[GRASS-SVN] r65959 - in grass/trunk: . locale/po
Tue Aug 18 03:47:46 PDT 2015
Author: neteler
Date: 2015-08-18 03:47:46 -0700 (Tue, 18 Aug 2015)
New Revision: 65959
Added:
   grass/trunk/locale/po/grasslibs_fi.po
   grass/trunk/locale/po/grassmods_fi.po
   grass/trunk/locale/po/grasswxpy_fi.po
   grass/trunk/translators.csv
Kari Salovaara: Finnish translation started
Added: grass/trunk/locale/po/grasslibs_fi.po
--- grass/trunk/locale/po/grasslibs_fi.po	                        (rev 0)
+++ grass/trunk/locale/po/grasslibs_fi.po	2015-08-18 10:47:46 UTC (rev 65959)
@@ -0,0 +1,8849 @@
+# translation of grasslibs_fi.po to Finnish
+# This file is distributed under the same license as the GRASS GIS package.
+# Copyright (C) 2014-2015 GRASS Development Team
+# Kari Salovaara <kari.salovaara at pp1.inet.fi>, 2015.
+msgid ""
+msgstr ""
+"Project-Id-Version: grasslibs_fi\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2015-07-20 21:44+0200\n"
+"PO-Revision-Date: 2015-08-17 16:24+0300\n"
+"Last-Translator: Kari Salovaara <kari.salovaara at pp1.inet.fi>\n"
+"Language-Team: Finnish <grass-translations at lists.osgeo.org>\n"
+"Language: fi\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"X-Generator: Lokalize 1.5\n"
+#: ../lib/db/dbmi_driver/d_error.c:35
+#, c-format
+msgid "DBMI-%s driver error:"
+msgstr "DBMI-%s ajurin virhe:"
+#: ../lib/db/dbmi_client/copy_tab.c:91
+#, c-format
+msgid "Array of values to select from column <%s> is empty"
+msgstr "Arvotaulukko valittaessa sarakkeesta  <%s> on tyhjä"
+#: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
+#: ../lib/db/dbmi_client/db.c:41 ../lib/vector/Vlib/ascii.c:404
+#: ../lib/vector/Vlib/write_pg.c:2902 ../lib/vector/Vlib/write_ogr.c:192
+#, c-format
+msgid "Unable to start driver <%s>"
+msgstr "Ei voida käynnistää ajuria <%s>"
+#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
+#: ../lib/db/dbmi_client/db.c:46 ../lib/vector/neta/timetables.c:133
+#: ../lib/vector/neta/utils.c:119 ../lib/vector/Vlib/ascii.c:410
+#: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/write_pg.c:2907
+#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/net.c:181
+#: ../lib/vector/Vlib/net.c:358 ../lib/vector/Vlib/write_ogr.c:197
+#: ../lib/vector/Vlib/map.c:305 ../lib/ogsf/gp3.c:208 ../lib/ogsf/gv3.c:350
+#: ../lib/rst/interp_float/vinput2d.c:88
+#, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "Ei voida avata tietokantaa <%s> ajurilla <%s>"
+#: ../lib/db/dbmi_client/copy_tab.c:151
+#, c-format
+msgid "Unable to get list tables in database <%s>"
+msgstr "Ei saada listaa tauluista tietokannasta <%s>"
+#: ../lib/db/dbmi_client/copy_tab.c:167
+#, c-format
+msgid "Table <%s> already exists in database and will be overwritten"
+msgstr "Taulu <%s> on jo olemassa tietokannassa ja päällekirjoitetaan"
+#: ../lib/db/dbmi_client/copy_tab.c:172
+#, c-format
+msgid "Table <%s> already exists in database <%s>"
+msgstr "Taulu <%s> on jo olemassa tietokannassa <%s>"
+#: ../lib/db/dbmi_client/copy_tab.c:218 ../lib/db/dbmi_client/copy_tab.c:295
+#: ../lib/db/dbmi_client/table.c:110 ../lib/vector/Vlib/write_ogr.c:210
+#, c-format
+msgid "Unable to open select cursor: '%s'"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:250
+#, c-format
+msgid "Column <%s> is not integer"
+msgstr "Sarake <%s> ei ole integer (kokonaisluku)"
+#: ../lib/db/dbmi_client/copy_tab.c:267 ../lib/rst/interp_float/vinput2d.c:94
+#: ../lib/rst/interp_float/vinput2d.c:108
+#, c-format
+msgid "Column <%s> not found"
+msgstr "Saraketta <%s> ei löydy"
+#: ../lib/db/dbmi_client/copy_tab.c:270
+#, c-format
+msgid "Unable to create table <%s>"
+msgstr "Ei voida luoda taulua <%s>"
+#: ../lib/db/dbmi_client/copy_tab.c:314 ../lib/vector/Vlib/write_pg.c:2009
+#: ../lib/vector/Vlib/write_ogr.c:585
+#, c-format
+msgid "Unable to fetch data from table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/copy_tab.c:370
+#, c-format
+msgid "Unknown column type (column <%s>)"
+msgstr "Tuntematon saraketyyppi (sarake <%s>)"
+#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
+#, c-format
+msgid "Unable open database <%s> by driver <%s>"
+#: ../lib/db/dbmi_client/column.c:136 ../lib/vector/Vlib/ascii.c:428
+#: ../lib/vector/Vlib/write_pg.c:666 ../lib/python/script/db.py:45
+#, c-format, python-format
+msgid "Unable to describe table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/delete_tab.c:53
+#, c-format
+msgid "Unable to drop table: '%s'"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
+#: ../lib/db/dbmi_client/select.c:288
+msgid "Missing column name"
+msgstr "Puuttuva sarakkeen nimi"
+#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
+msgid "Missing key column name"
+msgstr "Puuttuva avain sarakkeen nimi"
+#: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
+#, c-format
+msgid "Unable select records from table <%s>"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:333
+msgid "Key column type is not integer"
+msgstr ""
+#: ../lib/db/dbmi_base/index.c:180
+msgid "db_set_index_column_name(): invalid column number"
+msgstr ""
+#: ../lib/db/dbmi_base/index.c:197
+msgid "db_get_index_column_name(): invalid column number"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:99
+#, c-format
+msgid "Unable to read file '%s'"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:113
+#, c-format
+msgid "Login file (%s) corrupted (line: %s)"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:142
+#, c-format
+msgid "Unable to write file '%s'"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:72
+msgid "<NULL error message>"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:91
+msgid "dbmi: Protocol error"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:136
+msgid "dbmi: Out of Memory"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:149
+#, c-format
+msgid "dbmi: %s() not implemented"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:163
+#, c-format
+msgid "dbmi: Invalid procedure %d"
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:38
+#, c-format
+msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:45
+#, c-format
+msgid "Illegal table map name <%s>. Must start with a letter."
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:54
+#, c-format
+msgid "Illegal table map name <%s>. Character <%c> not allowed."
+msgstr ""
+#: ../lib/db/dbmi_base/valuefmt.c:52
+msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
+msgstr ""
+#: ../lib/db/dbmi_base/valuefmt.c:91
+msgid "db_convert_value_into_string(): unrecongized sqltype-type"
+msgstr ""
+#: ../lib/db/dbmi_base/xdrtable.c:109
+msgid "fetch: table has wrong number of columns"
+msgstr ""
+#: ../lib/db/dbmi_base/default_name.c:136
+msgid "Programmer error"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_main.c:47
+#: ../lib/vector/rtree/test_suite/test_main.c:44
+#: ../lib/gmath/test/test_main.c:47
+msgid "Choose the unit tests to run"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_main.c:54 ../lib/gmath/test/test_main.c:54
+msgid "Choose the integration tests to run"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_main.c:58 ../lib/gmath/test/test_main.c:79
+msgid "Run all unit tests"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_main.c:62 ../lib/gmath/test/test_main.c:83
+msgid "Run all integration tests"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_main.c:66 ../lib/gmath/test/test_main.c:87
+msgid "Run all unit and integration tests"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_main.c:83
+msgid "Performs unit and integration tests for the dbmi base library"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:37
+msgid ""
+"\n"
+"++ Running column unit tests ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:42
+msgid ""
+"\n"
+"-- column unit tests failure --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:44
+msgid ""
+"\n"
+"-- column unit tests finished successfully --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:57
+msgid ""
+"\n"
+"++ Run test copy column ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:150
+msgid ""
+"\n"
+"++ Test copy column finished ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:38
+msgid ""
+"\n"
+"++ Running table unit tests ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:43
+msgid ""
+"\n"
+"-- Table unit tests failure --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:45
+msgid ""
+"\n"
+"-- Table unit tests finished successfully --"
+msgstr ""
+#: ../lib/db/dbmi_base/xdrvalue.c:82
+msgid "send data: invalid C-type"
+msgstr ""
+#: ../lib/cairodriver/read_xid.c:14
+#, c-format
+msgid "Unable to open input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_xid.c:17
+#, c-format
+msgid "Unable to read input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_xid.c:20
+#, c-format
+msgid "Unable to parse input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/graph.c:67
+msgid "Unable to open display"
+msgstr ""
+#: ../lib/cairodriver/graph.c:85
+msgid "Unable to obtain visual"
+msgstr ""
+#: ../lib/cairodriver/graph.c:160
+#, c-format
+msgid "Unknown file extension: %s"
+msgstr ""
+#: ../lib/cairodriver/graph.c:190
+#, c-format
+msgid "cairo: collecting to file '%s'"
+msgstr ""
+#: ../lib/cairodriver/graph.c:192
+#, c-format
+msgid "cairo: image size %dx%d"
+msgstr ""
+#: ../lib/cairodriver/graph.c:371
+msgid "Unknown Cairo surface type"
+msgstr ""
+#: ../lib/cairodriver/graph.c:376
+msgid "Failed to initialize Cairo surface"
+msgstr ""
+#: ../lib/cairodriver/raster.c:109
+msgid "Failed to create cairo surface"
+msgstr ""
+#: ../lib/cairodriver/draw_bitmap.c:47
+msgid "Cairo_Bitmap: Failed to create source"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:28 ../lib/cairodriver/read_bmp.c:88
+#, c-format
+msgid "Cairo: unable to open input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:32 ../lib/cairodriver/read_bmp.c:92
+#, c-format
+msgid "Cairo: invalid input file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:38
+#, c-format
+msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:46
+#, c-format
+msgid "Cairo: unable to open input mask file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:50
+#, c-format
+msgid "Cairo: invalid input mask file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_ppm.c:56
+#, c-format
+msgid ""
+"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgstr ""
+#: ../lib/cairodriver/write_xid.c:14
+#, c-format
+msgid "Unable to open output file <%s>"
+msgstr ""
+#: ../lib/cairodriver/write_xid.c:19
+#, c-format
+msgid "Unable to write output file <%s>"
+msgstr ""
+#: ../lib/cairodriver/read_bmp.c:96
+#, c-format
+msgid "Cairo: Invalid BMP header for <%s>"
+msgstr ""
+#: ../lib/cairodriver/text.c:46
+#, c-format
+msgid "Unable to convert from <%s> to UTF-8"
+msgstr ""
+#: ../lib/cairodriver/text.c:56
+msgid "Some characters could not be converted to UTF-8"
+msgstr ""
+#: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
+#, c-format
+msgid "Cairo: unable to open output file <%s>"
+msgstr ""
+#: ../lib/cairodriver/write_ppm.c:34
+#, c-format
+msgid "Cairo: unable to open mask file <%s>"
+msgstr ""
+#: ../lib/driver/parse_ftcap.c:84
+#, c-format
+msgid "%s: Unable to read font definition file; use the default"
+msgstr ""
+#: ../lib/driver/parse_ftcap.c:90
+#, c-format
+msgid "%s: No font definition file"
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_main.c:61
+msgid "Unit tests for the vector rtree library"
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_basics.c:40
+msgid ""
+"\n"
+"++ Running basic unit tests ++"
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_basics.c:48
+msgid ""
+"\n"
+"-- Basic rtree unit tests failure --"
+msgstr ""
+#: ../lib/vector/rtree/test_suite/test_basics.c:50
+msgid ""
+"\n"
+"-- Basic rtree unit tests finished successfully --"
+msgstr ""
+#: ../lib/vector/vedit/cats.c:63
+#, c-format
+msgid "Unable to set category %d for (feature id %d)"
+msgstr ""
+#: ../lib/vector/vedit/select.c:231
+msgid "Unknown query tool"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:40
+#, c-format
+msgid "Attempt to delete dead feature (%d)"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:72
+#, c-format
+msgid "No area found for centroid %d"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:76
+#, c-format
+msgid "Duplicate centroid %d, unable to delete area"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:105
+#, c-format
+msgid "Area %d without centroid"
+msgstr ""
+#: ../lib/vector/vedit/delete.c:121
+#, c-format
+msgid "Area %d has no boundaries"
+msgstr ""
+#: ../lib/vector/diglib/port_init.c:158
+#, c-format
+msgid "Unable to find '%x' in %s"
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
+msgid "Topology file must be written before spatial index file"
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:302
+#, c-format
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this spatial index format. "
+"Try to rebuild topology or upgrade GRASS to at least version %d."
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:308
+#, c-format
+msgid ""
+"Your GRASS version does not fully support spatial index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:317
+#, c-format
+msgid ""
+"Spatial index format version %d.%d is not supported by this release. Please "
+"rebuild topology."
+msgstr ""
+#: ../lib/vector/diglib/file.c:159
+msgid "Writing to file loaded to memory not supported"
+msgstr ""
+#: ../lib/vector/diglib/file.c:197
+msgid "Unable to load file to memory, file not open"
+msgstr ""
+#: ../lib/vector/diglib/file.c:212
+msgid "Vector memory mode not supported, using 'AUTO'"
+msgstr ""
+#: ../lib/vector/diglib/cindex_rw.c:156
+#, c-format
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this category index format. "
+msgstr ""
+#: ../lib/vector/diglib/plus_node.c:214
+#, c-format
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
+msgstr ""
+#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
+#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
+msgid "Vector exceeds supported file size limit"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:222
+msgid "Unable read topology for nodes"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:227
+#, c-format
+msgid "Unable to read topology for node %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:232
+msgid "Unable read topology for lines"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:237
+#, c-format
+msgid "Unable to read topology for line %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:242
+msgid "Unable to read topo for areas"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:247
+#, c-format
+msgid "Unable read topology for area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:252
+msgid "Unable to read topology for isles"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:257
+#, c-format
+msgid "Unable to read topology for isle %d"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
+msgid "Unable to write head to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:284
+msgid "Unable to write nodes to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:289
+msgid "Unable to write lines to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:294
+msgid "Unable to write areas to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus.c:299
+msgid "Unable to write isles to plus file"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:215 ../lib/vector/diglib/plus_area.c:711
+#, c-format
+msgid "Line %d already has area/isle %d to left"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:225 ../lib/vector/diglib/plus_area.c:719
+#, c-format
+msgid "Line %d already has area/isle %d to right"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:279
+msgid "Isle already registered in area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:313
+msgid "Attempt to delete isle from dead area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:330
+#, c-format
+msgid "Attempt to delete not registered isle %d from area %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:369
+msgid "Attempt to delete dead area"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:408
+#, c-format
+msgid "Dead centroid %d registered for area (bug in the vector library)"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:431
+#, c-format
+msgid "Attempt to delete area %d info from dead isle %d"
+msgstr ""
+#: ../lib/vector/diglib/plus_area.c:777
+#, c-format
+msgid "Attempt to delete isle %d info from dead area %d"
+msgstr ""
+#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
+#, c-format
+msgid "Vector format not recognized: %s"
+msgstr ""
+#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
+#, c-format
+msgid "Vector format '%s' not supported"
+msgstr ""
+#: ../lib/vector/diglib/frmt.c:97
+#, c-format
+msgid "Format definition is not correct: %s"
+msgstr ""
+#: ../lib/vector/diglib/struct_alloc.c:491
+msgid "Out of memmory"
+msgstr ""
+#: ../lib/vector/diglib/test.c:58
+msgid "Unable to open test.tmp file"
+msgstr ""
+#: ../lib/vector/diglib/test.c:75
+#, c-format
+msgid ""
+"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
+"%.16e3E"
+msgstr ""
+#: ../lib/vector/diglib/test.c:89
+#, c-format
+msgid ""
+"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
+"%.8e3E"
+msgstr ""
+#: ../lib/vector/diglib/test.c:104
+#, c-format
+msgid ""
+"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgstr ""
+#: ../lib/vector/diglib/test.c:119
+#, c-format
+msgid ""
+"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgstr ""
+#: ../lib/vector/diglib/test.c:134
+#, c-format
+msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/test.c:150
+#, c-format
+msgid ""
+"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/test.c:165
+#, c-format
+msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:450
+#, c-format
+msgid "Unable to delete node %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:493
+#, c-format
+msgid "Unable to delete line %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:529
+msgid "Attempt to delete sidx for dead area"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:546
+#, c-format
+msgid "Unable to delete area %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/spindex.c:595
+#, c-format
+msgid "Unable to delete isle %d from spatial index"
+msgstr ""
+#: ../lib/vector/diglib/plus_struct.c:523
+#, c-format
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this topology format. Try "
+"to rebuild topology or upgrade GRASS to at least version %d."
+msgstr ""
+#: ../lib/vector/diglib/plus_struct.c:529
+#, c-format
+msgid ""
+"Your GRASS version does not fully support topology format %d.%d of the "
+msgstr ""
+#: ../lib/vector/diglib/plus_struct.c:539
+#, c-format
+msgid ""
+"Old topology format version %d.%d is not supported by this release. Try to "
+"rebuild topology using v.build or v.build.all module."
+msgstr ""
+#: ../lib/vector/neta/flow.c:64 ../lib/vector/neta/flow.c:179
+#: ../lib/vector/neta/spanningtree.c:99 ../lib/vector/neta/timetables.c:69
+#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
+#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
+#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
+#: ../lib/vector/neta/articulation_point.c:60
+#: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
+#: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
+#: ../lib/vector/neta/path.c:136 ../lib/vector/neta/bridge.c:58
+#: ../lib/vector/Vlib/line.c:50 ../lib/vector/Vlib/line.c:154
+#: ../lib/segment/open.c:98 ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
+#: ../lib/rst/interp_float/segmen2d.c:182
+#: ../lib/rst/interp_float/segmen2d.c:188
+#: ../lib/rst/interp_float/segmen2d.c:194
+#: ../lib/rst/interp_float/segmen2d.c:204
+#: ../lib/rst/interp_float/interp2d.c:121
+#: ../lib/rst/interp_float/interp2d.c:127
+msgid "Out of memory"
+msgstr ""
+#: ../lib/vector/neta/flow.c:310 ../lib/vector/Vlib/graph.c:105
+#: ../lib/vector/Vlib/net.c:444
+msgid "GngFlatten error"
+msgstr ""
+#: ../lib/vector/neta/spanningtree.c:104
+msgid "Computing minimum spanning tree..."
+msgstr ""
+#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
+#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
+#, c-format
+msgid "Unable to open select cursor: %s"
+msgstr ""
+#: ../lib/vector/neta/utils.c:195
+#, c-format
+msgid "Point %d is not connected!"
+msgstr ""
+#: ../lib/vector/neta/utils.c:230
+#, c-format
+msgid "'%s' must be > 0"
+msgstr ""
+#: ../lib/vector/neta/utils.c:239
+msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
+msgstr ""
+#: ../lib/vector/neta/utils.c:242
+msgid "Unable to load data from database"
+msgstr ""
+#: ../lib/vector/neta/utils.c:249
+msgid "Problem loading category values"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:32
+msgid "Category index is not up to date"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:38
+msgid "Layer index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:268
+msgid "Category index out of range"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:489
+#, c-format
+msgid "Unable to create category index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:498
+msgid "Error writing out category index file"
+msgstr ""
+#: ../lib/vector/Vlib/cindex.c:542 ../lib/vector/Vlib/open.c:382
+#, c-format
+msgid "Unable to open category index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:37 ../lib/vector/Vlib/rewind.c:29
+#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/open.c:59
+#: ../lib/vector/Vlib/read.c:32 ../lib/vector/Vlib/write.c:56
+#: ../lib/vector/Vlib/write.c:62
+msgid "Requested format is not compiled in this version"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:115
+msgid "Area of size = 0.0 (less than 4 vertices) ignored"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:131
+msgid "Unable to add area (map closed, topo saved)"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:139
+msgid "Unable to add isle (map closed, topo saved)"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:149
+msgid "Area of size = 0.0 ignored"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:200
+msgid "Request to find area outside nonexistent isle"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:351
+msgid "Larger bbox but smaller area!!!"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:606
+msgid "Checking for topological errors..."
+msgstr ""
+#: ../lib/vector/Vlib/build.c:641
+#, c-format
+msgid "Number of lines of length zero: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:643
+#, c-format
+msgid "Number of boundaries of length zero: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:652
+#, c-format
+msgid "Number of boundary intersections: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:676
+msgid "Skipping further checks because of incorrect boundaries"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:726
+#, c-format
+msgid "Number of redundant holes: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:865 ../lib/vector/Vlib/open.c:356
+#: ../lib/vector/Vlib/open.c:860
+#, c-format
+msgid "Unable to open spatial index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:871
+#, c-format
+msgid "Building topology for vector map <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/build.c:889
+msgid "Topology was built"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:900
+#, c-format
+msgid "Number of nodes: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:901
+#, c-format
+msgid "Number of primitives: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:902
+#, c-format
+msgid "Number of points: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:903
+#, c-format
+msgid "Number of lines: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:904
+#, c-format
+msgid "Number of boundaries: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:905
+#, c-format
+msgid "Number of centroids: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:908
+#, c-format
+msgid "Number of faces: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:911
+#, c-format
+msgid "Number of kernels: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:957
+#, c-format
+msgid "Number of areas: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:958
+#, c-format
+msgid "Number of isles: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:963
+#, c-format
+msgid "Number of areas without centroid: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:968
+#, c-format
+msgid "Number of centroids exceeds number of areas: %d > %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:972
+#, c-format
+msgid "Number of incorrect boundaries: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:976
+#, c-format
+msgid "Number of centroids outside area: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:980
+#, c-format
+msgid "Number of duplicate centroids: %d"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:984
+msgid "Number of areas: -"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:985
+msgid "Number of isles: -"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1014
+#, c-format
+msgid "Unable to create topo file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1022
+msgid "Error writing out topo file"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1211
+msgid ""
+"Unable to build spatial index from topology, vector map is not opened at "
+"topology level 2"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1234
+#, c-format
+msgid "%s is no longer supported"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1257
+msgid "Spatial index not available, can not be saved"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1270
+#, c-format
+msgid "Unable to create spatial index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build.c:1279
+msgid "Error writing out spatial index file"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:84
+#, c-format
+msgid "Error reading ASCII file: (bad type) [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:123
+#, c-format
+msgid "Error reading ASCII file: (unknown type) [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:143
+msgid "End of ASCII file reached before end of coordinates"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:155
+#, c-format
+msgid "Error reading ASCII file: (bad point) [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:160
+#, c-format
+msgid "Unparsable longitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:165
+#, c-format
+msgid "Unparsable latitude value: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:201
+msgid "End of ASCII file reached before end of categories"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:212
+#, c-format
+msgid "Error reading categories: [%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:225
+msgid "Unable to copy points"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:238
+#, c-format
+msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:270
+#, c-format
+msgid ""
+"Unexpected data in vector header:\n"
+"[%s]"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:306
+#, c-format
+msgid "Unknown keyword <%s> in vector head"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:398 ../lib/vector/Vlib/array.c:276
+#: ../lib/vector/Vlib/copy.c:594 ../lib/vector/Vlib/copy.c:704
+#: ../lib/vector/Vlib/cats.c:589 ../lib/vector/Vlib/net.c:175
+#: ../lib/vector/Vlib/net.c:353 ../lib/vector/Vlib/map.c:264
+#: ../lib/vector/Vlib/map.c:400 ../lib/ogsf/gp3.c:202 ../lib/ogsf/gv3.c:344
+#: ../lib/rst/interp_float/vinput2d.c:79
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:465
+#, c-format
+msgid "Column <%s> does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:467
+msgid "Available columns:"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:472
+msgid "Export cancelled"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:505
+#, c-format
+msgid "Unknown type of column <%s>, export cancelled"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:539
+#, c-format
+msgid "Unable to select record from table <%s> (key %s, column %s)"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:661
+#, c-format
+msgid "Unknown feature type %d"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:701
+#, c-format
+msgid "Feature has more categories. Only one category (%d) is exported."
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:718
+#, c-format
+msgid "Cannot select attributes for cat = %d"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:724
+msgid "Unable to fetch data from table"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:756 ../lib/vector/Vlib/net.c:186
+#: ../lib/vector/Vlib/net.c:203 ../lib/vector/Vlib/net.c:363
+#, c-format
+msgid "Column <%s> not found in table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:758
+#, c-format
+msgid "Column <%s>: unsupported data type"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:840
+msgid "Unknown format"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:850
+msgid "Topology not available, unable to process areas"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:863
+#, c-format
+msgid "Unable to get boundary of area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:875
+#, c-format
+msgid "Unable to get boundary of isle id %d (area id %d)"
+msgstr ""
+#: ../lib/vector/Vlib/ascii.c:889
+#, c-format
+msgid ""
+"%d features without category skipped. To export also features without "
+"category use '%s=-1'."
+msgstr ""
+#: ../lib/vector/Vlib/graph.c:138
+msgid "Unable to add network arc"
+msgstr ""
+#: ../lib/vector/Vlib/graph.c:226 ../lib/vector/Vlib/net.c:533
+#, c-format
+msgid "dglShortestPath error: %s"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:57
+#, c-format
+msgid "Unable to open coor file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:154
+#, c-format
+msgid ""
+"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:158
+#, c-format
+msgid ""
+"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr ""
+#: ../lib/vector/Vlib/area.c:50
+msgid "Attempt to read points of nonexistent area"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:81
+msgid "Attempt to read points of nonexistent isle"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:94 ../lib/vector/Vlib/area.c:499
+#: ../lib/vector/Vlib/write_sfa.c:306 ../lib/vector/Vlib/write_pg.c:123
+#: ../lib/vector/Vlib/write_pg.c:157 ../lib/vector/Vlib/write_pg.c:196
+#: ../lib/vector/Vlib/write_pg.c:294 ../lib/vector/Vlib/write_pg.c:354
+#: ../lib/vector/Vlib/write_pg.c:476 ../lib/vector/Vlib/close_pg.c:99
+#: ../lib/vector/Vlib/close_pg.c:147 ../lib/vector/Vlib/close.c:275
+#: ../lib/vector/Vlib/copy.c:404 ../lib/vector/Vlib/simple_features.c:336
+#: ../lib/vector/Vlib/build_pg.c:117 ../lib/vector/Vlib/build_sfa.c:718
+#: ../lib/vector/Vlib/open_pg.c:143 ../lib/vector/Vlib/open_pg.c:200
+#: ../lib/vector/Vlib/open_pg.c:299 ../lib/vector/Vlib/open_pg.c:349
+#: ../lib/vector/Vlib/rewind_pg.c:56 ../lib/vector/Vlib/rewind_pg.c:81
+#: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
+#: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
+#: ../lib/vector/Vlib/header_finfo.c:47 ../lib/vector/Vlib/header_finfo.c:86
+#: ../lib/vector/Vlib/header_finfo.c:123 ../lib/vector/Vlib/header_finfo.c:171
+msgid "GRASS is not compiled with PostgreSQL support"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
+#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
+#, c-format
+msgid "Attempt to read topo for dead area (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
+#, c-format
+msgid "Attempt to read topo for dead isle (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/close_ogr.c:77 ../lib/vector/Vlib/close_ogr.c:111
+#: ../lib/vector/Vlib/write_sfa.c:298 ../lib/vector/Vlib/close.c:284
+#: ../lib/vector/Vlib/read_ogr.c:56 ../lib/vector/Vlib/read_ogr.c:157
+#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/build_ogr.c:94
+#: ../lib/vector/Vlib/build_ogr.c:169 ../lib/vector/Vlib/open_ogr.c:121
+#: ../lib/vector/Vlib/open_ogr.c:154 ../lib/vector/Vlib/open_ogr.c:231
+#: ../lib/vector/Vlib/simple_features.c:310 ../lib/vector/Vlib/build_sfa.c:711
+#: ../lib/vector/Vlib/rewind_ogr.c:47 ../lib/vector/Vlib/rewind_ogr.c:71
+#: ../lib/vector/Vlib/field.c:660 ../lib/vector/Vlib/write_ogr.c:69
+#: ../lib/vector/Vlib/write_ogr.c:105 ../lib/vector/Vlib/write_ogr.c:145
+#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
+#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
+#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/proj/convert.c:82
+msgid "GRASS is not compiled with OGR support"
+msgstr ""
+#: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:140
+#, c-format
+msgid "Unable to save feature index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:117
+msgid "Unable to calculate centroid for area"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:131 ../lib/vector/Vlib/write_sfa.c:173
+#: ../lib/vector/Vlib/write_sfa.c:273 ../lib/vector/Vlib/read_sfa.c:124
+msgid "GRASS is not compiled with OGR/PostgreSQL support"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:158 ../lib/vector/Vlib/write_sfa.c:207
+#: ../lib/vector/Vlib/write_pg.c:236 ../lib/vector/Vlib/write_pg.c:381
+#: ../lib/vector/Vlib/write_pg.c:396 ../lib/vector/Vlib/read.c:173
+#: ../lib/vector/Vlib/write_nat.c:182 ../lib/vector/Vlib/write_nat.c:295
+#: ../lib/vector/Vlib/write_nat.c:397 ../lib/vector/Vlib/write_nat.c:652
+#: ../lib/vector/Vlib/read_pg.c:331 ../lib/vector/Vlib/box.c:213
+#: ../lib/vector/Vlib/read_nat.c:144 ../lib/vector/Vlib/read_sfa.c:50
+#, c-format
+msgid "Attempt to access feature with invalid id (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:164 ../lib/vector/Vlib/write_pg.c:187
+#: ../lib/vector/Vlib/write_pg.c:255 ../lib/vector/Vlib/write_ogr.c:96
+msgid "Unable to rewrite feature (incompatible feature types)"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:219
+msgid "Attempt to delete dead feature"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:311
+#, c-format
+msgid "Unsupported vector map format (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_sfa.c:349 ../lib/vector/Vlib/write_pg.c:554
+#: ../lib/vector/Vlib/write_pg.c:1294
+msgid "Boundary is not closed. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/array.c:96
+#, c-format
+msgid "%d errors in category string"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
+msgid "Mixed area and other type requested for vector array"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
+#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
+msgid "Not enough space in vector array"
+msgstr ""
+#: ../lib/vector/Vlib/array.c:292
+#, c-format
+msgid "Unable to select record from table <%s> (key %s, where %s)"
+msgstr ""
+#: ../lib/vector/Vlib/clean_nodes.c:248
+#, c-format
+msgid "Modifications: %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:242 ../lib/vector/Vlib/write_pg.c:402
+#: ../lib/vector/Vlib/write_pg.c:2584 ../lib/vector/Vlib/write_pg.c:2681
+#: ../lib/vector/Vlib/write_nat.c:301 ../lib/vector/Vlib/write_nat.c:658
+#: ../lib/vector/Vlib/read_pg.c:337 ../lib/vector/Vlib/read_nat.c:150
+#: ../lib/vector/Vlib/read_sfa.c:56
+#, c-format
+msgid "Attempt to access dead feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:285
+#, c-format
+msgid "Unable to rewrite feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:321 ../lib/vector/Vlib/write_pg.c:811
+#: ../lib/vector/Vlib/write_pg.c:1212 ../lib/vector/Vlib/write_pg.c:1364
+#: ../lib/vector/Vlib/simple_features.c:324
+msgid "No connection defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:326
+#, c-format
+msgid "Invalid offset (%ld)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:347 ../lib/vector/Vlib/write_ogr.c:140
+msgid "Unable to delete feature"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:452
+#, c-format
+msgid "Unable to delete feature (%s) %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:612 ../lib/vector/Vlib/write_pg.c:880
+#: ../lib/vector/Vlib/build_pg.c:411 ../lib/vector/Vlib/open.c:1351
+msgid "Unable to open PG file"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:737 ../lib/vector/Vlib/write_pg.c:1175
+#: ../lib/vector/Vlib/write_pg.c:1278 ../lib/vector/Vlib/write_pg.c:1790
+#: ../lib/vector/Vlib/write_pg.c:1967 ../lib/vector/Vlib/write_pg.c:2325
+#: ../lib/vector/Vlib/copy.c:100 ../lib/vector/Vlib/read_pg.c:884
+#: ../lib/vector/Vlib/read_pg.c:1192 ../lib/vector/Vlib/read_pg.c:1347
+#: ../lib/vector/Vlib/read_pg.c:1440
+#, c-format
+msgid "Unsupported feature type %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:773
+#, c-format
+msgid "Building spatial index on <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:841
+#, c-format
+msgid "Schema <%s> doesn't exist, created"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:920
+#, c-format
+msgid "Creating topology schema <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:934
+#, c-format
+msgid "Adding new topology column <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1072 ../lib/vector/Vlib/open_pg.c:85
+#: ../lib/vector/Vlib/open_pg.c:232
+msgid "Connection string not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1216
+#: ../lib/vector/Vlib/write_pg.c:1368 ../lib/vector/Vlib/open_pg.c:90
+#: ../lib/vector/Vlib/open_pg.c:237
+msgid "PostGIS feature table not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1104 ../lib/vector/Vlib/write_ogr.c:304
+#, c-format
+msgid "Unsupported geometry type (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1117 ../lib/vector/Vlib/write_ogr.c:338
+#, c-format
+msgid "More layers defined, using driver <%s> and database <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1122 ../lib/vector/Vlib/write_ogr.c:344
+msgid "Database connection not defined. Unable to write attributes."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1129
+msgid "Unable to create new PostGIS feature table"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1143
+msgid "Unable to create new PostGIS topology schema"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1237 ../lib/vector/Vlib/write_pg.c:1396
+#: ../lib/vector/Vlib/write_ogr.c:408
+#, c-format
+msgid "No category defined for layer %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1239 ../lib/vector/Vlib/write_pg.c:1398
+#: ../lib/vector/Vlib/write_ogr.c:410
+#, c-format
+msgid "Feature has more categories, using category %d (from layer %d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1250
+#, c-format
+msgid "Point skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1257
+#, c-format
+msgid "Line skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1264
+#, c-format
+msgid "Boundary/centroid skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1266 ../lib/vector/Vlib/write_ogr.c:439
+msgid "Feature is not a polygon. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1272
+#, c-format
+msgid "Face skipped (output feature type: %s)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1358
+#, c-format
+msgid "Invalid feature type (%d) for nodes"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1372
+msgid "PostGIS topology schema not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1872
+msgid "Trying to insert 3D data into feature table which store 2D data only"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1877
+msgid "Trying to insert 2D data into feature table which store 3D data only"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1902
+msgid "Unable to insert topological element into PostGIS Topology schema"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2005 ../lib/vector/Vlib/write_ogr.c:579
+#, c-format
+msgid "Unable to select attributes for category %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2014 ../lib/vector/Vlib/write_ogr.c:591
+#, c-format
+msgid "No database record for category %d, no attributes will be written"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2040
+#, c-format
+msgid "FID column must be integer, column <%s> ignored!"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2074 ../lib/vector/Vlib/write_ogr.c:653
+#, c-format
+msgid "Unsupported column type %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2081
+msgid "Invalid value for FID column: NULL"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2173
+#, c-format
+msgid "Invalid feature %d (max: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2187
+#, c-format
+msgid "Invalid feature type (%d) for node"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2191
+#, c-format
+msgid "Invalid node %d (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2269
+#, c-format
+msgid "Unable to determine next left/right edge for edge %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2274
+msgid "Unable to insert new edge. Topology not available."
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2373 ../lib/vector/Vlib/write_pg.c:2380
+msgid "Invalid topology"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2579 ../lib/vector/Vlib/write_pg.c:2676
+#, c-format
+msgid "Attempt to access non-existing feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2610
+msgid "Unable to determine next left/right edge"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2696
+msgid "Unable to create new face"
+msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:2834 ../lib/vector/Vlib/write_pg.c:2846
+#, c-format
+msgid "Unable to delete node %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:52
+msgid "vector map is not opened"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:55
+#, c-format
+msgid ""
+"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
+"vector map <%s>: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:60
+msgid "only native format supported"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:259
+msgid "Attempt to read dead line"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:90
+#, c-format
+msgid "Vect_read_area_geos(): unable to read area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:104
+#, c-format
+msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:206
+#, c-format
+msgid "Unable to read line offset %ld"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:413
+#, c-format
+msgid "Attempt to read points of nonexistent area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:473
+#, c-format
+msgid "Unable to read feature id %d"
+msgstr ""
+#: ../lib/vector/Vlib/bridges.c:213
+#, c-format
+msgid "Removed lines: %d"
+msgstr ""
+#: ../lib/vector/Vlib/bridges.c:214
+#, c-format
+msgid "Removed bridges: %d"
+msgstr ""
+#: ../lib/vector/Vlib/close_pg.c:66 ../lib/vector/Vlib/read_pg.c:1405
+#, c-format
+msgid "Unable to close cursor %s"
+msgstr ""
+#: ../lib/vector/Vlib/intersect2.c:1177 ../lib/vector/Vlib/intersect2.c:1183
+#: ../lib/vector/Vlib/intersect2.c:1185 ../lib/vector/Vlib/intersect2.c:1237
+#: ../lib/vector/Vlib/intersect2.c:1246 ../lib/vector/Vlib/intersect2.c:1267
+#: ../lib/vector/Vlib/intersect2.c:1284 ../lib/vector/Vlib/intersect.c:1157
+#: ../lib/vector/Vlib/intersect.c:1163 ../lib/vector/Vlib/intersect.c:1165
+#: ../lib/vector/Vlib/intersect.c:1219 ../lib/vector/Vlib/intersect.c:1228
+#: ../lib/vector/Vlib/intersect.c:1249 ../lib/vector/Vlib/intersect.c:1266
+msgid "Error while adding point to array. Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:91
+#, c-format
+msgid "Unable to create vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:108
+msgid "Copying features failed"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:141
+#, c-format
+msgid "Unable to open %s file"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:226
+#, c-format
+msgid "Unable to close vector <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:257
+#, c-format
+msgid "Invalid request for writing frmt file - map format is %d"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:289
+#, c-format
+msgid "Link to vector map <%s> created"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
+#, c-format
+msgid "Unable to get feature geometry, fid %ld"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:344 ../lib/vector/Vlib/read_ogr.c:578
+#: ../lib/vector/Vlib/build_sfa.c:603
+#, c-format
+msgid "OGR feature type %d not supported"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:382 ../lib/vector/Vlib/read_pg.c:482
+msgid "Feature without geometry. Skipped."
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:390
+msgid "OGR feature without ID"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:514
+#, c-format
+msgid "OGR feature type '%s' not supported"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:69
+msgid "Empty OGR layer, nothing to build"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:80 ../lib/vector/Vlib/build_pg.c:93
+#, c-format
+msgid "Feature table <%s> has no primary key defined"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:82
+msgid ""
+"Random read is not supported by OGR for this layer. Unable to build topology."
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:101
+#, c-format
+msgid "Using external data format '%s' (feature type '%s')"
+msgstr ""
+#: ../lib/vector/Vlib/build_ogr.c:132
+#, c-format
+msgid "Unable to open fidx file for write <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/merge_lines.c:240
+#, c-format
+msgid "%d boundaries merged"
+msgstr ""
+#: ../lib/vector/Vlib/merge_lines.c:241
+#, c-format
+msgid "%d new boundaries"
+msgstr ""
+#: ../lib/vector/Vlib/poly.c:268
+msgid "Unable to find point in polygon"
+msgstr ""
+#: ../lib/vector/Vlib/poly.c:810
+msgid "conditions failed"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:81
+#, c-format
+msgid "Unable to copy features. Input vector map <%s> is not open"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:104
+#, c-format
+msgid "Unable to create PostGIS layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:133
+#, c-format
+msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:168 ../lib/vector/Vlib/copy.c:245
+#: ../lib/ogsf/gp3.c:92
+#, c-format
+msgid "Unable to read vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
+msgid "Copying features..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:231
+#, c-format
+msgid "Copying features (%s)..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:334
+msgid "Writing new feature failed"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:340
+#, c-format
+msgid "%d features without category or from different layer skipped"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:372
+msgid "Exporting nodes..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:400
+#, c-format
+msgid "Writing node %d failed"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:478
+msgid "Exporting areas..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:505
+#, c-format
+msgid "No centroid defined for area %d. Area not exported."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
+#, c-format
+msgid "Writing area %d failed"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:550
+#, c-format
+msgid "%d areas without category or from different layer skipped"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:604
+#, c-format
+msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:723
+#, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:738 ../lib/vector/Vlib/map.c:281
+#, c-format
+msgid "Unable to copy table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:747
+#, c-format
+msgid "Unable to open database <%s> with driver <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:754
+msgid "Unable to create index"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:760
+#, c-format
+msgid "Unable to grant privileges on table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:72
+msgid "unknown operator"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:124
+msgid "Overlay: line/boundary types not supported by AND operator"
+msgstr ""
+#: ../lib/vector/Vlib/overlay.c:127
+msgid "Overlay: area x area types not supported by AND operator"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:60
+msgid "OGR datasource not defined"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:65 ../lib/vector/Vlib/write_ogr.c:129
+msgid "OGR layer not defined"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:77 ../lib/vector/Vlib/field.c:675
+#, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:97
+#, c-format
+msgid "OGR layer <%s> not found"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:145 ../lib/vector/Vlib/open_pg.c:193
+#, c-format
+msgid "Unable to open feature index file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:191
+#, c-format
+msgid "Unable to get OGR driver <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:199
+#, c-format
+msgid "Unable to create OGR data source '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:211
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:215
+#, c-format
+msgid "Unable to delete OGR layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:221
+#, c-format
+msgid "OGR layer <%s> already exists in datasource '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:279
+#, c-format
+msgid ""
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:284
+#, c-format
+msgid ""
+"Your GRASS version does not fully support feature index format %d.%d of the "
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:127
+msgid "3D not supported by Vect_segment_intersection()"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:313
+msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
+msgstr ""
+#: ../lib/vector/Vlib/intersect.c:407
+msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
+msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:225
+#, c-format
+msgid "Unknown Simple Features type (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:332
+msgid "Unable to get number of simple features"
+msgstr ""
+#: ../lib/vector/Vlib/simple_features.c:341
+#, c-format
+msgid "Unable to report simple features for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:88
+msgid "No DB connection"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:95
+msgid "Random read is not supported for this layer. Unable to build topology."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:105
+msgid "Building pseudo-topology over simple features..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:107
+#, c-format
+msgid "Building topology from PostGIS topology schema <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:212 ../lib/vector/Vlib/open_pg.c:1475
+#, c-format
+msgid "Inconsistency in topology: number of nodes %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:237
+msgid "Cleaning-up topology schema..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:282
+msgid "Updating faces..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:314
+msgid "Updating edges..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:323
+msgid "Inconsistency in topology detected. Dead line found."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:377
+msgid "Updating TopoGeometry data..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:462
+#, c-format
+msgid "Unsupported topo geometry type %d"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:491
+#, c-format
+msgid "Unable to create <%s.%s>"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:642
+msgid "Unable to write nodes, offset array mismatch"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:671
+msgid "Unable to write nodes"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:716
+#, c-format
+msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:739
+msgid "Unable to write lines"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:790
+#, c-format
+msgid "Topology for centroid %d not available. Area %d skipped"
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:1000
+msgid "Create simple features topology from topogeometry data..."
+msgstr ""
+#: ../lib/vector/Vlib/build_pg.c:1018
+#, c-format
+msgid ""
+"Unable to build simple features from topogeometry data. Unsupported type %d."
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:23
+#, c-format
+msgid "Vector map <%s> is not open at topological level"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:284
+#, c-format
+msgid "Invalid node id: %d"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:316
+#, c-format
+msgid "Nodes not available for line %d"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:357
+#, c-format
+msgid "Areas not available for line %d"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:362
+#, c-format
+msgid "Line %d is not a boundary"
+msgstr ""
+#: ../lib/vector/Vlib/level_two.c:445
+#, c-format
+msgid "Topology info not available for feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
+#, c-format
+msgid "Unable to calculate centroid for area %d"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:305
+#, c-format
+msgid "Feature type %d not supported"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:339 ../lib/vector/Vlib/build_sfa.c:629
+#: ../lib/vector/Vlib/build_nat.c:74
+msgid "Registering primitives..."
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:354 ../lib/vector/Vlib/build_sfa.c:364
+#: ../lib/vector/Vlib/read_pg.c:378
+#, c-format
+msgid "Feature %d without geometry skipped"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:385 ../lib/vector/Vlib/build_sfa.c:661
+#: ../lib/vector/Vlib/build_nat.c:117
+#, c-format
+msgid "One primitive registered"
+msgid_plural "%d primitives registered"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_sfa.c:386 ../lib/vector/Vlib/build_sfa.c:662
+#: ../lib/vector/Vlib/build_nat.c:118
+#, c-format
+msgid "One vertex registered"
+msgid_plural "%d vertices registered"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_sfa.c:665
+#, c-format
+msgid "One feature without geometry skipped"
+msgid_plural "%d features without geometry skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_sfa.c:722
+#, c-format
+msgid "%s: Native format unsupported"
+msgstr ""
+#: ../lib/vector/Vlib/build_sfa.c:748
+msgid "Feature index is built only for non-native formats. Nothing to dump."
+msgstr ""
+#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
+#: ../lib/vector/Vlib/line.c:250
+msgid "Index out of range in"
+msgstr ""
+#: ../lib/vector/Vlib/line.c:550
+msgid "Segment outside line, no segment created"
+msgstr ""
+#: ../lib/vector/Vlib/remove_duplicates.c:199
+#, c-format
+msgid "Removed duplicates: %d"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:138
+#, c-format
+msgid "Programmer requested unknown access level %d"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:232
+#, c-format
+msgid "Vector map <%s> not found in current mapset"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:235 ../lib/vector/Vlib/legal_vname.c:141
+#: ../lib/vector/Vlib/legal_vname.c:144 ../lib/vector/Vlib/map.c:227
+#: ../lib/ogsf/gp3.c:56 ../lib/ogsf/gp3.c:191 ../lib/ogsf/gv3.c:60
+#: ../lib/ogsf/gv3.c:333 ../lib/manage/do_remove.c:57
+#: ../lib/manage/do_rename.c:54
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:252
+msgid "Temporary vector maps can be accessed only in the current mapset"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:266
+msgid ""
+"Vector map which is not in the current mapset cannot be opened for update"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:290 ../lib/vector/Vlib/open.c:426
+#: ../lib/vector/Vlib/map.c:156 ../lib/vector/Vlib/map.c:166
+#: ../lib/vector/Vlib/map.c:238
+#: ../lib/python/temporal/c_libraries_interface.py:578 ../lib/ogsf/gp3.c:62
+#: ../lib/ogsf/gp3.c:196 ../lib/ogsf/gv3.c:66 ../lib/ogsf/gv3.c:338
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:300
+#, c-format
+msgid "Unable to read header file of vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:341
+#, c-format
+msgid "Unable to open topology file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:408
+#, c-format
+msgid ""
+"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
+"with v.build."
+msgstr ""
+#: ../lib/vector/Vlib/open.c:434
+#, c-format
+msgid "Building topology for OGR layer <%s> from datasource '%s'..."
+msgstr ""
+#: ../lib/vector/Vlib/open.c:442
+#, c-format
+msgid "Unable to open vector map <%s> on level %d"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:496
+#, c-format
+msgid "Unable to open history file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:768
+#, c-format
+msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:777
+#, c-format
+msgid "Unable to create vector map: <%s> is not SQL compliant"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:803 ../lib/vector/Vlib/open.c:814
+#: ../lib/vector/Vlib/map.c:123
+#, c-format
+msgid "Unable to delete vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:809 ../lib/vector/Vlib/map.c:119
+#: ../lib/vector/Vlib/map.c:213
+#, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:835
+#, c-format
+msgid "Unable to open history file of vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:876
+#, c-format
+msgid "Using OGR/%s format"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:880
+msgid "Using PostGIS Topology format"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:882
+msgid "Using PostGIS format"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:885
+msgid "Using native format"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:976
+#, c-format
+msgid "Unable to stat file <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1040
+#, c-format
+msgid "unknown %d (update Vect_maptype_info)"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1132
+msgid "Size of 'coor' file differs from value saved in topology file"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1143 ../lib/vector/Vlib/open.c:1244
+#, c-format
+msgid "Please rebuild topology for vector map <%s@%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1233
+msgid "Size of 'coor' file differs from value saved in sidx file"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1313
+msgid "Unable to open OGR file"
+msgstr ""
+#: ../lib/vector/Vlib/open.c:1339
+msgid "OGR output also detected, using OGR"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:45
+msgid "Vect_new_cats_struct(): Out of memory"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:127
+#, c-format
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:419
+#, c-format
+msgid "Unable to convert category string '%s' (from '%s') to category range"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
+msgid "Layer number must be > 0 for category constraints"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:585
+#, c-format
+msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:593
+#, c-format
+msgid "Loading categories from table <%s>..."
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:605
+#, c-format
+msgid "One category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/cats.c:627
+#, c-format
+msgid "No categories selected with '%s' option"
+msgstr ""
+#: ../lib/vector/Vlib/cats.c:637
+#, c-format
+msgid "%d errors in '%s' option"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:25 ../lib/vector/Vlib/write.c:30
+#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:42
+#: ../lib/vector/Vlib/write.c:49
+msgid "for this format/level not supported"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
+#: ../lib/vector/Vlib/read.c:168
+msgid "Vector map is not open for reading"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
+#, c-format
+msgid "Unable to read feature %d from vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:200
+msgid "Line index is out of range"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:224
+msgid "Node index is out of range"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:248
+msgid "Area index is out of range"
+msgstr ""
+#: ../lib/vector/Vlib/read.c:272
+msgid "Isle index is out of range"
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:43
+#, c-format
+msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:50
+#, c-format
+msgid "Illegal vector map name <%s>. Must start with a letter."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:58
+#, c-format
+msgid "Illegal vector map name <%s>. Character '%c' not allowed."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:65
+#, c-format
+msgid ""
+"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
+#, c-format
+msgid "Output vector map name <%s> is not in the current mapset (%s)"
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
+#, c-format
+msgid "Output vector map name <%s> is not SQL compliant"
+msgstr ""
+#: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
+#, c-format
+msgid "Output vector map <%s> is used as input"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
+msgid "No feature tables found in database."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:133
+#, c-format
+msgid "Feature table <%s> not found in 'geometry_columns'"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:181
+msgid "Topology schema not found."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:273
+#, c-format
+msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:276
+#, c-format
+msgid "Unable to delete PostGIS layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:282
+#, c-format
+msgid "PostGIS layer <%s.%s> already exists in database '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:390
+msgid "No key column detected."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
+#, c-format
+msgid "Execution failed: %s"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:476
+#, c-format
+msgid "PostGIS topology schema <%s> dropped"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:549
+msgid ""
+"Connection to PostgreSQL database failed. Try to set up username/password by "
+"db.login."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:556
+msgid "Unable to get database name"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:561
+#, c-format
+msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:570
+#, c-format
+msgid "PostGIS Topology extension not found in the database <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:657
+msgid "Empty bounding box"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:758
+#, c-format
+msgid "Inconsistency in topology: unable to read node %d"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:824
+#, c-format
+msgid "Inconsistency in topology: node %d - unexpected feature type %d"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:993
+#, c-format
+msgid "Area %d without boundary detected"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1051
+#, c-format
+msgid "Isle %d without boundary detected"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1118
+msgid "Unable to get map bounding box from topology"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1125
+#, c-format
+msgid ""
+"Unable to parse map bounding box:\n"
+"%s"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1149
+#, c-format
+msgid "Different number of nodes detected (%d, %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1177 ../lib/vector/Vlib/open_pg.c:1199
+#, c-format
+msgid "Different number of areas detected (%d, %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1370
+msgid "To be implemented: isles not attached in Topo-Geo-only mode"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1559
+#, c-format
+msgid "Inconsistency in topology: number of points %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1604
+#, c-format
+msgid "Inconsistency in topology: number of lines %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1658
+#, c-format
+msgid "Inconsistency in topology: number of centroids %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:213
+msgid "Snap vertices Pass 1: select points"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:267
+msgid "Snap vertices Pass 2: assign anchor vertices"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:336
+msgid "Snap vertices Pass 3: snap to assigned points"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:518
+#, c-format
+msgid "Snapped vertices: %d"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:519
+#, c-format
+msgid "New vertices: %d"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:546
+msgid "Reading features..."
+msgstr ""
+#: ../lib/vector/Vlib/break_lines.c:563
+#, c-format
+msgid "Intersections: %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:403
+#, c-format
+msgid "Attempt to access alive feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:567 ../lib/vector/Vlib/write_nat.c:603
+#, c-format
+msgid "%s: Area %d does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/write_nat.c:757
+#, c-format
+msgid "Attempt to access dead area %d"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:117
+msgid "Building graph..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:159
+msgid "Unable to build network graph"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:165
+msgid "Forward costs column not specified"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:172
+msgid "Arc field < 1"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:192 ../lib/vector/Vlib/net.c:209
+#: ../lib/vector/Vlib/net.c:369
+#, c-format
+msgid "Data type of column <%s> not supported (must be numeric)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:222
+msgid "Registering arcs..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:251
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(forward/both direction(s) of line skipped)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:270
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not "
+"found(direction of line skipped)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:319
+msgid "Cannot add network arc"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:349
+msgid "Setting node costs..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:412
+#, c-format
+msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:441
+msgid "Flattening the graph..."
+msgstr ""
+#: ../lib/vector/Vlib/net.c:450
+msgid "Graph was built"
+msgstr ""
+#: ../lib/vector/Vlib/net.c:633
+msgid "Wrong line direction in Vect_net_get_line_cost()"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:361
+msgid "Line is not looped"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:443
+#, c-format
+msgid "Unexpected result of line_intersection() res = %d"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:589
+msgid ""
+"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:600
+msgid ""
+"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:648
+msgid "side != 0 feature not implemented"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
+msgid "zero area size"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
+msgid "Line was not closed"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
+msgid "Vect_get_point_in_poly() failed"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:192 ../lib/vector/Vlib/read_sfa.c:117
+#, c-format
+msgid "Unexpected feature type (%d) - should be (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
+#, c-format
+msgid "Feature %ld without geometry skipped"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:365
+#, c-format
+msgid ""
+"Requesting invalid feature from cache (%d). Number of features in cache: %d"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:368
+#, c-format
+msgid "Feature %d: unexpected type (%d) - should be %d"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:575
+msgid "No geometry or topo geometry column defined"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:585
+msgid "Random access not supported. Primary key not defined."
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:652
+msgid "Inconsistency in topology: detected centroid (should be point)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:662
+msgid "Inconsistency in topology: detected boundary (should be line)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:787
+#, c-format
+msgid "Invalid WKB content: %d bytes"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:803
+msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
+#: ../lib/vector/Vlib/read_pg.c:1137
+msgid "Length of input WKB is too small"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1077
+#, c-format
+msgid "Invalid cache index %d (max: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1215
+#, c-format
+msgid "Corrupted data. %s."
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1217
+msgid "Corrupted data"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1510 ../lib/vector/Vlib/read_pg.c:1541
+#, c-format
+msgid ""
+"Execution failed: %s\n"
+"Reason: %s"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1670
+#, c-format
+msgid ""
+"Unable to read features. Reason:\n"
+"%s"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:91
+msgid "Layer number must be 1 or greater"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:96
+msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:103
+msgid "Unable to add attribute link"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:109
+msgid "Unable to write attribute links"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:154
+msgid "Unable to write database links"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:178
+msgid "Database connection not defined. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/field.c:185
+msgid ""
+"More DB links defined for input vector map. Using only first DB link for "
+"output."
+msgstr ""
+#: ../lib/vector/Vlib/field.c:261
+#, c-format
+msgid "Layer number %d or name <%s> already exists"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:345
+#, c-format
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:352
+msgid "Default driver is not set"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:355
+msgid "Default database is not set"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:412
+#, c-format
+msgid "Requested dblink %d, maximum link number %d"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:599 ../lib/vector/Vlib/field.c:607
+#, c-format
+msgid "Error in rule on row %d in <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:692
+#, c-format
+msgid "Unable to open OGR layer <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:719
+msgid "Unable to open OGR DBMI driver"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:758
+msgid ""
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:825
+#, c-format
+msgid ""
+"Feature table <%s> has no primary key defined. Unable to define DB links."
+msgstr ""
+#: ../lib/vector/Vlib/field.c:845
+msgid "GRASS not compiled with PostgreSQL support"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:877
+msgid "Unknown vector map format"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:911
+#, c-format
+msgid "Unable to create database definition file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:1006
+msgid "Bug: attempt to update map which is not in current mapset"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:134
+#, c-format
+msgid "Invalid offset (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:239
+#, c-format
+msgid "Creating field <%s> failed"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:326
+#, c-format
+msgid "Unable to create OGR layer <%s> in '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:424
+msgid "Feature is not a point. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:432
+msgid "Feature is not a line. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:446
+msgid "Feature is not a face. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:452
+#, c-format
+msgid "Unsupported feature type (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:471
+msgid "Boundary is not closed. Feature skipped."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:500
+msgid "Unable to writes feature attributes"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:565
+#, c-format
+msgid "Feature without category of layer %d"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:624
+#, c-format
+msgid "Unable to create field <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/dgraph.c:432
+msgid ""
+"Trying to add more edges to the planar_graph than the initial allocation "
+"size allows"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:228
+#, c-format
+msgid "Unable to determine bbox for feature %d"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:277 ../lib/vector/Vlib/box.c:323
+#, c-format
+msgid "Attempt to access area with invalid id (%d)"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:289
+#, c-format
+msgid "Unable to determine bbox for area %d"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:335
+#, c-format
+msgid "Unable to determine bbox for isle %d"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:194
+#, c-format
+msgid "Unable to write feature in vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:234
+#, c-format
+msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:266
+#, c-format
+msgid "Unable to delete feature/offset %lu from vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:299
+#, c-format
+msgid "Unable to restore feature/offset %lu in vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:308
+#, c-format
+msgid "Vector map <%s> is not opened"
+msgstr ""
+#: ../lib/vector/Vlib/write.c:313
+#, c-format
+msgid "Vector map <%s> is not opened in write mode"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:148
+msgid "Changed"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:151
+msgid "Removed"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:154
+msgid "Selected"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:262
+#, c-format
+msgid "%s lines: %d"
+msgstr ""
+#: ../lib/vector/Vlib/dangles.c:263
+#, c-format
+msgid "%s dangles: %d"
+msgstr ""
+#: ../lib/vector/Vlib/color_write.c:71 ../lib/raster/color_write.c:81
+#, c-format
+msgid "Qualified name <%s> doesn't match mapset <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/color_write.c:91 ../lib/raster/color_write.c:96
+#, c-format
+msgid "Unable to create <%s> file for map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/read_sfa.c:90
+#, c-format
+msgid "Unable to construct centroid for area %d. Skipped."
+msgstr ""
+#: ../lib/vector/Vlib/read_sfa.c:95
+#, c-format
+msgid "Centroid %d: invalid area %d"
+msgstr ""
+#: ../lib/vector/Vlib/select.c:116
+#, c-format
+msgid "Unable to delete item %d from spatial index"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:87
+#, c-format
+msgid "Unable to create header file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:131
+#, c-format
+msgid "Unable to open header file of vector <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:139
+#, c-format
+msgid "Corrupted row in head: %s"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:177
+#, c-format
+msgid "Unknown keyword '%s' in vector head"
+msgstr ""
+#: ../lib/vector/Vlib/header.c:554 ../lib/gis/proj3.c:110
+msgid "Unknown projection"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:103 ../lib/vector/Vlib/map.c:209
+msgid "Vector map name is not SQL compliant"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:107
+#, c-format
+msgid "Unable to find vector map <%s> in <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:143 ../lib/vector/Vlib/map.c:231
+#, c-format
+msgid "Unable to copy vector map <%s> to <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:295 ../lib/vector/Vlib/map.c:426
+#, c-format
+msgid "Unable to delete table <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:310
+#, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:366
+#, c-format
+msgid "Ignoring invalid mapset: %s"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:371
+#, c-format
+msgid "Invalid vector map name <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:381
+#, c-format
+msgid "Unable to open header file for vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:413
+#, c-format
+msgid "Unable to find table <%s> linked to vector map <%s>"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:436
+#, c-format
+msgid "Table <%s> linked to vector map <%s> does not exist"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:450
+#, c-format
+msgid "Unable to open directory '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:464
+#, c-format
+msgid "Unable to delete file '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:478
+#, c-format
+msgid "Unable to rename directory '%s' to '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/map.c:487
+#, c-format
+msgid "Unable to remove directory '%s'"
+msgstr ""
+#: ../lib/vector/Vlib/constraint.c:150
+msgid "Layer constraint ignored for non-native vector formats"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
+msgid "Area is composed of dead boundary"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
+#, c-format
+msgid "%d areas of total size %g removed"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:395
+msgid "Could not delete line from coor"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:458
+msgid "dissolve_neighbour > 0, failed to build new area"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
+msgid "Dissolve with neighbour area: corrupt topology"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:497
+msgid "Failed to build new area"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
+msgid "Failed to build new isle"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
+msgid "Dissolve with outer isle: corrupt topology"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:581
+msgid "Area merging failed"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:84
+msgid "Unable to read vector map"
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:129
+msgid "Building areas..."
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:153
+#, c-format
+msgid "One area built"
+msgid_plural "%d areas built"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_nat.c:154
+#, c-format
+msgid "One isle built"
+msgid_plural "%d isles built"
+msgstr[0] ""
+msgstr[1] ""
+#: ../lib/vector/Vlib/build_nat.c:163
+msgid "Attaching islands..."
+msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:180
+msgid "Attaching centroids..."
+msgstr ""
+#: ../lib/vector/Vlib/level.c:34
+msgid "Map structure was never initialized"
+msgstr ""
+#: ../lib/vector/Vlib/level.c:36
+msgid "Map structure has been closed"
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:102
+msgid "Break polygons: Bug in binary tree!"
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:156
+#: ../lib/vector/Vlib/break_polygons.c:435
+msgid "Breaking polygons (pass 1: select break points)..."
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:286
+#: ../lib/vector/Vlib/break_polygons.c:552
+msgid "Breaking polygons (pass 2: break at selected points)..."
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:398
+#: ../lib/vector/Vlib/break_polygons.c:650
+#, c-format
+msgid "Breaks: %d"
+msgstr ""
+#: ../lib/vector/Vlib/break_polygons.c:592
+msgid "Point not in search tree!"
+msgstr ""
+#: ../lib/segment/format.c:143
+msgid "Segment format: file size too large"
+msgstr ""
+#: ../lib/segment/format.c:144
+msgid "Please recompile with Large File Support (LFS)"
+msgstr ""
+#: ../lib/segment/open.c:53
+msgid "Segment file name is NULL"
+msgstr ""
+#: ../lib/segment/open.c:58
+msgid "Segment file exists already"
+msgstr ""
+#: ../lib/segment/open.c:66
+msgid "Unable to create segment file"
+msgstr ""
+#: ../lib/segment/open.c:74
+msgid "Could not write segment file"
+msgstr ""
+#: ../lib/segment/open.c:78
+msgid "Illegal segment configuration parameter(s)"
+msgstr ""
+#: ../lib/segment/open.c:87
+msgid "Unable to re-open segment file"
+msgstr ""
+#: ../lib/segment/open.c:94
+msgid "Could not read segment file"
+msgstr ""
+#: ../lib/htmldriver/graph_set.c:97
+#, c-format
+msgid "html: collecting to file '%s'"
+msgstr ""
+#: ../lib/htmldriver/graph_set.c:98
+#, c-format
+msgid "html: image size %dx%d"
+msgstr ""
+#: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
+#: ../lib/htmldriver/graph_set.c:119
+#, c-format
+msgid "html: type '%s'"
+msgstr ""
+#: ../lib/temporal/lib/connect.c:101
+#, c-format
+msgid "You don't have permission to access the mapset <%s>"
+msgstr ""
+#: ../lib/temporal/lib/connect.c:105
+#, c-format
+msgid "Mapset <%s> does not exist."
+msgstr ""
+#: ../lib/temporal/lib/default_name.c:69
+msgid "Programmer error - only SQLite driver is currently supported"
+msgstr ""
+#: ../lib/gpde/n_parse_options.c:106
+msgid "The calculation time in seconds"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:93
+#, c-format
+msgid "Reading raster map <%s> into memory"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:183
+msgid "N_array_2d * array is empty"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:202
+#, c-format
+msgid "Write 2d array to raster map <%s>"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:273 ../lib/ogsf/gvl3.c:40
+#: ../lib/ogsf/gvl_file.c:427 ../lib/manage/do_remove.c:78
+#: ../lib/manage/do_rename.c:76
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:281
+#: ../lib/python/temporal/c_libraries_interface.py:507
+#: ../lib/ogsf/gvl_file.c:436
+#, c-format, python-format
+msgid "Unable to open 3D raster map <%s>"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:309
+#, c-format
+msgid "Read g3d map <%s> into the memory"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
+msgid "Error closing g3d file"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:420
+#, c-format
+msgid "Error opening g3d map <%s>"
+msgstr ""
+#: ../lib/gpde/n_arrays_io.c:422
+#, c-format
+msgid "Write 3d array to g3d map <%s>"
+msgstr ""
+#: ../lib/gpde/test/test_main.c:88
+msgid "Performs unit and integration tests for gpde library"
+msgstr ""
+#: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
+#, c-format
+msgid "The total sum of the water budget: %g\n"
+msgstr ""
+#: ../lib/gpde/n_gwflow.c:438 ../lib/gpde/n_gwflow.c:717
+#, c-format
+msgid "The total sum of the water budget is significantly larger then 0: %g\n"
+msgstr ""
+#: ../lib/pngdriver/graph_set.c:101
+#, c-format
+msgid "png: truecolor status %s"
+msgstr ""
+#: ../lib/pngdriver/graph_set.c:102 ../lib/psdriver/graph_set.c:200
+msgid "enabled"
+msgstr ""
+msgid "disabled"
+msgstr ""
+#: ../lib/pngdriver/graph_set.c:149
+#, c-format
+msgid "png: collecting to file '%s'"
+msgstr ""
+#: ../lib/pngdriver/graph_set.c:150
+#, c-format
+msgid "png: image size %dx%d"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:68
+#, python-format
+msgid "Module run %s %s ended with error"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:69
+#, python-format
+msgid ""
+"\n"
+"Process ended with non-zero return code %s"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:71
+#, python-format
+msgid ""
+". See the following errors:\n"
+"%s"
+msgstr ""
+#: ../lib/python/exceptions/__init__.py:75
+msgid ". See errors in the (error) output."
+msgstr ""
+#: ../lib/python/pygrass/utils.py:236
+msgid "Vector doesn't contain points"
+msgstr ""
+#: ../lib/python/pygrass/vector/table.py:1017
+#, python-format
+msgid "Deleting table <%s> which is attached to following map(s):"
+msgstr ""
+#: ../lib/python/pygrass/vector/table.py:1021
+msgid "You must use the force flag to actually remove it. Exiting."
+msgstr ""
+#: ../lib/python/pygrass/vector/abstract.py:108
+#: ../lib/python/pygrass/raster/abstract.py:298
+#, python-brace-format
+msgid "Map name {0} not valid"
+msgstr ""
+#: ../lib/python/pygrass/modules/grid/grid.py:538
+msgid "Execution of subprocesses was not successful"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:81
+msgid "Raster type: {0} not supported"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:168
+msgid "Error executing: Rast_get_ith_cat"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:196
+msgid "Null value detected"
+msgstr ""
+#: ../lib/python/pygrass/raster/category.py:198
+msgid "Error executing: Rast_set_cat"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:180
+msgid "The map does not exist, I can't open in 'r' mode"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:185
+msgid "Raster map <{0}> already exists and will be not overwritten"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:189
+msgid "Raster type not defined"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:280
+msgid "Mode type: {0} not supported ('r', 'w','rw')"
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:300
+#, python-format
+msgid "Index out of range: %r."
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:401
+msgid "Raster map <{0}> already exists. Use overwrite."
+msgstr ""
+#: ../lib/python/pygrass/raster/__init__.py:432
+msgid "Raster map <{0}> does not exists"
+msgstr ""
+#: ../lib/python/pygrass/raster/abstract.py:274
+msgid "Mode type: {0} not supported ('r', 'w')"
+msgstr ""
+#: ../lib/python/pygrass/raster/abstract.py:285
+msgid "Overwrite type: {0} not supported (True/False)"
+msgstr ""
+#: ../lib/python/pygrass/errors.py:17
+msgid "The map is close!"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:99
+#, python-format
+msgid "Unable to export raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:110
+#, python-format
+msgid "Unable to export color rules for raster map <%s> r.out.gdal"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:134
+#, python-format
+msgid "Unable to export raster map <%s> with r.pack"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:162
+#, python-format
+msgid "Unable to export vector map <%s> as GML with v.out.ogr"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:195
+#, python-format
+msgid "Unable to export vector map <%s> with v.pack"
+msgstr ""
+#: ../lib/python/temporal/stds_export.py:221
+#, python-format
+msgid "Unable to export raster map <%s> with r3.pack"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:60
+#: ../lib/python/temporal/open_stds.py:116
+#, python-format
+msgid "Unkown type: %s"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:66
+#, python-format
+msgid "Space time %(sp)s dataset <%(name)s> no found"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:105
+msgid "Space time datasets can only be created in the current mapset"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:122
+#, python-format
+msgid ""
+"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
+"overwrite flag."
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:157
+#, python-format
+msgid ""
+"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:165
+#, python-format
+msgid "Creating a new space time %s dataset"
+msgstr ""
+#: ../lib/python/temporal/open_stds.py:208
+#: ../lib/python/temporal/extract.py:114 ../lib/python/temporal/mapcalc.py:236
+#, python-format
+msgid ""
+"Map <%s> is already in temporal database, use overwrite flag to overwrite"
+msgstr ""
+#: ../lib/python/temporal/sampling.py:91 ../lib/python/temporal/sampling.py:96
+#, python-format
+msgid "Dataset <%s> not found in temporal database"
+msgstr ""
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:589
+#, python-format
+msgid "Error computing map <%s>"
+msgstr ""
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:655
+#: ../lib/python/temporal/temporal_algebra.py:2212
+#, python-format
+msgid "%s map <%s> not found in GRASS spatial database"
+msgstr ""
+#: ../lib/python/temporal/gui_support.py:56 ../lib/python/script/core.py:1214
+#, python-format
+msgid "Invalid element '%s'"
+msgstr ""
+#: ../lib/python/temporal/abstract_dataset.py:388
+#, python-format
+msgid ""
+"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
+"The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_dataset.py:428
+#: ../lib/python/temporal/abstract_dataset.py:471
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2274
+#: ../lib/python/temporal/abstract_map_dataset.py:415
+#: ../lib/python/temporal/abstract_map_dataset.py:511
+#, python-format
+msgid ""
+"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
+#: ../lib/python/temporal/factory.py:47
+#, python-format
+msgid "Unknown dataset type: %s"
+msgstr ""
+#: ../lib/python/temporal/extract.py:54
+msgid "You need to specify the base name of new created maps"
+msgstr ""
+#: ../lib/python/temporal/extract.py:121
+#, python-format
+msgid "Applying r.mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:126
+#, python-format
+msgid "Applying r3.mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:131
+#, python-format
+msgid "Applying v.extract where statement: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/extract.py:159
+msgid "Error in computation process"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:220
+#, python-format
+msgid "Unable to read timestamp file for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:244
+#, python-format
+msgid "Unable to create timestamp file for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:249
+#, python-format
+msgid "Invalid datetime in timestamp for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:254
+#: ../lib/python/temporal/space_time_datasets.py:588
+msgid "Internal error"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:271
+#: ../lib/python/temporal/space_time_datasets.py:602
+#, python-format
+msgid "Unable to remove timestamp for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:554
+#, python-format
+msgid "Unable to read timestamp file for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:578
+#, python-format
+msgid "Unable to create timestamp file for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:583
+#, python-format
+msgid "Invalid datetime in timestamp for 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:847
+#, python-format
+msgid "Unable to read timestamp file for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:870
+#, python-format
+msgid "Unable to create timestamp file for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:875
+#, python-format
+msgid "Invalid datetime in timestamp for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:891
+#, python-format
+msgid "Unable to remove timestamp for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:84
+#, python-format
+msgid "Unable to import/link raster map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:95
+#, python-format
+msgid "Unable to set the color rules for raster map <%s>."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:119
+#, python-format
+msgid "Unable to unpack raster map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:143
+#, python-format
+msgid "Unable to import vector map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:167
+#, python-format
+msgid "Unable to unpack vector map <%s> from file %s."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:205
+#, python-format
+msgid "Space time raster dataset archive <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:208
+#, python-format
+msgid "Extraction directory <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:216
+#, python-format
+msgid "Unable to find init file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:218
+#, python-format
+msgid "Unable to find list file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:220
+#, python-format
+msgid "Unable to find projection file <%s>"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:246
+msgid "Projection information does not match. Proceeding..."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:250
+msgid ""
+"Difference between PROJ_INFO file of imported map and of current location:\n"
+"{diff}"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:253
+msgid "Projection information does not match. Aborting."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:270
+#, python-format
+msgid "Unable to create location %(l)s. Reason: %(e)s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:278
+#, python-format
+msgid "Unable to switch to location %s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:283
+#, python-format
+msgid "Unable to create default temporal database in new location %s"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:356
+#, python-format
+msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:362
+msgid "Number of maps mismatch in init and list file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:373
+msgid "The archive file is of wrong space time dataset type"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:381
+#, python-format
+msgid "Unable to find GeoTIFF raster file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:387
+#, python-format
+msgid "Unable to find AAIGrid raster file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:393
+#, python-format
+msgid "Unable to find GML vector file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:402
+#, python-format
+msgid "Unable to find GRASS package file <%s> in archive."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:405
+msgid "Unsupported input format"
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:411
+#, python-format
+msgid ""
+"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
+"overwrite flag."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:431
+#, python-format
+msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:443
+#, python-format
+msgid "Key word %s not found in init file."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:448
+#, python-format
+msgid "Create space time %s dataset."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:477
+msgid "Switching to original location failed"
+msgstr ""
+#: ../lib/python/temporal/temporal_vector_algebra.py:372
+#, python-format
+msgid ""
+"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
+"file"
+msgstr ""
+#: ../lib/python/temporal/temporal_vector_algebra.py:404
+#, python-format
+msgid ""
+"Error starting %s : \n"
+"%s"
+msgstr ""
+#: ../lib/python/temporal/temporal_vector_algebra.py:476
+#, python-format
+msgid ""
+"Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
+"%s"
+msgstr ""
+#: ../lib/python/temporal/core.py:576
+msgid ""
+"Unable to initialize the temporal DBMI interface. Please use t.connect to "
+"specify the driver and the database string"
+msgstr ""
+#: ../lib/python/temporal/core.py:639
+#, python-format
+msgid ""
+"Unable to receive temporal database metadata.\n"
+"Current temporal database info:%(info)s"
+msgstr ""
+#: ../lib/python/temporal/core.py:644
+#, python-format
+msgid ""
+"Unsupported temporal database: version mismatch.\n"
+" %(backup)s Supported temporal API version is: %(api)i.\n"
+"Please update your GRASS GIS installation.\n"
+msgstr ""
+#: ../lib/python/temporal/core.py:652
+#, python-format
+msgid ""
+" %(backup)sSupported temporal database version is: %(tdb)i\n"
+msgstr ""
+#: ../lib/python/temporal/core.py:740
+#, python-format
+msgid "Creating temporal database: %s"
+msgstr ""
+#: ../lib/python/temporal/core.py:749
+#, python-format
+msgid ""
+"Unable to create SQLite temporal database\n"
+"Exception: %s\n"
+"Please use t.connect to set a read- and writable temporal database path"
+msgstr ""
+#: ../lib/python/temporal/core.py:913
+#, python-format
+msgid ""
+"Unable to mogrify sql statement. There is no temporal database connection "
+"defined for mapset <%(mapset)s>"
+msgstr ""
+#: ../lib/python/temporal/core.py:936
+#, python-format
+msgid ""
+"Unable to check table. There is no temporal database connection defined for "
+"mapset <%(mapset)s>"
+msgstr ""
+#: ../lib/python/temporal/core.py:953
+#, python-format
+msgid ""
+"Unable to execute sql statement. There is no temporal database connection "
+msgstr ""
+#: ../lib/python/temporal/core.py:964
+#, python-format
+msgid ""
+"Unable to fetch one. There is no temporal database connection defined for "
+msgstr ""
+#: ../lib/python/temporal/core.py:975
+#, python-format
+msgid ""
+"Unable to fetch all. There is no temporal database connection defined for "
+msgstr ""
+#: ../lib/python/temporal/core.py:993
+#, python-format
+msgid ""
+"Unable to execute transaction. There is no temporal database connection "
+msgstr ""
+#: ../lib/python/temporal/core.py:1074
+#, python-format
+msgid ""
+"Unable to connect to %(db)s database: %(string)s\n"
+"Exception: \"%(ex)s\"\n"
+"Please use t.connect to set a read- and writable temporal database backend"
+msgstr ""
+#: ../lib/python/temporal/core.py:1231
+#, python-format
+msgid ""
+"Unable to execute :\n"
+" %(sql)s"
+msgstr ""
+#: ../lib/python/temporal/core.py:1275
+#, python-format
+msgid ""
+"Unable to execute transaction:\n"
+" %(sql)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:155
+#: ../lib/python/temporal/abstract_space_time_dataset.py:289
+#, python-format
+msgid "Unknown temporal type \"%s\""
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:282
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1050
+#, python-format
+msgid "Wrong granularity: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:310
+#, python-format
+msgid "Unsupported temporal unit: %s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:360
+#, python-format
+msgid "Created register table <%s> for space time %s  dataset <%s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:678
+#: ../lib/python/temporal/abstract_space_time_dataset.py:920
+msgid "The space time datasets must be of the same temporal type"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:683
+#: ../lib/python/temporal/abstract_space_time_dataset.py:925
+msgid "The temporal map type of the sample dataset must be interval"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1487
+#, python-format
+msgid "Unable to get map ids from register table <%s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1569
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1605
+#: ../lib/python/temporal/datetime_math.py:451
+#, python-format
+msgid "Wrong granularity format: %s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1598
+#, python-format
+msgid ""
+"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1767
+#, python-format
+msgid ""
+"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1869
+#, python-format
+msgid ""
+"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1878
+msgid "Renaming of space time datasets is not supported for PostgreSQL."
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1943
+#, python-format
+msgid "Delete space time %s  dataset <%s> from temporal database"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1949
+#: ../lib/python/temporal/abstract_map_dataset.py:823
+#, python-format
+msgid ""
+"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
+"database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1962
+#, python-format
+msgid "Drop map register table: %s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2017
+msgid "Error in register table request"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2046
+#, python-format
+msgid ""
+"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
+"the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2055
+msgid ""
+"Only a map that was inserted in the temporal database can be registered in a "
+"space time dataset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2078
+#, python-format
+msgid "Map <%(id)s> with layer %(l)s has invalid time"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2082
+#, python-format
+msgid "Map <%s> has invalid time"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2100
+#, python-format
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
+"%(l)s are different"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2106
+#, python-format
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2121
+#, python-format
+msgid "Set temporal unit for space time %s dataset <%s> to %s"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2131
+#, python-format
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
+"layer %(l)s are different"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2137
+#, python-format
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
+"different"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2143
+msgid "Only maps from the same mapset can be registered"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2148
+#, python-format
+msgid "Map <%(map)s> with layer %(l)s is already registered."
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2152
+#, python-format
+msgid "Map <%s> is already registered."
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2200
+#, python-format
+msgid ""
+"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
+"temporal database. The mapset of the dataset does not match the current "
+"mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2213
+#, python-format
+msgid ""
+"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
+"%(base)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2219
+#, python-format
+msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2280
+#, python-format
+msgid ""
+"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:105
+msgid "Starting spatio-temporal sampling..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:107
+msgid "Starting temporal sampling..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:124
+msgid "No samples found for map calculation"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:151
+msgid ""
+"Found more than a single map in a sample granule. Only the first map is used "
+"for computation. Use t.rast.aggregate.ds to create synchronous raster "
+"datasets."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:169
+msgid "No maps registered in input dataset"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:185
+msgid "Starting mapcalc computation..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:256
+#, python-format
+msgid "Apply mapcalc expression: \"%s\""
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:275
+msgid "Error while mapcalc computation"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:281
+msgid "Starting map registration in temporal database..."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:438 ../lib/python/temporal/mapcalc.py:444
+#: ../lib/python/temporal/mapcalc.py:450 ../lib/python/temporal/mapcalc.py:456
+#: ../lib/python/temporal/mapcalc.py:462 ../lib/python/temporal/mapcalc.py:468
+#: ../lib/python/temporal/mapcalc.py:474 ../lib/python/temporal/mapcalc.py:480
+#: ../lib/python/temporal/mapcalc.py:486 ../lib/python/temporal/mapcalc.py:521
+#: ../lib/python/temporal/mapcalc.py:530 ../lib/python/temporal/mapcalc.py:539
+#: ../lib/python/temporal/mapcalc.py:548 ../lib/python/temporal/mapcalc.py:557
+#: ../lib/python/temporal/mapcalc.py:566 ../lib/python/temporal/mapcalc.py:575
+#: ../lib/python/temporal/mapcalc.py:584 ../lib/python/temporal/mapcalc.py:593
+#, python-format
+msgid "The temporal operators <%s> support only absolute time."
+msgstr ""
+#: ../lib/python/temporal/c_libraries_interface.py:427
+#: ../lib/python/temporal/c_libraries_interface.py:444
+msgid "Unable to read range file"
+msgstr ""
+#: ../lib/python/temporal/c_libraries_interface.py:522
+#, python-format
+msgid "Unable to load range of 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/c_libraries_interface.py:537
+#: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
+#: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
+msgid "Unable to close 3D raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:121
+#, python-format
+msgid "Aggregating %s raster maps"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:135
+#, python-format
+msgid ""
+"Raster map <%(name)s> is already in temporal database, use overwrite flag to "
+"overwrite"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:140
+#, python-format
+msgid "Computing aggregation of maps between %(st)s - %(end)s"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:165
+msgid "Error occurred in r.series computation"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:271
+#, python-format
+msgid "Aggregating %(len)i raster maps from %(start)s to %(end)s"
+msgstr ""
+#: ../lib/python/temporal/aggregation.py:289
+#, python-format
+msgid ""
+"Unable to perform aggregation. Output raster map <%(name)s> exists and "
+"overwrite flag was not set"
+msgstr ""
+#: ../lib/python/temporal/register.py:76 ../lib/python/temporal/register.py:79
+#, python-format
+msgid "%s= and %s= are mutually exclusive"
+msgstr ""
+#: ../lib/python/temporal/register.py:83
+#, python-format
+msgid "Please specify %s= and %s="
+msgstr ""
+#: ../lib/python/temporal/register.py:87
+#, python-format
+msgid "Please specify %s= or %s="
+msgstr ""
+#: ../lib/python/temporal/register.py:98
+#, python-format
+msgid ""
+"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
+"relative unit set for %(sp)s maps"
+msgstr ""
+#: ../lib/python/temporal/register.py:163
+msgid "Gathering map information..."
+msgstr ""
+#: ../lib/python/temporal/register.py:173
+#, python-format
+msgid "Unable to update %(t)s map <%(id)s>. The map does not exist."
+msgstr ""
+#: ../lib/python/temporal/register.py:191
+#, python-format
+msgid ""
+"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
+"timestamp and the start time is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:197
+#, python-format
+msgid ""
+"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
+"start time is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:205
+#, python-format
+msgid "%(u)s= can only be set for relative time"
+msgstr ""
+#: ../lib/python/temporal/register.py:208
+#, python-format
+msgid "%(u)s= must be set in case of relative time stamps"
+msgstr ""
+#: ../lib/python/temporal/register.py:221
+#, python-format
+msgid ""
+"Map is already registered in temporal database. Unable to update %(t)s map <"
+"%(id)s> with layer %(l)s. Overwrite flag is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:228
+#, python-format
+msgid ""
+"%(id)s>. Overwrite flag is not set."
+msgstr ""
+#: ../lib/python/temporal/register.py:252
+#, python-format
+msgid ""
+"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
+"different."
+msgstr ""
+#: ../lib/python/temporal/register.py:258
+#, python-format
+msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
+msgstr ""
+#: ../lib/python/temporal/register.py:304
+msgid "Registering maps in the temporal database..."
+msgstr ""
+#: ../lib/python/temporal/register.py:311
+msgid "Registering maps in the space time dataset..."
+msgstr ""
+#: ../lib/python/temporal/register.py:320
+msgid "Updating space time dataset..."
+msgstr ""
+#: ../lib/python/temporal/register.py:373
+#: ../lib/python/temporal/register.py:380
+#, python-format
+msgid "Unable to convert string \"%s\"into a datetime object"
+msgstr ""
+#: ../lib/python/temporal/register.py:388
+#: ../lib/python/temporal/register.py:393
+msgid "Error occurred in increment computation"
+msgstr ""
+#: ../lib/python/temporal/register.py:396
+#, python-format
+msgid ""
+"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
+"%(end)s"
+msgstr ""
+#: ../lib/python/temporal/register.py:401
+#, python-format
+msgid "Set absolute valid time for map <%s> to %s - %s"
+msgstr ""
+#: ../lib/python/temporal/register.py:418
+#, python-format
+msgid ""
+"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgstr ""
+#: ../lib/python/temporal/register.py:423
+#, python-format
+msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
+msgstr ""
+#: ../lib/python/temporal/base.py:379
+#, python-format
+msgid "Object <%s> not found in the temporal database"
+msgstr ""
+#: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
+msgid "Missing identifer"
+msgstr ""
+#: ../lib/python/temporal/base.py:620
+msgid "Wrong identifier, the mapset is missing"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:50
+#: ../lib/python/temporal/univar_statistics.py:149
+#, python-format
+msgid "Space time %(sp)s dataset <%(i)s> is empty"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:84
+#, python-format
+msgid "Unable to get statistics for raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:87
+#, python-format
+msgid "Unable to get statistics for 3d raster map <%s>"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:139
+#, python-format
+msgid "Space time %(sp)s dataset <%(i)s> not found"
+msgstr ""
+#: ../lib/python/temporal/univar_statistics.py:190
+#, python-format
+msgid "Unable to get statistics for vector map <%s>"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:256
+#: ../lib/python/temporal/datetime_math.py:273
+#, python-format
+msgid "Wrong increment format: %s"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:729
+msgid "Time string seems to specify relative time"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:741
+msgid "Dates Before Christ (BC) are not supported"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:745
+msgid "Time zones are not supported"
+msgstr ""
+#: ../lib/python/temporal/datetime_math.py:755
+#, python-format
+msgid "Unable to parse time string: %s"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:790
+msgid "Spatio temporal operators are not supported in granularity algebra mode"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:826
+msgid "All input space time datasets must have a valid temporal topology."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:834
+msgid "All input space time datasets must have the same temporal type."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1059
+#, python-format
+msgid "Removing un-needed or empty %s maps"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1106
+#, python-format
+msgid "Space time %s dataset <%s> not found"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1133
+#: ../lib/python/temporal/temporal_algebra.py:1137
+#, python-format
+msgid ""
+"Wrong temporal type of space time dataset <"
+"%s>                                       <%s> time is required"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:1157
+msgid "Wrong type of input "
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2031
+#, python-format
+msgid ""
+"The resulting space time dataset type <%(a)s> is different from the "
+"requested type <%(b)s>"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2037
+msgid ""
+"Maps that should be registered in the resulting space time dataset have "
+"different types."
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:2218
+#, python-format
+msgid ""
+"Wrong map type <%s> . TMAP only supports single maps that are registered in "
+"the temporal GRASS database"
+msgstr ""
+#: ../lib/python/temporal/list_stds.py:191
+msgid "Empty map list"
+msgstr ""
+#: ../lib/python/temporal/list_stds.py:202
+msgid "Empty entry in map list, this should not happen"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:118
+msgid ""
+"Projections are different. Unable to compute overlapping_2d for spatial "
+"extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:524
+msgid ""
+"Projections are different. Unable to compute is_in_2d for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:656
+msgid ""
+"Projections are different. Unable to compute equivalent_2d for spatial "
+"extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:761
+msgid ""
+"Projections are different. Unable to compute cover_2d for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:833
+msgid "Projections are different. Unable to compute cover for spatial extents"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:1685
+msgid "Volume computation is not supported for LL projections"
+msgstr ""
+#: ../lib/python/temporal/spatial_extent.py:1703
+msgid "Area computation is not supported for LL projections"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:341
+#, python-format
+msgid ""
+"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
+"%(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:348
+#, python-format
+msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:356
+#, python-format
+msgid ""
+"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:363
+#, python-format
+msgid "End time must be of type datetime for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:372
+#, python-format
+msgid ""
+"End time must be greater than start time for %(type)s map <%(id)s> with "
+"layer: %(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:380
+#: ../lib/python/temporal/abstract_map_dataset.py:473
+#, python-format
+msgid "End time must be greater than start time for %(type)s map <%(id)s>"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:451
+#, python-format
+msgid ""
+"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
+"%(l)s: %(u)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:458
+#, python-format
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:467
+#, python-format
+msgid ""
+"End time must be greater than start time for %(typ)s map <%(id)s> with layer "
+"%(l)s"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:782
+#, python-format
+msgid ""
+"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
+"greater than end time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:788
+#, python-format
+msgid ""
+"Map <%s> has incorrect time interval, start time is greater than end time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:794
+#, python-format
+msgid "Map <%s> has incorrect start time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:841
+#, python-format
+msgid "Delete %s dataset <%s> from temporal database"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:891
+#, python-format
+msgid ""
+"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+msgstr ""
+#: ../lib/python/script/db.py:149
+#, python-format
+msgid ""
+"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
+msgstr ""
+#: ../lib/python/script/db.py:159
+msgid "Fetching data failed"
+msgstr ""
+#: ../lib/python/script/task.py:54
+msgid "unknown"
+msgstr ""
+#: ../lib/python/script/task.py:168
+#, python-format
+msgid "Parameter element '%(element)s' not found: '%(value)s'"
+msgstr ""
+#: ../lib/python/script/task.py:183
+#, python-format
+msgid "Flag not found: %s"
+msgstr ""
+#: ../lib/python/script/task.py:202
+#, python-format
+msgid "Parameter '%(name)s' (%(desc)s) is missing."
+msgstr ""
+#: ../lib/python/script/task.py:235
+msgid "<required>"
+msgstr ""
+#: ../lib/python/script/task.py:495 ../lib/python/script/task.py:499
+#, python-format
+msgid ""
+"Unable to fetch interface description for command '%(cmd)s'.\n"
+"\n"
+"Details: %(det)s"
+msgstr ""
+#: ../lib/python/script/task.py:519
+msgid "Cannot parse interface description of<{name}> module: {error}"
+msgstr ""
+#: ../lib/python/script/core.py:287
+#, python-format
+msgid ""
+"To run the module <%s> add underscore at the end of the option <%s> to avoid "
+"conflict with Python keywords. Underscore at the beginning is depreciated in "
+"GRASS GIS 7.0 and will be removed in version 7.1."
+msgstr ""
+#: ../lib/python/script/core.py:909
+msgid "Mixing value types. Will try to compare after integer conversion"
+msgstr ""
+#: ../lib/python/script/core.py:1104
+#, python-format
+msgid "Element type should be \"cell\" and not \"%s\""
+msgstr ""
+#: ../lib/python/script/core.py:1133 ../lib/python/script/core.py:1198
+#, python-format
+msgid "Element type should be \"raster\" and not \"%s\""
+msgstr ""
+#: ../lib/python/script/core.py:1353
+msgid "Unable to list mapsets"
+msgstr ""
+#: ../lib/python/script/core.py:1392
+#, python-format
+msgid "Location <%s> already exists. Operation canceled."
+msgstr ""
+#: ../lib/python/script/core.py:1395
+#, python-format
+msgid "Location <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/python/script/core.py:1532
+#, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+msgstr ""
+#: ../lib/python/script/core.py:1541
+#, python-format
+msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
+msgstr ""
+#: ../lib/python/script/vector.py:82
+#, python-format
+msgid "Database connection not defined for layer %s"
+msgstr ""
+#: ../lib/python/script/vector.py:222
+#, python-format
+msgid "Missing layer %(layer)d in vector map <%(map)s>"
+msgstr ""
+#: ../lib/python/script/vector.py:237
+msgid "vector_db_select() failed"
+msgstr ""
+#: ../lib/python/script/vector.py:387
+msgid ""
+"v.what output is not valid JSON format:\n"
+" {ret}"
+msgstr ""
+#: ../lib/python/script/raster3d.py:85
+msgid "An error occurred while running r3.mapcalc"
+msgstr ""
+#: ../lib/python/script/raster.py:46
+#, python-format
+msgid ""
+"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
+"current mapset."
+msgstr ""
+#: ../lib/python/script/raster.py:105
+msgid "An error occurred while running r.mapcalc"
+msgstr ""
+#: ../lib/python/script/raster.py:183
+msgid "No data"
+msgstr ""
+#: ../lib/python/script/raster.py:190
+msgid "value"
+msgstr ""
+msgid "label"
+msgstr ""
+msgid "color"
+msgstr ""
+#: ../lib/symbol/read.c:211
+#, c-format
+msgid "Cannot read symbol line coordinates: %s"
+msgstr ""
+#: ../lib/symbol/read.c:260
+#, c-format
+msgid ""
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr ""
+#: ../lib/symbol/read.c:284
+#, c-format
+msgid "Cannot find/open symbol: '%s'"
+msgstr ""
+#: ../lib/symbol/read.c:389 ../lib/symbol/read.c:407 ../lib/symbol/read.c:417
+#: ../lib/symbol/read.c:435
+#, c-format
+msgid "Incorrect symbol color: '%s', using default."
+msgstr ""
+#: ../lib/ogsf/trans.c:180
+msgid "Out of matrix stack space"
+msgstr ""
+#: ../lib/ogsf/trans.c:200
+msgid "Tried to pop an empty stack"
+msgstr ""
+#: ../lib/ogsf/gp3.c:148
+#, c-format
+msgid "No points from vector map <%s> fall within current region"
+msgstr ""
+#: ../lib/ogsf/gp3.c:153
+#, c-format
+msgid "Vector map <%s> loaded (%d points)"
+msgstr ""
+#: ../lib/ogsf/gp3.c:211
+#, c-format
+msgid "Loading thematic points layer <%s>..."
+msgstr ""
+#: ../lib/ogsf/gp3.c:235 ../lib/ogsf/gv3.c:377
+#, c-format
+msgid "No color rule defined for category %d"
+msgstr ""
+#: ../lib/ogsf/gp3.c:249 ../lib/ogsf/gv3.c:392
+#, c-format
+msgid "Invalid color definition (%s)"
+msgstr ""
+#: ../lib/ogsf/gp3.c:288
+#, c-format
+msgid ""
+"%d points without category. Unable to determine color rules for features "
+"without category."
+msgstr ""
+#: ../lib/ogsf/gp2.c:705
+msgid "Unknown icon marker, using \"sphere\""
+msgstr ""
+#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/gk2.c:216
+#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
+#, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr ""
+#: ../lib/ogsf/gs3.c:125 ../lib/ogsf/gs3.c:189 ../lib/ogsf/gs3.c:264
+#: ../lib/ogsf/gs3.c:336 ../lib/ogsf/gs3.c:442 ../lib/ogsf/gs3.c:529
+#: ../lib/ogsf/gs3.c:588 ../lib/ogsf/gs3.c:645 ../lib/ogsf/gs3.c:716
+#: ../lib/ogsf/gs3.c:786 ../lib/ogsf/gsd_legend.c:239
+#: ../lib/manage/do_remove.c:73 ../lib/manage/do_rename.c:71
+#: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97
+#: ../lib/rst/interp_float/output2d.c:236
+#: ../lib/rst/interp_float/output2d.c:317
+#: ../lib/rst/interp_float/output2d.c:386
+#: ../lib/rst/interp_float/output2d.c:436
+#: ../lib/rst/interp_float/output2d.c:450
+#: ../lib/rst/interp_float/output2d.c:464
+#: ../lib/rst/interp_float/output2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426 ../lib/raster/open.c:175
+#: ../lib/raster/open.c:744 ../lib/raster/open.c:781 ../lib/raster/open.c:833
+#, c-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
+#: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
+#, c-format
+msgid "Loading raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/gs3.c:596
+#, c-format
+msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
+msgstr ""
+#: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
+#, c-format
+msgid "Translating colors from raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/gs3.c:967
+msgid "View not saved by this program,there may be some inconsistancies"
+msgstr ""
+#: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
+msgid "Check no. of frames requested and keyframes marked"
+msgstr ""
+#: ../lib/ogsf/gs_bm.c:124
+msgid "Bitmap mismatch"
+msgstr ""
+#: ../lib/ogsf/gsd_prim.c:146
+#, c-format
+msgid "Color Material: %d"
+msgstr ""
+#: ../lib/ogsf/gsd_prim.c:630
+#, c-format
+msgid ""
+"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
+"advise GRASS developers of this error"
+msgstr ""
+#: ../lib/ogsf/gv3.c:269
+#, c-format
+msgid "No features from vector map <%s> fall within current region"
+msgstr ""
+#: ../lib/ogsf/gv3.c:274
+#, c-format
+msgid "Vector map <%s> loaded (%d features)"
+msgstr ""
+#: ../lib/ogsf/gv3.c:353
+#, c-format
+msgid "Loading thematic vector layer <%s>..."
+msgstr ""
+#: ../lib/ogsf/gv3.c:414
+#, c-format
+msgid ""
+"%d features without category. Unable to determine color rules for features "
+msgstr ""
+#: ../lib/ogsf/gsd_label.c:58
+msgid "Max. number of labels reached!"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1211
+#, c-format
+msgid "no category info"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1230
+#, c-format
+msgid "no data"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1655
+#, c-format
+msgid "Raster map <%s> is outside of current region. Load failed."
+msgstr ""
+#: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
+#: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
+#: ../lib/ogsf/gs2.c:1822
+msgid "GS_load_att_map(): Out of memory. Unable to load map"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1850
+msgid "Loading failed"
+msgstr ""
+#: ../lib/ogsf/gs2.c:1854
+msgid "Error finding range"
+msgstr ""
+#: ../lib/ogsf/gsd_surf.c:1742
+msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:246
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:252
+#, c-format
+msgid "Unable to read category file of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:269
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:281
+#, c-format
+msgid "Unable to read range of raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:295
+msgid "Range request error for legend"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:385
+msgid "Unable to show discrete FP range (use list)"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:501
+msgid "Too many categories to show as discrete!"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:503
+msgid "Try using smaller font!"
+msgstr ""
+#: ../lib/ogsf/gsds.c:109
+msgid "Maximum number of datasets exceeded"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:103
+msgid "Maximum number of datafiles exceeded"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:442
+#, c-format
+msgid "Unable to read range of 3D raster map <%s>"
+msgstr ""
+#: ../lib/ogsf/gvl2.c:267
+#, c-format
+msgid "Loading 3d raster map <%s>..."
+msgstr ""
+#: ../lib/ogsf/gk.c:320
+msgid "Need at least 3 keyframes for spline"
+msgstr ""
+#: ../lib/ogsf/gk.c:622
+msgid "Need at least 2 keyframes for interpolation"
+msgstr ""
+#: ../lib/ogsf/gsdrape.c:207
+msgid "Unable to process vector map - out of memory"
+msgstr ""
+#: ../lib/cluster/c_begin.c:57
+#, c-format
+msgid "produced by i.cluster"
+msgstr ""
+#: ../lib/cluster/c_exec.c:44
+#, c-format
+msgid "Not enough data points (%d) in cluster"
+msgstr ""
+#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
+#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
+#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
+#: ../lib/lidar/raster.c:175
+#, c-format
+msgid "Unable to access table <%s>"
+msgstr ""
+#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
+#, c-format
+msgid "<%s> created in database."
+msgstr ""
+#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
+#, c-format
+msgid "<%s> has not been created in database."
+msgstr ""
+#: ../lib/arraystats/class.c:19
+#, c-format
+msgid "Unknown algorithm '%s'"
+msgstr ""
+#: ../lib/arraystats/class.c:42
+msgid "Discont algorithm currently not available because of bugs"
+msgstr ""
+#: ../lib/arraystats/class.c:49
+msgid "Classification algorithm failed"
+msgstr ""
+#: ../lib/arraystats/class.c:227
+msgid "Equiprobable classbreaks currently limited to 10 classes"
+msgstr ""
+#: ../lib/arraystats/class.c:242
+#, c-format
+msgid ""
+"There are classbreaks outside the range min-max. Number of classes reduced "
+"to %i, but using probabilities for %i classes."
+msgstr ""
+#: ../lib/psdriver/graph_set.c:199
+#, c-format
+msgid "ps: truecolor status %s"
+msgstr ""
+#: ../lib/psdriver/graph_set.c:214
+#, c-format
+msgid "ps: collecting to file '%s'"
+msgstr ""
+#: ../lib/psdriver/graph_set.c:215
+#, c-format
+msgid "ps: image size %dx%d"
+msgstr ""
+#: ../lib/raster3d/maskfn.c:77
+#, c-format
+msgid "Adding rule: %lf - %lf"
+msgstr ""
+#: ../lib/raster3d/maskfn.c:95
+#, c-format
+msgid "%s: illegal value spec"
+msgstr ""
+#: ../lib/raster3d/param.c:84
+msgid "Rast3d_get_standard3d_params: precision value invalid"
+msgstr ""
+#: ../lib/raster3d/param.c:105
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+msgstr ""
+#: ../lib/raster3d/param.c:129
+msgid "Window replacing the default"
+msgstr ""
+#: ../lib/raster3d/close.c:47
+#, c-format
+msgid "Unable to write history for 3D raster map <%s>"
+msgstr ""
+#: ../lib/raster3d/close.c:62
+#, c-format
+msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
+msgstr ""
+#: ../lib/raster3d/close.c:79
+msgid "Unable to flush all tiles"
+msgstr ""
+#: ../lib/raster3d/close.c:84
+msgid "Unable to flush index"
+msgstr ""
+#: ../lib/raster3d/close.c:94
+msgid "Unable to position file"
+msgstr ""
+#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
+#: ../lib/raster3d/close.c:191 ../lib/raster3d/header.c:217
+#, c-format
+msgid "Unable to write header for 3D raster map <%s>"
+msgstr ""
+#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
+#, c-format
+msgid "Unable to create 3D raster map <%s>"
+msgstr ""
+#: ../lib/raster3d/close.c:169
+msgid "Error in cache"
+msgstr ""
+#: ../lib/raster3d/range.c:73
+#, c-format
+msgid "Unable to open range file for [%s in %s]"
+msgstr ""
+#: ../lib/raster3d/range.c:88
+#, c-format
+msgid "Error reading range file for [%s in %s]"
+msgstr ""
+#: ../lib/raster3d/range.c:150
+#, c-format
+msgid "Unable to open range file for <%s>"
+msgstr ""
+#: ../lib/raster3d/open.c:20
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
+msgstr ""
+#: ../lib/raster3d/open.c:26
+msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
+msgstr ""
+#: ../lib/raster3d/open.c:37
+msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
+msgstr ""
+#: ../lib/raster3d/open.c:93
+msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
+msgstr ""
+#: ../lib/raster3d/open.c:98
+msgid "Rast3d_open_cell_old: can't rewind file"
+msgstr ""
+#: ../lib/raster3d/open.c:111
+msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
+msgstr ""
+#: ../lib/raster3d/open.c:119
+msgid "Rast3d_open_cell_old: projection does not match window projection"
+msgstr ""
+#: ../lib/raster3d/open.c:123
+msgid "Rast3d_open_cell_old: zone does not match window zone"
+msgstr ""
+#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
+msgid "Rast3d_open_cell_old: can't read header"
+msgstr ""
+#: ../lib/raster3d/open.c:141
+msgid "Rast3d_open_cell_old: index does not fit into long"
+msgstr ""
+#: ../lib/raster3d/open.c:145
+msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
+msgstr ""
+#: ../lib/raster3d/open.c:172
+msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
+msgstr ""
+#: ../lib/raster3d/open.c:219
+msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
+msgstr ""
+#: ../lib/raster3d/open.c:228
+msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
+msgstr ""
+#: ../lib/raster3d/open.c:233
+#, c-format
+msgid "map <%s> is not in the current mapset"
+msgstr ""
+#: ../lib/raster3d/open.c:243
+msgid "Rast3d_open_cell_new: could not open file"
+msgstr ""
+#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
+msgid "Rast3d_open_cell_new: can't write header"
+msgstr ""
+#: ../lib/raster3d/open.c:314
+msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
+msgstr ""
+#: ../lib/raster3d/color.c:354
+#, c-format
+msgid "mapset <%s> is not the current mapset"
+msgstr ""
+#: ../lib/raster3d/history.c:43
+#, c-format
+msgid "can't get history information for [%s] in mapset [%s]"
+msgstr ""
+#: ../lib/raster3d/test/test_main.c:98
+msgid "raster3d"
+msgstr ""
+#: ../lib/raster3d/test/test_main.c:99
+msgid "test"
+msgstr ""
+#: ../lib/manage/do_remove.c:42
+#, c-format
+msgid "Removing %s <%s>"
+msgstr ""
+#: ../lib/manage/do_remove.c:65
+msgid "Unable to delete vector map"
+msgstr ""
+#: ../lib/manage/do_remove.c:85
+#, c-format
+msgid "Unable to remove %s element"
+msgstr ""
+#: ../lib/manage/do_remove.c:89 ../lib/manage/do_remove.c:109
+#: ../lib/manage/do_rename.c:87 ../lib/manage/do_rename.c:107
+#: ../lib/manage/do_copy.c:61
+#, c-format
+msgid "%s is missing"
+msgstr ""
+#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
+#, c-format
+msgid "%s removed"
+msgstr ""
+#: ../lib/manage/do_remove.c:105
+#, c-format
+msgid "Unable to remove %s"
+msgstr ""
+#: ../lib/manage/do_remove.c:121
+#, c-format
+msgid "<%s> nothing removed"
+msgstr ""
+#: ../lib/manage/option.c:47
+#, c-format
+msgid "%s to be %s"
+msgstr ""
+#: ../lib/manage/option.c:51
+msgid "Raster"
+msgstr ""
+#: ../lib/manage/option.c:53
+msgid "Vector"
+msgstr ""
+#: ../lib/manage/option.c:55
+msgid "Region"
+msgstr ""
+#: ../lib/manage/option.c:57
+msgid "Group"
+msgstr ""
+#: ../lib/manage/do_rename.c:42
+#, c-format
+msgid "Rename %s <%s> to <%s>"
+msgstr ""
+#: ../lib/manage/do_rename.c:62
+#, c-format
+msgid "Unable to rename vector map <%s> to <%s>"
+msgstr ""
+#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
+#, c-format
+msgid "Unable to rename %s"
+msgstr ""
+#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
+#, c-format
+msgid "%s renamed"
+msgstr ""
+#: ../lib/manage/do_rename.c:119
+#, c-format
+msgid "<%s> nothing renamed"
+msgstr ""
+#: ../lib/manage/do_copy.c:43
+#, c-format
+msgid "Copy %s <%s> to current mapset as <%s>"
+msgstr ""
+#: ../lib/manage/do_copy.c:50
+#, c-format
+msgid "Unable to copy <%s> to current mapset as <%s>"
+msgstr ""
+#: ../lib/manage/do_copy.c:70
+#, c-format
+msgid "%s copied"
+msgstr ""
+#: ../lib/manage/read_list.c:73
+#, c-format
+msgid "Unable to open data base element list '%s'"
+msgstr ""
+#: ../lib/manage/read_list.c:134
+#, c-format
+msgid "Format error: file ('%s') line (%d) - %s"
+msgstr ""
+#: ../lib/manage/do_list.c:30
+#, c-format
+msgid "%s: invalid index %d"
+msgstr ""
+#: ../lib/gis/view.c:176
+#, c-format
+msgid "Unable to open %s for writing"
+msgstr ""
+#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
+#, c-format
+msgid "Unable to open %s for reading"
+msgstr ""
+#: ../lib/gis/view.c:465
+#, c-format
+msgid "GRASS window when view was saved:\n"
+msgstr ""
+#: ../lib/gis/view.c:545
+#, c-format
+msgid " Window saved in \"%s\" is completely outside of current GRASS window."
+msgstr ""
+#: ../lib/gis/view.c:549
+#, c-format
+msgid ""
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr ""
+#: ../lib/gis/parser_interface.c:329 ../lib/gis/parser_html.c:167
+#: ../lib/gis/parser_help.c:200 ../lib/gis/parser_rest.c:164
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../lib/gis/parser_interface.c:337 ../lib/gis/parser_html.c:171
+#: ../lib/gis/parser_help.c:202
+msgid "Print usage summary"
+msgstr ""
+#: ../lib/gis/parser_interface.c:344 ../lib/gis/parser_html.c:174
+#: ../lib/gis/parser_help.c:203 ../lib/gis/parser_rest.c:168
+msgid "Verbose module output"
+msgstr ""
+#: ../lib/gis/parser_interface.c:351 ../lib/gis/parser_html.c:177
+#: ../lib/gis/parser_help.c:204 ../lib/gis/parser_rest.c:171
+msgid "Quiet module output"
+msgstr ""
+#: ../lib/gis/location.c:61
+#, c-format
+msgid "LOCATION <%s> not available"
+msgstr ""
+#: ../lib/gis/proj3.c:60 ../lib/gis/units.c:210
+msgid "units"
+msgstr ""
+msgid "unit"
+msgstr ""
+#: ../lib/gis/parser_wps.c:490
+msgid "Multiple outputs are not supported by WPS 1.0.0"
+msgstr ""
+#: ../lib/gis/key_value3.c:33
+#, c-format
+msgid "Unable to open output file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:36
+#, c-format
+msgid "Error writing file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:39
+#, c-format
+msgid "Error closing output file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:60
+#, c-format
+msgid "Unable to open input file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:64
+#, c-format
+msgid "Error reading file <%s>: %s"
+msgstr ""
+#: ../lib/gis/key_value3.c:67
+#, c-format
+msgid "Error closing input file <%s>: %s"
+msgstr ""
+#: ../lib/gis/legal_name.c:39
+#, c-format
+msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
+msgstr ""
+#: ../lib/gis/legal_name.c:46
+#, c-format
+msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
+msgstr ""
+#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#, c-format
+msgid "Output raster map name <%s> is not valid map name"
+msgstr ""
+#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
+#, c-format
+msgid "Output raster map <%s> is used as input"
+msgstr ""
+#: ../lib/gis/find_file.c:114
+#, c-format
+msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
+msgstr ""
+#: ../lib/gis/find_file.c:127
+#, c-format
+msgid "Using <%s@%s>"
+msgstr ""
+#: ../lib/gis/worker.c:84
+msgid "Task already has a worker"
+msgstr ""
+#: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
+#, c-format
+msgid ""
+"Module built against version %s but trying to use version %s. You need to "
+"rebuild GRASS GIS or untangle multiple installations."
+msgstr ""
+#: ../lib/gis/gisinit.c:65
+#, c-format
+msgid "MAPSET %s - permission denied"
+msgstr ""
+#: ../lib/gis/gisinit.c:68
+#, c-format
+msgid "MAPSET %s not found at %s"
+msgstr ""
+#: ../lib/gis/gisinit.c:102
+msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr ""
+#: ../lib/gis/timestamp.c:292
+#, c-format
+msgid "Unable to create timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:301
+#, c-format
+msgid "Invalid timestamp specified for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:331
+#, c-format
+msgid "Unable to open timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:340
+#, c-format
+msgid "Invalid timestamp file for %s map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:479
+#, c-format
+msgid "Unable to open timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:488
+#, c-format
+msgid "Invalid timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:524
+#, c-format
+msgid "Unable to create timestamp file for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/timestamp.c:533
+#, c-format
+msgid "Invalid timestamp specified for vector map <%s@%s>"
+msgstr ""
+#: ../lib/gis/error.c:361
+msgid "WARNING: "
+msgstr ""
+#: ../lib/gis/error.c:362
+msgid "ERROR: "
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:141 ../lib/gis/rd_cellhd.c:152
+#: ../lib/gis/rd_cellhd.c:162 ../lib/gis/rd_cellhd.c:179
+#: ../lib/gis/rd_cellhd.c:195 ../lib/gis/rd_cellhd.c:203
+#: ../lib/gis/rd_cellhd.c:211 ../lib/gis/rd_cellhd.c:219
+#: ../lib/gis/rd_cellhd.c:227 ../lib/gis/rd_cellhd.c:235
+#: ../lib/gis/rd_cellhd.c:243 ../lib/gis/rd_cellhd.c:245
+#: ../lib/gis/rd_cellhd.c:253 ../lib/gis/rd_cellhd.c:255
+#: ../lib/gis/rd_cellhd.c:263 ../lib/gis/rd_cellhd.c:265
+#: ../lib/gis/rd_cellhd.c:273 ../lib/gis/rd_cellhd.c:275
+#: ../lib/gis/rd_cellhd.c:283 ../lib/gis/rd_cellhd.c:285
+#: ../lib/gis/rd_cellhd.c:293 ../lib/gis/rd_cellhd.c:295
+#: ../lib/gis/rd_cellhd.c:303 ../lib/gis/rd_cellhd.c:305
+#: ../lib/gis/rd_cellhd.c:313 ../lib/gis/rd_cellhd.c:315
+#: ../lib/gis/rd_cellhd.c:323 ../lib/gis/rd_cellhd.c:325
+#: ../lib/gis/rd_cellhd.c:333 ../lib/gis/rd_cellhd.c:335
+#: ../lib/gis/rd_cellhd.c:343 ../lib/gis/rd_cellhd.c:351
+#: ../lib/gis/rd_cellhd.c:355
+msgid "Syntax error in cell header"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:149
+msgid "Duplicate projection field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:159
+msgid "Duplicate zone field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:169 ../lib/gis/rd_cellhd.c:171
+#: ../lib/gis/rd_cellhd.c:360 ../lib/gis/rd_cellhd.c:362
+#: ../lib/gis/rd_cellhd.c:364 ../lib/gis/rd_cellhd.c:366
+#: ../lib/gis/rd_cellhd.c:368 ../lib/gis/rd_cellhd.c:370
+#: ../lib/gis/rd_cellhd.c:381 ../lib/gis/rd_cellhd.c:383
+#: ../lib/gis/rd_cellhd.c:385 ../lib/gis/rd_cellhd.c:387
+#, c-format
+msgid "Field <%s> missing"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:193
+msgid "Duplicate north field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:201
+msgid "Duplicate south field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:209
+msgid "Duplicate east field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:217
+msgid "Duplicate west field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:225
+msgid "Duplicate top field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:233
+msgid "Duplicate bottom field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:241
+msgid "Duplicate e-w resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:251
+msgid "Duplicate 3D e-w resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:261
+msgid "Duplicate n-s resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:271
+msgid "Duplicate 3D n-s resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:281
+msgid "Duplicate t-b resolution field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:291
+msgid "Duplicate rows field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:301
+msgid "Duplicate 3D rows field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:311
+msgid "Duplicate cols field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:321
+msgid "Duplicate 3D cols field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:331
+msgid "Duplicate depths field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:341
+msgid "Duplicate format field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:349
+msgid "Duplicate compressed field"
+msgstr ""
+#: ../lib/gis/make_mapset.c:66 ../lib/init/grass.py:592
+#, c-format, python-format
+msgid "Location <%s> doesn't exist"
+msgstr ""
+#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
+msgid "Unable to seek"
+msgstr ""
+#: ../lib/gis/seek.c:56
+msgid "Seek offset out of range"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:42 ../lib/gis/adj_cellhd.c:191
+msgid "Illegal n-s resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:46 ../lib/gis/adj_cellhd.c:197
+msgid "Illegal row value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:50 ../lib/gis/adj_cellhd.c:203
+msgid "Illegal e-w resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:54 ../lib/gis/adj_cellhd.c:209
+msgid "Illegal col value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:74 ../lib/gis/adj_cellhd.c:239
+#, c-format
+msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:244
+msgid "Illegal latitude for North"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:85 ../lib/gis/adj_cellhd.c:250
+#, c-format
+msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:255
+msgid "Illegal latitude for South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:267
+#, c-format
+msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:113 ../lib/gis/adj_cellhd.c:278
+#, c-format
+msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:126 ../lib/gis/adj_cellhd.c:291
+msgid "North must be north of South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:293
+msgid "North must be larger than South"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:296
+msgid "East must be larger than West"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:150 ../lib/gis/adj_cellhd.c:340
+msgid "Invalid coordinates"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:193
+msgid "Illegal n-s3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:199
+msgid "Illegal row3 value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:205
+msgid "Illegal e-w3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:211
+msgid "Illegal col3 value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:215
+msgid "Illegal t-b3 resolution value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:219
+msgid "Illegal depths value"
+msgstr ""
+#: ../lib/gis/adj_cellhd.c:299
+msgid "Top must be larger than Bottom"
+msgstr ""
+#: ../lib/gis/mapset.c:38
+msgid "MAPSET is not set"
+msgstr ""
+#: ../lib/gis/mapset.c:80
+#, c-format
+msgid "MAPSET <%s> not available"
+msgstr ""
+#: ../lib/gis/env.c:311
+msgid "GISRC - variable not set"
+msgstr ""
+#: ../lib/gis/env.c:343 ../lib/gis/env.c:369
+#, c-format
+msgid "Variable '%s' not set"
+msgstr ""
+#: ../lib/gis/open.c:66
+#, c-format
+msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open.c:82
+#, c-format
+msgid "G__open(read): Unable to open '%s': %s"
+msgstr ""
+#: ../lib/gis/open.c:91
+#, c-format
+msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
+#: ../lib/gis/open.c:109
+#, c-format
+msgid "G__open(write): Unable to open '%s': %s"
+msgstr ""
+#: ../lib/gis/home.c:39
+msgid "Unable to determine user's home directory"
+msgstr ""
+#: ../lib/gis/home.c:120
+#, c-format
+msgid "Failed to create directory [%s]"
+msgstr ""
+#: ../lib/gis/get_window.c:118
+#, c-format
+msgid "Unable to open element file <%s> for <%s@%s>"
+msgstr ""
+#: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
+#, c-format
+msgid "<%s> file not found for location <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:220
+#, c-format
+msgid "Unable to open ellipsoid table file <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
+#, c-format
+msgid "Invalid a: field '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:356
+#, c-format
+msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:370
+#, c-format
+msgid "Invalid es: field '%s' in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/get_ellipse.c:383
+#, c-format
+msgid "No ellipsoid info given in file %s in <%s>"
+msgstr ""
+#: ../lib/gis/mapset_msc.c:61
+#, c-format
+msgid "Unable to make mapset element %s (%s): %s"
+msgstr ""
+#: ../lib/gis/mapset_msc.c:65
+#, c-format
+msgid "Unable to access mapset element %s (%s): %s"
+msgstr ""
+#: ../lib/gis/parser_html.c:57 ../lib/gis/parser_rest.c:60
+msgid "NAME"
+msgstr ""
+#: ../lib/gis/parser_html.c:70 ../lib/gis/parser_rest.c:73
+msgid "KEYWORDS"
+msgstr ""
+#: ../lib/gis/parser_html.c:75 ../lib/gis/parser_rest.c:78
+msgid "SYNOPSIS"
+msgstr ""
+#: ../lib/gis/parser_html.c:141 ../lib/gis/parser_rest.c:146
+#: ../lib/init/grass.py:204
+msgid "Flags"
+msgstr ""
+#: ../lib/gis/parser_html.c:180 ../lib/gis/parser_help.c:205
+msgid "Force launching GUI dialog"
+msgstr ""
+#: ../lib/gis/parser_html.c:189 ../lib/gis/parser_rest.c:179
+#: ../lib/init/grass.py:217
+msgid "Parameters"
+msgstr ""
+#: ../lib/gis/parser_html.c:233 ../lib/gis/parser_rest.c:223
+msgid "Options"
+msgstr ""
+#: ../lib/gis/parser_html.c:239 ../lib/gis/parser_rest.c:230
+msgid "Default"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:122
+msgid "Internal error: option or flag not found"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:179
+#, c-format
+msgid "<%s> or <%s>"
+msgstr ""
+#, c-format
+msgid "<%s> and <%s>"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:212
+#, c-format
+msgid "Options %s are mutually exclusive"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:236
+#, c-format
+msgid "At least one of the following options is required: %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:269
+#, c-format
+msgid "Option %s requires at least one of %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:301
+#, c-format
+msgid "Option %s requires all of %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:328
+#, c-format
+msgid "Option %s is mutually exclusive with all of %s"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:354
+#, c-format
+msgid "Either all or none of %s must be given"
+msgstr ""
+#: ../lib/gis/parser_dependencies.c:387 ../lib/gis/parser_dependencies.c:424
+#, c-format
+msgid "Internal error: invalid rule type: %d"
+msgstr ""
+#: ../lib/gis/datum.c:160
+#, c-format
+msgid "unable to open datum table file: %s"
+msgstr ""
+#: ../lib/gis/datum.c:182
+#, c-format
+msgid "error in datum table file, line %d"
+msgstr ""
+#: ../lib/gis/parser_help.c:79
+msgid "Description:"
+msgstr ""
+#: ../lib/gis/parser_help.c:89
+msgid "Keywords:"
+msgstr ""
+#: ../lib/gis/parser_help.c:97
+msgid "Usage:"
+msgstr ""
+#: ../lib/gis/parser_help.c:127
+msgid "ERROR: Option key not defined"
+msgstr ""
+#: ../lib/gis/parser_help.c:177
+msgid "Flags:"
+msgstr ""
+#: ../lib/gis/parser_help.c:213
+msgid "Parameters:"
+msgstr ""
+#: ../lib/gis/parser_help.c:236
+#, c-format
+msgid "  %*s   default: %s\n"
+msgstr ""
+#: ../lib/gis/parser_help.c:262
+#, c-format
+msgid "  %*s   options: "
+msgstr ""
+#: ../lib/gis/debug.c:80
+#, c-format
+msgid "Cannot open debug file '%s'"
+msgstr ""
+#: ../lib/gis/myname.c:46
+msgid "This location has no description."
+msgstr ""
+#: ../lib/gis/paths.c:201
+#, c-format
+msgid "Unable to open file <%s> for reading"
+msgstr ""
+#: ../lib/gis/paths.c:217
+#, c-format
+msgid "Unable to fetch security info for <%s>"
+msgstr ""
+#: ../lib/gis/done_msg.c:38
+#, c-format
+msgid "%s complete. %s"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:146
+msgid "SQL select statement"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:148
+msgid "For example: 'select * from rybniky where kapri = 'hodne'"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:155
+msgid "WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:156
+msgid "Example: income < 1000 and inhab >= 10000"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:164
+msgid "Name of attribute table"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:173
+msgid "Name of database driver"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:182
+msgid "Name of database"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:191
+msgid "Database schema"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:192
+msgid ""
+"Do not use this option if schemas are not supported by driver/database server"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:201
+msgid "Name of attribute column"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:210
+msgid "Name of attribute column(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:219
+msgid "Name of key column"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:220
+msgid "Must refer to an integer column"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:232
+msgid "Name of input imagery group"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:240
+msgid "Name of input imagery subgroup"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:250
+msgid "Name of input raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:259
+msgid "Name of input raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:267
+msgid "Name for output raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:276
+msgid "Name for output raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:284
+msgid "Name of raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:293
+msgid "Name of raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:301
+msgid "Name of base raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:309
+msgid "Name of cover raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:317
+msgid "Name of input elevation raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:326
+msgid "Name of input elevation raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:332
+msgid "Sampling interpolation method"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:336
+msgid "Nearest-neighbor interpolation"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:337
+msgid "Bilinear interpolation"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:338
+msgid "Bicubic interpolation"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:347
+msgid "Name of input basename raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:356
+msgid "Name for output basename raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:366
+msgid "Name of input 3D raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:375
+msgid "Name of input 3D raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:383
+msgid "Name for output 3D raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:391
+msgid "Name of 3D raster map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:400
+msgid "Name of 3D raster map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:409
+msgid "Data type used in the output raster3d map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:418
+msgid ""
+"Number of digits used as mantissa in the internal map storage, 0 -23 for "
+"float, 0 - 52 for double, max or default"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:428
+msgid "The compression method used in the output raster3d map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:438
+msgid ""
+"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
+"default: 16x16x8)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:448
+msgid "Name of input vector map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:449
+#: ../lib/gis/parser_standard_options.c:476
+msgid "Or data source for direct OGR access"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:458
+msgid "Name of input vector map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:459
+msgid "Or data source(s) for direct OGR access"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:467
+msgid "Name for output vector map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:475
+msgid "Name of vector map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:485
+msgid "Name of vector map(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:494
+#: ../lib/gis/parser_standard_options.c:503
+msgid "Input feature type"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:510
+msgid "Layer number or name"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:512
+msgid ""
+"Vector features can have category values in different layers. This number "
+"determines which layer to use. When used with direct OGR access this is the "
+"layer name."
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:522
+msgid "Layer number or name ('-1' for all layers)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:524
+msgid ""
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use. When used with direct OGR access this "
+"is the layer name."
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:533
+msgid "Category value"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:540
+msgid "Category values"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:541
+#: ../lib/gis/parser_standard_options.c:555
+msgid "Example: 1,3,7-9,13"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:547
+msgid "Feature id"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:554
+msgid "Feature ids"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:565
+#: ../lib/gis/parser_standard_options.c:573
+msgid "Name of input file"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:581
+msgid "Name for output file"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:590
+msgid "Field separator"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:591
+msgid "Special characters: pipe, comma, space, tab, newline"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:602
+#: ../lib/gis/parser_standard_options.c:613
+msgid "Color"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:604
+msgid "Either a standard color name or R:G:B triplet"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:615
+msgid "Either a standard color name, R:G:B triplet, or \"none\""
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:626
+msgid "Name of input directory"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:636
+msgid "Units"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:645
+msgid "Data type(s)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:655
+msgid "Name of mapset (default: current search path)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:656
+msgid "'.' for current mapset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:664
+msgid "Location name"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:665
+msgid "Location name (not location path)"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:675
+msgid "GRASS GIS database directory"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:676
+msgid "Default: path to the current GRASS GIS database"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:688
+msgid "Coordinates"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:697
+msgid "Name of color table"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:708
+msgid "String representing NULL value"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:717
+msgid "Name of saved region"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:727
+msgid "Name of the input space time dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:736
+msgid "Name of the input space time datasets"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:744
+msgid "Name of the output space time dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:752
+msgid "Name of the input space time raster dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:761
+msgid "Name of the input space time raster datasets"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:769
+msgid "Name of the output space time raster dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:777
+msgid "Name of the input space time vector dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:786
+msgid "Name of the input space time vector datasets"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:794
+msgid "Name of the output space time vector dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:802
+msgid "Name of the input space time raster3d dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:811
+msgid "Name of the input space time raster3d datasets"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:819
+msgid "Name of the output space time raster3d dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:828
+msgid "Type of the input space time dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:836
+msgid "Name of the input map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:845
+msgid "Name of the input maps"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:854
+msgid "Type of the input map"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:863
+msgid "The temporal type of the space time dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:870
+msgid ""
+"WHERE conditions of SQL statement without 'where' keyword used in the "
+"temporal GIS framework"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:871
+msgid "Example: start_time > '2001-01-01 12:30:00'"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:881
+msgid "The method to be used for sampling the input dataset"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:915
+msgid "Do not create attribute table"
+msgstr ""
+#: ../lib/gis/parser_standard_options.c:919
+msgid "Do not build topology"
+msgstr ""
+#: ../lib/gis/open_misc.c:49
+#, c-format
+msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
+msgstr ""
+#: ../lib/gis/open_misc.c:74
+#, c-format
+msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
+msgstr ""
+#: ../lib/gis/mkstemp.c:132
+msgid "Attempt to create read-only temporary file"
+msgstr ""
+#: ../lib/gis/mkstemp.c:138
+#, c-format
+msgid "Unrecognised access mode: %o"
+msgstr ""
+#: ../lib/gis/lrand48.c:79
+#, c-format
+msgid "gettimeofday failed: %s"
+msgstr ""
+#: ../lib/gis/lrand48.c:108
+msgid "Pseudo-random number generator not seeded"
+msgstr ""
+#: ../lib/gis/spawn.c:386
+#, c-format
+msgid "CreateProcess() failed: error = %d"
+msgstr ""
+#: ../lib/gis/spawn.c:421
+#, c-format
+msgid "G_spawn: unable to redirect descriptor %d"
+msgstr ""
+#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
+#, c-format
+msgid "G_spawn: unable to open file %s"
+msgstr ""
+#: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
+msgid "Unable to execute command"
+msgstr ""
+#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
+#, c-format
+msgid "G_spawn: unable to restore signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:567
+#, c-format
+msgid "G_spawn: unable to reset signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:576
+#, c-format
+msgid "G_spawn: unable to ignore signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:587
+#, c-format
+msgid "G_spawn: unable to block signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:595
+#, c-format
+msgid "G_spawn: unable to unblock signal %d"
+msgstr ""
+#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
+#, c-format
+msgid "G_spawn: unable to duplicate descriptor %d to %d"
+msgstr ""
+#: ../lib/gis/spawn.c:666
+msgid "Unable to create a new process"
+msgstr ""
+#: ../lib/gis/spawn.c:681
+#, c-format
+msgid "Unable to change directory to %s"
+msgstr ""
+#: ../lib/gis/list.c:83
+#, c-format
+msgid "no %s files available in current mapset\n"
+msgstr ""
+#: ../lib/gis/list.c:86
+#, c-format
+msgid "no %s files available in mapset <%s>\n"
+msgstr ""
+#: ../lib/gis/list.c:132
+#, c-format
+msgid "%s files available in mapset <%s>:\n"
+msgstr ""
+#: ../lib/gis/list.c:204
+msgid "G_list: Unknown element type"
+msgstr ""
+#: ../lib/gis/color_rules.c:88
+msgid "no description"
+msgstr ""
+#: ../lib/gis/parser.c:351
+#, c-format
+msgid "BUG in option name, '%s' is not valid"
+msgstr ""
+#: ../lib/gis/parser.c:403
+#, c-format
+msgid "BUG in descriptions, option '%s' in <%s> does not exist"
+msgstr ""
+#: ../lib/gis/parser.c:519
+msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+msgstr ""
+#: ../lib/gis/parser.c:533
+msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+msgstr ""
+#: ../lib/gis/parser.c:564
+#, c-format
+msgid "Sorry <%s> is not a valid option"
+msgstr ""
+#: ../lib/gis/parser.c:599 ../lib/init/grass.py:129
+msgid "ERROR"
+msgstr ""
+#: ../lib/gis/parser.c:836
+msgid "Unable to determine program name"
+msgstr ""
+#: ../lib/gis/parser.c:852 ../lib/gis/parser.c:869
+#, c-format
+msgid "%s: Sorry, <%c> is not a valid flag"
+msgstr ""
+#: ../lib/gis/parser.c:999
+#, c-format
+msgid "%s: Sorry, <%s=> is ambiguous"
+msgstr ""
+#: ../lib/gis/parser.c:1002
+#, c-format
+msgid "Option <%s=> matches"
+msgstr ""
+#: ../lib/gis/parser.c:1020
+#, c-format
+msgid "Please update the usage of <%s>: option <%s> has been renamed to <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:1033
+#, c-format
+msgid "%s: Sorry, <%s> is not a valid parameter"
+msgstr ""
+#: ../lib/gis/parser.c:1039 ../lib/gis/parser.c:1284
+#, c-format
+msgid "<%s> is an abbreviation for <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:1044
+#, c-format
+msgid "Option <%s> does not accept multiple answers"
+msgstr ""
+#: ../lib/gis/parser.c:1115
+#, c-format
+msgid ""
+"Illegal range syntax for parameter <%s>\n"
+"\tPresented as: %s"
+msgstr ""
+#: ../lib/gis/parser.c:1121
+#, c-format
+msgid ""
+"Value <%s> out of range for parameter <%s>\n"
+"\tLegal range: %s"
+msgstr ""
+#: ../lib/gis/parser.c:1127
+#, c-format
+msgid "Missing value for parameter <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:1133
+#, c-format
+msgid ""
+"Value <%s> ambiguous for parameter <%s>\n"
+"\tValid options: %s"
+msgstr ""
+#: ../lib/gis/parser.c:1306
+#, c-format
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
+msgstr ""
+#: ../lib/gis/parser.c:1398
+#, c-format
+msgid ""
+"Option <%s> must be provided in multiples of %d\n"
+"\tYou provided %d item(s): %s"
+msgstr ""
+#: ../lib/gis/parser.c:1473
+#, c-format
+msgid "ERROR: option <%s>: <%s> exists.\n"
+msgstr ""
+#: ../lib/gis/parser.c:1587
+#, c-format
+msgid "%s= is not a separator option"
+msgstr ""
+#: ../lib/gis/parser.c:1590
+#, c-format
+msgid "No separator given for %s="
+msgstr ""
+#: ../lib/gis/parser.c:1652 ../lib/gis/parser.c:1669
+#, c-format
+msgid "%s= is not a file option"
+msgstr ""
+#: ../lib/gis/parser.c:1654
+#, c-format
+msgid "Opening multiple files not supported for %s="
+msgstr ""
+#: ../lib/gis/parser.c:1660
+#, c-format
+msgid "Unable to open %s file <%s>"
+msgstr ""
+#: ../lib/gis/parser.c:1666
+#, c-format
+msgid "Unable to create %s file <%s>"
+msgstr ""
+#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#, c-format
+msgid "Current region rows: %d, cols: %d"
+msgstr ""
+#: ../lib/gis/alloc.c:47
+#, c-format
+msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/alloc.c:89
+#, c-format
+msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/alloc.c:135
+#, c-format
+msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
+msgstr ""
+#: ../lib/gis/distance.c:154
+#, c-format
+msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr ""
+#: ../lib/gis/units.c:208
+msgid "square units"
+msgstr ""
+msgid "square unit"
+msgstr ""
+#: ../lib/gis/units.c:215
+msgid "square meters"
+msgstr ""
+msgid "square meter"
+msgstr ""
+#: ../lib/gis/units.c:217
+msgid "meters"
+msgstr ""
+msgid "meter"
+msgstr ""
+#: ../lib/gis/units.c:222
+msgid "square kilometers"
+msgstr ""
+msgid "square kilometer"
+msgstr ""
+#: ../lib/gis/units.c:224
+msgid "kilometers"
+msgstr ""
+msgid "kilometer"
+msgstr ""
+#: ../lib/gis/units.c:229
+msgid "acres"
+msgstr ""
+msgid "acre"
+msgstr ""
+#: ../lib/gis/units.c:237
+msgid "hectares"
+msgstr ""
+msgid "hectare"
+msgstr ""
+#: ../lib/gis/units.c:245
+msgid "square miles"
+msgstr ""
+msgid "square mile"
+msgstr ""
+#: ../lib/gis/units.c:247
+msgid "miles"
+msgstr ""
+msgid "mile"
+msgstr ""
+#: ../lib/gis/units.c:252
+msgid "square feet"
+msgstr ""
+msgid "square foot"
+msgstr ""
+#: ../lib/gis/units.c:254
+msgid "feet"
+msgstr ""
+msgid "foot"
+msgstr ""
+#: ../lib/gis/units.c:259
+msgid "square US feet"
+msgstr ""
+msgid "square US foot"
+msgstr ""
+#: ../lib/gis/units.c:261
+msgid "US feet"
+msgstr ""
+msgid "US foot"
+msgstr ""
+#: ../lib/gis/units.c:266
+msgid "square degrees"
+msgstr ""
+msgid "square degree"
+msgstr ""
+#: ../lib/gis/units.c:268
+msgid "degrees"
+msgstr ""
+msgid "degree"
+msgstr ""
+#: ../lib/gis/units.c:272
+msgid "years"
+msgstr ""
+msgid "year"
+msgstr ""
+#: ../lib/gis/units.c:276
+msgid "months"
+msgstr ""
+msgid "month"
+msgstr ""
+#: ../lib/gis/units.c:280
+msgid "days"
+msgstr ""
+msgid "day"
+msgstr ""
+#: ../lib/gis/units.c:284
+msgid "hours"
+msgstr ""
+msgid "hour"
+msgstr ""
+#: ../lib/gis/units.c:288
+msgid "minutes"
+msgstr ""
+msgid "minute"
+msgstr ""
+#: ../lib/gis/units.c:292
+msgid "seconds"
+msgstr ""
+msgid "second"
+msgstr ""
+#: ../lib/gis/ls.c:103
+#, c-format
+msgid "Unable to open directory %s"
+msgstr ""
+#: ../lib/gis/proj2.c:63
+msgid "Latitude-Longitude"
+msgstr ""
+#: ../lib/gis/proj2.c:65
+msgid "Other Projection"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:73
+#, c-format
+msgid "Vector map <%s> is not 3D"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:76
+msgid "Loading data from attribute table ..."
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:97
+#: ../lib/rst/interp_float/vinput2d.c:110
+#, c-format
+msgid "Data type of column <%s> must be numeric"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:121
+msgid "Reading features from vector map ..."
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:153
+#, c-format
+msgid "Database record for cat %d not found"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:171
+msgid "Negative value of smoothing detected: sm must be >= 0"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:235
+msgid "Strip exists with insufficient data"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:249
+#, c-format
+msgid "There are points outside specified 2D/3D region - %d points ignored"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:252
+#, c-format
+msgid "Ignoring %d points (too dense)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:256
+#, c-format
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:261
+msgid "Zero points in the given region"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:266
+#, c-format
+msgid ""
+"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
+"smooth connection of segments, npmin > segmax (see manual)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:272
+#, c-format
+msgid ""
+"There are less than %d points for interpolation. No segmentation is "
+"necessary, to run the program faster set segmax=%d (see manual)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:276
+#, c-format
+msgid "Number of points from vector map %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:277
+#, c-format
+msgid "Number of points outside of 2D/3D region %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:279
+#, c-format
+msgid "Number of points being used %d"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:312
+msgid "Some points outside of region (ignored)"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:318
+msgid "Unable to allocate memory"
+msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:326
+#, c-format
+msgid "Unable to insert %f,%f,%f a = %d"
+msgstr ""
+#: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
+#: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
+#: ../lib/rst/interp_float/write2d.c:83 ../lib/rst/interp_float/write2d.c:91
+msgid "Cannot write files"
+msgstr ""
+#: ../lib/rst/interp_float/segmen2d.c:118
+msgid ""
+"Taking too long to find points for interpolation - please change the region "
+"to area where your points are. Continuing calculations..."
+msgstr ""
+#: ../lib/rst/interp_float/input2d.c:48
+#, c-format
+msgid "Mask raster map <%s> not found"
+msgstr ""
+#: ../lib/rst/interp_float/input2d.c:71
+msgid "Bitmap mask created"
+msgstr ""
+#: ../lib/rst/interp_float/output2d.c:106
+#, c-format
+msgid "First change your rows number to nsizr! %d %d"
+msgstr ""
+#: ../lib/rst/interp_float/output2d.c:113
+#, c-format
+msgid "First change your cols number to nsizc %d %d"
+msgstr ""
+#: ../lib/rst/interp_float/interp2d.c:214
+#, c-format
+msgid ""
+"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
+"cell. Z-value %f, zmin %f, zmax %f."
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:77
+msgid "Temporarily changing the region to desired resolution..."
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:103
+#, c-format
+msgid "First change your rows number(%d) to %d"
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:110
+#, c-format
+msgid "First change your columns number(%d) to %d"
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:264
+msgid "No color table for input raster map -- will not create color table"
+msgstr ""
+#: ../lib/rst/interp_float/resout2d.c:458
+msgid "Changing the region back to initial..."
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:84
+#, c-format
+msgid "sparse Jacobi -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:156
+#, c-format
+msgid "sparse SOR -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:218
+#, c-format
+msgid "Jacobi -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_classic_iter.c:275
+#, c-format
+msgid "SOR -- iteration %5i error %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:45
+msgid "Starting direct gauss elimination solver"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:73
+msgid "Starting direct lu decomposition solver"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:131
+msgid "Starting cholesky decomposition solver"
+msgstr ""
+#: ../lib/gmath/solvers_direct.c:134 ../lib/gmath/solvers_krylov.c:254
+#: ../lib/gmath/solvers_krylov.c:482 ../lib/gmath/solvers_krylov.c:646
+msgid "Unable to solve the linear equation system"
+msgstr ""
+#: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
+msgid "Matrix dimensions out of range"
+msgstr ""
+#: ../lib/gmath/la.c:150
+msgid "Matrix is not initialised fully."
+msgstr ""
+#: ../lib/gmath/la.c:155
+msgid "Unable to allocate space for matrix copy"
+msgstr ""
+#: ../lib/gmath/la.c:220
+msgid "Input matrix is uninitialized"
+msgstr ""
+#: ../lib/gmath/la.c:285
+msgid "First scalar multiplier must be non-zero"
+msgstr ""
+#: ../lib/gmath/la.c:291 ../lib/gmath/la.c:299 ../lib/gmath/la.c:364
+msgid "One or both input matrices uninitialised"
+msgstr ""
+#: ../lib/gmath/la.c:304 ../lib/gmath/la.c:369
+msgid "Matrix order does not match"
+msgstr ""
+#: ../lib/gmath/la.c:310
+msgid "Unable to allocate space for matrix sum"
+msgstr ""
+#: ../lib/gmath/la.c:374
+msgid "Unable to allocate space for matrix product"
+msgstr ""
+#: ../lib/gmath/la.c:486
+msgid "Input: one or both data matrices uninitialised"
+msgstr ""
+#: ../lib/gmath/la.c:491
+msgid "Principal matrix is not properly dimensioned"
+msgstr ""
+#: ../lib/gmath/la.c:496
+msgid "Input: you must have at least one array to solve"
+msgstr ""
+#: ../lib/gmath/la.c:502
+msgid "Could not allocate space for solution matrix"
+msgstr ""
+#: ../lib/gmath/la.c:508 ../lib/gmath/la.c:516
+msgid "Could not allocate space for working matrix"
+msgstr ""
+#: ../lib/gmath/la.c:569
+msgid "Matrix (or submatrix is singular). Solution undetermined"
+msgstr ""
+#: ../lib/gmath/la.c:573
+msgid "Problem in LA routine."
+msgstr ""
+#: ../lib/gmath/la.c:580
+msgid "Procedure not yet available for selected matrix type"
+msgstr ""
+#: ../lib/gmath/la.c:614
+msgid "Matrix is not square. Cannot determine inverse"
+msgstr ""
+#: ../lib/gmath/la.c:619
+msgid "Unable to allocate space for matrix"
+msgstr ""
+#: ../lib/gmath/la.c:636
+msgid "Matrix is singular"
+msgstr ""
+#: ../lib/gmath/la.c:641
+msgid "Problem in LA procedure."
+msgstr ""
+#: ../lib/gmath/la.c:729
+msgid "Element array has not been allocated"
+msgstr ""
+#: ../lib/gmath/la.c:734
+msgid "Specified element is outside array bounds"
+msgstr ""
+#: ../lib/gmath/la.c:788
+msgid "Specified matrix column index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:793 ../lib/gmath/la.c:834 ../lib/gmath/la.c:1198
+#: ../lib/gmath/la.c:1250 ../lib/gmath/la.c:1325
+msgid "Matrix is not initialised"
+msgstr ""
+#: ../lib/gmath/la.c:798 ../lib/gmath/la.c:839
+msgid "Could not allocate space for vector structure"
+msgstr ""
+#: ../lib/gmath/la.c:829
+msgid "Specified matrix row index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:869
+msgid "Specified row index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:874
+msgid "Specified column index is outside range"
+msgstr ""
+#: ../lib/gmath/la.c:894
+msgid "Unknown vector type."
+msgstr ""
+#: ../lib/gmath/la.c:949
+msgid "Input matrix and vector have differing dimensions1"
+msgstr ""
+#: ../lib/gmath/la.c:955 ../lib/gmath/la.c:1071 ../lib/gmath/la.c:1361
+msgid "Output vector is uninitialized"
+msgstr ""
+#: ../lib/gmath/la.c:1076 ../lib/gmath/la.c:1366
+msgid "Vectors are not of the same type"
+msgstr ""
+#: ../lib/gmath/la.c:1081 ../lib/gmath/la.c:1371
+msgid "Output vector is of incorrect type"
+msgstr ""
+#: ../lib/gmath/la.c:1086 ../lib/gmath/la.c:1376
+msgid "Matrices not allowed"
+msgstr ""
+#: ../lib/gmath/la.c:1092 ../lib/gmath/la.c:1383
+msgid "Vectors have differing dimensions"
+msgstr ""
+#: ../lib/gmath/la.c:1098 ../lib/gmath/la.c:1390
+msgid "Output vector has incorrect dimension"
+msgstr ""
+#: ../lib/gmath/la.c:1143
+msgid "Vector dimensions out of range"
+msgstr ""
+#: ../lib/gmath/la.c:1148
+msgid "Row/column out of range"
+msgstr ""
+#: ../lib/gmath/la.c:1437
+msgid "Vector structure is not initialised"
+msgstr ""
+#: ../lib/gmath/la.c:1558 ../lib/gmath/la.c:1566 ../lib/gmath/la.c:1571
+msgid "Input format error"
+msgstr ""
+#: ../lib/gmath/del2g.c:50
+msgid "    taking FFT of image..."
+msgstr ""
+#: ../lib/gmath/del2g.c:56
+msgid "    computing del**2 g..."
+msgstr ""
+#: ../lib/gmath/del2g.c:59
+msgid "    taking FFT of del**2 g..."
+msgstr ""
+#: ../lib/gmath/del2g.c:63
+msgid "    multiplying transforms..."
+msgstr ""
+#: ../lib/gmath/del2g.c:66
+msgid "    taking inverse FFT..."
+msgstr ""
+#: ../lib/gmath/solvers_direct_cholesky_band.c:33
+#, c-format
+msgid "Decomposition failed at row %i and col %i"
+msgstr ""
+#: ../lib/gmath/test/bench_blas2.c:35
+msgid ""
+"\n"
+"++ Running blas level 2 benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:61
+msgid "The size of the matrices and vectors for benchmarking"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:68
+msgid "Choose solver benchmark"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:75
+msgid "Choose blas benchmark"
+msgstr ""
+#: ../lib/gmath/test/test_main.c:106
+msgid "Performs benchmarks, unit and integration tests for the gmath library"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:37
+msgid ""
+"\n"
+"++ Running ccmath wrapper unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:42
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_ccmath_wrapper.c:44
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:37
+msgid ""
+"\n"
+"++ Running solver unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:42
+msgid ""
+"\n"
+"-- Solver unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_solvers.c:44
+msgid ""
+"\n"
+"-- Solver unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/bench_blas3.c:34
+msgid ""
+"\n"
+"++ Running blas level 3 benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/bench_solver_krylov.c:34
+msgid ""
+"\n"
+"++ Running krylov solver benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:38
+msgid ""
+"\n"
+"++ Running blas level 3 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:44
+msgid ""
+"\n"
+"-- blas level 3 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas3.c:46
+msgid ""
+"\n"
+"-- blas level 3 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:40
+msgid ""
+"\n"
+"++ Running blas level 1 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:47
+msgid ""
+"\n"
+"-- blas level 1 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas1.c:49
+msgid ""
+"\n"
+"-- blas level 1 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/bench_solver_direct.c:34
+msgid ""
+"\n"
+"++ Running direct solver benchmark ++"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:37
+msgid ""
+"\n"
+"++ Running matrix conversion unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:42
+msgid ""
+"\n"
+"-- Matrix conversion unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_matrix_conversion.c:44
+msgid ""
+"\n"
+"-- Matrix conversion unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:38
+msgid ""
+"\n"
+"++ Running blas level 2 unit tests ++"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:44
+msgid ""
+"\n"
+"-- blas level 2 unit tests failure --"
+msgstr ""
+#: ../lib/gmath/test/test_blas2.c:46
+msgid ""
+"\n"
+"-- blas level 2 unit tests finished successfully --"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:262
+#, c-format
+msgid "Sparse PCG -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:264
+#, c-format
+msgid "PCG -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:490
+#, c-format
+msgid "Sparse CG -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:492
+#, c-format
+msgid "CG -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:695
+#, c-format
+msgid "Sparse BiCGStab -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/gmath/solvers_krylov.c:698
+#, c-format
+msgid "BiCGStab -- iteration %i error  %g\n"
+msgstr ""
+#: ../lib/proj/convert.c:120
+msgid "Unable parse GRASS PROJ_INFO file"
+msgstr ""
+#: ../lib/proj/convert.c:125
+msgid "Unable get PROJ.4-style parameter string"
+msgstr ""
+#: ../lib/proj/convert.c:139
+#, c-format
+msgid ""
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr ""
+#: ../lib/proj/convert.c:146
+#, c-format
+msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
+msgstr ""
+#: ../lib/proj/convert.c:406
+msgid "No projection name! Projection parameters likely to be meaningless."
+msgstr ""
+#: ../lib/proj/convert.c:442
+#, c-format
+msgid "Datum <%s> not recognised by GRASS and no parameters found"
+msgstr ""
+#: ../lib/proj/convert.c:458
+#, c-format
+msgid ""
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
+msgstr ""
+#: ../lib/proj/convert.c:462
+#, c-format
+msgid ""
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
+msgstr ""
+#: ../lib/proj/get_proj.c:148
+#, c-format
+msgid "Invalid zone %s specified"
+msgstr ""
+#: ../lib/proj/get_proj.c:228
+msgid "Unable to initialise PROJ.4 with the following parameter list:"
+msgstr ""
+#: ../lib/proj/get_proj.c:236
+#, c-format
+msgid "The error message: %s"
+msgstr ""
+#: ../lib/proj/get_proj.c:294
+msgid "Option input overflowed option table"
+msgstr ""
+#: ../lib/proj/get_proj.c:325
+#, c-format
+msgid "Unable to initialize pj cause: %s"
+msgstr ""
+#: ../lib/proj/get_proj.c:401
+msgid "Input Projection Parameters"
+msgstr ""
+#: ../lib/proj/get_proj.c:404
+msgid "Input Unit Factor"
+msgstr ""
+#: ../lib/proj/get_proj.c:414
+msgid "Output Projection Parameters"
+msgstr ""
+#: ../lib/proj/get_proj.c:417
+msgid "Output Unit Factor"
+msgstr ""
+#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
+#, c-format
+msgid "pj_transform() failed: %s"
+msgstr ""
+#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
+#, c-format
+msgid "Unable to open datum table file <%s>"
+msgstr ""
+#: ../lib/proj/datum.c:283 ../lib/proj/datum.c:364
+#, c-format
+msgid "Error in datum table file <%s>, line %d"
+msgstr ""
+#: ../lib/proj/ellipse.c:76
+#, c-format
+msgid "Invalid ellipsoid <%s> in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:103
+msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:107
+msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+msgstr ""
+#: ../lib/proj/ellipse.c:120
+msgid "No ellipsoid info given in file"
+msgstr ""
+#: ../lib/raster/format.c:154
+#, c-format
+msgid "Fail of initial read of compressed file [%s in %s]"
+msgstr ""
+#: ../lib/raster/init.c:61
+msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
+msgstr ""
+#: ../lib/raster/histogram.c:55
+#, c-format
+msgid "Histogram for [%s in %s] missing (run r.support)"
+msgstr ""
+#: ../lib/raster/histogram.c:62
+#, c-format
+msgid "Can't read histogram for [%s in %s]"
+msgstr ""
+#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
+#, c-format
+msgid "Invalid histogram file for [%s in %s]"
+msgstr ""
+#: ../lib/raster/histogram.c:331
+#, c-format
+msgid "Unable to create histogram file for <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:121
+#, c-format
+msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
+msgstr ""
+#: ../lib/raster/put_row.c:131
+#, c-format
+msgid "Error writing compressed FP data for row %d of <%s>: %s"
+msgstr ""
+#: ../lib/raster/put_row.c:390 ../lib/raster/put_row.c:396
+#, c-format
+msgid "Error writing compressed data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:406
+#, c-format
+msgid "Error writing uncompressed data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:465
+#, c-format
+msgid "Error writing data via GDAL for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:489
+#, c-format
+msgid "No null file for <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:503
+msgid "GDAL output doesn't support writing null rows separately"
+msgstr ""
+#: ../lib/raster/put_row.c:523
+#, c-format
+msgid "Unable to find a temporary null file <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:528
+#, c-format
+msgid "Unable to open null file <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:556 ../lib/raster/put_row.c:559
+#, c-format
+msgid "Error writing null row %d of <%s>"
+msgstr ""
+#: ../lib/raster/put_row.c:684
+#, c-format
+msgid "put_raster_row: raster map <%s> not open for write - request ignored"
+msgstr ""
+#: ../lib/raster/put_row.c:691
+msgid "put_raster_row: unopened file descriptor - request ignored"
+msgstr ""
+#: ../lib/raster/quant_io.c:43
+#, c-format
+msgid "Floating data range for raster map <%s> is empty"
+msgstr ""
+#: ../lib/raster/quant_io.c:52
+#, c-format
+msgid "Integer data range for raster map <%s> is empty"
+msgstr ""
+#: ../lib/raster/quant_io.c:105
+#, c-format
+msgid "Attempt to open quantization table for CELL raster map <%s>"
+msgstr ""
+#: ../lib/raster/quant_io.c:135
+#, c-format
+msgid "Quantization file for raster map <%s> is missing"
+msgstr ""
+#: ../lib/raster/quant_io.c:145
+#, c-format
+msgid "Quantization file for raster map <%s> is empty"
+msgstr ""
+#: ../lib/raster/reclass.c:168
+#, c-format
+msgid "Too many reclass categories for <%s@%s>"
+msgstr ""
+#: ../lib/raster/reclass.c:171
+#, c-format
+msgid "Illegal reclass format in header file for <%s@%s>"
+msgstr ""
+#: ../lib/raster/reclass.c:273
+msgid "Illegal reclass request"
+msgstr ""
+#: ../lib/raster/reclass.c:278
+msgid "Illegal reclass type"
+msgstr ""
+#: ../lib/raster/reclass.c:284
+#, c-format
+msgid "Unable to create header file for <%s@%s>"
+msgstr ""
+#: ../lib/raster/reclass.c:332
+#, c-format
+msgid "Unable to create dependency file in <%s@%s>"
+msgstr ""
+#: ../lib/raster/window.c:31
+msgid ""
+"Internal error: Rast_get_window() called with split window. Use "
+"Rast_get_input_window() or Rast_get_output_window() instead."
+msgstr ""
+#: ../lib/raster/window.c:90
+msgid ""
+"Internal error: Rast_window_rows() called with split window. Use "
+"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgstr ""
+#: ../lib/raster/window.c:125
+msgid ""
+"Internal error: Rast_window_cols() called with split window. Use "
+"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgstr ""
+#: ../lib/raster/raster_metadata.c:109
+#, c-format
+msgid "Unable to read <%s> for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
+#, c-format
+msgid "Error closing <%s> metadata file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/raster_metadata.c:142
+#, c-format
+msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/close.c:75 ../lib/raster/close.c:108
+#, c-format
+msgid "Invalid descriptor: %d"
+msgstr ""
+#: ../lib/raster/close.c:374
+#, c-format
+msgid "Unable to rename null file '%s' to '%s': %s"
+msgstr ""
+#: ../lib/raster/close.c:440
+#, c-format
+msgid "Unable to rename cell file '%s' to '%s': %s"
+msgstr ""
+#: ../lib/raster/close.c:476
+msgid "unable to write f_format file for CELL maps"
+msgstr ""
+#: ../lib/raster/quant_rw.c:88
+#, c-format
+msgid "Unable to read fp range for raster map <%s>"
+msgstr ""
+#: ../lib/raster/quant_rw.c:92
+#, c-format
+msgid "Raster map <%s> is empty"
+msgstr ""
+#: ../lib/raster/quant_rw.c:157
+#, c-format
+msgid "Unable to write quant rules: raster map <%s> is integer"
+msgstr ""
+#: ../lib/raster/quant_rw.c:166
+#, c-format
+msgid "Unable to write quant rules for raster map <%s>"
+msgstr ""
+#: ../lib/raster/interp.c:211
+#, c-format
+msgid "Unknown interpolation method: %s"
+msgstr ""
+#: ../lib/raster/null_val.c:64
+msgid "EmbedGivenNulls: wrong data type"
+msgstr ""
+#: ../lib/raster/null_val.c:114
+msgid "Rast_set_null_value: wrong data type!"
+msgstr ""
+#: ../lib/raster/range.c:102
+#, c-format
+msgid "Unable to read fp range file for <%s>"
+msgstr ""
+#: ../lib/raster/range.c:169
+#, c-format
+msgid "Unable to read quant rules for raster map <%s>"
+msgstr ""
+#: ../lib/raster/range.c:206 ../lib/raster/range.c:226
+#, c-format
+msgid "Unable to read range file for <%s>"
+msgstr ""
+#: ../lib/raster/range.c:264 ../lib/raster/range.c:270
+#: ../lib/raster/range.c:300 ../lib/raster/range.c:314
+#, c-format
+msgid "Unable to write range file for <%s>"
+msgstr ""
+#: ../lib/raster/put_cellhd.c:34
+#, c-format
+msgid "Unable to create header file for <%s>"
+msgstr ""
+#: ../lib/raster/open.c:190
+#, c-format
+msgid ""
+"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
+"%s> which does not exist"
+msgstr ""
+#: ../lib/raster/open.c:195
+#, c-format
+msgid "Error reading reclass file for raster map <%s>"
+msgstr ""
+#: ../lib/raster/open.c:206
+#, c-format
+msgid "Error reading map type for raster map <%s>"
+msgstr ""
+#: ../lib/raster/open.c:214
+#, c-format
+msgid "Raster map <%s@%s>: format field in header file invalid"
+msgstr ""
+#: ../lib/raster/open.c:219
+#, c-format
+msgid ""
+"Raster map <%s> is in different projection than current region. Found <%s>, "
+"should be <%s>."
+msgstr ""
+#: ../lib/raster/open.c:226
+#, c-format
+msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
+msgstr ""
+#: ../lib/raster/open.c:231
+#, c-format
+msgid "Raster map <%s>: bytes per cell (%d) too large"
+msgstr ""
+#: ../lib/raster/open.c:256
+#, c-format
+msgid ""
+"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgstr ""
+#: ../lib/raster/open.c:264
+#, c-format
+msgid "Unable to open %s file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/open.c:301
+#, c-format
+msgid "Error reading format for <%s@%s>"
+msgstr ""
+#: ../lib/raster/open.c:498
+msgid "Unable to create GDAL link"
+msgstr ""
+#: ../lib/raster/open.c:569 ../lib/raster/gdal.c:475
+#, c-format
+msgid "Invalid map type <%d>"
+msgstr ""
+#: ../lib/raster/open.c:574
+#, c-format
+msgid "Raster map <%s> is not in the current mapset (%s)"
+msgstr ""
+#: ../lib/raster/open.c:581
+#, c-format
+msgid "<%s> is an illegal file name"
+msgstr ""
+#: ../lib/raster/open.c:595 ../lib/raster/open.c:667
+#, c-format
+msgid "No temp files available: %s"
+msgstr ""
+#: ../lib/raster/open.c:720
+msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
+msgstr ""
+#: ../lib/raster/open.c:778
+#, c-format
+msgid "Raster map <%s> not found in mapset <%s>"
+msgstr ""
+#: ../lib/raster/open.c:839
+#, c-format
+msgid "Unable to find '%s'"
+msgstr ""
+#: ../lib/raster/open.c:850
+#, c-format
+msgid "Invalid type: field '%s' in file '%s'"
+msgstr ""
+#: ../lib/raster/open.c:855
+#, c-format
+msgid "Missing type: field in file '%s'"
+msgstr ""
+#: ../lib/raster/open.c:860
+#, c-format
+msgid "Raster map <%s> is not xdr: byte_order: %s"
+msgstr ""
+#: ../lib/raster/open.c:929
+msgid ""
+"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr ""
+#: ../lib/raster/cats.c:109
+#, c-format
+msgid "Category support for <%s@%s> missing"
+msgstr ""
+#: ../lib/raster/cats.c:112
+#, c-format
+msgid "Category support for <%s@%s> invalid"
+msgstr ""
+#: ../lib/raster/cats.c:145
+#, c-format
+msgid "Category support for vector map <%s@%s> missing"
+msgstr ""
+#: ../lib/raster/cats.c:149
+#, c-format
+msgid "Category support for vector map <%s@%s> invalid"
+msgstr ""
+#: ../lib/raster/cats.c:968
+#, c-format
+msgid "Unable to open %s file for map <%s>"
+msgstr ""
+#: ../lib/raster/alloc_cell.c:151
+#, c-format
+msgid "Rast__null_bitstream_size: cols (%d) is negative"
+msgstr ""
+#: ../lib/raster/color_rand.c:33
+#, c-format
+msgid "Rast_make_random_colors: min (%d) > max (%d)"
+msgstr ""
+#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:845
+#, c-format
+msgid "Reading raster map <%s@%s> request for row %d is outside region"
+msgstr ""
+#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:101
+#: ../lib/raster/get_row.c:135 ../lib/raster/get_row.c:142
+#: ../lib/raster/get_row.c:177 ../lib/raster/get_row.c:181
+#, c-format
+msgid "Error reading raster data for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:217
+#, c-format
+msgid "Error reading raster data via GDAL for row %d of <%s>"
+msgstr ""
+#: ../lib/raster/get_row.c:829 ../lib/raster/get_row.c:832
+#, c-format
+msgid "Error reading null row %d for <%s>"
+msgstr ""
+#: ../lib/raster/set_window.c:48
+msgid "Rast_set_window() called while window split"
+msgstr ""
+#: ../lib/raster/set_window.c:131
+msgid ""
+"Rast_set_read_window(): projection/zone differs from that of currently open "
+"raster maps"
+msgstr ""
+#: ../lib/raster/set_window.c:158
+#, c-format
+msgid "Input window changed while maps are open for read. Map name <%s>"
+msgstr ""
+#: ../lib/raster/set_window.c:174
+#, c-format
+msgid "Output window changed while maps are open for write. Map name <%s>"
+msgstr ""
+#: ../lib/raster/put_title.c:28
+#, c-format
+msgid "category information for [%s] in [%s] missing or invalid"
+msgstr ""
+#: ../lib/raster/put_title.c:37
+msgid "G_put_title - can't create a temp file"
+msgstr ""
+#: ../lib/raster/put_title.c:53
+#, c-format
+msgid "category information for [%s] in [%s] invalid"
+msgstr ""
+#: ../lib/raster/put_title.c:60
+msgid "G_put_title - can't reopen temp file"
+msgstr ""
+#: ../lib/raster/put_title.c:67
+#, c-format
+msgid "can't write category information for [%s] in [%s]"
+msgstr ""
+#: ../lib/raster/get_cellhd.c:66
+#, c-format
+msgid ""
+"Unable to read header file for raster map <%s@%s>. It is a reclass of raster "
+"map <%s@%s> %s"
+msgstr ""
+#: ../lib/raster/get_cellhd.c:70
+msgid "which is missing."
+msgstr ""
+#: ../lib/raster/get_cellhd.c:71
+msgid "whose header file can't be opened."
+msgstr ""
+#: ../lib/raster/get_cellhd.c:76
+#, c-format
+msgid "Unable to open header file for raster map <%s@%s>"
+msgstr ""
+#: ../lib/raster/sample.c:70
+msgid "Unknown interpolation type"
+msgstr ""
+#: ../lib/raster/sample.c:327
+msgid "\"no data\" label found; setting to zero"
+msgstr ""
+#: ../lib/raster/color_read.c:103
+msgid "missing"
+msgstr ""
+#: ../lib/raster/color_read.c:106
+msgid "invalid"
+msgstr ""
+#: ../lib/raster/color_read.c:112
+#, c-format
+msgid "Color support for <%s@%s> %s"
+msgstr ""
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
+#, c-format
+msgid "Unable to get history information for <%s@%s>"
+msgstr ""
+#: ../lib/raster/history.c:162
+#, c-format
+msgid "Unable to write history information for <%s>"
+msgstr ""
+#: ../lib/raster/history.c:235
+#, c-format
+msgid "generated by %s"
+msgstr ""
+#: ../lib/raster/auto_mask.c:69
+msgid "Unable to open automatic MASK file"
+msgstr ""
+#: ../lib/raster/color_rules.c:125
+msgid "syntax error"
+msgstr ""
+#: ../lib/raster/color_rules.c:127
+msgid "R/G/B not in range 0-255"
+msgstr ""
+#: ../lib/raster/color_rules.c:129
+msgid "invalid color name"
+msgstr ""
+#: ../lib/raster/color_rules.c:131
+msgid "percentage not in range 0-100"
+msgstr ""
+#: ../lib/raster/color_rules.c:133
+msgid "invalid value"
+msgstr ""
+#: ../lib/raster/color_rules.c:135
+msgid "unknown error"
+msgstr ""
+#: ../lib/raster/color_rules.c:181
+#, c-format
+msgid "bad rule (%s): [%s]"
+msgstr ""
+#: ../lib/raster/color_rules.c:328
+#, c-format
+msgid "Unable to load color rules <%s>"
+msgstr ""
+#: ../lib/raster/gdal.c:88
+#, c-format
+msgid "Unable to locate symbol <%s>"
+msgstr ""
+#: ../lib/raster/gdal.c:141
+msgid "Unable to load GDAL library"
+msgstr ""
+#: ../lib/raster/gdal.c:371
+msgid "Unable to open GDAL file"
+msgstr ""
+#: ../lib/raster/gdal.c:481
+#, c-format
+msgid "Unable to get <%s> driver"
+msgstr ""
+#: ../lib/raster/gdal.c:490
+#, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
+msgstr ""
+#: ../lib/raster/gdal.c:498
+#, c-format
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
+msgstr ""
+#: ../lib/raster/gdal.c:504
+msgid "Unable to get in-memory raster driver"
+msgstr ""
+#: ../lib/raster/gdal.c:511
+#, c-format
+msgid "Unable to create <%s> dataset using memory driver"
+msgstr ""
+#: ../lib/raster/gdal.c:515
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
+msgstr ""
+#: ../lib/raster/gdal.c:531
+msgid "Unable to set geo transform"
+msgstr ""
+#: ../lib/raster/gdal.c:535
+msgid "Unable to set projection"
+msgstr ""
+#: ../lib/raster/gdal.c:539
+#, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
+msgstr ""
+#: ../lib/raster/gdal.c:555
+#, c-format
+msgid "Error writing cell_misc/%s/gdal file"
+msgstr ""
+#: ../lib/raster/gdal.c:603
+#, c-format
+msgid "Unable to create output file <%s> using driver <%s>"
+msgstr ""
+#: ../lib/raster/mask_info.c:43
+#, c-format
+msgid "<%s> in mapset <%s>"
+msgstr ""
+#: ../lib/raster/mask_info.c:46
+msgid "none"
+msgstr ""
+#: ../lib/raster/mask_info.c:49
+msgid "not known"
+msgstr ""
+#: ../lib/display/icon.c:80
+#, c-format
+msgid "Unsupported icon %d"
+msgstr ""
+#: ../lib/display/r_raster.c:128
+#, c-format
+msgid "%s variable defined, %s ignored"
+msgstr ""
+#: ../lib/display/r_raster.c:147
+#, c-format
+msgid ""
+"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
+"defined"
+msgstr ""
+#: ../lib/display/r_raster.c:165
+#, c-format
+msgid "Unknown display driver <%s>"
+msgstr ""
+#: ../lib/display/r_raster.c:166
+#, c-format
+msgid "Using display driver <%s>..."
+msgstr ""
+#: ../lib/display/r_raster.c:236
+#, c-format
+msgid "Unable to open file '%s'"
+msgstr ""
+#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
+#, c-format
+msgid "[%s]: No such color"
+msgstr ""
+#: ../lib/nviz/nviz.c:128
+#, c-format
+msgid "Invalid color (%s), using \"white\" as default"
+msgstr ""
+#: ../lib/nviz/lights.c:171
+msgid "Unable to define new light"
+msgstr ""
+#: ../lib/nviz/map_obj.c:59
+msgid "Maximum surfaces loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:88
+msgid "Maximum vector line maps loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
+#, c-format
+msgid "Error loading vector map <%s>"
+msgstr ""
+#: ../lib/nviz/map_obj.c:116
+msgid "Maximum vector point maps loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:143
+msgid "Maximum volumes loaded!"
+msgstr ""
+#: ../lib/nviz/map_obj.c:152
+#, c-format
+msgid "Error loading 3d raster map <%s>"
+msgstr ""
+#: ../lib/nviz/map_obj.c:160
+msgid "Nviz_new_map_obj(): unsupported data type"
+msgstr ""
+#: ../lib/nviz/position.c:56
+msgid "Unable to set focus"
+msgstr ""
+#: ../lib/nviz/render.c:106
+msgid "Bad server connection"
+msgstr ""
+#: ../lib/nviz/render.c:112
+msgid "Unable to get visual info"
+msgstr ""
+#: ../lib/nviz/render.c:119
+msgid "Unable to create rendering context"
+msgstr ""
+#: ../lib/init/lock.c:38
+#, c-format
+msgid "Usage: %s file pid"
+msgstr ""
+#: ../lib/init/lock.c:42
+msgid "Concurrent mapset locking is not supported on Windows"
+msgstr ""
+#: ../lib/init/lock.c:60
+#, c-format
+msgid "Unable to write lockfile %s (%s)"
+msgstr ""
+#: ../lib/init/grass.py:74
+msgid "WARNING"
+msgstr ""
+#: ../lib/init/grass.py:130
+msgid "Exiting..."
+msgstr ""
+#: ../lib/init/grass.py:203
+msgid "Usage"
+msgstr ""
+#: ../lib/init/grass.py:205
+msgid "print this help message"
+msgstr ""
+#: ../lib/init/grass.py:206
+msgid "show version information and exit"
+msgstr ""
+#: ../lib/init/grass.py:207
+msgid "create given database, location or mapset if it doesn't exist"
+msgstr ""
+#: ../lib/init/grass.py:208
+msgid "exit after creation of location or mapset. Only with -c flag"
+msgstr ""
+#: ../lib/init/grass.py:209
+msgid "use text based interface (skip welcome screen)"
+msgstr ""
+#: ../lib/init/grass.py:210 ../lib/init/grass.py:212 ../lib/init/grass.py:214
+msgid "and set as default"
+msgstr ""
+#: ../lib/init/grass.py:211
+msgid "use text based interface (show welcome screen)"
+msgstr ""
+#: ../lib/init/grass.py:213
+msgid "use $DEFAULT_GUI graphical user interface"
+msgstr ""
+#: ../lib/init/grass.py:215
+msgid "print GRASS configuration parameters"
+msgstr ""
+#: ../lib/init/grass.py:216
+msgid "options: arch,build,compiler,path,revision"
+msgstr ""
+#: ../lib/init/grass.py:218
+msgid "initial database (path to GIS data)"
+msgstr ""
+#: ../lib/init/grass.py:219
+msgid "initial location"
+msgstr ""
+#: ../lib/init/grass.py:220
+msgid "initial mapset"
+msgstr ""
+#: ../lib/init/grass.py:221
+msgid "fully qualified initial mapset directory"
+msgstr ""
+#: ../lib/init/grass.py:222
+msgid "Environment variables relevant for startup"
+msgstr ""
+#: ../lib/init/grass.py:223
+msgid "select GUI (text, gui)"
+msgstr ""
+#: ../lib/init/grass.py:224
+msgid "set html web browser for help pages"
+msgstr ""
+#: ../lib/init/grass.py:225
+msgid "set additional path(s) to local GRASS modules or user scripts"
+msgstr ""
+#: ../lib/init/grass.py:226
+msgid "set additional GISBASE for locally installed GRASS Addons"
+msgstr ""
+#: ../lib/init/grass.py:227
+msgid "shell script to be processed as batch job"
+msgstr ""
+#: ../lib/init/grass.py:228
+msgid "set python shell name to override 'python'"
+msgstr ""
+#: ../lib/init/grass.py:266
+#, python-format
+msgid ""
+"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+msgstr ""
+#: ../lib/init/grass.py:301
+#, python-format
+msgid "ERROR: Invalid line in RC file: '%s' (%s)\n"
+msgstr ""
+#: ../lib/init/grass.py:354
+#, python-format
+msgid "GUI <%s> not supported in this version"
+msgstr ""
+#: ../lib/init/grass.py:499
+msgid "Searched for a web browser, but none found"
+msgstr ""
+#: ../lib/init/grass.py:533
+msgid ""
+"The python command does not work as expected!\n"
+"Please check your GRASS_PYTHON environment variable.\n"
+"Use the -help option for details.\n"
+"Switching to text based interface mode.\n"
+"\n"
+"Hit RETURN to continue.\n"
+msgstr ""
+#: ../lib/init/grass.py:545
+msgid ""
+"It appears that the X Windows system is not active.\n"
+"A graphical based user interface is not supported.\n"
+"\n"
+"Hit RETURN to continue"
+msgstr ""
+#: ../lib/init/grass.py:597
+#, python-format
+msgid "ERROR: <%s> is not a valid GRASS location"
+msgstr ""
+#: ../lib/init/grass.py:600
+#, python-format
+msgid ""
+"Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be "
+"created by '-c' switch."
