[GRASS-SVN] r67237 - grass-addons/grass7/raster/r.hydrodem
    svn_grass at osgeo.org
    Fri Dec 18 13:13:57 PST 2015
Author: mmetz
Date: 2015-12-18 13:13:57 -0800 (Fri, 18 Dec 2015)
New Revision: 67237
   grass-addons/grass7/raster/r.hydrodem/bseg.c
   grass-addons/grass7/raster/r.hydrodem/cseg.c
   grass-addons/grass7/raster/r.hydrodem/do_astar.c
   grass-addons/grass7/raster/r.hydrodem/dseg.c
   grass-addons/grass7/raster/r.hydrodem/hydro_con.c
   grass-addons/grass7/raster/r.hydrodem/init_search.c
   grass-addons/grass7/raster/r.hydrodem/load.c
   grass-addons/grass7/raster/r.hydrodem/local_proto.h
   grass-addons/grass7/raster/r.hydrodem/main.c
   grass-addons/grass7/raster/r.hydrodem/seg.c
   grass-addons/grass7/raster/r.hydrodem/seg.h
r.hydrodem: sync to r.watershed
Modified: grass-addons/grass7/raster/r.hydrodem/bseg.c
--- grass-addons/grass7/raster/r.hydrodem/bseg.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/bseg.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -2,7 +2,7 @@
 #include <fcntl.h>
 #include <grass/segment.h>
 #include <grass/glocale.h>
-#include "seg.h"
+#include "local_proto.h"
 int bseg_open(BSEG *bseg, int srows, int scols, int nsegs_in_memory)
@@ -73,7 +73,7 @@
     return 0;
-int bseg_put(BSEG *bseg, char *value, int row, int col)
+int bseg_put(BSEG *bseg, char *value, GW_LARGE_INT row, GW_LARGE_INT col)
     if (Segment_put(&(bseg->seg), value, row, col) < 0) {
 	G_warning(_("Unable to write segment file"));
@@ -82,7 +82,7 @@
     return 0;
-int bseg_put_row(BSEG *bseg, char *value, int row)
+int bseg_put_row(BSEG *bseg, char *value, GW_LARGE_INT row)
     if (Segment_put_row(&(bseg->seg), value, row) < 0) {
@@ -91,7 +91,7 @@
     return 0;
-int bseg_get(BSEG *bseg, char *value, int row, int col)
+int bseg_get(BSEG *bseg, char *value, GW_LARGE_INT row, GW_LARGE_INT col)
     if (Segment_get(&(bseg->seg), value, row, col) < 0) {
 	G_warning(_("Unable to read segment file"));
Modified: grass-addons/grass7/raster/r.hydrodem/cseg.c
--- grass-addons/grass7/raster/r.hydrodem/cseg.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/cseg.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -2,7 +2,7 @@
 #include <fcntl.h>
-#include "seg.h"
 int cseg_open(CSEG *cseg, int srows, int scols, int nsegs_in_memory)
@@ -74,7 +74,7 @@
     return 0;
-int cseg_put(CSEG *cseg, CELL *value, int row, int col)
+int cseg_put(CSEG *cseg, CELL *value, GW_LARGE_INT row, GW_LARGE_INT col)
     if (Segment_put(&(cseg->seg), value, row, col) < 0) {
@@ -83,7 +83,7 @@
     return 0;
-int cseg_put_row(CSEG *cseg, CELL *value, int row)
+int cseg_put_row(CSEG *cseg, CELL *value, GW_LARGE_INT row)
     if (Segment_put_row(&(cseg->seg), value, row) < 0) {
@@ -92,7 +92,7 @@
     return 0;
-int cseg_get(CSEG *cseg, CELL *value, int row, int col)
+int cseg_get(CSEG *cseg, CELL *value, GW_LARGE_INT row, GW_LARGE_INT col)
     if (Segment_get(&(cseg->seg), value, row, col) < 0) {
 	G_warning(_("Unabel to read segment file"));
Modified: grass-addons/grass7/raster/r.hydrodem/do_astar.c
--- grass-addons/grass7/raster/r.hydrodem/do_astar.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/do_astar.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -4,8 +4,8 @@
-#define GET_PARENT(c) ((unsigned int)(((c) - 2) >> 2) + 1)
