[GRASS-SVN] r67128 - grass/branches/releasebranch_7_0/mswindows/osgeo4w
Mon Dec 14 12:47:47 PST 2015
Author: martinl
Date: 2015-12-14 12:47:47 -0800 (Mon, 14 Dec 2015)
New Revision: 67128
Removed:
   grass/branches/releasebranch_7_0/mswindows/osgeo4w/msys.bat
osgeo4w: remove unsed file
Deleted: grass/branches/releasebranch_7_0/mswindows/osgeo4w/msys.bat
--- grass/branches/releasebranch_7_0/mswindows/osgeo4w/msys.bat	2015-12-14 20:47:20 UTC (rev 67127)
+++ grass/branches/releasebranch_7_0/mswindows/osgeo4w/msys.bat	2015-12-14 20:47:47 UTC (rev 67128)
@@ -1,207 +0,0 @@
- at echo off
-rem Copyright (C):  2001, 2002, 2003, 2004, 2005  Earnie Boyd
-rem   mailto:earnie at users.sf.net
-rem This file is part of Minimal SYStem
-rem   http://www.mingw.org/msys.shtml
-rem
-rem File:	    msys.bat
-rem Revision:	    2.4
-rem Revision Date:  December 8th, 2005
-rem --- MODIFIED FOR GRASS Aug 2009: Quote path name variables ---
-rem ember to set the "Start in:" field of the shortcut.
-rem A value similar to C:\msys\1.0\bin is what the "Start in:" field needs
-rem to represent.
-rem ember value of GOTO: is used to know recursion has happened.
-if "%1" == "GOTO:" goto %2
-if NOT "x%WD%" == "x" set WD=
-rem ember command.com only uses the first eight characters of the label.
-goto _WindowsNT
-rem ember that we only execute here if we are in command.com.
-:_Windows
-if "x%COMSPEC%" == "x" set COMSPEC=command.com
-start /min "%COMSPEC%" /e:4096 /c %0 GOTO: _Resume %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
-goto EOF
-rem ember that we execute here if we recursed.
-:_Resume
-for %%F in (1 2 3) do shift
-if NOT EXIST "%WD%msys-1.0.dll" set WD=.\bin\
-rem ember that we get here even in command.com.
-:_WindowsNT
-rem Hopefully a temporary workaround for getting MSYS shell to run on x64
-rem (WoW64 cmd prompt sets PROCESSOR_ARCHITECTURE to x86)
-if not "x%PROCESSOR_ARCHITECTURE%" == "xAMD64" goto _NotX64
-set COMSPEC=%WINDIR%\SysWOW64\cmd.exe
-"%COMSPEC%" /c %0 %1 %2 %3 %4 %5 %6 %7 %8 %9
-goto EOF
-:_NotX64
-if NOT EXIST "%WD%msys-1.0.dll" set WD=%~dps0bin\
-rem echo %WD%
-rem ember Set up option to use rxvt based on value of %1
-set MSYSCON=unknown
-if "x%1" == "x-norxvt" set MSYSCON=sh.exe
-if "x%1" == "x--norxvt" set MSYSCON=sh.exe
-if "x%1" == "x-rxvt" set MSYSCON=rxvt.exe
-if "x%1" == "x--rxvt" set MSYSCON=rxvt.exe
-if "x%1" == "x-mintty" set MSYSCON=mintty.exe
-if "x%1" == "x--mintty" set MSYSCON=mintty.exe
-if NOT "x%MSYSCON%" == "xunknown" shift
-if "x%MSYSCON%" == "xunknown" set MSYSCON=sh.exe
-rem the default is a MSYS (user), not a MINGW (developer) console
-if "x%MSYSTEM%" == "x" set MSYSTEM=MSYS
-if "%1" == "MINGW32" set MSYSTEM=MINGW32
-if "%1" == "MSYS" set MSYSTEM=MSYS
-if NOT "x%DISPLAY%" == "x" set DISPLAY=
-if "x%MSYSCON%" == "xmintty.exe" goto startmintty
-if "x%MSYSCON%" == "xrxvt.exe" goto startrxvt
-if "x%MSYSCON%" == "xsh.exe" goto startsh
-:unknowncon
-echo %MSYSCON% is an unknown option for msys.bat.
-pause
-exit 1
-:notfound
-echo Cannot find the rxvt.exe or sh.exe binary -- aborting.
-pause
-exit 1
-:startmintty
-if NOT EXIST "%WD%mintty.exe" goto startsh
-start "%WD%mintty" /bin/bash -l
-exit
-rem If you don't want to use rxvt then rename the file rxvt.exe to something
-rem else.  Then sh.exe will be used instead.
-:startrxvt
-if NOT EXIST "%WD%rxvt.exe" goto startsh
-rem Setup the default colors for rxvt.