+msgstr ""
+#: ../lib/init/grass.py:619
+#, python-format
+msgid "Failed to create new location. The location <%s> already exists."
+msgstr ""
+#: ../lib/init/grass.py:651
+msgid "Missing WIND file fixed"
+msgstr ""
+#: ../lib/init/grass.py:663
+msgid ""
+"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
+"Interactive startup needed."
+msgstr ""
+#: ../lib/init/grass.py:678
+#, python-format
+msgid ""
+"Invalid user interface specified - <%s>. Use the --help option to see valid "
+"interface names."
+msgstr ""
+#: ../lib/init/grass.py:691
+msgid ""
+"Error in GUI startup. If necessary, please report this error to the GRASS "
+"developers.\n"
+"Switching to text mode now.\n"
+"\n"
+"Hit RETURN to continue..."
+msgstr ""
+#: ../lib/init/grass.py:701
+msgid ""
+"Received EXIT message from GUI.\n"
+"GRASS is not started. Bye."
+msgstr ""
+#: ../lib/init/grass.py:704
+msgid ""
+"Invalid return code from GUI startup script.\n"
+"Please advise GRASS developers of this error."
+msgstr ""
+#: ../lib/init/grass.py:715
+msgid ""
+"Error reading data path information from g.gisenv.\n"
+"GISDBASE=%(gisbase)s\n"
+"LOCATION_NAME=%(location)s\n"
+"MAPSET=%(mapset)s\n"
+"\n"
+"Check the <%s(file)> file."
+msgstr ""
+#: ../lib/init/grass.py:742
+#, python-format
+msgid "Environmental variable '%s' already set, ignoring value '%s'"
+msgstr ""
+#: ../lib/init/grass.py:804
+msgid "Default locale settings are missing. GRASS running with C locale."
+msgstr ""
+#: ../lib/init/grass.py:809
+#, python-format
+msgid ""
+"A language override has been requested. Trying to switch GRASS into '%s'..."
+msgstr ""
+#: ../lib/init/grass.py:868
+#, python-format
+msgid "Path '%s' doesn't exist"
+msgstr ""
+#: ../lib/init/grass.py:876
+#, python-format
+msgid ""
+"%(user)s is currently running GRASS in selected mapset (file %(file)s "
+"found). Concurrent use not allowed."
+msgstr ""
+#: ../lib/init/grass.py:880
+#, python-format
+msgid ""
+"Unable to properly access '%s'.\n"
+"Please notify system personel."
+msgstr ""
+#: ../lib/init/grass.py:895
+msgid "Building user fontcap..."
+msgstr ""
+#: ../lib/init/grass.py:947
+#, python-format
+msgid "Unsupported shell <%(sh)s>: %(env)s"
+msgstr ""
+#: ../lib/init/grass.py:952
+msgid "The SHELL variable is not set"
+msgstr ""
+#: ../lib/init/grass.py:963
+#, python-format
+msgid ""
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
+"found. Exiting.\n"
+"\n"
+"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
+msgstr ""
+#: ../lib/init/grass.py:968
+#, python-format
+msgid "Change file permission to 'executable' for '%s'"
+msgstr ""
+#: ../lib/init/grass.py:970
+#, python-format
+msgid "Executing '%s' ..."
+msgstr ""
+#: ../lib/init/grass.py:975
+#, python-format
+msgid "Execution of '%s' finished."
+msgstr ""
+#: ../lib/init/grass.py:981
+#, python-format
+msgid "GRASS GUI should be <%s>"
+msgstr ""
+#: ../lib/init/grass.py:1010
+#, python-format
+msgid "Welcome to GRASS GIS %s"
+msgstr ""
+#: ../lib/init/grass.py:1029
+msgid "GRASS GIS homepage:"
+msgstr ""
+#: ../lib/init/grass.py:1030
+msgid "This version running through:"
+msgstr ""
+#: ../lib/init/grass.py:1032
+msgid "Help is available with the command:"
+msgstr ""
+#: ../lib/init/grass.py:1033
+msgid "See the licence terms with:"
+msgstr ""
+#: ../lib/init/grass.py:1036
+msgid "If required, restart the GUI with:"
+msgstr ""
+#: ../lib/init/grass.py:1038
+msgid "Start the GUI with:"
+msgstr ""
+#: ../lib/init/grass.py:1040
+msgid "When ready to quit enter:"
+msgstr ""
+#: ../lib/init/grass.py:1130
+msgid "2D and 3D raster MASKs present"
+msgstr ""
+#: ../lib/init/grass.py:1131
+msgid "Raster MASK present"
+msgstr ""
+#: ../lib/init/grass.py:1132
+msgid "3D raster MASK present"
+msgstr ""
+#: ../lib/init/grass.py:1171
+#, python-format
+msgid "Failed to start shell '%s'"
+msgstr ""
+#: ../lib/init/grass.py:1176
+#, python-format
+msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
+msgstr ""
+#: ../lib/init/grass.py:1177 ../lib/init/grass.py:1182
+msgid "Goodbye from GRASS GIS"
+msgstr ""
+#: ../lib/init/grass.py:1180
+msgid "Done."
+msgstr ""
+#: ../lib/init/grass.py:1187
+msgid "Cleaning up temporary files..."
+msgstr ""
+#: ../lib/init/grass.py:1201
+msgid "Please install the GRASS GIS development package"
+msgstr ""
+#: ../lib/init/grass.py:1233
+#, python-format
+msgid "Parameter <%s> not supported"
+msgstr ""
+#: ../lib/init/grass.py:1356
+msgid "Flag -e required also flag -c"
+msgstr ""
+#: ../lib/init/grass.py:1399
+#, python-format
+msgid ""
+"Unable to start GRASS. You can:\n"
+" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
+" - Create manually GISRC file (%s)\n"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
+"path/to/location/mapset`)"
+msgstr ""
+#: ../lib/init/grass.py:1409
+msgid "Creating new GRASS GIS location/mapset..."
+msgstr ""
+#: ../lib/init/grass.py:1411
+msgid "Starting GRASS GIS..."
+msgstr ""
+#: ../lib/init/grass.py:1469
+#, python-format
+msgid "Launching <%s> GUI in the background, please wait..."
+msgstr ""
+#: ../lib/imagery/target.c:38
+#, c-format
+msgid "Unable to read target file for group [%s]"
+msgstr ""
+#: ../lib/imagery/list_subgp.c:72
+#, c-format
+msgid "subgroup <%s> of group <%s> is empty\n"
+msgstr ""
+#: ../lib/imagery/list_subgp.c:85
+#, c-format
+msgid "subgroup <%s> of group <%s> references the following raster maps\n"
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:218
+msgid "prepare_signature: outline has odd number of points."
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:227 ../lib/imagery/iscatt_core.c:972
+#, c-format
+msgid "prepare_signature: scan line %d has odd number of points."
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:237 ../lib/imagery/iscatt_core.c:981
+msgid "signature: perimeter points out of order."
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:248
+#, c-format
+msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:561
+#: ../lib/imagery/iclass_statistics.c:584
+#: ../lib/imagery/iclass_statistics.c:607
+#: ../lib/imagery/iclass_statistics.c:630
+#: ../lib/imagery/iclass_statistics.c:653
+#: ../lib/imagery/iclass_statistics.c:680
+#: ../lib/imagery/iclass_statistics.c:712
+#: ../lib/imagery/iclass_statistics.c:735
+#: ../lib/imagery/iclass_statistics.c:758
+msgid "Band index out of range"
+msgstr ""
+#: ../lib/imagery/iclass_statistics.c:684
+msgid "Cell category value out of range"
+msgstr ""
+#: ../lib/imagery/iclass.c:83
+#, c-format
+msgid "No areas in category %d"
+msgstr ""
+#: ../lib/imagery/iclass.c:127
+#, c-format
+msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
+msgstr ""
+#: ../lib/imagery/iclass.c:131
+#, c-format
+msgid "Raster map <%s@%s> in group <%s> does not exist"
+msgstr ""
+#: ../lib/imagery/iclass.c:143
+#, c-format
+msgid "Subgroup <%s> does not have enough files (it has %d files)"
+msgstr ""
+#: ../lib/imagery/iclass.c:147
+#, c-format
+msgid "Group <%s> does not have enough files (it has %d files)"
+msgstr ""
+#: ../lib/imagery/iclass_signatures.c:120
+#, c-format
+msgid "Unable to open output signature file '%s'"
+msgstr ""
+#: ../lib/imagery/points.c:124
+#, c-format
+msgid "Unable to open control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/points.c:132
+#, c-format
+msgid "Bad format in control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/points.c:159
+#, c-format
+msgid "Unable to create control point file for group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:23
+#, c-format
+msgid "Unable to create file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
+#, c-format
+msgid "Unable to open file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:49
+#, c-format
+msgid "Unable to find file [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:79
+#, c-format
+msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
+#, c-format
+msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/fopen.c:116
+#, c-format
+msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr ""
+#: ../lib/imagery/sigsetfile.c:41
+#, c-format
+msgid ""
+"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
+"is not current mapset"
+msgstr ""
+#: ../lib/imagery/sigsetfile.c:57
+#, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:81
+#, c-format
+msgid "Unable to write header into category raster condition file <%s>."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:98
+#, c-format
+msgid "Unable to write into category raster condition file <%s>."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:255
+#, c-format
+msgid "Unable to open category raster condtions file <%s>."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:263
+#, c-format
+msgid "Unable to find patch raster <%s>."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:280
+#, c-format
+msgid "Resolutions of patch <%s> and patched file <%s> are not same."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:307 ../lib/imagery/iscatt_core.c:349
+#, c-format
+msgid "Corrupted  category raster conditions file <%s> (fseek failed)"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:338
+#, c-format
+msgid "Unable to write into category raster conditions file <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:526
+msgid "Unable to read from category raster condtition file."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:533
+msgid "Invalid size of category raster conditions file."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:579
+msgid ""
+"Data inconsistent. Value computed for scatter plot is out of initialized "
+"range."
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:745
+#, c-format
+msgid "Unbale to read find raster <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:755
+#, c-format
+msgid "Unbale to open raster <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:761
+#, c-format
+msgid "Raster <%s> type is not <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:775
+#, c-format
+msgid "Unable to read range of raster <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:803
+#, c-format
+msgid "Unable to open category raster condtition file <%s>"
+msgstr ""
+#: ../lib/imagery/iscatt_core.c:817
+msgid "Corrupted category raster conditions file (fseek failed)"
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:109
+#, c-format
+msgid "Get area %d failed"
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:116
+msgid "Perimeter computation failed"
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:208
+msgid "Absurd polygon."
+msgstr ""
+#: ../lib/imagery/iclass_perimeter.c:253
+msgid "Outlined area is too large."
+msgstr ""
+#: ../lib/imagery/list_gp.c:34
+#, c-format
+msgid "group <%s> is empty\n"
+msgstr ""
+#: ../lib/imagery/list_gp.c:44
+#, c-format
+msgid "group <%s> references the following raster maps\n"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:219
+msgid "Calculating forward transformation coefficients"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:236
+msgid "Calculating backward transformation coefficients"
+msgstr ""
+#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
+#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
+#: ../lib/imagery/georef_tps.c:293
+#, c-format
+msgid "%s: out of memory"
+msgstr ""
Property changes on: grass/trunk/locale/po/grasslibs_fi.po
___________________________________________________________________
Added: svn:mime-type
   + text/x-po
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po	                        (rev 0)
+++ grass/trunk/locale/po/grassmods_fi.po	2015-08-18 10:47:46 UTC (rev 65959)
@@ -0,0 +1,38006 @@
+# translation of grassmods_fi.po to Finnish
+# This file is distributed under the same license as the GRASS GIS package.
+# Copyright (C) 2014-2015 GRASS Development Team
+# Kari Salovaara <kari.salovaara at pp1.inet.fi>, 2015.
+msgid ""
+msgstr ""
+"Project-Id-Version: grassmods_fi\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2015-07-20 21:44+0200\n"
+"PO-Revision-Date: 2015-08-17 23:02+0300\n"
+"Last-Translator: Kari Salovaara <kari.salovaara at pp1.inet.fi>\n"
+"Language-Team: Finnish <grass-translations at lists.osgeo.org>\n"
+"Language: fi\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"X-Generator: Lokalize 1.5\n"
+#: ../db/drivers/mysql/index.c:55 ../db/drivers/sqlite/index.c:77
+msgid "Unable to create index:"
+msgstr "Indeksiä ei voida luoda:"
+#: ../db/drivers/mysql/dbe.c:45
+msgid "Unable parse MySQL embedded database name"
+msgstr "Ei voitu jäsentää MySQL sisäistä tietokannan nimeä"
+#: ../db/drivers/mysql/dbe.c:61
+msgid "Cannot initialize MySQL embedded server"
+msgstr "Ei voitu alustaa MySQL sisäistä palvelinta"
+#: ../db/drivers/mysql/dbe.c:80
+msgid "Unable to connect to MySQL embedded server: "
+msgstr "Ei voitu yhdistää MySQL sisäiseen palvelimeen"
+#: ../db/drivers/mysql/fetch.c:34 ../db/drivers/mysql/fetch.c:276
+#: ../db/drivers/ogr/fetch.c:55 ../db/drivers/ogr/fetch.c:188
+#: ../db/drivers/sqlite/fetch.c:265 ../db/drivers/postgres/fetch.c:33
+msgid "Cursor not found"
+msgstr "Kursoria ei löytynyt"
+#: ../db/drivers/mysql/fetch.c:52
+msgid "Cursor position is not supported by MySQL driver"
+msgstr "Kursorin sijaintia ei MySQL ajuri tue"
+#: ../db/drivers/mysql/fetch.c:191
+msgid "Unable to scan timestamp: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:200
+msgid "Unknown timestamp format: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:215
+msgid "Unable to scan date: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:229
+msgid "Unable to scan time: "
+msgstr ""
+#: ../db/drivers/mysql/fetch.c:245
+msgid "Unable to scan datetime:"
+msgstr ""
+#: ../db/drivers/mysql/parse.c:62
+msgid "Wrong port number in MySQL database definition: "
+msgstr ""
+#: ../db/drivers/mysql/parse.c:73 ../db/drivers/postgres/parse.c:60
+msgid "'user' in database definition is not supported, use db.login"
+msgstr ""
+#: ../db/drivers/mysql/parse.c:77 ../db/drivers/postgres/parse.c:64
+msgid "'password' in database definition is not supported, use db.login"
+msgstr ""
+#: ../db/drivers/mysql/parse.c:82
+msgid "Unknown option in database definition for MySQL: "
+msgstr ""
+#: ../db/drivers/mysql/listtab.c:37
+msgid "Unable get list of tables:"
+msgstr "Ei saada listaa tauluista:"
+#: ../db/drivers/mysql/describe.c:32 ../db/drivers/sqlite/describe.c:92
+#: ../db/drivers/sqlite/select.c:95
+msgid "Unable to describe table:"
+msgstr ""
+#: ../db/drivers/mysql/describe.c:50 ../db/drivers/postgres/select.c:69
+msgid "Unable to describe table"
+msgstr ""
+#: ../db/drivers/mysql/describe.c:121
+#, c-format
+msgid "MySQL driver: column '%s', type %d is not supported"
+msgstr "MySQL ajuri: sarake '%s', tyyppiä %d ei tueta"
+#: ../db/drivers/mysql/describe.c:127
+#, c-format
+msgid ""
+"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
+"damaged"
+msgstr ""
+#: ../db/drivers/mysql/execute.c:41 ../db/drivers/postgres/execute.c:42
+msgid "Unable to execute:"
+msgstr ""
+#: ../db/drivers/mysql/execute.c:62
+msgid "Unable to start transaction:"
+msgstr ""
+#: ../db/drivers/mysql/execute.c:77
+msgid "Unable to commit transaction:"
+msgstr ""
+#: ../db/drivers/mysql/select.c:42
+msgid "Unable to select data:"
+msgstr ""
+#: ../db/drivers/mysql/select.c:64 ../db/drivers/postgres/describe.c:40
+msgid "Unable to describe table."
+msgstr ""
+#: ../db/drivers/mysql/cursor.c:44 ../db/drivers/postgres/cursor.c:41
+msgid "Unable allocate cursor."
+msgstr ""
+#: ../db/drivers/mysql/cursor.c:53
+msgid "Unable to add dnew token."
+msgstr ""
+#: ../db/drivers/mysql/create_table.c:108
+#: ../db/drivers/sqlite/create_table.c:122
+#: ../db/drivers/postgres/create_table.c:103
+msgid "Unable to create table:"
+msgstr ""
+#: ../db/drivers/mysql/db.c:61 ../db/drivers/postgres/db.c:71
+#: ../db/drivers/postgres/db.c:249
+msgid "Connection failed."
+msgstr ""
+#: ../db/drivers/odbc/table.c:159
+#, c-format
+msgid "Table %s doesn't exist"
+msgstr ""
+#: ../db/drivers/odbc/table.c:176
+#, c-format
+msgid "Table %s isn't 'TABLE' or 'VIEW' but %s"
+msgstr ""
+#: ../db/drivers/odbc/listdb.c:29
+msgid "Unable to allocate handle."
+msgstr ""
+#: ../db/drivers/odbc/listdb.c:40 ../db/drivers/sqlite/listdb.c:147
+#: ../db/drivers/postgres/listdb.c:95
+msgid "Unable to set handle"
+msgstr ""
+#: ../db/drivers/odbc/cursor.c:36 ../db/drivers/ogr/cursor.c:65
+msgid "Unable to allocate cursor"
+msgstr ""
+#: ../db/drivers/odbc/cursor.c:55 ../db/drivers/sqlite/cursor.c:56
+#: ../db/drivers/postgres/cursor.c:50
+msgid "Unable to add new token."
+msgstr ""
+#: ../db/drivers/ogr/fetch.c:71
+msgid "DB_PREVIOUS not supported"
+msgstr ""
+#: ../db/drivers/ogr/fetch.c:82
+msgid "DB_LAST not supported"
+msgstr ""
+#: ../db/drivers/ogr/fetch.c:160 ../db/drivers/ogr/describe.c:200
+msgid "Unknown type"
+msgstr ""
+#: ../db/drivers/ogr/listtab.c:49 ../db/drivers/sqlite/listtab.c:78
+msgid "Unable to db_alloc_string_array()"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:55
+#, c-format
+msgid "OGR layer <%s> does not exist\n"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:63 ../db/drivers/ogr/select.c:58
+msgid "Unable to describe table\n"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:112
+#, c-format
+msgid "OGR driver: column '%s', OGR type %d is not supported"
+msgstr ""
+#: ../db/drivers/ogr/describe.c:192
+#, c-format
+msgid ""
+"column '%s', type 'string': unknown width -> stored as varchar(250) some "
+"data may be lost"
+msgstr ""
+#: ../db/drivers/ogr/execute.c:56 ../vector/v.out.ogr/main.c:593
+#, c-format
+msgid "OGR layer <%s> not found"
+msgstr "OGR tasoa <%s> ei löytynyt"
+#: ../db/drivers/ogr/execute.c:69 ../vector/v.colors/scan_attr.c:35
+#: ../vector/v.in.db/main.c:187 ../vector/v.to.3d/trans3.c:65
+#: ../vector/v.to.3d/trans2.c:63 ../vector/v.vect.stats/main.c:395
+#: ../vector/v.colors.out/make_colors.c:42 ../vector/v.distance/main.c:471
+#: ../vector/v.distance/main.c:512 ../vector/v.reclass/main.c:145
+#: ../vector/v.db.connect/main.c:289 ../vector/v.transform/trans_digit.c:101
+#: ../vector/v.univar/main.c:355
+#, c-format
+msgid "Column <%s> not found in table <%s>"
+msgstr "Saraketta <%s> ei löytynyt taulusta <%s>"
+#: ../db/drivers/ogr/select.c:50
+msgid "Unable to select: \n"
+msgstr ""
+#: ../db/drivers/ogr/cursor.c:74
+msgid "Unable to add new token"
+msgstr ""
+#: ../db/drivers/ogr/db.c:56
+msgid "Had to open data source read-only"
+msgstr ""
+#: ../db/drivers/ogr/db.c:60
+msgid "Unable to open OGR data source"
+msgstr ""
+#: ../db/drivers/dbf/table.c:117 ../db/drivers/dbf/table.c:170
+msgid "Unable to open DBF file."
+msgstr ""
+#: ../db/drivers/dbf/table.c:312
+#, c-format
+msgid "Unable to move '%s' to '%s'."
+msgstr ""
+#: ../db/drivers/dbf/column.c:49
+#, c-format
+msgid "Column '%s' already exists (duplicate name)"
+msgstr ""
+#: ../db/drivers/dbf/column.c:99
+#, c-format
+msgid "Column '%s' does not exist"
+msgstr ""
+#: ../db/drivers/dbf/describe.c:34
+#, c-format
+msgid "Table '%s' doesn't exist"
+msgstr "Taulua '%s' ei ole olemassa"
+#: ../db/drivers/dbf/execute.c:32
+msgid "Unable to execute statement."
+msgstr "Ei voida suorittaa lauseketta."
+#: ../db/drivers/dbf/select.c:44
+msgid "Unable to open cursor."
+msgstr "Kursoria ei voida avata"
+#: ../db/drivers/dbf/dbfexe.c:72
+msgid "SQL parser error"
+msgstr "SQL jäsentelyvirhe"
+#: ../db/drivers/dbf/dbfexe.c:74
+msgid "in statement:"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:88
+#, c-format
+msgid "Table '%s' doesn't exist."
+msgstr "Taulua '%s' ei ole olemassa."
+#: ../db/drivers/dbf/dbfexe.c:96
+msgid "Unable to load table head."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:106
+msgid "Unable to modify table, don't have write permission for DBF file."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:121 ../db/drivers/dbf/dbfexe.c:1023
+#, c-format
+msgid "Column '%s' not found"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:145
+msgid "Incompatible value type."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:161
+msgid "Unable to add column."
+msgstr "Saraketta ei voida lisätä."
+#: ../db/drivers/dbf/dbfexe.c:183
+msgid "Unable to delete column."
+msgstr "Saraketta ei voida poistaa."
+#: ../db/drivers/dbf/dbfexe.c:191
+#, c-format
+msgid "Table %s already exists"
+msgstr "Taulu %s on jo olemassa"
+#: ../db/drivers/dbf/dbfexe.c:206
+msgid "Unable to create table."
+msgstr "Ei voida luoda taulua."
+#: ../db/drivers/dbf/dbfexe.c:263 ../db/drivers/dbf/dbfexe.c:273
+#: ../db/drivers/dbf/dbfexe.c:303
+msgid "Error in selecting rows"
+msgstr "Virhe valittaessa rivejä"
+#: ../db/drivers/dbf/dbfexe.c:552
+msgid "Cannot load table."
+msgstr "Ei voida ladata taulua."
+#: ../db/drivers/dbf/dbfexe.c:567
+msgid "Incompatible types in WHERE condition."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:572
+msgid "Result of WHERE condition is not of type BOOL."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:588
+msgid "Error in evaluation of WHERE condition."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:600
+#, c-format
+msgid "Unknown result (%d) of WHERE evaluation"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:607
+msgid "Unknown WHERE condition type (bug in DBF driver)."
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:633
+#, c-format
+msgid "Unable to find order column '%s'"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:778
+msgid "Division by zero"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:917
+msgid "Value operand for AND"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:931
+msgid "Value operand for OR"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:946
+msgid "Value operand for NOT"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:954 ../db/drivers/dbf/dbfexe.c:1151
+#, c-format
+msgid "Unknown operator %d"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:1061
+msgid "Arithmetical operation with strings is not allowed"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:1083
+msgid "Comparison between string and number is not allowed"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:1098
+#, c-format
+msgid "Comparison '%s' between strings not allowed"
+msgstr ""
+#: ../db/drivers/dbf/dbfexe.c:1112
+msgid "Match (~) between numbers not allowed"
+msgstr ""
+#: ../db/drivers/dbf/cursor.c:47
+msgid "Unable to allocate new cursor"
+msgstr ""
+#: ../db/drivers/dbf/cursor.c:59
+msgid "Unable to tokenize new cursor"
+msgstr ""
+#: ../db/drivers/dbf/create_table.c:22
+msgid "Unable to create table"
+msgstr ""
+#: ../db/drivers/dbf/db.c:94
+#, c-format
+msgid "Unable create DBF database: %s"
+msgstr ""
+#: ../db/drivers/dbf/db.c:102
+#, c-format
+msgid "Cannot open DBF database directory: %s"
+msgstr ""
+#: ../db/drivers/dbf/db.c:110
+#, c-format
+msgid "Unable to open DBF database: %s"
+msgstr ""
+#: ../db/drivers/sqlite/index.c:96 ../db/drivers/sqlite/describe.c:78
+#: ../db/drivers/sqlite/describe.c:132 ../db/drivers/sqlite/execute.c:69
+#: ../db/drivers/sqlite/select.c:80 ../db/drivers/sqlite/create_table.c:141
+msgid "Error in sqlite3_step():"
+msgstr ""
+#: ../db/drivers/sqlite/main.c:47
+#, c-format
+msgid "Busy SQLITE db, already waiting for %d seconds..."
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:72
+msgid "Unable to fetch:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:87
+msgid "DB_PREVIOUS is not supported"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:93
+msgid "DB_LAST is not supported"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:171 ../db/drivers/postgres/fetch.c:129
+msgid "Unable to scan date:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:188 ../db/drivers/postgres/fetch.c:147
+msgid "Unable to scan time:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:203
+msgid "Unable to scan timestamp:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:218
+msgid ""
+"SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:223
+msgid "Unable to scan interval:"
+msgstr ""
+#: ../db/drivers/sqlite/fetch.c:286
+msgid "Unable to get number of rows:"
+msgstr ""
+#: ../db/drivers/sqlite/listtab.c:50 ../db/drivers/sqlite/listtab.c:66
+msgid "Unable to list tables:"
+msgstr ""
+#: ../db/drivers/sqlite/describe.c:60 ../db/drivers/sqlite/execute.c:53
+#: ../db/drivers/sqlite/select.c:63
+msgid "Error in sqlite3_prepare():"
+msgstr ""
+#: ../db/drivers/sqlite/describe.c:194
+#, c-format
+msgid "SQLite driver: column '%s', SQLite type %d  is not supported"
+msgstr ""
+#: ../db/drivers/sqlite/execute.c:83
+msgid "Error in sqlite3_finalize():"
+msgstr ""
+#: ../db/drivers/sqlite/execute.c:111
+msgid "'BEGIN' transaction failed:"
+msgstr ""
+#: ../db/drivers/sqlite/execute.c:139
+msgid "'COMMIT' transaction failed:"
+msgstr ""
+#: ../db/drivers/sqlite/listdb.c:45 ../db/drivers/postgres/listdb.c:35
+msgid "No path given"
+msgstr ""
+#: ../db/drivers/sqlite/listdb.c:99
+#, c-format
+msgid "Unable to open directory '%s'"
+msgstr ""
+#: ../db/drivers/sqlite/listdb.c:117
+#, c-format
+msgid "SQLite database connection '%s' is still busy"
+msgstr ""
+#: ../db/drivers/sqlite/listdb.c:134 ../db/drivers/postgres/listtab.c:92
+#: ../db/drivers/postgres/listdb.c:87 ../vector/v.vol.rst/user1.c:423
+#: ../vector/v.kcv/main.c:208 ../vector/v.net.centrality/main.c:293
+#: ../vector/v.net.centrality/main.c:298 ../vector/v.net.centrality/main.c:304
+#: ../vector/v.net.centrality/main.c:310 ../vector/v.net.centrality/main.c:316
+#: ../vector/v.net.connectivity/main.c:186
+#: ../vector/v.net.connectivity/main.c:202
+#: ../vector/v.net.components/main.c:169
+#: ../vector/v.generalize/smoothing.c:144
+#: ../vector/v.generalize/smoothing.c:231
+#: ../vector/v.generalize/smoothing.c:374
+#: ../vector/v.generalize/smoothing.c:528
+#: ../vector/v.generalize/smoothing.c:574
+#: ../vector/v.generalize/smoothing.c:578
+#: ../vector/v.generalize/smoothing.c:582
+#: ../vector/v.generalize/smoothing.c:586
+#: ../vector/v.generalize/smoothing.c:590
+#: ../vector/v.generalize/smoothing.c:594
+#: ../vector/v.generalize/smoothing.c:598 ../vector/v.generalize/matrix.c:144
+#: ../vector/v.generalize/network.c:96 ../vector/v.generalize/network.c:131
+#: ../vector/v.generalize/simplification.c:33
+#: ../vector/v.generalize/simplification.c:40
+#: ../vector/v.generalize/simplification.c:306
+#: ../vector/v.generalize/simplification.c:314
+#: ../vector/v.generalize/simplification.c:338 ../vector/v.surf.rst/main.c:800
+#: ../vector/v.net.distance/main.c:205 ../vector/v.net.allpairs/main.c:201
+#: ../vector/v.mkgrid/write_grid.c:28 ../vector/v.net.timetable/main.c:389
+#: ../vector/v.net.timetable/main.c:399 ../vector/v.net.flow/main.c:232
+#: ../raster3d/r3.to.rast/main.c:295 ../raster/r.to.rast3/main.c:244
+#: ../raster/r.stream.extract/seg.c:55 ../raster/r.stream.extract/cseg.c:51
+#: ../raster/r.stream.extract/dseg.c:51 ../raster/r.stream.extract/bseg.c:50
+#: ../raster/r.li/r.li.daemon/list.c:49 ../imagery/i.smap/multialloc.c:115
+msgid "Out of memory"
+msgstr ""
+#: ../db/drivers/sqlite/cursor.c:47
+msgid "Unable to allocate cursor."
+msgstr ""
+#: ../db/drivers/sqlite/db.c:99
+#, c-format
+msgid "Unable to create directory '%s' for sqlite database"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:107
+msgid "Unable to open database:"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:131
+msgid "SQLite database connection is still busy"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:152
+#, c-format
+msgid "Database <%s> already exists"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:159
+msgid "Unable to create database:"
+msgstr ""
+#: ../db/drivers/sqlite/db.c:183
+#, c-format
+msgid "Database <%s> not found"
+msgstr ""
+#: ../db/drivers/postgres/index.c:59 ../vector/v.extract/copy_tab.c:124
+#: ../vector/v.overlay/main.c:585 ../vector/v.random/main.c:256
+#: ../vector/v.select/copy_tabs.c:82 ../vector/v.patch/main.c:311
+#: ../vector/v.mkgrid/main.c:345 ../vector/v.mkgrid/main.c:403
+#: ../raster/r.random/random.c:253 ../raster/r.to.vect/main.c:226
+msgid "Unable to create index"
+msgstr ""
+#: ../db/drivers/postgres/priv.c:53
+msgid "Unable grant on table:"
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:166
+msgid "Unable to scan timestamp (no idea how to process time zone):"
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:174
+msgid "Unable to scan timestamp (not enough arguments):"
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:188
+msgid "Unable to recognize boolean value"
+msgstr ""
+#: ../db/drivers/postgres/fetch.c:206
+msgid "Taken not found"
+msgstr ""
+#: ../db/drivers/postgres/parse.c:69
+msgid "Unknown option in database definition for PostgreSQL: "
+msgstr ""
+#: ../db/drivers/postgres/listtab.c:38
+msgid "Unable to select table names."
+msgstr ""
+#: ../db/drivers/postgres/listtab.c:65
+msgid "Unable to select view names."
+msgstr ""
+#: ../db/drivers/postgres/describe.c:123
+#, c-format
+msgid "PostgreSQL driver: column '%s', type %d is not supported"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:130
+#, c-format
+msgid ""
+"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
+"may be damaged"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:134
+#, c-format
+msgid ""
+"column '%s' : type character varying is stored as varchar(250) some data may "
+"be lost"
+msgstr ""
+#: ../db/drivers/postgres/describe.c:140
+#, c-format
+msgid ""
+"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
+"(true)"
+msgstr ""
+#: ../db/drivers/postgres/execute.c:68
+msgid "Unable to 'BEGIN' transaction"
+msgstr ""
+#: ../db/drivers/postgres/execute.c:88
+msgid "Unable to 'COMMIT' transaction"
+msgstr ""
+#: ../db/drivers/postgres/select.c:31
+msgid "Unable set DATESTYLE"
+msgstr ""
+#: ../db/drivers/postgres/select.c:55
+msgid "Unable to select:"
+msgstr ""
+#: ../db/drivers/postgres/listdb.c:64
+msgid "Unable to connect to Postgres:"
+msgstr ""
+#: ../db/drivers/postgres/listdb.c:75
+msgid "Unable to select from Postgres:"
+msgstr ""
+#: ../db/drivers/postgres/create_table.c:90
+#, c-format
+msgid "Unknown column type (%s)"
+msgstr ""
+#: ../db/drivers/postgres/create_table.c:132
+msgid "Unable to grant select on table:"
+msgstr ""
+#: ../db/drivers/postgres/db.c:99
+msgid "Unable to set schema:"
+msgstr ""
+#: ../db/drivers/postgres/db.c:117
+msgid "Unable to select data types"
+msgstr ""
+#: ../db/drivers/postgres/db.c:268
+#, c-format
+msgid "Unable to create database <%s>"
+msgstr ""
+#: ../db/drivers/postgres/db.c:270
+#, c-format
+msgid "Unable to drop database <%s>"
+msgstr ""
+#: ../db/db.login/main.c:40 ../db/db.drivers/main.c:71 ../db/db.copy/main.c:35
+#: ../db/db.describe/main.c:129 ../db/db.createdb/main.c:71
+#: ../db/db.databases/main.c:95 ../db/db.dropdb/main.c:71
+#: ../db/db.tables/main.c:97 ../db/db.connect/main.c:43
+#: ../db/db.columns/main.c:99 ../db/db.select/main.c:265
+#: ../db/db.execute/main.c:125 ../vector/v.in.db/main.c:54
+#: ../vector/v.vect.stats/main.c:130 ../vector/v.distance/main.c:92
+#: ../vector/v.db.connect/main.c:54 ../vector/v.db.select/main.c:55
+#: ../vector/v.to.db/main.c:38 ../temporal/t.connect/main.c:34
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
+#: ../locale/scriptstrings/db.univar_to_translate.c:2
+#: ../locale/scriptstrings/v.db.update_to_translate.c:4
+#: ../locale/scriptstrings/db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
+#: ../locale/scriptstrings/db.test_to_translate.c:2
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
+#: ../locale/scriptstrings/v.db.join_to_translate.c:4
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
+msgid "database"
+msgstr ""
+#: ../db/db.login/main.c:41 ../db/db.drivers/main.c:72
+#: ../db/db.connect/main.c:45 ../temporal/t.connect/main.c:36
+msgid "connection settings"
+msgstr ""
+#: ../db/db.login/main.c:42
+msgid "Sets user/password for DB driver/database."
+msgstr ""
+#: ../db/db.login/main.c:58
+msgid "Username to set for DB connection"
+msgstr ""
+#: ../db/db.login/main.c:59 ../db/db.login/main.c:67
+#: ../vector/v.external.out/args.c:20 ../vector/v.external.out/args.c:35
+#: ../vector/v.external.out/args.c:47 ../vector/v.external.out/args.c:53
+#: ../vector/v.vol.rst/main.c:268 ../vector/v.vol.rst/main.c:276
+#: ../vector/v.vol.rst/main.c:283 ../vector/v.vol.rst/main.c:311
+#: ../vector/v.vol.rst/main.c:320 ../vector/v.vol.rst/main.c:329
+#: ../vector/v.vol.rst/main.c:337 ../vector/v.vol.rst/main.c:346
+#: ../vector/v.vol.rst/main.c:354 ../vector/v.colors.out/main.c:68
+#: ../vector/v.colors.out/main.c:73 ../vector/v.surf.bspline/main.c:113
+#: ../vector/v.surf.bspline/main.c:120 ../vector/v.surf.bspline/main.c:150
+#: ../vector/v.surf.bspline/main.c:159 ../vector/v.surf.bspline/main.c:167
+#: ../vector/v.surf.bspline/main.c:179
+#: ../vector/v.lidar.edgedetection/main.c:95
+#: ../vector/v.lidar.edgedetection/main.c:104
+#: ../vector/v.lidar.edgedetection/main.c:113
+#: ../vector/v.lidar.edgedetection/main.c:122
+#: ../vector/v.lidar.edgedetection/main.c:131
+#: ../vector/v.lidar.edgedetection/main.c:139
+#: ../vector/v.lidar.edgedetection/main.c:148 ../vector/v.outlier/main.c:106
+#: ../vector/v.outlier/main.c:115 ../vector/v.outlier/main.c:123
+#: ../vector/v.db.connect/main.c:66 ../vector/v.db.connect/main.c:72
+#: ../vector/v.surf.idw/main.c:115 ../vector/v.surf.idw/main.c:124
+#: ../vector/v.surf.idw/main.c:132 ../vector/v.lidar.correction/main.c:102
+#: ../vector/v.lidar.correction/main.c:111 ../general/g.access/main.c:50
+#: ../general/g.access/main.c:58 ../raster/r.slope.aspect/main.c:181
+#: ../raster/r.slope.aspect/main.c:190 ../raster/r.slope.aspect/main.c:248
+#: ../raster/r.slope.aspect/main.c:257 ../raster/r.slope.aspect/main.c:263
+#: ../raster/r.walk/main.c:274 ../raster/r.walk/main.c:284
+#: ../raster/r.walk/main.c:294 ../raster/r.out.mpeg/main.c:132
+#: ../raster/r.in.bin/main.c:275 ../raster/r.in.bin/main.c:280
+#: ../raster/r.in.bin/main.c:306 ../raster/r.in.bin/main.c:314
+#: ../raster/r.in.bin/main.c:323 ../raster/r.in.bin/main.c:384
+#: ../raster/r.in.bin/main.c:398 ../raster/r.resamp.bspline/main.c:108
+#: ../raster/r.resamp.bspline/main.c:116 ../raster/r.resamp.bspline/main.c:122
+#: ../raster/r.resamp.bspline/main.c:134 ../raster/r.resamp.bspline/main.c:139
+#: ../raster/r.resamp.rst/main.c:210 ../raster/r.resamp.rst/main.c:216
+#: ../raster/r.resamp.rst/main.c:224 ../raster/r.resamp.rst/main.c:232
+#: ../raster/r.resamp.rst/main.c:240 ../display/d.mon/main.c:70
+#: ../display/d.mon/main.c:78 ../display/d.mon/main.c:86
+#: ../display/d.mon/main.c:92 ../display/d.mon/main.c:98
+#: ../display/d.mon/main.c:128 ../display/d.mon/main.c:134
+#: ../imagery/i.cluster/main.c:103 ../imagery/i.cluster/main.c:120
+#: ../imagery/i.cluster/main.c:128 ../imagery/i.cluster/main.c:137
+#: ../imagery/i.cluster/main.c:145 ../imagery/i.cluster/main.c:153
+#: ../imagery/i.landsat.toar/main.c:159 ../imagery/i.landsat.toar/main.c:168
+#: ../imagery/i.landsat.toar/main.c:178 ../imagery/i.landsat.toar/main.c:187
+#: ../imagery/i.landsat.toar/main.c:208 ../imagery/i.segment/parse_args.c:42
+#: ../imagery/i.segment/parse_args.c:51 ../imagery/i.segment/parse_args.c:62
+#: ../imagery/i.segment/parse_args.c:73 ../imagery/i.segment/parse_args.c:83
+#: ../imagery/i.segment/parse_args.c:102 ../imagery/i.segment/parse_args.c:129
+#: ../imagery/i.segment/parse_args.c:135
+msgid "Settings"
+msgstr ""
+#: ../db/db.login/main.c:66
+msgid "Password to set for DB connection"
+msgstr ""
+#: ../db/db.login/main.c:71
+msgid "Print connection settings and exit"
+msgstr ""
+#: ../db/db.login/main.c:72 ../db/db.connect/main.c:53
+#: ../db/db.connect/main.c:58 ../vector/v.external.out/args.c:63
+#: ../vector/v.external.out/args.c:75 ../vector/v.external.out/args.c:81
+#: ../vector/v.colors/main.c:134 ../vector/v.info/parse.c:25
+#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
+#: ../vector/v.info/parse.c:41 ../vector/v.info/parse.c:46
+#: ../vector/v.what/main.c:89 ../vector/v.what/main.c:94
+#: ../vector/v.what/main.c:99 ../vector/v.what/main.c:104
+#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:47
+#: ../vector/v.external/args.c:55 ../vector/v.db.connect/main.c:84
+#: ../vector/v.db.connect/main.c:89 ../vector/v.db.connect/main.c:96
+#: ../vector/v.db.connect/main.c:103 ../vector/v.in.ogr/main.c:252
+#: ../vector/v.in.ogr/main.c:258 ../vector/v.to.db/parse.c:116
+#: ../vector/v.to.db/parse.c:121 ../vector/v.to.db/parse.c:127
+#: ../vector/v.to.db/parse.c:133 ../temporal/t.connect/main.c:43
+#: ../locale/scriptstrings/g.extension_to_translate.c:13
+#: ../locale/scriptstrings/g.extension_to_translate.c:15
+#: ../locale/scriptstrings/g.extension_to_translate.c:17
+#: ../locale/scriptstrings/g.extension_to_translate.c:19
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
+#: ../general/g.mapsets/main.c:87 ../general/g.mapsets/main.c:92
+#: ../general/g.mapsets/main.c:98 ../general/g.proj/main.c:79
+#: ../general/g.proj/main.c:85 ../general/g.proj/main.c:91
+#: ../general/g.proj/main.c:97 ../general/g.proj/main.c:103
+#: ../general/g.proj/main.c:114 ../general/g.proj/main.c:119
+#: ../general/g.list/main.c:128 ../general/g.list/main.c:139
+#: ../general/g.list/main.c:161 ../general/g.list/main.c:166
+#: ../general/g.list/main.c:171 ../general/g.list/main.c:176
+#: ../general/g.region/main.c:84 ../general/g.region/main.c:90
+#: ../general/g.region/main.c:95 ../general/g.region/main.c:101
+#: ../general/g.region/main.c:107 ../general/g.region/main.c:113
+#: ../general/g.region/main.c:119 ../general/g.region/main.c:127
+#: ../general/g.region/main.c:132 ../general/g.region/main.c:138
+#: ../general/g.region/main.c:143 ../general/g.mapset/main.c:76
+#: ../general/g.mapset/main.c:82 ../raster/r.proj/main.c:204
+#: ../raster/r.proj/main.c:214 ../raster/r.proj/main.c:220
+#: ../raster/r.out.gdal/main.c:142 ../raster/r.colors/edit_colors.c:128
+#: ../raster/r.external.out/main.c:272 ../raster/r.external.out/main.c:283
+#: ../raster/r.sunmask/main.c:232 ../raster/r.sunmask/main.c:238
+#: ../raster/r.external/main.c:94 ../raster/r.in.gdal/main.c:169
+#: ../raster/r.what/main.c:120 ../raster/r.what/main.c:128
+#: ../raster/r.what/main.c:142 ../raster/r.what/main.c:147
+#: ../raster/r.what/main.c:152 ../raster/r.what/main.c:157
+#: ../display/d.mon/main.c:103 ../display/d.mon/main.c:108
+#: ../display/d.mon/main.c:113 ../imagery/i.group/main.c:79
+#: ../imagery/i.group/main.c:84 ../imagery/i.group/main.c:89
+msgid "Print"
+msgstr ""
+#: ../db/db.login/main.c:85
+msgid "Unable to set user/password"
+msgstr ""
+#: ../db/db.login/main.c:89
+#, c-format
+msgid "The password was stored in file (%s%cdblogin)"
+msgstr ""
+#: ../db/db.drivers/main.c:39
+msgid "Unable to read dbmscap file"
+msgstr ""
+#: ../db/db.drivers/main.c:63
+msgid "Full output"
+msgstr ""
+#: ../db/db.drivers/main.c:67
+msgid "Print drivers and exit"
+msgstr ""
+#: ../db/db.drivers/main.c:73
+msgid "Lists all database drivers."
+msgstr ""
+#: ../db/db.copy/main.c:36 ../db/db.describe/main.c:130
+#: ../db/db.createdb/main.c:72 ../db/db.databases/main.c:96
+#: ../db/db.dropdb/main.c:72 ../db/db.tables/main.c:98
+#: ../db/db.connect/main.c:44 ../db/db.columns/main.c:100
+#: ../db/db.select/main.c:266 ../db/db.execute/main.c:126
+#: ../vector/v.what.rast/main.c:76 ../vector/v.vect.stats/main.c:129
+#: ../vector/v.distance/main.c:93 ../vector/v.class/main.c:47
+#: ../vector/v.db.connect/main.c:53 ../vector/v.db.select/main.c:54
+#: ../vector/v.univar/main.c:95 ../vector/v.what.rast3/main.c:69
+#: ../vector/v.to.db/main.c:37 ../temporal/t.connect/main.c:35
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/db.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.update_to_translate.c:3
+#: ../locale/scriptstrings/db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
+#: ../locale/scriptstrings/db.test_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
+#: ../locale/scriptstrings/v.db.join_to_translate.c:3
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
+msgid "attribute table"
+msgstr ""
+#: ../db/db.copy/main.c:37 ../db/db.createdb/main.c:73
+#: ../db/db.databases/main.c:97 ../db/db.dropdb/main.c:73
+#: ../db/db.select/main.c:267 ../db/db.execute/main.c:127
+#: ../db/db.execute/main.c:134 ../db/db.execute/main.c:140
+#: ../vector/v.db.select/main.c:56
+msgid "SQL"
+msgstr "SQL"
+#: ../db/db.copy/main.c:38
+msgid "Copy a table."
+msgstr "Kopioi taulu."
+#: ../db/db.copy/main.c:40
+msgid ""
+"Either 'from_table' (optionally with 'where') can be used or 'select' "
+"option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../db/db.copy/main.c:46
+msgid "Input driver name"
+msgstr ""
+#: ../db/db.copy/main.c:52
+msgid "Input database name"
+msgstr ""
+#: ../db/db.copy/main.c:59
+msgid "Input table name (only, if 'select' is not used)"
+msgstr ""
+#: ../db/db.copy/main.c:65
+msgid "Output driver name"
+msgstr ""
+#: ../db/db.copy/main.c:71
+msgid "Output database name"
+msgstr ""
+#: ../db/db.copy/main.c:78
+msgid "Output table name"
+msgstr ""
+#: ../db/db.copy/main.c:87
+msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
+msgstr ""
+#: ../db/db.copy/main.c:88
+msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
+msgstr ""
+#: ../db/db.copy/main.c:96
+msgid "Cannot combine 'from_table' and 'select' options"
+msgstr ""
+#: ../db/db.copy/main.c:100 ../db/db.describe/main.c:50
+#: ../db/db.columns/main.c:44 ../db/db.select/main.c:53
+#, c-format
+msgid "Table <%s> not found in database <%s> using driver <%s>"
+msgstr ""
+#: ../db/db.copy/main.c:122
+msgid "Either 'from_table' or 'select' option must be given."
+msgstr ""
+#: ../db/db.copy/main.c:125
+msgid "Cannot combine 'select' and 'where' options"
+msgstr ""
+#: ../db/db.copy/main.c:135
+msgid "Copy table failed"
+msgstr "Taulun kopiointi epäonnistui"
+#: ../db/db.describe/main.c:56 ../db/db.createdb/main.c:42
+#: ../db/db.databases/main.c:48 ../db/db.dropdb/main.c:42
+#: ../db/db.tables/main.c:45 ../db/db.columns/main.c:51
+#: ../db/db.select/main.c:75 ../db/db.execute/main.c:70
+#: ../vector/v.edit/select.c:509 ../vector/v.out.svg/main.c:152
+#: ../vector/v.out.vtk/writeVTK.c:644 ../vector/v.db.connect/main.c:217
+#: ../vector/v.db.connect/main.c:283 ../doc/vector/v.example/main.c:126
+#: ../raster/r.stream.extract/close.c:172 ../display/d.vect/opt.c:147
+#: ../display/d.vect.thematic/main.c:208
+#, c-format
+msgid "Unable to start driver <%s>"
+msgstr ""
+#: ../db/db.describe/main.c:61 ../db/db.tables/main.c:50
+#: ../db/db.columns/main.c:56 ../db/db.select/main.c:81
+#: ../db/db.execute/main.c:76 ../display/d.vect/opt.c:152
+#: ../display/d.vect.thematic/main.c:213
+#, c-format
+msgid "Unable to open database <%s>"
+msgstr ""
+#: ../db/db.describe/main.c:67 ../db/db.columns/main.c:62
+#: ../vector/v.info/print.c:152 ../vector/v.random/main.c:269
+#: ../vector/v.out.svg/main.c:165 ../vector/v.out.vtk/writeVTK.c:655
+#: ../vector/v.reclass/main.c:193 ../vector/v.out.ogr/main.c:640
+#: ../vector/v.patch/main.c:147 ../vector/v.patch/main.c:187
+#: ../vector/v.db.connect/main.c:228 ../vector/v.out.postgis/table.c:41
+#: ../vector/v.in.ascii/main.c:429 ../doc/vector/v.example/main.c:137
+#, c-format
+msgid "Unable to describe table <%s>"
+msgstr ""
+#: ../db/db.describe/main.c:108
+msgid "Print column names only instead of full column descriptions"
+msgstr ""
+#: ../db/db.describe/main.c:113
+msgid "Print table structure"
+msgstr ""
+#: ../db/db.describe/main.c:131
+msgid "Describes a table in detail."
+msgstr ""
+#: ../db/db.createdb/main.c:74
+msgid "Creates an empty database."
+msgstr ""
+#: ../db/db.databases/main.c:53
+msgid ""
+"Unable to list databases. Try to define correct connection settings by db."
+"login."
+msgstr ""
+#: ../db/db.databases/main.c:63
+msgid "No databases found"
+msgstr ""
+#: ../db/db.databases/main.c:80 ../db/db.databases/main.c:91
+#: ../db/db.select/main.c:219 ../db/db.select/main.c:224
+#: ../db/db.execute/main.c:144 ../db/db.execute/main.c:149
+#: ../db/db.execute/main.c:154
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
+#: ../locale/scriptstrings/db.droptable_to_translate.c:7
+#: ../locale/scriptstrings/db.droptable_to_translate.c:10
+msgid "Connection"
+msgstr "Yhteys"
+#: ../db/db.databases/main.c:87
+msgid "Location"
+msgstr "Paikka"
+#: ../db/db.databases/main.c:88
+msgid "Path for SQLite driver, or connection string for PostgreSQL driver"
+msgstr ""
+#: ../db/db.databases/main.c:99
+msgid "Lists all databases for a given driver and location."
+msgstr ""
+#: ../db/db.dropdb/main.c:74
+msgid "Removes an existing database."
+msgstr ""
+#: ../db/db.tables/main.c:41 ../db/db.connect/main.c:141
+msgid "Database connection not defined. Run db.connect."
+msgstr ""
+#: ../db/db.tables/main.c:54
+#, c-format
+msgid "Unable to list tables from database <%s>"
+msgstr ""
+#: ../db/db.tables/main.c:60
+msgid "No tables found"
+msgstr "Tauluja ei löytynyt"
+#: ../db/db.tables/main.c:89
+msgid "Print tables and exit"
+msgstr ""
+#: ../db/db.tables/main.c:93
+msgid "System tables instead of user tables"
+msgstr ""
+#: ../db/db.tables/main.c:99
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../db/db.connect/main.c:47
+msgid "Prints/sets general DB connection for current mapset."
+msgstr ""
+#: ../db/db.connect/main.c:51 ../temporal/t.connect/main.c:42
+msgid "Print current connection parameters and exit"
+msgstr ""
+#: ../db/db.connect/main.c:52
+msgid "Substitute variables in database settings"
+msgstr ""
+#: ../db/db.connect/main.c:57
+msgid "Print current connection parameters using shell style and exit"
+msgstr ""
+#: ../db/db.connect/main.c:63 ../temporal/t.connect/main.c:48
+msgid "Check connection parameters, set if uninitialized, and exit"
+msgstr ""
+#: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
+#: ../db/db.connect/main.c:75 ../db/db.connect/main.c:79
+#: ../db/db.connect/main.c:83 ../db/db.connect/main.c:93
+#: ../temporal/t.connect/main.c:49 ../temporal/t.connect/main.c:55
+#: ../temporal/t.connect/main.c:60 ../temporal/t.connect/main.c:65
+#: ../temporal/t.connect/main.c:69 ../general/g.gisenv/main.c:66
+#: ../general/g.gisenv/main.c:74 ../general/g.gisenv/main.c:84
+msgid "Set"
+msgstr ""
+#: ../db/db.connect/main.c:68 ../temporal/t.connect/main.c:53
+msgid "Set from default settings and exit"
+msgstr ""
+#: ../db/db.connect/main.c:69
+msgid "Overwrite current settings if already initialized"
+msgstr ""
+#: ../db/db.connect/main.c:91
+msgid "Default group of database users to which select privilege is granted"
+msgstr ""
+#: ../db/db.connect/main.c:161 ../db/db.connect/main.c:188
+#: ../temporal/t.connect/main.c:133
+#, c-format
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../db/db.connect/main.c:166
+msgid "DB settings already defined, nothing to do"
+msgstr ""
+#: ../db/db.connect/main.c:172
+msgid "Default driver is not set"
+msgstr ""
+#: ../db/db.connect/main.c:175
+msgid "Default database is not set"
+msgstr ""
+#: ../db/db.columns/main.c:101
+msgid "List all columns for a given table."
+msgstr ""
+#: ../db/db.select/main.c:63 ../db/db.execute/main.c:57
+#, c-format
+msgid "Unable to open file <%s>: %s"
+msgstr ""
+#: ../db/db.select/main.c:105
+#, c-format
+msgid "Test %s."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
+#: ../imagery/i.rectify/report.c:10
+msgid "failed"
+msgstr "epäonistui"
+msgid "succeeded"
+msgstr "onnistui"
+#: ../db/db.select/main.c:142 ../vector/v.db.select/main.c:117
+#: ../raster/r.regression.line/main.c:76 ../raster/r.stats/main.c:227
+#: ../raster/r.regression.multi/main.c:168
+#: ../raster/r.univar/r3.univar_main.c:128
+#: ../raster/r.univar/r.univar_main.c:121 ../raster/r.what/main.c:170
+#, c-format
+msgid "Unable to open file <%s> for writing"
+msgstr ""
+#: ../db/db.select/main.c:203 ../db/db.select/main.c:209
+#: ../db/db.select/main.c:213 ../db/db.select/main.c:251
+#: ../db/db.select/main.c:261 ../vector/v.to.db/parse.c:104
+#: ../vector/v.to.db/parse.c:112 ../raster/r.what/main.c:110
+#: ../raster/r.what/main.c:116
+msgid "Query"
+msgstr "Kysely"
+#: ../db/db.select/main.c:207
+msgid "Name of file containing SQL select statement(s)"
+msgstr ""
+#: ../db/db.select/main.c:208 ../db/db.execute/main.c:139
+#: ../vector/v.edit/args.c:89 ../vector/v.segment/main.c:80
+#: ../vector/v.what/main.c:76 ../locale/scriptstrings/m.proj_to_translate.c:7
+#: ../general/g.proj/main.c:140 ../general/g.proj/main.c:149
+#: ../raster/r.in.ascii/main.c:79 ../raster/r.reclass/main.c:66
+#: ../raster/r.recode/main.c:60
+msgid "'-' for standard input"
+msgstr ""
+#: ../db/db.select/main.c:212
+msgid "Name of table to query"
+msgstr ""
+#: ../db/db.select/main.c:227 ../db/db.select/main.c:233
+#: ../db/db.select/main.c:236 ../db/db.select/main.c:246
+#: ../db/db.select/main.c:256 ../vector/v.db.select/main.c:71
+#: ../vector/v.db.select/main.c:77 ../vector/v.db.select/main.c:80
+#: ../vector/v.db.select/main.c:97 ../vector/v.db.select/main.c:102
+#: ../general/g.gisenv/main.c:93 ../general/g.gisenv/main.c:98
+msgid "Format"
+msgstr ""
+#: ../db/db.select/main.c:231
+msgid "Vertical record separator (requires -v flag)"
+msgstr ""
+#: ../db/db.select/main.c:241 ../vector/v.db.select/main.c:86
+#: ../locale/scriptstrings/i.oif_to_translate.c:5
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
+#: ../raster/r.stats/main.c:119 ../raster/r.univar/r3.univar_main.c:42
+#: ../raster/r.univar/r.univar_main.c:41 ../raster/r.what/main.c:125
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
+msgstr ""
+#: ../db/db.select/main.c:245 ../vector/v.db.select/main.c:96
+msgid "Do not include column names in output"
+msgstr ""
+#: ../db/db.select/main.c:250
+msgid "Describe query only (don't run it)"
+msgstr ""
+#: ../db/db.select/main.c:255 ../vector/v.db.select/main.c:101
+msgid "Vertical output (instead of horizontal)"
+msgstr ""
+#: ../db/db.select/main.c:260
+msgid "Only test query, do not execute"
+msgstr ""
+#: ../db/db.select/main.c:268
+msgid "Selects data from attribute table."
+msgstr ""
+#: ../db/db.select/main.c:269
+msgid "Performs SQL query statement(s)."
+msgstr ""
+#: ../db/db.select/main.c:304
+#, c-format
+msgid "You must provide one of these options: <%s>, <%s>, or <%s>"
+msgstr ""
+#: ../db/db.execute/main.c:94 ../db/db.execute/main.c:99
+#, c-format
+msgid "Error while executing: '%s'"
+msgstr ""
+#: ../db/db.execute/main.c:128
+msgid "Executes any SQL statement."
+msgstr ""
+#: ../db/db.execute/main.c:129
+msgid "For SELECT statements use 'db.select'."
+msgstr ""
+#: ../db/db.execute/main.c:132
+msgid "SQL statement"
+msgstr "SQL lauseke"
+#: ../db/db.execute/main.c:133
+msgid "Example: update rybniky set kapri = 'hodne' where kapri = 'malo'"
+msgstr ""
+#: ../db/db.execute/main.c:138
+msgid "Name of file containing SQL statement(s)"
+msgstr ""
+#: ../db/db.execute/main.c:160
+msgid "Ignore SQL errors and continue"
+msgstr ""
+#: ../db/db.execute/main.c:161 ../vector/v.build/main.c:51
+#: ../vector/v.build/main.c:77
+msgid "Errors"
+msgstr "Virheet"
+#: ../db/db.execute/main.c:167
+#, c-format
+msgid "You must provide <%s> or <%s> option"
+msgstr ""
+#: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_vlegend.c:49
+#: ../ps/ps.map/r_colortable.c:65
+msgid "illegal where request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:67 ../ps/ps.map/r_header.c:65
+#: ../ps/ps.map/ps_outline.c:87 ../ps/ps.map/getgrid.c:61
+#: ../ps/ps.map/getgrid.c:85 ../ps/ps.map/getgrid.c:171
+#: ../ps/ps.map/getgrid.c:195
+msgid "Unsupported color request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:69 ../ps/ps.map/r_instructions.c:149
+#: ../ps/ps.map/r_instructions.c:464 ../ps/ps.map/r_header.c:67
+#: ../ps/ps.map/ps_outline.c:89 ../ps/ps.map/getgrid.c:63
+#: ../ps/ps.map/getgrid.c:87 ../ps/ps.map/getgrid.c:173
+#: ../ps/ps.map/getgrid.c:197
+msgid "illegal color request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:81
+msgid "illegal bgcolor request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
+msgid "illegal border color request"
+msgstr ""
+#: ../ps/ps.map/r_info.c:103
+msgid "illegal mapinfo sub-request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:62
+msgid "Data exist after final 'end' instruction!"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:80
+msgid "no file specified"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:84
+msgid "unable to open"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:115
+msgid "illegal maploc request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:129 ../ps/ps.map/main.c:220
+msgid "illegal copies request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
+msgid "no raster map selected yet"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:160
+msgid "illegal value list"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:196
+msgid "scalebar is not appropriate for this projection"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:204
+msgid "Bad scalebar length"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:220
+msgid "illegal text request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:234
+msgid "illegal point request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:248
+msgid "illegal eps request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:265
+msgid "illegal line request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:282
+msgid "illegal rectangle request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:293
+msgid "illegal comments request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:309
+msgid "illegal scale request"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:369
+msgid "group not found"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:411
+msgid "illegal grid spacing"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:422
+msgid "geogrid is not available for this projection"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:432
+msgid "illegal geo-grid spacing"
+msgstr ""
+#: ../ps/ps.map/r_instructions.c:469
+msgid "illegal request"
+msgstr ""
+#: ../ps/ps.map/main.c:93
+msgid "postscript"
+msgstr ""
+#: ../ps/ps.map/main.c:94
+msgid "printing"
+msgstr ""
+#: ../ps/ps.map/main.c:95
+msgid "Produces hardcopy PostScript map output."
+msgstr ""
+#: ../ps/ps.map/main.c:99
+msgid "Rotate plot 90 degrees"
+msgstr ""
+#: ../ps/ps.map/main.c:100 ../ps/ps.map/main.c:113 ../ps/ps.map/main.c:135
+#: ../locale/scriptstrings/r.unpack_to_translate.c:7
+#: ../locale/scriptstrings/r.unpack_to_translate.c:9
+#: ../raster/r.univar/r.univar_main.c:42 ../raster/r.kappa/main.c:90
+#: ../raster/r.kappa/main.c:98
+msgid "Output settings"
+msgstr ""
+#: ../ps/ps.map/main.c:105
+msgid "List paper formats (name width height left right top bottom(margin))"
+msgstr ""
+#: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
+msgid "Utility"
+msgstr ""
+#: ../ps/ps.map/main.c:112
+msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
+msgstr ""
+#: ../ps/ps.map/main.c:118
+msgid ""
+"Describe map-box's position on the page and exit (inches from top-left of "
+"paper)"
+msgstr ""
+#: ../ps/ps.map/main.c:123
+msgid "File containing mapping instructions"
+msgstr ""
+#: ../ps/ps.map/main.c:124
+msgid "Use '-' to enter instructions from keyboard)"
+msgstr ""
+#: ../ps/ps.map/main.c:127
+msgid "Name for PostScript output file"
+msgstr ""
+#: ../ps/ps.map/main.c:133
+msgid "Number of copies to print"
+msgstr ""
+#: ../ps/ps.map/main.c:205
+#, c-format
+msgid "Unable to open file '%s': %s"
+msgstr ""
+#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
+#: ../vector/v.univar/main.c:147 ../vector/v.to.db/parse.c:141
+#: ../vector/v.to.db/parse.c:144
+#, c-format
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
+msgstr ""
+#: ../ps/ps.map/main.c:273
+#, c-format
+msgid "PostScript file '%s' successfully written."
+msgstr ""
+#: ../ps/ps.map/r_vlegend.c:97
+msgid "illegal vlegend sub-request"
+msgstr ""
+#: ../ps/ps.map/r_header.c:77
+msgid "illegal header sub-request"
+msgstr ""
+#: ../ps/ps.map/ps_outline.c:43
+#, c-format
+msgid "Outlining areas in raster map <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:73
+#: ../ps/ps.map/r_colortable.c:89
+msgid "illegal width request"
+msgstr ""
+#: ../ps/ps.map/ps_outline.c:107
+msgid "illegal outline sub-request"
+msgstr ""
+#: ../ps/ps.map/ps_vareas.c:67 ../ps/ps.map/ps_vareas.c:78
+#: ../ps/ps.map/ps_vlines.c:84
+msgid "Read error in vector map"
+msgstr ""
+#: ../ps/ps.map/ps_vareas.c:102 ../ps/ps.map/ps_vlines.c:119
+#: ../ps/ps.map/ps_vpoints.c:160 ../ps/ps.map/ps_vpoints.c:171
+#: ../ps/ps.map/ps_vpoints.c:195 ../ps/ps.map/ps_vpoints.c:236
+#: ../ps/ps.map/ps_vpoints.c:246
+#, c-format
+msgid "No record for category [%d]"
+msgstr ""
+#: ../ps/ps.map/ps_vareas.c:108 ../ps/ps.map/ps_vlines.c:125
+#: ../ps/ps.map/ps_vpoints.c:201
+#, c-format
+msgid "Invalid RGB color definition in column <%s> for category [%d]"
+msgstr ""
+#: ../ps/ps.map/ps_vareas.c:161 ../ps/ps.map/ps_vlines.c:56
+#: ../ps/ps.map/ps_vpoints.c:71
+msgid "Cannot load data from table"
+msgstr ""
+#: ../ps/ps.map/do_geogrid.c:86 ../ps/ps.map/do_geogrid.c:91
+#: ../ps/ps.map/do_geogrid.c:115 ../ps/ps.map/do_geogrid.c:120
+#: ../ps/ps.map/do_geogrid.c:189 ../ps/ps.map/do_geogrid.c:230
+#: ../ps/ps.map/do_geogrid.c:306 ../ps/ps.map/do_geogrid.c:322
+#: ../ps/ps.map/do_geogrid.c:339 ../ps/ps.map/do_geogrid.c:356
+#: ../ps/ps.map/do_geogrid.c:412 ../ps/ps.map/do_geogrid.c:418
+#: ../ps/ps.map/do_geogrid.c:422 ../ps/ps.map/do_geogrid.c:430
+#: ../ps/ps.map/do_geogrid.c:434 ../raster/r.latlong/main.c:133
+#: ../raster/r.horizon/main.c:840 ../raster/r.horizon/main.c:858
+#: ../display/d.grid/plot.c:201 ../display/d.grid/plot.c:207
+#: ../display/d.grid/plot.c:260 ../display/d.grid/plot.c:266
+#: ../display/d.grid/plot.c:430 ../display/d.grid/plot.c:446
+#: ../display/d.grid/plot.c:463 ../display/d.grid/plot.c:480
+msgid "Error in pj_do_proj"
+msgstr ""
+#: ../ps/ps.map/do_geogrid.c:272 ../general/g.region/printwindow.c:253
+#: ../general/g.region/printwindow.c:509 ../general/g.region/printwindow.c:628
+#: ../raster/r.horizon/main.c:532 ../raster/r.sun/main.c:736
+#: ../display/d.grid/plot.c:349 ../display/d.where/main.c:113
+msgid "Can't get projection key values of current location"
+msgstr ""
+#: ../ps/ps.map/do_geogrid.c:278 ../raster/r.latlong/main.c:114
+#: ../raster/r.horizon/main.c:542 ../raster/r.sun/main.c:746
+#: ../display/d.grid/plot.c:356 ../display/d.grid/plot.c:383
+#: ../display/d.where/main.c:120 ../display/d.where/main.c:146
+msgid "Unable to set up lat/long projection parameters"
+msgstr ""
+#: ../ps/ps.map/do_psfiles.c:20
+#, c-format
+msgid "Reading PostScript include file <%s> ..."
+msgstr ""
+#: ../ps/ps.map/do_vectors.c:33
+#, c-format
+msgid "Reading vector map <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/do_vectors.c:136
+#, c-format
+msgid "Reading vector points file <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/do_scalebar.c:192
+msgid "meters"
+msgstr "metrit"
+#: ../ps/ps.map/do_scalebar.c:194
+msgid "kilometers"
+msgstr "kilometrit"
+#: ../ps/ps.map/do_scalebar.c:196
+msgid "feet"
+msgstr "jalat"
+#: ../ps/ps.map/do_scalebar.c:198
+msgid "miles"
+msgstr "mailit"
+#: ../ps/ps.map/do_scalebar.c:200
+msgid "nautical miles"
+msgstr "meripenikulmat"
+#: ../ps/ps.map/do_plt.c:38
+msgid "Reading point/line file ..."
+msgstr ""
+#: ../ps/ps.map/do_plt.c:169 ../ps/ps.map/ps_vpoints.c:87
+msgid "Cannot read symbol, using default icon"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:81
+msgid "illegal height request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:106
+msgid "illegal range request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:122
+msgid "illegal columns request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:141
+msgid "Unsupported color request (colortable)"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:143
+msgid "illegal color request (colortable)"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:170
+msgid "illegal colortable sub-request"
+msgstr ""
+#: ../ps/ps.map/r_colortable.c:181
+msgid "No raster selected for colortable!"
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:42
+msgid "Can't create temporary PostScript mask file."
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:102 ../raster/r.series.accumulate/main.c:248
+#: ../raster/r.series.accumulate/main.c:273
+#: ../raster/r.series.accumulate/main.c:284
+#: ../raster/r.series.accumulate/main.c:292
+#: ../raster/r.series.accumulate/main.c:300
+#: ../raster/r.grow.distance/main.c:263 ../raster/r.out.mpeg/main.c:286
+#: ../raster/r.surf.idw/main.c:713
+#, c-format
+msgid "Reading raster map <%s>..."
+msgstr ""
+#: ../ps/ps.map/ps_raster.c:105
+#, c-format
+msgid "Reading raster maps in group <%s>..."
+msgstr ""
+#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
+msgid "illegal numbers request"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
+msgid "illegal grid width request"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:132
+msgid "illegal request (grid)"
+msgstr ""
+#: ../ps/ps.map/getgrid.c:240
+msgid "illegal request (geogrid)"
+msgstr ""
+#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110
+#: ../ps/ps.map/catval.c:176 ../vector/v.vol.rst/user1.c:95
+#: ../vector/v.class/main.c:111 ../vector/v.label.sa/labels.c:75
+#: ../vector/v.label/main.c:274
+msgid "Unable to get layer info for vector map"
+msgstr ""
+#: ../ps/ps.map/catval.c:53 ../ps/ps.map/catval.c:115
+#: ../ps/ps.map/catval.c:181 ../misc/m.nviz.image/vector.c:293
+#: ../vector/v.extract/main.c:260 ../vector/v.net.path/path.c:96
+#: ../vector/v.edit/select.c:516 ../vector/v.colors/read_rgb.c:28
+#: ../vector/v.colors/scan_attr.c:29 ../vector/v.colors/write_rgb.c:25
+#: ../vector/v.vol.rst/main.c:600 ../vector/v.vol.rst/user1.c:99
+#: ../vector/v.in.db/main.c:164 ../vector/v.in.db/main.c:302
+#: ../vector/v.kcv/main.c:126 ../vector/v.info/print.c:147
+#: ../vector/v.to.3d/trans3.c:57 ../vector/v.to.3d/trans2.c:55
+#: ../vector/v.overlay/main.c:239 ../vector/v.overlay/main.c:406
+#: ../vector/v.random/main.c:236 ../vector/v.what.rast/main.c:143
+#: ../vector/v.to.rast/support.c:132 ../vector/v.to.rast/support.c:294
+#: ../vector/v.to.rast/support.c:447 ../vector/v.to.rast/vect2rast.c:60
+#: ../vector/v.net.centrality/main.c:246 ../vector/v.out.svg/main.c:159
+#: ../vector/v.colors.out/make_colors.c:36
+#: ../vector/v.net.components/main.c:179 ../vector/v.in.dwg/main.c:213
+#: ../vector/v.select/copy_tabs.c:77 ../vector/v.distance/main.c:458
+#: ../vector/v.distance/main.c:493 ../vector/v.distance/main.c:539
+#: ../vector/v.distance/main.c:1268 ../vector/v.distance/main.c:1289
+#: ../vector/v.class/main.c:117 ../vector/v.label.sa/labels.c:78
+#: ../vector/v.surf.bspline/main.c:388
+#: ../vector/v.surf.bspline/crosscorr.c:123 ../vector/v.out.vtk/writeVTK.c:649
+#: ../vector/v.reclass/main.c:133 ../vector/v.surf.rst/main.c:587
+#: ../vector/v.out.ogr/main.c:635 ../vector/v.net.distance/main.c:251
+#: ../vector/v.patch/main.c:139 ../vector/v.patch/main.c:171
+#: ../vector/v.patch/main.c:292 ../vector/v.patch/main.c:374
+#: ../vector/v.buffer/main.c:417 ../vector/v.normal/main.c:122
+#: ../vector/v.db.connect/main.c:223 ../vector/v.db.connect/main.c:331
+#: ../vector/v.surf.idw/read_sites.c:55 ../vector/v.transform/trans_digit.c:40
+#: ../vector/v.net.allpairs/main.c:166 ../vector/v.lrs/v.lrs.create/main.c:296
+#: ../vector/v.lrs/v.lrs.create/main.c:305 ../vector/v.db.select/main.c:168
+#: ../vector/v.mkgrid/main.c:277 ../vector/v.label/main.c:278
+#: ../vector/v.extrude/main.c:229 ../vector/v.sample/main.c:179
+#: ../vector/v.what.rast3/main.c:125 ../vector/v.in.ogr/main.c:1111
+#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.net.timetable/main.c:93
+#: ../vector/v.to.db/query.c:89 ../vector/v.to.db/update.c:46
+#: ../vector/v.to.points/main.c:167 ../vector/v.to.rast3/main.c:84
+#: ../vector/v.out.postgis/table.c:34 ../vector/v.in.ascii/main.c:342
+#: ../vector/v.net.flow/main.c:169 ../doc/vector/v.example/main.c:131
+#: ../raster/r.volume/main.c:242 ../raster/r.random/random.c:73
+#: ../raster/r.contour/main.c:172 ../raster/r.to.vect/main.c:180
+#: ../display/d.vect/shape.c:44 ../display/d.vect/attr.c:43
+#: ../display/d.vect.thematic/plot1.c:111 ../display/d.vect.chart/plot.c:43
+#, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr ""
+#: ../ps/ps.map/catval.c:63
+msgid "Column type not supported (must be string)"
+msgstr ""
+#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
+#: ../ps/ps.map/catval.c:198 ../vector/v.vol.rst/user1.c:112
+#: ../vector/v.class/main.c:132 ../vector/v.surf.bspline/main.c:402
+#: ../vector/v.normal/main.c:134 ../vector/v.surf.idw/read_sites.c:68
+#: ../vector/v.sample/main.c:152 ../vector/v.univar/main.c:366
+#: ../vector/v.to.rast3/main.c:95
+msgid "Unable to select data from table"
+msgstr ""
+#: ../ps/ps.map/catval.c:128
+msgid "Size column type must be numeric"
+msgstr ""
+#: ../ps/ps.map/catval.c:195
+msgid "Rotation column type must be numeric"
+msgstr ""
+#: ../ps/ps.map/makeprocs.c:29
+#, c-format
+msgid "Unable to open prolog <%s>"
+msgstr ""
+#: ../ps/ps.map/read_cfg.c:64
+#, c-format
+msgid "Paper '%s' not found, using defaults"
+msgstr ""
+#: ../ps/ps.map/scale.c:136
+msgid "PSmap: do_scale(): shouldn't happen"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:44
+#, c-format
+msgid "Can't open label file <%s> in mapset <%s>"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:48
+#, c-format
+msgid "Reading labels file <%s in %s> ..."
+msgstr ""
+#: ../ps/ps.map/do_labels.c:66
+#, c-format
+msgid "Can't open temporary label file <%s>"
+msgstr ""
+#: ../ps/ps.map/do_labels.c:69
+msgid "Reading text file ..."
+msgstr ""
+#: ../ps/ps.map/do_labels.c:162
+msgid "Text labels: 'fontsize' given so ignoring 'size'"
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:46 ../ps/ps.map/ps_clrtbl.c:35
+#, c-format
+msgid "Creating color table for <%s in %s>..."
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:51
+msgid "Range information not available (run r.support)"
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:64
+msgid "A floating point colortable must contain a range of values"
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
+msgid "Unable to read colors for colorbar"
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:97 ../ps/ps.map/ps_fclrtbl.c:102
+#: ../ps/ps.map/ps_clrtbl.c:69
+msgid "Colorbar y location beyond page margins. Adjusting."
+msgstr ""
+#: ../ps/ps.map/ps_fclrtbl.c:108 ../ps/ps.map/ps_fclrtbl.c:113
+#: ../ps/ps.map/ps_clrtbl.c:75
+msgid "Colorbar x location beyond page margins. Adjusting."
+msgstr ""
+#: ../ps/ps.map/ps_vpoints.c:177
+#, c-format
+msgid "Attribute is of invalid size [%.3f] for category [%d]"
+msgstr ""
+#: ../ps/ps.map/r_plt.c:173
+msgid "Can't open eps file"
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:39 ../display/d.histogram/main.c:174
+#, c-format
+msgid "Category file for <%s> not available"
+msgstr ""
+#: ../ps/ps.map/ps_clrtbl.c:54
+msgid ""
+"Your cats/ file is invalid. A cats/ file with categories and labels is "
+"required for 'colortable' when using categorical legends; see the r.category "
+"help page. Colortable creation has been skipped."
+msgstr ""
+#: ../ps/ps.map/r_group.c:29
+msgid "Can't get group information"
+msgstr ""
+#: ../ps/ps.map/eps.c:18
+#, c-format
+msgid "Can't open eps file <%s>"
+msgstr ""
+#: ../ps/ps.map/eps.c:37
+#, c-format
+msgid "Bounding box in eps file <%s> was not found"
+msgstr ""
+#: ../ps/ps.map/map_setup.c:82
+#, c-format
+msgid "Scale set to %s"
+msgstr ""
+#: ../ps/ps.map/do_masking.c:23
+msgid "Can't open temporary PostScript mask file."
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
+#: ../vector/v.colors/main.c:313 ../vector/v.vol.rst/main.c:615
+#: ../general/g.region/main.c:418 ../general/g.region/main.c:742
+#: ../general/g.region/main.c:750 ../doc/raster/r.example/main.c:105
+#: ../raster/r.buffer/main.c:112 ../raster/r.spread/main.c:438
+#: ../raster/r.spread/main.c:441 ../raster/r.spread/main.c:444
+#: ../raster/r.spread/main.c:448 ../raster/r.spread/main.c:451
+#: ../raster/r.spread/main.c:454 ../raster/r.ros/main.c:367
+#: ../raster/r.ros/main.c:378 ../raster/r.ros/main.c:383
+#: ../raster/r.ros/main.c:388 ../raster/r.ros/main.c:393
+#: ../raster/r.ros/main.c:407 ../raster/r.ros/main.c:411
+#: ../raster/r.ros/main.c:426 ../raster/r.ros/main.c:430
+#: ../raster/r.ros/main.c:441 ../raster/r.coin/main.c:121
+#: ../raster/r.coin/main.c:123 ../raster/r.category/main.c:119
+#: ../raster/r.category/main.c:140 ../raster/r.walk/main.c:435
+#: ../raster/r.walk/main.c:440 ../raster/r.walk/main.c:801
+#: ../raster/r.null/main.c:121 ../raster/r.reclass/main.c:79
+#: ../raster/r.report/parse.c:273 ../raster/r.carve/main.c:165
+#: ../raster/r.colors/edit_colors.c:393 ../raster/r.cross/main.c:106
+#: ../raster/r.univar/r.univar_main.c:216 ../raster/r.flow/io.c:65
+#: ../raster/r.flow/io.c:242 ../raster/r.stream.extract/main.c:174
+#: ../raster/r.stream.extract/main.c:178 ../raster/r.stream.extract/main.c:183
+#: ../raster/r.mapcalc/map.c:505 ../raster/r.tile/main.c:86
+#: ../raster/r.kappa/main.c:150 ../raster/r.kappa/stats.c:33
+#: ../raster/r.kappa/stats.c:38 ../raster/r.sim/simlib/output.c:363
+#: ../raster/r.sim/simlib/output.c:372 ../raster/r.sim/simlib/output.c:403
+#: ../raster/r.sim/simlib/output.c:412 ../raster/r.sim/simlib/output.c:458
+#: ../raster/r.sim/simlib/output.c:475 ../raster/r.sim/simlib/output.c:497
+#: ../raster/r.sim/simlib/output.c:541 ../raster/r.sim/simlib/output.c:583
+#: ../raster/r.sim/simlib/output.c:755 ../raster/r.distance/parse.c:72
+#: ../raster/r.distance/parse.c:81 ../raster/r.compress/main.c:117
+#: ../raster/r.compress/main.c:257 ../raster/r.cost/main.c:350
+#: ../raster/r.cost/main.c:665 ../raster/r.info/main.c:103
+#: ../imagery/i.pca/main.c:139 ../imagery/i.gensigset/parse.c:44
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
+#: ../imagery/i.gensig/parse.c:38
+#, c-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:67
+#, c-format
+msgid "Missing topography attribute for surface %d"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:131 ../misc/m.nviz.image/volume.c:159
+#, c-format
+msgid "Color attribute not defined, using default <%s>"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:137
+#, c-format
+msgid "Missing color attribute for surface %d"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:217
+#, c-format
+msgid "Surface id %d doesn't exist"
+msgstr ""
+#: ../misc/m.nviz.image/surface.c:264 ../misc/m.nviz.image/surface.c:271
+#, c-format
+msgid "Unable to set draw mode for surface id %d"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:50 ../misc/m.nviz.script/main.c:74
+#: ../visualization/ximgview/main.c:294
+#: ../locale/scriptstrings/r.shade_to_translate.c:6
+#: ../locale/scriptstrings/d.shade_to_translate.c:6
+msgid "visualization"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:51 ../misc/m.nviz.script/main.c:70
+#: ../visualization/ximgview/main.c:291
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
+#: ../locale/scriptstrings/d.redraw_to_translate.c:3
+#: ../display/d.mon/main.c:39 ../display/d.erase/main.c:30
+#: ../display/d.rast/main.c:54 ../display/d.vect/main.c:71
+#: ../display/d.info/main.c:32 ../display/d.his/main.c:63
+#: ../display/d.rgb/main.c:54
+msgid "graphics"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:52 ../misc/m.nviz.script/main.c:71
+#: ../vector/v.what.rast/main.c:73 ../vector/v.to.rast/main.c:46
+#: ../vector/v.neighbors/main.c:53 ../vector/v.sample/main.c:77
+#: ../vector/v.what.rast3/main.c:66 ../visualization/ximgview/main.c:292
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
+#: ../locale/scriptstrings/r.blend_to_translate.c:2
+#: ../locale/scriptstrings/r.plane_to_translate.c:2
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
+#: ../locale/scriptstrings/i.spectral_to_translate.c:4
+#: ../locale/scriptstrings/r.tileset_to_translate.c:2
+#: ../locale/scriptstrings/r.rgb_to_translate.c:2
+#: ../locale/scriptstrings/r.unpack_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:4
+#: ../locale/scriptstrings/r.shade_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:4
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
+#: ../locale/scriptstrings/r.pack_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
+#: ../locale/scriptstrings/v.krige_to_translate.c:4
+#: ../locale/scriptstrings/r.mask_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
+#: ../locale/scriptstrings/r.grow_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:4
+#: ../raster3d/r3.to.rast/main.c:208 ../raster3d/r3.cross.rast/main.c:230
+#: ../doc/raster/r.example/main.c:83 ../raster/r.out.gridatb/main.c:67
+#: ../raster/r.buffer/main.c:66 ../raster/r.slope.aspect/main.c:151
+#: ../raster/r.param.scale/interface.c:54 ../raster/r.in.png/main.c:519
+#: ../raster/r.sunhours/main.c:72 ../raster/r.surf.random/main.c:36
+#: ../raster/r.in.mat/main.c:91 ../raster/r.proj/main.c:144
+#: ../raster/r.support/main.c:55 ../raster/r.volume/main.c:75
+#: ../raster/r.spread/main.c:105 ../raster/r.series.accumulate/main.c:80
+#: ../raster/r.ros/main.c:212 ../raster/r.topmodel/main.c:51
+#: ../raster/r.coin/main.c:66 ../raster/r.stats.quantile/main.c:389
+#: ../raster/r.category/main.c:52 ../raster/r.in.ascii/main.c:69
+#: ../raster/r.series.interp/main.c:64 ../raster/r.in.xyz/main.c:159
+#: ../raster/r.out.gdal/main.c:136 ../raster/r.in.gridatb/main.c:45
+#: ../raster/r.mode/main.c:54 ../raster/r.walk/main.c:178
+#: ../raster/r.null/main.c:59 ../raster/r.timestamp/main.c:35
+#: ../raster/r.latlong/main.c:56 ../raster/r.quant/main.c:47
+#: ../raster/r.reclass/main.c:50 ../raster/r.in.poly/main.c:34
+#: ../raster/r.out.ppm/main.c:54 ../raster/r.in.lidar/main.c:170
+#: ../raster/r.grow.distance/main.c:151 ../raster/r.regression.line/main.c:46
+#: ../raster/r.what.color/main.c:88 ../raster/r.describe/main.c:54
+#: ../raster/r.out.png/main.c:112 ../raster/r.covar/main.c:51
+#: ../raster/r.random/main.c:51 ../raster/r.report/main.c:67
+#: ../raster/r.profile/main.c:53 ../raster/r.colors.out/raster_main.c:45
+#: ../raster/r.out.mpeg/main.c:102 ../raster/r.out.bin/main.c:279
+#: ../raster/r.surf.contour/main.c:60 ../raster/r.out.vrml/main.c:47
+#: ../raster/r.his/main.c:67 ../raster/r.fill.dir/main.c:86
+#: ../raster/r.relief/main.c:107 ../raster/r.to.rast3elev/main.c:361
+#: ../raster/r.out.mat/main.c:62 ../raster/r.rescale.eq/main.c:52
+#: ../raster/r.recode/main.c:48 ../raster/r.surf.gauss/main.c:38
+#: ../raster/r.clump/main.c:51 ../raster/r.drain/main.c:109
+#: ../raster/r.water.outlet/main.c:67 ../raster/r.stats/main.c:106
+#: ../raster/r.watershed/front/main.c:72 ../raster/r.resamp.stats/main.c:256
+#: ../raster/r.surf.area/main.c:76 ../raster/r.regression.multi/main.c:128
+#: ../raster/r.carve/main.c:74 ../raster/r.mfilter/main.c:56
+#: ../raster/r.colors/edit_colors.c:63 ../raster/r.usler/main.c:52
+#: ../raster/r.out.vtk/main.c:59 ../raster/r.composite/main.c:72
+#: ../raster/r.external.out/main.c:235 ../raster/r.spreadpath/main.c:88
+#: ../raster/r.cross/main.c:69 ../raster/r.univar/r.univar_main.c:100
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.flow/main.c:421
+#: ../raster/r.circle/main.c:51 ../raster/r.to.rast3/main.c:197
+#: ../raster/r.thin/main.c:55 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.series/main.c:133 ../raster/r.sunmask/main.c:116
+#: ../raster/r.contour/main.c:87 ../raster/r.stream.extract/main.c:76
+#: ../raster/r.solute.transport/main.c:229 ../raster/r.mapcalc/main.c:115
+#: ../raster/r.resample/main.c:54 ../raster/r.tile/main.c:43
+#: ../raster/r.region/main.c:51 ../raster/r.stats.zonal/main.c:101
+#: ../raster/r.support.stats/main.c:38 ../raster/r.basins.fill/main.c:54
+#: ../raster/r.external/main.c:55 ../raster/r.in.gdal/main.c:86
+#: ../raster/r.kappa/main.c:68 ../raster/r.uslek/main.c:53
+#: ../raster/r.topidx/main.c:39 ../raster/r.lake/main.c:150
+#: ../raster/r.patch/main.c:54 ../raster/r.surf.idw/main.c:104
+#: ../raster/r.to.vect/main.c:70 ../raster/r.sim/r.sim.sediment/main.c:109
+#: ../raster/r.sim/r.sim.water/main.c:109 ../raster/r.out.ppm3/main.c:57
+#: ../raster/r.out.pov/main.c:121 ../raster/r.surf.fractal/main.c:38
+#: ../raster/r.what/main.c:98 ../raster/r.gwflow/main.c:208
+#: ../raster/r.quantile/main.c:255 ../raster/r.random.surface/main.c:57
+#: ../raster/r.in.bin/main.c:257 ../raster/r.distance/main.c:39
+#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.rescale/main.c:48
+#: ../raster/r.transect/main.c:103
+#: ../raster/r.li/r.li.dominance/dominance.c:46
+#: ../raster/r.li/r.li.simpson/simpson.c:46
+#: ../raster/r.li/r.li.padsd/padsd.c:53
+#: ../raster/r.li/r.li.patchdensity/main.c:51
+#: ../raster/r.li/r.li.padrange/padrange.c:53
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
+#: ../raster/r.li/r.li.renyi/renyi.c:47 ../raster/r.li/r.li.cwed/cwed.c:54
+#: ../raster/r.li/r.li.richness/richness.c:43
+#: ../raster/r.li/r.li.padcv/padcv.c:53 ../raster/r.li/r.li.shape/main.c:49
+#: ../raster/r.li/r.li.mps/mps.c:52 ../raster/r.li/r.li.patchnum/main.c:50
+#: ../raster/r.li/r.li.shannon/shannon.c:46 ../raster/r.li/r.li.mpa/mpa.c:43
+#: ../raster/r.li/r.li.pielou/pielou.c:46 ../raster/r.horizon/main.c:180
+#: ../raster/r.sun/main.c:239 ../raster/r.compress/main.c:64
+#: ../raster/r.statistics/main.c:55 ../raster/r.resamp.filter/main.c:384
+#: ../raster/r.neighbors/main.c:167 ../raster/r.cost/main.c:140
+#: ../raster/r.info/main.c:69 ../raster/r.resamp.rst/main.c:148
+#: ../raster/r.texture/main.c:101 ../raster/r.random.cells/main.c:45
+#: ../display/d.rast/main.c:55 ../display/d.rast.num/main.c:78
+#: ../display/d.rgb/main.c:55 ../display/d.rast.arrow/main.c:97
+#: ../display/d.profile/main.c:193 ../display/d.colortable/main.c:61
+msgid "raster"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:53 ../misc/m.nviz.script/main.c:73
+#: ../vector/v.extract/main.c:77 ../vector/v.external.out/main.c:43
+#: ../vector/v.net.path/main.c:40 ../vector/v.edit/main.c:54
+#: ../vector/v.colors/main.c:55 ../vector/v.vol.rst/main.c:235
+#: ../vector/v.net.steiner/main.c:345 ../vector/v.in.db/main.c:52
+#: ../vector/v.kcv/main.c:55 ../vector/v.net.visibility/main.c:45
+#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:424
+#: ../vector/v.to.3d/main.c:36 ../vector/v.overlay/main.c:62
+#: ../vector/v.build/main.c:36 ../vector/v.random/main.c:96
+#: ../vector/v.what.rast/main.c:71 ../vector/v.vect.stats/main.c:128
+#: ../vector/v.to.rast/main.c:44 ../vector/v.net.centrality/main.c:96
+#: ../vector/v.segment/main.c:60 ../vector/v.type/main.c:38
+#: ../vector/v.net.salesman/main.c:126 ../vector/v.net.iso/main.c:71
+#: ../vector/v.out.svg/main.c:77 ../vector/v.net.connectivity/main.c:52
+#: ../vector/v.out.ascii/main.c:47 ../vector/v.colors.out/main.c:49
+#: ../vector/v.net.components/main.c:71 ../vector/v.in.dwg/main.c:82
+#: ../vector/v.select/main.c:47 ../vector/v.distance/main.c:90
+#: ../vector/v.parallel/main.c:49 ../vector/v.class/main.c:45
+#: ../vector/v.generalize/main.c:76 ../vector/v.in.region/main.c:41
+#: ../vector/v.label.sa/main.c:38 ../vector/v.voronoi/main.c:123
+#: ../vector/v.hull/main.c:52 ../vector/v.surf.bspline/main.c:91
+#: ../vector/v.net.bridge/main.c:47 ../vector/v.drape/main.c:56
+#: ../vector/v.out.vtk/main.c:47 ../vector/v.lidar.edgedetection/main.c:72
+#: ../vector/v.net/main.c:45 ../vector/v.category/main.c:75
+#: ../vector/v.reclass/main.c:67 ../vector/v.surf.rst/main.c:141
+#: ../vector/v.perturb/main.c:62 ../vector/v.out.ogr/main.c:81
+#: ../vector/v.out.pov/main.c:46 ../vector/v.net.distance/main.c:64
+#: ../vector/v.outlier/main.c:69 ../vector/v.proj/main.c:67
+#: ../vector/v.support/main.c:39 ../vector/v.what/main.c:60
+#: ../vector/v.patch/main.c:68 ../vector/v.in.lidar/main.c:156
+#: ../vector/v.external/main.c:48 ../vector/v.delaunay/main.c:85
+#: ../vector/v.buffer/main.c:222 ../vector/v.normal/main.c:72
+#: ../vector/v.db.connect/main.c:52 ../vector/v.out.dxf/main.c:56
+#: ../vector/v.net.alloc/main.c:62 ../vector/v.surf.idw/main.c:87
+#: ../vector/v.transform/main.c:69 ../vector/v.net.allpairs/main.c:61
+#: ../vector/v.lrs/v.lrs.segment/main.c:71
+#: ../vector/v.lrs/v.lrs.where/main.c:57
+#: ../vector/v.lrs/v.lrs.create/main.c:121
+#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.clean/main.c:51
+#: ../vector/v.clean/test/topocheck.c:42 ../vector/v.db.select/main.c:53
+#: ../vector/v.net.spanningtree/main.c:46 ../vector/v.split/main.c:54
+#: ../vector/v.lidar.growing/main.c:75 ../vector/v.mkgrid/main.c:70
+#: ../vector/v.neighbors/main.c:50 ../vector/v.lidar.correction/main.c:68
+#: ../vector/v.label/main.c:59 ../vector/v.qcount/main.c:60
+#: ../vector/v.rectify/main.c:70 ../vector/v.extrude/main.c:67
+#: ../vector/v.sample/main.c:75 ../vector/v.univar/main.c:92
+#: ../vector/v.what.rast3/main.c:64 ../vector/v.in.ogr/main.c:133
+#: ../vector/v.in.dxf/main.c:64 ../vector/v.net.timetable/main.c:260
+#: ../vector/v.to.db/main.c:36 ../vector/v.kernel/main.c:109
+#: ../vector/v.build.polylines/main.c:111 ../vector/v.to.points/main.c:53
+#: ../vector/v.to.rast3/main.c:48 ../vector/v.out.postgis/main.c:44
+#: ../vector/v.in.ascii/main.c:68 ../vector/v.timestamp/main.c:35
+#: ../vector/v.net.flow/main.c:58 ../visualization/ximgview/main.c:293
+#: ../locale/scriptstrings/v.build.all_to_translate.c:2
+#: ../locale/scriptstrings/v.report_to_translate.c:2
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
+#: ../locale/scriptstrings/v.db.update_to_translate.c:2
+#: ../locale/scriptstrings/v.unpack_to_translate.c:2
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:3
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:4
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.krige_to_translate.c:2
+#: ../locale/scriptstrings/v.db.join_to_translate.c:2
+#: ../locale/scriptstrings/v.pack_to_translate.c:2
+#: ../doc/vector/v.example/main.c:50 ../raster/r.random/main.c:53
+#: ../raster/r.contour/main.c:90 ../display/d.vect/main.c:72
+#: ../display/d.extract/main.c:50
+msgid "vector"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:54 ../misc/m.nviz.script/main.c:72
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:4
+#: ../raster3d/r3.timestamp/main.c:43 ../raster3d/r3.info/main.c:75
+#: ../raster3d/r3.out.bin/main.c:205 ../raster3d/r3.gwflow/main.c:159
+#: ../raster3d/r3.to.rast/main.c:206 ../raster3d/r3.stats/main.c:48
+#: ../raster3d/r3.cross.rast/main.c:228 ../raster3d/r3.in.v5d/main.c:178
+#: ../raster3d/r3.in.ascii/main.c:313 ../raster3d/r3.null/main.c:186
+#: ../raster3d/r3.support/main.c:49 ../raster3d/r3.out.ascii/main.c:302
+#: ../raster3d/r3.in.bin/main.c:252 ../raster3d/r3.out.v5d/main.c:284
+#: ../raster3d/r3.mask/main.c:133 ../raster3d/r3.out.vtk/main.c:376
+#: ../raster3d/r3.neighbors/main.c:208 ../raster3d/r3.out.netcdf/main.c:586
+#: ../raster3d/r3.retile/main.c:96 ../raster3d/r3.mkdspf/main.c:79
+#: ../raster/r.colors.out/raster3d_main.c:46
+#: ../raster/r.to.rast3elev/main.c:363 ../raster/r.colors/edit_colors.c:59
+#: ../raster/r.univar/r3.univar_main.c:98
+msgid "raster3d"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:55
+msgid "Creates a 3D rendering of GIS data."
+msgstr ""
+#: ../misc/m.nviz.image/main.c:56
+msgid ""
+"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
+"data) in 3D."
+msgstr ""
+#: ../misc/m.nviz.image/main.c:82
+msgid "Unable to render data"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:141
+#, c-format
+msgid "Vertical exaggeration not given, using calculated value %.0f"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:153
+#, c-format
+msgid "Viewpoint height not given, using calculated value %.0f"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:239
+msgid "Unsupported output format"
+msgstr ""
+#: ../misc/m.nviz.image/main.c:241 ../imagery/i.cluster/main.c:337
+#, c-format
+msgid "File <%s> created."
+msgstr ""
+#: ../misc/m.nviz.image/cplane.c:40
+#, c-format
+msgid "Cutting plane number <%d> not found"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:51
+msgid "Use draw mode for all loaded surfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:133
+#: ../misc/m.nviz.image/args.c:143 ../misc/m.nviz.image/args.c:150
+#: ../misc/m.nviz.image/args.c:156 ../misc/m.nviz.image/args.c:164
+#: ../misc/m.nviz.image/args.c:173 ../misc/m.nviz.image/args.c:183
+#: ../misc/m.nviz.image/args.c:191 ../misc/m.nviz.image/args.c:201
+#: ../misc/m.nviz.image/args.c:209 ../misc/m.nviz.image/args.c:219
+msgid "Surfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:70 ../vector/v.label.sa/main.c:124
+#: ../vector/v.lrs/v.lrs.label/main.c:218 ../vector/v.label/main.c:187
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+#: ../general/g.pnmcomp/main.c:325 ../display/d.mon/main.c:90
+#: ../display/d.erase/main.c:37 ../display/d.histogram/main.c:108
+#: ../display/d.path/main.c:115
+msgid "Background color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:92
+msgid "Name for output image file (without extension)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:93 ../misc/m.nviz.image/args.c:107
+#: ../misc/m.nviz.image/args.c:117
+msgid "Image"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:105
+#: ../locale/scriptstrings/d.out.file_to_translate.c:5
+msgid "Graphics file format"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:115
+msgid "Size (width, height) of output image"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:132
+msgid "Name of raster map(s) for elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:142
+msgid "Constant elevation value(s) to use instead of a raster DEM"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:149
+msgid "Name of raster map(s) for color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:155
+msgid "Color value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:163
+msgid "Name of raster map(s) for mask"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:172
+msgid "Name of raster map(s) for transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:182
+msgid "Transparency value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:190
+msgid "Name of raster map(s) for shininess"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:200
+msgid "Shininess value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:208
+msgid "Name of raster map(s) for emission"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:218
+msgid "Emission value(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:230
+msgid "Draw mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:233 ../misc/m.nviz.image/args.c:244
+#: ../misc/m.nviz.image/args.c:255 ../misc/m.nviz.image/args.c:267
+#: ../misc/m.nviz.image/args.c:279 ../misc/m.nviz.image/args.c:288
+#: ../misc/m.nviz.image/args.c:298 ../misc/m.nviz.image/args.c:608
+#: ../misc/m.nviz.image/args.c:620 ../display/d.grid/main.c:121
+#: ../display/d.grid/main.c:127 ../display/d.grid/main.c:132
+#: ../display/d.grid/main.c:137 ../display/d.grid/main.c:142
+msgid "Draw"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:242
+msgid "Fine resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:253
+msgid "Coarse resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:264
+msgid "Draw style"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:276
+msgid "Shading"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:285
+msgid "Wire color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:297
+msgid "Surface position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:309
+msgid "Name of line vector overlay map(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:310 ../misc/m.nviz.image/args.c:318
+#: ../misc/m.nviz.image/args.c:330 ../misc/m.nviz.image/args.c:339
+#: ../misc/m.nviz.image/args.c:348 ../misc/m.nviz.image/args.c:355
+#: ../misc/m.nviz.image/args.c:369 ../misc/m.nviz.image/args.c:379
+#: ../misc/m.nviz.image/args.c:391
+msgid "Vector lines"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:317 ../misc/m.nviz.image/args.c:410
+msgid "Layer number or name for thematic mapping"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:329
+msgid "Vector line width"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:337 ../misc/m.nviz.image/args.c:449
+msgid "Name of width definition column"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:345
+msgid "Vector line color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:353 ../misc/m.nviz.image/args.c:465
+msgid "Name of color definition column"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:364
+msgid "Vector line display mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:366
+msgid "surface;drape on raster surface;flat;draw at constant elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:378
+msgid "Vector line height"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:390
+msgid "Vector lines position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:402
+msgid "Name of point vector overlay map(s)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:403 ../misc/m.nviz.image/args.c:411
+#: ../misc/m.nviz.image/args.c:423 ../misc/m.nviz.image/args.c:432
+#: ../misc/m.nviz.image/args.c:442 ../misc/m.nviz.image/args.c:451
+#: ../misc/m.nviz.image/args.c:460 ../misc/m.nviz.image/args.c:467
+#: ../misc/m.nviz.image/args.c:480 ../misc/m.nviz.image/args.c:488
+#: ../misc/m.nviz.image/args.c:503 ../misc/m.nviz.image/args.c:513
+msgid "Vector points"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:422
+msgid "Icon size (map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:430
+msgid "Name of size definition column"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:441
+msgid "Icon width"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:457
+msgid "Icon color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:476
+msgid "Icon marker"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:486
+msgid "Name of marker definition column"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:497
+msgid "3D vector point display mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:499
+msgid "surface;drape on raster surface;3D;place at 3D point's z-elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:512
+msgid "Vector points position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:529
+msgid "Viewpoint position (x,y model coordinates)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:530 ../misc/m.nviz.image/args.c:542
+#: ../misc/m.nviz.image/args.c:552 ../misc/m.nviz.image/args.c:564
+#: ../misc/m.nviz.image/args.c:586
+msgid "Viewpoint"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:541
+msgid "Viewpoint height (in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:551
+msgid "Viewpoint field of view (in degrees)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:563
+msgid "Viewpoint twist angle (in degrees)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:575 ../raster/r.out.vrml/main.c:65
+msgid "Vertical exaggeration"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:585
+msgid "Focus to point on surface (from SW corner in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:595 ../misc/m.nviz.image/args.c:630
+#: ../misc/m.nviz.image/args.c:642 ../misc/m.nviz.image/args.c:652
+#: ../misc/m.nviz.image/args.c:661 ../misc/m.nviz.image/args.c:669
+#: ../misc/m.nviz.image/args.c:678 ../misc/m.nviz.image/args.c:689
+#: ../misc/m.nviz.image/args.c:698 ../misc/m.nviz.image/args.c:709
+#: ../misc/m.nviz.image/args.c:716 ../misc/m.nviz.image/args.c:722
+#: ../misc/m.nviz.image/args.c:734 ../misc/m.nviz.image/args.c:744
+#: ../misc/m.nviz.image/args.c:755
+msgid "Volumes"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:605
+msgid "Volume draw mode"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:617
+msgid "Volume shading"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:629
+msgid "Volume position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:640
+msgid "Volume resolution"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:651
+msgid "Isosurface level"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:660
+msgid "Name of volume for isosurface color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:668
+msgid "Isosurface color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:677
+msgid "Name of 3D raster map(s) for isosurface transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:688
+msgid "Transparency value(s)for isosurfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:697
+msgid "Name of 3D raster map(s) for shininess"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:708
+msgid "Shininess value(s) for isosurfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:715
+msgid "Toggles normal direction of all isosurfaces (changes light effect)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:721
+msgid "Draw volume box"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:733
+msgid "Volume slice parallel to given axis (x, y, z)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:743
+msgid "Volume slice position"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:754
+msgid "Volume slice transparency"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:771
+msgid "Light position (x,y,z model coordinates)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:772 ../misc/m.nviz.image/args.c:778
+#: ../misc/m.nviz.image/args.c:787 ../misc/m.nviz.image/args.c:797
+msgid "Lighting"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:777
+msgid "Light color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:786
+msgid "Light brightness"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:796
+msgid "Light ambient"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:810
+msgid "Cutting plane index (0-5)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:811 ../misc/m.nviz.image/args.c:820
+#: ../misc/m.nviz.image/args.c:829 ../misc/m.nviz.image/args.c:841
+#: ../misc/m.nviz.image/args.c:852
+msgid "Cutting planes"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:819
+msgid "Cutting plane x,y,z coordinates"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:831
+msgid "Cutting plane rotation along the vertical axis"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:842
+msgid "Cutting plane tilt"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:854
+msgid "Cutting plane color (between two surfaces)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:870
+msgid "North-West edge"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:871
+msgid "North-East edge"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:872
+msgid "South-West edge"
+msgstr ""
+msgid "South-East edge"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:874
+msgid "Fringe edges"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:875 ../misc/m.nviz.image/args.c:881
+#: ../misc/m.nviz.image/args.c:890
+msgid "Fringe"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:880
+msgid "Fringe color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:889
+msgid "Fringe elevation"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:903
+msgid ""
+"Place north arrow at given position \t(in screen coordinates from bottom "
+"left corner)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
+#: ../misc/m.nviz.image/args.c:922
+msgid "Decoration"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:914
+msgid "North arrow size (in map units)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:921
+msgid "North arrow color"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:973
+#, c-format
+msgid "At least one <%s> or <%s> required"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:987 ../misc/m.nviz.image/args.c:1017
+#: ../misc/m.nviz.image/args.c:1023 ../misc/m.nviz.image/args.c:1029
+#: ../misc/m.nviz.image/args.c:1035 ../misc/m.nviz.image/args.c:1041
+#: ../misc/m.nviz.image/args.c:1047
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1058
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1064 ../misc/m.nviz.image/args.c:1070
+#: ../misc/m.nviz.image/args.c:1082 ../misc/m.nviz.image/args.c:1089
+#: ../misc/m.nviz.image/args.c:1096 ../misc/m.nviz.image/args.c:1103
+#: ../misc/m.nviz.image/args.c:1110 ../misc/m.nviz.image/args.c:1122
+#: ../misc/m.nviz.image/args.c:1127 ../misc/m.nviz.image/args.c:1164
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1146 ../misc/m.nviz.image/args.c:1156
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1171
+#, c-format
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:1183
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:133
+#, c-format
+msgid "3d raster map <%s> not found"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:96 ../misc/m.nviz.image/volume.c:256
+#, c-format
+msgid "Error tokenize '%s'"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:103 ../misc/m.nviz.image/volume.c:271
+#, c-format
+msgid "Volume set number %d is not available"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:108
+#, c-format
+msgid "Unable to add isosurface (volume set %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:119 ../misc/m.nviz.image/volume.c:140
+#: ../misc/m.nviz.image/volume.c:153 ../misc/m.nviz.image/volume.c:172
+#: ../misc/m.nviz.image/volume.c:182 ../misc/m.nviz.image/volume.c:195
+#: ../misc/m.nviz.image/volume.c:205
+#, c-format
+msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:267
+#, c-format
+msgid "Wrong name for axis: %s"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:276
+#, c-format
+msgid "Unable to add slice (volume set %d)"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:288
+#, c-format
+msgid "Unable to set slice (%d) position of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/volume.c:294
+#, c-format
+msgid "Unable to set slice (%d) transparency of volume %d"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:84 ../vector/v.edit/main.c:153
+#: ../vector/v.colors/main.c:239 ../vector/v.vect.stats/main.c:242
+#: ../vector/v.vect.stats/main.c:250 ../vector/v.surf.bspline/main.c:258
+#: ../vector/v.surf.bspline/main.c:326
+#: ../vector/v.lidar.edgedetection/main.c:213 ../vector/v.outlier/main.c:170
+#: ../vector/v.lrs/v.lrs.segment/main.c:140
+#: ../vector/v.lrs/v.lrs.where/main.c:127
+#: ../vector/v.lrs/v.lrs.where/main.c:136
+#: ../vector/v.lrs/v.lrs.create/main.c:251
+#: ../vector/v.lrs/v.lrs.create/main.c:260
+#: ../vector/v.lrs/v.lrs.label/main.c:268
+#: ../vector/v.clean/test/topocheck.c:63 ../vector/v.lidar.growing/main.c:126
+#: ../vector/v.lidar.correction/main.c:182 ../general/g.region/main.c:467
+#: ../doc/vector/v.example/main.c:75 ../raster/r.walk/main.c:410
+#: ../raster/r.carve/main.c:158 ../raster/r.cost/main.c:325
+#: ../display/d.extract/main.c:98
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:280 ../vector/v.extract/main.c:188
+#: ../vector/v.net.path/main.c:133 ../vector/v.edit/main.c:168
+#: ../vector/v.edit/main.c:240 ../vector/v.colors/main.c:263
+#: ../vector/v.vol.rst/main.c:560 ../vector/v.net.steiner/main.c:431
+#: ../vector/v.net.visibility/main.c:73 ../vector/v.net.visibility/main.c:82
+#: ../vector/v.info/main.c:60 ../vector/v.to.3d/main.c:72
+#: ../vector/v.overlay/main.c:181 ../vector/v.build/main.c:118
+#: ../vector/v.build/main.c:128 ../vector/v.random/main.c:197
+#: ../vector/v.what.rast/main.c:130 ../vector/v.vect.stats/main.c:246
+#: ../vector/v.vect.stats/main.c:257 ../vector/v.to.rast/support.c:123
+#: ../vector/v.to.rast/support.c:282 ../vector/v.to.rast/support.c:434
+#: ../vector/v.to.rast/vect2rast.c:39 ../vector/v.net.centrality/main.c:209
+#: ../vector/v.segment/main.c:108 ../vector/v.type/main.c:131
+#: ../vector/v.net.salesman/main.c:224 ../vector/v.net.iso/main.c:187
+#: ../vector/v.out.svg/main.c:139 ../vector/v.net.connectivity/main.c:130
+#: ../vector/v.out.ascii/main.c:87 ../vector/v.out.ascii/main.c:94
+#: ../vector/v.colors.out/scan_cats.c:20
+#: ../vector/v.colors.out/make_colors.c:23
+#: ../vector/v.net.components/main.c:147 ../vector/v.select/main.c:107
+#: ../vector/v.distance/main.c:310 ../vector/v.distance/main.c:329
+#: ../vector/v.parallel/main.c:148 ../vector/v.class/main.c:102
+#: ../vector/v.generalize/main.c:323 ../vector/v.label.sa/labels.c:58
+#: ../vector/v.voronoi/main.c:196 ../vector/v.hull/main.c:87
+#: ../vector/v.net.bridge/main.c:118 ../vector/v.drape/main.c:142
+#: ../vector/v.lidar.edgedetection/main.c:219 ../vector/v.net/main.c:66
+#: ../vector/v.net/main.c:90 ../vector/v.reclass/main.c:113
+#: ../vector/v.surf.rst/main.c:528 ../vector/v.surf.rst/main.c:632
+#: ../vector/v.perturb/main.c:147 ../vector/v.perturb/main.c:172
+#: ../vector/v.out.ogr/main.c:129 ../vector/v.out.pov/main.c:97
+#: ../vector/v.net.distance/main.c:177 ../vector/v.proj/main.c:231
+#: ../vector/v.support/main.c:130 ../vector/v.patch/main.c:114
+#: ../vector/v.patch/main.c:130 ../vector/v.patch/main.c:160
+#: ../vector/v.patch/main.c:257 ../vector/v.patch/main.c:338
+#: ../vector/v.external/main.c:191 ../vector/v.delaunay/main.c:120
+#: ../vector/v.buffer/main.c:338 ../vector/v.normal/main.c:110
+#: ../vector/v.db.connect/main.c:154 ../vector/v.out.dxf/main.c:80
+#: ../vector/v.net.alloc/main.c:146 ../vector/v.surf.idw/read_sites.c:29
+#: ../vector/v.transform/main.c:178 ../vector/v.net.allpairs/main.c:130
+#: ../vector/v.lrs/v.lrs.segment/main.c:144
+#: ../vector/v.lrs/v.lrs.where/main.c:131
+#: ../vector/v.lrs/v.lrs.where/main.c:140
+#: ../vector/v.lrs/v.lrs.create/main.c:254
+#: ../vector/v.lrs/v.lrs.create/main.c:263
+#: ../vector/v.lrs/v.lrs.label/main.c:272 ../vector/v.clean/main.c:283
+#: ../vector/v.clean/test/topocheck.c:67 ../vector/v.clean/test/topocheck.c:87
+#: ../vector/v.db.select/main.c:155 ../vector/v.net.spanningtree/main.c:101
+#: ../vector/v.split/main.c:164 ../vector/v.lidar.growing/main.c:138
+#: ../vector/v.lidar.growing/main.c:142 ../vector/v.neighbors/main.c:88
+#: ../vector/v.lidar.correction/main.c:186 ../vector/v.label/main.c:268
+#: ../vector/v.qcount/main.c:101 ../vector/v.rectify/main.c:148
+#: ../vector/v.extrude/main.c:190 ../vector/v.sample/main.c:124
+#: ../vector/v.univar/main.c:158 ../vector/v.what.rast3/main.c:113
+#: ../vector/v.net.timetable/main.c:353 ../vector/v.to.db/main.c:59
+#: ../vector/v.kernel/main.c:310 ../vector/v.kernel/main.c:323
+#: ../vector/v.build.polylines/main.c:151 ../vector/v.to.points/main.c:121
+#: ../vector/v.to.rast3/main.c:73 ../vector/v.out.postgis/main.c:100
+#: ../vector/v.net.flow/main.c:143 ../general/manage/lister/vector.c:32
+#: ../doc/vector/v.example/main.c:87 ../raster/r.walk/main.c:673
+#: ../raster/r.walk/main.c:742 ../raster/r.random/support.c:63
+#: ../raster/r.drain/main.c:268 ../raster/r.carve/main.c:162
+#: ../raster/r.region/main.c:170
+#: ../raster/r.sim/simlib/observation_points.c:39 ../raster/r.what/main.c:236
+#: ../raster/r.cost/main.c:533 ../raster/r.cost/main.c:606
+#: ../display/d.extract/main.c:103 ../display/d.vect.chart/main.c:240
+#: ../display/d.path/main.c:185
+#, c-format
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:300 ../misc/m.nviz.image/vector.c:309
+#: ../misc/m.nviz.image/vector.c:319 ../misc/m.nviz.image/vector.c:329
+#, c-format
+msgid "Column <%s> in table <%s> not found"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:304
+msgid "Data type of color column must be character"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:314
+msgid "Data type of size column must be numeric"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:324
+msgid "Data type of width column must be numeric"
+msgstr ""
+#: ../misc/m.nviz.image/vector.c:335
+msgid "Data type of marker column must be character"
+msgstr ""
+#: ../misc/m.transform/main.c:92
+#, c-format
+msgid "Not enough points, %d are required"
+msgstr ""
+#: ../misc/m.transform/main.c:96
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
+#, c-format
+msgid "Error conducting transform (%d)"
+msgstr ""
+#: ../misc/m.transform/main.c:194
+msgid "Poorly placed control points"
+msgstr ""
+#: ../misc/m.transform/main.c:196
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
+msgid "Insufficient memory"
+msgstr ""
+#: ../misc/m.transform/main.c:198
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
+msgid "Parameter error"
+msgstr ""
+#: ../misc/m.transform/main.c:200
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
+msgid "No active control points"
+msgstr ""
+#: ../misc/m.transform/main.c:276 ../misc/m.nviz.script/main.c:202
+#: ../vector/v.edit/main.c:79 ../vector/v.out.ascii/main.c:125
+#: ../vector/v.out.vtk/main.c:173 ../vector/v.net/main.c:98
+#: ../general/g.pnmcomp/main.c:242 ../general/g.pnmcomp/main.c:259
+#: ../raster/r.category/main.c:173 ../raster/r.in.lidar/main.c:315
+#: ../raster/r.profile/main.c:175 ../raster/r.recode/main.c:89
+#: ../raster/r.out.ascii/main.c:157 ../raster/r.out.ppm3/main.c:133
+#: ../raster/r.horizon/main.c:385
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
+#, c-format
+msgid "Unable to open file <%s>"
+msgstr ""
+#: ../misc/m.transform/main.c:295
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
+#, c-format
+msgid "Invalid coordinates: [%s]"
+msgstr ""
+#: ../misc/m.transform/main.c:316 ../misc/m.cogo/main.c:225
+#: ../misc/m.nviz.script/main.c:69 ../misc/m.measure/main.c:46
+#: ../locale/scriptstrings/m.proj_to_translate.c:2
+msgid "miscellaneous"
+msgstr ""
+#: ../misc/m.transform/main.c:317 ../vector/v.proj/main.c:69
+#: ../vector/v.transform/main.c:70
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
+#: ../raster/r.proj/main.c:146 ../imagery/i.pca/main.c:73
+#: ../imagery/i.fft/main.c:79 ../imagery/i.ifft/main.c:78
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
+msgid "transformation"
+msgstr ""
+#: ../misc/m.transform/main.c:320
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
+msgid "Computes a coordinate transformation based on the control points."
+msgstr ""
+#: ../misc/m.transform/main.c:329
+msgid "Rectification polynomial order"
+msgstr ""
+#: ../misc/m.transform/main.c:340
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
+msgid "point index"
+msgstr ""
+#: ../misc/m.transform/main.c:341
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
+msgid "source coordinates"
+msgstr ""
+#: ../misc/m.transform/main.c:342
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
+msgid "destination coordinates"
+msgstr ""
+#: ../misc/m.transform/main.c:343
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
+msgid "forward coordinates (destination)"
+msgstr ""
+#: ../misc/m.transform/main.c:344
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
+msgid "reverse coordinates (source)"
+msgstr ""
+#: ../misc/m.transform/main.c:345
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
+msgid "forward coordinates difference (destination)"
+msgstr ""
+#: ../misc/m.transform/main.c:346
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
+msgid "reverse coordinates difference (source)"
+msgstr ""
+#: ../misc/m.transform/main.c:347
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
+msgid "forward error (destination)"
+msgstr ""
+#: ../misc/m.transform/main.c:348
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
+msgid "reverse error (source)"
+msgstr ""
+#: ../misc/m.transform/main.c:351 ../vector/v.out.ascii/args.c:55
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
+msgid "Output format"
+msgstr ""
+#: ../misc/m.transform/main.c:355
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
+msgid "Display summary information"
+msgstr ""
+#: ../misc/m.transform/main.c:360
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
+msgid "File containing coordinates to transform (\"-\" to read from stdin)"
+msgstr ""
+#: ../misc/m.transform/main.c:361
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
+msgid "Local x,y coordinates to target east,north"
+msgstr ""
+#: ../misc/m.transform/main.c:365
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
+msgid "Reverse transform of coords file or coeff. dump"
+msgstr ""
+#: ../misc/m.transform/main.c:366
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
+msgid "Target east,north coordinates to local x,y"
+msgstr ""
+#: ../misc/m.transform/main.c:370
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
+msgid "Display transform matrix coefficients"
+msgstr ""
+#: ../misc/m.cogo/main.c:226 ../vector/v.distance/main.c:91
+#: ../raster/r.grow.distance/main.c:152 ../raster/r.distance/main.c:40
+#: ../display/d.rhumbline/main.c:45 ../display/d.geodesic/main.c:47
+msgid "distance"
+msgstr ""
+#: ../misc/m.cogo/main.c:227
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa."
+msgstr ""
+#: ../misc/m.cogo/main.c:229
+msgid "It assumes a cartesian coordinate system"
+msgstr ""
+#: ../misc/m.cogo/main.c:233
+msgid "Lines are labelled"
+msgstr ""
+#: ../misc/m.cogo/main.c:238
+msgid "Convert from coordinates to bearing and distance"
+msgstr ""
+#: ../misc/m.cogo/main.c:243
+msgid "Repeat the starting coordinate at the end to close a loop"
+msgstr ""
+#: ../misc/m.cogo/main.c:254
+msgid "Starting coordinate pair"
+msgstr ""
+#: ../misc/m.cogo/main.c:264
+#, c-format
+msgid "Couldn't open COGO file <%s>"
+msgstr ""
+#: ../misc/m.cogo/main.c:273
+#, c-format
+msgid "Couldn't open output file <%s>"
+msgstr ""
+#: ../misc/m.cogo/main.c:300 ../misc/m.cogo/main.c:303
+msgid "Converting starting coordinate pair"
+msgstr ""
+#: ../misc/m.cogo/main.c:318
+#, c-format
+msgid "Input parse error on line %lu"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:75
+msgid "Creates fly-through script to run in NVIZ."
+msgstr ""
+#: ../misc/m.nviz.script/main.c:80
+msgid "Name of output script"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:86
+msgid "Prefix of output images (default = NVIZ)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:94
+msgid "Route coordinates (east,north)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:100
+msgid "Camera layback distance (in map units)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:106
+msgid "Camera height above terrain"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:112
+msgid "Number of frames"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:118
+msgid "Start frame number (default=0)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:123
+msgid "Full render -- Save images"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:127
+msgid "Fly at constant elevation (ht)"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:132
+msgid "Include command in the script to output a KeyFrame file"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:136
+msgid "Render images off-screen"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:140
+msgid "Enable vector and sites drawing"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:148
+msgid "Either -i flag and/or route parameter must be used"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:172
+msgid "Off-screen only available with full render mode"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:250
+#, c-format
+msgid "You must provide at least four points %d"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:324
+#, c-format
+msgid "Created NVIZ script <%s>."
+msgstr ""
+#: ../misc/m.nviz.script/main.c:439
+msgid ""
+"Skipping this point, selected point is outside region. Perhaps the camera "
+"setback distance puts it beyond the edge?"
+msgstr ""
+#: ../misc/m.measure/main.c:45
+msgid "Measures the lengths and areas of features."
+msgstr ""
+#: ../misc/m.measure/main.c:47
+msgid "measurement"
+msgstr ""
+#: ../misc/m.measure/main.c:54
+msgid "Units"
+msgstr "Yksiköt"
+#: ../misc/m.measure/main.c:55
+msgid "Default: location map units"
+msgstr "Oletus: paikan karttayksiköt"
+#: ../misc/m.measure/main.c:59
+msgid "Shell script style"
+msgstr ""
+#: ../misc/m.measure/main.c:102
+msgid "Length:"
+msgstr "Pituus:"
+#: ../misc/m.measure/main.c:113
+msgid "Area:"
+msgstr "Ala:"
+#: ../vector/v.extract/copy_tab.c:57 ../vector/v.select/copy_tabs.c:17
+#: ../vector/v.generalize/misc.c:124 ../vector/v.voronoi/main.c:384
+#: ../raster/r.contour/main.c:203
+msgid "Writing attributes..."
+msgstr ""
+#: ../vector/v.extract/copy_tab.c:90
+#, c-format
+msgid "Writing attributes for layer %d"
+msgstr ""
+#: ../vector/v.extract/copy_tab.c:95
+#, c-format
+msgid "No attribute table for layer %d"
+msgstr ""
+#: ../vector/v.extract/copy_tab.c:108 ../vector/v.generalize/misc.c:174
+#: ../vector/v.to.points/main.c:155
+#, c-format
+msgid "Unable to copy table <%s>"
+msgstr ""
+#: ../vector/v.extract/copy_tab.c:117 ../vector/v.vect.stats/main.c:300
+#: ../vector/v.vect.stats/main.c:384
+#, c-format
+msgid "Unable to open database <%s> with driver <%s>"
+msgstr ""
+#: ../vector/v.extract/copy_tab.c:129 ../vector/v.overlay/main.c:590
+#: ../vector/v.random/main.c:262 ../vector/v.in.dwg/main.c:249
+#: ../vector/v.select/copy_tabs.c:85 ../vector/v.distance/main.c:1355
+#: ../vector/v.reclass/main.c:327 ../vector/v.patch/main.c:316
+#: ../vector/v.in.lidar/main.c:623 ../vector/v.mkgrid/main.c:349
+#: ../vector/v.mkgrid/main.c:407 ../vector/v.sample/main.c:197
+#: ../vector/v.in.ogr/main.c:1125 ../vector/v.in.dxf/write_vect.c:238
+#: ../vector/v.to.points/main.c:192 ../vector/v.in.ascii/main.c:417
+#: ../raster/r.random/random.c:257 ../raster/r.contour/main.c:193
+#: ../raster/r.stream.extract/close.c:196 ../raster/r.to.vect/main.c:231
+#, c-format
+msgid "Unable to grant privileges on table <%s>"
+msgstr ""
+#: ../vector/v.extract/extract.c:171
+#, c-format
+msgid "No category found for area %d. Skipping."
+msgstr ""
+#: ../vector/v.extract/extract.c:175
+#, c-format
+msgid "More categories (%d) found for area %d. Using first found category %d"
+msgstr ""
+#: ../vector/v.extract/extract.c:228
+msgid ""
+"Topology level required for extracting areas for OGR layers. Areas will be "
+"not processed."
+msgstr ""
+#: ../vector/v.extract/main.c:78
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
+msgid "extract"
+msgstr ""
+#: ../vector/v.extract/main.c:80
+msgid ""
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
+msgstr ""
+#: ../vector/v.extract/main.c:85
+msgid "Dissolve common boundaries (default is no)"
+msgstr ""
+#: ../vector/v.extract/main.c:89
+msgid "Do not copy attributes (see also 'new' parameter)"
+msgstr ""
+#: ../vector/v.extract/main.c:90 ../vector/v.extract/main.c:142
+#: ../vector/v.overlay/main.c:132 ../vector/v.overlay/main.c:142
+#: ../vector/v.to.rast/main.c:88 ../vector/v.to.rast/main.c:94
+#: ../vector/v.to.rast/main.c:100 ../vector/v.generalize/main.c:241
+#: ../vector/v.in.lidar/main.c:209 ../vector/v.buffer/main.c:307
+#: ../vector/v.in.ogr/main.c:221 ../vector/v.in.ogr/main.c:231
+#: ../vector/v.in.ogr/main.c:241 ../vector/v.in.ogr/main.c:274
+#: ../vector/v.in.ogr/main.c:297 ../raster/r.to.vect/main.c:100
+#: ../raster/r.to.vect/main.c:107
+msgid "Attributes"
+msgstr ""
+#: ../vector/v.extract/main.c:94 ../vector/v.edit/args.c:198
+#: ../vector/v.select/args.c:105
+msgid "Reverse selection"
+msgstr ""
+#: ../vector/v.extract/main.c:95 ../vector/v.extract/main.c:100
+#: ../vector/v.extract/main.c:106 ../vector/v.extract/main.c:109
+#: ../vector/v.extract/main.c:112 ../vector/v.extract/main.c:122
+#: ../vector/v.extract/main.c:132 ../vector/v.edit/args.c:24
+#: ../vector/v.edit/args.c:29 ../vector/v.edit/args.c:112
+#: ../vector/v.edit/args.c:116 ../vector/v.edit/args.c:125
+#: ../vector/v.edit/args.c:134 ../vector/v.edit/args.c:143
+#: ../vector/v.edit/args.c:146 ../vector/v.edit/args.c:164
+#: ../vector/v.edit/args.c:199 ../vector/v.in.db/main.c:94
+#: ../vector/v.to.3d/args.c:19 ../vector/v.to.3d/args.c:25
+#: ../vector/v.random/main.c:115 ../vector/v.random/main.c:118
+#: ../vector/v.random/main.c:121 ../vector/v.random/main.c:124
+#: ../vector/v.to.rast/main.c:57 ../vector/v.to.rast/main.c:60
+#: ../vector/v.to.rast/main.c:63 ../vector/v.net.centrality/main.c:121
+#: ../vector/v.net.centrality/main.c:123 ../vector/v.out.ascii/args.c:24
+#: ../vector/v.out.ascii/args.c:28 ../vector/v.out.ascii/args.c:43
+#: ../vector/v.out.ascii/args.c:46 ../vector/v.select/args.c:18
+#: ../vector/v.select/args.c:24 ../vector/v.select/args.c:33
+#: ../vector/v.select/args.c:39 ../vector/v.select/args.c:106
+#: ../vector/v.generalize/main.c:92 ../vector/v.generalize/main.c:229
+#: ../vector/v.generalize/main.c:232 ../vector/v.drape/main.c:66
+#: ../vector/v.drape/main.c:69 ../vector/v.drape/main.c:72
+#: ../vector/v.drape/main.c:77 ../vector/v.category/main.c:85
+#: ../vector/v.category/main.c:89 ../vector/v.category/main.c:93
+#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
+#: ../vector/v.surf.rst/main.c:172 ../vector/v.surf.rst/main.c:184
+#: ../vector/v.out.ogr/args.c:12 ../vector/v.out.ogr/args.c:22
+#: ../vector/v.out.ogr/args.c:104 ../vector/v.buffer/main.c:234
+#: ../vector/v.buffer/main.c:237 ../vector/v.buffer/main.c:240
+#: ../vector/v.buffer/main.c:245 ../vector/v.net.allpairs/main.c:75
+#: ../vector/v.net.allpairs/main.c:81 ../vector/v.net.allpairs/main.c:84
+#: ../vector/v.net.allpairs/main.c:87 ../vector/v.clean/main.c:61
+#: ../vector/v.clean/main.c:64 ../vector/v.db.select/main.c:62
+#: ../vector/v.db.select/main.c:65 ../vector/v.db.select/main.c:68
+#: ../vector/v.db.select/main.c:107 ../vector/v.extrude/main.c:84
+#: ../vector/v.extrude/main.c:87 ../vector/v.extrude/main.c:90
+#: ../vector/v.extrude/main.c:95 ../vector/v.in.ogr/main.c:157
+#: ../vector/v.in.ogr/main.c:170 ../vector/v.in.ogr/main.c:175
+#: ../vector/v.in.ogr/main.c:184 ../vector/v.in.ogr/main.c:200
+#: ../vector/v.in.ogr/main.c:247 ../vector/v.in.ogr/main.c:283
+#: ../vector/v.to.db/parse.c:45 ../vector/v.to.points/main.c:67
+#: ../vector/v.to.points/main.c:71 ../vector/v.out.postgis/args.c:15
+#: ../vector/v.out.postgis/args.c:19
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:10
+#: ../locale/scriptstrings/v.report_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:10
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.list_to_translate.c:6
+#: ../locale/scriptstrings/t.list_to_translate.c:7
+#: ../locale/scriptstrings/t.list_to_translate.c:13
+#: ../locale/scriptstrings/t.list_to_translate.c:14
+#: ../raster/r.category/main.c:62 ../raster/r.category/main.c:71
+#: ../display/d.rast/main.c:70 ../display/d.rast/main.c:87
+#: ../display/d.vect/main.c:80 ../display/d.vect/main.c:105
+#: ../display/d.vect/main.c:108 ../display/d.vect/main.c:111
+#: ../display/d.vect/main.c:287 ../display/d.vect.thematic/main.c:90
+#: ../display/d.vect.thematic/main.c:140 ../display/d.vect.chart/main.c:74
+#: ../display/d.vect.chart/main.c:77
+msgid "Selection"
+msgstr "Valinta"
+#: ../vector/v.extract/main.c:105
+msgid "Types to be extracted"
+msgstr ""
+#: ../vector/v.extract/main.c:120
+msgid "Input text file with category numbers/number ranges to be extracted"
+msgstr ""
+#: ../vector/v.extract/main.c:121
+msgid "If '-' given reads from standard input"
+msgstr ""
+#: ../vector/v.extract/main.c:129
+msgid "Number of random categories matching vector objects to extract"
+msgstr ""
+#: ../vector/v.extract/main.c:131
+msgid "Number must be smaller than unique cat count in layer"
+msgstr ""
+#: ../vector/v.extract/main.c:139
+msgid "Desired new category value (enter -1 to keep original categories)"
+msgstr ""
+#: ../vector/v.extract/main.c:141
+msgid "If new >= 0, attributes is not copied"
+msgstr ""
+#: ../vector/v.extract/main.c:158
+#, c-format
+msgid ""
+"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
+"one of them."
+msgstr ""
+#: ../vector/v.extract/main.c:205
+#, c-format
+msgid "Category value in '%s' not valid"
+msgstr ""
+#: ../vector/v.extract/main.c:221
+#, c-format
+msgid "Process file <%s> for category numbers..."
+msgstr ""
+#: ../vector/v.extract/main.c:226
+#, c-format
+msgid "Unable to open specified file <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:237
+#, c-format
+msgid "Ignored text entry: %s"
+msgstr ""
+#: ../vector/v.extract/main.c:252 ../vector/v.info/print.c:138
+#: ../vector/v.to.3d/trans3.c:51 ../vector/v.to.3d/trans2.c:49
+#: ../vector/v.to.rast/vect2rast.c:55 ../vector/v.colors.out/make_colors.c:31
+#: ../vector/v.distance/main.c:453 ../vector/v.distance/main.c:534
+#: ../vector/v.db.connect/main.c:213 ../vector/v.db.select/main.c:162
+#: ../vector/v.to.rast3/main.c:80
+#, c-format
+msgid "Database connection not defined for layer <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:256
+#, c-format
+msgid "Loading categories from table <%s>..."
+msgstr ""
+#: ../vector/v.extract/main.c:266
+#, c-format
+msgid "Unable select records from table <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:268
+#, c-format
+msgid "%d category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.extract/main.c:283
+msgid ""
+"This map has no categories attached. Use v.category to attach categories to "
+"this vector map."
+msgstr ""
+#: ../vector/v.extract/main.c:290
+msgid "Please specify random number larger than 0"
+msgstr ""
+#: ../vector/v.extract/main.c:294
+#, c-format
+msgid ""
+"Random category count must be smaller than feature count. There are only %d "
+"features of type(s): %s"
+msgstr ""
+#: ../vector/v.extract/main.c:317
+#, c-format
+msgid ""
+"Random category count is larger or equal to uniq <%s> feature category count "
+"%d"
+msgstr ""
+#: ../vector/v.extract/main.c:343 ../vector/v.net.path/main.c:137
+#: ../vector/v.edit/main.c:105 ../vector/v.edit/main.c:120
+#: ../vector/v.vol.rst/main.c:580 ../vector/v.vol.rst/main.c:583
+#: ../vector/v.net.steiner/main.c:602 ../vector/v.in.db/main.c:151
+#: ../vector/v.net.visibility/main.c:77 ../vector/v.to.3d/main.c:87
+#: ../vector/v.overlay/main.c:213 ../vector/v.build/main.c:154
+#: ../vector/v.random/main.c:225 ../vector/v.net.centrality/main.c:215
+#: ../vector/v.segment/main.c:114 ../vector/v.net.salesman/main.c:492
+#: ../vector/v.net.iso/main.c:285 ../vector/v.net.connectivity/main.c:136
+#: ../vector/v.net.components/main.c:153 ../vector/v.in.dwg/main.c:200
+#: ../vector/v.select/main.c:121 ../vector/v.distance/main.c:350
+#: ../vector/v.parallel/main.c:153 ../vector/v.generalize/main.c:334
+#: ../vector/v.in.region/main.c:75 ../vector/v.voronoi/main.c:215
+#: ../vector/v.hull/main.c:121 ../vector/v.surf.bspline/main.c:347
+#: ../vector/v.net.bridge/main.c:124 ../vector/v.drape/main.c:157
+#: ../vector/v.lidar.edgedetection/main.c:241 ../vector/v.reclass/main.c:117
+#: ../vector/v.surf.rst/main.c:567 ../vector/v.surf.rst/main.c:570
+#: ../vector/v.surf.rst/main.c:726 ../vector/v.perturb/main.c:153
+#: ../vector/v.net.distance/main.c:183 ../vector/v.outlier/main.c:221
+#: ../vector/v.outlier/main.c:226 ../vector/v.outlier/main.c:232
+#: ../vector/v.proj/main.c:374 ../vector/v.patch/main.c:266
+#: ../vector/v.patch/main.c:271 ../vector/v.in.lidar/main.c:502
+#: ../vector/v.external/main.c:146 ../vector/v.delaunay/main.c:126
+#: ../vector/v.buffer/main.c:391 ../vector/v.net.alloc/main.c:248
+#: ../vector/v.transform/main.c:246 ../vector/v.net.allpairs/main.c:136
+#: ../vector/v.lrs/v.lrs.segment/main.c:148
+#: ../vector/v.lrs/v.lrs.create/main.c:267
+#: ../vector/v.lrs/v.lrs.create/main.c:273
+#: ../vector/v.lrs/v.lrs.label/main.c:276 ../vector/v.clean/main.c:288
+#: ../vector/v.clean/main.c:295 ../vector/v.net.spanningtree/main.c:107
+#: ../vector/v.split/main.c:169 ../vector/v.mkgrid/main.c:263
+#: ../vector/v.lidar.correction/main.c:209
+#: ../vector/v.lidar.correction/main.c:215 ../vector/v.qcount/main.c:127
+#: ../vector/v.rectify/main.c:214 ../vector/v.extrude/main.c:196
+#: ../vector/v.sample/main.c:162 ../vector/v.in.ogr/main.c:912
+#: ../vector/v.in.dxf/main.c:144 ../vector/v.net.timetable/main.c:359
+#: ../vector/v.kernel/main.c:329 ../vector/v.build.polylines/main.c:156
+#: ../vector/v.to.points/main.c:129 ../vector/v.in.ascii/main.c:247
+#: ../vector/v.net.flow/main.c:149 ../vector/v.net.flow/main.c:155
+#: ../doc/vector/v.example/main.c:98 ../raster/r.volume/main.c:154
+#: ../raster/r.random/random.c:63 ../raster/r.drain/main.c:197
+#: ../raster/r.carve/vect.c:32 ../raster/r.flow/io.c:178
+#: ../raster/r.contour/main.c:156 ../raster/r.stream.extract/close.c:37
+#: ../raster/r.to.vect/main.c:149 ../raster/r.sim/simlib/output.c:38
+#: ../raster/r.sim/simlib/output.c:44 ../raster/r.resamp.bspline/main.c:485
+#: ../display/d.extract/main.c:106
+#, c-format
+msgid "Unable to create vector map <%s>"
+msgstr ""
+#: ../vector/v.extract/main.c:351
+msgid "Extracting features..."
+msgstr ""
+#: ../vector/v.extract/main.c:375
+msgid "Removing duplicate centroids..."
+msgstr ""
+#: ../vector/v.external.out/format.c:21 ../vector/v.external/main.c:72
+msgid ""
+"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
+"OGR support. Using GRASS-PostGIS data driver instead."
+msgstr ""
+#: ../vector/v.external.out/format.c:26 ../vector/v.external/main.c:77
+msgid ""
+"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
+"instead of native GRASS-PostGIS data driver."
+msgstr ""
+#: ../vector/v.external.out/format.c:48 ../raster/r.external.out/main.c:156
+#, c-format
+msgid "Format <%s> not supported"
+msgstr ""
+#: ../vector/v.external.out/format.c:51 ../raster/r.external.out/main.c:166
+#, c-format
+msgid "Format <%s> does not support writing"
+msgstr ""
+#: ../vector/v.external.out/main.c:44 ../vector/v.out.svg/main.c:78
+#: ../vector/v.out.ascii/main.c:48 ../vector/v.colors.out/main.c:51
+#: ../vector/v.out.vtk/main.c:48 ../vector/v.out.ogr/main.c:82
+#: ../vector/v.out.pov/main.c:47 ../vector/v.out.dxf/main.c:57
+#: ../vector/v.out.postgis/main.c:45
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
+#: ../locale/scriptstrings/d.out.file_to_translate.c:3
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
+#: ../locale/scriptstrings/r.pack_to_translate.c:3
+#: ../locale/scriptstrings/v.pack_to_translate.c:3
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
+#: ../raster3d/r3.out.bin/main.c:206 ../raster3d/r3.out.ascii/main.c:303
+#: ../raster3d/r3.out.v5d/main.c:285 ../raster3d/r3.out.vtk/main.c:377
+#: ../raster3d/r3.out.netcdf/main.c:587 ../raster/r.out.gridatb/main.c:68
+#: ../raster/r.out.gdal/main.c:137 ../raster/r.out.ppm/main.c:55
+#: ../raster/r.out.png/main.c:113 ../raster/r.colors.out/raster_main.c:47
+#: ../raster/r.colors.out/raster3d_main.c:48 ../raster/r.out.mpeg/main.c:103
+#: ../raster/r.out.bin/main.c:280 ../raster/r.out.vrml/main.c:48
+#: ../raster/r.out.mat/main.c:63 ../raster/r.out.vtk/main.c:60
+#: ../raster/r.external.out/main.c:236 ../raster/r.out.ascii/main.c:60
+#: ../raster/r.out.ppm3/main.c:58 ../raster/r.out.pov/main.c:122
+msgid "export"
+msgstr ""
+#: ../vector/v.external.out/main.c:45 ../raster/r.external.out/main.c:237
+msgid "output"
+msgstr ""
+#: ../vector/v.external.out/main.c:46 ../vector/v.external/main.c:50
+#: ../raster/r.external.out/main.c:238 ../raster/r.external/main.c:57
+msgid "external"
+msgstr ""
+#: ../vector/v.external.out/main.c:49
+msgid "Defines vector output format."
+msgstr ""
+#: ../vector/v.external.out/main.c:63
+msgid "Switched from OGR to native format"
+msgstr ""
+#: ../vector/v.external.out/main.c:67
+msgid "Switched from PostGIS to native format"
+msgstr ""
+#: ../vector/v.external.out/main.c:69 ../vector/v.external.out/main.c:96
+#, c-format
+msgid "Current output format for vectors: %s"
+msgstr ""
+#: ../vector/v.external.out/status.c:25
+#, c-format
+msgid "format: native\n"
+msgstr ""
+#: ../vector/v.external.out/status.c:80
+msgid "No settings defined"
+msgstr ""
+#: ../vector/v.external.out/status.c:109 ../vector/v.external.out/status.c:149
+msgid "Format not defined"
+msgstr ""
+#: ../vector/v.external.out/status.c:116
+msgid "OGR datasource (dsn) not defined"
+msgstr ""
+#: ../vector/v.external.out/status.c:124
+msgid "PG connection info (conninfo) not defined"
+msgstr ""
+#: ../vector/v.external.out/status.c:158 ../vector/v.external.out/link.c:88
+msgid "Unable to create settings file"
+msgstr ""
+#: ../vector/v.external.out/status.c:160 ../vector/v.external.out/link.c:91
+msgid "Error writing settings file"
+msgstr ""
+#: ../vector/v.external.out/link.c:26 ../vector/v.out.ogr/main.c:96
+#, c-format
+msgid ""
+"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
+"\" given)"
+msgstr ""
+#: ../vector/v.external.out/link.c:96
+#, c-format
+msgid "Switched to OGR format (%s)"
+msgstr ""
+#: ../vector/v.external.out/link.c:99
+msgid "Switched to PostGIS format"
+msgstr ""
+#: ../vector/v.external.out/link.c:110
+#, c-format
+msgid "Unable to parse option '%s'"
+msgstr ""
+#: ../vector/v.external.out/args.c:14
+msgid "Name of output directory or OGR or PostGIS data source"
+msgstr ""
+#: ../vector/v.external.out/args.c:15 ../vector/v.external/args.c:15
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing a shapefile\n"
+"\t\tMapInfo File: directory containing a mapinfo file\n"
+"\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'"
+msgstr ""
+#: ../vector/v.external.out/args.c:24
+msgid "Format for output vector data"
+msgstr ""
+#: ../vector/v.external.out/args.c:39 ../vector/v.out.postgis/args.c:52
+#: ../raster/r.external.out/main.c:264
+msgid "Creation options"
+msgstr ""
+#: ../vector/v.external.out/args.c:40
+msgid ""
+"Examples:\n"
+"\t\t'SHPT=POINTZ': create 3D point Shapefile data\n"
+"\t\t'GEOM_TYPE=geography': use geography PostGIS data\n"
+"\t\t'SCHEMA=grass': create new PostGIS tables in 'grass' schema"
+msgstr ""
+#: ../vector/v.external.out/args.c:52
+msgid "Name of input file to read settings from"
+msgstr ""
+#: ../vector/v.external.out/args.c:58
+msgid "Name for output file where to save current settings"
+msgstr ""
+#: ../vector/v.external.out/args.c:62 ../vector/v.external/args.c:40
+#: ../raster/r.external.out/main.c:271 ../raster/r.external/main.c:93
+#: ../raster/r.in.gdal/main.c:168
+msgid "List supported formats and exit"
+msgstr ""
+#: ../vector/v.external.out/args.c:68
+msgid "Cease using OGR/PostGIS, revert to native output and exit"
+msgstr ""
+#: ../vector/v.external.out/args.c:70
+msgid "Native"
+msgstr ""
+#: ../vector/v.external.out/args.c:74 ../raster/r.external.out/main.c:282
+msgid "Print current status"
+msgstr ""
+#: ../vector/v.external.out/args.c:80
+msgid "Print current status in shell script style"
+msgstr ""
+#: ../vector/v.external.out/args.c:90 ../raster/r.resamp.filter/main.c:432
+#, c-format
+msgid "%s= and %s=/%s= are mutually exclusive"
+msgstr ""
+#: ../vector/v.external.out/args.c:98
+#, c-format
+msgid "%s= or %s= must be specified"
+msgstr ""
+#: ../vector/v.external.out/args.c:101
+#, c-format
+msgid "%s= must be specified"
+msgstr ""
+#: ../vector/v.external.out/list.c:102 ../vector/v.external/list.c:94
+#: ../vector/v.in.ogr/main.c:319 ../raster/r.external/list.c:22
+#: ../raster/r.in.gdal/main.c:246
+msgid "Supported formats:"
+msgstr ""
+#: ../vector/v.net.path/main.c:41 ../vector/v.net.steiner/main.c:346
+#: ../vector/v.net.visibility/main.c:46 ../vector/v.net.centrality/main.c:97
+#: ../vector/v.net.salesman/main.c:127 ../vector/v.net.iso/main.c:72
+#: ../vector/v.net.connectivity/main.c:53 ../vector/v.net.components/main.c:72
+#: ../vector/v.net.bridge/main.c:48 ../vector/v.net/main.c:46
+#: ../vector/v.net.distance/main.c:65 ../vector/v.net.alloc/main.c:63
+#: ../vector/v.net.allpairs/main.c:62 ../vector/v.lrs/v.lrs.segment/main.c:73
+#: ../vector/v.lrs/v.lrs.where/main.c:59
+#: ../vector/v.lrs/v.lrs.create/main.c:123
+#: ../vector/v.lrs/v.lrs.label/main.c:104
+#: ../vector/v.net.spanningtree/main.c:47 ../vector/v.net.timetable/main.c:261
+#: ../vector/v.net.flow/main.c:59 ../display/d.path/main.c:49
+msgid "network"
+msgstr ""
+#: ../vector/v.net.path/main.c:42 ../vector/v.net.visibility/main.c:47
+#: ../vector/v.net.distance/main.c:66 ../vector/v.net.allpairs/main.c:63
+#: ../vector/v.net.timetable/main.c:262 ../display/d.geodesic/main.c:49
+#: ../display/d.path/main.c:50
+msgid "shortest path"
+msgstr ""
+#: ../vector/v.net.path/main.c:43
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../vector/v.net.path/main.c:51 ../vector/v.net.steiner/main.c:362
+#: ../vector/v.net.salesman/main.c:146 ../vector/v.net.iso/main.c:92
+#: ../vector/v.net.distance/main.c:87 ../vector/v.net.alloc/main.c:84
+#: ../display/d.path/main.c:60
+msgid "Arc type"
+msgstr ""
+#: ../vector/v.net.path/main.c:56 ../vector/v.net.steiner/main.c:367
+#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.salesman/main.c:140
+#: ../vector/v.net.iso/main.c:86 ../vector/v.net.connectivity/main.c:64
+#: ../vector/v.net.components/main.c:83 ../vector/v.net.bridge/main.c:60
+#: ../vector/v.net/args.c:55 ../vector/v.net.distance/main.c:80
+#: ../vector/v.net.alloc/main.c:78 ../vector/v.net.allpairs/main.c:74
+#: ../vector/v.net.spanningtree/main.c:59 ../vector/v.net.timetable/main.c:274
+#: ../vector/v.net.flow/main.c:70 ../display/d.path/main.c:70
+msgid "Arc layer"
+msgstr ""
+#: ../vector/v.net.path/main.c:61 ../vector/v.net.centrality/main.c:115
+#: ../vector/v.net.iso/main.c:97 ../vector/v.net.connectivity/main.c:70
+#: ../vector/v.net.components/main.c:89 ../vector/v.net.bridge/main.c:66
+#: ../vector/v.net/args.c:62 ../vector/v.net.distance/main.c:93
+#: ../vector/v.net.alloc/main.c:89 ../vector/v.net.allpairs/main.c:80
+#: ../vector/v.net.spanningtree/main.c:65 ../vector/v.net.timetable/main.c:280
+#: ../vector/v.net.flow/main.c:76 ../display/d.path/main.c:75
+msgid "Node layer"
+msgstr ""
+#: ../vector/v.net.path/main.c:66
+msgid ""
+"Name of file containing start and end points. If not given, read from stdin"
+msgstr ""
+#: ../vector/v.net.path/main.c:73 ../vector/v.net.centrality/main.c:129
+#: ../vector/v.net.salesman/main.c:157 ../vector/v.net.iso/main.c:102
+#: ../vector/v.net.connectivity/main.c:77 ../vector/v.net.components/main.c:96
+#: ../vector/v.net.bridge/main.c:73 ../vector/v.net.distance/main.c:139
+#: ../vector/v.net.alloc/main.c:95 ../vector/v.net.allpairs/main.c:93
+#: ../vector/v.net.spanningtree/main.c:72 ../vector/v.net.timetable/main.c:288
+#: ../vector/v.net.flow/main.c:90 ../display/d.path/main.c:81
+msgid "Arc forward/both direction(s) cost column (number)"
+msgstr ""
+#: ../vector/v.net.path/main.c:74 ../vector/v.net.path/main.c:81
+#: ../vector/v.net.path/main.c:88 ../vector/v.net.centrality/main.c:110
+#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:130
+#: ../vector/v.net.centrality/main.c:136 ../vector/v.net.centrality/main.c:143
+#: ../vector/v.net.iso/main.c:103 ../vector/v.net.iso/main.c:108
+#: ../vector/v.net.iso/main.c:113 ../vector/v.net.connectivity/main.c:65
+#: ../vector/v.net.connectivity/main.c:71
+#: ../vector/v.net.connectivity/main.c:78
+#: ../vector/v.net.connectivity/main.c:84
+#: ../vector/v.net.connectivity/main.c:92 ../vector/v.net.components/main.c:84
+#: ../vector/v.net.components/main.c:90 ../vector/v.net.components/main.c:97
+#: ../vector/v.net.components/main.c:103 ../vector/v.net.components/main.c:110
+#: ../vector/v.net.bridge/main.c:61 ../vector/v.net.bridge/main.c:67
+#: ../vector/v.net.bridge/main.c:74 ../vector/v.net.bridge/main.c:80
+#: ../vector/v.net.bridge/main.c:87 ../vector/v.net.distance/main.c:81
+#: ../vector/v.net.distance/main.c:88 ../vector/v.net.distance/main.c:94
+#: ../vector/v.net.distance/main.c:140 ../vector/v.net.distance/main.c:146
+#: ../vector/v.net.distance/main.c:152 ../vector/v.net.alloc/main.c:96
+#: ../vector/v.net.alloc/main.c:103 ../vector/v.net.alloc/main.c:110
+#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:100
+#: ../vector/v.net.allpairs/main.c:107 ../vector/v.net.spanningtree/main.c:60
+#: ../vector/v.net.spanningtree/main.c:66
+#: ../vector/v.net.spanningtree/main.c:73
+#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.timetable/main.c:275
+#: ../vector/v.net.timetable/main.c:281 ../vector/v.net.timetable/main.c:289
+#: ../vector/v.net.timetable/main.c:296 ../vector/v.net.timetable/main.c:303
+#: ../vector/v.net.flow/main.c:71 ../vector/v.net.flow/main.c:77
+#: ../vector/v.net.flow/main.c:91 ../vector/v.net.flow/main.c:97
+#: ../vector/v.net.flow/main.c:103
+msgid "Cost"
+msgstr ""
+#: ../vector/v.net.path/main.c:80 ../vector/v.net.centrality/main.c:135
+#: ../vector/v.net.iso/main.c:107 ../vector/v.net.connectivity/main.c:83
+#: ../vector/v.net.components/main.c:102 ../vector/v.net.bridge/main.c:79
+#: ../vector/v.net.distance/main.c:145 ../vector/v.net.alloc/main.c:102
+#: ../vector/v.net.allpairs/main.c:99 ../vector/v.net.timetable/main.c:295
+#: ../vector/v.net.flow/main.c:96 ../display/d.path/main.c:87
+msgid "Arc backward direction cost column (number)"
+msgstr ""
+#: ../vector/v.net.path/main.c:87 ../vector/v.net.centrality/main.c:142
+#: ../vector/v.net.iso/main.c:112 ../vector/v.net.connectivity/main.c:91
+#: ../vector/v.net.components/main.c:109 ../vector/v.net.bridge/main.c:86
+#: ../vector/v.net.distance/main.c:151 ../vector/v.net.alloc/main.c:109
+#: ../vector/v.net.allpairs/main.c:106 ../vector/v.net.spanningtree/main.c:78
+#: ../vector/v.net.timetable/main.c:302 ../vector/v.net.flow/main.c:102
+msgid "Node cost column (number)"
+msgstr ""
+#: ../vector/v.net.path/main.c:95
+msgid "Maximum distance to the network"
+msgstr ""
+#: ../vector/v.net.path/main.c:96
+msgid ""
+"If start/end are given as coordinates. If start/end point is outside this "
+"threshold, the path is not found and error message is printed. To speed up "
+"the process, keep this value as low as possible."
+msgstr ""
+#: ../vector/v.net.path/main.c:105 ../vector/v.net.steiner/main.c:397
+#: ../vector/v.net.centrality/main.c:188 ../vector/v.net.salesman/main.c:180
+#: ../vector/v.net.iso/main.c:133 ../vector/v.net.distance/main.c:157
+#: ../vector/v.net.alloc/main.c:123 ../vector/v.net.allpairs/main.c:112
+#: ../vector/v.net.spanningtree/main.c:84 ../display/d.path/main.c:122
+msgid "Use geodesic calculation for longitude-latitude locations"
+msgstr ""
+#: ../vector/v.net.path/main.c:109
+msgid "Write output as original input segments, not each path as one line."
+msgstr ""
+#: ../vector/v.net.path/main.c:123 ../vector/v.net.centrality/main.c:222
+#: ../vector/v.net.distance/main.c:190 ../vector/v.net.allpairs/main.c:142
+#: ../vector/v.net.spanningtree/main.c:113 ../display/d.path/main.c:178
+msgid "The current projection is not longitude-latitude"
+msgstr ""
+#: ../vector/v.net.path/path.c:49 ../vector/v.segment/main.c:98
+#: ../vector/v.lrs/v.lrs.segment/main.c:133 ../raster3d/r3.support/main.c:167
+#: ../general/g.cairocomp/main.c:46 ../raster/r.in.mat/main.c:125
+#: ../raster/r.support/main.c:180 ../raster/r.series.accumulate/main.c:221
+#: ../raster/r.topmodel/file_io.c:28 ../raster/r.topmodel/file_io.c:53
+#: ../raster/r.topmodel/file_io.c:161 ../raster/r.in.xyz/main.c:541
+#: ../raster/r.series/main.c:216 ../raster/r.mapcalc/main.c:94
+#: ../display/d.linegraph/main.c:205 ../display/d.linegraph/main.c:221
+#: ../display/d.linegraph/main.c:361 ../display/d.where/main.c:163
+#: ../display/d.text/main.c:364
+#, c-format
+msgid "Unable to open input file <%s>"
+msgstr ""
+#: ../vector/v.net.path/path.c:82
+#, c-format
+msgid "[%d] points without category (nfield: [%d])"
+msgstr ""
+#: ../vector/v.net.path/path.c:109 ../vector/v.overlay/main.c:580
+#: ../vector/v.net.centrality/main.c:266 ../vector/v.net.components/main.c:189
+#: ../vector/v.in.dwg/main.c:240 ../vector/v.distance/main.c:1350
+#: ../vector/v.net.distance/main.c:263 ../vector/v.in.lidar/main.c:612
+#: ../vector/v.net.allpairs/main.c:179 ../vector/v.in.ogr/main.c:1118
+#: ../vector/v.net.timetable/main.c:103 ../vector/v.to.points/main.c:182
+#: ../vector/v.net.flow/main.c:181 ../raster/r.contour/main.c:183
+#: ../raster/r.stream.extract/close.c:188
+#, c-format
+msgid "Unable to create table: '%s'"
+msgstr ""
+#: ../vector/v.net.path/path.c:113 ../vector/v.kcv/main.c:175
+#: ../vector/v.net.centrality/main.c:270 ../vector/v.net.components/main.c:193
+#: ../vector/v.net.distance/main.c:267 ../vector/v.db.connect/main.c:336
+#: ../vector/v.net.allpairs/main.c:183 ../vector/v.sample/main.c:193
+#: ../vector/v.net.timetable/main.c:107 ../vector/v.net.flow/main.c:185
+msgid "Cannot create index"
+msgstr ""
+#: ../vector/v.net.path/path.c:117 ../vector/v.net.centrality/main.c:274
+#: ../vector/v.net.components/main.c:197 ../vector/v.net.distance/main.c:271
+#: ../vector/v.net.allpairs/main.c:187 ../vector/v.net.timetable/main.c:112
+#: ../vector/v.net.flow/main.c:189
+#, c-format
+msgid "Cannot grant privileges on table <%s>"
+msgstr ""
+#: ../vector/v.net.path/path.c:149 ../vector/v.net.timetable/main.c:482
+#, c-format
+msgid "Wrong input format: %s"
+msgstr ""
+#: ../vector/v.net.path/path.c:168 ../vector/v.net.path/path.c:188
+#, c-format
+msgid "No point with category [%d]"
+msgstr ""
+#: ../vector/v.net.path/path.c:209
+#, c-format
+msgid "Point with category [%d] is not reachable from point with category [%d]"
+msgstr ""
+#: ../vector/v.net.path/path.c:266
+#, c-format
+msgid "Point %f,%f is not reachable from point %f,%f"
+msgstr ""
+#: ../vector/v.net.path/path.c:312 ../vector/v.net.centrality/main.c:69
+#: ../vector/v.net.components/main.c:38 ../vector/v.net.distance/main.c:325
+#: ../vector/v.net.allpairs/main.c:271 ../vector/v.net.timetable/main.c:134
+#: ../vector/v.net.timetable/main.c:156 ../vector/v.net.flow/main.c:262
+#: ../raster/r.random/random.c:190
+#, c-format
+msgid "Cannot insert new record: %s"
+msgstr ""
+#: ../vector/v.net.path/path.c:330
+#, c-format
+msgid "[%d] input format errors"
+msgstr ""
+#: ../vector/v.net.path/path.c:332
+#, c-format
+msgid "[%d] points of given category missing"
+msgstr ""
+#: ../vector/v.net.path/path.c:334
+#, c-format
+msgid "%d destination(s) unreachable (including points out of threshold)"
+msgstr ""
+#: ../vector/v.edit/main.c:55 ../vector/v.to.3d/main.c:37
+#: ../vector/v.overlay/main.c:63 ../vector/v.build/main.c:38
+#: ../vector/v.segment/main.c:61 ../vector/v.type/main.c:39
+#: ../vector/v.select/main.c:48 ../vector/v.parallel/main.c:50
+#: ../vector/v.in.region/main.c:42 ../vector/v.voronoi/main.c:124
+#: ../vector/v.hull/main.c:53 ../vector/v.drape/main.c:57
+#: ../vector/v.perturb/main.c:63 ../vector/v.patch/main.c:69
+#: ../vector/v.delaunay/main.c:86 ../vector/v.buffer/main.c:226
+#: ../vector/v.transform/main.c:71 ../vector/v.clean/main.c:53
+#: ../vector/v.split/main.c:55 ../vector/v.mkgrid/main.c:71
+#: ../vector/v.extrude/main.c:68 ../vector/v.univar/main.c:96
+#: ../vector/v.build.polylines/main.c:113 ../vector/v.to.points/main.c:54
+#: ../locale/scriptstrings/v.report_to_translate.c:3
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:3
+#: ../raster/r.circle/main.c:53 ../raster/r.thin/main.c:56
+#: ../raster/r.patch/main.c:55 ../raster/r.to.vect/main.c:72
+msgid "geometry"
+msgstr ""
+#: ../vector/v.edit/main.c:56 ../vector/v.type/main.c:40
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
+msgid "editing"
+msgstr ""
+#: ../vector/v.edit/main.c:57 ../vector/v.type/main.c:42
+#: ../vector/v.parallel/main.c:52 ../vector/v.category/main.c:681
+#: ../vector/v.buffer/main.c:227 ../vector/v.build.polylines/main.c:114
+#: ../vector/v.to.points/main.c:56
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:5
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
+msgid "line"
+msgstr ""
+#: ../vector/v.edit/main.c:58 ../vector/v.segment/main.c:62
+#: ../vector/v.split/main.c:57 ../vector/v.build.polylines/main.c:115
+#: ../vector/v.to.points/main.c:57
+msgid "node"
+msgstr ""
+#: ../vector/v.edit/main.c:59 ../vector/v.segment/main.c:63
+#: ../vector/v.type/main.c:43 ../vector/v.category/main.c:677
+#: ../vector/v.to.points/main.c:59
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:6
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
+msgid "point"
+msgstr ""
+#: ../vector/v.edit/main.c:60 ../vector/v.segment/main.c:65
+#: ../vector/v.split/main.c:59 ../vector/v.build.polylines/main.c:116
+#: ../vector/v.to.points/main.c:58
+msgid "vertex"
+msgstr ""
+#: ../vector/v.edit/main.c:61
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
+msgstr ""
+#: ../vector/v.edit/main.c:70
+#, c-format
+msgid "Unable to get category list <%s>"
+msgstr ""
+#: ../vector/v.edit/main.c:87 ../vector/v.what.rast/main.c:120
+#: ../vector/v.select/main.c:88 ../vector/v.net/args.c:119
+#: ../vector/v.net/args.c:125 ../vector/v.net/args.c:131
+#: ../vector/v.net/args.c:135 ../vector/v.net/args.c:145
+#: ../vector/v.proj/main.c:200 ../vector/v.external/main.c:116
+#: ../vector/v.in.ogr/main.c:338 ../raster/r.proj/main.c:299
+#, c-format
+msgid "Required parameter <%s> not set"
+msgstr ""
+#: ../vector/v.edit/main.c:97 ../vector/v.in.lidar/main.c:492
+#: ../vector/v.in.ogr/main.c:523 ../vector/v.kernel/main.c:227
+#, c-format
+msgid "Vector map <%s> already exists"
+msgstr ""
+#: ../vector/v.edit/main.c:117
+msgid "Supported feature types for non-native formats:"
+msgstr ""
+#: ../vector/v.edit/main.c:138
+#, c-format
+msgid ""
+"Unable to open vector map <%s> on topological level. Try to rebuild vector "
+"topology by v.build."
+msgstr ""
+#: ../vector/v.edit/main.c:158
+#, c-format
+msgid ""
+"Unable to open vector map <%s> as the background map. It is given as vector "
+"map to be edited."
+msgstr ""
+#: ../vector/v.edit/main.c:169
+#, c-format
+msgid "Background vector map <%s> registered"
+msgstr ""
+#: ../vector/v.edit/main.c:205
+msgid "Threshold for snapping must be > 0. No snapping applied."
+msgstr ""
+#: ../vector/v.edit/main.c:212
+msgid "Selecting features..."
+msgstr ""
+#: ../vector/v.edit/main.c:224
+msgid "No features selected, nothing to edit"
+msgstr ""
+#: ../vector/v.edit/main.c:232
+#, c-format
+msgid ""
+"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
+"the vector map to 3D using e.g. %s."
+msgstr ""
+#: ../vector/v.edit/main.c:274
+#, c-format
+msgid "%d feature added"
+msgid_plural "%d features added"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:282 ../vector/v.edit/main.c:311
+#: ../vector/v.edit/main.c:322 ../vector/v.edit/main.c:354
+#: ../vector/v.edit/main.c:400
+#, c-format
+msgid "Threshold value for snapping is %.2f"
+msgstr ""
+#: ../vector/v.edit/main.c:294
+#, c-format
+msgid "%d boundary closed"
+msgid_plural "%d boundaries closed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:303
+#, c-format
+msgid "%d feature deleted"
+msgid_plural "%d features deleted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:314
+#, c-format
+msgid "%d feature moved"
+msgid_plural "%d features moved"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:325
+#, c-format
+msgid "%d vertex moved"
+msgid_plural "%d vertices moved"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:331
+#, c-format
+msgid "%d vertex added"
+msgid_plural "%d vertices added"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:337
+#, c-format
+msgid "%d vertex removed"
+msgid_plural "%d vertices removed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:349
+#, c-format
+msgid "%d line broken"
+msgid_plural "%d lines broken"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:357
+#, c-format
+msgid "%d line connected"
+msgid_plural "%d lines connected"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:363
+#, c-format
+msgid "%d line merged"
+msgid_plural "%d lines merged"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:372 ../vector/v.edit/main.c:378
+#, c-format
+msgid "%d feature modified"
+msgid_plural "%d features modified"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:385
+#, c-format
+msgid ""
+"Multiple background maps were given. Selected features will be copied only "
+"from vector map <%s>."
+msgstr ""
+#: ../vector/v.edit/main.c:395
+#, c-format
+msgid "%d feature copied"
+msgid_plural "%d features copied"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:406
+#, c-format
+msgid "%d line flipped"
+msgid_plural "%d lines flipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:427
+#, c-format
+msgid "%d line labeled"
+msgid_plural "%d lines labeled"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:436
+#, c-format
+msgid "%d feature converted"
+msgid_plural "%d features converted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:441
+msgid "No feature modified"
+msgstr ""
+#: ../vector/v.edit/main.c:448
+#, c-format
+msgid "Select feature %d is not centroid, ignoring..."
+msgstr ""
+#: ../vector/v.edit/main.c:455
+#, c-format
+msgid "%d area removed"
+msgid_plural "%d areas removed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/main.c:461
+msgid "Operation not implemented"
+msgstr ""
+#: ../vector/v.edit/close.c:56 ../vector/v.edit/snap.c:111
+#, c-format
+msgid "Unable to rewrite line %d"
+msgstr ""
+#: ../vector/v.edit/args.c:20
+msgid "Name of vector map to edit"
+msgstr ""
+#: ../vector/v.edit/args.c:36
+msgid "Tool"
+msgstr ""
+#: ../vector/v.edit/args.c:58
+msgid "Create new (empty) vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:59
+msgid "Add new features to existing vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:60
+msgid "Delete selected features from vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:61
+msgid "Move selected features in vector map"
+msgstr ""
+#: ../vector/v.edit/args.c:62
+msgid "Move vertex of selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:63
+msgid "Remove vertex from selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:64
+msgid "Add new vertex to selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:65
+msgid "Merge selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:66
+msgid "Break/split vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:67
+msgid "Select lines and print their ID's"
+msgstr ""
+#: ../vector/v.edit/args.c:68
+msgid "Set new categories to selected vector features for defined layer"
+msgstr ""
+#: ../vector/v.edit/args.c:70
+msgid "Delete categories from selected vector features for defined layer"
+msgstr ""
+#: ../vector/v.edit/args.c:72
+msgid "Copy selected features"
+msgstr ""
+#: ../vector/v.edit/args.c:73
+msgid "Snap vector features in given threshold"
+msgstr ""
+#: ../vector/v.edit/args.c:74
+msgid "Flip direction of selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:75
+msgid "Connect two lines"
+msgstr ""
+#: ../vector/v.edit/args.c:76
+msgid "Z bulk-labeling (automated assignment of z coordinate to vector lines)"
+msgstr ""
+#: ../vector/v.edit/args.c:78
+msgid "Change feature type (point<->centroid, line<->boundary)"
+msgstr ""
+#: ../vector/v.edit/args.c:79
+msgid "Delete selected areas from vector map (based on selected centroids)"
+msgstr ""
+#: ../vector/v.edit/args.c:87
+msgid "Name of file containing data in GRASS ASCII vector format"
+msgstr ""
+#: ../vector/v.edit/args.c:90 ../vector/v.edit/args.c:209
+#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+#: ../locale/scriptstrings/i.spectral_to_translate.c:8
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
+#: ../locale/scriptstrings/t.register_to_translate.c:5
+#: ../locale/scriptstrings/t.register_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:8
+#: ../locale/scriptstrings/t.register_to_translate.c:11
+#: ../locale/scriptstrings/t.register_to_translate.c:25
+#: ../locale/scriptstrings/t.remove_to_translate.c:5
+#: ../locale/scriptstrings/t.remove_to_translate.c:8
+#: ../locale/scriptstrings/t.remove_to_translate.c:10
+#: ../raster/r.spread/main.c:124 ../raster/r.spread/main.c:138
+#: ../raster/r.spread/main.c:150 ../raster/r.spread/main.c:163
+#: ../raster/r.spread/main.c:176 ../raster/r.spread/main.c:188
+#: ../raster/r.spread/main.c:200 ../raster/r.in.xyz/main.c:193
+#: ../raster/r.in.xyz/main.c:202 ../raster/r.in.xyz/main.c:210
+#: ../raster/r.in.xyz/main.c:221 ../raster/r.in.xyz/main.c:231
+#: ../raster/r.external/main.c:64 ../raster/r.external/main.c:72
+#: ../raster/r.external/main.c:81 ../raster/r.sim/r.sim.sediment/main.c:152
+#: ../raster/r.sim/r.sim.sediment/main.c:160
+#: ../raster/r.sim/r.sim.sediment/main.c:167
+#: ../raster/r.sim/r.sim.water/main.c:133
+#: ../raster/r.sim/r.sim.water/main.c:142
+#: ../raster/r.sim/r.sim.water/main.c:149
+#: ../raster/r.sim/r.sim.water/main.c:158
+#: ../raster/r.sim/r.sim.water/main.c:164
+#: ../raster/r.sim/r.sim.water/main.c:172
+#: ../raster/r.sim/r.sim.water/main.c:179
+#: ../raster/r.sim/r.sim.water/main.c:186 ../raster/r.horizon/main.c:195
+#: ../raster/r.horizon/main.c:204 ../raster/r.horizon/main.c:212
+#: ../raster/r.sun/main.c:260 ../raster/r.sun/main.c:269
+#: ../raster/r.sun/main.c:278 ../raster/r.sun/main.c:287
+#: ../raster/r.sun/main.c:295 ../raster/r.sun/main.c:304
+#: ../raster/r.sun/main.c:313 ../raster/r.sun/main.c:322
+#: ../raster/r.sun/main.c:331 ../raster/r.sun/main.c:340
+#: ../raster/r.sun/main.c:349 ../raster/r.sun/main.c:358
+#: ../raster/r.sun/main.c:367 ../raster/r.sun/main.c:374
+#: ../raster/r.sun/main.c:382 ../display/d.legend/main.c:94
+#: ../display/d.legend/main.c:99
+msgid "Input"
+msgstr ""
+#: ../vector/v.edit/args.c:99
+msgid "Difference in x,y,z direction for moving feature or vertex"
+msgstr ""
+#: ../vector/v.edit/args.c:106
+msgid "Threshold distance (coords,snap,query)"
+msgstr ""
+#: ../vector/v.edit/args.c:108
+msgid "'-1' for threshold based on the current resolution settings"
+msgstr ""
+#: ../vector/v.edit/args.c:124
+msgid "List of point coordinates"
+msgstr ""
+#: ../vector/v.edit/args.c:133
+msgid "Bounding box for selecting features"
+msgstr ""
+#: ../vector/v.edit/args.c:142
+msgid "Polygon for selecting features"
+msgstr ""
+#: ../vector/v.edit/args.c:152
+msgid "Query tool"
+msgstr ""
+#: ../vector/v.edit/args.c:154
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
+msgstr ""
+#: ../vector/v.edit/args.c:160
+msgid "Select only lines or boundaries shorter/longer than threshold distance"
+msgstr ""
+#: ../vector/v.edit/args.c:162
+msgid "Select dangles shorter/longer than threshold distance"
+msgstr ""
+#: ../vector/v.edit/args.c:169
+msgid "Name of background vector map(s)"
+msgstr ""
+#: ../vector/v.edit/args.c:176
+msgid ""
+"Snap added or modified features in the given threshold to the nearest "
+"existing feature"
+msgstr ""
+#: ../vector/v.edit/args.c:182
+msgid "Not apply snapping"
+msgstr ""
+#: ../vector/v.edit/args.c:183
+msgid "Snap only to node"
+msgstr ""
+#: ../vector/v.edit/args.c:184
+msgid "Allow snapping also to vertex"
+msgstr ""
+#: ../vector/v.edit/args.c:192
+msgid "Starting value and step for z bulk-labeling"
+msgstr ""
+#: ../vector/v.edit/args.c:193
+msgid "Pair: value,step (e.g. 1100,10)"
+msgstr ""
+#: ../vector/v.edit/args.c:204
+msgid "Close added boundaries (using threshold distance)"
+msgstr ""
+#: ../vector/v.edit/args.c:208
+msgid "Do not expect header of input data"
+msgstr ""
+#: ../vector/v.edit/args.c:216
+msgid "Modify only first found feature in bounding box"
+msgstr ""
+#: ../vector/v.edit/args.c:228
+msgid "Polygon must have at least 3 coordinate pairs"
+msgstr ""
+#: ../vector/v.edit/args.c:292
+#, c-format
+msgid "Operation '%s' not implemented"
+msgstr ""
+#: ../vector/v.edit/args.c:301
+#, c-format
+msgid "At least one option from %s must be specified"
+msgstr ""
+#: ../vector/v.edit/args.c:307 ../vector/v.edit/args.c:316
+#: ../vector/v.edit/args.c:323 ../vector/v.edit/args.c:330
+#: ../vector/v.edit/args.c:334
+#, c-format
+msgid "Tool %s requires option %s"
+msgstr ""
+#: ../vector/v.edit/select.c:73
+#, c-format
+msgid "Threshold value for coordinates is %.2f"
+msgstr ""
+#: ../vector/v.edit/select.c:160
+#, c-format
+msgid "Threshold value for querying is %.2f"
+msgstr ""
+#: ../vector/v.edit/select.c:176
+#, c-format
+msgid "%d of %d feature selected from vector map <%s>"
+msgid_plural "%d of %d features selected from vector map <%s>"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.edit/select.c:496
+msgid "Layer must be > 0 for 'where'"
+msgstr ""
+#: ../vector/v.edit/select.c:502 ../vector/v.colors/read_rgb.c:23
+#: ../vector/v.colors/scan_attr.c:24 ../vector/v.colors/write_rgb.c:20
+#: ../vector/v.overlay/main.c:391 ../vector/v.what.rast/main.c:137
+#: ../vector/v.vect.stats/main.c:295 ../vector/v.vect.stats/main.c:371
+#: ../vector/v.to.rast/support.c:127 ../vector/v.to.rast/support.c:286
+#: ../vector/v.to.rast/support.c:439 ../vector/v.distance/main.c:487
+#: ../vector/v.generalize/misc.c:160 ../vector/v.surf.bspline/crosscorr.c:114
+#: ../vector/v.buffer/main.c:412 ../vector/v.extrude/main.c:224
+#: ../vector/v.univar/main.c:229 ../vector/v.what.rast3/main.c:119
+#: ../doc/vector/v.example/main.c:105 ../display/d.vect/shape.c:38
+#: ../display/d.vect.thematic/plot1.c:105 ../display/d.vect.chart/plot.c:37
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr ""
+#: ../vector/v.colors/read_rgb.c:32
+#, c-format
+msgid "Data type of RGB column <%s> must be char"
+msgstr ""
+#: ../vector/v.colors/read_rgb.c:37
+msgid "No RGB values found"
+msgstr ""
+#: ../vector/v.colors/read_rgb.c:65
+#, c-format
+msgid "%d invalid RGB color values skipped"
+msgstr ""
+#: ../vector/v.colors/main.c:56 ../vector/v.colors.out/main.c:50
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
+#: ../raster/r.what.color/main.c:90 ../raster/r.colors.out/raster_main.c:46
+#: ../raster/r.colors.out/raster3d_main.c:47
+#: ../raster/r.colors/edit_colors.c:67 ../display/d.colortable/main.c:62
+msgid "color table"
+msgstr ""
+#: ../vector/v.colors/main.c:58
+msgid "Creates/modifies the color table associated with a vector map."
