[GRASS-SVN] r66011 - grass-addons/grass7/gui/wxpython/wx.metadata/mdlib
Tue Aug 25 02:39:03 PDT 2015
Author: krejcmat
Date: 2015-08-25 02:39:03 -0700 (Tue, 25 Aug 2015)
New Revision: 66011
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswutil.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdeditorfactory.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdffactory.py
   grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdutil.py
wx.metadata addons: fix paths for working without addons BASE
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py	2015-08-25 08:37:10 UTC (rev 66010)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswlib.py	2015-08-25 09:39:03 UTC (rev 66011)
@@ -17,7 +17,8 @@
     sys.exit('owslib python library is missing. Check requirements on the manual page < https://grasswiki.osgeo.org/wiki/ISO/INSPIRE_Metadata_Support >')
 from cswutil import *
-from mdutil import yesNo
+from mdutil import yesNo, StaticContext
 import tempfile
 import json
@@ -47,6 +48,7 @@
 from grass.pygrass.modules import Module
 from grass.script import parse_key_val
 class ConstraintsBulder(wx.Panel):
     def __init__(self, parent, settings=''):
         wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
@@ -101,7 +103,7 @@
         sizeConst = 55
         self.splitterBrowser = SplitterWindow(self, style=wx.SP_3D | wx.SP_LIVE_UPDATE | wx.SP_BORDER)
         self.context=StaticContext()
-        self.connectionFilePath = os.path.join(self.context.addonsPath, 'connections_resources.xml')
+        self.connectionFilePath = os.path.join(self.context.lib_path, 'connections_resources.xml')
         self.pnlLeft = wx.Panel(self.splitterBrowser, id=wx.ID_ANY)
         self.pnlRight = wx.Panel(self.splitterBrowser, -1)
@@ -854,7 +856,7 @@
         self.connectionLBox = wx.ListBox(self.panelLeft, id=-1, pos=wx.DefaultPosition)
         self.timeoutSpin = wx.SpinCtrl(self.panelLeft, min=1, max=100, initial=10 , style=wx.ALIGN_RIGHT | wx.SP_ARROW_KEYS)
         self.context = StaticContext()
         self.servicePath = 'service_metadata.html'
         self.serviceInfoBtt = wx.Button(self.panelLeft, -1, label='Service info')
         self.newBtt = wx.Button(self.panelLeft, label='New')
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswutil.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswutil.py	2015-08-25 08:37:10 UTC (rev 66010)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/cswutil.py	2015-08-25 09:39:03 UTC (rev 66011)
@@ -21,13 +21,6 @@
 from pygments.lexers import XmlLexer
 from pygments.formatters import HtmlFormatter
-class StaticContext(object):
-    def __init__(self):
-        self.ppath = os.path.dirname(os.path.abspath(__file__))
-        self.addonsPath=os.path.join(os.getenv('GRASS_ADDON_BASE'), 'etc','wx.metadata','config')
 def get_connections_from_file( filename):
     """load connections from connection file"""
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdeditorfactory.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdeditorfactory.py	2015-08-25 08:37:10 UTC (rev 66010)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdeditorfactory.py	2015-08-25 09:39:03 UTC (rev 66011)
@@ -114,7 +114,6 @@
         if not xmlOutName.lower().endswith('.xml'):
             xmlOutName += '.xml'
         # if path is None, use lunch. dir
-        # TODO change default folder to mapset location
         if not outPath:
             outPath = os.path.join(self.dirpath, xmlOutName)
         else:
@@ -126,9 +125,12 @@
             line = mdutil.removeNonAscii(line)
             str1 += line
         xml.close
-        io = open(jinjaPath, 'w')
-        io.write(str1)
-        io.close()
+        try:
+            io = open(jinjaPath, 'w')
+            io.write(str1)
+            io.close()
+        except Exception,err:
+            print "WARNING: Cannot check and remove non ascii characters from template err:< %s >"%err
         # generating xml using jinja templates
         head, tail = os.path.split(jinjaPath)
@@ -838,17 +840,20 @@
         if not mdutil.isTableExists('metadata_themes'):
             sql='create table if not exists metadata_themes (title TEXT, keyword TEXT, date_iso TEXT ,date_type TEXT)'
             self.dbExecute(sql)
-            p1=os.path.join(sys.path[0],'..')
             titles = [['keywordConcepts.txt','GEMET - Concepts, version 2.4'],
                      ['keywordThemes.txt','GEMET - Themes, version 2.4'],
                      ['keywordGroups.txt','GEMET - Groups, version 2.4']]
+            context=mdutil.StaticContext()
+            libPath = os.path.join(context.lib_path,'config')
             for title in titles:
-                path = os.path.join(p1, 'config', title[0])
+                path =  os.path.join(libPath,title[0])
                 str=''
                 with open(path, "r") as inp :
                     exec(inp.read())
-                    for item in keywords:#!!! from exec, no mistake
+                    for item in keywords:#!!! keywords from exec, no mistake!
                             str+="('%s','%s','%s','%s'),"%(title[1],item['preferredLabel']['string'],'2010-01-13','publication')
                     str=str[:-1]
                     sql="INSERT INTO 'metadata_themes' ('title', 'keyword', 'date_iso' ,'date_type' ) VALUES"+str
@@ -1574,7 +1579,8 @@
         self.md = self.mdo.initMD()
         # most of objects from OWSLib is initialized in configure file
         #dirpath = os.path.dirname(os.path.realpath(__file__))
-        path = os.path.join(os.getenv('GRASS_ADDON_BASE'),'etc','wx.metadata','config','init_md.txt')
+        path = os.path.join(context.lib_path,'config','init_md.txt')
         mdInitData = open(path, 'r')
         mdExec = mdInitData.read()
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py	2015-08-25 08:37:10 UTC (rev 66010)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdgrass.py	2015-08-25 09:39:03 UTC (rev 66011)
@@ -3,7 +3,7 @@
 @package mdgrass
 @module  v.info.iso, r.info.iso, g.gui.metadata
- at brief   Base class for import(r.info,v.info) and export(r/v.support)
+ at brief   Base class for import(r.info.iso,v.info) and export(r/v.support)
          metadata with using OWSLib and jinja template.