-if "x%MSYSBGCOLOR%" == "x" set MSYSBGCOLOR=White
-if "x%MSYSFGCOLOR%" == "x" set MSYSFGCOLOR=Black
-if "x%MINGW32BGCOLOR%" == "x" set MINGW32BGCOLOR=Black
-if "x%MINGW32FGCOLOR%" == "x" set MINGW32FGCOLOR=White
-if "%MSYSTEM%" == "MSYS" set BGCOLOR=%MSYSBGCOLOR%
-if "%MSYSTEM%" == "MSYS" set FGCOLOR=%MSYSFGCOLOR%
-if "%MSYSTEM%" == "MINGW32" set BGCOLOR=%MINGW32BGCOLOR%
-if "%MSYSTEM%" == "MINGW32" set FGCOLOR=%MINGW32FGCOLOR%
-if "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -i
-if NOT "x%*" == "x" start "MSYS 1.0" "%WD%rxvt" -backspacekey  -sl 2500 -fg %FGCOLOR% -bg %BGCOLOR% -sr -fn Courier-16 -tn msys -geometry 80x25 -e /bin/sh --login -c "%*"
-exit
-:startsh
-if NOT EXIST "%WD%sh.exe" goto notfound
-if "x%*" == "x" start "MSYS 1.0" "%WD%sh" --login -i
-if NOT "x%*" == "x" start "MSYS 1.0" "%WD%sh" --login -c "%*"
-exit
-:EOF
-rem ChangeLog:
-rem 2002.03.07  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Move the @echo off to the top.
-rem	* Change the binmode setting to nobinmode.
-rem     * Remove the angle brackets around email address to workaround MS
-rem	buggy command processor.
-rem
-rem 2002.03.12  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add filter logic to find rxvt.exe
-rem
-rem 2002.03.13  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Revert the nobinmode change.
-rem
-rem 2002.03.20  Earnie Boyd  mailto:earnie at users.sf.net
-rem     * Add logic for stating bash.
-rem
-rem 2002.04.11  Earnie Boyd  mailto;earnie at users.sf.net
-rem	* Add logic for setting MSYSTEM value based on parameter.
-rem
-rem 2002.04.15  Olivier Gautherot  mailto:olivier_gautherot at mentorg.com
-rem	* Reduce number test conditions for finding an executable.
-rem
-rem 2002.04.15  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Unset DISPLAY if set before starting shell.
-rem
-rem 2002.04.16  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Remove use of DEFINED in conditional statments for variables for
-rem	command.com support.
-rem	* Add check for nonexistance of USERNAME variable for Win9x support.
-rem
-rem 2002.04.17  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add foreground and background color defaults based on MSYSTEM value.
-rem
-rem 2002.04.22  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* More Win 9x changes.
-rem
-rem 2002.05.04  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Remove the SET of USERNAME and HOME.
-rem
-rem 2002.11.18  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add command.com detection and restart with a larger environment to
-rem	avoid errors on w9x.
-rem     Many thanks to Randy W. Sims mailto:RandyS at ThePierianSpring.org.
-rem	See Randy's response to "RE: [Mingw-msys] Installation on WindowsME"
-rem	from 11/06/2002 in the archives of mingw-msys at lists.sf.net.
-rem
-rem 2002.11.19  Paul Garceau  mailto:pgarceau at attbi.com
-rem	* Fix a typo: Change COMPSPEC to COMSPEC.
-rem
-rem 2002.11.25  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Remove the SET CYGWIN since it doesn't matter any longer.
-rem
-rem 2003.02.03  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Win9x doesn't like ``EXISTS dir'' so change it to ``EXISTS dir\nul''.
-rem	Thanks to Nicolas Weber mailto:nicolasweber at gmx.de.
-rem
-rem 2003.03.06  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add -backspacekey switch to rxvt startup.
-rem	* Move RXVT color setup to startrxvt label
-rem
-rem 2004.01.30  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add -geometry parameter to work around an off by one issue with
-rem       the default values.
-rem	Thanks to Dave Schuyler mailto:parameter at users.sf.net
-rem
-rem 2004.03.28  Earnie Boyd  mailto:earnie at users.sf.net
-rem	* Add -norxvt or --norxvt switch argument.
-rem	Thanks to Keith Marshall mailto:Keith.Marshall at total.com.
-rem	* Add method to determine absolute path of msys.bat so that we no
-rem	longer need to change to the bin directory.  This allows msys.bat to be
-rem	called from any working directory.
-rem	Thanks to Kevin Mack  mailto:kevin.mack at us.cd-adapco.com
-rem
-rem 2005.07.06  Max TE Woodbury  mailto:mtew at users.sf.net
-rem     * Fixed WD check for command.com systems.
-rem     * Minimized intermediate CMD window to reduce startup flashyness.
-rem     * If rxvt.exe cannot be found, try sh.exe.
-rem
-rem 2005.12.06  Tuomo Latto  mailto:nonperson at users.sf.net
-rem     * Added a temporary workaround for getting MSYS shell to run on x64.
-rem
-rem 2005.12.07  Keith Marshall  mailto:keithmarshall at users.sf.net
-rem     * ``EXISTS %WD%\sh.exe'' should be ``EXISTS %WD%sh.exe''; corrected.
-rem     * Modified Tuomo's patch, to avoid trashing Window settings in Win32.
-rem
-rem 2005.12.08  Tuomo Latto  mailto:nonperson at users.sf.net
-rem     * Keith's modified patch fails on x64; start did funny things.
-rem     Reworked, for correct behaviour on both platforms.
-rem
-rem 2009.03.17  Keith Marshall  mailto:keithmarshall at users.sf.net
-rem     * Add -rxvt or --rxvt switch; start in --norxvt mode by default.
-rem     Make it deterministic; (do not inherit MSYSCON from parent).
-rem
