[GRASS-SVN] r65880 - grass/trunk/scripts/g.extension
Mon Aug 10 11:10:21 PDT 2015
Author: wenzeslaus
Date: 2015-08-10 11:10:21 -0700 (Mon, 10 Aug 2015)
New Revision: 65880
   grass/trunk/scripts/g.extension/g.extension.html
   grass/trunk/scripts/g.extension/g.extension.py
g.extension: add and improve messages and docs
Modified: grass/trunk/scripts/g.extension/g.extension.html
--- grass/trunk/scripts/g.extension/g.extension.html	2015-08-10 16:28:14 UTC (rev 65879)
+++ grass/trunk/scripts/g.extension/g.extension.html	2015-08-10 18:10:21 UTC (rev 65880)
@@ -3,62 +3,193 @@
 <!-- TODO: the use of Addon and extension is not coherent -->
 <em>g.extension</em> downloads and installs, removes or updates
-extensions (Addons) from the
-<a href="http://svn.osgeo.org/grass/grass-addons/grass7/">GRASS GIS Addons repository</a>
+extensions (addons) from the official
+<a href="http://grass.osgeo.org/grass70/manuals/addons/">GRASS GIS Addons repository</a>
+or user-specified source
 into the local GRASS GIS installation.
+<h3>Managing installed extensions</h3>
 <p>Re-running <em>g.extension</em> on an installed GRASS GIS Addon
 extension re-installs the requested extension which may include
 updates.
 <p>
-In order to bulk-update all locally installed GRASS GIS extensions, they can
-be re-installed altogether by the
-<em><a href="g.extension.all.html">g.extension.all</a></em> module.
+To bulk-update all locally installed GRASS GIS extensions,
+<em><a href="g.extension.all.html">g.extension.all</a></em> module
+is available.
-<h2>NOTES</h2>
-GRASS GIS extensions are installed by <tt>g.extension</tt> into a dedicated
-directory (GRASS_ADDON_BASE). The default on GNU/Linux is
-<tt>$HOME/.grass7/addons</tt>, on MS-Windows it is
-<tt>$APPDATA\GRASS7\addons</tt>.
+<h3>Where the extensions are installed</h3>
+GRASS GIS extensions are installed by <em>g.extension</em> into a dedicated
+directory.
+The default is a directory for application data and settings inside
+the user's home directory.
+On GNU/Linux it is <tt>$HOME/.grass7/addons</tt>,
+on MS Windows it is <tt>$APPDATA\GRASS7\addons</tt>.
+The directory is stored in <tt>GRASS_ADDON_BASE</tt> environmental variable.
 <p>
 The flag <b>-s</b> changes this install target directory to the GRASS GIS
-installation directory (GISBASE, e.g. <tt>/usr/</tt>) rather than the
-default GRASS_ADDON_BASE directory (see also <a href="variables.html">variables</a>).
+installation directory
+(determined by <tt>GISBASE</tt> environmental variable, e.g. <tt>/usr/</tt>)
+rather than the
+default GRASS_ADDON_BASE directory
+(see also documentation for <a href="variables.html">variables</a>).
 <em>g.extension</em> checks if the user has permission to write to
 GISBASE or GRASS_ADDON_BASE.
 <p>
-On MS-Windows systems, <em>g.extension</em> downloads an executable from
-the GRASS GIS project server. On all other operating systems, it downloads the
-source code of the requested Addon and compiles it locally.
+The place where the extensions are installed can be customized by
+the option <b>prefix</b>. Ensuring that these extensions will be accessible
+in GRASS GIS is then responsibility of the user.
+<h3>Source code sources and repositories</h3>
+By default, <em>g.extension</em> installs extensions from the official
+GRASS GIS Addons repository. However, different source can be specified
+using the <b>url</b> option.
+<p>
+New extension can be also installed from a source code placed
+in a local directory on disk. This is advantageous when developing
+a new module.
+To keep the directory clean, the directory content is copied
+to a temporary directory and the compilation happens there.
+<p>
+New extension can be also installed from a ZIP file
+or an archive file from the TAR family (e.g., <tt>.tar.gz</tt> or <tt>.bz2</tt>).
+The file can be a file on disk (specified a path), which was probably downloaded
+at some point, or a file on web (specified by an URL).
+<p>
+For well known general hosting services, namely GitHub, GitLab and Bitbucket,
+<em>g.extension</em> supports download of a repository as a ZIP file
+when user needs to provide only a basic URL to the repository web page
+(with or without the <tt>https://</tt> part).