+msgstr ""
+#: ../vector/v.colors/main.c:70
+msgid "Source values"
+msgstr ""
+#: ../vector/v.colors/main.c:73
+msgid "read values from attribute table (requires <column> option)"
+msgstr ""
+#: ../vector/v.colors/main.c:74 ../vector/v.to.rast/main.c:78
+msgid "use category values"
+msgstr ""
+#: ../vector/v.colors/main.c:75
+msgid "use z coordinate (3D points or centroids only)"
+msgstr ""
+#: ../vector/v.colors/main.c:79
+msgid "Name of column containing numeric data"
+msgstr ""
+#: ../vector/v.colors/main.c:80
+msgid "Required for use=attr"
+msgstr ""
+#: ../vector/v.colors/main.c:81 ../vector/v.colors/main.c:92
+#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:106
+#: ../vector/v.colors/main.c:113 ../vector/v.colors/main.c:139
+#: ../vector/v.colors/main.c:144 ../vector/v.colors/main.c:149
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:25
+#: ../raster/r.category/main.c:81 ../raster/r.category/main.c:88
+#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
+#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
+#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
+#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
+#: ../raster/r.colors/edit_colors.c:148
+msgid "Define"
+msgstr ""
+#: ../vector/v.colors/main.c:87
+msgid "Manually set range (refers to 'column' option)"
+msgstr ""
+#: ../vector/v.colors/main.c:88
+msgid "Ignored when 'rules' given"
+msgstr ""
+#: ../vector/v.colors/main.c:98
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
+#: ../raster/r.colors/edit_colors.c:96
+msgid "Raster map from which to copy color table"
+msgstr ""
+#: ../vector/v.colors/main.c:105
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
+#: ../raster/r.colors/edit_colors.c:103
+msgid "3D raster map from which to copy color table"
+msgstr ""
+#: ../vector/v.colors/main.c:111
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
+#: ../raster/r.colors/edit_colors.c:109
+msgid "Path to rules file"
+msgstr ""
+#: ../vector/v.colors/main.c:112 ../raster/r.colors/edit_colors.c:110
+msgid "\"-\" to read rules from stdin"
+msgstr ""
+#: ../vector/v.colors/main.c:117
+msgid "Name of color column to populate RGB values"
+msgstr ""
+#: ../vector/v.colors/main.c:118
+msgid "If not given writes color table"
+msgstr ""
+#: ../vector/v.colors/main.c:122
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
+#: ../raster/r.colors/edit_colors.c:115
+msgid "Remove existing color table"
+msgstr ""
+#: ../vector/v.colors/main.c:123
+#: ../locale/scriptstrings/g.extension_to_translate.c:27
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
+#: ../locale/scriptstrings/r.mask_to_translate.c:20
+#: ../raster/r.null/main.c:107 ../raster/r.colors/edit_colors.c:116
+msgid "Remove"
+msgstr ""
+#: ../vector/v.colors/main.c:128
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
+#: ../raster/r.colors/edit_colors.c:121
+msgid "Only write new color table if it does not already exist"
+msgstr ""
+#: ../vector/v.colors/main.c:132
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
+#: ../raster/r.colors/edit_colors.c:126
+msgid "List available rules then exit"
+msgstr ""
+#: ../vector/v.colors/main.c:138
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
+#: ../raster/r.colors/edit_colors.c:132
+msgid "Invert colors"
+msgstr ""
+#: ../vector/v.colors/main.c:143
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
+#: ../raster/r.colors/edit_colors.c:137
+msgid "Logarithmic scaling"
+msgstr ""
+#: ../vector/v.colors/main.c:148
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
+#: ../raster/r.colors/edit_colors.c:142
+msgid "Logarithmic-absolute scaling"
+msgstr ""
+#: ../vector/v.colors/main.c:153
+msgid "Convert color rules from RGB values to color table"
+msgstr ""
+#: ../vector/v.colors/main.c:154
+msgid "Option 'rgb_column' with valid RGB values required"
+msgstr ""
+#: ../vector/v.colors/main.c:197
+msgid "No vector map specified"
+msgstr ""
+#: ../vector/v.colors/main.c:200 ../raster/r.sunmask/main.c:444
+#, c-format
+msgid "Option <%s> required"
+msgstr ""
+#: ../vector/v.colors/main.c:202
+#, c-format
+msgid "Option <%s> given, assuming <use=attr>..."
+msgstr ""
+#: ../vector/v.colors/main.c:207 ../raster/r.series.accumulate/main.c:206
+#: ../raster/r.series.interp/main.c:118 ../raster/r.series.interp/main.c:122
+#: ../raster/r.series.interp/main.c:134 ../raster/r.series.interp/main.c:138
+#: ../raster/r.series/main.c:198 ../raster/r.mapcalc/main.c:159
+#: ../raster/r.external/main.c:147 ../raster/r.neighbors/main.c:266
+#, c-format
+msgid "%s= and %s= are mutually exclusive"
+msgstr ""
+#: ../vector/v.colors/main.c:217
+#, c-format
+msgid "One of -%c, -%c or %s=, %s= or %s= must be specified"
+msgstr ""
+#: ../vector/v.colors/main.c:222
+#, c-format
+msgid "%s=, %s= and %s= are mutually exclusive"
+msgstr ""
+#: ../vector/v.colors/main.c:226 ../general/g.list/main.c:192
+#: ../general/g.list/main.c:196 ../raster/r.out.bin/main.c:379
+#: ../raster/r.in.bin/main.c:462
+#, c-format
+msgid "-%c and -%c are mutually exclusive"
+msgstr ""
+#: ../vector/v.colors/main.c:230
+#, c-format
+msgid "%s= required for -%c"
+msgstr ""
+#: ../vector/v.colors/main.c:245
+#, c-format
+msgid "Unable to remove color table of vector map <%s>"
+msgstr ""
+#: ../vector/v.colors/main.c:247
+#, c-format
+msgid "Color table of vector map <%s> not found"
+msgstr ""
+#: ../vector/v.colors/main.c:255
+msgid "Color table exists. Exiting."
+msgstr ""
+#: ../vector/v.colors/main.c:267 ../vector/v.to.rast/vect2rast.c:48
+#, c-format
+msgid "Vector map <%s> is not 3D"
+msgstr ""
+#: ../vector/v.colors/main.c:271 ../vector/v.out.ascii/main.c:104
+#: ../vector/v.colors.out/scan_cats.c:24
+#: ../vector/v.colors.out/make_colors.c:27 ../vector/v.surf.rst/main.c:537
+#, c-format
+msgid "Layer <%s> not found"
+msgstr ""
+#: ../vector/v.colors/main.c:277
+#, c-format
+msgid "Option <%s>: min must be greater or equal to max"
+msgstr ""
+#: ../vector/v.colors/main.c:283
+msgid "Reading color rules from standard input is currently not supported"
+msgstr ""
+#: ../vector/v.colors/main.c:290
+#, c-format
+msgid "Color table <%s> not found"
+msgstr ""
+#: ../vector/v.colors/main.c:316 ../raster/r.grow.distance/main.c:368
+#: ../raster/r.colors.out/raster_main.c:69 ../raster/r.fill.dir/main.c:150
+#: ../raster/r.colors/edit_colors.c:396
+#, c-format
+msgid "Unable to read color table for raster map <%s>"
+msgstr ""
+#: ../vector/v.colors/main.c:320 ../raster3d/r3.timestamp/main.c:71
+#: ../raster3d/r3.out.bin/main.c:299 ../raster3d/r3.to.rast/main.c:222
+#: ../raster3d/r3.stats/main.c:96 ../raster3d/r3.cross.rast/main.c:245
+#: ../raster3d/r3.null/main.c:103 ../raster3d/r3.support/main.c:135
+#: ../raster3d/r3.out.ascii/main.c:326 ../raster3d/r3.out.v5d/main.c:307
+#: ../raster3d/r3.mask/main.c:58 ../raster3d/r3.out.vtk/main.c:142
+#: ../raster3d/r3.neighbors/main.c:229 ../raster3d/r3.out.netcdf/main.c:600
+#: ../raster3d/r3.retile/main.c:113 ../general/g.region/main.c:444
+#: ../raster/r.colors/edit_colors.c:400
+#: ../raster/r.univar/r3.univar_main.c:144
+#: ../raster/r.univar/r3.univar_main.c:182
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr ""
+#: ../vector/v.colors/main.c:323 ../raster/r.colors/edit_colors.c:403
+#, c-format
+msgid "Unable to read color table for 3D raster map <%s>"
+msgstr ""
+#: ../vector/v.colors/main.c:348
+msgid "Writing color rules..."
+msgstr ""
+#: ../vector/v.colors/main.c:364
+#, c-format
+msgid "Color table for vector map <%s> set to '%s'"
+msgstr ""
+#: ../vector/v.colors/scan_z.c:31 ../vector/v.colors/scan_cats.c:19
+#: ../vector/v.to.rast/do_lines.c:36 ../vector/v.colors.out/scan_cats.c:28
+#: ../vector/v.voronoi/main.c:208 ../vector/v.to.db/lines.c:75
+#: ../vector/v.to.db/query.c:23
+msgid "Reading features..."
+msgstr ""
+#: ../vector/v.colors/scan_z.c:36 ../vector/v.colors/scan_cats.c:24
+#: ../vector/v.vol.rst/user1.c:140 ../vector/v.info/level1.c:37
+#: ../vector/v.to.3d/trans3.c:85 ../vector/v.to.3d/trans2.c:84
+#: ../vector/v.colors.out/scan_cats.c:32 ../vector/v.label.sa/labels.c:141
+#: ../vector/v.perturb/main.c:181 ../vector/v.label/main.c:293
+#: ../raster/r.walk/main.c:688 ../raster/r.walk/main.c:754
+#: ../raster/r.drain/main.c:283 ../raster/r.cost/main.c:548
+#: ../raster/r.cost/main.c:618 ../display/d.vect/dir.c:30
+#: ../display/d.vect/topo.c:52 ../display/d.vect/vert.c:27
+#: ../display/d.vect/lines.c:143 ../display/d.vect/attr.c:51
+#: ../display/d.vect/label.c:44
+msgid "Unable to read vector map"
+msgstr ""
+#: ../vector/v.colors/scan_z.c:68 ../vector/v.colors/scan_attr.c:59
+#, c-format
+msgid "Min value (%f) is out of range %f,%f"
+msgstr ""
+#: ../vector/v.colors/scan_z.c:74 ../vector/v.colors/scan_attr.c:65
+#, c-format
+msgid "Max value (%f) is out of range %f,%f"
+msgstr ""
+#: ../vector/v.colors/scan_attr.c:38 ../vector/v.colors.out/make_colors.c:45
+#, c-format
+msgid "Column <%s> is not numeric"
+msgstr ""
+#: ../vector/v.colors/scan_attr.c:45 ../vector/v.colors.out/make_colors.c:52
+msgid "No data selected"
+msgstr ""
+#: ../vector/v.colors/scan_attr.c:77 ../vector/v.colors/scan_cats.c:43
+#, c-format
+msgid "Min value (%d) is out of range %d,%d"
+msgstr ""
+#: ../vector/v.colors/scan_attr.c:83 ../vector/v.colors/scan_cats.c:49
+#, c-format
+msgid "Max value (%d) is out of range %d,%d"
+msgstr ""
+#: ../vector/v.colors/scan_attr.c:108
+msgid "Converting color rules into categories..."
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:37
+#, c-format
+msgid "Unable to add column <%s> to table <%s>"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:60
+#, c-format
+msgid "Column <%s> added to table <%s>"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:64
+#, c-format
+msgid "Data type of column <%s> must be char"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:68
+msgid "No categories found"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:78
+#, c-format
+msgid "No color value defined for category %d"
+msgstr ""
+#: ../vector/v.colors/write_rgb.c:86
+msgid "Unable to update RGB values"
+msgstr ""
+#: ../vector/v.colors/make_colors.c:14
+#, c-format
+msgid "Color table '%s' is not supported for floating point attributes"
+msgstr ""
+#: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
+#, c-format
+msgid "Color table <%s> not supported"
+msgstr ""
+#: ../vector/v.colors/make_colors.c:51 ../raster/r.colors/edit_colors.c:386
+#, c-format
+msgid "Unable to load rules file <%s>"
+msgstr ""
+#: ../vector/v.vol.rst/dataoct.c:196
+msgid "Points are too concentrated -- please increase DMIN"
+msgstr ""
+#: ../vector/v.vol.rst/dataoct.c:245
+msgid "Point out of range"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:236 ../vector/v.to.rast3/main.c:50
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:5
+#: ../raster3d/r3.timestamp/main.c:45 ../raster3d/r3.info/main.c:77
+#: ../raster3d/r3.out.bin/main.c:207 ../raster3d/r3.gwflow/main.c:161
+#: ../raster3d/r3.to.rast/main.c:209 ../raster3d/r3.stats/main.c:50
+#: ../raster3d/r3.cross.rast/main.c:231 ../raster3d/r3.in.v5d/main.c:180
+#: ../raster3d/r3.in.ascii/main.c:315 ../raster3d/r3.null/main.c:188
+#: ../raster3d/r3.support/main.c:51 ../raster3d/r3.out.ascii/main.c:304
+#: ../raster3d/r3.in.bin/main.c:254 ../raster3d/r3.out.v5d/main.c:286
+#: ../raster3d/r3.mask/main.c:135 ../raster3d/r3.out.vtk/main.c:378
+#: ../raster3d/r3.neighbors/main.c:210 ../raster3d/r3.out.netcdf/main.c:589
+#: ../raster3d/r3.retile/main.c:98 ../raster3d/r3.mkdspf/main.c:81
+#: ../raster/r.to.rast3elev/main.c:364 ../raster/r.to.rast3/main.c:199
+msgid "voxel"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:237 ../vector/v.surf.bspline/main.c:92
+#: ../vector/v.surf.rst/main.c:142 ../vector/v.surf.idw/main.c:88
+#: ../raster/r.surf.random/main.c:37 ../raster/r.surf.contour/main.c:61
+#: ../raster/r.surf.gauss/main.c:39 ../raster/r.surf.area/main.c:77
+#: ../raster/r.contour/main.c:88 ../raster/r.surf.idw/main.c:105
+#: ../raster/r.surf.fractal/main.c:39 ../raster/r.random.surface/main.c:58
+#: ../raster/r.resamp.bspline/main.c:81
+msgid "surface"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:238 ../vector/v.surf.bspline/main.c:93
+#: ../vector/v.surf.rst/main.c:143 ../vector/v.surf.idw/main.c:89
+#: ../locale/scriptstrings/v.krige_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
+#: ../raster/r.series.interp/main.c:66 ../raster/r.surf.contour/main.c:62
+#: ../raster/r.resamp.interp/main.c:78 ../raster/r.surf.idw/main.c:106
+#: ../raster/r.resamp.bspline/main.c:83
+msgid "interpolation"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:239
+msgid "RST"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:241
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+#: ../vector/v.vol.rst/main.c:246
+msgid "Name of input 3D vector points map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:253
+msgid "Name of input surface raster map for cross-section"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:254 ../vector/v.vol.rst/main.c:303
+#: ../imagery/i.vi/main.c:142 ../imagery/i.vi/main.c:150
+#: ../imagery/i.vi/main.c:158 ../imagery/i.vi/main.c:166
+#: ../imagery/i.vi/main.c:174
+msgid "Optional inputs"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:260
+msgid "Name of column containing w-values attribute to interpolate"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:267 ../vector/v.surf.rst/main.c:260
+msgid "Tension parameter"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:275 ../vector/v.surf.rst/main.c:267
+msgid "Smoothing parameter"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:282
+msgid "Name of column with smoothing parameters"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:290 ../vector/v.surf.rst/main.c:225
+msgid "Name for output deviations vector point map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:291 ../vector/v.vol.rst/main.c:297
+#: ../vector/v.vol.rst/main.c:360 ../vector/v.vol.rst/main.c:366
+#: ../vector/v.vol.rst/main.c:372 ../vector/v.vol.rst/main.c:379
+#: ../vector/v.vol.rst/main.c:385 ../vector/v.vol.rst/main.c:391
+#: ../vector/v.vol.rst/main.c:397 ../vector/v.vol.rst/main.c:403
+#: ../vector/v.surf.bspline/main.c:130 ../vector/v.surf.bspline/main.c:135
+#: ../vector/v.surf.rst/main.c:166 ../vector/v.surf.rst/main.c:190
+#: ../vector/v.surf.rst/main.c:196 ../vector/v.surf.rst/main.c:202
+#: ../vector/v.surf.rst/main.c:208 ../vector/v.surf.rst/main.c:214
+#: ../vector/v.surf.rst/main.c:220 ../vector/v.surf.rst/main.c:226
+#: ../vector/v.surf.rst/main.c:233 ../vector/v.surf.rst/main.c:240
+#: ../vector/v.surf.rst/main.c:247 ../raster/r.slope.aspect/main.c:166
+#: ../raster/r.slope.aspect/main.c:172 ../raster/r.slope.aspect/main.c:197
+#: ../raster/r.slope.aspect/main.c:204 ../raster/r.slope.aspect/main.c:211
+#: ../raster/r.slope.aspect/main.c:218 ../raster/r.slope.aspect/main.c:225
+#: ../raster/r.slope.aspect/main.c:232 ../raster/r.slope.aspect/main.c:239
+#: ../raster/r.watershed/front/main.c:133
+#: ../raster/r.watershed/front/main.c:140
+#: ../raster/r.watershed/front/main.c:146
+#: ../raster/r.watershed/front/main.c:152
+#: ../raster/r.watershed/front/main.c:158
+#: ../raster/r.watershed/front/main.c:166
+#: ../raster/r.watershed/front/main.c:174
+#: ../raster/r.watershed/front/main.c:181
+msgid "Outputs"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:296 ../vector/v.surf.rst/main.c:232
+msgid "Name for output cross-validation errors vector point map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:302
+msgid "Name of input raster map used as mask"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:310 ../vector/v.surf.rst/main.c:283
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
+msgid "Maximum number of points in a segment"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:319 ../vector/v.surf.rst/main.c:292
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
+msgid "Minimum number of points for approximation in a segment (>segmax)"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:328
+msgid "Maximum number of points for approximation in a segment (>npmin)"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:336 ../vector/v.surf.rst/main.c:300
+msgid "Minimum distance between points (to remove almost identical points)"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:345
+msgid "Conversion factor for w-values used for interpolation"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:353
+msgid "Conversion factor for z-values"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:359
+msgid "Name for output cross-section raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:365
+msgid "Name for output elevation 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:371
+msgid "Name for output gradient magnitude 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:378
+msgid "Name for output gradient horizontal angle 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:384
+msgid "Name for output gradient vertical angle 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:390
+msgid "Name for output change of gradient 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:396
+msgid "Name for output Gaussian curvature 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:402
+msgid "Name for output mean curvature 3D raster map"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:408
+msgid "Perform a cross-validation procedure without volume interpolation"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:471
+msgid "Smoothing must be a positive value"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:477
+#, c-format
+msgid "Both crossvalidation options (-%c, %s) must be specified"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:480
+msgid "Both crossvalidation and deviations must be specified"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:491
+msgid ""
+"Crossvalidation cannot be computed simultanuously with output grids or devi "
+"file"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:507 ../vector/v.vol.rst/main.c:510
+#: ../vector/v.vol.rst/main.c:513 ../vector/v.vol.rst/main.c:516
+#: ../vector/v.vol.rst/main.c:519 ../vector/v.vol.rst/main.c:522
+#: ../vector/v.vol.rst/main.c:525 ../vector/v.vol.rst/main.c:528
+#: ../vector/v.vol.rst/main.c:531 ../vector/v.vol.rst/main.c:534
+#: ../vector/v.vol.rst/main.c:621 ../vector/v.vol.rst/main.c:652
+#: ../vector/v.vol.rst/main.c:674 ../vector/v.vol.rst/main.c:696
+#: ../vector/v.vol.rst/main.c:718 ../vector/v.vol.rst/main.c:740
+#: ../vector/v.vol.rst/main.c:762 ../vector/v.vol.rst/main.c:784
+#: ../vector/v.vol.rst/user3.c:273 ../vector/v.vol.rst/user3.c:279
+#: ../vector/v.vol.rst/user3.c:285 ../vector/v.vol.rst/user2.c:122
+#: ../vector/v.vol.rst/user2.c:232 ../vector/v.surf.rst/main.c:482
+#: ../vector/v.surf.rst/main.c:487 ../vector/v.surf.rst/main.c:491
+#: ../vector/v.surf.rst/main.c:496 ../vector/v.surf.rst/main.c:500
+#: ../vector/v.surf.rst/main.c:504
+#, c-format
+msgid "Not enough memory for %s"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:539 ../vector/v.vol.rst/main.c:544
+#: ../vector/v.vol.rst/main.c:546 ../vector/v.surf.rst/main.c:511
+#: ../vector/v.surf.rst/main.c:517 ../vector/v.surf.rst/main.c:520
+#: ../vector/v.surf.rst/main.c:524
+#, c-format
+msgid "Unable to create %s"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:555
+#, c-format
+msgid "Unable to open %s"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:563
+msgid "Vector is not 3D"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:605 ../vector/v.surf.rst/main.c:592
+#, c-format
+msgid "Unable to create table '%s'"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:628 ../vector/v.vol.rst/main.c:659
+#: ../vector/v.vol.rst/main.c:681 ../vector/v.vol.rst/main.c:703
+#: ../vector/v.vol.rst/main.c:725 ../vector/v.vol.rst/main.c:747
+#: ../vector/v.vol.rst/main.c:769 ../vector/v.vol.rst/main.c:791
+#, c-format
+msgid "Unable to open temp file '%s'"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:636 ../vector/v.vol.rst/main.c:665
+#: ../vector/v.vol.rst/main.c:687 ../vector/v.vol.rst/main.c:709
+#: ../vector/v.vol.rst/main.c:731 ../vector/v.vol.rst/main.c:753
+#: ../vector/v.vol.rst/main.c:775 ../vector/v.vol.rst/main.c:797
+msgid "Not enough disk space - cannot write temp files"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:640
+msgid "Unable to create cellout raster map without cellinp"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:818
+msgid "Finished interpolating"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:853
+#, c-format
+msgid "Raster map <%s> created"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:893
+#, c-format
+msgid "Vector map <%s> created"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:909
+msgid "Interpolation failed"
+msgstr ""
+#: ../vector/v.vol.rst/main.c:914 ../vector/v.surf.rst/main.c:623
+#: ../vector/v.surf.rst/main.c:678 ../raster/r.sim/r.sim.sediment/main.c:357
+#: ../raster/r.sim/r.sim.water/main.c:458
+msgid "Input failed"
+msgstr ""
+#: ../vector/v.vol.rst/user3.c:549
+msgid "Secpar_loop failed"
+msgstr ""
+#: ../vector/v.vol.rst/user3.c:589 ../vector/v.vol.rst/user3.c:600
+#: ../vector/v.vol.rst/user3.c:611 ../vector/v.vol.rst/user3.c:622
+#: ../vector/v.vol.rst/user3.c:633 ../vector/v.vol.rst/user3.c:644
+#: ../vector/v.vol.rst/user3.c:655 ../vector/v.vol.rst/user3.c:666
+msgid "Not enough disk space--cannot write files"
+msgstr ""
+#: ../vector/v.vol.rst/user2.c:213
+msgid "Cannot allocate A"
+msgstr ""
+#: ../vector/v.vol.rst/user2.c:217
+msgid "Cannot allocate b"
+msgstr ""
+#: ../vector/v.vol.rst/user2.c:221
+msgid "Cannot allocate w"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:109
+msgid "Column type of wcolumn is not supported (must be integer or double)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:123
+msgid "Cannot read column type of smooth column"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:126
+msgid "Column type of smooth column (datetime) is not supported"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:128
+msgid ""
+"Column type of smooth column is not supported (must be integer or double)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:150
+msgid "Point without category"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:172 ../vector/v.what.rast/main.c:592
+#: ../vector/v.label.sa/labels.c:166 ../vector/v.buffer/main.c:520
+#: ../vector/v.buffer/main.c:621 ../vector/v.label/main.c:325
+#: ../vector/v.sample/main.c:226 ../vector/v.sample/main.c:234
+#: ../vector/v.what.rast3/main.c:271
+#, c-format
+msgid "No record for category %d in table <%s>"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:208
+msgid "Some points outside of region -- will ignore..."
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:215
+msgid "Cannot allocate memory for point"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:223
+#, c-format
+msgid "Can't insert %lf,%lf,%lf,%lf,%lf a=%d"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:270
+msgid "Strip exists with insufficient data"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:280
+msgid "Zero segments!"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:311
+#, c-format
+msgid ""
+"There are points outside specified 2D/3D region--ignored %d points (total "
+"points: %d)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:315
+#, c-format
+msgid ""
+"Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:321
+#, c-format
+msgid ""
+"%d points given for interpolation (after thinning) is less than given NPMIN="
+"%d"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:341
+#, c-format
+msgid ""
+"There is less than %d points for interpolation, no segmentation is "
+"necessary, to run the program faster, set segmax=%d (see manual)"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:368
+#, c-format
+msgid "Mask raster map [%s] not found"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:383
+msgid "Bitmap mask created"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:432 ../vector/v.vol.rst/user1.c:485
+#: ../vector/v.vol.rst/user1.c:538 ../vector/v.vol.rst/user1.c:591
+#: ../vector/v.vol.rst/user1.c:644 ../vector/v.vol.rst/user1.c:697
+#: ../vector/v.vol.rst/user1.c:750
+#, c-format
+msgid "Unable to open %s for writing"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:443 ../vector/v.vol.rst/user1.c:496
+#: ../vector/v.vol.rst/user1.c:549 ../vector/v.vol.rst/user1.c:602
+#: ../vector/v.vol.rst/user1.c:655 ../vector/v.vol.rst/user1.c:708
+#: ../vector/v.vol.rst/user1.c:761
+msgid "Unable to read data from temp file"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:461 ../vector/v.vol.rst/user1.c:514
+#: ../vector/v.vol.rst/user1.c:567 ../vector/v.vol.rst/user1.c:620
+#: ../vector/v.vol.rst/user1.c:673 ../vector/v.vol.rst/user1.c:726
+#: ../vector/v.vol.rst/user1.c:779
+#, c-format
+msgid "Error writing cell (%d,%d,%d) with value %f"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:474 ../vector/v.vol.rst/user1.c:527
+#: ../vector/v.vol.rst/user1.c:580 ../vector/v.vol.rst/user1.c:633
+#: ../vector/v.vol.rst/user1.c:686 ../vector/v.vol.rst/user1.c:739
+#: ../vector/v.vol.rst/user1.c:792
+#, c-format
+msgid "Error closing output file %s"
+msgstr ""
+#: ../vector/v.vol.rst/user1.c:476 ../vector/v.vol.rst/user1.c:529
+#: ../vector/v.vol.rst/user1.c:582 ../vector/v.vol.rst/user1.c:635
+#: ../vector/v.vol.rst/user1.c:688 ../vector/v.vol.rst/user1.c:741
+#: ../vector/v.vol.rst/user1.c:794
+#, c-format
+msgid "3D raster map <%s> created"
+msgstr ""
+#: ../vector/v.vol.rst/vector.c:80 ../vector/v.random/main.c:467
+#: ../vector/v.random/main.c:587 ../vector/v.in.lidar/main.c:784
+#: ../vector/v.in.ogr/main.c:1244 ../raster/r.volume/main.c:295
+#: ../raster/r.to.vect/areas_io.c:377 ../raster/r.to.vect/util.c:157
+#, c-format
+msgid "Cannot insert new row: %s"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:58
+#, c-format
+msgid "Init costs from node %d"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:347
+msgid "steiner tree"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:349
+msgid "Creates Steiner tree for the network and given terminals."
+msgstr ""
+#: ../vector/v.net.steiner/main.c:351
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal."
+msgstr ""
+#: ../vector/v.net.steiner/main.c:372
+msgid "Node layer (used for terminals)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:378
+msgid "Arcs' cost column (for both directions)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:384
+msgid "Categories of points on terminals (layer is specified by nlayer)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:392
+msgid "Number of Steiner points (-1 for all possible)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:445 ../vector/v.net.salesman/main.c:242
+#: ../vector/v.net.iso/main.c:205 ../vector/v.net.alloc/main.c:169
+msgid "Point is not connected to the network"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:459
+msgid "Not enough terminals (< 2)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:465
+msgid "Requested number of Steiner points > than possible"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:517
+#, c-format
+msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:533
+#, c-format
+msgid ""
+"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:538
+#, c-format
+msgid "MST costs = %f"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:544
+#, c-format
+msgid "Search for [%d]. Steiner point"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:565
+#, c-format
+msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
+msgstr ""
+#: ../vector/v.net.steiner/main.c:577
+msgid "No Steiner point found -> leaving cycle"
+msgstr ""
+#: ../vector/v.in.db/main.c:53 ../vector/v.in.dwg/main.c:83
+#: ../vector/v.in.lidar/main.c:157 ../vector/v.external/main.c:49
+#: ../vector/v.in.ogr/main.c:134 ../vector/v.in.dxf/main.c:65
+#: ../vector/v.in.ascii/main.c:69
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
+#: ../locale/scriptstrings/r.unpack_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
+#: ../locale/scriptstrings/v.unpack_to_translate.c:3
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
+#: ../raster3d/r3.in.v5d/main.c:179 ../raster3d/r3.in.ascii/main.c:314
+#: ../raster3d/r3.in.bin/main.c:253 ../raster/r.in.png/main.c:520
+#: ../raster/r.in.mat/main.c:92 ../raster/r.in.ascii/main.c:70
+#: ../raster/r.in.xyz/main.c:160 ../raster/r.in.gridatb/main.c:46
+#: ../raster/r.in.poly/main.c:35 ../raster/r.in.lidar/main.c:171
+#: ../raster/r.external/main.c:56 ../raster/r.in.gdal/main.c:87
+#: ../raster/r.in.bin/main.c:258
+msgid "import"
+msgstr ""
+#: ../vector/v.in.db/main.c:55 ../vector/v.kcv/main.c:57
+#: ../vector/v.normal/main.c:74
+msgid "points"
+msgstr ""
+#: ../vector/v.in.db/main.c:57
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../vector/v.in.db/main.c:61
+msgid "Input table name"
+msgstr ""
+#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+msgid "Input DB"
+msgstr ""
+#: ../vector/v.in.db/main.c:75
+msgid "Name of column containing x coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:80
+msgid "Name of column containing y coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:84
+msgid "Name of column containing z coordinate"
+msgstr ""
+#: ../vector/v.in.db/main.c:85 ../vector/v.random/main.c:133
+#: ../vector/v.random/main.c:142 ../vector/v.random/main.c:155
+#: ../vector/v.random/main.c:165 ../vector/v.random/main.c:170
+msgid "3D output"
+msgstr ""
+#: ../vector/v.in.db/main.c:90
+msgid "Name of column containing category number"
+msgstr ""
+#: ../vector/v.in.db/main.c:91
+msgid "Must refer to an integer column"
+msgstr ""
+#: ../vector/v.in.db/main.c:101
+msgid "Use imported table as attribute table for new map"
+msgstr ""
+#: ../vector/v.in.db/main.c:141
+#, c-format
+msgid ""
+"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
+"this map."
+msgstr ""
+#: ../vector/v.in.db/main.c:177
+#, c-format
+msgid ""
+"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr ""
+#: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
+msgid "Data type of key column must be integer"
+msgstr ""
+#: ../vector/v.in.db/main.c:194
+#, c-format
+msgid "Option <%s> must be specified when -%c flag is given"
+msgstr ""
+#: ../vector/v.in.db/main.c:199
+#, c-format
+msgid ""
+"Unable to define key column. This operation is not supported by <%s> driver. "
+"You need to define <%s> option."
+msgstr ""
+#: ../vector/v.in.db/main.c:225 ../display/d.vect/attr.c:110
+#: ../display/d.vect.chart/plot.c:85
+#, c-format
+msgid "Unable to open select cursor: '%s'"
+msgstr ""
+#: ../vector/v.in.db/main.c:235 ../vector/v.voronoi/main.c:322
+msgid "Writing features..."
+msgstr ""
+#: ../vector/v.in.db/main.c:243
+msgid "Key column must be integer"
+msgstr ""
+#: ../vector/v.in.db/main.c:256
+msgid "x/y/z column must be integer or double"
+msgstr ""
+#: ../vector/v.in.db/main.c:282 ../vector/v.to.3d/main.c:96
+#: ../vector/v.to.3d/main.c:117 ../vector/v.net/main.c:150
+#: ../vector/v.transform/main.c:282
+msgid "Copying attributes..."
+msgstr ""
+#: ../vector/v.in.db/main.c:288
+msgid "Unable to copy table"
+msgstr ""
+#: ../vector/v.in.db/main.c:313
+#, c-format
+msgid "Unable to add key column <%s>: SERIAL type is not supported by <%s>"
+msgstr ""
+#: ../vector/v.in.db/main.c:324
+#, c-format
+msgid "Failed to update key column <%s>"
+msgstr ""
+#: ../vector/v.in.db/main.c:340
+#, c-format
+msgid "%d point written to vector map."
+msgid_plural "%d points written to vector map."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.kcv/main.c:56 ../vector/v.random/main.c:98
+#: ../vector/v.class/main.c:48 ../vector/v.perturb/main.c:64
+#: ../vector/v.outlier/main.c:70 ../vector/v.normal/main.c:73
+#: ../vector/v.neighbors/main.c:52 ../vector/v.qcount/main.c:61
+#: ../vector/v.univar/main.c:93
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:4
+#: ../locale/scriptstrings/i.oif_to_translate.c:4
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
+#: ../locale/scriptstrings/db.univar_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:3
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../raster3d/r3.stats/main.c:49 ../raster3d/r3.neighbors/main.c:211
+#: ../raster/r.coin/main.c:67 ../raster/r.stats.quantile/main.c:390
+#: ../raster/r.mode/main.c:56 ../raster/r.quant/main.c:49
+#: ../raster/r.regression.line/main.c:47 ../raster/r.covar/main.c:52
+#: ../raster/r.report/main.c:68 ../raster/r.clump/main.c:52
+#: ../raster/r.stats/main.c:107 ../raster/r.surf.area/main.c:78
+#: ../raster/r.regression.multi/main.c:129 ../raster/r.mfilter/main.c:58
+#: ../raster/r.cross/main.c:70 ../raster/r.univar/r3.univar_main.c:99
+#: ../raster/r.univar/r.univar_main.c:101 ../raster/r.stats.zonal/main.c:102
+#: ../raster/r.support.stats/main.c:39 ../raster/r.kappa/main.c:69
+#: ../raster/r.quantile/main.c:257 ../raster/r.statistics/main.c:56
+#: ../raster/r.neighbors/main.c:169 ../raster/r.texture/main.c:103
+#: ../display/d.histogram/main.c:85 ../imagery/i.cca/main.c:85
+msgid "statistics"
+msgstr ""
+#: ../vector/v.kcv/main.c:58 ../vector/v.random/main.c:100
+#: ../vector/v.perturb/main.c:66 ../vector/v.normal/main.c:75
+#: ../vector/v.mkgrid/main.c:73 ../vector/v.qcount/main.c:62
+msgid "point pattern"
+msgstr ""
+#: ../vector/v.kcv/main.c:60
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../vector/v.kcv/main.c:70
+msgid "Number of partitions"
+msgstr ""
+#: ../vector/v.kcv/main.c:71
+msgid "Must be > 1"
+msgstr ""
+#: ../vector/v.kcv/main.c:76
+msgid "Name for new column to which partition number is written"
+msgstr ""
+#: ../vector/v.kcv/main.c:85
+#, c-format
+msgid "'%s' must be > 1"
+msgstr ""
+#: ../vector/v.kcv/main.c:96 ../vector/v.kcv/main.c:186
+#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:250
+#: ../vector/v.category/main.c:258
+#, c-format
+msgid "Unable to open vector map <%s> at topological level %d"
+msgstr ""
+#: ../vector/v.kcv/main.c:102
+msgid "Layer number must be positive"
+msgstr ""
+#: ../vector/v.kcv/main.c:107
+#, c-format
+msgid "More partitions than points (%d)"
+msgstr ""
+#: ../vector/v.kcv/main.c:120
+#, c-format
+msgid "Unable to get layer info for vector map <%s>"
+msgstr ""
+#: ../vector/v.kcv/main.c:145
+#, c-format
+msgid "Column <%s> already exists but is not numeric"
+msgstr ""
+#: ../vector/v.kcv/main.c:160
+#, c-format
+msgid "Unable to alter table: %s"
+msgstr ""
+#: ../vector/v.kcv/main.c:168 ../vector/v.db.connect/main.c:158
+msgid "Unable to modify vector map stored in other mapset"
+msgstr ""
+#: ../vector/v.kcv/main.c:179 ../vector/v.db.connect/main.c:341
+#, c-format
+msgid "Cannot grant privileges on table %s"
+msgstr ""
+#: ../vector/v.kcv/main.c:182 ../vector/v.db.connect/main.c:344
+msgid "Select privileges were granted on the table"
+msgstr ""
+#: ../vector/v.kcv/main.c:267
+#, c-format
+msgid "No category for line %d in layer %d"
+msgstr ""
+#: ../vector/v.kcv/main.c:284 ../vector/v.sample/main.c:263
+#, c-format
+msgid "Unable to insert row: %s"
+msgstr ""
+#: ../vector/v.kcv/main.c:300
+msgid "internal error"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:48
+msgid "visibility"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:49
+msgid "Performs visibility graph construction."
+msgstr ""
+#: ../vector/v.net.visibility/main.c:60
+msgid "Name of input vector map containing visable points"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:61
+msgid "Add points after computing the visibility graph"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:85
+#, c-format
+msgid "Unable to copy elements from vector map <%s>"
+msgstr ""
+#: ../vector/v.net.visibility/main.c:90
+msgid "Lat-long projection"
+msgstr ""
+#: ../vector/v.info/main.c:38 ../vector/v.support/main.c:40
+#: ../vector/v.timestamp/main.c:36
+#: ../locale/scriptstrings/t.select_to_translate.c:3
+#: ../locale/scriptstrings/t.support_to_translate.c:3
+#: ../locale/scriptstrings/t.info_to_translate.c:3
+#: ../raster3d/r3.info/main.c:76 ../raster3d/r3.support/main.c:50
+#: ../raster/r.support/main.c:56 ../raster/r.timestamp/main.c:36
+#: ../raster/r.describe/main.c:55 ../raster/r.region/main.c:52
+#: ../raster/r.info/main.c:70
+msgid "metadata"
+msgstr ""
+#: ../vector/v.info/main.c:39 ../vector/v.build/main.c:37
+#: ../vector/v.clean/main.c:52 ../vector/v.build.polylines/main.c:112
+#: ../vector/v.out.postgis/main.c:48
+#: ../locale/scriptstrings/v.build.all_to_translate.c:3
+#: ../locale/scriptstrings/t.topology_to_translate.c:3
+msgid "topology"
+msgstr ""
+#: ../vector/v.info/main.c:40 ../locale/scriptstrings/t.info_to_translate.c:4
+#: ../raster3d/r3.info/main.c:78 ../raster/r.info/main.c:71
+msgid "extent"
+msgstr ""
+#: ../vector/v.info/main.c:41 ../raster/r.info/main.c:72
+msgid "history"
+msgstr ""
+#: ../vector/v.info/main.c:42
+msgid "attribute columns"
+msgstr ""
+#: ../vector/v.info/main.c:45
+msgid "Outputs basic information about a vector map."
+msgstr ""
+#: ../vector/v.info/print.c:130
+#, c-format
+msgid "Database connection for map <%s> is not defined in DB file"
+msgstr ""
+#: ../vector/v.info/print.c:134
+#, c-format
+msgid "Displaying column types/names for database connection of layer <%s>:"
+msgstr ""
+#: ../vector/v.info/print.c:142
+#, c-format
+msgid "Unable to open driver <%s>"
+msgstr ""
+#: ../vector/v.info/print.c:305
+msgid "Name:"
+msgstr ""
+#: ../vector/v.info/print.c:308
+msgid "Mapset:"
+msgstr ""
+#: ../vector/v.info/print.c:312
+msgid "Location:"
+msgstr ""
+#: ../vector/v.info/print.c:315
+msgid "Database:"
+msgstr ""
+#: ../vector/v.info/print.c:319
+msgid "Title:"
+msgstr ""
+#: ../vector/v.info/print.c:322
+msgid "Map scale:"
+msgstr ""
+#: ../vector/v.info/print.c:326
+msgid "Name of creator:"
+msgstr ""
+#: ../vector/v.info/print.c:329
+msgid "Organization:"
+msgstr ""
+#: ../vector/v.info/print.c:332
+msgid "Source date:"
+msgstr ""
+#: ../vector/v.info/print.c:339
+msgid "Timestamp (first layer): "
+msgstr ""
+#: ../vector/v.info/print.c:343
+msgid "Timestamp (first layer): none"
+msgstr ""
+#: ../vector/v.info/print.c:351 ../vector/v.info/print.c:375
+#: ../vector/v.info/print.c:415
+msgid "Map format:"
+msgstr ""
+#: ../vector/v.info/print.c:356
+msgid "OGR layer:"
+msgstr ""
+#: ../vector/v.info/print.c:359
+msgid "OGR datasource:"
+msgstr ""
+#: ../vector/v.info/print.c:362 ../vector/v.info/print.c:391
+msgid "Feature type:"
+msgstr ""
+#: ../vector/v.info/print.c:380
+msgid "DB table:"
+msgstr ""
+#: ../vector/v.info/print.c:383
+msgid "DB name:"
+msgstr ""
+#: ../vector/v.info/print.c:387
+msgid "Geometry column:"
+msgstr ""
+#: ../vector/v.info/print.c:401 ../vector/v.info/print.c:410
+msgid "Topology:"
+msgstr ""
+#: ../vector/v.info/print.c:402
+msgid "schema:"
+msgstr ""
+#: ../vector/v.info/print.c:406
+msgid "Topology column:"
+msgstr ""
+#: ../vector/v.info/print.c:424
+msgid "Type of map"
+msgstr ""
+msgid "level"
+msgstr ""
+#: ../vector/v.info/print.c:431
+msgid "Number of points:"
+msgstr ""
+#: ../vector/v.info/print.c:433
+msgid "Number of centroids:"
+msgstr ""
+#: ../vector/v.info/print.c:438
+msgid "Number of lines:"
+msgstr ""
+#: ../vector/v.info/print.c:440
+msgid "Number of boundaries:"
+msgstr ""
+#: ../vector/v.info/print.c:445
+msgid "Number of areas:"
+msgstr ""
+#: ../vector/v.info/print.c:447
+msgid "Number of islands:"
+msgstr ""
+#: ../vector/v.info/print.c:453
+msgid "Number of faces:"
+msgstr ""
+#: ../vector/v.info/print.c:455
+msgid "Number of kernels:"
+msgstr ""
+#: ../vector/v.info/print.c:460
+msgid "Number of volumes:"
+msgstr ""
+#: ../vector/v.info/print.c:462
+msgid "Number of holes:"
+msgstr ""
+#: ../vector/v.info/print.c:469
+msgid "Map is 3D:"
+msgstr ""
+#: ../vector/v.info/print.c:470
+msgid "Yes"
+msgstr ""
+msgid "No"
+msgstr ""
+#: ../vector/v.info/print.c:473
+msgid "Number of dblinks:"
+msgstr ""
+#: ../vector/v.info/print.c:486
+msgid "invalid"
+msgstr ""
+#: ../vector/v.info/print.c:488
+msgid "unspecified"
+msgstr ""
+#: ../vector/v.info/print.c:493 ../vector/v.info/print.c:498
+msgid "Projection"
+msgstr ""
+#: ../vector/v.info/print.c:494
+msgid "zone"
+msgstr ""
+#: ../vector/v.info/print.c:527
+msgid "Digitization threshold"
+msgstr ""
+#: ../vector/v.info/print.c:529
+msgid "Comment"
+msgstr ""
+#: ../vector/v.info/parse.c:24
+msgid "Print history instead of info and exit"
+msgstr ""
+#: ../vector/v.info/parse.c:30
+msgid ""
+"Print types/names of table columns for specified layer instead of info and "
+"exit"
+msgstr ""
+#: ../vector/v.info/parse.c:35
+msgid "Print region info in shell script style"
+msgstr ""
+#: ../vector/v.info/parse.c:40
+msgid "Print extended metadata info in shell script style"
+msgstr ""
+#: ../vector/v.info/parse.c:45
+msgid "Print topology info in shell script style"
+msgstr ""
+#: ../vector/v.to.3d/main.c:38 ../vector/v.hull/main.c:54
+#: ../vector/v.drape/main.c:59 ../vector/v.surf.rst/main.c:144
+#: ../vector/v.extrude/main.c:70 ../vector/v.out.postgis/main.c:49
+msgid "3D"
+msgstr ""
+#: ../vector/v.to.3d/main.c:40
+msgid "Performs transformation of 2D vector features to 3D."
+msgstr ""
+#: ../vector/v.to.3d/main.c:52
+#, c-format
+msgid "Either '%s' or '%s' parameter have to be used"
+msgstr ""
+#: ../vector/v.to.3d/main.c:58
+#, c-format
+msgid "Parameters '%s' ignored"
+msgstr ""
+#: ../vector/v.to.3d/main.c:63
+msgid "Attribute table required"
+msgstr ""
+#: ../vector/v.to.3d/main.c:76
+#, c-format
+msgid "Vector map <%s> is 2D"
+msgstr ""
+#: ../vector/v.to.3d/main.c:80
+#, c-format
+msgid "Vector map <%s> is 3D"
+msgstr ""
+#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:119
+msgid "Unable to copy attributes"
+msgstr ""
+#: ../vector/v.to.3d/main.c:128
+#, c-format
+msgid "Vertical extent of vector map <%s>: B: %f T: %f"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:45 ../vector/v.to.3d/trans2.c:43
+#, c-format
+msgid "Invalid layer number %d, assuming 1"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:69 ../vector/v.to.3d/trans2.c:67
+msgid "Column must be numeric"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:75
+msgid "Reading categories..."
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:80 ../vector/v.to.3d/trans2.c:79
+msgid "Transforming features..."
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:101
+#, c-format
+msgid "Feature id %d has no category - skipping"
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:104
+#, c-format
+msgid "Feature id %d has more categories. Using category %d."
+msgstr ""
+#: ../vector/v.to.3d/trans3.c:130 ../vector/v.to.db/update.c:222
+#, c-format
+msgid "Record (cat %d) does not exist (not updated)"
+msgstr ""
+#: ../vector/v.to.3d/args.c:11
+msgid "Reverse transformation; 3D vector features to 2D"
+msgstr ""
+#: ../vector/v.to.3d/args.c:14
+msgid "Do not copy attribute table"
+msgstr ""
+#: ../vector/v.to.3d/args.c:30
+msgid "Name of attribute column used for height"
+msgstr ""
+#: ../vector/v.to.3d/args.c:32
+msgid "Can be used for reverse transformation, to store height of points"
+msgstr ""
+#: ../vector/v.to.3d/args.c:33 ../vector/v.to.3d/args.c:41
+#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
+#: ../vector/v.extrude/main.c:119
+msgid "Height"
+msgstr ""
+#: ../vector/v.to.3d/args.c:40 ../vector/v.extrude/main.c:112
+msgid "Fixed height for 3D vector features"
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:70
+#, c-format
+msgid "Fetching height from <%s> column..."
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:101
+msgid "Skipping feature without category"
+msgstr ""
+#: ../vector/v.to.3d/trans2.c:116
+#, c-format
+msgid "Unable to get height for feature category %d"
+msgstr ""
+#: ../vector/v.overlay/main.c:64 ../vector/v.select/main.c:49
+msgid "spatial query"
+msgstr ""
+#: ../vector/v.overlay/main.c:65
+msgid "intersection"
+msgstr ""
+#: ../vector/v.overlay/main.c:66
+msgid "union"
+msgstr ""
+#: ../vector/v.overlay/main.c:67
+msgid "clip"
+msgstr ""
+#: ../vector/v.overlay/main.c:68
+msgid "Overlays two vector maps."
+msgstr ""
+#: ../vector/v.overlay/main.c:71
+msgid "Name of input vector map (A)"
+msgstr ""
+#: ../vector/v.overlay/main.c:75
+msgid "Layer number or name (vector map A)"
+msgstr ""
+#: ../vector/v.overlay/main.c:79 ../vector/v.select/args.c:21
+msgid "Feature type (vector map A)"
+msgstr ""
+#: ../vector/v.overlay/main.c:85
+msgid "Name of input vector map (B)"
+msgstr ""
+#: ../vector/v.overlay/main.c:89
+msgid "Layer number or name (vector map B)"
+msgstr ""
+#: ../vector/v.overlay/main.c:93 ../vector/v.select/args.c:36
+msgid "Feature type (vector map B)"
+msgstr ""
+#: ../vector/v.overlay/main.c:104
+msgid "Operator defines features written to output vector map"
+msgstr ""
+#: ../vector/v.overlay/main.c:107
+msgid ""
+"Feature is written to output if the result of operation 'ainput operator "
+"binput' is true. Input feature is considered to be true, if category of "
+"given layer is defined."
+msgstr ""
+#: ../vector/v.overlay/main.c:114
+msgid "also known as 'intersection' in GIS"
+msgstr ""
+#: ../vector/v.overlay/main.c:115
+msgid "also known as 'union' in GIS (only for atype=area)"
+msgstr ""
+#: ../vector/v.overlay/main.c:116
+msgid "features from ainput not overlayed by features from binput"
+msgstr ""
+#: ../vector/v.overlay/main.c:117
+msgid ""
+"features from either ainput or binput but not those from ainput overlayed by "
+"binput (only for atype=area)"
+msgstr ""
+#: ../vector/v.overlay/main.c:128
+msgid "Output layer for new category, ainput and binput"
+msgstr ""
+#: ../vector/v.overlay/main.c:129
+msgid "If 0 or not given, the category is not written"
+msgstr ""
+#: ../vector/v.overlay/main.c:136
+msgid "Snapping threshold for boundaries"
+msgstr ""
+#: ../vector/v.overlay/main.c:137
+msgid "Disable snapping with snap <= 0"
+msgstr ""
+#: ../vector/v.overlay/main.c:171 ../vector/v.select/main.c:84
+#, c-format
+msgid "Unknown operator '%s'"
+msgstr ""
+#: ../vector/v.overlay/main.c:188
+#, c-format
+msgid "Unable to determine feature type for <%s>"
+msgstr ""
+#: ../vector/v.overlay/main.c:194
+#, c-format
+msgid "Invalid feature type (%d) for <%s>. Only '%s' or '%s' supported."
+msgstr ""
+#: ../vector/v.overlay/main.c:202
+#, c-format
+msgid "Operator '%s' is not supported for type line"
+msgstr ""
+#: ../vector/v.overlay/main.c:220 ../vector/v.buffer/main.c:400
+#: ../vector/v.in.ogr/main.c:923
+msgid "Unable to create temporary vector map"
+msgstr ""
+#: ../vector/v.overlay/main.c:257
+#, c-format
+msgid "Copying vector features from <%s>..."
+msgstr ""
+#: ../vector/v.overlay/main.c:338
+#, c-format
+msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
+msgstr ""
+#: ../vector/v.overlay/main.c:387
+msgid "Collecting input attributes..."
+msgstr ""
+#: ../vector/v.overlay/main.c:416 ../vector/v.label.sa/labels.c:162
+#: ../vector/v.label/main.c:319
+msgid "Unable to select attributes"
+msgstr ""
+#: ../vector/v.overlay/main.c:467
+#, c-format
+msgid "Unknown column type '%s' of column '%s'"
+msgstr ""
+#: ../vector/v.overlay/main.c:480 ../vector/v.out.svg/main.c:400
+#: ../vector/v.out.vtk/writeVTK.c:589 ../vector/v.out.ogr/attrb.c:53
+#: ../vector/v.lrs/v.lrs.label/main.c:331
+msgid "Unable to fetch data from table"
+msgstr ""
+#: ../vector/v.overlay/main.c:532
+#, c-format
+msgid "Unknown column type '%s' of column '%s', values lost"
+msgstr ""
+#: ../vector/v.overlay/area_area.c:51
+#, c-format
+msgid "Snapping boundaries with %g ..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:99
+#, c-format
+msgid "%d boundary snapped"
+msgid_plural "%d boundaries snapped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.overlay/area_area.c:109 ../vector/v.overlay/line_area.c:255
+msgid "Breaking lines..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:113 ../vector/v.delaunay/main.c:144
+#: ../vector/v.buffer/main.c:733 ../vector/v.buffer/main.c:740
+#: ../vector/v.in.ogr/main.c:1309 ../vector/v.in.ogr/main.c:1323
+msgid "Removing duplicates..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:116 ../vector/v.in.ogr/main.c:1327
+msgid "Cleaning boundaries at nodes..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:154
+msgid "Merging lines..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:158 ../vector/v.buffer/main.c:757
+msgid "Attaching islands..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:171 ../vector/v.buffer/main.c:778
+msgid "Cannot calculate area centroid"
+msgstr ""
+#: ../vector/v.overlay/area_area.c:181
+#, c-format
+msgid "Querying vector map <%s>..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:208 ../vector/v.overlay/area_area.c:290
+#: ../vector/v.overlay/area_area.c:318 ../vector/v.overlay/line_area.c:354
+#: ../vector/v.overlay/line_area.c:382
+msgid "Attribute not found"
+msgstr ""
+#: ../vector/v.overlay/area_area.c:218 ../vector/v.in.ogr/main.c:1438
+msgid "Writing centroids..."
+msgstr ""
+#: ../vector/v.overlay/area_area.c:345 ../vector/v.overlay/line_area.c:410
+#: ../vector/v.to.points/write.c:52 ../raster/r.contour/main.c:216
+#, c-format
+msgid "Unable to insert new record: '%s'"
+msgstr ""
+#: ../vector/v.overlay/line_area.c:272
+msgid "Selecting lines..."
+msgstr ""
+#: ../vector/v.build/main.c:39
+msgid "Creates topology for vector map."
+msgstr ""
+#: ../vector/v.build/main.c:40
+msgid "Optionaly also checks for topological errors."
+msgstr ""
+#: ../vector/v.build/main.c:44
+msgid "Name of vector map"
+msgstr ""
+#: ../vector/v.build/main.c:49
+msgid ""
+"Name for output vector map where erroneous vector features are written to"
+msgstr ""
+#: ../vector/v.build/main.c:61
+msgid "Build topology or dump topology or indeces to standard output"
+msgstr ""
+#: ../vector/v.build/main.c:65
+msgid "build topology"
+msgstr ""
+#: ../vector/v.build/main.c:66
+msgid "write topology to stdout"
+msgstr ""
+#: ../vector/v.build/main.c:67
+msgid "write spatial index to stdout"
+msgstr ""
+#: ../vector/v.build/main.c:68
+msgid "write category index to stdout"
+msgstr ""
+#: ../vector/v.build/main.c:69
+msgid "write feature index to stdout (OGR simple-feature-based formats only)"
+msgstr ""
+#: ../vector/v.build/main.c:75
+msgid "Extensive checks for topological errors"
+msgstr ""
+#: ../vector/v.build/main.c:76
+msgid "Perform in-depth checks for topological errors when building topology"
+msgstr ""
+#: ../vector/v.build/main.c:106
+#, c-format
+msgid ""
+"Direct read access to OGR layers is not supported by this module. Run %s to "
+"create a link as GRASS vector map in the current mapset."
+msgstr ""
+#: ../vector/v.build/main.c:111
+#, c-format
+msgid "Vector map <%s> is not in current mapset"
+msgstr ""
+#: ../vector/v.random/main.c:97 ../vector/v.what.rast/main.c:72
+#: ../vector/v.drape/main.c:58 ../vector/v.extrude/main.c:69
+#: ../vector/v.sample/main.c:76 ../vector/v.what.rast3/main.c:65
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
+#: ../locale/scriptstrings/t.sample_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
+#: ../raster/r.random/main.c:52 ../raster/r.random.cells/main.c:46
+#: ../display/d.where/main.c:44
+msgid "sampling"
+msgstr ""
+#: ../vector/v.random/main.c:99 ../vector/v.perturb/main.c:65
+#: ../raster/r.surf.random/main.c:38 ../raster/r.random/main.c:54
+#: ../raster/r.surf.gauss/main.c:40 ../raster/r.random.surface/main.c:59
+#: ../raster/r.random.cells/main.c:47
+msgid "random"
+msgstr ""
+#: ../vector/v.random/main.c:101
+msgid "Generates random 2D/3D vector points."
+msgstr ""
+#: ../vector/v.random/main.c:109
+msgid "Number of points to be created"
+msgstr ""
+#: ../vector/v.random/main.c:114
+msgid "Restrict points to areas in input vector"
+msgstr ""
+#: ../vector/v.random/main.c:131
+msgid "Minimum z height (needs -z flag or column name)"
+msgstr ""
+#: ../vector/v.random/main.c:140
+msgid "Maximum z height (needs -z flag or column name)"
+msgstr ""
+#: ../vector/v.random/main.c:149
+msgid ""
+"The seed to initialize the random generator. If not set the process ID is "
+"used"
+msgstr ""
+#: ../vector/v.random/main.c:152
+msgid "Name of column for z values"
+msgstr ""
+#: ../vector/v.random/main.c:154
+msgid "Writes z values to column"
+msgstr ""
+#: ../vector/v.random/main.c:162
+msgid "Type of column for z values"
+msgstr ""
+#: ../vector/v.random/main.c:169
+msgid "Create 3D output"
+msgstr ""
+#: ../vector/v.random/main.c:174
+msgid "Generate n points for each individual area"
+msgstr ""
+#: ../vector/v.random/main.c:188
+#, c-format
+msgid "Number of points must be > 0 (%d given)"
+msgstr ""
+#: ../vector/v.random/main.c:204 ../vector/v.drape/main.c:149
+#: ../vector/v.buffer/main.c:348
+#, c-format
+msgid ""
+"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
+"'1'."
+msgstr ""
+#: ../vector/v.random/main.c:214
+#, c-format
+msgid "No areas in vector map <%s>"
+msgstr ""
+#: ../vector/v.random/main.c:219
+#, c-format
+msgid "The <-%c> flag requires an input vector with areas"
+msgstr ""
+#: ../vector/v.random/main.c:250 ../vector/v.lrs/v.lrs.create/main.c:338
+#: ../vector/v.mkgrid/main.c:341 ../vector/v.mkgrid/main.c:399
+#: ../vector/v.in.dxf/write_vect.c:233 ../vector/v.in.ascii/main.c:409
+#: ../raster/r.volume/main.c:259 ../raster/r.to.vect/main.c:222
+#, c-format
+msgid "Unable to create table: %s"
+msgstr ""
+#: ../vector/v.random/main.c:273
+msgid "Table should contain only two columns"
+msgstr ""
+#: ../vector/v.random/main.c:282
+msgid ""
+"You have created unsupported column type. This module supports only INTEGER "
+"and DOUBLE PRECISION column types."
+msgstr ""
+#: ../vector/v.random/main.c:345
+#, c-format
+msgid ""
+"Selected areas in input vector <%s> do not overlap with the current region"
+msgstr ""
+#: ../vector/v.random/main.c:357
+#, c-format
+msgid "Input vector <%s> does not overlap with the current region"
+msgstr ""
+#: ../vector/v.random/main.c:382
+msgid "Generating points..."
+msgstr ""
+#: ../vector/v.what.rast/main.c:74 ../vector/v.what/main.c:62
+#: ../vector/v.what.rast3/main.c:67
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
+#: ../raster/r.what/main.c:100 ../display/d.where/main.c:45
+msgid "position"
+msgstr ""
+#: ../vector/v.what.rast/main.c:75 ../vector/v.what/main.c:61
+#: ../vector/v.what.rast3/main.c:68
+#: ../locale/scriptstrings/i.spectral_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
+#: ../raster/r.what.color/main.c:89 ../raster/r.what/main.c:99
+#: ../display/d.where/main.c:46
+msgid "querying"
+msgstr ""
+#: ../vector/v.what.rast/main.c:78
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../vector/v.what.rast/main.c:82 ../vector/v.what.rast3/main.c:75
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+msgid "Name of vector points map for which to edit attributes"
+msgstr ""
+#: ../vector/v.what.rast/main.c:92
+msgid "Name of existing raster map to be queried"
+msgstr ""
+#: ../vector/v.what.rast/main.c:97 ../vector/v.what.rast3/main.c:86
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
+msgid "Name of attribute column to be updated with the query result"
+msgstr ""
+#: ../vector/v.what.rast/main.c:104
+msgid "Interpolate values from the nearest four cells"
+msgstr ""
+#: ../vector/v.what.rast/main.c:109
+msgid "Print categories and values instead of updating the database"
+msgstr ""
+#: ../vector/v.what.rast/main.c:169 ../vector/v.to.rast/support.c:318
+#: ../vector/v.to.rast/support.c:471 ../vector/v.to.rast/vect2rast.c:69
+#: ../vector/v.what.rast3/main.c:140
+#, c-format
+msgid "Column <%s> not found"
+msgstr ""
+#: ../vector/v.what.rast/main.c:172 ../vector/v.class/main.c:129
+#: ../vector/v.surf.bspline/main.c:399
+#: ../vector/v.surf.bspline/crosscorr.c:133 ../vector/v.buffer/main.c:434
+#: ../vector/v.surf.idw/read_sites.c:65 ../vector/v.sample/main.c:240
+#: ../vector/v.to.rast3/main.c:99
+msgid "Column type not supported"
+msgstr ""
+#: ../vector/v.what.rast/main.c:175
+msgid "Raster type is integer and column type is float"
+msgstr ""
+#: ../vector/v.what.rast/main.c:178
+msgid "Raster type is float and column type is integer, some data lost!!"
+msgstr ""
+#: ../vector/v.what.rast/main.c:194 ../vector/v.what.rast3/main.c:157
+msgid "Reading features from vector map..."
+msgstr ""
+#: ../vector/v.what.rast/main.c:264
+#, c-format
+msgid "%d points outside current region were skipped"
+msgstr ""
+#: ../vector/v.what.rast/main.c:268
+#, c-format
+msgid "%d points without category were skipped"
+msgstr ""
+#: ../vector/v.what.rast/main.c:539 ../vector/v.what.rast/main.c:579
+#, c-format
+msgid "Multiple points (%d) of category %d, value set to 'NULL'"
+msgstr ""
+#: ../vector/v.what.rast/main.c:647
+#, c-format
+msgid "%d categories loaded from vector"
+msgstr ""
+#: ../vector/v.what.rast/main.c:649
+#, c-format
+msgid "%d duplicate categories in vector"
+msgstr ""
+#: ../vector/v.what.rast/main.c:652
+#, c-format
+msgid "%d categories loaded from table"
+msgstr ""
+#: ../vector/v.what.rast/main.c:653
+#, c-format
+msgid "%d categories from vector missing in table"
+msgstr ""
+#: ../vector/v.what.rast/main.c:656 ../vector/v.vect.stats/main.c:710
+#: ../vector/v.distance/main.c:1664
+#, c-format
+msgid "%d update errors"
+msgstr ""
+#: ../vector/v.what.rast/main.c:658 ../vector/v.distance/main.c:1666
+#, c-format
+msgid "%d records updated."
+msgstr ""
+#: ../vector/v.vect.stats/main.c:131 ../vector/v.univar/main.c:94
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
+#: ../raster/r.univar/r3.univar_main.c:100
+#: ../raster/r.univar/r.univar_main.c:102
+msgid "univariate statistics"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:132
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
+#: ../raster/r.univar/r.univar_main.c:103
+msgid "zonal statistics"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:133
+msgid "Count points in areas, calculate statistics from point attributes."
+msgstr ""
+#: ../vector/v.vect.stats/main.c:137
+msgid "Name of existing vector map with points"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:142
+msgid "Name of existing vector map with areas"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:149 ../vector/v.net.bridge/main.c:101
+#: ../vector/v.to.db/parse.c:41
+msgid "Feature type"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:154
+msgid "Layer number for points map"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:158
+msgid "Layer number for area map"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:174
+msgid "Method for aggregate statistics"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:181
+msgid "Column name of points map to use for statistics"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:182
+msgid "Column of points map must be numeric"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:189
+msgid "Column name to upload points count"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:191
+msgid ""
+"Column to hold points count, must be of type integer, will be created if not "
+"existing"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:198
+msgid "Column name to upload statistics"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:200
+msgid ""
+"Column to hold statistics, must be of type double, will be created if not "
+"existing"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:207
+msgid "Print output to stdout, do not update attribute table"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:208
+msgid "First column is always area category"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:252
+#, c-format
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:268 ../raster/r.proj/main.c:237
+#: ../raster/r.stats.zonal/main.c:164 ../raster/r.statistics/main.c:117
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:152
+#: ../imagery/i.rectify/main.c:172
+#, c-format
+msgid "<%s=%s> unknown %s"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:304
+msgid "count_column is required to upload point counts"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:313
+msgid "count_column must be of type integer"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:326 ../vector/v.vect.stats/main.c:356
+#, c-format
+msgid "Unable to add column <%s>"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:332
+msgid "stats_column is required to upload point stats"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:343
+msgid "stats_column must be of type double precision"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:367
+msgid "collecting attributes from points vector..."
+msgstr ""
+#: ../vector/v.vect.stats/main.c:408
+msgid "column for points vector must be numeric"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:483
+msgid "Selecting points for each area..."
+msgstr ""
+#: ../vector/v.vect.stats/main.c:580
+#, c-format
+msgid "could not find area category %d"
+msgstr ""
+#: ../vector/v.vect.stats/main.c:708
+#, c-format
+msgid "%d records updated"
+msgstr ""
+#: ../vector/v.to.rast/support.c:142 ../vector/v.to.rast/support.c:301
+#: ../vector/v.to.rast/support.c:454
+#, c-format
+msgid "Unknown column <%s> in table <%s>"
+msgstr ""
+#: ../vector/v.to.rast/support.c:146 ../vector/v.to.rast/support.c:305
+#: ../vector/v.to.rast/support.c:458 ../vector/v.to.rast/vect2rast.c:78
+#: ../vector/v.reclass/main.c:241
+#, c-format
+msgid "No records selected from table <%s>"
+msgstr ""
+#: ../vector/v.to.rast/support.c:163 ../vector/v.to.rast/support.c:330
+msgid "No records selected"
+msgstr ""
+#: ../vector/v.to.rast/support.c:176
+#, c-format
+msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
+msgstr ""
+#: ../vector/v.to.rast/support.c:179
+msgid "Color set to [200:200:200]"
+msgstr ""
+#: ../vector/v.to.rast/support.c:184
+#, c-format
+msgid "Error in color definition column (%s), with cat %d"
+msgstr ""
+#: ../vector/v.to.rast/support.c:273
+msgid "Label column was not specified, no labels will be written"
+msgstr ""
+#: ../vector/v.to.rast/support.c:353 ../vector/v.to.rast/support.c:500
+#, c-format
+msgid "Column type (%s) not supported"
+msgstr ""
+#: ../vector/v.to.rast/support.c:576 ../vector/v.to.rast/vect2rast.c:122
+#, c-format
+msgid "Unknown use type: %d"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:36
+msgid "Loading data..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:74
+#, c-format
+msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:104
+#, c-format
+msgid "Unable to use column <%s>"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:131
+#, c-format
+msgid "No areas selected from vector map <%s>"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:147
+#, c-format
+msgid "Pass %d of %d:"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:155
+#, c-format
+msgid "Problem processing areas from vector map <%s>, continuing..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:167
+#, c-format
+msgid "Problem processing lines from vector map <%s>, continuing..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:174 ../raster/r.in.poly/poly2rast.c:81
+#: ../raster/r.carve/raster.c:33
+msgid "Writing raster map..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:192
+msgid "Creating support files for raster map..."
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:199
+msgid "Color can be updated from database only if use=attr"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:219
+#, c-format
+msgid "Converted areas: %d of %d"
+msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:222
+#, c-format
+msgid "Converted points/lines: %d of %d"
+msgstr ""
+#: ../vector/v.to.rast/main.c:45 ../vector/v.to.rast3/main.c:49
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
+#: ../raster3d/r3.to.rast/main.c:207 ../raster3d/r3.in.ascii/main.c:316
+#: ../raster3d/r3.out.ascii/main.c:305 ../raster/r.in.ascii/main.c:71
+#: ../raster/r.in.xyz/main.c:161 ../raster/r.to.rast3elev/main.c:362
+#: ../raster/r.to.rast3/main.c:198 ../raster/r.to.vect/main.c:71
+msgid "conversion"
+msgstr ""
+#: ../vector/v.to.rast/main.c:47
+msgid "rasterization"
+msgstr ""
+#: ../vector/v.to.rast/main.c:48
+msgid "Converts (rasterize) a vector map into a raster map."
+msgstr ""
+#: ../vector/v.to.rast/main.c:73
+msgid "Source of raster values"
+msgstr ""
+#: ../vector/v.to.rast/main.c:77
+msgid "read values from attribute table"
+msgstr ""
+#: ../vector/v.to.rast/main.c:79
+msgid "use value specified by value option"
+msgstr ""
+#: ../vector/v.to.rast/main.c:80
+msgid "use z coordinate (points or contours only)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:81
+msgid "output as flow direction (lines only)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:87
+msgid "Name of column for 'attr' parameter (data type must be numeric)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:93
+msgid "Name of color definition column (with RRR:GGG:BBB entries)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:99
+msgid "Name of column used as raster category labels"
+msgstr ""
+#: ../vector/v.to.rast/main.c:108
+msgid "Raster value (for use=val)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:116 ../vector/v.surf.bspline/main.c:194
+#: ../raster/r.proj/main.c:191 ../raster/r.stream.extract/main.c:141
+#: ../raster/r.in.gdal/main.c:112 ../raster/r.resamp.bspline/main.c:151
+msgid "Maximum memory to be used (in MB)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:117 ../vector/v.surf.bspline/main.c:195
+#: ../raster/r.proj/main.c:192 ../raster/r.stream.extract/main.c:142
+#: ../raster/r.in.gdal/main.c:113 ../raster/r.resamp.bspline/main.c:152
+msgid "Cache size for raster rows"
+msgstr ""
+#: ../vector/v.to.rast/main.c:121
+msgid "Create densified lines (default: thin lines)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:122
+msgid ""
+"All cells touched by the line will be set, not only those on the render path"
+msgstr ""
+#: ../vector/v.to.rast/main.c:132
+#, c-format
+msgid "Cache size must be at least 1 MiB, changing %d to 1"
+msgstr ""
+#: ../vector/v.to.rast/main.c:141
+msgid "Column parameter missing (or use value parameter)"
+msgstr ""
+#: ../vector/v.to.rast/main.c:146
+msgid "Column parameter cannot be combined with use of category values option"
+msgstr ""
+#: ../vector/v.to.rast/main.c:151
+msgid "Column parameter cannot be combined with use of value option"
+msgstr ""
+#: ../vector/v.to.rast/main.c:156
+msgid "Column parameter cannot be combined with use of z coordinate"
+msgstr ""
+#: ../vector/v.to.rast/main.c:162
+#, c-format
+msgid "Unknown option '%s'"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:34 ../vector/v.to.db/areas.c:28
+msgid "Reading areas..."
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:50 ../vector/v.to.rast/do_areas.c:58
+#, c-format
+msgid "No record for area (cat = %d)"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:64 ../vector/v.to.rast/do_lines.c:73
+msgid "Unable to use column specified"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:79
+#, c-format
+msgid "Get area %d failed"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:117
+msgid "Area without centroid (OK for island)"
+msgstr ""
+#: ../vector/v.to.rast/do_areas.c:127
+msgid "Area centroid without category"
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:59 ../vector/v.to.rast/do_lines.c:67
+#: ../vector/v.to.rast3/main.c:145
+#, c-format
+msgid "No record for line (cat = %d)"
+msgstr ""
+#: ../vector/v.to.rast/do_lines.c:133
+#, c-format
+msgid "%d lines with varying height were not written to raster"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:98
+msgid "centrality measures"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:100
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
+msgstr ""
+#: ../vector/v.net.centrality/main.c:148
+msgid "Name of degree centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:149 ../vector/v.net.centrality/main.c:155
+#: ../vector/v.net.centrality/main.c:161 ../vector/v.net.centrality/main.c:167
+msgid "Columns"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:154
+msgid "Name of closeness centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:160
+msgid "Name of betweenness centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:166
+msgid "Name of eigenvector centrality column"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:175
+msgid "Maximum number of iterations to compute eigenvector centrality"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:183
+msgid "Cumulative error tolerance for eigenvector centrality"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:192 ../vector/v.net.components/main.c:130
+msgid "Add points on nodes"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:284
+#: ../vector/v.net.connectivity/main.c:178
+#: ../vector/v.net.components/main.c:162 ../vector/v.generalize/network.c:89
+#: ../vector/v.net.bridge/main.c:134 ../vector/v.net.distance/main.c:239
+#: ../vector/v.net.spanningtree/main.c:124
+#: ../vector/v.net.timetable/main.c:405 ../vector/v.net.flow/main.c:226
+#, c-format
+msgid "Unable to build graph for vector map <%s>"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:321
+msgid "Computing degree centrality measure"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:325
+msgid "Computing betweenness and/or closeness centrality measure"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:332
+msgid "Computing eigenvector centrality measure"
+msgstr ""
+#: ../vector/v.net.centrality/main.c:339
+msgid "Writing data into the table..."
+msgstr ""
+#: ../vector/v.segment/main.c:64 ../vector/v.split/main.c:58
+msgid "segment"
+msgstr ""
+#: ../vector/v.segment/main.c:67
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../vector/v.segment/main.c:70
+msgid "Name of input vector lines map"
+msgstr ""
+#: ../vector/v.segment/main.c:79
+msgid "Name of file containing segment rules"
+msgstr ""
+#: ../vector/v.segment/main.c:146 ../vector/v.segment/main.c:190
+#, c-format
+msgid "Unable to read input: %s"
+msgstr ""
+#: ../vector/v.segment/main.c:157 ../vector/v.segment/main.c:201
+#, c-format
+msgid "Unable to find line of cat %d"
+msgstr ""
+#: ../vector/v.segment/main.c:172
+#, c-format
+msgid ""
+"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
+"%s"
+msgstr ""
+#: ../vector/v.segment/main.c:226
+msgid "End of segment > line length -> cut"
+msgstr ""
+#: ../vector/v.segment/main.c:232
+#, c-format
+msgid ""
+"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
+"%s"
+msgstr ""
+#: ../vector/v.segment/main.c:254 ../vector/v.lrs/v.lrs.segment/main.c:336
+#, c-format
+msgid "Incorrect segment type: %s"
+msgstr ""
+#: ../vector/v.segment/main.c:261
+#, c-format
+msgid "%d point read from input"
+msgid_plural "%d points read from input"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC Number of lost points
+#. GTC Number of lost lines
+#: ../vector/v.segment/main.c:265 ../vector/v.segment/main.c:276
+#: ../vector/v.lrs/v.lrs.segment/main.c:359
+#: ../vector/v.lrs/v.lrs.segment/main.c:371
+#, c-format
+msgid "%d lost"
+msgid_plural "%d lost"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s is replaced with message indicating number of lost points.
+#: ../vector/v.segment/main.c:267
+#, c-format
+msgid "%d point written to output map (%s)"
+msgid_plural "%d points written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.segment/main.c:272
+#, c-format
+msgid "%d line read from input"
+msgid_plural "%d lines read from input"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s is replaced with message indicating number of lost lines.
+#: ../vector/v.segment/main.c:278
+#, c-format
+msgid "%d line written to output map (%s)"
+msgid_plural "%d lines written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.type/main.c:41 ../vector/v.category/main.c:693
+#: ../vector/v.buffer/main.c:224
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:4
+msgid "area"
+msgstr ""
+#: ../vector/v.type/main.c:44
+msgid "Changes type of vector features."
+msgstr ""
+#: ../vector/v.type/main.c:57
+msgid "Feature type to convert from"
+msgstr ""
+#: ../vector/v.type/main.c:65
+msgid "Feature type to convert to"
+msgstr ""
+#: ../vector/v.type/main.c:120
+msgid "Incompatible types"
+msgstr ""
+#: ../vector/v.type/main.c:155 ../vector/v.net/main.c:152
+#: ../vector/v.category/main.c:761 ../vector/v.proj/main.c:497
+#: ../vector/v.transform/main.c:284 ../vector/v.rectify/main.c:276
+#: ../vector/v.build.polylines/main.c:242
+msgid "Failed to copy attribute table to output map"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:128
+msgid "salesman"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:130
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
+msgstr ""
+#: ../vector/v.net.salesman/main.c:132
+msgid ""
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:151
+msgid "Node layer (used for cities)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:163
+msgid "EXPERIMENTAL: Arc backward direction cost column (number)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:169
+msgid "Name for output file holding node sequence (\"-\" for stdout)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:174
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:250
+#, c-format
+msgid "Number of cities: %d"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:252
+msgid "Not enough cities (< 2)"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:288
+msgid "Creating cost cache..."
+msgstr ""
+#: ../vector/v.net.salesman/main.c:309 ../vector/v.net.salesman/main.c:319
+#, c-format
+msgid "No point at node %d"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:313 ../vector/v.net.salesman/main.c:323
+#, c-format
+msgid "No category for point at node %d"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:325
+#, c-format
+msgid "Destination node [cat %d] is unreachable from node [cat %d]"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:368
+msgid "Searching for the shortest cycle..."
+msgstr ""
+#: ../vector/v.net.salesman/main.c:496
+#, c-format
+msgid "Cycle with total cost %.3f"
+msgstr ""
+#: ../vector/v.net.salesman/main.c:521 ../vector/v.rectify/main.c:170
+#, c-format
+msgid "Unable to open file '%s' for writing"
+msgstr ""
+#: ../vector/v.net.iso/main.c:73
+msgid "isolines"
+msgstr ""
+#: ../vector/v.net.iso/main.c:74
+msgid "Splits net by cost isolines."
+msgstr ""
+#: ../vector/v.net.iso/main.c:77
+msgid ""
+"Splits net to bands between cost isolines (direction from center). Center "
+"node must be opened (costs >= 0). Costs of center node are used in "
+"calculation."
+msgstr ""
+#: ../vector/v.net.iso/main.c:119 ../vector/v.net.alloc/main.c:116
+msgid ""
+"Categories of centers (points on nodes) to which net will be allocated, "
+"layer for this categories is given by nlayer option"
+msgstr ""
+#: ../vector/v.net.iso/main.c:128
+msgid "Costs for isolines"
+msgstr ""
+#: ../vector/v.net.iso/main.c:165
+#, c-format
+msgid "Wrong iso cost: %f"
+msgstr ""
+#: ../vector/v.net.iso/main.c:168
+#, c-format
+msgid "Iso cost: %f less than previous"
+msgstr ""
+#: ../vector/v.net.iso/main.c:170
+#, c-format
+msgid "Iso cost %d: %f"
+msgstr ""
+#: ../vector/v.net.iso/main.c:177
+msgid "Not enough costs, everything reachable falls to first band"
+msgstr ""
+#: ../vector/v.net.iso/main.c:213
+msgid "Centre at closed node (costs = -1) ignored"
+msgstr ""
+#: ../vector/v.net.iso/main.c:231
+#, c-format
+msgid "Number of centres: %d (nlayer %d)"
+msgstr ""
+#: ../vector/v.net.iso/main.c:234
+msgid "Not enough centres for selected nlayer. Nothing will be allocated."
+msgstr ""
+#: ../vector/v.net.iso/main.c:254
+#, c-format
+msgid "Calculating costs from centre %d..."
+msgstr ""
+#: ../vector/v.net.iso/main.c:517 ../vector/v.net.alloc/main.c:351
+#: ../vector/v.net.alloc/main.c:362
+msgid "Cannot get line segment, segment out of line"
+msgstr ""
+#: ../vector/v.out.svg/main.c:76
+msgid "Exports a vector map to SVG file."
+msgstr ""
+#: ../vector/v.out.svg/main.c:85
+msgid "Name for SVG output file"
+msgstr ""
+#: ../vector/v.out.svg/main.c:94
+msgid "Output type"
+msgstr ""
+#: ../vector/v.out.svg/main.c:95
+msgid "Defines which feature-type will be extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:103
+msgid "Coordinate precision"
+msgstr ""
+#: ../vector/v.out.svg/main.c:109
+msgid "Attribute(s) to include in output SVG"
+msgstr ""
+#: ../vector/v.out.svg/main.c:130
+msgid "Precision must not be negative"
+msgstr ""
+#: ../vector/v.out.svg/main.c:133
+msgid "Precision must not be higher than 15"
+msgstr ""
+#: ../vector/v.out.svg/main.c:201
+#, c-format
+msgid "Unable to create SVG file <%s>"
+msgstr ""
+#: ../vector/v.out.svg/main.c:218
+#, c-format
+msgid "No areas found, skipping %s"
+msgstr ""
+#: ../vector/v.out.svg/main.c:233 ../vector/v.extrude/main.c:275
+#, c-format
+msgid "Skipping area %d without centroid"
+msgstr ""
+#: ../vector/v.out.svg/main.c:259
+#, c-format
+msgid "%d areas extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:266
+#, c-format
+msgid "No points found, skipping %s"
+msgstr ""
+#: ../vector/v.out.svg/main.c:295
+#, c-format
+msgid "%d points extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:302
+#, c-format
+msgid "No lines found, skipping %s"
+msgstr ""
+#: ../vector/v.out.svg/main.c:329
+#, c-format
+msgid "%d lines extracted"
+msgstr ""
+#: ../vector/v.out.svg/main.c:396
+#, c-format
+msgid "Cannot select attributes for cat=%d"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:54
+msgid "connectivity"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:56
+msgid "Computes vertex connectivity between two sets of nodes in the network."
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:96
+msgid "Set1 category values"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:97
+#: ../vector/v.net.connectivity/main.c:103
+msgid "Set1"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:102
+msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:107
+msgid "Set2 category values"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:108
+#: ../vector/v.net.connectivity/main.c:114
+msgid "Set2"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:113
+msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:146
+#: ../vector/v.net.connectivity/main.c:153
+#, c-format
+msgid "No features for %s selected. Please check options '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.connectivity/main.c:167
+#: ../vector/v.net.connectivity/main.c:170
+#, c-format
+msgid "%s is empty"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:51
+msgid "Exports a vector map to a GRASS ASCII vector representation."
+msgstr ""
+#: ../vector/v.out.ascii/main.c:52
+msgid ""
+"By default only features with category are exported. To export all features "
+"use 'layer=-1'."
+msgstr ""
+#: ../vector/v.out.ascii/main.c:60
+#, c-format
+msgid "Parameter '%s' ignored in standard mode"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:69
+#, c-format
+msgid "Format '%s' is not supported for old version"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:73
+#, c-format
+msgid "Parameter '%s' must be given for old version"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:80
+#, c-format
+msgid ""
+"Unable to open vector map <%s> at topology level. Areas will not be "
+"processed."
+msgstr ""
+#: ../vector/v.out.ascii/main.c:107
+#, c-format
+msgid "%d error in <%s> option"
+msgid_plural "%d errors in <%s> option"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ascii/main.c:141
+msgid "dig_att file already exist"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:144
+#, c-format
+msgid "Unable to open dig_att file <%s>"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:149
+msgid "Fetching data..."
+msgstr ""
+#: ../vector/v.out.ascii/main.c:156
+msgid "No points found, nothing to be exported"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:159
+msgid "No features found, nothing to be exported"
+msgstr ""
+#: ../vector/v.out.ascii/main.c:163
+msgid "An error occured, nothing to be exported"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:31
+msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:33 ../general/g.list/main.c:138
+msgid "If not given or '-' then standard output"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:35 ../vector/v.out.ascii/args.c:81
+#: ../vector/v.in.ogr/main.c:161 ../vector/v.in.ogr/main.c:265
+#: ../vector/v.in.ogr/main.c:271
+#: ../locale/scriptstrings/i.spectral_to_translate.c:10
+#: ../locale/scriptstrings/i.spectral_to_translate.c:12
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:22
+#: ../locale/scriptstrings/m.proj_to_translate.c:24
+#: ../locale/scriptstrings/m.proj_to_translate.c:26
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:8
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:10
+#: ../raster/r.spread/main.c:276 ../raster/r.spread/main.c:288
+#: ../raster/r.spread/main.c:300 ../raster/r.grow.distance/main.c:162
+#: ../raster/r.grow.distance/main.c:168
+#: ../raster/r.sim/r.sim.sediment/main.c:173
+#: ../raster/r.sim/r.sim.sediment/main.c:180
+#: ../raster/r.sim/r.sim.sediment/main.c:187
+#: ../raster/r.sim/r.sim.sediment/main.c:193
+#: ../raster/r.sim/r.sim.sediment/main.c:200
+#: ../raster/r.sim/r.sim.sediment/main.c:207
+#: ../raster/r.sim/r.sim.sediment/main.c:214
+#: ../raster/r.sim/r.sim.water/main.c:192
+#: ../raster/r.sim/r.sim.water/main.c:198
+#: ../raster/r.sim/r.sim.water/main.c:204
+#: ../raster/r.sim/r.sim.water/main.c:211
+#: ../raster/r.sim/r.sim.water/main.c:218
+#: ../raster/r.sim/r.sim.water/main.c:293 ../raster/r.sun/main.c:391
+#: ../raster/r.sun/main.c:400 ../raster/r.sun/main.c:409
+#: ../raster/r.sun/main.c:418 ../raster/r.sun/main.c:427
+#: ../raster/r.sun/main.c:436 ../raster/r.resamp.rst/main.c:174
+#: ../raster/r.resamp.rst/main.c:180 ../raster/r.resamp.rst/main.c:186
+#: ../raster/r.resamp.rst/main.c:192 ../raster/r.resamp.rst/main.c:198
+#: ../raster/r.resamp.rst/main.c:204 ../raster/r.resamp.rst/main.c:264
+msgid "Output"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:38
+msgid "Name of attribute column(s) to be exported (point mode)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:39
+msgid "\"*\" for all columns"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:40 ../vector/v.out.ascii/args.c:66
+#: ../vector/v.out.ascii/args.c:76 ../vector/v.out.ascii/args.c:86
+#: ../vector/v.out.ascii/args.c:92 ../vector/v.in.ascii/main.c:115
+#: ../vector/v.in.ascii/main.c:122 ../vector/v.in.ascii/main.c:134
+#: ../vector/v.in.ascii/main.c:144 ../vector/v.in.ascii/main.c:154
+#: ../vector/v.in.ascii/main.c:164 ../vector/v.in.ascii/main.c:188
+#: ../vector/v.in.ascii/main.c:192 ../vector/v.in.ascii/main.c:198
+#: ../vector/v.in.ascii/main.c:203 ../raster/r.random/main.c:97
+msgid "Points"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:59
+msgid "Simple point format (point per row)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:60
+msgid "GRASS ASCII vector format"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:61
+msgid "OGC well-known text"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:65
+msgid "Field separator (points mode)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:75 ../vector/v.out.vtk/main.c:70
+#: ../raster3d/r3.out.vtk/parameters.c:107 ../raster/r.out.vtk/parameters.c:98
+#: ../raster/r.out.ascii/main.c:79 ../display/d.rast.num/main.c:103
+msgid "Number of significant digits (floating point only)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:80
+msgid "Create old (version 4) ASCII file"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:85
+msgid "Include column names in output (points mode)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:91
+msgid "Only export points falling within current 3D region (points mode)"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:109 ../vector/v.out.vtk/main.c:153
+msgid "Failed to interpret 'dp' parameter as an integer"
+msgstr ""
+#: ../vector/v.colors.out/main.c:53
+msgid "Exports the color table associated with a vector map."
+msgstr ""
+#: ../vector/v.colors.out/main.c:61 ../raster/r.colors.out/raster_main.c:55
+#: ../raster/r.colors.out/raster3d_main.c:56
+msgid "Path to output rules file"
+msgstr ""
+#: ../vector/v.colors.out/main.c:62 ../raster/r.colors.out/raster_main.c:56
+#: ../raster/r.colors.out/raster3d_main.c:57 ../raster/r.kappa/main.c:89
+msgid "If not given write to standard output"
+msgstr ""
+#: ../vector/v.colors.out/main.c:66
+msgid "Name of attribute (numeric) column to which refer color rules"
+msgstr ""
+#: ../vector/v.colors.out/main.c:67
+msgid "If not given, color rules refer to categories"
+msgstr ""
+#: ../vector/v.colors.out/main.c:72 ../raster/r.colors.out/raster_main.c:61
+#: ../raster/r.colors.out/raster3d_main.c:62
+msgid "Output values as percentages"
+msgstr ""
+#: ../vector/v.colors.out/main.c:85
+#, c-format
+msgid "Unable to read color table for vector map <%s>"
+msgstr ""
+#: ../vector/v.colors.out/main.c:88
+#, c-format
+msgid "No color table defined for vector map <%s>"
+msgstr ""
+#: ../vector/v.colors.out/main.c:103 ../raster3d/r3.support/main.c:153
+#: ../general/g.cairocomp/main.c:66 ../raster/r.support/main.c:166
+#: ../raster/r.out.png/main.c:205 ../raster/r.colors.out/raster_main.c:79
+#: ../raster/r.colors.out/raster3d_main.c:80 ../raster/r.out.vrml/main.c:131
+#: ../raster/r.out.mat/main.c:91 ../raster/r.out.pov/main.c:173
+#, c-format
+msgid "Unable to open output file <%s>"
+msgstr ""
+#: ../vector/v.net.components/main.c:73
+msgid "components"
+msgstr ""
+#: ../vector/v.net.components/main.c:75
+msgid "Computes strongly and weakly connected components in the network."
+msgstr ""
+#: ../vector/v.net.components/main.c:123
+msgid "Weakly connected components"
+msgstr ""
+#: ../vector/v.net.components/main.c:124
+msgid "Strongly connected components"
+msgstr ""
+#: ../vector/v.net.components/main.c:126
+msgid "Type of components"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:84
+msgid "Converts DWG/DXF to GRASS vector map"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:87
+msgid "Name of DWG or DXF file"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:97
+msgid "List of layers to import"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:102
+msgid "Invert selection by layers (don't import layers in list)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:106 ../vector/v.in.ascii/main.c:172
+msgid "Create 3D vector map"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:110
+msgid "Write circles as points (centre)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:114
+msgid "List available layers and exit"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:118
+msgid "Use numeric type for attribute \"layer\""
+msgstr ""
+#: ../vector/v.in.dwg/main.c:138
+#, c-format
+msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
+msgstr ""
+#: ../vector/v.in.dwg/main.c:141
+#, c-format
+msgid "%s Cannot open %s"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:149
+#, c-format
+msgid "Unable to open input file <%s>. Error %d: %s"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:244 ../vector/v.reclass/main.c:322
+#: ../vector/v.in.lidar/main.c:617 ../vector/v.in.ogr/main.c:1628
+#: ../vector/v.in.dxf/write_vect.c:241 ../vector/v.to.points/main.c:187
+#: ../vector/v.in.ascii/main.c:517 ../raster/r.contour/main.c:188
+#, c-format
+msgid "Unable to create index for table <%s>, key <%s>"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:287
+#, c-format
+msgid "%d elements skipped (layer name was not in list)"
+msgstr ""
+#: ../vector/v.in.dwg/main.c:290
+#, c-format
+msgid "%d elements processed"
+msgstr ""
+#: ../vector/v.select/main.c:51
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+#: ../vector/v.select/main.c:93
+msgid "Operator can only be 'overlap'"
+msgstr ""
+#: ../vector/v.select/main.c:124
+msgid "Output from v.select"
+msgstr ""
+#: ../vector/v.select/main.c:175
+#, c-format
+msgid "%d features from <%s> without category skipped"
+msgstr ""
+#: ../vector/v.select/main.c:184
+#, c-format
+msgid "%d features written to output."
+msgstr ""
+#: ../vector/v.select/copy_tabs.c:51
+#, c-format
+msgid "No table for layer %d"
+msgstr ""
+#: ../vector/v.select/copy_tabs.c:66
+#, c-format
+msgid "Unable to copy table for layer %d"
+msgstr ""
+#: ../vector/v.select/args.c:12
+msgid "Input vector map from which to select features (A)"
+msgstr ""
+#: ../vector/v.select/args.c:16
+msgid "Layer number (vector map A)"
+msgstr ""
+#: ../vector/v.select/args.c:27
+msgid "Query vector map (B)"
+msgstr ""
+#: ../vector/v.select/args.c:31
+msgid "Layer number (vector map B)"
+msgstr ""
+#: ../vector/v.select/args.c:49
+msgid "Operator defines required relation between features"
+msgstr ""
+#: ../vector/v.select/args.c:51
+msgid ""
+"A feature is written to output if the result of operation 'ainput operator "
+"binput' is true. An input feature is considered to be true, if category of "
+msgstr ""
+#: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
+msgid "features partially or completely overlap"
+msgstr ""
+#: ../vector/v.select/args.c:76
+msgid "features are spatially equals (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:77
+msgid "features do not spatially intersect (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:78
+msgid "features spatially intersect (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:79
+msgid "features spatially touches (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:80
+msgid "features spatially crosses (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:81
+msgid "feature A is completely inside feature B (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:82
+msgid "feature B is completely inside feature A (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:83
+msgid "features spatially overlap (using GEOS)"
+msgstr ""
+#: ../vector/v.select/args.c:84
+msgid ""
+"feature A is spatially related to feature B (using GEOS, requires 'relate' "
+"option)"
+msgstr ""
+#: ../vector/v.select/args.c:94
+msgid "Intersection Matrix Pattern used for 'relate' operator"
+msgstr ""
+#: ../vector/v.select/args.c:101
+msgid "Do not skip features without category"
+msgstr ""
+#: ../vector/v.select/write.c:26
+msgid "Writing selected features..."
+msgstr ""
+#: ../vector/v.select/select.c:40 ../vector/v.drape/main.c:176
+#: ../vector/v.category/main.c:332
+msgid "Processing features..."
+msgstr ""
+#: ../vector/v.select/select.c:64
+#, c-format
+msgid "Unable to read line id %d from vector map <%s>"
+msgstr ""
+#: ../vector/v.select/select.c:167 ../vector/v.out.pov/main.c:175
+msgid "Processing areas..."
+msgstr ""
+#: ../vector/v.select/select.c:191
+#, c-format
+msgid "Unable to read area id %d from vector map <%s>"
+msgstr ""
+#: ../vector/v.distance/main.c:95
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+#: ../vector/v.distance/main.c:99
+msgid "Name of existing vector map (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:100 ../vector/v.distance/main.c:105
+#: ../vector/v.distance/main.c:112 ../vector/v.distance/main.c:156
+#: ../vector/v.distance/main.c:192 ../vector/v.net.distance/main.c:99
+#: ../vector/v.net.distance/main.c:104 ../vector/v.net.distance/main.c:110
+msgid "From"
+msgstr ""
+#: ../vector/v.distance/main.c:104
+msgid "Layer number or name (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:111
+msgid "Feature type (from)"
+msgstr ""
+#: ../vector/v.distance/main.c:116
+msgid "Name of existing vector map (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:117 ../vector/v.distance/main.c:122
+#: ../vector/v.distance/main.c:129 ../vector/v.distance/main.c:198
+#: ../vector/v.net.distance/main.c:115 ../vector/v.net.distance/main.c:122
+#: ../vector/v.net.distance/main.c:127 ../vector/v.net.distance/main.c:133
+msgid "To"
+msgstr ""
+#: ../vector/v.distance/main.c:121
+msgid "Layer number or name (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:128
+msgid "Feature type (to)"
+msgstr ""
+#: ../vector/v.distance/main.c:134
+msgid "Name for output vector map containing lines connecting nearest elements"
+msgstr ""
+#: ../vector/v.distance/main.c:142
+msgid "Maximum distance or -1 for no limit"
+msgstr ""
+#: ../vector/v.distance/main.c:149
+msgid "Minimum distance or -1 for no limit"
+msgstr ""
+#: ../vector/v.distance/main.c:159
+msgid "Values describing the relation between two nearest features"
+msgstr ""
+#: ../vector/v.distance/main.c:169
+msgid "category of the nearest feature"
+msgstr ""
+#: ../vector/v.distance/main.c:170
+msgid "minimum distance to nearest feature"
+msgstr ""
+#: ../vector/v.distance/main.c:171
+msgid "x coordinate of the nearest point on the 'to' feature"
+msgstr ""
+#: ../vector/v.distance/main.c:172
+msgid "y coordinate of the nearest point on the 'to' feature"
+msgstr ""
+#: ../vector/v.distance/main.c:173
+msgid ""
+"distance to the nearest point on the 'to' feature along that linear feature"
+msgstr ""
+#: ../vector/v.distance/main.c:175
+msgid ""
+"angle along the nearest linear feature in the 'to' map, measured CCW from "
+"the +x axis, in radians, between -Pi and Pi inclusive"
+msgstr ""
+#: ../vector/v.distance/main.c:178
+msgid "attribute of nearest feature given by to_column option"
+msgstr ""
+#: ../vector/v.distance/main.c:191
+msgid ""
+"Column name(s) where values specified by 'upload' option will be uploaded"
+msgstr ""
+#: ../vector/v.distance/main.c:197
+msgid "Column name of nearest feature (used with upload=to_attr)"
+msgstr ""
+#: ../vector/v.distance/main.c:203
+msgid "Name of table created when the 'distance to all' flag is used"
+msgstr ""
+#: ../vector/v.distance/main.c:206
+msgid "Field separator for printing output to stdout"
+msgstr ""
+#: ../vector/v.distance/main.c:211
+msgid "Print output to stdout, don't update attribute table"
+msgstr ""
+#: ../vector/v.distance/main.c:213
+msgid "First column is always category of 'from' feature called from_cat"
+msgstr ""
+#: ../vector/v.distance/main.c:218
+msgid "Calculate distances to all features within the threshold"
+msgstr ""
+#: ../vector/v.distance/main.c:220
+msgid ""
+"Output is written to stdout but may be uploaded to a new table created by "
+"this module; multiple 'upload' options may be used."
+msgstr ""
+#: ../vector/v.distance/main.c:284
+msgid "to_column option missing"
+msgstr ""
+#: ../vector/v.distance/main.c:296
+msgid "Too many column names"
+msgstr ""
+#: ../vector/v.distance/main.c:303
+msgid "Not enough column names"
+msgstr ""
+#: ../vector/v.distance/main.c:323 ../vector/v.distance/main.c:341
+#, c-format
+msgid "No features of selected type found in <%s>"
+msgstr ""
+#: ../vector/v.distance/main.c:413
+msgid "dmin can not be larger than dmax"
+msgstr ""
+#: ../vector/v.distance/main.c:555
+msgid "Incompatible column types"
+msgstr ""
+#: ../vector/v.distance/main.c:603
+msgid "No categories for 'from' for slected type and layer"
+msgstr ""
+#: ../vector/v.distance/main.c:627
+msgid "Finding nearest features..."
+msgstr ""
+#: ../vector/v.distance/main.c:728 ../vector/v.distance/main.c:1013
+#, c-format
+msgid "More cats found in to_layer (line=%d)"
+msgstr ""
+#: ../vector/v.distance/main.c:742 ../vector/v.distance/main.c:819
+#: ../vector/v.distance/main.c:1027 ../imagery/i.segment/flag.c:21
+#: ../imagery/i.segment/flag.c:28
+msgid "Out of memory!"
+msgstr ""
+#: ../vector/v.distance/main.c:805 ../vector/v.distance/main.c:1160
+#, c-format
+msgid "More cats found in to_layer (area=%d)"
+msgstr ""
+#: ../vector/v.distance/main.c:913
+msgid "Finding nearest features for areas..."
+msgstr ""
+#: ../vector/v.distance/main.c:1277
+msgid "DATETIME type not yet supported, no attributes will be uploaded"
+msgstr ""
+#: ../vector/v.distance/main.c:1295
+msgid "Unable to open default database"
+msgstr ""
+#: ../vector/v.distance/main.c:1635
+#, c-format
+msgid "%d categories with more than 1 feature in vector map <%s>"
+msgstr ""
+#: ../vector/v.distance/main.c:1638
+#, c-format
+msgid "%d categories - no nearest feature found"
+msgstr ""
+#: ../vector/v.distance/main.c:1647
+#, c-format
+msgid "%d distances calculated"
+msgstr ""
+#: ../vector/v.distance/main.c:1648
+#, c-format
+msgid "%d records inserted"
+msgstr ""
+#: ../vector/v.distance/main.c:1650
+#, c-format
+msgid "%d insert errors"
+msgstr ""
+#: ../vector/v.distance/main.c:1654
+#, c-format
+msgid "%d categories read from the map"
+msgstr ""
+#: ../vector/v.distance/main.c:1656
+#, c-format
+msgid "%d categories exist in the table"
+msgstr ""
+#: ../vector/v.distance/main.c:1658
+#, c-format
+msgid "%d categories read from the map exist in the table"
+msgstr ""
+#: ../vector/v.distance/main.c:1661
+#, c-format
+msgid "%d categories read from the map don't exist in the table"
+msgstr ""
+#: ../vector/v.distance/distance.c:49
+#, c-format
+msgid "Invalid segment number %d for %d points"
+msgstr ""
+#: ../vector/v.distance/distance.c:416
+msgid "At least one point is really inside the area!"
+msgstr ""
+#: ../vector/v.parallel/main.c:51 ../vector/v.buffer/main.c:223
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
+#: ../raster/r.buffer/main.c:67 ../raster/r.circle/main.c:52
+msgid "buffer"
+msgstr ""
+#: ../vector/v.parallel/main.c:53
+msgid "Creates parallel line to input vector lines."
+msgstr ""
+#: ../vector/v.parallel/main.c:68
+msgid "Offset along major axis in map units"
+msgstr ""
+#: ../vector/v.parallel/main.c:76
+msgid "Offset along minor axis in map units"
+msgstr ""
+#: ../vector/v.parallel/main.c:84 ../vector/v.buffer/main.c:270
+msgid "Angle of major axis in degrees"
+msgstr ""
+#: ../vector/v.parallel/main.c:93
+msgid "Side"
+msgstr ""
+#: ../vector/v.parallel/main.c:97
+msgid "Parallel line is on the left"
+msgstr ""
+#: ../vector/v.parallel/main.c:98
+msgid "Parallel line is on the right"
+msgstr ""
+#: ../vector/v.parallel/main.c:99
+msgid "Parallel lines on both sides"
+msgstr ""
+#: ../vector/v.parallel/main.c:108
+msgid "Tolerance of arc polylines in map units"
+msgstr ""
+#: ../vector/v.parallel/main.c:112
+msgid "Make outside corners round"
+msgstr ""
+#: ../vector/v.parallel/main.c:116
+msgid "Create buffer-like parallel lines"
+msgstr ""
+#: ../vector/v.class/main.c:46 ../raster/r.kappa/main.c:70
+#: ../imagery/i.cluster/main.c:76 ../imagery/i.gensigset/main.c:41
+#: ../imagery/i.smap/main.c:39 ../imagery/i.segment/main.c:37
+#: ../imagery/i.maxlik/main.c:62 ../imagery/i.gensig/main.c:40
+msgid "classification"
+msgstr ""
+#: ../vector/v.class/main.c:50
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
+#: ../vector/v.class/main.c:58
+msgid "Column name or expression"
+msgstr ""
+#: ../vector/v.class/main.c:68 ../display/d.vect.thematic/main.c:111
+msgid "Algorithm to use for classification"
+msgstr ""
+#: ../vector/v.class/main.c:76 ../display/d.vect.thematic/main.c:115
+msgid "simple intervals"
+msgstr ""
+#: ../vector/v.class/main.c:77 ../display/d.vect.thematic/main.c:116
+msgid "standard deviations"
+msgstr ""
+#: ../vector/v.class/main.c:78 ../display/d.vect.thematic/main.c:117
+msgid "quantiles"
+msgstr ""
+#: ../vector/v.class/main.c:79 ../display/d.vect.thematic/main.c:118
+msgid "equiprobable (normal distribution)"
+msgstr ""
+#: ../vector/v.class/main.c:88 ../display/d.vect.thematic/main.c:128
+msgid "Number of classes to define"
+msgstr ""
+#: ../vector/v.class/main.c:93
+msgid "Print only class breaks (without min and max)"
+msgstr ""
+#: ../vector/v.class/main.c:138
+msgid "Unable to sort array of values"
+msgstr ""
+#: ../vector/v.class/main.c:173
+msgid ""
+"The discontinuities algorithm indicates that some class breaks are not "
+"statistically significant at alpha=0.05. You are advised to reduce the "
+"number of classes."
+msgstr ""
+#: ../vector/v.class/main.c:201
+#, c-format
+msgid ""
+"\n"
+"Classification of %s into %i classes\n"
+msgstr ""
+#: ../vector/v.class/main.c:203 ../display/d.vect.thematic/main.c:439
+#, c-format
+msgid "Using algorithm: *** %s ***\n"
+msgstr ""
+#: ../vector/v.class/main.c:204 ../display/d.vect.thematic/main.c:441
+#, c-format
+msgid "Mean: %f\tStandard deviation = %f\n"
+msgstr ""
+#: ../vector/v.class/main.c:208
+#, c-format
+msgid "Lowest chi2 = %f\n"
+msgstr ""
+#: ../vector/v.class/main.c:211 ../display/d.vect.thematic/main.c:448
+#, c-format
+msgid "Stdev multiplied by %.4f to define step\n"
+msgstr ""
+#: ../vector/v.class/main.c:214
+#, c-format
+msgid ""
+"%15s%15s%15s\n"
+"\n"
+msgstr ""
+#: ../vector/v.class/main.c:226
+#, c-format
+msgid ""
+"\n"
+"Note: Minimum of first class is including\n"
+"\n"
+msgstr ""
+#: ../vector/v.generalize/misc.c:156
+#, c-format
+msgid "Layer %d"
+msgstr ""
+#: ../vector/v.generalize/displacement.c:78 ../raster/r.contour/main.c:237
+msgid "Reading data..."
+msgstr ""
+#: ../vector/v.generalize/displacement.c:199
+msgid "Inverting matrix..."
+msgstr ""
+#: ../vector/v.generalize/displacement.c:201
+msgid "Unable to calculate the inverse matrix"
+msgstr ""
+#: ../vector/v.generalize/displacement.c:204
+msgid "Resolving conflicts..."
+msgstr ""
+#: ../vector/v.generalize/main.c:77
+msgid "generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:78
+msgid "simplification"
+msgstr ""
+#: ../vector/v.generalize/main.c:79
+msgid "smoothing"
+msgstr ""
+#: ../vector/v.generalize/main.c:80
+msgid "displacement"
+msgstr ""
+#: ../vector/v.generalize/main.c:81
+msgid "network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:82
+msgid "Performs vector based generalization."
+msgstr ""
+#: ../vector/v.generalize/main.c:100
+msgid ""
+"Error map of all lines and boundaries not being generalized due to topology "
+"issues or over-simplification"
+msgstr ""
+#: ../vector/v.generalize/main.c:124
+msgid "Douglas-Peucker Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:125
+msgid "Douglas-Peucker Algorithm with reduction parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:126
+msgid "Lang Simplification Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:127
+msgid "Vertex Reduction Algorithm eliminates points close to each other"
+msgstr ""
+#: ../vector/v.generalize/main.c:128
+msgid "Reumann-Witkam Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:129
+msgid "Boyle's Forward-Looking Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:130
+msgid "McMaster's Sliding Averaging Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:131
+msgid "McMaster's Distance-Weighting Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:132
+msgid "Chaiken's Algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:133
+msgid "Interpolation by Cubic Hermite Splines"
+msgstr ""
+#: ../vector/v.generalize/main.c:134
+msgid "Snakes method for line smoothing"
+msgstr ""
+#: ../vector/v.generalize/main.c:135
+msgid "Network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:136
+msgid "Displacement of lines close to each other"
+msgstr ""
+#: ../vector/v.generalize/main.c:139
+msgid "Generalization algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:146
+msgid "Maximal tolerance value"
+msgstr ""
+#: ../vector/v.generalize/main.c:153
+msgid "Look-ahead parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:162
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
+msgstr ""
+#: ../vector/v.generalize/main.c:171
+msgid "Slide of computed point toward the original point"
+msgstr ""
+#: ../vector/v.generalize/main.c:180
+msgid "Minimum angle between two consecutive segments in Hermite method"
+msgstr ""
+#: ../vector/v.generalize/main.c:188
+msgid "Degree threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:197
+msgid "Closeness threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:205
+msgid "Betweeness threshold in network generalization"
+msgstr ""
+#: ../vector/v.generalize/main.c:212
+msgid "Snakes alpha parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:219
+msgid "Snakes beta parameter"
+msgstr ""
+#: ../vector/v.generalize/main.c:226
+msgid "Number of iterations"
+msgstr ""
+#: ../vector/v.generalize/main.c:236
+msgid "Disable loop support"
+msgstr ""
+#: ../vector/v.generalize/main.c:237
+msgid "Do not modify end points of lines forming a closed loop"
+msgstr ""
+#: ../vector/v.generalize/main.c:240
+msgid "Do not copy attributes"
+msgstr ""
+#: ../vector/v.generalize/main.c:294
+msgid "Unknown method"
+msgstr ""
+#: ../vector/v.generalize/main.c:326
+#, c-format
+msgid "No lines found in input map <%s>"
+msgstr ""
+#: ../vector/v.generalize/main.c:340
+#, c-format
+msgid "Unable to create error vector map <%s>"
+msgstr ""
+#: ../vector/v.generalize/main.c:360
+msgid "Displacement..."
+msgstr ""
+#: ../vector/v.generalize/main.c:369
+msgid "Network generalization..."
+msgstr ""
+#: ../vector/v.generalize/main.c:384
+msgid "Attributes are needed for 'where' option, copying table"
+msgstr ""
+#: ../vector/v.generalize/main.c:401
+#, c-format
+msgid "Generalization (%s)..."
+msgstr ""
+#: ../vector/v.generalize/main.c:402
+#, c-format
+msgid "Using threshold: %g %s"
+msgstr ""
+#: ../vector/v.generalize/main.c:533
+#, c-format
+msgid "Method '%s' did not preserve first point"
+msgstr ""
+#: ../vector/v.generalize/main.c:538
+#, c-format
+msgid "Method '%s' did not preserve last point"
+msgstr ""
+#: ../vector/v.generalize/main.c:545
+#, c-format
+msgid "Method '%s' did not preserve loop"
+msgstr ""
+#: ../vector/v.generalize/main.c:577
+#, c-format
+msgid ""
+"%d boundaries were not modified because modification would damage topology"
+msgstr ""
+#: ../vector/v.generalize/main.c:580
+#, c-format
+msgid "%d lines/boundaries were not modified due to over-simplification"
+msgstr ""
+#: ../vector/v.generalize/main.c:601
+#, c-format
+msgid ""
+"Number of vertices for selected features %s from %d to %d (%d%% remaining)"
+msgstr ""
+#: ../vector/v.generalize/main.c:602
+msgid "reduced"
+msgstr ""
+msgid "changed"
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:135
+#: ../vector/v.generalize/smoothing.c:225
+msgid "Look ahead parameter must be odd"
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:664
+msgid "Unable to find the inverse matrix"
+msgstr ""
+#: ../vector/v.generalize/smoothing.c:671
+msgid "Unable to calculate the output vectors"
+msgstr ""
+#: ../vector/v.generalize/network.c:166
+msgid "Calculating centrality measures..."
+msgstr ""
+#: ../vector/v.in.region/main.c:43
+msgid "Creates a vector polygon from the current region extent."
+msgstr ""
+#: ../vector/v.in.region/main.c:51
+msgid "Select type: line or area"
+msgstr ""
+#: ../vector/v.in.region/main.c:58
+msgid "Densify lines using region resolution"
+msgstr ""
+#: ../vector/v.label.sa/main.c:39 ../vector/v.label/main.c:60
+#: ../display/d.labels/main.c:44
+msgid "paint labels"
+msgstr ""
+#: ../vector/v.label.sa/main.c:41
+msgid "Create optimally placed labels for vector map(s)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:57 ../vector/v.label/main.c:78
+msgid "Name of attribute column to be used for labels"
+msgstr ""
+#: ../vector/v.label.sa/main.c:61 ../vector/v.label/main.c:67
+msgid "Name for new paint-label file"
+msgstr ""
+#: ../vector/v.label.sa/main.c:71
+msgid "Name of TrueType font (as listed in the fontcap)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:72 ../vector/v.label.sa/main.c:80
+#: ../vector/v.lrs/v.lrs.label/main.c:181 ../vector/v.label/main.c:125
+#: ../vector/v.label/main.c:132 ../vector/v.label/main.c:140
+#: ../vector/v.label/main.c:148
+msgid "Font"
+msgstr ""
+#: ../vector/v.label.sa/main.c:77 ../vector/v.lrs/v.lrs.label/main.c:187
+#: ../vector/v.label/main.c:129
+msgid "Label size (in map-units)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:84
+msgid "Icon size of point features (in map-units)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:98 ../vector/v.lrs/v.lrs.label/main.c:193
+#: ../vector/v.label/main.c:151 ../display/d.grid/main.c:102
+#: ../display/d.geodesic/main.c:66 ../display/d.rast.num/main.c:87
+#: ../display/d.legend/main.c:160
+msgid "Text color"
+msgstr ""
+#: ../vector/v.label.sa/main.c:103 ../vector/v.label.sa/main.c:113
+#: ../vector/v.label.sa/main.c:120 ../vector/v.label.sa/main.c:130
+#: ../vector/v.label.sa/main.c:140 ../vector/v.label.sa/main.c:150
+#: ../vector/v.label.sa/main.c:157 ../vector/v.label/main.c:152
+#: ../vector/v.label/main.c:176 ../vector/v.label/main.c:189
+#: ../vector/v.label/main.c:195 ../vector/v.label/main.c:205
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:11
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:13
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:15
+#: ../display/d.rast.num/main.c:88 ../display/d.rast.num/main.c:94
+#: ../display/d.rast.num/main.c:112 ../display/d.vect/main.c:117
+#: ../display/d.vect/main.c:123 ../display/d.vect/main.c:127
+#: ../display/d.vect/main.c:134 ../display/d.vect/main.c:279
+#: ../display/d.northarrow/main.c:66 ../display/d.northarrow/main.c:72
+#: ../display/d.rast.arrow/main.c:117 ../display/d.rast.arrow/main.c:123
+#: ../display/d.rast.arrow/main.c:129 ../display/d.rast.arrow/main.c:135
+#: ../display/d.barscale/main.c:113 ../display/d.barscale/main.c:119
+msgid "Colors"
+msgstr ""
+#: ../vector/v.label.sa/main.c:107 ../vector/v.lrs/v.lrs.label/main.c:205
+#: ../vector/v.label/main.c:174
+msgid "Highlight color for text"
+msgstr ""
+#: ../vector/v.label.sa/main.c:117 ../vector/v.label/main.c:180
+msgid "Width of highlight coloring"
+msgstr ""
+#: ../vector/v.label.sa/main.c:135 ../vector/v.label/main.c:200
+msgid "Opaque to vector (only relevant if background color is selected)"
+msgstr ""
+#: ../vector/v.label.sa/main.c:144 ../vector/v.lrs/v.lrs.label/main.c:223
+#: ../vector/v.label/main.c:193 ../display/d.grid/main.c:96
+msgid "Border color"
+msgstr ""
+#: ../vector/v.label.sa/main.c:154
+msgid "Border width (only for ps.map output)"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:68
+#, c-format
+msgid "Cannot allocate %lu bytes of memory"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:87
+msgid "Unable to initialise FreeType"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:90
+#, c-format
+msgid "Unable to find font '%s'\n"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:92
+#, c-format
+msgid "Font '%s' is not a FreeType font\n"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:96
+msgid "Font file format is not supported by FreeType"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:98
+msgid "Font file can not be loaded"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:107
+msgid "Unable to set font size"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:128
+msgid "Cannot allocate more memory"
+msgstr ""
+#: ../vector/v.label.sa/labels.c:244
+#, c-format
+msgid "Cannot load glyph for '%c'"
+msgstr ""
+#: ../vector/v.voronoi/sw_main.c:188
+#, c-format
+msgid "Found %d point/centroid in <%s>, but at least 2 are needed"
+msgid_plural "Found %d points/centroids in <%s>, but at least 2 are needed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.voronoi/sw_main.c:410 ../vector/v.voronoi/sw_main.c:436
+msgid "All boundaries in the list should be valid"
+msgstr ""
+#: ../vector/v.voronoi/sw_main.c:416 ../vector/v.voronoi/sw_main.c:442
+msgid "Boundary is degenerate"
+msgstr ""
+#: ../vector/v.voronoi/sw_main.c:468
+#, c-format
+msgid "Found %d vertex in <%s>, but at least 2 are needed"
+msgid_plural "Found %d vertices in <%s>, but at least 2 are needed"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.voronoi/main.c:125 ../vector/v.delaunay/main.c:87
+msgid "triangulation"
+msgstr ""
+#: ../vector/v.voronoi/main.c:126
+msgid "skeleton"
+msgstr ""
+#: ../vector/v.voronoi/main.c:127
+msgid ""
+"Creates a Voronoi diagram in current region from an input vector map "
+"containing points or centroids."
+msgstr ""
+#: ../vector/v.voronoi/main.c:131 ../vector/v.surf.bspline/main.c:110
+#: ../vector/v.sample/main.c:82
+msgid "Name of input vector point map"
+msgstr ""
+#: ../vector/v.voronoi/main.c:141
+msgid "Factor for output smoothness"
+msgstr ""
+#: ../vector/v.voronoi/main.c:142
+msgid ""
+"Applies to input areas only. Smaller values produce smoother output but can "
+"cause numerical instability."
+msgstr ""
+#: ../vector/v.voronoi/main.c:149
+msgid "Maximum dangle length of skeletons"
+msgstr ""
+#: ../vector/v.voronoi/main.c:150
+msgid ""
+"Applies only to skeleton extraction. Default = -1 will extract the center "
+"line."
+msgstr ""
+#: ../vector/v.voronoi/main.c:156
+msgid "Create Voronoi diagram for input areas"
+msgstr ""
+#: ../vector/v.voronoi/main.c:161
+msgid "Extract skeletons for input areas"
+msgstr ""
+#: ../vector/v.voronoi/main.c:166
+msgid "Output tessellation as a graph (lines), not areas"
+msgstr ""
+#: ../vector/v.voronoi/main.c:182
+#, c-format
+msgid "Option '%s' is too small, set to %g"
+msgstr ""
+#: ../vector/v.voronoi/main.c:226
+#, c-format
+msgid "Voronoi triangulation for %d point..."
+msgid_plural "Voronoi triangulation for %d points..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.voronoi/main.c:230 ../vector/v.delaunay/in_out.c:93
+msgid "Writing edges..."
+msgstr ""
+#: ../vector/v.voronoi/main.c:239
+msgid "Thin skeletons ..."
+msgstr ""
+#: ../vector/v.voronoi/main.c:396
+msgid "No table"
+msgstr ""
+#: ../vector/v.voronoi/main.c:411
+msgid "Cannot copy table"
+msgstr ""
+#: ../vector/v.voronoi/skeleton.c:293 ../vector/v.voronoi/skeleton.c:400
+#, c-format
+msgid "Pass %d"
+msgstr ""
+#: ../vector/v.voronoi/skeleton.c:509
+msgid "Node is outside any input area"
+msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:20
+msgid "Searching for topology errors..."
+msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:78
+msgid "Cleaning output topology"
+msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:87 ../vector/v.buffer/main.c:751
+#: ../vector/v.in.ogr/main.c:1343
+msgid "Removing dangles..."
+msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:89 ../vector/v.buffer/main.c:754
+#: ../vector/v.in.ogr/main.c:1358
+msgid "Removing bridges..."
+msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:115
+msgid "Removing incorrect boundaries from output"
+msgstr ""
+#: ../vector/v.hull/main.c:56
+msgid "Produces a 2D/3D convex hull for a given vector map."
+msgstr ""
+#: ../vector/v.hull/main.c:70
+msgid "Limit to current region"
+msgstr ""
+#: ../vector/v.hull/main.c:75
+msgid "Create a 'flat' 2D hull even if the input is 3D points"
+msgstr ""
+#: ../vector/v.hull/main.c:100
+#, c-format
+msgid "Error loading vector points from <%s>"
+msgstr ""
+#: ../vector/v.hull/main.c:103
+#, c-format
+msgid "Convex hull calculation requires at least three points (%d found)"
+msgstr ""
+#: ../vector/v.hull/main.c:105
+#, c-format
+msgid "%d points read from vector map <%s>"
+msgstr ""
+#: ../vector/v.hull/hull.c:107
+msgid "Simple planar hulls not implemented yet"
+msgstr ""
+#: ../vector/v.hull/chull.c:212
+msgid "Reading 3D vertices..."
+msgstr ""
+#: ../vector/v.hull/chull.c:396
+msgid "Constructing 3D hull..."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:94
+#: ../vector/v.lidar.edgedetection/main.c:73 ../vector/v.in.lidar/main.c:158
+#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
+#: ../raster/r.in.xyz/main.c:164 ../raster/r.in.lidar/main.c:172
+msgid "LIDAR"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:96
+msgid ""
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:101 ../raster/r.resamp.bspline/main.c:144
+msgid ""
+"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
+"cross validation method"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:105
+#: ../vector/v.lidar.edgedetection/main.c:80 ../vector/v.outlier/main.c:75
+#: ../vector/v.lidar.correction/main.c:75
+msgid "Estimate point density and distance"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:107
+#: ../vector/v.lidar.edgedetection/main.c:82 ../vector/v.outlier/main.c:77
+#: ../vector/v.lidar.correction/main.c:77
+msgid ""
+"Estimate point density and distance for the input vector points within the "
+"current region extends and quit"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:118 ../vector/v.surf.rst/main.c:178
+msgid "Name of the attribute column with values to be used for approximation"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:119
+msgid "If not given and input is 3D vector map then z-coordinates are used."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:126
+msgid "Name of input vector map with sparse points"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:139
+msgid "Raster map to use for masking (applies to raster output only)"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:140 ../raster/r.resamp.bspline/main.c:99
+msgid "Only cells that are not NULL and not zero are interpolated"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:149
+#: ../vector/v.lidar.edgedetection/main.c:94 ../vector/v.outlier/main.c:105
+#: ../vector/v.lidar.correction/main.c:101
+msgid "Length of each spline step in the east-west direction"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:158
+#: ../vector/v.lidar.edgedetection/main.c:103 ../vector/v.outlier/main.c:114
+#: ../vector/v.lidar.correction/main.c:110
+msgid "Length of each spline step in the north-south direction"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:163 ../raster/r.resamp.bspline/main.c:119
+msgid "Spline interpolation algorithm"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:170
+#: ../vector/v.lidar.edgedetection/main.c:414 ../vector/v.outlier/main.c:413
+#: ../vector/v.lidar.correction/main.c:402
+#: ../raster/r.resamp.bspline/main.c:125
+msgid "Bilinear interpolation"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:171
+#: ../vector/v.lidar.edgedetection/main.c:431
+#: ../raster/r.resamp.bspline/main.c:126
+msgid "Bicubic interpolation"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:177 ../raster/r.resamp.bspline/main.c:132
+msgid "Tykhonov regularization parameter (affects smoothing)"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:207
+msgid "Choose either vector or raster output, not both"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:210
+msgid "No raster or vector or cross-validation output"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:226
+msgid "Unable to set default DB connection"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:231
+msgid "No default DB defined"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:247 ../vector/v.surf.bspline/main.c:416
+#: ../vector/v.lidar.edgedetection/main.c:189
+#: ../vector/v.lidar.edgedetection/main.c:201
+#: ../vector/v.lidar.edgedetection/main.c:251 ../vector/v.outlier/main.c:185
+#: ../vector/v.outlier/main.c:253 ../vector/v.lidar.growing/main.c:163
+#: ../vector/v.lidar.correction/main.c:167
+#: ../vector/v.lidar.correction/main.c:229
+#, c-format
+msgid "No database connection for driver <%s> is defined. Run db.connect."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:252
+msgid "Old auxiliary table could not be dropped"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:262 ../vector/v.surf.bspline/main.c:330
+#: ../vector/v.outlier/main.c:197
+#, c-format
+msgid "Unable to open vector map <%s> at the topological level"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:272 ../vector/v.surf.rst/main.c:541
+msgid ""
+"Input is 3D: using attribute values instead of z-coordinates for "
+"approximation"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:274 ../vector/v.surf.rst/main.c:543
+msgid "Input is 3D: using z-coordinates for approximation"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:278
+#, c-format
+msgid "Input vector map is 2D. Parameter <%s> required."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:289
+#, c-format
+msgid "Estimated point density: %.4g"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:290
+#, c-format
+msgid "Estimated mean distance between points: %.4g"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:293
+#, c-format
+msgid "No points in current region"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:307 ../raster/r.resamp.bspline/main.c:363
+msgid "Cross validation didn't finish correctly"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:313 ../raster/r.resamp.bspline/main.c:367
+#, c-format
+msgid "Cross validation finished for ew_step = %f and ns_step = %f"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:322
+#, c-format
+msgid "Vector map <%s> of sparse points will be interpolated"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:338
+#, c-format
+msgid ""
+"Sorry, the <%s> driver is not compatible with the vector output of this "
+"module. Try with raster output or another driver."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:361
+#, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:372
+#, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:378
+msgid "Reading values from attribute table..."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:382
+msgid "Cannot read layer info"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:404 ../vector/v.normal/main.c:135
+#, c-format
+msgid "%d records selected from table"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:424
+#, c-format
+msgid "Interpolation: Creating table: It was impossible to create table <%s>."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:455 ../raster/r.resamp.bspline/main.c:292
+msgid "Memory in MB must be >= 3"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:469 ../vector/v.surf.bspline/main.c:497
+#: ../raster/r.walk/main.c:549 ../raster/r.walk/main.c:554
+#: ../raster/r.resamp.bspline/main.c:308 ../raster/r.resamp.bspline/main.c:394
+#: ../raster/r.resamp.bspline/main.c:465 ../raster/r.cost/main.c:435
+#: ../raster/r.cost/main.c:440
+msgid "Can not create temporary file"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:474 ../vector/v.surf.bspline/main.c:502
+#: ../raster/r.resamp.bspline/main.c:313 ../raster/r.resamp.bspline/main.c:399
+#: ../raster/r.resamp.bspline/main.c:470
+msgid "Can not initialize temporary file"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:477 ../raster/r.resamp.bspline/main.c:473
+msgid "Initializing output..."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:492
+msgid "Load masking map"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:549 ../vector/v.outlier/main.c:293
+#, c-format
+msgid "Adjusted EW splines %d"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:550 ../vector/v.outlier/main.c:294
+#, c-format
+msgid "Adjusted NS splines %d"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:621 ../vector/v.outlier/main.c:350
+#, c-format
+msgid "Processing subregion %d of %d..."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:705
+#, c-format
+msgid "%d points found in this subregion"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:752
+#, c-format
+msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:888 ../vector/v.outlier/main.c:445
+msgid "No data within this subregion. Consider increasing spline step values."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:894 ../raster/r.resamp.bspline/main.c:736
+msgid "Writing output..."
+msgstr ""
+#: ../vector/v.surf.bspline/main.c:941 ../vector/v.outlier/main.c:455
+msgid "Auxiliary table could not be dropped"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:75
+#, c-format
+msgid "%d are too many points. The cross validation would take too much time."
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:84
+#, c-format
+msgid "%d points read in region"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:88
+msgid ""
+"Maybe it takes too long. It will depend on how many points you are "
+"considering."
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:119
+#, c-format
+msgid "CrossCorrelation: driver=%s db=%s"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:136
+#, c-format
+msgid "No records selected from table <%s> "
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:151
+#: ../raster/r.resamp.bspline/crosscorr.c:197
+#, c-format
+msgid ""
+"Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" "
+"\"ns_step=\"."
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:169
+#: ../raster/r.resamp.bspline/crosscorr.c:215
+#, c-format
+msgid "Beginning cross validation with lambda_i=%.4f ... (%d of %d)"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:220
+#: ../vector/v.surf.idw/read_sites.c:107
+#, c-format
+msgid "No record for point (cat = %d)"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:295
+#: ../raster/r.resamp.bspline/crosscorr.c:306
+#, c-format
+msgid "Mean = %.5lf"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:296
+#: ../raster/r.resamp.bspline/crosscorr.c:307
+#, c-format
+msgid "Root Mean Square (RMS) = %.5lf"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:313
+#: ../raster/r.resamp.bspline/crosscorr.c:324
+msgid ""
+"Different number of splines and lambda_i values have been taken for the "
+"cross correlation"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:315
+#: ../raster/r.resamp.bspline/crosscorr.c:326
+#, c-format
+msgid ""
+"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:323
+#: ../raster/r.resamp.bspline/crosscorr.c:334
+msgid "Table of results:"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:324
+#: ../raster/r.resamp.bspline/crosscorr.c:335
+#, c-format
+msgid "    lambda |       mean |        rms |\n"
+msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:334
+#: ../raster/r.resamp.bspline/crosscorr.c:345
+msgid "No point lies into the current region"
+msgstr ""
+#: ../vector/v.net.bridge/main.c:49
+msgid "articulation points"
+msgstr ""
+#: ../vector/v.net.bridge/main.c:51
+msgid "Computes bridges and articulation points in the network."
+msgstr ""
+#: ../vector/v.net.bridge/main.c:98
+msgid "Finds bridges"
+msgstr ""
+#: ../vector/v.net.bridge/main.c:99
+msgid "Finds articulation points"
+msgstr ""
+#: ../vector/v.drape/main.c:61
+msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../vector/v.drape/main.c:82 ../vector/v.extrude/main.c:124
+msgid "Elevation raster map for height extraction"
+msgstr ""
+#: ../vector/v.drape/main.c:86 ../vector/v.drape/main.c:93
+#: ../vector/v.drape/main.c:100 ../vector/v.extrude/main.c:79
+#: ../vector/v.extrude/main.c:125 ../vector/v.extrude/main.c:129
+#: ../vector/v.extrude/main.c:136 ../vector/v.extrude/main.c:143
+msgid "Elevation"
+msgstr ""
+#: ../vector/v.drape/main.c:91 ../vector/v.extrude/main.c:134
+msgid "Scale factor sampled raster values"
+msgstr ""
+#: ../vector/v.drape/main.c:99 ../vector/v.extrude/main.c:142
+msgid "Height for sampled raster NULL values"
+msgstr ""
+#: ../vector/v.drape/main.c:198
+#, c-format
+msgid "Undefined height for feature %d. Skipping."
+msgstr ""
+#: ../vector/v.drape/main.c:203
+msgid "Copying attribute tables..."
+msgstr ""
+#: ../vector/v.out.vtk/main.c:51
+msgid "Converts a vector map to VTK ASCII output."
+msgstr ""
+#: ../vector/v.out.vtk/main.c:59
+msgid "Name for output VTK file"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:76 ../raster3d/r3.out.vtk/parameters.c:94
+#: ../raster/r.out.vtk/parameters.c:85
+msgid "Scale factor for elevation"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:84
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
+msgid "Correct the coordinates to fit the VTK-OpenGL precision"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:89
+msgid "Export numeric attribute table fields as VTK scalar variables"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:155
+msgid "dp has to be from 0 to 8"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:164
+msgid "Failed to interpret 'layer' parameter as an integer"
+msgstr ""
+#: ../vector/v.out.vtk/main.c:183
+#, c-format
+msgid ""
+"Export of areas requires topology. Please adjust '%s' option or rebuild "
+"topology."
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:196
+msgid ""
+"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:585 ../vector/v.out.ogr/attrb.c:48
+#, c-format
+msgid "Cannot select attributes for cat = %d"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:632
+msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:640
+msgid "No attribute table found"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:673
+msgid "No numerical attributes found. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:732 ../vector/v.out.vtk/writeVTK.c:763
+#: ../vector/v.out.vtk/writeVTK.c:794 ../vector/v.out.vtk/writeVTK.c:823
+#, c-format
+msgid "Error reading value of attribute '%s'"
+msgstr ""
+#: ../vector/v.out.vtk/head.c:27
+msgid "writeVTKHeader: Writing VTK-Header"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:74 ../imagery/i.zc/main.c:53
+msgid "edges"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:76
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:111
+msgid "Regularization weight in gradient evaluation"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:120
+msgid "High gradient threshold for edge classification"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:129
+msgid "Low gradient threshold for edge classification"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:137
+msgid "Angle range for same direction detection"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:146
+msgid "Regularization weight in residual evaluation"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:169 ../vector/v.outlier/main.c:146
+#: ../vector/v.lidar.correction/main.c:150
+msgid "Unable to read name of database"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:172 ../vector/v.outlier/main.c:149
+#: ../vector/v.lidar.correction/main.c:153
+msgid "Unable to read name of driver"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:192
+#: ../vector/v.lidar.edgedetection/main.c:204 ../vector/v.outlier/main.c:190
+#: ../vector/v.lidar.correction/main.c:172
+msgid "Old auxiliar table could not be dropped"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:223 ../vector/v.outlier/main.c:202
+#: ../vector/v.lidar.correction/main.c:190
+#, c-format
+msgid "Input vector map <%s> is not 3D!"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:233 ../vector/v.outlier/main.c:212
+#: ../vector/v.lidar.correction/main.c:200
+msgid "No points in current region!"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:257
+#, c-format
+msgid "It was impossible to create <%s>."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:260
+#, c-format
+msgid "It was impossible to create <%s> interpolation table in database."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:295
+#: ../raster/r.resamp.bspline/main.c:224
+#, c-format
+msgid "adjusted EW splines %d"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:296
+#: ../raster/r.resamp.bspline/main.c:225
+#, c-format
+msgid "adjusted NS splines %d"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:351
+#: ../vector/v.lidar.growing/main.c:246
+#: ../vector/v.lidar.correction/main.c:333
+#: ../raster/r.resamp.bspline/main.c:546
+#, c-format
+msgid "subregion %d of %d"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:393
+msgid "Allocating memory for bilinear interpolation"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:426
+msgid "Allocating memory for bicubic interpolation"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:443
+msgid "Point classification"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:457
+#: ../vector/v.lidar.correction/main.c:428
+msgid "No data within this subregion. Consider changing the spline step."
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:465
+#: ../vector/v.lidar.correction/main.c:437
+#, c-format
+msgid "Dropping <%s>"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/main.c:467
+#: ../vector/v.lidar.correction/main.c:439
+msgid "Auxiliar table could not be dropped"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/edgedetection.c:228
+#: ../vector/v.lidar.edgedetection/edgedetection.c:274
+#: ../vector/v.lidar.edgedetection/edgedetection.c:304
+#: ../vector/v.lidar.edgedetection/edgedetection.c:322
+#: ../vector/v.lidar.edgedetection/edgedetection.c:352
+msgid "Impossible to read from aux table"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/edgedetection.c:233
+#: ../vector/v.lidar.edgedetection/edgedetection.c:309
+msgid "Impossible to update aux table"
+msgstr ""
+#: ../vector/v.lidar.edgedetection/edgedetection.c:246
+#: ../vector/v.lidar.edgedetection/edgedetection.c:258
+#: ../vector/v.lidar.edgedetection/edgedetection.c:379
+msgid "Impossible to write to aux table"
+msgstr ""
+#: ../vector/v.net/main.c:47
+msgid "network maintenance"
+msgstr ""
+#: ../vector/v.net/main.c:48
+msgid "Performs network maintenance."
+msgstr ""
+#: ../vector/v.net/main.c:119
+#, c-format
+msgid "Unable to open vector map <%s> at topology level %d"
+msgstr ""
+#: ../vector/v.net/main.c:135
+#, c-format
+msgid "%d new points (nodes) written to output."
+msgstr ""
+#: ../vector/v.net/main.c:146
+#, c-format
+msgid "%d lines (network arcs) written to output."
+msgstr ""
+#: ../vector/v.net/connect.c:78
+msgid "Failed to find intersection segment"
+msgstr ""
+#: ../vector/v.net/arcs.c:42
+#, c-format
+msgid "Error reading file: '%s'"
+msgstr ""
+#: ../vector/v.net/arcs.c:48
+#, c-format
+msgid "Skipping arc %d"
+msgstr ""
+#: ../vector/v.net/arcs.c:85
+#, c-format
+msgid "No point with category %d found"
+msgstr ""
+#: ../vector/v.net/arcs.c:89
+#, c-format
+msgid "More points with category %d found"
+msgstr ""
+#: ../vector/v.net/args.c:14
+msgid "Name of input vector line map (arcs)"
+msgstr ""
+#: ../vector/v.net/args.c:15
+msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
+msgstr ""
+#: ../vector/v.net/args.c:17 ../vector/v.net/args.c:56
+msgid "Arcs"
+msgstr ""
+#: ../vector/v.net/args.c:21
+msgid "Name of input vector point map (nodes)"
+msgstr ""
+#: ../vector/v.net/args.c:23
+msgid "Required for operation 'connect' and 'arcs'"
+msgstr ""
+#: ../vector/v.net/args.c:25 ../vector/v.net/args.c:63
+#: ../vector/v.net/args.c:85 ../vector/v.net/args.c:92
+msgid "Nodes"
+msgstr ""
+#: ../vector/v.net/args.c:36
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
+#: ../locale/scriptstrings/g.extension_to_translate.c:8
+#: ../general/g.mapsets/main.c:81
+msgid "Operation to be performed"
+msgstr ""
+#: ../vector/v.net/args.c:40
+msgid "new point is placed on each node (line end) if doesn't exist"
+msgstr ""
+#: ../vector/v.net/args.c:42
+msgid ""
+"connect still unconnected points to vector network by inserting new line(s)"
+msgstr ""
+#: ../vector/v.net/args.c:44
+msgid "new line is created from start point to end point"
+msgstr ""
+#: ../vector/v.net/args.c:46
+msgid ""
+"print to standard output {line_category start_point_category "
+"end_point_category}"
+msgstr ""
+#: ../vector/v.net/args.c:48
+msgid ""
+"print to standard output {point_category line_category[,line_category...]}"
+msgstr ""
+#: ../vector/v.net/args.c:72
+msgid "Required for operation 'connect'. Connect points in given threshold."
+msgstr ""
+#: ../vector/v.net/args.c:76
+msgid "Name of input file"
+msgstr ""
+#: ../vector/v.net/args.c:78
+msgid "Required for operation 'arcs' ('-' for standard input)"
+msgstr ""
+#: ../vector/v.net/args.c:83
+msgid "Assign unique categories to new points"
+msgstr ""
+#: ../vector/v.net/args.c:84
+msgid "For operation 'nodes'"
+msgstr ""
+#: ../vector/v.net/args.c:89
+msgid "Snap points to network"
+msgstr ""
+#: ../vector/v.net/args.c:91
+msgid ""
+"For operation 'connect'. By default, a new line from the point to the "
+"network is created."
+msgstr ""
+#: ../vector/v.net/args.c:114
+msgid "Unknown operation"
+msgstr ""
+#: ../vector/v.net/args.c:141
+msgid "Threshold value must be >= 0"
+msgstr ""
+#: ../vector/v.net/report.c:37
+#, c-format
+msgid "Line %d has no category"
+msgstr ""
+#: ../vector/v.net/report.c:67
+#, c-format
+msgid "%d points found: %g %g %g line category: %d"
+msgstr ""
+#: ../vector/v.net/report.c:94
+#, c-format
+msgid "Duplicate nodes at x=%g y=%g z=%g "
+msgstr ""
+#: ../vector/v.category/main.c:76 ../raster/r.category/main.c:53
+msgid "category"
+msgstr ""
+#: ../vector/v.category/main.c:77 ../vector/v.db.connect/main.c:55
+msgid "layer"
+msgstr ""
+#: ../vector/v.category/main.c:79
+msgid "Attaches, deletes or reports vector categories to map geometry."
+msgstr ""
+#: ../vector/v.category/main.c:92
+msgid "Feature ids (by default all features are processed)"
+msgstr ""
+#: ../vector/v.category/main.c:104
+msgid "Action to be done"
+msgstr ""
+#: ../vector/v.category/main.c:115
+msgid "add a category to features without category in the given layer"
+msgstr ""
+#: ../vector/v.category/main.c:116
+msgid "delete category (cat=-1 to delete all categories of given layer)"
+msgstr ""
+#: ../vector/v.category/main.c:117
+msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
+msgstr ""
+#: ../vector/v.category/main.c:118
+msgid "add the value specified by cat option to the current category value"
+msgstr ""
+#: ../vector/v.category/main.c:119
+msgid ""
+"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
+"layer 1 to layer 2 and 3)"
+msgstr ""
+#: ../vector/v.category/main.c:120
+msgid "print report (statistics), in shell style: layer type count min max"
+msgstr ""
+#: ../vector/v.category/main.c:121
+msgid ""
+"print category values, layers are separated by '|', more cats in the same "
+"layer are separated by '/'"
+msgstr ""
+#: ../vector/v.category/main.c:122
+msgid "print only layer numbers"
+msgstr ""
+#: ../vector/v.category/main.c:134
+#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+msgid "Category increment"
+msgstr ""
+#: ../vector/v.category/main.c:138
+msgid "Shell script style, currently only for report"
+msgstr ""
+#: ../vector/v.category/main.c:139
+msgid "Format: layer type count min max"
+msgstr ""
+#: ../vector/v.category/main.c:142
+msgid "Do not copy attribute table(s)"
+msgstr ""
+#: ../vector/v.category/main.c:160
+msgid ""
+"Database connection and attribute tables for concerned layers are not changed"
+msgstr ""
+#: ../vector/v.category/main.c:208
+msgid ""
+"Invalid category number (must be equal to or greater than 0). Normally "
+"category number starts at 1."
+msgstr ""
+#: ../vector/v.category/main.c:217
+#, c-format
+msgid "%d error in id option"
+msgid_plural "%d errors in id option"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.category/main.c:228
+msgid "Output vector wasn't entered"
+msgstr ""
+#: ../vector/v.category/main.c:275
+msgid "Too many layers for this operation"
+msgstr ""
+#: ../vector/v.category/main.c:278 ../vector/v.category/main.c:281
+msgid "2 layers must be specified"
+msgstr ""
+#: ../vector/v.category/main.c:289
+#, c-format
+msgid "Categories already exist in layer %d"
+msgstr ""
+#: ../vector/v.category/main.c:364 ../vector/v.delaunay/main.c:172
+#: ../vector/v.in.ogr/main.c:1380
+msgid "Unable to calculate area centroid"
+msgstr ""
+#: ../vector/v.category/main.c:378
+#, c-format
+msgid "%d new centroid placed in output map"
+msgid_plural "%d new centroids placed in output map"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.category/main.c:670
+msgid "Layer/table"
+msgstr ""
+#: ../vector/v.category/main.c:674
+msgid "Layer"
+msgstr ""
+#: ../vector/v.category/main.c:676
+#, c-format
+msgid "type       count        min        max\n"
+msgstr ""
+#: ../vector/v.category/main.c:685
+msgid "boundary"
+msgstr ""
+#: ../vector/v.category/main.c:689
+#: ../locale/scriptstrings/v.centroids_to_translate.c:3
+msgid "centroid"
+msgstr ""
+#: ../vector/v.category/main.c:697
+msgid "face"
+msgstr ""
+#: ../vector/v.category/main.c:701
+msgid "kernel"
+msgstr ""
+#: ../vector/v.category/main.c:705
+msgid "all"
+msgstr ""
+#: ../vector/v.category/main.c:759 ../vector/v.rectify/main.c:274
+msgid "Copying attribute table(s)..."
+msgstr ""
+#: ../vector/v.category/main.c:769
+#, c-format
+msgid "Categories copied from layer %d to layer %d"
+msgstr ""
+#: ../vector/v.category/main.c:773
+#, c-format
+msgid "%d feature modified."
+msgid_plural "%d features modified."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.reclass/main.c:68 ../raster/r.reclass/main.c:51
+msgid "reclassification"
+msgstr ""
+#: ../vector/v.reclass/main.c:69
+msgid "attributes"
+msgstr ""
+#: ../vector/v.reclass/main.c:71
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../vector/v.reclass/main.c:88
+msgid "The name of the column whose values are to be used as new categories"
+msgstr ""
+#: ../vector/v.reclass/main.c:89
+msgid "The source for the new key column must be type integer or string"
+msgstr ""
+#: ../vector/v.reclass/main.c:94
+msgid "Full path to the reclass rule file"
+msgstr ""
+#: ../vector/v.reclass/main.c:104
+#, c-format
+msgid "Either '%s' or '%s' must be specified"
+msgstr ""
+#: ../vector/v.reclass/main.c:128 ../vector/v.surf.idw/read_sites.c:50
+#: ../vector/v.sample/main.c:133
+#, c-format
+msgid "Database connection not defined for layer %s"
+msgstr ""
+#: ../vector/v.reclass/main.c:254
+msgid "Key column type is not integer"
+msgstr ""
+#: ../vector/v.reclass/main.c:267 ../vector/v.db.select/main.c:211
+#, c-format
+msgid "Unable to fetch data from table <%s>"
+msgstr ""
+#: ../vector/v.reclass/main.c:298
+#, c-format
+msgid "Cannot insert data: [%s]"
+msgstr ""
+#: ../vector/v.reclass/main.c:336
+msgid "Column type must be integer or string"
+msgstr ""
+#: ../vector/v.reclass/main.c:348
+#, c-format
+msgid "Unable to open rule file <%s>"
+msgstr ""
+#: ../vector/v.reclass/main.c:364
+#, c-format
+msgid "Category %d overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:368
+#, c-format
+msgid "Category '%s' invalid"
+msgstr ""
+#: ../vector/v.reclass/main.c:372
+#, c-format
+msgid "Label '%s' overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:378
+#, c-format
+msgid "Condition '%s' overwritten by '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:383
+#, c-format
+msgid "Unknown rule option: '%s'"
+msgstr ""
+#: ../vector/v.reclass/main.c:397
+msgid "Cannot select values from database"
+msgstr ""
+#: ../vector/v.reclass/main.c:413
+#, c-format
+msgid "%d previously set categories overwritten by new category %d"
+msgstr ""
+#: ../vector/v.reclass/main.c:439
+msgid "Incomplete rule"
+msgstr ""
+#: ../vector/v.reclass/main.c:475
+#, c-format
+msgid "%d features reclassed."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:145
+msgid "Performs surface interpolation from vector points map by splines."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:147
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:154
+msgid "Perform cross-validation procedure without raster approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:155 ../vector/v.surf.rst/main.c:160
+#: ../vector/v.surf.rst/main.c:181 ../vector/v.surf.rst/main.c:253
+#: ../vector/v.surf.rst/main.c:261 ../vector/v.surf.rst/main.c:268
+#: ../vector/v.surf.rst/main.c:276 ../vector/v.surf.rst/main.c:284
+#: ../vector/v.surf.rst/main.c:293 ../vector/v.surf.rst/main.c:301
+#: ../vector/v.surf.rst/main.c:309 ../vector/v.surf.rst/main.c:318
+#: ../vector/v.surf.rst/main.c:326 ../vector/v.surf.rst/main.c:333
+#: ../raster/r.sim/r.sim.sediment/main.c:221
+#: ../raster/r.sim/r.sim.sediment/main.c:229
+#: ../raster/r.sim/r.sim.sediment/main.c:238
+#: ../raster/r.sim/r.sim.sediment/main.c:256
+#: ../raster/r.sim/r.sim.water/main.c:226
+#: ../raster/r.sim/r.sim.water/main.c:234
+#: ../raster/r.sim/r.sim.water/main.c:243
+#: ../raster/r.sim/r.sim.water/main.c:261
+#: ../raster/r.sim/r.sim.water/main.c:271
+#: ../raster/r.sim/r.sim.water/main.c:279
+#: ../raster/r.sim/r.sim.water/main.c:288 ../imagery/i.eb.hsebal01/main.c:141
+#: ../imagery/i.eb.hsebal01/main.c:150 ../imagery/i.eb.hsebal01/main.c:157
+#: ../imagery/i.eb.hsebal01/main.c:164 ../imagery/i.eb.hsebal01/main.c:171
+#: ../imagery/i.eb.hsebal01/main.c:178
+msgid "Parameters"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:159
+msgid "Use scale dependent tension"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:165 ../raster/r.resamp.rst/main.c:263
+msgid "Output partial derivatives instead of topographic parameters"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.idw/main.c:102
+msgid ""
+"If not given and input is 2D vector map then category values are used. If "
+"input is 3D vector map then z-coordinates are used."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:189
+msgid "Name for output surface elevation raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:195 ../raster/r.slope.aspect/main.c:165
+msgid "Name for output slope raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:201 ../raster/r.slope.aspect/main.c:171
+msgid "Name for output aspect raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:207 ../raster/r.slope.aspect/main.c:196
+msgid "Name for output profile curvature raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:213 ../raster/r.slope.aspect/main.c:203
+msgid "Name for output tangential curvature raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:219
+msgid "Name for output mean curvature raster map"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:239
+msgid "Name for output vector map showing quadtree segmentation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:246
+msgid "Name for output vector map showing overlapping windows"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:252
+msgid "Name of raster map used as mask"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:275
+msgid "Name of the attribute column with smoothing parameters"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:308
+msgid ""
+"Maximum distance between points on isoline (to insert additional points)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:317
+msgid "Conversion factor for values used for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:325 ../raster/r.resamp.rst/main.c:246
+msgid "Anisotropy angle (in degrees counterclockwise from East)"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:332 ../raster/r.resamp.rst/main.c:253
+msgid "Anisotropy scaling factor"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:388 ../vector/v.surf.rst/main.c:393
+#: ../vector/v.surf.rst/main.c:398 ../vector/v.surf.rst/main.c:403
+#, c-format
+msgid "Output vector map name <%s> is not valid map name"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:416
+msgid "You are not outputting any raster or vector maps"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:425
+msgid ""
+"Both cross-validation options (-c flag and cvdev vector output) must be "
+"specified"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:428
+msgid ""
+"The cross-validation cannot be computed simultaneously with output raster or "
+"devi file"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:446
+msgid "Using anisotropy - both theta and scalex have to be specified"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:454
+msgid "Both smatt and smooth options specified - using constant"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:464
+msgid "The computation will last too long - lower npmin is suggested"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:547
+msgid "Input is 2D: using attribute values for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:549
+msgid "Input is 2D: using category values for approximation"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:662
+#, c-format
+msgid ""
+"Processing all selected output files will require %d bytes of disk space for "
+"temp files"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:682
+msgid "Processing segments..."
+msgstr ""
+#: ../vector/v.surf.rst/main.c:688
+msgid "Interp_segmets failed"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:706
+msgid "Unable to write raster maps - try to increase resolution"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:821 ../vector/v.in.ascii/main.c:271
+#: ../general/g.setproj/get_stp.c:162 ../general/g.setproj/get_stp.c:165
+#: ../general/g.setproj/get_stp.c:282 ../general/g.setproj/get_stp.c:286
+#: ../raster/r.in.ascii/main.c:124 ../raster/r.in.ascii/main.c:154
+#: ../raster/r.resamp.rst/main.c:542 ../display/d.title/main.c:117
+#, c-format
+msgid "Unable to open temporary file <%s>"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:826 ../raster/r.thin/io.c:128
+#: ../raster/r.thin/io.c:135 ../raster/r.thin/io.c:144
+#: ../raster/r.resamp.rst/main.c:547
+#, c-format
+msgid "Error writing temporary file <%s>"
+msgstr ""
+#: ../vector/v.perturb/main.c:69
+msgid "Random location perturbations of vector points."
+msgstr ""
+#: ../vector/v.perturb/main.c:83
+msgid "Distribution of perturbation"
+msgstr ""
+#: ../vector/v.perturb/main.c:90
+msgid "Parameter(s) of distribution"
+msgstr ""
+#: ../vector/v.perturb/main.c:91
+msgid ""
+"If the distribution is uniform, only one parameter, the maximum, is needed. "
+"For a normal distribution, two parameters, the mean and standard deviation, "
+"are required."
+msgstr ""
+#: ../vector/v.perturb/main.c:101
+msgid "Minimum deviation in map units"
+msgstr ""
+#: ../vector/v.perturb/main.c:108
+msgid "Seed for random number generation"
+msgstr ""
+#: ../vector/v.perturb/main.c:129 ../vector/v.perturb/main.c:136
+msgid "Error scanning arguments"
+msgstr ""
+#: ../vector/v.perturb/main.c:132
+msgid "Maximum of uniform distribution must be >= zero"
+msgstr ""
+#: ../vector/v.perturb/main.c:139
+msgid "Standard deviation of normal distribution must be >= zero"
+msgstr ""
+#: ../vector/v.perturb/main.c:244
+msgid "Cannot get db link info"
+msgstr ""
+#: ../vector/v.perturb/normalrs.c:31
+msgid "normalsv: restoration of unitialized block"
+msgstr ""
+#: ../vector/v.perturb/normalsv.c:29
+msgid "normalsv: save of unitialized block"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:86
+msgid "Exports a vector map layer to any of the supported OGR vector formats."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:87
+msgid "By default a vector map layer is exported to Esri Shapefile format."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:164
+msgid "Volumes will be exported as sets of faces"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:182
+msgid "Unable to determine input map's vector feature type(s)."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:197
+#, c-format
+msgid "Appending to OGR layer requires option '%s'"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:252
+msgid "The combination of types is not supported by all formats."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:276
+#, c-format
+msgid "Unknown EPSG code %s"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:294
+#, c-format
+msgid "OGR layer <%s> created in datasource <%s> (format '%s')"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:306
+msgid ""
+"The map contains islands. With the -c flag, islands will appear as filled "
+"areas, not holes in the output map."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:312
+#, c-format
+msgid ""
+"%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d points found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:320
+#, c-format
+msgid ""
+"%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:329
+#, c-format
+msgid ""
+"%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d boundaries found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:338
+#, c-format
+msgid ""
+"%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d centroids found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:346
+#, c-format
+msgid ""
+"%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:354
+#, c-format
+msgid ""
+"%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:362
+#, c-format
+msgid ""
+"%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:372
+msgid ""
+"No points found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:381
+msgid ""
+"No lines found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:391
+msgid ""
+"No boundaries found, but requested to be exported. Will skip this feature "
+"type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:400
+msgid ""
+"No areas found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:410
+msgid ""
+"No centroids found, but requested to be exported. Will skip this feature "
+"type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:419
+msgid ""
+"No faces found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:428
+msgid ""
+"No kernels found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:437
+msgid ""
+"No volumes found, but requested to be exported. Will skip this feature type."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:462
+#, c-format
+msgid "OGR driver <%s> not found"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:489
+#, c-format
+msgid "Unable to open OGR data source '%s'"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:503
+#, c-format
+msgid "Layer <%s> already exists in OGR data source '%s'"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:507
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:514
+#, c-format
+msgid "OGR layer <%s> doesn't exists, creating new OGR layer instead"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:542
+msgid "Overriding existing user-defined 'SHPT=' LCO."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:557
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
+"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:569
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options DIM "
+"(parameter 'lco') to export in 3D rather than 2D (default)."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:576
+#, c-format
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
+"'lco') to export <in 3D rather than 2D (default)."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:595
+msgid "Unable to create OGR layer"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:607
+msgid "No attribute table found -> using only category numbers as attributes"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:611
+msgid "Exporting 'cat' anyway, as it is the only attribute table field"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:620 ../vector/v.out.ogr/main.c:692
+#, c-format
+msgid "New attribute column <%s> added to the table"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:704
+#, c-format
+msgid "Key column <%s> not found"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:717
+#, c-format
+msgid "Exporting %d feature..."
+msgid_plural "Exporting %d features..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:732
+#, c-format
+msgid "Exporting %d area (may take some time)..."
+msgid_plural "Exporting %d areas (may take some time)..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:751
+#, c-format
+msgid "Exporting %d volume..."
+msgid_plural "Exporting %d volumes..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:755
+msgid "Export of volumes not implemented yet. Skipping."
+msgstr ""
+#: ../vector/v.out.ogr/main.c:772
+#, c-format
+msgid "%d feature without attributes was written"
+msgid_plural "%d features without attributes were written"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:778
+#, c-format
+msgid "%d feature without category was written"
+msgid_plural "%d features without category were written"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:782
+#, c-format
+msgid ""
+"%d feature without category was skipped. Features without category are "
+"written only when -%c flag is given."
+msgid_plural ""
+"%d features without category were skipped. Features without category are "
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/main.c:798
+msgid "Output layer is empty, no features written"
+msgstr ""
+#: ../vector/v.out.ogr/main.c:799
+#, c-format
+msgid "%d feature (%s type) written to <%s> (%s format)."
+msgid_plural "%d features (%s type) written to <%s> (%s format)."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.ogr/export_areas.c:150
+#: ../vector/v.out.ogr/export_lines.c:172
+#, c-format
+msgid "Unable to export multi-features. No category index for layer %d."
+msgstr ""
+#: ../vector/v.out.ogr/export_areas.c:161
+msgid "Exporting features with category..."
+msgstr ""
+#: ../vector/v.out.ogr/export_areas.c:183
+#: ../vector/v.out.ogr/export_lines.c:206
+#, c-format
+msgid ""
+"Unable to create multi-feature. Category %d not found in line %d, field %d"
+msgstr ""
+#: ../vector/v.out.ogr/export_areas.c:221
+msgid "Exporting features without category..."
+msgstr ""
+#: ../vector/v.out.ogr/args.c:9
+msgid "Name of input vector map to export"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:18
+msgid "Feature type(s)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:20
+msgid ""
+"Combination of types is not supported by all output formats. Default is to "
+"use first type found in input vector map."
+msgstr ""
+#: ../vector/v.out.ogr/args.c:28
+msgid "Name of output OGR datasource"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:30
+msgid ""
+"For example: ESRI Shapefile: filename or directory for storage\n"
+"\t\t\tPostGIS database: connection string"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:40
+msgid "Data format to write"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:47
+msgid "Name for output OGR layer. If not specified, input name is used"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:49
+msgid ""
+"For example: ESRI Shapefile: shapefile name\n"
+"\t\t\tPostGIS database: table name"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:51 ../vector/v.out.ogr/args.c:62
+#: ../vector/v.out.ogr/args.c:72 ../vector/v.out.ogr/args.c:82
+#: ../vector/v.out.ogr/args.c:97 ../vector/v.out.ogr/args.c:110
+#: ../vector/v.out.ogr/args.c:117 ../vector/v.out.ogr/args.c:123
+#: ../vector/v.out.ogr/args.c:130 ../vector/v.out.postgis/args.c:38
+#: ../vector/v.out.postgis/args.c:48 ../vector/v.out.postgis/args.c:61
+#: ../vector/v.out.postgis/args.c:67 ../vector/v.out.postgis/args.c:73
+#: ../vector/v.out.postgis/args.c:79 ../raster/r.out.gdal/main.c:149
+#: ../raster/r.out.gdal/main.c:196 ../raster/r.out.gdal/main.c:207
+#: ../raster/r.out.gdal/main.c:218 ../raster/r.out.gdal/main.c:227
+msgid "Creation"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:57
+msgid "Optionally change default output type"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:60
+msgid "export area boundaries as linestrings"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:61
+msgid "export lines as polygons"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:71
+msgid "OGR dataset creation option (format specific, NAME=VALUE)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:81
+msgid "OGR layer creation option (format specific, NAME=VALUE)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:86
+msgid "Open an existing OGR datasource for update"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:90
+msgid "Append to existing layer"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:91
+msgid "A new OGR layer is created if it does not exist"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:96
+msgid "Skip export of GRASS category ID ('cat') attribute"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:102
+msgid ""
+"Also export features without category (not labeled). Otherwise only features "
+"with category are exported."
+msgstr ""
+#: ../vector/v.out.ogr/args.c:108
+msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:114
+msgid "Force 2D output even if input is 3D (applies to Shapefile output only)"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:116 ../vector/v.in.ogr/main.c:270
+#: ../vector/v.out.postgis/args.c:78
+msgid "Useful if input is 3D but all z coordinates are identical"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:122
+msgid "Export vector data as multi-features"
+msgstr ""
+#: ../vector/v.out.ogr/args.c:128
+msgid ""
+"Create a new empty layer in defined OGR datasource and exit. Nothing is read "
+"from input."
+msgstr ""
+#: ../vector/v.out.ogr/attrb.c:65
+#, c-format
+msgid "No database record for cat = %d and export of 'cat' disabled"
+msgstr ""
+#: ../vector/v.out.ogr/create.c:20
+#, c-format
+msgid "OGR driver <%s> not available"
+msgstr ""
+#: ../vector/v.out.ogr/create.c:26
+#, c-format
+msgid "Creation of output OGR datasource <%s> failed"
+msgstr ""
+#: ../vector/v.out.ogr/create.c:36
+#, c-format
+msgid "Creation of OGR layer <%s> failed"
+msgstr ""
+#: ../vector/v.out.pov/main.c:49
+msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
+msgstr ""
+#: ../vector/v.out.pov/main.c:60
+msgid "Name for output POV file"
+msgstr ""
+#: ../vector/v.out.pov/main.c:67
+msgid "Radius of sphere for points and tube for lines"
+msgstr ""
+#: ../vector/v.out.pov/main.c:68
+msgid "May be also variable, e.g. grass_r."
+msgstr ""
+#: ../vector/v.out.pov/main.c:74
+msgid "Modifier for z coordinates"
+msgstr ""
+#: ../vector/v.out.pov/main.c:75
+msgid ""
+"This string is appended to each z coordinate. Examples: '*10', '+1000', "
+"'*10+100', '*exaggeration'"
+msgstr ""
+#: ../vector/v.out.pov/main.c:82
+msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
+msgstr ""
+#: ../vector/v.out.pov/main.c:83
+msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
+msgstr ""
+#: ../vector/v.out.pov/main.c:104 ../raster/r.topmodel/topmodel.c:75
+#: ../raster/r.topmodel/file_io.c:209
+#, c-format
+msgid "Unable to create output file <%s>"
+msgstr ""
+#: ../vector/v.out.pov/main.c:218
+#, c-format
+msgid "%d feature written."
+msgid_plural "%d features written."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.net.distance/main.c:67
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features."
+msgstr ""
+#: ../vector/v.net.distance/main.c:70
+msgid ""
+"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
+"and various information about this relation are uploaded to the attribute "
+"table."
+msgstr ""
+#: ../vector/v.net.distance/main.c:98
+msgid "From layer number or name"
+msgstr ""
+#: ../vector/v.net.distance/main.c:103
+msgid "From category values"
+msgstr ""
+#: ../vector/v.net.distance/main.c:109
+msgid "From WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.distance/main.c:114
+msgid "To layer number or name"
+msgstr ""
+#: ../vector/v.net.distance/main.c:121
+msgid "To feature type"
+msgstr ""
+#: ../vector/v.net.distance/main.c:126
+msgid "To category values"
+msgstr ""
+#: ../vector/v.net.distance/main.c:132
+msgid "To WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.distance/main.c:219
+#, c-format
+msgid "No 'from' features selected. Please check options '%s', '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.distance/main.c:226
+#, c-format
+msgid "No 'to' features selected. Please check options '%s', '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.distance/main.c:235
+msgid "No 'to' features"
+msgstr ""
+#: ../vector/v.net.distance/main.c:354
+#, c-format
+msgid "%d 'from' feature was not reachable"
+msgid_plural "%d 'from' features were not reachable"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.outlier/main.c:71
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../vector/v.outlier/main.c:89
+msgid "Name of output outlier vector map"
+msgstr ""
+#: ../vector/v.outlier/main.c:97
+msgid "Name of vector map for visualization in QGIS"
+msgstr ""
+#: ../vector/v.outlier/main.c:121
+msgid "Tykhonov regularization weight"
+msgstr ""
+#: ../vector/v.outlier/main.c:129
+msgid "Threshold for the outliers"
+msgstr ""
+#: ../vector/v.outlier/main.c:136
+msgid "Filtering option"
+msgstr ""
+#: ../vector/v.outlier/main.c:260
+#, c-format
+msgid "It was impossible to create <%s> table."
+msgstr ""
+#: ../vector/v.outlier/main.c:352
+msgid ""
+"No subregions found! Check values for 'ew_step' and 'ns_step' parameters"
+msgstr ""
+#: ../vector/v.outlier/main.c:425
+msgid "Outlier detection"
+msgstr ""
+#: ../vector/v.outlier/outlier.c:86 ../vector/v.outlier/outlier.c:123
+#: ../vector/v.outlier/outlier.c:148 ../vector/v.outlier/outlier.c:161
+#: ../vector/v.outlier/outlier.c:185
+#: ../vector/v.lidar.correction/correction.c:93
+#: ../vector/v.lidar.correction/correction.c:127
+#: ../vector/v.lidar.correction/correction.c:151
+#: ../vector/v.lidar.correction/correction.c:163
+#: ../vector/v.lidar.correction/correction.c:187
+msgid "Impossible to read the database"
+msgstr ""
+#: ../vector/v.outlier/outlier.c:90 ../vector/v.outlier/outlier.c:152
+#: ../vector/v.lidar.correction/correction.c:97
+#: ../vector/v.lidar.correction/correction.c:155
+msgid "Impossible to update the database"
+msgstr ""
+#: ../vector/v.outlier/outlier.c:101 ../vector/v.outlier/outlier.c:110
+#: ../vector/v.outlier/outlier.c:207
+#: ../vector/v.lidar.correction/correction.c:107
+#: ../vector/v.lidar.correction/correction.c:115
+#: ../vector/v.lidar.correction/correction.c:210
+msgid "Impossible to write in the database"
+msgstr ""
+#: ../vector/v.proj/main.c:68 ../locale/scriptstrings/m.proj_to_translate.c:3
+#: ../general/g.proj/main.c:64 ../general/g.setproj/main.c:79
+#: ../raster/r.proj/main.c:145 ../raster/r.latlong/main.c:59
+msgid "projection"
+msgstr ""
+#: ../vector/v.proj/main.c:70
+msgid "Re-projects a vector map from one location to the current location."
+msgstr ""
+#: ../vector/v.proj/main.c:76
+msgid "Name of input vector map to re-project"
+msgstr ""
+#: ../vector/v.proj/main.c:78 ../vector/v.proj/main.c:83
+#: ../vector/v.proj/main.c:88 ../vector/v.proj/main.c:92
+#: ../vector/v.net.flow/main.c:108 ../vector/v.net.flow/main.c:114
+#: ../raster/r.proj/main.c:153 ../raster/r.proj/main.c:158
+#: ../raster/r.proj/main.c:163 ../raster/r.proj/main.c:167
+msgid "Source"
+msgstr ""
+#: ../vector/v.proj/main.c:82
+msgid "Location containing input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:86
+msgid "Mapset containing input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:87 ../raster/r.proj/main.c:162
+msgid "Default: name of current mapset"
+msgstr ""
+#: ../vector/v.proj/main.c:91 ../raster/r.proj/main.c:166
+msgid "Path to GRASS database of input location"
+msgstr ""
+#: ../vector/v.proj/main.c:99
+msgid "Maximum segment length in meters in output vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:100
+msgid "Increases accuracy of reprojected shapes, disable with smax=0"
+msgstr ""
+#: ../vector/v.proj/main.c:101 ../vector/v.proj/main.c:106
+#: ../vector/v.proj/main.c:118 ../vector/v.proj/main.c:125
+#: ../raster/r.proj/main.c:172 ../raster/r.proj/main.c:183
+#: ../raster/r.proj/main.c:199
+msgid "Target"
+msgstr ""
+#: ../vector/v.proj/main.c:105
+msgid "Name for output vector map (default: input)"
+msgstr ""
+#: ../vector/v.proj/main.c:110
+msgid "List vector maps in input mapset and exit"
+msgstr ""
+#: ../vector/v.proj/main.c:114
+msgid "3D vector maps only"
+msgstr ""
+#: ../vector/v.proj/main.c:116
+msgid "Assume z coordinate is ellipsoidal height and transform if possible"
+msgstr ""
+#: ../vector/v.proj/main.c:122
+msgid "Latlon output only, default is -180,180"
+msgstr ""
+#: ../vector/v.proj/main.c:124
+msgid "Disable wrapping to -180,180 for latlon output"
+msgstr ""
+#: ../vector/v.proj/main.c:144 ../vector/v.external/main.c:139
+#: ../raster/r.proj/main.c:245 ../display/d.mon/start.c:38
+#, c-format
+msgid "option <%s>: <%s> exists."
