[GRASS-SVN] r67082 - grass/branches/releasebranch_7_0
Sat Dec 12 05:58:26 PST 2015
Author: martinl
Date: 2015-12-12 05:58:26 -0800 (Sat, 12 Dec 2015)
New Revision: 67082
   grass/branches/releasebranch_7_0/aclocal.m4
   grass/branches/releasebranch_7_0/configure
aclocal.m4: add support for w64-ming32 builds
update configure to support w64-mingw32 builds
       (merge r67050:1 from trunk)
Modified: grass/branches/releasebranch_7_0/aclocal.m4
--- grass/branches/releasebranch_7_0/aclocal.m4	2015-12-12 13:53:22 UTC (rev 67081)
+++ grass/branches/releasebranch_7_0/aclocal.m4	2015-12-12 13:58:26 UTC (rev 67082)
@@ -501,7 +501,7 @@
             LDFLAGS="-Wl,--export-dynamic"
 	    LD_LIBRARY_PATH_VAR="PATH"
-        *-pc-mingw32 | *-pc-msys)
+        *-pc-mingw32 | *-w64-mingw32 | *-pc-msys)
             SHLIB_SUFFIX=".dll"
             SHLIB_LD="${CC} -shared"
             LDFLAGS="-Wl,--export-dynamic,--enable-runtime-pseudo-reloc"
Modified: grass/branches/releasebranch_7_0/configure
--- grass/branches/releasebranch_7_0/configure	2015-12-12 13:53:22 UTC (rev 67081)
+++ grass/branches/releasebranch_7_0/configure	2015-12-12 13:58:26 UTC (rev 67082)
@@ -1499,7 +1499,7 @@
             SHLIB_SUFFIX=".dll"
@@ -11819,58 +11819,7 @@
   fi
 fi
-for ac_declaration in \
-   '#include <stdlib.h>' \
-   'extern "C" void std::exit (int) throw (); using std::exit;' \
-   'extern "C" void std::exit (int); using std::exit;' \
-   'extern "C" void exit (int) throw ();' \
-   'extern "C" void exit (int);' \
-   'void exit (int);'
-do
-  cat > conftest.$ac_ext <<EOF
-#line 11833 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:11841: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  continue
-fi
-rm -f conftest*
-#line 11851 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:11858: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
-  rm -rf conftest*
-  break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
-  echo '#ifdef __cplusplus' >>confdefs.h
-  echo $ac_declaration      >>confdefs.h
-  echo '#endif'             >>confdefs.h
-fi
-else
 	CXX=
 	CXXFLAGS=
@@ -11883,7 +11832,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:11887: checking whether to use openDWG" >&5
+echo "configure:11836: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -11903,7 +11852,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:11907: checking for location of openDGW includes" >&5
+echo "configure:11856: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -11929,15 +11878,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11933: checking for $ac_hdr" >&5
+echo "configure:11882: checking for $ac_hdr" >&5
-#line 11936 "configure"
+#line 11885 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11941: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11971,7 +11920,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:11975: checking for location of openDWG library" >&5
+echo "configure:11924: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12012,7 +11961,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12016: checking whether to use POSIX threads" >&5
+echo "configure:11965: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12032,7 +11981,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12036: checking for location of POSIX threads includes" >&5
+echo "configure:11985: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12058,15 +12007,15 @@
 do
-echo "configure:12062: checking for $ac_hdr" >&5
+echo "configure:12011: checking for $ac_hdr" >&5
-#line 12065 "configure"
+#line 12014 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12070: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12019: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12100,7 +12049,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12104: checking for location of POSIX threads library" >&5
+echo "configure:12053: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12125,10 +12074,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12129: checking for pthread_create" >&5
+echo "configure:12078: checking for pthread_create" >&5
-#line 12132 "configure"
+#line 12081 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -12151,7 +12100,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12178,13 +12127,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12182: checking for pthread_create in -lpthread" >&5
+echo "configure:12131: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12188 "configure"
+#line 12137 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12195,7 +12144,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12245,7 +12194,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12249: checking whether to use OpenMP" >&5
+echo "configure:12198: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12266,7 +12215,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12270: checking for location of OpenMP includes" >&5
+echo "configure:12219: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12292,15 +12241,15 @@
 do
-echo "configure:12296: checking for $ac_hdr" >&5
+echo "configure:12245: checking for $ac_hdr" >&5
-#line 12299 "configure"
+#line 12248 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12304: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12338,7 +12287,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12342: checking for location of OpenMP library" >&5
+echo "configure:12291: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12363,10 +12312,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12367: checking for GOMP_parallel_start" >&5
+echo "configure:12316: checking for GOMP_parallel_start" >&5
-#line 12370 "configure"
+#line 12319 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12389,7 +12338,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12416,13 +12365,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12420: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12369: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12426 "configure"
+#line 12375 "configure"
@@ -12433,7 +12382,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12506,7 +12455,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12510: checking whether to use OpenCL" >&5
+echo "configure:12459: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -12526,7 +12475,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12530: checking for location of OpenCL includes" >&5
+echo "configure:12479: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12553,15 +12502,15 @@