-#define GET_CHILD(p) ((unsigned int)((p) << 2) - 2)
+#define GET_PARENT(c) ((((GW_LARGE_INT)(c) - 2) >> 2) + 1)
+#define GET_CHILD(p) (((GW_LARGE_INT)(p) << 2) - 2)
 #define HEAP_CMP(a, b) (((a)->ele < (b)->ele) ? 1 : \
                        (((a)->ele > (b)->ele) ? 0 : \
@@ -19,7 +19,7 @@
 int do_astar(void)
     int r, c, r_nbr, c_nbr, ct_dir;
-    unsigned int count;
+    GW_LARGE_INT count;
     int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
     int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
     int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
@@ -70,13 +70,13 @@
     while (heap_size > 0) {
 	G_percent(count++, n_points, 1);
 	if (count > n_points)
-	    G_fatal_error(_("BUG in A* Search: %d surplus points"),
-	                  heap_size);
+	    G_fatal_error(_("BUG in A* Search: %lld surplus points"),
+	                  (long long int)heap_size);
 	if (heap_size > n_points)
 	    G_fatal_error
-		(_("BUG in A* Search: too many points in heap %d, should be %d"),
-		 heap_size, n_points);
+		(_("BUG in A* Search: too many points in heap %lld, should be %lld"),
+		 (long long int)heap_size, (long long int)n_points);
 	heap_p = heap_drop();
@@ -104,7 +104,8 @@
 	    /* get r, c (r_nbr, c_nbr) for neighbours */
 	    r_nbr = r + nextdr[ct_dir];
 	    c_nbr = c + nextdc[ct_dir];
-	    slope[ct_dir] = ele_nbr[ct_dir] = 0;
+	    slope[ct_dir] = -1;
+	    ele_nbr[ct_dir] = 0;
 	    /* check that neighbour is within region */
 	    if (r_nbr < 0 || r_nbr >= nrows || c_nbr < 0 || c_nbr >= ncols)
@@ -122,15 +123,15 @@
 		                          dist_to_nbr[ct_dir]);
-	    if (!is_in_list) {
-		if (ct_dir > 3 && slope[ct_dir] > 0) {
-		    if (slope[nbr_ew[ct_dir]] > 0) {
+	    if (!is_worked) {
+		if (ct_dir > 3 && slope[ct_dir] >= 0) {
+		    if (slope[nbr_ew[ct_dir]] >= 0) {
 			/* slope to ew nbr > slope to center */
 			if (slope[ct_dir] < get_slope(ele_nbr[nbr_ew[ct_dir]],
 			                              ele_nbr[ct_dir], ew_res))
 			    skip_diag = 1;
-		    if (!skip_diag && slope[nbr_ns[ct_dir]] > 0) {
+		    if (!skip_diag && slope[nbr_ns[ct_dir]] >= 0) {
 			/* slope to ns nbr > slope to center */
 			if (slope[ct_dir] < get_slope(ele_nbr[nbr_ns[ct_dir]],
 			                              ele_nbr[ct_dir], ns_res))
@@ -210,7 +211,7 @@
     G_percent(n_points, n_points, 1);	/* finish it */
     if (first_cum)
-	G_warning(_("processed points mismatch of %u"), first_cum);
+	G_warning(_("processed points mismatch of %lld"), (long long int)first_cum);
     return 1;
@@ -231,9 +232,9 @@
     return 0;
-int sift_up(unsigned int start, struct heap_point child_p)
+int sift_up(GW_LARGE_INT start, struct heap_point child_p)
-    unsigned int parent, child;
+    GW_LARGE_INT parent, child;
     struct heap_point heap_p;
     child = start;
@@ -263,7 +264,7 @@
  * add item to heap
  * returns heap_size
-unsigned int heap_add(int r, int c, CELL ele)
+GW_LARGE_INT heap_add(int r, int c, CELL ele)
Modified: grass-addons/grass7/raster/r.hydrodem/dseg.c
--- grass-addons/grass7/raster/r.hydrodem/dseg.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/dseg.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -2,7 +2,7 @@
 #include <fcntl.h>
-#include "seg.h"