+msgstr ""
+#: ../vector/v.proj/main.c:159 ../raster/r.proj/main.c:251
+msgid "Input and output locations can not be the same"
+msgstr ""
+#: ../vector/v.proj/main.c:183 ../raster/r.proj/main.c:287
+#, c-format
+msgid "Checking location <%s> mapset <%s>"
+msgstr ""
+#: ../vector/v.proj/main.c:194
+msgid "No vector maps found"
+msgstr ""
+#: ../vector/v.proj/main.c:207
+#, c-format
+msgid "Vector map <%s> in location <%s> mapset <%s> not found"
+msgstr ""
+#: ../vector/v.proj/main.c:237
+#, c-format
+msgid "Mapset <%s> in input location <%s> - permission denied"
+msgstr ""
+#: ../vector/v.proj/main.c:240
+#, c-format
+msgid "Mapset <%s> in input location <%s> not found"
+msgstr ""
+#: ../vector/v.proj/main.c:285 ../vector/v.proj/main.c:411
+#: ../vector/v.rectify/main.c:233
+msgid "Reading input vector map"
+msgstr ""
+#: ../vector/v.proj/main.c:308
+#, c-format
+msgid "Input vector map <%s> is empty"
+msgstr ""
+#: ../vector/v.proj/main.c:316 ../vector/v.proj/main.c:327
+#: ../vector/v.proj/main.c:342 ../vector/v.proj/main.c:357
+msgid "Error in pj_do_transform"
+msgstr ""
+#: ../vector/v.proj/main.c:402
+msgid "Reprojecting primitives ..."
+msgstr ""
+#: ../vector/v.proj/main.c:439 ../vector/v.proj/main.c:446
+#: ../vector/v.proj/main.c:472 ../vector/v.proj/main.c:486
+#, c-format
+msgid "Unable to re-project vector map <%s> from <%s>"
+msgstr ""
+#: ../vector/v.proj/main.c:505
+msgid "Try to disable wrapping to -180,180 if topological errors occurred"
+msgstr ""
+#: ../vector/v.support/main.c:41
+msgid "Updates vector map metadata."
+msgstr ""
+#: ../vector/v.support/main.c:52
+msgid "Organization where vector map was created"
+msgstr ""
+#: ../vector/v.support/main.c:61
+msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
+msgstr ""
+#: ../vector/v.support/main.c:68
+msgid "Person who created vector map"
+msgstr ""
+#: ../vector/v.support/main.c:75
+msgid "Vector map title"
+msgstr ""
+#: ../vector/v.support/main.c:83
+msgid "Date when the source map was originally produced"
+msgstr ""
+#: ../vector/v.support/main.c:89
+msgid "Vector map scale number (e.g., 24000)"
+msgstr ""
+#: ../vector/v.support/main.c:95
+msgid "Vector map projection zone"
+msgstr ""
+#: ../vector/v.support/main.c:102
+msgid "Vector map digitizing threshold number (e.g., 0.5)"
+msgstr ""
+#: ../vector/v.support/main.c:110
+msgid "Text to append to the comment line of the map's metadata file"
+msgstr ""
+#: ../vector/v.support/main.c:118
+msgid ""
+"Command line to store into vector map history file (used for vector scripts)"
+msgstr ""
+#: ../vector/v.support/main.c:122
+msgid "Replace comment instead of appending it"
+msgstr ""
+#: ../vector/v.support/main.c:183
+#, c-format
+msgid "Unable to open history file for vector map <%s>"
+msgstr ""
+#: ../vector/v.what/main.c:63
+msgid "Queries a vector map at given locations."
+msgstr ""
+#: ../vector/v.what/main.c:75 ../raster/r.what/main.c:109
+msgid "Coordinates for query"
+msgstr ""
+#: ../vector/v.what/main.c:83
+msgid "Query threshold distance"
+msgstr ""
+#: ../vector/v.what/main.c:84
+msgid "Threshold"
+msgstr ""
+#: ../vector/v.what/main.c:88
+msgid "Print topological information (debugging)"
+msgstr ""
+#: ../vector/v.what/main.c:93
+msgid "Print attribute information"
+msgstr ""
+#: ../vector/v.what/main.c:98 ../vector/v.univar/main.c:126
+#: ../raster/r.univar/r3.univar_main.c:59
+#: ../raster/r.univar/r.univar_main.c:61
+msgid "Print the stats in shell script style"
+msgstr ""
+#: ../vector/v.what/main.c:103
+msgid "Print the stats in JSON"
+msgstr ""
+#: ../vector/v.what/main.c:118
+msgid "No input vector maps!"
+msgstr ""
+#: ../vector/v.what/main.c:121
+msgid "Flags g and j are mutually exclusive"
+msgstr ""
+#: ../vector/v.what/main.c:166
+#, c-format
+msgid "Number of given vector maps (%d) differs from number of layers (%d)"
+msgstr ""
+#: ../vector/v.what/main.c:175
+#, c-format
+msgid "You must build topology on vector map <%s>"
+msgstr ""
+#: ../vector/v.what/main.c:192
+#, c-format
+msgid "Unknown input format, skipping: '%s'"
+msgstr ""
+#: ../vector/v.what/what.c:227
+#, c-format
+msgid "Nothing found.\n"
+msgstr ""
+#: ../vector/v.what/what.c:293
+#, c-format
+msgid ""
+"Id: %d\n"
+"Type: %s\n"
+"Left: %d\n"
+"Right: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:298 ../vector/v.what/what.c:368
+#, c-format
+msgid "Length: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:317
+#, c-format
+msgid ""
+"Node[%d]=%d\n"
+"Number_lines=%d\n"
+"Coordinates=%.6f,%.6f,%.6f\n"
+msgstr ""
+#: ../vector/v.what/what.c:322
+#, c-format
+msgid ""
+",\n"
+"\"Node[%d]\": %d,\n"
+"\"Number_lines\": %d,\n"
+"\"Coordinates\": %.6f,%.6f,%.6f"
+msgstr ""
+#: ../vector/v.what/what.c:327
+#, c-format
+msgid ""
+"Node[%d]: %d\n"
+"Number of lines: %d\n"
+"Coordinates: %.6f, %.6f, %.6f\n"
+msgstr ""
+#: ../vector/v.what/what.c:345
+#, c-format
+msgid ""
+"Id: %5d\n"
+"Angle: %.8f\n"
+msgstr ""
+#: ../vector/v.what/what.c:365
+#, c-format
+msgid "Type: %s\n"
+msgstr ""
+#: ../vector/v.what/what.c:366
+#, c-format
+msgid "Id: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:385
+#, c-format
+msgid "Point height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:405
+#, c-format
+msgid "Line height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:421
+#, c-format
+msgid ""
+"Line height min: %f\n"
+"Line height max: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:438
+#, c-format
+msgid ""
+"Type: Area\n"
+"Area height: %f\n"
+msgstr ""
+#: ../vector/v.what/what.c:449
+#, c-format
+msgid "Type: Area\n"
+msgstr ""
+#: ../vector/v.what/what.c:475
+#, c-format
+msgid ""
+"Area: %d\n"
+"Number of isles: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:488
+#, c-format
+msgid "Isle[%d]: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:505
+#, c-format
+msgid "Island: %d In area: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:524
+#, c-format
+msgid ""
+"Sq Meters: %.3f\n"
+"Hectares: %.3f\n"
+msgstr ""
+#: ../vector/v.what/what.c:526
+#, c-format
+msgid ""
+"Acres: %.3f\n"
+"Sq Miles: %.4f\n"
+msgstr ""
+#: ../vector/v.what/what.c:556
+#, c-format
+msgid ""
+"Layer: %d\n"
+"Category: %d\n"
+msgstr ""
+#: ../vector/v.what/what.c:576
+#, c-format
+msgid ""
+"\n"
+"Driver: %s\n"
+"Database: %s\n"
+"Table: %s\n"
+"Key column: %s\n"
+msgstr ""
+#: ../vector/v.patch/main.c:70
+msgid "Creates a new vector map by combining other vector maps."
+msgstr ""
+#: ../vector/v.patch/main.c:81
+msgid ""
+"Name for output vector map where bounding boxes of input vector maps are "
+"written to"
+msgstr ""
+#: ../vector/v.patch/main.c:85
+msgid ""
+"Append files to existing file (overwriting existing files must be activated)"
+msgstr ""
+#: ../vector/v.patch/main.c:90
+msgid "Copy also attribute table"
+msgstr ""
+#: ../vector/v.patch/main.c:92
+msgid "Only the table of layer 1 is currently supported"
+msgstr ""
+#: ../vector/v.patch/main.c:199
+msgid "Missing table"
+msgstr ""
+#: ../vector/v.patch/main.c:203
+msgid "Key columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:209
+msgid "Number of columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:221
+msgid "Column names differ"
+msgstr ""
+#: ../vector/v.patch/main.c:229
+msgid "Column types differ"
+msgstr ""
+#: ../vector/v.patch/main.c:234
+msgid "Length of string columns differ"
+msgstr ""
+#: ../vector/v.patch/main.c:248
+msgid "Key column not found"
+msgstr ""
+#: ../vector/v.patch/main.c:260
+msgid "The output map is not 3D"
+msgstr ""
+#: ../vector/v.patch/main.c:305 ../vector/v.sample/main.c:190
+#, c-format
+msgid "Unable to create table <%s>"
+msgstr ""
+#: ../vector/v.patch/main.c:332
+#, c-format
+msgid "Patching vector map <%s>..."
+msgstr ""
+#: ../vector/v.patch/main.c:356
+#, c-format
+msgid "Error reading vector map <%s> - some data may not be correct"
+msgstr ""
+#: ../vector/v.patch/main.c:409
+#, c-format
+msgid "Building topology for vector map <%s>..."
+msgstr ""
+#: ../vector/v.patch/main.c:415
+msgid "Intersections at borders will have to be snapped"
+msgstr ""
+#: ../vector/v.patch/main.c:416
+msgid "Lines common between files will have to be edited"
+msgstr ""
+#: ../vector/v.patch/main.c:417
+msgid "The header information also may have to be edited"
+msgstr ""
+#: ../vector/v.patch/main.c:419
+#, c-format
+msgid "%d vector maps patched"
+msgstr ""
+#: ../vector/v.patch/main.c:442
+#, c-format
+msgid "Cannot open select cursor: '%s'"
+msgstr ""
+#: ../vector/v.patch/main.c:454
+msgid "Cannot fetch row"
+msgstr ""
+#: ../vector/v.patch/main.c:504
+msgid "Unknown column type"
+msgstr ""
+#: ../vector/v.patch/main.c:512
+#, c-format
+msgid "Cannot insert new record: '%s'"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:159
+msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:162 ../raster/r.in.lidar/main.c:177
+msgid "LAS input file"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:163 ../raster/r.in.lidar/main.c:178
+msgid "LiDAR input files in LAS format (*.las or *.laz)"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:173 ../vector/v.in.ogr/main.c:169
+msgid "Import subregion only"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:174 ../vector/v.in.lidar/main.c:218
+msgid "Subregion"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:176 ../vector/v.in.ogr/main.c:172
+msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:182 ../vector/v.in.ogr/main.c:214
+#: ../raster/r.in.gdal/main.c:144
+msgid "Name for new location to create"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:189 ../raster/r.in.lidar/main.c:252
+msgid "Only import points of selected return type"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:190 ../raster/r.in.lidar/main.c:253
+msgid "If not specified, all points are imported"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:198 ../raster/r.in.lidar/main.c:261
+msgid "Only import points of selected class(es)"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:199 ../raster/r.in.lidar/main.c:262
+msgid ""
+"Input is comma separated integers. If not specified, all points are imported."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:205 ../raster/r.in.lidar/main.c:268
+msgid "Print LAS file info and exit"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:214 ../vector/v.in.ogr/main.c:279
+#: ../raster/r.in.lidar/main.c:279
+msgid "Override dataset projection (use location's projection)"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:219 ../vector/v.in.ogr/main.c:284
+msgid "Limit import to the current region"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:224 ../vector/v.in.ogr/main.c:289
+#: ../raster/r.in.lidar/main.c:274 ../raster/r.external/main.c:104
+#: ../raster/r.in.gdal/main.c:162
+msgid "Extend region extents based on new dataset"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:229 ../vector/v.in.ogr/main.c:302
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the vector data."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:245 ../raster/r.in.lidar/main.c:310
+#, c-format
+msgid "Input file <%s> does not exist"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:252 ../raster/r.in.lidar/main.c:320
+#, c-format
+msgid "Input file <%s> is not a LAS LiDAR point cloud"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:292 ../raster/r.in.lidar/main.c:347
+#, c-format
+msgid "Unknown filter option <%s>"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:297 ../vector/v.in.ogr/main.c:712
+msgid "Select either the current region flag or the spatial option, not both"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:325 ../vector/v.in.ogr/main.c:770
+msgid "4 parameters required for 'spatial' parameter"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:354 ../vector/v.in.ogr/main.c:579
+#: ../raster/r.in.gdal/main.c:388 ../raster/r.in.gdal/main.c:741
+msgid ""
+"Unable to convert input map projection to GRASS format; cannot create new "
+"location."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:360 ../vector/v.in.ogr/main.c:585
+#: ../raster/r.in.gdal/main.c:394 ../raster/r.in.gdal/main.c:765
+#, c-format
+msgid "Unable to create new location <%s>"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:363 ../vector/v.in.ogr/main.c:588
+#: ../general/g.proj/create.c:15 ../raster/r.in.gdal/main.c:397
+#: ../raster/r.in.gdal/main.c:771
+#, c-format
+msgid "Location <%s> created"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:382 ../vector/v.in.ogr/main.c:606
+#: ../raster/r.in.lidar/main.c:362
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:397 ../vector/v.in.ogr/main.c:621
+#: ../raster/r.in.lidar/main.c:377 ../raster/r.external/proj.c:34
+#: ../raster/r.in.gdal/main.c:425
+msgid "Over-riding projection check"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:406 ../vector/v.in.ogr/main.c:630
+#: ../raster/r.in.lidar/main.c:386 ../raster/r.external/proj.c:42
+#: ../raster/r.in.gdal/main.c:435
+msgid ""
+"Projection of dataset does not appear to match current location.\n"
+"\n"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:412 ../vector/v.in.ogr/main.c:636
+#: ../raster/r.in.lidar/main.c:392
+msgid "GRASS LOCATION PROJ_INFO is:\n"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:422 ../vector/v.in.lidar/main.c:429
+#: ../vector/v.in.ogr/main.c:646 ../vector/v.in.ogr/main.c:653
+#: ../raster/r.in.lidar/main.c:402 ../raster/r.in.lidar/main.c:409
+#: ../raster/r.external/proj.c:85 ../raster/r.in.gdal/main.c:487
+msgid "Import dataset PROJ_INFO is:\n"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:468 ../vector/v.in.ogr/main.c:692
+#: ../raster/r.in.lidar/main.c:448 ../raster/r.external/proj.c:107
+#: ../raster/r.in.gdal/main.c:505
+#, c-format
+msgid ""
+"\n"
+"In case of no significant differences in the projection definitions, use the "
+"-o flag to ignore them and use current location definition.\n"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:473 ../vector/v.in.ogr/main.c:697
+#: ../raster/r.in.lidar/main.c:452
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:478 ../vector/v.in.ogr/main.c:702
+#: ../raster/r.in.lidar/main.c:457 ../raster/r.external/proj.c:116
+#: ../raster/r.in.gdal/main.c:514
+msgid "Projection of input dataset and current location appear to match"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:489 ../vector/v.kernel/main.c:224
+#, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:606
+#, c-format
+msgid "Unable open database <%s> by driver <%s>"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:640
+#, c-format
+msgid "Scanning %d points..."
+msgstr ""
+#: ../vector/v.in.lidar/main.c:807
+#, c-format
+msgid "%d points imported"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:810
+#, c-format
+msgid "%d input points were not valid"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:812
+#, c-format
+msgid "%d input points were outside of the selected area"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:814
+#, c-format
+msgid "%d input points were filtered out by return number"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:816
+#, c-format
+msgid "%d input points were filtered out by class number"
+msgstr ""
+#: ../vector/v.external/main.c:53
+msgid ""
+"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
+"PostGIS feature table."
+msgstr ""
+#: ../vector/v.external/main.c:133 ../vector/v.in.ogr/main.c:499
+#, c-format
+msgid "Layer <%s> not available"
+msgstr ""
+#: ../vector/v.external/main.c:158
+#, c-format
+msgid "Unable to delete '%s'"
+msgstr ""
+#: ../vector/v.external/main.c:165
+#, c-format
+msgid "Unable to create file '%s/%s'"
+msgstr ""
+#: ../vector/v.external/main.c:196
+#, c-format
+msgid "Link to vector map <%s> created."
+msgstr ""
+#: ../vector/v.external/args.c:14
+msgid "Name of input OGR or PostGIS data source"
+msgstr ""
+#: ../vector/v.external/args.c:26
+msgid "Name of OGR layer or PostGIS feature table to be linked"
+msgstr ""
+#: ../vector/v.external/args.c:27
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name\n"
+"\t\tPostGIS database: table name"
+msgstr ""
+#: ../vector/v.external/args.c:36
+msgid "Name for output GRASS vector map (default: input layer)"
+msgstr ""
+#: ../vector/v.external/args.c:46
+msgid "List available layers in data source and exit"
+msgstr ""
+#: ../vector/v.external/args.c:52
+msgid "List available layers including feature type in data source and exit"
+msgstr ""
+#: ../vector/v.external/args.c:54
+msgid "Format: layer name,type,projection check,geometry"
+msgstr ""
+#: ../vector/v.external/list.c:111
+msgid "GRASS is not compiled with PostgreSQL support"
+msgstr ""
+#: ../vector/v.external/list.c:117
+msgid "GRASS is not compiled with OGR support"
+msgstr ""
+#: ../vector/v.external/list.c:158
+msgid "Connection to PostgreSQL database failed."
+msgstr ""
+#: ../vector/v.external/list.c:168
+msgid "No feature tables found in database."
+msgstr ""
+#: ../vector/v.external/list.c:179
+#, c-format
+msgid "PostGIS database <%s> contains %d feature table:"
+msgid_plural "PostGIS database <%s> contains %d feature tables:"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.external/list.c:260
+#, c-format
+msgid "Unable to open data source '%s'"
+msgstr ""
+#: ../vector/v.external/list.c:267
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layer:"
+msgid_plural "Data source <%s> (format '%s') contains %d layers:"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.external/list.c:300
+#, c-format
+msgid ""
+"Unable to convert input map projection to GRASS format. Projection check "
+"cannot be provided for OGR layer <%s>"
+msgstr ""
+#: ../vector/v.external/list.c:316
+#, c-format
+msgid "Invalid geometry column %d"
+msgstr ""
+#: ../vector/v.delaunay/main.c:88
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+#: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:96
+msgid "Use only points in current region"
+msgstr ""
+#: ../vector/v.delaunay/main.c:103
+msgid "Output triangulation as a graph (lines), not areas"
+msgstr ""
+#: ../vector/v.delaunay/main.c:147
+msgid "no points to triangulate"
+msgstr ""
+#: ../vector/v.delaunay/main.c:150
+msgid "Delaunay triangulation..."
+msgstr ""
+#: ../vector/v.delaunay/main.c:162
+msgid "Calculating area centroids..."
+msgstr ""
+#: ../vector/v.delaunay/main.c:178
+msgid "Unable to calculate area centroid z coordinate"
+msgstr ""
+#: ../vector/v.delaunay/memory.c:64 ../vector/v.delaunay/memory.c:70
+#: ../vector/v.delaunay/memory.c:74 ../vector/v.delaunay/memory.c:84
+#: ../vector/v.delaunay/memory.c:92 ../vector/v.delaunay/memory.c:104
+#: ../vector/v.delaunay/memory.c:108
+msgid "Not enough memory."
+msgstr ""
+#: ../vector/v.delaunay/memory.c:124
+msgid "All allocated edges have been used."
+msgstr ""
+#: ../vector/v.delaunay/in_out.c:214
+msgid "Reading point features..."
+msgstr ""
+#: ../vector/v.buffer/geos.c:19
+msgid "Invalid GEOS geometry!"
+msgstr ""
+#: ../vector/v.buffer/geos.c:25
+msgid "No coordinates in GEOS geometry (can be ok for negative distance)!"
+msgstr ""
+#: ../vector/v.buffer/geos.c:33
+#, c-format
+msgid "Invalid x coordinate %f"
+msgstr ""
+#: ../vector/v.buffer/geos.c:35
+#, c-format
+msgid "Invalid y coordinate %f"
+msgstr ""
+#: ../vector/v.buffer/geos.c:107
+msgid "Corrupt GEOS geometry"
+msgstr ""
+#: ../vector/v.buffer/geos.c:135
+msgid "Unknown GEOS geometry type"
+msgstr ""
+#: ../vector/v.buffer/geos.c:164
+msgid "Buffering failed"
+msgstr ""
+#: ../vector/v.buffer/main.c:225 ../raster/r.circle/main.c:54
+msgid "circle"
+msgstr ""
+#: ../vector/v.buffer/main.c:229
+msgid "Creates a buffer around vector features of given type."
+msgstr ""
+#: ../vector/v.buffer/main.c:254
+msgid "Buffer distance along major axis in map units"
+msgstr ""
+#: ../vector/v.buffer/main.c:255 ../vector/v.buffer/main.c:263
+#: ../vector/v.buffer/main.c:271 ../vector/v.buffer/main.c:276
+#: ../vector/v.buffer/main.c:284 ../vector/v.buffer/main.c:293
+msgid "Distance"
+msgstr ""
+#: ../vector/v.buffer/main.c:262
+msgid "Buffer distance along minor axis in map units"
+msgstr ""
+#: ../vector/v.buffer/main.c:275
+msgid "Name of column to use for buffer distances"
+msgstr ""
+#: ../vector/v.buffer/main.c:283
+msgid "Scaling factor for attribute column values"
+msgstr ""
+#: ../vector/v.buffer/main.c:292
+msgid ""
+"Maximum distance between theoretical arc and polygon segments as multiple of "
+"buffer"
+msgstr ""
+#: ../vector/v.buffer/main.c:297
+msgid "Make outside corners straight"
+msgstr ""
+#: ../vector/v.buffer/main.c:302
+msgid "Do not make caps at the ends of polylines"
+msgstr ""
+#: ../vector/v.buffer/main.c:306
+msgid "Transfer categories and attributes"
+msgstr ""
+#: ../vector/v.buffer/main.c:326
+msgid ""
+"Note: In latitude-longitude coordinate system specify distances in degree "
+"unit"
+msgstr ""
+#: ../vector/v.buffer/main.c:330
+msgid "Select a buffer distance/minordistance/angle or column, but not both."
+msgstr ""
+#: ../vector/v.buffer/main.c:359
+msgid "The bufcol option requires a valid layer."
+msgstr ""
+#: ../vector/v.buffer/main.c:363
+msgid "The tolerance must be > 0."
+msgstr ""
+#: ../vector/v.buffer/main.c:366
+#, c-format
+msgid "The tolerance was reset to %g"
+msgstr ""
+#: ../vector/v.buffer/main.c:370
+msgid "Illegal scale value"
+msgstr ""
+#: ../vector/v.buffer/main.c:387
+#, c-format
+msgid "The tolerance in map units = %g"
+msgstr ""
+#: ../vector/v.buffer/main.c:428
+#, c-format
+msgid "Unable to select data from table <%s>"
+msgstr ""
+#: ../vector/v.buffer/main.c:464
+msgid ""
+"No features available for buffering. Check type option and features "
+"available in the input vector."
+msgstr ""
+#: ../vector/v.buffer/main.c:480
+msgid ""
+"Negative distances for internal buffers are not supported and converted to "
+"positive values."
+msgstr ""
+#: ../vector/v.buffer/main.c:490
+msgid "Buffering areas..."
+msgstr ""
+#: ../vector/v.buffer/main.c:526 ../vector/v.buffer/main.c:627
+#, c-format
+msgid "Attribute is of invalid size (%.3f) for category %d"
+msgstr ""
+#: ../vector/v.buffer/main.c:540 ../vector/v.buffer/main.c:645
+#, c-format
+msgid "The tolerance in map units: %g"
+msgstr ""
+#: ../vector/v.buffer/main.c:585
+msgid "Buffering features..."
+msgstr ""
+#: ../vector/v.buffer/main.c:588 ../vector/v.buffer/main.c:637
+msgid "Negative distances are only supported for areas"
+msgstr ""
+#: ../vector/v.buffer/main.c:710
+msgid "Cleaning buffers..."
+msgstr ""
+#: ../vector/v.buffer/main.c:713
+msgid "Building parts of topology..."
+msgstr ""
+#: ../vector/v.buffer/main.c:727
+msgid "Snapping boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:730 ../vector/v.in.ogr/main.c:1304
+msgid "Breaking polygons..."
+msgstr ""
+#: ../vector/v.buffer/main.c:737 ../vector/v.in.ogr/main.c:1319
+msgid "Breaking boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:743
+msgid "Cleaning boundaries at nodes"
+msgstr ""
+#: ../vector/v.buffer/main.c:764
+msgid "Calculating centroids for all areas..."
+msgstr ""
+#: ../vector/v.buffer/main.c:795
+msgid "Generating list of boundaries to be deleted..."
+msgstr ""
+#: ../vector/v.buffer/main.c:828
+msgid "Deleting boundaries..."
+msgstr ""
+#: ../vector/v.buffer/main.c:860
+msgid "Calculating centroids for areas..."
+msgstr ""
+#: ../vector/v.buffer/main.c:873
+#, c-format
+msgid "Unable to calculate centroid for area %d"
+msgstr ""
+#: ../vector/v.normal/main.c:76
+msgid "Tests for normality for vector points."
+msgstr ""
+#: ../vector/v.normal/main.c:88
+msgid "Lists of tests (1-15)"
+msgstr ""
+#: ../vector/v.normal/main.c:89
+msgid "E.g. 1,3-8,13"
+msgstr ""
+#: ../vector/v.normal/main.c:100
+msgid "Lognormality instead of normality"
+msgstr ""
+#: ../vector/v.normal/main.c:131
+msgid "Only numeric column type supported"
+msgstr ""
+#: ../vector/v.normal/main.c:174 ../vector/v.normal/main.c:182
+#, c-format
+msgid "No record for cat %d"
+msgstr ""
+#: ../vector/v.normal/main.c:192
+#, c-format
+msgid "Number of points: %d"
+msgstr ""
+#: ../vector/v.normal/main.c:195 ../vector/v.surf.idw/main.c:176
+#: ../vector/v.neighbors/main.c:176
+msgid "No points found"
+msgstr ""
+#: ../vector/v.normal/main.c:198
+msgid "Too small sample"
+msgstr ""
+#: ../vector/v.normal/main.c:206
+msgid "Negative or very small point values set to -10.0"
+msgstr ""
+#: ../vector/v.normal/main.c:223
+#, c-format
+msgid "Moments \\sqrt{b_1} and b_2: "
+msgstr ""
+#: ../vector/v.normal/main.c:228
+#, c-format
+msgid "Geary's a-statistic & an approx. normal: "
+msgstr ""
+#: ../vector/v.normal/main.c:233
+#, c-format
+msgid "Extreme normal deviates: "
+msgstr ""
+#: ../vector/v.normal/main.c:238
+#, c-format
+msgid "D'Agostino's D & an approx. normal: "
+msgstr ""
+#: ../vector/v.normal/main.c:244
+#, c-format
+msgid "Kuiper's V (regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:250
+#, c-format
+msgid "Watson's U^2 (regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:256
+#, c-format
+msgid "Durbin's Exact Test (modified Kolmogorov): "
+msgstr ""
+#: ../vector/v.normal/main.c:262
+#, c-format
+msgid "Anderson-Darling's A^2 (regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:268
+#, c-format
+msgid "Cramer-Von Mises W^2(regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:274
+#, c-format
+msgid "Kolmogorov-Smirnov's D (regular & modified for normality): "
+msgstr ""
+#: ../vector/v.normal/main.c:280
+#, c-format
+msgid "Chi-Square stat (equal probability classes) and d.f.: "
+msgstr ""
+#: ../vector/v.normal/main.c:286
+msgid "Shapiro-Wilk's W cannot be used for n > 50"
+msgstr ""
+#: ../vector/v.normal/main.c:288
+msgid "Use Weisberg-Binghams's W''"
+msgstr ""
+#: ../vector/v.normal/main.c:291
+#, c-format
+msgid "Shapiro-Wilk W: "
+msgstr ""
+#: ../vector/v.normal/main.c:298
+msgid "Weisberg-Bingham's W'' cannot be used for n < 50 or n > 99"
+msgstr ""
+#: ../vector/v.normal/main.c:300
+#, c-format
+msgid "Weisberg-Bingham's W'': "
+msgstr ""
+#: ../vector/v.normal/main.c:307
+msgid "Royston only extended Shapiro-Wilk's W up to n = 2000"
+msgstr ""
+#: ../vector/v.normal/main.c:309
+#, c-format
+msgid "Shapiro-Wilk W'': "
+msgstr ""
+#: ../vector/v.normal/main.c:315
+#, c-format
+msgid "Kotz' T'_f (Lognormality vs. Normality): "
+msgstr ""
+#: ../vector/v.db.connect/main.c:57
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../vector/v.db.connect/main.c:79
+msgid "Format: layer number[/layer name]"
+msgstr ""
+#: ../vector/v.db.connect/main.c:83
+msgid "Field separator for shell script style output"
+msgstr ""
+#: ../vector/v.db.connect/main.c:88
+msgid "Print all map connection parameters and exit"
+msgstr ""
+#: ../vector/v.db.connect/main.c:93
+msgid "Print all map connection parameters in shell script style and exit"
+msgstr ""
+#: ../vector/v.db.connect/main.c:95
+msgid "Format: layer[/layer name] table key database driver"
+msgstr ""
+#: ../vector/v.db.connect/main.c:101
+msgid "Print types/names of table columns for specified layer and exit"
+msgstr ""
+#: ../vector/v.db.connect/main.c:108
+msgid "Overwrite connection parameter for certain layer"
+msgstr ""
+#: ../vector/v.db.connect/main.c:113
+msgid "Delete connection for certain layer (not the table)"
+msgstr ""
+#: ../vector/v.db.connect/main.c:149
+msgid "Please choose only one print style"
+msgstr ""
+#: ../vector/v.db.connect/main.c:166
+#, c-format
+msgid "Map <%s> is not connected to a database"
+msgstr ""
+#: ../vector/v.db.connect/main.c:175
+#, c-format
+msgid "Vector map <%s> is connected by:\n"
+msgstr ""
+#: ../vector/v.db.connect/main.c:180 ../display/d.vect/opt.c:143
+#: ../display/d.vect.thematic/main.c:204
+msgid "Database connection not defined"
+msgstr ""
+#: ../vector/v.db.connect/main.c:197
+#, c-format
+msgid ""
+"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr ""
+#: ../vector/v.db.connect/main.c:203
+#, c-format
+msgid ""
+"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr ""
+#: ../vector/v.db.connect/main.c:266
+#, c-format
+msgid "Use -o to overwrite existing link for layer <%d>"
+msgstr ""
+#: ../vector/v.db.connect/main.c:274 ../vector/v.db.connect/main.c:314
+#, c-format
+msgid "Table <%s> does not exist in database <%s>"
+msgstr ""
+#: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
+#, c-format
+msgid ""
+"The table <%s> is now part of vector map <%s> and may be deleted or "
+"overwritten by GRASS modules"
+msgstr ""
+#: ../vector/v.db.connect/main.c:351
+msgid ""
+"For defining a new connection you have to specify these parameters: driver, "
+"database, table [, key [, layer]]"
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:21
+#, c-format
+msgid "The file '%s' already exists."
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:23
+#, c-format
+msgid "The file '%s' already exists and will be overwritten."
+msgstr ""
+#: ../vector/v.out.dxf/write_dxf.c:27
+#, c-format
+msgid "%s: Cannot write dxf file."
+msgstr ""
+#: ../vector/v.out.dxf/main.c:58
+msgid "DXF"
+msgstr ""
+#: ../vector/v.out.dxf/main.c:60
+msgid "Exports vector map to DXF file format."
+msgstr ""
+#: ../vector/v.out.dxf/main.c:68
+msgid "Name for DXF output file"
+msgstr ""
+#: ../vector/v.out.dxf/main.c:93
+#, c-format
+msgid "%d features written to '%s'."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:64 ../raster/r.walk/main.c:181
+#: ../raster/r.cost/main.c:143
+msgid "cost allocation"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:66
+msgid "Allocates subnets for nearest centers (direction from center)."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:68
+msgid ""
+"center node must be opened (costs >= 0). Costs of center node are used in "
+"calculation"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:195
+#, c-format
+msgid "Number of centers: [%d] (nlayer: [%d])"
+msgstr ""
+#: ../vector/v.net.alloc/main.c:198
+msgid "Not enough centers for selected nlayer. Nothing will be allocated."
+msgstr ""
+#: ../vector/v.net.alloc/main.c:209
+msgid "Calculating costs from centers ..."
+msgstr ""
+#: ../vector/v.surf.idw/main.c:90 ../raster/r.surf.idw/main.c:107
+msgid "IDW"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:92
+msgid ""
+"Provides surface interpolation from vector point data by Inverse Distance "
+"Squared Weighting."
+msgstr ""
+#: ../vector/v.surf.idw/main.c:101
+msgid "Name of attribute column with values to interpolate"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:104
+msgid "Values"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:113 ../raster/r.surf.idw/main.c:119
+msgid "Number of interpolation points"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:121
+msgid "Power parameter"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:123
+msgid "Greater values assign greater influence to closer points"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:128
+msgid "Don't index points by raster cell"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:129
+msgid ""
+"Slower but uses less memory and includes points from outside region in the "
+"interpolation"
+msgstr ""
+#: ../vector/v.surf.idw/main.c:139
+#, c-format
+msgid "Illegal number (%s) of interpolation points"
+msgstr ""
+#. GTC Count of window rows
+#. GTC Count of raster rows
+#: ../vector/v.surf.idw/main.c:259 ../vector/v.kernel/main.c:299
+#: ../raster/r.thin/io.c:102 ../raster/r.thin/io.c:169
+#: ../raster/r.thin/io.c:178 ../display/d.rast.num/main.c:176
+#, c-format
+msgid "%d row"
+msgid_plural "%d rows"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC Count of window columns
+#. GTC Count of raster columns
+#: ../vector/v.surf.idw/main.c:261 ../vector/v.kernel/main.c:300
+#: ../raster/r.thin/io.c:104 ../raster/r.thin/io.c:171
+#: ../raster/r.thin/io.c:180
+#, c-format
+msgid "%d column"
+msgid_plural "%d columns"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC First argument is map name, second - message about number of rows, third - columns.
+#: ../vector/v.surf.idw/main.c:263
+#, c-format
+msgid "Interpolating raster map <%s> (%s, %s)..."
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:37
+#, c-format
+msgid "Input vector map <%s> is 2D - using categories to interpolate"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:40
+#, c-format
+msgid "Input vector map <%s> is 3D - using z-coordinates to interpolate"
+msgstr ""
+#: ../vector/v.surf.idw/read_sites.c:70
+#, c-format
+msgid "One record selected from table"
+msgid_plural "%d records selected from table"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.surf.idw/read_sites.c:123
+#, c-format
+msgid "%ld point loaded"
+msgid_plural "%ld points loaded"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.transform/main.c:74
+msgid ""
+"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr ""
+#: ../vector/v.transform/main.c:79
+msgid "Shift all z values to bottom=0"
+msgstr ""
+#: ../vector/v.transform/main.c:84
+msgid "Swap coordinates x, y and then apply other parameters"
+msgstr ""
+#: ../vector/v.transform/main.c:88
+msgid "Do not build topology"
+msgstr ""
+#: ../vector/v.transform/main.c:93 ../vector/v.transform/main.c:104
+#: ../vector/v.transform/main.c:113 ../vector/v.transform/main.c:122
+#: ../vector/v.transform/main.c:131 ../vector/v.transform/main.c:140
+#: ../vector/v.transform/main.c:149 ../vector/v.transform/main.c:159
+#: ../vector/v.transform/main.c:166
+msgid "Custom"
+msgstr ""
+#: ../vector/v.transform/main.c:102
+msgid "Shifting value for x coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:111
+msgid "Shifting value for y coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:120 ../vector/v.extrude/main.c:101
+msgid "Shifting value for z coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:129
+msgid "Scaling factor for x coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:138
+msgid "Scaling factor for y coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:147
+msgid "Scaling factor for z coordinates"
+msgstr ""
+#: ../vector/v.transform/main.c:157
+msgid "Rotation around z axis in degrees (counter-clockwise)"
+msgstr ""
+#: ../vector/v.transform/main.c:163
+msgid "Name of attribute column(s) used as transformation parameters"
+msgstr ""
+#: ../vector/v.transform/main.c:165
+msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
+msgstr ""
+#: ../vector/v.transform/main.c:182
+#, c-format
+msgid "Columns require a valid layer. Please use '%s' parameter."
+msgstr ""
+#: ../vector/v.transform/main.c:212
+#, c-format
+msgid "Unknown column parameter '%s'"
+msgstr ""
+#: ../vector/v.transform/main.c:223
+#, c-format
+msgid "Unable to tokenize column string: [%s]"
+msgstr ""
+#: ../vector/v.transform/main.c:277
+msgid "Tranforming features..."
+msgstr ""
+#: ../vector/v.transform/main.c:290
+#, c-format
+msgid "New vector map <%s> boundary coordinates:"
+msgstr ""
+#: ../vector/v.transform/main.c:292
+#, c-format
+msgid " N: %-10.3f    S: %-10.3f"
+msgstr ""
+#: ../vector/v.transform/main.c:293
+#, c-format
+msgid " E: %-10.3f    W: %-10.3f"
+msgstr ""
+#: ../vector/v.transform/main.c:294
+#, c-format
+msgid " B: %6.3f    T: %6.3f"
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:104
+#, c-format
+msgid "Unsupported column type of <%s>"
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:112
+#, c-format
+msgid ""
+"Unable to select value for category %d from table <%s>, column <%s>. For "
+"category %d using default transformation parameter %.3f."
+msgstr ""
+#: ../vector/v.transform/trans_digit.c:123
+msgid "No category number defined. Using default transformation parameters."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:65
+msgid "Computes the shortest path between all pairs of nodes in the network."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:208
+msgid "Writing node points..."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:242
+msgid "Collecting shortest paths..."
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:296
+msgid "Writing shortest paths..."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:72
+#: ../vector/v.lrs/v.lrs.where/main.c:58
+#: ../vector/v.lrs/v.lrs.create/main.c:122
+#: ../vector/v.lrs/v.lrs.label/main.c:103
+msgid "Linear Reference System"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:75
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:79
+#: ../vector/v.lrs/v.lrs.where/main.c:66
+#: ../vector/v.lrs/v.lrs.create/main.c:128
+#: ../vector/v.lrs/v.lrs.label/main.c:109
+msgid "Input vector map containing lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:83
+msgid "Output vector map where segments will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:88
+#: ../vector/v.lrs/v.lrs.where/main.c:75
+#: ../vector/v.lrs/v.lrs.create/main.c:147
+#: ../vector/v.lrs/v.lrs.label/main.c:118
+msgid "Line layer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:94
+#: ../vector/v.lrs/v.lrs.where/main.c:86
+#: ../vector/v.lrs/v.lrs.create/main.c:207
+#: ../vector/v.lrs/v.lrs.label/main.c:124
+msgid "Driver name for reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:102
+#: ../vector/v.lrs/v.lrs.where/main.c:94
+#: ../vector/v.lrs/v.lrs.create/main.c:215
+#: ../vector/v.lrs/v.lrs.label/main.c:132
+msgid "Database name for reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:109
+#: ../vector/v.lrs/v.lrs.where/main.c:101
+#: ../vector/v.lrs/v.lrs.label/main.c:139
+msgid "Name of the reference system table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:114
+msgid "Name of file containing segment rules. If not given, read from stdin."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:155
+#: ../vector/v.lrs/v.lrs.where/main.c:147
+#: ../vector/v.lrs/v.lrs.create/main.c:315
+#: ../vector/v.lrs/v.lrs.label/main.c:292
+msgid "Unable to open database for reference table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:184
+#: ../vector/v.lrs/v.lrs.segment/main.c:238
+#, c-format
+msgid "Cannot read input: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:196
+#, c-format
+msgid "No record in LR table for: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:200
+#, c-format
+msgid "More than one record in LR table for: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:207
+#: ../vector/v.lrs/v.lrs.segment/main.c:294
+#, c-format
+msgid "Unable to find line of cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:217
+#, c-format
+msgid ""
+"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
+"%s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:253
+#, c-format
+msgid ""
+"No record in LRS table for 1. point of:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:258
+#, c-format
+msgid ""
+"Using last from more offsets found for 1. point of:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:262
+#, c-format
+msgid ""
+"Requested offset for the 1. point not found, using nearest found:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:273
+#, c-format
+msgid ""
+"No record in LRS table for 2. point of:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:278
+#, c-format
+msgid ""
+"Requested offset for the 2. point not found, using nearest found:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:282
+#, c-format
+msgid ""
+"Using first from more offsets found for 2. point of:\n"
+"  %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:287
+msgid "Segment over 2 (or more) segments, not yet supported"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:304
+#, c-format
+msgid "End of segment > line length (%e) -> cut"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:313
+#, c-format
+msgid ""
+"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
+"%s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:356
+#: ../vector/v.lrs/v.lrs.where/main.c:222
+#, c-format
+msgid "[%d] point read from input"
+msgid_plural "[%d] points read from input"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s will be replaced with a message about lost points.
+#: ../vector/v.lrs/v.lrs.segment/main.c:363
+#, c-format
+msgid "[%d] point written to output map (%s)"
+msgid_plural "[%d] points written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.segment/main.c:368
+#, c-format
+msgid "[%d] line read from input"
+msgid_plural "[%d] lines read from input"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s will be replaced with a message about lost lines.
+#: ../vector/v.lrs/v.lrs.segment/main.c:375
+#, c-format
+msgid "[%d] line written to output map (%s)"
+msgid_plural "[%d] lines written to output map (%s)"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:61
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:70
+msgid "Input vector map containing points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:80
+#: ../vector/v.lrs/v.lrs.create/main.c:151
+msgid "Point layer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:108
+msgid "Maximum distance to nearest line"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:225
+#, c-format
+msgid "[%d] position found"
+msgid_plural "[%d] positions found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:229
+#, c-format
+msgid "[%d] point outside threshold"
+msgid_plural "[%d] points outside threshold"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:233
+#, c-format
+msgid "[%d] point - no record found"
+msgid_plural "[%d] points - no record found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.where/main.c:237
+#, c-format
+msgid "[%d] point - too many records found"
+msgid_plural "[%d] points - too many records found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lrs/v.lrs.create/main.c:124
+msgid "Creates a linear reference system."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:133
+msgid "Output vector map where oriented lines are written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:138
+msgid "Output vector map of errors"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:143
+msgid "Input vector map containing reference points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:158
+msgid "Column containing line identifiers for lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:165
+msgid "Column containing line identifiers for points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:173
+msgid "Column containing milepost position for the beginning of next segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:182
+msgid ""
+"Column containing offset from milepost for the beginning of next segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:191
+msgid "Column containing milepost position for the end of previous segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:200
+msgid "Column containing offset from milepost for the end of previous segment"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:223
+msgid "Name of table where the reference system will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:224
+msgid "New table is created by this module"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:231
+msgid "Maximum distance of point to line allowed"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:286
+msgid "Cannot get layer info for lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:289
+msgid "Cannot get layer info for points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:327
+#, c-format
+msgid "Unable to drop table: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:346
+#, c-format
+msgid "Unable to select line id values from %s.%s."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:356
+msgid "Line id column must be integer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:367
+#: ../vector/v.lrs/v.lrs.create/main.c:469
+msgid "Unable to fetch line id from line table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:419
+#, c-format
+msgid "Line [%d] without category (layer [%d])"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:439
+#, c-format
+msgid "No lines selected for line id [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:459
+#, c-format
+msgid "Unable to select point attributes from <%s>"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:490
+#, c-format
+msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:512
+#, c-format
+msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:538
+#, c-format
+msgid "Point [%d] without category (layer [%d])"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:585
+#, c-format
+msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:717
+#, c-format
+msgid "End > start for point cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:734
+msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:751
+#, c-format
+msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:761
+#, c-format
+msgid "Distance along line identical for points' cats [%d], [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:775
+#, c-format
+msgid "Not enough points (%d) attached to the line (cat %d), line skip."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:780
+#, c-format
+msgid "Unable to guess direction for the line (cat %d), line skip."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:784
+#, c-format
+msgid "Incorrect order of points along line cat [%d]"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:834
+#, c-format
+msgid "Unable to insert reference records: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:875
+msgid "Building topology for output (out_lines) map..."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:886
+msgid "Building topology for error (err) map..."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:105
+msgid "Creates stationing from input lines, and linear reference system."
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:113
+msgid "Output vector map where stationing will be written"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:147
+msgid "Label file"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:156
+msgid "PM left, MP right, stationing left, stationing right offset"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:161
+msgid "Offset label in label x-direction in map units"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:168
+msgid "Offset label in label y-direction in map units"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:174 ../vector/v.label/main.c:113
+msgid "Reference position"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:197
+msgid "Line width of text"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:198
+#: ../vector/v.lrs/v.lrs.label/main.c:211
+msgid "Only for d.label output"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:210
+msgid "Line width of highlight color"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:228
+msgid "Opaque to vector"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:229
+msgid "Only relevant if background color is selected"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:283 ../display/d.labels/main.c:114
+#, c-format
+msgid "Unable to open label file <%s>"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:322
+#, c-format
+msgid "Unable to select records from LRS table: %s"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:412
+msgid "No record in LR table"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.label/main.c:416
+msgid "More than one record in LR table"
+msgstr ""
+#: ../vector/v.clean/main.c:54 ../locale/scriptstrings/t.snap_to_translate.c:3
+msgid "snapping"
+msgstr ""
+#: ../vector/v.clean/main.c:55
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../vector/v.clean/main.c:70
+msgid "Name of output map where errors are written"
+msgstr ""
+#: ../vector/v.clean/main.c:81
+msgid "Cleaning tool"
+msgstr ""
+#: ../vector/v.clean/main.c:97
+msgid "break lines at each intersection"
+msgstr ""
+#: ../vector/v.clean/main.c:98
+msgid "remove duplicate geometry features (pay attention to categories!)"
+msgstr ""
+#: ../vector/v.clean/main.c:99
+msgid "remove dangles, threshold ignored if < 0"
+msgstr ""
+#: ../vector/v.clean/main.c:100
+msgid ""
+"change the type of boundary dangle to line, threshold ignored if < 0, input "
+"line type is ignored"
+msgstr ""
+#: ../vector/v.clean/main.c:102
+msgid "remove bridges connecting area and island or 2 islands"
+msgstr ""
+#: ../vector/v.clean/main.c:103
+msgid ""
+"change the type of bridges connecting area and island or 2 islands from "
+"boundary to line"
+msgstr ""
+#: ../vector/v.clean/main.c:105
+msgid "snap lines to vertex in threshold"
+msgstr ""
+#: ../vector/v.clean/main.c:106
+msgid "remove duplicate area centroids ('type' option ignored)"
+msgstr ""
+#: ../vector/v.clean/main.c:107
+msgid ""
+"break (topologically clean) polygons (imported from non topological format, "
+"like ShapeFile). Boundaries are broken on each point shared between 2 and "
+"more polygons where angles of segments are different"
+msgstr ""
+#: ../vector/v.clean/main.c:110
+msgid ""
+"remove vertices in threshold from lines and boundaries, boundary is pruned "
+"only if topology is not damaged (new intersection, changed attachment of "
+"centroid), first and last segment of the boundary is never changed"
+msgstr ""
+#: ../vector/v.clean/main.c:114
+msgid "remove small areas, the longest boundary with adjacent area is removed"
+msgstr ""
+#: ../vector/v.clean/main.c:115
+msgid "remove all lines or boundaries of zero length, threshold is ignored"
+msgstr ""
+#: ../vector/v.clean/main.c:116
+msgid "remove small angles between lines at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:124
+msgid "Threshold in map units, one value for each tool"
+msgstr ""
+#: ../vector/v.clean/main.c:125
+msgid "Default: 0.0[,0.0,...])"
+msgstr ""
+#: ../vector/v.clean/main.c:130
+msgid "Do not build topology for the output vector"
+msgstr ""
+#: ../vector/v.clean/main.c:135
+msgid "Combine tools with recommended follow-up tools"
+msgstr ""
+#: ../vector/v.clean/main.c:156
+msgid "You must select at least one tool"
+msgstr ""
+#: ../vector/v.clean/main.c:191
+msgid "Tool doesn't exist"
+msgstr ""
+#: ../vector/v.clean/main.c:202
+msgid ""
+"Note: In latitude-longitude coordinate system specify threshold in degree "
+"unit"
+msgstr ""
+#: ../vector/v.clean/main.c:215
+#, c-format
+msgid "Threshold for tool %d may not be > 0, set to 0"
+msgstr ""
+#: ../vector/v.clean/main.c:224
+msgid "Tool: Threshold"
+msgstr ""
+#: ../vector/v.clean/main.c:229
+msgid "Break"
+msgstr ""
+#: ../vector/v.clean/main.c:232
+msgid "Remove duplicates"
+msgstr ""
+#: ../vector/v.clean/main.c:235
+msgid "Remove dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:238
+msgid "Change type of boundary dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:242
+msgid "Remove bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:245
+msgid "Change type of boundary bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:249
+msgid "Snap vertices"
+msgstr ""
+#: ../vector/v.clean/main.c:252
+msgid "Remove duplicate area centroids"
+msgstr ""
+#: ../vector/v.clean/main.c:256
+msgid "Break polygons"
+msgstr ""
+#: ../vector/v.clean/main.c:259
+msgid "Prune"
+msgstr ""
+#: ../vector/v.clean/main.c:262
+msgid "Remove small areas"
+msgstr ""
+#: ../vector/v.clean/main.c:265
+msgid "Remove small angles at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:270
+msgid "Remove all lines or boundaries of zero length"
+msgstr ""
+#: ../vector/v.clean/main.c:314
+msgid "Topological cleaning works best with native GRASS vector format"
+msgstr ""
+#: ../vector/v.clean/main.c:325
+msgid "Failed to copy attribute table to output vector map"
+msgstr ""
+#: ../vector/v.clean/main.c:340 ../vector/v.clean/main.c:351
+msgid "Rebuilding parts of topology..."
+msgstr ""
+#: ../vector/v.clean/main.c:360 ../vector/v.clean/main.c:405
+#: ../vector/v.clean/main.c:456
+msgid "Tool: Split lines"
+msgstr ""
+#: ../vector/v.clean/main.c:363 ../vector/v.clean/main.c:409
+#: ../vector/v.clean/main.c:462
+msgid "Tool: Break lines at intersections"
+msgstr ""
+#: ../vector/v.clean/main.c:366 ../vector/v.clean/main.c:375
+#: ../vector/v.clean/main.c:411 ../vector/v.clean/main.c:427
+#: ../vector/v.clean/main.c:464
+msgid "Tool: Remove duplicates"
+msgstr ""
+#: ../vector/v.clean/main.c:369 ../vector/v.clean/main.c:418
+#: ../vector/v.clean/main.c:469
+msgid "Tool: Merge lines"
+msgstr ""
+#: ../vector/v.clean/main.c:379
+msgid "Tool: Remove dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:383
+msgid "Tool: Change type of boundary dangles"
+msgstr ""
+#: ../vector/v.clean/main.c:387
+msgid "Tool: Remove bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:391
+msgid "Tool: Change type of boundary bridges"
+msgstr ""
+#: ../vector/v.clean/main.c:395
+msgid "Tool: Remove duplicate area centroids"
+msgstr ""
+#: ../vector/v.clean/main.c:399
+msgid "Tool: Snap line to vertex in threshold"
+msgstr ""
+#: ../vector/v.clean/main.c:413 ../vector/v.clean/main.c:447
+#: ../vector/v.clean/main.c:466
+msgid "Tool: Remove small angles at nodes"
+msgstr ""
+#: ../vector/v.clean/main.c:424
+msgid "Tool: Break polygons"
+msgstr ""
+#: ../vector/v.clean/main.c:432
+msgid "Tool: Prune lines/boundaries"
+msgstr ""
+#: ../vector/v.clean/main.c:436
+msgid "Tool: Remove small areas"
+msgstr ""
+#: ../vector/v.clean/main.c:442
+msgid "Tool: Merge boundaries"
+msgstr ""
+#: ../vector/v.clean/main.c:475
+msgid "Tool: Remove all lines and boundaries of zero length"
+msgstr ""
+#: ../vector/v.clean/main.c:484
+msgid "Rebuilding topology for output vector map..."
+msgstr ""
+#: ../vector/v.clean/main.c:495
+msgid "Building topology for error vector map..."
+msgstr ""
+#: ../vector/v.clean/split.c:85
+#, c-format
+msgid "Line splits: %d"
+msgstr ""
+#: ../vector/v.clean/rmline.c:64
+#, c-format
+msgid "Lines / boundaries removed: %d"
+msgstr ""
+#: ../vector/v.clean/rmdac.c:60
+#, c-format
+msgid "Duplicate area centroids: %d"
+msgstr ""
+#: ../vector/v.clean/prune.c:216
+#, c-format
+msgid ""
+"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgstr ""
+#: ../vector/v.clean/prune.c:220
+#, c-format
+msgid "%d boundaries not pruned because pruning would damage topology"
+msgstr ""
+#: ../vector/v.db.select/main.c:57
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../vector/v.db.select/main.c:75
+msgid "Output vertical record separator"
+msgstr ""
+#: ../vector/v.db.select/main.c:91
+msgid ""
+"Print minimal region extent of selected vector features instead of attributes"
+msgstr ""
+#: ../vector/v.db.select/main.c:92
+msgid "Region"
+msgstr ""
+#: ../vector/v.db.select/main.c:106
+msgid "Exclude attributes not linked to features"
+msgstr ""
+#: ../vector/v.db.select/main.c:148
+#, c-format
+msgid ""
+"Unable to open vector map <%s> at topology level. Flag '%c' requires "
+"topology level."
+msgstr ""
+#: ../vector/v.db.select/main.c:190
+msgid "Unable to open select cursor"
+msgstr ""
+#: ../vector/v.db.select/main.c:268
+#, c-format
+msgid "Unable to get bounding box of area %d"
+msgstr ""
+#: ../vector/v.db.select/main.c:274
+#, c-format
+msgid "Unable to get bounding box of line %d"
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:48
+msgid "spanning tree"
+msgstr ""
+#: ../vector/v.net.spanningtree/main.c:50
+msgid "Computes minimum spanning tree for the network."
+msgstr ""
+#: ../vector/v.split/main.c:56
+msgid "densification"
+msgstr ""
+#: ../vector/v.split/main.c:60
+msgid "Splits vector lines to shorter segments."
+msgstr ""
+#: ../vector/v.split/main.c:73
+msgid "Maximum segment length"
+msgstr ""
+#: ../vector/v.split/main.c:82
+msgid "Length units"
+msgstr ""
+#: ../vector/v.split/main.c:89
+msgid "Maximum number of vertices in segment"
+msgstr ""
+#: ../vector/v.split/main.c:93
+msgid "Add new vertices, but do not split"
+msgstr ""
+#: ../vector/v.split/main.c:94
+msgid "Applies only to 'length' option"
+msgstr ""
+#: ../vector/v.split/main.c:101
+msgid "Use either length or vertices"
+msgstr ""
+#: ../vector/v.split/main.c:108
+#, c-format
+msgid "Length must be positive but is %g"
+msgstr ""
+#: ../vector/v.split/main.c:124
+#, c-format
+msgid "Unknown unit %s"
+msgstr ""
+#: ../vector/v.split/main.c:142
+msgid "Can not get projection units"
+msgstr ""
+#: ../vector/v.split/main.c:149
+#, c-format
+msgid "Length in map units: %g"
+msgstr ""
+#: ../vector/v.split/main.c:151
+#, c-format
+msgid "Length in meters: %g"
+msgstr ""
+#: ../vector/v.split/main.c:157
+msgid "Number of vertices must be at least 2"
+msgstr ""
+#: ../vector/v.split/main.c:235
+#, c-format
+msgid "Unable to make line segment: %f - %f (line length = %f)"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:78
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:83
+msgid "Input vector (v.lidar.edgedetection output)"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:93
+msgid "Name of the first pulse vector map"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:100
+msgid "Threshold for cell object frequency in region growing"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:108
+msgid "Threshold for double pulse in region growing"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:176
+#, c-format
+msgid "Unable to open table <%s>"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:201
+msgid "Setting regions and boxes"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:267
+#, c-format
+msgid "Rows = %d"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:268
+#, c-format
+msgid "Columns = %d"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:288
+msgid "read points in input vector"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:437
+msgid "Region Growing"
+msgstr ""
+#: ../vector/v.lidar.growing/ConvexHull.c:269
+msgid "...now exiting to system..."
+msgstr ""
+#: ../vector/v.mkgrid/hexgrid.c:86
+msgid "Writing out hexagon grid..."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:72
+msgid "grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:74
+msgid "Creates a vector map of a user-defined grid."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:81
+msgid "rows,columns"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:85
+msgid "Number of rows and columns in grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:94
+msgid "Where to place the grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:98
+msgid "current region"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:99
+msgid "use 'coor' and 'box' options"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:104
+msgid "Lower left easting and northing coordinates of map"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:108
+msgid "width,height"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:112
+msgid "Width and height of boxes in grid"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:119
+msgid "Angle of rotation (in degrees counter-clockwise)"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:127
+msgid "Number of vertex points per grid cell"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:135 ../raster/r.to.vect/main.c:81
+msgid "Output feature type"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:140
+msgid "Create hexagons (default: rectangles)"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:145
+msgid "Allow asymmetric hexagons"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:185
+msgid "'coor' and 'position=region' are exclusive options"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:188
+msgid "'box' and 'grid' are exclusive options for 'position=region'"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:211 ../vector/v.mkgrid/main.c:247
+msgid "Invalid width"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:214 ../vector/v.mkgrid/main.c:250
+msgid "Invalid height"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:230
+msgid "'grid' option missing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:233
+msgid "'coor' option missing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:236
+msgid "'box' option missing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:240
+msgid "Invalid easting"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:243
+msgid "Invalid northing"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:308
+msgid "The hexagons will be asymmetrical."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:321 ../vector/v.mkgrid/main.c:324
+msgid "Please use a higher resolution or a larger region"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:328
+#, c-format
+msgid "The number of rows has been adjusted from %d to %d"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:331
+#, c-format
+msgid "The number of columns has been adjusted from %d to %d"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:360 ../vector/v.mkgrid/main.c:444
+#: ../vector/v.mkgrid/main.c:456
+msgid "Unable to fill attribute table"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:364 ../vector/v.mkgrid/main.c:461
+#: ../vector/v.in.dxf/write_vect.c:70 ../vector/v.in.ascii/points.c:452
+#, c-format
+msgid "Unable to insert new record: %s"
+msgstr ""
+#: ../vector/v.mkgrid/main.c:371
+msgid "The rectangles will be asymmetrical."
+msgstr ""
+#: ../vector/v.mkgrid/main.c:416
+msgid "Creating centroids..."
+msgstr ""
+#: ../vector/v.mkgrid/write_grid.c:68
+msgid "Writing out vector rows..."
+msgstr ""
+#: ../vector/v.mkgrid/write_grid.c:106
+msgid "Writing out vector columns..."
+msgstr ""
+#: ../vector/v.neighbors/main.c:51
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
+#: ../raster3d/r3.neighbors/main.c:209 ../raster/r.mode/main.c:55
+#: ../raster/r.mfilter/main.c:57 ../raster/r.mapcalc/main.c:116
+#: ../raster/r.quantile/main.c:256 ../raster/r.neighbors/main.c:168
+#: ../raster/r.texture/main.c:102
+msgid "algebra"
+msgstr ""
+#: ../vector/v.neighbors/main.c:54
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
+#: ../raster3d/r3.neighbors/main.c:212 ../raster/r.in.xyz/main.c:162
+#: ../raster/r.series/main.c:134 ../raster/r.neighbors/main.c:170
+msgid "aggregation"
+msgstr ""
+#: ../vector/v.neighbors/main.c:55
+msgid "Neighborhood analysis tool for vector point maps."
+msgstr ""
+#: ../vector/v.neighbors/main.c:56
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map."
+msgstr ""
+#: ../vector/v.neighbors/main.c:72 ../raster/r.neighbors/main.c:204
+msgid "Neighborhood operation"
+msgstr ""
+#: ../vector/v.neighbors/main.c:78
+msgid "Neighborhood diameter in map units"
+msgstr ""
+#: ../vector/v.neighbors/main.c:98
+msgid "Input vector and computational region do not overlap"
+msgstr ""
+#: ../vector/v.neighbors/main.c:104
+#, c-format
+msgid ""
+"The search diameter %g is smaller than cell diagonal %g: some points could "
+"not be detected"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:71
+msgid ""
+"Corrects the v.lidar.growing output. It is the last of the three algorithms "
+"for LIDAR filtering."
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:81
+msgid "Input observation vector map name (v.lidar.growing output)"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:84
+msgid "Output classified vector map name"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:93
+msgid "Only 'terrain' points output vector map"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:118
+msgid "Regularization weight in reclassification evaluation"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:126
+msgid "High threshold for object to terrain reclassification"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:134
+msgid "Low threshold for terrain to object reclassification"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:273
+#, c-format
+msgid "adjusted EW spline %d"
+msgid_plural "adjusted EW splines %d"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lidar.correction/main.c:276
+#, c-format
+msgid "adjusted NS spline %d"
+msgid_plural "adjusted NS splines %d"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.lidar.correction/main.c:324
+#, c-format
+msgid "nsply = %d"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:357
+#, c-format
+msgid "nsplx = %d"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:360
+msgid "read vector region map"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:365
+#, c-format
+msgid "npoints = %d, nterrain = %d"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:371
+msgid "Mean calculation"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:385
+msgid "Only TERRAIN points"
+msgstr ""
+#: ../vector/v.lidar.correction/main.c:415
+msgid "Correction and creation of terrain vector"
+msgstr ""
+#: ../vector/v.label/main.c:62
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../vector/v.label/main.c:69
+msgid "If not given the name of the input map is used"
+msgstr ""
+#: ../vector/v.label/main.c:89
+msgid "Rotate labels to align with lines"
+msgstr ""
+#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
+#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
+#: ../general/g.region/main.c:155 ../general/g.region/main.c:337
+msgid "Effects"
+msgstr ""
+#: ../vector/v.label/main.c:94
+msgid "Curl labels along lines"
+msgstr ""
+#: ../vector/v.label/main.c:99
+msgid "Offset label in x-direction"
+msgstr ""
+#: ../vector/v.label/main.c:102 ../vector/v.label/main.c:109
+#: ../vector/v.label/main.c:118 ../vector/v.label/main.c:162
+msgid "Placement"
+msgstr ""
+#: ../vector/v.label/main.c:106
+msgid "Offset label in y-direction"
+msgstr ""
+#: ../vector/v.label/main.c:122 ../display/d.vect/main.c:236
+#: ../display/d.text/main.c:218 ../display/d.legend/main.c:167
+msgid "Font name"
+msgstr ""
+#: ../vector/v.label/main.c:137
+msgid "Space between letters for curled labels (in map-units)"
+msgstr ""
+#: ../vector/v.label/main.c:144
+msgid "Label size (in points)"
+msgstr ""
+#: ../vector/v.label/main.c:156 ../display/d.text/main.c:205
+msgid "Rotation angle in degrees (counter-clockwise)"
+msgstr ""
+#: ../vector/v.label/main.c:166
+msgid "Border width"
+msgstr ""
+#: ../vector/v.label/main.c:233 ../display/d.extract/main.c:79
+msgid "No graphics device selected"
+msgstr ""
+#: ../vector/v.label/main.c:251
+msgid ""
+"size and space options vary significantly which may lead to crummy output"
+msgstr ""
+#: ../vector/v.label/main.c:259
+msgid "Too many parameters for <reference>"
+msgstr ""
+#: ../vector/v.label/main.c:438
+#, c-format
+msgid "Labeled %d lines."
+msgstr ""
+#: ../vector/v.qcount/main.c:63
+msgid "Indices for quadrat counts of vector point lists."
+msgstr ""
+#: ../vector/v.qcount/main.c:72
+msgid ""
+"Name for output quadrat centers map (number of points is written as category)"
+msgstr ""
+#: ../vector/v.qcount/main.c:78
+msgid "Number of quadrats"
+msgstr ""
+#: ../vector/v.qcount/main.c:84
+msgid "Quadrat radius"
+msgstr ""
+#: ../vector/v.qcount/main.c:88
+msgid "Print results in shell script style"
+msgstr ""
+#: ../vector/v.qcount/main.c:104
+msgid "Finding quadrats..."
+msgstr ""
+#: ../vector/v.qcount/main.c:109
+msgid "Counting points quadrats..."
+msgstr ""
+#: ../vector/v.rectify/target.c:18
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:13
+#: ../imagery/i.rectify/target.c:14
+#, c-format
+msgid "Target information for group <%s> missing"
+msgstr ""
+#: ../vector/v.rectify/target.c:29
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
+#: ../imagery/i.rectify/target.c:20
+#, c-format
+msgid "Target location <%s> not found"
+msgstr ""
+#: ../vector/v.rectify/target.c:40 ../raster/r.in.gdal/main.c:871
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
+#: ../imagery/i.rectify/target.c:32
+#, c-format
+msgid "Mapset <%s> in target location <%s> - "
+msgstr ""
+#: ../vector/v.rectify/target.c:41 ../raster/r.proj/main.c:280
+#: ../raster/r.in.gdal/main.c:873
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
+#: ../imagery/i.rectify/target.c:33
+msgid "permission denied"
+msgstr ""
+#: ../vector/v.rectify/target.c:41 ../raster/r.proj/main.c:281
+#: ../raster/r.in.gdal/main.c:874
+msgid "not found"
+msgstr ""
+#: ../vector/v.rectify/target.c:43 ../imagery/i.rectify/target.c:35
+msgid "Please run i.target for group."
+msgstr ""
+#: ../vector/v.rectify/main.c:71 ../imagery/i.rectify/main.c:100
+msgid "rectify"
+msgstr ""
+#: ../vector/v.rectify/main.c:73
+msgid ""
+"Rectifies a vector by computing a coordinate transformation for each object "
+"in the vector based on the control points."
+msgstr ""
+#: ../vector/v.rectify/main.c:88
+msgid "Name of input file with control points"
+msgstr ""
+#: ../vector/v.rectify/main.c:93
+msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
+msgstr ""
+#: ../vector/v.rectify/main.c:102 ../imagery/i.rectify/main.c:124
+msgid "Rectification polynomial order (1-3)"
+msgstr ""
+#: ../vector/v.rectify/main.c:105
+msgid "Field separator for RMS report"
+msgstr ""
+#: ../vector/v.rectify/main.c:109
+msgid "Perform 3D transformation"
+msgstr ""
+#: ../vector/v.rectify/main.c:113
+msgid "Perform orthogonal 3D transformation"
+msgstr ""
+#: ../vector/v.rectify/main.c:117
+msgid "Print RMS errors"
+msgstr ""
+#: ../vector/v.rectify/main.c:118
+msgid "Print RMS errors and exit without rectifying the input map"
+msgstr ""
+#: ../vector/v.rectify/main.c:136
+msgid "Please select a group or give an input file."
+msgstr ""
+#: ../vector/v.rectify/main.c:138
+msgid "Points in group will be ignored, GCPs in input file are used."
+msgstr ""
+#: ../vector/v.rectify/main.c:143 ../imagery/i.rectify/main.c:199
+#, c-format
+msgid "Invalid order (%d); please enter 1 to %d"
+msgstr ""
+#: ../vector/v.rectify/main.c:154
+msgid "3D transformation requires a 3D vector"
+msgstr ""
+#: ../vector/v.rectify/main.c:157
+msgid "A file with 3D control points is needed for 3D transformation"
+msgstr ""
+#: ../vector/v.rectify/main.c:201
+#, c-format
+msgid "The vector map <%s> already exists in"
+msgstr ""
+#: ../vector/v.rectify/main.c:202
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:285
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:294
+#: ../imagery/i.rectify/main.c:291
+#, c-format
+msgid "target LOCATION %s, MAPSET %s:"
+msgstr ""
+#: ../vector/v.rectify/main.c:204
+msgid "Rectification cancelled."
+msgstr ""
+#: ../vector/v.rectify/cp.c:307 ../vector/v.rectify/cp.c:331
+#, c-format
+msgid "Can not open file <%s>"
+msgstr ""
+#: ../vector/v.rectify/cp.c:314 ../vector/v.rectify/cp.c:338
+#, c-format
+msgid "Bad format in control point file <%s>"
+msgstr ""
+#: ../vector/v.rectify/cp.c:350 ../imagery/i.rectify/cp.c:14
+#, c-format
+msgid "Control Point file for group <%s@%s> - "
+msgstr ""
+#: ../vector/v.rectify/cp.c:359 ../imagery/i.rectify/cp.c:47
+#, c-format
+msgid "Not enough active control points for current order, %d are required."
+msgstr ""
+#: ../vector/v.rectify/cp.c:363 ../imagery/i.rectify/cp.c:24
+#: ../imagery/i.rectify/cp.c:51
+msgid "Poorly placed control points."
+msgstr ""
+#: ../vector/v.rectify/cp.c:364 ../imagery/i.rectify/cp.c:25
+#: ../imagery/i.rectify/cp.c:52
+msgid " Can not generate the transformation equation."
+msgstr ""
+#: ../vector/v.rectify/cp.c:367 ../imagery/i.rectify/cp.c:28
+#: ../imagery/i.rectify/cp.c:55
+msgid "Not enough memory to solve for transformation equation"
+msgstr ""
+#: ../vector/v.rectify/cp.c:370 ../imagery/i.rectify/cp.c:31
+#: ../imagery/i.rectify/cp.c:58
+msgid "Invalid order"
+msgstr ""
+#: ../vector/v.extrude/main.c:72
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height."
+msgstr ""
+#: ../vector/v.extrude/main.c:74
+msgid ""
+"Optionally the height can be derived from sampling of elevation raster map."
+msgstr ""
+#: ../vector/v.extrude/main.c:78
+msgid "Trace elevation"
+msgstr ""
+#: ../vector/v.extrude/main.c:118
+msgid "Name of attribute column with feature height"
+msgstr ""
+#: ../vector/v.extrude/main.c:151
+#, c-format
+msgid "One of '%s' or '%s' parameters must be set"
+msgstr ""
+#: ../vector/v.extrude/main.c:202
+#, c-format
+msgid ""
+"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
+"layer '1'."
+msgstr ""
+#: ../vector/v.extrude/main.c:234
+#, c-format
+msgid "Column <%s> does not exist"
+msgstr ""
+#: ../vector/v.extrude/main.c:243
+#, c-format
+msgid "Column <%s>: invalid data type"
+msgstr ""
+#: ../vector/v.extrude/main.c:265
+msgid "Extruding areas..."
+msgstr ""
+#: ../vector/v.extrude/main.c:287
+#, c-format
+msgid "No category defined for area %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:293
+#, c-format
+msgid ""
+"Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:319
+msgid "Extruding features..."
+msgstr ""
+#: ../vector/v.extrude/main.c:340
+#, c-format
+msgid "No category defined for feature %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:346
+#, c-format
+msgid ""
+"Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgstr ""
+#: ../vector/v.extrude/main.c:364
+msgid "Copying attribute table..."
+msgstr ""
+#: ../vector/v.extrude/db.c:27
+#, c-format
+msgid "Unable to select attributes category %d"
+msgstr ""
+#: ../vector/v.sample/main.c:79
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../vector/v.sample/main.c:89
+msgid "Name of attribute column to use for comparison"
+msgstr ""
+#: ../vector/v.sample/main.c:92
+msgid "Name for output vector map to store differences"
+msgstr ""
+#: ../vector/v.sample/main.c:96
+msgid "Name of raster map to be sampled"
+msgstr ""
+#: ../vector/v.sample/main.c:107
+msgid "Scaling factor for values read from raster map"
+msgstr ""
+#: ../vector/v.sample/main.c:109
+msgid "Sampled values will be multiplied by this factor"
+msgstr ""
+#: ../vector/v.sample/main.c:148
+#, c-format
+msgid "Column type <%s> not supported (must be integer or double precision)"
+msgstr ""
+#: ../vector/v.sample/main.c:154
+#, c-format
+msgid "%d record selected from table"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.sample/main.c:200
+msgid "Reading points..."
+msgstr ""
+#: ../vector/v.univar/main.c:98
+msgid "Calculates univariate statistics of vector map features."
+msgstr ""
+#: ../vector/v.univar/main.c:99
+msgid ""
+"Variance and standard deviation is calculated only for points if specified."
+msgstr ""
+#: ../vector/v.univar/main.c:122
+#: ../locale/scriptstrings/db.univar_to_translate.c:6
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../raster/r.univar/r3.univar_main.c:52
+#: ../raster/r.univar/r.univar_main.c:52
+msgid "Percentile to calculate (requires extended statistics flag)"
+msgstr ""
+#: ../vector/v.univar/main.c:130
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:9
+#: ../raster/r.univar/r3.univar_main.c:63
+#: ../raster/r.univar/r.univar_main.c:66
+msgid "Calculate extended statistics"
+msgstr ""
+#: ../vector/v.univar/main.c:134
+msgid "Weigh by line length or area size"
+msgstr ""
+#: ../vector/v.univar/main.c:138
+msgid "Calculate geometric distances instead of attribute statistics"
+msgstr ""
+#: ../vector/v.univar/main.c:192
+#, c-format
+msgid "Geometry distances are not supported for areas. Use '%s' instead."
+msgstr ""
+#: ../vector/v.univar/main.c:195
+msgid ""
+"Incompatible vector type(s) specified, only number of features, minimum, "
+"maximum and range can be calculated"
+msgstr ""
+#: ../vector/v.univar/main.c:200
+msgid "Extended statistics is currently supported only for points/centroids"
+msgstr ""
+#: ../vector/v.univar/main.c:225
+msgid "'layer' must be > 0 for 'where'."
+msgstr ""
+#: ../vector/v.univar/main.c:242
+#, c-format
+msgid "Unable select categories from table <%s>"
+msgstr ""
+#: ../vector/v.univar/main.c:253
+#, c-format
+msgid "Calculating geometric distances between %d primitives..."
+msgstr ""
+#: ../vector/v.univar/main.c:343
+#, c-format
+msgid " Database connection not defined for layer <%s>"
+msgstr ""
+#: ../vector/v.univar/main.c:358
+msgid "Only numeric column type is supported"
+msgstr ""
+#: ../vector/v.univar/main.c:652
+msgid "Cannot sort the key/value array"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:71
+msgid "Uploads 3D raster values at positions of vector points to the table."
+msgstr ""
+#: ../vector/v.what.rast3/main.c:81
+msgid "Name of existing 3D raster map to be queried"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:134
+#, c-format
+msgid "Error opening 3D raster map <%s>"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:143
+msgid "Column type not supported, please use a column with double type"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:214
+#, c-format
+msgid "%d point outside current region was skipped"
+msgid_plural "%d points outside current region were skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:219
+#, c-format
+msgid "%d point without category was skipped"
+msgid_plural "%d points without category were skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:258
+#, c-format
+msgid "More points (%d) of category %d, value set to 'NULL'"
+msgstr ""
+#: ../vector/v.what.rast3/main.c:328
+#, c-format
+msgid "%d category loaded from table"
+msgid_plural "%d categories loaded from table"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:331
+#, c-format
+msgid "%d category loaded from vector"
+msgid_plural "%d categories loaded from vector"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:334
+#, c-format
+msgid "%d category from vector missing in table"
+msgid_plural "%d categories from vector missing in table"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:338
+#, c-format
+msgid "%d duplicate category in vector"
+msgid_plural "%d duplicate categories in vector"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:342
+#, c-format
+msgid "%d update error"
+msgid_plural "%d update errors"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.what.rast3/main.c:346
+#, c-format
+msgid "%d record updated."
+msgid_plural "%d records updated."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.in.ogr/main.c:136
+msgid "Imports vector data into a GRASS vector map using OGR library."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:142
+msgid "OGR datasource name"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:143
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:153
+msgid "OGR layer name. If not given, all available layers are imported"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:155
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:183
+msgid "Minimum size of area to be imported (square meters)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:185
+msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:191
+msgid "Optionally change default input type"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:195
+msgid "import area centroids as points"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:196
+msgid "import area boundaries as lines"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:197
+msgid "import lines as area boundaries"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:198
+msgid "import points as centroids"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:207
+msgid "Snapping threshold for boundaries (map units)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:208
+msgid "'-1' for no snap"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:219
+msgid ""
+"List of column names to be used instead of original names, first is used for "
+"category column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:228
+msgid "Encoding value for attribute data"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:230
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:238
+msgid "Name of column used for categories"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:240
+msgid ""
+"If not given, categories are generated as unique values and stored in 'cat' "
+"column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:245
+msgid "Name of geometry column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:246
+msgid "If not given, all geometry columns from the input are used"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:251
+msgid "List supported OGR formats and exit"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:257
+msgid "List available OGR layers in data source and exit"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:264
+msgid "Do not clean polygons (not recommended)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:269
+msgid "Force 2D output even if input is 3D"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:291 ../raster/r.external/main.c:105
+#: ../raster/r.in.gdal/main.c:164
+msgid "Also updates the default region if in the PERMANENT mapset"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:296
+msgid "Change column names to lowercase characters"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:359
+msgid ""
+"Database not defined, please check default  connection settings by db.connect"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:428
+#, c-format
+msgid "Unable to open data source <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:433
+#, c-format
+msgid ""
+"Option <%s> will be ignored. OGR doesn't support it for selected format (%s)."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:438
+#, c-format
+msgid ""
+"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
+">= 1.11"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:451
+#, c-format
+msgid "Encoding value not supported by OGR driver <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:460
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layers:"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:515
+msgid "No OGR layers available"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:518
+#, c-format
+msgid "All available OGR layers will be imported into vector map <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:714
+msgid "The region flag is applied only to the first OGR layer"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:724
+msgid "The current region does not overlap with OGR input. Nothing to import."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:751
+msgid "The 'spatial' option is applied only to the first OGR layer"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:782
+msgid ""
+"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:816
+msgid "The 'where' option is applied only to the first OGR layer"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:849
+#, c-format
+msgid "Geometry column <%s> not found in OGR layer <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:859
+#, c-format
+msgid "Check if OGR layer <%s> contains polygons..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:895
+#, c-format
+msgid "Boundary splitting distance in map units: %G"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:925
+#, c-format
+msgid "Using temporary vector <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:961
+#, c-format
+msgid "Key column '%s' not found"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:969
+#, c-format
+msgid "Key column '%s' is not integer"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1033
+#, c-format
+msgid "Column name <%s> renamed to <%s>"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1057
+#, c-format
+msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1080
+#, c-format
+msgid ""
+"Width for column %s set to 255 (was not specified by OGR), some strings may "
+"be truncated!"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1092
+#, c-format
+msgid "Writing column %s with fixed length %d chars (may be truncated)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1096
+#, c-format
+msgid "Column type not supported (%s)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1137
+#, c-format
+msgid "Importing %d features (OGR layer <%s>)..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1259
+#, c-format
+msgid "%d %s without geometry skipped"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1286
+msgid "Cleaning polygons"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1290
+#, c-format
+msgid "Snapping boundaries (threshold = %.3e)..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1334
+msgid "Merging boundaries..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1339
+msgid "Changing boundary dangles to lines..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1352
+msgid "Changing boundary bridges to lines..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1396
+#, c-format
+msgid "Finding centroids for OGR layer <%s>..."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1481
+#, c-format
+msgid ""
+"%d areas represent more (overlapping) features, because polygons overlap in "
+"input layer(s). Such areas are linked to more than 1 row in attribute table. "
+"The number of features for those areas is stored as category in layer %d"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1491
+#, c-format
+msgid "%d input polygons\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1492
+#, c-format
+msgid "%d input polygons"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1495
+#, c-format
+msgid "Total area: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1496
+#, c-format
+msgid "Total area: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1499
+#, c-format
+msgid "Overlapping area: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1502
+#, c-format
+msgid "Overlapping area: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1507
+#, c-format
+msgid "Area without category: %G (%d areas)\n"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1510
+#, c-format
+msgid "Area without category: %G (%d areas)"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1581
+msgid "Some input polygons are overlapping each other."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1582
+msgid "If overlapping is not desired, the data need to be cleaned."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1585 ../vector/v.in.ogr/main.c:1614
+msgid "The input could be cleaned by snapping vertices to each other."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1586 ../vector/v.in.ogr/main.c:1609
+#: ../vector/v.in.ogr/main.c:1615
+#, c-format
+msgid "Estimated range of snapping threshold: [%g, %g]"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1590
+#, c-format
+msgid "Try to import again, snapping with at least %g: 'snap=%g'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1594
+#, c-format
+msgid "Try to import again, snapping with %g: 'snap=%g'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1598 ../vector/v.in.ogr/main.c:1611
+msgid "Manual cleaning may be needed."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1602
+#, c-format
+msgid "%d input polygons got lost during import."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1605
+#, c-format
+msgid "%d additional areas where created during import."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1608
+#, c-format
+msgid "The snapping threshold %g might be too large."
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1624 ../vector/v.in.ascii/main.c:550
+#: ../vector/v.in.ascii/main.c:553
+msgid "Import failed"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1635
+#, c-format
+msgid "Unable to drop table: '%s'"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1667 ../raster/r.external/window.c:93
+#: ../raster/r.in.gdal/main.c:814
+msgid "Default region for this location updated"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1670 ../raster/r.external/window.c:96
+#: ../raster/r.in.gdal/main.c:817
+msgid "Region for the current mapset updated"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:1674
+msgid ""
+"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
+"to import 3D vector."
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
+#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:304
+#: ../vector/v.in.ogr/geom.c:352
+#, c-format
+msgid "Skipping empty geometry feature %d"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:199 ../vector/v.in.ogr/geom.c:220
+msgid "Unable to read part of geometry"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:320
+#, c-format
+msgid "Feature (cat %d): degenerated polygon (%d vertices)"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:366
+#, c-format
+msgid "Degenerate island (%d vertices)"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:400
+msgid "Unable calculate centroid"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:431
+msgid "No centroid written for polygon with 0 vertices"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:452
+msgid "Unable to write part of geometry"
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:458
+msgid "Unknown geometry type"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:68
+msgid "Converts file in DXF format to GRASS vector map."
+msgstr ""
+#: ../vector/v.in.dxf/main.c:72
+msgid "Ignore the map extent of DXF file"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:80
+msgid "Import polyface meshes as 3D wire frame"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:84
+msgid "List available DXF layers and exit"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:85 ../vector/v.in.dxf/main.c:92
+#: ../vector/v.in.dxf/main.c:97 ../vector/v.in.dxf/main.c:110
+msgid "DXF layers"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:91
+msgid "Invert selection by DXF layers (don't import layers in list)"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:96
+msgid "Import all objects into one layer"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:100
+msgid "Path to input DXF file"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:109
+msgid "List of DXF layers to import (default: all)"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:124
+msgid "Please specify list of DXF layers to exclude"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:128
+#, c-format
+msgid "Unable to open DXF file <%s>"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:131
+msgid "Layer number: layer name / GRASS compliant name"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:165
+msgid "Building topology failed"
+msgstr ""
+#: ../vector/v.in.dxf/main.c:171
+msgid "Failed to import DXF file!"
+msgstr ""
+#: ../vector/v.in.dxf/add_polyline.c:47
+msgid "vertices following flag missing"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:52
+msgid "Entity handle truncated to 16 characters."
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:91
+msgid "No DXF layers found!"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:100
+msgid "Following DXF layers found:"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:104
+#, c-format
+msgid "Layer %d: %s"
+msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:246
+#, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr ""
+#: ../vector/v.in.dxf/layer_list.c:16
+#, c-format
+msgid "Layer %d: %s\n"
+msgstr ""
+#: ../vector/v.in.dxf/read_dxf.c:57
+msgid "end of file while looking for HEADER"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:218
+#, c-format
+msgid "Could not find a path between stops %d and %d"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:263
+msgid "Finds shortest path using timetables."
+msgstr ""
+#: ../vector/v.net.timetable/main.c:309
+msgid "Layer number or name with walking connections or -1"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:315
+msgid "Name of column with route ids"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:322
+msgid "Name of column with stop timestamps"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:328
+msgid "Name of column with stop ids"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:334
+msgid "Name of column with walk lengths"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:381
+msgid "Could not initialize the timetables"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:459 ../vector/v.net.timetable/main.c:490
+#: ../vector/v.net.timetable/main.c:498
+#, c-format
+msgid "No stop with category: %d"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:505
+msgid "'From' and 'To' stops are the same"
+msgstr ""
+#: ../vector/v.net.timetable/main.c:514
+msgid "No path between the stops"
+msgstr ""
+#: ../vector/v.to.db/main.c:39
+msgid "Populates attribute values from vector features."
+msgstr ""
+#: ../vector/v.to.db/main.c:48
+#, c-format
+msgid ""
+"Vector map <%s> not found in the current mapset. Unable to modify vector "
+"maps from different mapsets."
+msgstr ""
+#: ../vector/v.to.db/main.c:65 ../vector/v.to.db/query.c:83
+#: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
+#, c-format
+msgid "Database connection not defined for layer %d. Use v.db.connect first."
+msgstr ""
+#: ../vector/v.to.db/parse.c:36
+msgid "Layer number or name (write to)"
+msgstr ""
+#: ../vector/v.to.db/parse.c:43
+msgid "For coor valid point/centroid, for length valid line/boundary"
+msgstr ""
+#: ../vector/v.to.db/parse.c:54
+msgid "Value to upload"
+msgstr ""
+#: ../vector/v.to.db/parse.c:72
+msgid "insert new row for each category if doesn't exist yet"
+msgstr ""
+#: ../vector/v.to.db/parse.c:73
+msgid "area size"
+msgstr ""
+#: ../vector/v.to.db/parse.c:74
+msgid ""
+"compactness of an area, calculated as \n"
+"              compactness = perimeter / (2 * sqrt(PI * area))"
+msgstr ""
+#: ../vector/v.to.db/parse.c:76
+msgid ""
+"fractal dimension of boundary defining a polygon, calculated as \n"
+"              fd = 2 * (log(perimeter) / log(area))"
+msgstr ""
+#: ../vector/v.to.db/parse.c:78
+msgid "perimeter length of an area"
+msgstr ""
+#: ../vector/v.to.db/parse.c:79
+msgid "line length"
+msgstr ""
+#: ../vector/v.to.db/parse.c:80
+msgid "number of features for each category"
+msgstr ""
+#: ../vector/v.to.db/parse.c:81
+msgid "point coordinates, X,Y or X,Y,Z"
+msgstr ""
+#: ../vector/v.to.db/parse.c:82
+msgid "line/boundary starting point coordinates, X,Y or X,Y,Z"
+msgstr ""
+#: ../vector/v.to.db/parse.c:83
+msgid "line/boundary end point coordinates, X,Y or X,Y,Z"
+msgstr ""
+#: ../vector/v.to.db/parse.c:84
+msgid ""
+"categories of areas on the left and right side of the boundary, "
+"'query_layer' is used for area category"
+msgstr ""
+#: ../vector/v.to.db/parse.c:86
+msgid ""
+"result of a database query for all records of the geometry(or geometries) "
+"from table specified by 'query_layer' option"
+msgstr ""
+#: ../vector/v.to.db/parse.c:88
+msgid "slope steepness of vector line or boundary"
+msgstr ""
+#: ../vector/v.to.db/parse.c:89
+msgid ""
+"line sinuousity, calculated as line length / distance between end points"
+msgstr ""
+#: ../vector/v.to.db/parse.c:90
+msgid ""
+"line azimuth, calculated as angle between North direction and endnode "
+"direction at startnode"
+msgstr ""
+#: ../vector/v.to.db/parse.c:94
+msgid "Name of attribute column(s) to populate"
+msgstr ""
+#: ../vector/v.to.db/parse.c:103
+msgid "Query layer number or name (read from)"
+msgstr ""
+#: ../vector/v.to.db/parse.c:109
+msgid "Name of attribute column used for 'query' option"
+msgstr ""
+#: ../vector/v.to.db/parse.c:110
+msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
+msgstr ""
+#: ../vector/v.to.db/parse.c:115
+msgid "Field separator for print mode"
+msgstr ""
+#: ../vector/v.to.db/parse.c:120
+msgid "Print only"
+msgstr ""
+#: ../vector/v.to.db/parse.c:126
+msgid "Only print SQL statements"
+msgstr ""
+#: ../vector/v.to.db/parse.c:132
+msgid "Print also totals for option length, area, or count"
+msgstr ""
+#: ../vector/v.to.db/parse.c:178
+msgid "This option requires one column"
+msgstr ""
+#: ../vector/v.to.db/parse.c:183
+msgid "This option requires two columns"
+msgstr ""
+#: ../vector/v.to.db/parse.c:188
+msgid "This option requires at least two columns"
+msgstr ""
+#: ../vector/v.to.db/parse.c:194
+msgid "Parameter 'qcolumn' must be specified for 'option=query'"
+msgstr ""
+#: ../vector/v.to.db/parse.c:199
+msgid "The 'sides' option makes sense only for boundaries"
+msgstr ""
+#: ../vector/v.to.db/parse.c:202
+msgid "The 'sinuous' option makes sense only for lines"
+msgstr ""
+#: ../vector/v.to.db/parse.c:205
+msgid "The 'azimuth' option makes sense only for lines"
+msgstr ""
+#: ../vector/v.to.db/query.c:93
+msgid "Querying database... "
+msgstr ""
+#: ../vector/v.to.db/query.c:108
+#, c-format
+msgid ""
+"Query for category '0' (no category) was not executed because of too many "
+"(%d) query categories. All later reported values for cat 0 are not valid."
+msgstr ""
+#: ../vector/v.to.db/query.c:145
+#, c-format
+msgid "Multiple query results, output value set to NULL (category [%d])"
+msgstr ""
+#: ../vector/v.to.db/query.c:152
+msgid "Unable to fetch record"
+msgstr ""
+#: ../vector/v.to.db/report.c:13
+msgid "No totals for selected option"
+msgstr ""
+#: ../vector/v.to.db/report.c:201
+#, c-format
+msgid "%d categories read from vector map (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:205
+#, c-format
+msgid "%d records selected from table (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:208
+#, c-format
+msgid "%d categories read from vector map exist in selection from table"
+msgstr ""
+#: ../vector/v.to.db/report.c:211
+#, c-format
+msgid "%d categories read from vector map don't exist in selection from table"
+msgstr ""
+#: ../vector/v.to.db/report.c:213
+#, c-format
+msgid "%d records updated/inserted (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:216
+#, c-format
+msgid "%d update/insert errors (layer %d)"
+msgstr ""
+#: ../vector/v.to.db/report.c:219
+#, c-format
+msgid "%d categories with more points (coordinates not loaded)"
+msgstr ""
+#: ../vector/v.to.db/update.c:83
+msgid "Updating database..."
+msgstr ""
+#: ../vector/v.to.db/update.c:116
+#, c-format
+msgid "More elements of category %d, nothing loaded to database"
+msgstr ""
+#: ../vector/v.to.db/update.c:214
+#, c-format
+msgid "Record (cat %d) already exists (not inserted)"
+msgstr ""
+#: ../vector/v.kernel/main.c:68
+#, c-format
+msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
+msgstr ""
+#: ../vector/v.kernel/main.c:110
+msgid "kernel density"
+msgstr ""
+#: ../vector/v.kernel/main.c:112
+msgid "Generates a raster density map from vector points map."
+msgstr ""
+#: ../vector/v.kernel/main.c:113
+msgid ""
+"Density is computed using a moving kernel. Optionally generates a vector "
+"density map on a vector network."
+msgstr ""
+#: ../vector/v.kernel/main.c:117
+msgid "Name of input vector map with training points"
+msgstr ""
+#: ../vector/v.kernel/main.c:122
+msgid "Name of input network vector map"
+msgstr ""
+#: ../vector/v.kernel/main.c:125 ../vector/v.kernel/main.c:154
+#: ../vector/v.kernel/main.c:162 ../vector/v.kernel/main.c:184
+#: ../vector/v.kernel/main.c:209 ../vector/v.kernel/main.c:215
+msgid "Network"
+msgstr ""
+#: ../vector/v.kernel/main.c:132
+msgid "Name for output raster/vector map"
+msgstr ""
+#: ../vector/v.kernel/main.c:133
+msgid "Outputs vector map if network map is given, otherwise raster map"
+msgstr ""
+#: ../vector/v.kernel/main.c:139
+msgid "Kernel radius in map units"
+msgstr ""
+#: ../vector/v.kernel/main.c:145
+msgid "Discretization error in map units"
+msgstr ""
+#: ../vector/v.kernel/main.c:152
+msgid "Maximum length of segment on network"
+msgstr ""
+#: ../vector/v.kernel/main.c:160
+msgid "Maximum distance from point to network"
+msgstr ""
+#: ../vector/v.kernel/main.c:168
+msgid "Multiply the density result by this number"
+msgstr ""
+#: ../vector/v.kernel/main.c:175
+msgid "Node method"
+msgstr ""
+#: ../vector/v.kernel/main.c:181
+msgid "No method applied at nodes with more than 2 arcs"
+msgstr ""
+#: ../vector/v.kernel/main.c:182
+msgid "Equal split (Okabe 2009) applied at nodes"
+msgstr ""
+#: ../vector/v.kernel/main.c:190
+msgid "Kernel function"
+msgstr ""
+#: ../vector/v.kernel/main.c:198
+msgid ""
+"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
+"maximum (experimental)"
+msgstr ""
+#: ../vector/v.kernel/main.c:203
+msgid "Only calculate optimal standard deviation and exit (no map is written)"
+msgstr ""
+#: ../vector/v.kernel/main.c:208
+msgid ""
+"In network mode, normalize values by sum of density multiplied by length of "
+"each segment. Integral over the output map then gives 1.0 * mult"
+msgstr ""
+#: ../vector/v.kernel/main.c:214
+msgid "In network mode, multiply the result by number of input points"
+msgstr ""
+#: ../vector/v.kernel/main.c:233 ../raster/r.relief/main.c:194
+#: ../raster/r.in.gdal/main.c:304 ../raster/r.in.gdal/main.c:621
+#: ../imagery/i.landsat.toar/main.c:548
+#, c-format
+msgid "Raster map <%s> already exists and will be overwritten"
+msgstr ""
+#: ../vector/v.kernel/main.c:236 ../raster/r.relief/main.c:197
+#: ../raster/r.in.gdal/main.c:307 ../raster/r.in.gdal/main.c:624
+#, c-format
+msgid "Raster map <%s> already exists"
+msgstr ""
+#: ../vector/v.kernel/main.c:253
+msgid "Unknown node method"
+msgstr ""
+#: ../vector/v.kernel/main.c:271
+msgid "Unknown kernel function"
+msgstr ""
+#: ../vector/v.kernel/main.c:277
+msgid ""
+"Optimal standard deviation calculation is supported only for node method "
+"'none' and kernel function 'gaussian'."
+msgstr ""
+#: ../vector/v.kernel/main.c:281
+msgid ""
+"Optimal standard deviation calculation is supported only for kernel function "
+"'gaussian'."
+msgstr ""
+#: ../vector/v.kernel/main.c:298
+#, c-format
+msgid "Standard deviation: %f"
+msgstr ""
+#. GTC First argument is resolution, second - number of rows as a text, third - number of columns as a text.
+#: ../vector/v.kernel/main.c:302
+#, c-format
+msgid "Output raster map: resolution: %f\t%s\t%s"
+msgstr ""
+#: ../vector/v.kernel/main.c:349
+#, c-format
+msgid "%d point outside threshold"
+msgid_plural "%d points outside threshold"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.kernel/main.c:372
+#, c-format
+msgid ""
+"Automatic choice of smoothing parameter (standard deviation), maximum "
+"possible value of standard deviation is set to %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:379
+#, c-format
+msgid "Using maximum distance between points: %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:393
+#, c-format
+msgid "Number of input points: %d."
+msgstr ""
+#: ../vector/v.kernel/main.c:394
+#, c-format
+msgid "%d distance read from the map."
+msgid_plural "%d distances read from the map."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.kernel/main.c:399
+#, c-format
+msgid ""
+"Distances between all points are beyond %e (4 * standard deviation), unable "
+"to calculate optimal value."
+msgstr ""
+#: ../vector/v.kernel/main.c:410
+#, c-format
+msgid "Optimal smoothing parameter (standard deviation): %f."
+msgstr ""
+#: ../vector/v.kernel/main.c:441
+#, c-format
+msgid "Writing output vector map using smooth parameter %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:443 ../vector/v.kernel/main.c:553
+#, c-format
+msgid "Normalising factor %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:551
+#, c-format
+msgid "Writing output raster map using smooth parameter %f"
+msgstr ""
+#: ../vector/v.kernel/main.c:603
+#, c-format
+msgid "Maximum value in output: %e."
+msgstr ""
+#: ../vector/v.build.polylines/main.c:117
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../vector/v.build.polylines/main.c:127
+msgid "Category number mode"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:132
+msgid "Do not assign any category number to polyline"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:133
+msgid "Assign category number of first line to polyline"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:134
+msgid "Assign multiple category numbers to polyline"
+msgstr ""
+#: ../vector/v.build.polylines/main.c:230
+#, c-format
+msgid "%d line or boundaries found in input vector map"
+msgid_plural "%d lines or boundaries found in input vector map"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.build.polylines/main.c:234
+#, c-format
+msgid "%d polyline stored in output vector map"
+msgid_plural "%d polylines stored in output vector map"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.to.points/main.c:61
+msgid "Creates points along input lines in new vector map with 2 layers."
+msgstr ""
+#: ../vector/v.to.points/main.c:79
+msgid "Use line nodes or vertices only"
+msgstr ""
+#: ../vector/v.to.points/main.c:87
+msgid "Maximum distance between points in map units"
+msgstr ""
+#: ../vector/v.to.points/main.c:91
+msgid "Interpolate points between line vertices (only for use=vertex)"
+msgstr ""
+#: ../vector/v.to.points/main.c:232
+#, c-format
+msgid ""
+"%d features without category in layer <%d> skipped. Note that features "
+"without category (usually boundaries) are not skipped when '%s=-1' is given."
+msgstr ""
+#: ../vector/v.to.points/main.c:282
+#, c-format
+msgid "%d points written to output vector map."
+msgstr ""
+#: ../vector/v.to.rast3/main.c:51
+msgid "Converts a vector map (only points) into a 3D raster map."
+msgstr ""
+#: ../vector/v.to.rast3/main.c:62
+msgid "Name of attribute column (data type must be numeric)"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:107
+msgid "Unable to create output map"
+msgstr ""
+#: ../vector/v.to.rast3/main.c:157
+msgid "Unable to close new 3d raster map"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:46
+msgid "PostGIS"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:47
+msgid "simple features"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:52
+msgid "Exports a vector map layer to PostGIS feature table."
+msgstr ""
+#: ../vector/v.out.postgis/main.c:103
+#, c-format
+msgid "Vector map <%s> is not in native format. Export cancelled."
+msgstr ""
+#: ../vector/v.out.postgis/main.c:110 ../general/g.region/main.c:473
+#, c-format
+msgid "Unable to open vector map <%s> on topological level"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:134
+#, c-format
+msgid "Unable to create PostGIS layer <%s>"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:141
+#, c-format
+msgid "Feature type %d is not supported"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:151
+msgid "Copying features failed"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:159
+#, c-format
+msgid "Building %s topology failed"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:163
+#, c-format
+msgid "No features exported. PostGIS layer <%s> not created."
+msgstr ""
+#: ../vector/v.out.postgis/main.c:167
+#, c-format
+msgid "%d feature (%s type) written to <%s>."
+msgid_plural "%d features (%s type) written to <%s>."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.postgis/main.c:173
+#, c-format
+msgid "%d primitive written to <%s>."
+msgid_plural "%d primitives written to <%s>."
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.out.postgis/main.c:212
+#, c-format
+msgid "Unable to drop table <%s.%s>"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:220
+#, c-format
+msgid "Unable to drop topology schema <%s>"
+msgstr ""
+#: ../vector/v.out.postgis/table.c:27
+#, c-format
+msgid "No database connection for layer <%s>"
+msgstr ""
+#: ../vector/v.out.postgis/table.c:50
+#, c-format
+msgid ""
+"Invalid FID column (%s). FID column must be integer. Please specify "
+"different FID column by 'options=\"FID=<name>\"'."
+msgstr ""
+#: ../vector/v.out.postgis/table.c:57
+#, c-format
+msgid ""
+"Column (%s) already exists in the table. Please specify different geometry "
+"column by 'options=\"GEOMETRY_NAME=<name>\"'."
+msgstr ""
+#: ../vector/v.out.postgis/args.c:25
+msgid "Name for output PostGIS datasource"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:27
+msgid "Starts with 'PG' prefix, eg. 'PG:dbname=grass'"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:35
+msgid "Name for output PostGIS layer"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:37
+msgid "If not specified, input name is used"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:44
+msgid ""
+"Name for output vector map defined as a link to the PostGIS feature table"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:46
+msgid ""
+"If not specified, the vector link is not created. The link can be also "
+"manually created by 'v.external' module."
+msgstr ""
+#: ../vector/v.out.postgis/args.c:53
+msgid ""
+"Examples:\n"
+"\t\t'FID=cat': define feature id column 'cat'\n"
+"\t\t'GEOMETRY_NAME=wkb_geometry': define geometry column 'wkb_geometry'\n"
+"\t\t'SPATIAL_INDEX=NO': do not create spatial index on geometry column"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:66
+msgid "Do not export attribute table"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:72
+msgid "Export PostGIS topology instead of simple features"
+msgstr ""
+#: ../vector/v.out.postgis/args.c:77
+msgid "Force 2D output even if input is 3D "
+msgstr ""
+#: ../vector/v.out.postgis/create.c:28
+#, c-format
+msgid "Unable to create <%s> file"
+msgstr ""
+#: ../vector/v.out.postgis/create.c:66
+#, c-format
+msgid "Invalid option skipped: %s"
+msgstr ""
+#: ../vector/v.out.postgis/create.c:74
+#, c-format
+msgid "EPSG code (%s) defined for current location will be ignored"
+msgstr ""
+#: ../vector/v.out.postgis/create.c:102
+#, c-format
+msgid "Error writing <%s> file"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:72
+msgid "Creates a vector map from an ASCII points file or ASCII vector file."
+msgstr ""
+#: ../vector/v.in.ascii/main.c:76 ../raster3d/r3.in.ascii/main.c:83
+#: ../raster/r.in.ascii/main.c:78
+msgid "Name of input file to be imported"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:90
+msgid "simple x,y[,z] list"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:91
+msgid "GRASS vector ASCII format"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:94
+msgid "Input file format"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:95 ../vector/v.in.ascii/main.c:98
+#: ../vector/v.in.ascii/main.c:105 ../vector/v.in.ascii/main.c:183
+msgid "Input format"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:104
+msgid "Special characters: doublequote, singlequote"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:114
+msgid "Number of header lines to skip at top of input file (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:123
+msgid "Column definition in SQL style (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:124
+msgid ""
+"For example: 'x double precision, y double precision, cat int, name "
+"varchar(10)'"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:136 ../vector/v.in.ascii/main.c:146
+msgid "First column is 1"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:145
+msgid "Number of column used as y coordinate (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:155
+msgid "Number of column used as z coordinate (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:156
+msgid "First column is 1. If 0, z coordinate is not used"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:166
+msgid "Number of column used as category (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:168
+msgid ""
+"First column is 1. If 0, unique category is assigned to each row and written "
+"to new column 'cat'"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:177
+msgid "Create a new empty vector map and exit. Nothing is read from input."
+msgstr ""
+#: ../vector/v.in.ascii/main.c:182
+msgid "Do not expect a header when reading in standard format"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:187
+msgid "Do not create table in points mode"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:191 ../raster/r.random/main.c:96
+msgid "Do not build topology in points mode"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:197
+msgid "Only import points falling within current region (points mode)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:202
+msgid "Ignore broken line(s) in points mode"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:216 ../raster/r.in.xyz/main.c:345
+msgid "Please specify reasonable number of lines to skip"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:219
+msgid "Please specify z column"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:230
+msgid "Please specify reasonable z column"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:235
+msgid "Column numbers must not be negative"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:279
+#, c-format
+msgid "Maximum input row length: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:281
+#, c-format
+msgid "Maximum number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:282
+#, c-format
+msgid "Minimum number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:285
+#, c-format
+msgid "Number of columns: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:288
+#, c-format
+msgid "Number of rows: %d"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:292 ../vector/v.in.ascii/main.c:296
+#: ../vector/v.in.ascii/main.c:301 ../vector/v.in.ascii/main.c:306
+#, c-format
+msgid ""
+"'%s' column number > minimum last column number (incorrect field separator "
+"or format?)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:311 ../vector/v.in.ascii/main.c:314
+#: ../vector/v.in.ascii/main.c:317 ../vector/v.in.ascii/main.c:320
+#, c-format
+msgid "'%s' column is not of number type"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:360
+msgid "Category column is not of integer type"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:437
+#, c-format
+msgid ""
+"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:465
+#, c-format
+msgid "Column number %d <%s> defined as double has only integer values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:470
+#, c-format
+msgid "Column number %d <%s> defined as string has only integer values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:477
+#, c-format
+msgid "Column number %d <%s> defined as integer has double values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:482
+#, c-format
+msgid "Column number %d <%s> defined as string has double values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:489
+#, c-format
+msgid "Column number %d <%s> defined as integer has string values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:494
+#, c-format
+msgid "Column number %d <%s> defined as double has string values"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:499
+#, c-format
+msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
+msgstr ""
+#: ../vector/v.in.ascii/main.c:535
+msgid "Populating table..."
+msgstr ""
+#: ../vector/v.in.ascii/main.c:541
+msgid ""
+"Could not close attribute table. The DBMI driver did not accept all "
+"attributes"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:82
+msgid "Scanning input for column types..."
+msgstr ""
+#: ../vector/v.in.ascii/points.c:130
+#, c-format
+msgid "Row %d: '%s' can not be imported into the attribute table"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:134 ../vector/v.in.ascii/points.c:144
+#, c-format
+msgid "Broken row %d: '%s'"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:188 ../vector/v.in.ascii/points.c:207
+#, c-format
+msgid ""
+"Current row %d:\n"
+"%s\n"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:189 ../vector/v.in.ascii/points.c:217
+#, c-format
+msgid "Unparsable longitude value in column %d: %s"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:208 ../vector/v.in.ascii/points.c:221
+#, c-format
+msgid "Unparsable latitude value in column %d: %s"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:298
+#, c-format
+msgid "Skipping %d of %d row falling outside of current region"
+msgid_plural "Skipping %d of %d rows falling outside of current region"
+msgstr[0] ""
+msgstr[1] ""
+#: ../vector/v.in.ascii/points.c:328
+msgid "Importing points..."
+msgstr ""
+#: ../vector/v.timestamp/main.c:37 ../raster3d/r3.timestamp/main.c:44
+#: ../raster/r.timestamp/main.c:37
+msgid "timestamp"
+msgstr ""
+#: ../vector/v.timestamp/main.c:38
+msgid "Modifies a timestamp for a vector map."
+msgstr ""
+#: ../vector/v.timestamp/main.c:39
+msgid "Print/add/remove a timestamp for a vector map."
+msgstr ""
+#: ../vector/v.timestamp/main.c:49 ../raster/r.timestamp/main.c:48
+msgid "Datetime, datetime1/datetime2, or 'none' to remove"
+msgstr ""
+#: ../vector/v.timestamp/main.c:50 ../raster/r.timestamp/main.c:49
+msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
+msgstr ""
+#: ../vector/v.timestamp/main.c:65
+#, c-format
+msgid "Vector map <%s> not found %s"
+msgstr ""
+#: ../vector/v.net.flow/main.c:60 ../raster/r.sim/r.sim.water/main.c:112
+msgid "flow"
+msgstr ""
+#: ../vector/v.net.flow/main.c:62
+msgid "Computes the maximum flow between two sets of nodes in the network."
+msgstr ""
+#: ../vector/v.net.flow/main.c:84
+msgid "Name for output vector map containing a minimum cut"
+msgstr ""
+#: ../vector/v.net.flow/main.c:107
+msgid "Source category values"
+msgstr ""
+#: ../vector/v.net.flow/main.c:113
+msgid "Source WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.flow/main.c:118
+msgid "Sink category values"
+msgstr ""
+#: ../vector/v.net.flow/main.c:119 ../vector/v.net.flow/main.c:125
+msgid "Sink"
+msgstr ""
+#: ../vector/v.net.flow/main.c:124
+msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
+msgstr ""
+#: ../vector/v.net.flow/main.c:199
+#, c-format
+msgid "No source features selected. Please check options '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.flow/main.c:206
+#, c-format
+msgid "No sink features selected. Please check options '%s', '%s'."
+msgstr ""
+#: ../vector/v.net.flow/main.c:215
+msgid "No sources"
+msgstr ""
+#: ../vector/v.net.flow/main.c:218
+msgid "No sinks"
+msgstr ""
+#: ../vector/v.net.flow/main.c:242
+msgid "Writing the output..."
+msgstr ""
+#: ../temporal/t.connect/main.c:38
+msgid ""
+"Prints/sets general temporal GIS database connection for current mapset."
+msgstr ""
+#: ../temporal/t.connect/main.c:54
+msgid "Overwrite current settings if initialized"
+msgstr ""
+#: ../temporal/t.connect/main.c:59
+msgid "Print current connection parameter in shell style and exit"
+msgstr ""
+#: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
+msgid "Temporal GIS database connection not defined. Run t.connect."
+msgstr ""
+#: ../temporal/t.connect/main.c:111
+#, c-format
+msgid ""
+"Default TGIS driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
+msgstr ""
+#: ../temporal/t.connect/main.c:118
+msgid "Default TGIS driver is not set"
+msgstr ""
+#: ../temporal/t.connect/main.c:121
+msgid "Default TGIS database is not set"
+msgstr ""
+#: ../visualization/ximgview/main.c:64 ../general/g.cairocomp/main.c:89
+#: ../general/g.cairocomp/main.c:256
+msgid "Unable to open display"
+msgstr ""
+#: ../visualization/ximgview/main.c:84
+msgid "Unable to get window attributes"
+msgstr ""
+#: ../visualization/ximgview/main.c:258
+msgid "Unable to open image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:261
+msgid "Unable to read BMP header"
+msgstr ""
+#: ../visualization/ximgview/main.c:264
+msgid "Invalid BMP header"
+msgstr ""
+#: ../visualization/ximgview/main.c:270
+msgid "Unable to map image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:290
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
+#: ../locale/scriptstrings/d.out.file_to_translate.c:2
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:2
+#: ../locale/scriptstrings/d.redraw_to_translate.c:2
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:2
+#: ../locale/scriptstrings/d.shade_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:2
+#: ../locale/scriptstrings/d.polar_to_translate.c:2
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
+#: ../raster3d/r3.mkdspf/main.c:80 ../general/g.ppmtopng/main.c:118
+#: ../general/g.cairocomp/main.c:197 ../general/g.pnmcomp/main.c:283
+#: ../display/d.graph/main.c:58 ../display/d.labels/main.c:43
+#: ../display/d.grid/main.c:51 ../display/d.rhumbline/main.c:44
+#: ../display/d.mon/main.c:38 ../display/d.erase/main.c:29
+#: ../display/d.font/main.c:45 ../display/d.geodesic/main.c:46
+#: ../display/d.rast/main.c:53 ../display/d.rast.num/main.c:76
+#: ../display/d.vect/main.c:70 ../display/d.histogram/main.c:83
+#: ../display/d.linegraph/main.c:119 ../display/d.extract/main.c:49
+#: ../display/d.where/main.c:43 ../display/d.info/main.c:31
+#: ../display/d.his/main.c:62 ../display/d.vect.thematic/main.c:78
+#: ../display/d.text/main.c:138 ../display/d.vect.chart/main.c:63
+#: ../display/d.rgb/main.c:53 ../display/d.legend/main.c:85
+#: ../display/d.northarrow/main.c:42 ../display/d.rast.arrow/main.c:95
+#: ../display/d.profile/main.c:191 ../display/d.barscale/main.c:54
+#: ../display/d.path/main.c:48 ../display/d.fontlist/main.c:45
+#: ../display/d.colorlist/main.c:35 ../display/d.title/main.c:49
+#: ../display/d.colortable/main.c:60
+msgid "display"
+msgstr ""
+#: ../visualization/ximgview/main.c:295
+msgid "View BMP images from the PNG driver."
+msgstr ""
+#: ../visualization/ximgview/main.c:301
+msgid "Image file"
+msgstr ""
+#: ../visualization/ximgview/main.c:308
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:6
+msgid "Percentage of CPU time to use"
+msgstr ""
+#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
+#, c-format
+msgid "Unknown visual class [%d]."
+msgstr ""
+#: ../visualization/ximgview/color.c:239
+msgid "Unable to get sufficient gray shades."
+msgstr ""
+#: ../visualization/ximgview/color.c:256
+msgid "Unable to get sufficient colors."
+msgstr ""
+#: ../visualization/ximgview/color.c:269
+msgid "Using private colormap for DirectColor visual."
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
+msgid ""
+"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
+"channels"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:2
+#: ../locale/scriptstrings/i.spectral_to_translate.c:2
+#: ../locale/scriptstrings/i.oif_to_translate.c:2
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
+#: ../imagery/i.cluster/main.c:75 ../imagery/i.eb.netrad/main.c:56
+#: ../imagery/i.eb.hsebal01/main.c:104 ../imagery/i.target/main.c:45
+#: ../imagery/i.landsat.toar/main.c:70 ../imagery/i.group/main.c:52
+#: ../imagery/i.modis.qc/main.c:138 ../imagery/i.zc/main.c:52
+#: ../imagery/i.pca/main.c:72 ../imagery/i.gensigset/main.c:40
+#: ../imagery/i.emissivity/main.c:44 ../imagery/i.fft/main.c:78
+#: ../imagery/i.eb.eta/main.c:42 ../imagery/i.smap/main.c:38
+#: ../imagery/i.ifft/main.c:77 ../imagery/i.segment/main.c:35
+#: ../imagery/i.eb.evapfr/main.c:47 ../imagery/i.his.rgb/main.c:46
+#: ../imagery/i.aster.toar/main.c:97 ../imagery/i.landsat.acca/main.c:105
+#: ../imagery/i.evapo.mh/main.c:69 ../imagery/i.topo.corr/main.c:47
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:88
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:388
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:56
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:63
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:47
+#: ../imagery/i.albedo/main.c:88 ../imagery/i.evapo.pt/main.c:66
+#: ../imagery/i.biomass/main.c:50 ../imagery/i.eb.soilheatflux/main.c:49
+#: ../imagery/i.evapo.time/main.c:77 ../imagery/i.cca/main.c:84
+#: ../imagery/i.evapo.pm/main.c:58 ../imagery/i.rectify/main.c:99
+#: ../imagery/i.maxlik/main.c:61 ../imagery/i.gensig/main.c:39
+#: ../imagery/i.vi/main.c:89 ../imagery/i.rgb.his/main.c:46
+msgid "imagery"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
+msgid "fusion"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:4
+msgid "sharpen"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:5
+msgid "Brovey"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:6
+msgid "IHS"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:7
+msgid "HIS"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
+#: ../imagery/i.pca/main.c:74
+msgid "PCA"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:9
+msgid "Name of raster map to be used for <red>"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:10
+msgid "Name of raster map to be used for <green>"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:11
+msgid "Name of raster map to be used for <blue>"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
+msgid "Name of raster map to be used for high resolution panchromatic channel"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
+msgid "Method for pan sharpening"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
+msgid "Serial processing rather than parallel processing"
+msgstr ""
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:15
+msgid "Rebalance blue channel for LANDSAT"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+"using gdalwarp."
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
+#: ../imagery/i.aster.toar/main.c:99
+msgid "Terra-ASTER"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
+msgid "Name of input ASTER image"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
+msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
+msgid ""
+"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
+"all bands"
+msgstr ""
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
+msgid ""
+"Base name for output raster map (band number will be appended to base name)"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:1
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:3
+#: ../raster/r.composite/main.c:73
+msgid "composite"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:4
+msgid "Name of first raster map for blending"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:5
+msgid "Name of second raster map for blending"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:6
+msgid "Basename for red, green and blue output raster maps"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:7
+msgid "Percentage weight of first map for color blending"
+msgstr ""
+#: ../locale/scriptstrings/r.blend_to_translate.c:8
+msgid "Combine resulting R,G,B layers into single output map"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:1
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:3
+#: ../locale/scriptstrings/r.shade_to_translate.c:3
+#: ../locale/scriptstrings/d.shade_to_translate.c:3
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
+#: ../raster/r.relief/main.c:108
+msgid "elevation"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:4
+msgid "Dip of plane in degrees"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:5
+msgid "Azimuth of the plane in degrees"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:6
+msgid "Easting coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:7
+msgid "Northing coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:8
+msgid "Elevation coordinate of a point on the plane"
+msgstr ""
+#: ../locale/scriptstrings/r.plane_to_translate.c:9
+msgid "Type of raster map to be created"
+msgstr ""
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
+msgid "Views BMP images from the PNG driver."
+msgstr ""
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
+msgid "Name of input image file"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"raster map of a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.rename_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:2
+#: ../locale/scriptstrings/t.snap_to_translate.c:2
+#: ../locale/scriptstrings/t.shift_to_translate.c:2
+#: ../locale/scriptstrings/t.merge_to_translate.c:2
+#: ../locale/scriptstrings/t.sample_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.list_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:2
+#: ../locale/scriptstrings/t.register_to_translate.c:2
+#: ../locale/scriptstrings/t.select_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.remove_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
+#: ../locale/scriptstrings/t.support_to_translate.c:2
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:2
+#: ../locale/scriptstrings/t.topology_to_translate.c:2
+#: ../locale/scriptstrings/t.unregister_to_translate.c:2
+#: ../locale/scriptstrings/t.create_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:2
+#: ../locale/scriptstrings/t.info_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
+msgid "temporal"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:13
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:7
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:12
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.list_to_translate.c:15
+msgid "Field separator character between the output columns"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:14
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:16
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:13
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:11
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:13
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:15
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
+#: ../locale/scriptstrings/t.list_to_translate.c:10
+#: ../locale/scriptstrings/t.list_to_translate.c:16
+#: ../locale/scriptstrings/t.list_to_translate.c:18
+#: ../raster/r.report/parse.c:69 ../raster/r.report/parse.c:77
+#: ../raster/r.report/parse.c:85 ../raster/r.report/parse.c:109
+#: ../raster/r.report/parse.c:114 ../raster/r.report/parse.c:119
+#: ../raster/r.report/parse.c:124 ../raster/r.stats/main.c:123
+#: ../raster/r.stats/main.c:127 ../raster/r.stats/main.c:151
+#: ../raster/r.univar/r.univar_main.c:56 ../raster/r.univar/r.univar_main.c:62
+#: ../raster/r.univar/r.univar_main.c:72 ../raster/r.kappa/main.c:104
+#: ../raster/r.kappa/main.c:109
+msgid "Formatting"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:15
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:14
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:10
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:14
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:10
+msgid "Suppress printing of column names"
+msgstr ""
+#: ../locale/scriptstrings/t.rename_to_translate.c:1
+msgid "Renames a space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rename_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
+#: ../locale/scriptstrings/t.list_to_translate.c:3
+#: ../locale/scriptstrings/t.register_to_translate.c:3
+#: ../locale/scriptstrings/t.remove_to_translate.c:3
+#: ../locale/scriptstrings/t.unregister_to_translate.c:3
+#: ../locale/scriptstrings/t.create_to_translate.c:3
+#: ../general/g.filename/main.c:40 ../general/g.findfile/main.c:39
+#: ../general/g.dirseps/main.c:35 ../general/g.rename/main.c:46
+#: ../general/g.findetc/main.c:29 ../general/g.copy/main.c:42
+#: ../general/g.remove/main.c:70 ../general/g.list/main.c:90
+#: ../general/g.access/main.c:38 ../raster/r.compress/main.c:65
+#: ../imagery/i.target/main.c:46 ../imagery/i.group/main.c:53
+msgid "map management"
+msgstr ""
+#: ../locale/scriptstrings/t.rename_to_translate.c:4
+#: ../general/g.rename/main.c:47
+msgid "rename"
+msgstr ""
+#: ../locale/scriptstrings/t.rename_to_translate.c:5
+#: ../locale/scriptstrings/t.snap_to_translate.c:5
+#: ../locale/scriptstrings/t.shift_to_translate.c:5
+#: ../locale/scriptstrings/t.select_to_translate.c:4
+#: ../locale/scriptstrings/t.support_to_translate.c:5
+#: ../locale/scriptstrings/t.topology_to_translate.c:4
+#: ../locale/scriptstrings/t.info_to_translate.c:6
+msgid "input"
+msgstr ""
+#: ../locale/scriptstrings/t.rename_to_translate.c:6
+#: ../locale/scriptstrings/t.snap_to_translate.c:6
+#: ../locale/scriptstrings/t.shift_to_translate.c:6
+#: ../locale/scriptstrings/t.merge_to_translate.c:5
+#: ../locale/scriptstrings/t.sample_to_translate.c:5
+#: ../locale/scriptstrings/t.sample_to_translate.c:6
+#: ../locale/scriptstrings/t.select_to_translate.c:5
+#: ../locale/scriptstrings/t.support_to_translate.c:6
+#: ../locale/scriptstrings/t.topology_to_translate.c:5
+#: ../locale/scriptstrings/t.info_to_translate.c:7
+msgid "Required"
+msgstr ""
+#: ../locale/scriptstrings/v.build.all_to_translate.c:1
+msgid "Rebuilds topology on all vector maps in the current mapset."
+msgstr ""
+msgid "Lists registered maps of a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:5
+#: ../locale/scriptstrings/t.list_to_translate.c:4 ../general/g.list/main.c:91
+msgid "list"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:6
+#: ../locale/scriptstrings/t.list_to_translate.c:9
+msgid "Sort the space time dataset by category"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:8
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:8
+#: ../locale/scriptstrings/t.list_to_translate.c:12
+msgid "Columns to be printed to stdout"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:11
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:11
+msgid "Method used for data listing"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:12
+msgid ""
+"The granule to be used for listing. The granule must be specified as string "
+"eg.: absolute time \"1 months\" or relative time \"1\""
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
+msgid "Imports SPOT VGT NDVI data into a raster map."
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
+msgid "Also import quality map (SM status map layer) and filter NDVI map"
+msgstr ""
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
+msgid "Name of input SPOT VGT NDVI HDF file"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:1
+msgid "Performs auto-balancing of colors for RGB images."
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:3
+#: ../locale/scriptstrings/r.rgb_to_translate.c:3
+msgid "RGB"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:4
+msgid "satellite"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:5
+#: ../display/d.colorlist/main.c:37
+msgid "colors"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:6
+msgid "Name of red channel"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:7
+msgid "Name of green channel"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:8
+msgid "Name of blue channel"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:9
+msgid "Cropping intensity (upper brightness level)"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:10
+msgid "Extend colors to full range of data on each channel"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:12
+msgid "Preserve relative colors, adjust brightness only"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:14
+msgid "Reset to standard color range"
+msgstr ""
+#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:16
+#: ../locale/scriptstrings/i.oif_to_translate.c:7
+msgid "Process bands serially (default: run in parallel)"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:1
+msgid "Reports geometry statistics for vector maps."
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:6
+msgid "Value to calculate"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:7
+msgid "Sort the result"
+msgstr ""
+#: ../locale/scriptstrings/v.report_to_translate.c:8
+msgid "asc;Sort in ascending order;desc;Sort in descending order"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:1
+msgid "Computes cyclic accumulations of a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
+#: ../raster/r.series.accumulate/main.c:82
+msgid "accumulation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
+msgid ""
+"Input space time raster dataset that defines the lower threshold, values "
+"lower this threshold are excluded from accumulation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
+msgid ""
+"Input space time raster dataset that defines the upper threshold, values "
+"upper this threshold are excluded from accumulation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
+msgid "The temporal starting point to begin the accumulation, eg '2001-01-01'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
+msgid "The temporal date to stop the accumulation, eg '2009-01-01'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:11
+msgid "The temporal cycle to restart the accumulation, eg '12 months'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
+msgid "The temporal offset to the begin of the next cycle, eg '6 months'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:11
+msgid "The granularity for accumulation '1 day'"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
+msgid "Basename of the new generated output maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
+msgid ""
+"A numerical suffix separated by an underscore will be attached to create a "
+"unique identifier"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
+msgid ""
+"Use these limits in case lower and/or upper input  space time raster "
+"datasets are not defined"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
+msgid "Scale factor for input space time raster dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
+msgid "Shift factor for input space time raster dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
+msgid ""
+"This method will be applied to compute the accumulative values from the "
+"input maps in a single granule"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
+msgid ""
+"Register empty maps in the output space time raster dataset, otherwise they "
+"will be deleted"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
+msgid "Reverse time direction in cyclic accumulation"
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
+msgid "Imports E00 file into a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
+msgid "Name of input E00 file"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:1
+msgid ""
+"Aggregates data of an existing space time raster dataset using the time "
+"intervals of a second space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
+msgid ""
+"Time intervals from this space time dataset (raster, vector or raster3d) are "
+"used for aggregation computation"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
+msgid "Type of the aggregation space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:8
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
+msgid "Aggregate operation to be performed on the raster maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
+msgid ""
+"Offset that is used to create the output map ids, output map id is generated "
+"as: basename_ (count + offset)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:8
+msgid "Number of r.mapcalc processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:10
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
+msgid "Register Null maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:13
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
+msgid ""
+"Use start time - truncated accoring to granularity - as suffix. This flag "
+"overrides the offset option."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
+msgid "Exports space time raster dataset as VTK time series."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
+msgid "VTK"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:6
+msgid "Path to the export directory"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
+#: ../raster/r.out.vtk/parameters.c:45
+msgid "Value to represent no data cell"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
+#: ../raster/r.out.vtk/parameters.c:59
+msgid ""
+"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
+msgid ""
+"Export files using the space time dataset granularity for equidistant time "
+"between maps, where statement will be ignored"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
+msgid "Imports GetFeature from a WFS server."
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
+msgid "OGC web services"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
+msgid "Base URL starting with 'http' and ending in '?'"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:6
+msgid "Comma separated names of data layers to download"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:7
+msgid "Specify alternate spatial reference system (example: EPSG:4326)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
+msgid ""
+"The given code must be supported by the server, consult the capabilities file"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
+msgid "Maximum number of features to download"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
+msgid "(default: unlimited)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:11
+msgid "Skip earlier feature IDs and start downloading at this one"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:12
+msgid "(default: start with the first feature)"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
+msgid ""
+"Download server capabilities to 'wms_capabilities.xml' in the current "
+"directory and exit"
+msgstr ""
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
+msgid "Restrict fetch to features which touch the current region"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:1
+msgid ""
+"Displays spectral response at user specified locations in group or images."
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:5
+#: ../locale/scriptstrings/i.oif_to_translate.c:3
+msgid "multispectral"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:9
+msgid "Name for output image"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:11
+msgid "Graphics format for output file"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:13
+msgid "Show sampling coordinates instead of numbering in the legend"
+msgstr ""
+#: ../locale/scriptstrings/i.spectral_to_translate.c:14
+msgid "Use gnuplot for display"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:1
+msgid ""
+"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
+msgid "Path to the extraction directory"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
+#: ../locale/scriptstrings/t.create_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
+msgid "Title of the new space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:9
+#: ../locale/scriptstrings/t.create_to_translate.c:8
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:9
+msgid "Description of the new space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:10
+msgid ""
+"Create a new location and import the data into it. Do not run this module in "
+"parallel or interrupt it when a new location should be created"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
+msgid "Extend location extents based on new dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:12
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
+#: ../raster/r.external/main.c:100 ../raster/r.in.gdal/main.c:158
+msgid "Override projection (use location's projection)"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:13
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the space time vector datasets."
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
+msgid "Downloads and imports data from WMS/WMTS/NASA OnEarth server."
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
+msgid "Typically starts with \"http://\""
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
+#: ../locale/scriptstrings/v.krige_to_translate.c:8
+#: ../imagery/i.ifft/main.c:93
+msgid "Name for output raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
+msgid "Layer(s) to request from the map server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
+msgid "Layer style(s) to request from the map server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
+msgid "Map style"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
+msgid "Image format requested from the server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
+msgid "Request"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
+msgid "EPSG code of requested source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
+msgid "Driver used to communication with server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
+msgid ""
+"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
+"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
+"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
+msgid "WMS standard version"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
+msgid "Maximum columns to request at a time"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
+msgid "Maximum rows to request at a time"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
+msgid "Additional query parameters to pass to the server"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
+msgid "Username for server connection"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
+msgid "Password for server connection"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
+msgid "Interpolation method to use in reprojection"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
+msgid "Request data for this named region instead of the current region bounds"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
+msgid "Format: 0xRRGGBB"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
+msgid ""
+"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
+"OnEarth_GRASS drivers"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
+msgid "File where the server capabilities will be saved ('c' flag)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
+msgid "Get the server capabilities then exit"
+msgstr ""
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
+msgid "Do not request transparent data"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:1
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+#: ../raster3d/r3.retile/main.c:97 ../raster/r.tile/main.c:44
+msgid "tiling"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:4
+msgid "Produces shell script output"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:5
+msgid "Produces web map server query string output"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:6
+msgid ""
+"Name of region to use instead of current region for bounds and resolution"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+msgid "Source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:8
+#: ../locale/scriptstrings/r.tileset_to_translate.c:10
+msgid "Conversion factor from units to meters in source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:9
+msgid "Destination projection, defaults to this location's projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:11
+msgid "Maximum number of columns for a tile in the source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:12
+msgid "Maximum number of rows for a tile in the source projection"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:13
+msgid "Number of cells tiles should overlap in each direction"
+msgstr ""
+#: ../locale/scriptstrings/r.tileset_to_translate.c:14
+msgid "Output field separator"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
+#: ../display/d.graph/main.c:59 ../display/d.grid/main.c:52
+#: ../display/d.linegraph/main.c:120 ../display/d.vect.thematic/main.c:79
+#: ../display/d.text/main.c:139 ../display/d.vect.chart/main.c:64
+#: ../display/d.legend/main.c:86 ../display/d.northarrow/main.c:43
+#: ../display/d.barscale/main.c:55 ../display/d.title/main.c:50
+msgid "cartography"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
+msgid "legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
+#: ../display/d.legend/main.c:216
+msgid "Flip legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
+msgid "Omit entries with missing label"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
+msgid "Name of raster map to display"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
+#: ../display/d.legend/main.c:211
+msgid "Draw smooth gradient"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
+msgid "Number of lines to appear in the legend"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
+msgid "Name of input raster map to generate legend from"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
+msgid ""
+"Observes specific locations in a space time raster dataset over a period of "
+"time using vector points."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
+msgid ""
+"Name of the new created vector map that stores the sampled values in "
+"different layers"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
+msgid ""
+"Names of the vector columns to be created and to store sampled raster "
+"values, one name for each STRDS"
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:1
+msgid "Calculates Optimum-Index-Factor table for spectral bands"
+msgstr ""
+#: ../locale/scriptstrings/i.oif_to_translate.c:6
+#: ../locale/scriptstrings/t.info_to_translate.c:8
+#: ../general/g.region/main.c:142 ../raster/r.regression.line/main.c:68
+#: ../raster/r.regression.multi/main.c:160 ../imagery/i.group/main.c:88
+msgid "Print in shell script style"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
+msgid ""
+"Prints attributes of vector maps registered in a space time vector dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
+msgid "select"
+msgstr ""
+msgid "Lists registered maps of a space time raster3d dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:7
+msgid "Order the space time dataset by category"
+msgstr ""
+#: ../locale/scriptstrings/t.snap_to_translate.c:1
+msgid "Snaps temporally the maps of a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.snap_to_translate.c:4
+#: ../locale/scriptstrings/t.shift_to_translate.c:4
+msgid "Name of an existing space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
+msgid "Mosaics several images and extends colormap."
+msgstr ""
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
+#: ../raster/r.patch/main.c:56
+msgid "mosaicking"
+msgstr ""
+#: ../locale/scriptstrings/t.shift_to_translate.c:1
+msgid "Shifts temporally the maps of a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.shift_to_translate.c:3
+msgid "shift"
+msgstr ""
+#: ../locale/scriptstrings/t.shift_to_translate.c:7
+msgid "Shift granularity"
+msgstr ""
+#: ../locale/scriptstrings/t.shift_to_translate.c:8
+msgid ""
+"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
+"minutes, x seconds\", relative time is of type integer"
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
+msgid "dissolve"
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+msgid "Layer number or name."
+msgstr ""
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
+msgid "Name of attribute column used to dissolve common boundaries"
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:1
+msgid "Converts vector polygons or points to lines."
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:7
+msgid "Method used for point interpolation"
+msgstr ""
+#: ../locale/scriptstrings/v.to.lines_to_translate.c:8
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:10
+msgid "Area"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:1
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:4
+#: ../general/g.list/main.c:137 ../raster/r.topmodel/main.c:71
+msgid "Name for output file"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:6
+msgid "Width and height of output image"
+msgstr ""
+#: ../locale/scriptstrings/d.out.file_to_translate.c:7
+msgid "Images"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
+msgid "Removes existing attribute table of a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
+msgid "Force removal (required for actual deletion of table)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
+msgid "Table name (default: vector map name)"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:1
+msgid "Splits a raster map into red, green and blue maps."
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:4
+msgid "Red channel raster map name"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:5
+msgid "Green channel raster map name"
+msgstr ""
+#: ../locale/scriptstrings/r.rgb_to_translate.c:6
+msgid "Blue channel raster map name"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:1
+msgid ""
+"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:4
+#: ../locale/scriptstrings/v.unpack_to_translate.c:4
+#: ../locale/scriptstrings/r.pack_to_translate.c:4
+#: ../locale/scriptstrings/v.pack_to_translate.c:4
+msgid "copying"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:5
+#: ../locale/scriptstrings/v.unpack_to_translate.c:5
+msgid "Name of input pack file"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:6
+msgid "Name for output raster map (default: taken from input file internals)"
+msgstr ""
+#: ../locale/scriptstrings/r.unpack_to_translate.c:8
+msgid "Override projection check (use location's projection)"
+msgstr ""
+#: ../locale/scriptstrings/t.merge_to_translate.c:1
+msgid "Merges several space time datasets into a single space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.merge_to_translate.c:3
+msgid "merge"
+msgstr ""
+#: ../locale/scriptstrings/t.merge_to_translate.c:4
+#: ../locale/scriptstrings/t.remove_to_translate.c:7
+msgid "inputs"
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:1
+msgid ""
+"Samples the input space time dataset(s) with a sample space time dataset and "
+"print the result to stdout."
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:4
+msgid "Name of the sample space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:7
+msgid "Type of the sample space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:8
+msgid "Field separator between output columns, default is tabular \" | \""
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:9
+msgid ""
+"Do not use \",\" as this char is reserved to list several map ids in a "
+"sample granule"
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:10
+#: ../locale/scriptstrings/t.list_to_translate.c:17
+msgid "Print the column names as first row"
+msgstr ""
+#: ../locale/scriptstrings/t.sample_to_translate.c:11
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:10
+msgid "Check spatial overlap"
+msgstr ""
+msgid ""
+"Detects accumulation patterns in temporally accumulated space time raster "
+"datasets created by t.rast.accumulate."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
+msgid ""
+"Input space time raster dataset that specifies the minimum values to detect "
+"the accumulation pattern"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
+msgid ""
+"Input space time raster dataset that specifies the maximum values to detect "
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
+msgid ""
+"The output space time raster dataset that stores the occurrence of the the "
+"accumulation pattern using the provided data range"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
+msgid ""
+"The output space time raster dataset that stores the indication of the "
+"start, intermediate and end of the specified data range"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
+msgid ""
+"The minimum and maximum value of the occurrence of accumulated values, these "
+"values will be used if the min/max space time raster datasets are not "
+"specified"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
+msgid ""
+"The user defined values that indicate start, intermediate and end status in "
+"the indicator output space time raster dataset"
+msgstr ""
+#: ../locale/scriptstrings/d.to.rast_to_translate.c:1
+msgid "Saves the contents of the active display monitor to a raster map."
+msgstr ""
+msgid ""
+"3D raster map of a space time 3D raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:1
+#: ../locale/scriptstrings/d.shade_to_translate.c:1
+msgid "Drapes a color raster over an shaded relief or aspect map."
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:4
+#: ../locale/scriptstrings/d.shade_to_translate.c:4
+#: ../raster/r.relief/main.c:109
+msgid "relief"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:5
+#: ../locale/scriptstrings/d.shade_to_translate.c:5
+#: ../raster/r.relief/main.c:111
+msgid "hillshade"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:7
+#: ../locale/scriptstrings/d.shade_to_translate.c:7
+msgid "Name of shaded relief or aspect raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:8
+#: ../locale/scriptstrings/d.shade_to_translate.c:8
+msgid "Name of raster to drape over relief raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:9
+#: ../locale/scriptstrings/d.shade_to_translate.c:9
+msgid "Typically, this raster is elevation or other colorful raster"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:10
+msgid "Name of shaded raster map"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:11
+#: ../locale/scriptstrings/d.shade_to_translate.c:10
+msgid "Percent to brighten"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:12
+#: ../raster/r.his/main.c:121
+msgid "Color to use instead of NULL values"
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:13
+msgid "Either a standard color name, R:G:B triplet, or \"none\""
+msgstr ""
+#: ../locale/scriptstrings/r.shade_to_translate.c:14
+#: ../raster/r.his/main.c:126
+msgid "Use colors from color tables for NULL values"
+msgstr ""
+#: ../locale/scriptstrings/db.univar_to_translate.c:1
+msgid "Calculates univariate statistics on selected table column."
+msgstr ""
+#: ../locale/scriptstrings/db.univar_to_translate.c:5
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
+msgid ""
+"Name of attribute column on which to calculate statistics (must be numeric)"
+msgstr ""
+#: ../locale/scriptstrings/db.univar_to_translate.c:7
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
+msgid "Extended statistics (quartiles and 90th percentile)"
+msgstr ""
+#: ../locale/scriptstrings/db.univar_to_translate.c:8
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
+msgid "Print stats in shell script style"
+msgstr ""
+msgid "Lists registered maps of a space time vector dataset."
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:1
+msgid "Updates a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:5
+msgid "Name of attribute column to update"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:6
+msgid "Literal value to update the column with"
+msgstr ""
+#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+msgid ""
+"Name of other attribute column to query, can be combination of columns (e.g. "
+"co1+col2)"
+msgstr ""
+#: ../locale/scriptstrings/d.redraw_to_translate.c:1
+msgid "Redraws the content of currently selected monitor."
+msgstr ""
+#: ../locale/scriptstrings/d.redraw_to_translate.c:4
+#: ../display/d.mon/main.c:40 ../display/d.erase/main.c:31
+#: ../display/d.info/main.c:33
+msgid "monitors"
+msgstr ""
+msgid ""
+"Create a 3D raster map from an assemblage of many coordinates using "
+"univariate statistics"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
+#: ../raster/r.in.xyz/main.c:303 ../raster/r.in.lidar/main.c:283
+msgid "Scan data file for extent then exit"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
+#: ../raster/r.in.xyz/main.c:308 ../raster/r.in.lidar/main.c:289
+msgid "In scan mode, print using shell script style"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
+#: ../raster/r.in.xyz/main.c:312
+msgid "Ignore broken lines"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
+msgid "ASCII file containing input data"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
+#: ../raster/r.in.xyz/main.c:178 ../raster/r.in.lidar/main.c:186
+msgid "Statistic to use for raster values"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
+#: ../raster/r.in.xyz/main.c:182 ../raster/r.in.xyz/main.c:290
+#: ../raster/r.in.xyz/main.c:299 ../raster/r.in.lidar/main.c:190
+#: ../raster/r.in.lidar/main.c:230 ../raster/r.in.lidar/main.c:239
+msgid "Statistic"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
+#: ../raster/r.in.ascii/main.c:88 ../raster/r.in.xyz/main.c:190
+#: ../raster/r.in.lidar/main.c:198
+msgid "Storage type for resultant raster map"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
+#: ../raster/r.in.xyz/main.c:201
+msgid "Column number of x coordinates in input file (first column is 1)"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
+#: ../raster/r.in.xyz/main.c:209
+msgid "Column number of y coordinates in input file"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
+msgid "Column number of z coordinates in input file"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
+#: ../raster/r.in.xyz/main.c:217
+msgid "Column number of data values in input file"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
+msgid "If not given or set to 0, the data points' z-values are used"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
+msgid "Filter range for value column data (min,max)"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
+msgid "Scaling factor to apply to value column data"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
+#: ../raster/r.in.xyz/main.c:280 ../raster/r.in.lidar/main.c:220
+msgid "Percent of map to keep in memory"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
+#: ../raster/r.in.xyz/main.c:289 ../raster/r.in.lidar/main.c:229
+msgid "pth percentile of the values"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
+#: ../raster/r.in.xyz/main.c:298 ../raster/r.in.lidar/main.c:238
+msgid ""
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
+msgstr ""
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
+msgid "Number of parallel processes to launch"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:1
+msgid ""
+"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:6
+msgid "Name for output vector map"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:7
+msgid "Default: taken from input file internals"
+msgstr ""
+#: ../locale/scriptstrings/v.unpack_to_translate.c:8
+msgid "Override projection check (use current location's projection)"
+msgstr ""
+#: ../locale/scriptstrings/d.what.rast_to_translate.c:1
+msgid ""
+"Allows the user to interactively query raster map layers at user-selected "
+"locations."
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:1
+msgid "Drops an attribute table."
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:4
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
+#: ../general/g.remove/main.c:135
+msgid "Force removal (required for actual deletion of files)"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:5
+msgid "Name of database driver"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:6
+msgid "If not given then default driver is used"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:8
+msgid "Name of database"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:9
+msgid "If not given then default database is used"
+msgstr ""
+#: ../locale/scriptstrings/db.droptable_to_translate.c:11
+msgid "Name of table to drop"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+msgid "Input map is in Matlab format"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
+msgid "Create a 3D vector points map from 3 column Matlab data"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+msgid "Name of input file in Mapgen/Matlab format"
+msgstr ""
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
+msgid "Name for output vector map (omit for display to stdout)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
+msgid "Layer number where to add column(s)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
+msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+msgid ""
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
+msgstr ""
+msgid ""
+"Calculates univariate statistics of attributes for each registered vector "
+"map of a space time vector dataset"
+msgstr ""
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
+"datasets."
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
+msgid "r3.mapcalc expression applied to each time step of the sampled data"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:9
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:8
+msgid "Number of r3.mapcalc processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:1
+msgid "Extracts a subset of a space time vector dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
+msgid ""
+"The number of v.extract processes to run in parallel. Use only if database "
+"backend is used which supports concurrent writing"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
+msgid "Register empty maps"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+msgid "Action to be taken"
+msgstr ""
+#: ../locale/scriptstrings/v.centroids_to_translate.c:6
+msgid "Category number starting value"
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:1
+msgid "Rebuilds or removes all locally installed GRASS Addons extensions."
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:2
+msgid ""
+"By default only extensions built against different GIS Library are rebuilt."
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
+#: ../locale/scriptstrings/g.extension_to_translate.c:3
+#: ../locale/scriptstrings/g.manual_to_translate.c:2
+#: ../general/g.filename/main.c:39 ../general/g.findfile/main.c:38
+#: ../general/g.dirseps/main.c:34 ../general/g.version/main.c:61
+#: ../general/g.ppmtopng/main.c:117 ../general/g.cairocomp/main.c:196
+#: ../general/g.message/main.c:33 ../general/g.rename/main.c:45
+#: ../general/g.findetc/main.c:28 ../general/g.mapsets/main.c:63
+#: ../general/g.copy/main.c:41 ../general/g.proj/main.c:63
+#: ../general/g.pnmcomp/main.c:282 ../general/g.mkfontcap/main.c:71
+#: ../general/g.remove/main.c:69 ../general/g.list/main.c:89
+#: ../general/g.region/main.c:63 ../general/g.mapset/main.c:49
+#: ../general/g.gisenv/main.c:43 ../general/g.tempfile/main.c:38
+#: ../general/g.gui/main.c:37 ../general/g.access/main.c:37
+#: ../general/g.setproj/main.c:78
+msgid "general"
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:4
+#: ../locale/scriptstrings/g.extension_to_translate.c:4
+msgid "installation"
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:5
+#: ../locale/scriptstrings/g.extension_to_translate.c:5
+msgid "extensions"
+msgstr ""
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:7
+msgid "Force operation (required for removal)"
+msgstr ""
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
+msgid "Drops a column from selected attribute table."
+msgstr ""
+#: ../locale/scriptstrings/d.correlate_to_translate.c:1
+msgid "Prints a graph of the correlation between raster maps (in pairs)."
+msgstr ""
+#: ../locale/scriptstrings/d.correlate_to_translate.c:5
+#: ../locale/scriptstrings/d.polar_to_translate.c:3
+msgid "diagram"
+msgstr ""
+#: ../locale/scriptstrings/d.correlate_to_translate.c:6
+msgid "correlation"
+msgstr ""
+msgid "Lists space time datasets and maps registered in the temporal database."
+msgstr ""
+#: ../locale/scriptstrings/t.list_to_translate.c:5
+msgid "Type of the space time dataset or map, default is strds"
+msgstr ""
+#: ../locale/scriptstrings/t.list_to_translate.c:8
+#: ../locale/scriptstrings/t.list_to_translate.c:11
+msgid ""
+"Columns number_of_maps and granularity only available for space time datasets"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+msgid "Name of new attribute table (default: vector map name)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:9
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
+msgid "Definition"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
+msgid "Layer number where to add new attribute table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
+msgid "Name and type of the new column(s)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
+msgid ""
+"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
+"PRECISION and DATE. Example: \"label varchar(250), type integer\""
+msgstr ""
+msgid ""
+"Aggregates temporally the maps of a space time raster dataset by a user "
+"defined granularity."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
+msgid ""
+"Either a numerical suffix or the start time (s-flag) separated by an "
+"underscore will be attached to create a unique identifier"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
+msgid ""
+"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
+"x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
+msgid "Number of r.series processes to run in parallel"
+msgstr ""
+msgid ""
+"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
+"space time raster datasets."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
+msgid "Spatio-temporal mapcalc expression"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
+msgid "Basename for output raster maps"
+msgstr ""
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
+msgid "Name of attribute column(s) to drop"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:1
+msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:4
+msgid "Input coordinates to reproject"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:5
+#: ../locale/scriptstrings/m.proj_to_translate.c:8
+#: ../locale/scriptstrings/m.proj_to_translate.c:12
+msgid "Input coordinates"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:6
+msgid "Name of input coordinate file"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:9
+msgid "Name for output coordinate file (omit to send to stdout)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:11
+msgid "Field separator (format: input[,output])"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:13
+msgid "Input projection parameters (PROJ.4 style)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:14
+#: ../locale/scriptstrings/m.proj_to_translate.c:16
+#: ../locale/scriptstrings/m.proj_to_translate.c:18
+#: ../locale/scriptstrings/m.proj_to_translate.c:20
+msgid "Projections"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:15
+msgid "Output projection parameters (PROJ.4 style)"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:17
+msgid "Use LL WGS84 as input and current location as output projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:19
+msgid "Use current location as input and LL WGS84 as output projection"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:21
+msgid ""
+"Output long/lat in decimal degrees, or other projections with many decimal "
+"places"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
+msgid "Include input coordinates in output file"
+msgstr ""
+#: ../locale/scriptstrings/m.proj_to_translate.c:25
+msgid "Include column names in output file"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
+msgid ""
+"Stores raster map values at spatial and temporal positions of vector points "
+"as vector attributes."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
+msgid ""
+"Name of the vector column to be created and to store sampled raster values"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
+msgid ""
+"The use of a column name forces t.vect.what.rast to sample only values from "
+"the first map found in an interval. Otherwise the raster map names are used "
+"as column names"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:1
+msgid "Maintains GRASS Addons extensions in local GRASS installation."
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:2
+msgid ""
+"Downloads, installs extensions from GRASS Addons SVN repository into local "
+"GRASS installation or removes installed extensions."
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:6
+msgid "Name of extension to install or remove"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:7
+msgid "Name of toolbox (set of extensions) when -t flag is given"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:9
+msgid "SVN Addons repository URL"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:10
+msgid "Prefix where to install extension (ignored when flag -s is given)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:11
+msgid "Set the proxy with: \"http=<value>,ftp=<value>\""
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:12
+msgid "List available extensions in the GRASS Addons SVN repository"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:14
+msgid ""
+"List available extensions in the GRASS Addons SVN repository including "
+"module description"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:16
+msgid ""
+"List available extensions in the GRASS Addons SVN repository (shell script "
+"style)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:18
+msgid "List locally installed extensions"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:20
+msgid "Install system-wide (may need system administrator rights)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:21
+#: ../locale/scriptstrings/g.extension_to_translate.c:23
+#: ../locale/scriptstrings/g.extension_to_translate.c:25
+msgid "Install"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:22
+msgid "Download source code and exit"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:24
+msgid "Do not install new extension, just compile it"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:26
+msgid "Force removal when uninstalling extension (operation=remove)"
+msgstr ""
+#: ../locale/scriptstrings/g.extension_to_translate.c:28
+msgid "Operate on toolboxes instead of single modules (experimental)"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:1
+msgid "Registers raster, vector and raster3d maps in a space time datasets."
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:4
+msgid "register"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:7
+#: ../locale/scriptstrings/t.unregister_to_translate.c:6
+msgid "input,maps"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:9
+#: ../locale/scriptstrings/t.unregister_to_translate.c:5
+msgid "Input file with map names, one per line"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:10
+msgid "Additionally the start time and the end time can be specified per line"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:12
+msgid "Valid start date and time of the first map"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:13
+#: ../locale/scriptstrings/t.register_to_translate.c:16
+msgid ""
+"Format absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of "
+"type integer)."
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:14
+#: ../locale/scriptstrings/t.register_to_translate.c:17
+#: ../locale/scriptstrings/t.register_to_translate.c:20
+#: ../locale/scriptstrings/t.register_to_translate.c:23
+#: ../locale/scriptstrings/t.register_to_translate.c:27
+msgid "Time & Date"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:15
+msgid "Valid end date and time of all map"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:18
+msgid "Time stamp unit"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:19
+msgid "Unit must be set in case of relative time stamps"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:21
+msgid "Time increment"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:22
+msgid ""
+"Time increment between maps for valid time interval creation (format "
+"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
+"relative is integer: 5)"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:24
+msgid "Field separator character of the input file"
+msgstr ""
+#: ../locale/scriptstrings/t.register_to_translate.c:26
+msgid ""
+"Create an interval (start and end time) in case an increment is provided"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:1
+msgid "Draws polar diagram of angle map such as aspect or flow directions"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:4
+msgid "Name of raster angle map"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:5
+msgid "Pixel value to be interpreted as undefined (different from NULL)"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:6
+msgid "Name for optional EPS output file"
+msgstr ""
+#: ../locale/scriptstrings/d.polar_to_translate.c:7
+msgid "Plot using Xgraph"
+msgstr ""
+#: ../locale/scriptstrings/t.select_to_translate.c:1
+msgid ""
+"Select maps from space time datasets by topological relationships to other "
+"space time datasets using temporal algebra."
+msgstr ""
+#: ../locale/scriptstrings/t.select_to_translate.c:6
+msgid "The temporal mapcalc expression"
+msgstr ""
+#: ../locale/scriptstrings/t.select_to_translate.c:7
+msgid "Activate spatial topology"
+msgstr ""
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
+msgid "Removes a vector feature from a vector map through attribute selection."
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
+msgid ""
+"Reconnects attribute tables for all vector maps from the current mapset to a "
+"new database."
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
+msgid "Copy attribute tables to the target database if not exist"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+msgid "Delete attribute tables from the source database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
+msgid "Name of source database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
+msgid "Name of source database schema"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:9
+msgid "Name for target driver"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:10
+msgid "Name for target database"
+msgstr ""
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:11
+msgid "Name for target database schema"
+msgstr ""
+#: ../locale/scriptstrings/db.test_to_translate.c:1
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../locale/scriptstrings/db.test_to_translate.c:4
+msgid "Test name"
+msgstr ""
+#: ../locale/scriptstrings/d.what.vect_to_translate.c:1
+msgid ""
+"Allows the user to interactively query vector map layers at user-selected "
+"locations."
+msgstr ""
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
+msgid "Value option that sets the area size limit (in hectares)"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
+msgid "Lesser or greater than specified value"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:9
+msgid "Method used for reclassification"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:11
+msgid "Input map is clumped"
+msgstr ""
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:12
+msgid "Clumps including diagonal neighbors"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
+msgid "Exports space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:5
+msgid "Name of a space time raster dataset archive"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:6
+msgid "Path to the work directory, default is /tmp"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
+msgid "Compression method of the tar archive"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:8
+msgid "The export format of a single raster map"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:9
+msgid ""
+"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
+"r.pack"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:1
+msgid "Displays the manual pages of GRASS modules."
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:3
+msgid "manual"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:4
+msgid "help"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:5
+msgid "Display index"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:6
+msgid "Display topics"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:7
+msgid "Display as MAN text page instead of HTML page in browser"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:8
+msgid "Display online manuals instead of locally installed"
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:9
+msgid ""
+"Use online manuals available at http://grass.osgeo.org website. This flag "
+"has no effect when displaying MAN text pages."
+msgstr ""
+#: ../locale/scriptstrings/g.manual_to_translate.c:10
+msgid "Manual entry to be displayed"
+msgstr ""
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
+msgid "Extracts a subset of a space time raster datasets."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
+msgid "r.mapcalc expression assigned to all extracted raster maps"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:1
+msgid "Removes space time datasets from temporal database."
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:4
+#: ../general/g.remove/main.c:71
+msgid "remove"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:6
+msgid "Type of the space time dataset, default is strds"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:9
+msgid "Input file with dataset names, one per line"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:11
+msgid "Remove all registered maps from the temporal and spatial database"
+msgstr ""
+#: ../locale/scriptstrings/t.remove_to_translate.c:12
+msgid "Force recursive removing"
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
+msgid "Imports geonames.org country files into a vector points map."
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
+msgid "gazetteer"
+msgstr ""
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
+msgid "Name of uncompressed geonames file (with .txt extension)"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
+msgid ""
+"Calculates univariate statistics from a raster map based on a vector map and "
+"uploads statistics to new attribute columns."
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
+msgid "Continue if upload column(s) already exist"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
+msgid "Name of input raster map to calculate statistics from"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
+msgid "Column prefix for new attribute columns"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
+msgid "The methods to use"
+msgstr ""
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
+msgid "Percentile to calculate"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
+msgid ""
+"Creates/modifies the color table associated with each raster map of the "
+"space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
+msgid "Name of color table (see r.color help)"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
+#: ../raster/r.colors/edit_colors.c:147
+msgid "Histogram equalization"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:1
+msgid "Modifies the metadata of a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:4
+#: ../locale/scriptstrings/t.create_to_translate.c:6
+msgid "Semantic type of the space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:7
+msgid "Title of the space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:8
+msgid "Description of the space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:9
+msgid ""
+"Update the metadata information and spatial extent of registered maps from "
+"the GRASS spatial database"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:10
+msgid ""
+"Check for removed maps and delete them from the temporal database and all "
+"effected space time datasets"
+msgstr ""
+#: ../locale/scriptstrings/t.support_to_translate.c:11
+msgid ""
+"Update metadata information, temporal and spatial extent from registered maps"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:1
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:5
+msgid "Name of a space time vector dataset archive"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:8
+msgid "The export format of a single vector map"
+msgstr ""
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:9
+msgid "Supported are GML via v.out.ogr and the GRASS package format of v.pack"
+msgstr ""
+#: ../locale/scriptstrings/t.topology_to_translate.c:1
+msgid "Lists temporal topology of a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.topology_to_translate.c:6
+msgid "Print temporal relationships and exit"
+msgstr ""
+#: ../locale/scriptstrings/t.topology_to_translate.c:7
+msgid "Print spatio-temporal relationships and exit"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+#: ../imagery/i.landsat.toar/main.c:75 ../imagery/i.landsat.acca/main.c:106
+msgid "Landsat"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+#: ../imagery/i.modis.qc/main.c:143
+msgid "MODIS"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
+msgid "Tasseled Cap transformation"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
+msgid ""
+"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
+"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
+#: ../imagery/i.pca/main.c:85
+msgid "Name for output basename raster map(s)"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+msgid "Satellite sensor"
+msgstr ""
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+msgid ""
+"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
+"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
+"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 OLI;"
+"modis;Use transformation rules for MODIS"
+msgstr ""
+#: ../locale/scriptstrings/t.unregister_to_translate.c:1
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.unregister_to_translate.c:4
+msgid "unregister"
+msgstr ""
+#: ../locale/scriptstrings/t.unregister_to_translate.c:7
+msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
+msgstr ""
+#: ../locale/scriptstrings/t.create_to_translate.c:1
+msgid "Creates a space time dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.create_to_translate.c:4
+msgid "create"
+msgstr ""
+#: ../locale/scriptstrings/t.create_to_translate.c:5
+msgid "Type of the output space time dataset"
+msgstr ""
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
+msgid ""
+"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
+msgid "ASCII"
+msgstr ""
+msgid ""
+"Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
+#: ../raster/r.neighbors/main.c:212
+msgid "Neighborhood size"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
+msgid "Number of r.neighbor processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
+msgid "Imports SRTM HGT files into raster map."
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
+msgid "Name of SRTM input tile (file without .hgt.zip extension)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
+msgid "Name for output raster map (default: input tile)"
+msgstr ""
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
+msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:1
+msgid "Exports a raster map as GRASS GIS specific archive file"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:5
+msgid "Name of raster map to pack up"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:6
+#: ../locale/scriptstrings/v.pack_to_translate.c:6
+msgid "Name for output file (default is <input>.pack)"
+msgstr ""
+#: ../locale/scriptstrings/r.pack_to_translate.c:7
+#: ../locale/scriptstrings/v.pack_to_translate.c:7
+msgid "Switch the compression off"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
+msgid "Edits cell values in a raster map."
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
+#: ../raster/r.flow/main.c:434
+msgid "Name of input aspect raster map"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
+msgid "Width of display canvas"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
+msgid "Height of display canvas"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
+msgid "Minimum size of each cell"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
+msgid "Maximum number of rows to load"
+msgstr ""
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
+msgid "Maximum number of columns to load"
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
+msgid "Sets color rules based on stddev from a raster map's mean value."
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
+msgid "Color using standard deviation bands"
+msgstr ""
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
+msgid "Force center at zero"
+msgstr ""
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
+msgid "Old and new name of the column (old,new)"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
+msgid "Name of vector map to be queried"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
+msgid "Name of attribute column to be queried"
+msgstr ""
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:12
+msgid "Maximum query distance in map units"
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
+msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
+msgid "Create a 3D line from 3 column data"
+msgstr ""
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:7
+msgid "Name of input file (or \"-\" to read from stdin)"
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:1
+msgid "Lists information about space time datasets and maps."
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:5
+msgid "Name of an existing space time dataset or map"
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:9
+msgid ""
+"Print history information in human readable shell style for space time "
+"datasets"
+msgstr ""
+#: ../locale/scriptstrings/t.info_to_translate.c:10
+msgid "Print information about the temporal DBMI interface and exit"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:1
+msgid "Performs ordinary or block kriging for vector maps."
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:5
+msgid "kriging"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:6
+msgid "Name of point vector map containing sample data"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:7
+msgid "Name of attribute column with numerical value to be interpolated"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:9
+msgid "If omitted, will be <input name>_kriging"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:10
+msgid "R package to use"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:11
+msgid "Variogram model(s)"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:12
+msgid "Leave empty to test all models (requires automap)"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:13
+msgid "Block size (square block)"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:14
+msgid "Block size. Used by block kriging."
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:15
+msgid "Range value"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:16
+#: ../locale/scriptstrings/v.krige_to_translate.c:18
+#: ../locale/scriptstrings/v.krige_to_translate.c:20
+msgid "Automatically fixed if not set"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:17
+msgid "Nugget value"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:19
+msgid "Sill value"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:21
+msgid "Name for output variance raster map"
+msgstr ""
+#: ../locale/scriptstrings/v.krige_to_translate.c:22
+msgid "If omitted, will be <input name>_kriging.var"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:1
+msgid "Creates a MASK for limiting raster operation."
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:3
+#: ../raster3d/r3.mask/main.c:134
+msgid "mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:4
+msgid "Name of raster map to use as mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:8
+msgid "Raster"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:6
+msgid "Raster values to use for mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:7
+msgid "Format: 1 2 3 thru 7 *"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:9
+msgid "Name of vector map to use as mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:10
+#: ../locale/scriptstrings/r.mask_to_translate.c:12
+#: ../locale/scriptstrings/r.mask_to_translate.c:14
+#: ../locale/scriptstrings/r.mask_to_translate.c:16
+msgid "Vector"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:11
+msgid "Layer number or name (vector)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:13
+msgid "Category values (vector)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:15
+msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:17
+msgid "Create inverse mask"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:18
+#: ../general/g.proj/main.c:200 ../general/g.mapset/main.c:70
+msgid "Create"
+msgstr ""
+#: ../locale/scriptstrings/r.mask_to_translate.c:19
+msgid "Remove existing mask (overrides other options)"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
+msgid "Table file to be imported or DB connection string"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
+msgid "Name of table from given DB to be imported"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+msgid "Name for output table"
+msgstr ""
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:9
+msgid "Name for auto-generated unique key column"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
+msgid "Converts a space time raster dataset into a 3D raster map."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
+msgid ""
+"Performs different aggregation algorithms from r.series on all or a subset "
+"of raster maps in a space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
+#: ../raster/r.series.accumulate/main.c:81 ../raster/r.series.interp/main.c:65
+#: ../raster/r.series/main.c:135
+msgid "series"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
+msgid "Sort the maps by category"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
+msgid ""
+"Do not assign the space time raster dataset start and end time to the output "
+"map"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:8
+#: ../raster/r.series.accumulate/main.c:159
+#: ../raster/r.resamp.stats/main.c:283 ../raster/r.series/main.c:183
+#: ../raster/r.resamp.filter/main.c:425
+msgid "Propagate NULLs"
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
+#: ../raster/r.buffer/main.c:69
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
+msgid "This is the low-memory alternative to the classic r.buffer module."
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
+#: ../raster/r.buffer/main.c:94
+msgid "Ignore zero (0) data cells instead of NULL cells"
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
+#: ../raster/r.buffer/main.c:81
+msgid "Distance zone(s)"
+msgstr ""
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
+#: ../raster/r.buffer/main.c:88
+msgid "Units of distance"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:1
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:3
+msgid "Radius is in map units rather than cells"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:4
+msgid "Radius of buffer in raster cells"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:5
+#: ../raster/r.grow.distance/main.c:174
+msgid "Metric"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:6
+msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
+msgstr ""
+#: ../locale/scriptstrings/r.grow_to_translate.c:7
+msgid "Value to write for \"grown\" cells"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
+msgid ""
+"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
+msgid "Number of interpolation processes to run in parallel"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:8
+msgid ""
+"Assign the space time raster dataset start and end time to the output map"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:1
+msgid "Extracts a subset of a space time 3D raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
+msgid "The r3.mapcalc expression assigned to all extracted 3D raster maps"
+msgstr ""
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
+msgid "Basename of the new generated 3D raster maps"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
+msgid "Fills no-data areas in raster maps using spline interpolation."
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
+#: ../raster/r.proj/main.c:182
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:127
+#: ../imagery/i.rectify/main.c:148
+msgid "Interpolation method to use"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
+msgid "Spline tension parameter"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
+msgid "RST options"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
+msgid "Spline smoothing parameter"
+msgstr ""
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
+msgid "Width of hole edge used for interpolation (in cells)"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:1
+msgid "Joins a database table to a vector map table."
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:5
+msgid "Vector map to which to join other table"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:6
+msgid "layer,column"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+msgid "Layer where to join"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:8
+msgid "column"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:9
+msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:10
+msgid "Other table name"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:11
+msgid "ocolumn,scolumns"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:12
+msgid "Identifier column (e.g.: id) in the other table used for join"
+msgstr ""
+#: ../locale/scriptstrings/v.db.join_to_translate.c:13
+msgid "Subset of columns from the other table"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:1
+msgid "Imports space time raster dataset."
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
+msgid "Set the current region from the last map that was imported"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:12
+msgid "Link the raster files using r.external"
+msgstr ""
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:15
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the space time raster datasets."
+msgstr ""
+#: ../locale/scriptstrings/v.pack_to_translate.c:1
+msgid "Exports a vector map as GRASS GIS specific archive file"
+msgstr ""
+#: ../locale/scriptstrings/v.pack_to_translate.c:5
+msgid "Name of vector map to pack up"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
+msgid "Exports attribute tables into various formats."
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
+msgid "GRASS table name"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
+msgid "Output table file name or DB connection string"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
+msgid "Table format"
+msgstr ""
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
+msgid "Name for output table (default: input name)"
+msgstr ""
+#: ../raster3d/r3.timestamp/main.c:47
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr ""
+#: ../raster3d/r3.timestamp/main.c:56
+msgid "Datetime, datetime1/datetime2, or none"
+msgstr ""
+#: ../raster3d/r3.timestamp/main.c:89
+msgid "Timestamp format is invalid"
+msgstr ""
+#: ../raster3d/r3.info/main.c:80
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../raster3d/r3.info/main.c:86
+msgid "Print raster3d information in shell style"
+msgstr ""
+#: ../raster3d/r3.info/main.c:90
+msgid "Print range in shell style only"
+msgstr ""
+#: ../raster3d/r3.info/main.c:94 ../raster/r.info/main.c:92
+msgid "Print raster history instead of info"
+msgstr ""
+#: ../raster3d/r3.info/main.c:103
+#, c-format
+msgid "3D Raster map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.info/main.c:110 ../raster3d/r3.out.bin/main.c:314
+#: ../raster3d/r3.to.rast/main.c:237 ../raster3d/r3.to.rast/main.c:261
+#: ../raster3d/r3.stats/main.c:103 ../raster3d/r3.cross.rast/main.c:279
+#: ../raster3d/r3.null/main.c:110 ../raster3d/r3.out.ascii/main.c:339
+#: ../raster3d/r3.out.v5d/main.c:312 ../raster3d/r3.mask/main.c:64
+#: ../raster3d/r3.out.vtk/main.c:207 ../raster3d/r3.out.vtk/main.c:292
+#: ../raster3d/r3.out.vtk/main.c:513 ../raster3d/r3.neighbors/main.c:266
+#: ../raster3d/r3.neighbors/main.c:275 ../raster3d/r3.out.netcdf/main.c:617
+#: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.mkdspf/main.c:168
+#: ../raster/r.univar/r3.univar_main.c:151
+#: ../raster/r.univar/r3.univar_main.c:189
+#, c-format
+msgid "Unable to open 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
+#: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
+#: ../raster3d/r3.info/main.c:162 ../raster3d/r3.info/main.c:167
+#: ../raster3d/r3.info/main.c:172 ../raster3d/r3.info/main.c:183
+#: ../raster3d/r3.info/main.c:189 ../raster3d/r3.info/main.c:204
+#: ../raster3d/r3.info/main.c:211 ../raster3d/r3.info/main.c:218
+#: ../raster3d/r3.info/main.c:223 ../raster3d/r3.info/main.c:228
+#: ../raster3d/r3.info/main.c:235 ../raster3d/r3.info/main.c:245
+#: ../raster3d/r3.info/main.c:251 ../raster3d/r3.info/main.c:257
+#: ../raster3d/r3.info/main.c:273 ../raster3d/r3.info/main.c:280
+#: ../raster3d/r3.info/main.c:287 ../raster3d/r3.info/main.c:296
+#: ../raster3d/r3.info/main.c:306 ../raster3d/r3.info/main.c:316
+#: ../raster3d/r3.info/main.c:326 ../raster3d/r3.info/main.c:346
+#: ../raster3d/r3.info/main.c:356 ../raster3d/r3.info/main.c:361
+#: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
+#: ../raster/r.info/main.c:289 ../raster/r.info/main.c:432
+msgid "Cannot allocate memory for string"
+msgstr ""
+#: ../raster3d/r3.info/main.c:328 ../raster3d/r3.info/main.c:448
+#: ../raster3d/r3.mkdspf/main.c:171
+#, c-format
+msgid "Unable to read range of 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.info/main.c:476
+msgid "Error while reading history file"
+msgstr ""
+#: ../raster3d/r3.info/main.c:483 ../raster3d/r3.cross.rast/main.c:343
+#: ../raster3d/r3.null/main.c:169 ../raster3d/r3.out.vtk/errorHandling.c:65
+#, c-format
+msgid "Unable to close 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:113 ../raster/r.out.bin/main.c:53
+#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:470
+#: ../raster/r.mapcalc/map3.c:126 ../raster/r.mapcalc/map3.c:140
+#: ../raster/r.mapcalc/map3.c:154
+msgid "Error writing data"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:208
+msgid "Exports a GRASS 3D raster map to a binary array."
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:221 ../raster/r.out.bin/main.c:304
+msgid "Value to write out for null"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:228 ../raster3d/r3.in.bin/main.c:268
+msgid "Number of bytes per cell in binary file"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:235 ../raster/r.out.bin/main.c:318
+#: ../raster/r.in.bin/main.c:330
+msgid "Output byte order"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:240 ../raster3d/r3.out.ascii/main.c:106
+#: ../raster3d/r3.in.bin/main.c:354
+msgid "Switch the row order in output from north->south to south->north"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:245 ../raster3d/r3.out.ascii/main.c:110
+#: ../raster3d/r3.in.bin/main.c:359
+msgid "Switch the depth order in output from bottom->top to top->bottom"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:250
+msgid "Write data as integer"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:256 ../raster/r.out.bin/main.c:347
+msgid "Invalid value for null (integers only)"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:269
+msgid "Floating-point output requires bytes=4 or bytes=8"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:273
+msgid "Integer output doesn't support bytes=8 in this build"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:321 ../raster/r.out.bin/main.c:144
+#: ../raster/r.out.bin/main.c:228 ../raster/r.out.bin/main.c:414
+#, c-format
+msgid "Unable to create file <%s>"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:323 ../raster/r.out.bin/main.c:454
+msgid "Using the current region settings..."
