"++ Test de copie de colonne terminé ++"
 #: ../lib/db/dbmi_base/test/test_table.c:38
 #, fuzzy
@@ -1565,19 +1569,19 @@
 #: ../lib/manage/option.c:51
 msgid "Raster"
-msgstr ""
+msgstr "Raster"
 #: ../lib/manage/option.c:53
 msgid "Vector"
-msgstr ""
+msgstr "Vecteur"
 #: ../lib/manage/option.c:55
 msgid "Region"
-msgstr ""
+msgstr "Région"
 #: ../lib/manage/option.c:57
 msgid "Group"
-msgstr ""
+msgstr "Groupe"
 #: ../lib/manage/do_rename.c:42
 #, fuzzy, c-format
@@ -1604,12 +1608,12 @@
 #: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
 #, c-format
 msgid "%s renamed"
-msgstr ""
+msgstr "%s renommé"
 #: ../lib/manage/do_rename.c:119
 #, c-format
 msgid "<%s> nothing renamed"
-msgstr ""
+msgstr "<%s> rien de renommé"
 #: ../lib/manage/do_copy.c:43
 #, fuzzy, c-format
@@ -1624,7 +1628,7 @@
 #: ../lib/manage/do_copy.c:70
 #, c-format
 msgid "%s copied"
-msgstr ""
+msgstr "%s copié"
 #: ../lib/manage/do_remove.c:42
 #, fuzzy, c-format
@@ -1644,7 +1648,7 @@
 #: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
 #, c-format
 msgid "%s removed"
-msgstr ""
+msgstr "%s supprimé"
 #: ../lib/manage/do_remove.c:105
 #, fuzzy, c-format
@@ -1654,7 +1658,7 @@
 #: ../lib/manage/do_remove.c:121
 #, c-format
 msgid "<%s> nothing removed"
-msgstr ""
+msgstr "<%s> rien de supprimé"
 #: ../lib/manage/read_list.c:73
 #, fuzzy, c-format
@@ -1664,7 +1668,7 @@
 #: ../lib/manage/read_list.c:134
 #, c-format
 msgid "Format error: file ('%s') line (%d) - %s"
-msgstr ""
+msgstr "Erreur de format : fichier ('%s') ligne (%d) - %s"
 #: ../lib/cairodriver/graph.c:67
 #, fuzzy
@@ -1679,7 +1683,7 @@
 #: ../lib/cairodriver/graph.c:160
 #, c-format
 msgid "Unknown file extension: %s"
-msgstr ""
+msgstr "Extention de fichier invalide : %s"
 #: ../lib/cairodriver/graph.c:190
 #, fuzzy, c-format
@@ -1689,7 +1693,7 @@
 #: ../lib/cairodriver/graph.c:192
 #, c-format
 msgid "cairo: image size %dx%d"
-msgstr ""
+msgstr "cairo : taille d'image %dx%d"
 #: ../lib/cairodriver/graph.c:371
 #, fuzzy
@@ -1703,7 +1707,7 @@
 #: ../lib/cairodriver/draw_bitmap.c:47
 msgid "Cairo_Bitmap: Failed to create source"
-msgstr ""
+msgstr "Cairo_Bitmap : Échec de création de la source"
 #: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
 #, fuzzy, c-format
@@ -1728,7 +1732,7 @@
 #: ../lib/cairodriver/read_bmp.c:96
 #, c-format
 msgid "Cairo: Invalid BMP header for <%s>"
-msgstr ""
+msgstr "Cairo : en-tête BMP invalide pour <%s>"
 #: ../lib/cairodriver/read_xid.c:14
 #, fuzzy, c-format
@@ -1752,7 +1756,7 @@
 #: ../lib/cairodriver/text.c:56
 msgid "Some characters could not be converted to UTF-8"
-msgstr ""
+msgstr "Certains caractères ne peuvent pas être convertis en UTF-8"
 #: ../lib/cairodriver/raster.c:109
 #, fuzzy
@@ -1762,7 +1766,7 @@
 #: ../lib/cairodriver/read_ppm.c:38
 #, c-format
 msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
+msgstr "Cairo : le fichier d'entrée a des dimensions incorrectes : attendu : %dx%d reçu : %dx%d"
 #: ../lib/cairodriver/read_ppm.c:46
 #, fuzzy, c-format
@@ -1777,7 +1781,7 @@
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
 msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
+msgstr "Cairo : le fichier de masque a des dimensions incorrects : attendu : %dx%d reçu : %dx%d"
 #: ../lib/cairodriver/write_xid.c:14
 #, fuzzy, c-format
@@ -1796,21 +1800,21 @@
 #: ../lib/pngdriver/graph_set.c:102 ../lib/psdriver/graph_set.c:200
 msgid "enabled"
-msgstr ""
+msgstr "activé"
 msgid "disabled"
-msgstr ""
+msgstr "désactivé"
 #: ../lib/pngdriver/graph_set.c:149
 #, c-format
 msgid "png: collecting to file '%s'"
-msgstr ""
+msgstr "png : enregistrement vers le fichier '%s'"
 #: ../lib/pngdriver/graph_set.c:150
 #, c-format
 msgid "png: image size %dx%d"
-msgstr ""
+msgstr "png : taille d'image %dx%d"
 #: ../lib/init/grass.py:75
 #, fuzzy
@@ -1842,27 +1846,27 @@
 #: ../lib/init/grass.py:207
 msgid "print this help message"
-msgstr ""
+msgstr "afficher ce message d'aide"
 #: ../lib/init/grass.py:208
 msgid "show version information and exit"
-msgstr ""
+msgstr "afficher les informations de version et quitter"
 #: ../lib/init/grass.py:209
 msgid "create given database, location or mapset if it doesn't exist"
-msgstr ""
+msgstr "créer la base de données, secteur ou jeu de cartes si non existants"
 #: ../lib/init/grass.py:210
 msgid "exit after creation of location or mapset. Only with -c flag"
-msgstr ""
+msgstr "quitter après la création du secteur ou du jeu de cartes. Uniquement avec l'argument -c"
 #: ../lib/init/grass.py:211
 msgid "force removal of .gislock if exists (use with care!). Only with -text flag"
-msgstr ""
+msgstr "force la suppression de .gislock si il existe (utiliser avec précausion). Uniquement avec l'argument -text"
 #: ../lib/init/grass.py:212
 msgid "use text based interface (skip welcome screen)"
-msgstr ""
+msgstr "utiliser l'interface texte (sauter l'écran de bienvenue)"
 #: ../lib/init/grass.py:213 ../lib/init/grass.py:215 ../lib/init/grass.py:217
 #, fuzzy
@@ -1871,15 +1875,15 @@
 #: ../lib/init/grass.py:214
 msgid "use text based interface (show welcome screen)"
-msgstr ""
+msgstr "utiliser l'interface texte (afficher l'écran de bienvenue)"
 #: ../lib/init/grass.py:216
 msgid "use $DEFAULT_GUI graphical user interface"
-msgstr ""
+msgstr "utiliser l'interface utilisateur graphique $DEFAULT_GUI"
 #: ../lib/init/grass.py:218
 msgid "print GRASS configuration parameters"
-msgstr ""