 int dseg_open(DSEG *dseg, int srows, int scols, int nsegs_in_memory)
@@ -74,7 +74,7 @@
     return 0;
-int dseg_put(DSEG *dseg, DCELL *value, int row, int col)
+int dseg_put(DSEG *dseg, DCELL *value, GW_LARGE_INT row, GW_LARGE_INT col)
     if (Segment_put(&(dseg->seg), (DCELL *) value, row, col) < 0) {
@@ -83,7 +83,7 @@
     return 0;
-int dseg_put_row(DSEG *dseg, DCELL *value, int row)
+int dseg_put_row(DSEG *dseg, DCELL *value, GW_LARGE_INT row)
     if (Segment_put_row(&(dseg->seg), (DCELL *) value, row) < 0) {
@@ -92,7 +92,7 @@
     return 0;
-int dseg_get(DSEG *dseg, DCELL *value, int row, int col)
+int dseg_get(DSEG *dseg, DCELL *value, GW_LARGE_INT row, GW_LARGE_INT col)
     if (Segment_get(&(dseg->seg), (DCELL *) value, row, col) < 0) {
@@ -133,7 +133,7 @@
     return 0;
-int dseg_write_cellfile(DSEG *dseg, char *map_name)
+int dseg_write_raster(DSEG *dseg, char *map_name)
     int map_fd;
     int row, nrows;
Modified: grass-addons/grass7/raster/r.hydrodem/hydro_con.c
--- grass-addons/grass7/raster/r.hydrodem/hydro_con.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/hydro_con.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -27,7 +27,7 @@
                CELL *next_ele)
-    CELL ele_val, ele_nbr;
+    CELL ele_nbr;
     int n_to_fill;
     int top, done;
     struct dir_flag df;
@@ -35,7 +35,6 @@
     /* go upstream from spill point */
     r = peak_r;
     c = peak_c;
-    ele_val = peak_ele;
     *n_splits = 0;
     n_to_fill = 0;
     /* post-order traversal */
@@ -776,9 +775,9 @@
     int ct_dir;
     int skipme;
     CELL ele_min, ele_max, ele_this, ele_nbr;
-    unsigned int n_pits = 0;
-    unsigned int n_peaks = 0;
-    unsigned int counter = 0;
+    GW_LARGE_INT n_pits = 0;
+    GW_LARGE_INT n_peaks = 0;
+    GW_LARGE_INT counter = 0;
     double sumofsquares, mean, stddev, upperci, lowerci;
     int n_valid;
@@ -871,9 +870,9 @@
     G_percent(nrows, nrows, 1);	/* finish it */
-    G_verbose_message("%u cells checked", counter);
-    G_verbose_message("%u one-cell peaks removed", n_peaks);
-    G_verbose_message("%u one-cell pits removed", n_pits);
+    G_verbose_message("%lld cells checked", (long long int)counter);
+    G_verbose_message("%lld one-cell peaks removed", (long long int)n_peaks);
+    G_verbose_message("%lld one-cell pits removed", (long long int)n_pits);
     return 1;
Modified: grass-addons/grass7/raster/r.hydrodem/init_search.c
--- grass-addons/grass7/raster/r.hydrodem/init_search.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/init_search.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -11,8 +11,8 @@
     char asp_value, is_null;
     struct dir_flag df, df_nbr;
-    unsigned int n_depr_cells = 0;
-    unsigned int n_null_cells = nrows * ncols - n_points;
+    GW_LARGE_INT n_depr_cells = 0;
+    GW_LARGE_INT n_null_cells = (GW_LARGE_INT) nrows * ncols - n_points;
     int depr_map_type, depr_size;
     nxt_avail_pt = heap_size = 0;
@@ -141,9 +141,9 @@
 	G_free(depr_buf);
-    G_debug(1, "%d edge cells", heap_size - n_depr_cells);
+    G_debug(1, "%lld edge cells", (long long int) (heap_size - n_depr_cells));
     if (n_depr_cells)
-	G_debug(1, "%d cells in depressions", n_depr_cells);
+	G_debug(1, "%lld cells in depressions", (long long int) n_depr_cells);
