[GRASS-SVN] r67120 - grass/trunk/vector/v.net.distance
Mon Dec 14 04:50:56 PST 2015
Author: neteler
Date: 2015-12-14 04:50:56 -0800 (Mon, 14 Dec 2015)
New Revision: 67120
   grass/trunk/vector/v.net.distance/v.net.distance.html
v.net.distance manual: remove OS specific paths; break long lines
Modified: grass/trunk/vector/v.net.distance/v.net.distance.html
--- grass/trunk/vector/v.net.distance/v.net.distance.html	2015-12-14 11:34:58 UTC (rev 67119)
+++ grass/trunk/vector/v.net.distance/v.net.distance.html	2015-12-14 12:50:56 UTC (rev 67120)
@@ -51,10 +51,12 @@
 <p><div class="code"><pre>
 # connect schools to streets as layer 2
-v.net input=streets_wake points=schools_wake output=streets_net1 operation=connect thresh=400 arc_layer=1 node_layer=2
+v.net input=streets_wake points=schools_wake output=streets_net1 \
+      operation=connect thresh=400 arc_layer=1 node_layer=2
 # connect hospitals to streets as layer 3
-v.net input=streets_net1 points=hospitals output=streets_net2 operation=connect thresh=400 arc_layer=1 node_layer=3
+v.net input=streets_net1 points=hospitals output=streets_net2 \
+      operation=connect thresh=400 arc_layer=1 node_layer=3
 # inspect the result
 v.category in=streets_net2 op=report
@@ -72,7 +74,7 @@
 pollution.txt:
 634731.563206905|216390.501834892
-v.in.ascii input=C:\data\pollution.txt output=pollution
+v.in.ascii input=pollution.txt output=pollution
 # add table to vector
 v.db.addtable map=pollution
@@ -83,14 +85,17 @@
 634893.462007813|216273.763350851
 634918.660011082|216254.949609689
-v.in.ascii input=C:\data\samples.txt output=samples
+v.in.ascii input=samples.txt output=samples
 v.db.addtable map=samples
 # connect samples and pollution to streams
-v.net -c input=streams points=samples output=streams_samples operation=connect node_layer=3 threshold=10
-v.net -c input=streams_samples points=pollution output=streams_samples_pollution operation=connect node_layer=4 threshold=10
+v.net -c input=streams points=samples output=streams_samples \
+         operation=connect node_layer=3 threshold=10 \
+v.net -c input=streams_samples points=pollution
+         output=streams_samples_pollution operation=connect \
+         node_layer=4 threshold=10
 # check vector layers
 v.category input=streams_samples_pollution option=report
@@ -126,7 +131,8 @@
 all            1          1          1
 # calculate distance between sample points and pollution point source
-v.net.distance input=streams_samples_pollution output=distance_samples_to_pollution from_layer=3 to_layer=4
+v.net.distance input=streams_samples_pollution \
+      output=distance_samples_to_pollution from_layer=3 to_layer=4
 # check results
 v.report map=distance_samples_to_pollution at vnettest option=length
@@ -136,7 +142,6 @@
 3|1|231.446|231.446
 </pre></div>
-<p>
 <h2>SEE ALSO</h2>
 <em>