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:324 ../raster/r.out.bin/main.c:455
+#, c-format
+msgid "north=%f"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:325 ../raster/r.out.bin/main.c:456
+#, c-format
+msgid "south=%f"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:326 ../raster/r.out.bin/main.c:457
+#, c-format
+msgid "east=%f"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:327 ../raster/r.out.bin/main.c:458
+#, c-format
+msgid "west=%f"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:328
+#, c-format
+msgid "top=%f"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:329
+#, c-format
+msgid "bottom=%f"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:330 ../raster/r.in.mat/main.c:398
+#: ../raster/r.out.mat/main.c:180
+#, c-format
+msgid "rows=%d"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:331 ../raster/r.in.mat/main.c:399
+#: ../raster/r.out.mat/main.c:181
+#, c-format
+msgid "cols=%d"
+msgstr ""
+#: ../raster3d/r3.out.bin/main.c:332
+#, c-format
+msgid "depths=%d"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:54
+msgid "Input 3D raster map with initial piezometric heads in [m]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:60
+msgid ""
+"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
+"active, 2 - dirichlet"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:65
+msgid ""
+"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
+"[m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:70
+msgid ""
+"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
+"[m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:75
+msgid ""
+"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
+"[m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:80
+msgid "Input 3D raster map with sources and sinks in [m^3/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:84
+msgid "Specific yield [1/m] input 3D raster map"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:89
+msgid "Recharge input 3D raster map in m^3/s"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:93
+msgid ""
+"Output 3D raster map storing the piezometric head result of the numerical "
+"calculation"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:99
+msgid ""
+"Output 3D raster map storing the groundwater filter velocity vector part in "
+"x direction [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:105
+msgid ""
+"y direction [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:111
+msgid ""
+"z direction [m/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:117
+msgid ""
+"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:127
+msgid "Use 3D raster mask (if exists)"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
+msgid ""
+"Use a full filled quadratic linear equation system, default is a sparse "
+"linear equation system."
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
+msgid "groundwater flow"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:162 ../raster/r.topmodel/main.c:52
+#: ../raster/r.fill.dir/main.c:87 ../raster/r.drain/main.c:110
+#: ../raster/r.water.outlet/main.c:68 ../raster/r.watershed/front/main.c:73
+#: ../raster/r.carve/main.c:75 ../raster/r.usler/main.c:53
+#: ../raster/r.flow/main.c:422 ../raster/r.stream.extract/main.c:77
+#: ../raster/r.solute.transport/main.c:230 ../raster/r.basins.fill/main.c:55
+#: ../raster/r.uslek/main.c:54 ../raster/r.topidx/main.c:40
+#: ../raster/r.lake/main.c:151 ../raster/r.sim/r.sim.sediment/main.c:110
+#: ../raster/r.sim/r.sim.water/main.c:110 ../raster/r.gwflow/main.c:210
+msgid "hydrology"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:163
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions."
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:180
+msgid ""
+"The cholesky solver does not work with sparse matrices.\n"
+"Consider to choose a full filled quadratic matrix with flag -f "
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:279 ../raster/r.gwflow/main.c:546
+msgid "Unable to create and solve the linear equation system"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:365
+#, c-format
+msgid "Unable to create 3D raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.gwflow/main.c:412 ../raster3d/r3.to.rast/main.c:55
+#: ../raster3d/r3.to.rast/main.c:383 ../raster3d/r3.cross.rast/main.c:55
+#: ../raster3d/r3.in.v5d/main.c:206 ../raster3d/r3.in.ascii/main.c:352
+#: ../raster3d/r3.out.ascii/main.c:63 ../raster3d/r3.out.ascii/main.c:367
+#: ../raster3d/r3.in.bin/main.c:471 ../raster3d/r3.out.v5d/main.c:55
+#: ../raster3d/r3.out.v5d/main.c:326 ../raster3d/r3.out.vtk/main.c:252
+#: ../raster3d/r3.out.vtk/main.c:338 ../raster3d/r3.out.netcdf/main.c:649
+msgid "Unable to close 3D raster map"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:80
+msgid "3D raster map(s) to be converted to 2D raster slices"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:86
+msgid "Basename for resultant raster slice maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:91 ../raster3d/r3.cross.rast/main.c:109
+#: ../raster3d/r3.out.ascii/main.c:118 ../raster3d/r3.out.netcdf/main.c:116
+#: ../raster/r.to.rast3elev/main.c:194
+msgid "Use 3D raster mask (if exists) with input map"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:96
+msgid ""
+"Use the same resolution as the input 3D raster map for the 2D output maps, "
+"independent of the current region settings"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:210
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:451
+msgid ""
+"The 2D and 3D region settings are different. Using the 2D window settings to "
+"adjust the 2D part of the 3D region."
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:297
+#, c-format
+msgid "Creating %i raster maps"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:303
+#, c-format
+msgid "Raster map %i Filename: %s"
+msgstr ""
+#: ../raster3d/r3.to.rast/main.c:308
+#, c-format
+msgid ""
+"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr ""
+#: ../raster3d/r3.stats/main.c:51
+msgid "Generates volume statistics for 3D raster maps."
+msgstr ""
+#: ../raster3d/r3.stats/main.c:62
+msgid "Number of subranges to collect stats from"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:67
+msgid "Calculate statistics based on equal value groups"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:71
+msgid "Only print cell counts"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:91
+msgid "The number of subranges has to be equal or greater than 1"
+msgstr ""
+#: ../raster3d/r3.stats/main.c:150
+msgid "Sort non-null values"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:90
+msgid "Input 3D raster map for cross section"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:97
+msgid "2D elevation map used to create the cross section map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:104
+msgid "Resulting cross section 2D raster map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:229 ../raster/r.profile/main.c:54
+#: ../display/d.profile/main.c:192
+msgid "profile"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:233
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:259
+msgid ""
+"The 2D and 3D region settings are different. Using the 3D raster map "
+"settings to adjust the 2D region."
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:302
+msgid "Output map already exists. Will be overwritten!"
+msgstr ""
+#: ../raster3d/r3.cross.rast/main.c:338
+msgid "Wrong 3D raster datatype! Cannot create raster map"
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:66
+msgid "Name of V5D raster file to be imported"
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:182
+msgid "Import 3-dimensional Vis5D files."
+msgstr ""
+#: ../raster3d/r3.in.v5d/main.c:201 ../raster3d/r3.in.ascii/main.c:346
+#: ../raster3d/r3.in.bin/main.c:463
+msgid "Unable to open 3D raster map"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:90
+msgid "String representing NULL value data cell (use 'none' if no such value)"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:180
+#, c-format
+msgid "Unsupported GRASS version %s"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:224
+#, c-format
+msgid "Loading data ...  (%dx%dx%d)"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:257
+msgid "End of file reached while still loading data."
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:269
+msgid "Invalid value detected"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:281
+#, c-format
+msgid ""
+"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:319
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
+msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:362
+msgid "Unable to close ASCII file"
+msgstr ""
+#: ../raster3d/r3.null/main.c:55
+msgid "3D raster map for which to modify null values"
+msgstr ""
+#: ../raster3d/r3.null/main.c:63 ../raster/r.null/main.c:72
+msgid "List of cell values to be set to NULL"
+msgstr ""
+#: ../raster3d/r3.null/main.c:70 ../raster/r.null/main.c:80
+msgid "The value to replace the null value by"
+msgstr ""
+#: ../raster3d/r3.null/main.c:85
+msgid "Illegal value for null"
+msgstr ""
+#: ../raster3d/r3.null/main.c:122
+msgid "modifyNull: error opening tmp file"
+msgstr ""
+#: ../raster3d/r3.null/main.c:156
+msgid "modifyNull: error flushing tiles in cube"
+msgstr ""
+#: ../raster3d/r3.null/main.c:161
+msgid "modifyNull: error flushing all tiles"
+msgstr ""
+#: ../raster3d/r3.null/main.c:171
+msgid "modifyNull: Unable to close tmp file"
+msgstr ""
+#: ../raster3d/r3.null/main.c:187 ../raster/r.null/main.c:60
+msgid "null data"
+msgstr ""
+#: ../raster3d/r3.null/main.c:190
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../raster3d/r3.support/main.c:52
+msgid ""
+"Allows creation and/or modification of 3D raster map layer support files."
+msgstr ""
+#: ../raster3d/r3.support/main.c:62 ../raster/r.support/main.c:67
+msgid "Text to use for map title"
+msgstr ""
+#: ../raster3d/r3.support/main.c:70 ../raster/r.support/main.c:75
+msgid "Text to append to the next line of the map's metadata file"
+msgstr ""
+#: ../raster3d/r3.support/main.c:76
+msgid "The map data unit"
+msgstr ""
+#: ../raster3d/r3.support/main.c:82
+msgid "The vertical unit of the map"
+msgstr ""
+#: ../raster3d/r3.support/main.c:89 ../raster/r.support/main.c:94
+msgid "Text to use for data source, line 1"
+msgstr ""
+#: ../raster3d/r3.support/main.c:96 ../raster/r.support/main.c:101
+msgid "Text to use for data source, line 2"
+msgstr ""
+#: ../raster3d/r3.support/main.c:104 ../raster/r.support/main.c:109
+msgid "Text to use for data description or keyword(s)"
+msgstr ""
+#: ../raster3d/r3.support/main.c:111 ../raster/r.support/main.c:116
+#: ../raster/r.category/main.c:80
+msgid "Raster map from which to copy category table"
+msgstr ""
+#: ../raster3d/r3.support/main.c:116 ../raster/r.support/main.c:121
+msgid "Text file from which to load history"
+msgstr ""
+#: ../raster3d/r3.support/main.c:121 ../raster/r.support/main.c:126
+msgid "Text file in which to save history"
+msgstr ""
+#: ../raster3d/r3.support/main.c:125
+msgid "Update range"
+msgstr ""
+#: ../raster3d/r3.support/main.c:248 ../raster/r.support/main.c:249
+#: ../raster/r.statistics/main.c:109 ../display/d.title/main.c:110
+#, c-format
+msgid "Unable to read category file of raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.support/main.c:252 ../raster/r.support/main.c:253
+#, c-format
+msgid "cats table for [%s] set to %s"
+msgstr ""
+#: ../raster3d/r3.support/check.c:20
+#, c-format
+msgid "Updating statistics for <%s>"
+msgstr ""
+#: ../raster3d/r3.support/check.c:36
+#, c-format
+msgid "Updating the number of categories for <%s>"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:82
+msgid "3D raster map to be converted to ASCII"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:86
+msgid "Name for ASCII output file"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:95
+msgid "Number of decimal places for floats"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:102 ../raster/r.out.ascii/main.c:95
+msgid "Suppress printing of header information"
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:114
+msgid "Print grass6 compatible format. Flags -d and -r are ignored."
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:308
+msgid "Converts a 3D raster map layer into a ASCII text file."
+msgstr ""
+#: ../raster3d/r3.out.ascii/main.c:371
+msgid "Unable to close new ASCII file"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:73
+msgid "Error reading binary data"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:154
+#, c-format
+msgid "Loading %s data with %i  bytes ...  (%dx%dx%d)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:202 ../raster3d/r3.neighbors/main.c:309
+msgid "Error flushing tiles"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:256
+msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:259
+msgid "Name of binary 3D raster file to be imported"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:275
+msgid "Byte order in binary file"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:283 ../raster/r.in.bin/main.c:338
+msgid "Northern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:284 ../raster3d/r3.in.bin/main.c:292
+#: ../raster3d/r3.in.bin/main.c:300 ../raster3d/r3.in.bin/main.c:308
+#: ../raster3d/r3.in.bin/main.c:316 ../raster3d/r3.in.bin/main.c:323
+#: ../raster3d/r3.in.bin/main.c:330 ../raster3d/r3.in.bin/main.c:337
+#: ../raster3d/r3.in.bin/main.c:344 ../general/g.region/main.c:150
+#: ../general/g.region/main.c:194 ../general/g.region/main.c:203
+#: ../general/g.region/main.c:212 ../general/g.region/main.c:221
+#: ../general/g.region/main.c:230 ../general/g.region/main.c:239
+#: ../general/g.region/main.c:315 ../general/g.region/main.c:326
+#: ../raster/r.region/main.c:104 ../raster/r.region/main.c:113
+#: ../raster/r.region/main.c:122 ../raster/r.region/main.c:131
+#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:339
+#: ../raster/r.in.bin/main.c:347 ../raster/r.in.bin/main.c:355
+#: ../raster/r.in.bin/main.c:363 ../raster/r.in.bin/main.c:370
+#: ../raster/r.in.bin/main.c:377
+msgid "Bounds"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:291 ../raster/r.in.bin/main.c:346
+msgid "Southern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:299 ../raster/r.in.bin/main.c:354
+msgid "Eastern limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:307 ../raster/r.in.bin/main.c:362
+msgid "Western limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:315
+msgid "Bottom limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:322
+msgid "Top limit of geographic region (outer edge)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:329 ../raster/r.in.bin/main.c:369
+msgid "Number of rows"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:336 ../raster/r.in.bin/main.c:376
+msgid "Number of columns"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:343
+msgid "Number of depths"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:350 ../raster/r.in.bin/main.c:383
+msgid "Set Value to NULL"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:365
+msgid "Binary data is of type integer"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:369 ../raster/r.in.bin/main.c:274
+msgid "Signed data (two's complement)"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:399
+#, c-format
+msgid "bytes=%d; must be 4 or 8 in case of floating point input"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:409
+msgid "Integer input doesn't support size=8 in this build"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:413
+msgid "bytes= must be 1, 2, 4 or 8"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:424 ../raster/r.in.bin/main.c:521
+#: ../display/d.grid/main.c:247
+#, c-format
+msgid "Illegal north coordinate <%s>"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:426 ../raster/r.in.bin/main.c:523
+#, c-format
+msgid "Illegal south coordinate <%s>"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:428 ../raster/r.in.bin/main.c:525
+#: ../display/d.grid/main.c:241
+#, c-format
+msgid "Illegal east coordinate <%s>"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:430 ../raster/r.in.bin/main.c:527
+#, c-format
+msgid "Illegal west coordinate <%s>"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:438 ../raster/r.in.bin/main.c:533
+#, c-format
+msgid "Unable to open <%s>"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:446
+#, c-format
+msgid "File Size %lld ... Total Bytes %lld"
+msgstr ""
+#: ../raster3d/r3.in.bin/main.c:448 ../raster/r.in.bin/main.c:577
+msgid "Bytes do not match file size"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:73
+msgid "3D raster map to be converted to Vis5D (V5D) file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:77
+msgid "Name for V5D output file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:147
+#, c-format
+msgid "Vis5D allows %d columns, %d columns found"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:150
+#, c-format
+msgid "Vis5D allows %d rows, %d rows found"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:257
+#, c-format
+msgid "Unable to create V5D file <%s>"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:262
+msgid "Failed writing V5D file"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:288
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:295
+msgid "Use map coordinates instead of xyz coordinates"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:75
+msgid "Unable to open 3D raster mask file"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:104
+msgid "makeMask: error flushing tiles in cube"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:109
+msgid "makeMask: error flushing all tiles"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:117
+msgid "Unable to close 3D raster mask file"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:119
+#, c-format
+msgid "Unable to close raster map <%s>"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:137
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../raster3d/r3.mask/main.c:145
+msgid "3D raster map with reference values"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:153
+msgid "List of cell values to be masked out"
+msgstr ""
+#: ../raster3d/r3.mask/main.c:159
+msgid "Cannot create mask file: RASTER3D_MASK already exists"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:117
+msgid "Specify top and bottom map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:124
+#, c-format
+msgid "Top cell map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:133
+#, c-format
+msgid "Bottom cell map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:152
+#, c-format
+msgid "3D raster map RGB map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:155
+msgid "Please provide three RGB 3D raster maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:165
+#, c-format
+msgid "3D vector map <%s> not found"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:168
+msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:175
+msgid ""
+"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
+"geometry."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:209
+msgid "No RGB Data will be created."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:294
+msgid "No vector data will be created."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:381
+msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:392
+msgid "failed to interpret dp as an integer"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:394 ../raster/r.out.ascii/main.c:116
+msgid "dp has to be from 0 to 20"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:542
+msgid "Unable to close 3D raster map, the VTK file may be incomplete"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:557
+msgid "Unable to close VTK-ASCII file"
+msgstr ""
+#: ../raster3d/r3.out.vtk/errorHandling.c:105
+msgid "Unable to close input raster maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:30
+msgid "3D raster map(s) to be converted to VTK-ASCII data format"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:36
+msgid "Name for VTK-ASCII output file"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:41
+msgid "Float value to represent no data cell/points"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:47
+msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:56
+msgid "Top surface 2D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:65
+msgid "Bottom surface 2D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:71
+msgid ""
+"Create 3D elevation output with a top and a bottom surface, both raster maps "
+"are required."
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:80
+msgid ""
+"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:88
+msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:112
+msgid "Use 3D raster mask (if exists) with input maps"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:117
+msgid "Scale factor affects the origin"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:123
+#: ../raster/r.out.vtk/parameters.c:128
+msgid "Correct the coordinates to match the VTK-OpenGL precision"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:129
+msgid ""
+"Do not convert the top-bottom resolution in case of lat long projection to "
+"meters"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:122
+msgid "write_vtk_points: Writing point coordinates"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:256
+msgid "write_vtk_unstructured_grid_cells: Writing the cells"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:335
+#, c-format
+msgid ""
+"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
+"ascii file"
+msgstr ""
+#: ../raster3d/r3.out.vtk/writeVTKData.c:441
+msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:94 ../raster/r.resamp.stats/main.c:296
+#: ../raster/r.series/main.c:102 ../raster/r.neighbors/main.c:102
+#, c-format
+msgid "Unknown method <%s>"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:119 ../raster/r.series/main.c:157
+msgid "Aggregate operation"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:127 ../raster/r.resamp.stats/main.c:277
+#: ../raster/r.series/main.c:164 ../raster/r.neighbors/main.c:239
+msgid "Quantile to calculate for method=quantile"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:137
+msgid ""
+"The size of the window in x, y and z direction, values must be odd integer "
+"numbers, eg: 3,3,3"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:213 ../raster/r.neighbors/main.c:171
+msgid "neighbor"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:214 ../raster/r.neighbors/main.c:172
+msgid "focal statistics"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:215 ../raster/r.mfilter/main.c:59
+#: ../raster/r.neighbors/main.c:173
+msgid "filter"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:218
+msgid ""
+"Makes each voxel value a function of the values assigned to the voxels "
+"around it, and stores new voxel values in an output 3D raster map"
+msgstr ""
+#: ../raster3d/r3.neighbors/main.c:287
+msgid "Unable to allocate buffer"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:81
+#, c-format
+msgid "Unable to close 3D raster map while catching error: %s"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:97
+msgid "Name for netCDF output file"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:106
+msgid "The value to be used for null values, default is the netCDF standard"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:111
+msgid "Export projection information as wkt and proj4 parameter"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:588
+msgid "netCDF"
+msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:590
+msgid "Export a 3D raster map as netCDF file."
+msgstr ""
+#: ../raster3d/r3.retile/main.c:49
+msgid "Unable to close the 3D raster map"
+msgstr ""
+#: ../raster3d/r3.retile/main.c:71
+msgid "Name of the retiled 3D raster map"
+msgstr ""
+#: ../raster3d/r3.retile/main.c:99
+msgid ""
+"Retiles an existing 3D raster map with user defined x, y and z tile size."
+msgstr ""
+#: ../raster3d/r3.retile/main.c:135
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
+msgstr ""
+#: ../raster3d/r3.retile/main.c:148
+msgid "Error closing 3D raster map"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:83
+msgid ""
+"Creates a display file from an existing 3D raster map according to specified "
+"threshold levels."
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:91
+msgid "Name of an existing 3D raster map"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:96
+msgid "Name for output display file"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:103
+msgid "List of thresholds for isosurfaces"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:109
+msgid "Minimum isosurface level"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:115
+msgid "Maximum isosurface level"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:121
+msgid "Positive increment between isosurface levels"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:128
+msgid "Number of isosurface threshold levels"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:132
+msgid "Suppress progress report & min/max information"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:136
+msgid "Use flat shading rather than gradient"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:144
+#, c-format
+msgid "Region from getWindow: %d %d %d"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:156
+#, c-format
+msgid "Not able to find grid3 file for [%s]"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:200
+#, c-format
+msgid "Unable to open display file <%s>"
+msgstr ""
+#: ../raster3d/r3.mkdspf/main.c:221
+#, c-format
+msgid "Writing %s from %s..."
+msgstr ""
+#: ../general/g.filename/main.c:41 ../general/g.findfile/main.c:40
+#: ../general/g.dirseps/main.c:36 ../general/g.message/main.c:35
+#: ../general/g.findetc/main.c:30 ../general/g.gisenv/main.c:46
+#: ../general/g.tempfile/main.c:40
+msgid "scripts"
+msgstr ""
+#: ../general/g.filename/main.c:42
+msgid "Prints GRASS data base file names."
+msgstr ""
+#: ../general/g.filename/main.c:50 ../general/g.findfile/main.c:53
+msgid "Name of an element"
+msgstr ""
+#: ../general/g.filename/main.c:56
+msgid "Name of a database file"
+msgstr ""
+#: ../general/g.filename/main.c:62
+msgid "Name of a mapset (default: current)"
+msgstr ""
+#: ../general/g.parser/rules.c:14
+#, c-format
+msgid "Unknown flag \"-%c\" in rule\n"
+msgstr ""
+#: ../general/g.parser/rules.c:26
+#, c-format
+msgid "Unknown option \"%s\" in rule\n"
+msgstr ""
+#: ../general/g.parser/rules.c:94
+#, c-format
+msgid "Unknown rule type \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/main.c:74
+msgid "Usage"
+msgstr ""
+#: ../general/g.parser/main.c:84
+msgid "Unable to open script file"
+msgstr ""
+#: ../general/g.parser/main.c:99
+#, c-format
+msgid "Line too long or missing newline at line %d\n"
+msgstr ""
+#: ../general/g.parser/main.c:139
+msgid "Error closing script file"
+msgstr ""
+#: ../general/g.parser/parse.c:22
+#, c-format
+msgid "Unknown boolean value \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:70
+#, c-format
+msgid "Unknown command \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:103
+#, c-format
+msgid "Unknown module parameter \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:140
+#, c-format
+msgid "Unknown flag parameter \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:155
+#, c-format
+msgid "Unknown type \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/parse.c:233
+#, c-format
+msgid "Unknown option parameter \"%s\" at line %d\n"
+msgstr ""
+#: ../general/g.parser/revoke.c:63
+msgid "G_spawn() failed"
+msgstr ""
+#: ../general/g.parser/revoke.c:71
+msgid "execl() failed"
+msgstr ""
+#: ../general/g.findfile/element.c:7
+msgid "List of available elements:"
+msgstr ""
+#: ../general/g.findfile/main.c:42
+msgid "Searches for GRASS data base files and sets variables for the shell."
+msgstr ""
+#: ../general/g.findfile/main.c:59
+msgid "Name of an existing map"
+msgstr ""
+#: ../general/g.findfile/main.c:65
+msgid "Name of a mapset (default: search path)"
+msgstr ""
+#: ../general/g.findfile/main.c:66
+msgid "'.' for current mapset"
+msgstr ""
+#: ../general/g.findfile/main.c:70
+msgid "Do not add quotes"
+msgstr ""
+#: ../general/g.findfile/main.c:74
+msgid "List available elements and exit"
+msgstr ""
+#: ../general/g.findfile/main.c:97
+#, c-format
+msgid ""
+"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
+"%s> does not correspond"
+msgstr ""
+#: ../general/g.dirseps/main.c:38
+msgid "Internal GRASS utility for converting directory separator characters."
+msgstr ""
+#: ../general/g.version/main.c:62 ../general/g.message/main.c:34
+#: ../general/g.tempfile/main.c:39
+msgid "support"
+msgstr ""
+#: ../general/g.version/main.c:63
+msgid "citing"
+msgstr ""
+#: ../general/g.version/main.c:64
+msgid "copyright"
+msgstr ""
+#: ../general/g.version/main.c:65
+msgid "version"
+msgstr ""
+#: ../general/g.version/main.c:66
+msgid "license"
+msgstr ""
+#: ../general/g.version/main.c:67
+msgid "Displays GRASS GIS version info."
+msgstr ""
+#: ../general/g.version/main.c:68
+msgid "Optionally also prints build or copyright information."
+msgstr ""
+#: ../general/g.version/main.c:72
+msgid "Print also the copyright message"
+msgstr ""
+#: ../general/g.version/main.c:73 ../general/g.version/main.c:78
+#: ../general/g.version/main.c:84 ../general/g.version/main.c:90
+msgid "Additional info"
+msgstr ""
+#: ../general/g.version/main.c:77
+msgid "Print also the build information"
+msgstr ""
+#: ../general/g.version/main.c:83
+msgid "Print also the GIS library revision number and date"
+msgstr ""
+#: ../general/g.version/main.c:88
+msgid "Print also extended info for additional libraries"
+msgstr ""
+#: ../general/g.version/main.c:89
+msgid "GDAL/OGR, PROJ.4, GEOS"
+msgstr ""
+#: ../general/g.version/main.c:94
+msgid "Print info in shell script style (including SVN revision number)"
+msgstr ""
+#: ../general/g.version/main.c:95
+msgid "Shell"
+msgstr ""
+#: ../general/g.version/main.c:157
+#, c-format
+msgid ""
+"Cannot determine GRASS libgis version and date number. The GRASS build might "
+"be broken. Report this to developers or packagers.\n"
+msgstr ""
+#: ../general/g.version/main.c:164
+msgid ""
+"GRASS GIS libgis version and date number don't have the expected format. "
+"Trying to print the original strings..."
+msgstr ""
+#: ../general/g.version/main.c:166
+#, c-format
+msgid "GIS_H_VERSION=\"%s\""
+msgstr ""
+#: ../general/g.version/main.c:167
+#, c-format
+msgid "GIS_H_DATE=\"%s\""
+msgstr ""
+#: ../general/g.version/main.c:197
+msgid "GRASS not compiled with GDAL/OGR support"
+msgstr ""
+#: ../general/g.version/main.c:208
+msgid "GRASS not compiled with GEOS support"
+msgstr ""
+#: ../general/g.version/main.c:219
+msgid "GRASS not compiled with SQLite support"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:34
+#, c-format
+msgid "Unable to open input file %s"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:37
+#, c-format
+msgid "Invalid input file %s"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
+#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
+msgid "Unable to allocate PNG structure"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:77
+msgid "Error writing PNG file"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:81
+#, c-format
+msgid "Unable to open output file %s"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:119
+msgid "Converts between PPM/PGM and PNG image formats."
+msgstr ""
+#: ../general/g.cairocomp/main.c:49
+#, c-format
+msgid "Unable to read input file <%s>"
+msgstr ""
+#: ../general/g.cairocomp/main.c:52
+#, c-format
+msgid "Unable to parse input file <%s>"
+msgstr ""
+#: ../general/g.cairocomp/main.c:71
+#, c-format
+msgid "Unable to write output file <%s>"
+msgstr ""
+#: ../general/g.cairocomp/main.c:113
+msgid "Unable to obtain visual"
+msgstr ""
+#: ../general/g.cairocomp/main.c:129
+msgid "Failed to initialize output surface"
+msgstr ""
+#: ../general/g.cairocomp/main.c:150 ../general/g.pnmcomp/main.c:38
+#, c-format
+msgid "Invalid color: %s"
+msgstr ""
+#: ../general/g.cairocomp/main.c:171
+msgid "Failed to initialize input surface"
+msgstr ""
+#: ../general/g.cairocomp/main.c:198
+msgid "Overlays multiple X Pixmaps."
+msgstr ""
+#: ../general/g.cairocomp/main.c:203 ../general/g.pnmcomp/main.c:290
+msgid "Name of input file(s)"
+msgstr ""
+#: ../general/g.cairocomp/main.c:212
+msgid "Output Visual XID"
+msgstr ""
+#: ../general/g.cairocomp/main.c:218
+msgid "Output screen"
+msgstr ""
+#: ../general/g.cairocomp/main.c:224 ../general/g.pnmcomp/main.c:302
+msgid "Layer opacities"
+msgstr ""
+#: ../general/g.cairocomp/main.c:230 ../general/g.pnmcomp/main.c:315
+msgid "Image width"
+msgstr ""
+#: ../general/g.cairocomp/main.c:236 ../general/g.pnmcomp/main.c:321
+msgid "Image height"
+msgstr ""
+#: ../general/g.cairocomp/main.c:240
+msgid "Background color (R:G:B:A)"
+msgstr ""
+#: ../general/g.cairocomp/main.c:245
+msgid "Do not composite; just delete input Pixmaps"
+msgstr ""
+#: ../general/g.cairocomp/main.c:277
+msgid "input= and opacity= must have the same number of values"
+msgstr ""
+#: ../general/g.message/main.c:37
+msgid ""
+"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgstr ""
+#: ../general/g.message/main.c:39
+msgid "This module should be used in scripts for messages served to user."
+msgstr ""
+#: ../general/g.message/main.c:43 ../general/g.message/main.c:48
+#: ../general/g.message/main.c:53 ../general/g.message/main.c:58
+#: ../general/g.gui/main.c:58
+msgid "Type"
+msgstr ""
+#: ../general/g.message/main.c:44
+msgid "Print message as warning"
+msgstr ""
+#: ../general/g.message/main.c:49
+msgid "Print message as fatal error"
+msgstr ""
+#: ../general/g.message/main.c:54
+msgid "Print message as debug message"
+msgstr ""
+#: ../general/g.message/main.c:59
+msgid "Print message as progress info"
+msgstr ""
+#: ../general/g.message/main.c:63 ../general/g.message/main.c:69
+#: ../general/g.message/main.c:85
+msgid "Level"
+msgstr ""
+#: ../general/g.message/main.c:64
+msgid "Print message in all modes except of quiet mode"
+msgstr ""
+#: ../general/g.message/main.c:65
+msgid "Message is printed on GRASS_VERBOSE>=1"
+msgstr ""
+#: ../general/g.message/main.c:70
+msgid "Print message only in verbose mode"
+msgstr ""
+#: ../general/g.message/main.c:71
+msgid "Message is printed only on GRASS_VERBOSE>=3"
+msgstr ""
+#: ../general/g.message/main.c:78
+msgid "Text of the message to be printed"
+msgstr ""
+#: ../general/g.message/main.c:79
+msgid "Message is printed on GRASS_VERBOSE>=2"
+msgstr ""
+#: ../general/g.message/main.c:88
+msgid "Level to use for debug messages"
+msgstr ""
+#: ../general/g.message/main.c:95
+msgid "Select only one message level"
+msgstr ""
+#: ../general/g.message/main.c:108
+msgid "Unable to parse input message"
+msgstr ""
+#: ../general/g.rename/main.c:49
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../general/g.rename/main.c:55
+msgid "renamed"
+msgstr ""
+#: ../general/g.rename/main.c:76
+#, c-format
+msgid "%s <%s> not found"
+msgstr ""
+#: ../general/g.rename/main.c:80
+#, c-format
+msgid "<%s> already exists in mapset <%s>"
+msgstr ""
+#: ../general/g.rename/main.c:85 ../general/g.copy/main.c:80
+#: ../raster/r.watershed/shed/com_line.c:231
+#: ../raster/r.watershed/shed/com_line.c:266
+#: ../imagery/i.landsat.toar/main.c:563 ../imagery/i.landsat.acca/main.c:187
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
+#, c-format
+msgid "<%s> is an illegal file name"
+msgstr ""
+#: ../general/g.rename/main.c:90
+#, c-format
+msgid "%s=%s,%s: files could be the same, no rename possible"
+msgstr ""
+#: ../general/g.rename/main.c:116
+msgid "Updating reclass maps"
+msgstr ""
+#: ../general/g.rename/main.c:184
+#, c-format
+msgid "Unable to find reclass information for <%s> in base map <%s@%s>"
+msgstr ""
+#: ../general/g.rename/main.c:188
+#, c-format
+msgid "Updating base map <%s@%s>"
+msgstr ""
+#: ../general/g.rename/main.c:194
+#, c-format
+msgid "Unable to update dependency file in <%s@%s>"
+msgstr ""
+#: ../general/g.mapsets/main.c:64 ../general/g.region/main.c:64
+#: ../general/g.mapset/main.c:50 ../general/g.gisenv/main.c:44
+#: ../display/d.font/main.c:46 ../display/d.fontlist/main.c:46
+#: ../display/d.colorlist/main.c:36
+msgid "settings"
+msgstr ""
+#: ../general/g.mapsets/main.c:65
+msgid "search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:66
+msgid "Modifies/prints the user's current mapset search path."
+msgstr ""
+#: ../general/g.mapsets/main.c:67
+msgid ""
+"Affects the user's access to data existing under the other mapsets in the "
+"current location."
+msgstr ""
+#: ../general/g.mapsets/main.c:73
+msgid "Name(s) of existing mapset(s) to add/remove or set"
+msgstr ""
+#: ../general/g.mapsets/main.c:85
+msgid "Field separator for printing (-l and -p flags)"
+msgstr ""
+#: ../general/g.mapsets/main.c:91
+msgid "List all available mapsets in alphabetical order"
+msgstr ""
+#: ../general/g.mapsets/main.c:97
+msgid "Print mapsets in current search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:103
+msgid "Launch mapset selection GUI dialog"
+msgstr ""
+#: ../general/g.mapsets/main.c:126
+#, c-format
+msgid "Unknown operation '%s'"
+msgstr ""
+#: ../general/g.mapsets/main.c:136 ../general/g.mapsets/main.c:138
+#: ../general/g.mapsets/main.c:148 ../display/d.mon/main.c:141
+#, c-format
+msgid "Flag -%c ignored"
+msgstr ""
+#: ../general/g.mapsets/main.c:140 ../general/g.mapsets/main.c:150
+#: ../general/g.mapsets/main.c:158 ../display/d.mon/main.c:183
+#, c-format
+msgid "Option <%s> ignored"
+msgstr ""
+#: ../general/g.mapsets/main.c:174 ../general/g.mapsets/main.c:208
+#, c-format
+msgid "Mapset <%s> not found"
+msgstr ""
+#: ../general/g.mapsets/main.c:181 ../general/g.mapsets/main.c:240
+#, c-format
+msgid "Current mapset (<%s>) must always included in the search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:203
+#, c-format
+msgid "Mapset <%s> already in the path"
+msgstr ""
+#: ../general/g.mapsets/main.c:210
+#, c-format
+msgid "Mapset <%s> added to search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:243
+#, c-format
+msgid "Mapset <%s> removed from search path"
+msgstr ""
+#: ../general/g.mapsets/main.c:255
+msgid "Search path not modified"
+msgstr ""
+#: ../general/g.mapsets/main.c:273
+msgid "Unable to open SEARCH_PATH for write"
+msgstr ""
+#: ../general/g.mapsets/list.c:10
+msgid "Available mapsets:"
+msgstr ""
+#: ../general/g.mapsets/list.c:35
+msgid "Accessible mapsets:"
+msgstr ""
+#: ../general/g.copy/main.c:44
+msgid ""
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
+msgstr ""
+#: ../general/g.copy/main.c:51
+msgid "copied"
+msgstr ""
+#: ../general/g.copy/main.c:66
+#, c-format
+msgid "<%s> not found"
+msgstr ""
+#: ../general/g.copy/main.c:71
+#, c-format
+msgid "%s=%s,%s: files are the same, no copy required"
+msgstr ""
+#: ../general/g.copy/main.c:76
+#, c-format
+msgid "<%s> already exists"
+msgstr ""
+#: ../general/g.proj/datumtrans.c:47
+#, c-format
+msgid "Invalid datum code <%s>"
+msgstr ""
+#: ../general/g.proj/datumtrans.c:77
+#, c-format
+msgid "Datum set to <%s>"
+msgstr ""
+#: ../general/g.proj/datumtrans.c:79
+#, c-format
+msgid "Ellipsoid set to <%s>"
+msgstr ""
+#: ../general/g.proj/main.c:65
+msgid "create location"
+msgstr ""
+#: ../general/g.proj/main.c:68
+msgid ""
+"Prints or modifies GRASS projection information files (in various co-"
+"ordinate system descriptions)."
+msgstr ""
+#: ../general/g.proj/main.c:71
+msgid "Can also be used to create new GRASS locations."
+msgstr ""
+#: ../general/g.proj/main.c:74
+msgid "Prints and manipulates GRASS projection information files."
+msgstr ""
+#: ../general/g.proj/main.c:81
+msgid "Print projection information in conventional GRASS format"
+msgstr ""
+#: ../general/g.proj/main.c:87
+msgid "Print projection information in shell script style"
+msgstr ""
+#: ../general/g.proj/main.c:93
+msgid "Verify datum information and print transformation parameters"
+msgstr ""
+#: ../general/g.proj/main.c:99
+msgid "Print projection information in PROJ.4 format"
+msgstr ""
+#: ../general/g.proj/main.c:105
+msgid ""
+"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr ""
+#: ../general/g.proj/main.c:115
+msgid "Print projection information in WKT format"
+msgstr ""
+#: ../general/g.proj/main.c:121
+msgid "Use ESRI-style format (applies to WKT output only)"
+msgstr ""
+#: ../general/g.proj/main.c:128 ../general/g.proj/main.c:137
+#: ../general/g.proj/main.c:147 ../general/g.proj/main.c:157
+msgid "Specification"
+msgstr ""
+#: ../general/g.proj/main.c:129
+msgid "Name of georeferenced data file to read projection information from"
+msgstr ""
+#: ../general/g.proj/main.c:138
+msgid "Name of ASCII file containing a WKT projection description"
+msgstr ""
+#: ../general/g.proj/main.c:148
+msgid "PROJ.4 projection description"
+msgstr ""
+#: ../general/g.proj/main.c:158
+msgid "EPSG projection code"
+msgstr ""
+#: ../general/g.proj/main.c:166 ../general/g.proj/main.c:179
+#: ../general/g.proj/main.c:185
+msgid "Datum"
+msgstr ""
+#: ../general/g.proj/main.c:168
+msgid "Datum (overrides any datum specified in input co-ordinate system)"
+msgstr ""
+#: ../general/g.proj/main.c:170
+msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
+msgstr ""
+#: ../general/g.proj/main.c:180
+msgid "Index number of datum transform parameters"
+msgstr ""
+#: ../general/g.proj/main.c:181
+msgid "\"0\" for unspecified or \"-1\" to list and exit"
+msgstr ""
+#: ../general/g.proj/main.c:187
+msgid ""
+"Force override of datum transformation information in input co-ordinate "
+"system"
+msgstr ""
+#: ../general/g.proj/main.c:192 ../raster/r.null/main.c:73
+#: ../raster/r.null/main.c:81
+msgid "Modify"
+msgstr ""
+#: ../general/g.proj/main.c:193
+msgid "Modify current location projection files"
+msgstr ""
+#: ../general/g.proj/main.c:201
+msgid "Name of new location to create"
+msgstr ""
+#: ../general/g.proj/main.c:217
+#, c-format
+msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
+msgstr ""
+#: ../general/g.proj/main.c:260
+msgid "Projection files missing"
+msgstr ""
+#: ../general/g.proj/main.c:280
+#, c-format
+msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
+msgstr ""
+#: ../general/g.proj/main.c:307
+#, c-format
+msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
+msgstr ""
+#: ../general/g.proj/main.c:311
+#, c-format
+msgid "No output format specified, define one of flags -%c, -%c, or -%c"
+msgstr ""
+#: ../general/g.proj/input.c:91
+msgid "Error reading WKT projection description"
+msgstr ""
+#: ../general/g.proj/input.c:98
+#, c-format
+msgid "Unable to open file '%s' for reading"
+msgstr ""
+#: ../general/g.proj/input.c:143
+msgid "Can't parse PROJ.4-style parameter string"
+msgstr ""
+#: ../general/g.proj/input.c:181
+msgid "Unable to translate EPSG code"
+msgstr ""
+#: ../general/g.proj/input.c:218
+msgid "Trying to open with OGR..."
+msgstr ""
+#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
+msgid "...succeeded."
+msgstr ""
+#: ../general/g.proj/input.c:239
+msgid "Trying to open with GDAL..."
+msgstr ""
+#: ../general/g.proj/input.c:254
+#, c-format
+msgid "Could not read georeferenced file %s using either OGR nor GDAL"
+msgstr ""
+#: ../general/g.proj/input.c:259
+#, c-format
+msgid ""
+"Read of file %s was successful, but it did not contain projection "
+"information. 'XY (unprojected)' will be used"
+msgstr ""
+#: ../general/g.proj/output.c:181
+#, c-format
+msgid "%s: Unable to convert to WKT"
+msgstr ""
+#: ../general/g.proj/create.c:17
+#, c-format
+msgid "Unable to create location <%s>: %s"
+msgstr ""
+#: ../general/g.proj/create.c:20
+#, c-format
+msgid "Unable to create projection files: %s"
+msgstr ""
+#: ../general/g.proj/create.c:24
+#, c-format
+msgid "Unable to create location <%s>"
+msgstr ""
+#: ../general/g.proj/create.c:30
+#, c-format
+msgid ""
+"You can switch to the new location by\n"
+"`%s=%s`"
+msgstr ""
+#: ../general/g.proj/create.c:40
+#, c-format
+msgid ""
+"You must select the PERMANENT mapset before updating the current location's "
+"projection (current mapset is <%s>)"
+msgstr ""
+#: ../general/g.proj/create.c:66
+msgid ""
+"Default region was updated to the new projection, but if you have multiple "
+"mapsets `g.region -d` should be run in each to update the region from the "
+"default"
+msgstr ""
+#: ../general/g.proj/create.c:70
+msgid "Projection information updated"
+msgstr ""
+#: ../general/g.proj/create.c:91
+#, c-format
+msgid "Unable to create PROJ_EPSG file: %s"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:54
+msgid "Error reading PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:69 ../general/g.pnmcomp/main.c:74
+#: ../general/g.pnmcomp/main.c:83 ../general/g.pnmcomp/main.c:134
+#: ../general/g.pnmcomp/main.c:147
+msgid "Invalid PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:96
+#, c-format
+msgid "File <%s> not found"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:104
+msgid "Expecting PPM but got PGM"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:109
+msgid "Expecting PGM but got PPM"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:112
+#, c-format
+msgid "Invalid magic number: 'P%c'"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:125 ../general/g.pnmcomp/main.c:142
+msgid "Invalid PGM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:247
+msgid "Error writing PPM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:264
+msgid "Error writing PGM file"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:285
+msgid "Overlays multiple PPM image files."
+msgstr ""
+#: ../general/g.pnmcomp/main.c:296
+msgid "Name of input mask file(s)"
+msgstr ""
+#: ../general/g.pnmcomp/main.c:309
+msgid "Name for output mask file"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:73
+msgid ""
+"Generates the font configuration file by scanning various directories for "
+"fonts."
+msgstr ""
+#: ../general/g.mkfontcap/main.c:79
+msgid "Overwrite font configuration file if already existing"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:84
+msgid ""
+"Write font configuration file to standard output instead of $GISBASE/etc"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:91
+msgid "List of extra directories to scan"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:93
+msgid ""
+"Comma-separated list of extra directories to scan for Freetype-compatible "
+"fonts as well as the defaults (see documentation)"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:110
+#, c-format
+msgid ""
+"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:122
+msgid ""
+"This GRASS installation was compiled without Freetype support, extradirs "
+"parameter ignored"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:149
+#, c-format
+msgid "Cannot open %s for writing: %s"
+msgstr ""
+#: ../general/g.remove/main.c:73
+msgid ""
+"Removes data base element files from the user's current mapset using the "
+"search pattern."
+msgstr ""
+#: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
+#: ../general/g.remove/main.c:133
+msgid "Basic"
+msgstr ""
+#: ../general/g.remove/main.c:90
+msgid "Name of file(s) to remove"
+msgstr ""
+#: ../general/g.remove/main.c:99
+msgid "Name of file(s) to ignore (default: none)"
+msgstr ""
+#: ../general/g.remove/main.c:100 ../general/g.remove/main.c:106
+#: ../general/g.remove/main.c:112 ../general/g.remove/main.c:117
+#: ../general/g.remove/main.c:123 ../general/g.remove/main.c:129
+#: ../general/g.list/main.c:110 ../general/g.list/main.c:118
+#: ../general/g.list/main.c:144 ../general/g.list/main.c:150
+#: ../general/g.list/main.c:156
+msgid "Pattern"
+msgstr ""
+#: ../general/g.remove/main.c:105
+msgid "File name search pattern"
+msgstr ""
+#: ../general/g.remove/main.c:111
+msgid "File name exclusion pattern (default: none)"
+msgstr ""
+#: ../general/g.remove/main.c:116 ../general/g.list/main.c:143
+msgid "Ignore case"
+msgstr ""
+#: ../general/g.remove/main.c:122 ../general/g.list/main.c:149
+msgid "Use basic regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.remove/main.c:128 ../general/g.list/main.c:155
+msgid "Use extended regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.remove/main.c:139
+msgid "Remove base raster maps"
+msgstr ""
+#: ../general/g.remove/main.c:178 ../general/g.remove/main.c:202
+#: ../general/g.list/main.c:220 ../general/g.list/main.c:247
+#, c-format
+msgid "Unable to compile pattern <%s>"
+msgstr ""
+#: ../general/g.remove/main.c:208
+msgid "The following data base element files would be deleted:"
+msgstr ""
+#: ../general/g.remove/main.c:261
+#, c-format
+msgid "You must use the force flag (-%c) to actually remove them. Exiting."
+msgstr ""
+#: ../general/g.remove/check_reclass.c:16
+#, c-format
+msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
+msgstr ""
+#: ../general/g.remove/check_reclass.c:19
+#, c-format
+msgid "Raster map <%s@%s> is a base map. Remove reclassed map <%s> first."
+msgstr ""
+#: ../general/g.remove/check_reclass.c:41
+#: ../general/g.remove/check_reclass.c:54
+#, c-format
+msgid "Removing information about reclassed map from <%s@%s> failed"
+msgstr ""
+#: ../general/g.remove/construct_pattern.c:37
+#, c-format
+msgid "%s: Cannot remove or exclude files not in the current mapset."
+msgstr ""
+#: ../general/g.remove/construct_pattern.c:57
+msgid "Illegal filenames not allowed in the name or ignore option."
+msgstr ""
+#: ../general/g.list/main.c:93
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
+msgstr ""
+#: ../general/g.list/main.c:109
+msgid "Map name search pattern (default: all)"
+msgstr ""
+#: ../general/g.list/main.c:117
+msgid "Map name exclusion pattern (default: none)"
+msgstr ""
+#: ../general/g.list/main.c:123
+msgid "Name of mapset to list (default: current search path)"
+msgstr ""
+#: ../general/g.list/main.c:125
+msgid "'.' for current mapset; '*' for all mapsets in location"
+msgstr ""
+#: ../general/g.list/main.c:131
+msgid "Name of saved region for map search (default: not restricted)"
+msgstr ""
+#: ../general/g.list/main.c:133
+msgid "'.' for current region; '*' for default region"
+msgstr ""
+#: ../general/g.list/main.c:160
+msgid "Print data types"
+msgstr ""
+#: ../general/g.list/main.c:165
+msgid "Print fully-qualified map names (including mapsets)"
+msgstr ""
+#: ../general/g.list/main.c:170
+msgid "Pretty printing in human readable format"
+msgstr ""
+#: ../general/g.list/main.c:175
+msgid "Verbose listing (also list map titles)"
+msgstr ""
+#: ../general/g.list/main.c:182
+#, c-format
+msgid "-%c/-%c and %s= are mutually exclusive"
+msgstr ""
+#: ../general/g.list/main.c:187
+#, c-format
+msgid "-%c/-%c and -%c/-%c are mutually exclusive"
+msgstr ""
+#: ../general/g.list/main.c:304
+#, c-format
+msgid "Mapset <%s> does not exist"
+msgstr ""
+#: ../general/g.list/main.c:514 ../general/g.region/main.c:447
+#, c-format
+msgid "Unable to read header of 3D raster map <%s@%s>"
+msgstr ""
+#: ../general/g.list/main.c:522
+#, c-format
+msgid "Unable to open vector map <%s@%s> on topological level"
+msgstr ""
+#: ../general/g.region/main.c:66
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../general/g.region/main.c:72 ../raster/r.region/main.c:65
+msgid "Set from default region"
+msgstr ""
+#: ../general/g.region/main.c:73 ../general/g.region/main.c:79
+#: ../general/g.region/main.c:161 ../general/g.region/main.c:168
+#: ../general/g.region/main.c:177 ../general/g.region/main.c:185
+#: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
+#: ../raster/r.region/main.c:81 ../raster/r.region/main.c:88
+#: ../raster/r.region/main.c:95 ../raster/r.region/main.c:138
+msgid "Existing"
+msgstr ""
+#: ../general/g.region/main.c:77
+msgid "Save as default region"
+msgstr ""
+#: ../general/g.region/main.c:78
+msgid "Only possible from the PERMANENT mapset"
+msgstr ""
+#: ../general/g.region/main.c:83
+msgid "Print the current region"
+msgstr ""
+#: ../general/g.region/main.c:88
+msgid "Print the current region in lat/long using the current ellipsoid/datum"
+msgstr ""
+#: ../general/g.region/main.c:94
+msgid "Print the current region extent"
+msgstr ""
+#: ../general/g.region/main.c:100
+msgid "Print the current region map center coordinates"
+msgstr ""
+#: ../general/g.region/main.c:106
+msgid "Print the current region in GMT style"
+msgstr ""
+#: ../general/g.region/main.c:112
+msgid "Print the current region in WMS style"
+msgstr ""
+#: ../general/g.region/main.c:118
+msgid "Print region resolution in meters (geodesic)"
+msgstr ""
+#: ../general/g.region/main.c:123
+msgid "Print the convergence angle (degrees CCW)"
+msgstr ""
+#: ../general/g.region/main.c:125
+msgid ""
+"The difference between the projection's grid north and true north, measured "
+"at the center coordinates of the current region."
+msgstr ""
+#: ../general/g.region/main.c:131
+msgid "Print also 3D settings"
+msgstr ""
+#: ../general/g.region/main.c:137
+msgid "Print the maximum bounding box in lat/long on WGS84"
+msgstr ""
+#: ../general/g.region/main.c:148
+msgid ""
+"Align region to resolution (default = align to bounds, works only for 2D "
+"resolution)"
+msgstr ""
+#: ../general/g.region/main.c:154
+msgid "Do not update the current region"
+msgstr ""
+#: ../general/g.region/main.c:160
+msgid "Set current region from named region"
+msgstr ""
+#: ../general/g.region/main.c:167
+msgid "Set region to match raster map(s)"
+msgstr ""
+#: ../general/g.region/main.c:175
+msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
+msgstr ""
+#: ../general/g.region/main.c:183
+msgid "Set region to match vector map(s)"
+msgstr ""
+#: ../general/g.region/main.c:193 ../raster/r.region/main.c:103
+msgid "Value for the northern edge"
+msgstr ""
+#: ../general/g.region/main.c:202 ../raster/r.region/main.c:112
+msgid "Value for the southern edge"
+msgstr ""
+#: ../general/g.region/main.c:211 ../raster/r.region/main.c:121
+msgid "Value for the eastern edge"
+msgstr ""
+#: ../general/g.region/main.c:220 ../raster/r.region/main.c:130
+msgid "Value for the western edge"
+msgstr ""
+#: ../general/g.region/main.c:229
+msgid "Value for the top edge"
+msgstr ""
+#: ../general/g.region/main.c:238
+msgid "Value for the bottom edge"
+msgstr ""
+#: ../general/g.region/main.c:247
+msgid "Number of rows in the new region"
+msgstr ""
+#: ../general/g.region/main.c:248 ../general/g.region/main.c:257
+#: ../general/g.region/main.c:267 ../general/g.region/main.c:277
+#: ../general/g.region/main.c:286 ../general/g.region/main.c:295
+#: ../general/g.region/main.c:304
+msgid "Resolution"
+msgstr ""
+#: ../general/g.region/main.c:256
+msgid "Number of columns in the new region"
+msgstr ""
+#: ../general/g.region/main.c:266
+msgid "2D grid resolution (north-south and east-west)"
+msgstr ""
+#: ../general/g.region/main.c:276
+msgid "3D grid resolution (north-south, east-west and top-bottom)"
+msgstr ""
+#: ../general/g.region/main.c:285
+msgid "North-south 2D grid resolution"
+msgstr ""
+#: ../general/g.region/main.c:294
+msgid "East-west 2D grid resolution"
+msgstr ""
+#: ../general/g.region/main.c:303
+msgid "Top-bottom 3D grid resolution"
+msgstr ""
+#: ../general/g.region/main.c:313
+msgid "Shrink region until it meets non-NULL data from this raster map"
+msgstr ""
+#: ../general/g.region/main.c:324
+msgid "Adjust region cells to cleanly align with this raster map"
+msgstr ""
+#: ../general/g.region/main.c:335
+msgid "Save current region settings in named region file"
+msgstr ""
+#: ../general/g.region/main.c:403
+#, c-format
+msgid "Region <%s> not found"
+msgstr ""
+#: ../general/g.region/main.c:760
+#, c-format
+msgid "Unable to set region <%s>"
+msgstr ""
+#: ../general/g.region/main.c:766
+msgid "Unable to update current region"
+msgstr ""
+#: ../general/g.region/main.c:774
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
+msgstr ""
+#: ../general/g.region/main.c:791 ../raster/r.in.lidar/main.c:612
+#, c-format
+msgid "Invalid input <%s=%s>"
+msgstr ""
+#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
+#: ../general/g.region/printwindow.c:622 ../raster/r.horizon/main.c:525
+#: ../raster/r.sun/main.c:728 ../display/d.where/main.c:107
+msgid "Can't get projection info of current location"
+msgstr ""
+#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
+#: ../general/g.region/printwindow.c:625 ../raster/r.horizon/main.c:528
+#: ../raster/r.sun/main.c:732 ../display/d.where/main.c:110
+msgid "Can't get projection units of current location"
+msgstr ""
+#: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:516
+#: ../general/g.region/printwindow.c:647 ../raster/r.sunhours/main.c:230
+msgid "Unable to update lat/long projection parameters"
+msgstr ""
+#: ../general/g.region/printwindow.c:281 ../general/g.region/printwindow.c:289
+#: ../general/g.region/printwindow.c:297 ../general/g.region/printwindow.c:305
+#: ../general/g.region/printwindow.c:534 ../general/g.region/printwindow.c:542
+#: ../general/g.region/printwindow.c:550 ../general/g.region/printwindow.c:558
+#: ../general/g.region/printwindow.c:676 ../general/g.region/printwindow.c:684
+#: ../general/g.region/printwindow.c:692 ../general/g.region/printwindow.c:700
+#: ../raster/r.sunhours/main.c:294 ../raster/r.sunhours/main.c:389
+#: ../raster/r.sunmask/g_solposition.c:127
+msgid "Error in pj_do_proj (projection of input coordinate pair)"
+msgstr ""
+#: ../general/g.region/printwindow.c:410
+msgid "You are already in Lat/Long. Use the -p flag instead."
+msgstr ""
+#: ../general/g.region/printwindow.c:412
+msgid ""
+"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
+"the -p flag instead."
+msgstr ""
+#: ../general/g.region/printwindow.c:637
+msgid ""
+"WGS84 output not possible as this location does not contain datum "
+"transformation parameters. Try running g.setproj."
+msgstr ""
+#: ../general/g.region/printwindow.c:783
+msgid "Lat/Long calculations are not possible from a simple XY system"
+msgstr ""
+#: ../general/g.mapset/main.c:51
+msgid "Changes/reports current mapset."
+msgstr ""
+#: ../general/g.mapset/main.c:52
+msgid ""
+"Optionally create new mapset or list available mapsets in given location."
+msgstr ""
+#: ../general/g.mapset/main.c:56
+msgid "Name of mapset where to switch"
+msgstr ""
+#: ../general/g.mapset/main.c:57 ../general/g.mapset/main.c:61
+#: ../general/g.mapset/main.c:64
+msgid "Mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:68
+msgid "Create mapset if it doesn't exist"
+msgstr ""
+#: ../general/g.mapset/main.c:75
+msgid "List available mapsets and exit"
+msgstr ""
+#: ../general/g.mapset/main.c:81
+msgid "Print current mapset and exit"
+msgstr ""
+#: ../general/g.mapset/main.c:136
+#, c-format
+msgid "<%s> is already the current mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:145
+#, c-format
+msgid "You don't have permission to use the mapset <%s>"
+msgstr ""
+#: ../general/g.mapset/main.c:153
+#, c-format
+msgid "Unable to create new mapset <%s>"
+msgstr ""
+#: ../general/g.mapset/main.c:156
+#, c-format
+msgid "Mapset <%s> does not exist. Use -c flag to create it."
+msgstr ""
+#: ../general/g.mapset/main.c:166
+msgid "Unable to read GIS_LOCK environment variable"
+msgstr ""
+#: ../general/g.mapset/main.c:182
+#, c-format
+msgid "Lock file of mapset <%s> cannot be checked"
+msgstr ""
+#: ../general/g.mapset/main.c:185
+#, c-format
+msgid "There appears to be an active GRASS session in selected mapset <%s>"
+msgstr ""
+#: ../general/g.mapset/main.c:191
+msgid "Cleaning up temporary files..."
+msgstr ""
+#: ../general/g.mapset/main.c:205
+msgid ""
+"Mapset switched. Your shell continues to use the history for the old mapset"
+msgstr ""
+#: ../general/g.mapset/main.c:210
+#, c-format
+msgid ""
+"You can switch the history by commands:\n"
+"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
+msgstr ""
+#: ../general/g.mapset/main.c:215
+#, c-format
+msgid ""
+"history -S; history -L %s/.history; setenv histfile=%s/.history"
+msgstr ""
+#: ../general/g.mapset/main.c:221
+#, c-format
+msgid "Your current mapset is <%s>"
+msgstr ""
+#: ../general/g.gisenv/main.c:45
+msgid "variables"
+msgstr ""
+#: ../general/g.gisenv/main.c:48
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../general/g.gisenv/main.c:49
+msgid "Prints all defined GRASS variables if no option is given."
+msgstr ""
+#: ../general/g.gisenv/main.c:54
+msgid "GRASS variable to get"
+msgstr ""
+#: ../general/g.gisenv/main.c:57
+msgid "Get"
+msgstr ""
+#: ../general/g.gisenv/main.c:63
+msgid "GRASS variable to set"
+msgstr ""
+#: ../general/g.gisenv/main.c:71
+msgid "GRASS variable to unset"
+msgstr ""
+#: ../general/g.gisenv/main.c:82
+msgid "Where GRASS variable is stored"
+msgstr ""
+#: ../general/g.gisenv/main.c:87
+msgid "Separator for multiple GRASS variables"
+msgstr ""
+#: ../general/g.gisenv/main.c:92
+msgid "Use shell syntax (for \"eval\")"
+msgstr ""
+#: ../general/g.gisenv/main.c:97
+msgid "Do not use shell syntax"
+msgstr ""
+#: ../general/g.gisenv/main.c:171
+#, c-format
+msgid "Variable <%s> is mandatory. No operation performed."
+msgstr ""
+#: ../general/g.gisenv/main.c:177
+#, c-format
+msgid "Value '%s' ignored when unsetting the GRASS variable"
+msgstr ""
+#: ../general/g.gisenv/main.c:216
+msgid "GRASS variable not defined"
+msgstr ""
+#: ../general/g.gisenv/main.c:222
+#, c-format
+msgid "GRASS variable must be uppercase. Using '%s'."
+msgstr ""
+#: ../general/g.tempfile/main.c:41
+msgid "Creates a temporary file and prints it's file name."
+msgstr ""
+#: ../general/g.tempfile/main.c:47
+msgid "Process id to use when naming the tempfile"
+msgstr ""
+#: ../general/g.tempfile/main.c:51
+msgid "Dry run - don't create a file, just prints it's file name"
+msgstr ""
+#: ../general/g.gui/main.c:38
+msgid "GUI"
+msgstr ""
+#: ../general/g.gui/main.c:39
+msgid "user interface"
+msgstr ""
+#: ../general/g.gui/main.c:42
+msgid "Launches a GRASS graphical user interface (GUI) session."
+msgstr ""
+#: ../general/g.gui/main.c:43
+msgid "Optionally updates default user interface settings."
+msgstr ""
+#: ../general/g.gui/main.c:48
+msgid "User interface"
+msgstr ""
+#: ../general/g.gui/main.c:52
+msgid "wxPython based GUI (wxGUI)"
+msgstr ""
+#: ../general/g.gui/main.c:53
+msgid "command line interface only"
+msgstr ""
+#: ../general/g.gui/main.c:54
+msgid "command line interface with GUI startup screen"
+msgstr ""
+#: ../general/g.gui/main.c:64
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+msgstr ""
+#: ../general/g.gui/main.c:68
+msgid "Update default user interface settings"
+msgstr ""
+#: ../general/g.gui/main.c:69 ../general/g.gui/main.c:75
+msgid "Default"
+msgstr ""
+#: ../general/g.gui/main.c:74
+msgid "Do not launch GUI after updating the default user interface settings"
+msgstr ""
+#: ../general/g.gui/main.c:85
+#, c-format
+msgid "<%s> is now the default GUI"
+msgstr ""
+#: ../general/g.gui/main.c:91
+#, c-format
+msgid "Nothing to do. For setting up <%s> as default UI use -%c flag."
+msgstr ""
+#: ../general/g.gui/main.c:96
+#, c-format
+msgid "Launching <%s> GUI in the background, please wait..."
+msgstr ""
+#: ../general/g.access/set_perms.c:26
+msgid "Unable to change mapset permissions"
+msgstr ""
+#: ../general/g.access/main.c:39
+msgid "permission"
+msgstr ""
+#: ../general/g.access/main.c:41
+msgid "Controls access to the current mapset for other users on the system."
+msgstr ""
+#: ../general/g.access/main.c:42
+msgid "If no option given, prints current status."
+msgstr ""
+#: ../general/g.access/main.c:49
+msgid "Access for group"
+msgstr ""
+#: ../general/g.access/main.c:57
+msgid "Access for others"
+msgstr ""
+#: ../general/g.access/main.c:64
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
+msgstr ""
+#: ../general/g.access/main.c:72
+msgid "Access to the PERMANENT mapset must be open, nothing changed"
+msgstr ""
+#: ../general/g.access/main.c:76
+msgid "Unable to determine mapset permissions"
+msgstr ""
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+msgid "read "
+msgstr ""
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
+#: ../general/g.setproj/proj.c:168
+#, c-format
+msgid "Unrecognized 'ask' value in parms.table: %s"
+msgstr ""
+#: ../general/g.setproj/proj.c:178
+#, c-format
+msgid "Unrecognized default value in parms.table: %s"
+msgstr ""
+#: ../general/g.setproj/main.c:81
+msgid "Interactively reset the location's projection settings."
+msgstr ""
+#: ../general/g.setproj/main.c:88
+msgid "You must be in the PERMANENT mapset to run g.setproj"
+msgstr ""
+#: ../general/g.setproj/main.c:101
+msgid "PERMANENT: permission denied"
+msgstr ""
+#: ../general/g.setproj/main.c:105
+msgid "Current region cannot be set"
+msgstr ""
+#: ../general/g.setproj/main.c:108
+msgid "Retrieving and setting region failed"
+msgstr ""
+#: ../general/g.setproj/main.c:135
+msgid "Would you still like to change some of the parameters?"
+msgstr ""
+#: ../general/g.setproj/main.c:137
+msgid "The projection information will not be updated"
+msgstr ""
+#: ../general/g.setproj/main.c:148
+#, c-format
+msgid ""
+"Zone in default geographic region definition: %d\n"
+" is different from zone in PROJ_INFO file: %d"
+msgstr ""
+#: ../general/g.setproj/main.c:158
+msgid "XY-location cannot be projected"
+msgstr ""
+#: ../general/g.setproj/main.c:192
+msgid "Unknown projection"
+msgstr ""
+#: ../general/g.setproj/main.c:198
+#, c-format
+msgid "Projection %s is not specified in the file 'proj-parms.table'"
+msgstr ""
+#: ../general/g.setproj/main.c:205
+msgid "Do you wish to specify a geodetic datum for this location?"
+msgstr ""
+#: ../general/g.setproj/main.c:214
+#, c-format
+msgid "The current datum is %s (%s)"
+msgstr ""
+#: ../general/g.setproj/main.c:217
+msgid "Do you wish to change the datum (or datum transformation parameters)?"
+msgstr ""
+#: ../general/g.setproj/main.c:225
+msgid "The datum information has not been changed"
+msgstr ""
+#: ../general/g.setproj/main.c:288
+#, c-format
+msgid "The current ellipsoid is %s"
+msgstr ""
+#: ../general/g.setproj/main.c:290
+msgid "Do you want to change ellipsoid parameter?"
+msgstr ""
+#: ../general/g.setproj/main.c:294
+msgid "The ellipse information has not been changed"
+msgstr ""
+#: ../general/g.setproj/main.c:311
+#, c-format
+msgid "The radius is currently %f"
+msgstr ""
+#: ../general/g.setproj/main.c:312
+msgid "Do you want to change the radius?"
+msgstr ""
+#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
+msgid "Enter radius for the sphere in meters"
+msgstr ""
+#: ../general/g.setproj/main.c:336
+msgid "Invalid input ellipsoid"
+msgstr ""
+#: ../general/g.setproj/main.c:447
+#, c-format
+msgid "The UTM zone is now set to %d"
+msgstr ""
+#: ../general/g.setproj/main.c:450
+msgid "Do you want to change the UTM zone?"
+msgstr ""
+#: ../general/g.setproj/main.c:451
+msgid "UTM zone information has not been updated"
+msgstr ""
+#: ../general/g.setproj/main.c:456
+msgid ""
+"But if you change zone, all the existing data will be interpreted by "
+"projection software. GRASS will not automatically re-project or even change "
+"the headers for existing maps."
+msgstr ""
+#: ../general/g.setproj/main.c:461
+msgid "Would you still like to change the UTM zone?"
+msgstr ""
+#: ../general/g.setproj/main.c:497
+#, c-format
+msgid "Error writing PROJ_INFO file <%s>"
+msgstr ""
+#: ../general/g.setproj/main.c:571
+#, c-format
+msgid "Enter plural form of units [meters]: "
+msgstr ""
+#: ../general/g.setproj/main.c:603
+#, c-format
+msgid "Enter singular for unit: "
+msgstr ""
+#: ../general/g.setproj/main.c:611
+#, c-format
+msgid "Enter conversion factor from %s to meters: "
+msgstr ""
+#: ../general/g.setproj/main.c:636
+#, c-format
+msgid "Error writing into UNITS output file <%s>"
+msgstr ""
+#: ../general/g.setproj/main.c:643
+msgid "Unable to write to DEFAULT_WIND region file"
+msgstr ""
+#: ../general/g.setproj/main.c:645
+#, c-format
+msgid ""
+"\n"
+"Projection information has been recorded for this location\n"
+"\n"
+msgstr ""
+#: ../general/g.setproj/main.c:647
+msgid "The geographic region information in WIND is now obsolete"
+msgstr ""
+#: ../general/g.setproj/main.c:648
+msgid "Run g.region -d to update it"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:43
+msgid "This should not happen. See your system admin."
+msgstr ""
+#: ../general/g.setproj/get_stp.c:99
+msgid "Unable to open FIPS code file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:125
+#, c-format
+msgid "No match of FIPS state %d county %d"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:179
+msgid "Reading sf key_value temp file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:212
+msgid "Invalid State FIPS code"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:302
+msgid "Reading cf key_value temp file"
+msgstr ""
+#: ../general/g.setproj/get_stp.c:336
+msgid "Invalid County FIPS code"
+msgstr ""
+#: ../doc/vector/v.example/main.c:51 ../doc/raster/r.example/main.c:84
+msgid "keyword2"
+msgstr ""
+#: ../doc/vector/v.example/main.c:52 ../doc/raster/r.example/main.c:85
+msgid "keyword3"
+msgstr ""
+#: ../doc/vector/v.example/main.c:53
+msgid "My first vector module"
+msgstr ""
+#: ../doc/vector/v.example/main.c:81
+msgid "Unable to set predetermined vector open level"
+msgstr ""
+#: ../doc/vector/v.example/main.c:170
+#, c-format
+msgid "Unable to get attribute data for cat %d"
+msgstr ""
+#: ../doc/vector/v.example/main.c:179
+#, c-format
+msgid "Error while retrieving database record for cat %d"
+msgstr ""
+#: ../doc/vector/v.example/main.c:212
+#, c-format
+msgid "Unable to copy attribute table to vector map <%s>"
+msgstr ""
+#: ../doc/raster/r.example/main.c:86
+msgid "My first raster module"
+msgstr ""
+#: ../raster/r.out.gridatb/main.c:70
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
+msgstr ""
+#: ../raster/r.buffer/write_map.c:45 ../raster/r.flow/io.c:207
+#: ../raster/r.cost/main.c:1034
+#, c-format
+msgid "Writing output raster map <%s>..."
+msgstr ""
+#: ../raster/r.buffer/read_map.c:52 ../raster/r.flow/io.c:89
+#: ../raster/r.flow/io.c:107
+#, c-format
+msgid "Reading input raster map <%s>..."
+msgstr ""
+#: ../raster/r.buffer/main.c:131
+msgid "Parse distances error"
+msgstr ""
+#: ../raster/r.buffer/main.c:150
+#, c-format
+msgid "Pass %d (of %d)"
+msgstr ""
+#: ../raster/r.buffer/parse_dist.c:54
+#, c-format
+msgid "%s: %s - illegal distance specification"
+msgstr ""
+#: ../raster/r.buffer/execute.c:34
+msgid "Finding buffer zones..."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:152 ../raster/r.relief/main.c:110
+#: ../imagery/i.topo.corr/main.c:48
+msgid "terrain"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:153
+msgid "aspect"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:154
+msgid "slope"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:155
+msgid "curvature"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:156
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from an elevation raster map."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:158
+msgid "Aspect is calculated counterclockwise from east."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:180
+msgid "Format for reporting the slope"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:188
+msgid "Type of output aspect and slope maps"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:210
+msgid ""
+"Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:217
+msgid ""
+"Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:224
+msgid "Name for output second order partial derivative dxx raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:231
+msgid "Name for output second order partial derivative dyy raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:238
+msgid "Name for output second order partial derivative dxy raster map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:244
+msgid "Multiplicative factor to convert elevation units to horizontal units"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:253
+msgid "Minimum slope value (in percent) for which aspect is computed"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:262
+msgid "Do not align the current region to the raster elevation map"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:316 ../raster/r.relief/main.c:220
+#, c-format
+msgid "%s=%s - must be a positive number"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:322 ../raster/r.relief/main.c:201
+#: ../raster/r.relief/main.c:207
+#, c-format
+msgid "%s=%s - must be a non-negative number"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:337
+#, c-format
+msgid ""
+"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
+"%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:359
+#, c-format
+msgid "Wrong raster type: %s"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:388
+msgid ""
+"r.slope.aspect does not convert horizontal units to meters in this version, "
+"see manual page."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:545
+#: ../raster/r.series.accumulate/main.c:318
+#: ../raster/r.series.interp/main.c:339 ../raster/r.relief/main.c:316
+#: ../raster/r.series/main.c:343 ../raster/r.patch/main.c:124
+msgid "Percent complete..."
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:969
+#, c-format
+msgid "Elevation products for mapset <%s> in <%s>"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:988
+#, c-format
+msgid "Min computed aspect %.4f, max computed aspect %.4f"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1052
+#, c-format
+msgid "Aspect raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1109
+#, c-format
+msgid "Min computed slope %.4f, max computed slope %.4f"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1162
+#, c-format
+msgid "Slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1234
+#, c-format
+msgid "Profile curve raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1261
+#, c-format
+msgid "Tangential curve raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1286
+#, c-format
+msgid "E-W slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1311
+#, c-format
+msgid "N-S slope raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1336
+#, c-format
+msgid "Dxx raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1361
+#, c-format
+msgid "Dyy raster map <%s> complete"
+msgstr ""
+#: ../raster/r.slope.aspect/main.c:1386
+#, c-format
+msgid "Dxy raster map <%s> complete"
+msgstr ""
+#: ../raster/r.param.scale/main.c:42
+msgid "Lat/Long locations are not supported by this module"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:55
+msgid "geomorphology"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:56
+msgid "Extracts terrain parameters from a DEM."
+msgstr ""
+#: ../raster/r.param.scale/interface.c:57
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
+msgstr ""
+#: ../raster/r.param.scale/interface.c:75
+msgid "Name for output raster map containing morphometric parameter"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:79
+msgid "Slope tolerance that defines a 'flat' surface (degrees)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:86
+msgid "Curvature tolerance that defines 'planar' surface"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:93
+msgid "Size of processing window (odd number only)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:101
+msgid "Morphometric parameter in 'size' window to calculate"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:109
+msgid "Exponent for distance weighting (0.0-4.0)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:115 ../raster/r.out.pov/main.c:150
+msgid "Vertical scaling factor"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:121
+msgid "Constrain model through central window cell"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:164
+msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:172
+msgid "Inappropriate window size (too big or even)"
+msgstr ""
+#: ../raster/r.param.scale/process.c:75
+msgid "E-W and N-S grid resolutions are different. Taking average."
+msgstr ""
+#: ../raster/r.in.png/main.c:297
+#, c-format
+msgid "Unable to open PNG file '%s'"
+msgstr ""
+#: ../raster/r.in.png/main.c:300
+msgid "Input file empty or too short"
+msgstr ""
+#: ../raster/r.in.png/main.c:303
+msgid "Input file not a PNG file"
+msgstr ""
+#: ../raster/r.in.png/main.c:314
+msgid "PNG error"
+msgstr ""
+#: ../raster/r.in.png/main.c:485 ../raster/r.cross/main.c:169
+#: ../raster/r.resample/main.c:125 ../raster/r.basins.fill/main.c:146
+#, c-format
+msgid "Creating support files for <%s>..."
+msgstr ""
+#: ../raster/r.in.png/main.c:522
+msgid "Imports non-georeferenced PNG format image."
+msgstr ""
+#: ../raster/r.in.png/main.c:532
+msgid "Title for created raster map"
+msgstr ""
+#: ../raster/r.in.png/main.c:538
+msgid "Display gamma"
+msgstr ""
+#: ../raster/r.in.png/main.c:544
+msgid "Alpha threshold"
+msgstr ""
+#: ../raster/r.in.png/main.c:548
+msgid "Create floating-point map (0.0 - 1.0)"
+msgstr ""
+#: ../raster/r.in.png/main.c:552
+msgid "Output image file header only and exit"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:994 ../raster/r.sunmask/solpos00.c:949
+#, c-format
+msgid "S_decode ==> Please fix the year: %d [1950-2050]"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:997 ../raster/r.sunmask/solpos00.c:952
+#, c-format
+msgid "S_decode ==> Please fix the month: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:999 ../raster/r.sunmask/solpos00.c:954
+#, c-format
+msgid "S_decode ==> Please fix the day-of-month: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1002 ../raster/r.sunmask/solpos00.c:957
+#, c-format
+msgid "S_decode ==> Please fix the day-of-year: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1005 ../raster/r.sunmask/solpos00.c:960
+#, c-format
+msgid "S_decode ==> Please fix the hour: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1007 ../raster/r.sunmask/solpos00.c:962
+#, c-format
+msgid "S_decode ==> Please fix the minute: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1009 ../raster/r.sunmask/solpos00.c:964
+#, c-format
+msgid "S_decode ==> Please fix the second: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1011 ../raster/r.sunmask/solpos00.c:966
+#, c-format
+msgid "S_decode ==> Please fix the time zone: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1014 ../raster/r.sunmask/solpos00.c:969
+#, c-format
+msgid "S_decode ==> Please fix the interval: %d"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1017 ../raster/r.sunmask/solpos00.c:972
+#, c-format
+msgid "S_decode ==> Please fix the latitude: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1020 ../raster/r.sunmask/solpos00.c:975
+#, c-format
+msgid "S_decode ==> Please fix the longitude: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1023 ../raster/r.sunmask/solpos00.c:978
+#, c-format
+msgid "S_decode ==> Please fix the temperature: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1026 ../raster/r.sunmask/solpos00.c:981
+#, c-format
+msgid "S_decode ==> Please fix the pressure: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1028 ../raster/r.sunmask/solpos00.c:983
+#, c-format
+msgid "S_decode ==> Please fix the tilt: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1030 ../raster/r.sunmask/solpos00.c:985
+#, c-format
+msgid "S_decode ==> Please fix the aspect: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1032 ../raster/r.sunmask/solpos00.c:987
+#, c-format
+msgid "S_decode ==> Please fix the shadowband width: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1035 ../raster/r.sunmask/solpos00.c:990
+#, c-format
+msgid "S_decode ==> Please fix the shadowband radius: %f"
+msgstr ""
+#: ../raster/r.sunhours/solpos00.c:1038 ../raster/r.sunmask/solpos00.c:993
+#, c-format
+msgid "S_decode ==> Please fix the shadowband sky factor: %f"
+msgstr ""
+#: ../raster/r.sunhours/main.c:73 ../raster/r.sunmask/main.c:117
+#: ../raster/r.horizon/main.c:181 ../raster/r.sun/main.c:240
+msgid "solar"
+msgstr ""
+#: ../raster/r.sunhours/main.c:74
+msgid "Calculates solar elevation, solar azimuth, and sun hours."
+msgstr ""
+#: ../raster/r.sunhours/main.c:75
+msgid ""
+"Solar elevation: the angle between the direction of the geometric center of "
+"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
+"angle from due north in clockwise direction."
+msgstr ""
+#: ../raster/r.sunhours/main.c:81
+msgid "Output raster map with solar elevation angle"
+msgstr ""
+#: ../raster/r.sunhours/main.c:86
+msgid "Output raster map with solar azimuth angle"
+msgstr ""
+#: ../raster/r.sunhours/main.c:91
+msgid "Output raster map with sunshine hours"
+msgstr ""
+#: ../raster/r.sunhours/main.c:92
+msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
+msgstr ""
+#: ../raster/r.sunhours/main.c:99
+msgid "Year"
+msgstr ""
+#: ../raster/r.sunhours/main.c:101 ../raster/r.sunhours/main.c:110
+#: ../raster/r.sunhours/main.c:118 ../raster/r.sunhours/main.c:127
+#: ../raster/r.sunhours/main.c:136 ../raster/r.sunhours/main.c:145
+#: ../raster/r.sunmask/main.c:153 ../raster/r.sunmask/main.c:161
+#: ../raster/r.sunmask/main.c:169 ../raster/r.sunmask/main.c:177
+#: ../raster/r.sunmask/main.c:185 ../raster/r.sunmask/main.c:194
+#: ../raster/r.sunmask/main.c:203 ../raster/r.sun/main.c:444
+#: ../raster/r.sun/main.c:453 ../raster/r.sun/main.c:470
+#: ../raster/r.sun/main.c:508 ../imagery/i.landsat.toar/main.c:206
+msgid "Time"
+msgstr ""
+#: ../raster/r.sunhours/main.c:107
+msgid "Month"
+msgstr ""
+#: ../raster/r.sunhours/main.c:108
+msgid "If not given, day is interpreted as day of the year"
+msgstr ""
+#: ../raster/r.sunhours/main.c:116
+msgid "Day"
+msgstr ""
+#: ../raster/r.sunhours/main.c:124
+msgid "Hour"
+msgstr ""
+#: ../raster/r.sunhours/main.c:133
+msgid "Minutes"
+msgstr ""
+#: ../raster/r.sunhours/main.c:142
+msgid "Seconds"
+msgstr ""
+#: ../raster/r.sunhours/main.c:149
+msgid "Time is local sidereal time, not Greenwich standard time"
+msgstr ""
+#: ../raster/r.sunhours/main.c:153
+msgid "Do not use SOLPOS algorithm of NREL"
+msgstr ""
+#: ../raster/r.sunhours/main.c:165
+msgid "No output requested, exiting."
+msgstr ""
+#: ../raster/r.sunhours/main.c:191
+msgid "NREL SOLPOS algorithm uses Greenwich standard time."
+msgstr ""
+#: ../raster/r.sunhours/main.c:192 ../raster/r.sunhours/main.c:200
+msgid "Time will be interpreted as Greenwich standard time."
+msgstr ""
+#: ../raster/r.sunhours/main.c:198
+msgid "Time will be interpreted as local sidereal time."
+msgstr ""
+#: ../raster/r.sunhours/main.c:203
+msgid "Sunshine hours require NREL SOLPOS."
+msgstr ""
+#: ../raster/r.sunhours/main.c:208
+msgid "Current projection is x,y (undefined)."
+msgstr ""
+#: ../raster/r.sunhours/main.c:214
+msgid "Cannot get projection info of current location"
+msgstr ""
+#: ../raster/r.sunhours/main.c:217
+msgid "Cannot get projection units of current location"
+msgstr ""
+#: ../raster/r.sunhours/main.c:220
+msgid "Cannot get projection key values of current location"
+msgstr ""
+#: ../raster/r.sunhours/main.c:322 ../raster/r.sunhours/main.c:333
+#: ../raster/r.sunhours/main.c:344 ../raster/r.mapcalc/map3.c:594
+#: ../imagery/i.landsat.toar/main.c:566 ../imagery/i.landsat.acca/tools.c:136
+#: ../imagery/i.landsat.acca/algorithm.c:234
+#: ../imagery/i.landsat.acca/algorithm.c:388
+#, c-format
+msgid "Unable to create raster map <%s>"
+msgstr ""
+#: ../raster/r.sunhours/main.c:354
+msgid "Calculating solar elevation and azimuth..."
+msgstr ""
+#: ../raster/r.sunhours/main.c:357
+msgid "Calculating solar elevation..."
+msgstr ""
+#: ../raster/r.sunhours/main.c:360
+msgid "Calculating solar azimuth..."
+msgstr ""
+#: ../raster/r.surf.random/main.c:40
+msgid ""
+"Produces a raster surface map of uniform random deviates with defined range."
+msgstr ""
+#: ../raster/r.surf.random/main.c:46
+msgid "Minimum random value"
+msgstr ""
+#: ../raster/r.surf.random/main.c:52
+msgid "Maximum random value"
+msgstr ""
+#: ../raster/r.surf.random/main.c:58
+msgid "Create an integer raster map"
+msgstr ""
+#: ../raster/r.surf.random/main.c:66 ../raster/r.composite/main.c:262
+#: ../raster/r.circle/main.c:153 ../raster/r.surf.fractal/main.c:85
+#: ../raster/r.li/r.li.daemon/daemon.c:174
+#, c-format
+msgid "Raster map <%s> created."
+msgstr ""
+#: ../raster/r.in.mat/main.c:94
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../raster/r.in.mat/main.c:101
+msgid "Name of input MAT-File(v4)"
+msgstr ""
+#: ../raster/r.in.mat/main.c:105
+msgid "Name for output raster map (override)"
+msgstr ""
+#: ../raster/r.in.mat/main.c:149
+msgid "Reading MAT-File..."
+msgstr ""
+#: ../raster/r.in.mat/main.c:175
+msgid "Array contains no data"
+msgstr ""
+#: ../raster/r.in.mat/main.c:180
+msgid "Array contains imaginary data"
+msgstr ""
+#: ../raster/r.in.mat/main.c:186
+msgid "Invalid array name"
+msgstr ""
+#: ../raster/r.in.mat/main.c:206
+msgid "Invalid 'map_name' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:216
+msgid "Error reading 'map_name' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:227
+msgid "Invalid 'map_northern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:236
+msgid "Invalid 'map_southern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:245
+msgid "Invalid 'map_eastern_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:254
+msgid "Invalid 'map_western_edge' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:262
+msgid "Invalid 'map_title' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:272
+msgid "Error reading 'map_title' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:285
+msgid "Invalid 'map_data' array"
+msgstr ""
+#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
+#: ../raster/r.in.mat/main.c:522
+msgid "Please contact the GRASS development team"
+msgstr ""
+#: ../raster/r.in.mat/main.c:316
+#, c-format
+msgid "Skipping unknown array '%s'"
+msgstr ""
+#: ../raster/r.in.mat/main.c:344
+#, c-format
+msgid "No 'map_data' array found in <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:351
+#, c-format
+msgid "Setting map name to <%s> which overrides <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:358
+#, c-format
+msgid "Setting map name to <%s>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:362
+msgid "No 'map_name' array found; using <MatFile>"
+msgstr ""
+#: ../raster/r.in.mat/main.c:373
+msgid "Missing bound"
+msgstr ""
+#: ../raster/r.in.mat/main.c:377
+msgid "Using default bounds"
+msgstr ""
+#: ../raster/r.in.mat/main.c:391
+#, c-format
+msgid "Map <%s> bounds set to:"
+msgstr ""
+#: ../raster/r.in.mat/main.c:392 ../raster/r.out.mat/main.c:174
+#, c-format
+msgid "northern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:393 ../raster/r.out.mat/main.c:175
+#, c-format
+msgid "southern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:394 ../raster/r.out.mat/main.c:176
+#, c-format
+msgid "eastern edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:395 ../raster/r.out.mat/main.c:177
+#, c-format
+msgid "western edge=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:396 ../raster/r.out.mat/main.c:178
+#, c-format
+msgid "nsres=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:397 ../raster/r.out.mat/main.c:179
+#, c-format
+msgid "ewres=%f"
+msgstr ""
+#: ../raster/r.in.mat/main.c:408
+msgid "Writing new raster map..."
+msgstr ""
+#: ../raster/r.proj/main.c:148
+msgid "Re-projects a raster map from given location to the current location."
+msgstr ""
+#: ../raster/r.proj/main.c:151
+msgid "Name of input raster map to re-project"
+msgstr ""
+#: ../raster/r.proj/main.c:157
+msgid "Location containing input raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:161
+msgid "Mapset containing input raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:171
+msgid "Name for output raster map (default: same as 'input')"
+msgstr ""
+#: ../raster/r.proj/main.c:198
+msgid "Resolution of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:203
+msgid "List raster maps in input mapset and exit"
+msgstr ""
+#: ../raster/r.proj/main.c:208
+msgid "Do not perform region cropping optimization"
+msgstr ""
+#: ../raster/r.proj/main.c:213
+msgid "Print input map's bounds in the current projection and exit"
+msgstr ""
+#: ../raster/r.proj/main.c:219
+msgid ""
+"Print input map's bounds in the current projection and exit (shell style)"
+msgstr ""
+#: ../raster/r.proj/main.c:253
+msgid "Input and output locations are the same"
+msgstr ""
+#: ../raster/r.proj/main.c:263
+msgid "Unable to get projection info of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:266
+msgid "Unable to get projection units of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:269
+msgid "Unable to get projection key values of output raster map"
+msgstr ""
+#: ../raster/r.proj/main.c:278
+#, c-format
+msgid "Mapset <%s> in input location <%s> - %s"
+msgstr ""
+#: ../raster/r.proj/main.c:302
+#, c-format
+msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
+msgstr ""
+#: ../raster/r.proj/main.c:310
+msgid "Unable to get projection info of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:313
+msgid "Unable to get projection units of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:316
+msgid "Unable to get projection key values of input map"
+msgstr ""
+#: ../raster/r.proj/main.c:331
+msgid "Unable to work with unprojected data (xy location)"
+msgstr ""
+#: ../raster/r.proj/main.c:350
+#, c-format
+msgid "Input map <%s@%s> in location <%s>:"
+msgstr ""
+#: ../raster/r.proj/main.c:442
+msgid "Input:"
+msgstr ""
+#: ../raster/r.proj/main.c:443 ../raster/r.proj/main.c:454
+#, c-format
+msgid "Cols: %d (%d)"
+msgstr ""
+#: ../raster/r.proj/main.c:444 ../raster/r.proj/main.c:455
+#, c-format
+msgid "Rows: %d (%d)"
+msgstr ""
+#: ../raster/r.proj/main.c:445 ../raster/r.proj/main.c:456
+#, c-format
+msgid "North: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
+#, c-format
+msgid "South: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
+#, c-format
+msgid "West: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:448 ../raster/r.proj/main.c:459
+#, c-format
+msgid "East: %f (%f)"
+msgstr ""
+#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
+#, c-format
+msgid "EW-res: %f"
+msgstr ""
+#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
+#, c-format
+msgid "NS-res: %f"
+msgstr ""
+#: ../raster/r.proj/main.c:453
+msgid "Output:"
+msgstr ""
+#: ../raster/r.proj/main.c:490
+msgid "Projecting..."
+msgstr ""
+#: ../raster/r.proj/bordwalk.c:216
+msgid "Input raster map is outside current region"
+msgstr ""
+#: ../raster/r.proj/bordwalk.c:242
+msgid "Unable to reproject map center"
+msgstr ""
+#: ../raster/r.proj/readcell.c:59 ../raster/r.proj/readcell.c:129
+#: ../raster/r.stats.quantile/main.c:309 ../raster/r.stats.zonal/main.c:481
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:64
+#: ../imagery/i.rectify/readcell.c:58
+msgid "Unable to open temporary file"
+msgstr ""
+#: ../raster/r.proj/readcell.c:67
+msgid "Allocating memory and reading input raster map..."
+msgstr ""
+#: ../raster/r.proj/readcell.c:92
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:100
+#: ../imagery/i.rectify/readcell.c:90 ../imagery/i.rectify/readcell.c:129
+msgid "Error writing segment file"
+msgstr ""
+#: ../raster/r.proj/readcell.c:125
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:130
+#: ../imagery/i.rectify/readcell.c:117
+msgid "Internal error: cache miss on fully-cached map"
+msgstr ""
+#: ../raster/r.proj/readcell.c:138
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:139
+#: ../imagery/i.rectify/readcell.c:126
+msgid "Error seeking on segment file"
+msgstr ""
+#: ../raster/r.proj/readcell.c:141
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:142
+msgid "Error reading segment file"
+msgstr ""
+#: ../raster/r.support/main.c:57
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../raster/r.support/main.c:81
+msgid "Text to use for map data units"
+msgstr ""
+#: ../raster/r.support/main.c:87
+msgid "Text to use for map vertical datum"
+msgstr ""
+#: ../raster/r.support/main.c:130
+msgid "Update statistics (histogram, range)"
+msgstr ""
+#: ../raster/r.support/main.c:134
+msgid "Create/reset the null file"
+msgstr ""
+#: ../raster/r.support/main.c:138
+msgid "Delete the null file"
+msgstr ""
+#: ../raster/r.support/main.c:148 ../raster/r.category/main.c:130
+#, c-format
+msgid "Raster map <%s> not found in current mapset"
+msgstr ""
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
+#, c-format
+msgid "[%s] is a reclass of another map. Exiting."
+msgstr ""
+#: ../raster/r.support/main.c:288
+#, c-format
+msgid "Writing new null file for [%s]... "
+msgstr ""
+#: ../raster/r.support/main.c:309
+#, c-format
+msgid "Removing null file for [%s]...\n"
+msgstr ""
+#: ../raster/r.support/main.c:316
+msgid "Done."
+msgstr ""
+#: ../raster/r.support/check.c:26
+#, c-format
+msgid ""
+"\n"
+"  Updating statistics for [%s]"
+msgstr ""
+#: ../raster/r.support/check.c:69
+#, c-format
+msgid ""
+"   Updating the number of categories for [%s]\n"
+"\n"
+msgstr ""
+#: ../raster/r.volume/main.c:76
+msgid "volume"
+msgstr ""
+#: ../raster/r.volume/main.c:77 ../raster/r.clump/main.c:54
+msgid "clumps"
+msgstr ""
+#: ../raster/r.volume/main.c:79
+msgid "Calculates the volume of data \"clumps\"."
+msgstr ""
+#: ../raster/r.volume/main.c:80
+msgid ""
+"Optionally produces a GRASS vector points map containing the calculated "
+"centroids of these clumps."
+msgstr ""
+#: ../raster/r.volume/main.c:85
+msgid ""
+"Name of input raster map representing data that will be summed within clumps"
+msgstr ""
+#: ../raster/r.volume/main.c:91
+msgid "Name of input clump raster map"
+msgstr ""
+#: ../raster/r.volume/main.c:92
+msgid ""
+"Preferably the output of r.clump. If no clump map is given than MASK is used."
+msgstr ""
+#: ../raster/r.volume/main.c:98
+msgid "Name for output vector points map to contain clump centroids"
+msgstr ""
+#: ../raster/r.volume/main.c:103 ../raster/r.report/parse.c:63
+msgid "Name for output file to hold the report"
+msgstr ""
+#: ../raster/r.volume/main.c:105 ../raster/r.report/parse.c:65
+msgid "If no output file given report is printed to standard output"
+msgstr ""
+#: ../raster/r.volume/main.c:109
+msgid "Generate unformatted report (items separated by colon)"
+msgstr ""
+#: ../raster/r.volume/main.c:142
+msgid ""
+"No MASK found. If no clump map is given than the MASK is required. You need "
+"to define a clump raster map or create a MASK by r.mask command."
+msgstr ""
+#: ../raster/r.volume/main.c:144
+msgid "No clump map given, using MASK"
+msgstr ""
+#: ../raster/r.volume/main.c:197
+#, c-format
+msgid "Invalid category value %d (max=%d): row=%d col=%d"
+msgstr ""
+#: ../raster/r.volume/main.c:230
+#, c-format
+msgid "Creating vector point map <%s>..."
+msgstr ""
+#: ../raster/r.volume/main.c:232
+#, c-format
+msgid "From '%s' on raster map <%s> using clumps from <%s>"
+msgstr ""
+#: ../raster/r.volume/main.c:265
+#, c-format
+msgid ""
+"\n"
+"Volume report on data from <%s> using clumps on <%s> raster map"
+msgstr ""
+#: ../raster/r.volume/main.c:269
+#, c-format
+msgid "Category   Average   Data   # Cells        Centroid             Total\n"
+msgstr ""
+#: ../raster/r.volume/main.c:271
+#, c-format
+msgid "Number     in clump  Total  in clump   Easting     Northing     Volume"
+msgstr ""
+#: ../raster/r.volume/main.c:317
+msgid "Total Volume"
+msgstr ""
+#: ../raster/r.spread/main.c:106 ../raster/r.ros/main.c:213
+#: ../raster/r.spreadpath/main.c:89
+msgid "fire"
+msgstr ""
+#: ../raster/r.spread/main.c:107 ../raster/r.ros/main.c:214
+msgid "spread"
+msgstr ""
+#: ../raster/r.spread/main.c:108 ../raster/r.ros/main.c:216
+#: ../raster/r.lake/main.c:152
+msgid "hazard"
+msgstr ""
+#: ../raster/r.spread/main.c:110
+msgid "Simulates elliptically anisotropic spread."
+msgstr ""
+#: ../raster/r.spread/main.c:112
+msgid ""
+"Generates a raster map of the cumulative time of spread, given raster maps "
+"containing the rates of spread (ROS), the ROS directions and the spread "
+"origins. It optionally produces raster maps to contain backlink UTM "
+"coordinates for tracing spread paths. Usable for fire spread simulations."
+msgstr ""
+#: ../raster/r.spread/main.c:126
+msgid "Raster map containing base ROS (cm/min)"
+msgstr ""
+#: ../raster/r.spread/main.c:128
+msgid ""
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the ROS values in the directions perpendicular to maximum "
+"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
+"directional factors."
+msgstr ""
+#: ../raster/r.spread/main.c:140
+msgid "Raster map containing maximal ROS (cm/min)"
+msgstr ""
+#: ../raster/r.spread/main.c:142
+msgid ""
+"path containing the maximum ROS values (cm/minute)."
+msgstr ""
+#: ../raster/r.spread/main.c:152
+msgid "Raster map containing directions of maximal ROS (degree)"
+msgstr ""
+#: ../raster/r.spread/main.c:154
+msgid ""
+"path containing directions of the maximum ROSes, clockwise from north "
+"(degree)."
+msgstr ""
+#: ../raster/r.spread/main.c:165
+msgid "Raster map containing starting sources"
+msgstr ""
+#: ../raster/r.spread/main.c:167
+msgid ""
+"path containing starting locations of the spread phenomenon. Any positive "
+"integers in this map are recognized as starting sources (seeds)."
+msgstr ""
+#: ../raster/r.spread/main.c:178
+msgid "Raster map containing maximal spotting distance (m, required with -s)"
+msgstr ""
+#: ../raster/r.spread/main.c:180
+msgid ""
+"path containing the maximum potential spotting distances (meters)."
+msgstr ""
+#: ../raster/r.spread/main.c:190
+msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
+msgstr ""
+#: ../raster/r.spread/main.c:192 ../raster/r.ros/main.c:278
+msgid ""
+"path containing wind velocities at half of the average flame height (feet/"
+"minute)."
+msgstr ""
+#: ../raster/r.spread/main.c:202
+msgid ""
+"Raster map containing fine fuel moisture of the cell receiving a spotting "
+"firebrand (%, required with -s)"
+msgstr ""
+#: ../raster/r.spread/main.c:204 ../raster/r.ros/main.c:239
+msgid ""
+"path containing the 1-hour (<.25\") fuel moisture (percentage content "
+"multiplied by 100)."
+msgstr ""
+#: ../raster/r.spread/main.c:214
+msgid "Basic sampling window size needed to meet certain accuracy (3)"
+msgstr ""
+#: ../raster/r.spread/main.c:216
+msgid ""
+"An odd integer ranging 3 - 15 indicating the basic sampling window size "
+"within which all cells will be considered to see whether they will be "
+"reached by the current spread cell. The default number is 3 which means a "
+"3x3 window."
+msgstr ""
+#: ../raster/r.spread/main.c:226
+msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
+msgstr ""
+#: ../raster/r.spread/main.c:228
+msgid ""
+"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will "
+"be considered to see whether they will be reached by the current spread "
+"cell. The closer to 1.0 the decimal number is, the longer the program will "
+"run and the higher the simulation accuracy will be. The default number is "
+"0.5."
+msgstr ""
+#: ../raster/r.spread/main.c:240
+msgid "Initial time for current simulation (0) (min)"
+msgstr ""
+#: ../raster/r.spread/main.c:242
+msgid ""
+"A non-negative number specifying the initial time for the current spread "
+"simulation (minutes). This is useful when multiple phase simulation is "
+"conducted. The default time is 0."
+msgstr ""
+#: ../raster/r.spread/main.c:251
+msgid "Simulating time duration LAG (fill the region) (min)"
+msgstr ""
+#: ../raster/r.spread/main.c:253
+msgid ""
+"A non-negative integer specifying the simulating duration time lag "
+"(minutes). The default is infinite, but the program will terminate when the "
+"current geographic region/mask has been filled. It also controls the "
+"computational time, the shorter the time lag, the faster the program will "
+"run."
+msgstr ""
+#: ../raster/r.spread/main.c:265
+msgid "Name of raster map as a display backdrop"
+msgstr ""
+#: ../raster/r.spread/main.c:267
+msgid ""
+"path to be used as the background on which the \"live\" movement will be "
+"shown."
+msgstr ""
+#: ../raster/r.spread/main.c:278
+msgid "Raster map to contain output spread time (min)"
+msgstr ""
+#: ../raster/r.spread/main.c:280
+msgid ""
+"Name of the new raster map layer to contain the results of the cumulative "
+"spread time needed for a phenomenon to reach each cell from the starting "
+"sources (minutes)."
+msgstr ""
+#: ../raster/r.spread/main.c:290
+msgid "Name of raster map to contain X back coordinates"
+msgstr ""
+#: ../raster/r.spread/main.c:292
+msgid ""
+"Name of the new raster map layer to contain the results of backlink "
+"information in UTM easting coordinates for each cell."
+msgstr ""
+#: ../raster/r.spread/main.c:302
+msgid "Name of raster map to contain Y back coordinates"
+msgstr ""
+#: ../raster/r.spread/main.c:304
+msgid ""
+"information in UTM northing coordinates for each cell."
+msgstr ""
+#: ../raster/r.spread/main.c:311
+msgid "DISPLAY 'live' spread process on screen"
+msgstr ""
+#: ../raster/r.spread/main.c:313
+msgid ""
+"Display the 'live' simulation on screen. A graphics window must be opened "
+"and selected before using this option."
+msgstr ""
+#: ../raster/r.spread/main.c:319
+msgid "Consider spotting effect (for wildfires)"
+msgstr ""
+#: ../raster/r.spread/main.c:323
+msgid "Use start raster map values in output spread time raster map"
+msgstr ""
+#: ../raster/r.spread/main.c:325
+msgid ""
+"Designed to be used with output of previous run of r.spread when computing "
+"spread iteratively. The values in start raster map are considered as time. "
+"Allowed values in raster map are from zero to the value of init_time option. "
+"If not enabled, init_time is used in the area of start raster map"
+msgstr ""
+#: ../raster/r.spread/main.c:501
+msgid "Reading inputs..."
+msgstr ""
+#: ../raster/r.spread/main.c:542
+#, c-format
+msgid "Maximum of start raster map is grater than init_time (%d > %d)"
+msgstr ""
+#: ../raster/r.spread/main.c:546
+#, c-format
+msgid "Minimum of start raster map is less than zero (%d < 0)"
+msgstr ""
+#: ../raster/r.spread/main.c:554
+#, c-format
+msgid "Reading %s..."
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:84
+msgid ""
+"Makes each output cell value a accumulationfunction of the values assigned "
+"to the corresponding cells in the input raster map layers."
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:90
+msgid "Existing map to be added to output"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:98
+msgid "Input file with raster map names, one per line"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:109
+msgid "Scale factor for input"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:116
+msgid "Shift factor for input"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:121
+msgid ""
+"The raster map specifying the lower accumulation limit, also called baseline"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:126
+msgid ""
+"The raster map specifying the upper accumulation limit, also called cutoff. "
+"Only applied to BEDD computation."
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:132 ../raster/r.series/main.c:179
+msgid "Ignore values outside this range"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:139
+msgid "Use these limits in case lower and/or upper input maps are not defined"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:151
+msgid "Growing Degree Days or Winkler indices"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:152
+msgid "Mean: sum(input maps)/(number of input maps)"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:153
+msgid "Biologically Effective Degree Days"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:154
+msgid "Huglin Heliothermal index"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:163 ../raster/r.series/main.c:187
+msgid "Do not keep files open"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:167
+msgid "Create a FCELL map (floating point single precision) as output"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:210
+#: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
+#: ../raster/r.series/main.c:202
+#, c-format
+msgid "Please specify %s= or %s="
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:255 ../raster/r.series/main.c:264
+msgid "No raster map name found in input file"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:265 ../raster/r.stats/main.c:285
+#: ../raster/r.series/main.c:274
+msgid "Raster map not found"
+msgstr ""
+#: ../raster/r.series.accumulate/main.c:354
+#, c-format
+msgid "'%s'=%f must be > '%s'=%f"
+msgstr ""
+#: ../raster/r.ros/main.c:215
+msgid "rate of spread"
+msgstr ""
+#: ../raster/r.ros/main.c:217
+msgid "Generates rate of spread raster maps."
+msgstr ""
+#: ../raster/r.ros/main.c:219
+msgid ""
+"Generates three, or four raster map layers showing the base (perpendicular) "
+"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
+"maximum ROS, and optionally the maximum potential spotting distance for fire "
+"spread simulation."
+msgstr ""
+#: ../raster/r.ros/main.c:226
+msgid "Raster map containing fuel models"
+msgstr ""
+#: ../raster/r.ros/main.c:228
+msgid ""
+"path containing the standard fuel models defined by the USDA Forest Service. "
+"Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+msgstr ""
+#: ../raster/r.ros/main.c:237
+msgid "Raster map containing the 1-hour fuel moisture (%)"
+msgstr ""
+#: ../raster/r.ros/main.c:247
+msgid "Raster map containing the 10-hour fuel moisture (%)"
+msgstr ""
+#: ../raster/r.ros/main.c:249
+msgid ""
+"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
+msgstr ""
+#: ../raster/r.ros/main.c:257
+msgid "Raster map containing the 100-hour fuel moisture (%)"
+msgstr ""
+#: ../raster/r.ros/main.c:259
+msgid ""
+"path containing the 100-hour (1-3\") fuel moisture (percentage content "
+msgstr ""
+#: ../raster/r.ros/main.c:266
+msgid "Raster map containing live fuel moisture (%)"
+msgstr ""
+#: ../raster/r.ros/main.c:268
+msgid ""
+"path containing live (herbaceous) fuel moisture (percentage content "
+msgstr ""
+#: ../raster/r.ros/main.c:276
+msgid "Raster map containing midflame wind velocities (ft/min)"
+msgstr ""
+#: ../raster/r.ros/main.c:286
+msgid "Name of raster map containing wind directions (degree)"
+msgstr ""
+#: ../raster/r.ros/main.c:288
+msgid ""
+"path containing wind direction, clockwise from north (degree)."
+msgstr ""
+#: ../raster/r.ros/main.c:296
+msgid "Name of raster map containing slope (degree)"
+msgstr ""
+#: ../raster/r.ros/main.c:298
+msgid ""
+"path containing topographic slope (degree)."
+msgstr ""
+#: ../raster/r.ros/main.c:306
+msgid "Raster map containing aspect (degree, CCW from E)"
+msgstr ""
+#: ../raster/r.ros/main.c:308
+msgid ""
+"path containing topographic aspect, counterclockwise from east (GRASS "
+"convention) in degrees."
+msgstr ""
+#: ../raster/r.ros/main.c:316
+msgid "Raster map containing elevation (m, required for spotting)"
+msgstr ""
+#: ../raster/r.ros/main.c:318
+msgid ""
+"path containing elevation (meters). Option is required from spotting "
+"distance computation (when spotting_distance option is provided)"
+msgstr ""
+#: ../raster/r.ros/main.c:327
+msgid "Output raster map containing base ROS (cm/min)"
+msgstr ""
+#: ../raster/r.ros/main.c:329
+msgid "Base (perpendicular) rate of spread (ROS)"
+msgstr ""
+#: ../raster/r.ros/main.c:335
+msgid "Output raster map containing maximal ROS (cm/min)"
+msgstr ""
+#: ../raster/r.ros/main.c:337
+msgid "The maximum (forward) rate of spread (ROS)"
+msgstr ""
+#: ../raster/r.ros/main.c:343
+msgid "Output raster map containing directions of maximal ROS (degree)"
+msgstr ""
+#: ../raster/r.ros/main.c:345
+msgid "The direction of the maximal (forward) rate of spread (ROS)"
+msgstr ""
+#: ../raster/r.ros/main.c:351
+msgid "Output raster map containing maximal spotting distance (m)"
+msgstr ""
+#: ../raster/r.ros/main.c:353
+msgid ""
+"The maximal potential spotting distance (requires elevation raster map to be "
+"provided)."
+msgstr ""
+#: ../raster/r.ros/main.c:372
+msgid ""
+"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
+"moisture layers is required."
+msgstr ""
+#: ../raster/r.ros/main.c:396
+#, c-format
+msgid ""
+"A wind direction layer should be given if the wind velocity layer <%s> has "
+"been given"
+msgstr ""
+#: ../raster/r.ros/main.c:401
+#, c-format
+msgid ""
+"A wind velocity layer should be given if the wind direction layer <%s> has "
+"been given"
+msgstr ""
+#: ../raster/r.ros/main.c:415
+#, c-format
+msgid "An aspect layer should be given if the slope layer <%s> has been given"
+msgstr ""
+#: ../raster/r.ros/main.c:420
+#, c-format
+msgid "A slope layer should be given if the aspect layer <%s> has been given"
+msgstr ""
+#: ../raster/r.ros/main.c:436
+msgid "An elevation layer should be given if considering spotting"
+msgstr ""
+#: ../raster/r.ros/main.c:872
+#, c-format
+msgid "Raster maps <%s>, <%s> and <%s> created."
+msgstr ""
+#: ../raster/r.topmodel/topmodel.c:30
+#, c-format
+msgid "Unable to run %s"
+msgstr ""
+#: ../raster/r.topmodel/topmodel.c:72
+#, c-format
+msgid "Invalid %s output"
+msgstr ""
+#: ../raster/r.topmodel/main.c:54
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../raster/r.topmodel/main.c:59
+msgid "Name of TOPMODEL parameters file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:64
+msgid "Name of topographic index statistics file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:68
+msgid "Name of rainfall and potential evapotranspiration data file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:75
+msgid "Time step"
+msgstr ""
+#: ../raster/r.topmodel/main.c:76
+msgid "Generate output for this time step"
+msgstr ""
+#: ../raster/r.topmodel/main.c:82
+msgid "Topographic index class"
+msgstr ""
+#: ../raster/r.topmodel/main.c:84
+msgid "Generate output for this topographic index class"
+msgstr ""
+#: ../raster/r.topmodel/main.c:91
+msgid "Name of input topographic index raster map"
+msgstr ""
+#: ../raster/r.topmodel/main.c:93
+msgid ""
+"Must be clipped to the catchment boundary. Used for generating outtopidxstats"
+msgstr ""
+#: ../raster/r.topmodel/main.c:95 ../raster/r.topmodel/main.c:105
+#: ../raster/r.topmodel/main.c:114
+msgid "Preprocess"
+msgstr ""
+#: ../raster/r.topmodel/main.c:99
+msgid "Number of topographic index classes"
+msgstr ""
+#: ../raster/r.topmodel/main.c:101
+msgid "Used for generating outtopidxstats"
+msgstr ""
+#: ../raster/r.topmodel/main.c:110
+msgid "Name for output topographic index statistics file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:112
+msgid "Requires topidx and ntopidxclasses"
+msgstr ""
+#: ../raster/r.topmodel/main.c:119
+msgid "Preprocess only and stop after generating outtopidxstats"
+msgstr ""
+#: ../raster/r.topmodel/main.c:149
+#, c-format
+msgid "%s must be greater than 1"
+msgstr ""
+#: ../raster/r.topmodel/main.c:153 ../raster/r.topmodel/main.c:156
+#, c-format
+msgid "Ignoring %s because %s is not specified"
+msgstr ""
+#: ../raster/r.topmodel/file_io.c:81
+#, c-format
+msgid "%s cannot be 0"
+msgstr ""
+#: ../raster/r.topmodel/infiltration.c:69
+#: ../raster/r.topmodel/infiltration.c:108
+#, c-format
+msgid "Maximum number of iterations exceeded at timestep %d"
+msgstr ""
+#: ../raster/r.coin/main.c:69
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+#: ../raster/r.coin/main.c:74
+msgid "Name of first input raster map"
+msgstr ""
+#: ../raster/r.coin/main.c:78
+msgid "Name of second input raster map"
+msgstr ""
+#: ../raster/r.coin/main.c:84
+msgid "Unit of measure"
+msgstr ""
+#: ../raster/r.coin/main.c:86
+msgid ""
+"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
+"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr ""
+#: ../raster/r.coin/main.c:93
+msgid "Wide report, 132 columns (default: 80)"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:48
+#, c-format
+msgid "Tabulating Coincidence between '%s' and '%s'"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:61
+msgid "Unable to create any tempfiles"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:65
+msgid "Unable to run r.stats"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:72
+msgid "Unexpected output from r.stats"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:84
+msgid "Unable to open tempfile"
+msgstr ""
+#: ../raster/r.coin/print_coin.c:44
+#, c-format
+msgid "Preparing report ..."
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:76
+msgid "Computing histograms"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:111 ../raster/r.quantile/main.c:97
+msgid "Computing bins"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:166 ../raster/r.quantile/main.c:134
+msgid "Binning data"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:218 ../raster/r.quantile/main.c:179
+msgid "Sorting bins"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:242
+msgid "Printing quantiles"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:257 ../raster/r.quantile/main.c:189
+msgid "Computing quantiles"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:294
+msgid "Generating reclass maps"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:333
+msgid "Writing output maps"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:391
+msgid "Compute category quantiles using two passes."
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:401 ../raster/r.quantile/main.c:266
+msgid "Number of quantiles"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:407 ../raster/r.quantile/main.c:274
+msgid "List of percentiles"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:414 ../raster/r.quantile/main.c:280
+msgid "Number of bins to use"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:418
+msgid "Resultant raster map(s)"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:425 ../raster/r.stats.zonal/main.c:148
+msgid "Create reclass map with statistics as category labels"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:430
+msgid "Do not create output maps; just print statistics"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:442
+#, c-format
+msgid "Either -%c or %s= must be given"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:446 ../raster/r.out.bin/main.c:369
+#: ../raster/r.in.bin/main.c:426 ../raster/r.in.bin/main.c:432
+#: ../raster/r.neighbors/main.c:262
+#, c-format
+msgid "-%c and %s= are mutually exclusive"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:471
+#, c-format
+msgid "Number of quantiles (%d) does not match number of output maps (%d)"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:480 ../raster/r.stats.zonal/main.c:180
+msgid "The base map must be an integer (CELL) map"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:483 ../raster/r.stats.zonal/main.c:183
+#, c-format
+msgid "Unable to read range of base map <%s>"
+msgstr ""
+#: ../raster/r.stats.quantile/main.c:488
+#, c-format
+msgid "Base map <%s> has too many categories (max: %d)"
+msgstr ""
+#: ../raster/r.category/main.c:55
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+#: ../raster/r.category/main.c:69
+msgid "Comma separated value list"
+msgstr ""
+#: ../raster/r.category/main.c:70
+msgid "Example: 1.4,3.8,13"
+msgstr ""
+#: ../raster/r.category/main.c:87
+msgid "File containing category label rules (or \"-\" to read from stdin)"
+msgstr ""
+#: ../raster/r.category/main.c:95
+msgid "Default label or format string for dynamic labeling"
+msgstr ""
+#: ../raster/r.category/main.c:97
+msgid "Used when no explicit label exists for the category"
+msgstr ""
+#: ../raster/r.category/main.c:105
+msgid "Dynamic label coefficients"
+msgstr ""
+#: ../raster/r.category/main.c:107
+msgid "Two pairs of category multiplier and offsets, for $1 and $2"
+msgstr ""
+#: ../raster/r.category/main.c:148 ../raster/r.category/main.c:230
+#: ../raster/r.report/parse.c:294 ../raster/r.mapcalc/map.c:216
+#: ../raster/r.mapcalc/map3.c:188
+#, c-format
+msgid "Unable to read category file of raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.category/main.c:152
+#, c-format
+msgid "Category table for <%s> set from <%s>"
+msgstr ""
+#: ../raster/r.category/main.c:211
+#, c-format
+msgid ""
+"Incorrect format of input rules. Check separators. Invalid line is:\n"
+"%s"
+msgstr ""
+#: ../raster/r.category/main.c:267
+#, c-format
+msgid "Unable to read category file of raster map <%s> in <%s>"
+msgstr ""
+#: ../raster/r.category/main.c:283
+msgid "The map is floating point! Ignoring cats list, using vals list"
+msgstr ""
+#: ../raster/r.category/main.c:300
+msgid "vals argument is required for floating point map!"
+msgstr ""
+#: ../raster/r.category/cats.c:47
+#, c-format
+msgid "Reading <%s> in <%s>"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:74
+msgid "Converts a GRASS ASCII raster file to binary raster map."
+msgstr ""
+#: ../raster/r.in.ascii/main.c:89
+msgid "Default: CELL for integer values, DCELL for floating-point values"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:96 ../raster/r.in.poly/main.c:50
+#: ../raster/r.external/main.c:88 ../raster/r.in.gdal/main.c:129
+#: ../raster/r.in.bin/main.c:298
+msgid "Title for resultant raster map"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:101 ../raster/r.in.ascii/main.c:106
+msgid "Default: read from header"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:103
+msgid "Multiplier for ASCII data"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:107
+msgid "String representing NULL value data cell"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:108
+msgid "NULL data"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:113
+msgid "SURFER (Golden Software) ASCII file will be imported"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:132
+#, c-format
+msgid "Wrong entry for multiplier: %s"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:157
+msgid "Unable to read input from stdin"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:164
+#, c-format
+msgid "Unable to read input from <%s>"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:184
+msgid "Can't get cell header"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:191 ../raster/r.horizon/main.c:648
+#, c-format
+msgid "OOPS: rows changed from %d to %d"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:194 ../raster/r.horizon/main.c:652
+#, c-format
+msgid "OOPS: cols changed from %d to %d"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:206
+#, c-format
+msgid "Data conversion failed at row %d, col %d"
+msgstr ""
+#: ../raster/r.in.ascii/main.c:279
+msgid "Unable to write to file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:35
+msgid "input file is not a Surfer ascii grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:41
+msgid "error reading the column and row dimension from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:47
+msgid "error reading the X range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:53
+msgid "error reading the Y range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:59
+msgid "error reading the Z range from the Surfer grid file"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:105
+msgid "error getting file position"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:164
+msgid "illegal type field: using type int"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:169
+msgid "ignoring type filed in header, type is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:176
+msgid "illegal multiplier field: using 1.0"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:181
+msgid "ignoring multiplier filed in header, multiplier is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:189
+msgid "ignoring null filed in header, null string is set on command line"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:218
+msgid "error in ascii data format"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:248
+#, c-format
+msgid "Duplicate \"%s\" field in header"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:253
+#, c-format
+msgid "Illegal \"%s\" value in header: %s"
+msgstr ""
+#: ../raster/r.in.ascii/gethead.c:261
+#, c-format
+msgid "\"%s\" field missing from header"
+msgstr ""
+#: ../raster/r.series.interp/main.c:69
+msgid ""
+"Interpolates raster maps located (temporal or spatial) in between input "
+"raster maps at specific sampling positions."
+msgstr ""
+#: ../raster/r.series.interp/main.c:79
+msgid "Data point position for each input map"
+msgstr ""
+#: ../raster/r.series.interp/main.c:84
+msgid ""
+"Input file with one input raster map name and data point position per line, "
+"field separator between name and sample point is |"
+msgstr ""
+#: ../raster/r.series.interp/main.c:97
+msgid "Sampling point position for each output map"
+msgstr ""
+#: ../raster/r.series.interp/main.c:101
+msgid ""
+"Input file with one output raster map name and sample point position per "
+"line, field separator between name and sample point is |"
+msgstr ""
+#: ../raster/r.series.interp/main.c:111
+msgid "Interpolation method, currently only linear interpolation is supported"
+msgstr ""
+#: ../raster/r.series.interp/main.c:130 ../raster/r.series.interp/main.c:146
+#, c-format
+msgid "Please specify %s= and %s="
+msgstr ""
+#: ../raster/r.series.interp/main.c:180 ../raster/r.colors/edit_colors.c:186
+#, c-format
+msgid "Unable to open %s file <%s>"
+msgstr ""
+#: ../raster/r.series.interp/main.c:213
+#, c-format
+msgid "Missing point position for %s map <%s> in file <%s> near line %i"
+msgstr ""
+#: ../raster/r.series.interp/main.c:228 ../raster/r.series.interp/main.c:262
+#, c-format
+msgid "Preparing %s map <%s> at position %g"
+msgstr ""
+#: ../raster/r.series.interp/main.c:232
+#, c-format
+msgid "No raster map name found in %s file <%s>"
+msgstr ""
+#: ../raster/r.series.interp/main.c:243
+#, c-format
+msgid "No %s raster map not found"
+msgstr ""
+#: ../raster/r.series.interp/main.c:250
+#, c-format
+msgid "The number of %s maps and %s point positions must be equal"
+msgstr ""
+#: ../raster/r.series.interp/main.c:279
+#, c-format
+msgid "Start interpolation run with %i input maps and %i output maps"
+msgstr ""
+#: ../raster/r.series.interp/main.c:299
+#, c-format
+msgid ""
+"map <%s> at position %g was not interpolated. Check the interpolation "
+"interval."
+msgstr ""
+#: ../raster/r.series.interp/main.c:319
+msgid "At least 2 input maps are required for linear interpolation"
+msgstr ""
+#: ../raster/r.series.interp/main.c:337
+#, c-format
+msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:166
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:170
+msgid "ASCII file containing input data (or \"-\" to read from stdin)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:219
+msgid ""
+"If a separate value column is given, this option refers to the z-coordinate "
+"column to be filtered by the zrange option"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:230
+msgid "Number of header lines to skip at top of input file"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:238 ../raster/r.in.lidar/main.c:205
+msgid "Filter range for z data (min,max)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:239 ../raster/r.in.xyz/main.c:247
+#: ../raster/r.in.xyz/main.c:256 ../raster/r.in.xyz/main.c:264
+#: ../raster/r.in.xyz/main.c:272
+msgid "Advanced Input"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:246 ../raster/r.in.lidar/main.c:212
+msgid "Scale to apply to z data"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:254
+msgid "Alternate column number of data values in input file"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:255
+msgid "If not given (or set to 0) the z-column data is used"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:263
+msgid "Filter range for alternate value column data (min,max)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:271
+msgid "Scale to apply to alternate value column data"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:333
+msgid "Please specify a reasonable column number."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:350 ../raster/r.in.lidar/main.c:468
+msgid "Invalid zrange"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:364
+msgid "Invalid vrange"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:450 ../raster/r.in.lidar/main.c:561
+msgid "Unable to calculate percentile without the pth option specified!"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:462 ../raster/r.in.lidar/main.c:573
+msgid "Unable to calculate trimmed mean without the trim option specified!"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:495 ../raster/r.in.lidar/main.c:648
+#, c-format
+msgid ""
+"Unable to process the hole map at once. Please set the %s option to some "
+"value lower than 100."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:548
+msgid ""
+"If input is not from a file it is only possible to perform a single pass."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:560
+msgid "Range filters will not be taken into account during scan"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:597
+msgid "Reading input data..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:604 ../raster/r.in.poly/poly2rast.c:56
+#: ../raster/r.in.lidar/main.c:705
+#, c-format
+msgid "Pass #%d (of %d) ..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:682 ../raster/r.in.xyz/main.c:690
+#: ../raster/r.in.xyz/main.c:1199 ../raster/r.in.xyz/main.c:1207
+#, c-format
+msgid ""
+"Not enough data columns. Incorrect delimiter or column number? Found the "
+"following character(s) in row %lu:\n"
+"[%s]"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:686 ../raster/r.in.xyz/main.c:1203
+msgid "Line ignored as requested"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:705 ../raster/r.in.xyz/main.c:1237
+#, c-format
+msgid "Bad y-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:712 ../raster/r.in.xyz/main.c:1222
+#, c-format
+msgid "Bad x-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:719 ../raster/r.in.xyz/main.c:1252
+#, c-format
+msgid "Bad z-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:732 ../raster/r.in.xyz/main.c:1270
+#, c-format
+msgid "Bad data value line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:815
+msgid "Writing to output raster map..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1155 ../raster/r.in.lidar/main.c:1231
+#, c-format
+msgid "%lu points found in region."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1184 ../raster/r.in.lidar/main.c:1323
+msgid "Scanning data ..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1290 ../raster/r.in.lidar/main.c:1365
+#, c-format
+msgid "Range:     min         max\n"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:52
+#: ../raster/r.out.gdal/export_band.c:344
+msgid "Unable to allocate buffer for reading raster map"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:156
+#, c-format
+msgid "Using GDAL data type <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:161
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d will "
+"be used to represent no-data values in the input map. You can specify a "
+"nodata value with the %s option."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:166
+#, c-format
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %g will "
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:176
+#, c-format
+msgid ""
+"The default nodata value is present in rasterband <%s> and would lead to "
+"data loss. Please specify a custom nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:183
+#, c-format
+msgid ""
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:227
+msgid "Unable to get raster band"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:381
+#: ../raster/r.out.gdal/export_band.c:410
+#: ../raster/r.out.gdal/export_band.c:439
+msgid "Unable to write GDAL raster file"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:460
+#: ../raster/r.out.gdal/export_band.c:472
+#: ../raster/r.out.gdal/export_band.c:485
+#: ../raster/r.out.gdal/export_band.c:498
+#: ../raster/r.out.gdal/export_band.c:510
+#: ../raster/r.out.gdal/export_band.c:523
+#: ../raster/r.out.gdal/export_band.c:537 ../raster/r.out.gdal/main.c:641
+#: ../raster/r.out.gdal/main.c:653 ../raster/r.out.gdal/main.c:666
+#: ../raster/r.out.gdal/main.c:679 ../raster/r.out.gdal/main.c:691
+#: ../raster/r.out.gdal/main.c:704
+msgid "Selected GDAL datatype does not cover data range."
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:461
+#: ../raster/r.out.gdal/export_band.c:473
+#: ../raster/r.out.gdal/export_band.c:486
+#: ../raster/r.out.gdal/export_band.c:499 ../raster/r.out.gdal/main.c:642
+#: ../raster/r.out.gdal/main.c:654 ../raster/r.out.gdal/main.c:667
+#: ../raster/r.out.gdal/main.c:680
+#, c-format
+msgid "GDAL datatype: %s, range: %d - %d"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:464
+#: ../raster/r.out.gdal/export_band.c:476
+#: ../raster/r.out.gdal/export_band.c:489
+#: ../raster/r.out.gdal/export_band.c:502
+#: ../raster/r.out.gdal/export_band.c:514
+#: ../raster/r.out.gdal/export_band.c:527
+#: ../raster/r.out.gdal/export_band.c:541
+#, c-format
+msgid "Raster map <%s> range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:511 ../raster/r.out.gdal/main.c:692
+#, c-format
+msgid "GDAL datatype: %s, range: %u - %u"
+msgstr ""
+#: ../raster/r.out.gdal/export_band.c:524
+#: ../raster/r.out.gdal/export_band.c:538 ../raster/r.out.gdal/main.c:705
+#, c-format
+msgid "GDAL datatype: %s, range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:50
+#, c-format
+msgid "Supported formats:\n"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:135
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:141
+msgid "List supported output formats"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:147
+msgid "Do not write GDAL standard colortable"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:148
+msgid "Only applicable to Byte or UInt16 data types"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:153
+msgid "Write raster attribute table"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:154
+msgid "Some export formats may not be supported"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:158
+msgid "Force raster export despite any warnings of data loss"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:159
+msgid "Overrides nodata safety check"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:162
+msgid "Name of raster map (or group) to export"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:165
+msgid "Name for output raster file"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:171
+msgid "Raster data format to write (case sensitive, see also -l flag)"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:192
+msgid "Data type"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:202
+msgid "Creation option(s) to pass to the output format driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:204
+msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:212
+msgid "Metadata key(s) and value(s) to include"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:214
+msgid ""
+"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
+"Not supported by all output format drivers."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:224
+msgid "Assign a specified nodata value to output bands"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:254
+#, c-format
+msgid "Raster map or group <%s> not found"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:258
+#, c-format
+msgid "No raster maps in group <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:272
+#, c-format
+msgid "Unable to get <%s> driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:278
+#, c-format
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:283
+msgid "Unable to get in-memory raster driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:287
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:362
+#, c-format
+msgid "Could not read data range of raster <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:419
+#, c-format
+msgid "Exporting to GDAL data type: %s"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:434
+msgid "Raster export would result in complete data loss, aborting."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:445
+#, c-format
+msgid ""
+"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
+"avoided by using %s."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:456
+#, c-format
+msgid ""
+"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
+"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:464
+#, c-format
+msgid ""
+"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
+"This can be avoided by using Float64"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:473 ../raster/r.out.gdal/main.c:516
+msgid "Forcing raster export."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:475 ../raster/r.out.gdal/main.c:489
+#: ../raster/r.out.gdal/main.c:518 ../raster/r.out.gdal/main.c:522
+msgid "Raster export aborted."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:499
+msgid "Checking GDAL data type and nodata value..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:502
+#, c-format
+msgid "Checking options for raster map <%s> (band %d)..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:547
+msgid "Unable to create dataset using memory raster driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:556
+#, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:571
+msgid "Unable to set geo transform"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:579
+msgid "Unable to set projection"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:585
+#, c-format
+msgid "Exporting raster data to %s format..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:588
+#, c-format
+msgid "Exporting raster map <%s> (band %d)..."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:601
+#, c-format
+msgid "Unable to export raster map <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:618
+#, c-format
+msgid "Unable to create raster map <%s> using driver <%s>"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:645 ../raster/r.out.gdal/main.c:657
+#: ../raster/r.out.gdal/main.c:670 ../raster/r.out.gdal/main.c:683
+#: ../raster/r.out.gdal/main.c:695 ../raster/r.out.gdal/main.c:708
+#, c-format
+msgid "Range to be exported: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:732 ../raster/r.out.gdal/main.c:745
+#: ../raster/r.out.gdal/main.c:759 ../raster/r.out.gdal/main.c:772
+#: ../raster/r.out.gdal/main.c:787
+#, c-format
+msgid ""
+"Mismatch between metadata nodata value and actual nodata value in exported "
+"raster: specified nodata value %g gets converted to %d by selected GDAL "
+"datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:735 ../raster/r.out.gdal/main.c:762
+#: ../raster/r.out.gdal/main.c:790
+#, c-format
+msgid "GDAL datatype: %s, valid range: %d - %d"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:748 ../raster/r.out.gdal/main.c:775
+#, c-format
+msgid "GDAL datatype: %s, valid range: %u - %u"
+msgstr ""
+#: ../raster/r.out.gdal/main.c:801
+#, c-format
+msgid ""
+"raster: specified nodata value %g gets converted to %g by selected GDAL "
+"datatype."
+msgstr ""
+#: ../raster/r.out.gdal/main.c:804
+#, c-format
+msgid "GDAL datatype: %s, valid range: %g - %g"
+msgstr ""
+#: ../raster/r.out.gdal/attr.c:90 ../raster/r.out.gdal/attr.c:128
+msgid "Failed to set raster attribute table"
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:48
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:51
+msgid "GRIDATB i/o map file"
+msgstr ""
+#: ../raster/r.in.gridatb/main.c:68
+#, c-format
+msgid "File not found: %s"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:35
+msgid "Setting window header failed"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:38
+msgid "Rows changed"
+msgstr ""
+#: ../raster/r.in.gridatb/file_io.c:41
+msgid "Cols changed"
+msgstr ""
+#: ../raster/r.mode/main.c:58
+msgid ""
+"Finds the mode of values in a cover map within areas assigned the same "
+"category value in a user-specified base map."
+msgstr ""
+#: ../raster/r.mode/main.c:64
+msgid "Base map to be reclassified"
+msgstr ""
+#: ../raster/r.mode/main.c:71
+msgid "Coverage map"
+msgstr ""
+#: ../raster/r.mode/main.c:78
+msgid "Output map"
+msgstr ""
+#: ../raster/r.mode/main.c:91
+#, c-format
+msgid "%s: Unable to read category labels"
+msgstr ""
+#: ../raster/r.mode/read_stats.c:14
+msgid "reading r.stats output"
+msgstr ""
+#: ../raster/r.walk/main.c:179 ../raster/r.drain/main.c:111
+#: ../raster/r.cost/main.c:141
+msgid "cost surface"
+msgstr ""
+#: ../raster/r.walk/main.c:180 ../raster/r.spreadpath/main.c:90
+#: ../raster/r.cost/main.c:142
+msgid "cumulative costs"
+msgstr ""
+#: ../raster/r.walk/main.c:183
+msgid ""
+"Creates a raster map showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input raster map whose cell "
+"category values represent cost."
+msgstr ""
+#: ../raster/r.walk/main.c:193
+msgid "Name of input raster map containing friction costs"
+msgstr ""
+#: ../raster/r.walk/main.c:196
+msgid "Name for output raster map to contain walking costs"
+msgstr ""
+#: ../raster/r.walk/main.c:202 ../raster/r.cost/main.c:167
+msgid "Name for output raster map to contain movement directions"
+msgstr ""
+#: ../raster/r.walk/main.c:203 ../raster/r.cost/main.c:161
+#: ../raster/r.cost/main.c:168
+msgid "Optional outputs"
+msgstr ""
+#: ../raster/r.walk/main.c:208 ../raster/r.cost/main.c:173
+msgid "Name of starting vector points map"
+msgstr ""
+#: ../raster/r.walk/main.c:209 ../raster/r.walk/main.c:221
+#: ../raster/r.walk/main.c:228 ../raster/r.walk/main.c:309
+#: ../raster/r.drain/main.c:137 ../raster/r.drain/main.c:144
+#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:186
+#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:243
+msgid "Start"
+msgstr ""
+#: ../raster/r.walk/main.c:214 ../raster/r.cost/main.c:179
+msgid "Name of stopping vector points map"
+msgstr ""
+#: ../raster/r.walk/main.c:215 ../raster/r.walk/main.c:235
+#: ../raster/r.cost/main.c:180 ../raster/r.cost/main.c:200
+msgid "Stop"
+msgstr ""
+#: ../raster/r.walk/main.c:220 ../raster/r.cost/main.c:185
+msgid "Name of starting raster points map"
+msgstr ""
+#: ../raster/r.walk/main.c:227 ../raster/r.drain/main.c:136
+#: ../raster/r.cost/main.c:192
+msgid "Coordinates of starting point(s) (E,N)"
+msgstr ""
+#: ../raster/r.walk/main.c:234 ../raster/r.cost/main.c:199
+msgid "Coordinates of stopping point(s) (E,N)"
+msgstr ""
+#: ../raster/r.walk/main.c:244 ../raster/r.cost/main.c:209
+msgid "Maximum cumulative cost"
+msgstr ""
+#: ../raster/r.walk/main.c:253 ../raster/r.cost/main.c:218
+msgid "Cost assigned to null cells. By default, null cells are excluded"
+msgstr ""
+#: ../raster/r.walk/main.c:254 ../raster/r.walk/main.c:304
+#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:238
+msgid "NULL cells"
+msgstr ""
+#: ../raster/r.walk/main.c:263 ../raster/r.cost/main.c:228
+msgid "Maximum memory to be used in MB"
+msgstr ""
+#: ../raster/r.walk/main.c:273
+msgid "Coefficients for walking energy formula parameters a,b,c,d"
+msgstr ""
+#: ../raster/r.walk/main.c:283
+msgid "Lambda coefficients for combining walking energy and friction cost"
+msgstr ""
+#: ../raster/r.walk/main.c:293
+msgid "Slope factor determines travel energy cost per height step"
+msgstr ""
+#: ../raster/r.walk/main.c:299 ../raster/r.cost/main.c:233
+msgid "Use the 'Knight's move'; slower, but more accurate"
+msgstr ""
+#: ../raster/r.walk/main.c:303 ../raster/r.cost/main.c:237
+msgid "Keep null values in output raster map"
+msgstr ""
+#: ../raster/r.walk/main.c:308 ../raster/r.cost/main.c:242
+msgid "Start with values in raster map"
+msgstr ""
+#: ../raster/r.walk/main.c:313 ../raster/r.cost/main.c:247
+msgid "Print info about disk space and memory requirements and exit"
+msgstr ""
+#: ../raster/r.walk/main.c:357 ../raster/r.cost/main.c:297
+msgid "Must specify exactly one of start_points, start_rast or coordinate"
+msgstr ""
+#: ../raster/r.walk/main.c:362 ../raster/r.walk/main.c:845
+#: ../raster/r.cost/main.c:302 ../raster/r.cost/main.c:712
+msgid "No start points"
+msgstr ""
+#: ../raster/r.walk/main.c:369 ../raster/r.cost/main.c:309
+#, c-format
+msgid "Inappropriate maximum cost: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:372 ../raster/r.cost/main.c:312
+#, c-format
+msgid "Inappropriate amount of memory: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:377
+#, c-format
+msgid "Missing required value: got %d instead of 4"
+msgstr ""
+#: ../raster/r.walk/main.c:380
+#, c-format
+msgid "Walking costs are a=%g b=%g c=%g d=%g"
+msgstr ""
+#: ../raster/r.walk/main.c:385 ../raster/r.walk/main.c:393
+#, c-format
+msgid "Missing required value: %d"
+msgstr ""
+#: ../raster/r.walk/main.c:388
+#, c-format
+msgid "Lambda is %g"
+msgstr ""
+#: ../raster/r.walk/main.c:396
+#, c-format
+msgid "Slope_factor is %g"
+msgstr ""
+#: ../raster/r.walk/main.c:415 ../raster/r.cost/main.c:330
+msgid "Assigning negative cost to null cell. Null cells excluded."
+msgstr ""
+#: ../raster/r.walk/main.c:525 ../raster/r.walk/main.c:538
+#: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:424
+#, c-format
+msgid "Will need at least %.2f MB of disk space"
+msgstr ""
+#: ../raster/r.walk/main.c:527 ../raster/r.walk/main.c:539
+#: ../raster/r.cost/main.c:414 ../raster/r.cost/main.c:425
+#, c-format
+msgid "Will need at least %.2f MB of memory"
+msgstr ""
+#: ../raster/r.walk/main.c:529 ../raster/r.walk/main.c:540
+#: ../raster/r.cost/main.c:416 ../raster/r.cost/main.c:426
+#, c-format
+msgid "%d of %d segments are kept in memory"
+msgstr ""
+#: ../raster/r.walk/main.c:545 ../raster/r.cost/main.c:431
+msgid "Creating some temporary files..."
+msgstr ""
+#: ../raster/r.walk/main.c:558
+#, c-format
+msgid "Reading raster maps <%s> and <%s>, initializing output..."
+msgstr ""
+#: ../raster/r.walk/main.c:643 ../raster/r.cost/main.c:504
+msgid "Initializing directional output..."
+msgstr ""
+#: ../raster/r.walk/main.c:675 ../raster/r.drain/main.c:270
+#: ../raster/r.cost/main.c:535
+#, c-format
+msgid "Reading vector map <%s> with start points..."
+msgstr ""
+#: ../raster/r.walk/main.c:722
+#, c-format
+msgid "No start points found in vector <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:734 ../raster/r.cost/main.c:598
+#, c-format
+msgid "Reading vector map <%s> with stop points..."
+msgstr ""
+#: ../raster/r.walk/main.c:788 ../raster/r.cost/main.c:652
+#, c-format
+msgid "No stop points found in vector <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:808 ../raster/r.stream.extract/load.c:44
+#: ../raster/r.stream.extract/load.c:53 ../raster/r.cost/main.c:673
+#: ../raster/r.texture/h_measure.c:594 ../imagery/i.smap/interp.c:68
+msgid "Unable to allocate memory"
+msgstr ""
+#: ../raster/r.walk/main.c:810 ../raster/r.cost/main.c:675
+#, c-format
+msgid "Reading raster map <%s> with start points..."
+msgstr ""
+#: ../raster/r.walk/main.c:859 ../raster/r.cost/main.c:726
+msgid "Specified starting location outside database window"
+msgstr ""
+#: ../raster/r.walk/main.c:879 ../raster/r.cost/main.c:748
+msgid "Finding cost path..."
+msgstr ""
+#: ../raster/r.walk/main.c:1356 ../raster/r.cost/main.c:1011
+msgid "Error, ct == pres_cell"
+msgstr ""
+#: ../raster/r.walk/main.c:1368
+#, c-format
+msgid "Writing output raster map <%s>... "
+msgstr ""
+#: ../raster/r.walk/main.c:1432 ../raster/r.cost/main.c:1131
+#, c-format
+msgid "Writing output movement direction raster map <%s>..."
+msgstr ""
+#: ../raster/r.walk/main.c:1477 ../raster/r.cost/main.c:1197
+#, c-format
+msgid "Peak cost value: %g"
+msgstr ""
+#: ../raster/r.walk/main.c:1498 ../raster/r.cost/main.c:1219
+#, c-format
+msgid "Illegal x coordinate <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:1500 ../raster/r.cost/main.c:1221
+#, c-format
+msgid "Illegal y coordinate <%s>"
+msgstr ""
+#: ../raster/r.walk/main.c:1504 ../raster/r.cost/main.c:1225
+#, c-format
+msgid "Warning, ignoring point outside window: %g, %g"
+msgstr ""
+#: ../raster/r.null/main.c:61
+msgid "Manages NULL-values of given raster map."
+msgstr ""
+#: ../raster/r.null/main.c:64
+msgid "Name of raster map for which to edit null values"
+msgstr ""
+#: ../raster/r.null/main.c:85
+msgid "Only do the work if the map is floating-point"
+msgstr ""
+#: ../raster/r.null/main.c:86 ../raster/r.null/main.c:91
+#: ../raster/r.null/main.c:97
+msgid "Check"
+msgstr ""
+#: ../raster/r.null/main.c:90
+msgid "Only do the work if the map is integer"
+msgstr ""
+#: ../raster/r.null/main.c:96
+msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
+msgstr ""
+#: ../raster/r.null/main.c:102
+msgid "Create NULL-value bitmap file validating all data cells"
+msgstr ""
+#: ../raster/r.null/main.c:106
+msgid "Remove NULL-value bitmap file"
+msgstr ""
+#: ../raster/r.null/main.c:125
+#, c-format
+msgid ""
+"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
+"with r.mapcalc. Exiting."
+msgstr ""
+#: ../raster/r.null/main.c:131
+#, c-format
+msgid "Raster map <%s> is not in your mapset <%s>"
+msgstr ""
+#: ../raster/r.null/main.c:138
+#, c-format
+msgid "%s is illegal entry for null"
+msgstr ""
+#: ../raster/r.null/main.c:145
+#, c-format
+msgid "Raster map <%s> already has a null bitmap file"
+msgstr ""
+#: ../raster/r.null/main.c:149
+#, c-format
+msgid "<%s> is integer raster map (CELL)"
+msgstr ""
+#: ../raster/r.null/main.c:153
+#, c-format
+msgid "<%s> is integer raster map (CELL). Using null=%d."
+msgstr ""
+#: ../raster/r.null/main.c:159
+#, c-format
+msgid "<%s> is floating pointing raster map"
+msgstr ""
+#: ../raster/r.null/main.c:175
+#, c-format
+msgid "Writing new null file for raster map <%s>..."
+msgstr ""
+#: ../raster/r.null/main.c:185 ../raster/r.null/main.c:198
+#, c-format
+msgid "Raster map <%s> modified."
+msgstr ""
+#: ../raster/r.null/main.c:192
+#, c-format
+msgid "Removing null file for raster map <%s>..."
+msgstr ""
+#: ../raster/r.null/main.c:262
+#, c-format
+msgid "%s: %s: illegal value spec"
+msgstr ""
+#: ../raster/r.null/main.c:264
+#, c-format
+msgid "%s: illegal value spec"
+msgstr ""
+#: ../raster/r.null/main.c:325
+#, c-format
+msgid "Writing new data for raster map <%s>..."
+msgstr ""
+#: ../raster/r.timestamp/main.c:38
+msgid "Modifies a timestamp for a raster map."
+msgstr ""
+#: ../raster/r.timestamp/main.c:39
+msgid "Print/add/remove a timestamp for a raster map."
+msgstr ""
+#: ../raster/r.timestamp/main.c:64
+#, c-format
+msgid "Raster map <%s> not found %s"
+msgstr ""
+#: ../raster/r.latlong/main.c:57
+msgid "latitude"
+msgstr ""
+#: ../raster/r.latlong/main.c:58
+msgid "longitude"
+msgstr ""
+#: ../raster/r.latlong/main.c:60
+msgid "Creates a latitude/longitude raster map."
+msgstr ""
+#: ../raster/r.latlong/main.c:66
+msgid "Name for output latitude or longitude raster map"
+msgstr ""
+#: ../raster/r.latlong/main.c:70
+msgid "Longitude output"
+msgstr ""
+#: ../raster/r.latlong/main.c:101 ../raster/r.sunmask/g_solposition.c:98
+msgid "Unable to get projection info of current location"
+msgstr ""
+#: ../raster/r.latlong/main.c:103 ../raster/r.sunmask/g_solposition.c:101
+msgid "Unable to get projection units of current location"
+msgstr ""
+#: ../raster/r.latlong/main.c:105 ../raster/r.sunmask/g_solposition.c:104
+msgid "Unable to get projection key values of current location"
+msgstr ""
+#: ../raster/r.quant/main.c:48
+msgid "quantization"
+msgstr ""
+#: ../raster/r.quant/main.c:51
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../raster/r.quant/main.c:59
+msgid "Raster map(s) to be quantized"
+msgstr ""
+#: ../raster/r.quant/main.c:64
+msgid "Path to rules file (\"-\" to read from stdin)"
+msgstr ""
+#: ../raster/r.quant/main.c:70
+msgid "Base map to take quant rules from"
+msgstr ""
+#: ../raster/r.quant/main.c:75
+msgid "Floating point range: dmin,dmax"
+msgstr ""
+#: ../raster/r.quant/main.c:81
+msgid "Integer range: min,max"
+msgstr ""
+#: ../raster/r.quant/main.c:86
+msgid "Truncate floating point data"
+msgstr ""
+#: ../raster/r.quant/main.c:90
+msgid "Round floating point data"
+msgstr ""
+#: ../raster/r.quant/main.c:111
+#, c-format
+msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
+msgstr ""
+#: ../raster/r.quant/main.c:120
+#, c-format
+msgid "%s= and %s= must be used together"
+msgstr ""
+#: ../raster/r.quant/main.c:131
+#, c-format
+msgid "%s is integer map, it can't be quantized"
+msgstr ""
+#: ../raster/r.quant/main.c:139
+msgid "Truncating..."
+msgstr ""
+#: ../raster/r.quant/main.c:144
+msgid "Rounding..."
+msgstr ""
+#: ../raster/r.quant/main.c:152
+#, c-format
+msgid "%s is integer map, it can't be used as basemap"
+msgstr ""
+#: ../raster/r.quant/main.c:156
+#, c-format
+msgid "unable to read quant rules for basemap <%s>"
+msgstr ""
+#: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
+#, c-format
+msgid "invalid value for %s= <%s>"
+msgstr ""
+#: ../raster/r.quant/main.c:168
+#, c-format
+msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
+msgstr ""
+#: ../raster/r.quant/main.c:181
+msgid "No rules specified. Quant table(s) not changed."
+msgstr ""
+#: ../raster/r.quant/main.c:183 ../raster/r.reclass/main.c:142
+#: ../raster/r.recode/main.c:98
+msgid "No rules specified"
+msgstr ""
+#: ../raster/r.quant/main.c:189
+#, c-format
+msgid "New quant table created for %s"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:50
+msgid "Old data range is empty"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:56
+#, c-format
+msgid "Old data range is %s to %s"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:59
+msgid "Old integer data range is empty"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:61
+#, c-format
+msgid "Old integer data range is %d to %d"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:83
+#, c-format
+msgid "unable to open input file <%s>"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:89
+#, c-format
+msgid ""
+"\n"
+"Enter the rule or 'help' for the format description or 'end' to exit:\n"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:112
+msgid "quant rules do not cover the whole range map"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:158 ../raster/r.recode/read_rules.c:126
+#, c-format
+msgid "%s is not a valid rule"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:51 ../raster/r.reclass/reclass.c:111
+msgid "Too many categories"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:216
+#, c-format
+msgid "Cannot read header file of <%s@%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:234
+#, c-format
+msgid "Cannot overwrite existing raster map <%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:239
+#, c-format
+msgid "Cannot create reclass file of <%s>"
+msgstr ""
+#: ../raster/r.reclass/reclass.c:247
+#, c-format
+msgid "Cannot create raster map <%s>"
+msgstr ""
+#: ../raster/r.reclass/main.c:52
+msgid "Reclassify raster map based on category values."
+msgstr ""
+#: ../raster/r.reclass/main.c:54
+msgid ""
+"Creates a new raster map whose category values are based upon a "
+"reclassification of the categories in an existing raster map."
+msgstr ""
+#: ../raster/r.reclass/main.c:59
+msgid "Name of raster map to be reclassified"
+msgstr ""
+#: ../raster/r.reclass/main.c:65
+msgid "File containing reclass rules"
+msgstr ""
+#: ../raster/r.reclass/main.c:72 ../raster/r.recode/main.c:66
+#: ../raster/r.clump/main.c:68 ../raster/r.neighbors/main.c:221
+msgid "Title for output raster map"
+msgstr ""
+#: ../raster/r.reclass/main.c:83
+msgid "Input map can NOT be the same as output map"
+msgstr ""
+#: ../raster/r.reclass/main.c:89
+#, c-format
+msgid "Cannot open rules file <%s>"
+msgstr ""
+#: ../raster/r.reclass/main.c:103
+#, c-format
+msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:105
+#, c-format
+msgid "FCELL: Data range is %.7g to %.7g\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:108
+#, c-format
+msgid "DCELL: Data range is %.15g to %.15g\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:111
+#, c-format
+msgid "CELL: Data range is %ld to %ld\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:119
+#, c-format
+msgid "Illegal reclass rule -"
+msgstr ""
+#: ../raster/r.reclass/main.c:120
+#, c-format
+msgid " ignored\n"
+msgstr ""
+#: ../raster/r.reclass/main.c:123
+msgid " - invalid reclass rule"
+msgstr ""
+#: ../raster/r.reclass/main.c:139
+#, c-format
+msgid "No rules specified. Raster map <%s> not created"
+msgstr ""
+#: ../raster/r.reclass/parse.c:41 ../raster/r.colors/rules.c:104
+#, c-format
+msgid "Enter a rule in one of these formats:\n"
+msgstr ""
+#: ../raster/r.reclass/parse.c:42
+msgid "poor quality"
+msgstr ""
+#: ../raster/r.reclass/parse.c:44
+msgid "medium quality"
+msgstr ""
+#: ../raster/r.reclass/parse.c:59
+msgid "Can't have null on the left-hand side of the rule"
+msgstr ""
+#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
+msgid "Can't have null on the right-hand side of the rule"
+msgstr ""
+#: ../raster/r.reclass/parse.c:196
+#, c-format
+msgid "%f rounded up to %d\n"
+msgstr ""
+#: ../raster/r.in.poly/main.c:37
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../raster/r.in.poly/main.c:41
+msgid "Name of input file; or \"-\" to read from stdin"
+msgstr ""
+#: ../raster/r.in.poly/main.c:56
+msgid "Output raster type"
+msgstr ""
+#: ../raster/r.in.poly/main.c:64
+msgid "Integer representing NULL value data cell"
+msgstr ""
+#: ../raster/r.in.poly/main.c:70
+msgid "Number of rows to hold in memory"
+msgstr ""
+#: ../raster/r.in.poly/main.c:78
+msgid "Minimum number of rows to hold in memory is 1"
+msgstr ""
+#: ../raster/r.in.poly/main.c:87
+msgid "Type doesn't exist"
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:97
+#, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:102
+#, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr ""
+#: ../raster/r.in.poly/get_item.c:107
+#, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr ""
+#: ../raster/r.out.ppm/main.c:56
+msgid "Converts a GRASS raster map to a PPM image file."
+msgstr ""
+#: ../raster/r.out.ppm/main.c:64
+msgid "Name for new PPM file (use '-' for stdout)"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:68
+msgid "Output greyscale instead of color"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:72
+msgid "Suppress printing of PPM header"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:101 ../raster/r.out.ppm3/main.c:95
+#, c-format
+msgid "row = %d"
+msgid_plural "rows = %d"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC Raster columns
+#: ../raster/r.out.ppm/main.c:102 ../raster/r.out.ppm3/main.c:97
+#, c-format
+msgid "column = %d"
+msgid_plural "columns = %d"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.out.ppm/main.c:124
+#, c-format
+msgid "Unable to open file <%s> for write"
+msgstr ""
+#: ../raster/r.out.ppm/main.c:154
+msgid "Converting..."
+msgstr ""
+#: ../raster/r.out.ppm/main.c:234
+#, c-format
+msgid "File <%s> created"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:174
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:246
+msgid "Output raster resolution"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:294
+msgid "Import intensity values rather than z values"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:594
+msgid "zrange will not be taken into account during scan"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:615
+#, c-format
+msgid "Option '%s' must be > 0.0"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:693
+msgid "Reading data ..."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:710
+msgid "Could not rewind input file"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:885
+msgid "Writing to map ..."
+msgstr ""
+#: ../raster/r.grow.distance/main.c:154
+msgid "Generates a raster map containing distances to nearest raster features."
+msgstr ""
+#: ../raster/r.grow.distance/main.c:161
+msgid "Name for distance output raster map"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:167
+msgid "Name for value output raster map"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:180
+msgid "Output distances in meters instead of map units"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:190
+msgid "At least one of distance= and value= must be given"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:205
+msgid "metric=geodesic is only valid for lat/lon"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:211
+#, c-format
+msgid "Unknown metric: '%s'"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:216
+#, c-format
+msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:236
+#, c-format
+msgid "Unable to create temporary file <%s>"
+msgstr ""
+#: ../raster/r.grow.distance/main.c:311 ../raster/r.fill.dir/main.c:250
+#: ../raster/r.stream.extract/close.c:248
+msgid "Writing output raster maps..."
+msgstr ""
+#: ../raster/r.regression.line/main.c:49
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
+msgstr ""
+#: ../raster/r.regression.line/main.c:54
+#: ../raster/r.regression.multi/main.c:136
+msgid "Map for x coefficient"
+msgstr ""
+#: ../raster/r.regression.line/main.c:58
+#: ../raster/r.regression.multi/main.c:140
+msgid "Map for y coefficient"
+msgstr ""
+#: ../raster/r.regression.line/main.c:64
+#: ../raster/r.regression.multi/main.c:156
+msgid ""
+"ASCII file for storing regression coefficients (output to screen if file not "
+"specified)."
+msgstr ""
+#: ../raster/r.what.color/main.c:91
+msgid "Queries colors for a raster map layer."
+msgstr ""
+#: ../raster/r.what.color/main.c:99
+msgid "Name of existing raster map to query colors"
+msgstr ""
+#: ../raster/r.what.color/main.c:106
+msgid "Values to query colors for"
+msgstr ""
+#: ../raster/r.what.color/main.c:113
+msgid "Output format (printf-style)"
+msgstr ""
+#: ../raster/r.what.color/main.c:117
+msgid "Read values from stdin"
+msgstr ""
+#: ../raster/r.what.color/main.c:123
+msgid "Either \"-i\" or \"value=\" must be given"
+msgstr ""
+#: ../raster/r.describe/main.c:57
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../raster/r.describe/main.c:71
+msgid "Number of quantization steps"
+msgstr ""
+#: ../raster/r.describe/main.c:77
+msgid "Print the output one value per line"
+msgstr ""
+#: ../raster/r.describe/main.c:81
+msgid "Only print the range of the data"
+msgstr ""
+#: ../raster/r.describe/main.c:85
+msgid "Suppress reporting of any NULLs"
+msgstr ""
+#: ../raster/r.describe/main.c:89
+msgid "Use the current region"
+msgstr ""
+#: ../raster/r.describe/main.c:93
+msgid "Read floating-point map as integer"
+msgstr ""
+#: ../raster/r.describe/main.c:105
+#, c-format
+msgid "%s = %s -- must be greater than zero"
+msgstr ""
+#: ../raster/r.describe/describe.c:94
+#, c-format
+msgid "Reading <%s> ..."
+msgstr ""
+#: ../raster/r.out.png/main.c:116
+msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+msgstr ""
+#: ../raster/r.out.png/main.c:122
+msgid "Name for new PNG file (use '-' for stdout)"
+msgstr ""
+#: ../raster/r.out.png/main.c:130
+msgid "Compression level of PNG file"
+msgstr ""
+#: ../raster/r.out.png/main.c:131
+msgid "(0 = none, 1 = fastest, 9 = best)"
+msgstr ""
+#: ../raster/r.out.png/main.c:138
+msgid "Make NULL cells transparent"
+msgstr ""
+#: ../raster/r.out.png/main.c:142
+msgid "Output world file"
+msgstr ""
+#: ../raster/r.out.png/main.c:175 ../display/d.graph/main.c:104
+#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
+#: ../display/d.graph/do_graph.c:370 ../display/d.labels/color.c:68
+#: ../display/d.rast/display.c:27
+#, c-format
+msgid "[%s]: No such color"
+msgstr ""
+#: ../raster/r.out.png/main.c:257
+#, c-format
+msgid "Converting <%s>..."
+msgstr ""
+#: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:183
+#, c-format
+msgid "Raster <%s> type mismatch"
+msgstr ""
+#: ../raster/r.out.png/main.c:422
+msgid "Writing world file"
+msgstr ""
+#: ../raster/r.out.png/main.c:425
+msgid "Got null file name"
+msgstr ""
+#: ../raster/r.out.png/main.c:427
+msgid "Got null region struct"
+msgstr ""
+#: ../raster/r.out.png/main.c:429
+msgid "Unable to open world file for writing"
+msgstr ""
+#: ../raster/r.covar/main.c:54
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map "
+"layer(s)."
+msgstr ""
+#: ../raster/r.covar/main.c:61
+msgid "Print correlation matrix"
+msgstr ""
+#: ../raster/r.covar/main.c:86
+#, c-format
+msgid "%s: complete ... "
+msgstr ""
+#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:197
+msgid "No non-null values"
+msgstr ""
+#: ../raster/r.random/main.c:56
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+#: ../raster/r.random/main.c:60 ../raster/r.out.bin/main.c:290
+#: ../imagery/i.zc/main.c:65
+msgid "Name of input raster map"
+msgstr ""
+#: ../raster/r.random/main.c:65
+msgid "Name of cover raster map"
+msgstr ""
+#: ../raster/r.random/main.c:72
+msgid "The number of points to allocate"
+msgstr ""
+#: ../raster/r.random/main.c:84
+msgid "Generate points also for NULL category"
+msgstr ""
+#: ../raster/r.random/main.c:89
+msgid "Report information about input raster and exit"
+msgstr ""
+#: ../raster/r.random/main.c:93
+msgid "Generate vector points as 3D points"
+msgstr ""
+#: ../raster/r.random/main.c:133
+#, c-format
+msgid "Note: one (or both) of %s and %s must be specified"
+msgstr ""
+#: ../raster/r.random/main.c:141
+#, c-format
+msgid "<%s=%s> invalid percentage"
+msgstr ""
+#: ../raster/r.random/main.c:148
+#, c-format
+msgid "<%s=%s> invalid number of points"
+msgstr ""
+#: ../raster/r.random/main.c:161
+#, c-format
+msgid "There aren't [%ld] cells in the current region"
+msgstr ""
+#: ../raster/r.random/main.c:164
+#, c-format
+msgid "There aren't [%ld] non-NULL cells in the current region"
+msgstr ""
+#: ../raster/r.random/main.c:169
+msgid "There are no valid locations in the current region"
+msgstr ""
+#: ../raster/r.random/random.c:43 ../raster/r.random/random.c:47
+#: ../raster/r.mapcalc/map3.c:515 ../imagery/i.landsat.toar/main.c:406
+#: ../imagery/i.landsat.toar/main.c:544 ../imagery/i.landsat.acca/main.c:57
+#: ../imagery/i.landsat.acca/tools.c:126
+#: ../imagery/i.landsat.acca/algorithm.c:380
+#, c-format
+msgid "Unable to open raster map <%s>"
+msgstr ""
+#: ../raster/r.random/random.c:100
+msgid "Cannot create new table"
+msgstr ""
+#: ../raster/r.random/random.c:110
+#, c-format
+msgid "Writing raster map <%s> and vector map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:113
+#, c-format
+msgid "Writing raster map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:115
+#, c-format
+msgid "Writing vector map <%s> ..."
+msgstr ""
+#: ../raster/r.random/random.c:243
+#, c-format
+msgid "Only [%ld] random points created"
+msgstr ""
+#: ../raster/r.random/count.c:68
+msgid "Collecting Stats..."
+msgstr ""
+#: ../raster/r.random/count.c:123
+msgid "Programmer error in get_stats/switch"
+msgstr ""
+#: ../raster/r.report/main.c:69
+msgid "Reports statistics for raster maps."
+msgstr ""
+#: ../raster/r.report/parse.c:38 ../raster/r.stats/main.c:114
+msgid "Name of raster map(s) to report on"
+msgstr ""
+#: ../raster/r.report/parse.c:45
+msgid "Units to report"
+msgstr ""
+#: ../raster/r.report/parse.c:49
+msgid "area in square miles"
+msgstr ""
+#: ../raster/r.report/parse.c:50
+msgid "area in square meters"
+msgstr ""
+#: ../raster/r.report/parse.c:51
+msgid "area in square kilometers"
+msgstr ""
+#: ../raster/r.report/parse.c:52
+msgid "area in acres"
+msgstr ""
+#: ../raster/r.report/parse.c:53
+msgid "area in hectares"
+msgstr ""
+#: ../raster/r.report/parse.c:54
+msgid "number of cells"
+msgstr ""
+#: ../raster/r.report/parse.c:55
+msgid "percent cover"
+msgstr ""
+#: ../raster/r.report/parse.c:58 ../raster/r.stats/main.c:158
+#: ../raster/r.stats/main.c:163 ../raster/r.stats/main.c:169
+msgid "Statistics"
+msgstr ""
+#: ../raster/r.report/parse.c:75
+msgid "Page length"
+msgstr ""
+#: ../raster/r.report/parse.c:83
+msgid "Page width"
+msgstr ""
+#: ../raster/r.report/parse.c:94 ../raster/r.stats/main.c:136
+msgid "Number of floating-point subranges to collect stats from"
+msgstr ""
+#: ../raster/r.report/parse.c:95 ../raster/r.report/parse.c:139
+#: ../raster/r.report/parse.c:145 ../raster/r.stats/main.c:137
+#: ../raster/r.stats/main.c:192 ../raster/r.stats/main.c:197
+#: ../raster/r.stats/main.c:212 ../raster/r.stats/main.c:217
+msgid "Floating point"
+msgstr ""
+#: ../raster/r.report/parse.c:102 ../raster/r.stats/main.c:144
+msgid "Sort output statistics by cell counts"
+msgstr ""
+#: ../raster/r.report/parse.c:103 ../raster/r.stats/main.c:145
+msgid "Default: sorted by categories or intervals"
+msgstr ""
+#: ../raster/r.report/parse.c:107 ../raster/r.stats/main.c:149
+msgid "Sort by cell counts in ascending order"
+msgstr ""
+#: ../raster/r.report/parse.c:108 ../raster/r.stats/main.c:150
+msgid "Sort by cell counts in descending order"
+msgstr ""
+#: ../raster/r.report/parse.c:113
+msgid "Suppress page headers"
+msgstr ""
+#: ../raster/r.report/parse.c:118
+msgid "Use formfeeds between pages"
+msgstr ""
+#: ../raster/r.report/parse.c:123
+msgid "Scientific format"
+msgstr ""
+#: ../raster/r.report/parse.c:128 ../raster/r.stats/main.c:201
+msgid "Do not report no data value"
+msgstr ""
+#: ../raster/r.report/parse.c:129 ../raster/r.report/parse.c:134
+#: ../raster/r.stats/main.c:202 ../raster/r.stats/main.c:207
+msgid "No data"
+msgstr ""
+#: ../raster/r.report/parse.c:133 ../raster/r.stats/main.c:206
+msgid "Do not report cells where all maps have no data"
+msgstr ""
+#: ../raster/r.report/parse.c:138 ../raster/r.stats/main.c:211
+msgid "Report for cats floating-point ranges (floating-point maps only)"
+msgstr ""
+#: ../raster/r.report/parse.c:144 ../raster/r.stats/main.c:216
+msgid "Read floating-point map as integer (use map's quant rules)"
+msgstr ""
+#: ../raster/r.report/parse.c:187
+msgid "nsteps has to be > 0; using nsteps=255"
+msgstr ""
+#: ../raster/r.report/parse.c:193
+msgid "Illegal page length"
+msgstr ""
+#: ../raster/r.report/parse.c:198
+msgid "Illegal page width"
+msgstr ""
+#: ../raster/r.report/parse.c:253
+#, c-format
+msgid "Only %d unit%s allowed"
+msgstr ""
+#: ../raster/r.report/parse.c:286
+#, c-format
+msgid "Unable to read fp range for raster map <%s>"
+msgstr ""
+#: ../raster/r.report/label.c:13
+msgid "Page width is too small"
+msgstr ""
+#: ../raster/r.report/stats.c:93
+#, c-format
+msgid "Unable to open result file <%s>"
+msgstr ""
+#: ../raster/r.report/stats.c:128 ../raster/r.kappa/stats.c:14
+msgid "Problem reading r.stats output"
+msgstr ""
+#: ../raster/r.profile/main.c:56
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../raster/r.profile/main.c:64 ../raster/r.horizon/main.c:304
+msgid "Name of file for output (use output=- for stdout)"
+msgstr ""
+#: ../raster/r.profile/main.c:69 ../display/d.profile/main.c:203
+msgid "Profile coordinate pairs"
+msgstr ""
+#: ../raster/r.profile/main.c:75
+msgid "Name of input file containing coordinate pairs"
+msgstr ""
+#: ../raster/r.profile/main.c:77
+msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
+msgstr ""
+#: ../raster/r.profile/main.c:85
+msgid "Resolution along profile (default = current region resolution)"
+msgstr ""
+#: ../raster/r.profile/main.c:93 ../raster/r.transect/main.c:126
+msgid "Output easting and northing in first two columns of four column output"
+msgstr ""
+#: ../raster/r.profile/main.c:98
+msgid "Output RRR:GGG:BBB color values for each profile point"
+msgstr ""
+#: ../raster/r.profile/main.c:103
+msgid ""
+"If units are not specified, current location units are used. Meters are used "
+"by default in geographic (latlon) locations."
+msgstr ""
+#: ../raster/r.profile/main.c:117
+msgid "Either use profile option or coordinate_file  option, but not both"
+msgstr ""
+#: ../raster/r.profile/main.c:144
+#, c-format
+msgid "Illegal resolution %g [%s]"
+msgstr ""
+#: ../raster/r.profile/main.c:151
+#, c-format
+msgid "Using resolution: %g [%s]"
+msgstr ""
+#: ../raster/r.profile/main.c:182
+msgid "Output columns:"
+msgstr ""
+#: ../raster/r.profile/main.c:185
+#, c-format
+msgid "Easting, Northing, Along track dist. [%s], Elevation"
+msgstr ""
+#: ../raster/r.profile/main.c:187
+#, c-format
+msgid "Along track dist. [%s], Elevation"
+msgstr ""
+#: ../raster/r.profile/main.c:189
+msgid " RGB color"
+msgstr ""
+#: ../raster/r.profile/main.c:200
+#, c-format
+msgid "Could not open <%s>"
+msgstr ""
+#: ../raster/r.profile/main.c:207
+#, c-format
+msgid "Invalid coordinates %s %s"
+msgstr ""
+#: ../raster/r.profile/main.c:278
+#, c-format
+msgid "Approx. transect length: %f [%s]"
+msgstr ""
+#: ../raster/r.profile/main.c:281
+msgid "Endpoint coordinates are outside of current region settings"
+msgstr ""
+#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
+#: ../raster/r.profile/input.c:60
+msgid "One coordinate pair per line, please"
+msgstr ""
+#: ../raster/r.colors.out/raster_main.c:49
+msgid "Exports the color table associated with a raster map."
+msgstr ""
+#: ../raster/r.colors.out/raster3d_main.c:50
+msgid "Exports the color table associated with a 3D raster map."
+msgstr ""
+#: ../raster/r.colors.out/raster3d_main.c:70
+#, c-format
+msgid "Unable to read color table for raster3d map <%s>"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:104
+msgid "animation"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:107
+msgid "Converts raster map series to MPEG movie."
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:115
+#, c-format
+msgid "Name of input raster map(s) for view no.%d"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:117
+msgid "Views"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:131
+msgid "Quality factor (1 = highest quality, lowest compression)"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:136
+msgid "Convert on the fly, uses less disk space"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:137
+msgid "Requires r.out.ppm with stdout option"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:160
+msgid "Either mpeg_encode or ppmtompeg must be installed"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:291
+#, c-format
+msgid "Unable to read color table for <%s>"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
+msgid "mpeg_encode ERROR"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:417
+msgid "Error reading wildcard"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
+msgid "Size mismatch error!"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
+msgid "Unable to open output file"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:215
+msgid "Unable to create temporary files."
+msgstr ""
+#: ../raster/r.out.bin/main.c:139
+#, c-format
+msgid "Header File = %s"
+msgstr ""
+#: ../raster/r.out.bin/main.c:223
+#, c-format
+msgid "World File = %s"
+msgstr ""
+#: ../raster/r.out.bin/main.c:281
+msgid "Exports a GRASS raster to a binary array."
+msgstr ""
+#: ../raster/r.out.bin/main.c:297
+msgid "Name for output binary map (use output=- for stdout)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:311 ../raster/r.in.bin/main.c:305
+msgid "Number of bytes per cell"
+msgstr ""
+#: ../raster/r.out.bin/main.c:323
+msgid "Generate integer output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:327
+msgid "Generate floating-point output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:331
+msgid "Export array with GMT compatible header"
+msgstr ""
+#: ../raster/r.out.bin/main.c:335
+msgid "Generate BIL world and header files"
+msgstr ""
+#: ../raster/r.out.bin/main.c:339
+msgid "Byte swap output"
+msgstr ""
+#: ../raster/r.out.bin/main.c:399
+#, c-format
+msgid "Floating-point output requires %s=4 or %s=8"
+msgstr ""
+#: ../raster/r.out.bin/main.c:404
+#, c-format
+msgid "Integer output doesn't support %s=8 in this build"
+msgstr ""
+#: ../raster/r.out.bin/main.c:419
+msgid "GMT grid doesn't support 64-bit integers"
+msgstr ""
+#: ../raster/r.out.bin/main.c:425
+msgid "Creating BIL support files..."
+msgstr ""
+#: ../raster/r.out.bin/main.c:442
+#, c-format
+msgid "Exporting raster as floating values (%s=%d)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:445
+msgid "Writing GMT float format ID=1"
+msgstr ""
+#: ../raster/r.out.bin/main.c:448
+#, c-format
+msgid "Exporting raster as integer values (%s=%d)"
+msgstr ""
+#: ../raster/r.out.bin/main.c:451
+msgid "Writing GMT integer format ID=2"
+msgstr ""
+#: ../raster/r.out.bin/main.c:459
+#, c-format
+msgid "r=%d"
+msgstr ""
+#: ../raster/r.out.bin/main.c:460
+#, c-format
+msgid "c=%d"
+msgstr ""
+#: ../raster/r.surf.contour/main.c:64
+msgid "Generates surface raster map from rasterized contours."
+msgstr ""
+#: ../raster/r.surf.contour/main.c:67
+msgid "Name of input raster map containing contours"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:49
+msgid "VRML"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:51
+msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+msgstr ""
+#: ../raster/r.out.vrml/main.c:58
+msgid "Name of input color map"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:69
+msgid "Name for output VRML file"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:88
+#, c-format
+msgid "Range info for [%s] not available (run r.support)"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:97
+#, c-format
+msgid "Range info for <%s> not available (run r.support)"
+msgstr ""
+#: ../raster/r.out.vrml/main.c:129
+#, c-format
+msgid "Opening %s for writing... "
+msgstr ""
+#: ../raster/r.out.vrml/put_grid.c:38
+msgid "Writing vertices..."
+msgstr ""
+#: ../raster/r.out.vrml/put_grid.c:83
+msgid "Writing color file..."
+msgstr ""
+#: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
+#: ../imagery/i.his.rgb/main.c:47 ../imagery/i.rgb.his/main.c:47
+msgid "color transformation"
+msgstr ""
+#: ../raster/r.his/main.c:73
+msgid ""
+"Generates red, green and blue (RGB) raster map layers combining hue, "
+"intensity and saturation (HIS) values from user-specified input raster map "
+"layers."
+msgstr ""
+#: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
+msgid "Name of layer to be used for hue"
+msgstr ""
+#: ../raster/r.his/main.c:89 ../display/d.his/main.c:85
+msgid "Name of layer to be used for intensity"
+msgstr ""
+#: ../raster/r.his/main.c:96 ../display/d.his/main.c:92
+msgid "Name of layer to be used for saturation"
+msgstr ""
+#: ../raster/r.his/main.c:103
+msgid "Name of output layer to be used for red"
+msgstr ""
+#: ../raster/r.his/main.c:110
+msgid "Name of output layer to be used for green"
+msgstr ""
+#: ../raster/r.his/main.c:117
+msgid "Name of output layer to be used for blue"
+msgstr ""
+#: ../raster/r.his/main.c:145
+#, c-format
+msgid "No such color <%s>"
+msgstr ""
+#: ../raster/r.his/main.c:167 ../raster/r.his/main.c:183
+#: ../raster/r.his/main.c:201 ../raster/r.out.ppm3/main.c:115
+#: ../display/d.rast/display.c:23 ../display/d.rast.num/main.c:222
+#: ../display/d.histogram/main.c:171 ../display/d.his/main.c:139
+#: ../display/d.his/main.c:156 ../display/d.his/main.c:174
+#: ../display/d.rgb/main.c:99 ../display/d.legend/main.c:296
+#: ../display/d.legend/main.c:304 ../display/d.colortable/main.c:135
+#, c-format
+msgid "Color file for <%s> not available"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:89
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:96
+msgid "Name for output depressionless elevation raster map"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:100
+msgid ""
+"Name for output flow direction map for depressionless elevation raster map"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:105
+msgid "Name for output raster map of problem areas"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:112
+msgid "Aspect direction format"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:118
+msgid "Find unresolved areas only"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:124
+#, c-format
+msgid "The '%c' flag requires '%s'to be specified"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:145
+msgid "Direction map is D8 resolution, i.e. 45 degrees"
+msgstr ""
+#: ../raster/r.fill.dir/main.c:187
+msgid "Reading input elevation raster map..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:197
+msgid "Filling sinks..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:201
+msgid "Determining flow directions for ambiguous cases..."