     return 1;
Modified: grass-addons/grass7/raster/r.hydrodem/load.c
--- grass-addons/grass7/raster/r.hydrodem/load.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/load.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -92,7 +92,7 @@
     Rast_close(ele_fd);
     G_free(ele_buf);
-    G_debug(1, "%d non-NULL cells", n_points);
+    G_debug(1, "%lld non-NULL cells", (long long int)n_points);
     return 1;
Modified: grass-addons/grass7/raster/r.hydrodem/local_proto.h
--- grass-addons/grass7/raster/r.hydrodem/local_proto.h	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/local_proto.h	2015-12-18 21:13:57 UTC (rev 67237)
@@ -4,10 +4,14 @@
 #include <grass/gis.h>
 #include <grass/raster.h>
+/* for grids with more than 2^31 - 1 cells */
+#define GW_LARGE_INT off_t
 #include "seg.h"
 #include "flag.h"
-#define INDEX(r, c) ((r) * ncols + (c))
+#define INDEX(r, c) ((GW_LARGE_INT)(r) * ncols + (c))
 #define MAXDEPTH 1000     /* maximum supported tree depth of stream network */
 struct ddir
@@ -22,7 +26,7 @@
 struct heap_point {
-   unsigned int added;
+   GW_LARGE_INT added;
    CELL ele;
    int r, c;
@@ -53,17 +57,17 @@
 extern struct snode *stream_node;
 extern int nrows, ncols;
-extern unsigned int n_search_points, n_points, nxt_avail_pt;
-extern unsigned int heap_size;
-extern unsigned int n_sinks;
+extern GW_LARGE_INT n_search_points, n_points, nxt_avail_pt;
+extern GW_LARGE_INT heap_size;
+extern int n_sinks;
 extern int n_mod_max, size_max;
 extern int do_all, keep_nat, nat_thresh;
-extern unsigned int n_stream_nodes, n_alloc_nodes;
+extern GW_LARGE_INT n_stream_nodes, n_alloc_nodes;
 extern struct point *outlets;
 extern struct sink_list *sinks, *first_sink;
-extern unsigned int n_outlets, n_alloc_outlets;
+extern GW_LARGE_INT n_outlets, n_alloc_outlets;
 extern char drain[3][3];
-extern unsigned int first_cum;
+extern GW_LARGE_INT first_cum;
 extern char sides;
 extern int c_fac;
 extern int ele_scale;
@@ -87,7 +91,7 @@
 /* do_astar.c */
 int do_astar(void);
-unsigned int heap_add(int, int, CELL);
+GW_LARGE_INT heap_add(int, int, CELL);
 /* hydro_con.c */
 int hydro_con(void);
Modified: grass-addons/grass7/raster/r.hydrodem/main.c
--- grass-addons/grass7/raster/r.hydrodem/main.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/main.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -22,19 +22,19 @@
 int nrows, ncols;
-unsigned int n_search_points, n_points, nxt_avail_pt;
-unsigned int heap_size;
-unsigned int n_sinks;
+GW_LARGE_INT n_search_points, n_points, nxt_avail_pt;
+GW_LARGE_INT heap_size;
+int n_sinks;
-unsigned int n_stream_nodes, n_alloc_nodes;
+GW_LARGE_INT n_stream_nodes, n_alloc_nodes;
-unsigned int n_outlets, n_alloc_outlets;
+GW_LARGE_INT n_outlets, n_alloc_outlets;
 char drain[3][3] = { {7, 6, 5}, {8, 0, 4}, {1, 2, 3} };
-unsigned int first_cum;
+GW_LARGE_INT first_cum;
 char sides;
 int c_fac;
 int ele_scale;
Modified: grass-addons/grass7/raster/r.hydrodem/seg.c
--- grass-addons/grass7/raster/r.hydrodem/seg.c	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/seg.c	2015-12-18 21:13:57 UTC (rev 67237)
@@ -1,10 +1,10 @@
 #include <unistd.h>
 #include <fcntl.h>
-#include "seg.h"
 int
-seg_open(SSEG *sseg, int nrows, int ncols, int row_in_seg, int col_in_seg,
