[GRASS-SVN] r67283 - grass/branches/releasebranch_7_0/gui/wxpython/gmodeler
Sun Dec 20 07:14:26 PST 2015
Author: martinl
Date: 2015-12-20 07:14:26 -0800 (Sun, 20 Dec 2015)
New Revision: 67283
   grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/model.py
wxGUI/gmodeler: fix checking undefined variables
                (merge r67280 from trunk)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/model.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/model.py	2015-12-20 15:04:40 UTC (rev 67282)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gmodeler/model.py	2015-12-20 15:14:26 UTC (rev 67283)
@@ -450,8 +450,13 @@
                 key, value = opt.split('=', 1)
                 sval = pattern.search(value)
                 if sval:
-                    var = sval.group(2).strip()[1:] # ignore '%'
-                    if var not in variables:
+                    var = sval.group(2).strip()[1:] # strip '%' from beginning
+                    found = False
+                    for v in variables:
+                        if var.startswith(v):
+                            found = True
+                            break
+                    if not found:
                         report = True
                         for item in filter(lambda x: isinstance(x, ModelLoop), action.GetBlock()):
                             if var in item.GetLabel():