+msgstr ""
+#: ../raster/r.fill.dir/main.c:214
+msgid "Repeat to get the final directions..."
+msgstr ""
+#: ../raster/r.fill.dir/wtrshed.c:95
+#, c-format
+msgid "Watershed pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/resolve.c:136
+#, c-format
+msgid "Downward pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/resolve.c:173
+#, c-format
+msgid "Upward pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/dopolys.c:84
+#, c-format
+msgid "Found %d unresolved area"
+msgid_plural "Found %d unresolved areas"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.relief/main.c:112
+msgid "Creates shaded relief map from an elevation map (DEM)."
+msgstr ""
+#: ../raster/r.relief/main.c:117
+msgid "Name for output shaded relief map"
+msgstr ""
+#: ../raster/r.relief/main.c:125
+msgid "Altitude of the sun in degrees above the horizon"
+msgstr ""
+#: ../raster/r.relief/main.c:126 ../raster/r.relief/main.c:136
+msgid "Sun position"
+msgstr ""
+#: ../raster/r.relief/main.c:135
+msgid "Azimuth of the sun in degrees to the east of north"
+msgstr ""
+#: ../raster/r.relief/main.c:143
+msgid "Factor for exaggerating relief"
+msgstr ""
+#: ../raster/r.relief/main.c:151
+msgid "Scale factor for converting meters to elevation units"
+msgstr ""
+#: ../raster/r.relief/main.c:158
+msgid "Elevation units (overrides scale factor)"
+msgstr ""
+#: ../raster/r.relief/main.c:163
+msgid "international feet"
+msgstr ""
+#: ../raster/r.relief/main.c:164
+msgid "survey feet"
+msgstr ""
+#: ../raster/r.relief/main.c:215
+#, c-format
+msgid "%s=%s - must not be zero"
+msgstr ""
+#: ../raster/r.relief/main.c:474
+#, c-format
+msgid "Shaded relief raster map <%s> complete"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:99
+msgid "The number of input and elevation maps is not equal"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:136 ../raster/r.to.rast3/main.c:59
+msgid "Could not close the map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:165
+msgid "The value to fill the upper cells, default is null"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:172
+msgid "The value to fill the lower cells, default is null"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:175 ../raster/r.to.rast3/main.c:84
+msgid "The maximum tile size in kilo bytes. Default is 32KB."
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:185
+msgid "Use the input map values to fill the upper cells"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:190
+msgid "Use the input map values to fill the lower cells"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
+msgid "Error writing 3D raster double data"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:366
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:400
+msgid "The upper value is not valid"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:410
+msgid "The lower value is not valid"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:427
+msgid ""
+"The 2D and 3D region settings are different. I will use the 3D region "
+"settings to adjust the 2D region."
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:443 ../raster/r.to.rast3/main.c:291
+msgid "Error opening 3D raster map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:457 ../raster/r.to.rast3/main.c:279
+msgid "Creating 3D raster map"
+msgstr ""
+#: ../raster/r.to.rast3elev/main.c:501 ../raster/r.to.rast3/main.c:326
+msgid "Error closing 3d raster map"
+msgstr ""
+#: ../raster/r.out.mat/main.c:64
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../raster/r.out.mat/main.c:73
+msgid "Name for output binary MAT file"
+msgstr ""
+#: ../raster/r.out.mat/main.c:113
+#, c-format
+msgid "Exporting <%s>"
+msgstr ""
+#: ../raster/r.out.mat/main.c:173
+msgid "Using the Current Region settings:"
+msgstr ""
+#: ../raster/r.out.mat/main.c:248
+msgid "Exporting raster as integer values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:253
+msgid "Exporting raster as floating point values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:258
+msgid "Exporting raster as double FP values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:301
+msgid "Reading in map ... "
+msgstr ""
+#: ../raster/r.out.mat/main.c:314
+msgid "Writing out map..."
+msgstr ""
+#: ../raster/r.out.mat/main.c:374
+#, c-format
+msgid "%ld bytes written to '%s'"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:53 ../raster/r.rescale/main.c:49
+msgid "rescale"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:55
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:61 ../raster/r.rescale/main.c:56
+msgid "The name of the raster map to be rescaled"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:69 ../raster/r.rescale/main.c:64
+msgid "The input data range to be rescaled (default: full range of input map)"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:67
+msgid "The resulting raster map name"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:74
+msgid "The output data range"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:86 ../raster/r.rescale/main.c:81
+msgid "Title for new raster map"
+msgstr ""
+#: ../raster/r.rescale.eq/main.c:115
+#, c-format
+msgid "Rescale %s[%d,%d] to %s[%d,%d]"
+msgstr ""
+#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:24
+#, c-format
+msgid "Reading %s ..."
+msgstr ""
+#: ../raster/r.recode/main.c:49
+msgid "recode categories"
+msgstr ""
+#: ../raster/r.recode/main.c:50
+msgid "Recodes categorical raster maps."
+msgstr ""
+#: ../raster/r.recode/main.c:53
+msgid "Name of raster map to be recoded"
+msgstr ""
+#: ../raster/r.recode/main.c:59
+msgid "File containing recode rules"
+msgstr ""
+#: ../raster/r.recode/main.c:70
+msgid "Align the current region to the input raster map"
+msgstr ""
+#: ../raster/r.recode/main.c:74
+msgid "Force output to 'double' raster map type (DCELL)"
+msgstr ""
+#: ../raster/r.recode/main.c:95
+#, c-format
+msgid "No rules specified. Raster map <%s> not created."
+msgstr ""
+#: ../raster/r.recode/read_rules.c:20
+#, c-format
+msgid "Unable to read f_range for map %s"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:146
+msgid "Data range is empty"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:30
+#, c-format
+msgid "Data range of %s is %s to %s (entire map)"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:35 ../raster/r.stats/main.c:358
+#, c-format
+msgid "Unable to read range for map <%s>"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:39
+#, c-format
+msgid "Integer data range of %s is empty"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:41
+#, c-format
+msgid "Integer data range of %s is %d to %d"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:61
+msgid "Enter the rule or 'help' for the format description"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:85
+msgid "Enter a rule in one of these formats:"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:87
+msgid "old_low:old_high:new_low:new_high"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:88
+msgid "old_low:old_high:new_val      (i.e. new_high == new_low)"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:89
+msgid "*:old_val:new_val             (interval [inf, old_val])"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:90
+msgid "old_val:*:new_val             (interval [old_val, inf])"
+msgstr ""
+#: ../raster/r.recode/read_rules.c:92
+msgid "When finished type \"end\"."
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:42
+msgid "Generates a raster map using gaussian random number generator."
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:44
+msgid ""
+"Mean and standard deviation of gaussian deviates can be expressed by the "
+"user."
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:51
+msgid "Distribution mean"
+msgstr ""
+#: ../raster/r.surf.gauss/main.c:57
+msgid "Standard deviation"
+msgstr ""
+#: ../raster/r.clump/main.c:53
+msgid "reclass"
+msgstr ""
+#: ../raster/r.clump/main.c:56
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+#: ../raster/r.clump/main.c:72
+msgid "Clump also diagonal cells"
+msgstr ""
+#: ../raster/r.clump/main.c:73
+msgid "Clumps are also traced along diagonal neighboring cells"
+msgstr ""
+#: ../raster/r.clump/main.c:77
+msgid "Print only the number of clumps in shell script style"
+msgstr ""
+#: ../raster/r.clump/main.c:122
+#, c-format
+msgid "%d clump."
+msgid_plural "%d clumps."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.clump/clump.c:72
+msgid "Unable to open temp file"
+msgstr ""
+#: ../raster/r.clump/clump.c:94
+msgid "Pass 1 of 2..."
+msgstr ""
+#: ../raster/r.clump/clump.c:207 ../raster/r.clump/clump.c:221
+msgid "Unable to write to temp file"
+msgstr ""
+#: ../raster/r.clump/clump.c:225
+msgid "Generating renumbering scheme..."
+msgstr ""
+#: ../raster/r.clump/clump.c:265
+msgid "Pass 2 of 2..."
+msgstr ""
+#: ../raster/r.clump/clump.c:271
+msgid "Unable to read from temp file"
+msgstr ""
+#: ../raster/r.drain/main.c:113
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
+msgstr ""
+#: ../raster/r.drain/main.c:116
+msgid "Name of input elevation or cost surface raster map"
+msgstr ""
+#: ../raster/r.drain/main.c:121
+msgid "Name of input movement direction map associated with the cost surface"
+msgstr ""
+#: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
+msgid "Cost surface"
+msgstr ""
+#: ../raster/r.drain/main.c:131
+msgid "Name for output drain vector map"
+msgstr ""
+#: ../raster/r.drain/main.c:132
+msgid "Recommended for cost surface made using knight's move"
+msgstr ""
+#: ../raster/r.drain/main.c:142
+msgid "Name of starting vector points map(s)"
+msgstr ""
+#: ../raster/r.drain/main.c:148
+msgid "Copy input cell values on output"
+msgstr ""
+#: ../raster/r.drain/main.c:152
+msgid "Accumulate input values along the path"
+msgstr ""
+#: ../raster/r.drain/main.c:153 ../raster/r.drain/main.c:158
+msgid "Path settings"
+msgstr ""
+#: ../raster/r.drain/main.c:157
+msgid "Count cell numbers along the path"
+msgstr ""
+#: ../raster/r.drain/main.c:163
+msgid ""
+"The input raster map is a cost surface (direction surface must also be "
+"specified)"
+msgstr ""
+#: ../raster/r.drain/main.c:175
+msgid "Directional drain selected... checking for direction raster map"
+msgstr ""
+#: ../raster/r.drain/main.c:178
+msgid "Surface/Hydrology drain selected"
+msgstr ""
+#: ../raster/r.drain/main.c:183
+#, c-format
+msgid ""
+"Direction raster map <%s> not specified, if direction flag is on, a "
+"direction raster must be given"
+msgstr ""
+#: ../raster/r.drain/main.c:190
+#, c-format
+msgid ""
+"Direction raster map <%s> should not be specified for Surface/Hydrology "
+"drains"
+msgstr ""
+#: ../raster/r.drain/main.c:209
+msgid "Specify just one of the -c, -a and -n flags"
+msgstr ""
+#: ../raster/r.drain/main.c:240
+#, c-format
+msgid "Starting point %d is outside the current region"
+msgstr ""
+#: ../raster/r.drain/main.c:315
+#, c-format
+msgid "Starting vector map <%s> contains no points in the current region"
+msgstr ""
+#: ../raster/r.drain/main.c:323
+msgid "No start/stop point(s) specified"
+msgstr ""
+#: ../raster/r.drain/main.c:398
+msgid "Calculating flow directions..."
+msgstr ""
+#: ../raster/r.drain/main.c:467
+msgid "Writing output raster map..."
+msgstr ""
+#: ../raster/r.drain/main.c:519 ../raster/r.composite/main.c:191
+#: ../raster/r.random.surface/save.c:98 ../raster/r.random.cells/indep.c:134
+#: ../imagery/i.ifft/main.c:207
+#, c-format
+msgid "Writing raster map <%s>..."
+msgstr ""
+#: ../raster/r.drain/main.c:689
+#, c-format
+msgid "direction read: %lf, neighbour found: %i"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:66
+msgid "Creates watershed basins from a drainage direction map."
+msgstr ""
+#: ../raster/r.water.outlet/main.c:69 ../raster/r.watershed/front/main.c:74
+#: ../raster/r.basins.fill/main.c:56
+msgid "watershed"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:72
+msgid "Name of input drainage direction map"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:75
+msgid "Name for output watershed basin map"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:78
+msgid "Coordinates of outlet point"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:91
+#, c-format
+msgid "Illegal east coordinate '%s'"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:93
+#, c-format
+msgid "Illegal north coordinate '%s'"
+msgstr ""
+#: ../raster/r.water.outlet/main.c:98
+#, c-format
+msgid "Ignoring point outside computation region: %.4f,%.4f"
+msgstr ""
+#: ../raster/r.stats/main.c:109
+msgid "Generates area statistics for raster map."
+msgstr ""
+#: ../raster/r.stats/main.c:157
+msgid "Print area totals in square meters"
+msgstr ""
+#: ../raster/r.stats/main.c:162
+msgid "Print cell counts (sortable)"
+msgstr ""
+#: ../raster/r.stats/main.c:168
+msgid "Print approximate (total percent may not be 100%) percents"
+msgstr ""
+#: ../raster/r.stats/main.c:173
+msgid "Print category labels"
+msgstr ""
+#: ../raster/r.stats/main.c:177
+msgid "One cell (range) per line"
+msgstr ""
+#: ../raster/r.stats/main.c:181
+msgid "Print grid coordinates (east and north)"
+msgstr ""
+#: ../raster/r.stats/main.c:182 ../raster/r.stats/main.c:187
+msgid "Coordinates"
+msgstr ""
+#: ../raster/r.stats/main.c:186
+msgid "Print x and y (column and row)"
+msgstr ""
+#: ../raster/r.stats/main.c:191
+msgid "Print averaged values instead of intervals (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:196
+msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:233
+#, c-format
+msgid "'%s' must be greater than zero; using %s=255"
+msgstr ""
+#: ../raster/r.stats/main.c:303
+#, c-format
+msgid ""
+"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
+"will be ignored."
+msgstr ""
+#: ../raster/r.stats/main.c:319
+#, c-format
+msgid ""
+"Cats for raster map <%s> are either missing or have no explicit labels. "
+"Using %s=%d."
+msgstr ""
+#: ../raster/r.stats/main.c:325
+#, c-format
+msgid ""
+"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
+"option"
+msgstr ""
+#: ../raster/r.stats/main.c:331 ../raster/r.contour/main.c:149
+#, c-format
+msgid "Unable to read fp range of raster map <%s>"
+msgstr ""
+#: ../raster/r.stats/raw_stats.c:118
+msgid "Invalid map type"
+msgstr ""
+#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
+#: ../raster/r.watershed/seg/main.c:90 ../raster/r.watershed/seg/main.c:105
+#, c-format
+msgid "SECTION %d: Closing Maps."
+msgstr ""
+#: ../raster/r.watershed/ram/main.c:96 ../raster/r.watershed/seg/main.c:103
+#, c-format
+msgid "SECTION %d: Watershed determination."
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:118
+#, c-format
+msgid "SECTION 1a (of %1d): Initiating Memory."
+msgstr ""
+#: ../raster/r.watershed/ram/init_vars.c:299
+#, c-format
+msgid "SECTION 1b (of %1d): Determining Offmap Flow."
+msgstr ""
+#: ../raster/r.watershed/ram/sg_factor.c:14
+msgid "SECTION 4: RUSLE LS and/or S factor determination."
+msgstr ""
+#: ../raster/r.watershed/ram/usage.c:9 ../raster/r.watershed/seg/usage.c:9
+#, c-format
+msgid ""
+"USAGE for basin delineation:\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold "
+"[flow=overland_flow_map] [drainage=drain_direction_map] "
+"[depression=depression_map] [accumulation=accumulation_map] "
+"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"\n"
+"USAGE for slope length determination:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold "
+"[drainage=drain_direction_map] [depression=depression_map] "
+"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
+"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
+"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
+"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
+"creation:\n"
+"[basin=watershed_basin_map] [stream=stream_segment_map] "
+"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"\n"
+msgstr ""
+#: ../raster/r.watershed/ram/close_maps2.c:34
+#: ../raster/r.watershed/seg/close_maps2.c:38
+msgid "No basins were created. Verify threshold and region settings."
+msgstr ""
+#: ../raster/r.watershed/ram/do_astar.c:27
+#: ../raster/r.watershed/seg/do_astar.c:30
+msgid "SECTION 2: A* Search."
+msgstr ""
+#: ../raster/r.watershed/ram/do_astar.c:254
+msgid "heapsize too large"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:56
+msgid "Beautify flat areas: priority queue error"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:229
+msgid "flat cell escaped for uphill correction"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:235
+#, c-format
+msgid "queue error: last uphill order %d > current uphill order %d"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:240
+msgid "uphill order not set"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:266
+msgid "flat cell escaped in uphill correction"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:302
+msgid "downhill order: no more points in down queue"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:310
+msgid "flat cell escaped for downhill correction"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:316
+#, c-format
+msgid "queue error: last downhill order %d > current downhill order %d"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:321
+msgid "downhill order: downhill order not set"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:344
+msgid "flat cell escaped in downhill correction"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:382
+msgid "flat cell escaped for adjustment"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:389
+msgid "adjustment: uphill order not set"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:391
+msgid "adjustment: downhill order not set"
+msgstr ""
+#: ../raster/r.watershed/ram/do_flatarea.c:417
+msgid "flat cell escaped in adjustment"
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:114
+#: ../raster/r.watershed/seg/do_cum.c:118
+msgid "SECTION 3: Accumulating Surface Flow with SFD."
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:272
+#: ../raster/r.watershed/seg/do_cum.c:283
+msgid "SECTION 3a: Accumulating Surface Flow with MFD."
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:437
+#: ../raster/r.watershed/seg/do_cum.c:473
+#: ../raster/r.stream.extract/streams.c:336
+#, c-format
+msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
+msgstr ""
+#: ../raster/r.watershed/ram/do_cum.c:474
+#, c-format
+msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
+msgid_plural ""
+"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.watershed/ram/do_cum.c:480
+#: ../raster/r.watershed/seg/do_cum.c:521
+msgid "SECTION 3b: Adjusting drainage directions."
+msgstr ""
+#: ../raster/r.watershed/shed/file_in.c:15
+msgid "unable to open ARMSED file"
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:41
+msgid "Slow version of water analysis program starting now"
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
+#, c-format
+msgid "<<%s>> command line failed"
+msgstr ""
+#: ../raster/r.watershed/shed/main.c:72
+msgid "unable to open output file"
+msgstr ""
+#: ../raster/r.watershed/shed/valid.c:24
+msgid "accum file missing in valid_basins()"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:12
+msgid ""
+"\n"
+"\n"
+"Please indicate which map layers you wish to use in the lumped"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:13
+msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:14
+msgid "layers, one at a time, until all desired map layers are in."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:15
+#, c-format
+msgid "You can have %s include a list of categories in each."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:17
+#, c-format
+msgid ""
+"\n"
+"Hit <return> at the map prompt to continue with %s"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:36
+#, c-format
+msgid ""
+"\n"
+"The output from %s will be divided into watershed"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:38
+msgid "basins.  There are two possible methods of tabulating the information:"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:39
+msgid "1) by only including data pertaining to the basin itself, or 2) using"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:40
+msgid "data from the basin, and all basins upstream of it."
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:43
+msgid ""
+"\n"
+"Would you like the data organized:"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:44
+msgid ""
+"1) Basin only\n"
+"2) Upstream only\n"
+"3) Both\n"
+"OR 0) to cancel program"
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:45
+#, c-format
+msgid ""
+"\n"
+"Your choice: "
+msgstr ""
+#: ../raster/r.watershed/shed/basin_maps.c:69
+#: ../raster/r.watershed/shed/basin_maps.c:73
+#, c-format
+msgid ""
+"\n"
+"OK, %s should start running now using the following form:\n"
+"%s"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:8
+#, c-format
+msgid "%s provides a text-based user-interface to the %s program."
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:10
+#, c-format
+msgid "%s also allows the user to prepare a report of map layers for each"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:12
+#, c-format
+msgid "watershed basin determined in %s.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:14
+#, c-format
+msgid "%s will help the user determine which options to use for the"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:16
+#, c-format
+msgid "%s program.  %s will then ask for map layers that will be"
+msgstr ""
+#: ../raster/r.watershed/shed/intro.c:18
+#, c-format
+msgid "divided by basin. %s will then run %s and create the report."
+msgstr ""
+#: ../raster/r.watershed/shed/read.c:23
+msgid "unable to open basin/half basin map"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:23
+msgid ""
+"\n"
+"This set of questions will organize the command line for the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:24
+#, c-format
+msgid "%s program to run properly for your application."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:26
+#, c-format
+msgid "The first question is whether you want %s to run"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:28
+#, c-format
+msgid "in its fast mode or its slow mode.  If you run %s"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:30
+msgid "in the fast mode, the computer will finish about 10 times faster"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:31
+msgid "than in the slow mode, but will not allow other programs to run"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:32
+msgid "at the same time.  The fast mode also places all of the data into"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:33
+msgid "RAM, which limits the size of window that can be run.  The slow"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:34
+msgid "mode uses disk space in the same hard disk partition as where GRASS is"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:35
+msgid "stored.  Thus, if the program does not work in the slow mode, you will"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:36
+msgid "need to remove unnecessary files from that partition.  The slow mode"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:37
+#, c-format
+msgid "will allow other processes to run concurrently with %s.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:69
+#: ../raster/r.watershed/shed/com_line.c:182
+msgid ""
+"\n"
+"If you hit <return> by itself for the next question, this"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:70
+#: ../raster/r.watershed/shed/com_line.c:183
+msgid "program will terminate."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:81
+#, c-format
+msgid ""
+"\n"
+"One of the options for %s is a `depression map'.  A"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:83
+msgid ""
+"depression map indicates all the locations in the current map window where"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:84
+msgid ""
+"water accumulates and does not leave by the edge of the map. Lakes without"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:85
+msgid ""
+"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:86
+msgid "have a depression map, prepare a map where non-zero values indicate the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:87
+msgid "locations where depressions occur.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:88
+msgid ""
+"Hit <return> by itself for the next question if there is no depression map."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:99
+#, c-format
+msgid ""
+"\n"
+"The %s program will divide the elevation map into a number of"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:101
+msgid ""
+"watershed basins.  The number of watershed basins is indirectly determined"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:102
+msgid ""
+"by the `basin threshold' value.  The basin threshold is the area necessary "
+"for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:103
+#, c-format
+msgid "%s to define a unique watershed basin.  This area only applies to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:105
+msgid ""
+"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:106
+msgid ""
+"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:107
+msgid ""
+"by the surface flow going into stream segments between stream interceptions."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:108
+#, c-format
+msgid "Thus interior drainage basins can be of any size.  The %s program"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:110
+msgid "also allows the user to relate basin size to potential overland flow"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:111
+msgid ""
+"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:112
+msgid ""
+"develop stream channels than neighboring areas with high infiltration rates)."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:113
+msgid ""
+"The user can create a map layer with potential overland flow values, and"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:114
+#, c-format
+msgid "%s will accumulate those values instead of area.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:116
+msgid "What unit of measure will you use for the basin threshold:"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:119
+msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:120
+msgid " 5) kilometers sq., 6) map cells,  7) overland flow units"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:121
+#, c-format
+msgid "Choose 1-7 or 0 to exit this program: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:131
+msgid ""
+"\n"
+"How large an area (or how many overland flow units) must a drainage basin"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:132
+#, c-format
+msgid "be for it to be an exterior drainage basin: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:201
+#, c-format
+msgid ""
+"\n"
+"%s must create a map layer of watershed basins"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:203
+#: ../raster/r.watershed/shed/com_line.c:224
+#, c-format
+msgid "before %s can run properly."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:222
+#, c-format
+msgid ""
+"\n"
+"%s must create a file of watershed basin relationships"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:228
+#: ../raster/r.watershed/shed/com_line.c:263
+#, c-format
+msgid ""
+"\n"
+"Please name this file:"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:257
+#, c-format
+msgid ""
+"\n"
+"%s will generate a lot of output.  Indicate a file"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:259
+#, c-format
+msgid "name for %s to send the output to."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:277
+#, c-format
+msgid ""
+"\n"
+"The accumulation map from %s must be present for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:279
+#, c-format
+msgid "%s to work properly."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:290
+#, c-format
+msgid ""
+"\n"
+"%s can produce several maps not necessary for"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:292
+#, c-format
+msgid "%s to function (stream channels, overland flow aspect, and"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:294
+#, c-format
+msgid "a display version of the accumulation map).  %s also has the"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:296
+msgid ""
+"ability to generate several variables in the Revised Universal Soil Loss"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:297
+msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:348
+msgid ""
+"\n"
+"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:349
+#, c-format
+msgid "disturbed land.  %s reflects this with an optional map layer or value"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:351
+msgid ""
+"where the value indicates the percent of disturbed (barren) land in that "
+"cell."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:352
+msgid "Type <return> if you do not have a disturbed land map layer."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:364
+msgid ""
+"\n"
+"Type the value indicating the percent of disturbed land.  This value will"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:365
+msgid "be used for every cell in the current region."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:368
+#, c-format
+msgid ""
+"\n"
+"Input value here [0-100]: "
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:379
+msgid ""
+"\n"
+"Overland surface flow only occurs for a set distance before swales form."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:380
+#, c-format
+msgid "Because of digital terrain model limitations, %s cannot pick up"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:382
+#, c-format
+msgid "these swales.  %s allows for an input (warning: kludge factor)"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:384
+msgid ""
+"that prevents the surface flow distance from getting too long.  Normally,"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:385
+msgid "maximum slope length is around 600 feet (about 183 meters)."
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:400
+msgid ""
+"\n"
+"Roads, ditches, changes in ground cover, and other factors will stop"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:401
+msgid ""
+"slope length.  You may input a raster map indicating the locations of these"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:402
+msgid "blocking factors.\n"
+msgstr ""
+#: ../raster/r.watershed/shed/com_line.c:403
+msgid ""
+"Hit <return> by itself for the next question if there is no blocking map."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:75
+msgid "Calculates hydrological parameters and RUSLE factors."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:78 ../raster/r.watershed/front/main.c:85
+#: ../raster/r.watershed/front/main.c:91 ../raster/r.watershed/front/main.c:98
+#: ../raster/r.watershed/front/main.c:107
+#: ../raster/r.watershed/front/main.c:115
+#: ../raster/r.watershed/front/main.c:124
+msgid "Inputs"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:82
+msgid "Name of input depressions raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:83
+msgid "All non-NULL and non-zero cells are considered as real depressions"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:89
+msgid "Name of input raster representing amount of overland flow per cell"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:95
+msgid "Name of input raster map percent of disturbed land"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:96
+#: ../raster/r.watershed/front/main.c:121
+msgid "For USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:103
+msgid "Name of input raster map blocking overland surface flow"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:105
+msgid ""
+"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:112
+msgid "Minimum size of exterior watershed basin"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:120
+msgid "Maximum length of surface flow in map units"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:129
+msgid "Name for output accumulation raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:131
+msgid "Number of cells that drain through each cell"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:138
+msgid "Name for output topographic index ln(a / tan(b)) map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:144
+msgid "Name for output drainage direction raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:150
+msgid "Name for output basins raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:156
+msgid "Name for output stream segments raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:162
+msgid "Name for output half basins raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:164
+msgid "Each half-basin is given a unique value"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:170
+msgid "Name for output slope length raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:172
+msgid "Slope length and steepness (LS) factor for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:178
+msgid "Name for output slope steepness raster map"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:179
+msgid "Slope steepness (S) factor for USLE"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:188
+msgid "Convergence factor for MFD (1-10)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:190
+msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:197
+msgid "Maximum memory to be used with -m flag (in MB)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:201
+msgid "SFD (D8) flow (default is MFD)"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:203
+msgid "SFD: single flow direction, MFD: multiple flow direction"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:208
+msgid "Allow only horizontal and vertical flow of water"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:213
+msgid "Enable disk swap memory option: Operation is slow"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:215
+msgid ""
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:220
+msgid "Use positive flow accumulation even for likely underestimates"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:222
+msgid "See manual for a detailed description of flow accumulation output"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:227
+msgid "Beautify flat areas"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:229
+msgid "Flow direction in flat areas is modified to look prettier"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:245
+msgid "Sorry, you must choose an output map."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:251
+msgid "The basin threshold must be a positive number."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:267
+msgid ""
+"Sorry, if any of the following options are set:\n"
+"    basin, stream, half_basin, length_slope, or slope_steepness\n"
+"    you MUST provide a value for the basin threshold parameter."
+msgstr ""
+#: ../raster/r.watershed/front/main.c:294
+msgid "Beautify flat areas is not yet supported for disk swap mode"
+msgstr ""
+#: ../raster/r.watershed/front/main.c:321
+#, c-format
+msgid "Subprocess failed with exit code %d"
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:132
+#, c-format
+msgid "SECTION 1 beginning: Initiating Variables. %d section total."
+msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.watershed/seg/init_vars.c:168
+msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:245
+#: ../raster/r.stream.extract/main.c:319
+#, c-format
+msgid "Will need up to %.2f MB of disk space"
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:247
+#: ../raster/r.stream.extract/main.c:321
+#, c-format
+msgid "Will need up to %.2f GB (%.0f MB) of disk space"
+msgstr ""
+#: ../raster/r.watershed/seg/init_vars.c:457
+msgid "SECTION 1b: Determining Offmap Flow."
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:20
+msgid "Closing accumulation map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:132
+msgid "Closing TCI map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:214
+msgid "Closing flow direction map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:241
+msgid "Closing LS map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:246
+msgid "Closing SL map"
+msgstr ""
+#: ../raster/r.watershed/seg/sg_factor.c:14
+msgid "SECTION 5: RUSLE LS and/or S factor determination."
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:86
+msgid "Closing stream segments map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:109
+msgid "Closing basins map"
+msgstr ""
+#: ../raster/r.watershed/seg/close_maps2.c:116
+msgid "Closing half basins map"
+msgstr ""
+#: ../raster/r.watershed/seg/do_astar.c:48
+msgid "No seeds for A* Search"
+msgstr ""
+#: ../raster/r.watershed/seg/do_astar.c:146
+msgid "bug in A* Search: doer %"
+msgstr ""
+#: ../raster/r.watershed/seg/do_cum.c:517
+msgid "MFD: A * path already processed when distributing flow: %d of %"
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:257 ../raster/r.resamp.interp/main.c:77
+#: ../raster/r.resample/main.c:55 ../raster/r.resamp.bspline/main.c:82
+#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resamp.rst/main.c:149
+msgid "resample"
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:259
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:269
+msgid "Aggregation method"
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:287
+msgid "Weight according to area (slower)"
+msgstr ""
+#: ../raster/r.resamp.stats/main.c:370 ../raster/r.resamp.interp/main.c:353
+#: ../raster/r.tile/main.c:200 ../raster/r.resamp.filter/main.c:556
+#, c-format
+msgid "Unable to read color table for %s"
+msgstr ""
+#: ../raster/r.surf.area/main.c:79
+msgid "area estimation"
+msgstr ""
+#: ../raster/r.surf.area/main.c:80
+msgid "Prints estimation of surface area for raster map."
+msgstr ""
+#: ../raster/r.surf.area/main.c:89
+msgid "Vertical scale"
+msgstr ""
+#: ../raster/r.surf.area/main.c:93
+msgid "Output units"
+msgstr ""
+#: ../raster/r.surf.area/main.c:94
+msgid "Default: square map units"
+msgstr ""
+#: ../raster/r.surf.area/main.c:102
+#, c-format
+msgid "Output in '%s'"
+msgstr ""
+#: ../raster/r.surf.area/main.c:106
+msgid "Output in 'square map units'"
+msgstr ""
+#: ../raster/r.surf.area/main.c:153
+msgid "Null value area ignored in calculation:"
+msgstr ""
+#: ../raster/r.surf.area/main.c:155
+msgid "Plan area used in calculation:"
+msgstr ""
+#: ../raster/r.surf.area/main.c:158
+msgid "Surface area calculation(low, high, avg):"
+msgstr ""
+#: ../raster/r.surf.area/main.c:163
+msgid "Current region plan area:"
+msgstr ""
+#: ../raster/r.surf.area/main.c:165
+msgid "Estimated region Surface Area:"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:61
+msgid "Matrix is unsolvable"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:131
+msgid "Calculates multiple linear regression from raster maps."
+msgstr ""
+#: ../raster/r.regression.multi/main.c:145
+msgid "Map to store residuals"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:150
+msgid "Map to store estimates"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:248
+msgid "First pass..."
+msgstr ""
+#: ../raster/r.regression.multi/main.c:321
+msgid "Not enough valid cells available"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:335
+msgid "Multiple regression failed"
+msgstr ""
+#: ../raster/r.regression.multi/main.c:340
+msgid "Second pass..."
+msgstr ""
+#: ../raster/r.carve/raster.c:13 ../raster/r.texture/main.c:288
+#: ../imagery/i.zc/main.c:152
+msgid "Reading raster map..."
+msgstr ""
+#: ../raster/r.carve/main.c:76
+msgid "Generates stream channels."
+msgstr ""
+#: ../raster/r.carve/main.c:77
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
+msgstr ""
+#: ../raster/r.carve/main.c:82
+msgid "Name of input raster elevation map"
+msgstr ""
+#: ../raster/r.carve/main.c:87
+msgid "Name of input vector map containing stream(s)"
+msgstr ""
+#: ../raster/r.carve/main.c:95
+msgid "Name for output vector map for adjusted stream points"
+msgstr ""
+#: ../raster/r.carve/main.c:100
+msgid "Stream width (in meters)"
+msgstr ""
+#: ../raster/r.carve/main.c:101
+msgid "Default is raster cell width"
+msgstr ""
+#: ../raster/r.carve/main.c:106
+msgid "Additional stream depth (in meters)"
+msgstr ""
+#: ../raster/r.carve/main.c:110
+msgid "No flat areas allowed in flow direction"
+msgstr ""
+#: ../raster/r.carve/main.c:134
+#, c-format
+msgid "Invalid width value '%s' - using default."
+msgstr ""
+#: ../raster/r.carve/main.c:148
+#, c-format
+msgid "Invalid depth value '%s' - using default."
+msgstr ""
+#: ../raster/r.carve/main.c:213 ../raster/r.solute.transport/main.c:244
+#: ../raster/r.topidx/main.c:55 ../raster/r.gwflow/main.c:222
+#, c-format
+msgid "Lat/Long location is not supported by %s. Please reproject map first."
+msgstr ""
+#: ../raster/r.carve/enforce_ds.c:82
+msgid "Processing lines... "
+msgstr ""
+#: ../raster/r.carve/enforce_ds.c:174
+msgid ""
+"Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr ""
+#: ../raster/r.carve/lobf.c:74
+msgid "trying to divide by zero...no unique solution for system...skipping..."
+msgstr ""
+#: ../raster/r.mfilter/main.c:60
+msgid "Performs raster map matrix filter."
+msgstr ""
+#: ../raster/r.mfilter/main.c:71
+msgid "Path to filter file"
+msgstr ""
+#: ../raster/r.mfilter/main.c:79
+msgid "Number of times to repeat the filter"
+msgstr ""
+#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
+#: ../imagery/i.pca/main.c:109 ../imagery/i.pca/main.c:120
+msgid "Filter"
+msgstr ""
+#: ../raster/r.mfilter/main.c:86
+msgid "Output raster map title"
+msgstr ""
+#: ../raster/r.mfilter/main.c:98
+msgid "Apply filter only to null data values"
+msgstr ""
+#: ../raster/r.mfilter/main.c:125
+msgid "Raster map too small for the size of the filter"
+msgstr ""
+#: ../raster/r.mfilter/getrow.c:23
+msgid "Error reading temporary file"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:27
+#, c-format
+msgid "Cannot open filter file '%s'"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:47
+msgid "Illegal filter matrix size specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:50
+msgid "Even filter matrix size specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:72
+msgid "Illegal filter matrix"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
+#: ../raster/r.mfilter/getfilt.c:124
+msgid "Filter file format error"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:83
+msgid "Duplicate filter divisor specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:101
+msgid "Illegal divisor matrix"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:110
+msgid "Duplicate filter type specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:117
+msgid "Illegal filter type specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:127
+msgid "Duplicate filter start specified"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:135
+#, c-format
+msgid "Filter start %s ignored, using UL"
+msgstr ""
+#: ../raster/r.mfilter/getfilt.c:157
+msgid "Illegal filter file format"
+msgstr ""
+#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
+msgid "Unable to create temporary file"
+msgstr ""
+#: ../raster/r.mfilter/perform.c:81
+#, c-format
+msgid "Writing raster map <%s>"
+msgstr ""
+#: ../raster/r.colors/rules.c:40
+#, c-format
+msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:49
+#, c-format
+msgid "fp: Data range is %s to %s\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:53
+#, c-format
+msgid "Data range is %ld to %ld\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:64
+#, c-format
+msgid ""
+"Your color rules do not cover the whole range of data!\n"
+" (rules %f to %f but data %f to %f)"
+msgstr ""
+#: ../raster/r.colors/rules.c:105
+#, c-format
+msgid " val color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:106
+#, c-format
+msgid " n%% color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:107
+#, c-format
+msgid " nv color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:108
+#, c-format
+msgid " default color\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:109
+#, c-format
+msgid "color can be one of:\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:111
+#, c-format
+msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:132
+#, c-format
+msgid "bad rule (%s); rule not added"
+msgstr ""
+#: ../raster/r.colors/rules.c:134
+#, c-format
+msgid "bad rule (%s): [%s]"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:61
+msgid "Creates/modifies the color table associated with a 3D raster map."
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:65
+msgid "Creates/modifies the color table associated with a raster map."
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
+msgid "Map"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:81
+msgid "Input file with one map name per line"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:83
+msgid ""
+"Input map names can be defined in an input file in case a large amount of "
+"maps must be specified. This option is mutual exclusive to the map option."
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:229 ../raster/r.colors/edit_colors.c:262
+#, c-format
+msgid "%s map <%s> not found"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:235
+#, c-format
+msgid "No %s map name found in input file <%s>"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:278
+#, c-format
+msgid "Unable to remove color table of %s map <%s>"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:280
+#, c-format
+msgid "Color table of %s map <%s> not found"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:302
+#, c-format
+msgid "Color table exists for %s map <%s>. Exiting."
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:358
+#, c-format
+msgid "Color table 'random' is not supported for floating point %s map"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:362
+#, c-format
+msgid "Color table 'grey.eq' is not supported for floating point %s map"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:368
+#, c-format
+msgid "Color table 'grey.log' is not supported for floating point %s map"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:376
+#, c-format
+msgid "Unknown color request '%s'"
+msgstr ""
+#: ../raster/r.colors/edit_colors.c:447
+#, c-format
+msgid "Color table for %s map <%s> set to '%s'"
+msgstr ""
+#: ../raster/r.colors/stats.c:39
+#, c-format
+msgid "(%i/%i) Reading raster map <%s>..."
+msgstr ""
+#: ../raster/r.colors/stats.c:73
+msgid "Unable to use logarithmic scaling if range includes zero"
+msgstr ""
+#: ../raster/r.colors/stats.c:118
+msgid "Error opening 3d raster map"
+msgstr ""
+#: ../raster/r.colors/stats.c:125
+#, c-format
+msgid "(%i/%i) Reading map <%s>..."
+msgstr ""
+#: ../raster/r.usler/main.c:54
+msgid "rainfall"
+msgstr ""
+#: ../raster/r.usler/main.c:55 ../raster/r.uslek/main.c:55
+#: ../raster/r.sim/r.sim.sediment/main.c:111
+#: ../raster/r.sim/r.sim.water/main.c:111
+msgid "soil"
+msgstr ""
+#: ../raster/r.usler/main.c:56 ../raster/r.uslek/main.c:56
+#: ../raster/r.sim/r.sim.sediment/main.c:113
+msgid "erosion"
+msgstr ""
+#: ../raster/r.usler/main.c:57
+msgid "Computes USLE R factor, Rainfall erosivity index."
+msgstr ""
+#: ../raster/r.usler/main.c:60
+msgid "Name of annual precipitation raster map [mm/year]"
+msgstr ""
+#: ../raster/r.usler/main.c:63
+msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
+msgstr ""
+#: ../raster/r.usler/main.c:70
+msgid "Name of USLE R equation"
+msgstr ""
+#: ../raster/r.usler/main.c:75
+msgid "Roosle (1975)"
+msgstr ""
+#: ../raster/r.usler/main.c:76
+msgid "Morgan (1974)"
+msgstr ""
+#: ../raster/r.usler/main.c:77
+msgid "Foster (1981)"
+msgstr ""
+#: ../raster/r.usler/main.c:78
+msgid "El-Swaify (1985)"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:62
+msgid "Converts raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../raster/r.out.vtk/main.c:73
+msgid ""
+"No input maps specified. You need to specify at least one input map or three "
+"vector maps or three rgb maps."
+msgstr ""
+#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
+#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
+#, c-format
+msgid "Open Raster file %s"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:222
+msgid "Writing VTK ImageData\n"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:232
+msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:261
+msgid "Writing VTK Vector Data\n"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:271
+msgid ""
+"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr ""
+#: ../raster/r.out.vtk/main.c:283
+msgid "Error closing VTK-ASCII file"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:75
+msgid "write_vtk_normal_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:108
+msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:124
+msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:139
+msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:148
+msgid "writeVTKPointHeader: Writing VTK-DataHeader"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:169
+msgid "write_vtk_structured_coordinates: Writing Coordinates"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:225
+msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:334
+msgid "write_vtk_data: Writing VTK-Data"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:384
+msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:412
+msgid "Wrong map values! Values should in between 0 and 255!\n"
+msgstr ""
+#: ../raster/r.out.vtk/writeascii.c:442
+msgid "write_vtk_vector_data: Writing VTK-vector data"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:32
+msgid "Raster map(s) to be converted to VTK-ASCII data format"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:53
+msgid "Constant elevation (if no elevation map is specified)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:69
+msgid ""
+"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:79
+msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:104
+msgid "Use structured grid for elevation (not recommended)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:110
+msgid "Use polydata-trianglestrips for elevation grid creation"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:116
+msgid ""
+"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr ""
+#: ../raster/r.out.vtk/parameters.c:122
+msgid "Scale factor affects the origin (if no elevation map is given)"
+msgstr ""
+#: ../raster/r.composite/main.c:76
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+#: ../raster/r.composite/main.c:90 ../raster/r.out.ppm3/main.c:64
+#: ../display/d.rgb/main.c:69
+#, c-format
+msgid "Name of raster map to be used for <%s>"
+msgstr ""
+#: ../raster/r.composite/main.c:102
+msgid "Number of levels to be used for each component"
+msgstr ""
+#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
+msgid "Levels"
+msgstr ""
+#: ../raster/r.composite/main.c:118
+#, c-format
+msgid "Number of levels to be used for <%s>"
+msgstr ""
+#: ../raster/r.composite/main.c:128
+msgid "Dither"
+msgstr ""
+#: ../raster/r.composite/main.c:132
+msgid "Use closest color"
+msgstr ""
+#: ../raster/r.composite/main.c:164
+#, c-format
+msgid "Unable to read color file of raster map <%s>"
+msgstr ""
+#: ../raster/r.composite/main.c:286
+msgid "Creating color table for output raster map..."
+msgstr ""
+#: ../raster/r.external.out/main.c:38
+#, c-format
+msgid "Supported Formats:\n"
+msgstr ""
+#: ../raster/r.external.out/main.c:132
+msgid "Unable to open GDAL file"
+msgstr ""
+#: ../raster/r.external.out/main.c:162
+#, c-format
+msgid "Format <%s> does not support direct write"
+msgstr ""
+#: ../raster/r.external.out/main.c:214
+msgid "Unable to create GDAL file"
+msgstr ""
+#: ../raster/r.external.out/main.c:217
+msgid "Error writing GDAL file"
+msgstr ""
+#: ../raster/r.external.out/main.c:240
+msgid "Defines raster output format utilizing GDAL library."
+msgstr ""
+#: ../raster/r.external.out/main.c:244
+msgid "Name of output directory"
+msgstr ""
+#: ../raster/r.external.out/main.c:251
+msgid "Extension for output files"
+msgstr ""
+#: ../raster/r.external.out/main.c:257
+msgid "Format of output files"
+msgstr ""
+#: ../raster/r.external.out/main.c:277
+msgid "Cease using GDAL and revert to native output"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:92
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+#: ../raster/r.spreadpath/main.c:98
+msgid "Name of raster map containing back-path easting information"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:103
+msgid "Name of raster map containing back-path northing information"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:108
+msgid "The map E and N grid coordinates of starting points"
+msgstr ""
+#: ../raster/r.spreadpath/main.c:161
+#, c-format
+msgid "eading the input map -%s- and -%s- and creating some temporary files..."
+msgstr ""
+#: ../raster/r.spreadpath/main.c:281
+msgid "Finding the least cost paths ..."
+msgstr ""
+#: ../raster/r.spreadpath/main.c:296
+#, c-format
+msgid "Writing the output map  -%s-..."
+msgstr ""
+#: ../raster/r.cross/main.c:72
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../raster/r.cross/main.c:81
+#, c-format
+msgid "Names of 2-%d input raster maps"
+msgstr ""
+#: ../raster/r.cross/main.c:90
+msgid "Non-zero data only"
+msgstr ""
+#: ../raster/r.cross/main.c:103
+#, c-format
+msgid "More than %d files not allowed"
+msgstr ""
+#: ../raster/r.cross/main.c:119
+msgid "Must specify 2 or more input maps"
+msgstr ""
+#: ../raster/r.cross/main.c:136
+#, c-format
+msgid "%s: STEP 2 ..."
+msgstr ""
+#: ../raster/r.cross/main.c:179
+#, c-format
+msgid "%ld categories"
+msgstr ""
+#: ../raster/r.cross/renumber.c:33
+#, c-format
+msgid "%s: STEP 3 ... "
+msgstr ""
+#: ../raster/r.cross/cross.c:65
+#, c-format
+msgid "%s: STEP 1 ... "
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:37
+msgid "3D Raster map used for zoning, must be of type CELL"
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:67
+#: ../raster/r.univar/r.univar_main.c:71
+msgid "Table output format instead of standard output format"
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:103
+msgid ""
+"Calculates univariate statistics from the non-null cells of a 3D raster map."
+msgstr ""
+#: ../raster/r.univar/r3.univar_main.c:105
+#: ../raster/r.univar/r.univar_main.c:108
+msgid ""
+"Statistics include number of cells counted, minimum and maximum cell values, "
+"range, arithmetic mean, population variance, standard deviation, coefficient "
+"of variation, and sum."
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:36
+msgid "Raster map used for zoning, must be of type CELL"
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
+msgid "Extended"
+msgstr ""
+#: ../raster/r.univar/r.univar_main.c:106
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../raster/r.out.ascii/main.c:63
+msgid "Converts a raster map layer into a GRASS ASCII text file."
+msgstr ""
+#: ../raster/r.out.ascii/main.c:72
+msgid "Name for output ASCII grid map (use out=- for stdout)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:86
+msgid ""
+"Number of values printed before wrapping a line (only SURFER or MODFLOW "
+"format)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:91
+msgid "String to represent null cell (GRASS grid only)"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:99
+msgid "Write SURFER (Golden Software) ASCII grid"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:103
+msgid "Write MODFLOW (USGS) ASCII array"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:107
+msgid "Force output of integer values"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:114
+msgid "Failed to interpret dp as an integer"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:122
+msgid "Failed to interpret width as an integer"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:128
+msgid "Both -s and -h doesn't make sense"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:131
+msgid "Use -M or -s, not both"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:166
+#, c-format
+msgid "Unable to read fp range for <%s>"
+msgstr ""
+#: ../raster/r.out.ascii/main.c:182
+#, c-format
+msgid "Read failed at row %d"
+msgstr ""
+#: ../raster/r.flow/io.c:87
+msgid "Elevation raster map resolution differs from current region resolution"
+msgstr ""
+#: ../raster/r.flow/io.c:104
+msgid "Resolution of aspect file differs from current region resolution"
+msgstr ""
+#: ../raster/r.flow/io.c:121
+msgid "Reading input files: barrier"
+msgstr ""
+#: ../raster/r.flow/io.c:149
+#, c-format
+msgid "Cannot create segment file %s"
+msgstr ""
+#: ../raster/r.flow/io.c:154
+#, c-format
+msgid "Cannot format segment file %s"
+msgstr ""
+#: ../raster/r.flow/io.c:160
+#, c-format
+msgid "Cannot open segment file %s"
+msgstr ""
+#: ../raster/r.flow/main.c:314 ../raster/r.topidx/topidx.c:41
+#: ../imagery/i.landsat.toar/main.c:534
+msgid "Calculating..."
+msgstr ""
+#: ../raster/r.flow/main.c:423
+msgid "Constructs flowlines."
+msgstr ""
+#: ../raster/r.flow/main.c:425
+msgid ""
+"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
+"areas) from a elevation raster map."
+msgstr ""
+#: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
+#: ../raster/r.stream.extract/main.c:89 ../raster/r.stream.extract/main.c:97
+msgid "Input maps"
+msgstr ""
+#: ../raster/r.flow/main.c:440
+msgid "Name of input barrier raster map"
+msgstr ""
+#: ../raster/r.flow/main.c:447
+msgid "Number of cells between flowlines"
+msgstr ""
+#: ../raster/r.flow/main.c:453
+msgid "Maximum number of segments per flowline"
+msgstr ""
+#: ../raster/r.flow/main.c:458
+msgid "Name for output flow line vector map"
+msgstr ""
+#: ../raster/r.flow/main.c:459 ../raster/r.flow/main.c:465
+#: ../raster/r.flow/main.c:471 ../raster/r.stream.extract/main.c:149
+#: ../raster/r.stream.extract/main.c:156 ../raster/r.stream.extract/main.c:163
+msgid "Output maps"
+msgstr ""
+#: ../raster/r.flow/main.c:464
+msgid "Name for output flow path length raster map"
+msgstr ""
+#: ../raster/r.flow/main.c:470
+msgid "Name for output flow accumulation raster map"
+msgstr ""
+#: ../raster/r.flow/main.c:476
+msgid "Compute upslope flowlines instead of default downhill flowlines"
+msgstr ""
+#: ../raster/r.flow/main.c:480
+msgid "3D lengths instead of 2D"
+msgstr ""
+#: ../raster/r.flow/main.c:484
+msgid "Use less memory, at a performance penalty"
+msgstr ""
+#: ../raster/r.flow/main.c:539
+msgid "You must select one or more output maps (flout, lgout, dsout)"
+msgstr ""
+#: ../raster/r.flow/main.c:555
+msgid ""
+"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
+"calculating flow accumulation."
+msgstr ""
+#: ../raster/r.flow/precomp.c:48
+msgid "Precomputing e/w distances..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:50
+msgid "Precomputing quantization tolerances..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:53
+msgid "Precomputing inverted elevations..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:57
+msgid "Precomputing interpolated border elevations..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:63
+msgid "Precomputing re-oriented aspects..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:67
+msgid "Precomputing aspects..."
+msgstr ""
+#: ../raster/r.flow/precomp.c:111
+#, c-format
+msgid ""
+"Resolution too unbalanced:\n"
+"atan2(%f deg, %f deg) =%f < %f tolerance\n"
+"please resample input map"
+msgstr ""
+#: ../raster/r.flow/precomp.c:116
+#, c-format
+msgid "Resolution too unbalanced (%f x %f); please resample input map"
+msgstr ""
+#: ../raster/r.flow/mem.c:40
+#, c-format
+msgid "Unable to write segment file for %s"
+msgstr ""
+#: ../raster/r.circle/main.c:56
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../raster/r.circle/main.c:63
+msgid "The coordinate of the center (east,north)"
+msgstr ""
+#: ../raster/r.circle/main.c:69
+msgid "Minimum radius for ring/circle map (in meters)"
+msgstr ""
+#: ../raster/r.circle/main.c:75
+msgid "Maximum radius for ring/circle map (in meters)"
+msgstr ""
+#: ../raster/r.circle/main.c:81
+msgid "Data value multiplier"
+msgstr ""
+#: ../raster/r.circle/main.c:85
+msgid "Generate binary raster map"
+msgstr ""
+#: ../raster/r.circle/main.c:108
+msgid "Please specify a radius in which min < max"
+msgstr ""
+#: ../raster/r.circle/main.c:116
+msgid "Please specify min and/or max radius when using the binary flag"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:79
+msgid "2D raster maps which represent the slices"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:93
+msgid "Use 3D raster mask (if exists) with output map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:201
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../raster/r.to.rast3/main.c:213
+msgid "No output map"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:230
+msgid ""
+"The 2D and 3D region settings are different. Using the 3D region settings to "
+"adjust the 2D region."
+msgstr ""
+#: ../raster/r.to.rast3/main.c:262
+#, c-format
+msgid "Open raster map %s - one time for each depth (%d/%d)"
+msgstr ""
+#: ../raster/r.to.rast3/main.c:275
+msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:68
+msgid "Unable to find bounding box for lines"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:70
+#, c-format
+msgid "Bounding box:  l = %d, r = %d, t = %d, b = %d"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:117
+#, c-format
+msgid "Pass number %d"
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:168
+#, c-format
+msgid "Deleted %d pixel"
+msgid_plural "Deleted %d pixels"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.thin/thin_lines.c:172
+msgid "Thinning completed successfully."
+msgstr ""
+#: ../raster/r.thin/thin_lines.c:174
+msgid "Thinning not completed, consider to increase 'iterations' parameter."
+msgstr ""
+#: ../raster/r.thin/io.c:95
+msgid "Input raster must be of type CELL."
+msgstr ""
+#. GTC First argument is the raster map name, second and third - a string representing number of rows and cols
+#: ../raster/r.thin/io.c:106
+#, c-format
+msgid "Raster map <%s> - %s X %s"
+msgstr ""
+#: ../raster/r.thin/io.c:119
+#, c-format
+msgid "Unable to create temporary file <%s> -- errno = %d"
+msgstr ""
+#. GTC %s will be replaced with number of rows and columns
+#: ../raster/r.thin/io.c:173
+#, c-format
+msgid "Output map %s X %s"
+msgstr ""
+#: ../raster/r.thin/io.c:182
+#, c-format
+msgid "Window %s X %s"
+msgstr ""
+#: ../raster/r.thin/main.c:58
+msgid "Thins non-null cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../raster/r.thin/main.c:70
+msgid "Maximal number of iterations"
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:80
+msgid "Resamples raster map to a finer grid using interpolation."
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:88
+msgid "Method"
+msgstr ""
+#: ../raster/r.resamp.interp/main.c:102 ../imagery/i.topo.corr/main.c:158
+#, c-format
+msgid "Invalid method: %s"
+msgstr ""
+#: ../raster/r.series/main.c:137
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+#: ../raster/r.series/main.c:146
+msgid ""
+"Input file with one raster map name and optional one weight per line, field "
+"separator between name and weight is |"
+msgstr ""
+#: ../raster/r.series/main.c:172
+msgid ""
+"Weighting factor for each input map, default value is 1.0 for each input map"
+msgstr ""
+#: ../raster/r.series/main.c:257 ../raster/r.series/main.c:300
+#, c-format
+msgid "Reading raster map <%s> using weight %f..."
+msgstr ""
+#: ../raster/r.series/main.c:286
+msgid "input= and weights= must have the same number of values"
+msgstr ""
+#: ../raster/r.series/main.c:315
+msgid "output= and method= must have the same number of values"
+msgstr ""
+#: ../raster/r.sunmask/main.c:118 ../raster/r.horizon/main.c:182
+msgid "sun position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:119 ../raster/r.sun/main.c:242
+msgid "shadow"
+msgstr ""
+#: ../raster/r.sunmask/main.c:120
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map."
+msgstr ""
+#: ../raster/r.sunmask/main.c:121
+msgid ""
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
+#: ../raster/r.sunmask/main.c:135
+msgid "Altitude of the sun in degrees above the horizon (A)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:136 ../raster/r.sunmask/main.c:145
+#: ../raster/r.sunmask/main.c:213 ../raster/r.sunmask/main.c:223
+msgid "Position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:144
+msgid "Azimuth of the sun in degrees from north (A)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:151
+msgid "Year (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:159
+msgid "Month (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:167
+msgid "Day (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:175
+msgid "Hour (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:183
+msgid "Minutes (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:191
+msgid "Seconds (B)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:201
+msgid "Timezone"
+msgstr ""
+#: ../raster/r.sunmask/main.c:202
+msgid "East positive, offset from GMT, also use to adjust daylight savings"
+msgstr ""
+#: ../raster/r.sunmask/main.c:211
+msgid "Easting coordinate (point of interest)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:212 ../raster/r.sunmask/main.c:222
+msgid "Default: map center"
+msgstr ""
+#: ../raster/r.sunmask/main.c:221
+msgid "Northing coordinate (point of interest)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:227
+msgid "Do not ignore zero elevation"
+msgstr ""
+#: ../raster/r.sunmask/main.c:231
+msgid "Calculate sun position only and exit"
+msgstr ""
+#: ../raster/r.sunmask/main.c:237
+msgid "Print the sun position output in shell script style"
+msgstr ""
+#: ../raster/r.sunmask/main.c:251
+#, c-format
+msgid "Using map center coordinates: %f %f"
+msgstr ""
+#: ../raster/r.sunmask/main.c:258
+msgid "Empty east coordinate specified"
+msgstr ""
+#: ../raster/r.sunmask/main.c:260
+msgid "Empty north coordinate specified"
+msgstr ""
+#: ../raster/r.sunmask/main.c:279
+msgid "Either define sun position or location/date/time parameters"
+msgstr ""
+#: ../raster/r.sunmask/main.c:282
+msgid ""
+"Neither sun position nor east/north, date/time/timezone definition are "
+"complete"
+msgstr ""
+#: ../raster/r.sunmask/main.c:286
+#, c-format
+msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:291
+msgid ""
+"Using user defined sun azimuth, altitude settings (ignoring eventual other "
+"values)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:399
+msgid "Please correct settings"
+msgstr ""
+#: ../raster/r.sunmask/main.c:413
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:417
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise"
+msgstr ""
+#: ../raster/r.sunmask/main.c:420 ../raster/r.sunmask/main.c:430
+msgid "Nothing to calculate. Please verify settings."
+msgstr ""
+#: ../raster/r.sunmask/main.c:424
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
+msgstr ""
+#: ../raster/r.sunmask/main.c:428
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset"
+msgstr ""
+#: ../raster/r.sunmask/main.c:439
+msgid "You already know the sun position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:456
+#, c-format
+msgid "Unable to open range file for raster map <%s>"
+msgstr ""
+#: ../raster/r.sunmask/main.c:472
+msgid "Calculating shadows from DEM..."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:66
+msgid ""
+"Unable to calculate sun position in un-projected locations. Specify "
+"sunposition directly."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:88
+#, c-format
+msgid ""
+"Specified point %f, %f outside of current region, is that intended? Anyway, "
+"it will be used."
+msgstr ""
+#: ../raster/r.contour/main.c:89
+msgid "contours"
+msgstr ""
+#: ../raster/r.contour/main.c:91
+msgid "Produces a vector map of specified contours from a raster map."
+msgstr ""
+#: ../raster/r.contour/main.c:101
+msgid "Increment between contour levels"
+msgstr ""
+#: ../raster/r.contour/main.c:102 ../raster/r.contour/main.c:110
+#: ../raster/r.contour/main.c:117 ../raster/r.contour/main.c:124
+msgid "Contour levels"
+msgstr ""
+#: ../raster/r.contour/main.c:109
+msgid "List of contour levels"
+msgstr ""
+#: ../raster/r.contour/main.c:116
+msgid "Minimum contour level"
+msgstr ""
+#: ../raster/r.contour/main.c:123
+msgid "Maximum contour level"
+msgstr ""
+#: ../raster/r.contour/main.c:132
+msgid "Minimum number of points for a contour line (0 -> no limit)"
+msgstr ""
+#: ../raster/r.contour/main.c:140
+#, c-format
+msgid "Neither <%s> nor <%s> option must be specified"
+msgstr ""
+#: ../raster/r.contour/main.c:263
+#, c-format
+msgid "Range of data: min=%f, max=%f"
+msgstr ""
+#: ../raster/r.contour/main.c:265
+msgid "Range of data: empty"
+msgstr ""
+#: ../raster/r.contour/main.c:293 ../raster/r.contour/main.c:296
+msgid "This step value is not allowed"
+msgstr ""
+#: ../raster/r.contour/main.c:321
+#, c-format
+msgid "Range of levels: min = %f, max = %f"
+msgstr ""
+#: ../raster/r.contour/main.c:350
+msgid "Displacing data..."
+msgstr ""
+#: ../raster/r.contour/cont.c:82
+#, c-format
+msgid "Writing vector contour (one level)..."
+msgid_plural "Writing vector contours (total levels %d)..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.contour/cont.c:213
+#, c-format
+msgid "%d crossing found"
+msgid_plural "%d crossings found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.contour/cont.c:266
+msgid "Illegal edge number"
+msgstr ""
+#: ../raster/r.contour/cont.c:374
+msgid "Edge number out of range"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:72
+#: ../raster/r.stream.extract/streams.c:668
+#, c-format
+msgid "Stream_no %d and n_stream_nodes %lld out of sync"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:128
+#, c-format
+msgid "BUG: stream node %d has only 1 tributary: %d"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:160
+msgid "Calculating flow accumulation..."
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:392
+msgid "Extracting streams..."
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:469
+msgid "Bug in stream extraction"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:631
+msgid "Can't use Montgomery's method, no stream direction found"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:700
+#, c-format
+msgid ""
+"MFD: A * path already processed when setting drainage direction: %lld of "
+"%lld cells"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:78
+msgid "stream network"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:79
+msgid "Performs stream network extraction."
+msgstr ""
+#: ../raster/r.stream.extract/main.c:85
+msgid "Name of input accumulation raster map"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:88
+msgid ""
+"Stream extraction will use provided accumulation instead of calculating it "
+"anew"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:93
+msgid "Name of input raster map with real depressions"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:96
+msgid "Streams will not be routed out of real depressions"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:101
+msgid "Minimum flow accumulation for streams"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:102
+msgid "Must be > 0"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:108
+msgid "Use SFD above this threshold"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:110
+msgid ""
+"If accumulation is larger than d8cut, SFD is used instead of MFD. Applies "
+"only if no accumulation map is given."
+msgstr ""
+#: ../raster/r.stream.extract/main.c:122
+msgid "Montgomery exponent for slope, disabled with 0"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:124
+msgid ""
+"Montgomery: accumulation is multiplied with pow(slope,mexp) and then "
+"compared with threshold"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:132
+msgid "Delete stream segments shorter than stream_length cells"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:134
+msgid "Applies only to first-order stream segments (springs/stream heads)"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:147
+msgid "Name for output raster map with unique stream ids"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:154
+msgid "Name for output vector map with unique stream ids"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:161
+msgid "Name for output raster map with flow direction"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:192
+#, c-format
+msgid "Threshold must be > 0 but is %f"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:201
+#, c-format
+msgid "d8cut must be positive or zero but is %f"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:209
+#, c-format
+msgid "Montgomery exponent must be positive or zero but is %f"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:212
+#, c-format
+msgid "Montgomery exponent is %f, recommended range is 0.0 - 3.0"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:222
+#, c-format
+msgid "Minimum stream length must be positive or zero but is %d"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:231
+#, c-format
+msgid "Memory must be positive but is %d"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:241
+msgid "At least one output raster maps must be specified"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:315
+#, c-format
+msgid "%.2f%% of data are kept in memory"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:325
+msgid "Creating temporary files..."
+msgstr ""
+#: ../raster/r.stream.extract/main.c:345
+msgid "Unable to load input raster map(s)"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:347
+msgid "No non-NULL cells in input raster map(s)"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:398
+msgid "Unable to initialize search"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:402
+msgid "Unable to sort elevation raster map values"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:408
+msgid "Unable to calculate flow accumulation"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:413
+msgid "Unable to extract streams"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:420
+msgid "Unable to thin streams"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:425
+msgid "Unable to delete short stream segments"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:431
+msgid "Unable to write output raster maps"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:34
+#, c-format
+msgid "Writing vector map <%s>..."
+msgstr ""
+#: ../raster/r.stream.extract/close.c:117
+#, c-format
+msgid "Stream id %d not set, top is %d, parent is %d"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:138
+msgid "Stream id not set while tracing"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:157
+msgid "Writing attribute data..."
+msgstr ""
+#: ../raster/r.stream.extract/close.c:192
+#, c-format
+msgid "Unable to create index on table <%s>"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:213
+#, c-format
+msgid "Unable to insert new row: '%s'"
+msgstr ""
+#: ../raster/r.stream.extract/close.c:313
+#, c-format
+msgid "Unable to write vector map <%s>"
+msgstr ""
+#: ../raster/r.stream.extract/thin.c:83
+msgid "Thinning stream segments..."
+msgstr ""
+#: ../raster/r.stream.extract/thin.c:169
+#, c-format
+msgid "%d of %lld stream segments were thinned"
+msgstr ""
+#: ../raster/r.stream.extract/seg.c:19 ../raster/r.stream.extract/cseg.c:19
+#: ../raster/r.stream.extract/bseg.c:19
+msgid "Unable to create segment file"
+msgstr ""
+#: ../raster/r.stream.extract/seg.c:33 ../raster/r.stream.extract/seg.c:75
+#: ../raster/r.stream.extract/cseg.c:29 ../raster/r.stream.extract/cseg.c:79
+#: ../raster/r.stream.extract/cseg.c:88 ../raster/r.stream.extract/dseg.c:29
+#: ../raster/r.stream.extract/dseg.c:79 ../raster/r.stream.extract/dseg.c:88
+#: ../raster/r.stream.extract/bseg.c:28 ../raster/r.stream.extract/bseg.c:78
+#: ../raster/r.stream.extract/bseg.c:87
+msgid "Unable to write segment file"
+msgstr ""
+#: ../raster/r.stream.extract/seg.c:37 ../raster/r.stream.extract/cseg.c:33
+#: ../raster/r.stream.extract/bseg.c:32
+msgid "Illegal configuration parameter(s)"
+msgstr ""
+#: ../raster/r.stream.extract/seg.c:44
+#, c-format
+msgid "Unable to re-open file '%s'"
+msgstr ""
+#: ../raster/r.stream.extract/seg.c:51 ../raster/r.stream.extract/seg.c:93
+#: ../raster/r.stream.extract/seg.c:102 ../raster/r.stream.extract/cseg.c:47
+#: ../raster/r.stream.extract/dseg.c:47 ../raster/r.stream.extract/dseg.c:97
+#: ../raster/r.stream.extract/bseg.c:46 ../raster/r.stream.extract/bseg.c:96
+msgid "Unable to read segment file"
+msgstr ""
+#: ../raster/r.stream.extract/seg.c:84
+msgid "seg_put_row(): could not write segment file"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:40 ../raster/r.stream.extract/dseg.c:40
+#: ../raster/r.stream.extract/bseg.c:39
+msgid "Unable to re-open segment file"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:97
+msgid "Unabel to read segment file"
+msgstr ""
+#: ../raster/r.stream.extract/cseg.c:120
+#, c-format
+msgid "Unable to segment put row %d for raster map <%s>"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:19
+msgid "dseg_open(): unable to create segment file"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:33
+msgid "Iillegal configuration parameter(s)"
+msgstr ""
+#: ../raster/r.stream.extract/dseg.c:120
+#, c-format
+msgid "Inable to segment put row %d for raster <%s>"
+msgstr ""
+#: ../raster/r.stream.extract/load.c:33
+msgid "Loading elevation raster map..."
+msgstr ""
+#: ../raster/r.stream.extract/load.c:35
+msgid "Loading input raster maps..."
+msgstr ""
+#: ../raster/r.stream.extract/load.c:95
+msgid "Elevation raster map is NULL but accumulation map is not NULL"
+msgstr ""
+#: ../raster/r.stream.extract/load.c:120
+msgid "Accumulation raster map is NULL but elevation map is not NULL"
+msgstr ""
+#: ../raster/r.stream.extract/del_streams.c:130
+#, c-format
+msgid "Deleting stream segments shorter than %d cell..."
+msgid_plural "Deleting stream segments shorter than %d cells..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.stream.extract/del_streams.c:193
+#, c-format
+msgid "%d stream segment deleted"
+msgid_plural "%d stream segments deleted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.stream.extract/init_search.c:24
+msgid "Initializing A* search..."
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:40
+msgid "A* Search..."
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:62
+#, c-format
+msgid "%lld surplus points"
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:67
+#, c-format
+msgid "Too many points in heap %lld, should be %lld"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:59
+msgid "The initial concentration in [kg/m^3]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:63
+msgid "The piezometric head in [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:68
+msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:73
+msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:79
+msgid ""
+"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
+"dirichlet- and 3 - transfer boundary condition"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:85
+msgid "The x-part of the diffusion tensor in [m^2/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:90
+msgid "The y-part of the diffusion tensor in [m^2/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:94
+#: ../raster/r.solute.transport/main.c:102
+#: ../raster/r.solute.transport/main.c:138
+#: ../raster/r.solute.transport/main.c:145
+msgid "Water flow"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:96
+msgid "Groundwater sources and sinks in [m^3/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:103
+msgid ""
+"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:112
+msgid ""
+"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
+"reaction)"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:117
+msgid "Retardation factor [-]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:121
+msgid "Effective porosity [-]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:125
+msgid "Top surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:129
+msgid "Bottom surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:132
+msgid ""
+"The resulting concentration of the numerical solute transport calculation "
+"will be written to this map. [kg/m^3]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:140
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in x "
+"direction [m/s]\n"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:147
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in y "
+msgstr ""
+#: ../raster/r.solute.transport/main.c:161
+msgid "The longditudinal dispersivity length. [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:169
+msgid "The transversal dispersivity length. [m]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:177
+msgid ""
+"Use this number of time loops if the CFL flag is off. The timestep will "
+"become dt/loops."
+msgstr ""
+#: ../raster/r.solute.transport/main.c:187
+msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
+msgstr ""
+#: ../raster/r.solute.transport/main.c:199
+msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:231
+msgid "solute transport"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:233
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:258
+msgid "The direct LU solver do not work with sparse matrices"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:260
+msgid "The direct Gauss solver do not work with sparse matrices"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:370
+#, c-format
+msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:371
+#, c-format
+msgid "The largest stable time step is %g"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:380
+#, c-format
+msgid "Number of inner loops is %g"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:381
+#, c-format
+msgid "Time step for each loop %g"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:385
+#, c-format
+msgid ""
+"The time step is to large: %gs. The largest time step should be of size %gs."
+msgstr ""
+#: ../raster/r.solute.transport/main.c:397
+#, c-format
+msgid "Time step %i with time sum %g"
+msgstr ""
+#: ../raster/r.solute.transport/main.c:543
+msgid "Could not create and solve the linear equation system"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:117
+msgid "Raster map calculator."
+msgstr ""
+#: ../raster/r.mapcalc/main.c:124
+msgid "Expression to evaluate"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:125 ../raster/r.mapcalc/main.c:131
+msgid "Expression"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:130
+msgid "File containing expression(s) to evaluate"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:137
+msgid "Seed for rand() function"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:141
+msgid "Generate random seed (result is non-deterministic)"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:163
+#, c-format
+msgid "%s= and -%c are mutually exclusive"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:174
+msgid "parse error"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:196
+msgid "Floating point error(s) occurred in the calculation"
+msgstr ""
+#: ../raster/r.mapcalc/main.c:201
+msgid "Overflow occurred in the calculation"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:94 ../raster/r.mapcalc/evaluate.c:234
+#: ../raster/r.mapcalc/map.c:412 ../raster/r.mapcalc/map3.c:351
+#, c-format
+msgid "Unknown type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:140
+#, c-format
+msgid "Invalid type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:179
+#, c-format
+msgid "Too few arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:183
+#, c-format
+msgid "Too many arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:187
+#, c-format
+msgid "Invalid argument type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:191
+#, c-format
+msgid "Invalid return type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:195
+#, c-format
+msgid "Unknown type for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:198
+#, c-format
+msgid "Number of arguments for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:202
+#, c-format
+msgid "Unknown error for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:282
+#, c-format
+msgid "output map <%s> exists"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:207 ../raster/r.mapcalc/map3.c:179
+#, c-format
+msgid "Unable to read color file for raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:220 ../raster/r.mapcalc/map3.c:192
+#, c-format
+msgid "Unable to create btree for raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:269 ../raster/r.mapcalc/map.c:481
+#: ../raster/r.mapcalc/map.c:522 ../raster/r.mapcalc/map.c:618
+#: ../raster/r.mapcalc/expression.c:353 ../raster/r.mapcalc/map3.c:237
+#: ../raster/r.mapcalc/map3.c:421 ../raster/r.mapcalc/map3.c:466
+#: ../raster/r.mapcalc/map3.c:563
+#, c-format
+msgid "Invalid map modifier: '%c'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:202
+#, c-format
+msgid "Undefined variable '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:217
+#, c-format
+msgid "Invalid map <%s>"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:258
+#, c-format
+msgid "Undefined function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:263
+#, c-format
+msgid "Too few arguments (%d) to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:267
+#, c-format
+msgid "Too many arguments (%d) to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:271
+#, c-format
+msgid "Incorrect argument types to function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:274
+#, c-format
+msgid "Internal error for function %s()"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:449
+#, c-format
+msgid "Illegal number of arguments (%d) for operator '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/expression.c:489
+#, c-format
+msgid "Format_expression_prec: unknown type: %d"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:370
+#, c-format
+msgid "Unable to close raster map <%s@%s>"
+msgstr ""
+#: ../raster/r.mapcalc/map3.c:619
+msgid "Unable to close output raster map"
+msgstr ""
+#: ../raster/r.mapcalc/function.c:100
+#, c-format
+msgid "Known functions:"
+msgstr ""
+#: ../raster/r.resample/main.c:57
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../raster/r.resample/main.c:66
+msgid "Name of an input layer"
+msgstr ""
+#: ../raster/r.resample/main.c:73
+msgid "Name of an output layer"
+msgstr ""
+#: ../raster/r.resample/main.c:112 ../raster/r.resamp.rst/main.c:478
+msgid "Percent complete: "
+msgstr ""
+#: ../raster/r.resample/main.c:138
+msgid "Creating new cats file..."
+msgstr ""
+#: ../raster/r.tile/main.c:46
+msgid "Splits a raster map into tiles."
+msgstr ""
+#: ../raster/r.tile/main.c:55
+msgid "Output base name"
+msgstr ""
+#: ../raster/r.tile/main.c:62
+msgid "Width of tiles (columns)"
+msgstr ""
+#: ../raster/r.tile/main.c:69
+msgid "Height of tiles (rows)"
+msgstr ""
+#: ../raster/r.tile/main.c:76
+msgid "Overlap of tiles"
+msgstr ""
+#: ../raster/r.tile/main.c:129
+#, c-format
+msgid "Generating %d x %d = %d tiles..."
+msgstr ""
+#: ../raster/r.tile/main.c:184
+#, c-format
+msgid "Unable to read cats for %s"
+msgstr ""
+#: ../raster/r.region/main.c:54
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../raster/r.region/main.c:60
+msgid "Set from current region"
+msgstr ""
+#: ../raster/r.region/main.c:71
+msgid "Name of raster map to change"
+msgstr ""
+#: ../raster/r.region/main.c:79
+msgid "Set region from named region"
+msgstr ""
+#: ../raster/r.region/main.c:87
+msgid "Set region to match this raster map"
+msgstr ""
+#: ../raster/r.region/main.c:94
+msgid "Set region to match this vector map"
+msgstr ""
+#: ../raster/r.region/main.c:137
+msgid "Raster map to align to"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:104
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:114 ../raster/r.statistics/main.c:68
+msgid "Method of object-based statistic"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:137 ../raster/r.statistics/main.c:91
+msgid "Resultant raster map"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:143 ../raster/r.statistics/main.c:97
+msgid "Cover values extracted from the category labels of the cover map"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:177
+#, c-format
+msgid "Unable to read category file of cover map <%s>"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:247
+msgid "First pass"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:326
+msgid "Second pass"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:473
+msgid "Generating reclass map"
+msgstr ""
+#: ../raster/r.stats.zonal/main.c:495
+msgid "Writing output map"
+msgstr ""
+#: ../raster/r.support.stats/main.c:37
+msgid "Update raster map statistics"
+msgstr ""
+#: ../raster/r.support.stats/main.c:49
+#, c-format
+msgid "Statistics for <%s> updated"
+msgstr ""
+#: ../raster/r.support.stats/check.c:43
+#, c-format
+msgid "Updating statistics for [%s]..."
+msgstr ""
+#: ../raster/r.support.stats/check.c:56
+msgid "Updating histogram range..."
+msgstr ""
+#: ../raster/r.support.stats/check.c:88
+#, c-format
+msgid "Updating the number of categories for [%s]..."
+msgstr ""
+#: ../raster/r.basins.fill/read_map.c:39
+#, c-format
+msgid "Reading <%s> ... "
+msgstr ""
+#: ../raster/r.basins.fill/main.c:58
+msgid "Generates watershed subbasins raster map."
+msgstr ""
+#: ../raster/r.basins.fill/main.c:62
+msgid "Name of input coded stream network raster map"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:66
+msgid "Name of input thinned ridge network raster map"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:74
+msgid "Number of passes through the dataset"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:122
+msgid "Forward sweep complete"
+msgstr ""
+#: ../raster/r.basins.fill/main.c:139
+msgid "Reverse sweep complete"
+msgstr ""
+#: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:409
+msgid ""
+"Unable to convert input raster map projection information to GRASS format "
+"for checking"
+msgstr ""
+#: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:440
+msgid "Location PROJ_INFO is:\n"
+msgstr ""
+#: ../raster/r.external/proj.c:58 ../raster/r.in.gdal/main.c:451
+msgid "Dataset PROJ_INFO is:\n"
+msgstr ""
+#: ../raster/r.external/proj.c:111 ../raster/r.in.gdal/main.c:509
+msgid ""
+"Consider generating a new location from the input dataset using the "
+"'location' parameter.\n"
+msgstr ""
+#: ../raster/r.external/window.c:23
+msgid ""
+"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
+"transform the map to North-up."
+msgstr ""
+#: ../raster/r.external/window.c:26
+msgid "Applying horizontal flip"
+msgstr ""
+#: ../raster/r.external/window.c:30
+msgid "Applying vertical flip"
+msgstr ""
+#: ../raster/r.external/main.c:59
+msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
+msgstr ""
+#: ../raster/r.external/main.c:62
+msgid "Name of raster file to be linked"
+msgstr ""
+#: ../raster/r.external/main.c:68
+msgid "Name of non-file GDAL data source"
+msgstr ""
+#: ../raster/r.external/main.c:80
+msgid "Band to select (default is all bands)"
+msgstr ""
+#: ../raster/r.external/main.c:89 ../raster/r.in.gdal/main.c:130
+#: ../raster/r.in.gdal/main.c:138 ../imagery/i.landsat.toar/main.c:93
+#: ../imagery/i.landsat.toar/main.c:115 ../imagery/i.landsat.toar/main.c:125
+#: ../imagery/i.landsat.toar/main.c:134 ../imagery/i.landsat.toar/main.c:142
+#: ../imagery/i.landsat.toar/main.c:151
+msgid "Metadata"
+msgstr ""
+#: ../raster/r.external/main.c:109
+msgid "Flip horizontally"
+msgstr ""
+#: ../raster/r.external/main.c:113
+msgid "Flip vertically"
+msgstr ""
+#: ../raster/r.external/main.c:143
+#, c-format
+msgid "%s= or %s= must be given"
+msgstr ""
+#: ../raster/r.external/main.c:176
+msgid "Proceeding with import..."
+msgstr ""
+#: ../raster/r.external/main.c:180
+#, c-format
+msgid "Imagery group <%s> already exists and will be overwritten."
+msgstr ""
+#: ../raster/r.external/main.c:187
+#, c-format
+msgid "Reading band %d of %d..."
+msgstr ""
+#: ../raster/r.external/main.c:192 ../raster/r.in.gdal/main.c:552
+#, c-format
+msgid "Selected band (%d) does not exist"
+msgstr ""
+#: ../raster/r.external/main.c:224
+#, c-format
+msgid "Imagery group <%s> created"
+msgstr ""
+#: ../raster/r.external/link.c:48
+msgid "Complex types not supported"
+msgstr ""
+#: ../raster/r.external/link.c:63
+#, c-format
+msgid "Copying color table for %s"
+msgstr ""
+#: ../raster/r.external/link.c:81
+#, c-format
+msgid "Setting grey color table for <%s> (full 8bit range)"
+msgstr ""
+#: ../raster/r.external/link.c:87
+#, c-format
+msgid "Setting grey color table for <%s> (data range)"
+msgstr ""
+#: ../raster/r.external/link.c:101
+#, c-format
+msgid "Unable to create cell/%s file"
+msgstr ""
+#: ../raster/r.external/link.c:110
+#, c-format
+msgid "Unable to create fcell/%s file"
+msgstr ""
+#: ../raster/r.external/link.c:146
+#, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
+msgstr ""
+#: ../raster/r.external/link.c:149
+#, c-format
+msgid "Error writing cell_misc/%s/gdal file"
+msgstr ""
+#: ../raster/r.external/link.c:174
+#, c-format
+msgid "Unable to create cell_misc/%s/f_format file"
+msgstr ""
+#: ../raster/r.external/link.c:177
+#, c-format
+msgid "Error writing cell_misc/%s/f_format file"
+msgstr ""
+#: ../raster/r.external/link.c:224
+#, c-format
+msgid "Creating support files for %s"
+msgstr ""
+#: ../raster/r.external/link.c:236
+#, c-format
+msgid "Link to raster map <%s> created."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:89
+msgid "Imports raster data into a GRASS raster map using GDAL library."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:95
+msgid "Name of raster file to be imported"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:104
+msgid "Band(s) to select (default is all bands)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:119
+msgid "Name of GCPs target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:121
+msgid ""
+"Name of location to create or to read projection from for GCPs transformation"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:137
+msgid ""
+"The offset will be added to the band number while output raster map name "
+"creation"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:151
+msgid "File prefix for raster attribute tables"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:152
+msgid "The band number and \".csv\" will be appended to the file prefix"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:175
+msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:180
+msgid "Keep band numbers instead of using band color names"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:185
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the raster file."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:190
+msgid "Print number of bands and exit"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:217
+msgid "You have to specify a target location different from output location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:221
+msgid "You need to specify valid location name."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:225
+msgid "The '-l' flag only works in Lat/Lon locations"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:235
+#, c-format
+msgid "Using memory cache size: %.1f MiB"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:277
+#, c-format
+msgid "Unable to open datasource <%s>"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:288
+#, c-format
+msgid ""
+"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
+"plate spline transformation (%s or %s)."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:327
+msgid ""
+"Input raster map is flipped or rotated - cannot import. You may use "
+"'gdalwarp' to transform the map to North-up."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:368
+msgid ""
+"Map bounds have been constrained to geographic coordinates. You will almost "
+"certainly want to check map bounds and resolution with r.info and reset them "
+"with r.region before going any further."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:520
+#, c-format
+msgid "Proceeding with import of %d raster bands..."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:593
+#, c-format
+msgid "Unable to get raster band number %d"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:664
+#, c-format
+msgid "Copying %d GCPS in points file for <%s>"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:672
+msgid "GCPs have the following OpenGIS WKT Coordinate System:"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:695
+msgid "Re-projecting GCPs table:"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:696
+#, c-format
+msgid "* Input projection for GCP table: %s"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:698
+#, c-format
+msgid "* Output projection for GCP table: %s"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:719
+#, c-format
+msgid "Error in pj_do_proj (can't re-projection GCP %i)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:774
+#, c-format
+msgid ""
+"The target for the output group <%s> has been set to location <%s>, mapset "
+"<PERMANENT>."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:847
+msgid "Unable to translate projection key values of input GCPs"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:863
+msgid "Unable to get projection info of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:865
+msgid "Unable to get projection units of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:867
+msgid "Unable to get projection key values of target location"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:906
+#, c-format
+msgid "Importing raster map <%s>..."
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1301 ../raster/r.in.gdal/main.c:1358
+msgid "Inconsistent color rules in RAT"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1415
+#, c-format
+msgid "Setting grey color table for <%s> (8bit, full range)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1429
+#, c-format
+msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:1531
+#, c-format
+msgid "Unable to open file <%s>: %s."
+msgstr ""
+#: ../raster/r.kappa/prt_label.c:17
+#, c-format
+msgid "Can't open file <%s> to write label"
+msgstr ""
+#: ../raster/r.kappa/main.c:72
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../raster/r.kappa/main.c:78
+msgid "Name of raster map containing classification result"
+msgstr ""
+#: ../raster/r.kappa/main.c:83
+msgid "Name of raster map containing reference classes"
+msgstr ""
+#: ../raster/r.kappa/main.c:88
+msgid "Name for output file containing error matrix and kappa"
+msgstr ""
+#: ../raster/r.kappa/main.c:96
+msgid "Title for error matrix and kappa"
+msgstr ""
+#: ../raster/r.kappa/main.c:102
+msgid "Wide report"
+msgstr ""
+#: ../raster/r.kappa/main.c:103
+msgid "132 columns (default: 80)"
+msgstr ""
+#: ../raster/r.kappa/main.c:108
+msgid "No header in the report"
+msgstr ""
+#: ../raster/r.kappa/prt_mat.c:39
+#, c-format
+msgid "Cannot open file <%s> to write cats and counts (error matrix)"
+msgstr ""
+#: ../raster/r.kappa/calc_kappa.c:32
+#, c-format
+msgid "Cannot open file <%s> to write kappa and relevant parameters"
+msgstr ""
+#: ../raster/r.kappa/prt_hdr.c:18
+#, c-format
+msgid "Cannot open file <%s> to write header"
+msgstr ""
+#: ../raster/r.uslek/main.c:57
+msgid "Computes USLE Soil Erodibility Factor (K)."
+msgstr ""
+#: ../raster/r.uslek/main.c:62
+msgid "Name of soil sand fraction raster map [0.0-1.0]"
+msgstr ""
+#: ../raster/r.uslek/main.c:66
+msgid "Name of soil clay fraction raster map [0.0-1.0]"
+msgstr ""
+#: ../raster/r.uslek/main.c:70
+msgid "Name of soil silt fraction raster map [0.0-1.0]"
+msgstr ""
+#: ../raster/r.uslek/main.c:74
+msgid "Name of soil organic matter raster map [0.0-1.0]"
+msgstr ""
+#: ../raster/r.uslek/main.c:77
+msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
+msgstr ""
+#: ../raster/r.topidx/main.c:42
+msgid "Creates a topographic index raster map from an elevation raster map."
+msgstr ""
+#: ../raster/r.topidx/main.c:48
+msgid "Name for output topographic index raster map"
+msgstr ""
+#: ../raster/r.topidx/file_io.c:35
+#, c-format
+msgid ""
+"The current region resolution [%s x %s] is finer than the input map's "
+"resolution [%s x %s]. The current region resolution must be identical to, or "
+"coarser than, the input map's resolution."
+msgstr ""
+#: ../raster/r.topidx/file_io.c:42
+msgid "Reading elevation map..."
+msgstr ""
+#: ../raster/r.topidx/file_io.c:87
+msgid "Writing topographic index map..."
+msgstr ""
+#: ../raster/r.topidx/topidx.c:277
+#, c-format
+msgid "Number of sinks or boundaries: %d"
+msgstr ""
+#: ../raster/r.lake/main.c:153
+msgid "flood"
+msgstr ""
+#: ../raster/r.lake/main.c:154
+msgid "Fills lake at given point to given level."
+msgstr ""
+#: ../raster/r.lake/main.c:160
+msgid "Water level"
+msgstr ""
+#: ../raster/r.lake/main.c:169
+msgid "Seed point coordinates"
+msgstr ""
+#: ../raster/r.lake/main.c:170
+msgid "Either this coordinates pair or a seed map have to be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:178
+msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
+msgstr ""
+#: ../raster/r.lake/main.c:180
+msgid "Either this parameter or a coordinates pair have to be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:186
+msgid "Use negative depth values for lake raster map"
+msgstr ""
+#: ../raster/r.lake/main.c:191
+msgid "Overwrite seed map with result (lake) map"
+msgstr ""
+#: ../raster/r.lake/main.c:197
+msgid "Both seed map and coordinates cannot be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:200
+msgid "Seed map or seed coordinates must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:203
+msgid "Seed coordinates and output map lake= must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:206
+msgid "Both lake and overwrite cannot be specified"
+msgstr ""
+#: ../raster/r.lake/main.c:209
+msgid "Output lake map or overwrite flag must be set!"
+msgstr ""
+#: ../raster/r.lake/main.c:236
+msgid "Seed point outside the current region"
+msgstr ""
+#: ../raster/r.lake/main.c:250
+msgid "G_malloc: out of memory"
+msgstr ""
+#: ../raster/r.lake/main.c:272
+msgid ""
+"Given water level at seed point is below earth surface. Increase water level "
+"or move seed point."
+msgstr ""
+#: ../raster/r.lake/main.c:351
+#, c-format
+msgid "Lake depth from %f to %f (specified water level is taken as zero)"
+msgstr ""
+#: ../raster/r.lake/main.c:352
+#, c-format
+msgid "Lake area %f square meters"
+msgstr ""
+#: ../raster/r.lake/main.c:353
+#, c-format
+msgid "Lake volume %f cubic meters"
+msgstr ""
+#: ../raster/r.lake/main.c:354
+msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
+msgstr ""
+#: ../raster/r.patch/main.c:58
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../raster/r.patch/main.c:65
+msgid "Name of raster maps to be patched together"
+msgstr ""
+#: ../raster/r.patch/main.c:68
+msgid "Name for resultant raster map"
+msgstr ""
+#: ../raster/r.patch/main.c:75
+msgid "Use zero (0) for transparency instead of NULL"
+msgstr ""
+#: ../raster/r.patch/main.c:89
+msgid "The minimum number of input raster maps is two"
+msgstr ""
+#: ../raster/r.patch/main.c:161
+#, c-format
+msgid "Creating support files for raster map <%s>..."
+msgstr ""
+#: ../raster/r.surf.idw/main.c:109
+msgid ""
+"Provides surface interpolation from raster point data by Inverse Distance "
+"Squared Weighting."
+msgstr ""
+#: ../raster/r.surf.idw/main.c:124
+msgid "Output is the interpolation error"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:130
+#, c-format
+msgid "Illegal value for '%s' (%s)"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:164 ../raster/r.statistics/main.c:103
+#: ../raster/r.statistics/main.c:106
+msgid "This module currently only works for integer (CELL) maps"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:260
+#, c-format
+msgid "Interpolating raster map <%s> (%d row)..."
+msgid_plural "Interpolating raster map <%s> (%d rows)..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.to.vect/areas.c:120
+msgid "Extracting areas..."
+msgstr ""
+#: ../raster/r.to.vect/areas_io.c:110
+#, c-format
+msgid ""
+"Line terminated unexpectedly\n"
+"previous (%d) point %p (%d,%d,%d) %p %p"
+msgstr ""
+#: ../raster/r.to.vect/areas_io.c:305
+msgid "Writing areas..."
+msgstr ""
+#: ../raster/r.to.vect/lines_io.c:76
+msgid "write_line:  found half a loop!"
+msgstr ""
+#: ../raster/r.to.vect/lines_io.c:132
+#, c-format
+msgid ""
+"write_line: line terminated unexpectedly\n"
+"  previous (%d) point %p (%d,%d,%d) %p %p"
+msgstr ""
+#: ../raster/r.to.vect/main.c:73
+msgid "vectorization"
+msgstr ""
+#: ../raster/r.to.vect/main.c:74
+msgid "Converts a raster map into a vector map."
+msgstr ""
+#: ../raster/r.to.vect/main.c:88
+msgid "Name of attribute column to store value"
+msgstr ""
+#: ../raster/r.to.vect/main.c:89
+msgid "Name must be SQL compliant"
+msgstr ""
+#: ../raster/r.to.vect/main.c:94
+msgid "Smooth corners of area features"
+msgstr ""
+#: ../raster/r.to.vect/main.c:99
+msgid "Use raster values as categories instead of unique sequence (CELL only)"
+msgstr ""
+#: ../raster/r.to.vect/main.c:104
+msgid "Write raster values as z coordinate"
+msgstr ""
+#: ../raster/r.to.vect/main.c:105
+msgid "Table is not created. Currently supported only for points."
+msgstr ""
+#: ../raster/r.to.vect/main.c:111
+msgid "Do not build vector topology"
+msgstr ""
+#: ../raster/r.to.vect/main.c:112
+msgid "Recommended for massive point conversion"
+msgstr ""
+#: ../raster/r.to.vect/main.c:125
+msgid "z flag is supported only for points"
+msgstr ""
+#: ../raster/r.to.vect/main.c:136
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
+"table."
+msgstr ""
+#: ../raster/r.to.vect/main.c:138
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+msgstr ""
+#: ../raster/r.to.vect/main.c:140
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
+msgstr ""
+#: ../raster/r.to.vect/main.c:145
+msgid "Categories will be unique sequence, raster values will be lost."
+msgstr ""
+#: ../raster/r.to.vect/main.c:278
+msgid "Updating attributes..."
+msgstr ""
+#: ../raster/r.to.vect/main.c:302
+#, c-format
+msgid "Unable to insert into table: %s"
+msgstr ""
+#: ../raster/r.to.vect/points.c:36
+msgid "Extracting points..."
+msgstr ""
+#: ../raster/r.to.vect/lines.c:70
+msgid "Extracting lines..."
+msgstr ""
+#: ../raster/r.to.vect/lines.c:498
+#, c-format
+msgid "Crowded cell at (%f, %f): row %d, col %d, count %d"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:502
+msgid ""
+"Raster map is not thinned properly.\n"
+"Please run r.thin."
+msgstr ""
+#: ../raster/r.to.vect/lines.c:576
+msgid "join_lines: p front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:582
+msgid "join_lines: q front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:600
+msgid "extend line:  p is NULL"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:626
+msgid "extend_lines: p front pointer not NULL!"
+msgstr ""
+#: ../raster/r.to.vect/lines.c:633
+msgid "extend_lines: q back pointer not NULL!"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:58
+#, c-format
+msgid ""
+"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
+"to process"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:171
+msgid "Zero value in Mannings n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:222
+msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:246
+#, c-format
+msgid ""
+"Min elevation \t= %.2f m\n"
+"Max elevation \t= %.2f m\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:248
+#, c-format
+msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:250
+#, c-format
+msgid "Mean flow velocity \t= %f m/s\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:251
+#, c-format
+msgid "Mean Mannings \t= %f\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:255
+#, c-format
+msgid "Number of iterations \t= %d cell\n"
+msgid_plural "Number of iterations \t= %d cells\n"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.sim/simlib/input.c:257
+#, c-format
+msgid "Time step \t= %.2f s\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:259
+#, c-format
+msgid ""
+"Sigmax \t= %f\n"
+"Max velocity \t= %f m/s\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:261
+#, c-format
+msgid "Time step used \t= %.2f s\n"
+msgstr ""
+#: ../raster/r.sim/simlib/input.c:313
+msgid "Unable to write et file"
+msgstr ""
+#: ../raster/r.sim/simlib/output.c:321 ../raster/r.sim/simlib/output.c:329
+#, c-format
+msgid "FP raster map <%s> not found"
+msgstr ""
+#: ../raster/r.sim/simlib/observation_points.c:59
+#, c-format
+msgid "Unable to read points from map %s"
+msgstr ""
+#: ../raster/r.sim/simlib/observation_points.c:80
+#, c-format
+msgid "Unable to open observation logfile %s for writing"
+msgstr ""
+#: ../raster/r.sim/simlib/hydro.c:205
+#, c-format
+msgid "nwalk (%d) > maxw (%d)!"
+msgstr ""
+#: ../raster/r.sim/simlib/hydro.c:400
+msgid "Unable to write raster maps"
+msgstr ""
+#: ../raster/r.sim/simlib/hydro.c:467
+#: ../raster/r.sim/r.sim.sediment/main.c:381
+msgid "Cannot write raster maps"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:112
+msgid "sediment flow"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:114
+msgid "deposition"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:116
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:123
+msgid "Name of water depth raster map [m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:127
+#: ../raster/r.sim/r.sim.water/main.c:122
+msgid "Name of x-derivatives raster map [m/m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:131
+#: ../raster/r.sim/r.sim.water/main.c:126
+msgid "Name of y-derivatives raster map [m/m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:136
+msgid "Name of detachment capacity coefficient raster map [s/m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:141
+msgid "Name of transport capacity coefficient raster map [s]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:146
+msgid "Name of critical shear stress raster map [Pa]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:151
+#: ../raster/r.sim/r.sim.water/main.c:163
+msgid "Name of Manning's n raster map"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:159
+#: ../raster/r.sim/r.sim.water/main.c:171
+msgid "Manning's n unique value"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:166
+#: ../raster/r.sim/r.sim.water/main.c:185
+msgid "Name of sampling locations vector points map"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:172
+msgid "Name for output transport capacity raster map [kg/ms]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:179
+msgid ""
+"Name for output transport limited erosion-deposition raster map [kg/m2s]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:186
+msgid "Name for output sediment concentration raster map [particle/m3]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:192
+msgid "Name for output sediment flux raster map [kg/ms]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:199
+msgid "Name for output erosion-deposition raster map [kg/m2s]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:206
+#: ../raster/r.sim/r.sim.water/main.c:217
+msgid ""
+"Name for sampling points output text file. For each observation vector point "
+"the time series of sediment transport is stored."
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:213
+#: ../raster/r.sim/r.sim.water/main.c:210
+msgid "Base name of the output walkers vector points map"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:220
+msgid "Number of walkers"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:228
+#: ../raster/r.sim/r.sim.water/main.c:233
+msgid "Time used for iterations [minutes]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:237
+#: ../raster/r.sim/r.sim.water/main.c:242
+msgid "Time interval for creating output maps [minutes]"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:255
+#: ../raster/r.sim/r.sim.water/main.c:260
+msgid "Water diffusion constant"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:333
+#: ../raster/r.sim/r.sim.water/main.c:435
+msgid "More than 100 files are going to be created !!!!!"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:339
+#: ../raster/r.sim/r.sim.water/main.c:441
+#, c-format
+msgid "default nwalk=%d, rwalk=%f"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:348
+#: ../raster/r.sim/r.sim.water/main.c:451
+#, c-format
+msgid "Using metric conversion factor %f, step=%f"
+msgstr ""
+#: ../raster/r.sim/r.sim.sediment/main.c:354
+msgid "You are not outputting any raster or site files"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:113
+msgid "overland flow"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:115
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:132
+msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:141
+msgid "Rainfall excess rate unique value [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:148
+msgid "Name of runoff infiltration rate raster map [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:157
+msgid "Runoff infiltration rate unique value [mm/hr]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:178
+msgid "Name of flow controls raster map (permeability ratio 0-1)"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:191
+msgid "Name for output water depth raster map [m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:197
+msgid "Name for output water discharge raster map [m3/s]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:203
+msgid "Name for output simulation error raster map [m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:225
+msgid "Number of walkers, default is twice the number of cells"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:269
+msgid "Threshold water depth [m]"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:270
+msgid "Diffusion increases after this water depth is reached"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:278
+msgid "Diffusion increase constant"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:287
+msgid "Weighting factor for water flow velocity vector"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:292
+msgid "Time-series output"
+msgstr ""
+#: ../raster/r.sim/r.sim.water/main.c:455
+msgid "You are not outputting any raster maps"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:59
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:84
+msgid "Name for new PPM file. (use '-' for stdout)"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:88
+msgid "Add comments to describe the region"
+msgstr ""
+#: ../raster/r.out.ppm3/main.c:160
+msgid "Converting ... "
+msgstr ""
+#: ../raster/r.out.pov/main.c:124
+msgid "Converts a raster map layer into a height-field file for POV-Ray."
+msgstr ""
+#: ../raster/r.out.pov/main.c:131
+msgid "Name of output povray file (TGA height field file)"
+msgstr ""
+#: ../raster/r.out.pov/main.c:138
+msgid "Height-field type (0=actual heights 1=normalized)"
+msgstr ""
+#: ../raster/r.out.pov/main.c:144
+msgid "Elevation bias"
+msgstr ""
+#: ../raster/r.out.pov/main.c:170
+#, c-format
+msgid "Invalid output filename <%s>"
+msgstr ""
+#: ../raster/r.out.pov/main.c:180
+#, c-format
+msgid "Raster map is too big! Exceeds %d columns or %d rows"
+msgstr ""
+#: ../raster/r.out.pov/main.c:201
+msgid "Negative elevation values in input"
+msgstr ""
+#: ../raster/r.surf.fractal/spec_syn.c:60
+msgid "Preliminary surface calculations..."
+msgstr ""
+#: ../raster/r.surf.fractal/spec_syn.c:119
+#, c-format
+msgid "Calculating surface %d (of %d)..."
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:40
+msgid "fractal"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:42
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:48
+msgid "Fractal dimension of surface (2 < D < 3)"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:55
+msgid "Number of intermediate images to produce"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:79
+#, c-format
+msgid "Fractal dimension of %.2lf must be between 2 and 3."
+msgstr ""
+#: ../raster/r.surf.fractal/process.c:54
+msgid "Unable to allocate data buffer. Check current region with g.region."
+msgstr ""
+#: ../raster/r.what/main.c:102
+msgid "Queries raster maps on their category values and category labels."
+msgstr ""
+#: ../raster/r.what/main.c:106
+msgid "Name of existing raster map(s) to query"
+msgstr ""
+#: ../raster/r.what/main.c:114
+msgid "Name of vector points map for query"
+msgstr ""
+#: ../raster/r.what/main.c:135
+msgid "Size of point cache"
+msgstr ""
+#: ../raster/r.what/main.c:137 ../raster/r.what/main.c:162
+#: ../display/d.legend/main.c:108 ../display/d.legend/main.c:118
+#: ../display/d.legend/main.c:197 ../display/d.legend/main.c:202
+#: ../display/d.legend/main.c:207 ../display/d.legend/main.c:217
+msgid "Advanced"
+msgstr ""
+#: ../raster/r.what/main.c:141
+msgid "Output header row"
+msgstr ""
+#: ../raster/r.what/main.c:146
+msgid "Show the category labels of the grid cell(s)"
+msgstr ""
+#: ../raster/r.what/main.c:151
+msgid "Output color values as RRR:GGG:BBB"
+msgstr ""
+#: ../raster/r.what/main.c:156
+msgid "Output integer category values, not cell values"
+msgstr ""
+#: ../raster/r.what/main.c:161
+msgid "Turn on cache reporting"
+msgstr ""
+#: ../raster/r.what/main.c:201
+#, c-format
+msgid "Can only do up to %d raster maps (%d given)"
+msgstr ""
+#: ../raster/r.what/main.c:217
+#, c-format
+msgid "Unable to read category file for <%s>"
+msgstr ""
+#: ../raster/r.what/main.c:296
+#, c-format
+msgid "Unable to read vector map <%s>"
+msgstr ""
+#: ../raster/r.what/main.c:300
+#, c-format
+msgid "Line %d is not point or centroid, skipped"
+msgstr ""
+#: ../raster/r.what/main.c:384
+#, c-format
+msgid "%s %s is outside your current region"
+msgstr ""
+#: ../raster/r.gwflow/main.c:57
+msgid "Name of input raster map with initial piezometric head in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:62
+msgid ""
+"Name of input raster map providing boundary condition status: 0-inactive, 1-"
+"active, 2-dirichlet"
+msgstr ""
+#: ../raster/r.gwflow/main.c:67
+msgid ""
+"Name of input raster map with x-part of the hydraulic conductivity tensor in "
+"[m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:72
+msgid ""
+"Name of input raster map with y-part of the hydraulic conductivity tensor in "
+"[m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:77
+msgid "Name of input raster map with water sources and sinks in [m^3/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:81
+msgid ""
+"Name of input raster map with storativity for confined or effective porosity "
+"for unconfined groundwater flow booth in [-] "
+msgstr ""
+#: ../raster/r.gwflow/main.c:86
+msgid "Recharge"
+msgstr ""
+#: ../raster/r.gwflow/main.c:88
+msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:92
+msgid ""
+"Name of input raster map describing the top surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:96
+msgid ""
+"Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:100
+msgid "Output raster map storing the numerical result [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:106
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in x "
+"direction [m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:112
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in y "
+"direction [m/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:118
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:126
+msgid "The type of groundwater flow"
+msgstr ""
+#: ../raster/r.gwflow/main.c:132
+msgid "Name of input raster map providing the height of the river bed in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:140
+msgid ""
+"Name of input raster map providing the water level (head) of the river with "
+"leakage connection in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:147
+msgid ""
+"Name of input raster map providing the leakage coefficient of the river bed "
+"in [1/s]."
+msgstr ""
+#: ../raster/r.gwflow/main.c:155
+msgid ""
+"Name of input raster map providing the height of the drainage bed in [m]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:162
+msgid ""
+"Name of input raster map providing the leakage coefficient of the drainage "
+"bed in [1/s]"
+msgstr ""
+#: ../raster/r.gwflow/main.c:167
+msgid "The maximum number of iterations in the linearization approach"
+msgstr ""
+#: ../raster/r.gwflow/main.c:176
+msgid ""
+"Allocate a full quadratic linear equation system, default is a sparse linear "
+"equation system."
+msgstr ""
+#: ../raster/r.gwflow/main.c:212
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
+msgstr ""
+#: ../raster/r.gwflow/main.c:237
+msgid "Please provide river_head, river_leak and river_bed maps"
+msgstr ""
+#: ../raster/r.gwflow/main.c:249
+msgid "Please provide drain_head and drain_leak maps"
+msgstr ""
+#: ../raster/r.gwflow/main.c:263
+msgid ""
+"The cholesky solver dos not work with sparse matrices. You may choose a full "
+"filled quadratic matrix, flag -f."
+msgstr ""
+#: ../raster/r.gwflow/main.c:293
+#, c-format
+msgid "Calculation time: %g"
+msgstr ""
+#: ../raster/r.gwflow/main.c:380
+#, c-format
+msgid "Calculation of unconfined groundwater flow loop %i"
+msgstr ""
+#: ../raster/r.gwflow/main.c:403
+#, c-format
+msgid "Maximum difference between this and last increment: %g"
+msgstr ""
+#: ../raster/r.quantile/main.c:63
+msgid "Computing histogram"
+msgstr ""
+#: ../raster/r.quantile/main.c:258
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../raster/r.quantile/main.c:285
+msgid "Generate recode rules based on quantile-defined intervals"
+msgstr ""
+#: ../raster/r.quantile/main.c:313
+msgid "Too many quantiles"
+msgstr ""
+#: ../raster/r.random.surface/init.c:73
+#, c-format
+msgid "High (%d) must be greater than 1"
+msgstr ""
+#: ../raster/r.random.surface/init.c:82
+#, c-format
+msgid "Rastar map <%s> repeated, maps must be unique"
+msgstr ""
+#: ../raster/r.random.surface/init.c:92
+msgid "Output raster map required"
+msgstr ""
+#: ../raster/r.random.surface/init.c:108
+#, c-format
+msgid "Seed (%d) larger than maximum (%d)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
+#, c-format
+msgid " seed is set to %d"
+msgstr ""
+#: ../raster/r.random.surface/init.c:116
+#, c-format
+msgid "Seed (%d) smaller than minimum (%d)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:159
+#, c-format
+msgid "Distance value (%d): %lf must be >= 0.0"
+msgstr ""
+#: ../raster/r.random.surface/init.c:187
+#, c-format
+msgid "Exponent value (%lf) must be > 0.0"
+msgstr ""
+#: ../raster/r.random.surface/init.c:211
+#, c-format
+msgid "Flat value (%lf) must be less than distance value (%lf)"
+msgstr ""
+#: ../raster/r.random.surface/init.c:232
+msgid "Must have a distance value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:264
+msgid "Must have a exponent value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/init.c:281
+msgid "Must have a weight value for each filter"
+msgstr ""
+#: ../raster/r.random.surface/main.c:61
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../raster/r.random.surface/main.c:68
+msgid "Name for output raster map(s)"
+msgstr ""
+#: ../raster/r.random.surface/main.c:77 ../raster/r.random.cells/main.c:60
+msgid "Maximum distance of spatial correlation (value >= 0.0)"
+msgstr ""
+#: ../raster/r.random.surface/main.c:85
+msgid "Distance decay exponent (value > 0.0)"
+msgstr ""
+#: ../raster/r.random.surface/main.c:94
+msgid "Distance filter remains flat before beginning exponent"
+msgstr ""
+#: ../raster/r.random.surface/main.c:102
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
+msgstr ""
+#: ../raster/r.random.surface/main.c:108
+msgid "Maximum cell value of distribution"
+msgstr ""
+#: ../raster/r.random.surface/main.c:113
+msgid "Uniformly distributed cell values"
+msgstr ""
+#: ../raster/r.random.surface/main.c:128 ../raster/r.random.cells/init.c:89
+#, c-format
+msgid "Generating raster map <%s>..."
+msgstr ""
+#: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
+#: ../raster/r.in.bin/main.c:614
+msgid "Error reading data"
+msgstr ""
+#: ../raster/r.in.bin/main.c:260
+msgid "Import a binary raster file into a GRASS raster map layer."
+msgstr ""
+#: ../raster/r.in.bin/main.c:265
+msgid "Import as floating-point data (default: integer)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:270
+msgid "Import as double-precision floating-point data (default: integer)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:279
+msgid "Byte swap the data during import"
+msgstr ""
+#: ../raster/r.in.bin/main.c:284
+msgid "Get region info from GMT style header"
+msgstr ""
+#: ../raster/r.in.bin/main.c:288
+msgid "Name of binary raster file to be imported"
+msgstr ""
+#: ../raster/r.in.bin/main.c:291
+msgid "Output name or prefix if several bands are imported"
+msgstr ""
+#: ../raster/r.in.bin/main.c:313
+msgid "Header size in bytes"
+msgstr ""
+#: ../raster/r.in.bin/main.c:321
+msgid "Number of bands in input file"
+msgstr ""
+#: ../raster/r.in.bin/main.c:322
+msgid "Bands must be in band-sequential order"
+msgstr ""
+#: ../raster/r.in.bin/main.c:392
+msgid "Flip input horizontal and/or vertical"
+msgstr ""
+#: ../raster/r.in.bin/main.c:395
+msgid "Flip input horizontal (East - West)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:396
+msgid "Flip input vertical (North - South)"
+msgstr ""
+#: ../raster/r.in.bin/main.c:410
+#, c-format
+msgid "Option %s must be > 0"
+msgstr ""
+#: ../raster/r.in.bin/main.c:413
+#, c-format
+msgid "Option %s must be >= 0"
+msgstr ""
+#: ../raster/r.in.bin/main.c:435 ../raster/r.in.bin/main.c:438
+#, c-format
+msgid "Option %s= is ignored if -%c is set"
+msgstr ""
+#: ../raster/r.in.bin/main.c:467
+#, c-format
+msgid "-%c incompatible with %s=%d; must be 4 or 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:476
+#, c-format
+msgid "-%c incompatible with %s=%d; must be 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:484
+#, c-format
+msgid "%s= required for integer data"
+msgstr ""
+#: ../raster/r.in.bin/main.c:488
+#, c-format
+msgid "Integer input doesn't support %s=8 in this build"
+msgstr ""
+#: ../raster/r.in.bin/main.c:493
+#, c-format
+msgid "%s= must be 1, 2, 4 or 8"
+msgstr ""
+#: ../raster/r.in.bin/main.c:506
+#, c-format
+msgid "Either -%c or %s= and %s= must be given"
+msgstr ""
+#: ../raster/r.in.bin/main.c:512
+#, c-format
+msgid "Either all or none of %s=, %s=, %s= and %s= must be given"
+msgstr ""
+#: ../raster/r.in.bin/main.c:554
+#, c-format
+msgid ""
+"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
+"significantly. Did you assign %s= and %s= correctly?"
+msgstr ""
+#: ../raster/r.in.bin/main.c:575
+msgid "File Size %"
+msgstr ""
+#: ../raster/r.in.bin/main.c:595
+#, c-format
+msgid "Importing band %d..."
+msgstr ""
+#: ../raster/r.distance/main.c:42
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../raster/r.distance/edges.c:47
+#, c-format
+msgid "Reading map %s ..."
+msgstr ""
+#: ../raster/r.distance/parse.c:35
+msgid "Name of two input raster maps for computing inter-class distances"
+msgstr ""
+#: ../raster/r.distance/parse.c:45
+msgid "Sort output by distance"
+msgstr ""
+#: ../raster/r.distance/parse.c:46
+msgid "Default: sorted by categories"
+msgstr ""
+#: ../raster/r.distance/parse.c:50
+msgid "Sort by distance in ascending order"
+msgstr ""
+#: ../raster/r.distance/parse.c:51
+msgid "Sort by distance in descending order"
+msgstr ""
+#: ../raster/r.distance/parse.c:55
+msgid "Include category labels in the output"
+msgstr ""
+#: ../raster/r.distance/parse.c:60
+msgid "Report zero distance if rasters are overlapping"
+msgstr ""
+#: ../raster/r.distance/parse.c:64
+msgid "Report null objects as *"
+msgstr ""
+#: ../raster/r.distance/parse.c:74 ../raster/r.distance/parse.c:83
+#, c-format
+msgid "Raster map <%s> is not CELL"
+msgstr ""
+#: ../raster/r.distance/report.c:61
+msgid "Processing..."
+msgstr ""
+#: ../raster/r.distance/distance.c:102
+#, c-format
+msgid "Reading maps  <%s,%s> while finding 0 distance ..."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:85
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:93
+msgid "Name for output vector map with interpolation grid"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:98
+msgid "Name of raster map to use for masking"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:107
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:115
+msgid ""
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:138
+msgid "Only interpolate null cells in input raster map"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:187
+msgid "ew_step must be positive"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:195
+msgid "ns_step must be positive"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:222
+#, c-format
+msgid "spline step in ew direction %g"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:223
+#, c-format
+msgid "spline step in ns direction %g"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:319
+#, c-format
+msgid "Loading input raster <%s>"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:339
+msgid "Only NULL cells in input raster"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:387
+msgid "Mark cells for interpolation"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:458
+msgid "No NULL cells found in input raster."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:720
+msgid "No data within this subregion. Consider increasing the spline step."
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:160
+#, c-format
+msgid ""
+"%d are too many cells, recommended are < 100 cells. The cross validation "
+"would take too much time."
+msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:169
+#, c-format
+msgid "%d point read in region"
+msgid_plural "%d points read in region"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.resamp.bspline/crosscorr.c:174
+msgid "Maybe it takes too long. Consider reducing the region extents."
+msgstr ""
+#: ../raster/r.rescale/main.c:51
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../raster/r.rescale/main.c:110
+#, c-format
+msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
+msgstr ""
+#: ../raster/r.transect/main.c:84
+#, c-format
+msgid "End coordinate: %.15g, %.15g"
+msgstr ""
+#: ../raster/r.transect/main.c:104
+msgid "transect"
+msgstr ""
+#: ../raster/r.transect/main.c:106
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../raster/r.transect/main.c:110
+msgid "Raster map to be queried"
+msgstr ""
+#: ../raster/r.transect/main.c:116
+msgid "Transect definition"
+msgstr ""
+#: ../raster/r.li/r.li.dominance/dominance.c:45
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.dominance/dominance.c:47
+#: ../raster/r.li/r.li.simpson/simpson.c:47
+#: ../raster/r.li/r.li.padsd/padsd.c:54
+#: ../raster/r.li/r.li.patchdensity/main.c:52
+#: ../raster/r.li/r.li.padrange/padrange.c:54
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:49
+#: ../raster/r.li/r.li.renyi/renyi.c:48 ../raster/r.li/r.li.cwed/cwed.c:55
+#: ../raster/r.li/r.li.richness/richness.c:44
+#: ../raster/r.li/r.li.padcv/padcv.c:54 ../raster/r.li/r.li.shape/main.c:50
+#: ../raster/r.li/r.li.mps/mps.c:53 ../raster/r.li/r.li.patchnum/main.c:51
+#: ../raster/r.li/r.li.shannon/shannon.c:47 ../raster/r.li/r.li.mpa/mpa.c:44
+#: ../raster/r.li/r.li.pielou/pielou.c:47
+msgid "landscape structure analysis"
+msgstr ""
+#: ../raster/r.li/r.li.dominance/dominance.c:48
+#: ../raster/r.li/r.li.simpson/simpson.c:48
+#: ../raster/r.li/r.li.renyi/renyi.c:49
+#: ../raster/r.li/r.li.richness/richness.c:45
+#: ../raster/r.li/r.li.shannon/shannon.c:48
+#: ../raster/r.li/r.li.pielou/pielou.c:48
+msgid "diversity index"
+msgstr ""
+#: ../raster/r.li/r.li.dominance/dominance.c:56
+#: ../raster/r.li/r.li.simpson/simpson.c:56
+#: ../raster/r.li/r.li.padsd/padsd.c:62
+#: ../raster/r.li/r.li.patchdensity/main.c:61
+#: ../raster/r.li/r.li.padrange/padrange.c:62
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:58
+#: ../raster/r.li/r.li.renyi/renyi.c:57 ../raster/r.li/r.li.cwed/cwed.c:64
+#: ../raster/r.li/r.li.richness/richness.c:53
+#: ../raster/r.li/r.li.padcv/padcv.c:62 ../raster/r.li/r.li.shape/main.c:59
+#: ../raster/r.li/r.li.mps/mps.c:62 ../raster/r.li/r.li.patchnum/main.c:59
+#: ../raster/r.li/r.li.shannon/shannon.c:56 ../raster/r.li/r.li.mpa/mpa.c:52
+#: ../raster/r.li/r.li.pielou/pielou.c:56
+msgid "Configuration file"
+msgstr ""
+#: ../raster/r.li/r.li.simpson/simpson.c:45
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.padsd/padsd.c:52
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.padsd/padsd.c:55
+#: ../raster/r.li/r.li.patchdensity/main.c:53
+#: ../raster/r.li/r.li.padrange/padrange.c:55
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:50
+#: ../raster/r.li/r.li.cwed/cwed.c:56 ../raster/r.li/r.li.padcv/padcv.c:55
+#: ../raster/r.li/r.li.shape/main.c:51 ../raster/r.li/r.li.mps/mps.c:54
+#: ../raster/r.li/r.li.patchnum/main.c:52 ../raster/r.li/r.li.mpa/mpa.c:45
+msgid "patch index"
+msgstr ""
+#: ../raster/r.li/r.li.patchdensity/main.c:50
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.padrange/padrange.c:52
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
+msgid "The value of the patch type"
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
+msgid ""
+"It can be integer, double or float; it will be changed in function of map "
+"type"
+msgstr ""
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
+msgid "Exclude border edges"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:46
+msgid "Calculates Renyi's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.renyi/renyi.c:63
+msgid "Alpha value is the order of the generalized entropy"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:53
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:70
+msgid "Name of file that contains the weight to calculate the index"
+msgstr ""
+#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:453
+#: ../raster/r.li/r.li.cwed/cwed.c:599
+msgid "Row cache is too small"
+msgstr ""
+#: ../raster/r.li/r.li.richness/richness.c:42
+msgid "Calculates richness index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.padcv/padcv.c:52
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.shape/main.c:48
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.mps/mps.c:51
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+#: ../raster/r.li/r.li.patchnum/main.c:49
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../raster/r.li/r.li.daemon/worker.c:135
+#, c-format
+msgid "unable to open <%s> mask ... continuing without!"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:97
+msgid "Cannot create random access file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:105
+#: ../raster/r.li/r.li.daemon/daemon.c:111
+#: ../raster/r.li/r.li.daemon/daemon.c:117
+#, c-format
+msgid "Cannot create %s directory"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:201
+#, c-format
+msgid "Cannot find configuration file <%s>"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:208
+#: ../raster/r.li/r.li.daemon/daemon.c:212
+msgid "Cannot read setup file"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:216
+msgid "Unable to parse configuration file (sampling frame)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:475
+msgid "Irregular MASKEDOVERLAY areas definition"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:479
+#, c-format
+msgid "The configuration file can only be used with the <%s> raster map"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:485
+msgid "Unable to parse configuration file (sample area)"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:520
+msgid "Too many units to place"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:589
+msgid "Too many stratified random sample for raster map"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:623
+msgid "Illegal areas disposition"
+msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:695
+msgid "Cannot make lseek"
+msgstr ""
+#: ../raster/r.li/r.li.shannon/shannon.c:45
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.mpa/mpa.c:42
+msgid "Calculates mean pixel attribute index on a raster map"
+msgstr ""
+#: ../raster/r.li/r.li.pielou/pielou.c:45
+msgid "Calculates Pielou's diversity index on a raster map"
+msgstr ""
+#: ../raster/r.horizon/main.c:184
+msgid "Computes horizon angle height from a digital elevation model."
+msgstr ""
+#: ../raster/r.horizon/main.c:186
+msgid ""
+"The module has two different modes of operation: 1. Computes the entire "
+"horizon around a single point whose coordinates are given with the 'coord' "
+"option. The horizon height (in radians). 2. Computes one or more raster maps "
+"of the horizon height in a single direction. The input for this is the angle "
+"(in degrees), which is measured counterclockwise with east=0, north=90 etc. "
+"The output is the horizon height in radians."
+msgstr ""
+#: ../raster/r.horizon/main.c:203
+msgid "Direction in which you want to know the horizon height"
+msgstr ""
+#: ../raster/r.horizon/main.c:211 ../raster/r.sun/main.c:381
+msgid "Angle step size for multidirectional horizon [degrees]"
+msgstr ""
+#: ../raster/r.horizon/main.c:220
+msgid "Start angle for multidirectional horizon [degrees]"
+msgstr ""
+#: ../raster/r.horizon/main.c:221 ../raster/r.horizon/main.c:230
+#: ../raster/r.horizon/main.c:238 ../raster/r.horizon/main.c:246
+#: ../raster/r.horizon/main.c:254 ../raster/r.horizon/main.c:262
+#: ../raster/r.horizon/main.c:270 ../raster/r.horizon/main.c:283
+msgid "Raster mode"
+msgstr ""
+#: ../raster/r.horizon/main.c:229
+msgid "End angle for multidirectional horizon [degrees]"
+msgstr ""
+#: ../raster/r.horizon/main.c:237
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer around the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:245
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer eastward the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:253
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer westward the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:261
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer northward the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:269
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer southward the present "
+"region"
+msgstr ""
+#: ../raster/r.horizon/main.c:277
+msgid "The maximum distance to consider when finding the horizon height"
+msgstr ""
+#: ../raster/r.horizon/main.c:278 ../raster/r.horizon/main.c:297
+msgid "Optional"
+msgstr ""
+#: ../raster/r.horizon/main.c:288
+msgid "Coordinate for which you want to calculate the horizon"
+msgstr ""
+#: ../raster/r.horizon/main.c:289 ../raster/r.horizon/main.c:305
+msgid "Point mode"
+msgstr ""
+#: ../raster/r.horizon/main.c:296 ../raster/r.sun/main.c:492
+msgid "Sampling distance step coefficient (0.5-1.5)"
+msgstr ""
+#: ../raster/r.horizon/main.c:310
+msgid "Write output in degrees (default is radians)"
+msgstr ""
+#: ../raster/r.horizon/main.c:315
+msgid "Write output in compass orientation (default is CCW, East=0)"
+msgstr ""
+#: ../raster/r.horizon/main.c:355
+msgid ""
+"Note: In latitude-longitude coordinate system specify buffers in degree unit"
+msgstr ""
+#: ../raster/r.horizon/main.c:368
+msgid "Can't read the coordinates from the \"coordinate\" option."
+msgstr ""
+#: ../raster/r.horizon/main.c:395
+msgid "You didn't specify a direction value or step size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:400
+msgid "You didn't specify a horizon raster name. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:415
+msgid "Negative values of start angle are not allowed. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:419
+msgid "End angle is not between 0 and 360. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:423
+msgid "You specify a start grater than the end angle. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:431
+msgid "You didn't specify an angle step size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:442
+msgid "Could not read bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:447 ../raster/r.horizon/main.c:453
+#: ../raster/r.horizon/main.c:460 ../raster/r.horizon/main.c:467
+#, c-format
+msgid "Could not read %s bufferzone size. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:448
+msgid "east"
+msgstr ""
+#: ../raster/r.horizon/main.c:454
+msgid "west"
+msgstr ""
+#: ../raster/r.horizon/main.c:461
+msgid "south"
+msgstr ""
+#: ../raster/r.horizon/main.c:468
+msgid "north"
+msgstr ""
+#: ../raster/r.horizon/main.c:473
+msgid "Could not read maximum distance. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:478
+msgid "The distance value must be 0.5-1.5. Aborting."
+msgstr ""
+#: ../raster/r.horizon/main.c:1168
+#, c-format
+msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
+msgstr ""
+#: ../raster/r.sun/main.c:241
+msgid "sun energy"
+msgstr ""
+#: ../raster/r.sun/main.c:243
+msgid "Solar irradiance and irradiation model."
+msgstr ""
+#: ../raster/r.sun/main.c:245
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
+msgstr ""
+#: ../raster/r.sun/main.c:259
+msgid "Name of the input elevation raster map [meters]"
+msgstr ""
+#: ../raster/r.sun/main.c:268
+msgid ""
+"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
+"[decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:277
+msgid "A single value of the orientation (aspect), 270 is south"
+msgstr ""
+#: ../raster/r.sun/main.c:286
+msgid ""
+"Name of the input slope raster map (terrain slope or solar panel "
+"inclination) [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:294
+msgid "A single value of inclination (slope)"
+msgstr ""
+#: ../raster/r.sun/main.c:303
+msgid ""
+"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:312
+msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:321
+msgid "Name of the ground albedo coefficient input raster map [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:330
+msgid "A single value of the ground albedo coefficient [-]"
+msgstr ""
+#: ../raster/r.sun/main.c:339
+msgid "Name of input raster map containing latitudes [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:348
+msgid "Name of input raster map containing longitudes [decimal degrees]"
+msgstr ""
+#: ../raster/r.sun/main.c:357
+msgid ""
+"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
+"[0-1]"
+msgstr ""
+#: ../raster/r.sun/main.c:366
+msgid ""
+"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgstr ""
+#: ../raster/r.sun/main.c:373
+msgid "The horizon information input map basename"
+msgstr ""
+#: ../raster/r.sun/main.c:390
+msgid "Output incidence angle raster map (mode 1 only)"
+msgstr ""
+#: ../raster/r.sun/main.c:399
+msgid ""
+"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:408
+msgid ""
+"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:417
+msgid ""
+"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
+"map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:426
+msgid ""
+"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
+"irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+#: ../raster/r.sun/main.c:435
+msgid "Output insolation time raster map [h] (mode 2 only)"
+msgstr ""
+#: ../raster/r.sun/main.c:442
+msgid "No. of day of the year (1-365)"
+msgstr ""
+#: ../raster/r.sun/main.c:452
+msgid "Time step when computing all-day radiation sums [decimal hours]"
+msgstr ""
+#: ../raster/r.sun/main.c:460
+msgid "Declination value (overriding the internally computed value) [radians]"
+msgstr ""
+#: ../raster/r.sun/main.c:468
+msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
+msgstr ""
+#: ../raster/r.sun/main.c:500
+msgid "Read the input files in this number of chunks"
+msgstr ""
+#: ../raster/r.sun/main.c:507
+msgid "Civil time zone value, if none, the time will be local solar time"
+msgstr ""
+#: ../raster/r.sun/main.c:513
+msgid "Do not incorporate the shadowing effect of terrain"
+msgstr ""
+#: ../raster/r.sun/main.c:518
+msgid "Use the low-memory version of the program"
+msgstr ""
+#: ../raster/r.sun/main.c:559
+msgid "You must give the longitude raster if you use civil time"
+msgstr ""
+#: ../raster/r.sun/main.c:562
+msgid "Error reading civil time zone value"
+msgstr ""
+#: ../raster/r.sun/main.c:565
+msgid "Invalid civil time zone value"
+msgstr ""
+#: ../raster/r.sun/main.c:590
+msgid "insol_time and incidout are incompatible options"
+msgstr ""
+#: ../raster/r.sun/main.c:595
+msgid "Error reading time step size"
+msgstr ""
+#: ../raster/r.sun/main.c:597
+msgid "Invalid time step size"
+msgstr ""
+#: ../raster/r.sun/main.c:601
+msgid "Error reading horizon step size"
+msgstr ""
+#: ../raster/r.sun/main.c:606
+msgid "The horizon step size must be greater than 0."
+msgstr ""
+#: ../raster/r.sun/main.c:609
+msgid ""
+"If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr ""
+#: ../raster/r.sun/main.c:615
+msgid "Time and insol_time are incompatible options"
+msgstr ""
+#: ../raster/r.sun/main.c:617
+msgid ""
+"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
+"time"
+msgstr ""
+#: ../raster/r.sun/main.c:622
+msgid "incidout requires time parameter to be set"
+msgstr ""
+#: ../raster/r.sun/main.c:624
+msgid "Mode 2: integrated daily irradiation for a given day of the year"
+msgstr ""
+#: ../raster/r.sun/main.c:670
+msgid "If you use -s and no horizon rasters, numpartitions must be =1"
+msgstr ""
+#: ../raster/r.sun/main.c:683
+msgid ""
+"If you want to save memory and to use shadows, you must use pre-calculated "
+"horizons."
+msgstr ""
+#: ../raster/r.sun/main.c:750
+msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
+msgstr ""
+#: ../raster/r.sun/main.c:755
+msgid "Both latin and longin raster maps must be given, or neither"
+msgstr ""
+#: ../raster/r.compress/main.c:66
+msgid "compression"
+msgstr ""
+#: ../raster/r.compress/main.c:67
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../raster/r.compress/main.c:75
+msgid "Name of existing raster map(s)"
+msgstr ""
+#: ../raster/r.compress/main.c:79
+msgid "Uncompress the map"
+msgstr ""
+#: ../raster/r.compress/main.c:83
+msgid "Print compression information and data type of input map(s)"
+msgstr ""
+#: ../raster/r.compress/main.c:123
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress"
+msgstr ""
+#: ../raster/r.compress/main.c:125
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"
+msgstr ""
+#: ../raster/r.compress/main.c:130
+#, c-format
+msgid "<%s> is a GDAL-linked map - can't (un)compress"
+msgstr ""
+#: ../raster/r.compress/main.c:172
+#, c-format
+msgid "DONE: uncompressed file is %lu bytes smaller"
+msgstr ""
+#: ../raster/r.compress/main.c:173
+#, c-format
+msgid "DONE: compressed file is %lu bytes smaller"
+msgstr ""
+#: ../raster/r.compress/main.c:177
+#, c-format
+msgid "DONE: uncompressed file is %lu bytes bigger"
+msgstr ""
+#: ../raster/r.compress/main.c:178
+#, c-format
+msgid "DONE: compressed file is %lu bytes bigger"
+msgstr ""
+#: ../raster/r.compress/main.c:196
+#, c-format
+msgid "<%s> already uncompressed"
+msgstr ""
+#: ../raster/r.compress/main.c:200
+#, c-format
+msgid "<%s> already compressed"
+msgstr ""
+#: ../raster/r.compress/main.c:204
+#, c-format
+msgid ""
+"\n"
+"%sCOMPRESS <%s>"
+msgstr ""
+#: ../raster/r.compress/main.c:261 ../raster/r.compress/main.c:276
+#, c-format
+msgid "<%s> is a GDAL-linked map"
+msgstr ""
+#: ../raster/r.compress/main.c:270
+#, c-format
+msgid "<%s> is a reclass file of map <%s> in mapset <%s>"
+msgstr ""
+#: ../raster/r.compress/main.c:286
+#, c-format
+msgid "<%s> is uncompressed (level %i: %s). Data type: <%s>"
+msgstr ""
+#: ../raster/r.compress/main.c:293
+#, c-format
+msgid "<%s> is compressed (level %i: %s). Data type: <%s>"
+msgstr ""
+#: ../raster/r.statistics/main.c:58
+msgid "Calculates category or object oriented statistics."
+msgstr ""
+#: ../raster/r.statistics/read_stats.c:20
+msgid "Reading r.stats output"
+msgstr ""
+#: ../raster/r.statistics/o_skew.c:91
+msgid "o_skew: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_sdev.c:94 ../raster/r.statistics/o_var.c:95
+msgid "o_var: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_kurt.c:91
+msgid "o_kurto: No data in array"
+msgstr ""
+#: ../raster/r.statistics/o_adev.c:93
+msgid "o_adev: No data in array"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:142
+#, c-format
+msgid "Filter <%s> not found"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:386
+msgid "kernel filter"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:388
+msgid "Resamples raster map layers using an analytic kernel."
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:399
+msgid "Filter kernel(s)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:407
+msgid "Filter radius"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:414
+msgid "Filter radius (horizontal)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:421
+msgid "Filter radius (vertical)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:437
+#, c-format
+msgid "Either %s= or %s=/%s= required"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:440
+#, c-format
+msgid "Both %s= and %s= required"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:463
+msgid "Differing number of values for filter= and [xy_]radius="
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:466
+#, c-format
+msgid "Too many filters (max: %d)"
+msgstr ""
+#: ../raster/r.resamp.filter/main.c:484
+msgid "At least one filter must be finite"
+msgstr ""
+#: ../raster/r.neighbors/main.c:121
+#, c-format
+msgid "Invalid out_type enumeration: %d"
+msgstr ""
+#: ../raster/r.neighbors/main.c:175
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+#: ../raster/r.neighbors/main.c:185
+msgid ""
+"Name of an input raster map to select the cells which should be processed"
+msgstr ""
+#: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
+#: ../raster/r.neighbors/main.c:249
+msgid "Neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:226
+msgid "Text file containing weights"
+msgstr ""
+#: ../raster/r.neighbors/main.c:232
+msgid "Sigma (in cells) for Gaussian filter"
+msgstr ""
+#: ../raster/r.neighbors/main.c:244
+msgid "Do not align output with the input"
+msgstr ""
+#: ../raster/r.neighbors/main.c:248
+msgid "Use circular neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:256
+msgid "Neighborhood size must be positive"
+msgstr ""
+#: ../raster/r.neighbors/main.c:258
+msgid "Neighborhood size must be odd"
+msgstr ""
+#: ../raster/r.neighbors/main.c:293
+#, c-format
+msgid "%s= and %s= must have the same number of values"
+msgstr ""
+#: ../raster/r.neighbors/main.c:329
+#, c-format
+msgid ""
+"Method %s not compatible with weighing window, using weight mask instead"
+msgstr ""
+#: ../raster/r.neighbors/main.c:337
+#, c-format
+msgid ""
+"Method %s not compatible with Gaussian filter, using unweighed version "
+"instead"
+msgstr ""
+#: ../raster/r.neighbors/main.c:386
+#, c-format
+msgid "Opening selection map <%s>"
+msgstr ""
+#: ../raster/r.neighbors/readweights.c:18
+#, c-format
+msgid "Unable to open weights file %s"
+msgstr ""
+#: ../raster/r.neighbors/readweights.c:23
+#, c-format
+msgid "Error reading weights file %s"
+msgstr ""
+#: ../raster/r.cost/main.c:145
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+#: ../raster/r.cost/main.c:152
+msgid "Name of input raster map containing grid cell cost information"
+msgstr ""
+#: ../raster/r.cost/main.c:160
+msgid "Name for output raster map with nearest start point"
+msgstr ""
+#: ../raster/r.cost/main.c:444
+#, c-format
+msgid "Reading raster map <%s>, initializing output..."
+msgstr ""
+#: ../raster/r.cost/main.c:489
+#, c-format
+msgid ""
+"Negative cell value found at row %d, col %d. Setting negative value to "
+"null_cost value"
+msgstr ""
+#: ../raster/r.cost/main.c:582
+#, c-format
+msgid "No start points found in vector map <%s>"
+msgstr ""
+#: ../raster/r.cost/main.c:584
+#, c-format
+msgid "%d point found"
+msgid_plural "%d points found"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.cost/main.c:1036
+#, c-format
+msgid "Writing raster map with nearest start point <%s>..."
+msgstr ""
+#: ../raster/r.info/main.c:74
+msgid "Outputs basic information about a raster map."
+msgstr ""
+#: ../raster/r.info/main.c:80
+msgid "Print raster array information in shell script style"
+msgstr ""
+#: ../raster/r.info/main.c:84
+msgid "Print range in shell script style"
+msgstr ""
+#: ../raster/r.info/main.c:88
+msgid "Print extended metadata information in shell script style"
+msgstr ""
+#: ../raster/r.info/main.c:98
+#, c-format
+msgid "Flags -%c and -%c/%c/%c are mutually exclusive"
+msgstr ""
+#: ../raster/r.info/main.c:126
+msgid "Unable to read range file"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:151
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:162
+msgid "Desired east-west resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:168
+msgid "Desired north-south resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:173
+msgid "Name for output elevation raster map"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:179
+msgid "Name for output slope map (or fx)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:185
+msgid "Name for output aspect map (or fy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:191
+msgid "Name for output profile curvature map (or fxx)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:197
+msgid "Name for output tangential curvature map (or fyy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:203
+msgid "Name for output mean curvature map (or fxy)"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:209
+msgid "Name of input raster map containing smoothing"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:215
+msgid "Name of input raster map to be used as mask"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:223
+msgid "Rows/columns overlap for segmentation"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:231
+msgid "Multiplier for z-values"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:239
+msgid "Spline tension value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:254
+msgid "Anisotropy"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:258
+msgid "Use dnorm independent tension"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:297
+msgid "Unable to read ew_res value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:300
+msgid "Unable to read ns_res value"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:303
+msgid "Invalid value for tension"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:306
+msgid "Invalid value for zmult"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:309
+msgid "Invalid value for overlap"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:313
+msgid "Invalid value for theta"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:317
+msgid "Invalid value for scalex"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:319
+msgid "When using anisotropy both theta and scalex must be specified"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:357
+#, c-format
+msgid "Map <%s> is the wrong resolution"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:365
+msgid "Smoothing values can not be negative or NULL"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:371
+msgid "Input map resolution differs from current region resolution!"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:387
+msgid "Processing all selected output files will require"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:391
+#, c-format
+msgid "%.2f GB of disk space for temp files."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:394
+#, c-format
+msgid "%.2f MB of disk space for temp files."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:397
+#, c-format
+msgid "%.2f KB of disk space for temp files."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:400
+#, c-format
+msgid "%d byte of disk space for temp files."
+msgid_plural "%d bytes of disk space for temp files."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.resamp.rst/main.c:436
+msgid "Maximum value of a raster map is NULL."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:464
+msgid "Temporarily changing the region to desired resolution ..."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:469
+msgid "Changing back to the original region ..."
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:490
+#, c-format
+msgid "dnorm in mainc after grid before out1= %f"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:494
+msgid "split_and_interpolate() failed"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:509
+#, c-format
+msgid "dnorm in mainc after grid before out2= %f"
+msgstr ""
+#: ../raster/r.resamp.rst/main.c:515
+msgid "Unable to write raster maps -- try increasing cell size"
+msgstr ""
+#: ../raster/r.texture/h_measure.c:123
+#, c-format
+msgid ""
+"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
+"map"
+msgstr ""
+#: ../raster/r.texture/main.c:67
+#, c-format
+msgid "Unknown measure <%s>"
+msgstr ""
+#: ../raster/r.texture/main.c:104
+msgid "texture"
+msgstr ""
+#: ../raster/r.texture/main.c:106
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../raster/r.texture/main.c:120
+msgid "The size of moving window (odd and >= 3)"
+msgstr ""
+#: ../raster/r.texture/main.c:130
+msgid "The distance between two samples (>= 1)"
+msgstr ""
+#: ../raster/r.texture/main.c:146
+msgid "Textural measurement method"
+msgstr ""
+#: ../raster/r.texture/main.c:150
+msgid "Separate output for each angle (0, 45, 90, 135)"
+msgstr ""
+#: ../raster/r.texture/main.c:154
+msgid "Calculate all textural measurements"
+msgstr ""
+#: ../raster/r.texture/main.c:163
+msgid "Size of the moving window must be > 0"
+msgstr ""
+#: ../raster/r.texture/main.c:165
+msgid "Size of the moving window must be odd"
+msgstr ""
+#: ../raster/r.texture/main.c:168
+msgid "The distance between two samples must be > 0"
+msgstr ""
+#: ../raster/r.texture/main.c:189
+msgid "Nothing to compute. Use at least one textural measure."
+msgstr ""
+#: ../raster/r.texture/main.c:327
+#, c-format
+msgid "Calculating %d texture measure"
+msgid_plural "Calculating %d texture measures"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.texture/main.c:330
+#, c-format
+msgid "Calculating %s"
+msgstr ""
+#: ../raster/r.random.cells/init.c:70
+msgid "Distance must be >= 0.0"
+msgstr ""
+#: ../raster/r.random.cells/main.c:48
+msgid "autocorrelation"
+msgstr ""
+#: ../raster/r.random.cells/main.c:50
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../raster/r.random.cells/main.c:67
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
+msgstr ""
+#: ../raster/r.random.cells/random.c:50
+#, c-format
+msgid "RAN1: j == %d shouldn't happen"
+msgstr ""
+#: ../display/d.graph/graphics.c:60 ../display/d.graph/do_graph.c:129
+#: ../display/d.graph/do_graph.c:195 ../display/d.graph/do_graph.c:216
+#: ../display/d.graph/do_graph.c:267 ../display/d.graph/do_graph.c:334
+#, c-format
+msgid "Problem parsing command [%s]"
+msgstr ""
+#: ../display/d.graph/main.c:61
+msgid ""
+"Program for generating and displaying simple graphics on the display monitor."
+msgstr ""
+#: ../display/d.graph/main.c:66
+msgid ""
+"Name of file containing graphics commands, if not given reads from standard "
+"input"
+msgstr ""
+#: ../display/d.graph/main.c:73
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.graph/main.c:80
+msgid "Coordinates are given in map units"
+msgstr ""
+#: ../display/d.graph/main.c:91
+#, c-format
+msgid "Graph file <%s> not found"
+msgstr ""
+#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
+#, c-format
+msgid "Problem parsing coordinates [%s]"
+msgstr ""
+#: ../display/d.graph/do_graph.c:98
+msgid "Unable to read color"
+msgstr ""
+#: ../display/d.graph/do_graph.c:377
+msgid "Cannot read symbol, cannot display points"
+msgstr ""
+#: ../display/d.labels/main.c:46
+msgid ""
+"Displays text labels (created with v.label) to the active frame on the "
+"graphics monitor."
+msgstr ""
+#: ../display/d.labels/main.c:52
+msgid "Ignore rotation setting and draw horizontally"
+msgstr ""
+#: ../display/d.labels/main.c:59
+msgid "Name of label file"
+msgstr ""
+#: ../display/d.labels/main.c:66
+msgid "Minimum region size (diagonal) when labels are displayed"
+msgstr ""
+#: ../display/d.labels/main.c:73
+msgid "Maximum region size (diagonal) when labels are displayed"
+msgstr ""
+#: ../display/d.labels/main.c:85
+#, c-format
+msgid "Label file <%s> not found"
+msgstr ""
+#: ../display/d.labels/main.c:97
+msgid "Region size is lower than minreg, nothing displayed."
+msgstr ""
+#: ../display/d.labels/main.c:105
+msgid "Region size is greater than maxreg, nothing displayed."
+msgstr ""
+#: ../display/d.labels/do_labels.c:142
+#, c-format
+msgid "Error: %s\n"
+msgstr ""
+#: ../display/d.grid/fiducial.c:61
+msgid "Reading symbol"
+msgstr ""
+#: ../display/d.grid/main.c:54
+msgid ""
+"Overlays a user-specified grid in the active display frame on the graphics "
+"monitor."
+msgstr ""
+#: ../display/d.grid/main.c:62
+msgid "Size of grid to be drawn (in map units)"
+msgstr ""
+#: ../display/d.grid/main.c:63
+msgid ""
+"0 for north-south resolution of the current region. In map units or DDD:MM:"
+"SS format. Example: \"1000\" or \"0:10\""
+msgstr ""
+#: ../display/d.grid/main.c:71
+msgid "Lines of the grid pass through this coordinate"
+msgstr ""
+#: ../display/d.grid/main.c:80
+msgid "Draw only east-west lines, north-south lines, or both "
+msgstr ""
+#: ../display/d.grid/main.c:81 ../display/d.grid/main.c:147
+#: ../display/d.grid/main.c:152 ../display/d.grid/main.c:157
+msgid "Disable"
+msgstr ""
+#: ../display/d.grid/main.c:87
+msgid "Grid line width"
+msgstr ""
+#: ../display/d.grid/main.c:91 ../display/d.rast.num/main.c:93
+msgid "Grid color"
+msgstr ""
+#: ../display/d.grid/main.c:92 ../display/d.grid/main.c:97
+#: ../display/d.grid/main.c:103
+msgid "Color"
+msgstr ""
+#: ../display/d.grid/main.c:111
+msgid "Font size for gridline coordinate labels"
+msgstr ""
+#: ../display/d.grid/main.c:115
+msgid "Align the origin to the east-north corner of the current region"
+msgstr ""
+#: ../display/d.grid/main.c:120
+msgid "Draw geographic grid (referenced to current ellipsoid)"
+msgstr ""
+#: ../display/d.grid/main.c:126
+msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
+msgstr ""
+#: ../display/d.grid/main.c:131
+msgid "Draw '+' marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:136
+msgid "Draw '.' marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:141
+msgid "Draw fiducial marks instead of grid lines"
+msgstr ""
+#: ../display/d.grid/main.c:146
+msgid "Disable grid drawing"
+msgstr ""
+#: ../display/d.grid/main.c:151
+msgid "Disable border drawing"
+msgstr ""
+#: ../display/d.grid/main.c:156
+msgid "Disable text drawing"
+msgstr ""
+#: ../display/d.grid/main.c:166
+msgid "Both grid and border drawing are disabled"
+msgstr ""
+#: ../display/d.grid/main.c:170
+msgid "Geo-grid option not available for LL projection, use without -g/-w"
+msgstr ""
+#: ../display/d.grid/main.c:172
+msgid "Geo-grid option not available for XY projection, use without -g/-w"
+msgstr ""
+#: ../display/d.grid/main.c:191
+msgid "Choose a single mark style"
+msgstr ""
+#: ../display/d.grid/main.c:221
+#, c-format
+msgid "Invalid geo-grid size <%s>"
+msgstr ""
+#: ../display/d.grid/main.c:226
+#, c-format
+msgid "Invalid grid size <%s>"
+msgstr ""
+#: ../display/d.grid/plot.c:310
+msgid "Geo-grid option only available for LL projection, use without -g/-w"
+msgstr ""
+#: ../display/d.grid/plot.c:370
+msgid ""
+"WGS84 grid output not possible as this location does not contain\n"
+"datum transformation parameters. Try running g.setproj."
+msgstr ""
+#: ../display/d.grid/plot.c:538
+msgid "Error in pj_do_proj1"
+msgstr ""
+#: ../display/d.grid/plot.c:544
+msgid "Error in pj_do_proj2"
+msgstr ""
+#: ../display/d.grid/plot.c:548
+msgid "Error in pj_do_proj3"
+msgstr ""
+#: ../display/d.grid/plot.c:556
+msgid "Error in pj_do_proj5"
+msgstr ""
+#: ../display/d.grid/plot.c:560
+msgid "Error in pj_do_proj6"
+msgstr ""
+#: ../display/d.rhumbline/main.c:46
+msgid "rhumbline"
+msgstr ""
+#: ../display/d.rhumbline/main.c:48
+msgid "Displays the rhumbline joining two longitude/latitude coordinates."
+msgstr ""
+#: ../display/d.rhumbline/main.c:53 ../display/d.geodesic/main.c:58
+#: ../display/d.path/main.c:65
+msgid "Starting and ending coordinates"
+msgstr ""
+#: ../display/d.rhumbline/main.c:57 ../display/d.geodesic/main.c:62
+#: ../display/d.northarrow/main.c:65
+msgid "Line color"
+msgstr ""
+#: ../display/d.rhumbline/main.c:62
+msgid "Text color or \"none\""
+msgstr ""
+#: ../display/d.rhumbline/main.c:75 ../display/d.geodesic/main.c:78
+#, c-format
+msgid "Location is not %s"
+msgstr ""
+#: ../display/d.rhumbline/main.c:86 ../display/d.geodesic/main.c:87
+#: ../display/d.path/main.c:140
+msgid "No coordinates given"
+msgstr ""
+#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
+#: ../display/d.rhumbline/main.c:95 ../display/d.rhumbline/main.c:98
+#: ../display/d.geodesic/main.c:90 ../display/d.geodesic/main.c:93
+#: ../display/d.geodesic/main.c:96 ../display/d.geodesic/main.c:99
+#, c-format
+msgid "%s - illegal longitude"
+msgstr ""
+#: ../display/d.mon/main.c:41
+msgid "Controls graphics display monitors from the command line."
+msgstr ""
+#: ../display/d.mon/main.c:46
+msgid "Name of monitor to start"
+msgstr ""
+#: ../display/d.mon/main.c:48 ../display/d.mon/main.c:55
+#: ../display/d.mon/main.c:62 ../display/d.mon/main.c:118
+#: ../display/d.mon/main.c:123
+msgid "Manage"
+msgstr ""
+#: ../display/d.mon/main.c:53
+msgid "Name of monitor to stop"
+msgstr ""
+#: ../display/d.mon/main.c:60
+msgid "Name of monitor to select"
+msgstr ""
+#: ../display/d.mon/main.c:66
+msgid "Width for display monitor if not set by GRASS_RENDER_WIDTH"
+msgstr ""
+#: ../display/d.mon/main.c:67
+msgid "Default value: 640"
+msgstr ""
+#: ../display/d.mon/main.c:74
+msgid "Height for display monitor if not set by GRASS_RENDER_HEIGHT"
+msgstr ""
+#: ../display/d.mon/main.c:75
+msgid "Default value: 480"
+msgstr ""
+#: ../display/d.mon/main.c:82
+msgid "Dimensions of display monitor versus current size"
+msgstr ""
+#: ../display/d.mon/main.c:83
+msgid "Example: resolution=2 enlarge display monitor twice to 1280x960"
+msgstr ""
+#: ../display/d.mon/main.c:96
+msgid "Name for output file (when starting new monitor)"
+msgstr ""
+#: ../display/d.mon/main.c:97
+msgid "Ignored for 'wx' monitors"
+msgstr ""
+#: ../display/d.mon/main.c:102
+msgid "List running monitors and exit"
+msgstr ""
+#: ../display/d.mon/main.c:107
+msgid "Print name of currently selected monitor and exit"
+msgstr ""
+#: ../display/d.mon/main.c:112
+msgid "Print commands for currently selected monitor and exit"
+msgstr ""
+#: ../display/d.mon/main.c:117
+msgid "Do not automatically select when starting"
+msgstr ""
+#: ../display/d.mon/main.c:122
+msgid "Release and stop currently selected monitor and exit"
+msgstr ""
+#: ../display/d.mon/main.c:127
+msgid "Disable true colors"
+msgstr ""
+#: ../display/d.mon/main.c:132
+msgid "Open output file in update mode"
+msgstr ""
+#: ../display/d.mon/main.c:133
+msgid "Requires --overwrite flag"
+msgstr ""
+#: ../display/d.mon/main.c:145
+msgid "Currently selected monitor:"
+msgstr ""
+#: ../display/d.mon/main.c:149
+#, c-format
+msgid "List of commands for monitor <%s>:"
+msgstr ""
+#: ../display/d.mon/main.c:154
+#, c-format
+msgid "Monitor <%s> released"
+msgstr ""
+#: ../display/d.mon/main.c:159
+msgid "No monitor selected"
+msgstr ""
+#: ../display/d.mon/main.c:178
+#, c-format
+msgid "Either <%s>, <%s> or <%s> must be given"
+msgstr ""
+#: ../display/d.mon/stop.c:18 ../display/d.mon/select.c:30
+#, c-format
+msgid "Monitor <%s> is not running"
+msgstr ""
+#: ../display/d.mon/stop.c:37
+msgid "Env file not found"
+msgstr ""
+#: ../display/d.mon/stop.c:55
+msgid "PID file not found"
+msgstr ""
+#: ../display/d.mon/start.c:32
+#, c-format
+msgid "File '%s' already exists and will be overwritten"
+msgstr ""
+#: ../display/d.mon/start.c:54
+msgid "Unable to get current working directory"
+msgstr ""
+#: ../display/d.mon/start.c:61
+#, c-format
+msgid "Output file: %s"
+msgstr ""
+#: ../display/d.mon/start.c:119
+#, c-format
+msgid "Monitor <%s> already running"
+msgstr ""
+#: ../display/d.mon/start.c:132
+#, c-format
+msgid "Unable to create file '%s'"
+msgstr ""
+#: ../display/d.mon/start.c:163
+#, c-format
+msgid "Starting monitor <%s> with env file '%s'"
+msgstr ""
+#: ../display/d.mon/select.c:14
+#, c-format
+msgid "Monitor <%s> is already selected"
+msgstr ""
+#: ../display/d.mon/list.c:47
+msgid "List of running monitors:"
+msgstr ""
+#: ../display/d.mon/list.c:49
+msgid "No monitors running"
+msgstr ""
+#: ../display/d.mon/list.c:84
+msgid "Command file not found"
+msgstr ""
+#: ../display/d.mon/list.c:88
+msgid "Unable to read command file"
+msgstr ""
+#: ../display/d.erase/main.c:33
+msgid ""
+"Erases the contents of the active graphics display frame with user defined "
+"color."
+msgstr ""
+#: ../display/d.erase/main.c:42
+msgid "Remove all frames and erase the screen"
+msgstr ""
+#: ../display/d.font/main.c:48
+msgid ""
+"Selects the font in which text will be displayed on the user's graphics "
+"monitor."
+msgstr ""
+#: ../display/d.font/main.c:56
+msgid "Choose new current font"
+msgstr ""
+#: ../display/d.font/main.c:62
+msgid "Path to Freetype-compatible font including file name"
+msgstr ""
+#: ../display/d.font/main.c:70
+msgid "Character encoding"
+msgstr ""
+#: ../display/d.font/main.c:74
+msgid "List fonts"
+msgstr ""
+#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:55
+msgid "List fonts verbosely"
+msgstr ""
+#: ../display/d.font/main.c:103
+#, c-format
+msgid "Unable to access font path %s: %s"
+msgstr ""
+#: ../display/d.font/main.c:107
+#, c-format
+msgid "Font path %s is not a file"
+msgstr ""
+#: ../display/d.font/main.c:124
+#, c-format
+msgid ""
+"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgstr ""
+#: ../display/d.geodesic/main.c:48
+msgid "great circle"
+msgstr ""
+#: ../display/d.geodesic/main.c:51
+msgid ""
+"Displays a geodesic line, tracing the shortest distance between two "
+"geographic points along a great circle, in a longitude/latitude data set."
+msgstr ""
+#: ../display/d.rast/main.c:56
+msgid "Displays user-specified raster map in the active graphics frame."
+msgstr ""
+#: ../display/d.rast/main.c:61
+msgid "Name of raster map to be displayed"
+msgstr ""
+#: ../display/d.rast/main.c:69
+msgid "List of categories or values to be displayed"
+msgstr ""
+#: ../display/d.rast/main.c:76
+msgid "Background color (for null)"
+msgstr ""
+#: ../display/d.rast/main.c:77 ../display/d.rast/main.c:82
+#: ../display/d.rgb/main.c:64
+msgid "Null cells"
+msgstr ""
+#: ../display/d.rast/main.c:81 ../display/d.rgb/main.c:63
+msgid "Make null cells opaque"
+msgstr ""
+#: ../display/d.rast/main.c:86
+msgid "Invert value list"
+msgstr ""
+#: ../display/d.rast/main.c:204
+#, c-format
+msgid "[%s]: illegal category specified"
+msgstr ""
+#: ../display/d.rast/main.c:235
+#, c-format
+msgid "[%s]: illegal value specified"
+msgstr ""
+#: ../display/d.rast.num/main.c:77 ../display/d.rast.arrow/main.c:96
+msgid "map annotations"
+msgstr ""
+#: ../display/d.rast.num/main.c:80
+msgid ""
+"Overlays cell category values on a raster map displayed in the active "
+"graphics frame."
+msgstr ""
+#: ../display/d.rast.num/main.c:107 ../display/d.rast.arrow/main.c:162
+msgid "Align grids with raster cells"
+msgstr ""
+#: ../display/d.rast.num/main.c:111
+msgid "Get text color from cell color value"
+msgstr ""
+#: ../display/d.rast.num/main.c:177
+#, c-format
+msgid "%d col"
+msgid_plural "%d cols"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s will be replaced by strings "X rows" and "Y cols"
+#: ../display/d.rast.num/main.c:179
+#, c-format
+msgid ""
+"Current region size: %s X %s\n"
+"Your current region setting may be too large. Cells displayed on your "
+"graphics window may be too small for cell category number to be visible."
+msgstr ""
+#: ../display/d.rast.num/main.c:189
+msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
+msgstr ""
+#: ../display/d.vect/opt.c:126
+#, c-format
+msgid "Unknown color: '%s'"
+msgstr ""
+#: ../display/d.vect/area.c:37
+msgid ""
+"Unable to display areas, topology not available. Please try to rebuild "
+"topology using v.build or v.build.all."
+msgstr ""
+#: ../display/d.vect/area.c:137
+#, c-format
+msgid "Invalid area %d skipped (not enough points)"
+msgstr ""
+#: ../display/d.vect/area.c:236
+#, c-format
+msgid "%d invalid color rule for areas skipped"
+msgid_plural "%d invalid color rules for areas skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/main.c:73
+msgid "Displays user-specified vector map in the active graphics frame."
+msgstr ""
+#: ../display/d.vect/main.c:89
+msgid "Display"
+msgstr ""
+#: ../display/d.vect/main.c:93
+msgid "Display geometry of features"
+msgstr ""
+#: ../display/d.vect/main.c:94
+msgid "Display category numbers of features"
+msgstr ""
+#: ../display/d.vect/main.c:95
+msgid "Display topology information (nodes, edges)"
+msgstr ""
+#: ../display/d.vect/main.c:96
+msgid "Display vertices of features"
+msgstr ""
+#: ../display/d.vect/main.c:97
+msgid "Display direction of linear features"
+msgstr ""
+#: ../display/d.vect/main.c:98
+msgid "Display z-coordinate of features (only for 3D vector maps)"
+msgstr ""
+#: ../display/d.vect/main.c:116
+msgid "Feature color"
+msgstr ""
+#: ../display/d.vect/main.c:122
+msgid "Area fill color"
+msgstr ""
+#: ../display/d.vect/main.c:128
+msgid "Colorize features according color definition column"
+msgstr ""
+#: ../display/d.vect/main.c:129
+msgid "Color definition in R:G:B form"
+msgstr ""
+#: ../display/d.vect/main.c:133
+msgid "Colorize point or area features according to z-coordinate"
+msgstr ""
+#: ../display/d.vect/main.c:141 ../display/d.vect/main.c:146
+#: ../display/d.vect/main.c:154
+msgid "Lines"
+msgstr ""
+#: ../display/d.vect/main.c:142 ../display/d.northarrow/main.c:78
+msgid "Line width"
+msgstr ""
+#: ../display/d.vect/main.c:147
+msgid "Name of numeric column containing line width"
+msgstr ""
+#: ../display/d.vect/main.c:148
+msgid "These values will be scaled by width_scale"
+msgstr ""
+#: ../display/d.vect/main.c:155
+msgid "Scale factor for width_column"
+msgstr ""
+#: ../display/d.vect/main.c:163 ../display/d.vect/main.c:173
+#: ../display/d.vect/main.c:180 ../display/d.vect/main.c:186
+#: ../display/d.vect/main.c:296
+msgid "Symbols"
+msgstr ""
+#: ../display/d.vect/main.c:167
+msgid "Point and centroid symbol"
+msgstr ""
+#: ../display/d.vect/main.c:174
+msgid "Symbol size"
+msgstr ""
+#: ../display/d.vect/main.c:176
+msgid "When used with the size_column option this becomes the scale factor"
+msgstr ""
+#: ../display/d.vect/main.c:182
+msgid "Name of numeric column containing symbol size"
+msgstr ""
+#: ../display/d.vect/main.c:188
+msgid "Name of numeric column containing symbol rotation angle"
+msgstr ""
+#: ../display/d.vect/main.c:190
+msgid "Measured in degrees CCW from east"
+msgstr ""
+#: ../display/d.vect/main.c:196 ../display/d.vect/main.c:203
+#: ../display/d.vect/main.c:210 ../display/d.vect/main.c:215
+#: ../display/d.vect/main.c:222 ../display/d.vect/main.c:229
+#: ../display/d.vect/main.c:235 ../display/d.vect/main.c:241
+#: ../display/d.vect/main.c:247 ../display/d.vect/main.c:255
+msgid "Labels"
+msgstr ""
+#: ../display/d.vect/main.c:198
+msgid "Layer number for labels (default: the given layer number)"
+msgstr ""
+#: ../display/d.vect/main.c:204
+msgid "Name of column to be displayed as a label"
+msgstr ""
+#: ../display/d.vect/main.c:209
+msgid "Label color"
+msgstr ""
+#: ../display/d.vect/main.c:216
+msgid "Label background color"
+msgstr ""
+#: ../display/d.vect/main.c:223
+msgid "Label border color"
+msgstr ""
+#: ../display/d.vect/main.c:230
+msgid "Label size (pixels)"
+msgstr ""
+#: ../display/d.vect/main.c:242
+msgid "Text encoding"
+msgstr ""
+#: ../display/d.vect/main.c:250
+msgid "Label horizontal justification"
+msgstr ""
+#: ../display/d.vect/main.c:258
+msgid "Label vertical justification"
+msgstr ""
+#: ../display/d.vect/main.c:265
+msgid ""
+"Minimum region size (average from height and width) when map is displayed"
+msgstr ""
+#: ../display/d.vect/main.c:273
+msgid ""
+"Maximum region size (average from height and width) when map is displayed"
+msgstr ""
+#: ../display/d.vect/main.c:281
+msgid ""
+"Random colors according to category number (or layer number if 'layer=-1' is "
+"given)"
+msgstr ""
+#: ../display/d.vect/main.c:288
+msgid "Use values from 'cats' option as feature id"
+msgstr ""
+#: ../display/d.vect/main.c:292
+msgid "Use square root of the value of size_column"
+msgstr ""
+#: ../display/d.vect/main.c:294
+msgid ""
+"This makes circle areas proportionate to the size_column values instead of "
+"circle radius"
+msgstr ""
+#: ../display/d.vect/main.c:312
+msgid "Region size is lower than minreg, nothing displayed"
+msgstr ""
+#: ../display/d.vect/main.c:320
+msgid "Region size is greater than maxreg, nothing displayed"
+msgstr ""
+#: ../display/d.vect/main.c:333
+#, c-format
+msgid ""
+"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
+"ignored!"
+msgstr ""
+#: ../display/d.vect/main.c:357 ../display/d.vect/main.c:363
+#, c-format
+msgid "Option <%s> must be > 0"
+msgstr ""
+#: ../display/d.vect/main.c:367
+#, c-format
+msgid "%d error in cat option"
+msgid_plural "%d errors in cat option"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/main.c:383
+msgid "Plotting..."
+msgstr ""
+#: ../display/d.vect/main.c:391
+msgid ""
+"The bounding box of the map is outside the current region, nothing drawn"
+msgstr ""
+#: ../display/d.vect/main.c:457
+msgid "Rendering failed"
+msgstr ""
+#: ../display/d.vect/shape.c:53
+#, c-format
+msgid "Both color table and <%s> option detected. Color table will ignored."
+msgstr ""
+#: ../display/d.vect/shape.c:68
+#, c-format
+msgid ""
+"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
+"BBB' where RGB values range 0-255. You can use '%s' module to define color "
+"rules. Unable to colorize features."
+msgstr ""
+#: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
+#: ../display/d.vect/shape.c:131 ../display/d.vect/shape.c:162
+#, c-format
+msgid "Unable to select data ('%s') from table"
+msgstr ""
+#: ../display/d.vect/shape.c:85
+msgid "Line width column not specified"
+msgstr ""
+#: ../display/d.vect/shape.c:96
+#, c-format
+msgid "Line width column ('%s') not a number"
+msgstr ""
+#: ../display/d.vect/shape.c:116
+msgid "Symbol size column not specified"
+msgstr ""
+#: ../display/d.vect/shape.c:127
+#, c-format
+msgid "Symbol size column ('%s') is not numeric"
+msgstr ""
+#: ../display/d.vect/shape.c:147
+msgid "Symbol rotation column not specified"
+msgstr ""
+#: ../display/d.vect/shape.c:158
+#, c-format
+msgid "Symbol rotation column ('%s') is not numeric"
+msgstr ""
+#: ../display/d.vect/shape.c:182
+msgid ""
+"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgstr ""
+#: ../display/d.vect/shape.c:186
+#, c-format
+msgid "%s= and %s= are mutually exclusive. %s= will be ignored."
+msgstr ""
+#: ../display/d.vect/shape.c:329
+#, c-format
+msgid "Invalid negative value - feature %d with category %d"
+msgstr ""
+#: ../display/d.vect/topo.c:18
+msgid ""
+"Unable to display topology, not available.Please try to rebuild topology "
+"using v.build or v.build.all."
+msgstr ""
+#: ../display/d.vect/zcoor.c:19
+msgid "Vector map is not 3D. Unable to display z-coordinates."
+msgstr ""
+#: ../display/d.vect/lines.c:107 ../display/d.vect/lines.c:335
+#, c-format
+msgid "Unable to read symbol <%s>, unable to display points"
+msgstr ""
+#: ../display/d.vect/lines.c:121
+msgid ""
+"Unable to display features by id, topology not available. Please try to "
+"rebuild topology using v.build or v.build.all."
+msgstr ""
+#: ../display/d.vect/lines.c:169
+#, c-format
+msgid "%d invalid color rule for lines skipped"
+msgid_plural "%d invalid color rules for lines skipped"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/lines.c:175
+#, c-format
+msgid "%d point plotted"
+msgid_plural "%d points plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/lines.c:177
+#, c-format
+msgid "%d line plotted"
+msgid_plural "%d lines plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/lines.c:179
+#, c-format
+msgid "%d centroid plotted"
+msgid_plural "%d centroids plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/lines.c:181
+#, c-format
+msgid "%d boundary plotted"
+msgid_plural "%d boundaries plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/lines.c:183
+#, c-format
+msgid "%d face plotted"
+msgid_plural "%d faces plotted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.vect/attr.c:28
+msgid "attrcol not specified, cannot display attributes"
+msgstr ""
+#: ../display/d.vect/attr.c:129
+#, c-format
+msgid "No attribute found for cat %d: %s"
+msgstr ""
+#: ../display/d.vect/label.c:33
+msgid "Topology level required for drawing centroids for OGR layers"
+msgstr ""
+#: ../display/d.histogram/main.c:84
+msgid "histogram"
+msgstr ""
+#: ../display/d.histogram/main.c:87
+msgid ""
+"Displays a histogram in the form of a pie or bar chart for a user-specified "
+"raster map."
+msgstr ""
+#: ../display/d.histogram/main.c:91
+msgid "Raster map for which histogram will be displayed"
+msgstr ""
+#: ../display/d.histogram/main.c:95
+msgid "Indicate if a pie or bar chart is desired"
+msgstr ""
+#: ../display/d.histogram/main.c:104
+msgid "Color for text and axes"
+msgstr ""
+#: ../display/d.histogram/main.c:115
+msgid "Indicate if cell counts or map areas should be displayed"
+msgstr ""
+#: ../display/d.histogram/main.c:125
+msgid "Number of steps to divide the data range into (fp maps only)"
+msgstr ""
+#: ../display/d.histogram/main.c:132
+msgid "Display information for null cells"
+msgstr ""
+#: ../display/d.histogram/main.c:137
+msgid "Report for ranges defined in cats file (fp maps only)"
+msgstr ""
+#: ../display/d.histogram/main.c:161
+#, c-format
+msgid "Invalid number of steps: %s"
+msgstr ""
+#: ../display/d.histogram/main.c:166
+msgid "When -C flag is set, the nsteps argument is ignored"
+msgstr ""
+#: ../display/d.histogram/main.c:177 ../display/d.legend/main.c:560
+#: ../display/d.legend/main.c:565
+#, c-format
+msgid "Range information for <%s> not available"
+msgstr ""
+#: ../display/d.linegraph/main.c:122
+msgid ""
+"Generates and displays simple line graphs in the active graphics monitor "
+"display frame."
+msgstr ""
+#: ../display/d.linegraph/main.c:126
+msgid "Name of data file for X axis of graph"
+msgstr ""
+#: ../display/d.linegraph/main.c:132
+msgid "Name of data file(s) for Y axis of graph"
+msgstr ""
+#: ../display/d.linegraph/main.c:139
+msgid "Path to file location"
+msgstr ""
+#: ../display/d.linegraph/main.c:147
+msgid "Color for Y data"
+msgstr ""
+#: ../display/d.linegraph/main.c:156
+msgid "Color for axis, tics, numbers, and title"
+msgstr ""
+#: ../display/d.linegraph/main.c:164
+msgid "Title for X data"
+msgstr ""
+#: ../display/d.linegraph/main.c:171
+msgid "Title for Y data"
+msgstr ""
+#: ../display/d.linegraph/main.c:178
+msgid "Title for Graph"
+msgstr ""
+#: ../display/d.linegraph/main.c:226
+msgid "Maximum of 10 Y data files exceeded"
+msgstr ""
+#: ../display/d.linegraph/main.c:255
+#, c-format
+msgid "Only <%d> colors given for <%d> lines"
+msgstr ""
+#: ../display/d.linegraph/main.c:308
+#, c-format
+msgid "Y input file <%s> contains fewer data points than the X input file"
+msgstr ""
+#: ../display/d.linegraph/main.c:312
+#, c-format
+msgid "Y input file <%s> contains more data points than the X input file"
+msgstr ""
+#: ../display/d.linegraph/main.c:317
+#, c-format
+msgid "The last point will be ignored"
+msgid_plural "The last %d points will be ignored"
+msgstr[0] ""
+msgstr[1] ""
+#: ../display/d.linegraph/main.c:380
+#, c-format
+msgid "Problem reading X data file at line %d"
+msgstr ""
+#: ../display/d.linegraph/main.c:390
+#, c-format
+msgid "Problem reading <%s> data file at line %d"
+msgstr ""
+#: ../display/d.extract/extract.c:43
+msgid "Select vector(s) with mouse"
+msgstr ""
+#: ../display/d.extract/extract.c:44
+msgid " - L: draw box with left mouse button to select"
+msgstr ""
+#: ../display/d.extract/extract.c:45
+msgid " - M: draw box with middle mouse button to remove from display"
+msgstr ""
+#: ../display/d.extract/extract.c:46
+msgid " - R: quit and save selected vectors to new map\n"
+msgstr ""
+#: ../display/d.extract/extract.c:48
+msgid "L: add  M: remove  R: quit and save\n"
+msgstr ""
+#: ../display/d.extract/main.c:52
+msgid "Selects and extracts vectors with mouse into new vector map."
+msgstr ""
+#: ../display/d.extract/main.c:65 ../display/d.path/main.c:99
+msgid "Original line color"
+msgstr ""
+#: ../display/d.extract/main.c:71 ../display/d.path/main.c:107
+msgid "Highlight color"
+msgstr ""
+#: ../display/d.extract/main.c:122
+msgid "Copying tables..."
+msgstr ""
+#: ../display/d.extract/main.c:130
+msgid "Cannot get db link info -> cannot copy table."
+msgstr ""
+#: ../display/d.where/main.c:48
+msgid ""
+"Identifies the geographic coordinates associated with point locations given "
+"in display coordinates."
+msgstr ""
+#: ../display/d.where/main.c:58
+msgid "Display coordinates to convert"
+msgstr ""
+#: ../display/d.where/main.c:63
+msgid "File from which to read coordinates (\"-\" to read from stdin)"
+msgstr ""
+#: ../display/d.where/main.c:67
+msgid "Output lat/long in decimal degree"
+msgstr ""
+#: ../display/d.where/main.c:72
+msgid "Output lat/long referenced to current ellipsoid"
+msgstr ""
+#: ../display/d.where/main.c:77
+msgid ""
+"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
+"parameters defined in current location (if available)"
+msgstr ""
+#: ../display/d.where/main.c:83
+msgid "Output frame coordinates of current display monitor (percentage)"
+msgstr ""
+#: ../display/d.where/main.c:91
+msgid "Ambiguous request for lat/long ellipsoids"
+msgstr ""
+#: ../display/d.where/main.c:94
+msgid "Please specify a lat/long ellipsoid with -l or -w"
+msgstr ""
+#: ../display/d.where/main.c:136
+msgid ""
+"WGS84 output not possible as this location does not contain\n"
+msgstr ""
+#: ../display/d.where/where.c:29
+#, c-format
+msgid "Invalid coordinates <%s,%s>"
+msgstr ""
+#: ../display/d.info/main.c:35
+msgid "Displays information about the active display monitor."