+seg_open(SSEG *sseg, GW_LARGE_INT nrows, GW_LARGE_INT ncols, int row_in_seg, int col_in_seg,
 	 int nsegs_in_memory, int size_struct, int fill)
     char *filename;
@@ -69,7 +69,7 @@
     return 0;
-int seg_put(SSEG *sseg, char *value, int row, int col)
+int seg_put(SSEG *sseg, char *value, GW_LARGE_INT row, GW_LARGE_INT col)
     if (Segment_put(&(sseg->seg), value, row, col) < 0) {
@@ -78,7 +78,7 @@
     return 0;
-int seg_put_row(SSEG *sseg, char *value, int row)
+int seg_put_row(SSEG *sseg, char *value, GW_LARGE_INT row)
     if (Segment_put_row(&(sseg->seg), value, row) < 0) {
 	G_warning(_("seg_put_row(): could not write segment file"));
@@ -87,7 +87,7 @@
     return 0;
-int seg_get(SSEG *sseg, char *value, int row, int col)
+int seg_get(SSEG *sseg, char *value, GW_LARGE_INT row, GW_LARGE_INT col)
     if (Segment_get(&(sseg->seg), value, row, col) < 0) {
@@ -96,7 +96,7 @@
     return 0;
-int seg_get_row(SSEG *sseg, char *value, int row)
+int seg_get_row(SSEG *sseg, char *value, GW_LARGE_INT row)
     if (Segment_get_row(&(sseg->seg), value, row) < 0) {
Modified: grass-addons/grass7/raster/r.hydrodem/seg.h
--- grass-addons/grass7/raster/r.hydrodem/seg.h	2015-12-18 21:09:49 UTC (rev 67236)
+++ grass-addons/grass7/raster/r.hydrodem/seg.h	2015-12-18 21:13:57 UTC (rev 67237)
@@ -40,39 +40,38 @@
 /* bseg.c */
 int bseg_close(BSEG *);
-int bseg_get(BSEG *, char *, int, int);
+int bseg_get(BSEG *, char *, GW_LARGE_INT, GW_LARGE_INT);
 int bseg_open(BSEG *, int, int, int);
-int bseg_put(BSEG *, char *, int, int);
-int bseg_put_row(BSEG *, char *, int);
+int bseg_put(BSEG *, char *, GW_LARGE_INT, GW_LARGE_INT);
+int bseg_put_row(BSEG *, char *, GW_LARGE_INT);
 int bseg_read_raster(BSEG *, char *, char *);
 int bseg_write_raster(BSEG *, char *);
 /* cseg.c */
 int cseg_close(CSEG *);
-int cseg_get(CSEG *, CELL *, int, int);
+int cseg_get(CSEG *, CELL *, GW_LARGE_INT, GW_LARGE_INT);
 int cseg_open(CSEG *, int, int, int);
-int cseg_put(CSEG *, CELL *, int, int);
-int cseg_put_row(CSEG *, CELL *, int);
+int cseg_put(CSEG *, CELL *, GW_LARGE_INT, GW_LARGE_INT);
+int cseg_put_row(CSEG *, CELL *, GW_LARGE_INT);
 int cseg_read_raster(CSEG *, char *, char *);
 int cseg_write_raster(CSEG *, char *);
 /* dseg.c */
 int dseg_close(DSEG *);
-int dseg_get(DSEG *, double *, int, int);
+int dseg_get(DSEG *, double *, GW_LARGE_INT, GW_LARGE_INT);
 int dseg_open(DSEG *, int, int, int);
-int dseg_put(DSEG *, double *, int, int);
-int dseg_put_row(DSEG *, double *, int);
+int dseg_put(DSEG *, double *, GW_LARGE_INT, GW_LARGE_INT);
+int dseg_put_row(DSEG *, double *, GW_LARGE_INT);
 int dseg_read_raster(DSEG *, char *, char *);
 int dseg_write_raster(DSEG *, char *);
 /* seg.c */
 int seg_close(SSEG *);
-int seg_get(SSEG *, char *, int, int);
-int seg_open(SSEG *, int, int, int, int, int, int, int);
-int seg_put(SSEG *, char *, int, int);
-int seg_put_row(SSEG *, char *, int);
-int seg_get_row(SSEG *, char *, int);
+int seg_get(SSEG *, char *, GW_LARGE_INT, GW_LARGE_INT);
+int seg_open(SSEG *, GW_LARGE_INT, GW_LARGE_INT, int, int, int, int, int);
+int seg_put(SSEG *, char *, GW_LARGE_INT, GW_LARGE_INT);
+int seg_put_row(SSEG *, char *, GW_LARGE_INT);
+int seg_get_row(SSEG *, char *, GW_LARGE_INT);
 int seg_flush(SSEG *);
 #endif /* __SEG_H__ */