+msgstr "afficher les paramètres de configuration GRASS"
 #: ../lib/init/grass.py:219
 msgid "options: arch,build,compiler,path,revision"
@@ -1892,7 +1896,7 @@
 #: ../lib/init/grass.py:221
 msgid "initial database (path to GIS data)"
-msgstr ""
+msgstr "base de données initiale (chemin vers les données SIG)"
 #: ../lib/init/grass.py:222
 #, fuzzy
@@ -1903,7 +1907,7 @@
 #: ../lib/init/grass.py:223
 msgid "initial mapset"
-msgstr ""
+msgstr "jeu de cartes initial"
 #: ../lib/init/grass.py:224
 msgid "fully qualified initial mapset directory"
@@ -1911,7 +1915,7 @@
 #: ../lib/init/grass.py:225
 msgid "Environment variables relevant for startup"
-msgstr ""
+msgstr "Variables d'environnement pour le démarrage"
 #: ../lib/init/grass.py:226
 msgid "select GUI (text, gui)"
@@ -1919,23 +1923,24 @@
 #: ../lib/init/grass.py:227
 msgid "set html web browser for help pages"
-msgstr ""
+msgstr "définir le navigateur web pour les pages d'aide"
 #: ../lib/init/grass.py:228
 msgid "set additional path(s) to local GRASS modules or user scripts"
-msgstr ""
+msgstr "définir des chemins supplémentaires pour les modules GRASS locaux ou les scripts utilisateurs"
 #: ../lib/init/grass.py:229
 msgid "set additional GISBASE for locally installed GRASS Addons"
-msgstr ""
+msgstr "définir un GISBASE supplémentaire pour les extentions GRASS installées localement"
 #: ../lib/init/grass.py:230
+#, fuzzy
 msgid "shell script to be processed as batch job"
-msgstr ""
+msgstr "script shell à exécuter par lot"
 #: ../lib/init/grass.py:231
 msgid "set python shell name to override 'python'"
-msgstr ""
+msgstr "définir le nom du shell python pour supplanter 'python'"
 #: ../lib/init/grass.py:269
 #, fuzzy, python-format
@@ -1949,9 +1954,10 @@
 #: ../lib/init/grass.py:497
 msgid "Searched for a web browser, but none found"
-msgstr ""
+msgstr "Aucun navigateur web trouvé"
 #: ../lib/init/grass.py:531
+#, fuzzy
 msgid ""
 "The python command does not work as expected!\n"
 "Please check your GRASS_PYTHON environment variable.\n"
@@ -1960,6 +1966,12 @@
 "\n"
 "Hit RETURN to continue.\n"
 msgstr ""
+"La commande python ne fonctionne pas comme prévu !\n"
+"Merci de vérifier vos variables d'environnement GRASS_PYTHON.\n"
+"Utilisez l'option -help pour les détails.\n"
+"Bascule vers l'interface en mode texte.\n"
+"\n"
+"Appuyez sur ENTRÉE pour continuer.\n"
 #: ../lib/init/grass.py:543
 msgid ""
@@ -1983,12 +1995,12 @@
 #: ../lib/init/grass.py:598
 #, python-format
 msgid "Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be created by '-c' switch."
-msgstr ""
+msgstr "Le jeu de cartes <%s> n'existepas dans le secteur GRASS <%s>. Il est possible de créer un nouveau jeu de cartes avec l'option '-c'."
 #: ../lib/init/grass.py:617
 #, python-format
 msgid "Failed to create new location. The location <%s> already exists."
-msgstr ""
+msgstr "Échec de création du nouveau secteur. Le secteur <%s> existe déjà."
 #: ../lib/init/grass.py:649
 msgid "Missing WIND file fixed"
@@ -1999,19 +2011,26 @@
 "GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
 "Interactive startup needed."
 msgstr ""
+"Les variables GISDBASE, LOCATION_NAME et MAPSET ne sont aps définies correctement.\n"
+"Démarrage interactif nécessaire."
 #: ../lib/init/grass.py:676
 #, python-format
 msgid "Invalid user interface specified - <%s>. Use the --help option to see valid interface names."
-msgstr ""
+msgstr "Interface utilisateur spécifiée invalide - <%s>. Utilisez l'option --help pour voir les noms d'interfaces valides."
 #: ../lib/init/grass.py:689
+#, fuzzy
 msgid ""
 "Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
 "Switching to text mode now.\n"
 "\n"
 "Hit RETURN to continue..."
 msgstr ""
+"Erreur dans le démarrage de l'interface graphique. Si nécessaire, merci de rapporter cette erreur aux développeurs GRASS.\n"
+"Bascule vers le mode texte.\n"
+"\n"
+"Appuyez sur ENTRÉE pour continuer ..."
 #: ../lib/init/grass.py:699
 msgid ""
@@ -2035,20 +2054,27 @@
 "\n"
 "Check the <%s(file)> file."
 msgstr ""
+"Erreur de lecture des informations de chemin des données depuis g.gisenv.\n"
+"GISDBASE=%(gisbase)s\n"
+"LOCATION_NAME=%(location)s\n"
+"MAPSET=%(mapset)s\n"
+"\n"
+"Vérifier le fichier <%s(file)>."
 #: ../lib/init/grass.py:793
+#, fuzzy
 msgid "Default locale settings are missing. GRASS running with C locale."
-msgstr ""
+msgstr "Les paramètres de locale par défaut sont manquants. Lancement de GRASS avec la locale C."
 #: ../lib/init/grass.py:797
 #, python-format
 msgid "A language override has been requested. Trying to switch GRASS into '%s'..."
-msgstr ""
+msgstr "Un forçage de langage a été demandé. Essai de basculer GRASS en '%s' ..."
 #: ../lib/init/grass.py:856
 #, python-format
 msgid "Path '%s' doesn't exist"
-msgstr ""
+msgstr "Le chemin '%s' n'existe pas"
 #: ../lib/init/grass.py:864
 #, python-format
@@ -2056,18 +2082,22 @@
 "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed.\n"
 "You can force launching GRASS using -f flag (note that you need permission for this operation). Have another look in the processor manager just to be sure..."
 msgstr ""
+"%(user)s utilise GRASS dans le jeu de cartes sélectionné (fichier %(file)s trouvé). Les utilisations simultanées ne sont pas permises.\n"
+"Vous pouvez forcer le démarrage de GRASS avec l'option -f (vous devez avoir les permissions pour cette opération). Vérifiez le gestionnaire de processus pour être sûr ..."