 do
-echo "configure:12557: checking for $ac_hdr" >&5
+echo "configure:12506: checking for $ac_hdr" >&5
-#line 12560 "configure"
+#line 12509 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12565: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12514: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12601,10 +12550,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12605: checking for clGetPlatformInfo" >&5
+echo "configure:12554: checking for clGetPlatformInfo" >&5
-#line 12608 "configure"
+#line 12557 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -12627,7 +12576,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -12666,15 +12615,15 @@
 do
-echo "configure:12670: checking for $ac_hdr" >&5
+echo "configure:12619: checking for $ac_hdr" >&5
-#line 12673 "configure"
+#line 12622 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12707,7 +12656,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:12711: checking for location of OpenCL library" >&5
+echo "configure:12660: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -12731,13 +12680,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:12735: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:12684: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 12741 "configure"
+#line 12690 "configure"
@@ -12748,7 +12697,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:12752: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12808,7 +12757,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:12812: checking for special C compiler options needed for large files" >&5
+echo "configure:12761: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -12816,7 +12765,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 12820 "configure"
+#line 12769 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -12832,7 +12781,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12836: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12785: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -12841,7 +12790,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 12845 "configure"
+#line 12794 "configure"
@@ -12857,7 +12806,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12861: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12810: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -12884,11 +12833,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:12888: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:12837: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 12892 "configure"
+#line 12841 "configure"
@@ -12904,14 +12853,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12908: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12857: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 12915 "configure"
+#line 12864 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -12929,7 +12878,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12933: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12882: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -12955,11 +12904,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:12959: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:12908: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 12963 "configure"
+#line 12912 "configure"
@@ -12975,14 +12924,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12979: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12928: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 12986 "configure"
+#line 12935 "configure"
 #define _LARGE_FILES 1
@@ -13000,7 +12949,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13004: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12953: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13026,25 +12975,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13030: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:12979: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13034 "configure"
+#line 12983 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13041: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12990: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13048 "configure"
+#line 12997 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13053,7 +13002,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13057: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13006: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13085,25 +13034,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13089: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13038: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13093 "configure"
+#line 13042 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13100: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13049: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13107 "configure"
+#line 13056 "configure"
 #include <stdio.h>
@@ -13112,7 +13061,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13116: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13142,18 +13091,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13146: checking for fseeko" >&5
+echo "configure:13095: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13150 "configure"
+#line 13099 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13170,10 +13119,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13174: checking if system supports Large Files at all" >&5
+echo "configure:13123: checking if system supports Large Files at all" >&5
-#line 13177 "configure"
+#line 13126 "configure"
 #include <stdio.h>
@@ -13205,7 +13154,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13209: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13158: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13236,7 +13185,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13240: checking whether to use wxWidgets" >&5
+echo "configure:13189: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -13257,7 +13206,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13261: checking for $ac_word" >&5
+echo "configure:13210: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -13305,7 +13254,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13309: checking wxWidgets version" >&5
+echo "configure:13258: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -13328,15 +13277,15 @@
 do
-echo "configure:13332: checking for $ac_hdr" >&5
+echo "configure:13281: checking for $ac_hdr" >&5
-#line 13335 "configure"
+#line 13284 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
