[GRASS-SVN] r67214 - in grass/trunk: . include include/Make
Fri Dec 18 00:30:15 PST 2015
Author: mmetz
Date: 2015-12-18 00:30:15 -0800 (Fri, 18 Dec 2015)
New Revision: 67214
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Grass.make
   grass/trunk/include/Make/Platform.make.in
   grass/trunk/include/config.h.in
configure: add bzip2 support
Modified: grass/trunk/configure
--- grass/trunk/configure	2015-12-18 08:28:13 UTC (rev 67213)
+++ grass/trunk/configure	2015-12-18 08:30:15 UTC (rev 67214)
@@ -67,6 +67,8 @@
 ac_help="$ac_help
   --with-opencl           support OpenCL functionality (default: no)"
 ac_help="$ac_help
+  --with-bzlib            support BZIP2 functionality (default: no)"
+ac_help="$ac_help
   --with-gdal[=path/gdal-config]
                           enable GDAL/OGR support (gdal-config with path,
                           e.g. '--with-gdal=/usr/local/bin/gdal-config')"
@@ -95,6 +97,11 @@
 ac_help="$ac_help
   --with-zlib-libs=DIRS   zlib library files are in DIRS"
 ac_help="$ac_help
+  --with-bzlib-includes=DIRS
+                          BZIP2 include files are in DIRS"
+ac_help="$ac_help
+  --with-bzlib-libs=DIRS  BZIP2 library files are in DIRS"
+ac_help="$ac_help
   --with-readline-includes=DIRS
                           Readline include files are in DIRS"
 ac_help="$ac_help
@@ -738,7 +745,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:742: checking host system type" >&5
+echo "configure:749: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -761,7 +768,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:765: checking for $ac_word" >&5
+echo "configure:772: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -788,7 +795,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:792: checking for $ac_word" >&5
+echo "configure:799: checking for $ac_word" >&5
@@ -836,7 +843,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:840: checking for $ac_word" >&5
+echo "configure:847: checking for $ac_word" >&5
@@ -865,7 +872,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:869: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:876: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -876,12 +883,12 @@
 cat > conftest.$ac_ext << EOF
-#line 880 "configure"
+#line 887 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -907,19 +914,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:911: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:918: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:916: checking whether we are using GNU C" >&5
+echo "configure:923: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:923: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -937,7 +944,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:941: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:948: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -966,10 +973,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:970: checking for Cygwin environment" >&5
+echo "configure:977: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 973 "configure"
+#line 980 "configure"
 int main() {
@@ -980,7 +987,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:984: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:991: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -996,17 +1003,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1000: checking for mingw32 environment" >&5
+echo "configure:1007: checking for mingw32 environment" >&5
-#line 1003 "configure"
+#line 1010 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1010: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1017: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1024,7 +1031,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1028: checking for executable suffix" >&5
+echo "configure:1035: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1043,23 +1050,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1047: checking for full floating-point support" >&5
+echo "configure:1054: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1052: checking whether "cc -mieee" works" >&5
+echo "configure:1059: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1056 "configure"
+#line 1063 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1063: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1070: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1075,7 +1082,7 @@
 else
-#line 1079 "configure"
+#line 1086 "configure"
 #include <float.h>
@@ -1089,7 +1096,7 @@
 EOF
-if { (eval echo configure:1093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1102,14 +1109,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1106: checking for full floating-point support with -mieee" >&5
+echo "configure:1113: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1113 "configure"
+#line 1120 "configure"
 #include <float.h>
@@ -1123,7 +1130,7 @@
 EOF
-if { (eval echo configure:1127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1160,7 +1167,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1164: checking for $ac_word" >&5
+echo "configure:1171: checking for $ac_word" >&5
 case "$pwd" in
@@ -1198,7 +1205,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1202: checking for source directory" >&5
+echo "configure:1209: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1209,7 +1216,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1213: checking for build directory" >&5
+echo "configure:1220: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1277,7 +1284,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
-echo "configure:1281: checking for $ac_word" >&5
+echo "configure:1288: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1336,7 +1343,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1340: checking for MacOSX App" >&5
+echo "configure:1347: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1348,7 +1355,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1352: checking for MacOSX architectures" >&5
+echo "configure:1359: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1377,7 +1384,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1381: checking for MacOSX SDK" >&5
+echo "configure:1388: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1387,7 +1394,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1391: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1398: checking for $with_macosx_sdk/SDKSettings.plist" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1431,7 +1438,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1435: checking how to build libraries" >&5
+echo "configure:1442: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1868,6 +1875,16 @@
+# Check whether --with-bzlib or --without-bzlib was given.
+if test "${with_bzlib+set}" = set; then
+  withval="$with_bzlib"
+else
+  with_bzlib=no
+fi
 # Check whether --with-gdal or --without-gdal was given.
 if test "${with_gdal+set}" = set; then
   withval="$with_gdal"
@@ -1936,6 +1953,23 @@
+# Check whether --with-bzlib-includes or --without-bzlib-includes was given.
+if test "${with_bzlib_includes+set}" = set; then
+  withval="$with_bzlib_includes"
+fi
+# Check whether --with-bzlib-libs or --without-bzlib-libs was given.
+if test "${with_bzlib_libs+set}" = set; then
+  withval="$with_bzlib_libs"