 #: ../lib/init/grass.py:871
 #, python-format
 msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Forcing to launch GRASS..."
-msgstr ""
+msgstr "%(user)s utilise GRASS dans le jeu de cartes sélectionné (fichier %(file)s trouvé). Lancement de GRASS forcé ..."
 #: ../lib/init/grass.py:875
-#, python-format
+#, fuzzy, python-format
 msgid ""
 "Unable to properly access '%s'.\n"
 "Please notify system personel."
 msgstr ""
+"Impossible d'accéder correctement à '%s'.\n"
+"Merci d'en notifier votre administrateur système."
 #: ../lib/init/grass.py:890
 #, fuzzy
@@ -2077,7 +2107,7 @@
 #: ../lib/init/grass.py:935
 #, python-format
 msgid "Unsupported shell <%(sh)s>: %(env)s"
-msgstr ""
+msgstr "Shell <%(sh)s> non supporté : %(env)s"
 #: ../lib/init/grass.py:940
 #, fuzzy
Modified: grass/trunk/locale/po/grasswxpy_fr.po
--- grass/trunk/locale/po/grasswxpy_fr.po	2015-08-08 14:38:16 UTC (rev 65863)
+++ grass/trunk/locale/po/grasswxpy_fr.po	2015-08-08 21:15:05 UTC (rev 65864)
@@ -10,7 +10,7 @@
 "Project-Id-Version: grasswxpy_fr\n"
-"PO-Revision-Date: 2015-06-07 13:56+0100\n"
+"PO-Revision-Date: 2015-08-06 10:16+0100\n"
 "Language-Team: français <grass-translations at lists.osgeo.org>\n"
 "Language: fr\n"
@@ -18,6 +18,7 @@
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "X-Generator: Poedit 1.5.5\n"
+"X-Poedit-SourceCharset: UTF-8\n"
 #: ../gui/wxpython/iscatt/plots.py:42
 #, python-format
@@ -9189,9 +9190,8 @@
 msgstr "Métadonnées élémentaires d'une carte vecteur"
 #: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1629
-#, fuzzy
 msgid "Outputs basic information about a vector map."
-msgstr "Sortie."
+msgstr "Affiche les métadonnées d'une carte vecteur."
 #: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1630
 msgid "Classify attribute data"
@@ -9206,9 +9206,8 @@
 msgstr "Rendre compte de la topologie par catégorie"
 #: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1633
-#, fuzzy
 msgid "Reports geometry statistics for vector maps."
-msgstr "Convertit un fichier 'raster' ASCII en une carte 'raster' binaire"
+msgstr "Compte-rendu des statistiques de géométrie pour les cartes vecteur."
 #: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1634
 msgid "Univariate attribute statistics for points"
@@ -9231,18 +9230,16 @@
 msgstr "Indices des quadrats"
 #: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1639
-#, fuzzy
 msgid "Indices for quadrat counts of vector point lists."
-msgstr "Indice de compte par quadrat."
+msgstr "Indice de quadrat pour la liste de points vecteurs."
 #: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1640
 msgid "Test normality"
 msgstr "Test de normalité"
 #: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1641
-#, fuzzy
 msgid "Tests for normality for vector points."
-msgstr "IDW de points vecteur"
+msgstr "Test de normalité pour les points vecteur."
 #: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1642
 msgid "&Imagery"
@@ -9274,9 +9271,8 @@
 msgstr "Mosaïquage d'images"
 #: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1649
-#, fuzzy
 msgid "Mosaics several images and extends colormap."
-msgstr "Créer une mosaïque jusqu'à 4 images et étend la table de couleurs; créer une carte *.mosaic"
+msgstr "Créer une mosaïque d'images et étendre la table de couleurs."
 #: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1650
 msgid "Manage image colors"
@@ -9287,9 +9283,8 @@
 msgstr "Balance des couleurs pour RVB"
 #: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1652
-#, fuzzy
 msgid "Performs auto-balancing of colors for RGB images."
-msgstr "Applique une balance automatique des couleurs pour les images LANDSAT."
+msgstr "Effectuer une balance automatique des couleurs pour les images RVB."
 #: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1653
 msgid "HIS to RGB"
@@ -9336,7 +9331,7 @@
 #: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1664
 #, fuzzy
 msgid "Image fusion algorithms to sharpen multispectral with high-res panchromatic channels"
-msgstr "Transformation de Brovey pour fusionner des canaux multispectraux et panchromatique haute résolution."
+msgstr "Algorithme de fusion d'image pour améliorer la netteté des canaux multispectraux avec un canal panchromatique haute résolution."
 #: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1665
 msgid "Classify image"
@@ -9347,9 +9342,8 @@
 msgstr "Regroupement pour classification non-supervisée"
 #: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1667
-#, fuzzy
 msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm. The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
-msgstr "Générer les signatures spectrales pour l'occupation des sols dans une image, à l'aide d'un algorithme de regroupement."
+msgstr "Générer les signatures spectrales pour les types d'occupation des sols dans une image avec un algorithme de regroupement. Le fichier de signature résultant est utilisé en entrée pour i.maxlik, pour générer une classification non supervisée de l'image."
 #: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1668
 msgid "Input for supervised MLC"
@@ -9369,15 +9363,13 @@
 #: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1672
 #: ../gui/wxpython/menustrings.py:1933
-#, fuzzy
 msgid "Interactive input for supervised classification"
-msgstr "Regroupement pour classification non-supervisée"
+msgstr "Entrée interactive pour la  classification supervisée"
 #: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1673
 #: ../gui/wxpython/menustrings.py:1934
-#, fuzzy
 msgid "Generates spectral signatures by allowing the user to outline training areas."
-msgstr "Générer les signatures spectrales en autorisant l'utilisateur à définir les zones d'entrainement."
+msgstr "Générer les signatures spectrales en permettant à l'utilisateur à définir les zones d'entrainement."
 #: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1674
 msgid "Input for supervised SMAP"
@@ -9396,9 +9388,8 @@
 msgstr "Effectue une classification d'image contextuelle, en utilisant l'estimation du maximum séquentiel à postériori (SMAP)."
 #: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1678
-#, fuzzy
 msgid "Object segmentation"
-msgstr "Orientation"
+msgstr "Segmentation orientée objet"
 #: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1679
 msgid "Identifies segments (objects) from imagery data."