+For GitLab and Bitbucket, the latest source code in the default branch is downloaded,
+for GitHub, the latest source code in the master branch is downloaded.
+Of course, user can still specify full URL of a ZIP file
+and install a specific branch or release in this way (ZIP file mechanism will be applied).
+<p>
+Individual extensions can be also installed by providing a URL to
+source code on OSGeo Trac. This, however, works only for certain directories
+where download of a downloads a ZIP file was enabled by project administrators.
+<p>
+When none of the above sources is identified, <em>g.extension</em> assumes
+that the source is a Subversion repository and uses <em>svn</em> command line tool
+to obtain the source code. The expected structure of the repository
+should be the same as the one of the official repository.
+<p>
+For the official repository, <em>g.extension</em> supports listing available
+extensions (addons) and few other metadata-related operations which
+depend on a specific infrastructure.
+For other sources and repositories, this is not supported because it is assumed
+that other sources contain only one extension, typically a module or group of modules.
+<p>
+Non-official sources are supported on all operating systems except for MS Windows.
+<h3>Compilation and installation</h3>
+On MS Windows systems, where compilation tools not readily available,
+<em>g.extension</em> downloads a compiled executable
+from the GRASS GIS project server. On all other operating systems
+where it is not difficult to install compilation tools,
+<em>g.extension</em> downloads the source code of the requested
+extension (addon) and compiles it locally.
+This applies for both C and Python modules
+as well as any other extensions. The reason is that more things such
+as manual page are compiled, not only the source code (which is really
+necessary to compile just in case of C).
 <h2>EXAMPLES</h2>
 <h3>Download and install of an extension</h3>
 Download and install <em>r.stream.distance</em> into current GRASS installation
 <div class="code"><pre>
 g.extension extension=r.stream.distance
 </pre></div>
-<h3>Removal of a locally installed extension</h3>
+This installs the extension from the official repository.
+For convenience, a shorter syntax can be used:
-g.extension extension=r.stream.distance operation=remove
+g.extension r.stream.distance
 </pre></div>
-<h3>List all available extensions from GRASS Addons SVN repository</h3>
+<h3>Managing the extensions</h3>
+List all available extensions in the official GRASS GIS Addons repository:
 g.extension -l
 </pre></div>
-<h3>List all locally installed extensions</h3>
+List all locally installed extensions:
 g.extension -a
 </pre></div>
+Removal of a locally installed extension:
+<div class="code"><pre>
+g.extension extension=r.stream.distance operation=remove
+</pre></div>
+<h3>Installing from various repositories online</h3>
+Simple URL to GitHub, GitLab, Bitbucket repositories:
+g.extension r.example url=github.com/johnsmith/r.example
+</pre></div>
+Simple URL to OSGeo Trac (downloads a ZIP file, requires download to be enabled in Trac):
+g.extension r.example url=trac.osgeo.org/.../r.example
+</pre></div>
+In general, when a ZIP file or other archive is provided, the full URL can be used:
+g.extension r.example url=http://example.com/.../r.example?format=zip
+</pre></div>
+Note that because of MS Windows operating system architecture,
+only official repository is supported on this platform.
+<h3>Installing when writing a module</h3>
+Having source code of a GRASS module in a directory on disk
+one can install it using:
+g.extension r.example url=/local/directory/r.example/
+</pre></div>
+<h2>KNOWN ISSUES</h2>
+Toolboxes in the official repository cannot be downloaded.
+On MS Windows, only the official repository is working
+because there is no way of compiling the modules
+(a Python replacement for Python scripts should be implemented).
 <h2>SEE ALSO</h2>
 <em>
@@ -73,7 +204,8 @@
 <h2>AUTHORS</h2>
 Markus Neteler (original shell script)<br>
-Martin Landa, Czech Technical University in Prague, Czech Republic (Python rewrite)
+Martin Landa, Czech Technical University in Prague, Czech Republic (Python rewrite)<br>
+Vaclav Petras, <a href="http://gis.ncsu.edu/osgeorel/">NCSU OSGeoREL</a> (support for general sources, partial refactoring)
 <p>
 <i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2015-08-10 16:28:14 UTC (rev 65879)
+++ grass/trunk/scripts/g.extension/g.extension.py	2015-08-10 18:10:21 UTC (rev 65880)
@@ -3,11 +3,11 @@
 # MODULE:       g.extension
-# AUTHOR(S):    Markus Neteler
+# AUTHOR(S):    Markus Neteler (original shell script)
 #               Martin Landa <landa.martin gmail com> (Pythonized & upgraded for GRASS 7)
 #               Vaclav Petras <wenzeslaus gmail com> (support for general sources)
 # PURPOSE:      Tool to download and install extensions into local installation
 # COPYRIGHT:    (C) 2009-2014 by Markus Neteler, and the GRASS Development Team
 #               This program is free software under the GNU General
@@ -48,7 +48,7 @@
 #% key: url
 #% type: string
 #% key_desc: url
-#% label: URL or directory to get the extension from
+#% label: URL or directory to get the extension from (supported only on Linux and Mac)
 #% description: The official repository is used by default. User can specify a ZIP file, directory or a repository on common hosting services. If not identified, Subversion repository is assumed. See manual for all options.