+fi
 # Check whether --with-readline-includes or --without-readline-includes was given.
 if test "${with_readline_includes+set}" = set; then
   withval="$with_readline_includes"
@@ -2292,7 +2326,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2296: checking for additional include dirs" >&5
+echo "configure:2330: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2315,7 +2349,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2319: checking for additional library dirs" >&5
+echo "configure:2353: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2349,7 +2383,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2353: checking for a BSD compatible install" >&5
+echo "configure:2387: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2402,7 +2436,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:2406: checking for $ac_word" >&5
+echo "configure:2440: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2433,13 +2467,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2437: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2471: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-l$ac_lib  $LIBS"
-#line 2443 "configure"
+#line 2477 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -2450,7 +2484,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -2475,7 +2509,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2479: checking for $ac_word" >&5
+echo "configure:2513: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2515,7 +2549,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2519: checking for $ac_word" >&5
+echo "configure:2553: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2546,7 +2580,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2550: checking for $ac_word" >&5
+echo "configure:2584: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2584,7 +2618,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2588: checking for $ac_word" >&5
+echo "configure:2622: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2613,7 +2647,7 @@
-echo "configure:2617: checking for $ac_word" >&5
+echo "configure:2651: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2644,7 +2678,7 @@
-echo "configure:2648: checking for $ac_word" >&5
+echo "configure:2682: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2673,7 +2707,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2677: checking for $ac_word" >&5
+echo "configure:2711: checking for $ac_word" >&5
 case "$PERL" in
@@ -2704,7 +2738,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2708: checking how to run the C preprocessor" >&5
+echo "configure:2742: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2717,13 +2751,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2721 "configure"
+#line 2755 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2727: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2761: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2734,13 +2768,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2738 "configure"
+#line 2772 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2744: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2778: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2751,13 +2785,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2755 "configure"
+#line 2789 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2761: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2795: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2781,10 +2815,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2785: checking for ANSI C header files" >&5
+echo "configure:2819: checking for ANSI C header files" >&5
-#line 2788 "configure"
+#line 2822 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2792,7 +2826,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2830: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2809,7 +2843,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2813 "configure"
+#line 2847 "configure"
 #include <string.h>
 EOF
@@ -2827,7 +2861,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2831 "configure"
+#line 2865 "configure"
 #include <stdlib.h>
 EOF
@@ -2848,7 +2882,7 @@
 else
-#line 2852 "configure"
+#line 2886 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2859,7 +2893,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2886,15 +2920,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2890: checking for $ac_hdr" >&5
+echo "configure:2924: checking for $ac_hdr" >&5
-#line 2893 "configure"
+#line 2927 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2898: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2932: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2923,15 +2957,15 @@
 do
-echo "configure:2927: checking for $ac_hdr" >&5
+echo "configure:2961: checking for $ac_hdr" >&5
-#line 2930 "configure"
+#line 2964 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2969: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2960,15 +2994,15 @@
 do
-echo "configure:2964: checking for $ac_hdr" >&5
+echo "configure:2998: checking for $ac_hdr" >&5
-#line 2967 "configure"
+#line 3001 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2972: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3006: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2997,15 +3031,15 @@
 do
-echo "configure:3001: checking for $ac_hdr" >&5
+echo "configure:3035: checking for $ac_hdr" >&5
-#line 3004 "configure"
+#line 3038 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3009: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3043: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3034,15 +3068,15 @@
 do
-echo "configure:3038: checking for $ac_hdr" >&5
+echo "configure:3072: checking for $ac_hdr" >&5
-#line 3041 "configure"
+#line 3075 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3080: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3068,10 +3102,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3072: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3106: checking whether time.h and sys/time.h may both be included" >&5
-#line 3075 "configure"
+#line 3109 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3080,7 +3114,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3084: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3118: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3100,10 +3134,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3104: checking for off_t" >&5
+echo "configure:3138: checking for off_t" >&5
-#line 3107 "configure"
+#line 3141 "configure"
 #if STDC_HEADERS
@@ -3130,10 +3164,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3134: checking for uid_t in sys/types.h" >&5
+echo "configure:3168: checking for uid_t in sys/types.h" >&5
-#line 3137 "configure"
+#line 3171 "configure"
 EOF
@@ -3161,10 +3195,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3165: checking return type of signal handlers" >&5
+echo "configure:3199: checking return type of signal handlers" >&5
-#line 3168 "configure"
+#line 3202 "configure"
 #include <signal.h>
@@ -3181,7 +3215,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3185: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3219: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3199,10 +3233,10 @@
-echo "configure:3203: checking for Cygwin environment" >&5
+echo "configure:3237: checking for Cygwin environment" >&5
-#line 3206 "configure"
+#line 3240 "configure"
 int main() {
@@ -3213,7 +3247,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3217: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3251: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3231,10 +3265,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3235: checking for $ac_func" >&5
+echo "configure:3269: checking for $ac_func" >&5
-#line 3238 "configure"
+#line 3272 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3257,7 +3291,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3283,10 +3317,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3287: checking for $ac_func" >&5
+echo "configure:3321: checking for $ac_func" >&5
-#line 3290 "configure"
+#line 3324 "configure"
@@ -3309,7 +3343,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3335,10 +3369,10 @@
 for ac_func in drand48
 do
-echo "configure:3339: checking for $ac_func" >&5
+echo "configure:3373: checking for $ac_func" >&5
-#line 3342 "configure"
+#line 3376 "configure"
@@ -3361,7 +3395,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3387,10 +3421,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3391: checking for $ac_func" >&5
+echo "configure:3425: checking for $ac_func" >&5
-#line 3394 "configure"
+#line 3428 "configure"
@@ -3413,7 +3447,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3439,10 +3473,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3443: checking for $ac_func" >&5
+echo "configure:3477: checking for $ac_func" >&5
-#line 3446 "configure"
+#line 3480 "configure"
@@ -3465,7 +3499,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3490,13 +3524,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3494: checking whether setpgrp takes no argument" >&5
+echo "configure:3528: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3500 "configure"
+#line 3534 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3516,7 +3550,7 @@
 EOF
-if { (eval echo configure:3520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3544,16 +3578,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3548: checking for long long int" >&5
+echo "configure:3582: checking for long long int" >&5
-#line 3550 "configure"
+#line 3584 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3557: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3591: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -3573,7 +3607,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3577: checking for W11" >&5
+echo "configure:3611: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3601,7 +3635,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3605: checking for X" >&5
+echo "configure:3639: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3661,12 +3695,12 @@
   # First, try using that file with no special directory specified.
-#line 3665 "configure"
+#line 3699 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3670: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3704: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3735,14 +3769,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3739 "configure"
+#line 3773 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3847,17 +3881,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3851: checking whether -R must be followed by a space" >&5
+echo "configure:3885: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3854 "configure"
+#line 3888 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3873,14 +3907,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3877 "configure"
+#line 3911 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3912,13 +3946,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3916: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3950: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3922 "configure"
+#line 3956 "configure"
@@ -3929,7 +3963,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3950,13 +3984,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3954: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3988: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 3960 "configure"
