[GRASS-SVN] r67277 - grass/trunk/imagery/i.cluster
Sun Dec 20 05:00:07 PST 2015
Author: martinl
Date: 2015-12-20 05:00:07 -0800 (Sun, 20 Dec 2015)
New Revision: 67277
   grass/trunk/imagery/i.cluster/checkpt.c
   grass/trunk/imagery/i.cluster/main.c
   grass/trunk/imagery/i.cluster/print1.c
   grass/trunk/imagery/i.cluster/print2.c
   grass/trunk/imagery/i.cluster/print4.c
i.cluster: use cross-platforn newline character for reports (rest of issues)
Modified: grass/trunk/imagery/i.cluster/checkpt.c
--- grass/trunk/imagery/i.cluster/checkpt.c	2015-12-20 12:51:44 UTC (rev 67276)
+++ grass/trunk/imagery/i.cluster/checkpt.c	2015-12-20 13:00:07 UTC (rev 67277)
@@ -13,7 +13,8 @@
     case 1:
 	print_band_means(report, X);
 	if (insigfile) {
-	    fprintf(report, _("using seed means (%d files)\n"), ref.nfiles);
+	    fprintf(report, _("using seed means (%d files)%s"),
+                    ref.nfiles, HOST_NEWLINE);
 	    for (c = 0; c < in_sig.nsigs; c++)
 		for (band = 0; band < ref.nfiles; band++)
 		    X->mean[band][c] = in_sig.sig[c].mean[band];
@@ -25,10 +26,11 @@
 	print_distribution(report, X);
 	break;
     case 3:
-	fprintf(report, _("\n######## iteration %d ###########\n"),
-		X->iteration);
-	fprintf(report, _("%d classes, %.2f%% points stable\n"),
-		I_cluster_nclasses(X, 1), (double)X->percent_stable);
+	fprintf(report, _("%s######## iteration %d ###########%s"),
+		HOST_NEWLINE, X->iteration, HOST_NEWLINE);
+	fprintf(report, _("%d classes, %.2f%% points stable%s"),
+		I_cluster_nclasses(X, 1), (double)X->percent_stable,
+                HOST_NEWLINE);
 	   I_cluster_sum2 (X);
 	   print_class_means(report,X);
@@ -46,8 +48,8 @@
 	break;
     case 4:
-	   fprintf (report, _("\nmerging class %d into %d\n"),
-	   X->merge2+1, X->merge1+1);
+	   fprintf (report, _("%smerging class %d into %d%s"),
+	   HOST_NEWLINE, X->merge2+1, X->merge1+1, HOST_NEWLINE);
 	break;
Modified: grass/trunk/imagery/i.cluster/main.c
--- grass/trunk/imagery/i.cluster/main.c	2015-12-20 12:51:44 UTC (rev 67276)
+++ grass/trunk/imagery/i.cluster/main.c	2015-12-20 13:00:07 UTC (rev 67277)
@@ -328,7 +328,8 @@
     fprintf(report,
-	    _("\n\n#################### CLASSES ####################%s"), HOST_NEWLINE);
+	    _("%s%s#################### CLASSES ####################%s"),
+            HOST_NEWLINE, HOST_NEWLINE, HOST_NEWLINE);
     fprintf(report, _("%s%d classes, %.2f%% points stable%s"),
 	    HOST_NEWLINE, I_cluster_nclasses(&C, 1), (double)C.percent_stable, HOST_NEWLINE);
     fprintf(report, _("%s######## CLUSTER END (%s) ########%s"),
Modified: grass/trunk/imagery/i.cluster/print1.c
--- grass/trunk/imagery/i.cluster/print1.c	2015-12-20 12:51:44 UTC (rev 67276)
+++ grass/trunk/imagery/i.cluster/print1.c	2015-12-20 13:00:07 UTC (rev 67277)
@@ -14,7 +14,7 @@
     fprintf(fd, _(" means  "));
     for (band = 0; band < C->nbands; band++)
 	fprintf(fd, " %g", C->band_sum[band] / C->npoints);
-    fprintf(fd, "\n");
+    fprintf(fd, "%s", HOST_NEWLINE);
     fprintf(fd, _(" stddev "));
 	fprintf(fd, " %g",
Modified: grass/trunk/imagery/i.cluster/print2.c
--- grass/trunk/imagery/i.cluster/print2.c	2015-12-20 12:51:44 UTC (rev 67276)
+++ grass/trunk/imagery/i.cluster/print2.c	2015-12-20 13:00:07 UTC (rev 67277)
@@ -25,7 +25,7 @@
 	if (n > 0)
 		fprintf(fd, " %g", C->sum[band][c] / n);
 	fprintf(fd, _("  stddev"));
 	if (n > 1)
Modified: grass/trunk/imagery/i.cluster/print4.c
--- grass/trunk/imagery/i.cluster/print4.c	2015-12-20 12:51:44 UTC (rev 67276)
+++ grass/trunk/imagery/i.cluster/print4.c	2015-12-20 13:00:07 UTC (rev 67277)
@@ -22,7 +22,7 @@
 			(double)C->sum[band][cat] / (double)C->count[cat]);
 	    else
 		sprintf(buf, FMT2, C->sum[band][cat], C->count[cat]);
-	    fprintf(fd, "%s %-18s", cat % 4 ? "" : "\n", buf);
+	    fprintf(fd, "%s %-18s", cat % 4 ? "" : HOST_NEWLINE, buf);