 #%end
 #%option
@@ -70,19 +70,19 @@
 #%flag
 #% key: l
-#% description: List available extensions in the GRASS Addons SVN repository
+#% description: List available extensions in the official GRASS GIS Addons repository
 #% guisection: Print
 #% suppress_required: yes
 #%end
 #%flag
 #% key: c
-#% description: List available extensions in the GRASS Addons SVN repository including module description
+#% description: List available extensions in the official GRASS GIS Addons repository including module description
 #%end
 #%flag
 #% key: g
-#% description: List available extensions in the GRASS Addons SVN repository (shell script style)
+#% description: List available extensions in the official GRASS GIS Addons repository (shell script style)
 #%end
@@ -123,7 +123,9 @@
 #% exclusive: extension, -l, -c, -g, -a
 #%end
+# TODO: solve addon-extension(-module) confusion
 from __future__ import print_function
 import os
 import sys
@@ -145,7 +147,7 @@
     import xml.etree.ElementTree as etree
 except ImportError:
     import elementtree.ElementTree as etree  # Python <= 2.4
-# Get the XML parsing exceptions to catch. The behavior chnaged with Python 2.7
+# Get the XML parsing exceptions to catch. The behavior changed with Python 2.7
 # and ElementTree 1.3.
 from xml.parsers import expat  # TODO: works for any Python?
 if hasattr(etree, 'ParseError'):
@@ -644,9 +646,13 @@
         grass.warning(_('Installation failed, sorry.'
                         ' Please check above error messages.'))
     else:
-        grass.message(_("Updating addons metadata file..."))
-        blist = install_extension_xml(xmlurl, mlist)
-        for module in blist:
+        # for now it is reasonable to assume that only official source
+        # will provide the metadata file
+        if source == 'official':
+            grass.message(_("Updating addons metadata file..."))
+            blist = install_extension_xml(xmlurl, mlist)
+        # the blist was used here, but it seems that it is the same as mlist
+        for module in mlist:
             update_manual_page(module)
         grass.message(_("Installation of <%s> successfully finished") %
@@ -996,6 +1002,9 @@
 def extract_zip(name, directory, tmpdir):
     """Extract a ZIP file into a directory"""
+    gscript.debug("extract_zip(name={name}, directory={directory},"
+                  " tmpdir={tmpdir})".format(name=name, directory=directory,
+                                             tmpdir=tmpdir), 3)
     try:
         zip_file = zipfile.ZipFile(name, mode='r')
         file_list = zip_file.namelist()
@@ -1016,6 +1025,9 @@
 # TODO: solve the other related formats
 def extract_tar(name, directory, tmpdir):
     """Extract a TAR or a similar file into a directory"""
+    gscript.debug("extract_tar(name={name}, directory={directory},"
     try:
         import tarfile  # we don't need it anywhere else
         tar = tarfile.open(name)
@@ -1034,6 +1046,9 @@
 def download_source_code(source, url, name, outdev,
                          directory=None, tmpdir=None):
     """Get source code to a local directory for compilation"""
+    gscript.verbose("Downloading source code for <{name}> from <{url}>"
+                    " which is identified as '{source}' type of source..."
+                    .format(source=source, url=url, name=name))
     if source == 'svn':
         download_source_code_svn(url, name, outdev, directory)
     elif source in ['remote_zip', 'official']:
@@ -1070,8 +1085,12 @@
 def install_extension_std_platforms(name, source, url):
     """Install extension on standard plaforms"""
     gisbase = os.getenv('GISBASE')
-    grass.message(_("Fetching <%s> from"
-                    " GRASS-Addons SVN repository (be patient)...") % name)
+        gscript.message(_("Fetching <%s> from "
+                          "GRASS GIS Addons repository (be patient)...") % name)
+    else:
+        gscript.message(_("Fetching <{name}> from "
+                          "<{url}> (be patient)...").format(name=name, url=url))
     # to hide non-error messages from subprocesses
     if grass.verbosity() <= 2:
