[GRASS-SVN] r65934 - in grass-addons/grass7/gui/wxpython/wx.metadata: db.csw.admin g.gui.cswbrowser g.gui.metadata mdlib r.info.iso
Fri Aug 14 09:14:42 PDT 2015
Author: krejcmat
Date: 2015-08-14 09:14:42 -0700 (Fri, 14 Aug 2015)
New Revision: 65934
   grass-addons/grass7/gui/wxpython/wx.metadata/db.csw.admin/db.csw.admin.py
   grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py
   grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswutil.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdftheme.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdutil.py
   grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py
wx.metadata addons: fix path, rm guiparser,add empty line
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/db.csw.admin/db.csw.admin.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/db.csw.admin/db.csw.admin.py	2015-08-14 15:53:34 UTC (rev 65933)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/db.csw.admin/db.csw.admin.py	2015-08-14 16:14:42 UTC (rev 65934)
@@ -14,7 +14,7 @@
-# %module
+#%module
 #% description: CSW database manager
 #% keyword: csw
 #% keyword: metadata
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py	2015-08-14 15:53:34 UTC (rev 65933)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.cswbrowser/g.gui.cswbrowser.py	2015-08-14 16:14:42 UTC (rev 65934)
@@ -47,4 +47,4 @@
 if __name__ == '__main__':
     grass.parser()
-    main()
\ No newline at end of file
+    main()
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py	2015-08-14 15:53:34 UTC (rev 65933)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/g.gui.metadata/g.gui.metadata.py	2015-08-14 16:14:42 UTC (rev 65934)
@@ -21,18 +21,10 @@
 @author Matej Krejci <matejkrejci gmail.com> (GSoC 2014)
-# %module
-# % description: Tool for creating and modifying map's metadata.
-#% keyword: general
-#% keyword: GUI
-#% keyword: metadata
-#%end
 import sys
 import os
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'wx.metadata' 'mdlib'))
+sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc','wx.metadata','mdlib'))
 from lxml import etree
 import wx
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py	2015-08-14 15:53:34 UTC (rev 65933)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py	2015-08-14 16:14:42 UTC (rev 65934)
@@ -1155,4 +1155,4 @@
 class AutoWidthListCtrl(wx.ListCtrl, ListCtrlAutoWidthMixin):
     def __init__(self, parent):
         wx.ListCtrl.__init__(self, parent, -1, style=wx.LC_REPORT | wx.BORDER_SUNKEN)
-        ListCtrlAutoWidthMixin.__init__(self)
+        ListCtrlAutoWidthMixin.__init__(self)
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswutil.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswutil.py	2015-08-14 15:53:34 UTC (rev 65933)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswutil.py	2015-08-14 16:14:42 UTC (rev 65934)
@@ -125,4 +125,4 @@
     else:
         value = '%s 1' % input_string
-    return value
+    return value
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdftheme.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdftheme.py	2015-08-14 15:53:34 UTC (rev 65933)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdftheme.py	2015-08-14 16:14:42 UTC (rev 65934)
@@ -332,5 +332,3 @@
         pdf = buffer.getvalue()
         buffer.close()
         return pdf
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdutil.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdutil.py	2015-08-14 15:53:34 UTC (rev 65933)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdutil.py	2015-08-14 16:14:42 UTC (rev 65934)
@@ -471,4 +471,4 @@
                 elif tagval == 'SV_ServiceIdentification':
                     self.identificationinfo.append(SV_ServiceIdentification(val))
-            val = md.find(util.nspath_eval('gmd:distributionInfo/gmd:MD_Distribution', namespaces))
+            val = md.find(util.nspath_eval('gmd:distributionInfo/gmd:MD_Distribution', namespaces))
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py	2015-08-14 15:53:34 UTC (rev 65933)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py	2015-08-14 16:14:42 UTC (rev 65934)
@@ -84,3 +84,4 @@
 if __name__ == "__main__":
     options, flags = parser()
     main()
