[GRASS-SVN] r66014 - grass/trunk/lib/python/temporal
Tue Aug 25 03:13:30 PDT 2015
Author: huhabla
Date: 2015-08-25 03:13:30 -0700 (Tue, 25 Aug 2015)
New Revision: 66014
   grass/trunk/lib/python/temporal/c_libraries_interface.py
   grass/trunk/lib/python/temporal/core.py
   grass/trunk/lib/python/temporal/space_time_datasets.py
temporal library: Fixed wrong mapset access method
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py	2015-08-25 10:03:10 UTC (rev 66013)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py	2015-08-25 10:13:30 UTC (rev 66014)
@@ -151,15 +151,17 @@
        :returns: Names of available mapsets as list of strings
     count = 0
     mapset_list = []
     try:
+        # Initilaize the accessable mapset list, this is bad C design!!!
+        libgis.G_get_mapset_name(0)
         mapsets = libgis.G_get_available_mapsets()
         while mapsets[count]:
             char_list = ""
             mapset = mapsets[count]
-            if libgis.G_mapset_permissions(mapset) > 0:
+            if libgis.G_mapset_permissions(mapset) == 1 and libgis.G_is_mapset_in_search_path(mapset) == 1:
                 c = 0
                 while mapset[c] != "\x00":
                     char_list += mapset[c]
@@ -758,7 +760,7 @@
     CALLBACK.argtypes = c_void_p
     cerror_handler = CALLBACK(error_handler)
     libgis.G_add_error_handler(cerror_handler, None)
     # Crerate the function array
@@ -914,17 +916,17 @@
            >>> mapset = ciface.get_mapset()
            >>> location = ciface.get_location()
            >>> gisdbase = ciface.get_gisdbase()
            >>> ciface.fatal_error()
                raise FatalError(message)
            FatalError: Fatal error
@@ -950,7 +952,7 @@
         self.start_server()
         self.start_checker_thread()
         self.stopThread = False
     def start_checker_thread(self):
         if self.checkThread is not None and self.checkThread.is_alive():
             self.stop_checker_thread()
@@ -959,13 +961,13 @@
         self.checkThread.daemon = True
         self.checkThread.start()
     def stop_checker_thread(self):
         self.threadLock.acquire()
         self.stopThread = True
         self.threadLock.release()
         self.checkThread.join(None)
     def thread_checker(self):
         """Check every 200 micro seconds if the server process is alive"""
         while True:
@@ -989,7 +991,7 @@
     def check_server(self):
         self._check_restart_server()
     def _check_restart_server(self):
         """Restart the server if it was terminated
@@ -1351,7 +1353,7 @@
     def fatal_error(self, mapset=None):
         """Generate a fatal error in libgis.
             This function is only for testing purpose.
         self.check_server()
@@ -1360,7 +1362,7 @@
         return self.safe_receive("Fatal error")
     def safe_receive(self, message):
-        """Receive the data and throw an FatalError exception in case the server
+        """Receive the data and throw an FatalError exception in case the server
            process was killed and the pipe was closed by the checker thread"""
         try:
             ret = self.client_conn.recv()
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py	2015-08-25 10:03:10 UTC (rev 66013)
+++ grass/trunk/lib/python/temporal/core.py	2015-08-25 10:13:30 UTC (rev 66014)
@@ -750,7 +750,7 @@
     stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
     str3ds_tables_sql = stds_tables_template_sql.replace("STDS", "str3ds")
-    msgr.message(_("Creating temporal database: %s" % (tgis_database_string)))
+    msgr.message(_("Creating temporal database: %s" % (str(tgis_database_string))))
     if tgis_backend == "sqlite":
         # We need to create the sqlite3 database path if it does not exists
@@ -860,7 +860,7 @@
             driver,  dbstring = self.tgis_mapsets[mapset]
             if dbstring not in self.unique_connections.keys():
-                self.unique_connections[dbstring] = DBConnection(backend=driver,
+                self.unique_connections[dbstring] = DBConnection(backend=driver,
        dbstring=dbstring)
             self.connections[mapset] = self.unique_connections[dbstring]
@@ -1025,7 +1025,7 @@
     def __init__(self, backend=None, dbstring=None):
         """ Constructor of a database connection
             param backend:The database backend sqlite or pg
             param dbstring: The database connection string
@@ -1071,7 +1071,7 @@
         """Connect to the DBMI to execute SQL statements
             Supported backends are sqlite3 and postgresql
         # Connection in the current mapset
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py	2015-08-25 10:03:10 UTC (rev 66013)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py	2015-08-25 10:13:30 UTC (rev 66014)
@@ -88,7 +88,7 @@
             >>> rmap.get_temporal_extent_as_tuple()
             (datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2012, 1, 1, 0, 0))
             >>> rmap.get_name()
-            'strds_map_test_case'
+            u'strds_map_test_case'
             >>> rmap.get_mapset() == mapset
             True
             >>> rmap.get_temporal_type()
@@ -407,7 +407,7 @@
             >>> r3map.get_temporal_extent_as_tuple()
             >>> r3map.get_name()
-            'str3ds_map_test_case'
+            u'str3ds_map_test_case'
             >>> r3map.get_mapset() == mapset
             True
             >>> r3map.get_temporal_type()
@@ -737,7 +737,7 @@
             >>> vmap.get_temporal_extent_as_tuple()
             >>> vmap.get_name()
-            'stvds_map_test_case'
+            u'stvds_map_test_case'
             >>> vmap.get_mapset() == mapset
             True
             >>> vmap.get_temporal_type()