@@ -9433,9 +9424,8 @@
 msgstr "Corrélation canonique"
 #: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1687
-#, fuzzy
 msgid "Canonical components analysis (CCA) program for image processing."
-msgstr "Analyse d'image par composante canonique (cca)."
+msgstr "Analyse d'image par composante canonique (CCA)."
 #: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1688
 msgid "Principal components"
@@ -9496,9 +9486,8 @@
 msgstr "Contrôle de qualité MODIS"
 #: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1702
-#, fuzzy
 msgid "Extracts quality control parameters from MODIS QC layers."
-msgstr "Extraire le sparamètres de contrôle de qualité d'une couche MODIS QC."
+msgstr "Extraire les paramètres de contrôle de qualité d'une couche MODIS QC."
 #: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1703
 msgid "Atmospheric correction"
@@ -9507,12 +9496,11 @@
 #: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1704
 #, fuzzy
 msgid "Performs atmospheric correction using the 6S algorithm. 6S - Second Simulation of Satellite Signal in the Solar Spectrum."
-msgstr "Effectue une correction atmosphérique par l'algorithme 6S."
+msgstr "Effectue une correction atmosphérique par l'algorithme 6S. 6S - Seconde Simulation du Signal d'un Satellite dans le Spectre Solaire."
 #: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1705
-#, fuzzy
 msgid "Topographic correction"
-msgstr "Corrections atmosphériques"
+msgstr "Corrections topographiques"
 #: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1706
 msgid "Computes topographic correction of reflectance."
@@ -9523,9 +9511,8 @@
 msgstr "Produits d'imagerie satellitale"
 #: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1708
-#, fuzzy
 msgid "Vegetation indices"
-msgstr "Indices des quadrats"
+msgstr "Indices de végétation"
 #: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1709
 msgid "Calculates different types of vegetation indices. Uses red and nir bands mostly, and some indices require additional bands."
@@ -9538,7 +9525,7 @@
 #: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1711
 #, fuzzy
 msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
-msgstr "Transformation de Tasseled cap (Kauth Thomas) pour les données LANDSAT-TM"
+msgstr "Transformation de Tasseled cap (Kauth Thomas)."
 #: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1712
 msgid "Albedo"
@@ -9552,7 +9539,7 @@
 #: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1714
 #, fuzzy
 msgid "Emissivity"
-msgstr "Emission"
+msgstr " Emissivité"
 #: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1715
 msgid "Computes emissivity from NDVI, generic method for sparse land."
@@ -9700,12 +9687,11 @@
 #: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1750
 #, fuzzy
 msgid "3D rasters to raster series"
-msgstr "Volume vers série raster"
+msgstr "Rasters 3D vers séris raster"
 #: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1752
-#, fuzzy
 msgid "3D color tables"
-msgstr "Tables de couleurs"
+msgstr "Tables de couleurs 3D"
 #: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1753
 #, fuzzy
@@ -9713,14 +9699,12 @@
 #: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1754
-#, fuzzy
 msgid "Export 3D color table"
-msgstr "Choisir une couleur"
+msgstr "Exporter une table de couleur 3D"
 #: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1755
-#, fuzzy
 msgid "Exports the color table associated with a 3D raster map."
+msgstr "Exporter la table de couleur associée à une carte raster 3D."
 #: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1756
 msgid "3D mask"
@@ -9741,7 +9725,6 @@
 msgstr "Coupe transversale"
 #: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1761
-#, fuzzy
 msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
 msgstr "Créer une section de coupe 2D depuis une carte raster 3D et une carte d'altitude 2D"
@@ -10055,9 +10038,8 @@
 msgstr "Lister les jeux de données temporels et cartes enregistrées dans la base de données temporelle."
 #: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1848
-#, fuzzy
 msgid "Manage maps in datasets"
-msgstr "Gérer les cartes dans le jeu de données"
+msgstr "Gérer les cartes du jeu de données"
 #: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1849
 #, fuzzy
@@ -10077,7 +10059,6 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1853
-#, fuzzy
 msgid "List raster dataset maps"
 msgstr "Lister les rasters du jeu de données"
@@ -10087,7 +10068,6 @@
 msgstr "Lister les cartes enregistrées dans le jeu de données raster temporel."
 #: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1855
-#, fuzzy
 msgid "List vector dataset maps"
 msgstr "Lister les vecteurs du jeu de données"
@@ -10123,7 +10103,7 @@
 #: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1863
 #, fuzzy
 msgid "Imports a space time vector dataset from a GRASS GIS specific archive file."
-msgstr "Importer des données vectorielles"
+msgstr "Importer un jeu de données vectoriel temporel depuis un fichier d'archive GRASS GIS."
 #: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1864
 #: ../gui/wxpython/animation/dialogs.py:763
@@ -10186,17 +10166,17 @@
 #: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1878
 #, fuzzy
 msgid "Extract subset of raster3D dataset"
-msgstr "Extraire une sous-partie du jeu de données raster3D"
+msgstr "Extraire une partie du jeu de données raster3D"
 #: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1879
 #, fuzzy
 msgid "Extracts a subset of a space time 3D raster dataset."
-msgstr "Extraire une sous-partie du jeu de données raster 3D temporel."
+msgstr "Extraire une partie du jeu de données raster 3D temporel."
 #: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1880
 #, fuzzy
 msgid "Query vector dataset attribute data"
-msgstr "Interroger la carte vecteur depuis la table d'attributs"
+msgstr "Interroger la table d'attributs d'une carte vectorielle"
 #: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1881
 msgid "Prints attributes of vector maps registered in a space time vector dataset."
@@ -10205,12 +10185,12 @@
 #: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1882
 #, fuzzy
 msgid "Raster dataset color table"
-msgstr "Définir une table de couleur"
+msgstr "Table de couleur du jeu de données raster"
 #: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1883
 #, fuzzy
 msgid "Creates/modifies the color table associated with each raster map of the space time raster dataset."
-msgstr "Crée/modifie la table de couleur associée à une carte raster."
+msgstr "Crée/modifie la table de couleur associée à chaque carte raster d'un jeu de données temporel"
 #: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1884
 msgid "Raster calculations"
@@ -10219,7 +10199,7 @@
 #: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1885
 #, fuzzy
 msgid "Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets."
-msgstr "Importer une carte raster"
+msgstr "Applique les expressions mapcalc temporelles sur un échantillon temporel de cartes d'un jeu de données raster temporel."
 #: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1886
 msgid "Raster3D calculations"
@@ -10228,51 +10208,48 @@
 #: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1887
 #, fuzzy
 msgid "Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets."
+msgstr "Applique des expressions r3.mapcalc sur les cartes d'échantillonnage d'un jeu de donénes raster3D temporel."