+#line 3994 "configure"
@@ -3967,7 +4001,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3995,10 +4029,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3999: checking for gethostbyname" >&5
+echo "configure:4033: checking for gethostbyname" >&5
-#line 4002 "configure"
+#line 4036 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -4021,7 +4055,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -4041,13 +4075,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4045: checking for gethostbyname in -lnsl" >&5
+echo "configure:4079: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4051 "configure"
+#line 4085 "configure"
@@ -4058,7 +4092,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4087,10 +4121,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4091: checking for connect" >&5
+echo "configure:4125: checking for connect" >&5
-#line 4094 "configure"
+#line 4128 "configure"
     which can conflict with char connect(); below.  */
@@ -4113,7 +4147,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4133,13 +4167,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4137: checking for connect in -lsocket" >&5
+echo "configure:4171: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4143 "configure"
+#line 4177 "configure"
@@ -4150,7 +4184,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4173,10 +4207,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4177: checking for remove" >&5
+echo "configure:4211: checking for remove" >&5
-#line 4180 "configure"
+#line 4214 "configure"
     which can conflict with char remove(); below.  */
@@ -4199,7 +4233,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4203: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4219,13 +4253,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4223: checking for remove in -lposix" >&5
+echo "configure:4257: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4229 "configure"
+#line 4263 "configure"
@@ -4236,7 +4270,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4259,10 +4293,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4263: checking for shmat" >&5
+echo "configure:4297: checking for shmat" >&5
-#line 4266 "configure"
+#line 4300 "configure"
     which can conflict with char shmat(); below.  */
@@ -4285,7 +4319,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4305,13 +4339,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4309: checking for shmat in -lipc" >&5
+echo "configure:4343: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4315 "configure"
+#line 4349 "configure"
@@ -4322,7 +4356,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4354,13 +4388,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4358: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4392: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4364 "configure"
+#line 4398 "configure"
@@ -4371,7 +4405,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4411,12 +4445,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4415: checking for library containing cuserid" >&5
+echo "configure:4449: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4420 "configure"
+#line 4454 "configure"
@@ -4427,7 +4461,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4438,7 +4472,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4442 "configure"
+#line 4476 "configure"
@@ -4449,7 +4483,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4475,10 +4509,10 @@
 for ac_func in asprintf
 do
-echo "configure:4479: checking for $ac_func" >&5
+echo "configure:4513: checking for $ac_func" >&5
-#line 4482 "configure"
+#line 4516 "configure"
@@ -4501,7 +4535,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4528,10 +4562,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4532: checking for atan" >&5
+echo "configure:4566: checking for atan" >&5
-#line 4535 "configure"
+#line 4569 "configure"
     which can conflict with char atan(); below.  */
@@ -4554,7 +4588,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4572,13 +4606,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4576: checking for atan in -lm" >&5
+echo "configure:4610: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4582 "configure"
+#line 4616 "configure"
@@ -4589,7 +4623,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4616,10 +4650,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4620: checking for dlsym" >&5
+echo "configure:4654: checking for dlsym" >&5
-#line 4623 "configure"
+#line 4657 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4642,7 +4676,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4646: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4660,13 +4694,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4664: checking for dlsym in -ldl" >&5
+echo "configure:4698: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4670 "configure"
+#line 4704 "configure"
@@ -4677,7 +4711,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4704,10 +4738,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4708: checking for iconv" >&5
+echo "configure:4742: checking for iconv" >&5
-#line 4711 "configure"
+#line 4745 "configure"
     which can conflict with char iconv(); below.  */
@@ -4730,7 +4764,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4748,13 +4782,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4752: checking for iconv in -liconv" >&5
+echo "configure:4786: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4758 "configure"
+#line 4792 "configure"
@@ -4765,7 +4799,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4784,13 +4818,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4788: checking for iconv in -lgiconv" >&5
+echo "configure:4822: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4794 "configure"
+#line 4828 "configure"
@@ -4801,7 +4835,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4820,10 +4854,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4824: checking for libiconv" >&5
+echo "configure:4858: checking for libiconv" >&5
-#line 4827 "configure"
+#line 4861 "configure"
     which can conflict with char libiconv(); below.  */
@@ -4846,7 +4880,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -4864,13 +4898,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4868: checking for libiconv in -liconv" >&5
+echo "configure:4902: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4874 "configure"
+#line 4908 "configure"
@@ -4881,7 +4915,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4900,13 +4934,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4904: checking for libiconv in -lgiconv" >&5
+echo "configure:4938: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4910 "configure"
+#line 4944 "configure"
@@ -4917,7 +4951,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4954,10 +4988,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4958: checking for socket" >&5
+echo "configure:4992: checking for socket" >&5
-#line 4961 "configure"
+#line 4995 "configure"
     which can conflict with char socket(); below.  */
@@ -4980,7 +5014,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -4998,13 +5032,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5002: checking for socket in -lsocket" >&5
+echo "configure:5036: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5008 "configure"
+#line 5042 "configure"
@@ -5015,7 +5049,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5063,7 +5097,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5067: checking for location of zlib includes" >&5
+echo "configure:5101: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5089,15 +5123,15 @@
 do
-echo "configure:5093: checking for $ac_hdr" >&5
+echo "configure:5127: checking for $ac_hdr" >&5
-#line 5096 "configure"
+#line 5130 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5135: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5131,7 +5165,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5135: checking for location of zlib library" >&5
+echo "configure:5169: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5156,13 +5190,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5160: checking for deflate in -lz" >&5
+echo "configure:5194: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5166 "configure"
+#line 5200 "configure"
@@ -5173,7 +5207,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5211,6 +5245,180 @@
 # Done checking zlib
+# bzip2 support
+echo $ac_n "checking whether to use bzlib""... $ac_c" 1>&6
+echo "configure:5253: checking whether to use bzlib" >&5
+echo "$ac_t"""$with_bzlib"" 1>&6
+case "$with_bzlib" in
+	"no")	USE_BZIP2=	;;
+	"yes")	USE_BZIP2="1"	;;
+	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
+esac
+if test -n "$USE_BZIP2"; then
+BZLIBLIBPATH=
+BZLIBINCPATH=
+BZLIB=
+# With bzip2 includes directory
+echo $ac_n "checking for location of bzlib includes""... $ac_c" 1>&6
+echo "configure:5273: checking for location of bzlib includes" >&5
+case "$with_bzlib_includes" in
+y | ye | yes | n | no)
+	{ echo "configure: error: *** You must supply a directory to --with-bzlib-includes." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_bzlib_includes" 1>&6
+if test -n "$with_bzlib_includes" ; then
+    for dir in $with_bzlib_includes; do
+        if test -d "$dir"; then
+            BZLIBINCPATH="$BZLIBINCPATH -I$dir"
+        else
+            { echo "configure: error: *** bzlib includes directory $dir does not exist." 1>&2; exit 1; }
+        fi
+    done
+fi
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$BZLIBINCPATH $CPPFLAGS"
+for ac_hdr in bzlib.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:5299: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 5302 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:5307: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=yes"
+else
+  echo "$ac_err" >&5
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+  cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+  echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate bzlib includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
+# With bzip2 library directory
+echo $ac_n "checking for location of bzlib library""... $ac_c" 1>&6
+echo "configure:5341: checking for location of bzlib library" >&5
+case "$with_bzlib_libs" in
+	{ echo "configure: error: *** You must supply a directory to --with-bzlib-libs." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_bzlib_libs" 1>&6
+if test -n "$with_bzlib_libs"; then
+    for dir in $with_bzlib_libs; do
+            BZLIBLIBPATH="$BZLIBLIBPATH -L$dir"
+        else
+            { echo "configure: error: *** bzlib library directory $dir does not exist." 1>&2; exit 1; }
+        fi
+    done
+fi
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$BZLIBLIBPATH $LDFLAGS"
+echo $ac_n "checking for BZ2_bzBuffToBuffCompress in -lbz2""... $ac_c" 1>&6
+echo "configure:5366: checking for BZ2_bzBuffToBuffCompress in -lbz2" >&5
+ac_lib_var=`echo bz2'_'BZ2_bzBuffToBuffCompress | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lbz2  $LIBS"
+#line 5372 "configure"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char BZ2_bzBuffToBuffCompress();
+int main() {
+BZ2_bzBuffToBuffCompress()
+; return 0; }
+EOF
+if { (eval echo configure:5383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  BZLIB="$BZLIB -lbz2 "
+else
+LDFLAGS=${ac_save_ldflags}
+    { echo "configure: error: *** Unable to locate bzlib library." 1>&2; exit 1; }
+fi
+fi # $USE_BZIP2
+# Done checking bzip2
 # Mandatory PROJ dependency
 PROJINC=
@@ -5221,7 +5429,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5225: checking for location of External PROJ.4 includes" >&5
+echo "configure:5433: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5247,15 +5455,15 @@
 do
-echo "configure:5251: checking for $ac_hdr" >&5
+echo "configure:5459: checking for $ac_hdr" >&5
-#line 5254 "configure"
+#line 5462 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5259: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5467: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5292,7 +5500,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5296: checking External PROJ.4 version" >&5
+echo "configure:5504: checking External PROJ.4 version" >&5
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5300,7 +5508,7 @@
 else
-#line 5304 "configure"
+#line 5512 "configure"
 #include <stdio.h>
@@ -5312,7 +5520,7 @@
 EOF
-if { (eval echo configure:5316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5337,7 +5545,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5341: checking for location of External PROJ.4 library" >&5
+echo "configure:5549: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5362,13 +5570,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5366: checking for pj_get_def in -lproj" >&5
+echo "configure:5574: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5372 "configure"
+#line 5580 "configure"
@@ -5379,7 +5587,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5413,7 +5621,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5417: checking for location of External PROJ.4 data files" >&5
+echo "configure:5625: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5437,14 +5645,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5441: checking for epsg" >&5
+echo "configure:5649: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5448: checking for $PROJSHARE/epsg" >&5
+echo "configure:5656: checking for $PROJSHARE/epsg" >&5
@@ -5476,7 +5684,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5480: checking for $ac_word" >&5
+echo "configure:5688: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5516,7 +5724,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5520: checking whether to use regex" >&5
+echo "configure:5728: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5536,7 +5744,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5540: checking for location of regex includes" >&5
+echo "configure:5748: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5562,15 +5770,15 @@
 do
-echo "configure:5566: checking for $ac_hdr" >&5
+echo "configure:5774: checking for $ac_hdr" >&5
-#line 5569 "configure"
+#line 5777 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5574: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5782: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5604,7 +5812,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5608: checking for location of regex library" >&5
+echo "configure:5816: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5629,10 +5837,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5633: checking for regcomp" >&5
+echo "configure:5841: checking for regcomp" >&5
-#line 5636 "configure"
+#line 5844 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5655,7 +5863,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5682,13 +5890,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5686: checking for regcomp in -lregex" >&5
+echo "configure:5894: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5692 "configure"
+#line 5900 "configure"
@@ -5699,7 +5907,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5749,7 +5957,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5753: checking whether to use Readline" >&5
+echo "configure:5961: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5770,7 +5978,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5774: checking for location of Readline includes" >&5
+echo "configure:5982: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5796,15 +6004,15 @@
 do
-echo "configure:5800: checking for $ac_hdr" >&5
+echo "configure:6008: checking for $ac_hdr" >&5
-#line 5803 "configure"
+#line 6011 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6016: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5840,15 +6048,15 @@
 do
-echo "configure:5844: checking for $ac_hdr" >&5
+echo "configure:6052: checking for $ac_hdr" >&5
-#line 5847 "configure"
+#line 6055 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5852: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5882,7 +6090,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5886: checking for location of Readline library" >&5
+echo "configure:6094: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5907,13 +6115,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5911: checking for readline in -lreadline" >&5
+echo "configure:6119: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 5917 "configure"
+#line 6125 "configure"
@@ -5924,7 +6132,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:5928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5959,13 +6167,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:5963: checking for add_history in -lhistory" >&5
+echo "configure:6171: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 5969 "configure"
+#line 6177 "configure"
@@ -5976,7 +6184,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:5980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6018,7 +6226,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6022: checking whether to use GDAL" >&5
+echo "configure:6230: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6036,7 +6244,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6040: checking for $ac_word" >&5
+echo "configure:6248: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6091,14 +6299,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6095 "configure"
+#line 6303 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6107,14 +6315,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6111 "configure"
+#line 6319 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6146,7 +6354,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6150: checking whether to use libLAS" >&5
+echo "configure:6358: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6163,7 +6371,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6167: checking for $ac_word" >&5
+echo "configure:6375: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6213,14 +6421,14 @@
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
   CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
-#line 6217 "configure"
+#line 6425 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6228,14 +6436,14 @@
   rm -rf conftest*
-#line 6232 "configure"
+#line 6440 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6268,7 +6476,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6272: checking whether to use NetCDF" >&5
+echo "configure:6480: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6285,7 +6493,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6289: checking for $ac_word" >&5
+echo "configure:6497: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6332,14 +6540,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6336 "configure"
+#line 6544 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6347,14 +6555,14 @@
   rm -rf conftest*
-#line 6351 "configure"
+#line 6559 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6385,7 +6593,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6389: checking whether to use GEOS" >&5
+echo "configure:6597: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6403,7 +6611,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6407: checking for $ac_word" >&5
+echo "configure:6615: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6451,15 +6659,15 @@
 do
-echo "configure:6455: checking for $ac_hdr" >&5
+echo "configure:6663: checking for $ac_hdr" >&5
-#line 6458 "configure"
+#line 6666 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6463: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6498,13 +6706,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6502: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6710: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6508 "configure"
+#line 6716 "configure"
@@ -6515,7 +6723,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6559,7 +6767,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6563: checking whether to use TIFF" >&5
+echo "configure:6771: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6579,7 +6787,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6583: checking for location of TIFF includes" >&5
+echo "configure:6791: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6605,15 +6813,15 @@
 do
-echo "configure:6609: checking for $ac_hdr" >&5
+echo "configure:6817: checking for $ac_hdr" >&5
-#line 6612 "configure"
+#line 6820 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6617: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6825: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6647,7 +6855,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6651: checking for location of TIFF library" >&5
+echo "configure:6859: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6678,13 +6886,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6682: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6890: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6688 "configure"
+#line 6896 "configure"
@@ -6695,7 +6903,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6714,13 +6922,13 @@
-echo "configure:6718: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6926: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6724 "configure"
+#line 6932 "configure"
@@ -6731,7 +6939,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6750,13 +6958,13 @@
-echo "configure:6754: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6962: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6760 "configure"
+#line 6968 "configure"
@@ -6767,7 +6975,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6786,13 +6994,13 @@
-echo "configure:6790: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6998: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6796 "configure"
+#line 7004 "configure"
@@ -6803,7 +7011,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6822,13 +7030,13 @@
-echo "configure:6826: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7034: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 6832 "configure"
+#line 7040 "configure"
@@ -6839,7 +7047,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6858,13 +7066,13 @@
-echo "configure:6862: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7070: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6868 "configure"
+#line 7076 "configure"
@@ -6875,7 +7083,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6894,13 +7102,13 @@
-echo "configure:6898: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7106: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6904 "configure"
+#line 7112 "configure"
@@ -6911,7 +7119,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6930,13 +7138,13 @@
-echo "configure:6934: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7142: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6940 "configure"
+#line 7148 "configure"
@@ -6947,7 +7155,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7045,7 +7253,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7049: checking whether to use PNG" >&5
+echo "configure:7257: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7064,7 +7272,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7068: checking for location of PNG includes" >&5
+echo "configure:7276: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7090,15 +7298,15 @@
 do
-echo "configure:7094: checking for $ac_hdr" >&5
+echo "configure:7302: checking for $ac_hdr" >&5
-#line 7097 "configure"
+#line 7305 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7102: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7310: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7132,7 +7340,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7136: checking for location of PNG library" >&5
+echo "configure:7344: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7157,13 +7365,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7161: checking for png_read_image in -lpng" >&5
+echo "configure:7369: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7167 "configure"
+#line 7375 "configure"
@@ -7174,7 +7382,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7216,7 +7424,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7220: checking whether to use PostgreSQL" >&5
+echo "configure:7428: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7243,7 +7451,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7247: checking for location of PostgreSQL includes" >&5
+echo "configure:7455: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7269,15 +7477,15 @@
 do
-echo "configure:7273: checking for $ac_hdr" >&5
+echo "configure:7481: checking for $ac_hdr" >&5
-#line 7276 "configure"
+#line 7484 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7315,7 +7523,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7319: checking for location of PostgreSQL library" >&5
+echo "configure:7527: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7344,13 +7552,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7348: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7556: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7354 "configure"
+#line 7562 "configure"
@@ -7361,7 +7569,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7380,13 +7588,13 @@
-echo "configure:7384: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7592: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7390 "configure"
+#line 7598 "configure"
@@ -7397,7 +7605,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7416,13 +7624,13 @@
-echo "configure:7420: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7628: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7426 "configure"
+#line 7634 "configure"
@@ -7433,7 +7641,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7452,13 +7660,13 @@
-echo "configure:7456: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7664: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7462 "configure"
+#line 7670 "configure"
@@ -7469,7 +7677,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7526,13 +7734,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7530: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7738: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7536 "configure"
+#line 7744 "configure"
@@ -7543,7 +7751,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7565,13 +7773,13 @@
-echo "configure:7569: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7777: checking for PQcmdTuples in -lpq" >&5
-#line 7575 "configure"
+#line 7783 "configure"
@@ -7582,7 +7790,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7625,7 +7833,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7629: checking whether to use MySQL" >&5
+echo "configure:7837: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7645,7 +7853,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7649: checking for location of MySQL includes" >&5
+echo "configure:7857: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7671,15 +7879,15 @@
 do
-echo "configure:7675: checking for $ac_hdr" >&5
+echo "configure:7883: checking for $ac_hdr" >&5
-#line 7678 "configure"
+#line 7886 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7683: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7716,7 +7924,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7720: checking for location of MySQL library" >&5
+echo "configure:7928: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7747,13 +7955,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7751: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7959: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7757 "configure"
+#line 7965 "configure"
@@ -7764,7 +7972,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7783,13 +7991,13 @@
-echo "configure:7787: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7995: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7793 "configure"
+#line 8001 "configure"
@@ -7800,7 +8008,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7819,13 +8027,13 @@
-echo "configure:7823: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8031: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7829 "configure"
+#line 8037 "configure"
@@ -7836,7 +8044,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7855,13 +8063,13 @@
-echo "configure:7859: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8067: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7865 "configure"
+#line 8073 "configure"
@@ -7872,7 +8080,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7891,13 +8099,13 @@
-echo "configure:7895: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8103: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7901 "configure"
+#line 8109 "configure"
@@ -7908,7 +8116,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7927,13 +8135,13 @@
-echo "configure:7931: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8139: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7937 "configure"
+#line 8145 "configure"
@@ -7944,7 +8152,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7963,13 +8171,13 @@
-echo "configure:7967: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8175: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7973 "configure"
+#line 8181 "configure"
@@ -7980,7 +8188,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7999,13 +8207,13 @@
-echo "configure:8003: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8211: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8009 "configure"
+#line 8217 "configure"
@@ -8016,7 +8224,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8106,7 +8314,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8110: checking for $ac_word" >&5
+echo "configure:8318: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8155,10 +8363,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8159: checking for mysql_server_init" >&5
+echo "configure:8367: checking for mysql_server_init" >&5
-#line 8162 "configure"
+#line 8370 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -8184,7 +8392,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8236,7 +8444,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8240: checking whether to use SQLite" >&5
+echo "configure:8448: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8256,7 +8464,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8260: checking for location of SQLite includes" >&5
+echo "configure:8468: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8282,15 +8490,15 @@
 do
-echo "configure:8286: checking for $ac_hdr" >&5
+echo "configure:8494: checking for $ac_hdr" >&5
-#line 8289 "configure"
+#line 8497 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8294: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8333,7 +8541,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8337: checking for location of SQLite library" >&5
+echo "configure:8545: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8362,13 +8570,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8366: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8574: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8372 "configure"
+#line 8580 "configure"
@@ -8379,7 +8587,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8398,13 +8606,13 @@
-echo "configure:8402: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8610: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8408 "configure"
+#line 8616 "configure"
@@ -8415,7 +8623,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8434,13 +8642,13 @@
-echo "configure:8438: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8646: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8444 "configure"
+#line 8652 "configure"
@@ -8451,7 +8659,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8470,13 +8678,13 @@
-echo "configure:8474: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8682: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8480 "configure"
+#line 8688 "configure"
@@ -8487,7 +8695,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8562,7 +8770,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:8566: checking whether to use OpenGL" >&5
+echo "configure:8774: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -8596,7 +8804,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:8600: checking for location of OpenGL includes" >&5
+echo "configure:8808: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -8622,15 +8830,15 @@
 do
-echo "configure:8626: checking for $ac_hdr" >&5
+echo "configure:8834: checking for $ac_hdr" >&5
-#line 8629 "configure"
+#line 8837 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8842: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8664,7 +8872,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:8668: checking for location of OpenGL library" >&5
+echo "configure:8876: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -8693,13 +8901,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:8697: checking for glBegin in -lGL" >&5
+echo "configure:8905: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 8703 "configure"
+#line 8911 "configure"
@@ -8710,7 +8918,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:8714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8729,13 +8937,13 @@
-echo "configure:8733: checking for glBegin in -lGL" >&5
+echo "configure:8941: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 8739 "configure"
+#line 8947 "configure"
@@ -8746,7 +8954,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8765,13 +8973,13 @@
-echo "configure:8769: checking for glBegin in -lGL" >&5
+echo "configure:8977: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 8775 "configure"
+#line 8983 "configure"
@@ -8782,7 +8990,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:8786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8801,13 +9009,13 @@
-echo "configure:8805: checking for glBegin in -lGL" >&5
+echo "configure:9013: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 8811 "configure"
+#line 9019 "configure"
@@ -8818,7 +9026,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8880,13 +9088,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:8884: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9092: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 8890 "configure"
+#line 9098 "configure"
@@ -8897,7 +9105,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:8901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8916,13 +9124,13 @@
-echo "configure:8920: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9128: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 8926 "configure"
+#line 9134 "configure"
@@ -8933,7 +9141,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:8937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8980,10 +9188,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:8984: checking for glXCreatePbuffer" >&5
+echo "configure:9192: checking for glXCreatePbuffer" >&5
-#line 8987 "configure"
+#line 9195 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9006,7 +9214,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9043,10 +9251,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9047: checking for glXCreateGLXPixmap" >&5
+echo "configure:9255: checking for glXCreateGLXPixmap" >&5
-#line 9050 "configure"
+#line 9258 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9069,7 +9277,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9112,7 +9320,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9116: checking for location of OpenGL framework" >&5
+echo "configure:9324: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9136,15 +9344,15 @@
 do
-echo "configure:9140: checking for $ac_hdr" >&5
+echo "configure:9348: checking for $ac_hdr" >&5
-#line 9143 "configure"
+#line 9351 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9148: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9356: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9180,10 +9388,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9184: checking for glBegin" >&5
+echo "configure:9392: checking for glBegin" >&5
-#line 9187 "configure"
+#line 9395 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9206,7 +9414,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9243,10 +9451,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9247: checking for gluBeginCurve" >&5
+echo "configure:9455: checking for gluBeginCurve" >&5
-#line 9250 "configure"
+#line 9458 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9269,7 +9477,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9317,7 +9525,7 @@
-echo "configure:9321: checking for location of OpenGL includes" >&5
+echo "configure:9529: checking for location of OpenGL includes" >&5
@@ -9343,15 +9551,15 @@
 do
-echo "configure:9347: checking for $ac_hdr" >&5
+echo "configure:9555: checking for $ac_hdr" >&5
-#line 9350 "configure"
+#line 9558 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9563: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9385,7 +9593,7 @@
-echo "configure:9389: checking for location of OpenGL library" >&5
+echo "configure:9597: checking for location of OpenGL library" >&5
@@ -9410,18 +9618,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9414: checking for OpenGL library" >&5
+echo "configure:9622: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9418 "configure"
+#line 9626 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -9445,18 +9653,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9449: checking for GLU library" >&5
+echo "configure:9657: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 9453 "configure"
+#line 9661 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -9505,7 +9713,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:9509: checking whether to use ODBC" >&5
+echo "configure:9717: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -9524,7 +9732,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:9528: checking for location of ODBC includes" >&5
+echo "configure:9736: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -9550,15 +9758,15 @@
 do
-echo "configure:9554: checking for $ac_hdr" >&5
+echo "configure:9762: checking for $ac_hdr" >&5
-#line 9557 "configure"
+#line 9765 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9592,7 +9800,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:9596: checking for location of ODBC library" >&5
+echo "configure:9804: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -9617,13 +9825,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:9621: checking for SQLConnect in -lodbc" >&5
+echo "configure:9829: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 9627 "configure"
+#line 9835 "configure"
@@ -9634,7 +9842,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:9638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9659,13 +9867,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:9663: checking for SQLConnect in -liodbc" >&5
+echo "configure:9871: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 9669 "configure"
+#line 9877 "configure"
@@ -9676,7 +9884,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:9680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9701,11 +9909,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:9705: checking for ODBC library" >&5
+echo "configure:9913: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 9709 "configure"
+#line 9917 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -9713,7 +9921,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:9717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -9762,7 +9970,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:9766: checking whether to use FFTW" >&5
+echo "configure:9974: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -9781,7 +9989,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:9785: checking for location of FFTW includes" >&5
+echo "configure:9993: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -9807,15 +10015,15 @@
 do
-echo "configure:9811: checking for $ac_hdr" >&5
+echo "configure:10019: checking for $ac_hdr" >&5
-#line 9814 "configure"
+#line 10022 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9843,15 +10051,15 @@
 do
-echo "configure:9847: checking for $ac_hdr" >&5
+echo "configure:10055: checking for $ac_hdr" >&5
-#line 9850 "configure"
+#line 10058 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10063: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9879,15 +10087,15 @@
 do
-echo "configure:9883: checking for $ac_hdr" >&5
+echo "configure:10091: checking for $ac_hdr" >&5
-#line 9886 "configure"
+#line 10094 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9933,7 +10141,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:9937: checking for location of FFTW library" >&5
+echo "configure:10145: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -9958,13 +10166,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:9962: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10170: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 9968 "configure"
+#line 10176 "configure"
@@ -9975,7 +10183,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:9979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10000,13 +10208,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10004: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10212: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10010 "configure"
+#line 10218 "configure"
@@ -10017,7 +10225,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10042,13 +10250,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10046: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10254: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10052 "configure"
+#line 10260 "configure"
@@ -10059,7 +10267,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10116,7 +10324,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10120: checking whether to use BLAS" >&5
+echo "configure:10328: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10137,7 +10345,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10141: checking for location of BLAS includes" >&5
+echo "configure:10349: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10157,7 +10365,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10161: checking for location of BLAS library" >&5
+echo "configure:10369: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10183,15 +10391,15 @@
 do
-echo "configure:10187: checking for $ac_hdr" >&5
+echo "configure:10395: checking for $ac_hdr" >&5
-#line 10190 "configure"
+#line 10398 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10195: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10226,13 +10434,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10230: checking for dnrm2_ in -lblas" >&5
+echo "configure:10438: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10236 "configure"
+#line 10444 "configure"
@@ -10243,7 +10451,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10262,13 +10470,13 @@
-echo "configure:10266: checking for dnrm2_ in -lblas" >&5
+echo "configure:10474: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 10272 "configure"
+#line 10480 "configure"
 #include "confdefs.h"
@@ -10279,7 +10487,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10323,13 +10531,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10327: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10535: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10333 "configure"
+#line 10541 "configure"
@@ -10340,7 +10548,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10355,13 +10563,13 @@
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10359: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10567: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lf77blas -latlas $LIBS"
-#line 10365 "configure"
+#line 10573 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -10372,7 +10580,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -10387,13 +10595,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10391: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10599: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10397 "configure"
+#line 10605 "configure"
@@ -10404,7 +10612,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:10408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10450,16 +10658,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10454: checking for sgemm in $vlib_flags" >&5
+echo "configure:10662: checking for sgemm in $vlib_flags" >&5
-#line 10456 "configure"
+#line 10664 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:10463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -10477,13 +10685,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10481: checking for sgemm_ in -lblas" >&5
+echo "configure:10689: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 10487 "configure"
+#line 10695 "configure"
@@ -10494,7 +10702,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10509,13 +10717,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:10513: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10721: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 10519 "configure"
+#line 10727 "configure"
@@ -10526,7 +10734,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10541,13 +10749,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:10545: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10753: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 10551 "configure"
+#line 10759 "configure"
@@ -10558,7 +10766,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10592,13 +10800,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:10596: checking for acosp in -lsunmath" >&5
+echo "configure:10804: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 10602 "configure"
+#line 10810 "configure"
@@ -10609,7 +10817,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:10613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10624,13 +10832,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:10628: checking for sgemm_ in -lsunperf" >&5
+echo "configure:10836: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 10634 "configure"
+#line 10842 "configure"
@@ -10641,7 +10849,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10671,13 +10879,13 @@
 # Generic BLAS library
-echo "configure:10675: checking for sgemm_ in -lblas" >&5
+echo "configure:10883: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 10681 "configure"
+#line 10889 "configure"
@@ -10688,7 +10896,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10727,7 +10935,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:10731: checking whether to use LAPACK" >&5
+echo "configure:10939: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -10752,7 +10960,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:10756: checking for location of LAPACK includes" >&5
+echo "configure:10964: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -10772,7 +10980,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:10776: checking for location of LAPACK library" >&5
+echo "configure:10984: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -10798,15 +11006,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:10802: checking for $ac_hdr" >&5
+echo "configure:11010: checking for $ac_hdr" >&5
-#line 10805 "configure"
+#line 11013 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:10810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -10838,10 +11046,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:10842: checking for dsegv_" >&5
+echo "configure:11050: checking for dsegv_" >&5
-#line 10845 "configure"
+#line 11053 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -10864,7 +11072,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -10891,13 +11099,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:10895: checking for desgv_ in -llapack" >&5
+echo "configure:11103: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 10901 "configure"
+#line 11109 "configure"
@@ -10908,7 +11116,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:10912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10940,13 +11148,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:10944: checking for dgesv_ in -llapack" >&5
+echo "configure:11152: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 10950 "configure"
+#line 11158 "configure"
@@ -10957,7 +11165,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:10961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10976,13 +11184,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10980: checking for dgesv_ in -llapack" >&5
+echo "configure:11188: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 10986 "configure"
+#line 11194 "configure"
@@ -10993,7 +11201,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:10997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11049,7 +11257,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11053: checking whether to use Cairo" >&5
+echo "configure:11261: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11081,7 +11289,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11085: checking for location of cairo includes" >&5
+echo "configure:11293: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11107,15 +11315,15 @@
 do
-echo "configure:11111: checking for $ac_hdr" >&5
+echo "configure:11319: checking for $ac_hdr" >&5
-#line 11114 "configure"
+#line 11322 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11119: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11151,7 +11359,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11155: checking for location of cairo library" >&5
+echo "configure:11363: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11171,7 +11379,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11175: checking for cairo linking flags" >&5
+echo "configure:11383: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11187,10 +11395,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11191: checking for cairo_create" >&5
+echo "configure:11399: checking for cairo_create" >&5
-#line 11194 "configure"
+#line 11402 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -11213,7 +11421,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11247,10 +11455,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11251: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11459: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11254 "configure"
+#line 11462 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11273,7 +11481,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11306,10 +11514,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11310: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11518: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11313 "configure"
+#line 11521 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11332,7 +11540,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -11374,7 +11582,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11378: checking whether to use FreeType" >&5
+echo "configure:11586: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -11393,7 +11601,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11397: checking for location of FreeType includes" >&5
+echo "configure:11605: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11419,15 +11627,15 @@
 do
-echo "configure:11423: checking for $ac_hdr" >&5
+echo "configure:11631: checking for $ac_hdr" >&5
-#line 11426 "configure"
+#line 11634 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11431: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11639: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11461,7 +11669,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11465: checking for location of FreeType library" >&5
+echo "configure:11673: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11486,13 +11694,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11490: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11698: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 11496 "configure"
+#line 11704 "configure"
@@ -11503,7 +11711,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:11507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11544,7 +11752,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:11548: checking whether to use NLS" >&5
+echo "configure:11756: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -11564,10 +11772,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:11568: checking for gettext" >&5
+echo "configure:11776: checking for gettext" >&5
-#line 11571 "configure"
+#line 11779 "configure"
     which can conflict with char gettext(); below.  */
@@ -11590,7 +11798,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11594: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -11608,13 +11816,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:11612: checking for gettext in -lintl" >&5
+echo "configure:11820: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 11618 "configure"
+#line 11826 "configure"
@@ -11625,7 +11833,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:11629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11660,7 +11868,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:11664: checking whether to use C++" >&5
+echo "configure:11872: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -11676,7 +11884,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:11680: checking for $ac_word" >&5
+echo "configure:11888: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -11705,7 +11913,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:11709: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:11917: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -11716,12 +11924,12 @@
 cat > conftest.$ac_ext << EOF
-#line 11720 "configure"
+#line 11928 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:11725: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -11747,19 +11955,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:11751: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:11959: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:11756: checking whether we are using GNU C++" >&5
+echo "configure:11964: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:11763: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:11971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -11777,7 +11985,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:11781: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:11989: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -11805,7 +12013,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 12027 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12035: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 12045 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -11818,7 +12077,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:11822: checking whether to use openDWG" >&5
+echo "configure:12081: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -11838,7 +12097,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:11842: checking for location of openDGW includes" >&5
+echo "configure:12101: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -11864,15 +12123,15 @@
 do
-echo "configure:11868: checking for $ac_hdr" >&5
+echo "configure:12127: checking for $ac_hdr" >&5
-#line 11871 "configure"
+#line 12130 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12135: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11906,7 +12165,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:11910: checking for location of openDWG library" >&5
+echo "configure:12169: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -11947,7 +12206,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:11951: checking whether to use POSIX threads" >&5
+echo "configure:12210: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -11967,7 +12226,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:11971: checking for location of POSIX threads includes" >&5
+echo "configure:12230: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -11993,15 +12252,15 @@
 do
-echo "configure:11997: checking for $ac_hdr" >&5
+echo "configure:12256: checking for $ac_hdr" >&5
-#line 12000 "configure"
+#line 12259 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12005: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12035,7 +12294,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12039: checking for location of POSIX threads library" >&5
+echo "configure:12298: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12060,10 +12319,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12064: checking for pthread_create" >&5
+echo "configure:12323: checking for pthread_create" >&5
-#line 12067 "configure"
+#line 12326 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12086,7 +12345,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12113,13 +12372,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12117: checking for pthread_create in -lpthread" >&5
+echo "configure:12376: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 12123 "configure"
+#line 12382 "configure"
@@ -12130,7 +12389,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12180,7 +12439,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12184: checking whether to use OpenMP" >&5
+echo "configure:12443: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12201,7 +12460,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12205: checking for location of OpenMP includes" >&5
+echo "configure:12464: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12227,15 +12486,15 @@
 do
-echo "configure:12231: checking for $ac_hdr" >&5
+echo "configure:12490: checking for $ac_hdr" >&5
-#line 12234 "configure"
+#line 12493 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12239: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12498: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12273,7 +12532,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12277: checking for location of OpenMP library" >&5
+echo "configure:12536: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12298,10 +12557,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12302: checking for GOMP_parallel_start" >&5
+echo "configure:12561: checking for GOMP_parallel_start" >&5
-#line 12305 "configure"
+#line 12564 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12324,7 +12583,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12351,13 +12610,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12355: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12614: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12361 "configure"
+#line 12620 "configure"
@@ -12368,7 +12627,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12441,7 +12700,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12445: checking whether to use OpenCL" >&5
+echo "configure:12704: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -12461,7 +12720,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12465: checking for location of OpenCL includes" >&5
+echo "configure:12724: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12488,15 +12747,15 @@
 do
-echo "configure:12492: checking for $ac_hdr" >&5
+echo "configure:12751: checking for $ac_hdr" >&5
-#line 12495 "configure"
+#line 12754 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12500: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12536,10 +12795,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12540: checking for clGetPlatformInfo" >&5
+echo "configure:12799: checking for clGetPlatformInfo" >&5
-#line 12543 "configure"
+#line 12802 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -12562,7 +12821,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -12601,15 +12860,15 @@
 do
-echo "configure:12605: checking for $ac_hdr" >&5
+echo "configure:12864: checking for $ac_hdr" >&5
-#line 12608 "configure"
+#line 12867 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12613: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12872: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12642,7 +12901,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:12646: checking for location of OpenCL library" >&5
+echo "configure:12905: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -12666,13 +12925,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:12670: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:12929: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 12676 "configure"
+#line 12935 "configure"
@@ -12683,7 +12942,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:12687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12743,7 +13002,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:12747: checking for special C compiler options needed for large files" >&5
+echo "configure:13006: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -12751,7 +13010,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 12755 "configure"
+#line 13014 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -12767,7 +13026,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12771: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13030: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -12776,7 +13035,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 12780 "configure"
+#line 13039 "configure"
@@ -12792,7 +13051,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12796: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13055: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -12819,11 +13078,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:12823: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13082: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 12827 "configure"
+#line 13086 "configure"
@@ -12839,14 +13098,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12843: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13102: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 12850 "configure"
+#line 13109 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -12864,7 +13123,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12868: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13127: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -12890,11 +13149,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:12894: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13153: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 12898 "configure"
+#line 13157 "configure"
@@ -12910,14 +13169,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12914: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13173: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 12921 "configure"
+#line 13180 "configure"
 #define _LARGE_FILES 1
@@ -12935,7 +13194,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12939: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13198: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -12961,25 +13220,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:12965: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13224: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 12969 "configure"
+#line 13228 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:12976: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13235: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 12983 "configure"
+#line 13242 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -12988,7 +13247,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:12992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13251: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13020,25 +13279,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13024: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13283: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13028 "configure"
+#line 13287 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13035: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13294: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13042 "configure"
+#line 13301 "configure"
 #include <stdio.h>
@@ -13047,7 +13306,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13051: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13310: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13077,18 +13336,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13081: checking for fseeko" >&5
+echo "configure:13340: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13085 "configure"
+#line 13344 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13105,10 +13364,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13109: checking if system supports Large Files at all" >&5
+echo "configure:13368: checking if system supports Large Files at all" >&5
-#line 13112 "configure"
+#line 13371 "configure"
 #include <stdio.h>
@@ -13140,7 +13399,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13144: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13403: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13335,6 +13594,9 @@
 s%@ZLIBINCPATH@%$ZLIBINCPATH%g
 s%@ZLIBLIBPATH@%$ZLIBLIBPATH%g
 s%@ZLIB@%$ZLIB%g
+s%@BZLIBINCPATH@%$BZLIBINCPATH%g
+s%@BZLIBLIBPATH@%$BZLIBLIBPATH%g
+s%@BZLIB@%$BZLIB%g
 s%@PROJINC@%$PROJINC%g
 s%@PROJLIB@%$PROJLIB%g
 s%@PROJSHARE@%$PROJSHARE%g
@@ -13709,6 +13971,8 @@
 echo "  BLAS support:               `if test -n "${USE_BLAS}" ; then echo yes ; else echo no ; fi`"
+echo "  BZIP2 support:              `if test -n "${USE_BZIP2}" ; then echo yes ; else echo no ; fi`"
 echo "  C++ support:                `if test -n "${USE_CXX}" ; then echo yes ; else echo no ; fi`"
 echo "  Cairo support:              `if test -n "${USE_CAIRO}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2015-12-18 08:28:13 UTC (rev 67213)
+++ grass/trunk/configure.in	2015-12-18 08:30:15 UTC (rev 67214)
@@ -265,6 +265,7 @@
 LOC_ARG_WITH(pthread, POSIX threads, no)
 LOC_ARG_WITH(openmp, OpenMP, no)
 LOC_ARG_WITH(opencl, OpenCL, no)
+LOC_ARG_WITH(bzlib, BZIP2, no)
 AC_ARG_WITH(gdal,
 [  --with-gdal[=path/gdal-config]
@@ -300,6 +301,9 @@
 LOC_ARG_WITH_INC(zlib, zlib)
 LOC_ARG_WITH_LIB(zlib, zlib)
+LOC_ARG_WITH_INC(bzlib, BZIP2)
+LOC_ARG_WITH_LIB(bzlib, BZIP2)
 LOC_ARG_WITH_INC(readline, Readline)
 LOC_ARG_WITH_LIB(readline, Readline)
@@ -580,6 +584,38 @@
 # Done checking zlib
+# bzip2 support
+LOC_CHECK_USE(bzlib,bzlib,USE_BZIP2)
+if test -n "$USE_BZIP2"; then
+BZLIBLIBPATH=
+BZLIBINCPATH=
+BZLIB=
+# With bzip2 includes directory
+LOC_CHECK_INC_PATH(bzlib,bzlib,BZLIBINCPATH)
+LOC_CHECK_INCLUDES(bzlib.h,bzlib,$BZLIBINCPATH)
+# With bzip2 library directory
+LOC_CHECK_LIB_PATH(bzlib,bzlib,BZLIBLIBPATH)
+LOC_CHECK_LIBS(bz2,BZ2_bzBuffToBuffCompress,bzlib,$BZLIBLIBPATH,BZLIB,,,)
+fi # $USE_BZIP2
+AC_SUBST(BZLIBINCPATH)
+AC_SUBST(BZLIBLIBPATH)
+AC_SUBST(BZLIB)
+# Done checking bzip2
 # Mandatory PROJ dependency
 PROJINC=
@@ -1795,6 +1831,7 @@
 LOC_MSG([  MacOSX SDK:                 ${MACOSX_SDK}])
 LOC_MSG()
 LOC_MSG_USE(BLAS support,USE_BLAS)
+LOC_MSG_USE(BZIP2 support,USE_BZIP2)
 LOC_MSG_USE(C++ support,USE_CXX)
 LOC_MSG_USE(Cairo support,USE_CAIRO)
 LOC_MSG_USE(DWG support,USE_OPENDWG)
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make	2015-12-18 08:28:13 UTC (rev 67213)
+++ grass/trunk/include/Make/Grass.make	2015-12-18 08:30:15 UTC (rev 67214)
@@ -195,7 +195,7 @@
 DSPFDEPS         = $(GISLIB)
 FORMDEPS         = $(DBMILIB) $(GISLIB)
 RASTER3DDEPS     = $(RASTERLIB) $(GISLIB)
-GISDEPS          = $(DATETIMELIB) $(ZLIBLIBPATH) $(ZLIB) $(INTLLIB) $(REGEXLIBPATH) $(REGEXLIB) $(ICONVLIB) $(PTHREADLIBPATH) $(PTHREADLIB) $(MATHLIB)
+GISDEPS          = $(DATETIMELIB) $(ZLIBLIBPATH) $(ZLIB) $(BZLIB) $(INTLLIB) $(REGEXLIBPATH) $(REGEXLIB) $(ICONVLIB) $(PTHREADLIBPATH) $(PTHREADLIB) $(MATHLIB)
 GMATHDEPS        = $(GISLIB) $(FFTWLIB) $(LAPACKLIB) $(BLASLIB) $(CCMATHLIB) $(OMPLIBPATH) $(OMPLIB)
 GPDEDEPS         = $(RASTER3DLIB) $(RASTERLIB) $(GISLIB) $(GMATHLIB) $(OMPLIBPATH) $(OMPLIB) $(MATHLIB)
 GPROJDEPS        = $(GISLIB) $(GDALLIBS) $(PROJLIB) $(MATHLIB)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2015-12-18 08:28:13 UTC (rev 67213)
+++ grass/trunk/include/Make/Platform.make.in	2015-12-18 08:30:15 UTC (rev 67214)
@@ -94,6 +94,11 @@
 ZLIBINCPATH         = @ZLIBINCPATH@
 ZLIBLIBPATH         = @ZLIBLIBPATH@
+#BZIP2:
+BZLIB                = @BZLIB@
+BZLIBINCPATH         = @BZLIBINCPATH@
+BZLIBLIBPATH         = @BZLIBLIBPATH@
 DBMIEXTRALIB        = @DBMIEXTRALIB@
 #readline
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in	2015-12-18 08:28:13 UTC (rev 67213)
+++ grass/trunk/include/config.h.in	2015-12-18 08:30:15 UTC (rev 67214)
@@ -38,6 +38,9 @@
 /* define if zlib.h exists */
 #undef HAVE_ZLIB_H
+/* define if bzlib.h exists */
+#undef HAVE_BZLIB_H
 /* define if sys/ioctl.h exists */
 #undef HAVE_SYS_IOCTL_H