+msgstr ""
+#: ../display/d.info/main.c:37
+msgid "Display monitors are maintained by d.mon."
+msgstr ""
+#: ../display/d.info/main.c:42
+msgid "Display screen rectangle (left, right, top, bottom)"
+msgstr ""
+#: ../display/d.info/main.c:46
+msgid "Display screen dimensions (width, height)"
+msgstr ""
+#: ../display/d.info/main.c:50
+msgid "Display active frame rectangle"
+msgstr ""
+#: ../display/d.info/main.c:54
+msgid "Display frame dimensions (width, height)"
+msgstr ""
+#: ../display/d.info/main.c:58
+msgid "Display screen rectangle of current region"
+msgstr ""
+#: ../display/d.info/main.c:63
+msgid "Display geographic coordinates and resolution of entire frame"
+msgstr ""
+#: ../display/d.his/main.c:69
+msgid ""
+"Displays the result obtained by combining hue, intensity, and saturation "
+"(HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../display/d.his/main.c:97
+msgid "Percent to brighten intensity channel"
+msgstr ""
+#: ../display/d.his/main.c:103
+msgid "Respect NULL values while drawing"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:80
+msgid "choropleth map"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:82
+msgid "Displays a thematic vector map in the active graphics frame."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:89
+msgid "Layer number. If -1, all layers are displayed."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:95
+msgid "Name of attribute column to be classified"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:102
+msgid "Class breaks, without minimum and maximum"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:103 ../display/d.vect.thematic/main.c:121
+#: ../display/d.vect.thematic/main.c:129
+msgid "Classes"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:136
+msgid "Colors (one per class)"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:146 ../display/d.vect.thematic/main.c:152
+msgid "Boundaries"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:147
+msgid "Boundary width"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:151
+msgid "Boundary color"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:157
+msgid "File in which to save d.graph instructions for legend display"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:159 ../display/d.vect.thematic/main.c:165
+#: ../display/d.vect.thematic/main.c:171 ../display/d.vect.thematic/main.c:176
+msgid "Legend"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:164 ../display/d.vect.chart/main.c:142
+msgid "Create legend information and send to stdout"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:170
+msgid ""
+"When printing legend info, include extended statistical info from "
+"classification algorithm"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:175
+msgid "Do not draw map, only output the legend"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:195
+#, c-format
+msgid "%s: You must build topology on vector map. Run v.build."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:202
+msgid "'layer' must be > 0"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:228
+#, c-format
+msgid "Data (%s) not numeric. Column must be numeric."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:232
+#: ../display/d.vect.thematic/plot1.c:135
+#: ../display/d.vect.thematic/plot1.c:163
+#, c-format
+msgid "Cannot select data (%s) from table"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:295
+#, c-format
+msgid "Unknown color: [%s]"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:306
+msgid ""
+"You gave both manual breaks and a classification algorithm or a number of "
+"classes. The manual breaks have precedence and will thus be used."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:343
+msgid "You must either give classbreaks or a classification algorithm"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:356
+#, c-format
+msgid ""
+"Not enough colors or error in color specifications.\n"
+"Need %i colors."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:361
+#, c-format
+msgid "Error interpreting color %s"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:378
+msgid "Plotting ..."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:385
+msgid ""
+"The bounding box of the map is outside the current region, nothing drawn."
+msgstr ""
+#: ../display/d.vect.thematic/main.c:435
+#, c-format
+msgid ""
+"\n"
+"Total number of records: %.0f\n"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:437
+#, c-format
+msgid "Classification of %s into %i classes\n"
+msgstr ""
+#: ../display/d.vect.thematic/main.c:445
+#, c-format
+msgid "Last chi2 = %f\n"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:120
+msgid "Color definition column not specified"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:130
+#, c-format
+msgid ""
+"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
+"BBB where RGB values range 0-255."
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:148
+msgid "Line width column not specified."
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:159
+#, c-format
+msgid "Line width column (%s) not a number."
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:204
+#, c-format
+msgid ""
+"\n"
+"ERROR: vector map - can't read\n"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:279
+#, c-format
+msgid ""
+"Error in color definition column (%s), element %d with cat %d: colorstring "
+"[%s]"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:286
+#, c-format
+msgid "Error in color definition column (%s), element %d with cat %d"
+msgstr ""
+#: ../display/d.vect.thematic/plot1.c:354
+#, c-format
+msgid ""
+"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr ""
+#: ../display/d.text/main.c:141
+msgid ""
+"Draws text in the active display frame on the graphics monitor using the "
+"current font."
+msgstr ""
+#: ../display/d.text/main.c:147
+msgid "Text to display"
+msgstr ""
+#: ../display/d.text/main.c:156
+msgid "Height of letters in percentage of available frame height"
+msgstr ""
+#: ../display/d.text/main.c:164
+msgid "Text color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.text/main.c:172
+msgid "Text background color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+#: ../display/d.text/main.c:181
+msgid "The screen line number on which text will begin to be drawn"
+msgstr ""
+#: ../display/d.text/main.c:189
+msgid ""
+"Screen position at which text will begin to be drawn (percentage, [0,0] is "
+"lower left)"
+msgstr ""
+#: ../display/d.text/main.c:197
+msgid "Text alignment"
+msgstr ""
+#: ../display/d.text/main.c:212
+msgid "Line spacing"
+msgstr ""
+#: ../display/d.text/main.c:223 ../display/d.legend/main.c:182
+msgid "Path to font file"
+msgstr ""
+#: ../display/d.text/main.c:231 ../display/d.legend/main.c:191
+msgid "Text encoding (only applicable to TrueType fonts)"
+msgstr ""
+#: ../display/d.text/main.c:235
+msgid "Input file"
+msgstr ""
+#: ../display/d.text/main.c:239
+msgid "Screen position in pixels ([0,0] is top left)"
+msgstr ""
+#: ../display/d.text/main.c:243
+msgid "Screen position in geographic coordinates"
+msgstr ""
+#: ../display/d.text/main.c:247
+msgid "Use bold text"
+msgstr ""
+#: ../display/d.text/main.c:251
+msgid "Use radians instead of degrees for rotation"
+msgstr ""
+#: ../display/d.text/main.c:255
+msgid "Font size is height in pixels"
+msgstr ""
+#: ../display/d.text/main.c:266
+msgid "Please choose only one placement method"
+msgstr ""
+#: ../display/d.text/main.c:325
+msgid "Invalid coordinates"
+msgstr ""
+#: ../display/d.text/main.c:369
+#, c-format
+msgid ""
+"\n"
+"Please enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"
+msgstr ""
+#: ../display/d.text/main.c:560
+#, c-format
+msgid "[%s]: No such color. Use '%s'"
+msgstr ""
+#: ../display/d.vect.chart/main.c:65
+msgid "chart maps"
+msgstr ""
+#: ../display/d.vect.chart/main.c:67
+msgid ""
+"Displays charts of vector data in the active frame on the graphics monitor."
+msgstr ""
+#: ../display/d.vect.chart/main.c:86
+msgid "Chart type"
+msgstr ""
+#: ../display/d.vect.chart/main.c:87 ../display/d.vect.chart/main.c:97
+#: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
+#: ../display/d.vect.chart/main.c:117 ../display/d.vect.chart/main.c:123
+#: ../display/d.vect.chart/main.c:129
+msgid "Chart properties"
+msgstr ""
+#: ../display/d.vect.chart/main.c:91
+msgid "Attribute columns containing data"
+msgstr ""
+#: ../display/d.vect.chart/main.c:96
+msgid "Column used for pie chart size"
+msgstr ""
+#: ../display/d.vect.chart/main.c:104
+msgid "Size of chart (diameter for pie, total width for bar)"
+msgstr ""
+#: ../display/d.vect.chart/main.c:111
+msgid "Scale for size (to get size in pixels)"
+msgstr ""
+#: ../display/d.vect.chart/main.c:116
+msgid "Outline color"
+msgstr ""
+#: ../display/d.vect.chart/main.c:122
+msgid "Colors used to fill charts"
+msgstr ""
+#: ../display/d.vect.chart/main.c:128
+msgid "Center the bar chart around a data point"
+msgstr ""
+#: ../display/d.vect.chart/main.c:137
+msgid "Maximum value used for bar plot reference"
+msgstr ""
+#: ../display/d.rgb/main.c:58
+msgid ""
+"Displays three user-specified raster maps as red, green, and blue overlays "
+"in the active graphics frame."
+msgstr ""
+#: ../display/d.legend/main.c:88
+msgid ""
+"Displays a legend for a 2D or 3D raster map in the active frame of the "
+msgstr ""
+#: ../display/d.legend/main.c:107
+msgid "Number of text lines (useful for truncating long legends)"
+msgstr ""
+#: ../display/d.legend/main.c:117
+msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
+msgstr ""
+#: ../display/d.legend/main.c:126
+msgid "Number of text labels for smooth gradient legend"
+msgstr ""
+#: ../display/d.legend/main.c:127 ../display/d.legend/main.c:212
+#: ../display/d.legend/main.c:222
+msgid "Gradient"
+msgstr ""
+#: ../display/d.legend/main.c:136
+msgid ""
+"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgstr ""
+#: ../display/d.legend/main.c:146
+msgid "List of discrete category numbers/values for legend"
+msgstr ""
+#: ../display/d.legend/main.c:148 ../display/d.legend/main.c:157
+msgid "Subset"
+msgstr ""
+#: ../display/d.legend/main.c:156
+msgid "Use a subset of the map range for the legend (min,max)"
+msgstr ""
+#: ../display/d.legend/main.c:161 ../display/d.legend/main.c:168
+#: ../display/d.legend/main.c:177 ../display/d.legend/main.c:184
+#: ../display/d.legend/main.c:192
+msgid "Font settings"
+msgstr ""
+#: ../display/d.legend/main.c:175 ../display/d.northarrow/main.c:86
+#: ../display/d.barscale/main.c:134
+msgid "Font size"
+msgstr ""
+#: ../display/d.legend/main.c:176
+msgid "Default: Auto-scaled"
+msgstr ""
+#: ../display/d.legend/main.c:196
+msgid "Do not show category labels"
+msgstr ""
+#: ../display/d.legend/main.c:201
+msgid "Do not show category numbers"
+msgstr ""
+#: ../display/d.legend/main.c:206
+msgid "Skip categories with no label"
+msgstr ""
+#: ../display/d.legend/main.c:221
+msgid "Add histogram to smoothed legend"
+msgstr ""
+#: ../display/d.legend/main.c:232
+msgid "Please specify a single map name. To launch GUI use d.legend --ui."
+msgstr ""
+#: ../display/d.legend/main.c:380
+msgid "Legend box lies outside of frame. Text may not display properly."
+msgstr ""
+#: ../display/d.legend/main.c:384
+msgid "Drawing horizontal legend as box width exceeds height"
+msgstr ""
+#: ../display/d.legend/main.c:395
+#, c-format
+msgid "Range information for <%s> not available (run r.support)"
+msgstr ""
+#: ../display/d.legend/main.c:400
+msgid "Input map contains no data"
+msgstr ""
+#: ../display/d.legend/main.c:413
+msgid "Requested range exceeds lower limit of actual data"
+msgstr ""
+#: ../display/d.legend/main.c:419
+msgid "Requested range exceeds upper limit of actual data"
+msgstr ""
+#: ../display/d.legend/main.c:478
+#, c-format
+msgid "use=%s out of range [%d,%d] (extend with range= ?)"
+msgstr ""
+#: ../display/d.legend/main.c:519
+msgid "Nothing to draw! (no categories with labels? out of range?)"
+msgstr ""
+#: ../display/d.legend/main.c:529
+msgid "Forcing a smooth legend: too many categories for current window height"
+msgstr ""
+#: ../display/d.legend/main.c:579
+msgid "Color range exceeds lower limit of actual data"
+msgstr ""
+#: ../display/d.legend/main.c:583
+msgid "Color range exceeds upper limit of actual data"
+msgstr ""
+#: ../display/d.legend/main.c:590
+#, c-format
+msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
+msgstr ""
+#: ../display/d.legend/main.c:841
+msgid "Histogram constrained by range not yet implemented"
+msgstr ""
+#: ../display/d.legend/main.c:1018
+msgid "Nothing to draw! (no categories with labels?)"
+msgstr ""
+#: ../display/d.northarrow/main.c:44
+msgid "Displays a north arrow on the graphics monitor."
+msgstr ""
+#: ../display/d.northarrow/main.c:48
+msgid "North arrow style"
+msgstr ""
+#: ../display/d.northarrow/main.c:51 ../display/d.barscale/main.c:74
+msgid "Style"
+msgstr ""
+#: ../display/d.northarrow/main.c:61 ../display/d.barscale/main.c:108
+msgid "Screen coordinates of the rectangle's top-left corner"
+msgstr ""
+#: ../display/d.northarrow/main.c:62 ../display/d.barscale/main.c:109
+msgid "(0,0) is lower-left of the display frame"
+msgstr ""
+#: ../display/d.northarrow/main.c:70
+msgid "Fill color"
+msgstr ""
+#: ../display/d.northarrow/main.c:71
+msgid "black"
+msgstr ""
+#: ../display/d.northarrow/main.c:87 ../display/d.northarrow/main.c:92
+#: ../display/d.barscale/main.c:65 ../display/d.barscale/main.c:126
+#: ../display/d.barscale/main.c:135
+msgid "Text"
+msgstr ""
+#: ../display/d.northarrow/main.c:91
+msgid "Draw the symbol without text"
+msgstr ""
+#: ../display/d.northarrow/draw_n_arrow.c:80
+#: ../display/d.northarrow/draw_n_arrow.c:139
+msgid "Could not parse symbol"
+msgstr ""
+#: ../display/d.northarrow/draw_n_arrow.c:157
+#: ../display/d.barscale/draw_scale.c:563
+#, c-format
+msgid "Could not read symbol \"%s\""
+msgstr ""
+#: ../display/d.rast.arrow/main.c:99
+msgid ""
+"Draws arrows representing cell aspect direction for a raster map containing "
+"aspect data."
+msgstr ""
+#: ../display/d.rast.arrow/main.c:103
+msgid "Name of raster aspect map to be displayed"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:111
+msgid "Type of existing raster aspect map"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:116
+msgid "Color for drawing arrows"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:122
+msgid "Color for drawing drawing grid"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:128
+msgid "Color for drawing null values (X symbol)"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:134
+msgid "Color for showing unknown information (? symbol)"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:142
+msgid "Draw arrow every Nth grid cell"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:151
+msgid "Raster map containing values used for arrow length"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:158
+msgid "Scale factor for arrows (magnitude map)"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:206
+msgid "Illegal value for scale factor"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:210
+msgid "Illegal value for skip factor"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:215
+msgid "Magnitude is only supported for GRASS and compass aspect maps."
+msgstr ""
+#: ../display/d.rast.arrow/main.c:220
+msgid "Scale option requires magnitude_map"
+msgstr ""
+#: ../display/d.rast.arrow/main.c:271
+msgid "Problem reading range file"
+msgstr ""
+#: ../display/d.profile/main.c:68
+#, c-format
+msgid "Unable to read range for %s"
+msgstr ""
+#: ../display/d.profile/main.c:79
+#, c-format
+msgid "Unable to read FP range for %s"
+msgstr ""
+#: ../display/d.profile/main.c:194
+msgid "Plots profile of a transect."
+msgstr ""
+#: ../display/d.profile/main.c:198
+msgid "Raster map to be profiled"
+msgstr ""
+#: ../display/d.profile/main.c:207
+msgid "Use map's range recorded range"
+msgstr ""
+#: ../display/d.profile/main.c:256
+msgid "At least two points are required"
+msgstr ""
+#: ../display/d.barscale/main.c:56
+msgid "Displays a barscale on the graphics monitor."
+msgstr ""
+#: ../display/d.barscale/main.c:60
+msgid "Use feet/miles instead of meters"
+msgstr ""
+#: ../display/d.barscale/main.c:64
+msgid "Draw the scale bar without text"
+msgstr ""
+#: ../display/d.barscale/main.c:69
+msgid "Type of barscale to draw"
+msgstr ""
+#: ../display/d.barscale/main.c:88
+msgid "Classic style"
+msgstr ""
+#: ../display/d.barscale/main.c:89
+msgid "Line style"
+msgstr ""
+#: ../display/d.barscale/main.c:90
+msgid "Solid style"
+msgstr ""
+#: ../display/d.barscale/main.c:91
+msgid "Hollow style"
+msgstr ""
+#: ../display/d.barscale/main.c:92
+msgid "Full checker style"
+msgstr ""
+#: ../display/d.barscale/main.c:93
+msgid "Part checker style"
+msgstr ""
+#: ../display/d.barscale/main.c:94
+msgid "Mixed checker style"
+msgstr ""
+#: ../display/d.barscale/main.c:95
+msgid "Tail checker style"
+msgstr ""
+#: ../display/d.barscale/main.c:96
+msgid "Up ticks style"
+msgstr ""
+#: ../display/d.barscale/main.c:97
+msgid "Down ticks style"
+msgstr ""
+#: ../display/d.barscale/main.c:98
+msgid "Both ticks style"
+msgstr ""
+#: ../display/d.barscale/main.c:99
+msgid "Arrow ends style"
+msgstr ""
+#: ../display/d.barscale/main.c:112
+msgid "Bar scale and text color"
+msgstr ""
+#: ../display/d.barscale/main.c:118
+msgid "Background color (drawn behind the bar)"
+msgstr ""
+#: ../display/d.barscale/main.c:123
+msgid "Text position"
+msgstr ""
+#: ../display/d.barscale/main.c:143
+#, c-format
+msgid "%s does not work with a latitude-longitude location"
+msgstr ""
+#: ../display/d.barscale/main.c:186 ../display/d.barscale/main.c:203
+#: ../display/d.barscale/draw_scale.c:211
+msgid "Programmer error"
+msgstr ""
+#: ../display/d.path/main.c:52
+msgid "Finds shortest path for selected starting and ending node."
+msgstr ""
+#: ../display/d.path/main.c:93
+msgid "Node cost column"
+msgstr ""
+#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
+#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
+msgid "Rendering"
+msgstr ""
+#: ../display/d.path/main.c:126
+msgid "Render bold lines"
+msgstr ""
+#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
+#, c-format
+msgid "%s - illegal x value"
+msgstr ""
+#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
+#, c-format
+msgid "%s - illegal y value"
+msgstr ""
+#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
+#, c-format
+msgid "Node %d: %f %f\n"
+msgstr ""
+#: ../display/d.path/select.c:122
+#, c-format
+msgid "Destination unreachable\n"
+msgstr ""
+#: ../display/d.path/select.c:125
+#, c-format
+msgid "Costs on the network = %f\n"
+msgstr ""
+#: ../display/d.path/select.c:126
+#, c-format
+msgid ""
+"  Distance to the network = %f, distance from the network = %f\n"
+"\n"
+msgstr ""
+#: ../display/d.fontlist/main.c:47
+msgid "Lists the available fonts."
+msgstr ""
+#: ../display/d.fontlist/main.c:51
+msgid "List fonts (default; provided for compatibility with d.font)"
+msgstr ""
+#: ../display/d.colorlist/main.c:39
+msgid "Outputs a list of all available display colors."
+msgstr ""
+#: ../display/d.title/main.c:52
+msgid ""
+"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgstr ""
+#: ../display/d.title/main.c:63
+msgid "Sets the text color"
+msgstr ""
+#: ../display/d.title/main.c:71
+msgid "Sets the text size as percentage of the frame's height"
+msgstr ""
+#: ../display/d.title/main.c:75
+msgid "Draw title on current display"
+msgstr ""
+#: ../display/d.title/main.c:79
+msgid "Do a fancier title"
+msgstr ""
+#: ../display/d.title/main.c:84
+msgid "Do a simple title"
+msgstr ""
+#: ../display/d.title/main.c:102
+msgid "Title can be fancy or simple, not both"
+msgstr ""
+#: ../display/d.title/main.c:105
+msgid "No map name given"
+msgstr ""
+#: ../display/d.colortable/main.c:64
+msgid "Displays the color table associated with a raster map layer."
+msgstr ""
+#: ../display/d.colortable/main.c:68
+msgid "Name of raster map whose color table is to be displayed"
+msgstr ""
+#: ../display/d.colortable/main.c:73
+msgid "Color of lines separating the colors of the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:79
+msgid "Number of lines to appear in the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:85
+msgid "Number of columns to appear in the color table"
+msgstr ""
+#: ../display/d.colortable/main.c:90
+msgid "Do not draw a collar showing the NULL color in FP maps"
+msgstr ""
+#: ../display/d.colortable/main.c:112
+#, c-format
+msgid ""
+"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgstr ""
+#: ../display/d.colortable/main.c:126
+#, c-format
+msgid ""
+"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgstr ""
+#: ../display/d.colortable/main.c:137
+#, c-format
+msgid "Range file for <%s> not available"
+msgstr ""
+#: ../imagery/i.cluster/print5.c:15
+#, c-format
+msgid ""
+"\n"
+"class separability matrix\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:18 ../imagery/i.gensigset/parse.c:47
+#: ../imagery/i.smap/parse.c:61 ../imagery/i.maxlik/open.c:17
+#: ../imagery/i.gensig/parse.c:41
+#, c-format
+msgid "Group <%s> not found in current mapset"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:22 ../imagery/i.gensigset/parse.c:50
+#: ../imagery/i.smap/parse.c:64 ../imagery/i.maxlik/open.c:20
+#: ../imagery/i.gensig/parse.c:44
+#, c-format
+msgid "Subgroup <%s> in group <%s> not found"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:34
+#, c-format
+msgid "Raster map <%s> do not exists in subgroup <%s>"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:39
+msgid "No raster maps found"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:43
+#, c-format
+msgid "Subgroup <%s> doesn't have any raster maps"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:46
+#, c-format
+msgid "Subgroup <%s> only has 1 raster map"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:47
+msgid "Subgroup must have at least 2 raster maps"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:64
+#, c-format
+msgid "Unable to open seed signature file <%s>"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:70 ../imagery/i.smap/read_sig.c:23
+#: ../imagery/i.maxlik/open.c:53
+#, c-format
+msgid "Unable to read signature file <%s>"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:74 ../imagery/i.maxlik/open.c:57
+#, c-format
+msgid "<%s> has too many signatures (limit is 255)"
+msgstr ""
+#: ../imagery/i.cluster/print3.c:16
+#, c-format
+msgid ""
+"\n"
+"initial means for each band\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/print3.c:19
+#, c-format
+msgid "class %-3d "
+msgstr ""
+#: ../imagery/i.cluster/main.c:77 ../imagery/i.gensigset/main.c:44
+#: ../imagery/i.gensig/main.c:44
+msgid "signatures"
+msgstr ""
+#: ../imagery/i.cluster/main.c:79
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm."
+msgstr ""
+#: ../imagery/i.cluster/main.c:82
+msgid ""
+"The resulting signature file is used as input for i.maxlik, to generate an "
+"unsupervised image classification."
+msgstr ""
+#: ../imagery/i.cluster/main.c:95 ../imagery/i.gensigset/parse.c:25
+#: ../imagery/i.gensig/parse.c:26
+msgid "Name for output file containing result signatures"
+msgstr ""
+#: ../imagery/i.cluster/main.c:102
+msgid "Initial number of classes"
+msgstr ""
+#: ../imagery/i.cluster/main.c:111
+msgid "Name of file containing initial signatures"
+msgstr ""
+#: ../imagery/i.cluster/main.c:119
+msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
+msgstr ""
+#: ../imagery/i.cluster/main.c:126 ../imagery/i.segment/parse_args.c:101
+msgid "Maximum number of iterations"
+msgstr ""
+#: ../imagery/i.cluster/main.c:135
+msgid "Percent convergence"
+msgstr ""
+#: ../imagery/i.cluster/main.c:143
+msgid "Cluster separation"
+msgstr ""
+#: ../imagery/i.cluster/main.c:151
+msgid "Minimum number of pixels in a class"
+msgstr ""
+#: ../imagery/i.cluster/main.c:158
+msgid "Name for output file containing final report"
+msgstr ""
+#: ../imagery/i.cluster/main.c:177
+#, c-format
+msgid "Illegal number of initial classes (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:188
+#, c-format
+msgid "Illegal value(s) of sample intervals (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:202
+#, c-format
+msgid "Illegal value of iterations (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:208
+#, c-format
+msgid "Illegal value of convergence (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:213
+#, c-format
+msgid "Illegal value of separation (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:218
+#, c-format
+msgid "Illegal value of min_size (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:227
+#, c-format
+msgid "Unable to create report file <%s>"
+msgstr ""
+#: ../imagery/i.cluster/main.c:235
+#, c-format
+msgid ""
+"#################### CLUSTER (%s) ####################\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:237
+#, c-format
+msgid "Location: %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:238
+#, c-format
+msgid "Mapset:   %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:239
+#, c-format
+msgid "Group:    %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:240
+#, c-format
+msgid "Subgroup: %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:242
+#, c-format
+msgid " %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:245
+#, c-format
+msgid "Result signature file: %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:247
+#, c-format
+msgid "Region\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:248
+#, c-format
+msgid "  North: %12.2f  East: %12.2f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:250
+#, c-format
+msgid "  South: %12.2f  West: %12.2f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:252
+#, c-format
+msgid "  Res:   %12.2f  Res:  %12.2f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:254
+#, c-format
+msgid "  Rows:  %12d  Cols: %12d  Cells: %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:256
+#, c-format
+msgid "Mask: %s\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:258
+#, c-format
+msgid "Cluster parameters\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:259
+#, c-format
+msgid " Number of initial classes:    %d"
+msgstr ""
+#: ../imagery/i.cluster/main.c:261
+#, c-format
+msgid " [from signature file %s]"
+msgstr ""
+#: ../imagery/i.cluster/main.c:263
+#, c-format
+msgid " Minimum class size:           %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:264
+#, c-format
+msgid " Minimum class separation:     %f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:265
+#, c-format
+msgid " Percent convergence:          %f\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:266
+#, c-format
+msgid " Maximum number of iterations: %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:268
+#, c-format
+msgid " Row sampling interval:        %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:269
+#, c-format
+msgid " Col sampling interval:        %d\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:278 ../imagery/i.gensigset/read_data.c:22
+#: ../imagery/i.ifft/main.c:141
+msgid "Reading raster maps..."
+msgstr ""
+#: ../imagery/i.cluster/main.c:288
+msgid "Out of Memory. Please run again and choose a smaller sample size."
+msgstr ""
+#: ../imagery/i.cluster/main.c:294
+#, c-format
+msgid "Sample size: %d points\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:297
+msgid ""
+"Not enough sample points. Please run again and choose a larger sample size."
+msgstr ""
+#: ../imagery/i.cluster/main.c:301
+msgid ""
+"Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr ""
+#: ../imagery/i.cluster/main.c:314
+#, c-format
+msgid ""
+"\n"
+"########## final results #############\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:315
+#, c-format
+msgid "%d classes (convergence=%.1f%%)\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:326
+#, c-format
+msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
+msgstr ""
+#: ../imagery/i.cluster/main.c:331
+#, c-format
+msgid ""
+"\n"
+"\n"
+"#################### CLASSES ####################\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:332
+#, c-format
+msgid ""
+"\n"
+"%d classes, %.2f%% points stable\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:334
+#, c-format
+msgid ""
+"\n"
+"######## CLUSTER END (%s) ########\n"
+msgstr ""
+#: ../imagery/i.cluster/print6.c:11
+#, c-format
+msgid "class distribution"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:16
+#, c-format
+msgid "using seed means (%d files)\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:28
+#, c-format
+msgid ""
+"\n"
+"######## iteration %d ###########\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:30
+#, c-format
+msgid "%d classes, %.2f%% points stable\n"
+msgstr ""
+#: ../imagery/i.cluster/checkpt.c:40
+#, c-format
+msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
+msgstr ""
+#: ../imagery/i.cluster/print1.c:12
+#, c-format
+msgid ""
+"means and standard deviations for %d band%s\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/print1.c:14
+#, c-format
+msgid " means  "
+msgstr ""
+#: ../imagery/i.cluster/print1.c:18
+#, c-format
+msgid " stddev "
+msgstr ""
+#: ../imagery/i.cluster/print2.c:18
+#, c-format
+msgid ""
+"\n"
+"class means/stddev for each band\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/print2.c:22
+#, c-format
+msgid "class %d (%d)\n"
+msgstr ""
+#: ../imagery/i.cluster/print2.c:23
+#, c-format
+msgid "  means "
+msgstr ""
+#: ../imagery/i.cluster/print2.c:28
+#, c-format
+msgid "  stddev"
+msgstr ""
+#: ../imagery/i.cluster/print4.c:16
+#, c-format
+msgid "class centroids (sum/count=mean)\n"
+msgstr ""
+#: ../imagery/i.cluster/print4.c:18
+#, c-format
+msgid "band %d"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:57 ../imagery/i.eb.hsebal01/main.c:105
+#: ../imagery/i.emissivity/main.c:47 ../imagery/i.eb.eta/main.c:43
+#: ../imagery/i.eb.evapfr/main.c:48 ../imagery/i.eb.soilheatflux/main.c:50
+msgid "energy balance"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:58
+msgid "net radiation"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:59 ../imagery/i.eb.hsebal01/main.c:108
+#: ../imagery/i.eb.eta/main.c:45 ../imagery/i.eb.evapfr/main.c:51
+#: ../imagery/i.eb.soilheatflux/main.c:52
+msgid "SEBAL"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:61
+msgid "Net radiation approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:66 ../imagery/i.eb.soilheatflux/main.c:58
+msgid "Name of albedo raster map [0.0;1.0]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:70 ../imagery/i.eb.soilheatflux/main.c:62
+msgid "Name of NDVI raster map [-1.0;+1.0]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:75
+msgid "Name of surface temperature raster map [K]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:80 ../imagery/i.eb.soilheatflux/main.c:76
+msgid "Name of time of satellite overpass raster map [local time in UTC]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:85
+msgid ""
+"Name of the difference map of temperature from surface skin to about 2 m "
+"height [K]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:89
+msgid "Name of the emissivity map [-]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:94
+msgid "Name of the single-way atmospheric transmissivitymap [-]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:98
+msgid "Name of the Day Of Year (DOY) map [-]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:102
+msgid "Name of the sun zenith angle map [degrees]"
+msgstr ""
+#: ../imagery/i.eb.netrad/main.c:105
+msgid "Name of the output net radiation layer"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:106 ../imagery/i.eb.evapfr/main.c:49
+msgid "soil moisture"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:107 ../imagery/i.eb.evapfr/main.c:50
+msgid "evaporative fraction"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:110
+msgid "Computes sensible heat flux iteration SEBAL 01."
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:116
+msgid "Name of instantaneous net radiation raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:121
+msgid "Name of instantaneous soil heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:126
+msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:131
+msgid "Name of altitude corrected surface temperature raster map [K]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:140
+msgid "Value of the height independent friction velocity (u*) [m/s]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:149
+msgid "Value of the actual vapour pressure (e_act) [KPa]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:156
+msgid "Row value of the wet pixel"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:163
+msgid "Column value of the wet pixel"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:170
+msgid "Row value of the dry pixel"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:177
+msgid "Column value of the dry pixel"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:182
+msgid "Name for output sensible heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:187
+msgid "Automatic wet/dry pixel (careful!)"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:192
+msgid "Dry/Wet pixels coordinates are in image projection, not row/col"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:210
+msgid "Automatic mode selected"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:222
+msgid "Manual wet/dry pixels in image coordinates"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:223
+#, c-format
+msgid "Wet Pixel=> x:%f y:%f"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:224
+#, c-format
+msgid "Dry Pixel=> x:%f y:%f"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:228
+msgid "Either auto-mode either wet/dry pixels coordinates should be provided!"
+msgstr ""
+#: ../imagery/i.eb.hsebal01/main.c:233
+#, c-format
+msgid "<%s> is an illegal name"
+msgstr ""
+#: ../imagery/i.target/main.c:48
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../imagery/i.target/main.c:57
+msgid "Name of imagery target location"
+msgstr ""
+#: ../imagery/i.target/main.c:63
+msgid "Name of target mapset"
+msgstr ""
+#: ../imagery/i.target/main.c:68
+msgid "Set current location and mapset as target for of imagery group"
+msgstr ""
+#: ../imagery/i.target/main.c:80 ../imagery/i.group/main.c:117
+msgid "Group must exist in the current mapset"
+msgstr ""
+#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
+#: ../imagery/i.target/main.c:116
+#, c-format
+msgid "Group <%s> targeted for location [%s], mapset [%s]"
+msgstr ""
+#: ../imagery/i.target/main.c:93
+#, c-format
+msgid "Group <%s> has no target"
+msgstr ""
+#: ../imagery/i.target/main.c:101
+msgid ""
+"Use either the Current Mapset and Location Flag (-c)\n"
+" OR\n"
+" manually enter the variables"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:69
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+/OLI"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:71 ../imagery/i.aster.toar/main.c:98
+msgid "radiometric conversion"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:72 ../imagery/i.landsat.toar/main.c:577
+#: ../imagery/i.aster.toar/main.c:100
+msgid "radiance"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:73 ../imagery/i.landsat.toar/main.c:579
+#: ../imagery/i.modis.qc/main.c:140 ../imagery/i.aster.toar/main.c:101
+#: ../imagery/i.albedo/main.c:90
+msgid "reflectance"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:74 ../imagery/i.aster.toar/main.c:102
+msgid "brightness temperature"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:76
+msgid "atmospheric correction"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:81 ../imagery/i.landsat.acca/main.c:111
+msgid "Base name of input raster bands"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:82 ../imagery/i.landsat.acca/main.c:112
+msgid "Example: 'B.' for B.1, B.2, ..."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:85
+msgid "Prefix for output raster maps"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:87
+msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:92
+msgid "Name of Landsat metadata file (.met or MTL.txt)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:98
+msgid "Spacecraft sensor"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:99
+msgid "Required only if 'metfile' not given (recommended for sanity)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:104
+msgid "Landsat-1 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:105
+msgid "Landsat-2 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:106
+msgid "Landsat-3 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:107
+msgid "Landsat-4 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:108
+msgid "Landsat-5 MSS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:109
+msgid "Landsat-4 TM"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:110
+msgid "Landsat-5 TM"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:111
+msgid "Landsat-7 ETM+"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:112
+msgid "Landsat_8 OLI/TIRS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:122 ../imagery/i.landsat.toar/main.c:123
+msgid "Atmospheric correction method"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:132
+msgid "Image acquisition date (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:133 ../imagery/i.landsat.toar/main.c:141
+#: ../imagery/i.landsat.toar/main.c:150 ../imagery/i.landsat.toar/main.c:158
+msgid "Required only if 'metfile' not given"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:140
+msgid "Sun elevation in degrees"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:149
+msgid "Image creation date (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:157
+msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:165
+msgid "Percent of solar radiance in path radiance"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:166 ../imagery/i.landsat.toar/main.c:176
+msgid "Required only if 'method' is any DOS"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:175
+msgid "Minimum pixels to consider digital number as dark object"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:184
+msgid "Rayleigh atmosphere (diffuse sky irradiance)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:185
+msgid "Required only if 'method' is DOS3"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:194
+msgid "return value stored for a given metadata"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:195
+msgid "Required only if 'metfile' and -p given"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:201
+msgid "Landsat Number"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:202
+msgid "Creation timestamp"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:203
+msgid "Date"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:204
+msgid "Sun Elevation"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:205
+msgid "Sensor"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:206
+msgid "Bands count"
+msgstr ""
+msgid "Sun Azimuth Angle"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:215
+msgid "Scale factor for output"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:221
+msgid "Output at-sensor radiance instead of reflectance for all bands"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:226
+msgid ""
+"Input raster maps use as extension the number of the band instead the code"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:230
+msgid "Print output metadata info"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:256 ../imagery/i.landsat.toar/main.c:264
+#, c-format
+msgid "Illegal date format: [%s] (yyyy-mm-dd)"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:286
+msgid "Please use a metadata keyword with -p"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:323
+msgid "Failed to identify satellite"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:337
+#, c-format
+msgid "Lacking '%s' and/or '%s' for this satellite"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:343
+msgid "Landsat-7 requires band gain with 9 (H/L) characters"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:363
+#, c-format
+msgid "Unknown satellite type (defined by '%s')"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:410 ../imagery/i.landsat.toar/main.c:559
+#, c-format
+msgid "Unable to read data type of raster map <%s>"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:552
+#, c-format
+msgid "Raster map <%s> exists. Skipping."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:575
+#, c-format
+msgid "Writing %s of <%s> to <%s>..."
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:579
+msgid "temperature"
+msgstr ""
+#: ../imagery/i.landsat.toar/landsat_met.c:117
+#, c-format
+msgid "Metadata file <%s> not found"
+msgstr ""
+#: ../imagery/i.group/main.c:55
+msgid "Creates, edits, and lists groups of imagery data."
+msgstr ""
+#: ../imagery/i.group/main.c:59
+msgid "Name of imagery group"
+msgstr ""
+#: ../imagery/i.group/main.c:63
+msgid "Name of imagery subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:67
+msgid "Name of raster map(s) to include in group"
+msgstr ""
+#: ../imagery/i.group/main.c:68 ../imagery/i.group/main.c:74
+msgid "Maps"
+msgstr ""
+#: ../imagery/i.group/main.c:73
+msgid "Remove selected files from specified group or subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:78
+msgid "List files from specified (sub)group"
+msgstr ""
+#: ../imagery/i.group/main.c:83
+msgid "List subgroups from specified group"
+msgstr ""
+#: ../imagery/i.group/main.c:109
+msgid "No input raster map(s) specified"
+msgstr ""
+#: ../imagery/i.group/main.c:128 ../imagery/i.group/main.c:150
+msgid "Specified group does not exist in current mapset"
+msgstr ""
+#: ../imagery/i.group/main.c:132
+#, c-format
+msgid "Removing raster maps from subgroup <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:137
+#, c-format
+msgid "Removing raster maps from group <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:158
+#, c-format
+msgid "Subgroup <%s> of group <%s> references the following raster maps:"
+msgstr ""
+#: ../imagery/i.group/main.c:173
+#, c-format
+msgid "Group <%s> references the following raster maps:"
+msgstr ""
+#: ../imagery/i.group/main.c:185
+#, c-format
+msgid "Group <%s> does not yet exist. Creating..."
+msgstr ""
+#: ../imagery/i.group/main.c:189 ../imagery/i.group/main.c:198
+#, c-format
+msgid "Adding raster maps to group <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:193
+#, c-format
+msgid "Adding raster maps to subgroup <%s>..."
+msgstr ""
+#: ../imagery/i.group/main.c:219 ../imagery/i.group/main.c:261
+#, c-format
+msgid "Raster map <%s> not found. Skipped."
+msgstr ""
+#: ../imagery/i.group/main.c:224
+#, c-format
+msgid "Adding raster map <%s> to group"
+msgstr ""
+#: ../imagery/i.group/main.c:230
+#, c-format
+msgid "Raster map <%s> exists in group. Skipped."
+msgstr ""
+#: ../imagery/i.group/main.c:267
+#, c-format
+msgid "Adding raster map <%s> to subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:274
+#, c-format
+msgid "Raster map <%s> exists in subgroup. Skipping..."
+msgstr ""
+#: ../imagery/i.group/main.c:323
+#, c-format
+msgid "Removing raster map <%s> from group"
+msgstr ""
+#: ../imagery/i.group/main.c:340 ../imagery/i.group/main.c:399
+msgid "No raster map removed"
+msgstr ""
+#: ../imagery/i.group/main.c:382
+#, c-format
+msgid "Removing raster map <%s> from subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:418
+#, c-format
+msgid "Group <%s> does not contain any subgroup.\n"
+msgstr ""
+#: ../imagery/i.group/main.c:429
+#, c-format
+msgid "group <%s> references the following subgroups\n"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:139
+msgid "imagery quality assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:141
+msgid "land surface temperature"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:142
+msgid "vegetation"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:145
+msgid "Extracts quality control parameters from MODIS QC layers."
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:150
+msgid "Name of input surface reflectance QC layer [bit array]"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:155
+msgid "Name for output QC type classification layer"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:161
+msgid "Name of MODIS product type"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:175
+msgid "surf. refl. 250m 8-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:176
+msgid "surf. refl. 500m 8-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:177
+msgid "surf. refl. 500m 8-days, State QA"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:178
+msgid "surf. refl. 5000m daily"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:179
+msgid "surf. refl. 5000m daily, State QA"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:180
+msgid "surf. refl. 5000m daily, Internal Climatology"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:181
+msgid "LST 1km daily (Day/Night)"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:182
+msgid "LST 1km 8-days (Day/Night)"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:183
+msgid "VI 1km 16-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:184
+msgid "Brdf-Albedo Quality (Ancillary SDS) 1km 8-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:185
+msgid "Brdf-Albedo Quality (BRDF SDS) 1km 8-days"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:194
+msgid "Name of QC type to extract"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:249
+msgid "mod09: Adjacency Correction"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:250
+msgid "mod09: Atmospheric Correction"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:251
+msgid "mod09: Cloud State"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:252
+msgid "mod09: Band-Wise Data Quality Flag"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:253
+msgid "mod09: 250m Band is at Different Orbit than 500m"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:254
+msgid "mod09: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:255
+msgid "mod11A1: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:256
+msgid "mod11A1: Detailed Quality Indications"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:257
+msgid "mod11A1: Average Emissivity Error Classes"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:258
+msgid "mod11A1: Average LST Error Classes"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:259
+msgid "mod11A2: Detailed Quality Indications"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:260
+msgid "mod11A2: Average Emissivity Error Classes"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:261
+msgid "mod11A2: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:262
+msgid "mod11A2: Average LST Error Classes"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:263
+msgid "mod09*s: StateQA Aerosol Quantity"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:264
+msgid "mod09*s: StateQA BRDF Correction Performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:265
+msgid "mod09*s: StateQA Cirrus Detected"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:266
+msgid "mod09*s: StateQA Cloud Shadow"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:267
+msgid "mod09*s: StateQA Cloud State"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:268
+msgid "mod09*s: StateQA Internal Cloud Algorithm"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:269
+msgid "mod09*s: StateQA Internal Fire Algorithm"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:270
+msgid "mod09*s: StateQA Internal Snow Mask"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:271
+msgid "mod09*s: StateQA Land Water"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:272
+msgid "mod09*s: StateQA mod35 Snow Ice"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:273
+msgid "mod09*s: StateQA Pixel Adjacent to Cloud"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:274
+msgid "mod09*i: Internal CM: Cloudy"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:275
+msgid "mod09*i: Internal CM: Clear"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:276
+msgid "mod09*i: Internal CM: High Clouds"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:277
+msgid "mod09*i: Internal CM: Low Clouds"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:278
+msgid "mod09*i: Internal CM: Snow"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:279
+msgid "mod09*i: Internal CM: Fire"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:280
+msgid "mod09*i: Internal CM: Sun Glint"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:281
+msgid "mod09*i: Internal CM: Dust"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:282
+msgid "mod09*i: Internal CM: Cloud Shadow"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:283
+msgid "mod09*i: Internal CM: Pixel is Adjacent to Cloud"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:284
+msgid "mod09*i: Internal CM: Cirrus"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:285
+msgid "mod09*i: Internal CM: Pan Flag"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:286
+msgid "mod09*i: Internal CM: Criteria for Aerosol Retrieval"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:287
+msgid "mod09*i: Internal CM: AOT (aerosol optical depth) has clim. val."
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:288
+msgid "mod13A2: MODIS Land General Quality Assessment"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:289
+msgid "mod13A2: Quality estimation of the pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:290
+msgid "mod13A2: Quantity range of Aerosol"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:291
+msgid "mod13A2: if pixel is a cloud neighbour"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:292
+msgid "mod13A2: if BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:293
+msgid "mod13A2: if pixel mixed with clouds"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:294
+msgid "mod13A2: separate land from various water objects"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:295
+msgid "mod13A2: if snow/ice present in pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:296
+msgid "mod13A2: if shadow is present in pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:297 ../imagery/i.modis.qc/main.c:298
+#: ../imagery/i.modis.qc/main.c:299
+msgid "mcd43B2: Quality of BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:300
+msgid "mcd43B2q: Quality of BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:310
+msgid ""
+"Band number of MODIS product (mod09Q1=[1,2],mod09A1=[1-7],m[o/"
+"y]d09CMG=[1-7], mcd43B2q=[1-7])"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:314
+msgid "Band 1: Red"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:315
+msgid "Band 2: NIR"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:316
+msgid "Band 3: Blue"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:317
+msgid "Band 4: Green"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:318
+msgid "Band 5: SWIR 1"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:319
+msgid "Band 6: SWIR 2"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:320
+msgid "Band 7: SWIR 3"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:339
+msgid "This bit flag is only available for MOD09Q1 @ 250m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:343 ../imagery/i.modis.qc/main.c:398
+msgid "Band number out of allowed range [1-7]"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:345
+msgid "mod09Q1 product only has 2 bands"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:381
+msgid "This bit flag is only available for mod09CMGi @ 5000m products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:388
+msgid "This bit flag is only available for MOD13A2 @ 1km products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:394
+msgid "This bit flag is only available for MCD43B2 @ 1km products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:680
+msgid "Unknown names and/or combination, please check spelling"
+msgstr ""
+#: ../imagery/i.zc/main.c:55
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../imagery/i.zc/main.c:73
+msgid "Zero crossing raster map"
+msgstr ""
+#: ../imagery/i.zc/main.c:80
+msgid "x-y extent of the Gaussian filter"
+msgstr ""
+#: ../imagery/i.zc/main.c:88
+msgid "Sensitivity of Gaussian filter"
+msgstr ""
+#: ../imagery/i.zc/main.c:96
+msgid "Number of azimuth directions categorized"
+msgstr ""
+#: ../imagery/i.zc/main.c:108
+msgid "Threshold less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:114
+msgid "Width less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:118
+msgid "Fewer than 1 orientation classes not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:132
+#, c-format
+msgid "Power 2 values : %d rows %d columns"
+msgstr ""
+#: ../imagery/i.zc/main.c:142
+msgid "Initializing data..."
+msgstr ""
+#: ../imagery/i.zc/main.c:172
+msgid "Writing transformed data to file..."
+msgstr ""
+#: ../imagery/i.zc/main.c:192
+msgid "Transform successful"
+msgstr ""
+#: ../imagery/i.pca/support.c:50
+msgid "Eigen values, (vectors), and [percent importance]:"
+msgstr ""
+#: ../imagery/i.pca/main.c:75
+msgid "principal components analysis"
+msgstr ""
+#: ../imagery/i.pca/main.c:76
+msgid "Principal components analysis (PCA) for image processing."
+msgstr ""
+#: ../imagery/i.pca/main.c:82
+msgid "Name of two or more input raster maps or imagery group"
+msgstr ""
+#: ../imagery/i.pca/main.c:87
+msgid "A numerical suffix will be added for each component map"
+msgstr ""
+#: ../imagery/i.pca/main.c:96
+msgid "Rescaling range for output maps"
+msgstr ""
+#: ../imagery/i.pca/main.c:98
+msgid "For no rescaling use 0,0"
+msgstr ""
+#: ../imagery/i.pca/main.c:99
+msgid "Rescale"
+msgstr ""
+#: ../imagery/i.pca/main.c:108
+msgid "Cumulative percent importance for filtering"
+msgstr ""
+#: ../imagery/i.pca/main.c:113
+msgid "Normalize (center and scale) input maps"
+msgstr ""
+#: ../imagery/i.pca/main.c:114
+msgid "Default: center only"
+msgstr ""
+#: ../imagery/i.pca/main.c:118
+msgid "Output will be filtered input bands"
+msgstr ""
+#: ../imagery/i.pca/main.c:119
+msgid "Apply inverse PCA after PCA"
+msgstr ""
+#: ../imagery/i.pca/main.c:148
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:180
+#, c-format
+msgid "Group <%s> not found"
+msgstr ""
+#: ../imagery/i.pca/main.c:154
+msgid "Sorry, at least 2 input bands must be provided"
+msgstr ""
+#: ../imagery/i.pca/main.c:169
+#, c-format
+msgid "'%s' must be positive"
+msgstr ""
+#: ../imagery/i.pca/main.c:171
+#, c-format
+msgid "'%s' must be < 100"
+msgstr ""
+#: ../imagery/i.pca/main.c:233
+msgid "Not enough principal components left for filtering"
+msgstr ""
+#: ../imagery/i.pca/main.c:235
+#, c-format
+msgid "Using %d of %d principal components for filtering"
+msgstr ""
+#: ../imagery/i.pca/main.c:297
+msgid "Scale range length should be > 0. Using default values: 0,255."
+msgstr ""
+#: ../imagery/i.pca/main.c:343
+msgid "Computing covariance matrix..."
+msgstr ""
+#: ../imagery/i.pca/main.c:456
+#, c-format
+msgid "Rescaling to range %d,%d..."
+msgstr ""
+#: ../imagery/i.pca/main.c:464
+msgid "Calculating principal components..."
+msgstr ""
+#: ../imagery/i.gensigset/main.c:42 ../imagery/i.smap/main.c:40
+#: ../imagery/i.gensig/main.c:41
+msgid "supervised classification"
+msgstr ""
+#: ../imagery/i.gensigset/main.c:43 ../imagery/i.smap/main.c:42
+msgid "SMAP"
+msgstr ""
+#: ../imagery/i.gensigset/main.c:46
+msgid "Generates statistics for i.smap from raster map."
+msgstr ""
+#: ../imagery/i.gensigset/main.c:56
+#, c-format
+msgid "Clustering class %d (%d pixels)..."
+msgstr ""
+#: ../imagery/i.gensigset/main.c:59
+#, c-format
+msgid "Number of subclasses is %d"
+msgstr ""
+#: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
+#, c-format
+msgid "Unable to create signature file <%s>"
+msgstr ""
+#: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
+msgid "Writing signatures..."
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
+msgid "Ground truth training map"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:29
+msgid "Maximum number of sub-signatures in any class"
+msgstr ""
+#: ../imagery/i.gensigset/parse.c:54
+#, c-format
+msgid "Illegal number of sub-signatures (%s)"
+msgstr ""
+#: ../imagery/i.gensigset/openfiles.c:18 ../imagery/i.smap/openfiles.c:18
+#: ../imagery/i.smap/read_sig.c:13 ../imagery/i.gensig/openfiles.c:19
+#, c-format
+msgid "Unable to read REF file for subgroup <%s> in group <%s>"
+msgstr ""
+#: ../imagery/i.gensigset/openfiles.c:22 ../imagery/i.gensig/openfiles.c:23
+#, c-format
+msgid "Subgroup <%s> in group <%s> contains no raster maps."
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:35 ../imagery/i.gensig/get_train.c:32
+msgid "Finding training classes..."
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:58 ../imagery/i.gensig/get_train.c:55
+#, c-format
+msgid "Training class %d only has one cell - this class will be ignored"
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:63 ../imagery/i.gensig/get_train.c:60
+msgid "Training map has no classes"
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:79 ../imagery/i.gensig/get_train.c:75
+msgid "1 class found"
+msgstr ""
+#: ../imagery/i.gensigset/get_train.c:81 ../imagery/i.gensig/get_train.c:77
+#, c-format
+msgid "%d classes found"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:76
+#, c-format
+msgid "Not enough pixels in class %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:86
+#, c-format
+msgid "Too many subclasses for class index %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:88
+#, c-format
+msgid "Number of subclasses set to %d"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:106
+#, c-format
+msgid "Combining subclasses (%d,%d)..."
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:318
+#, c-format
+msgid "Subsignature %d only contains %.0f pixels"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:552
+msgid "Unreliable clustering. Try a smaller initial number of clusters"
+msgstr ""
+#: ../imagery/i.gensigset/subcluster.c:561
+#, c-format
+msgid "Removed a singular subsignature number %d (%d remain)"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:45
+msgid "emissivity"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:46
+msgid "land flux"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:49
+msgid "Computes emissivity from NDVI, generic method for sparse land."
+msgstr ""
+#: ../imagery/i.emissivity/main.c:53
+msgid "Name of the NDVI map [-]"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:56
+msgid "Name of the output emissivity layer"
+msgstr ""
+#: ../imagery/i.fft/main.c:80 ../imagery/i.ifft/main.c:79
+msgid "Fast Fourier Transform"
+msgstr ""
+#: ../imagery/i.fft/main.c:82
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../imagery/i.fft/main.c:90
+msgid "Name for output real part arrays stored as raster map"
+msgstr ""
+#: ../imagery/i.fft/main.c:94
+msgid "Name for output imaginary part arrays stored as raster map"
+msgstr ""
+#: ../imagery/i.fft/main.c:106
+msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
+msgstr ""
+#: ../imagery/i.fft/main.c:129
+#, c-format
+msgid "Reading the raster map <%s>..."
+msgstr ""
+#: ../imagery/i.fft/main.c:145
+msgid "Starting FFT..."
+msgstr ""
+#: ../imagery/i.fft/main.c:166 ../imagery/i.ifft/main.c:191
+msgid "Rotating data..."
+msgstr ""
+#: ../imagery/i.fft/main.c:174
+msgid "Writing transformed data..."
+msgstr ""
+#: ../imagery/i.fft/main.c:200
+msgid " "
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:44
+msgid "actual evapotranspiration"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:47
+msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:52
+msgid "Name of the diurnal net radiation map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:57
+msgid "Name of the evaporative fraction map [-]"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:62
+msgid "Name of the surface skin temperature [K]"
+msgstr ""
+#: ../imagery/i.eb.eta/main.c:67
+msgid "Name of the output actual evapotranspiration layer [mm/d]"
+msgstr ""
+#: ../imagery/i.smap/write_img.c:15
+msgid "Writing output raster map(s)..."
+msgstr ""
+#: ../imagery/i.smap/main.c:41 ../imagery/i.segment/main.c:36
+msgid "segmentation"
+msgstr ""
+#: ../imagery/i.smap/main.c:44
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../imagery/i.smap/interp.c:233
+msgid "Invalid parameter values"
+msgstr ""
+#: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:81
+msgid "Name of input file containing signatures"
+msgstr ""
+#: ../imagery/i.smap/parse.c:21
+msgid "Generated by i.gensigset"
+msgstr ""
+#: ../imagery/i.smap/parse.c:28 ../imagery/i.maxlik/main.c:86
+msgid "Name for output raster map holding classification results"
+msgstr ""
+#: ../imagery/i.smap/parse.c:33
+msgid "Name for output raster map holding goodness of fit (lower is better)"
+msgstr ""
+#: ../imagery/i.smap/parse.c:37
+msgid "Size of submatrix to process at one time"
+msgstr ""
+#: ../imagery/i.smap/parse.c:45
+msgid "Use maximum likelihood estimation (instead of smap)"
+msgstr ""
+#: ../imagery/i.smap/openfiles.c:22 ../imagery/i.smap/read_sig.c:17
+#, c-format
+msgid "Subgroup <%s> in group <%s> contains no raster maps"
+msgstr ""
+#: ../imagery/i.smap/read_sig.c:27
+#, c-format
+msgid "Signature file <%s> is invalid"
+msgstr ""
+#: ../imagery/i.smap/read_sig.c:30
+#, c-format
+msgid "Signature file <%s> is empty"
+msgstr ""
+#: ../imagery/i.smap/segment.c:67
+msgid "Number of classes must be < 256"
+msgstr ""
+#: ../imagery/i.smap/segment.c:102
+#, c-format
+msgid "Processing rows %d-%d (of %d)..."
+msgstr ""
+#: ../imagery/i.smap/model.c:43
+#, c-format
+msgid "Nonsymetric covariance for class %d subclass %d"
+msgstr ""
+#: ../imagery/i.smap/model.c:55
+#, c-format
+msgid "Nonpositive eigenvalues for class %d subclass %d"
+msgstr ""
+#: ../imagery/i.ifft/main.c:81
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../imagery/i.ifft/main.c:86
+msgid "Name of input raster map (image fft, real part)"
+msgstr ""
+#: ../imagery/i.ifft/main.c:90
+msgid "Name of input raster map (image fft, imaginary part"
+msgstr ""
+#: ../imagery/i.ifft/main.c:115
+msgid "The real and imaginary original windows did not match"
+msgstr ""
+#: ../imagery/i.ifft/main.c:157
+msgid "Masking raster maps..."
+msgstr ""
+#: ../imagery/i.ifft/main.c:200
+msgid "Starting Inverse FFT..."
+msgstr ""
+#: ../imagery/i.segment/open_files.c:40 ../imagery/i.segment/write_output.c:97
+#, c-format
+msgid "Group <%s> not found in the current mapset"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:44
+#: ../imagery/i.segment/write_output.c:100
+#, c-format
+msgid "Group <%s> contains no raster maps"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:69 ../imagery/i.segment/open_files.c:228
+#: ../imagery/i.segment/open_files.c:236
+#: ../imagery/i.segment/write_output.c:116
+#, c-format
+msgid "No min/max found in raster map <%s>"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:117
+#, c-format
+msgid "Non-NULL cells: %ld"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:119
+msgid "Insufficient number of non-NULL cells in current region"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:140
+msgid "Loading input bands..."
+msgstr ""
+#: ../imagery/i.segment/open_files.c:142
+msgid "Loading input band..."
+msgstr ""
+#: ../imagery/i.segment/open_files.c:174 ../imagery/i.segment/open_files.c:201
+#: ../imagery/i.segment/open_files.c:260 ../imagery/i.segment/open_files.c:347
+#: ../imagery/i.segment/open_files.c:373 ../imagery/i.segment/open_files.c:413
+#: ../imagery/i.segment/open_files.c:469
+msgid "Unable to write to temporary file"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:267
+#, c-format
+msgid "There are no boundary constraints in '%s'"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:322
+#, c-format
+msgid "Loading seeds from raster map <%s>..."
+msgstr ""
+#: ../imagery/i.segment/open_files.c:352
+#, c-format
+msgid "No seeds found in '%s'!"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:489
+#, c-format
+msgid "Segment %d is already registered!"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:538
+#, c-format
+msgid "Regions with at least %d cells are stored in memory"
+msgstr ""
+#: ../imagery/i.segment/open_files.c:563
+#, c-format
+msgid "Number of segments in memory: %d of %d total"
+msgstr ""
+#: ../imagery/i.segment/rclist.c:17
+msgid "rclist out of memory"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:244
+#, c-format
+msgid "Processing pass %d..."
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:522
+#, c-format
+msgid ""
+"Segmentation processes stopped at %d due to reaching max iteration limit, "
+"more merges may be possible"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:524
+#, c-format
+msgid "Segmentation converged after %d iterations"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:532
+#, c-format
+msgid "Merging segments smaller than %d cells..."
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1075
+#, c-format
+msgid "Region stats should go in tree, %d >= %d"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1082
+msgid "Region ids are different"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1086
+msgid "Region consists of only one cell, nothing to update"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1130
+#: ../imagery/i.segment/create_isegs.c:1555
+#, c-format
+msgid "Region size is larger than 2: %d"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1197
+#, c-format
+msgid "Region size is %d, should be %d"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1420
+#, c-format
+msgid "Candidate flag is already %s"
+msgstr ""
+msgid "set"
+msgstr ""
+msgid "unset"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1640
+#, c-format
+msgid "Region of size %d should be in search tree"
+msgstr ""
+#: ../imagery/i.segment/main.c:38
+msgid "object recognition"
+msgstr ""
+#: ../imagery/i.segment/main.c:40
+msgid "Identifies segments (objects) from imagery data."
+msgstr ""
+#: ../imagery/i.segment/main.c:46
+msgid "Error in reading data"
+msgstr ""
+#: ../imagery/i.segment/main.c:50
+msgid "Error in creating segments"
+msgstr ""
+#: ../imagery/i.segment/main.c:54
+msgid "Error in writing data"
+msgstr ""
+#: ../imagery/i.segment/main.c:59
+#, c-format
+msgid "Number of segments created: %d"
+msgstr ""
+#: ../imagery/i.segment/write_output.c:31
+msgid "Writing out segment IDs..."
+msgstr ""
+#: ../imagery/i.segment/write_output.c:124
+msgid "Writing out goodness of fit"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:30
+msgid "Difference threshold between 0 and 1"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:31
+msgid "Threshold = 0 merges only identical segments; threshold = 1 merges all"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:41
+msgid "Segmentation method"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:50
+msgid "Similarity calculation method"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:59
+msgid "Minimum number of cells in a segment"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:61
+msgid "The final step will merge small segments with their best neighbor"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:72
+msgid "Importance of radiometric (input raster) values relative to shape"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:82
+msgid "Importance of smoothness relative to compactness"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:91
+msgid "Memory in MB"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:109
+msgid "Name for input raster map with starting seeds"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:115
+msgid "Name of input bounding/constraining raster map"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:117
+msgid ""
+"Must be integer values, each area will be segmented independent of the others"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:123
+msgid "Name for output goodness of fit estimate map"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:128
+msgid ""
+"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
+"each pixel"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:134
+msgid "Weighted input, do not perform the default scaling of input raster maps"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:153
+msgid "Threshold should be > 0 and < 1"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:159
+msgid "Unable to assign segmentation method"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:169
+msgid "Invalid similarity method"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:175
+#, c-format
+msgid "Option '%s' must be > 0"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:177 ../imagery/i.segment/parse_args.c:182
+#, c-format
+msgid "Option '%s' must be <= 1"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:180
+#, c-format
+msgid "Option '%s' must be >= 0"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:208
+msgid "Seeds raster map not found"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:212
+msgid "Seeeds raster map must be CELL type (integers)"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:222
+msgid "Segmentation constraint/boundary raster map not found"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:226
+msgid "Segmentation constraint raster map must be CELL type (integers)"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:241
+msgid "Invalid output raster name for goodness of fit"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:249
+msgid "Invalid number of iterations, 100 will be used"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:259
+msgid "Invalid number of MB, 300 will be used"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:53
+msgid ""
+"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
+"moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:59 ../imagery/i.eb.soilheatflux/main.c:71
+msgid "Name of Net Radiation raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:63
+msgid "Name of soil heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:67
+msgid "Name of sensible heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:72
+msgid "Name for output evaporative fraction raster map"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:78
+msgid "Name for output root zone soil moisture raster map"
+msgstr ""
+#: ../imagery/i.eb.evapfr/main.c:83
+msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:52
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:58
+msgid "Name of input raster map (hue)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:62
+msgid "Name of input raster map (intensity)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:66
+msgid "Name of input raster map (saturation)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:70
+msgid "Name for output raster map (red)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:74
+msgid "Name for output raster map (green)"
+msgstr ""
+#: ../imagery/i.his.rgb/main.c:78
+msgid "Name for output raster map (blue)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:104
+msgid ""
+"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
+"from ASTER DN.\n"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:108
+msgid "Names of ASTER DN layers (15 layers)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:115
+msgid "Day of Year of satellite overpass [0-366]"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:122
+msgid "Sun elevation angle (degrees, < 90.0)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:125
+msgid "Base name of the output layers (will add .x)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:130
+msgid "Output is radiance (W/m2)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:134
+msgid "VNIR is High Gain"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:138
+msgid "SWIR is High Gain"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:142
+msgid "VNIR is Low Gain 1"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:146
+msgid "SWIR is Low Gain 1"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:150
+msgid "SWIR is Low Gain 2"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:229 ../imagery/i.albedo/main.c:150
+#, c-format
+msgid "Too many input maps. Only %d allowed."
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:244
+msgid "The input band number should be 15"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:70
+#, c-format
+msgid ""
+"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
+"to radiance first)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:104
+msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:108
+msgid "cloud detection"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:120
+msgid "B56composite (step 6)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:127
+msgid "B45ratio: Desert detection (step 10)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:135
+msgid "Number of classes in the cloud temperature histogram"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:137 ../imagery/i.landsat.acca/main.c:152
+#: ../imagery/i.landsat.acca/main.c:158 ../imagery/i.landsat.acca/main.c:163
+msgid "Cloud settings"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:141
+msgid "Data is Landsat-5 TM"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:142
+msgid "I.e. Thermal band is '.6' not '.61')"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:147
+msgid "Apply post-processing filter to remove small holes"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:151
+msgid "Always use cloud signature (step 14)"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:157
+msgid ""
+"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgstr ""
+#: ../imagery/i.landsat.acca/main.c:162
+msgid "Include a category for cloud shadows"
+msgstr ""
+#: ../imagery/i.landsat.acca/tools.c:138
+msgid "Filling small holes in clouds..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:124
+msgid "Preliminary scene analysis:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:125
+#, c-format
+msgid "* Desert index: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:126
+#, c-format
+msgid "* Snow cover: %.2lf %%"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:127
+#, c-format
+msgid "* Cloud cover: %.2lf %%"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:128
+msgid "* Temperature of clouds:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:129
+#, c-format
+msgid "** Maximum: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:130
+#, c-format
+msgid "** Mean (%s cloud): %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:132
+#, c-format
+msgid "** Minimum: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:142
+msgid "Histogram cloud signature:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:148
+#, c-format
+msgid "* Mean temperature: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:149
+#, c-format
+msgid "* Standard deviation: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:150
+#, c-format
+msgid "* Skewness: %.2lf"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:151
+#, c-format
+msgid "* Histogram classes: %d"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:163
+#, c-format
+msgid "* 98.75 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:164
+#, c-format
+msgid "* 97.50 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:165
+#, c-format
+msgid "* 83.50 percentile: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:186
+msgid "Maximum temperature:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:187
+#, c-format
+msgid "* Cold cloud: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:188
+#, c-format
+msgid "* Warm cloud: %.2lf K"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:193
+msgid "Result: Scene with clouds"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:200
+msgid "Result: Scene cloud free"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:237
+msgid "Processing first pass..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:391
+msgid "Removing ambiguous pixels..."
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:393
+msgid "Pass two processing..."
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:70 ../imagery/i.evapo.pt/main.c:67
+#: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
+msgid "evapotranspiration"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:72
+msgid ""
+"Computes evapotranspiration calculation modified or original Hargreaves "
+"formulation, 2001."
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:78
+msgid "Name of input diurnal net radiation raster map [W/m2/d]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:82
+msgid "Name of input average air temperature raster map [C]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:86
+msgid "Name of input minimum air temperature raster map [C]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:90
+msgid "Name of input maximum air temperature raster map [C]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:96
+msgid "Name of precipitation raster map [mm/month]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:97
+msgid "Disabled for original Hargreaves (1985)"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:100
+msgid "Name for output raster map [mm/d]"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:105 ../imagery/i.evapo.pt/main.c:102
+msgid "Set negative ETa to zero"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:109
+msgid "Use original Hargreaves (1985)"
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:113
+msgid "Use Hargreaves-Samani (1985)"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:49
+msgid "topographic correction"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:50
+msgid "Computes topographic correction of reflectance."
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:58
+msgid "Name of reflectance raster maps to be corrected topographically"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:62
+msgid "Name (flag -i) or prefix for output raster maps"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:66
+msgid "Name of input base raster map (elevation or illumination)"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:72
+msgid "Solar zenith in degrees"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:78
+msgid "Solar azimuth in degrees (only if flag -i)"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:85
+msgid "Topographic correction method"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:90
+msgid "Output sun illumination terrain model"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:94
+msgid "Scale output to input and copy color rules"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:100
+msgid "Solar azimuth is necessary to calculate illumination terrain model"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:104
+msgid "Reflectance maps are necessary to make topographic correction"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:164
+msgid "Illumination model is of CELL type"
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:167
+#, c-format
+msgid "Band %s: "
+msgstr ""
+#: ../imagery/i.topo.corr/main.c:175
+#, c-format
+msgid "Reflectance of <%s> is not of DCELL type - ignored."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:89
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:389
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:57
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:64
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:48
+msgid "orthorectify"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
+msgid ""
+"Orthorectifies an image by using the image to photo coordinate "
+"transformation matrix."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
+#: ../imagery/i.rectify/main.c:116
+msgid "Output raster map(s) suffix"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:109
+#: ../imagery/i.rectify/main.c:130
+msgid "Target resolution (ignored if -c flag used)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:117
+#: ../imagery/i.rectify/main.c:138
+msgid "Amount of memory to use in MB"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
+msgid "Raster map with camera angle relative to ground surface"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
+#: ../imagery/i.rectify/main.c:153
+msgid ""
+"Use current region settings in target location (def.=calculate smallest area)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
+#: ../imagery/i.rectify/main.c:157
+msgid "Rectify all raster maps in group"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:184
+#, c-format
+msgid "Could not read REF file for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:187
+#: ../imagery/i.rectify/main.c:212
+#, c-format
+msgid "Group <%s> contains no raster maps; run i.group"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:241
+#, c-format
+msgid "No camera reference file selected for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:245
+#, c-format
+msgid "Bad format in camera file for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:251
+#, c-format
+msgid "Bad format in initial exposure station file for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:281
+#: ../imagery/i.rectify/main.c:287
+#, c-format
+msgid "Extension <%s> is illegal"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:284
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:293
+#: ../imagery/i.rectify/main.c:290
+msgid "The following raster map already exists in"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:288
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:297
+#: ../imagery/i.rectify/main.c:294
+msgid "Orthorectification cancelled."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:312
+#: ../imagery/i.rectify/main.c:309
+msgid "Target resolution must be > 0, ignored"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:319
+#: ../imagery/i.rectify/main.c:320
+#, c-format
+msgid "Using region: N=%f S=%f, E=%f W=%f"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:327
+#, c-format
+msgid "No target elevation model selected for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:386
+#: ../imagery/i.rectify/main.c:335
+#, c-format
+msgid "Input raster map <%s> does not exist in group <%s>."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:388
+#: ../imagery/i.rectify/main.c:337
+msgid "Try:"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:393
+#: ../imagery/i.rectify/main.c:342
+msgid "Exit!"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:13
+#, c-format
+msgid ""
+"Control Z Point file for group [%s] in [%s] \n"
+" \n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:16
+msgid "Computing equations..."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
+msgid "Poorly placed Control Points!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:23
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:28
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:52
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
+msgid "Can not generate the transformation equation.\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:24
+msgid "Run OPTION 7 of i.ortho.photo again!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
+msgid "No active Control Points!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:29
+msgid "Run OPTION 7 of i.ortho.photo!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:45
+#, c-format
+msgid ""
+"Reference Point file for group [%s] in [%s] \n"
+" \n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:51
+msgid "Poorly placed Reference Points!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:53
+msgid "Run OPTION 5 of i.ortho.photo again!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:57
+msgid "No active Reference Points!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:59
+msgid "Run OPTION 5 of i.ortho.photo!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/exec.c:43
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:50
+msgid "Could not open elevation raster"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:42
+#: ../imagery/i.rectify/rectify.c:41
+#, c-format
+msgid "Rectify <%s@%s> (location <%s>)"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:46
+#: ../imagery/i.rectify/rectify.c:44
+#, c-format
+msgid "into  <%s@%s> (location <%s>) ..."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:80
+#, c-format
+msgid "No elevation available at row = %d, col = %d"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:126
+#: ../imagery/i.rectify/rectify.c:108
+#, c-format
+msgid "Raster map <%s@%s>: projection don't match current settings"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:132
+#: ../imagery/i.rectify/rectify.c:114
+#, c-format
+msgid "Raster map <%s@%s>: zone don't match current settings"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
+#: ../imagery/i.rectify/report.c:10
+msgid "complete"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:20
+#: ../imagery/i.rectify/report.c:20
+#, c-format
+msgid "%d rows, %d cols (%ld cells) completed in"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:23
+#: ../imagery/i.rectify/report.c:23
+#, c-format
+msgid "%d:%02d:%02ld hours"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:25
+#: ../imagery/i.rectify/report.c:25
+#, c-format
+msgid "%d:%02ld minutes"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:27
+#: ../imagery/i.rectify/report.c:27
+#, c-format
+msgid "%.1f cells per minute"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:72
+#: ../imagery/i.rectify/readcell.c:64
+msgid "Allocating memory and reading input map..."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:36
+msgid "Calculating camera angle to local surface..."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:66
+#, c-format
+msgid "Converting units to meters, factor=%.6f"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
+msgid "Poorly placed image to photo control points"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:253
+msgid "Poorly placed image to target control points"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:391
+msgid "GCP"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:452
+#, c-format
+msgid "Can not read reference points for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:456
+#, c-format
+msgid "Can not read control points for group <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:59
+msgid "Select and modify the imagery group camera reference file."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:64
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:70
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:57
+msgid "Name of imagery group for ortho-rectification"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:71
+msgid "Name of camera reference file"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:77
+msgid "Camera name"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:83
+msgid "Camera id"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:89
+msgid "Calibrated focal length"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:94
+msgid "Principal point coordinates"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:100
+msgid "Fiducial coordinates"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:129
+#, c-format
+msgid "Can not read camera file '%s'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:132
+#, c-format
+msgid "Replacing camera name '%s' with '%s'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:138
+#, c-format
+msgid "Replacing camera cam_id '%s' with '%s'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:146
+#, c-format
+msgid "Replacing calibrated focal length '%g' with '%g'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
+#, c-format
+msgid ""
+"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
+msgid "Please provide a camera name for a new camera definition"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:168
+msgid "Please provide a camera ID for a new camera definition"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:172
+msgid "Please provide calibrated focal length for a new camera definition"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:176
+msgid "Using default coordinates 0.0, 0.0 for the principal point"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:190
+msgid "Too many fiducials!"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:212
+#, c-format
+msgid "No group '%s' in current mapset"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
+#, c-format
+msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:66
+msgid "Select or modify the target elevation model."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:75
+msgid "Name of elevation map to use for ortho-rectification"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:80
+msgid "List available raster maps in target mapset and exit"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:85
+msgid "Print currently selected elevation map and exit"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:108
+#, c-format
+msgid "Please select a target for group [%s] first"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:114
+#, c-format
+msgid "Target location [%s] not found\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:147
+#, c-format
+msgid "Elevation map name is missing. Please set '%s' option"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:162
+#, c-format
+msgid "Elevation for group <%s> is already set to <%s>"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:175
+#, c-format
+msgid "Mapset [%s] in target location [%s] - %s "
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:177
+msgid "permission denied\n"
+msgstr ""
+msgid "not found\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
+msgid ""
+"Interactively creates or modifies entries in a camera initial exposure "
+"station file for imagery group referenced by a sub-block."
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
+msgid "Initial Camera Exposure X-coordinate"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:67
+msgid "Initial Camera Exposure Y-coordinate"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:72
+msgid "Initial Camera Exposure Z-coordinate"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
+msgid "X-coordinate standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
+msgid "Y-coordinate standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
+msgid "Z-coordinate standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
+msgid "Initial Camera Omega (roll) degrees"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:97
+msgid "Initial Camera Phi (pitch) degrees"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:102
+msgid "Initial Camera Kappa (yaw) degrees"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:107
+msgid "Omega (roll) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:112
+msgid "Phi (pitch) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:117
+msgid "Kappa (yaw) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:121
+msgid "Use initial values at run time"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
+msgid "Print initial values"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
+#, c-format
+msgid "Group [%s] not found"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:150
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:154
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:158
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:162
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:166
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:170
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:174
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:178
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:182
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:186
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:190
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:194
+#, c-format
+msgid "Option '%s' is required for new exposure info"
+msgstr ""
+#: ../imagery/i.albedo/main.c:89
+msgid "albedo"
+msgstr ""
+#: ../imagery/i.albedo/main.c:91
+msgid "Computes broad band albedo from surface reflectance."
+msgstr ""
+#: ../imagery/i.albedo/main.c:104
+msgid "MODIS (7 input bands:1,2,3,4,5,6,7)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:108
+msgid "NOAA AVHRR (2 input bands:1,2)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:112
+msgid "Landsat 5+7 (6 input bands:1,2,3,4,5,7)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:116
+msgid "ASTER (6 input bands:1,3,5,6,8,9)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:120
+msgid "Aggressive mode (Landsat)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
+msgid ""
+"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
+"kind of simple atmospheric correction"
+msgstr ""
+#: ../imagery/i.albedo/main.c:127
+msgid "Soft mode (MODIS)"
+msgstr ""
+#: ../imagery/i.albedo/main.c:164
+msgid "At least two raster maps are required"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:69
+msgid ""
+"Computes evapotranspiration calculation Priestley and Taylor formulation, "
+"1972."
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:75
+msgid "Name of input net radiation raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:79
+msgid "Name of input soil heat flux raster map [W/m2]"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:83
+msgid "Name of input air temperature raster map [K]"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:87
+msgid "Name of input atmospheric pressure raster map [millibars]"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:93
+msgid "Priestley-Taylor coefficient"
+msgstr ""
+#: ../imagery/i.evapo.pt/main.c:97
+msgid "Name of output evapotranspiration raster map [mm/d]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:51
+msgid "biomass"
+msgstr ""
+#: ../imagery/i.biomass/main.c:53
+msgid "yield"
+msgstr ""
+#: ../imagery/i.biomass/main.c:55
+msgid "Computes biomass growth, precursor of crop yield calculation."
+msgstr ""
+#: ../imagery/i.biomass/main.c:60
+msgid "Name of fPAR raster map"
+msgstr ""
+#: ../imagery/i.biomass/main.c:65
+msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
+msgstr ""
+#: ../imagery/i.biomass/main.c:69
+msgid "Name of degree latitude raster map [dd.ddd]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:73
+msgid "Name of Day of Year raster map [1-366]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:78
+msgid "Name of single-way transmissivity raster map [0.0-1.0]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:83
+msgid "Value of water availability raster map [0.0-1.0]"
+msgstr ""
+#: ../imagery/i.biomass/main.c:87
+msgid "Name for output daily biomass growth raster map [kg/ha/d]"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:51
+msgid "soil heat flux"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:53
+msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:67
+msgid "Name of Surface temperature raster map [K]"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:83
+msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:79
+msgid ""
+"Computes temporal integration of satellite ET actual (ETa) following the "
+"daily ET reference (ETo) from meteorological station(s)."
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:86
+msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:91
+msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:96
+msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:102
+msgid "Value of DOY for ETo first day"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:108
+msgid "Value of DOY for the first day of the period studied"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:114
+msgid "Value of DOY for the last day of the period studied"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:142
+msgid "The DOY for end_period can not be smaller than start_period"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:146
+msgid "The DOY for start_period can not be smaller than eto_doy_min"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:151
+#, c-format
+msgid "Too many ETa files. Only %d allowed."
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
+#: ../imagery/i.evapo.time/main.c:200
+msgid "The min specified input map is two"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:167
+#, c-format
+msgid "Too many ETa_doy files. Only %d allowed."
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:183
+msgid "ETa and ETa_DOY file numbers are not equal!"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:189
+#, c-format
+msgid "Too many ETo files. Only %d allowed."
+msgstr ""
+#: ../imagery/i.cca/main.c:87
+msgid "canonical components analysis"
+msgstr ""
+#: ../imagery/i.cca/main.c:89
+msgid "Canonical components analysis (CCA) program for image processing."
+msgstr ""
+#: ../imagery/i.cca/main.c:96
+msgid "Name of input imagery subgroup"
+msgstr ""
+#: ../imagery/i.cca/main.c:103
+msgid "File containing spectral signatures"
+msgstr ""
+#: ../imagery/i.cca/main.c:106
+msgid "Output raster map prefix name"
+msgstr ""
+#: ../imagery/i.cca/main.c:114
+msgid "Unknown imagery group."
+msgstr ""
+#: ../imagery/i.cca/main.c:117
+msgid "Unable to find subgroup reference information."
+msgstr ""
+#: ../imagery/i.cca/main.c:123
+msgid "Unable to open the signature file"
+msgstr ""
+#: ../imagery/i.cca/main.c:127
+msgid "Error while reading the signatures file."
+msgstr ""
+#: ../imagery/i.cca/main.c:132
+msgid "Need at least two signatures in signature file."
+msgstr ""
+#: ../imagery/i.cca/main.c:226
+#, c-format
+msgid "The output cell map <%s.%d> has values outside the 0-255 range."
+msgstr ""
+#: ../imagery/i.cca/transform.c:24
+msgid "Unable to allocate cell buffers."
+msgstr ""
+#: ../imagery/i.cca/transform.c:58
+msgid "Transform completed.\n"
+msgstr ""
+#: ../imagery/i.find/main.c:63
+#, c-format
+msgid "usage: %s location mapset element file."
+msgstr ""
+#: ../imagery/i.find/main.c:83
+msgid "Unable to open temp file."
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:61
+msgid ""
+"Computes potential evapotranspiration calculation with hourly Penman-"
+"Monteith."
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:65
+msgid "Name of input elevation raster map [m a.s.l.]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:69
+msgid "Name of input temperature raster map [C]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:73
+msgid "Name of input relative humidity raster map [%]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:77
+msgid "Name of input wind speed raster map [m/s]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:82
+msgid "Name of input net solar radiation raster map [MJ/m2/h]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:86
+msgid "Name of input crop height raster map [m]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:89
+msgid "Name for output raster map [mm/h]"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:93
+msgid "Set negative evapotranspiration to zero"
+msgstr ""
+#: ../imagery/i.evapo.pm/main.c:97
+msgid "Use Night-time"
+msgstr ""
+#: ../imagery/i.rectify/main.c:102
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
+#: ../imagery/i.rectify/main.c:161
+msgid "Use thin plate spline"
+msgstr ""
+#: ../imagery/i.rectify/main.c:206
+#, c-format
+msgid "Location: %s"
+msgstr ""
+#: ../imagery/i.rectify/main.c:207
+#, c-format
+msgid "Mapset: %s"
+msgstr ""
+#: ../imagery/i.rectify/main.c:208
+#, c-format
+msgid "Group <%s> does not exist"
+msgstr ""
+#: ../imagery/i.rectify/cp.c:21
+#, c-format
+msgid "Not enough active control points for thin plate spline."
+msgstr ""
+#: ../imagery/i.rectify/get_wind.c:124
+#, c-format
+msgid "Region N=%f S=%f E=%f W=%f"
+msgstr ""
+#: ../imagery/i.rectify/get_wind.c:126
+#, c-format
+msgid "Resolution EW=%f NS=%f"
+msgstr ""
+#: ../imagery/i.maxlik/invert.c:28
+#, c-format
+msgid "Signature %d is not valid (ill-conditioned) - ignored"
+msgstr ""
+#: ../imagery/i.maxlik/invert.c:31
+#, c-format
+msgid "Signature %d is not valid (singular) - ignored"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:63 ../imagery/i.gensig/main.c:42
+msgid "Maximum Likelihood Classification"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:66
+msgid "Classifies the cell spectral reflectances in imagery data."
+msgstr ""
+#: ../imagery/i.maxlik/main.c:68
+msgid ""
+"Classification is based on the spectral signature information generated by "
+"either i.cluster, g.gui.iclass, or i.gensig."
+msgstr ""
+#: ../imagery/i.maxlik/main.c:82
+msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
+msgstr ""
+#: ../imagery/i.maxlik/main.c:92
+msgid "Name for output raster map holding reject threshold results"
+msgstr ""
+#: ../imagery/i.maxlik/open.c:27
+#, c-format
+msgid ""
+"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
+"have at least 2 raster maps."
+msgstr ""
+#: ../imagery/i.maxlik/open.c:30
+#, c-format
+msgid ""
+"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
+"least 2 raster maps."
+msgstr ""
+#: ../imagery/i.maxlik/open.c:47
+#, c-format
+msgid "Unable to open signature file <%s>"
+msgstr ""
+#: ../imagery/i.gensig/main.c:46
+msgid "Generates statistics for i.maxlik from raster map."
+msgstr ""
+#: ../imagery/i.gensig/covariance.c:30
+msgid "Calculating class covariance matrices..."
+msgstr ""
+#: ../imagery/i.gensig/means.c:26
+msgid "Calculating class means..."
+msgstr ""
+#: ../imagery/i.gensig/check.c:21
+#, c-format
+msgid "Signature %d not invertible"
+msgstr ""
+#: ../imagery/i.gensig/check.c:27
+#, c-format
+msgid "Signature %d unable to get eigen values"
+msgstr ""
+#: ../imagery/i.gensig/check.c:33
+#, c-format
+msgid "Signature %d not positive definite"
+msgstr ""
+#: ../imagery/i.vi/main.c:90
+msgid "vegetation index"
+msgstr ""
+#: ../imagery/i.vi/main.c:91
+msgid "biophysical parameters"
+msgstr ""
+#: ../imagery/i.vi/main.c:93
+msgid "Calculates different types of vegetation indices."
+msgstr ""
+#: ../imagery/i.vi/main.c:94
+msgid ""
+"Uses red and nir bands mostly, and some indices require additional bands."
+msgstr ""
+#: ../imagery/i.vi/main.c:101
+msgid "Name of input red channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:102 ../imagery/i.vi/main.c:141
+#: ../imagery/i.vi/main.c:149 ../imagery/i.vi/main.c:157
+#: ../imagery/i.vi/main.c:165 ../imagery/i.vi/main.c:173
+msgid "Range: [0.0;1.0]"
+msgstr ""
+#: ../imagery/i.vi/main.c:110
+msgid "Type of vegetation index"
+msgstr ""
+#: ../imagery/i.vi/main.c:115
+msgid "Atmospherically Resistant Vegetation Indices"
+msgstr ""
+#: ../imagery/i.vi/main.c:116
+msgid "Difference Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:117
+msgid "Enhanced Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:118
+msgid "Enhanced Vegetation Index 2"
+msgstr ""
+#: ../imagery/i.vi/main.c:119
+msgid "Green Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:120
+msgid "Green Atmospherically Resistant Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:121
+msgid "Global Environmental Monitoring Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:122
+msgid "Infrared Percentage Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:123
+msgid "Modified Soil Adjusted Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:124
+msgid "second Modified Soil Adjusted Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:125
+msgid "Normalized Difference Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:126
+msgid "Perpendicular Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:127
+msgid "Soil Adjusted Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:128
+msgid "Simple Ratio"
+msgstr ""
+#: ../imagery/i.vi/main.c:129
+msgid "Visible Atmospherically Resistant Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:130
+msgid "Weighted Difference Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:134
+msgid "type"
+msgstr ""
+#: ../imagery/i.vi/main.c:140
+msgid "Name of input nir channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:148
+msgid "Name of input green channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:156
+msgid "Name of input blue channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:164
+msgid "Name of input 5th channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:172
+msgid "Name of input 7th channel surface reflectance map"
+msgstr ""
+#: ../imagery/i.vi/main.c:180
+msgid "Value of the slope of the soil line (MSAVI2 only)"
+msgstr ""
+#: ../imagery/i.vi/main.c:181 ../imagery/i.vi/main.c:188
+#: ../imagery/i.vi/main.c:195
+msgid "MSAVI2 seetings"
+msgstr ""
+#: ../imagery/i.vi/main.c:187
+msgid "Value of the intercept of the soil line (MSAVI2 only)"
+msgstr ""
+#: ../imagery/i.vi/main.c:194
+msgid "Value of the factor of reduction of soil noise (MSAVI2 only)"
+msgstr ""
+#: ../imagery/i.vi/main.c:201
+msgid "Maximum bits for digital numbers"
+msgstr ""
+#: ../imagery/i.vi/main.c:202
+msgid ""
+"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 "
+"for Landsat -> [0-255])"
+msgstr ""
+#: ../imagery/i.vi/main.c:227
+msgid "sr index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:230
+msgid "ndvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:233
+msgid "ipvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:236
+msgid "dvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:239
+msgid "pvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:242
+msgid "wdvi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:245
+msgid "savi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:248
+msgid "msavi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:253
+msgid ""
+"msavi2 index requires red and nir maps, and 3 parameters related to soil line"
+msgstr ""
+#: ../imagery/i.vi/main.c:256
+msgid "gemi index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:260
+msgid "arvi index requires blue, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:264
+msgid "evi index requires blue, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:267
+msgid "evi2 index requires red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:271
+msgid "vari index requires blue, green and red maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:275
+msgid "gari index requires blue, green, red and nir maps"
+msgstr ""
+#: ../imagery/i.vi/main.c:280
+msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:52
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:58
+msgid "Name of input raster map (red)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:62
+msgid "Name of input raster map (green)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:66
+msgid "Name of input raster map (blue)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:70
+msgid "Name for output raster map (hue)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:74
+msgid "Name for output raster map (intensity)"
+msgstr ""
+#: ../imagery/i.rgb.his/main.c:78
+msgid "Name for output raster map (saturation)"
+msgstr ""
Property changes on: grass/trunk/locale/po/grassmods_fi.po
___________________________________________________________________
Added: svn:mime-type
   + text/x-po
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Added: grass/trunk/locale/po/grasswxpy_fi.po
--- grass/trunk/locale/po/grasswxpy_fi.po	                        (rev 0)
+++ grass/trunk/locale/po/grasswxpy_fi.po	2015-08-18 10:47:46 UTC (rev 65959)
@@ -0,0 +1,17245 @@
+# translation of grasswxpy_fi.po to Finnish
+# This file is distributed under the same license as the GRASS GIS package.
+# Copyright (C) 2014-2015 GRASS Development Team
+# Kari Salovaara <kari.salovaara at pp1.inet.fi>, 2015.
+msgid ""
+msgstr ""
+"Project-Id-Version: grasswxpy_fi\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2015-07-20 21:44+0200\n"
+"PO-Revision-Date: 2015-08-17 22:18+0300\n"
+"Last-Translator: Kari Salovaara <kari.salovaara at pp1.inet.fi>\n"
+"Language-Team: Finnish <grass-translations at lists.osgeo.org>\n"
+"Language: fi\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"X-Generator: Lokalize 1.5\n"
+#: ../gui/wxpython/gis_set.py:107
+msgid "1. Select GRASS GIS database directory"
+msgstr "1. Valitse GRASS GIS tietokannan hakemisto"
+#: ../gui/wxpython/gis_set.py:109
+msgid "2. Select GRASS Location"
+msgstr "2. Valitse GRASS Paikka"
+#: ../gui/wxpython/gis_set.py:111
+msgid "3. Select GRASS Mapset"
+msgstr "3. Valitse GRASS Karttajoukko"
+#: ../gui/wxpython/gis_set.py:129
+msgid "GRASS GIS database directory contains Locations."
+msgstr "GRASS GIS tietokanta hakemisto sisältää Paikat."
+#: ../gui/wxpython/gis_set.py:133
+msgid ""
+"All data in one Location is in the same  coordinate reference system "
+"(projection). One Location can be one project. Location contains Mapsets."
+msgstr ""
+"Kaikki tiedot yhdessä Paikassa ovat samassa koordinaattijärjestelmässä "
+"(projektiossa). Yksi Paikka voi olla yksi projekti. Paikka sisältää "
+"Karttajoukot."
+#: ../gui/wxpython/gis_set.py:141
+msgid ""
+"Mapset contains GIS data related to one project, task within one project, "
+"subregion or user."
+msgstr ""
+"Karttajoukko sisältää GIS tiedot jotka liittyvät yhteen projektiin. "
+"tehtävään yhdessä projektissa, seutuun tai käyttäjään."
+#: ../gui/wxpython/gis_set.py:156
+msgid "Start &GRASS session"
+msgstr "Käynnistä &GRASS istunto"
+#: ../gui/wxpython/gis_set.py:162
+msgid "&Browse"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:164
+msgid "&New"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:166
+msgid "Create a new Mapset in selected Location"
+msgstr "Luo uusi Karttajoukko valittuun Paikkaan"
+#: ../gui/wxpython/gis_set.py:168
+msgid "N&ew"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:169
+msgid ""
+"Create a new location using location wizard. After location is created "
+"successfully, GRASS session is started."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:173
+msgid "Ren&ame"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:174 ../gui/wxpython/gis_set.py:637
+msgid "Rename selected location"
+msgstr "Nimeä uudelleen valittu paikka"
+#: ../gui/wxpython/gis_set.py:176
+msgid "De&lete"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:177 ../gui/wxpython/gis_set.py:707
+msgid "Delete selected location"
+msgstr "Poista valittu paikka"
+#: ../gui/wxpython/gis_set.py:179 ../gui/wxpython/dbmgr/base.py:2166
+msgid "&Rename"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:180 ../gui/wxpython/gis_set.py:601
+msgid "Rename selected mapset"
+msgstr "Nimeä uudelleen valittu karttajoukko"
+#: ../gui/wxpython/gis_set.py:182
+msgid "&Delete"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:183 ../gui/wxpython/gis_set.py:683
+msgid "Delete selected mapset"
+msgstr "Poista valittu karttajoukko"
+#: ../gui/wxpython/gis_set.py:227
+#, python-format
+msgid "GRASS GIS %s startup%s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:232
+msgid "Enter GRASS session"
+msgstr "Anna GRASS istunto"
+#: ../gui/wxpython/gis_set.py:251 ../gui/wxpython/gis_set.py:624
+#: ../gui/wxpython/gis_set.py:661 ../gui/wxpython/vdigit/dialogs.py:244
+#: ../gui/wxpython/vdigit/dialogs.py:436 ../gui/wxpython/gmodeler/frame.py:961
+#: ../gui/wxpython/psmap/dialogs.py:3951 ../gui/wxpython/lmgr/layertree.py:758
+#: ../gui/wxpython/gui_core/preferences.py:212
+#: ../gui/wxpython/gui_core/preferences.py:1383
+#: ../gui/wxpython/gui_core/preferences.py:1412
+#: ../gui/wxpython/gui_core/preferences.py:1421
+#: ../gui/wxpython/gui_core/preferences.py:1430
+#: ../gui/wxpython/core/workspace.py:1329 ../gui/wxpython/core/gcmd.py:115
+#: ../gui/wxpython/location_wizard/wizard.py:541
+#: ../gui/wxpython/location_wizard/wizard.py:725
+#: ../gui/wxpython/location_wizard/wizard.py:1503
+#: ../gui/wxpython/location_wizard/wizard.py:1569
+#: ../gui/wxpython/location_wizard/dialogs.py:114
+#: ../gui/wxpython/location_wizard/dialogs.py:131
+#: ../gui/wxpython/location_wizard/dialogs.py:439
+msgid "Error"
+msgstr "Virhe"
+#: ../gui/wxpython/gis_set.py:252 ../gui/wxpython/gis_set.py:728
+msgid "Unable to set GRASS database. Check your locale settings."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:270
+#, python-format
+msgid "ERROR: Location <%s> not found\n"
+msgstr "VIRHE: Paikkaa <%s> ei löydy\n"
+#: ../gui/wxpython/gis_set.py:287
+#, python-format
+msgid "ERROR: Mapset <%s> not found\n"
+msgstr "VIRHE: Karttajoukkoa <%s> ei löydy\n"
+#: ../gui/wxpython/gis_set.py:445
+#, python-format
+msgid "Invalid line in GISRC file (%s):%s\n"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:477
+#, python-brace-format
+msgid "Error: {text}"
+msgstr "Virhe: {text}"
+#: ../gui/wxpython/gis_set.py:509
+#, python-format
+msgid "Do you want to import <%(name)s> to the newly created location?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:513
+msgid "Import data?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:525
+msgid "Do you want to create new mapset?"
+msgstr "Haluatko luoda uuden karttajoukon?"
+#: ../gui/wxpython/gis_set.py:526 ../gui/wxpython/gis_set.py:886
+#: ../gui/wxpython/lmgr/frame.py:930 ../gui/wxpython/menustrings.py:228
+msgid "Create new mapset"
+msgstr "Luo uusi karttajoukko"
+#: ../gui/wxpython/gis_set.py:538 ../gui/wxpython/lmgr/frame.py:425
+#, python-format
+msgid "Location <%s> created"
+msgstr "Paikka <%s> luotu"
+#: ../gui/wxpython/gis_set.py:539 ../gui/wxpython/lmgr/frame.py:423
+msgid "Do you want to set the default region extents and resolution now?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:579
+#, python-format
+msgid ""
+"Import of <%(name)s> failed.\n"
+"Reason: %(msg)s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:582
+#, python-format
+msgid ""
+"Data file <%(name)s> imported successfully. The location's default region "
+"was set from this imported map."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:595
+msgid ""
+"Mapset <PERMANENT> is required for valid GRASS location.\n"
+"\n"
+"This mapset cannot be renamed."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:600 ../gui/wxpython/gis_set.py:636
+#, python-format
+msgid ""
+"Current name: %s\n"
+"\n"
+"Enter new name:"
+msgstr ""
+"Nykyinen nimi: %s\n"
+"\n"
+"Anna uusi nimi:"
+#: ../gui/wxpython/gis_set.py:612 ../gui/wxpython/gis_set.py:648
+#: ../gui/wxpython/lmgr/frame.py:2238 ../gui/wxpython/core/gcmd.py:149
+msgid "Message"
+msgstr "Viesti"
+#: ../gui/wxpython/gis_set.py:613
+#, python-format
+msgid ""
+"Unable to rename mapset.\n"
+"\n"
+"Mapset <%s> already exists in location."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:625
+#, python-format
+msgid ""
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:649
+#, python-format
+msgid ""
+"Unable to rename location.\n"
+"\n"
+"Location <%s> already exists in GRASS database."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:662
+#, python-format
+msgid ""
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:674
+msgid ""
+"\n"
+"This mapset cannot be deleted."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:678
+#, python-format
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <"
+"%(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:692
+msgid "Unable to delete mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:703
+#, python-format
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:718
+msgid "Unable to delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:739
+#, python-format
+msgid ""
+"No GRASS Location found in '%s'. Create a new Location or choose different "
+"GRASS database directory."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:857
+#, python-format
+msgid "Path '%s' doesn't exist."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:872 ../gui/wxpython/gui_core/gselect.py:1076
+msgid "Choose GIS Data Directory"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:885 ../gui/wxpython/lmgr/frame.py:929
+msgid "Enter name for new mapset:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:898
+#, python-format
+msgid "Mapset <%s> already exists."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:903
+#, python-format
+msgid ""
+"Mapset <%s> is reserved for direct read access to OGR layers. Please "
+"consider to use another name for your mapset.\n"
+"\n"
+"Are you really sure that you want to create this mapset?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:907
+msgid "Reserved mapset name"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:930
+#, python-format
+msgid "Unable to create new mapset: %s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:943
+#, python-format
+msgid ""
+"GRASS is already running in selected mapset <%(mapset)s>\n"
+"(file %(lock)s found).\n"
+"\n"
+"Concurrent use not allowed.\n"
+"\n"
+"Do you want to try to remove .gislock (note that you need permission for "
+"this operation) and continue?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:949 ../gui/wxpython/gis_set.py:961
+msgid "Lock file found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:957
+msgid ""
+"ARE YOU REALLY SURE?\n"
+"\n"
+"If you really are running another GRASS session doing this could corrupt "
+"your data. Have another look in the processor manager just to be sure..."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:972
+#, python-format
+msgid ""
+"Unable to remove '%(lock)s'.\n"
+"\n"
+"Details: %(reason)s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1020
+#, python-format
+msgid ""
+"Name <%(name)s> is not a valid name for location or mapset. Please use only "
+"ASCII characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1023 ../gui/wxpython/lmgr/layertree.py:789
+msgid "Invalid name"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1091
+msgid ""
+"GRASS needs a directory (GRASS database) in which to store its data. Create "
+"one now if you have not already done so. A popular choice is \"grassdata\", "
+"located in your home directory. Press Browse button to select the directory."
+msgstr ""
+#: ../gui/wxpython/iclass/statistics.py:29
+msgid "Loading imagery lib failed"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:39
+#, python-format
+msgid ""
+"Loading imagery lib failed.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:75
+msgid "GRASS GIS Supervised Classification Tool"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:294 ../gui/wxpython/mapswipe/frame.py:272
+#: ../gui/wxpython/gcp/mapdisplay.py:248 ../gui/wxpython/mapdisp/frame.py:473
+#: ../gui/wxpython/rlisetup/sampling_frame.py:99
+msgid "Map Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:306
+msgid "IClass Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:318
+msgid "IClass Misc Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:335
+msgid "Digitization Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:359
+msgid "Plots"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:379
+msgid "Preview Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:382
+msgid "Training Areas Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:452
+msgid "Adjust Training Area Display to Preview Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:453
+msgid "Adjust Preview display to Training Area Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:454
+msgid "Display synchronization ON"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:455
+msgid "Display synchronization OFF"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:525
+msgid "All changes will be lost. Do you want to continue?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:533
+msgid "Import vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:552
+#, python-format
+msgid "No areas in vector map <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:554
+#, python-format
+msgid "Vector map <%s> contains points or lines, these features are ignored."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:579
+#, python-format
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:586
+#, python-format
+msgid "Unable to copy vector features from <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:596
+msgid "Unable to open temporary vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:686
+msgid "No training areas to export."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:698
+#, python-format
+msgid "%d training areas (%d classes) exported to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:897
+msgid "Failed to create temporary vector map."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:973
+#, python-format
+msgid "No area in category %s. Category skipped."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:976
+msgid "Analysis failed."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:983
+msgid "results"
+msgstr "tulokset"
+#: ../gui/wxpython/iclass/frame.py:989
+msgid "No imagery group selected."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:994
+msgid ""
+"Due to recent changes in classes, signatures can be outdated and should be "
+"recalculated. Do you still want to continue?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:997
+msgid "Outdated signatures"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1013
+#, python-format
+msgid ""
+"A signature file named %s already exists.\n"
+"Do you want to replace it?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1015 ../gui/wxpython/gmodeler/frame.py:458
+msgid "File already exists"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1061
+msgid "No imagery group selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1070
+#, python-format
+msgid ""
+"Group <%(group)s> does not have enough files (it has %(files)d files). "
+"Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1079
+msgid "No areas given. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1094
+msgid "Vector features are outside raster layers. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:66
+msgid "Histograms"
+msgstr "Histogrammit"
+#: ../gui/wxpython/iclass/plots.py:67
+msgid "Coincident plots"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:68
+msgid "Scatter plots"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:83
+#, python-format
+msgid ""
+"Scatter plot functionality is disabled.\n"
+"\n"
+"Reason: Unable to import packages needed for scatter plot.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:57
+msgid ""
+"You are trying to create a training area outside the computational region. "
+"Please, use g.region to set the appropriate region first."
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:66
+msgid ""
+"In order to create a training area, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:70
+#: ../gui/wxpython/iscatt/controllers.py:403
+msgid "No class selected"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:71
+msgid "Name of subgroup required"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:75
+#: ../gui/wxpython/iclass/dialogs.py:189
+#, python-format
+msgid "Group <%s> not found"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:80
+#, python-format
+msgid "Subgroup <%s> not found"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:87
+#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:75
+#: ../gui/wxpython/modules/histogram.py:352 ../gui/wxpython/nviz/wxnviz.py:329
+#: ../gui/wxpython/nviz/wxnviz.py:340
+#, python-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:93
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:59
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:44 ../gui/wxpython/nviz/wxnviz.py:417
+#, python-format
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:115
+#, python-format
+msgid "Loading raster map <%s>..."
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:118
+#, python-format
+msgid "Loading training map <%s>..."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:42 ../gui/wxpython/iclass/toolbars.py:37
+#: ../gui/wxpython/iscatt/toolbars.py:43
+msgid "Select imagery group"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:72 ../gui/wxpython/gcp/manager.py:464
+msgid "Create/edit group..."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:78
+msgid "Name of imagery group is missing."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:85
+msgid "Name of imagery group:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:97
+msgid "Name of imagery subgroup:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:171
+msgid "Please choose a subgroup."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:174
+#, python-format
+msgid "Subgroup <%s> not found in group <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:180
+#, python-format
+msgid ""
+"No data found in subgroup <%s> of group <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:185
+#, python-format
+msgid ""
+"No data found in group <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:232
+msgid "Name of map is missing."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:239
+#: ../gui/wxpython/gmodeler/dialogs.py:76
+msgid "Name of raster map:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:241
+#: ../gui/wxpython/gmodeler/dialogs.py:78
+#: ../gui/wxpython/gui_core/dialogs.py:211
+msgid "Name of vector map:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:261 ../gui/wxpython/iclass/toolbars.py:35
+msgid "Class manager"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:276 ../gui/wxpython/iscatt/frame.py:129
+msgid "Classes"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:357 ../gui/wxpython/iscatt/frame.py:375
+msgid "Class name"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:358
+#: ../gui/wxpython/gmodeler/preferences.py:90
+#: ../gui/wxpython/gmodeler/preferences.py:328
+#: ../gui/wxpython/gmodeler/preferences.py:413
+#: ../gui/wxpython/psmap/dialogs.py:4597 ../gui/wxpython/psmap/dialogs.py:4852
+#: ../gui/wxpython/wxplot/dialogs.py:917 ../gui/wxpython/wxplot/dialogs.py:967
+#: ../gui/wxpython/nviz/tools.py:788 ../gui/wxpython/nviz/tools.py:2402
+msgid "Color"
+msgstr "Väri"
+#: ../gui/wxpython/iclass/dialogs.py:390 ../gui/wxpython/iscatt/frame.py:412
+msgid "Please use only ASCII characters."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:500
+msgid "Zoom to training areas of selected class"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:558
+msgid "Save signature file"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:615
+msgid "Enter name of signature file:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:624
+msgid "Signature file path:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:666
+msgid "Export training areas"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:710 ../gui/wxpython/iscatt/dialogs.py:253
+msgid "Enter name of new vector map:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:720
+msgid "Export attribute table"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:722
+msgid "Export attribute table containing computed statistical data"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:760
+#, python-format
+msgid "Vector map <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:762
+#, python-format
+msgid "Vector <%s> exists"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:33
+msgid "Set opacity level"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:39
+msgid "Run analysis, update histogram and coincidence plots"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:41
+msgid "Save signature file for i.maxlik"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:43
+msgid "Remove selected map layer"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:45
+msgid "Export training areas to vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:47
+msgid "Import training areas from vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:49 ../gui/wxpython/lmgr/layertree.py:80
+#: ../gui/wxpython/gui_core/simplelmgr.py:455
+msgid "Add RGB map layer"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:66
+msgid "Training"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:523
+msgid "Preview"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:70
+msgid "Set map canvas for "
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:72
+msgid "/ Zoom to map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:244
+#: ../gui/wxpython/iclass/toolbars.py:249
+msgid "std dev"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:319
+msgid "Add raster map"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:42
+msgid "GRASS GIS Map Swipe"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:284
+#: ../gui/wxpython/animation/frame.py:146
+msgid "Main Toolbar"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:296
+#: ../gui/wxpython/animation/frame.py:167 ../gui/wxpython/lmgr/frame.py:148
+msgid "Misc Toolbar"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:397
+#, python-format
+msgid "Map <%s> not found. "
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:399 ../gui/wxpython/animation/utils.py:93
+#: ../gui/wxpython/animation/utils.py:101
+#: ../gui/wxpython/lmgr/layertree.py:1661
+#, python-format
+msgid "Map <%s> not found."
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:518 ../gui/wxpython/gcp/mapdisplay.py:368
+#: ../gui/wxpython/mapdisp/frame.py:734
+msgid "Nothing to render (empty map). Operation canceled."
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:524 ../gui/wxpython/gcp/mapdisplay.py:383
+#: ../gui/wxpython/gmodeler/frame.py:577 ../gui/wxpython/mapdisp/frame.py:587
+#: ../gui/wxpython/modules/histogram.py:423
+msgid "Choose a file name to save the image (no need to add extension)"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:630 ../gui/wxpython/mapdisp/frame.py:823
+msgid "No raster or vector map layer selected for querying."
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:42
+#: ../gui/wxpython/mapswipe/toolbars.py:28
+msgid "Select raster maps"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:119
+msgid "Name of top/left raster map:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:123
+msgid "Name of bottom/right raster map:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:156
+msgid "Switch to advanced mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:157
+msgid "Cancel"
+msgstr "Peruuta"
+#: ../gui/wxpython/mapswipe/dialogs.py:161
+msgid "Switch to simple mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:162 ../gui/wxpython/menustrings.py:13
+#: ../gui/wxpython/menustrings.py:1921
+msgid "Close"
+msgstr "Sulje"
+#: ../gui/wxpython/mapswipe/dialogs.py:185
+msgid "Name of the first map is missing."
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:187
+msgid "Name of the second map is missing."
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:218
+msgid "Map Swipe settings"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:233
+#: ../gui/wxpython/mapswipe/toolbars.py:111
+msgid "Mirror mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:236
+msgid "Mirrored cursor"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:242 ../gui/wxpython/gcp/manager.py:2473
+#: ../gui/wxpython/psmap/dialogs.py:1777 ../gui/wxpython/psmap/dialogs.py:1880
+#: ../gui/wxpython/gui_core/preferences.py:1068
+#: ../gui/wxpython/nviz/tools.py:1150 ../gui/wxpython/nviz/tools.py:1792
+#: ../gui/wxpython/nviz/tools.py:1913 ../gui/wxpython/nviz/preferences.py:334
+#: ../gui/wxpython/nviz/preferences.py:491
+#: ../gui/wxpython/nviz/preferences.py:545
+msgid "Color:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:255
+msgid "Shape:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:270 ../gui/wxpython/gcp/manager.py:2564
+#: ../gui/wxpython/psmap/dialogs.py:4900 ../gui/wxpython/vnet/dialogs.py:1167
+#: ../gui/wxpython/gui_core/preferences.py:1004
+msgid "Line width:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:283
+#: ../gui/wxpython/nviz/preferences.py:516
+msgid "Size:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:26
+#: ../gui/wxpython/modules/vclean.py:455
+msgid "Tools"
+msgstr "Työkalut"
+#: ../gui/wxpython/mapswipe/toolbars.py:27
+msgid "Quit Map Swipe"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:30
+#: ../gui/wxpython/mapdisp/toolbars.py:29
+msgid "Query raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:31
+#: ../gui/wxpython/mapdisp/toolbars.py:30
+msgid "Query selected raster/vector map(s)"
+msgstr ""
+msgid "Swipe mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:120
+msgid "Choose view mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:144
+msgid "Switch orientation"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:146
+msgid "Switch maps"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:48
+msgid "GRASS GIS Manage Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:163
+msgid "GCP List"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:168
+msgid "Source Display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:172
+msgid "Target Display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:261
+msgid "GCP Display toolbar"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:274
+msgid "GCP Manager toolbar"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:412 ../gui/wxpython/psmap/toolbars.py:73
+#: ../gui/wxpython/mapdisp/frame.py:745 ../gui/wxpython/wxplot/base.py:558
+#: ../gui/wxpython/menustrings.py:1963
+#: ../gui/wxpython/modules/histogram.py:452
+msgid "Page setup"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:416 ../gui/wxpython/mapdisp/frame.py:749
+#: ../gui/wxpython/wxplot/base.py:559 ../gui/wxpython/modules/histogram.py:456
+msgid "Print preview"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:420 ../gui/wxpython/mapdisp/frame.py:753
+#: ../gui/wxpython/wxplot/base.py:560 ../gui/wxpython/gui_core/toolbars.py:67
+#: ../gui/wxpython/modules/histogram.py:460
+msgid "Print display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:459
+msgid "Zoom to computational region (set with g.region)"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:463 ../gui/wxpython/mapdisp/frame.py:1354
+msgid "Zoom to default region"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:467 ../gui/wxpython/mapdisp/frame.py:1355
+msgid "Zoom to saved region"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:471
+msgid "Set computational region from display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:475 ../gui/wxpython/mapdisp/frame.py:1361
+msgid "Save display geometry to named region"
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:36
+msgid "Go to GCP No."
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:53
+msgid "Valid Range:"
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:118
+msgid "RMS error"
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:122
+#, python-format
+msgid "Forward: %(forw)s, Backward: %(back)s"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:136
+msgid "Setup for georectification"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:169 ../gui/wxpython/gcp/manager.py:173
+msgid "Georectifying setup canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:315
+msgid "Select map type and location/mapset"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:328
+msgid "Map type to georectify"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:329 ../gui/wxpython/gmodeler/frame.py:1454
+#: ../gui/wxpython/psmap/dialogs.py:696
+#: ../gui/wxpython/gui_core/dialogs.py:1327
+#: ../gui/wxpython/gui_core/dialogs.py:1558
+msgid "raster"
+msgstr "rasteri"
+#: ../gui/wxpython/gcp/manager.py:329 ../gui/wxpython/gmodeler/frame.py:1455
+#: ../gui/wxpython/psmap/dialogs.py:697
+msgid "vector"
+msgstr "vektori"
+#: ../gui/wxpython/gcp/manager.py:336
+msgid "Select source location:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:345
+msgid "Select source mapset:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:399
+msgid "You must select a valid location before selecting a mapset"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:412
+msgid "You must select a valid location and mapset in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:431
+msgid "Select image/map group to georectify"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:449
+msgid "Select group:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:460
+msgid "Create group if none exists"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:465
+msgid "Add vector map to group..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:477 ../gui/wxpython/gcp/manager.py:2666
+msgid "Extension for output maps:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:537
+msgid "You must select a valid image/map group in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:544
+msgid "You must enter an map name extension in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:610
+msgid "Select maps to display for ground control point (GCP) creation"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:618 ../gui/wxpython/gcp/manager.py:2602
+msgid "Select source map to display:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:629 ../gui/wxpython/gcp/manager.py:2607
+msgid "Select target raster map to display:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:640 ../gui/wxpython/gcp/manager.py:2612
+msgid "Select target vector map to display:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:703
+msgid "You must select a source map in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:729 ../gui/wxpython/gcp/manager.py:759
+#, python-format
+msgid ""
+"No maps in selected group <%s>.\n"
+"Please edit group or select another group."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:787
+msgid "Manage Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1040
+#, python-format
+msgid "At least %d GCPs required. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1172
+msgid "source"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1174
+msgid "target"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1176
+msgid "Set GCP coordinates"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1177
+#, python-format
+msgid ""
+"Set %(coor)s coordinates for GCP No. %(key)s? \n"
+"\n"
+"East: %(coor0)s \n"
+"North: %(coor1)s"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1243
+msgid "Writing POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1252
+#, python-format
+msgid "POINTS file saved for group <%s>"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1267
+msgid "source mapwin not defined"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1272
+msgid "target mapwin not defined"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1300
+msgid "Reading POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1382
+#, python-format
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification "
+"method (order: %d).\n"
+"3+ points needed for 1st order,\n"
+"6+ points for 2nd order, and\n"
+"10+ points for 3rd order."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1409
+msgid "Rectifying images, please wait..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1449
+#, python-format
+msgid "Transforming <%s>..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1453
+#, python-format
+msgid "Rectifying vector map <%s>, please wait..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1486
+#, python-format
+msgid "Georectification of vector map <%s> failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1493
+msgid "GCP Manager settings"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1538
+msgid "Quit GCP Manager"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1539
+msgid "Save ground control points?"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1618
+msgid ""
+"Could not calculate RMS Error.\n"
+"Possible error with m.transform."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1742
+msgid ""
+"Could not calculate new extends.\n"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1871
+msgid "Adjust source display to target display"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1875
+msgid "Adjust target display to source display"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1948 ../gui/wxpython/gcp/manager.py:1965
+#: ../gui/wxpython/vnet/widgets.py:85 ../gui/wxpython/vnet/vnet_data.py:238
+msgid "use"
+msgstr "käytä"
+#: ../gui/wxpython/gcp/manager.py:1949 ../gui/wxpython/gcp/manager.py:1966
+msgid "source E"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1950 ../gui/wxpython/gcp/manager.py:1967
+msgid "source N"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1951 ../gui/wxpython/gcp/manager.py:1968
+msgid "target E"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1952 ../gui/wxpython/gcp/manager.py:1969
+msgid "target N"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1953 ../gui/wxpython/gcp/manager.py:1970
+msgid "Forward error"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1954 ../gui/wxpython/gcp/manager.py:1971
+msgid "Backward error"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2106
+msgid "Invalid coordinate value. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2151
+msgid "Create vector map group"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2224
+msgid "Select vector map(s) to add to group:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2271
+msgid "Edit GCP"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2282
+msgid "Ground Control Point No."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2301
+msgid "source E:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2302
+msgid "target E:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2303
+msgid "source N:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2304
+msgid "target N:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2407 ../gui/wxpython/vnet/dialogs.py:1189
+#: ../gui/wxpython/wxplot/dialogs.py:685
+#: ../gui/wxpython/wxplot/dialogs.py:1134
+#: ../gui/wxpython/iscatt/dialogs.py:357
+msgid "Apply changes for the current session"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2409 ../gui/wxpython/vnet/dialogs.py:1191
+#: ../gui/wxpython/wxplot/dialogs.py:690
+#: ../gui/wxpython/wxplot/dialogs.py:1136
+#: ../gui/wxpython/gui_core/preferences.py:93
+#: ../gui/wxpython/iscatt/dialogs.py:359
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2411 ../gui/wxpython/vnet/dialogs.py:1193
+#: ../gui/wxpython/gui_core/dialogs.py:1689
+#: ../gui/wxpython/gui_core/dialogs.py:2019
+#: ../gui/wxpython/web_services/dialogs.py:132
+#: ../gui/wxpython/web_services/dialogs.py:827
+#: ../gui/wxpython/iscatt/dialogs.py:361
+msgid "Close dialog"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2433
+#: ../gui/wxpython/vdigit/preferences.py:86
+#: ../gui/wxpython/psmap/dialogs.py:1954
+msgid "Symbology"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2441
+msgid "Highlight highest RMS error only"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2447
+msgid "Highlight RMS error > M + SD * factor:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2448
+msgid ""
+"Highlight GCPs with an RMS error larger than \n"
+"mean + standard deviation * given factor. \n"
+"Recommended values for this factor are between 1 and 2."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2465
+msgid "Symbol settings"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2490
+msgid "Color for high RMS error:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2507
+msgid "Color for selected GCP:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2524
+msgid "Color for unused GCPs:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2540
+msgid "Show unused GCPs"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2549
+#: ../gui/wxpython/gui_core/preferences.py:1016
+msgid "Symbol size:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2633
+msgid "Rectification"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2639
+msgid "Select rectification order"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2640
+msgid "1st order"
+msgstr ""
+msgid "2nd order"
+msgstr ""
+msgid "3rd order"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2648
+msgid "Select interpolation method:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2660
+msgid "clip to computational region in target location"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2700
+msgid "RMS threshold factor must be > 0"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2703
+msgid ""
+"RMS threshold factor is < 1\n"
+"Too many points might be highlighted"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2850
+#, python-format
+msgid "GCP Manager settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:63
+msgid "GRASS GIS Vector Digitizer"
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:79
+#, python-format
+msgid "Vector digitizer not available. %s"
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:84
+#, python-format
+msgid ""
+"Vector map <%s> not found in current mapset. New vector map can be created "
+"by providing '-c' flag."
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:87
+#, python-format
+msgid "New vector map <%s> created"
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:91
+#, python-format
+msgid "Unable to create new vector map <%s>"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:948
+#, python-format
+msgid ""
+"Topology for vector map <%s> is not available. Topology is required by "
+"digitizer. Do you want to rebuild topology (takes some time) and open the "
+"vector map for editing?"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:952
+msgid "Topology missing"
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:411
+msgid "Update categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:535
+#: ../gui/wxpython/vdigit/mapwindow.py:905
+msgid "No vector map selected for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:543
+msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:1041
+msgid "Z bulk-labeling dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:31
+#: ../gui/wxpython/vdigit/toolbars.py:164
+msgid "Digitization settings"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:57
+msgid "Apply changes for this session"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:60
+msgid "Close dialog and save changes to user settings file"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:62
+#: ../gui/wxpython/gmodeler/preferences.py:539
+#: ../gui/wxpython/psmap/dialogs.py:355 ../gui/wxpython/wxplot/dialogs.py:692
+#: ../gui/wxpython/wxplot/dialogs.py:1137
+#: ../gui/wxpython/gui_core/preferences.py:96
+msgid "Close dialog and ignore changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:124
+#: ../gui/wxpython/gmodeler/preferences.py:47
+#: ../gui/wxpython/animation/dialogs.py:287
+#: ../gui/wxpython/animation/dialogs.py:1489
+#: ../gui/wxpython/gui_core/preferences.py:246
+msgid "General"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:131
+#: ../gui/wxpython/nviz/tools.py:1295 ../gui/wxpython/nviz/tools.py:1469
+msgid "Display"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:136
+#: ../gui/wxpython/wxplot/dialogs.py:878
+msgid "Line width"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:154
+msgid "Snapping"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:160
+msgid "Snapping threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:167
+msgid "screen pixels"
+msgstr ""
+msgid "map units"
+msgstr "karttayksiköt"
+#: ../gui/wxpython/vdigit/preferences.py:176
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:181
+#: ../gui/wxpython/vdigit/preferences.py:625
+#: ../gui/wxpython/vdigit/preferences.py:639
+#: ../gui/wxpython/vdigit/preferences.py:643
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:194
+msgid "Select vector features"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:211
+msgid "Select threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:224
+msgid "Select only features inside of selection bounding box"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:226
+msgid ""
+"By default are selected all features overlapping selection bounding box "
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:229
+msgid "Check for duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:241
+msgid "Digitize lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:244
+msgid "Break lines at intersection"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:254
+msgid "Digitize areas"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:257
+msgid "Close boundary (snap to the start node)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:267
+msgid "Save changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:270
+msgid "Save changes on exit"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:282
+msgid "Query tool"
+msgstr "Kyselyn työkalu"
+#: ../gui/wxpython/vdigit/preferences.py:289
+msgid "Choose query tool"
+msgstr "Valitse kyselyn työkalu"
+#: ../gui/wxpython/vdigit/preferences.py:294
+msgid "Select by box"
+msgstr "Valitse laatikolla"
+#: ../gui/wxpython/vdigit/preferences.py:303
+#: ../gui/wxpython/vdigit/preferences.py:434
+msgid "length"
+msgstr "pituus"
+#: ../gui/wxpython/vdigit/preferences.py:308
+msgid "Select lines"
+msgstr "Valitse viivat"
+#: ../gui/wxpython/vdigit/preferences.py:310
+#: ../gui/wxpython/vdigit/preferences.py:333
+msgid "shorter than"
+msgstr ""
+msgid "longer than"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:326
+msgid "dangle"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:331
+msgid "Select dangles"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:363
+#: ../gui/wxpython/gui_core/preferences.py:1053
+msgid "Attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:370
+msgid "Digitize new feature"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:375
+msgid "Add new record into table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:381
+#: ../gui/wxpython/vdigit/preferences.py:383
+#: ../gui/wxpython/vdigit/dialogs.py:113 ../gui/wxpython/vdigit/dialogs.py:558
+#: ../gui/wxpython/dbmgr/base.py:2642 ../gui/wxpython/dbmgr/base.py:2756
+#: ../gui/wxpython/dbmgr/base.py:3010 ../gui/wxpython/dbmgr/dialogs.py:493
+msgid "Layer"
+msgstr "Taso"
+#: ../gui/wxpython/vdigit/dialogs.py:120 ../gui/wxpython/vdigit/dialogs.py:559
+#: ../gui/wxpython/dbmgr/dialogs.py:494 ../gui/wxpython/dbmgr/dialogs.py:612
+msgid "Category"
+msgstr "Luokka"
+msgid "Mode"
+msgstr "Tila"
+#: ../gui/wxpython/vdigit/preferences.py:403
+msgid "Next to use"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:391
+msgid "Category number"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:401
+msgid "Category mode"
+msgstr ""
+msgid "Manual entry"
+msgstr ""
+msgid "No category"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:416
+msgid "Delete existing feature(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:421
+msgid "Delete record from table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:431
+msgid "Geometry attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:435
+#: ../gui/wxpython/modules/vclean.py:200
+msgid "area"
+msgstr "alue"
+#: ../gui/wxpython/vdigit/preferences.py:436
+msgid "perimeter"
+msgstr "kehä"
+#: ../gui/wxpython/vdigit/preferences.py:505
+msgid ""
+"Note: These settings are stored in the workspace not in the vector digitizer "
+"preferences."
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:534
+msgid "Digitize new line segment"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:535
+msgid "Digitize new line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:536
+msgid "Highlight"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:537
+msgid "Highlight (duplicates)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:538
+#: ../gui/wxpython/psmap/dialogs.py:4526 ../gui/wxpython/psmap/toolbars.py:100
+#: ../gui/wxpython/gui_core/gselect.py:2113
+msgid "Point"
+msgstr "Piste"
+#: ../gui/wxpython/vdigit/preferences.py:539
+#: ../gui/wxpython/psmap/toolbars.py:102
+msgid "Line"
+msgstr "Viiva"
+#: ../gui/wxpython/vdigit/preferences.py:540
+msgid "Boundary (no area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:541
+msgid "Boundary (one area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:542
+msgid "Boundary (two areas)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:543
+msgid "Centroid (in area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:544
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:545
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:546
+msgid "Node (one line)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:547
+msgid "Node (two lines)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:548
+msgid "Vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:549
+msgid "Area (closed boundary + centroid)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:550
+msgid "Direction"
+msgstr "Suunta"
+#: ../gui/wxpython/vdigit/preferences.py:618
+msgid "Snapping disabled"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:620
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:676
+#, python-format
+msgid "Vector digitizer settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:54
+msgid "Digitization Error"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:59
+#, python-format
+msgid "Unable to open vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:61 ../gui/wxpython/vdigit/toolbars.py:585
+msgid "No vector map open for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:62
+msgid "Operation canceled."
+msgstr "Toiminto peruutettiin."
+#: ../gui/wxpython/vdigit/wxdigit.py:69
+#, python-format
+msgid ""
+"Writing new feature failed. Operation canceled.\n"
+"\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:78
+#, python-format
+msgid "Reading feature id %d failed. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:86
+#, python-format
+msgid "Database link %d not available. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:94
+#, python-format
+msgid "Unable to start database driver <%s>. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:102
+#, python-format
+msgid ""
+"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:110
+#, python-format
+msgid "Unable to execute SQL query '%s'. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:118
+#, python-format
+msgid "Feature id %d is marked as dead. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:126
+#, python-format
+msgid "Unsupported feature type %d. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:473
+#, python-format
+msgid "Unknown feature type '%s'"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:478
+msgid "Not enough points for line"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:76
+msgid "List of categories - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:107
+msgid "Add new category"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:144 ../gui/wxpython/psmap/dialogs.py:359
+#: ../gui/wxpython/web_services/dialogs.py:627
+msgid "Apply changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:146
+msgid "Ignore changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:148
+#: ../gui/wxpython/web_services/dialogs.py:632
+msgid "Apply changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:168 ../gui/wxpython/dbmgr/dialogs.py:142
+msgid "Feature id:"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:239 ../gui/wxpython/vdigit/dialogs.py:458
+#, python-format
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater than zero."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:275
+#: ../gui/wxpython/gmodeler/dialogs.py:770
+#: ../gui/wxpython/gmodeler/dialogs.py:921
+msgid "Delete selected"
+msgstr "Poista valitut"
+#: ../gui/wxpython/vdigit/dialogs.py:279
+#: ../gui/wxpython/gmodeler/dialogs.py:771
+msgid "Delete all"
+msgstr "Poista kaikki"
+#: ../gui/wxpython/vdigit/dialogs.py:281
+#: ../gui/wxpython/gmodeler/dialogs.py:777
+#: ../gui/wxpython/gmodeler/dialogs.py:925 ../gui/wxpython/dbmgr/base.py:1294
+#: ../gui/wxpython/dbmgr/base.py:2315
+msgid "Reload"
+msgstr "Lataa uudelleen"
+#: ../gui/wxpython/vdigit/dialogs.py:435
+msgid "Unable to update vector map."
+msgstr "Vektorikarttaa ei voida päivittää."
+#: ../gui/wxpython/vdigit/dialogs.py:595
+#, python-format
+msgid "%d lines selected for z bulk-labeling"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:598
+msgid "Set value"
+msgstr "Aseta arvo"
+#: ../gui/wxpython/vdigit/dialogs.py:605
+msgid "Starting value"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:614
+msgid "Step"
+msgstr "Askel"
+#: ../gui/wxpython/vdigit/dialogs.py:644
+msgid "List of duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:740
+msgid "Feature id"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:741
+msgid "Layer (Categories)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:97
+msgid "Select area/boundary/centroid tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:123
+msgid "Digitize new point"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:124
+#: ../gui/wxpython/vdigit/toolbars.py:133
+#: ../gui/wxpython/vdigit/toolbars.py:136
+msgid "Left: new point"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:126
+msgid "Digitize new line"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:127
+#: ../gui/wxpython/vdigit/toolbars.py:130
+#: ../gui/wxpython/vdigit/toolbars.py:154
+msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:129
+msgid "Digitize new boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:132
+msgid "Digitize new centroid"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:135
+msgid "Digitize new area (boundary without category)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:138
+msgid "Add new vertex to line or boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:139
+#: ../gui/wxpython/vdigit/toolbars.py:142
+#: ../gui/wxpython/vdigit/toolbars.py:145
+#: ../gui/wxpython/vdigit/toolbars.py:157
+#: ../gui/wxpython/vdigit/toolbars.py:160
+#: ../gui/wxpython/vdigit/toolbars.py:163
+#: ../gui/wxpython/vdigit/toolbars.py:172
+msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:141
+msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:144
+msgid "Delete selected area(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:147
+msgid "Display/update attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:148
+#: ../gui/wxpython/vdigit/toolbars.py:151
+msgid "Left: Select"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:150
+msgid "Display/update categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:153
+msgid "Edit selected line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:156
+msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:159
+msgid "Move selected vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:162
+msgid "Remove selected vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:165
+msgid "Quit digitizer"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:166
+msgid "Quit digitizer and save changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:167
+msgid "Vector Digitizer manual"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:168
+msgid "Show Vector Digitizer manual"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:170
+msgid "Additional tools (copy, flip, connect, etc.)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:174
+msgid "Undo"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:175
+msgid "Undo previous changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:177
+msgid "Redo"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:178
+msgid "Redo previous changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:541
+msgid "Break selected lines/boundaries at intersection"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:543
+msgid "Connect selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:545
+msgid "Copy categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:547
+msgid "Copy features from (background) vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:549
+msgid "Copy attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:551
+msgid "Feature type conversion"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:553
+msgid "Flip selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:555
+msgid "Merge selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:557
+msgid "Snap selected lines/boundaries (only to nodes)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:559
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:561
+msgid "Query features"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:563
+msgid "Z bulk-labeling of 3D lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:589
+msgid "Select background vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:746
+msgid "Vector map is not 3D. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:819
+#: ../gui/wxpython/vdigit/toolbars.py:957
+#: ../gui/wxpython/vdigit/toolbars.py:1045
+#: ../gui/wxpython/gui_core/dialogs.py:189
+msgid "Select vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:848
+#, python-format
+msgid ""
+"digitizer.\n"
+"Do you want to rebuild topology (takes some time) and open the vector map "
+"for editing?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:852
+msgid "Digitizer error"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:872
+#, python-format
+msgid "Please wait, opening vector map <%s> for editing..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:904
+#, python-format
+msgid ""
+"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:916
+msgid "Vector digitizer"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:965
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:967
+msgid "Save changes?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:974
+#, python-format
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:988
+#, python-format
+msgid "Editing of vector map <%s> successfully finished"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:1052
+#: ../gui/wxpython/vdigit/toolbars.py:1057
+msgid "New vector map"
+msgstr ""
+#: ../gui/wxpython/mapwin/graphics.py:258
+#: ../gui/wxpython/mapwin/graphics.py:387
+#, python-format
+msgid "Property does not exist: %s"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:218
+#: ../gui/wxpython/mapwin/analysis.py:332
+msgid "Measuring finished"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:233
+#: ../gui/wxpython/mapwin/analysis.py:342
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:239
+msgid "Measuring distance"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:242
+msgid "Measuring distance:"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:250
+#, python-format
+msgid ""
+"Geodesic distance calculation is not available.\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:286
+#: ../gui/wxpython/mapwin/analysis.py:292
+msgid "segment"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:287
+#: ../gui/wxpython/mapwin/analysis.py:293
+msgid "total distance"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:288
+msgid "bearing"
+msgstr ""
+msgid "degrees (clockwise from grid-north)"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:346
+msgid "Measuring area:"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:359
+msgid "Units not recognized, measurement failed."
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:364
+#: ../gui/wxpython/mapwin/analysis.py:366
+msgid "Area: {area} {unit}\n"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:154
+msgid "legend"
+msgstr ""
+msgid "scale bar"
+msgstr ""
+msgid "north arrow"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:233
+msgid "Copy coordinates to clipboard"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:243
+msgid "Hide {overlay}"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:250
+msgid "Resize legend"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:605
+#: ../gui/wxpython/modules/histogram.py:179
+msgid "Please wait, exporting image..."
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:886
+msgid "Unable to draw registered graphics. The graphics was unregistered."
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1879
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1881
+msgid "Set compulational region from named region"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1893
+#, python-format
+msgid "Region <%s> not found. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1922
+msgid "Save display extents to region file"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1924
+msgid "Save computational region to region file"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1934
+#, python-format
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1936
+#: ../gui/wxpython/wxplot/dialogs.py:802
+#: ../gui/wxpython/core/workspace.py:1345 ../gui/wxpython/core/gcmd.py:140
+msgid "Warning"
+msgstr "Varoitus"
+#: ../gui/wxpython/mapwin/base.py:195
+#, python-format
+msgid ""
+"Error occured during calling of handler: %s \n"
+"Handler was unregistered."
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:275
+#, python-format
+msgid ""
+"Error occured during unregistration of handler: %s \n"
+"                                        Handler was unregistered."
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:304
+#, python-format
+msgid "Handler: %s was not registered"
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:308
+#, python-format
+msgid ""
+"                                        Handler was unregistered"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:177
+#: ../gui/wxpython/mapwin/decorations.py:224
+msgid ""
+"Please install Python Imaging Library (PIL)\n"
+"for better control of legend and other decorations."
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:329
+msgid "Show text object"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:338
+#: ../gui/wxpython/animation/dialogs.py:865
+msgid "Text:"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:354
+#: ../gui/wxpython/nviz/tools.py:1011
+msgid "Rotation:"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:366
+#: ../gui/wxpython/psmap/dialogs.py:291
+msgid "Font:"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:369
+#: ../gui/wxpython/animation/dialogs.py:847
+#: ../gui/wxpython/gui_core/preferences.py:394
+#: ../gui/wxpython/gui_core/preferences.py:589
+msgid "Set font"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:382
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:63
+msgid "GRASS GIS Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:128
+msgid "Model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:129
+msgid "Items"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:130
+#: ../gui/wxpython/gmodeler/model.py:2580
+msgid "Variables"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:131
+msgid "Python editor"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:132
+#: ../gui/wxpython/gui_core/forms.py:1830
+#: ../gui/wxpython/modules/vkrige.py:102
+msgid "Command output"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:201
+msgid "Python script contains local modifications"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:203
+#: ../gui/wxpython/gmodeler/frame.py:1821
+msgid "Python script is up-to-date"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:218
+msgid "Redrawing model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:254
+msgid "Do you want to save changes in the model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:256
+msgid "Do you want to store current model settings to model file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:262
+msgid "Quit Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:316
+msgid "No intermediate data to delete."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:320
+#, python-format
+msgid "Do you want to permanently delete data?%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:321
+msgid "Delete intermediate data?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:338
+#, python-format
+msgid "%d maps deleted from current mapset"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:353 ../gui/wxpython/gmodeler/frame.py:479
+msgid ""
+"Current model is not empty. Do you want to store current settings to model "
+"file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:356 ../gui/wxpython/gmodeler/frame.py:482
+msgid "Create new model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:394
+msgid "Choose model file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:396 ../gui/wxpython/gmodeler/frame.py:440
+#: ../gui/wxpython/lmgr/frame.py:505
+msgid "GRASS Model File (*.gxm)|*.gxm"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:412
+#, python-format
+msgid "%(items)d items (%(actions)d actions) loaded into model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:419 ../gui/wxpython/gmodeler/frame.py:456
+#, python-format
+msgid "Model file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:422 ../gui/wxpython/menustrings.py:1918
+msgid "Save model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:429 ../gui/wxpython/gmodeler/frame.py:469
+#, python-format
+msgid "File <%s> saved"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:438
+msgid "Choose file to save current model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:531
+msgid "Model is empty. Nothing to validate."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:535 ../gui/wxpython/gmodeler/model.py:584
+msgid "Validating model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:541
+#, python-format
+msgid ""
+"Model is not valid.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:544
+msgid "Model is valid."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:605 ../gui/wxpython/gmodeler/frame.py:612
+#, python-format
+msgid "Model exported to <%s>"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:743
+#: ../gui/wxpython/gmodeler/frame.py:1366
+#: ../gui/wxpython/gmodeler/dialogs.py:202
+msgid "Comment:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:743 ../gui/wxpython/menustrings.py:1943
+msgid "Add comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:748
+msgid "Empty comment. Nothing to add to the model."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:780
+msgid "wxGUI Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:875
+#, python-format
+msgid ""
+"Reading model file <%s> failed.\n"
+"Invalid file, unable to parse XML document.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:884
+msgid "Please wait, loading model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:950
+msgid "Writing current settings to model file failed."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:960 ../gui/wxpython/lmgr/frame.py:1452
+#, python-format
+msgid "Unable to open file <%s> for writing."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1292
+#: ../gui/wxpython/animation/dialogs.py:629
+#: ../gui/wxpython/animation/dialogs.py:820
+#: ../gui/wxpython/rlisetup/frame.py:130 ../gui/wxpython/lmgr/layertree.py:419
+#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1810
+#: ../gui/wxpython/gui_core/simplelmgr.py:438
+msgid "Remove"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1296
+msgid "Disable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1299
+msgid "Enable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1304
+#: ../gui/wxpython/gmodeler/frame.py:1354
+msgid "Set label"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1307
+msgid "Set comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1312
+msgid "Add control point"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1314
+msgid "Remove control point"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1321
+msgid "Intermediate"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1332
+#: ../gui/wxpython/lmgr/layertree.py:447
+msgid "Properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:198
+msgid "Label:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1438
+msgid "List of variables - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1441
+#: ../gui/wxpython/gmodeler/frame.py:1485
+#: ../gui/wxpython/gui_core/ghelp.py:343 ../gui/wxpython/gui_core/ghelp.py:345
+#: ../gui/wxpython/gui_core/ghelp.py:408
+#: ../gui/wxpython/web_services/widgets.py:857
+msgid "Name"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1492 ../gui/wxpython/dbmgr/base.py:2588
+msgid "Data type"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1442
+#: ../gui/wxpython/gmodeler/frame.py:1498
+msgid "Default value"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1505
+#: ../gui/wxpython/location_wizard/wizard.py:353
+#: ../gui/wxpython/location_wizard/wizard.py:854
+#: ../gui/wxpython/location_wizard/wizard.py:1026
+#: ../gui/wxpython/location_wizard/wizard.py:1337
+msgid "Description"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1447
+msgid "Add new variable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1451
+msgid "integer"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1452
+msgid "float"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1453
+msgid "string"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1456
+msgid "region"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1457
+msgid "mapset"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1458
+#: ../gui/wxpython/gui_core/forms.py:1524
+msgid "file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1465
+msgid "Add new variable to the model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1585
+msgid "List of items - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1588
+#: ../gui/wxpython/gmodeler/dialogs.py:436
+#: ../gui/wxpython/gmodeler/dialogs.py:539
+#: ../gui/wxpython/psmap/dialogs.py:2618
+msgid "Label"
+msgstr ""
+msgid "In loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1589
+#: ../gui/wxpython/gmodeler/preferences.py:85
+#: ../gui/wxpython/gmodeler/dialogs.py:160
+#: ../gui/wxpython/gmodeler/dialogs.py:437
+#: ../gui/wxpython/gmodeler/dialogs.py:540
+msgid "Command"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1637
+msgid "No items to selected."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1671
+msgid "Python script"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1674
+#: ../gui/wxpython/gmodeler/model.py:2536 ../gui/wxpython/gui_core/menu.py:158
+#: ../gui/wxpython/gui_core/forms.py:515
+#: ../gui/wxpython/modules/mcalc_builder.py:136
+#: ../gui/wxpython/modules/vkrige.py:151 ../gui/wxpython/modules/vclean.py:158
+msgid "&Run"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1675
+msgid "Run python script"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1678
+msgid "Save python script to file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1681
+msgid ""
+"Refresh python script based on the model.\n"
+"It will discards all local changes."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1719
+#, python-format
+msgid "Unable to launch Python script. %s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1743
+msgid "Choose file to save"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1746
+msgid "Python script (*.py)|*.py"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1760
+#: ../gui/wxpython/wxplot/profile.py:352
+#, python-format
+msgid "File <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1762
+msgid "Save file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1797
+msgid ""
+"Python script is locally modificated. Refresh will discard all changes. Do "
+"you really want to continue?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1800
+msgid "Update"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:29
+#: ../gui/wxpython/menustrings.py:1931
+msgid "Modeler settings"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:52
+msgid "Item properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:59
+msgid "Disabled:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:97
+#: ../gui/wxpython/gmodeler/preferences.py:335
+#: ../gui/wxpython/gmodeler/preferences.py:420
+msgid "Valid:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:114
+msgid "Invalid:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:131
+msgid "Running:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:152
+#: ../gui/wxpython/gmodeler/preferences.py:271
+#: ../gui/wxpython/gmodeler/preferences.py:356
+#: ../gui/wxpython/gmodeler/preferences.py:441
+msgid "Shape size"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:159
+#: ../gui/wxpython/gmodeler/preferences.py:278
+#: ../gui/wxpython/gmodeler/preferences.py:363
+#: ../gui/wxpython/gmodeler/preferences.py:448
+#: ../gui/wxpython/psmap/dialogs.py:2723
+#: ../gui/wxpython/gui_core/dialogs.py:2423
+#: ../gui/wxpython/nviz/preferences.py:476
+msgid "Width:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:177
+#: ../gui/wxpython/gmodeler/preferences.py:296
+#: ../gui/wxpython/gmodeler/preferences.py:381
+#: ../gui/wxpython/gmodeler/preferences.py:466
+#: ../gui/wxpython/psmap/dialogs.py:2735 ../gui/wxpython/psmap/dialogs.py:2873
+#: ../gui/wxpython/psmap/dialogs.py:3476
+#: ../gui/wxpython/gui_core/dialogs.py:2427 ../gui/wxpython/nviz/tools.py:284
+#: ../gui/wxpython/nviz/tools.py:1043 ../gui/wxpython/nviz/tools.py:1770
+msgid "Height:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:204
+#: ../gui/wxpython/nviz/tools.py:92
+msgid "Data"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:209
+#: ../gui/wxpython/dbmgr/base.py:2111 ../gui/wxpython/dbmgr/dialogs.py:759
+#: ../gui/wxpython/web_services/widgets.py:858
+msgid "Type"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:216
+msgid "Raster:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:233
+msgid "3D raster:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:250
+msgid "Vector:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:323
+msgid "Loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:408
+msgid "Comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:508
+#: ../gui/wxpython/menustrings.py:1947
+msgid "Model properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:515
+#: ../gui/wxpython/lmgr/layertree.py:570 ../gui/wxpython/lmgr/layertree.py:628
+#: ../gui/wxpython/lmgr/layertree.py:644
+msgid "Metadata"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:517
+msgid "Commands"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:529
+#: ../gui/wxpython/gui_core/preferences.py:816
+#: ../gui/wxpython/gui_core/dialogs.py:1676
+#: ../gui/wxpython/modules/mcalc_builder.py:232
+#: ../gui/wxpython/modules/vkrige.py:137 ../gui/wxpython/modules/vclean.py:137
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:537
+msgid "Apply properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:549
+#: ../gui/wxpython/animation/dialogs.py:331
+#: ../gui/wxpython/vnet/dialogs.py:1479
+#: ../gui/wxpython/gui_core/widgets.py:1081
+#: ../gui/wxpython/gui_core/gselect.py:1439
+#: ../gui/wxpython/gui_core/gselect.py:1449
+#: ../gui/wxpython/gui_core/gselect.py:1450
+msgid "Name:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:558
+msgid "Description:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:567
+msgid "Author(s):"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:63
+msgid "model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:64
+msgid "Script generated by wxGUI Graphical Modeler."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:461 ../gui/wxpython/gmodeler/model.py:523
+#, python-format
+msgid "undefined variable '%s'"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:556
+msgid "Running model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:575
+msgid "Model is empty. Nothing to run."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:590
+#, python-format
+msgid ""
+"Model is not valid. Do you want to run the model anyway?\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:592
+msgid "Run model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:627
+msgid "Variables below not defined:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:737
+msgid "Raster maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:740
+msgid "3D raster maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:743 ../gui/wxpython/psmap/dialogs.py:1271
+msgid "Vector maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1056
+#: ../gui/wxpython/gmodeler/model.py:1153
+#: ../gui/wxpython/gui_core/ghelp.py:212 ../gui/wxpython/core/gconsole.py:617
+msgid "unknown"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1398
+msgid "<not defined>"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1507
+msgid "Condition: "
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1509
+msgid "Condition: not defined"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1628
+msgid "if-else"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2511
+msgid "Model parameters"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2528
+msgid "Delete intermediate data when finish"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:47
+msgid "Data properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:81
+#: ../gui/wxpython/gmodeler/dialogs.py:94
+msgid "Name of element:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:89
+msgid "Type of element:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:141
+msgid "Add GRASS command to the model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:162
+msgid "Label and comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:254
+msgid ""
+"Command not defined.\n"
+"\n"
+"Unable to add new action to the model."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:260
+#, python-format
+msgid ""
+"'%s' is not a GRASS module.\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:292
+msgid "Relation properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:309
+msgid "From"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:311 ../gui/wxpython/dbmgr/base.py:2159
+msgid "To"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:353
+#, python-format
+msgid "Data: %s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:359
+msgid "Command:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:365
+msgid "Option:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:380
+msgid ""
+"Relation doesn't start with data item.\n"
+"Unable to add relation."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:387
+msgid ""
+"Relation doesn't point to GRASS command.\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:400
+msgid ""
+"No relevant option found.\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:431
+msgid "Condition"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:457
+msgid "Loop properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:463
+msgid "List of items in loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:466
+msgid "Series"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:467
+msgid "Define map series as condition for the loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:511
+msgid "Define series of maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:526
+msgid "If-else properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:532
+msgid "List of items in 'if' block"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:537
+msgid "List of items in 'else' block"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:700
+#, python-format
+msgid "Variable <%s> already exists in the model. Adding variable failed."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:729
+msgid "Do you want to delete all variables from the model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:731
+msgid "Delete variables"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:836
+#: ../gui/wxpython/gui_core/gselect.py:1930
+#: ../gui/wxpython/location_wizard/wizard.py:778
+msgid "No"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:838
+#: ../gui/wxpython/gui_core/gselect.py:1932
+msgid "Yes"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:133
+#, python-format
+msgid ""
+"Unable to open file\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:467
+#, python-format
+msgid "Instruction file will be loaded with following region: %s\n"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:472
+#, python-format
+msgid ""
+"Region cannot be set\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:611
+#: ../gui/wxpython/psmap/instructions.py:761
+#: ../gui/wxpython/psmap/instructions.py:877
+#: ../gui/wxpython/psmap/instructions.py:935
+#: ../gui/wxpython/psmap/instructions.py:1076
+#: ../gui/wxpython/psmap/instructions.py:1131
+#: ../gui/wxpython/psmap/instructions.py:1190
+#: ../gui/wxpython/psmap/instructions.py:1259
+#: ../gui/wxpython/psmap/instructions.py:1365
+#: ../gui/wxpython/psmap/instructions.py:1490
+#: ../gui/wxpython/psmap/instructions.py:1541
+#: ../gui/wxpython/psmap/instructions.py:1850
+#, python-format
+msgid "Failed to read instruction %s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:625
+#, python-format
+msgid ""
+"Scale has changed, old value: %(old)s\n"
+"new value: %(new)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:628
+#, python-format
+msgid ""
+"Failed to read instruction %s.\n"
+"Use 1:25000 notation."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:636
+#, python-format
+msgid ""
+"Map frame position changed, old value: %(old1)s %(old2)s\n"
+"new value: %(new1)s %(new2)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:644
+#, python-format
+msgid ""
+"Map frame size changed, old value: %(old1)s %(old2)s\n"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:691
+#, python-format
+msgid ""
+"Failed to read instruction %(file)s.\n"
+"Unknown format %(for)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:704
+#, python-format
+msgid "Failed to read instruction %s."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:818
+#: ../gui/wxpython/psmap/instructions.py:1700
+#, python-format
+msgid ""
+"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
+"which is required by module ps.map."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:822
+#: ../gui/wxpython/psmap/instructions.py:1704
+msgid ""
+"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
+"required by module ps.map."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:938
+#, python-format
+msgid "Failed to read instruction %(inst)s: file %(file)s not found."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:51
+msgid "GRASS GIS Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:186
+msgid ""
+"Python Imaging Library is not available.\n"
+"'Preview' functionality won't work."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:238
+msgid "Program ps2pdf is not available. Please install it first to create PDF."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:282
+msgid "Generating PDF..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:284
+msgid "Generating PostScript..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:286
+msgid "Generating preview..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:296
+#, python-format
+msgid "Ps.map exited with return code %s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:326
+#, python-format
+msgid "%(prg)s exited with return code %(code)s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:329
+msgid "PDF generated"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:332
+#, python-format
+msgid ""
+"Program ps2pdf is not available. Please install it to create PDF.\n"
+"\n"
+" %s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:335
+msgid "PostScript file generated"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:341
+msgid "Generating preview, wait please"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:355
+msgid "Preview not available"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:356
+msgid ""
+"Preview is not available probably because Ghostscript is not installed or "
+"not on PATH."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:358
+msgid "Please follow instructions on GRASS Trac Wiki."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:369
+msgid "Preview generated"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:399
+msgid "Save file as"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:441
+#, python-format
+msgid "Failed to read file %s."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:569 ../gui/wxpython/psmap/frame.py:592
+#: ../gui/wxpython/psmap/dialogs.py:1211
+msgid "Please, create map frame first."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:608
+msgid "Scalebar is not appropriate for this projection"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1028
+msgid "Press button with green triangle icon to generate preview."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1052
+msgid "wxGUI Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1103
+msgid "MAP FRAME"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1104
+msgid "RASTER LEGEND"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1105
+msgid "VECTOR LEGEND"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1106
+msgid "MAP INFO"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1107
+msgid "SCALE BAR"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1108
+msgid "IMAGE"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1109
+msgid "NORTH ARROW"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1351
+msgid "Click and drag to resize object"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:2171
+msgid "labels: "
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:93
+msgid "inch"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:94 ../gui/wxpython/modules/vclean.py:196
+msgid "point"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:95
+msgid "centimeter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:96
+msgid "millimeter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:97
+msgid "meters"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:98
+msgid "kilometers"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:99
+msgid "feet"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:100
+msgid "miles"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:101 ../gui/wxpython/psmap/utils.py:105
+msgid "nautical miles"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:103
+msgid "pixel"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:104
+msgid "meter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:106
+msgid "degree"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:351
+msgid "Unable to run `ps.map -b`"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:198
+msgid "Units:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:207
+msgid ""
+"Position of the top left corner\n"
+"from the top left edge of the paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:208
+#: ../gui/wxpython/animation/dialogs.py:887
+msgid "X:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:209
+#: ../gui/wxpython/animation/dialogs.py:889
+msgid "Y:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:221
+msgid "Position is given:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:222
+msgid "relative to paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:223
+msgid "by map coordinates"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:237
+msgid ""
+"Position from the top left\n"
+"edge of the paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:292 ../gui/wxpython/psmap/dialogs.py:3555
+#: ../gui/wxpython/gui_core/preferences.py:1591
+msgid "Font size:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:305
+msgid "Choose color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:353
+msgid "Close dialog and apply changes"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:384
+msgid "Units"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:759
+msgid "Format"
+msgstr ""
+msgid "Orientation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:384 ../gui/wxpython/psmap/dialogs.py:2085
+msgid "Width"
+msgstr ""
+msgid "Height"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:385
+msgid "Left"
+msgstr ""
+msgid "Right"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:232
+msgid "Top"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:240
+msgid "Bottom"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:440
+msgid "Literal is not allowed!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:440 ../gui/wxpython/psmap/dialogs.py:1035
+#: ../gui/wxpython/psmap/dialogs.py:1057 ../gui/wxpython/psmap/dialogs.py:1107
+#: ../gui/wxpython/psmap/dialogs.py:3637
+#: ../gui/wxpython/animation/controller.py:277
+#: ../gui/wxpython/animation/dialogs.py:599
+#: ../gui/wxpython/wxplot/dialogs.py:495
+msgid "Invalid input"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:449
+msgid "Page size"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:451
+msgid "Margins"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:455
+msgid "Portrait"
+msgstr ""
+msgid "Landscape"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:507 ../gui/wxpython/psmap/dialogs.py:528
+#: ../gui/wxpython/location_wizard/wizard.py:1782
+msgid "custom"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:557
+msgid "Map settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:563
+msgid "Map frame settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:619 ../gui/wxpython/psmap/dialogs.py:674
+#: ../gui/wxpython/psmap/toolbars.py:79 ../gui/wxpython/menustrings.py:1978
+msgid "Map frame"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:680
+msgid "Map frame options:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:681
+msgid "fit frame to match selected map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:682
+msgid "fit frame to match saved region"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:683
+msgid "fit frame to match current computational region"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:684
+msgid "fixed scale and map center"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:692 ../gui/wxpython/psmap/dialogs.py:860
+msgid "Map selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:700 ../gui/wxpython/psmap/dialogs.py:1284
+msgid "Map:"
+msgstr ""
+msgid "Region:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:719
+msgid "Map scale and center"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:724
+msgid "Center:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:725
+msgid "E:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:726
+msgid "N:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:729 ../gui/wxpython/psmap/dialogs.py:4166
+msgid "Scale:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:730
+msgid "1 :"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:750
+msgid "Map max resolution (dpi):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:763 ../gui/wxpython/psmap/dialogs.py:2654
+msgid "Border"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:767
+msgid "draw border around map frame"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:773
+msgid "border color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:774
+msgid "border width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:868
+msgid ""
+"Region is set to match this map,\n"
+"raster or vector map must be added later"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:875
+msgid "Region selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1034
+msgid "No map selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1056
+msgid "No region selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1106
+msgid "Invalid scale or map center!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1144 ../gui/wxpython/lmgr/layertree.py:800
+#: ../gui/wxpython/menustrings.py:1980 ../gui/wxpython/nviz/mapwindow.py:1676
+#: ../gui/wxpython/nviz/tools.py:652
+msgid "Raster map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1166
+msgid "Choose raster map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1170
+msgid "no raster map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1171
+msgid "raster:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1280
+msgid "Add map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1288 ../gui/wxpython/psmap/dialogs.py:1652
+msgid "points"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1288 ../gui/wxpython/psmap/dialogs.py:1654
+msgid "lines"
+msgstr ""
+msgid "areas"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1290
+msgid "Data Type"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1293 ../gui/wxpython/dbmgr/base.py:2130
+#: ../gui/wxpython/animation/dialogs.py:625
+msgid "Add"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1305
+msgid "Manage vector maps"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1311
+msgid "The topmost vector map overlaps the others"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1313 ../gui/wxpython/psmap/dialogs.py:2635
+#: ../gui/wxpython/web_services/widgets.py:225
+msgid "Up"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1314 ../gui/wxpython/psmap/dialogs.py:2636
+#: ../gui/wxpython/web_services/widgets.py:226
+msgid "Down"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1315 ../gui/wxpython/menustrings.py:166
+#: ../gui/wxpython/menustrings.py:1143 ../gui/wxpython/menustrings.py:1996
+#: ../gui/wxpython/nviz/tools.py:1101 ../gui/wxpython/nviz/tools.py:1979
+#: ../gui/wxpython/nviz/tools.py:2027
+msgid "Delete"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1316
+msgid "Properties..."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1518
+msgid "Raster map settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1555
+msgid "Vector maps settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1590
+#, python-format
+msgid "%s properties"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1641
+msgid "Data selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1648
+#: ../gui/wxpython/gui_core/dialogs.py:1633
+msgid "Feature type"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1652
+msgid "centroids"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1654
+msgid "boundaries"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1670
+msgid "Layer selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1676
+msgid "Database connection is not defined in DB file."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1677
+msgid "Select layer:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1700
+msgid "list of categories (e.g. 1,3,5-7)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1727 ../gui/wxpython/menustrings.py:316
+#: ../gui/wxpython/menustrings.py:1215 ../gui/wxpython/nviz/tools.py:789
+#: ../gui/wxpython/nviz/tools.py:2403
+msgid "Mask"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1730
+msgid "Use current mask"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1747 ../gui/wxpython/psmap/dialogs.py:1846
+msgid "Colors"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1752 ../gui/wxpython/psmap/dialogs.py:1851
+msgid "Outline"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1756 ../gui/wxpython/psmap/dialogs.py:1860
+msgid "draw outline"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1759 ../gui/wxpython/psmap/dialogs.py:1864
+#: ../gui/wxpython/psmap/dialogs.py:3750 ../gui/wxpython/psmap/dialogs.py:3755
+msgid "Width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1796 ../gui/wxpython/psmap/dialogs.py:1900
+#: ../gui/wxpython/wxplot/dialogs.py:932 ../gui/wxpython/wxplot/dialogs.py:982
+msgid "Fill"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1800
+msgid "fill color"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1803 ../gui/wxpython/psmap/dialogs.py:1906
+msgid "choose color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1815 ../gui/wxpython/psmap/dialogs.py:1919
+msgid "color from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1862
+msgid "No effect for fill color from table column"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1904
+msgid "Color of lines:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1949 ../gui/wxpython/psmap/dialogs.py:2080
+#: ../gui/wxpython/psmap/dialogs.py:2149
+msgid "Size and style"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1958 ../gui/wxpython/nviz/tools.py:1422
+msgid "symbol:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1967
+msgid "eps file:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
+#: ../gui/wxpython/psmap/dialogs.py:4121
+#: ../gui/wxpython/animation/dialogs.py:398
+#: ../gui/wxpython/animation/dialogs.py:858
+#: ../gui/wxpython/animation/dialogs.py:929
+#: ../gui/wxpython/animation/dialogs.py:952
+#: ../gui/wxpython/animation/dialogs.py:969
+#: ../gui/wxpython/animation/dialogs.py:992
+#: ../gui/wxpython/gui_core/forms.py:1525
+#: ../gui/wxpython/gui_core/forms.py:1589
+#: ../gui/wxpython/gui_core/dialogs.py:2091
+#: ../gui/wxpython/gui_core/gselect.py:1077
+#: ../gui/wxpython/gui_core/gselect.py:1389
+#: ../gui/wxpython/gui_core/gselect.py:1402
+#: ../gui/wxpython/gui_core/gselect.py:1441
+#: ../gui/wxpython/gui_core/gselect.py:1464
+#: ../gui/wxpython/location_wizard/wizard.py:104
+#: ../gui/wxpython/location_wizard/wizard.py:1170
+#: ../gui/wxpython/location_wizard/wizard.py:1244
+#: ../gui/wxpython/location_wizard/wizard.py:1330
+#: ../gui/wxpython/nviz/tools.py:483
+msgid "Browse"
+msgstr ""
+msgid "Type filename or click browse to choose file"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
+msgid "Choose a file"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1996 ../gui/wxpython/psmap/dialogs.py:2707
+#: ../gui/wxpython/psmap/dialogs.py:3471 ../gui/wxpython/wxplot/dialogs.py:923
+#: ../gui/wxpython/wxplot/dialogs.py:973
+msgid "Size"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2000 ../gui/wxpython/nviz/tools.py:1365
+msgid "size:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2002
+msgid "size from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2004
+msgid "scale:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2037
+msgid "Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2042
+msgid "rotate symbols:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2043
+msgid "counterclockwise in degrees:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2045
+msgid "from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2089
+msgid "Set width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2098
+msgid "multiply width by category value"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2115 ../gui/wxpython/psmap/dialogs.py:4897
+#: ../gui/wxpython/wxplot/dialogs.py:888
+msgid "Line style"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2119
+msgid "Choose line style:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2129
+msgid "Choose linecap:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2154
+msgid "Pattern"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2158
+msgid "use pattern:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2159
+msgid "Choose pattern file:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2163
+msgid "pattern line width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2165
+msgid "pattern scale factor:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2482
+msgid "Raster legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2486
+#: ../gui/wxpython/animation/dialogs.py:369
+msgid "Show raster legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2492
+msgid "Source raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2496
+msgid "current raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2497
+msgid "select raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2504 ../gui/wxpython/psmap/dialogs.py:3190
+#, python-format
+msgid "%(rast)s: type %(type)s"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2524
+msgid "Type of legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2528
+msgid "discrete legend (categorical maps)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2530
+msgid "continuous color gradient legend (floating point map)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2541
+msgid "Advanced legend settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2545
+msgid "draw \"no data\" box"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2551
+msgid "draw ticks across color table"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2562
+#: ../gui/wxpython/modules/colorrules.py:878
+#: ../gui/wxpython/modules/colorrules.py:1500
+#: ../gui/wxpython/modules/colorrules.py:1503
+msgid "range"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2599
+msgid "Vector legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2603
+msgid "Show vector legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2609
+msgid "Source vector maps"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2613
+msgid "Choose vector maps and their order in legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/lmgr/layertree.py:804
+#: ../gui/wxpython/menustrings.py:1982 ../gui/wxpython/nviz/tools.py:1180
+msgid "Vector map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2637 ../gui/wxpython/psmap/dialogs.py:2945
+msgid "Edit label"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2658
+msgid "draw border around legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2695
+msgid "Size and position"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2705 ../gui/wxpython/psmap/dialogs.py:3246
+#: ../gui/wxpython/psmap/dialogs.py:3441 ../gui/wxpython/psmap/dialogs.py:3815
+#: ../gui/wxpython/psmap/dialogs.py:3819 ../gui/wxpython/psmap/dialogs.py:4221
+#: ../gui/wxpython/psmap/dialogs.py:4226 ../gui/wxpython/psmap/dialogs.py:4679
+#: ../gui/wxpython/psmap/dialogs.py:4684 ../gui/wxpython/nviz/tools.py:860
+#: ../gui/wxpython/nviz/tools.py:1679
+msgid "Position"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2729
+msgid "Leave the edit field empty, to use default values."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2751
+msgid ""
+"Width of the color symbol (for lines)\n"
+"in front of the legend text"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2757 ../gui/wxpython/psmap/dialogs.py:2862
+msgid "Columns:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2761
+msgid "column span:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2763
+msgid ""
+"Column separation distance between the left edges\n"
+"of two columns in a multicolumn legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2788 ../gui/wxpython/psmap/dialogs.py:3265
+#: ../gui/wxpython/psmap/dialogs.py:3721 ../gui/wxpython/wxplot/dialogs.py:619
+#: ../gui/wxpython/gui_core/preferences.py:376
+#: ../gui/wxpython/gui_core/preferences.py:574
+#: ../gui/wxpython/gui_core/preferences.py:1543
+msgid "Font settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2945
+msgid "Edit legend label:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2986
+msgid "No raster map selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2987
+msgid "No raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3221
+msgid "Mapinfo settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3283
+msgid "Color settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3288
+msgid "use border color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3289
+msgid "use background color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3430
+msgid ""
+"Units of current projection are not supported,\n"
+" meters will be used!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3431
+msgid "Unsupported units"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3475
+msgid "Length:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3479
+msgid "Scalebar length is given in map units"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3482
+msgid "Scalebar height is real height on paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3484
+msgid "default"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3524 ../gui/wxpython/wxplot/dialogs.py:947
+#: ../gui/wxpython/wxplot/dialogs.py:997
+msgid "Style"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3529
+msgid "Type:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3545
+msgid "Number of segments:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3549
+msgid "Label every "
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3550
+msgid "segments"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3559
+msgid "transparent text background"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3636
+msgid "Length of scale bar is not defined"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3705 ../gui/wxpython/psmap/dialogs.py:3710
+#: ../gui/wxpython/psmap/toolbars.py:88
+#: ../gui/wxpython/animation/dialogs.py:1194
+#: ../gui/wxpython/menustrings.py:1990
+msgid "Text"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3713
+msgid "Enter text:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3739
+msgid "Text effects"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3744
+msgid "text background"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3747
+msgid "highlight"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3752
+msgid "text border"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3827
+msgid "Offset"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3830
+msgid "horizontal (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3831
+msgid "vertical (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3844
+msgid " Reference point"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3872
+msgid "Text rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3875
+msgid "rotate text (counterclockwise)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3951
+msgid "No text entered!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4061 ../gui/wxpython/psmap/dialogs.py:4109
+#: ../gui/wxpython/psmap/toolbars.py:96
+#: ../gui/wxpython/menustrings.py:1992
+msgid "Image"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4119 ../gui/wxpython/nviz/tools.py:481
+msgid "Choose a directory:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4120
+msgid "Choose a directory with images"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4152
+msgid "Note: only EPS format supported"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4161
+msgid "Scale And Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4654
+msgid "Rotation angle (deg):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4663
+msgid "Counterclockwise rotation in degrees"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4299
+msgid ""
+"PIL\n"
+"missing"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4319
+#, python-format
+msgid "Unable to read file %s"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4378
+#, python-format
+msgid "size: %(width)s x %(height)s pts"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4400
+msgid "No image selected."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4494 ../gui/wxpython/psmap/toolbars.py:98
+#: ../gui/wxpython/menustrings.py:1994 ../gui/wxpython/nviz/tools.py:1949
+msgid "North Arrow"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4497
+msgid "North Arrow settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4508
+msgid "Compute convergence"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4564
+msgid "Symbol"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4569
+msgid "Select symbol:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4583
+msgid ""
+"Note: Selected symbol is not displayed\n"
+"in draft mode (only in preview mode)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4602 ../gui/wxpython/psmap/dialogs.py:4856
+msgid "Outline color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4604 ../gui/wxpython/psmap/dialogs.py:4619
+#: ../gui/wxpython/psmap/dialogs.py:4858 ../gui/wxpython/psmap/dialogs.py:4879
+#: ../gui/wxpython/gui_core/dialogs.py:2276
+msgid "transparent"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4617 ../gui/wxpython/psmap/dialogs.py:4877
+msgid "Fill color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4640
+msgid "Size and Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4645
+msgid "Size (pt):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4647
+msgid "Symbol size in points"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4821
+msgid "Rectangle settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4823
+msgid "Line settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4909
+msgid "Line width in points"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4977
+msgid "Vector labels"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4996
+msgid "Vector label files created beforehand by v.label module"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:5004
+msgid "You can select multiple label files."
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:65 ../gui/wxpython/menustrings.py:1968
+msgid "Generate text file with mapping instructions"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:67 ../gui/wxpython/menustrings.py:1966
+msgid "Load text file with mapping instructions"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:69 ../gui/wxpython/menustrings.py:1970
+msgid "Generate PostScript output"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:71 ../gui/wxpython/menustrings.py:1972
+msgid "Generate PDF output"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:74 ../gui/wxpython/menustrings.py:1964
+msgid "Specify paper size, margins and orientation"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:76
+msgid "Full extent"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:77
+msgid "Zoom to full extent"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:80
+msgid "Click and drag to place map frame"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:82 ../gui/wxpython/menustrings.py:1997
+msgid "Delete selected object"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:84
+msgid "Show preview"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:86
+msgid "Quit Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:90 ../gui/wxpython/menustrings.py:1986
+msgid "Map info"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:92 ../gui/wxpython/wxplot/dialogs.py:897
+#: ../gui/wxpython/wxplot/dialogs.py:940 ../gui/wxpython/wxplot/dialogs.py:990
+msgid "Legend"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:94 ../gui/wxpython/menustrings.py:1988
+#: ../gui/wxpython/nviz/tools.py:1994
+msgid "Scale bar"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:104
+#: ../gui/wxpython/rlisetup/wizard.py:1105
+#: ../gui/wxpython/rlisetup/wizard.py:1267
+#: ../gui/wxpython/rlisetup/wizard.py:1356
+msgid "Rectangle"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:106
+msgid "Add overlays"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:108 ../gui/wxpython/lmgr/layertree.py:102
+msgid "Add labels"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:196
+msgid "Add simple graphics: points"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:208
+msgid "Add simple graphics: lines"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:220
+msgid "Add simple graphics: rectangles"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:70
+msgid "GRASS GIS Attribute Table Manager - "
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:72
+msgid "READONLY - "
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:85
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:90
+msgid "Please wait, loading attribute data..."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:99
+msgid "Browse data"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:105
+msgid "Manage tables"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:110
+msgid "Manage layers"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:121
+msgid "Close Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:123
+msgid "Reload currently selected attribute data"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:125
+msgid "Reload all attribute data (drop current selection)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:198 ../gui/wxpython/dbmgr/base.py:291
+#: ../gui/wxpython/dbmgr/base.py:837 ../gui/wxpython/dbmgr/base.py:996
+#: ../gui/wxpython/dbmgr/base.py:1300 ../gui/wxpython/dbmgr/base.py:1897
+#, python-format
+msgid "Number of loaded records: %d"
+msgstr ""
+#: ../gui/wxpython/dbmgr/vinfo.py:101
+#, python-brace-format
+msgid ""
+"Failed to query vector map <{map}>. Check database settings and topology."