 #: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1888
 #, fuzzy
 msgid "Interpolate gaps in raster datasets"
+msgstr "Interpoler les trous dans un jeu de données raster"
 #: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1889
 #, fuzzy
 msgid "Replaces gaps in a space time raster dataset with interpolated raster maps."
-msgstr "Convertir une carte vecteur en carte raster."
+msgstr "Remplir les trous dans un jeu de données raster temporel par des cartes raster interpolées."
 #: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1890
-#, fuzzy
 msgid "Aggregation"
+msgstr "Agrégation"
 #: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1891
-#, fuzzy
 msgid "Neighborhood analysis in raster dataset"
-msgstr "Analyse de voisinage"
+msgstr "Analyse de voisinage dans un jeu de donnée raster"
 #: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1892
 msgid "Performs a neighborhood analysis for each map in a space time raster dataset."
 msgstr "Effectuer une analyse de voisinage pour chaque carte d'un jeu de données temporel."
 #: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1893
-#, fuzzy
 msgid "Aggregation in raster datasets"
+msgstr "Agrégation dans un jeu  de données raster"
 #: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1894
 #, fuzzy
 msgid "Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset."
-msgstr "Effectue différents algorithmes d'aggrégation depuis r.series ou a sous-jeu de cartes raster dans un jeu de données raster temporels."
+msgstr "Applique différents algorithmes d'aggrégation de r.series sur tout ou partie des cartes raster d'un jeu de données raster temporel."
 #: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1895
 #, fuzzy
 msgid "Temporal aggregation"
-msgstr "Mode catégorie"
+msgstr "Aggrégation temporelle"
 #: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1896
 #, fuzzy
 msgid "Aggregates temporally the maps of a space time raster dataset by a user defined granularity."
+msgstr "Aggrège temporelement les cartes d'un jeux de données raster temporel selon une granularité définie par l'utilisateur."
 #: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1897
 #, fuzzy
@@ -10282,17 +10259,16 @@
 #: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1898
 #, fuzzy
 msgid "Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset."
-msgstr "Aggrégation de données d'un jeu de données raster temporel en utilisant le temps d'intervale d'un second jeu de données temporel."
+msgstr "Aggrège les données d'un jeu de données raster temporel en utilisant le temps d'intervale d'un second jeu de données temporel."
 #: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1899
-#, fuzzy
 msgid "Sampling"
-msgstr "Unités de carte"
+msgstr "Échantillonnage"
 #: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1900
 #, fuzzy
 msgid "Temporal sampling"
+msgstr "Échantillonnage temporel"
 #: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1901
 #, fuzzy
@@ -10302,12 +10278,12 @@
 #: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1902
 #, fuzzy
 msgid "Query raster dataset by vector points dataset"
-msgstr "Échantillonne une carte raster au droit des points d'une carte vecteur."
+msgstr "Échantillonne une carte raster par des points vectoriels"
 #: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1903
 #, fuzzy
 msgid "Stores raster map values at spatial and temporal positions of vector points as vector attributes."
-msgstr "Ajouter dans la table les valeurs de raster à la position des points du vecteur."
+msgstr "Stocker les valeurs raster aux positions spatiales et temporelles de points vectoriels, en tant que données attributaire."
 #: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1904
 msgid "Observe specific locations in raster dataset"
@@ -10320,78 +10296,75 @@
 #: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1907
 #, fuzzy
 msgid "Space time datasets metadata"
+msgstr "Méta-données de jeux de données temporels"
 #: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1908
 #, fuzzy
 msgid "Lists information about space time datasets and maps."
-msgstr "Afficher les informations élémentaire d'une carte raster."
+msgstr "Afficher les informations sur les jeux de données et cartes temporelles."
 #: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1909
-#, fuzzy
 msgid "Univariate raster dataset statistics"
 msgstr "Statistiques raster univariées"
 #: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1910
 #, fuzzy
 msgid "Calculates univariate statistics from the non-null cells for each registered raster map of a space time raster dataset."
-msgstr "Calculer les statistiques univariées pour les cellules non nulles de la carte raster."
+msgstr "Calculer les statistiques univariées pour les cellules non nulles de chaque carte raster enregistrée dans un jeux de données temporel."
 #: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1911
-#, fuzzy
 msgid "Univariate vector dataset statistics"
-msgstr "Statistiques raster univariées"
+msgstr "Statistiques univariées vectorielles"
 #: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1912
 #, fuzzy
 msgid "Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset"
-msgstr "Calcule les statistiques univariées sur la colonne sélectionnée."
+msgstr "Calcule les statistiques univariées des attributs de chaque carte vectorielle enregistrée dans un jeux de données vectorielles temporel"
 #: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1913
-#, fuzzy
 msgid "Univariate raster3D dataset statistics"
+msgstr "Statistiques univariées raster3D"
 #: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1914
 #, fuzzy
 msgid "Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset."
+msgstr "Calculer les statistiques univariées pour les cellules non nulles de chaque carte raster3D enregistrée dans un jeux de données raster3D temporel."
 #: ../gui/wxpython/menustrings.py:1002 ../gui/wxpython/menustrings.py:1915
 #, fuzzy
 msgid "Report temporal topology"
-msgstr "Envoyer ou charger la topologie"
+msgstr "Compte-rendu de topologie temporelle"
 #: ../gui/wxpython/menustrings.py:1003 ../gui/wxpython/menustrings.py:1916
 #, fuzzy
 msgid "Lists temporal topology of a space time dataset."
-msgstr "Lister toutes les tables d'une base de données"
+msgstr "Lister la topologie temporelle d'un jeu de données temporel"
 #: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1917
 #: ../gui/wxpython/menustrings.py:1924
 #, fuzzy
 msgid "GUI tools"
-msgstr "Interface graphique"
+msgstr "Outils d'interface graphique"
 #: ../gui/wxpython/menustrings.py:1007 ../gui/wxpython/menustrings.py:1920
 #, fuzzy
 msgid "Timeline tool"
-msgstr "Barre d'outils pour les cartes"
+msgstr "Barre d'outils temporelle"
 #: ../gui/wxpython/menustrings.py:1008 ../gui/wxpython/menustrings.py:1921
 #, fuzzy
 msgid "Plot temporal extents."
-msgstr "Afficher les limites de calculs"
+msgstr "Afficher l'emprise temporelle."
 #: ../gui/wxpython/menustrings.py:1009 ../gui/wxpython/menustrings.py:1922
 #, fuzzy
 msgid "Temporal plot tool"
-msgstr "Histogramme GRASS"
+msgstr "Outil d'affichage temporel"
 #: ../gui/wxpython/menustrings.py:1010 ../gui/wxpython/menustrings.py:1923
 #, fuzzy
 msgid "Plot temporal values."