 Classes:
@@ -47,7 +47,6 @@
 from datetime import date, datetime
 from osgeo import osr
-#sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc','wx.metadata','mdlib'))
 class GrassMD():
@@ -69,7 +68,8 @@
         # suffix of output xml file (variables)
         self.schema_type = '_basic.xml'
         self.profileName='GRASS BASIC'
-        self.dirpath = os.getenv('GRASS_ADDON_BASE')
+        self.dirpath = os.path.join(context.lib_path,'profiles')
         # metadata object from OWSLIB ( for define md values)
         self.md = mdutil.MD_MetadataMOD(md=None)
         self.profilePath = None  # path to file with xml templates
@@ -163,7 +163,7 @@
             date = datetime.strptime(self.md_grass[key], '%a %b %d %H:%M:%S %Y')
             self.md_grass['dateofcreation'] = date.strftime('%Y-%m-%d')
         except:
-            grass.warning('date of creation: unknown date format')
+            grass.message('date of creation: unknown date format')
             self.md_grass['dateofcreation'] = self.md_grass[key]
     def parseRast(self):
@@ -229,7 +229,7 @@
             int(srs.GetAuthorityCode(None))
             return srs.GetAuthorityCode(None)
         except:
-            grass.warning('Epsg code cannot be identified')
+            grass.message('Attemp of identifiyng EPSG is not successful')
             return None
     def createTemporalISO(self, profile=None):
@@ -239,7 +239,7 @@
         n = '$NULL'
         # jinja templates
         if profile is None:
-            self.profilePath = os.path.join('etc','wx.metadata','profiles', 'temporalProfile.xml')
+            self.profilePath =  'temporalProfile.xml'
         else:
             self.profilePath = profile
         self.schema_type = '_temporal.xml'
@@ -318,7 +318,7 @@
         n = '$NULL'
         # jinja templates
         if profile is None:
-            self.profilePath = os.path.join('etc','wx.metadata','profiles', 'basicProfile.xml')
+            self.profilePath =  'basicProfile.xml'
         else:
@@ -387,7 +387,7 @@
             try:
                 self.md.dataquality.lineage = mdutil.replaceXMLReservedChar(self.md_grass['comments']).replace('\n', '\\n')
             except:
-                grass.warning('Native metadata *flag=comments* not found, dataquality.lineage filled by $NULL')
+                grass.message('Native metadata *flag=comments* not found, dataquality.lineage filled by $NULL')
                 self.md.dataquality.lineage = n
             self.md.identification.denominators.append(n)
@@ -427,7 +427,7 @@
         self.createGrassBasicISO()
         if profile is None:
-            self.profilePath = os.path.join('etc','wx.metadata','profiles', 'inspireProfile.xml')
+            self.profilePath = 'inspireProfile.xml'
         else:
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdffactory.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdffactory.py	2015-08-25 08:37:10 UTC (rev 66010)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdpdffactory.py	2015-08-25 09:39:03 UTC (rev 66011)
@@ -2,19 +2,25 @@
     from owslib.iso import *
 except:
     sys.exit('owslib library is missing. Check requirements on the manual page < https://grasswiki.osgeo.org/wiki/ISO/INSPIRE_Metadata_Support >')
-from reportlab.platypus import PageBreak
 import tempfile, sys, os
+from grass.pygrass.utils import get_lib_path
+from grass.script import core as grass
+def load_mdlib(libs):
+    for lib in libs:
+        path = get_lib_path(modname=os.path.join('wx.metadata','mdlib') ,libname=lib)
+        if path is not None and path not in sys.path:
+            sys.path.append(path)
+        elif path is  None:
+            grass.fatal("Fatal error: library < %s > not found "%lib)
+load_mdlib(['pdf','mdlib'])
 import math
 from reportlab.platypus import Paragraph, Image, Table
+from reportlab.platypus import PageBreak
 from mdpdftheme import *
-from grass.script import core as grass
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'pdf'))
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]),'etc','wx.metadata','mdlib'))
 class MyTheme(DefaultTheme):
     doc = {
         'leftMargin': 25,
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdutil.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdutil.py	2015-08-25 08:37:10 UTC (rev 66010)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/mdlib/mdutil.py	2015-08-25 09:39:03 UTC (rev 66011)
@@ -35,13 +35,25 @@
 from subprocess import PIPE
+import wx
-import wx
     def __init__(self):
-        self.addonsPath=os.path.join(os.getenv('GRASS_ADDON_BASE'),'etc' 'wx.metadata')
+        path = os.path.join('wx.metadata','config')
+        self.configureLibPath = get_lib_path(modname=path ,libname='init_md.txt')
+        if self.configureLibPath is None:
+            grass.fatal("Fatal error: library < %s > not found"%path)
+        path=os.path.join('wx.metadata','profiles')
+        self.profilesLibPath = get_lib_path(modname= path,libname='basicProfile.xml')
+        if self.profilesLibPath is None:
+        self.lib_path = os.path.normpath(self.configureLibPath+ os.sep + os.pardir)
 def isTableExists(name):
     res = Module('db.tables',flags='p',stdout_=PIPE)
     for line in res.outputs.stdout.splitlines():