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:93 ../gui/wxpython/dbmgr/base.py:2065
+msgid "Database connection"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:105 ../gui/wxpython/menustrings.py:877
+#: ../gui/wxpython/menustrings.py:1776
+msgid "Query"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:121
+msgid "Set SQL statement to default"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:123
+msgid "Apply SQL statement in Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:125
+msgid "Close the dialog"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:176
+msgid "Columns"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:187
+msgid "Interactive insertion"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:201
+msgid "Values"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:211
+msgid "Get all values"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:214
+msgid "Get sample"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:215
+msgid "Get first 256 unique values as sample"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:231
+msgid "Go to:"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:244
+msgid "Close dialog on apply"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:401
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:543
+#, python-format
+msgid "GRASS SQL Builder (%(type)s) - <%(map)s>"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:404
+msgid "Column to show (SELECT clause)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:405
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:547
+msgid "Constraint for query (WHERE clause)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:417 ../gui/wxpython/dbmgr/base.py:1104
+#: ../gui/wxpython/dbmgr/base.py:1121
+#, python-format
+msgid "Example: %s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:420
+msgid "Verify"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:421
+msgid "Verify SQL statement"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:429
+msgid "SQL statement not verified"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:473
+msgid "SQL statement is not valid"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:475
+#, python-format
+msgid ""
+"SQL statement is not valid.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:477
+msgid "SQL statement is valid"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:546
+msgid "Column to set (SET clause)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:548
+msgid "Calculate column value to set"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:603
+msgid "Functions"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:636
+msgid "SQL statement was not applied"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:638
+msgid "SQL statement applied"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:671
+msgid "Dbf driver does not support usage of SQL functions."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:147 ../gui/wxpython/iscatt/controllers.py:138
+msgid "Loading data..."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:154
+#, python-format
+msgid ""
+"Attribute table <%s> not found. For creating the table switch to 'Manage "
+"layers' tab."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:165
+#, python-format
+msgid "Column <%(column)s> not found in in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:238
+msgid "Can display only 256 columns."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:256
+#, python-format
+msgid "Inconsistent number of columns in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:266
+msgid "Viewing limit: 100000 records."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:315
+msgid "Unknown value"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:321
+msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:330
+#, python-format
+msgid ""
+"Error loading attribute data. Record number: %(rec)d. Unable to convert "
+"value '%(val)s' in key column (%(key)s) to integer.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:422
+msgid "Sort ascending"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:423
+msgid "Sort descending"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:426
+msgid "Calculate (only numeric columns)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:428
+msgid "Field calculator"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:430 ../gui/wxpython/wxplot/dialogs.py:241
+msgid "Statistics"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:435 ../gui/wxpython/dbmgr/base.py:2088
+#: ../gui/wxpython/modules/colorrules.py:1023
+msgid "Add column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:446
+msgid "Area size"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:447
+msgid "Line length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:448
+msgid "Compactness of an area"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:449
+msgid "Fractal dimension of boundary defining a polygon"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:450
+msgid "Perimeter length of an area"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:451
+msgid "Number of features for each category"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:452
+msgid "Slope steepness of 3D line"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:453
+msgid "Line sinuousity"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:454
+msgid "Line azimuth"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:564
+#, python-format
+msgid "Add column to table <%s>"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:937
+msgid "Unable to add column to the table. No column name defined."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:950
+#, python-format
+msgid "Column <%(column)s> already exists in table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1026
+msgid "Attribute data - right-click to edit/manage records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1041 ../gui/wxpython/dbmgr/base.py:2049
+#: ../gui/wxpython/dbmgr/base.py:2642 ../gui/wxpython/dbmgr/base.py:2773
+#: ../gui/wxpython/dbmgr/base.py:3030
+msgid "Table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1043 ../gui/wxpython/dbmgr/base.py:2051
+msgid " (readonly)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1057
+msgid "SQL Query"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1086
+msgid "Simple"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1089
+msgid "Apply SELECT statement and reload data records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1112
+msgid "Builder"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1114
+msgid "SQL Builder"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1265 ../gui/wxpython/core/settings.py:846
+msgid "Edit selected record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1269 ../gui/wxpython/dbmgr/base.py:1444
+msgid "Insert new record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1270
+msgid "Delete selected record(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1271
+msgid "Delete all records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1277 ../gui/wxpython/gui_core/widgets.py:817
+#: ../gui/wxpython/gui_core/dialogs.py:684
+#: ../gui/wxpython/gui_core/dialogs.py:737
+#: ../gui/wxpython/gui_core/dialogs.py:1444
+msgid "Select all"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1278 ../gui/wxpython/gui_core/widgets.py:818
+#: ../gui/wxpython/gui_core/dialogs.py:1446
+msgid "Deselect all"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1280
+#: ../gui/wxpython/gui_core/preferences.py:1061
+msgid "Highlight selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1281
+msgid "Highlight selected features and zoom"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1285 ../gui/wxpython/dbmgr/base.py:1765
+msgid "Extract selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1286
+msgid "Delete selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1347
+msgid "Update existing record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1373 ../gui/wxpython/dbmgr/base.py:1477
+#, python-format
+msgid "Value '%(value)s' needs to be entered as %(type)s."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1387
+#, python-format
+msgid ""
+"Unable to update existing record.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1455
+#, python-format
+msgid "Record with category number %d already exists in the table."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1465
+#, python-format
+msgid "Category number (column %s) is missing."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1489
+#, python-format
+msgid ""
+"Unable to insert new record.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1540
+#, python-format
+msgid ""
+"Selected data records (%d) will be permanently deleted from table. Do you "
+"want to delete them?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1543 ../gui/wxpython/dbmgr/base.py:1589
+msgid "Delete records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1586
+#, python-format
+msgid ""
+"All data records (%d) will be permanently deleted from table. Do you want to "
+"delete them?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1761
+msgid "Nothing to extract."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1794
+msgid "Nothing to delete."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1857 ../gui/wxpython/dbmgr/base.py:1882
+#, python-format
+msgid ""
+"Loading attribute data failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1870
+#, python-format
+msgid ""
+"Invalid SQL select statement.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2077
+#, python-format
+msgid "Table <%s> - right-click to delete column(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2096 ../gui/wxpython/dbmgr/base.py:2147
+#: ../gui/wxpython/dbmgr/dialogs.py:752
+msgid "Column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2123 ../gui/wxpython/dbmgr/dialogs.py:766
+msgid "Length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2139 ../gui/wxpython/menustrings.py:895
+#: ../gui/wxpython/menustrings.py:1794
+msgid "Rename column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2259
+msgid "Unable to rename column. No column name defined."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2267
+#, python-format
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2283
+#, python-format
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
+"%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2310
+msgid "Drop selected column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2313
+msgid "Drop all columns"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2342
+#, python-format
+msgid ""
+"Selected %s will PERMANENTLY removed from table. Do you want to drop the "
+"column?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2345 ../gui/wxpython/dbmgr/base.py:2382
+msgid "Drop column(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2379
+#, python-format
+msgid ""
+"Selected columns\n"
+"%s\n"
+"will PERMANENTLY removed from table. Do you want to drop the columns?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2467
+msgid "List of layers"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2547 ../gui/wxpython/dbmgr/base.py:2953
+#: ../gui/wxpython/dbmgr/base.py:3373
+#, python-format
+msgid "Drop also linked attribute table (%s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2588
+msgid "Column name"
+msgstr ""
+msgid "Data length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2642 ../gui/wxpython/dbmgr/base.py:2762
+#: ../gui/wxpython/dbmgr/base.py:3018
+msgid "Driver"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2642 ../gui/wxpython/dbmgr/base.py:2767
+#: ../gui/wxpython/dbmgr/base.py:3024 ../gui/wxpython/gui_core/gselect.py:1324
+msgid "Database"
+msgstr ""
+msgid "Key"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2738
+msgid "Add layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2748
+msgid "Layer description"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2778 ../gui/wxpython/dbmgr/base.py:2816
+#: ../gui/wxpython/dbmgr/base.py:3036
+msgid "Key column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2783
+msgid "Insert record for each category into table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2798
+msgid "You need to add categories by v.category module."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2803
+msgid "Table description"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2811
+msgid "Table name"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2824
+msgid "&Create table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2828
+#: ../gui/wxpython/web_services/dialogs.py:487
+msgid "&Add layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2832
+msgid "&Set default"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2936
+msgid "Remove layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2939
+msgid "Layer to remove"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2960
+msgid "&Remove layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3003
+msgid "Modify layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3075
+msgid "&Modify layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3123
+msgid ""
+"Unable to get list of tables.\n"
+"Please use db.connect to set database parameters."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3220
+msgid "Unable to create new table. Table name or key column name is missing."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3226
+#, python-format
+msgid "Unable to create new table. Table <%s> already exists in the database."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3264
+#, python-format
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3428
+msgid "Field statistics"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3440
+msgid "Copy statistics the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3503
+msgid "Statistics is not support for DBF tables."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3526
+msgid "Unable to calculte statistics."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3533
+#, python-format
+msgid ""
+"Unable to calculte statistics. Invalid number of lines %d (should be %d)."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3551
+msgid "Unable to calculte standard deviation."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3557
+#, python-format
+msgid "Field statistics <%s>"
+msgstr ""
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:47
+#, python-format
+msgid "Loading attribute data for vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:49
+msgid "GRASS GIS Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:74
+#, python-format
+msgid ""
+"No attribute table found.\n"
+"\n"
+"Do you want to create a new attribute table and defined a link to vector map "
+"<%s>?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:77
+msgid "Create table?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:97
+msgid "Close dialog on submit"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:109
+msgid "No attributes found"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:666
+#: ../gui/wxpython/menustrings.py:1565
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:117
+msgid "Define attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:119
+msgid "Display attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:123
+msgid "&Reload"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:124 ../gui/wxpython/dbmgr/dialogs.py:597
+msgid "&Submit"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:226
+#, python-format
+msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:436
+msgid "Unknown"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:34
+#, python-format
+msgid "Unknown iconset '%s', using default 'grass'...\n"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:51
+#, python-format
+msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
+msgstr ""
+#: ../gui/wxpython/animation/data.py:44 ../gui/wxpython/mapdisp/frame.py:270
+#: ../gui/wxpython/mapdisp/frame.py:329 ../gui/wxpython/mapdisp/frame.py:510
+#: ../gui/wxpython/mapdisp/toolbars.py:82
+#: ../gui/wxpython/lmgr/layertree.py:906
+msgid "2D view"
+msgstr ""
+#: ../gui/wxpython/animation/data.py:45 ../gui/wxpython/mapdisp/toolbars.py:88
+#: ../gui/wxpython/lmgr/frame.py:359
+msgid "3D view"
+msgstr ""
+#: ../gui/wxpython/animation/data.py:65
+msgid "No animation name selected."
+msgstr ""
+#: ../gui/wxpython/animation/data.py:131
+msgid "No workspace file selected."
+msgstr ""
+#: ../gui/wxpython/animation/data.py:134
+#, python-format
+msgid "File %s not found"
+msgstr ""
+#: ../gui/wxpython/animation/data.py:143
+#, python-format
+msgid "Animation %d"
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:224
+#, python-format
+msgid "Maximum number of animations is %s."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:245
+#: ../gui/wxpython/animation/dialogs.py:727
+msgid ""
+"More animations are using one window. Please select different window for "
+"each animation."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:404
+msgid "Failed to display legend."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:435
+msgid "Inconsistent number of maps, please check input data."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:458
+msgid "No animation to export."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:493
+msgid "Preparing export, please wait..."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:539
+#: ../gui/wxpython/animation/frame.py:575
+#, python-format
+msgid "%(from)s %(dash)s %(to)s"
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:545
+#, python-format
+msgid "%(start)s %(unit)s"
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:560
+msgid "Exporting animation, please wait..."
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:50
+msgid "GRASS GIS Animation tool"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:156
+msgid "Animation Toolbar"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:264
+msgid "Loading data"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:273
+msgid " ({c} out of {p})"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:578
+#, python-format
+msgid "to %(to)s"
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:69 ../gui/wxpython/animation/utils.py:75
+#: ../gui/wxpython/animation/temporal_manager.py:228
+#: ../gui/wxpython/timeline/frame.py:400
+#, python-format
+msgid "Space time dataset <%s> not found."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:178
+msgid "The number of maps in space-time datasets has to be the same."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:182
+msgid ""
+"The temporal type (absolute/relative) of space-time datasets has to be the "
+"same."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:186
+msgid ""
+"The map type (point/interval) of space-time datasets has to be the same."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:190
+msgid ""
+"The temporal extents of maps in space-time datasets have to be the same."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:198
+msgid "The number of maps to animate has to be the same for each map series."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:202
+msgid ""
+"The number of maps to animate has to be the same as the number of maps in "
+"temporal dataset."
+msgstr ""
+#: ../gui/wxpython/animation/nviztask.py:42 ../gui/wxpython/lmgr/frame.py:1224
+#, python-format
+msgid ""
+"Reading workspace file <%s> failed.\n"
+"Invalid file, unable to parse XML document."
+msgstr ""
+#: ../gui/wxpython/animation/nviztask.py:51
+#, python-format
+msgid "No 3d view information in workspace file <%s>."
+msgstr ""
+#: ../gui/wxpython/animation/nviztask.py:259
+msgid "Please add only one layer in the list."
+msgstr ""
+#: ../gui/wxpython/animation/nviztask.py:265
+msgid "No map series nor space-time dataset is added."
+msgstr ""
+#: ../gui/wxpython/animation/provider.py:362
+msgid "Rendering map layers"
+msgstr ""
+#: ../gui/wxpython/animation/provider.py:458
+msgid "Overlaying map layers"
+msgstr ""
+#: ../gui/wxpython/animation/provider.py:676
+msgid "Directory {t} not removed."
+msgstr ""
+#: ../gui/wxpython/animation/temporal_manager.py:105
+msgid ""
+"It is not allowed to display data with different temporal types (absolute "
+"and relative)."
+msgstr ""
+#: ../gui/wxpython/animation/temporal_manager.py:119
+#, python-format
+msgid "It is not allowed to display data with different units (%s)."
+msgstr ""
+#: ../gui/wxpython/animation/temporal_manager.py:130
+msgid ""
+"You are going to display data with different temporal types of maps "
+"(interval and point). It is recommended to use data of one temporal type to "
+"avoid confusion."
+msgstr ""
+#: ../gui/wxpython/animation/temporal_manager.py:330
+#, python-format
+msgid "Topology of Space time dataset %s is invalid."
+msgstr ""
+#: ../gui/wxpython/animation/g.gui.animation.py:88
+#, python-format
+msgid "%s=, %s=, %s= and %s= are mutually exclusive."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:51
+msgid "Adjust speed of animation"
+msgstr ""
+msgid "Simple mode"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:100
+msgid "Frame duration:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:101
+#: ../gui/wxpython/animation/dialogs.py:124
+msgid "ms"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:118
+msgid "Temporal mode"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:122
+msgid "Time unit:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:123
+msgid "Duration of time unit:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:175
+msgid "year"
+msgstr ""
+msgid "month"
+msgstr ""
+msgid "day"
+msgstr ""
+msgid "hour"
+msgstr ""
+msgid "minute"
+msgstr ""
+msgid "second"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:239
+msgid "Animation speed is too high."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:274
+#: ../gui/wxpython/animation/toolbars.py:36
+#: ../gui/wxpython/animation/toolbars.py:37
+msgid "Add new animation"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:276
+msgid "Edit animation"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:288
+msgid "Advanced"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:312
+msgid "top left"
+msgstr ""
+msgid "top right"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:313
+msgid "bottom left"
+msgstr ""
+msgid "bottom right"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:327
+msgid "Select 2D or 3D view"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:334
+msgid "Window position:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:337
+msgid "View mode:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:343
+msgid ""
+"For 3D animation, please select only one space-time dataset\n"
+"or one series of map layers."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:371
+#: ../gui/wxpython/lmgr/layertree.py:109
+msgid "Set options"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:388
+msgid "3D view parameters"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:395
+msgid "Workspace file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:396
+msgid "Choose workspace file to import 3D view parameters"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:403
+msgid "Parameter for animation:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:425
+msgid "Animate region change (2D view only)"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:429
+msgid "Start region:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:436
+msgid "End region:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:440
+msgid "Zoom value:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:441
+msgid "N-S/E-W distances in map units used to gradually reduce region."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:448
+msgid "N-S:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:451
+msgid "E-W:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:543
+msgid "Only one series or space-time dataset is accepted for 3D mode."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:551
+msgid "No map series or space-time dataset added."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:579
+msgid "Region information is not complete"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:608
+msgid "Add, edit or remove animations"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:616
+msgid "List of animations"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:627
+msgid "Edit"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:680
+#, python-format
+msgid "Maximum number of animations is %d."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:742
+#: ../gui/wxpython/animation/toolbars.py:40
+#: ../gui/wxpython/animation/toolbars.py:41
+msgid "Export animation"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:760 ../gui/wxpython/nviz/tools.py:610
+msgid "Decorations"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:765
+#: ../gui/wxpython/lmgr/layertree.py:584 ../gui/wxpython/menustrings.py:939
+#: ../gui/wxpython/menustrings.py:1838
+msgid "Export"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:811
+msgid "Add time stamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1993
+msgid "Add image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1991
+msgid "Add text"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:831
+msgid "Add time stamp, image or text decoration by one of the buttons above."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:833
+msgid "Add image or text decoration by one of the buttons above."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:842
+msgid "Font settings:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:844
+msgid "Sample text"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:856
+msgid "Image file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:857
+msgid "Choose image file"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:878
+msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:901
+msgid "image sequence"
+msgstr ""
+msgid "animated GIF"
+msgstr ""
+msgid "SWF"
+msgstr ""
+msgid "AVI"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:905
+msgid "Export to:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:920 ../gui/wxpython/nviz/tools.py:486
+msgid "File prefix:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:921
+msgid "animation_"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:922 ../gui/wxpython/nviz/tools.py:491
+msgid "File format:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:927
+#: ../gui/wxpython/gui_core/gselect.py:1400
+#: ../gui/wxpython/gui_core/gselect.py:1462
+msgid "Directory:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:928
+msgid "Choose directory for export"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:950
+msgid "GIF file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:951
+#: ../gui/wxpython/animation/dialogs.py:968
+#: ../gui/wxpython/animation/dialogs.py:991
+msgid "Choose file to save animation"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:967
+msgid "SWF file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:984
+msgid ""
+"Program 'ffmpeg' was not found.\n"
+"Please install it first and make sure\n"
+"it's in the PATH variable."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:990
+msgid "AVI file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:994
+msgid "Video codec:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:996
+msgid "Additional options:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:998
+msgid ""
+"Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. "
+"Options depend on ffmpeg version."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1020
+#, python-format
+msgid "Current frame rate: %.2f fps"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1138
+#, python-format
+msgid "File %s not found."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1140
+msgid "Decoration image file is missing."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1147
+#, python-format
+msgid "Directory %s not found."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1149
+msgid "Export directory is missing."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1153
+#: ../gui/wxpython/animation/dialogs.py:1157
+msgid "Export file is missing."
+msgstr ""
+msgid "Time stamp"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1265
+msgid "Add space-time dataset layer"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1283
+msgid "Multiple raster maps"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1284
+msgid "Multiple vector maps"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1285
+msgid "Multiple 3D raster maps"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1286
+msgid "Space time raster dataset"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1287
+msgid "Space time vector dataset"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1288
+msgid "Space time 3D raster dataset"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1327
+msgid "Input data type:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1403
+msgid "Select raster/vector maps."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1430
+msgid "Please select maps or dataset first."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1458
+msgid "Animation Tool settings"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1497
+#: ../gui/wxpython/gui_core/preferences.py:652
+#: ../gui/wxpython/web_services/widgets.py:263
+#: ../gui/wxpython/nviz/tools.py:354 ../gui/wxpython/nviz/preferences.py:178
+msgid "Background color:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1519
+#: ../gui/wxpython/timeline/frame.py:270
+msgid "Time"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1527
+msgid "Absolute time format:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1537
+msgid ""
+"Click and then press key up or down to preview different date and time "
+"formats. Type custom format string."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1546
+msgid "Learn more about formatting options"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1555
+msgid "Display instances with no data"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1556
+msgid ""
+"When animating instant-based data which have irregular timestamps you can "
+"display 'no data frame' (checked option) or keep last frame."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1578
+msgid "Invalid"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:28
+msgid "Change animation speed"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:29
+msgid "Play forward"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:30
+msgid "Play back"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:31 ../gui/wxpython/nviz/tools.py:409
+msgid "Stop"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:32 ../gui/wxpython/nviz/tools.py:407
+msgid "Pause"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:33
+msgid "Repeat"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:35
+msgid "Play back and forward"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:38
+#: ../gui/wxpython/animation/toolbars.py:39
+msgid "Add, edit or remove animation"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:49
+msgid "Add space-time dataset or series of map layers"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:50
+msgid "Add space-time dataset or series of map layers for animation"
+msgstr ""
+#: ../gui/wxpython/vnet/widgets.py:377
+msgid "Invalid value inserted. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vnet/widgets.py:528
+msgid "Edit point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:106
+msgid "Unable to perform analysis."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:211
+#, python-format
+msgid ""
+"Temporary map '%s' with result was changed outside vector network analysis "
+"tool.\n"
+"Showed result may not correspond original analysis result."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:216
+msgid "Result changed outside"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:253
+msgid "Map can be created only in current mapset"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:260 ../gui/wxpython/vnet/vnet_core.py:337
+#, python-format
+msgid "Vector map %s already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:263 ../gui/wxpython/vnet/vnet_core.py:340
+msgid "Overwrite vector map"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:289
+msgid "Creation of turntable failed."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:309
+msgid "Vector map with analysis result does not exist."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:330
+msgid "Map can be saved only to currently set mapset"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:409 ../gui/wxpython/vnet/vnet_core.py:609
+#, python-format
+msgid "Please choose '%s' and '%s' point."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:616
+msgid "Please choose at least two points."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:895
+#, python-format
+msgid ""
+"Input map '%s' for analysis was changed outside vector network analysis "
+"tool.\n"
+"Topology column may not correspond to changed situation."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:900
+msgid "Input changed outside"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:975
+#, python-format
+msgid ""
+"Temporary map %s  already exists.\n"
+"Do you want to continue in analysis and overwrite it?"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1001
+msgid "Unable to use ctypes. \n"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1002
+#: ../gui/wxpython/vnet/vnet_core.py:1024
+msgid "Snapping mode can not be activated."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1033
+msgid "Do you really want to activate snapping and overwrite it?"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1040
+#, python-format
+msgid ""
+"Temporary map '%s' was changed outside vector analysis tool.\n"
+"Do you really want to activate snapping and overwrite it? "
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1045
+msgid "Overwrite map"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:145
+#, python-format
+msgid "Module <%s> does not support turns costs."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:151
+#, python-format
+msgid "Vector map '%s' does not exist."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:153
+msgid "Vector map was not chosen."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:162
+msgid "arc layer"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:163
+msgid "node layer"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:164
+msgid "turntable layer"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:165
+msgid "unique categories layer"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:171
+#, python-format
+msgid "Chosen %s '%s' does not exist in vector map '%s'.\n"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:174
+#, python-format
+msgid "Choose existing %s.\n"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:184
+#, python-format
+msgid ""
+"Chosen column '%s' does not exist in attribute table of layer '%s' of vector "
+"map '%s'.\n"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:238
+msgid "type"
+msgstr ""
+msgid "topology"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:239 ../gui/wxpython/vnet/vnet_data.py:686
+msgid "Start point"
+msgstr ""
+msgid "End Point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:492 ../gui/wxpython/vnet/vnet_data.py:501
+#: ../gui/wxpython/vnet/vnet_data.py:504
+msgid "new point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:663
+msgid "Arc forward/both direction(s) cost column:"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:664
+msgid "arc forward/both"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:667
+msgid "Arc backward direction cost column:"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:668
+msgid "arc backward"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:671
+msgid "Arcs' cost column (for both directions):"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:672
+msgid "arc"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:676
+msgid "Node cost column:"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:677
+msgid "node"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:683
+#, python-format
+msgid "Shortest path %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:687
+msgid "End point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:703
+#, python-format
+msgid "Traveling salesman %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:719
+#, python-format
+msgid "Maximum flow %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:722
+msgid "Source point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:723
+msgid "Sink point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:738
+#, python-format
+msgid "Subnets for nearest centers %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:754
+#, python-format
+msgid "Steiner tree for the network and given terminals %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:768
+#, python-format
+msgid "Shortest distance via the network %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:787
+#, python-format
+msgid "Cost isolines %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:873
+msgid "Overwrite map layer"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:67
+msgid "GRASS GIS Vector Network Analysis Tool"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:165
+msgid "Point list toolbar"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:172
+msgid "Analysis toolbar"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:203
+msgid "Points for analysis:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:206
+msgid "Points"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:219
+msgid "Analysis settings:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:222
+msgid "Maximum distance of point to the network:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:234
+msgid "Iso lines:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:302
+#: ../gui/wxpython/modules/mcalc_builder.py:125
+#: ../gui/wxpython/modules/vkrige.py:113
+msgid "Output"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:319
+#: ../gui/wxpython/location_wizard/wizard.py:1337
+msgid "Parameters"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:350
+msgid "Add vector map into layer tree"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:469
+msgid "Input tables"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:495
+msgid "Result tables"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:507
+msgid "Loading tables..."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:643
+msgid "Creating turntable..."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:798
+msgid "Input vector map does not exists."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:816
+msgid "Analysing..."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:872
+#: ../gui/wxpython/gui_core/widgets.py:1024
+#: ../gui/wxpython/gui_core/toolbars.py:84 ../gui/wxpython/nviz/tools.py:1895
+#: ../gui/wxpython/iscatt/toolbars.py:44
+#: ../gui/wxpython/iscatt/toolbars.py:135
+msgid "Settings"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:939
+msgid "Computing nodes..."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1134
+#, python-format
+msgid "Color table style %s:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1145
+#, python-format
+msgid "Invert colors %s:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1150
+msgid "Line color:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1151
+msgid "Color for unused point:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1152
+msgid "Color for Start/From/Source/Used point:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1153
+msgid "Color for End/To/Sink point:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1154
+msgid "Color for selected point:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1168
+msgid "Point size:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1169
+msgid "Point width:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1170 ../gui/wxpython/iscatt/dialogs.py:338
+msgid "Snapping treshold in pixels:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1171
+msgid "Maximum number of results in history:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1203
+msgid "Analysis result style:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1233
+msgid "Point style:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1255
+msgid "Other settings"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1330
+msgid "New vector map with turntable"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1469
+msgid "Save analysis result"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1580
+msgid "Edit intersection turns costs"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1612
+msgid "Define Global Turn Costs"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:50
+msgid "Insert points from Map Display"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:52
+msgid "Activate snapping to nodes"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:54
+msgid "Activate mode for turns editing"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:56
+msgid "Activate mode for global turns editing"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:58
+msgid "Add new point"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:60
+msgid "Delete selected point"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:110
+msgid "Execute analysis"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:112
+msgid "Go to previous analysis result"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:114
+msgid "Go to next analysis result"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:116
+msgid "Show analysis result"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:118
+msgid "Save temporary result"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:119
+msgid "Vector network analysis settings"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:121
+#: ../gui/wxpython/gui_core/toolbars.py:71
+#: ../gui/wxpython/iscatt/toolbars.py:46
+msgid "Show manual"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:184
+msgid "Availiable analyses"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:402
+msgid "Render"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:406
+msgid "Enable/disable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:436
+msgid "Show comp. extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:440
+msgid "Show computational extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:443
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:492
+msgid "Display mode"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:496
+#: ../gui/wxpython/gui_core/preferences.py:671
+msgid "Align region extent based on display size"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:499
+msgid ""
+"Align region extent based on display size from center point. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:532
+msgid "Display resolution"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:535
+#: ../gui/wxpython/gui_core/preferences.py:684
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:538
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:575
+msgid "Map scale"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:589
+msgid ""
+"As everyone's monitors and resolutions are set differently these values are "
+"not true map scales, but should get you into the right neighborhood."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:642
+msgid "Go to"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:663
+#: ../gui/wxpython/mapdisp/statusbar.py:727
+#: ../gui/wxpython/mapdisp/statusbar.py:934
+#: ../gui/wxpython/mapdisp/statusbar.py:1001
+msgid "Projection not defined (check the settings)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:741
+#: ../gui/wxpython/mapdisp/statusbar.py:947
+#: ../gui/wxpython/mapdisp/statusbar.py:1031
+msgid "Error in projection (check the settings)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:773
+#: ../gui/wxpython/gui_core/preferences.py:1192
+msgid "Projection"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:775
+msgid "Use defined projection"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:787
+msgid ""
+"Reproject coordinates displayed in the statusbar. Projection can be defined "
+"in GUI preferences dialog (tab 'Projection')"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:812
+msgid "MASK"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:856
+msgid "Display geometry"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:878
+msgid "Coordinates"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:959
+msgid "Extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:1055
+#: ../gui/wxpython/web_services/dialogs.py:805
+msgid "Computational region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:69
+msgid "GRASS GIS - Map display"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:250 ../gui/wxpython/lmgr/frame.py:95
+#: ../gui/wxpython/lmgr/frame.py:1070 ../gui/wxpython/gui_core/ghelp.py:100
+#: ../gui/wxpython/gui_core/ghelp.py:810
+msgid "Unable to get GRASS version\n"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:254
+#, python-format
+msgid ""
+"GRASS GIS %(version)s Map Display: %(id)s  - Location: %(loc)s@%(mapset)s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:272 ../gui/wxpython/lmgr/layertree.py:908
+#, python-format
+msgid ""
+"Unable to start wxGUI vector digitizer.\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:310
+msgid "Vector Digitizer Toolbar"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:331
+#, python-format
+msgid ""
+"Unable to switch to 3D display mode.\n"
+"The Nviz python extension was not found or loaded properly.\n"
+"Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:357
+msgid "Starting 3D view mode..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:358
+msgid "Please wait, loading data..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:430
+msgid "Please wait, unloading data..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:432
+msgid "Switching back to 2D view mode..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:482 ../gui/wxpython/mapdisp/toolbars.py:99
+msgid "Digitize"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:658
+msgid "d.to.rast can be used only in 2D mode."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:682 ../gui/wxpython/mapdisp/frame.py:690
+#: ../gui/wxpython/mapdisp/frame.py:701
+msgid "Failed to run d.to.rast:\n"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:817
+#, python-format
+msgid "Vector map <%s> opened for editing - skipped."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:878
+msgid ""
+"Failed to query vector map(s) <{maps}>. Check database settings and topology."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1253
+#: ../gui/wxpython/mapdisp/toolbars.py:49
+msgid "Add text layer"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1357
+msgid "Set computational region extent from display"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1358
+msgid "Set computational region extent interactively"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1359
+msgid "Set computational region from named region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1362
+msgid "Save computational region to named region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:88
+#: ../gui/wxpython/gui_core/mapdisp.py:114 ../gui/wxpython/core/render.py:449
+#, python-format
+msgid "GRASS module '%s' not found. Unable to start map display window."
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:129
+msgid "Map window test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:148
+msgid "Map display test"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:157
+msgid "Map window API test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:187
+msgid "Map window distance measurement test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:218
+msgid "Map window profile tool test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:265
+msgid "Map window rlisetup test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:326
+#, python-format
+msgid "Unknown value %s of test parameter."
+msgstr ""
+#: ../gui/wxpython/mapdisp/gprint.py:150
+msgid ""
+"There was a problem printing.\n"
+"Perhaps your current printer is not set correctly?"
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:143
+#, python-format
+msgid "Unsupported command %s."
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:205
+#, python-format
+msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:448
+#, python-format
+msgid "Starting map display <%s>..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:459
+#, python-format
+msgid "Stopping map display <%s>..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:32
+msgid "Show/hide scale bar"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:34
+msgid "Show/hide legend"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:36
+msgid "Show/hide north arrow"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:38
+msgid "Analyze map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:39
+msgid "Measuring, profiling, histogramming, ..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:41
+msgid "Measure distance"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:43
+msgid "Measure area"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:45
+msgid "Profile surface map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:47
+msgid "Create bivariate scatterplot of raster maps"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:51
+msgid "Create histogram of raster map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:53 ../gui/wxpython/menustrings.py:622
+#: ../gui/wxpython/menustrings.py:1521
+msgid "Vector network analysis tool"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:58
+msgid "Rotate 3D scene"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:59
+msgid "Drag with mouse to rotate 3D scene"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:61
+#: ../gui/wxpython/nviz/preferences.py:209
+msgid "Fly-through mode"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:62
+msgid ""
+"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:64
+msgid "Click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:65
+msgid "Click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:93
+msgid "3D view mode not available"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:94
+#: ../gui/wxpython/mapdisp/toolbars.py:108
+#, python-format
+msgid "Reason: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:107
+msgid "Vector digitizer not available"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:109
+msgid ""
+"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
+"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
+"In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:205
+#: ../gui/wxpython/rlisetup/sampling_frame.py:308
+#, python-format
+msgid "The raster file %s already exists, please change name"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:229
+msgid "Raster map not created. Please redraw region."
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:330
+msgid "Raster map not created. redraw region again."
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:382
+#: ../gui/wxpython/rlisetup/wizard.py:751
+msgid "Draw sampling frame"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:383
+msgid "Draw sampling frame by clicking and dragging"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:385
+msgid "Draw sampling rectangle"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:386
+msgid "Draw sampling rectangle by clicking and dragging"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:388
+msgid "Draw sampling circle"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:389
+msgid "Draw sampling circle radius by clicking and dragging"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:391
+#: ../gui/wxpython/rlisetup/wizard.py:1053
+#: ../gui/wxpython/rlisetup/wizard.py:1402
+msgid "Draw sampling region"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:392
+msgid "Draw sampling region by polygon. Right Double click to end drawing"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:22
+msgid "Modify the configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:35
+msgid "View and modify the configuration file '{name}'"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:84
+msgid ""
+"Are you sure that you want modify r.li configuration file {name}?\n"
+"You could broke the configuration file..."
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:88
+msgid "WARNING"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:105
+msgid "GRASS GIS Setup for r.li modules"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:122
+msgid "Available sampling area configuration files"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:131
+msgid "Remove a configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:133 ../gui/wxpython/menustrings.py:907
+#: ../gui/wxpython/menustrings.py:1806
+msgid "Create"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:134
+msgid "Create a new configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:136 ../gui/wxpython/lmgr/layertree.py:425
+#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:909
+#: ../gui/wxpython/menustrings.py:1141 ../gui/wxpython/menustrings.py:1808
+msgid "Rename"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:137
+msgid "Rename a configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:139
+msgid "View/Edit"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:140
+msgid "View and edit a configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:213
+#, python-format
+msgid "Do you want remove r.li configuration file <%s>?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:215
+msgid "Remove new r.li configuration file?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:238 ../gui/wxpython/rlisetup/frame.py:258
+msgid "You have to select a configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:241
+#, python-format
+msgid ""
+"Set the new name for %s \"                                            "
+"\"configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:243
+msgid "Rename configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:52
+msgid "Create new configuration file for r.li modules"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:116
+#, python-format
+msgid "Do you want to create r.li configuration file <%s>?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:118
+msgid "Create new r.li configuration file?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:130
+msgid "r.li.setup wizard canceled. Configuration file not created."
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:429
+msgid "Select maps and define name"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:441
+msgid "Name for new configuration file to create"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:453
+msgid "Raster map to use to select areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:463
+msgid "Vector map to use to select areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:473
+msgid "Vector map layer to use to select areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:482
+msgid "Define sampling region (region for analysis)"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:484
+#: ../gui/wxpython/rlisetup/wizard.py:809
+msgid "Whole map layer"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:485
+msgid "Keyboard setting"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:486
+msgid "Draw the sampling frame"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:526
+#, python-format
+msgid "The configuration file %s already exists, please change name"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:588
+#, python-format
+msgid "Vector %s was not found, please select another vector"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:592
+#, python-format
+msgid "Vector %s has no areas, please select another vector"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:597
+#, python-format
+msgid "Vector %s has no table connected, please select another vector"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:639
+msgid "Insert sampling frame parameter"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:649
+msgid "Column of upper left corner"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:663
+msgid "Row of upper left corner"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:676
+#: ../gui/wxpython/rlisetup/wizard.py:688
+msgid "Row length of sampling frame"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:802
+msgid "Insert sampling areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:810
+msgid "Regions"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:811
+msgid "Sample units"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:812 ../gui/wxpython/menustrings.py:321
+#: ../gui/wxpython/menustrings.py:1220
+msgid "Moving window"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:813
+msgid ""
+"Select areas from the\n"
+"overlayed vector map"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:822
+msgid "Choose a method"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:823
+msgid "Use keyboard to enter sampling area"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:824
+msgid "Use mouse to draw sampling area"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:828
+msgid "This option is not supported yet"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:840
+msgid "Number of regions to draw:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:854
+msgid "Do you want to overwrite existing temporal maps if they exist?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:858
+msgid "Do you want to check vector areas?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:860
+msgid "Select if use area by area"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:862
+msgid "All the features will be used"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:878
+msgid "Analysing all vector features..."
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:975
+msgid "Analysing vector"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:991
+msgid "All feature are been analyzed."
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:995
+msgid "An error occurred"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1026
+msgid "Draw sampling regions"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1043
+msgid "Draw sample region "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1051
+#: ../gui/wxpython/rlisetup/wizard.py:1396
+msgid "Draw moving windows region"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1090
+msgid "Select sample units from keyboard"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1104
+#: ../gui/wxpython/rlisetup/wizard.py:1266
+#: ../gui/wxpython/rlisetup/wizard.py:1355
+msgid "Select type of shape"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1105
+#: ../gui/wxpython/rlisetup/wizard.py:1267
+#: ../gui/wxpython/rlisetup/wizard.py:1356
+msgid "Circle"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1127
+#: ../gui/wxpython/rlisetup/wizard.py:1278
+#: ../gui/wxpython/rlisetup/wizard.py:1293
+msgid "Width size (in cells)?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1128
+#: ../gui/wxpython/rlisetup/wizard.py:1294
+msgid "What radius size (in meters)?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1129
+#: ../gui/wxpython/rlisetup/wizard.py:1285
+#: ../gui/wxpython/rlisetup/wizard.py:1295
+msgid "Height size (in cells)?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1130
+#: ../gui/wxpython/rlisetup/wizard.py:1296
+msgid "Name of the circle mask"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1136
+msgid "Select method of sampling unit distribution"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1137
+msgid "Random non overlapping"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1138
+msgid "Systematic contiguos"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1139
+msgid "Stratified random"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1140
+msgid "Systematic non contiguos"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1141
+msgid "Centered over sites"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1147
+#: ../gui/wxpython/rlisetup/wizard.py:1207
+msgid "What number of Sampling Units to use?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1221
+msgid "Insert number of row strates"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1222
+msgid "Insert number of column strates"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1228
+msgid "Insert distance between units"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1258
+msgid "Set sample units"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1307
+msgid "Set moving windows"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1349
+#: ../gui/wxpython/rlisetup/wizard.py:1448
+msgid "Draw sampling units"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1367
+msgid "Number of sampling area to draw:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1465
+msgid "Draw Sampling "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1519
+msgid "Select sampling areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1528
+msgid "Is this area ok?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1551
+msgid "Select sample area "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1578
+#: ../gui/wxpython/rlisetup/functions.py:138
+#, python-format
+msgid ""
+"The raster map <%s> already exists. Please remove or rename the maps with "
+"the prefix '%s' or select the option to overwrite existing maps"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1618
+#: ../gui/wxpython/rlisetup/functions.py:127
+msgid "The polygon seems to have 0 areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1621
+msgid "Select sample area 1 of "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1643
+#: ../gui/wxpython/location_wizard/wizard.py:1623
+msgid "Summary"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1650
+msgid "Configuration file name:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1659
+msgid "Raster name:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1669
+msgid "Vector name:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1678
+msgid "Region type:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1696
+msgid "Sampling area type:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1760
+msgid "Region keyboard values:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1774
+#: ../gui/wxpython/rlisetup/wizard.py:1799
+#: ../gui/wxpython/rlisetup/wizard.py:1803
+msgid "Type of shape:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1777
+#: ../gui/wxpython/rlisetup/wizard.py:1806
+msgid "Radius size:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1778
+#: ../gui/wxpython/rlisetup/wizard.py:1807
+msgid "Name circle mask:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1780
+#: ../gui/wxpython/rlisetup/wizard.py:1809
+msgid "Width size:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1781
+#: ../gui/wxpython/rlisetup/wizard.py:1810
+msgid "Height size:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1784
+msgid "Method of distribution:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1787
+msgid "Number sampling units:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1790
+msgid "Distance between units:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1793
+msgid "Number row strates:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1795
+msgid "Number column strates:"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:37
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:38
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:39
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:49
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:99
+#, python-format
+msgid "Raster or vector map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:106
+#, python-format
+msgid "Raster map <%s> added"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:108
+#, python-format
+msgid "Vector map <%s> added"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:97
+#, python-format
+msgid "GRASS GIS %s Layer Manager"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:142
+msgid "Workspace Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:145
+msgid "Data Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:151
+msgid "Tools Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:154
+msgid "Vector Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:157
+msgid "3D view Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:262 ../gui/wxpython/lmgr/frame.py:1489
+msgid "Rename Map Display"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:290
+msgid "Map layers"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:301
+msgid "Command console"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:318
+msgid "Search modules"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:325
+#: ../gui/wxpython/gui_core/preferences.py:292
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:398
+#, python-format
+msgid ""
+"Location <%s> created.\n"
+"\n"
+"Do you want to switch to the new location?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:401
+msgid "Switch to new location?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:417 ../gui/wxpython/lmgr/frame.py:922
+#, python-format
+msgid ""
+"Current location is <%(loc)s>.\n"
+"Current mapset is <%(mapset)s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:503
+msgid "Choose model to run"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:561 ../gui/wxpython/lmgr/frame.py:2197
+msgid "Do you want to save changes in the workspace?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:563 ../gui/wxpython/lmgr/frame.py:2199
+msgid "Do you want to store current settings to workspace file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:571
+#, python-format
+msgid "Close Map Display %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:646
+#, python-format
+msgid ""
+"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
+"layer instead."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:807 ../gui/wxpython/lmgr/frame.py:1732
+msgid "Selected map layer is not vector."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:812
+msgid "Editing is allowed only for vector maps from the current mapset."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:836
+msgid "Choose script file to run"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:838
+msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:850
+msgid ""
+"Due to the limitations of your operating system, the script path cannot "
+"contain certain non-ascii characters. Please rename the script or move it to "
+"a different location."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:857
+#, python-format
+msgid "Script file '%s' doesn't exist. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:864
+#, python-format
+msgid ""
+"Script <%s> is not executable. Do you want to set the permissions that "
+"allows you to run this script (note that you must be the owner of the file)?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:869
+msgid "Set permission?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:878
+msgid "Unable to set permission. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:889
+#, python-format
+msgid ""
+"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
+"directory to GRASS_ADDON_PATH?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:892
+msgid "Update Addons path?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:898
+#, python-format
+msgid "Launching script '%s'..."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:910
+msgid "No location/mapset provided. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:936 ../gui/wxpython/lmgr/frame.py:957
+msgid "No mapset provided. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:945 ../gui/wxpython/lmgr/frame.py:964
+#, python-format
+msgid "Current mapset is <%s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:986
+#, python-format
+msgid ""
+"Working directory changed to:\n"
+"\"%s\""
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:993
+msgid "Changes current working directory for this GUI."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:995
+msgid "Usage: cd [directory]"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:996
+msgid "Without parameters it opens a dialog."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1000
+msgid ""
+"If ~ (tilde) is present as the first directory on the path, it is replaced "
+"by user's home directory."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1014
+msgid "More than one parameter provided."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1034
+msgid "Choose a working directory"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1079
+msgid "System Info"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1094
+msgid "GRASS version"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1094 ../gui/wxpython/gui_core/ghelp.py:114
+msgid "unknown version"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1095
+msgid "GRASS SVN Revision"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1096 ../gui/wxpython/gui_core/ghelp.py:152
+msgid "Build Date"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1097
+msgid "Build Platform"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1102
+msgid "Platform"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1160
+msgid ""
+"Current workspace is not empty. Do you want to store current settings to "
+"workspace file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1163
+msgid "Create new workspace?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1189
+msgid "Choose workspace file"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1190 ../gui/wxpython/lmgr/frame.py:1387
+msgid "GRASS Workspace File (*.gxw)|*.gxw"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1228 ../gui/wxpython/lmgr/frame.py:1364
+msgid "Please wait, loading workspace..."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1348
+msgid "Choose GRC file to load"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1349
+msgid "Old GRASS Workspace File (*.grc)|*.grc"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1386
+msgid "Choose file to save current workspace"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1401 ../gui/wxpython/lmgr/frame.py:1417
+#, python-format
+msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1403 ../gui/wxpython/lmgr/frame.py:1420
+#: ../gui/wxpython/menustrings.py:10
+msgid "Save workspace"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1441
+msgid "Writing current settings to workspace file failed."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1488
+msgid "Enter new name:"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1494
+#, python-brace-format
+msgid "GRASS GIS {version} Map Display: {name} - Location: {loc}"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1574
+#, python-format
+msgid ""
+"Unable to launch \"Supervised Classification Tool\".\n"
+"\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1614
+msgid "Unable to start Timeline Tool."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1842
+msgid "Add selected map layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1876 ../gui/wxpython/lmgr/frame.py:1923
+#, python-format
+msgid "Unsupported map layer type <%s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2052
+msgid ""
+"Note that cell values can only be displayed for regions of less than 10,000 "
+"cells."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2126 ../gui/wxpython/lmgr/layertree.py:1643
+msgid "opacity:"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2134
+#, python-format
+msgid ""
+"Do you want to remove map layer(s)\n"
+"%s\n"
+"from layer tree?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2137
+msgid "Do you want to remove selected map layer(s) from layer tree?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2141
+msgid "Remove map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2206
+msgid "Quit GRASS GUI"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2237
+msgid "No map layer selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2247
+msgid ""
+"Display resolution is currently not constrained to computational settings. "
+"It's suggested to constrain map to region geometry. Do you want to constrain "
+"the resolution?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2256
+msgid "Constrain map to region geometry?"
+msgstr ""
+#: ../gui/wxpython/lmgr/menudata.py:42
+msgid ""
+"Unable to parse user toolboxes XML files. Default main menu will be loaded."
+msgstr ""
+#: ../gui/wxpython/lmgr/menudata.py:64
+msgid ""
+"Unable to parse user toolboxes XML files. Default module tree will be loaded."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:56 ../gui/wxpython/menustrings.py:32
+#: ../gui/wxpython/menustrings.py:1009
+#: ../gui/wxpython/gui_core/dialogs.py:1866
+msgid "Import raster data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:58 ../gui/wxpython/menustrings.py:151
+#: ../gui/wxpython/menustrings.py:1128
+#: ../gui/wxpython/gui_core/dialogs.py:1864
+msgid "Link external raster data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:60 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/menustrings.py:1033
+msgid "Unpack raster map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:62
+msgid "Set raster output format"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:64 ../gui/wxpython/menustrings.py:60
+#: ../gui/wxpython/menustrings.py:1037
+#: ../gui/wxpython/gui_core/dialogs.py:1860
+msgid "Import vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:66 ../gui/wxpython/menustrings.py:153
+#: ../gui/wxpython/menustrings.py:1130
+#: ../gui/wxpython/gui_core/dialogs.py:1858
+msgid "Link external vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:68 ../gui/wxpython/menustrings.py:78
+#: ../gui/wxpython/menustrings.py:1055
+msgid "Unpack vector map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:70
+msgid "Set vector output format"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:72
+msgid "Import data from WMS server"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:74
+msgid "Add command layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:76 ../gui/wxpython/menustrings.py:1975
+#: ../gui/wxpython/gui_core/toolbars.py:73
+msgid "Quit"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:78
+#: ../gui/wxpython/gui_core/toolbars.py:75
+msgid "Add raster map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:82
+msgid "Add HIS map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:84
+msgid "Add shaded relief map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:86
+msgid "Add raster flow arrows"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:88
+msgid "Add raster cell numbers"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:77
+msgid "Add vector map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:92
+msgid "Add thematic area (choropleth) map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:94
+msgid "Add thematic chart layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:96
+msgid "Add grid layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:98
+msgid "Add geodesic line layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:100
+msgid "Add rhumbline layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:104
+#: ../gui/wxpython/gui_core/simplelmgr.py:453
+#: ../gui/wxpython/gui_core/simplelmgr.py:454
+msgid "Add 3D raster map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:105
+msgid "Note that 3D raster data are rendered only in 3D view mode"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:107
+msgid "Add WMS layer."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:111
+msgid "Editing mode"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:113
+msgid "Background vector map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:191
+msgid "Map Layers"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:443 ../gui/wxpython/iscatt/frame.py:540
+msgid "Change opacity level"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:453
+msgid "3D view properties"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:458
+msgid "Zoom to selected map(s)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:463
+msgid "Set computational region from selected map(s)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:477
+msgid "Export common formats"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:486
+msgid "Export PostGIS"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:493 ../gui/wxpython/lmgr/layertree.py:591
+msgid "Create pack"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:501 ../gui/wxpython/lmgr/layertree.py:599
+msgid "Make a copy in the current mapset"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:506 ../gui/wxpython/lmgr/layertree.py:604
+#: ../gui/wxpython/lmgr/layertree.py:636
+msgid "Set color table"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:509
+msgid "Show attribute data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:521
+msgid "Start editing"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:524
+msgid "Stop editing"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:540
+msgid "Rebuild topology"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:578
+msgid "Zoom to selected map(s) (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:607 ../gui/wxpython/menustrings.py:735
+#: ../gui/wxpython/menustrings.py:1634
+msgid "Histogram"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:612 ../gui/wxpython/lmgr/layertree.py:639
+#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1417
+msgid "Univariate raster statistics"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:617
+msgid "Report raster statistics"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:623
+msgid "Profile"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:651
+msgid "Save web service layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:756
+msgid "Unable to create profile of raster map."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:786
+#, python-format
+msgid ""
+"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:808 ../gui/wxpython/nviz/tools.py:1532
+msgid "3D raster map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:810
+#, python-format
+msgid "Unsupported map type <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:815
+#, python-format
+msgid "Enter name for the new %s in the current mapset:"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:816
+#, python-format
+msgid "Make a copy of %s <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:830
+#, python-format
+msgid ""
+"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:833
+#: ../gui/wxpython/gui_core/dialogs.py:423
+msgid "Overwrite?"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:840
+#, python-format
+msgid "Unable to make copy of <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:847
+#, python-format
+msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:864
+msgid "Unable to display histogram of raster map. No map name defined."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:965
+#: ../gui/wxpython/gui_core/simplelmgr.py:270
+#, python-format
+msgid "Set opacity of <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1070
+msgid "Layer group:"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1075
+#: ../gui/wxpython/lmgr/layertree.py:1568
+msgid "Click to edit layer settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1127
+msgid "(double click to set properties)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1368
+msgid "Please wait, updating data..."
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:46
+msgid "Start new map display"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:48
+msgid "Create new workspace (Ctrl+N)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:50
+msgid "Open existing workspace file (Ctrl+O)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:52
+msgid "Save current workspace to file (Ctrl+S)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:81
+msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:82
+msgid "Add raster map layer (Ctrl+Shift+R)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:84
+msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:85
+msgid "Add vector map layer (Ctrl+Shift+V)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:87
+msgid "Add various vector map layers (thematic, chart...)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:89
+msgid "Add web service layer (WMS, WMTS, NASA OnEarth)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:91
+msgid "Add group"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:93
+msgid "Add various overlays"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:95
+msgid "Remove selected map layer(s) from layer tree"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:136
+msgid "Import/link raster or vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:138
+msgid "Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:140 ../gui/wxpython/gui_core/forms.py:1205
+msgid "Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:142
+msgid "Georectifier"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:144 ../gui/wxpython/menustrings.py:195
+#: ../gui/wxpython/menustrings.py:1908
+msgid "Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:146
+msgid "Launch user-defined script"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:180
+msgid "GUI settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:181
+msgid "GRASS manual"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:206
+msgid "Edit selected vector map"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:208
+msgid "Show attribute data for selected vector map"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:237
+msgid "Generate command for m.nviz.image"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:238
+msgid "Generate command for m.nviz.image based on current state"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:240
+msgid "3D view mode settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:241
+msgid "Show 3D view mode settings dialog"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:243
+msgid "Show 3D view mode manual"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:34 ../gui/wxpython/nviz/wxnviz.py:32
+msgid ""
+"This module requires the NumPy module, which could not be imported. It "
+"probably is not installed (it's not part of the standard Python "
+"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
+"information on downloading source or binaries."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:61
+msgid "GRASS Profile Analysis Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:77 ../gui/wxpython/wxplot/profile.py:168
+msgid "Profile of"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:93
+#, python-format
+msgid "Distance (%s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:95
+msgid "Distance along transect"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:96
+msgid "Cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:161
+msgid "Not all points of profile lie inside computational region."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:228
+msgid "Raster values"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:279
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:280
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:342
+msgid "Choose prefix for file(s) where to save profile values..."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:344
+msgid "Comma separated value (*.csv)|*.csv"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:354
+msgid "Overwrite file?"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:365
+#, python-format
+msgid ""
+"Unable to open file <%s> for writing.\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:377
+#, python-format
+msgid ""
+"%d files created:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:379
+msgid "No files generated."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:387
+msgid "Statistics for Profile(s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:46
+msgid "GRASS Bivariate Scatterplot Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:53
+msgid "Bivariate Scatterplot"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:54 ../gui/wxpython/wxplot/scatter.py:55
+#: ../gui/wxpython/wxplot/histogram.py:54
+#: ../gui/wxpython/wxplot/histogram.py:140
+msgid "Raster cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:87 ../gui/wxpython/wxplot/scatter.py:232
+msgid "Nothing to plot."
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:97
+msgid "At least 2 raster maps must be specified"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:118
+msgid "Bivariate Scatterplot of "
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:136 ../gui/wxpython/wxplot/scatter.py:137
+#, python-format
+msgid "Raster <%s> cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:141 ../gui/wxpython/wxplot/scatter.py:145
+#, python-format
+msgid ": %s"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:238
+msgid "Regression Statistics for Scatterplot(s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:250
+#, python-format
+msgid ""
+"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:39
+msgid "Draw/re-draw plot"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:41
+msgid "Draw transect in map display window to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:43
+msgid "Plot options"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:45
+msgid "Plot statistics"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:47
+msgid "Save profile data to CSV file"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:48
+msgid "Quit plot tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:439
+msgid "Left Mouse Down at Point:"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:466 ../gui/wxpython/wxplot/base.py:532
+#: ../gui/wxpython/wxplot/dialogs.py:556
+msgid "Text settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:470 ../gui/wxpython/wxplot/base.py:546
+#: ../gui/wxpython/wxplot/dialogs.py:823
+msgid "Plot settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:483
+msgid "This feature is not yet functional"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:484
+msgid "Under Construction"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:45
+msgid "GRASS GIS Histogramming Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:53
+msgid "Histogram of"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:55
+#: ../gui/wxpython/wxplot/histogram.py:145
+msgid "Cell counts"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:126
+#, python-format
+msgid "Histogram of image group <%s>"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:129
+#, python-format
+msgid "Histogram of raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:131
+msgid "Histogram of selected raster maps"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:138
+#, python-format
+msgid "Raster cell values %s"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:146
+msgid "Percent of total cells"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:147
+msgid "Area"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:230
+msgid "Statistics for Map(s) Histogrammed"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:234
+#, python-format
+msgid "Statistics for raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:35
+msgid "Select raster maps to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:64
+msgid "Select raster map(s) to profile:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:106
+msgid "Select pairs of raster maps for scatterplots"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:142
+msgid "Select pairs of raster maps for bivariate scatterplots:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:157 ../gui/wxpython/wxplot/dialogs.py:404
+msgid "Number of bins (for FP maps)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:292
+msgid "C&opy"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:293
+msgid "Copy regression statistics the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:322
+msgid "Regression statistics copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:331
+msgid "Select raster map or imagery group to histogram"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:357
+msgid "Histogram single raster"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:358
+msgid "Histogram imagery group"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:370
+#: ../gui/wxpython/modules/colorrules.py:383
+msgid "Select raster map:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:389
+msgid "Select image group:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:415
+msgid "Histogram type"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:494
+msgid "Selected group must be in current mapset"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:563
+msgid "Profile title:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:573
+msgid "Title font size (pts):"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:584
+msgid "X-axis label:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:594
+msgid "Y-axis label:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:604
+msgid "Label font size (pts):"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:626
+msgid "Font family:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:640
+msgid "Style:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:654
+msgid "Weight:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:687
+#: ../gui/wxpython/wxplot/dialogs.py:1135
+msgid "Apply changes for the current session and close dialog"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:743
+#, python-format
+msgid "Plot text sizes saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:801
+msgid "No map or image group selected to plot."
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:843
+msgid "Map/image plotted"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:855
+msgid "Settings for selected map"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:871
+msgid "Line color"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:912
+msgid "Transect segment marker settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:962
+msgid "Scatterplot points"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1013
+msgid "Axis settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1019
+msgid "X-Axis"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1020
+msgid "Y-Axis"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1029
+msgid "Scale"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1033
+msgid ""
+"Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1038
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1046
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1054
+msgid "Log scale"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1078
+msgid "Grid and Legend settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1083
+msgid "Grid color"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1090
+msgid "Show grid"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1096
+msgid "Legend font size"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1106
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1246
+#, python-format
+msgid "Plot settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1912
+#: ../gui/wxpython/menustrings.py:1962
+msgid "&File"
+msgstr "&Tiedosto"
+#: ../gui/wxpython/menustrings.py:4
+msgid "Workspace"
+msgstr "Työtila"
+#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1913
+#: ../gui/wxpython/nviz/tools.py:1097
+msgid "New"
+msgstr "Uusi"
+#: ../gui/wxpython/menustrings.py:6
+msgid "Create new workspace"
+msgstr "Luo uusi työtila"
+#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1915
+msgid "Open"
+msgstr "Avaa"
+#: ../gui/wxpython/menustrings.py:8
+msgid "Load workspace from file"
+msgstr "Lataa työtila tiedostosta"
+#: ../gui/wxpython/menustrings.py:9 ../gui/wxpython/menustrings.py:1917
+#: ../gui/wxpython/modules/colorrules.py:418
+msgid "Save"
+msgstr "Tallenna"
+#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1919
+msgid "Save as"
+msgstr "Tallenna nimellä"
+msgid "Save workspace to file"
+msgstr "Tallenna työtila tiedostoon"
+#: ../gui/wxpython/menustrings.py:14
+msgid "Close workspace file"
+msgstr "Sulje työtilan tiedosto"
+msgid "Load GRC file (Tcl/Tk GUI)"
+msgstr ""
+msgid "Load map layers from GRC file to layer tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/web_services/dialogs.py:803
+msgid "Map display"
+msgstr "Karttanäyttö"
+msgid "Add raster"
+msgstr "Lisää rasteri"
+msgid "Add raster map layer to current display"
+msgstr "Lisää rasterikarttataso nykyiselle näytölle"
+#: ../gui/wxpython/menustrings.py:20
+msgid "Add vector"
+msgstr "Lisää vektori"
+#: ../gui/wxpython/menustrings.py:21
+msgid "Add vector map layer to current display"
+msgstr "Lisää vektorikarttataso nykyiselle näytölle"
+#: ../gui/wxpython/menustrings.py:22
+msgid "Add multiple rasters or vectors"
+msgstr "Lisää useita rastereita tai vektoreita"
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple raster or vector map layers to current display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24 ../gui/wxpython/menustrings.py:25
+#: ../gui/wxpython/web_services/dialogs.py:477
+msgid "Add web service layer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:26
+msgid "New map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:27
+msgid "Open new map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:28 ../gui/wxpython/menustrings.py:29
+msgid "Close current map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:30 ../gui/wxpython/menustrings.py:31
+msgid "Close all open map display windows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:1010
+msgid "Common formats import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:1011
+msgid "Import raster data into a GRASS map layer using GDAL."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1012
+msgid "ASCII x,y,z point import and gridding"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1013
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1014
+msgid "ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:1015
+msgid "Converts a GRASS ASCII raster file to binary raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1016
+msgid "ASCII polygons, lines, and point import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1017
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1018
+msgid "Raw binary array import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1019
+msgid "Import a binary raster file into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1020
+msgid "GRIDATB.FOR import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1021
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1022
+msgid "Matlab 2D array import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1023
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1024
+msgid "PNG import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1025
+msgid "Imports non-georeferenced PNG format image."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1026
+msgid "SPOT NDVI import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1027
+msgid "Imports SPOT VGT NDVI data into a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1028
+msgid "SRTM HGT import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1029
+msgid "Imports SRTM HGT files into raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1030
+msgid "Terra ASTER HDF import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1031
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+"using gdalwarp."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:77
+#: ../gui/wxpython/menustrings.py:1032 ../gui/wxpython/menustrings.py:1054
+msgid "LAS LiDAR points import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1034
+msgid ""
+"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:274
+#: ../gui/wxpython/menustrings.py:1035 ../gui/wxpython/menustrings.py:1173
+msgid "Reproject raster map from different GRASS location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:275
+#: ../gui/wxpython/menustrings.py:1036 ../gui/wxpython/menustrings.py:1174
+msgid "Re-projects a raster map from given location to the current location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:90
+#: ../gui/wxpython/menustrings.py:1038 ../gui/wxpython/menustrings.py:1067
+msgid "Common import formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1039
+msgid "Converts vector layers into a GRASS vector map using OGR."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1040
+msgid "ASCII points or GRASS ASCII format"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1041
+msgid "Creates a vector map from an ASCII points file or ASCII vector file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1042
+msgid "ASCII points as a vector lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:1043
+msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1044
+msgid "DXF import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1045
+msgid "Converts files in DXF format to GRASS vector map format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1046
+msgid "WFS"
+msgstr "WFS"
+#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1047
+msgid "Imports GetFeature from a WFS server."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1048
+msgid "ESRI e00 import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1049
+msgid "Imports E00 file into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1050
+msgid "Geonames import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1051
+msgid "Imports geonames.org country files into a vector points map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1052
+msgid "Matlab array or Mapgen format import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1053
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1056
+msgid ""
+"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:554
+#: ../gui/wxpython/menustrings.py:1057 ../gui/wxpython/menustrings.py:1453
+msgid "Reproject vector map from different GRASS location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:555
+#: ../gui/wxpython/menustrings.py:1058 ../gui/wxpython/menustrings.py:1454
+msgid "Re-projects a vector map from one location to the current location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1059
+msgid "Import 3D raster data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1060
+msgid "ASCII 3D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1061
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:85 ../gui/wxpython/menustrings.py:1062
+msgid "Raw binary array 3D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1063
+msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:1064
+msgid "Vis5D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:1065
+msgid "Import 3-dimensional Vis5D files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:1066
+msgid "Import database table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1068
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1069
+msgid "Export raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:122
+#: ../gui/wxpython/menustrings.py:148 ../gui/wxpython/menustrings.py:1070
+#: ../gui/wxpython/menustrings.py:1099 ../gui/wxpython/menustrings.py:1125
+msgid "Common export formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1071
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1072
+msgid "ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1073
+msgid "Converts a raster map layer into a GRASS ASCII text file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1074
+msgid "ASCII x,y,z points export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1075
+msgid ""
+"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1076
+msgid "GRIDATB.FOR export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1077
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1078
+msgid "Matlab 2D array export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:1079
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1080
+msgid "Raw binary array export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1081
+msgid "Exports a GRASS raster to a binary array."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1082
+msgid "MPEG-1 export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1083
+msgid "Converts raster map series to MPEG movie."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1084
+msgid "PNG export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1085
+msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1086
+msgid "PPM export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1087
+msgid "Converts a GRASS raster map to a PPM image file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1088
+msgid "PPM from RGB export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1089
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:130
+#: ../gui/wxpython/menustrings.py:1090 ../gui/wxpython/menustrings.py:1107
+msgid "POV-Ray export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1091
+msgid "Converts a raster map layer into a height-field file for POV-Ray."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1092
+msgid "VRML export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1093
+msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:134
+#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1094
+#: ../gui/wxpython/menustrings.py:1111 ../gui/wxpython/menustrings.py:1122
+msgid "VTK export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1095
+msgid "Converts raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1096
+msgid "Pack raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1097
+msgid "Exports a raster map as GRASS GIS specific archive file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1098
+msgid "Export vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1100
+msgid ""
+"Exports a vector map layer to any of the supported OGR vector formats. By "
+"default a vector map layer is exported to Esri Shapefile format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:1101
+msgid "ASCII points or GRASS ASCII vector export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1102
+msgid ""
+"Exports a vector map to a GRASS ASCII vector representation. By default only "
+"features with category are exported. To export all features use 'layer=-1'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1103
+msgid "DXF export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1104
+msgid "Exports vector map to DXF file format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:1105
+msgid "PostGIS export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1106
+msgid "Exports a vector map layer to PostGIS feature table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1108
+msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1109
+msgid "SVG export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:133 ../gui/wxpython/menustrings.py:1110
+msgid "Exports a vector map to SVG file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:135 ../gui/wxpython/menustrings.py:1112
+msgid "Converts a vector map to VTK ASCII output."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1113
+msgid "Pack vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1114
+msgid "Exports a vector map as GRASS GIS specific archive file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1115
+msgid "Export 3D raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1116
+msgid "ASCII 3D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1117
+msgid "Converts a 3D raster map layer into a ASCII text file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1118
+msgid "Raw binary array 3D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1119
+msgid "Exports a GRASS 3D raster map to a binary array."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1120
+msgid "Vis5D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:144 ../gui/wxpython/menustrings.py:1121
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1123
+msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1124
+msgid "Export database table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1126
+msgid "Exports attribute tables into various formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1127
+msgid "Link external data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1129
+msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1131
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1132
+msgid "Output format for raster data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1133
+msgid "Defines raster output format utilizing GDAL library."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1134
+msgid "Output format for vector data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1135
+msgid "Defines vector output format utilizing OGR library."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1136
+msgid "Manage maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1137
+msgid "Copy"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1138
+msgid ""
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:921
+#: ../gui/wxpython/menustrings.py:1139 ../gui/wxpython/menustrings.py:1820
+msgid "List"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1140
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1142
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1144
+msgid ""
+"Removes data base element files from the user's current mapset using the "
+"search pattern."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:298
+#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:824
+#: ../gui/wxpython/menustrings.py:1197 ../gui/wxpython/menustrings.py:1491
+#: ../gui/wxpython/menustrings.py:1723
+msgid "Map type conversions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:299
+#: ../gui/wxpython/menustrings.py:1198
+msgid "Raster to vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:300
+#: ../gui/wxpython/menustrings.py:1199
+msgid "Converts a raster map into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:301
+#: ../gui/wxpython/menustrings.py:1200
+msgid "Raster series to 3D raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:302
+#: ../gui/wxpython/menustrings.py:1201
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:303
+#: ../gui/wxpython/menustrings.py:1202
+msgid "Raster 2.5D to 3D raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:304
+#: ../gui/wxpython/menustrings.py:1203
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:593
+#: ../gui/wxpython/menustrings.py:1492
+msgid "Vector to raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:594
+#: ../gui/wxpython/menustrings.py:1493
+msgid "Converts (rasterize) a vector map into a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:595
+#: ../gui/wxpython/menustrings.py:1494
+msgid "Vector to 3D raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:596
+#: ../gui/wxpython/menustrings.py:1495
+msgid "Converts a vector map (only points) into a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:597
+#: ../gui/wxpython/menustrings.py:1496
+msgid "2D vector to 3D vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:598
+#: ../gui/wxpython/menustrings.py:1497
+msgid "Performs transformation of 2D vector features to 3D."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:181
+msgid "3D raster to raster series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:826
+#: ../gui/wxpython/menustrings.py:1725
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:1900
+msgid "Georectify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:1901
+msgid "Manage Ground Control Points for Georectification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:1902
+msgid "Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:1903
+msgid "Launch Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:1951
+msgid "Run model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:188
+msgid "Run model prepared by Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:189
+msgid "3D image rendering"
+msgstr ""
+msgid ""
+"Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D "
+"vector data, and volumes (3D raster data) in 3D."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:993
+#: ../gui/wxpython/menustrings.py:1892 ../gui/wxpython/menustrings.py:1897
+msgid "Animation tool"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:994
+#: ../gui/wxpython/menustrings.py:1893 ../gui/wxpython/menustrings.py:1898
+msgid "Launch animation tool."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:193
+msgid "Bearing/distance to coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:194
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa. It assumes a cartesian coordinate system"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:1909
+msgid "Launch Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:1906
+msgid "Map Swipe"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:1907
+msgid "Launch Map Swipe"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:199
+msgid "Launch script"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:200
+msgid "Launches script file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:201
+msgid "Exit GUI"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:202
+msgid "Quit the GRASS wxGUI session."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1929
+msgid "&Settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:204
+msgid "Region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:205
+msgid "Display region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:208
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:207
+msgid "Set region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:209
+msgid "GRASS working environment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:210
+msgid "Mapset access"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:211
+msgid "Set/unset access to other mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:212
+msgid "User access"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:213
+msgid ""
+"Controls access to the current mapset for other users on the system. If no "
+"option given, prints current status."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:214
+msgid "Change working environment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:215
+msgid ""
+"Changes/reports current mapset. Optionally create new mapset or list "
+"available mapsets in given location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:216
+msgid "Change location and mapset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:217
+msgid "Change current location and mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:218
+msgid "Change mapset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:219
+msgid "Change current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:221
+msgid "Change working directory"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:222
+msgid "Show settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:223
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:224
+msgid "Change settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:225
+msgid ""
+"Outputs and modifies the user's current GRASS variable settings. Prints all "
+"defined GRASS variables if no option is given."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:226
+msgid "Create new location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:227
+msgid "Launches location wizard to create new GRASS location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:229
+msgid "Creates new mapset in the current location, changes current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:230
+msgid "Version and copyright"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:231
+msgid "Displays version and copyright information."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:232
+msgid "Map projections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:233
+msgid "Display map projection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:234
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:235
+msgid "Manage projections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:236
+msgid ""
+"Prints or modifies GRASS projection information files (in various co-"
+"ordinate system descriptions). Can also be used to create new GRASS "
+"locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:237
+msgid "Convert coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:238
+msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:239
+msgid "Addons extensions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:240
+msgid "Install extension from addons"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:241
+msgid "Installs new extension from GRASS AddOns SVN repository."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:242
+msgid "Manage installed extension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:243
+msgid "Updates or removes installed GRASS AddOns extension(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:244 ../gui/wxpython/menustrings.py:1930
+msgid "Preferences"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:245
+msgid "User GUI preferences (display font, commands, digitizer, etc.)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:246 ../gui/wxpython/menustrings.py:1145
+msgid "&Raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:247 ../gui/wxpython/menustrings.py:1146
+msgid "Develop raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:248 ../gui/wxpython/menustrings.py:1147
+msgid "Compress/decompress"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:249 ../gui/wxpython/menustrings.py:1148
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:250 ../gui/wxpython/menustrings.py:1149
+msgid "Region boundaries"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:251 ../gui/wxpython/menustrings.py:1150
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:252 ../gui/wxpython/menustrings.py:1151
+msgid "Manage NULL values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:253 ../gui/wxpython/menustrings.py:1152
+msgid "Manages NULL-values of given raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:254 ../gui/wxpython/menustrings.py:1153
+msgid "Quantization"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:255 ../gui/wxpython/menustrings.py:1154
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:256 ../gui/wxpython/menustrings.py:1155
+msgid "Timestamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:257 ../gui/wxpython/menustrings.py:1156
+msgid ""
+"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
+"raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:258 ../gui/wxpython/menustrings.py:1157
+msgid "Resample using aggregate statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:259 ../gui/wxpython/menustrings.py:1158
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:260 ../gui/wxpython/menustrings.py:1159
+msgid "Resample using multiple methods"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:261 ../gui/wxpython/menustrings.py:1160
+msgid "Resamples raster map to a finer grid using interpolation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:262 ../gui/wxpython/menustrings.py:1161
+msgid "Resample using nearest neighbor"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:263 ../gui/wxpython/menustrings.py:1162
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:264 ../gui/wxpython/menustrings.py:1163
+msgid "Resample using spline tension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:1164
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1165
+msgid "Resample using bspline"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1166
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1167
+msgid "Resample using analytic kernel"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1168
+msgid "Resamples raster map layers using an analytic kernel."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:556
+#: ../gui/wxpython/menustrings.py:1169 ../gui/wxpython/menustrings.py:1455
+msgid "Support file maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1170
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1171
+msgid "Update map statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1172
+msgid "Update raster map statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1175
+msgid "Tiling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1176
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:575
+#: ../gui/wxpython/menustrings.py:1177 ../gui/wxpython/menustrings.py:1474
+msgid "Manage colors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:576
+#: ../gui/wxpython/menustrings.py:1178 ../gui/wxpython/menustrings.py:1475
+msgid "Color tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1179
+msgid "Creates/modifies the color table associated with a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1180
+msgid "Color tables (stddev)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1181
+msgid "Sets color rules based on stddev from a raster map's mean value."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:578
+#: ../gui/wxpython/menustrings.py:1182 ../gui/wxpython/menustrings.py:1477
+msgid "Manage color rules interactively"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1183
+msgid "Interactive management of raster color tables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:580
+#: ../gui/wxpython/menustrings.py:1184 ../gui/wxpython/menustrings.py:1479
+msgid "Export color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1185
+msgid "Exports the color table associated with a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1186
+msgid "Blend 2 color rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1187
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:1188
+msgid "Create RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:1189
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:731
+#: ../gui/wxpython/menustrings.py:1190 ../gui/wxpython/menustrings.py:1630
+msgid "RGB to HIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1191
+msgid ""
+"Generates red, green and blue (RGB) raster map layers combining hue, "
+"intensity and saturation (HIS) values from user-specified input raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:293 ../gui/wxpython/menustrings.py:1192
+msgid "Query raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:294 ../gui/wxpython/menustrings.py:1193
+msgid "Query values by coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1194
+msgid "Queries raster maps on their category values and category labels."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1195
+msgid "Query colors by value"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:1196
+msgid "Queries colors for a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:1204
+msgid "Raster buffers and distance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1205
+msgid "Buffer rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1206
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1207
+msgid "Concentric circles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1208
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:1209
+msgid "Closest points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:1210
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1211
+msgid "Grow by one cell"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:376
+#: ../gui/wxpython/menustrings.py:1212 ../gui/wxpython/menustrings.py:1275
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:368
+#: ../gui/wxpython/menustrings.py:1213 ../gui/wxpython/menustrings.py:1267
+msgid "Distance to features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:369
+#: ../gui/wxpython/menustrings.py:1214 ../gui/wxpython/menustrings.py:1268
+msgid "Generates a raster map containing distances to nearest raster features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:317 ../gui/wxpython/menustrings.py:1216
+msgid "Creates a MASK for limiting raster operation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:318 ../gui/wxpython/menustrings.py:319
+#: ../gui/wxpython/menustrings.py:1217 ../gui/wxpython/menustrings.py:1218
+msgid "Raster map calculator"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:320 ../gui/wxpython/menustrings.py:1219
+msgid "Neighborhood analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:322 ../gui/wxpython/menustrings.py:1221
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:323 ../gui/wxpython/menustrings.py:1222
+msgid "Neighborhood points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1223
+msgid ""
+"Neighborhood analysis tool for vector point maps. Makes each cell value a "
+"function of the attribute values assigned to the vector points or centroids "
+"around it, and stores new cell values in an output raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1224
+msgid "Overlay rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1225
+msgid "Cross product"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1226
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1227
+msgid "Patch raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1228
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1229
+msgid "Raster series aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:1230
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1231
+msgid "Raster series accumulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1232
+msgid ""
+"Makes each output cell value a accumulationfunction of the values assigned "
+"to the corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1233
+msgid "Statistical overlay"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1234
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1235
+msgid "Quantiles overlay"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1236
+msgid "Compute category quantiles using two passes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1237
+msgid "Solar radiance and shadows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1238
+msgid "LatLong map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1239
+msgid "Creates a latitude/longitude raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1240
+msgid "Solar irradiance and irradiation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1241
+msgid ""
+"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
+"reflected solar irradiation raster maps for given day, latitude, surface and "
+"atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
+"declination, extraterrestrial irradiance, daylight length) are saved in the "
+"map history file. Alternatively, a local time can be specified to compute "
+"solar incidence angle and/or irradiance raster maps. The shadowing effect of "
+"the topography is optionally incorporated."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1242
+msgid "Shadows map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1243
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map. "
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1244
+msgid "Sunshine hours and solar angles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1245
+msgid ""
+"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
+"the angle between the direction of the geometric center of the sun's "
+"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due "
+"north in clockwise direction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1246
+msgid "Terrain analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1247
+msgid "Generate contour lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1248
+msgid "Produces a vector map of specified contours from a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1249
+msgid "Cost surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1250
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1251
+msgid "Cumulative movement costs"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1252
+msgid ""
+"Creates a raster map showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input raster map whose cell "
+"category values represent cost."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1253
+msgid "Least cost route or flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1254
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1255
+msgid "Compute shaded relief"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1256
+msgid "Creates shaded relief map from an elevation map (DEM). "
+msgstr ""
+#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1257
+msgid "Apply shade to raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1258
+msgid "Drapes a color raster over an shaded relief or aspect map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1259
+msgid "Slope and aspect"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1260
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from an elevation raster map. Aspect is calculated counterclockwise from "
+"east."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1261
+msgid "Terrain parameters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1262
+msgid ""
+"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
+"taking fitting quadratic parameters to any size window (via least squares)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1263
+msgid "Textural features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1264
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1265
+msgid "Visibility"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1266
+msgid ""
+"Computes the viewshed of a point on an elevation raster map. Default format: "
+"NULL (invisible), vertical angle wrt viewpoint (visible)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1269
+msgid "Horizon angle"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1270
+msgid ""
+"Computes horizon angle height from a digital elevation model. The module has "
+"two different modes of operation: 1. Computes the entire horizon around a "
+"single point whose coordinates are given with the 'coord' option. The "
+"horizon height (in radians). 2. Computes one or more raster maps of the "
+"horizon height in a single direction. The input for this is the angle (in "
+"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
+"output is the horizon height in radians."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1271
+msgid "Transform features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1272
+msgid "Clump"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1273
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1274
+msgid "Grow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1276
+msgid "Thin"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1277
+msgid "Thins non-null cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1278
+msgid "Hydrologic modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1279
+msgid "Carve stream channels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1280
+msgid ""
+"Generates stream channels. Takes vector stream data, transforms it to raster "
+"and subtracts depth from the output DEM."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1281
+msgid "Fill lake"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1282
+msgid "Fills lake at given point to given level."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1283
+msgid "Depressionless map and flowlines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1284
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1285
+msgid "Flow accumulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1286
+msgid "Performs flow computation for massive grids. Float version."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1287
+msgid "Flow lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1288
+msgid ""
+"Constructs flowlines. Computes flowlines, flowpath lengths, and "
+"flowaccumulation (contributing areas) from a elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1289
+msgid "Watershed analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1290
+msgid "Calculates hydrological parameters and RUSLE factors."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1291
+msgid "Watershed subbasins"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1292
+msgid "Generates watershed subbasins raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1293
+msgid "Watershed basin creation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1294
+msgid "Creates watershed basins from a drainage direction map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1295
+msgid "Extraction of stream networks"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1296
+msgid "Performs stream network extraction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1297
+msgid "SIMWE Overland flow modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1298
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1299
+msgid "SIMWE Sediment flux modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1300
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1301
+msgid "Topographic index map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1302
+msgid "Creates a topographic index raster map from an elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1303
+msgid "TOPMODEL simulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1304
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1305
+msgid "USLE K-factor"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1306
+msgid "Computes USLE Soil Erodibility Factor (K)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1307
+msgid "USLE R-factor"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1308
+msgid "Computes USLE R factor, Rainfall erosivity index."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:837
+#: ../gui/wxpython/menustrings.py:1309 ../gui/wxpython/menustrings.py:1736
+msgid "Groundwater modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1310
+msgid "Groundwater flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1311
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1312
+msgid "Groundwater solute transport"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1313
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1314
+msgid "Landscape patch analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1315
+msgid "Set up sampling and analysis framework"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1316
+msgid "Configuration editor for r.li.'index'"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1317
+msgid "Edge density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1318
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1319
+msgid "Contrast weighted edge density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1320
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1321
+msgid "Patch area mean"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1322
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1323
+msgid "Patch area range"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1324
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1325
+msgid "Patch area Std Dev"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1326
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1327
+msgid "Patch area Coeff Var"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1328
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1329
+msgid "Patch density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1330
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1331
+msgid "Patch number"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1332
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1333
+msgid "Dominance's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1334
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1335
+msgid "Shannon's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1336
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1337
+msgid "Simpson's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1338
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1339
+msgid "Richness"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1340
+msgid "Calculates richness index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1341
+msgid "Shape index"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1342
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1343
+msgid "Wildfire modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1344
+msgid "Rate of spread"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1345
+msgid ""
+"Generates rate of spread raster maps. Generates three, or four raster map "
+"layers showing the base (perpendicular) rate of spread (ROS), the maximum "
+"(forward) ROS, the direction of the maximum ROS, and optionally the maximum "
+"potential spotting distance for fire spread simulation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1346
+msgid "Least-cost spread paths"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1347
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1348
+msgid "Anisotropic spread simulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1349
+msgid ""
+"Simulates elliptically anisotropic spread. Generates a raster map of the "
+"cumulative time of spread, given raster maps containing the rates of spread "
+"(ROS), the ROS directions and the spread origins. It optionally produces "
+"raster maps to contain backlink UTM coordinates for tracing spread paths. "
+"Usable for fire spread simulations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1350
+msgid "Change category values and labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:504
+#: ../gui/wxpython/menustrings.py:1351 ../gui/wxpython/menustrings.py:1403
+msgid "Manage category information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:505
+#: ../gui/wxpython/menustrings.py:1352 ../gui/wxpython/menustrings.py:1404
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1353
+msgid "Interactively edit category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1354
+msgid "Edits cell values in a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1355
+msgid "Reclassify by size"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1356
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:664
+#: ../gui/wxpython/menustrings.py:1357 ../gui/wxpython/menustrings.py:1563
+msgid "Reclassify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1358
+msgid ""
+"Reclassify raster map based on category values. Creates a new raster map "
+"whose category values are based upon a reclassification of the categories in "
+"an existing raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1359
+msgid "Recode"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1360
+msgid "Recodes categorical raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1361
+msgid "Rescale"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1362
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1363
+msgid "Rescale with histogram"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1364
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1365
+msgid "Generate random cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1366
+msgid "Random cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1367
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1368
+msgid "Random cells and vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1369
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1370
+msgid "Generate surfaces"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1371
+msgid "Fractal surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1372
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1373
+msgid "Gaussian kernel density surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1374
+msgid ""
+"Generates a raster density map from vector points map. Density is computed "
+"using a moving kernel. Optionally generates a vector density map on a vector "
+"network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1375
+msgid "Gaussian deviates surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1376
+msgid ""
+"Generates a raster map using gaussian random number generator. Mean and "
+"standard deviation of gaussian deviates can be expressed by the user."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1377
+#: ../gui/wxpython/nviz/tools.py:4593
+msgid "Plane"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1378
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1379
+msgid "Random deviates surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1380
+msgid ""
+"Produces a raster surface map of uniform random deviates with defined range."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1381
+msgid "Random surface with spatial dependence"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1382
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1383
+msgid "Interpolate surfaces"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1384
+msgid "Bilinear and bicubic from vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1385
+msgid ""
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1386
+msgid "IDW from raster points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1387
+msgid ""
+"Provides surface interpolation from raster point data by Inverse Distance "
+"Squared Weighting."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1388
+msgid "IDW from vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1389
+msgid ""
+"Provides surface interpolation from vector point data by Inverse Distance "
+msgstr ""
+#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1390
+msgid "Raster contours"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1391
+msgid "Generates surface raster map from rasterized contours."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1392
+msgid "Regularized spline tension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1393
+msgid ""
+"Performs surface interpolation from vector points map by splines. Spatial "
+"approximation and topographic analysis from given point or isoline data in "
+"vector format to floating point raster format using regularized spline with "
+"tension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1394
+msgid "Raster series interpolation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1395
+msgid ""
+"Interpolates raster maps located (temporal or spatial) in between input "
+"raster maps at specific sampling positions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1396
+msgid "Ordinary or block kriging"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1397
+msgid "Performs ordinary or block kriging."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1398
+msgid "Fill NULL cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1399
+msgid "Fills no-data areas in raster maps using spline interpolation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:703
+#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:981
+#: ../gui/wxpython/menustrings.py:1400 ../gui/wxpython/menustrings.py:1602
+#: ../gui/wxpython/menustrings.py:1712 ../gui/wxpython/menustrings.py:1880
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1401
+msgid "Basic raster metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1402
+msgid "Outputs basic information about a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1405
+msgid "General statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1406
+msgid "Generates area statistics for raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1407
+msgid "Quantiles for large data sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1408
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1409
+msgid "Range of category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1410
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1411
+msgid "Sum area by raster map and category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1412
+msgid "Reports statistics for raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1413
+msgid "Statistics for clumped cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1414
+msgid ""
+"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
+"points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1415
+msgid "Total corrected area"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1416
+msgid "Prints estimation of surface area for raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1418
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map. "
+"Statistics include number of cells counted, minimum and maximum cell values, "
+"range, arithmetic mean, population variance, standard deviation, coefficient "
+"of variation, and sum."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1419
+msgid "Sample transects"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1420
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1421
+msgid "Sample transects (bearing/distance)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1422
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1423
+msgid "Covariance/correlation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1424
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map "
+"layer(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1425
+msgid "Linear regression"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1426
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1427
+msgid "Multiple regression"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1428
+msgid "Calculates multiple linear regression from raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1429
+msgid "Mutual category occurrences"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1430
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1431
+msgid "&Vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1432
+msgid "Develop vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1433
+#: ../gui/wxpython/gui_core/dialogs.py:234
+#: ../gui/wxpython/gui_core/dialogs.py:354
+msgid "Create new vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1434
+msgid "Create new empty vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1435
+msgid "Edit vector map (non-interactively)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1436
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1437
+msgid "Convert object types"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1438
+msgid "Changes type of vector features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1439
+msgid "Parallel lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1440
+msgid "Creates parallel line to input vector lines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1441
+msgid "Dissolve boundaries"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1442
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1443
+msgid "Create 3D vector over raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1444
+msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1445
+msgid "Extrude 3D vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1446
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height. "
+"Optionally the height can be derived from sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1447
+msgid "Create labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1448
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1449
+msgid "Reposition vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1450
+msgid ""
+"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1451
+msgid "Rectify vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1452
+msgid ""
+"Rectifies a vector by computing a coordinate transformation for each object "
+"in the vector based on the control points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1456
+msgid "Updates vector map metadata."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1457
+msgid "Topology maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1458
+msgid "Create or rebuild topology"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1459
+msgid ""
+"Creates topology for vector map. Optionaly also checks for topological "
+"errors."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1460
+msgid "Rebuild topology on all vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1461
+msgid "Rebuilds topology on all vector maps in the current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1462
+msgid "Build polylines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1463
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1464
+msgid "Split lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1465
+msgid "Splits vector lines to shorter segments."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1466
+msgid "Split polylines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1467
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1468
+msgid "Clean vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1469
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1470
+msgid "Smooth or simplify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1471
+msgid "Performs vector based generalization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1472
+msgid "Add centroids"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1473
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1476
+msgid "Creates/modifies the color table associated with a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1478
+msgid "Interactive management of vector color tables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1480
+msgid "Exports the color table associated with a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1481
+msgid "Query vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:583 ../gui/wxpython/menustrings.py:1482
+msgid "Query with coordinate(s)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1483
+msgid "Queries a vector map at given locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:880
+#: ../gui/wxpython/menustrings.py:1484 ../gui/wxpython/menustrings.py:1779
+msgid "Query vector attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:881
+#: ../gui/wxpython/menustrings.py:1485 ../gui/wxpython/menustrings.py:1780
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1486
+msgid "Feature selection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1487
+msgid "Select by attributes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1488
+msgid ""
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1489
+msgid "Select by another map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1490
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1498
+msgid "Buffer vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1499
+msgid "Creates a buffer around vector features of given type."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1500
+msgid "Lidar analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1501
+msgid "Identify and remove outliers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:603 ../gui/wxpython/menustrings.py:700
+#: ../gui/wxpython/menustrings.py:1502 ../gui/wxpython/menustrings.py:1599
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:604 ../gui/wxpython/menustrings.py:1503
+msgid "Detect edges"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:605 ../gui/wxpython/menustrings.py:1504
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:606 ../gui/wxpython/menustrings.py:1505
+msgid "Detect interiors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:607 ../gui/wxpython/menustrings.py:1506
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:608 ../gui/wxpython/menustrings.py:1507
+msgid "Correct and reclassify objects"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:609 ../gui/wxpython/menustrings.py:1508
+msgid ""
+"Corrects the v.lidar.growing output. It is the last of the three algorithms "
+"for LIDAR filtering."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1509
+msgid "Linear referencing"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1510
+msgid "Create LRS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1511
+msgid "Creates a linear reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:1512
+msgid "Create stationing"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:1513
+msgid "Creates stationing from input lines, and linear reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1514
+msgid "Create points/segments"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1515
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1516
+msgid "Find line id and offset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1517
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1518
+msgid "Nearest features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:1519
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:621 ../gui/wxpython/menustrings.py:1520
+msgid "Network analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:623 ../gui/wxpython/menustrings.py:1522
+msgid "Tool for interactive vector network analysis."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:624 ../gui/wxpython/menustrings.py:1523
+msgid "Network preparation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:625 ../gui/wxpython/menustrings.py:1524
+msgid "Performs network maintenance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:626 ../gui/wxpython/menustrings.py:1525
+msgid "Allocate subnets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:627 ../gui/wxpython/menustrings.py:1526
+msgid ""
+"Allocates subnets for nearest centers (direction from center). center node "
+"must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:628 ../gui/wxpython/menustrings.py:1527
+msgid "Split net"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1528
+msgid ""
+"Splits net by cost isolines. Splits net to bands between cost isolines "
+"(direction from center). Center node must be opened (costs >= 0). Costs of "
+"center node are used in calculation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1529
+msgid "Shortest path"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1530
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:1531
+msgid "Shortest path for sets of features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1532
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features. Finds the shortest paths from each 'from' point to the nearest "
+"'to' feature and various information about this relation are uploaded to the "
+"attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1533
+msgid "Shortest path using timetables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1534
+msgid "Finds shortest path using timetables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1535
+msgid "Shortest path for all pairs"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1536
+msgid "Computes the shortest path between all pairs of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1537
+msgid "Visibility network"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1538
+msgid "Performs visibility graph construction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1539
+msgid "Bridges and articulation points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1540
+msgid "Computes bridges and articulation points in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1541
+msgid "Maximum flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1542
+msgid "Computes the maximum flow between two sets of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1543
+msgid "Vertex connectivity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1544
+msgid "Computes vertex connectivity between two sets of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1545
+msgid "Components"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1546
+msgid "Computes strongly and weakly connected components in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1547
+msgid "Centrality"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1548
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1549
+msgid "Steiner tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:651 ../gui/wxpython/menustrings.py:1550
+msgid ""
+"Creates Steiner tree for the network and given terminals. Note that 'Minimum "
+"Steiner Tree' problem is NP-hard and heuristic algorithm is used in this "
+"module so the result may be sub optimal."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1551
+msgid "Minimum spanning tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1552
+msgid "Computes minimum spanning tree for the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1553
+msgid "Traveling salesman analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1554
+msgid ""
+"Creates a cycle connecting given nodes (Traveling salesman problem). Note "
+"that TSP is NP-hard, heuristic algorithm is used by this module and created "
+"cycle may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:657
+#: ../gui/wxpython/menustrings.py:1555 ../gui/wxpython/menustrings.py:1556
+msgid "Overlay vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1557
+msgid "Overlays two vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1558
+msgid "Patch vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1559
+msgid "Creates a new vector map by combining other vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1560
+msgid "Manage categories"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1561
+msgid "Change or report categories"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1562
+msgid "Attaches, deletes or reports vector categories to map geometry."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1564
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1566
+msgid "Update area attributes from raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1567
+msgid ""
+"Calculates univariate statistics from a raster map based on a vector map and "
+"uploads statistics to new attribute columns."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1568
+msgid "Update area attributes from vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1569
+msgid "Count points in areas, calculate statistics from point attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1570
+msgid "Update point attributes from areas"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1571
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1572
+msgid "Update database values from vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1573
+msgid "Populates attribute values from vector features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1574
+msgid "Sample raster maps at point locations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1575
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1576
+msgid "Sample raster neighborhood around points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1577
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1578
+msgid "Generate area for current region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1579
+msgid "Creates a vector polygon from the current region extent."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1580
+msgid "Generate areas from points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1581
+msgid "Convex hull"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1582
+msgid "Produces a 2D/3D convex hull for a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1583
+msgid "Delaunay triangles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:1584
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:686 ../gui/wxpython/menustrings.py:1585
+msgid "Voronoi diagram/Thiessen polygons"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1586
+msgid ""
+"Creates a Voronoi diagram in current region from an input vector map "
+"containing points or centroids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1587
+msgid "Generate grid"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1588
+msgid "Creates a vector map of a user-defined grid."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1589
+msgid "Generate points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1590
+msgid "Generate from database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1591
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:693 ../gui/wxpython/menustrings.py:1592
+msgid "Generate points along lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1593
+msgid "Creates points along input lines in new vector map with 2 layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:695 ../gui/wxpython/menustrings.py:1594
+msgid "Generate random points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1595
+msgid "Generates random 2D/3D vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1596
+msgid "Perturb points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1597
+msgid "Random location perturbations of vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1598
+msgid "Remove outliers in point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1600
+msgid "Test/training point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1601
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1603
+msgid "Basic vector metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1604
+msgid "Outputs basic information about a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1605
+msgid "Classify attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1606
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1607
+msgid "Report topology by category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1608
+msgid "Reports geometry statistics for vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1609
+msgid "Univariate attribute statistics for points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1610
+msgid ""
+"Calculates univariate statistics of vector map features. Variance and "
+"standard deviation is calculated only for points if specified."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1611
+msgid "Univariate statistics for attribute columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1612
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1613
+msgid "Quadrat indices"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1614
+msgid "Indices for quadrat counts of vector point lists."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1615
+msgid "Test normality"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1616
+msgid "Tests for normality for vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1617
+msgid "&Imagery"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1618
+msgid "Develop images and groups"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1619
+msgid "Create/edit group"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1620
+msgid "Creates, edits, and lists groups of imagery files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1621
+msgid "Target group"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1622
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1623
+msgid "Mosaic images"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1624
+msgid "Mosaics several images and extends colormap."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1625
+msgid "Manage image colors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1626
+msgid "Color balance for RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1627
+msgid "Performs auto-balancing of colors for RGB images."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:729 ../gui/wxpython/menustrings.py:1628
+msgid "HIS to RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1629
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:732 ../gui/wxpython/menustrings.py:1631
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1632
+msgid "Rectify image or raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1633
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1635
+msgid "Generate histogram of image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1636
+msgid "Spectral response"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1637
+msgid ""
+"Displays spectral response at user specified locations in group or images."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1638
+msgid "Pan sharpening"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1639
+msgid ""
+"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
+"channels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1640
+msgid "Classify image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1641
+msgid "Clustering input for unsupervised classification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1642
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm. The resulting signature file is used as input for i."
+"maxlik, to generate an unsupervised image classification."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1643
+msgid "Input for supervised MLC"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1644
+msgid "Generates statistics for i.maxlik from raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1645
+msgid "Maximum likelihood classification (MLC)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1646
+msgid ""
+"Classifies the cell spectral reflectances in imagery data. Classification is "
+"based on the spectral signature information generated by either i.cluster, g."
+"gui.iclass, or i.gensig."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1647
+#: ../gui/wxpython/menustrings.py:1904
+msgid "Interactive input for supervised classification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1648
+#: ../gui/wxpython/menustrings.py:1905
+msgid ""
+"Generates spectral signatures by allowing the user to outline training areas."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1649
+msgid "Input for supervised SMAP"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1650
+msgid "Generates statistics for i.smap from raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1651
+msgid "Sequential maximum a posteriori classification (SMAP)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1652
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1653
+msgid "Object segmentation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1654
+msgid "Identifies segments (objects) from imagery data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1655
+msgid "Filter image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1656
+msgid "Edge detection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1657
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1658
+msgid "Matrix/convolving filter"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/menustrings.py:1659
+msgid "Performs raster map matrix filter."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1660
+msgid "Transform image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1661
+msgid "Canonical correlation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1662
+msgid "Canonical components analysis (CCA) program for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:764 ../gui/wxpython/menustrings.py:1663
+msgid "Principal components"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1664
+msgid "Principal components analysis (PCA) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1665
+msgid "Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1666
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1667
+msgid "Inverse Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1668
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1669
+msgid "Satellite images tools"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1670
+msgid "Aster DN to radiance/reflectance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1671
+msgid ""
+"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
+"from ASTER DN."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1672
+msgid "Landsat DN to radiance/reflectance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1673
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+/OLI"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1674
+msgid "Landsat cloud cover assessment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1675
+msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1676
+msgid "Modis quality control"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1677
+msgid "Extracts quality control parameters from MODIS QC layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1678
+msgid "Atmospheric correction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1679
+msgid ""
+"Performs atmospheric correction using the 6S algorithm. 6S - Second "
+"Simulation of Satellite Signal in the Solar Spectrum."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1680
+msgid "Topographic correction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1681
+msgid "Computes topographic correction of reflectance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1682
+msgid "Satellite images products"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1683
+msgid "Vegetation indices"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1684
+msgid ""
+"Calculates different types of vegetation indices. Uses red and nir bands "
+"mostly, and some indices require additional bands."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1685
+msgid "Tasseled cap vegetation index"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1686
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1687
+msgid "Albedo"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1688
+msgid "Computes broad band albedo from surface reflectance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1689
+msgid "Emissivity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1690
+msgid "Computes emissivity from NDVI, generic method for sparse land."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1691
+msgid "Biomass growth"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1692
+msgid "Computes biomass growth, precursor of crop yield calculation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1693
+msgid "Evapotranspiration calculation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1694
+msgid "Instantaneaous Net Radiation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1695
+msgid "Net radiation approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1696
+msgid "Soil heat flux"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1697
+msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1698
+msgid "Sensible heat flux"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1699
+msgid "Computes sensible heat flux iteration SEBAL 01."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1700
+msgid "Evaporative fraction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1701
+msgid ""
+"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
+"moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1702
+msgid "Actual Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1703
+msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1704
+msgid "Temporal integration of ETa"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1705
+msgid ""
+"Computes temporal integration of satellite ET actual (ETa) following the "
+"daily ET reference (ETo) from meteorological station(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1706
+msgid "Hargreaves methods Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1707
+msgid ""
+"Computes evapotranspiration calculation modified or original Hargreaves "
+"formulation, 2001."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1708
+msgid "Penman-Monteith Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1709
+msgid ""
+"Computes potential evapotranspiration calculation with hourly Penman-"
+"Monteith."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1710
+msgid "Priestley-Taylor Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1711
+msgid ""
+"Computes evapotranspiration calculation Priestley and Taylor formulation, "
+"1972."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1713
+msgid "Kappa analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1714
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1715
+msgid "OIF for LandSat TM"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1716
+msgid "Calculates Optimum-Index-Factor table for spectral bands"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1717
+msgid "3D r&aster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1718
+msgid "Develop 3D raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1719
+msgid "Manage 3D NULL values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1720
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1721
+msgid "Manage timestamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1722
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1724
+msgid "3D rasters to raster series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1726
+msgid "3D color tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1727
+msgid "Creates/modifies the color table associated with a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1728
+msgid "Export 3D color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1729
+msgid "Exports the color table associated with a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1730
+msgid "3D mask"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1731
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:834
+#: ../gui/wxpython/menustrings.py:1732 ../gui/wxpython/menustrings.py:1733
+msgid "3D raster map calculator"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1734
+msgid "Cross section"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1735
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1737
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1738
+msgid "Interpolate 3D raster from points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1739
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1740
+msgid "Reports and Statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1741
+msgid "Basic 3D raster metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1742
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1743
+msgid "3D raster statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1744
+msgid "Generates volume statistics for 3D raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1745
+msgid "Univariate statistics for 3D rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1746
+msgid ""
+"Calculates univariate statistics from the non-null cells of a 3D raster map. "
+msgstr ""
+#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1747
+msgid "&Database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1748
+msgid "Database information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1749
+msgid "List databases"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1750
+msgid "Lists all databases for a given driver and location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1751
+msgid "List drivers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:853 ../gui/wxpython/menustrings.py:1752
+msgid "Lists all database drivers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:1753
+msgid "List tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:855 ../gui/wxpython/menustrings.py:1754
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1755
+msgid "Describe table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1756
+msgid "Describes a table in detail."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1757
+msgid "List columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1758
+msgid "List all columns for a given table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1759
+msgid "Manage databases"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1760
+msgid "Connect"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1761
+msgid "Prints/sets general DB connection for current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1762
+msgid "Login"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1763
+msgid "Sets user/password for DB driver/database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1764
+msgid "Create database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:866 ../gui/wxpython/menustrings.py:1765
+msgid "Creates an empty database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1766
+msgid "Drop database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1767
+msgid "Removes an existing database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1768
+msgid "Drop table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1769
+msgid "Drops an attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1770
+msgid "Copy table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1771
+msgid ""
+"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:893
+#: ../gui/wxpython/menustrings.py:1772 ../gui/wxpython/menustrings.py:1792
+msgid "Drop column"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1773
+msgid "Drops a column from selected attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1774
+msgid "Test"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1775
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1777
+msgid "Query any table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1778
+msgid "Selects data from attribute table. Performs SQL query statement(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1781
+msgid "SQL statement"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1782
+msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1783
+msgid "Vector database connections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1784
+msgid "New table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1785
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1786
+msgid "Remove table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1787
+msgid "Removes existing attribute table of a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1788
+msgid "Join table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1789
+msgid "Joins a database table to a vector map table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1790
+msgid "Add columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1791
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1793
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1795
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1796
+msgid "Change values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1797
+msgid "Updates a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1798
+msgid "Drop row"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1799
+msgid "Removes a vector feature from a vector map through attribute selection."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1800
+msgid "Reconnect vectors to database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:1801
+msgid ""
+"Reconnects attribute tables for all vector maps from the current mapset to a "
+"new database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1802
+msgid "Set vector map - database connection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1803
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1804
+msgid "&Temporal"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:906 ../gui/wxpython/menustrings.py:1805
+msgid "Manage datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1807
+msgid "Creates a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:910 ../gui/wxpython/menustrings.py:1809
+msgid "Renames a space time dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1811
+msgid "Removes space time datasets from temporal database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1812
+msgid "Update metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1813
+msgid "Modifies the metadata of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1814
+msgid "Merge"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1815
+msgid "Merges several space time datasets into a single space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1816
+msgid "Temporally shift"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1817
+msgid "Shifts temporally the maps of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1818
+msgid "Snap maps of dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1819
+msgid "Snaps temporally the maps of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:922 ../gui/wxpython/menustrings.py:1821
+msgid "Lists space time datasets and maps registered in the temporal database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1822
+msgid "Manage maps in datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:924 ../gui/wxpython/menustrings.py:1823
+msgid "Register maps in datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:925 ../gui/wxpython/menustrings.py:1824
+msgid "Registers raster, vector and raster3d maps in a space time datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1825
+msgid "Unregister maps from datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1826
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1827
+msgid "List raster dataset maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1828
+msgid "Lists registered maps of a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1829
+msgid "List vector dataset maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1830
+msgid "Lists registered maps of a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1831
+msgid "List raster3D dataset maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1832
+msgid "Lists registered maps of a space time raster3d dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1833
+msgid "Import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1834
+msgid "Import raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1835
+msgid "Imports space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1836
+msgid "Import vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1837
+msgid ""
+"Imports a space time vector dataset from a GRASS GIS specific archive file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:940 ../gui/wxpython/menustrings.py:1839
+msgid "Export raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1840
+msgid "Exports space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1841
+msgid "Export raster dataset as VTK time series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1842
+msgid "Exports space time raster dataset as VTK time series."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1843
+msgid "Export vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1844
+msgid "Exports a space time vector dataset as GRASS GIS specific archive file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:946 ../gui/wxpython/menustrings.py:1845
+msgid "Convert raster dataset to 3D raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1846
+msgid "Converts a space time raster dataset into a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1847
+msgid "Extraction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1848
+msgid "Extract subset of raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1849
+msgid "Extracts a subset of a space time raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1850
+msgid "Extract subset of vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:952 ../gui/wxpython/menustrings.py:1851
+msgid "Extracts a subset of a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1852
+msgid "Extract subset of raster3D dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1853
+msgid "Extracts a subset of a space time 3D raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1854
+msgid "Query vector dataset attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1855
+msgid ""
+"Prints attributes of vector maps registered in a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1856
+msgid "Raster dataset color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1857
+msgid ""
+"Creates/modifies the color table associated with each raster map of the "
+"space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1858
+msgid "Raster calculations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1859
+msgid ""
+"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
+"space time raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1860
+msgid "Raster3D calculations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1861
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
+"datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1862
+msgid "Interpolate gaps in raster datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1863
+msgid ""
+"Replaces gaps in a space time raster dataset with interpolated raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1864
+msgid "Aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1865
+msgid "Neighborhood analysis in raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1866
+msgid ""
+"Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:968 ../gui/wxpython/menustrings.py:1867
+msgid "Aggregation in raster datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1868
+msgid ""
+"Performs different aggregation algorithms from r.series on all or a subset "
+"of raster maps in a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1869
+msgid "Temporal aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1870
+msgid ""
+"Aggregates temporally the maps of a space time raster dataset by a user "
+"defined granularity."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1871
+msgid "Temporal aggregation by dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1872
+msgid ""
+"Aggregates data of an existing space time raster dataset using the time "
+"intervals of a second space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1873
+msgid "Sampling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1874
+msgid "Temporal sampling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1875
+msgid ""
+"Samples the input space time dataset(s) with a sample space time dataset and "
+"print the result to stdout."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1876
+msgid "Query raster dataset by vector points dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1877
+msgid ""
+"Stores raster map values at spatial and temporal positions of vector points "
+"as vector attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1878
+msgid "Observe specific locations in raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1879
+msgid ""
+"Observes specific locations in a space time raster dataset over a period of "
+"time using vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1881
+msgid "Space time datasets metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1882
+msgid "Lists information about space time datasets and maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1883
+msgid "Univariate raster dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1884
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"raster map of a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1885
+msgid "Univariate vector dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1886
+msgid ""
+"Calculates univariate statistics of attributes for each registered vector "
+"map of a space time vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1887
+msgid "Univariate raster3D dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1888
+msgid ""
+"3D raster map of a space time 3D raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1889
+msgid "Report temporal topology"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1890
+msgid "Lists temporal topology of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1891
+#: ../gui/wxpython/menustrings.py:1896
+msgid "GUI tools"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1894
+msgid "Timeline tool"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1895
+msgid "Plot temporal extents."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1955
+#: ../gui/wxpython/menustrings.py:1998
+msgid "&Help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:998
+msgid "GRASS help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1001
+msgid "Display the HTML man pages of GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1000
+msgid "GUI help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1002
+msgid "About system"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1003
+msgid "Prints system information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1005
+#: ../gui/wxpython/gui_core/ghelp.py:47
+msgid "About GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1008
+msgid "Import, export and link data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1899
+msgid "Attribute table manager"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1914
+msgid "Create new model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1916
+msgid "Load model from file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1920
+msgid "Save model to file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1922
+msgid "Close model file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1923
+msgid "Export to image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1924
+msgid "Export model to image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1925
+msgid "Export to Python"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1926
+msgid "Export model to Python script"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1927
+msgid "Quit modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1928
+msgid "Close modeler window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1932
+msgid "&Model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1933
+msgid "Add command"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1934
+msgid "Add action (GRASS command) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1935
+msgid "Add data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1936
+msgid "Add data item to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1937
+msgid "Define relation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1938
+msgid "Define relation between data and action items"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1939
+msgid "Add loop / series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1940
+msgid "Adds loop (series) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1941
+msgid "Add condition"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1942
+msgid "Adds condition (if/else) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1944
+msgid "Adds comment to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1945
+msgid "Remove item"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1946
+msgid "Remove action/data from model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1948
+msgid "Model properties (name, purpose, etc.)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1949
+msgid "Delete intermediate data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1950
+msgid "Delete intermediate data defined in the model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1952
+msgid "Run entire model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1953
+msgid "Validate model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1954
+msgid "Validate entire model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1956 ../gui/wxpython/menustrings.py:1999
+#: ../gui/wxpython/timeline/frame.py:128
+msgid "Help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1957
+msgid "Display the HTML man pages of Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1958
+msgid "About Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1959
+msgid "Display information about Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1965
+msgid "Load instruction file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1967
+msgid "Export instruction file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1969
+msgid "Export to PostScript"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1971
+msgid "Export to PDF"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1973 ../gui/wxpython/menustrings.py:1974
+msgid "Launch ps.map dialog"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1976
+msgid "Close Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1977
+msgid "&Insert"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1979
+msgid "Add or edit map frame"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1981
+msgid "Add or edit raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1983
+msgid "Add or edit vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1984
+msgid "Map legend"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1985
+msgid "Add or edit raster and vector legend"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1987
+msgid "Add or edit map info"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1989
+msgid "Add or edit scale bar"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1995
+msgid "Add north arrow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2000
+msgid "Display the HTML man pages of Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2001
+msgid "About Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2002
+msgid "Display information about Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:114
+msgid "Click here to show search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:115
+msgid "Click here to hide search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:130
+msgid "Command prompt"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:132
+msgid "Output window"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:139
+msgid "Clear output window content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:141
+msgid "Clear command prompt content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:143
+msgid "Save output window content to the file"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:145
+msgid "Abort running command"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:147
+msgid "&Log file"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:149
+msgid ""
+"Toggle to save list of executed commands into a file; content saved when "
+"switching off."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:374
+#: ../gui/wxpython/gui_core/goutput.py:461
+msgid "Save file as..."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:376
+#: ../gui/wxpython/gui_core/goutput.py:463
+#, python-format
+msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:377
+#: ../gui/wxpython/gui_core/goutput.py:464
+msgid "Text files"
+msgstr ""
+msgid "Files"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:389
+#, python-format
+msgid ""
+"Unable to write file '%(path)s'.\n"
+"\n"
+"Details: %(error)s"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:392
+#, python-format
+msgid "Command output saved into '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:442
+#: ../gui/wxpython/core/gconsole.py:695
+#, python-format
+msgid ""
+"Unable to write file '%(filePath)s'.\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:447
+#, python-format
+msgid "Command log saved to '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:141
+msgid "Double-click or Ctrl-Enter to run selected module"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:159
+msgid "Run selected module from the tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:57
+msgid "User settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:80
+msgid "Set to default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:88
+msgid "Revert settings to default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:90
+msgid "Apply changes for the current session only and close"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:91
+msgid "Save for this session only"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:152
+msgid "Settings applied to current session but not saved"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:211
+msgid "Key column cannot be empty string."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:225
+msgid "GUI Settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:252
+msgid "Layer Manager settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:262
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:272
+msgid "Ask when quiting wxGUI or closing display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:282
+#: ../gui/wxpython/gui_core/preferences.py:292
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
+msgstr ""
+msgid "Search module"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:305
+msgid "Automatically copy selected text to clipboard (in Command console)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:320
+msgid "Workspace settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:327
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:339
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:350
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:353
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:372
+#: ../gui/wxpython/nviz/tools.py:96
+msgid "Appearance"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:389
+msgid "Font for command output:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:403
+msgid "Language settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:412
+msgid "Choose language (requires to save and GRASS restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:437
+msgid "Appearance settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:447
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:469
+msgid "Menu style (requires to save and GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:493
+msgid "Height of map selection popup window (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:517
+msgid "Icon theme (requires GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:537
+msgid "Module dialog style:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:570
+msgid "Map Display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:584
+msgid "Default font for GRASS displays:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:602
+msgid "Default display settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:612
+msgid "Display driver:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:632
+msgid "Statusbar mode:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:697
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:710
+msgid "Enable auto-zooming to selected map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:723
+msgid "Mouse wheel action:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:738
+msgid "Mouse scrolling direction:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:764
+msgid "Advanced display settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:770
+msgid "3D view depth buffer (possible values are 16, 24, 32):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:802
+msgid "Modules"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:805
+msgid "Module dialog settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:826
+msgid "Close dialog when module is successfully finished"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:836
+#: ../gui/wxpython/gui_core/dialogs.py:271
+msgid "Add created map into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:847
+msgid "Allow interactive input"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:857
+msgid "Verbosity level:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:882
+msgid "Layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:888
+msgid "Default raster settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:898
+msgid "Make null cells opaque"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:909
+msgid "Default color table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:936
+msgid "Default vector settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:942
+msgid "Display:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:961
+msgid "Feature color:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:973
+#: ../gui/wxpython/gui_core/preferences.py:995
+#: ../gui/wxpython/gui_core/forms.py:1494
+msgid "Transparent"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:983
+msgid "Area fill color:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1026
+msgid "Symbol:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1079
+msgid "Line width (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1089
+msgid "Automatically hightlight selected features in map display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1109
+msgid "Data browser"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1114
+msgid "Left mouse double click:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1126
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1137
+msgid "Ask when deleting data record(s) from table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1158
+msgid "Create table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1165
+#: ../gui/wxpython/gui_core/dialogs.py:303
+msgid "Key column:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1199
+msgid "Projection statusbar settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1207
+msgid ""
+"\n"
+"Note: This only controls the coordinates displayed in the lower-left of the "
+"Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working "
+"location's\n"
+"projection in any way. You will need to enable the Projection check box in "
+"the drop-down\n"
+"menu located at the bottom of the Map Display window.\n"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1222
+#: ../gui/wxpython/location_wizard/wizard.py:1321
+msgid "EPSG code:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1239
+msgid "Proj.4 string (required):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1255
+msgid "EPSG file:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1270
+msgid ""
+"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
+"directly."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1278
+msgid "&Load EPSG codes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1290
+msgid "Coordinates format"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1298
+msgid "Lat/long projections"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1317
+msgid "Precision:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1382
+#, python-format
+msgid "Unable to read EPSG codes: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1411
+#: ../gui/wxpython/gui_core/preferences.py:1420
+#: ../gui/wxpython/gui_core/preferences.py:1429
+#, python-format
+msgid "EPSG code %s not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1437
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1449
+msgid "Failed to set default display font. Try different font."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1549
+msgid "Select font:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1573
+msgid "Character encoding:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1686
+msgid "Manage access to mapsets"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1699
+msgid ""
+"Check a mapset to make it accessible, uncheck it to hide it.\n"
+"  Notes:\n"
+"    - The current mapset is always accessible.\n"
+"    - You may only write to the current mapset.\n"
+"    - You may only write to mapsets which you own."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1772
+#: ../gui/wxpython/gui_core/gselect.py:493
+msgid "Mapset"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1773
+msgid "Owner"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:28
+msgid "Query results"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:40
+msgid "Right click to copy selected values to clipboard."
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:44
+msgid "Feature"
+msgstr ""
+msgid "Value"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:60
+msgid "Copy all to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:63
+msgid "Redirect to console"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:111 ../gui/wxpython/gui_core/query.py:112
+#, python-format
+msgid "Copy from '%s' column"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:113
+msgid "Copy selected lines"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:116 ../gui/wxpython/gui_core/query.py:119
+#, python-format
+msgid "Copy '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:120
+msgid "Copy line"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:142
+msgid "Query results:"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:145
+msgid " "
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:224
+msgid "east, north"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:235
+msgid "Nothing found"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:84
+msgid " (...)"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:881
+msgid "Fulltext search"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:882
+msgid "Type to search in all modules. Press Enter for next match."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:946
+msgid "Searching, please type more characters."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:955
+#, python-format
+msgid "%d modules match"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1030
+msgid "Save current settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1033
+msgid "Delete currently selected settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1053
+msgid "Load settings:"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1068
+#, python-format
+msgid "Settings <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1082
+#: ../gui/wxpython/gui_core/widgets.py:1098
+msgid "Save settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1087
+msgid "Name not given, settings is not saved."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1096
+#, python-format
+msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1146
+msgid "No settings is defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1180
+msgid "Unable to save settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:479
+msgid "Enter parameters for '"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:490
+msgid "Close this window without executing the command (Ctrl+Q)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:516
+msgid "Run the command (Ctrl+R)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:530
+#: ../gui/wxpython/modules/mcalc_builder.py:146
+msgid "Copy the current command string to the clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:538
+msgid "Show manual page of the command (Ctrl+H)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:569
+msgid "Add created map(s) into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:584
+#: ../gui/wxpython/gui_core/dialogs.py:1681
+msgid "Close dialog on finish"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:586
+msgid ""
+"Close dialog when command is successfully finished. Change this settings in "
+"Preferences dialog ('Command' tab)."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:753
+#, python-format
+msgid "'%s' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:824 ../gui/wxpython/gui_core/forms.py:837
+msgid "Required"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:827 ../gui/wxpython/gui_core/forms.py:837
+msgid "Optional"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:906
+#: ../gui/wxpython/gui_core/forms.py:1654
+msgid "Parameterized in model"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:969
+msgid "This option is required"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:986
+msgid "[multiple]"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1036
+msgid "valid range"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1301
+msgid "Show graphical representation of temporal extent of dataset(s) ."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1461 ../gui/wxpython/core/utils.py:998
+msgid "Select Color"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1523
+#: ../gui/wxpython/gui_core/forms.py:1587
+#, python-format
+msgid "Choose %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1552
+#: ../gui/wxpython/modules/mcalc_builder.py:143
+msgid "&Load"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1553
+msgid "Load and edit content of a file"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1555
+msgid "&Save as"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1556
+msgid "Save content to a file for further use"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1561
+msgid "or enter values directly:"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1563
+msgid ""
+"Enter file content directly instead of specifying a file. Temporary file "
+"will be automatically created."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1588
+#: ../gui/wxpython/gui_core/gselect.py:1320
+msgid "Directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1839
+msgid "Manual"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1880
+msgid "Nothing to load."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1888
+#, python-format
+msgid ""
+"Unable to load file.\n"
+"\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1914
+#: ../gui/wxpython/modules/colorrules.py:610
+msgid "Nothing to save."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1918
+msgid "Save input as..."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2227
+msgid "No dataset given."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2266 ../gui/wxpython/core/gcmd.py:701
+#, python-format
+msgid "Error in %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2380
+#, python-format
+msgid "Unable to parse command '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2386
+#, python-format
+msgid "%(cmd)s: parameter '%(key)s' not available"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2478
+msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:76
+msgid "Required item is not set."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:106
+msgid "Select GRASS location and mapset"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:118
+msgid "Location or mapset is not defined."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:125
+msgid "Name of GRASS location:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:131
+#: ../gui/wxpython/gui_core/dialogs.py:178
+msgid "Name of mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:156
+msgid "Select mapset in GRASS location"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:170
+msgid "Name of mapset is missing."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:205
+msgid "Name of vector map is missing."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:256
+msgid "Create attribute table"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:280
+msgid "Name of new vector map is missing."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:289
+msgid "Name for new vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:387
+#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:392
+#, python-format
+msgid ""
+"Invalid or empty key column.\n"
+"Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:420
+#, python-format
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:503
+msgid "Load region:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:507
+msgid "Save region:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:544
+msgid ""
+"Name cannot begin with '.' and must not contain space, quotes, '/', ''', "
+"'@', ',', '=', '*', and all other non-alphanumeric characters."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:559
+msgid "Create or edit imagery groups"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:592
+msgid "Apply changes to selected group and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:593
+msgid "Apply changes to selected group"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:594
+msgid "Close dialog, changes are not applied"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:635
+#: ../gui/wxpython/gui_core/dialogs.py:1382
+msgid ""
+"Put here a regular expression. Characters '.*' stand for anything, character "
+"'^' stands for the beginning and '$' for the end."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:642
+msgid "Select existing group or enter name of new group:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:653
+msgid "Edit/create subgroup"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:662
+msgid "Select existing subgroup or enter name of new subgroup:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:690
+#: ../gui/wxpython/gui_core/dialogs.py:743
+#: ../gui/wxpython/gui_core/dialogs.py:1369
+msgid "Pattern:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:705
+#: ../gui/wxpython/gui_core/dialogs.py:757
+#: ../gui/wxpython/gui_core/dialogs.py:1388
+msgid "List of maps:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:715
+msgid "Select map layers and add them to the list."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:719
+msgid "Remove selected layer(s) from list."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:762
+msgid "Check maps from group to be included into subgroup."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:922
+msgid "Add selected map layers into group"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1057
+#, python-format
+msgid "Group <%s> was changed, do you want to apply changes?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1059
+#: ../gui/wxpython/gui_core/dialogs.py:1071
+msgid "Unapplied changes"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1069
+#, python-format
+msgid "Subgroup <%s> was changed, do you want to apply changes?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1125
+msgid "No raster maps selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1154
+#, python-format
+msgid "No changes to apply in group <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1157
+#, python-format
+msgid "Group <%s> was successfully created."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1159
+#, python-format
+msgid "Group <%s> was successfully changed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1162
+#, python-format
+msgid "Creating of new group <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1164
+#, python-format
+msgid "Changing of group <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1202
+msgid "No group selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1208
+msgid "No subgroup selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1311
+msgid "Use fully-qualified map names"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1327 ../gui/wxpython/nviz/tools.py:563
+msgid "3D raster"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1337
+msgid "Map type:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1352
+msgid "Select toggle"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1359
+msgid "Mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1445
+msgid "Invert selection"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1579
+#, python-format
+msgid "Dynamic series (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1604
+msgid "Multiple import"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1621
+msgid "List of raster layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1623
+msgid "List of vector layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1625
+#, python-format
+msgid "List of %s layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1626
+msgid "right click to (un)select all"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1629
+msgid "Layer id"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1630
+#: ../gui/wxpython/web_services/widgets.py:860
+msgid "Layer name"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1631
+msgid "Name for output GRASS map (editable)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1634
+msgid "Projection match"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1640
+#: ../gui/wxpython/modules/extensions.py:71
+msgid "Options"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1672
+msgid "Encoding"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1692
+#: ../gui/wxpython/gui_core/dialogs.py:1886
+msgid "&Import"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1693
+#: ../gui/wxpython/gui_core/dialogs.py:1887
+msgid "Import selected layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1872
+msgid "this might not work for multiple bands"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1874
+#, python-brace-format
+msgid "Add linked layers into layer tree ({mightNotWork})"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1877
+msgid "Add imported layers into layer tree ({mightNotWork})"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1883
+msgid "&Link"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1884
+msgid "Link selected layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1896
+msgid "No layers selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2011
+msgid "Define output format for vector data"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2013
+msgid "Define output format for raster data"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2021
+msgid "Set external format and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2073
+msgid "No data source selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2086
+msgid "Import DXF layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2090
+msgid "Choose DXF file to import"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2096
+msgid "Add imported layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2110
+msgid "No layers selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2251
+msgid "Set Map Layer Opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2279
+msgid "opaque"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2375
+msgid "Set image size"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2384
+msgid "Image size"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2431
+msgid "Template:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2469
+msgid "GRASS GIS SQL Query Utility"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2480
+msgid " SQL statement "
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2525
+msgid "Symbols"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2552
+msgid "Symbol directory:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2560
+msgid "Symbol name:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:58
+msgid "Info"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:59
+msgid "Copyright"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:60
+msgid "License"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:61
+msgid "Authors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:62
+msgid "Contributors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:63
+msgid "Extra contributors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:64
+msgid "Translators"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:65
+msgid "Translation status"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:130
+msgid "Official GRASS site:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:141
+msgid "Code Revision"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:204 ../gui/wxpython/gui_core/ghelp.py:416
+msgid "Language"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:233 ../gui/wxpython/gui_core/ghelp.py:257
+#: ../gui/wxpython/gui_core/ghelp.py:281 ../gui/wxpython/gui_core/ghelp.py:338
+#: ../gui/wxpython/gui_core/ghelp.py:400 ../gui/wxpython/gui_core/ghelp.py:549
+#, python-format
+msgid "%s file missing"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:324 ../gui/wxpython/gui_core/ghelp.py:386
+#, python-format
+msgid "Error when reading file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:325 ../gui/wxpython/gui_core/ghelp.py:387
+msgid "Lines:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:343 ../gui/wxpython/gui_core/ghelp.py:345
+#: ../gui/wxpython/gui_core/ghelp.py:412
+msgid "E-mail"
+msgstr ""
+msgid "Country"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:345
+msgid "OSGeo_ID"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:420
+msgid "Nation"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:454
+#, python-format
+msgid "   %d translated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:458 ../gui/wxpython/gui_core/ghelp.py:484
+#, python-format
+msgid "   %d fuzzy"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:462 ../gui/wxpython/gui_core/ghelp.py:493
+#, python-format
+msgid "   %d untranslated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:475
+#, python-format
+msgid "%d translated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:546
+#, python-format
+msgid "File <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:701
+msgid "&Next"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:704
+msgid "&Previous"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:97
+msgid "Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:133
+msgid "Copy map names to clipboard (top to bottom)"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:134
+msgid "Copy map names to clipboard (bottom to top)"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:439
+msgid "Remove selected map(s) from list"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:441
+msgid "Layer up"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:442
+msgid "Move selected layer(s) up"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:444
+msgid "Layer down"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:445
+msgid "Move selected layer(s) down"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:447
+#: ../gui/wxpython/gui_core/simplelmgr.py:448
+msgid "Edit layer properties"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:450
+msgid "Change opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:451
+msgid "Change layer opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:36
+msgid "Display map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:37
+msgid "Re-render modified map layers only"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:39
+msgid "Render map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:40
+msgid "Force re-rendering all map layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:42
+msgid "Erase display"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:43
+msgid "Erase display canvas with given background color"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:45
+msgid "Pointer"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:47
+msgid "Zoom in"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:48
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:50
+msgid "Zoom out"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:51
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:53
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:55
+msgid "Various zoom options"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:56
+msgid "Zoom to default or saved region, save to named region, ..."
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:58
+msgid "Zoom to selected map layer(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:60
+msgid "Zoom to computational region extent"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:62
+msgid "Pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:63
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:65
+msgid "Save display to file"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:69
+msgid "Select font"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:79
+msgid "Add map elements"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:80
+msgid "Overlay elements like scale and legend onto map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:82
+msgid "Create histogram with d.histogram"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:256
+msgid "Select graphics tool"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:59
+#, python-format
+msgid ""
+"Unable to import pyGRASS: %s\n"
+"Some functionality will be not accessible"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:458
+msgid "Not selectable element"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:504
+msgid "Type: "
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:515
+#, python-format
+msgid "GSelect: invalid item: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1297
+msgid "Output settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1299
+msgid "Source settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1310
+msgid "Native"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1316
+msgid "File"
+msgstr "Tiedosto"
+#: ../gui/wxpython/gui_core/gselect.py:1328
+msgid "Protocol"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1339
+msgid "Output type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1341
+msgid "Source type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1361
+msgid "All files"
+msgstr "Kaikki tiedostot"
+#: ../gui/wxpython/gui_core/gselect.py:1377
+msgid "ZIP files"
+msgstr "ZIP tiedostot"
+#: ../gui/wxpython/gui_core/gselect.py:1378
+msgid "GZIP files"
+msgstr "GZIP tiedostot"
+#: ../gui/wxpython/gui_core/gselect.py:1379
+msgid "TAR files"
+msgstr "TAR tiedostot"
+#: ../gui/wxpython/gui_core/gselect.py:1381
+msgid "TARGZ files"
+msgstr "TARGZ tiedostot"
+#: ../gui/wxpython/gui_core/gselect.py:1387
+msgid "File:"
+msgstr "Tiedosto:"
+#: ../gui/wxpython/gui_core/gselect.py:1388
+msgid "Choose file to import"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1401
+#: ../gui/wxpython/gui_core/gselect.py:1463
+msgid "Choose input directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1415
+msgid "Extension:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1440
+msgid "Choose file"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1452
+#: ../gui/wxpython/gui_core/gselect.py:2121
+msgid "Feature type:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1453
+msgid "simple features"
+msgstr ""
+msgid "topological"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1559
+#: ../gui/wxpython/gui_core/gselect.py:1590
+#: ../gui/wxpython/gui_core/gselect.py:1641
+#: ../gui/wxpython/gui_core/gselect.py:1679
+msgid "Creation options:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1573
+#: ../gui/wxpython/gui_core/gselect.py:1612
+#: ../gui/wxpython/gui_core/gselect.py:1664
+msgid "Format:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1671
+msgid "Protocol:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1694
+msgid "No settings available"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1796
+#: ../gui/wxpython/web_services/dialogs.py:281
+msgid "No data source defined, settings are not saved."
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:2113
+msgid "LineString"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:38
+msgid ""
+"The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be "
+"installed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:70
+msgid "GRASS GIS Timeline Tool"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:126 ../gui/wxpython/nviz/tools.py:675
+#: ../gui/wxpython/nviz/tools.py:1555 ../gui/wxpython/nviz/preferences.py:368
+msgid "Draw"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:131
+msgid "3D plot of spatio-temporal extents"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:134
+msgid "3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:139
+msgid "Select space time dataset(s):"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:162
+#, python-format
+msgid "Dataset <%s> not found in temporal database"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:174
+msgid ""
+"Datasets have different temporal type (absolute x relative), which is not "
+"allowed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:189
+msgid "Datasets have different time unit which is not allowed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:264
+#, python-format
+msgid "X [%s]"
+msgstr "X [%s]"
+#: ../gui/wxpython/timeline/frame.py:265
+#, python-format
+msgid "Y [%s]"
+msgstr "Y [%s]"
+#: ../gui/wxpython/timeline/frame.py:267
+msgid "X"
+msgstr "X"
+#: ../gui/wxpython/timeline/frame.py:268
+msgid "Y"
+msgstr "Y"
+#: ../gui/wxpython/timeline/frame.py:325
+#, python-format
+msgid "Time [%s]"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:348 ../gui/wxpython/timeline/frame.py:440
+msgid "Invalid input data"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:413
+#, python-format
+msgid "Please specify the space time dataset <%s>."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:414
+msgid "Ambiguous dataset name"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:492
+#, python-format
+msgid "Space time raster dataset: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:494
+#, python-format
+msgid "Space time vector dataset: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:496
+#, python-format
+msgid "Space time 3D raster dataset: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:498
+#, python-format
+msgid "Mapset: %s"
+msgstr "Karttajoukko: %s"
+#: ../gui/wxpython/timeline/frame.py:499
+#, python-format
+msgid "Map name: %s"
+msgstr "Kartan nimi: %s"
+#: ../gui/wxpython/timeline/frame.py:500
+#, python-format
+msgid "Start time: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:501
+#, python-format
+msgid "End time: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:504
+msgid "WARNING: invalid topology"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:506
+msgid ""
+"\n"
+"Press Del to dismiss."
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:122
+msgid " Requested data settings "
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:149
+msgid "Request"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:154
+msgid "List of layers "
+msgstr "Tasojen lista"
+#: ../gui/wxpython/web_services/widgets.py:170
+msgid "Source projection:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:215
+msgid "Advanced request settings"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:222
+msgid "Order of layers in raster"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:232
+msgid "Reprojection method:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:236
+msgid "Nearest neighbor"
+msgstr ""
+msgid "Linear interpolation"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:237
+msgid "Cubic interpolation"
+msgstr ""
+msgid "Cubic spline interpolation"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:240
+msgid "Maximum columns to request from server at time:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:244
+msgid "Maximum rows to request from server at time:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:259
+msgid "Do not request transparent data"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:272
+msgid "Additional query parameters for server:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:479
+#, python-format
+msgid ""
+"Unable to download %s capabilities file\n"
+"from <%s>:\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:494
+#, python-format
+msgid ""
+"%s web service was not found in fetched capabilities file from <%s>:\n"
+"%s\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:769
+msgid "Source image format"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:803
+msgid "Select layer in layer list.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:808
+msgid "Select source image format.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:813
+msgid "Select source projection.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:817
+msgid "Choose output layer name.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:897
+msgid "layer"
+msgstr "taso"
+#: ../gui/wxpython/web_services/widgets.py:917
+msgid "style"
+msgstr "tyyli"
+#: ../gui/wxpython/web_services/widgets.py:1088
+msgid "Add default servers"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:1105
+#, python-format
+msgid ""
+"User defined server with same name as default server <%s> already exists.\n"
+"Keeping user defined server"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:90
+msgid " Server settings "
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:93
+msgid "Server:"
+msgstr "Palvelin:"
+#: ../gui/wxpython/web_services/dialogs.py:97
+msgid "&Connect"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:98
+msgid "Connect to the server"
+msgstr "Yhdistä palvelimeen"
+#: ../gui/wxpython/web_services/dialogs.py:102
+msgid "Show advanced connection settings"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:103
+msgid "Hide advanced connection settings"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:118
+msgid " Layer Manager Settings "
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:121
+msgid "Output layer name:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:236
+msgid "Username:"
+msgstr "Käyttäjänimi:"
+#: ../gui/wxpython/web_services/dialogs.py:240
+msgid "Password:"
+msgstr "Salasana:"
+#: ../gui/wxpython/web_services/dialogs.py:354
+#, python-format
+msgid "Connecting to <%s>..."
+msgstr "Yhdistetään <%s> ..."
+#: ../gui/wxpython/web_services/dialogs.py:420
+msgid "Available web services"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:428
+#, python-format
+msgid "Connected to <%s>"
+msgstr "Yhdistetty <%s>"
+#: ../gui/wxpython/web_services/dialogs.py:433
+#, python-format
+msgid "Unable to connect to <%s>"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:488
+msgid "Add selected web service layers as map layer into layer tree"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:581
+msgid "Web service layer properties"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:626
+msgid "&Apply"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:631
+msgid "&OK"
+msgstr "&OK"
+#: ../gui/wxpython/web_services/dialogs.py:793
+msgid "Name for output raster map:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:799
+msgid "Export region"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:806
+msgid "Named region"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:807
+msgid "Extent and resolution are based on Map Display geometry."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:809
+msgid "Extent and resolution are based on computational region."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:811
+msgid "Extent and resolution are based on named region."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:816
+msgid "Overwrite existing raster map"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:820
+msgid "Choose named region:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:829
+msgid "&Save layer"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:830
+msgid "Save web service layer as raster map"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:944
+msgid "Missing output raster."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:948
+msgid "Output map can be added only to current mapset."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:952
+#, python-format
+msgid "Output map <%s> already exists"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:972
+#, python-format
+msgid "Region <%s> does not exist."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:1000
+msgid "Downloading data..."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:1027
+msgid "Unable to fetch data.\n"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:74
+msgid "Check all"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:77
+msgid "Clear all"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:135
+msgid "Enter vector attribute values"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:292
+msgid "Bad color format. Use color format '0:0:0'"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:385
+msgid "Select vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:402
+msgid "Import or export color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:407
+msgid "Choose file to load color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:408
+msgid "Load"
+msgstr "Lataa"
+#: ../gui/wxpython/modules/colorrules.py:409
+msgid "Type filename or click to choose file and load color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:415
+msgid "Choose file to save color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:416
+msgid "Type filename or click to choose file and save color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:424
+msgid "&Set"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:431
+msgid "Load color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:435
+msgid "Load color table from file:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:438
+msgid "Save color table to file:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:467
+msgid "Reload default table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:527
+msgid "Show preview of map (current Map Display extent is used)."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:560
+#: ../gui/wxpython/modules/colorrules.py:1717
+msgid "No valid color rules given."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:643
+msgid "Invalid color table format"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:720
+#, python-format
+msgid "Invalid rule value '%s'. Unable to apply color table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:798
+msgid "Create new color table for raster map"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:874
+msgid "Enter raster category values or percents"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:880
+msgid "fp range"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:881
+#, python-format
+msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:969
+msgid "Create new color rules for vector map"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:981
+#: ../gui/wxpython/modules/colorrules.py:1512
+msgid "Enter vector attribute values or percents:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:983
+#: ../gui/wxpython/modules/colorrules.py:1514
+msgid "Enter vector attribute values:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:994
+msgid "Select vector columns"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:996
+msgid "Layer:"
+msgstr "Taso:"
+#: ../gui/wxpython/modules/colorrules.py:998
+msgid "Attribute column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1001
+msgid "Load color from column:"
+msgstr ""
+msgid "Save color to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1003
+msgid "Load size from column:"
+msgstr ""
+msgid "Save size to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1005
+msgid "Load width from column:"
+msgstr ""
+msgid "Save width to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1009
+msgid "Use color column instead of color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1024
+msgid "Add GRASSRGB column to current attribute table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1079
+#: ../gui/wxpython/modules/colorrules.py:1128
+msgid "Import or export color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1140
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file.  Do you "
+"want to create and connect new attribute table?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1143
+msgid "No database connection defined"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1215
+#, python-format
+msgid ""
+"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
+"table cannot be edited."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1368
+#, python-format
+msgid "%s column already exists."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1400
+msgid "Please wait, loading data from attribute table..."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1461
+#, python-format
+msgid ""
+"Number of loaded records reached %d, displaying all the records will be time-"
+"consuming and may lead to computer freezing, do you still want to continue?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1465
+msgid "Too many records"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1507
+#, python-format
+msgid "Enter vector attribute values or percents %s:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1509
+#, python-format
+msgid "Enter vector attribute values %s:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1651
+msgid "Please select column to save values to."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1687
+msgid "No color column defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1702
+msgid "Thematic mapping for vector map in 3D view"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:53
+msgid "GRASS GIS Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:56
+msgid "GRASS GIS 3D Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:67
+msgid "mapcalc statement"
+msgstr "mapcalc lauseke"
+#: ../gui/wxpython/modules/mcalc_builder.py:123
+msgid "Operators"
+msgstr "Operaattorit"
+#: ../gui/wxpython/modules/mcalc_builder.py:127
+msgid "Operands"
+msgstr "Operandit"
+#: ../gui/wxpython/modules/mcalc_builder.py:129
+msgid "Expression"
+msgstr "Lauseke"
+#: ../gui/wxpython/modules/mcalc_builder.py:141
+msgid "Save expression to file"
+msgstr "Tallenna lauseke tiedostoon"
+#: ../gui/wxpython/modules/mcalc_builder.py:144
+msgid "Load expression from file"
+msgstr "Lataa lauseke tiedostosta"
+#: ../gui/wxpython/modules/mcalc_builder.py:150
+msgid "exponent"
+msgstr "eksponentti"
+#: ../gui/wxpython/modules/mcalc_builder.py:152
+msgid "divide"
+msgstr "jaa"
+#: ../gui/wxpython/modules/mcalc_builder.py:154
+msgid "add"
+msgstr "lisää"
+#: ../gui/wxpython/modules/mcalc_builder.py:156
+msgid "subtract"
+msgstr "vähennä"
+#: ../gui/wxpython/modules/mcalc_builder.py:158
+msgid "modulus"
+msgstr "modulus"
+#: ../gui/wxpython/modules/mcalc_builder.py:160
+msgid "multiply"
+msgstr "kerro"
+#: ../gui/wxpython/modules/mcalc_builder.py:165
+msgid "left shift"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:167
+msgid "right shift"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:169
+msgid "right shift (unsigned)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:171
+msgid "greater than"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:173
+msgid "greater than or equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:175
+msgid "less than"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:177
+msgid "less than or equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:179
+msgid "equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:181
+msgid "not equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:184
+msgid "one's complement"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:186
+msgid "NOT"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:188
+msgid "bitwise AND"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:190
+msgid "bitwise OR"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:192
+msgid "logical AND"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:194
+msgid "logical AND (ignores NULLs)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:196
+msgid "logical OR"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:198
+msgid "logical OR (ignores NULLs)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:200
+msgid "conditional"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:213
+msgid "Name for new 3D raster map to create"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:215
+msgid "Name for new raster map to create"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:219
+msgid "Insert existing 3D raster map"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:221
+msgid "Insert existing raster map"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:225
+msgid "Insert mapcalc function"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:236
+msgid "Generate random seed for rand()"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:237
+msgid "Seed:"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:240
+msgid "Integer seed for rand() function"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:247
+msgid "Add created raster map into layer tree"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:549
+msgid "You must enter the name of a new raster map to create."
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:559
+msgid "You must enter an expression to create a new raster map."
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:616
+msgid "Choose a file name to save the expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:617
+#: ../gui/wxpython/modules/mcalc_builder.py:638
+msgid "Expression file (*)|*"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:637
+msgid "Choose a file name to load the expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:672
+msgid "'{cmd}' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:40
+msgid "Fetch & install extension from GRASS Addons"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:51
+msgid "Repository"
+msgstr "Etäkirjasto"
+#: ../gui/wxpython/modules/extensions.py:53
+msgid "List of extensions - double-click to install"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:95
+msgid "&Fetch"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:96
+msgid "Fetch list of available modules from GRASS Addons SVN repository"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:100
+msgid "&Install"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:101
+msgid "Install selected add-ons GRASS module"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:104
+msgid "Show g.extension manual page"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:168
+msgid "Extension not defined"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:191
+msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:213
+msgid "Install"
+msgstr "Asenna"
+#: ../gui/wxpython/modules/extensions.py:216
+msgid "Show manual page"
+msgstr "Näytä käsikirjan sivu"
+#: ../gui/wxpython/modules/extensions.py:315
+#, python-format
+msgid "Unable to load extensions. %s"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:356
+msgid "Manage installed GRASS Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:365
+msgid "List of installed extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:370
+msgid "Uninstall"
+msgstr "Poista asennus"
+#: ../gui/wxpython/modules/extensions.py:371
+msgid "Uninstall selected Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:372
+msgid "Reinstall"
+msgstr "Asenna uudelleen"
+#: ../gui/wxpython/modules/extensions.py:373
+msgid "Reinstall selected Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:410
+msgid "No extension selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:427
+#, python-format
+msgid ""
+"List of files to be removed:\n"
+"%(files)s\n"
+"\n"
+"Do you want really to remove <%(ext)s> extension?"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:430
+msgid "Remove extension"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:461
+msgid "Extension"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:32
+msgid "No GRASS-python library found."
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:62
+msgid "Input Data"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:68
+msgid "Point dataset:"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:80
+msgid "Numeric column:"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:91
+msgid "Kriging"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:116
+msgid "Name for the output raster map:"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:124
+msgid "Export variance map as well: "
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:276
+msgid "Kriging Module"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:280
+msgid "Ready."
+msgstr "Valmis."
+#: ../gui/wxpython/modules/vkrige.py:304
+msgid "Variogram fitting"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:314
+msgid "Plot/refresh variogram"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:325
+msgid ":"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:350
+msgid "Kriging techniques"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:364
+msgid "Block size:"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:397
+msgid "Auto-fit variogram"
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:421
+msgid "Model: "
+msgstr ""
+#: ../gui/wxpython/modules/vkrige.py:510
+msgid "Work in progress! No functionality provided."
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:270
+msgid "GRASS GIS Histogramming Tool (d.histogram)"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:377
+msgid "Select font for histogram text"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:31 ../gui/wxpython/modules/vclean.py:113
+msgid "Set up vector cleaning tools"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:68
+msgid "break lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:69
+msgid "remove duplicates"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:70
+msgid "remove dangles"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:71
+msgid "change boundary dangles to lines"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:72
+msgid "remove bridges"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:73
+msgid "change bridges to lines"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:74
+msgid "snap lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:75
+msgid "remove duplicate area centroids"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:76
+msgid "break polygons"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:77
+msgid "prune lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:78
+msgid "remove small areas"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:79
+msgid "remove lines/boundaries of zero length"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:80
+msgid "remove small angles at nodes"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:115
+msgid "Choose cleaning tools and set thresholds"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:119
+msgid "Select input vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:125
+msgid " Feature type: "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:129
+msgid "Select output vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:161
+msgid "Copy the current command string to the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:197
+msgid "line"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:198
+msgid "boundary"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:199
+msgid "centroid"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:201
+msgid "face"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:353
+#, python-format
+msgid "%s. cleaning tool removed, will be ignored"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:355
+msgid "Please select a cleaning tool to remove"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:376
+#, python-format
+msgid "%s. cleaning tool moved up"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:378
+msgid "1. cleaning tool can not be moved up "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:380
+msgid "Please select a cleaning tool to move up"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:402
+#, python-format
+msgid "%s. cleaning tool moved down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:404
+msgid "Last cleaning tool can not be moved down "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:406
+msgid "Please select a cleaning tool to move down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:417
+#, python-format
+msgid "cleaning tool: '%s'"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:425
+#, python-format
+msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:453
+msgid "Name of input vector map"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:454
+msgid "Name for output vector map"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:456
+msgid "Threshold"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:458
+#, python-format
+msgid "'%s' not defined"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:460
+#, python-format
+msgid ""
+"Some parameters not defined. Operation canceled.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:465
+msgid "Executing selected cleaning operations..."
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:521
+msgid "Vector cleaning command copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1328
+#, python-format
+msgid "Unable to open file <%s> for reading."
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1341
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %(line)d"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1559
+#, python-format
+msgid " row %d:"
+msgstr ""
+#: ../gui/wxpython/core/render.py:146
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported"
+msgstr ""
+#: ../gui/wxpython/core/render.py:167
+#, python-format
+msgid "Command '%s' failed\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:169
+#, python-format
+msgid "Details: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:274
+#, python-format
+msgid "Unsupported map layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/core/render.py:418
+msgid "Trying to recover from default region..."
+msgstr ""
+#: ../gui/wxpython/core/render.py:483
+#, python-format
+msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:491
+#, python-format
+msgid ""
+"\n"
+"ERROR: Unable to read WIND file: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:588
+#, python-format
+msgid "Invalid map size %d,%d\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:667
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:668 ../gui/wxpython/core/render.py:671
+#: ../gui/wxpython/core/render.py:674 ../gui/wxpython/core/gcmd.py:395
+msgid "Details:"
+msgstr ""
+#: ../gui/wxpython/core/render.py:670
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:673
+#, python-format
+msgid "Unable to zoom to 3d raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:676
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please "
+"manually run g.region to fix the problem."
+msgstr ""
+#: ../gui/wxpython/core/render.py:987
+#, python-format
+msgid "ERROR: Rendering failed. Details: %s"
+msgstr ""
+#: ../gui/wxpython/core/render.py:1034 ../gui/wxpython/core/render.py:1129
+#, python-format
+msgid "Unable to render map layer <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1240 ../gui/wxpython/core/render.py:1279
+#, python-format
+msgid "Unable to render overlay <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1376
+msgid "Downloading data "
+msgstr ""
+#: ../gui/wxpython/core/render.py:1386
+msgid "Rendering & "
+msgstr ""
+#: ../gui/wxpython/core/render.py:1388
+msgid "Rendering..."
+msgstr ""
+#: ../gui/wxpython/core/menutree.py:135
+#, python-format
+msgid "Unknow tag %s"
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:195
+msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:235
+msgid "Unable to create toolboxes directory."
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:455
+msgid "Custom toolboxes"
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:479
+msgid "List of addons cannot be obtained because g.extension failed."
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:527
+msgid "Addons"
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:607
+msgid ""
+"WARNING: Some addons failed when loading. Please consider to update your "
+"addons by running 'g.extension.all -f'.\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:53
+#, python-format
+msgid "Syntax error: %s"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:331
+#, python-format
+msgid "Vector map <%(map)s>: %(msg)s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:558
+#, python-format
+msgid "failed to open '%s'"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:853
+#, python-format
+msgid "ERROR: Unable to determine GRASS version. Details: %s"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:888
+#, python-format
+msgid "Unable to open file '%s'\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:895
+#, python-format
+msgid ""
+"%s: line skipped - unable to parse '%s'\n"
+"Reason: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:900
+#, python-format
+msgid "Duplicated key: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:916
+#, python-format
+msgid "Unable to create file '%s'\n"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:489
+#, python-format
+msgid ""
+"Unable to run command:\n"
+"%(cmd)s\n"
+"\n"
+"Option <%(opt)s>: read from standard input is not supported by wxGUI"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:610
+#, python-format
+msgid "%d sec"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:613
+#, python-format
+msgid "%(min)d min %(sec)d sec"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:621
+msgid ""
+"Please note that the data are left in inconsistent state and may be corrupted"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:623
+msgid "Command aborted"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:625
+msgid "Command finished"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:128
+msgid "Reason"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:392
+msgid "Execution failed:"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:397 ../gui/wxpython/core/gcmd.py:401
+msgid "Error: "
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:476
+#, python-format
+msgid "Unable to exectute command: '%s'"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:485
+msgid "Segment break"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:551
+msgid "Data point"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:625
+msgid "animation"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:839
+msgid "Collapse all except PERMANENT and current"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:840
+msgid "Collapse all except PERMANENT"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:841
+msgid "Collapse all except current"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:842
+msgid "Collapse all"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:843
+msgid "Expand all"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:847
+msgid "Display selected"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:855
+msgid "Classic (labels only)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:856
+msgid "Combined (labels and module names)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:857
+msgid "Expert (module names only)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:862
+msgid "Basic top"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:863
+msgid "Basic left"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:864
+msgid "Fancy green"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:865
+msgid "List left"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:869
+msgid "Zoom and recenter"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:870
+msgid "Zoom to mouse cursor"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:871
+msgid "Nothing"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:872
+msgid "Scroll forward to zoom in"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:873
+msgid "Scroll back to zoom in"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:906 ../gui/wxpython/core/settings.py:918
+msgid "box"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:907
+msgid "sphere"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:908
+msgid "cube"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:909
+msgid "diamond"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:910
+msgid "aster"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:911
+msgid "gyro"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:912
+msgid "histogram"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:917
+msgid "cross"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:919
+msgid "circle"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:951
+#, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:975
+#, python-format
+msgid ""
+"Error: Reading settings from file <%(file)s> failed.\n"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:994
+msgid "Unable to create settings directory"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1030
+#, python-format
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1135
+msgid "Unable to set "
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1171 ../gui/wxpython/core/settings.py:1181
+#, python-format
+msgid "Unable to parse settings '%s'"
+msgstr ""
+#: ../gui/wxpython/core/ws.py:49
+msgid ""
+"Unable to load GDAL Python bindings.\n"
+"WMS layers can not be displayed without the bindings.\n"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:97
+msgid "Define GRASS Database and Location Name"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:113
+msgid "GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:129
+msgid "Project Location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:130
+msgid "Name of location directory in GIS Data Directory"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:141
+msgid "Location Title"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:142
+msgid "Optional location title, you can leave this field blank."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:162
+#, python-format
+msgid ""
+"Name <%(name)s> is not a valid name for location. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:165
+msgid "Invalid location name"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:180
+msgid "Choose GRASS data directory:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:191
+#: ../gui/wxpython/location_wizard/wizard.py:2061
+msgid "Location already exists in GRASS Database."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:195
+msgid "Unable to create location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:208
+msgid ""
+"Title of the location is limited only to one line and 256 characters. The "
+"rest of the text will be ignored."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:215
+msgid "Choose method for creating a new location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:222
+msgid "Select coordinate system parameters from a list"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:225
+msgid "Select EPSG code of spatial reference system"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:227
+msgid "Read projection and datum terms from a georeferenced data file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:230
+msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:233
+msgid "Specify projection and datum terms using custom PROJ.4 parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:236
+msgid "Create a generic Cartesian coordinate system (XY)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:337
+msgid "Choose projection"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:353
+#: ../gui/wxpython/location_wizard/wizard.py:854
+#: ../gui/wxpython/location_wizard/wizard.py:1026
+#: ../gui/wxpython/location_wizard/wizard.py:1337
+msgid "Code"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:357
+msgid "Projection code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:365
+#: ../gui/wxpython/location_wizard/wizard.py:867
+#: ../gui/wxpython/location_wizard/wizard.py:1043
+msgid "Search in description:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:540
+#, python-format
+msgid "Unable to read list: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:643
+msgid "Choose projection parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:657
+msgid "Select datum or ellipsoid (next page)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:664
+msgid "Datum with associated ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:667
+msgid "Ellipsoid only"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:724
+#, python-format
+msgid "You must enter a value for %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:736
+#: ../gui/wxpython/location_wizard/wizard.py:755
+#, python-format
+msgid " Enter parameters for %s projection "
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:832
+msgid "Specify geodetic datum"
+msgstr ""
+msgid "Ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:858
+msgid "Datum code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:997
+msgid "Specify ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1014
+msgid "Earth based"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1017
+msgid "Planetary bodies"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1031
+msgid "Ellipsoid code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1163
+#: ../gui/wxpython/location_wizard/wizard.py:1223
+msgid "Select georeferenced file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1168
+msgid "Georeferenced file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1237
+#: ../gui/wxpython/location_wizard/wizard.py:1294
+msgid "Select Well Known Text (WKT) .prj file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1242
+msgid "WKT .prj file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1311
+msgid "Choose EPSG Code"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1319
+msgid "Path to the EPSG-codes file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1473
+msgid "Choose EPSG codes file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1502
+#, python-format
+msgid "Unable to read EPGS codes: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1520
+msgid "Choose method of specifying georeferencing parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1528
+msgid "Enter PROJ.4 parameters string:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1584
+#: ../gui/wxpython/location_wizard/wizard.py:1588
+msgid "Datum transform is required."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1664
+msgid "GRASS Database:"
+msgstr "GRASS Tietokanta:"
+#: ../gui/wxpython/location_wizard/wizard.py:1670
+msgid "Location Name:"
+msgstr "Paikan Nimi:"
+#: ../gui/wxpython/location_wizard/wizard.py:1676
+msgid "Location Title:"
+msgstr "Paikan Otsikko:"
+#: ../gui/wxpython/location_wizard/wizard.py:1682
+msgid "Projection:"
+msgstr "Projektio:"
+#: ../gui/wxpython/location_wizard/wizard.py:1688
+msgid ""
+"PROJ.4 definition:\n"
+" (non-definitive)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1791
+#, python-format
+msgid "Do you want to create GRASS location <%s>?"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1792
+msgid "Create new location?"
+msgstr "Luo uusi Paikka?"
+#: ../gui/wxpython/location_wizard/wizard.py:1836
+msgid "Define new GRASS Location"
+msgstr "Määrittele uusi GRASS Paikka"
+#: ../gui/wxpython/location_wizard/wizard.py:1928
+#, python-format
+msgid ""
+"Unable to create new location. Location <%(loc)s> not created.\n"
+"\n"
+"Details: %(err)s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1936
+msgid "Location wizard canceled. Location not created."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2059
+msgid "Unable to create new location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2078
+#, python-format
+msgid ""
+"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
+"need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2083
+msgid "New GIS data directory"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2114
+msgid "EPSG code missing."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2125
+#: ../gui/wxpython/location_wizard/wizard.py:2134
+#, python-format
+msgid "File <%s> not found."
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:36
+msgid "Set default region extent and resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:83
+msgid "&Set region"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:113
+msgid "Invalid location selected."
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:130
+msgid "Invalid region"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:160
+msgid "Click here to show 3D settings"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:161
+msgid "Click here to hide 3D settings"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:184
+#: ../gui/wxpython/location_wizard/dialogs.py:466
+#, python-format
+msgid "Rows: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:185
+#: ../gui/wxpython/location_wizard/dialogs.py:467
+#, python-format
+msgid "Cols: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:186
+#: ../gui/wxpython/location_wizard/dialogs.py:468
+#, python-format
+msgid "Cells: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:228
+#: ../gui/wxpython/location_wizard/dialogs.py:470
+#, python-format
+msgid "Depth: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:229
+#: ../gui/wxpython/location_wizard/dialogs.py:471
+#, python-format
+msgid "3D Cells: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:248
+msgid "T-B resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:311
+msgid "North"
+msgstr "Pohjoinen"
+#: ../gui/wxpython/location_wizard/dialogs.py:319
+msgid "West"
+msgstr "Länsi"
+#: ../gui/wxpython/location_wizard/dialogs.py:339
+msgid "East"
+msgstr "Itä"
+#: ../gui/wxpython/location_wizard/dialogs.py:348
+msgid "South"
+msgstr "Etelä"
+#: ../gui/wxpython/location_wizard/dialogs.py:352
+msgid "N-S resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:360
+msgid "E-W resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:438
+#, python-format
+msgid "Invalid value: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:522
+msgid "Select datum transformation"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:547
+msgid "Select from list of datum transformations"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:224
+msgid ""
+"Opening 3D view was not successful. Please try to change the value of depth "
+"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:559
+#, python-format
+msgid ""
+"Image is too large, your OpenGL implementation supports maximum texture size "
+"%d px."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1057
+msgid "Easting"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1058
+msgid "Northing"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1059
+msgid "Elevation"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1065
+msgid "Surface map name"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1066
+msgid "Surface map elevation"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1067
+msgid "Surface map color"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1076
+msgid "XY distance from previous"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1077
+msgid "XYZ distance from previous"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1078
+msgid "Distance along surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1083
+msgid "Distance along exag. surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1090
+msgid "No point on surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1551
+msgid "Loading raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1555
+msgid "Loading 3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1561
+msgid "failed"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1563
+#, python-format
+msgid "Unsupported layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1675
+msgid "Unable to unload raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1680
+msgid "Unable to unload 3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1681
+msgid "3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1691
+msgid "unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1743
+#, python-format
+msgid "Loading vector map <%(name)s> (%(type)s) failed"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1803
+#, python-format
+msgid "Unable to unload vector map <%(name)s> (%(type)s)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1806
+#, python-format
+msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2163
+#, python-format
+msgid "Vector point layer not found (id = %d)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2165
+#, python-format
+msgid "Unable to set data layer properties (id = %d)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2168
+#, python-format
+msgid ""
+"Setting data layer properties failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2223
+#: ../gui/wxpython/nviz/mapwindow.py:2241 ../gui/wxpython/nviz/tools.py:2278
+#: ../gui/wxpython/nviz/tools.py:2323 ../gui/wxpython/nviz/tools.py:4585
+msgid "constant#"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:88 ../gui/wxpython/nviz/preferences.py:56
+#: ../gui/wxpython/nviz/preferences.py:61
+msgid "View"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:100
+msgid "Analysis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:103 ../gui/wxpython/nviz/tools.py:385
+msgid "Animation"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:226
+msgid "Control View"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:247
+msgid "Adjusts the distance and angular perspective of the image viewpoint"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:252 ../gui/wxpython/nviz/preferences.py:69
+msgid "Perspective:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:260
+msgid "Tilts the plane of the surface from the horizontal"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:264 ../gui/wxpython/nviz/tools.py:1027
+msgid "Tilt:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:271
+msgid ""
+"Adjusts the viewing height above the surface (angle of view automatically "
+"adjusts to maintain the same center of view)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:276
+msgid "Adjusts the relative height of features above the plane of the surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:290 ../gui/wxpython/nviz/preferences.py:150
+msgid "Z-exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:303
+msgid "Look:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:306
+msgid "here"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:309
+msgid ""
+"Allows you to select a point on the surface that becomes the new center of "
+"view. Click on the button and then on the surface."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:315
+msgid "center"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:318
+msgid "Resets the view to the original default center of view"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:322
+msgid "top"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:325
+msgid ""
+"Sets the viewer directly over the scene's center position. This top view "
+"orients approximately north south."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:329
+msgid "reset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:330
+msgid "Reset to default view"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:347 ../gui/wxpython/nviz/preferences.py:172
+msgid "Image Appearance"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:392
+msgid ""
+"Press 'Record' button and start changing the view. It is recommended to use "
+"fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:403
+msgid "Record"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:405
+msgid "Play"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:421
+msgid "Total number of frames :"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:425
+msgid "Frame rate (FPS):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:431
+msgid "Frames are recorded with given frequency (FPS). "
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:474
+msgid "Save image sequence"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:482
+msgid "Choose a directory for images"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:490
+msgid ""
+"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:546 ../gui/wxpython/nviz/tools.py:1862
+#: ../gui/wxpython/nviz/preferences.py:361
+msgid "Surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:552 ../gui/wxpython/nviz/tools.py:1086
+msgid "Constant surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:557 ../gui/wxpython/nviz/preferences.py:463
+msgid "Vector"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:598 ../gui/wxpython/nviz/preferences.py:253
+msgid "Lighting"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:603
+msgid "Fringe"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:630 ../gui/wxpython/nviz/tools.py:944
+msgid "Cutting planes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:681 ../gui/wxpython/nviz/tools.py:1562
+#: ../gui/wxpython/nviz/preferences.py:374
+msgid "Mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:684 ../gui/wxpython/nviz/preferences.py:377
+msgid "coarse"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:685 ../gui/wxpython/nviz/preferences.py:378
+msgid "fine"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:686 ../gui/wxpython/nviz/preferences.py:379
+msgid "both"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:695 ../gui/wxpython/nviz/tools.py:960
+#: ../gui/wxpython/nviz/tools.py:1576
+msgid "Shading:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:698 ../gui/wxpython/nviz/tools.py:1579
+msgid "flat"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:699 ../gui/wxpython/nviz/tools.py:1580
+msgid "gouraud"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:707
+msgid "Set to all"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:708
+msgid "Use draw settings for all loaded surfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:716 ../gui/wxpython/nviz/preferences.py:406
+msgid "Coarse mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:719 ../gui/wxpython/nviz/tools.py:759
+#: ../gui/wxpython/nviz/preferences.py:393
+#: ../gui/wxpython/nviz/preferences.py:410
+msgid "resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:732 ../gui/wxpython/nviz/preferences.py:422
+msgid "style:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:735 ../gui/wxpython/nviz/preferences.py:425
+msgid "wire"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:736 ../gui/wxpython/nviz/preferences.py:426
+msgid "surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:748
+msgid "Change wire color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:755 ../gui/wxpython/nviz/preferences.py:389
+msgid "Fine mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:781
+msgid "Surface attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:790 ../gui/wxpython/nviz/tools.py:2404
+msgid "Transparency"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:791 ../gui/wxpython/nviz/tools.py:2405
+msgid "Shininess"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:797 ../gui/wxpython/nviz/tools.py:2416
+msgid "map"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:800 ../gui/wxpython/nviz/tools.py:2421
+msgid "unset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:805 ../gui/wxpython/nviz/tools.py:2426
+msgid "constant"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:865
+msgid "Changes the x, y, and z position of the current surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:875 ../gui/wxpython/nviz/tools.py:1062
+#: ../gui/wxpython/nviz/tools.py:1693 ../gui/wxpython/nviz/tools.py:2589
+msgid "Reset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:876 ../gui/wxpython/nviz/tools.py:1694
+msgid "Reset to default position"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:950
+msgid "Active cutting plane:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:962
+msgid "clear"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:963
+msgid "top color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:964
+msgid "bottom color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:965
+msgid "blend"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:966
+msgid "shaded"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:978
+msgid "Horizontal X:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:980
+msgid "Sets the X coordinate of the current cutting plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:994
+msgid "Horizontal Y:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:996
+msgid "Sets the Y coordinate of the current cutting plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1013
+msgid "Rotates the current cutting plane about vertical axis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1029
+msgid "Rotates the current cutting plane about horizontal axis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1045
+msgid ""
+"Sets the Z coordinate of the current cutting plane (only meaningful when "
+"tilt is not 0)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1114
+msgid "Fine resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1126
+msgid "Value:"
+msgstr "Arvo:"
+#: ../gui/wxpython/nviz/tools.py:1138 ../gui/wxpython/nviz/tools.py:2578
+msgid "Transparency:"
+msgstr "Läpinäkyvyys:"
+#: ../gui/wxpython/nviz/tools.py:1204
+msgid "Show vector lines"
+msgstr "Näytä vektoriviivat"
+#: ../gui/wxpython/nviz/tools.py:1214 ../gui/wxpython/nviz/preferences.py:469
+msgid "Vector lines"
+msgstr "Vektoriviivat"
+#: ../gui/wxpython/nviz/tools.py:1220
+msgid "Line:"
+msgstr "Viiva:"
+#: ../gui/wxpython/nviz/tools.py:1223
+msgid "width:"
+msgstr "leveys:"
+#: ../gui/wxpython/nviz/tools.py:1239 ../gui/wxpython/nviz/tools.py:1390
+msgid "color:"
+msgstr "väri:"
+#: ../gui/wxpython/nviz/tools.py:1255 ../gui/wxpython/nviz/tools.py:1435
+msgid "use color for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1257
+msgid "use width for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1270 ../gui/wxpython/nviz/tools.py:1282
+#: ../gui/wxpython/nviz/tools.py:1448 ../gui/wxpython/nviz/tools.py:1457
+msgid "Set options..."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1300 ../gui/wxpython/nviz/tools.py:4806
+#: ../gui/wxpython/nviz/tools.py:4859
+msgid "on surface(s):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1301 ../gui/wxpython/nviz/tools.py:4806
+msgid "as 3D"
+msgstr "kuin 3D"
+#: ../gui/wxpython/nviz/tools.py:1310 ../gui/wxpython/nviz/tools.py:1477
+msgid "Height above surface:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1346
+msgid "Show vector points"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1355 ../gui/wxpython/nviz/preferences.py:509
+msgid "Vector points"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1362
+msgid "Icon:"
+msgstr "Ikoni:"
+#: ../gui/wxpython/nviz/tools.py:1437
+msgid "use size for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1565
+msgid "isosurfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1566
+msgid "slices"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1589
+msgid "Resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1603
+msgid "Draw wire box"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1619 ../gui/wxpython/nviz/tools.py:3760
+msgid "List of isosurfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1735
+msgid "Show light model"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1748
+msgid "Light source position"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1764
+msgid "Adjusts the light height"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1788
+msgid "Light color and intensity"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1802 ../gui/wxpython/nviz/preferences.py:307
+msgid "Brightness:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1804
+msgid "Adjusts the brightness of the light"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1813 ../gui/wxpython/nviz/preferences.py:321
+msgid "Ambient:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1815
+msgid "Adjusts the ambient light"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1876
+msgid "Edges with fringe"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1878
+msgid "N && W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1879
+msgid "N && E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1880
+msgid "S && W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1881
+msgid "S && E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1901
+msgid "Elevation of fringe from bottom:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1954
+msgid "Arrow length (in map units):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1964
+msgid "Arrow color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1973
+msgid "Place arrow"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1999
+msgid "Scale bar length (in map units):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2009
+msgid "Scale bar color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2018
+msgid "Place new scale bar"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2090
+msgid "Do you want to record new animation without saving the previous one?"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2093
+msgid "Animation already axists"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2255
+msgid "No file prefix given."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2259
+#, python-format
+msgid "Directory %s does not exist."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2389
+msgid "Isosurface attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2395
+msgid "toggle normal direction"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2401
+msgid "Isosurface value"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2507
+msgid "Slice attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2513
+msgid "Slice parallel to axis:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2646
+msgid "W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2647
+msgid "N"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2648
+msgid "S"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2649
+msgid "E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2650
+msgid "NW"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2651
+msgid "NE"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2652
+msgid "SE"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2653
+msgid "SW"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3142 ../gui/wxpython/nviz/tools.py:4916
+msgid "Level"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3766
+msgid "List of slices"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3958 ../gui/wxpython/nviz/tools.py:3960
+#, python-brace-format
+msgid "Level {level}"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3967 ../gui/wxpython/nviz/tools.py:3969
+msgid "Slice parallel to {axis}"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4246 ../gui/wxpython/nviz/tools.py:4929
+msgid "Slice parallel to"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4456
+#, python-format
+msgid "Scalebar %d"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4591
+msgid "None"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4753
+msgid "Vector map is 3D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4756
+msgid "Vector map is 2D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4758
+#, python-format
+msgid "%(features)d features (%(points)d points)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4808 ../gui/wxpython/nviz/tools.py:4861
+msgid "on surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4949
+msgid "range:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5017 ../gui/wxpython/nviz/tools.py:5028
+msgid "North edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5018 ../gui/wxpython/nviz/tools.py:5029
+msgid "South edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5019 ../gui/wxpython/nviz/tools.py:5026
+#: ../gui/wxpython/nviz/tools.py:5035
+msgid "West edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5020 ../gui/wxpython/nviz/tools.py:5027
+#: ../gui/wxpython/nviz/tools.py:5036
+msgid "East edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5022 ../gui/wxpython/nviz/tools.py:5033
+#: ../gui/wxpython/nviz/tools.py:5041
+msgid "Northing (Y):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5023 ../gui/wxpython/nviz/tools.py:5032
+#: ../gui/wxpython/nviz/tools.py:5042
+msgid "Height (Z):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5024 ../gui/wxpython/nviz/tools.py:5031
+#: ../gui/wxpython/nviz/tools.py:5040
+msgid "Easting (X):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5037
+msgid "Bottom edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5038
+msgid "Top edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5143
+msgid "Adjusts the distance and direction of the image viewpoint"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5175
+msgid ""
+"Adjusts the light direction. Click and drag the puck to change the light "
+"direction."
+msgstr ""
+#: ../gui/wxpython/nviz/wxnviz.py:482 ../gui/wxpython/nviz/wxnviz.py:494
+#, python-format
+msgid "3d raster map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:32
+msgid "3D view default settings"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:49
+msgid "Revert settings to default, changes are not applied"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:72
+#: ../gui/wxpython/nviz/preferences.py:135
+#: ../gui/wxpython/nviz/preferences.py:153
+msgid "value:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:84
+msgid "step:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:99
+#: ../gui/wxpython/nviz/preferences.py:266
+msgid "Position:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:102
+#: ../gui/wxpython/nviz/preferences.py:269
+msgid "x:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:132
+msgid "Twist:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:205
+msgid "Fly-through"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:215
+msgid "Move exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:227
+msgid "Turn exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:258
+msgid "Light"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:293
+msgid "z:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:437
+msgid "wire color:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:531
+msgid "Marker:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:629
+#, python-format
+msgid "3D view settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:203
+msgid "No data set."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:219
+#, python-format
+msgid ""
+"Interactive Scatter Plot Tool can not be used.\n"
+"Number of cells (rows*cols) <%d> in current regionis higher than maximum "
+"limit <%d>.\n"
+"\n"
+"You can reduce number of cells in current region using <g.region> command."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:228
+#, python-format
+msgid ""
+"Number of cells (rows*cols) <%d> in current region is higher than "
+"recommended threshold <%d>.\n"
+"It is strongly advised to reduce number of cells in current region bellow "
+"recommend threshold.\n"
+" It can be done by <g.region> command.\n"
+"\n"
+"Do you want to continue using Interactive Scatter Plot Tool with this region?"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:284
+msgid ""
+"Scatter plot with same band combination (regardless x y order) is already "
+"displayed."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:297
+#, python-format
+msgid "Band <%s> is not CELL (integer) type.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:300
+msgid "Scatter plot cannot be added.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:306
+#, python-format
+msgid ""
+"Scatter plot cannot be added.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <"
+"%d>.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:314
+#, python-format
+msgid ""
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended "
+"limit <%d>.\n"
+"It is strongly advised to reduce range extend of bands(e. g. using r."
+"rescale) bellow recommended threshold.\n"
+"\n"
+"Do you really want to add this scatter plot?"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:399
+msgid ""
+"In order to select arrea in scatter plot, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:433
+#, python-format
+msgid ""
+"Error occured during computation of scatter plot category:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:742
+#, python-format
+msgid "Export scatter plot raster of class <%s>"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:759
+#, python-format
+msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:762
+#, python-format
+msgid ""
+"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/core_c.py:23
+msgid "Loading ctypes libs failed"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:146
+msgid "GRASS GIS Interactive Scatter Plot Tool"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:361
+msgid "scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:437
+msgid "Maximum limit of categories number was reached."
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:532
+msgid "Rename class"
+msgstr "Nimeä luokka uudelleen"
+#: ../gui/wxpython/iscatt/frame.py:536
+msgid "Set color"
+msgstr "Aseta väri"
+#: ../gui/wxpython/iscatt/frame.py:544
+msgid "Hide"
+msgstr "Piilota"
+#: ../gui/wxpython/iscatt/frame.py:546
+msgid "Show"
+msgstr "Näytä"
+#: ../gui/wxpython/iscatt/frame.py:557
+msgid "Move to top"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:563
+msgid "Move to bottom"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:571
+msgid "Move category up"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:577
+msgid "Move category down"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:585
+msgid "Export class raster"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:657
+#, python-format
+msgid "Change opacity of class <%s>"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:679
+msgid "Empty name was inserted."
+msgstr ""
+#: ../gui/wxpython/iscatt/plots.py:42
+#, python-format
+msgid ""
+"Unable to import matplotlib (try to install it).\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/plots.py:571
+msgid "Zoom to scatter plot extend"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:38
+msgid "Add scatter plots"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:56
+msgid "x axis:"
+msgstr "x akseli:"
+#: ../gui/wxpython/iscatt/dialogs.py:62
+msgid "y axis:"
+msgstr "y akseli:"
+#: ../gui/wxpython/iscatt/dialogs.py:97
+msgid "Bands of scatter plots to be added (x y):"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:135
+msgid "No scatter plots selected."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:183
+msgid "Select both x and y bands."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:186
+msgid "Selected bands must be different."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:191
+msgid ""
+"Scatter plot with same bands combination (regardless x y order) has been "
+"already added into the list."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:292
+#, python-format
+msgid "Raster map <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:294
+#, python-format
+msgid "Raster <%s> exists"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:317
+msgid "Show confidence ellipses"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:323
+msgid "Selection polygon color:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:324
+msgid "Color of selection polygon vertex:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:325
+msgid "Selected area color:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:339
+msgid "Selected area opacity:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:371
+msgid "Selection style:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:393
+msgid "Ellipses settings:"
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:107
+#: ../gui/wxpython/iscatt/iscatt_core.py:157
+msgid "Select category for editing."
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:148
+msgid "Computing of scatter plots failed."
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:286
+msgid "Patching category raster conditions file failed."
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:309
+#, python-format
+msgid ""
+"v.build failed:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:327
+#, python-format
+msgid ""
+"v.to.rast failed:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:48
+msgid "Add scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:50
+msgid "Select area with polygon"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:52
+msgid "Pan mode for scatter plots"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:54
+msgid "Zoom mode for scatter plots (left mouse button, wheel)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:56
+msgid ""
+"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
+"extend)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:58
+msgid "Show/hide class manager"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:162
+#: ../gui/wxpython/iscatt/toolbars.py:163
+msgid "Include selected area to class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:165
+#: ../gui/wxpython/iscatt/toolbars.py:166
+msgid "Exclude selected area from class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:168
+msgid "Add new vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:169
+msgid "Add new vertex to polygon boundary scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:171
+msgid "Create selection polygon"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:172
+msgid "Add new vertex between last and first points of the boundary"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:174
+msgid "Move vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:175
+msgid "Move boundary vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:177
+msgid "Remove vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:178
+msgid "Remove boundary vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:180
+msgid "Remove polygon (click on scatter plot for removing it's polygon)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:257
+msgid "Add class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:259
+msgid "Remove selected class"
+msgstr ""
Property changes on: grass/trunk/locale/po/grasswxpy_fi.po
___________________________________________________________________
Added: svn:mime-type
   + text/x-po
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Modified: grass/trunk/translators.csv
--- grass/trunk/translators.csv	2015-08-18 10:03:50 UTC (rev 65958)
+++ grass/trunk/translators.csv	2015-08-18 10:47:46 UTC (rev 65959)
@@ -29,6 +29,7 @@
 Luis Izquierdo,<luisizq2002 hotmail.com>,ES
 Roberto Antolin,<tolanss yahoo.es>,ES
 Daniel Torres,<nobeeakon gmail.com>,ES
+Kari Salovaara <kari.salovaara pp1.inet.fi>,FI
 Daniel Calvelo Aros,<dca users.sf.net>,FR
 Emmanuel Saracco,<esaracco users.labs.libre-entreprise.org>,FR
 Eve Rousseau,<phytosociologue yahoo fr>,FR