+msgstr "Afficher les valeurs temporelles."
 #: ../gui/wxpython/menustrings.py:1011 ../gui/wxpython/menustrings.py:1984
 #: ../gui/wxpython/menustrings.py:2027
@@ -10420,19 +10393,16 @@
 msgstr "Afficher les informations système"
 #: ../gui/wxpython/menustrings.py:1022
-#, fuzzy
 msgid "Import, export and link data"
+msgstr "Importer, exporter et lier les données"
 #: ../gui/wxpython/menustrings.py:1927
-#, fuzzy
 msgid "Attribute table manager"
 msgstr "Gestionnaire de table attributaire"
 #: ../gui/wxpython/menustrings.py:1928
-#, fuzzy
 msgid "Launches graphical attribute table manager."
-msgstr "Gestionnaire de table attributaire"
+msgstr "Lances le gestionnaire graphique de table attributaire"
 #: ../gui/wxpython/menustrings.py:1943
 msgid "Create new model"
@@ -10519,9 +10489,8 @@
 msgstr "Ajouter une condition (if/else) au modèle"
 #: ../gui/wxpython/menustrings.py:1973
-#, fuzzy
 msgid "Adds comment to model"
-msgstr "Ajouter une condition (if/else) au modèle"
+msgstr "Ajouter un commentaire au modèle"
 #: ../gui/wxpython/menustrings.py:1974
 msgid "Remove item"
@@ -10573,28 +10542,24 @@
 msgstr "Afficher les informations concernant le Modeleur Graphique"
 #: ../gui/wxpython/menustrings.py:1994
-#, fuzzy
 msgid "Load instruction file"
-msgstr "Impossible de lire les instructions %s"
+msgstr "Charger un fichier d'instructions"
 #: ../gui/wxpython/menustrings.py:1996
-#, fuzzy
 msgid "Export instruction file"
-msgstr "Exporter en image"
+msgstr "Exporter un fichier d'instructions"
 #: ../gui/wxpython/menustrings.py:1998
-#, fuzzy
 msgid "Export to PostScript"
-msgstr "Exporter le modèle dans un script Python"
+msgstr "Exporter en PostScript"
 #: ../gui/wxpython/menustrings.py:2000
 msgid "Export to PDF"
 msgstr "Exporter en PDF"
 #: ../gui/wxpython/menustrings.py:2002 ../gui/wxpython/menustrings.py:2003
-#, fuzzy
 msgid "Launch ps.map dialog"
-msgstr "Lancer un script"
+msgstr "Lancer la boite de dialogue ps.map"
 #: ../gui/wxpython/menustrings.py:2005
 msgid "Close Cartographic Composer"
@@ -10754,7 +10719,7 @@
 #: ../gui/wxpython/animation/toolbars.py:49
 #, fuzzy
 msgid "Add space-time dataset or series of map layers"
-msgstr "Ajouter une carte en relief ombré"
+msgstr "Ajouter un jeu de données temporel ou une série de cartes"
 #: ../gui/wxpython/animation/toolbars.py:50
 msgid "Add space-time dataset or series of map layers for animation"
@@ -10770,9 +10735,9 @@
 "Fichier non valide, impossible d'analyser le document XML."
 #: ../gui/wxpython/animation/nviztask.py:51
-#, fuzzy, python-format
+#, python-format
 msgid "No 3d view information in workspace file <%s>."
-msgstr "Paramètres de vue 3D enregistrés dans le fichier %s."
+msgstr "Pas d'information de vue 3D dans le fichier d'espace de travail <%s>."
 #: ../gui/wxpython/animation/nviztask.py:259
 msgid "Please add only one layer in the list."
@@ -10781,7 +10746,7 @@
 #: ../gui/wxpython/animation/nviztask.py:265
 #, fuzzy
 msgid "No map series nor space-time dataset is added."
-msgstr "données."
+msgstr "Pas de séries de carte ou de jeux de données temporels ajoutés."
 #: ../gui/wxpython/animation/data.py:44 ../gui/wxpython/mapdisp/toolbars.py:86
 #: ../gui/wxpython/mapdisp/toolbars.py:288
@@ -10798,7 +10763,7 @@
 #: ../gui/wxpython/animation/data.py:65
 #, fuzzy
 msgid "No animation name selected."
-msgstr "Pas d'image sélectionnée."
+msgstr "Pas de nom défini pour l'animation."
 #: ../gui/wxpython/animation/data.py:131
 msgid "No workspace file selected."
@@ -10825,7 +10790,7 @@
 #: ../gui/wxpython/animation/dialogs.py:100
 #, fuzzy
 msgid "Frame duration:"
-msgstr "Taux de rafraichissement (FPS) :"
+msgstr "Durée d'une frame :"
 #: ../gui/wxpython/animation/dialogs.py:101
 #: ../gui/wxpython/animation/dialogs.py:124
@@ -10835,7 +10800,7 @@
 #: ../gui/wxpython/animation/dialogs.py:118
 #, fuzzy
 msgid "Temporal mode"
+msgstr "Mode temporel"
 #: ../gui/wxpython/animation/dialogs.py:122
 msgid "Time unit:"
@@ -10973,7 +10938,7 @@
 #: ../gui/wxpython/animation/dialogs.py:549
 #, fuzzy
 msgid "No map series or space-time dataset added."
-msgstr "données."
 #: ../gui/wxpython/animation/dialogs.py:577
 msgid "Region information is not complete"
@@ -11206,7 +11171,7 @@
 #: ../gui/wxpython/animation/dialogs.py:1525
 #, fuzzy
 msgid "Absolute time format:"
-msgstr "Format des coordonnées"
+msgstr "Format de date absolue :"
 #: ../gui/wxpython/animation/dialogs.py:1535
 #, fuzzy
@@ -11766,7 +11731,7 @@
 #: ../gui/wxpython/modules/colorrules.py:425
 #, fuzzy
 msgid "&Set"
-msgstr "Paramètres"
+msgstr "Définir"
 #: ../gui/wxpython/modules/colorrules.py:432
 msgid "Load color table:"
@@ -12208,23 +12173,20 @@
 msgstr "'Copier les coordonnées dans le presse-papier"
 #: ../gui/wxpython/mapwin/buffered.py:240
-#, fuzzy
 msgid "Hide all toolbars"
-msgstr "Barre d'outil des points"
+msgstr "Cacher toutes les barres d'outils"
-#, fuzzy
 msgid "Show all toolbars"
-msgstr "Tour copier dans le presse-papier"
+msgstr "Afficher toutes les barres d'outils"
 #: ../gui/wxpython/mapwin/buffered.py:244
 msgid "Hide statusbar"
 msgstr "Cacher la barre de status"
-#, fuzzy
 msgid "Show statusbar"
-msgstr "Montrer les paramètres"
+msgstr "Afficher la barre de status"
 #: ../gui/wxpython/mapwin/buffered.py:258
 #, python-brace-format
@@ -12477,9 +12439,8 @@
 msgstr "Notez que le module de digitalisation de wxGUI est actuellement indisponible (en espérant que cela soit prochainement résolu). Merci de garder un œil sur les mises à jour de GRASS. En attendant, vous pouvez utiliser le module \"v.digit\", accessible depuis le menu Vecteur."
 #: ../gui/wxpython/mapdisp/toolbars.py:119
-#, fuzzy
 msgid "Raster digitizer"
-msgstr "Quitter l'outil d'édition"
+msgstr "Numérisation de raster"
 #: ../gui/wxpython/mapdisp/gprint.py:150
 msgid ""
@@ -12495,9 +12456,9 @@
 msgstr "Commande %s non prise en charge."
 #: ../gui/wxpython/mapdisp/main.py:209
+#, python-format
 msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
-msgstr "Impossible de lire le fichier de commandes '%(cmd)s'. Détails: %(det)s"
+msgstr "Impossible de lire le fichier de commandes '%(cmd)s'. Détails : %(det)s"
 #: ../gui/wxpython/mapdisp/main.py:490
 #, python-format
@@ -12505,9 +12466,9 @@
 msgstr "Lancement d'un nouvel affichage <%s>..."
 #: ../gui/wxpython/mapdisp/main.py:496
+#, python-format
 msgid "Unable to create file <%s>"
-msgstr "Impossible de créer le fichier '%s'\n"
+msgstr "Impossible de créer le fichier <%s>"
 #: ../gui/wxpython/mapdisp/main.py:512
 #, python-format
@@ -12714,9 +12675,8 @@
 msgstr "Enregistrer la région calculée vers un nom de région"
 #: ../gui/wxpython/mapdisp/frame.py:1525
-#, fuzzy
 msgid "Raster Digitizer Toolbar"
-msgstr "Barre d'outils de numérisation de vecteur"
+msgstr "Barre d'outils de numérisation de raster"
 #: ../gui/wxpython/nviz/tools.py:88 ../gui/wxpython/nviz/preferences.py:56
 #: ../gui/wxpython/nviz/preferences.py:61
@@ -13595,9 +13555,8 @@
 msgstr "carte raster 3d <%s> non trouvée"
 #: ../gui/wxpython/rdigit/controller.py:116
-#, fuzzy
 msgid "Please select first the raster map"
-msgstr "Merci de créer d'abord le cadre de carte."
+msgstr "Merci de commencer par sélectionner la carte raster"
 #: ../gui/wxpython/rdigit/controller.py:148
 msgid "Right click to finish area"
@@ -13608,24 +13567,20 @@
 msgstr "Clic droit pour terminer la ligne"
 #: ../gui/wxpython/rdigit/controller.py:280
-#, fuzzy
 msgid "Do you want to save changes?"
-msgstr "Voulez-vous enregistrer les modifications du modèle ?"
+msgstr "Voulez-vous enregistrer les modifications ?"
 #: ../gui/wxpython/rdigit/controller.py:281
-#, fuzzy
 msgid "Save raster map changes"
-msgstr "Sauvegarder les modifications"
+msgstr "Enregistrer les modifications de la carte raster"
 #: ../gui/wxpython/rdigit/controller.py:347
-#, fuzzy
 msgid "Failed to create backup copy of edited raster map."
-msgstr "Impossible de créer le profil de carte raster."
+msgstr "Échec de création de la copie de sauvegarde de la carte raster en modification."
 #: ../gui/wxpython/rdigit/controller.py:365
-#, fuzzy
 msgid "Failed to create new raster map."
-msgstr "Impossible de créer la carte vecteur <%s>."
+msgstr "Échec de création de la nouvelle carte raster."
 #: ../gui/wxpython/rdigit/controller.py:439
 #: ../gui/wxpython/rdigit/controller.py:463
@@ -13634,29 +13589,24 @@
 msgstr "Générer (l'affichage)"
 #: ../gui/wxpython/rdigit/controller.py:486
-#, fuzzy
 msgid "Failed to set default color table for edited raster map"
-msgstr "Créer une nouvelle table de couleur pour une carte raster"
+msgstr "Échec de définition de la table de couleur par défaut pour la carte raster modifiée"
 #: ../gui/wxpython/rdigit/toolbars.py:27
-#, fuzzy
 msgid "Digitize area"
-msgstr "Digitaliser une nouvelle ligne"
+msgstr "Numériser une surface"
 #: ../gui/wxpython/rdigit/toolbars.py:29
-#, fuzzy
 msgid "Digitize line"
-msgstr "Numériser une nouvelle ligne"
+msgstr "Numériser une ligne"
 #: ../gui/wxpython/rdigit/toolbars.py:31
-#, fuzzy
 msgid "Digitize point"
-msgstr "Numériser un nouveau point"
+msgstr "Numériser un point"
 #: ../gui/wxpython/rdigit/toolbars.py:32
-#, fuzzy
 msgid "Save raster map"
-msgstr "Empaqueter des cartes raster"
+msgstr "Enregistrer la carte raster"
 #: ../gui/wxpython/rdigit/toolbars.py:33
 #: ../gui/wxpython/vdigit/toolbars.py:174
@@ -13664,42 +13614,36 @@
 msgstr "Annuler"
 #: ../gui/wxpython/rdigit/toolbars.py:34
-#, fuzzy
 msgid "Quit raster digitizer"
+msgstr "Quitter l'outil d'édition raster"
 #: ../gui/wxpython/rdigit/toolbars.py:49
-#, fuzzy
 msgid "Select raster map"
-msgstr "Sélectionner une carte raster:"
+msgstr "Sélectionner une carte raster"
 #: ../gui/wxpython/rdigit/toolbars.py:60
 msgid "Set drawing color (not raster cell color)"
 msgstr "Définir la couleur de dessin (pas la couleur des cellules du raster)"
 #: ../gui/wxpython/rdigit/toolbars.py:73
-#, fuzzy
 msgid "Cell value:"
-msgstr "Valeurs de cellule"
+msgstr "Valeurs de cellule :"
 #: ../gui/wxpython/rdigit/toolbars.py:83
 msgid "Width of currently digitized line or diameter of a digitized point in map units."
 msgstr ""
 #: ../gui/wxpython/rdigit/toolbars.py:120
-#, fuzzy
 msgid "New raster map"
-msgstr "pas de carte raster"
+msgstr "Nouvelle carte raster"
 #: ../gui/wxpython/rdigit/dialogs.py:33
-#, fuzzy
 msgid "Create new raster map"
-msgstr "Créer un nouvelle carte vecteur"
+msgstr "Créer un nouvelle carte raster"
 #: ../gui/wxpython/rdigit/dialogs.py:52
-#, fuzzy
 msgid "Name for new raster map:"
-msgstr "Nom de la carte raster:"
+msgstr "Nom de la nouvelle carte raster :"
 #: ../gui/wxpython/rdigit/dialogs.py:55
 #, fuzzy
@@ -13707,19 +13651,17 @@
 msgstr "Sélectionner une carte vecteur"
 #: ../gui/wxpython/rdigit/dialogs.py:58
-#, fuzzy
 msgid "New raster map type:"
+msgstr "Type de la nouvelle carte raster :"
 #: ../gui/wxpython/rdigit/dialogs.py:87
-#, fuzzy
 msgid "Please specify name for a new raster map"
-msgstr "Calcule l'indice de forme sur une carte raster"
+msgstr "Merci d'indiquer un nom pour la nouvelle carte raster"
 #: ../gui/wxpython/rdigit/dialogs.py:92
+#, python-format
 msgid "Raster map <%s> already exists in the current mapset. Do you want to overwrite it?"
-msgstr "La carte vecteur <%s> existe déjà dans le jeu de cartes courant.  Voulez-vous l'écraser ?"
+msgstr "La carte raster <%s> existe déjà dans le jeu de cartes courant.  Voulez-vous l'écraser ?"
 #: ../gui/wxpython/wxplot/base.py:39
 msgid "Draw/re-draw plot"
@@ -14148,7 +14090,7 @@
 #: ../gui/wxpython/tplot/frame.py:140
 #, fuzzy
 msgid "Select space time raster dataset(s):"
-msgstr "Choisir le jeu de cartes source:"
+msgstr "Choisir le jeu de données temporel :"
 #: ../gui/wxpython/tplot/frame.py:174 ../gui/wxpython/timeline/frame.py:162
@@ -14171,7 +14113,7 @@
 #: ../gui/wxpython/tplot/frame.py:258 ../gui/wxpython/timeline/frame.py:325
 msgid "Time [%s]"
-msgstr "Date et heure"
+msgstr "Date [%s]"
 #: ../gui/wxpython/tplot/frame.py:281 ../gui/wxpython/timeline/frame.py:350
 #: ../gui/wxpython/timeline/frame.py:448
@@ -14185,7 +14127,7 @@
 #: ../gui/wxpython/tplot/frame.py:295 ../gui/wxpython/tplot/frame.py:390
 #, fuzzy
 msgid "Invalid input coordinates"
-msgstr "Entrée non valide"
+msgstr "Coordonnées en entrée non valides"
 #: ../gui/wxpython/tplot/frame.py:346 ../gui/wxpython/timeline/frame.py:417
 #, python-format
@@ -14199,7 +14141,7 @@
 #: ../gui/wxpython/tplot/frame.py:385
 #, fuzzy
 msgid "Invalid input temporal dataset"
+msgstr "Jeux de données temporel en entrée non valide"
 #: ../gui/wxpython/tplot/frame.py:410
 msgid "Datasets have different number ofvalues"
@@ -14208,17 +14150,17 @@
 #: ../gui/wxpython/tplot/frame.py:434 ../gui/wxpython/timeline/frame.py:500
 msgid "Space time raster dataset: %s"
+msgstr "Jeux de données raster temporel : %s"
 #: ../gui/wxpython/tplot/frame.py:436 ../gui/wxpython/timeline/frame.py:502
 msgid "Space time vector dataset: %s"
+msgstr "Jeux de données vecteur temporel : %s"
 #: ../gui/wxpython/tplot/frame.py:438 ../gui/wxpython/timeline/frame.py:504
 msgid "Space time 3D raster dataset: %s"
+msgstr "Jeux de données raster 3D temporel : %s"
 #: ../gui/wxpython/tplot/frame.py:440
@@ -14362,7 +14304,7 @@
 #: ../gui/wxpython/lmgr/layertree.py:619
 #, fuzzy
 msgid "Report raster statistics"
-msgstr "Compte-rendu et statistiques"
+msgstr "Compt-rendu de statistiques raster"
 #: ../gui/wxpython/lmgr/layertree.py:625
 msgid "Profile"
@@ -14766,9 +14708,8 @@
 "\"%s\""
 #: ../gui/wxpython/lmgr/frame.py:1001
-#, fuzzy
 msgid "Changes current working directory for this GUI."
-msgstr "Modifier le dossier de travail pour cette Interface Graphique"
+msgstr "Modifier le dossier de travail pour cette Interface Graphique."
 #: ../gui/wxpython/lmgr/frame.py:1003
 msgid "Usage: cd [directory]"
@@ -14865,7 +14806,7 @@
 msgstr "GRASS GIS {version} - Fenêtre de carte : {name} - Secteur : {loc}"
 #: ../gui/wxpython/lmgr/frame.py:1586
+#, python-format
 msgid ""
 "Unable to launch \"Supervised Classification Tool\".\n"
 "\n"
@@ -14873,21 +14814,17 @@
 msgstr ""
 "Impossible de lancer l' « Outil de classification supervisée ».\n"
 "\n"
-"Raison: %s"
+"Raison : %s"
 #: ../gui/wxpython/lmgr/frame.py:1626
 #, fuzzy
 msgid "Unable to start Timeline Tool."
-msgstr ""
-"Impossible d'insérer le nouvel enregistrement.\n"
-"%s"
+msgstr "Impossible de démarrer l'outil Temporel"
 #: ../gui/wxpython/lmgr/frame.py:1636
 #, fuzzy
 msgid "Unable to start Temporal Plot Tool."
-msgstr ""
-"%s"
+msgstr "Impossible de démarrer l'outil d'affichage temporel"
 #: ../gui/wxpython/lmgr/frame.py:1864
 msgid "Add selected map layers into layer tree"
@@ -14950,7 +14887,7 @@
 #: ../gui/wxpython/lmgr/datacatalog.py:334
 #, fuzzy
 msgid "Editing"
-msgstr "Validation du modèle ..."
+msgstr "Modification"
 #: ../gui/wxpython/lmgr/datacatalog.py:357
 #, fuzzy
@@ -15040,7 +14977,7 @@
 #: ../gui/wxpython/timeline/frame.py:139
 #, fuzzy
 msgid "Select space time dataset(s):"
-msgstr "Choisir le jeu de cartes source :"
+msgstr "Choisir le jeux de données temporel :"
 #: ../gui/wxpython/timeline/frame.py:264
 #, python-format
