[GRASS-SVN] r67293 - in grass/trunk: . include/Make
Sun Dec 20 18:50:05 PST 2015
Author: wenzeslaus
Date: 2015-12-20 18:50:05 -0800 (Sun, 20 Dec 2015)
New Revision: 67293
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Platform.make.in
add PDAL C++ lib dependency to configure
Modified: grass/trunk/configure
--- grass/trunk/configure	2015-12-20 22:59:54 UTC (rev 67292)
+++ grass/trunk/configure	2015-12-21 02:50:05 UTC (rev 67293)
@@ -78,6 +78,16 @@
                           e.g. '--with-liblas=/usr/local/bin/liblas-config',
                           default: no)"
 ac_help="$ac_help
+  --with-pdal[=path/pdal-config]
+                          enable PDAL support (pdal-config with path,
+                          e.g. '--with-pdal=/usr/local/bin/pdal-config',
+                          default: no)"
+ac_help="$ac_help
+  --with-wxwidgets[=path/wx-config]
+                          enable wxWidgets support (wx-config with path,
+                          e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
+                          default: no)"
+ac_help="$ac_help
   --with-netcdf[=path/nc-config]
                           enable NetCDF support (nc-config with path,
                           e.g. '--with-nc=/usr/local/bin/nc-config',
@@ -745,7 +755,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:749: checking host system type" >&5
+echo "configure:759: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -768,7 +778,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:772: checking for $ac_word" >&5
+echo "configure:782: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -795,7 +805,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:799: checking for $ac_word" >&5
+echo "configure:809: checking for $ac_word" >&5
@@ -843,7 +853,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:847: checking for $ac_word" >&5
+echo "configure:857: checking for $ac_word" >&5
@@ -872,7 +882,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:876: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:886: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -883,12 +893,12 @@
 cat > conftest.$ac_ext << EOF
-#line 887 "configure"
+#line 897 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -914,19 +924,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:918: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:928: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:923: checking whether we are using GNU C" >&5
+echo "configure:933: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -944,7 +954,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:948: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:958: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -973,10 +983,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:977: checking for Cygwin environment" >&5
+echo "configure:987: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 980 "configure"
+#line 990 "configure"
 int main() {
@@ -987,7 +997,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:991: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1001: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -1003,17 +1013,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1007: checking for mingw32 environment" >&5
+echo "configure:1017: checking for mingw32 environment" >&5
-#line 1010 "configure"
+#line 1020 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1017: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1031,7 +1041,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1035: checking for executable suffix" >&5
+echo "configure:1045: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1050,23 +1060,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1054: checking for full floating-point support" >&5
+echo "configure:1064: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1059: checking whether "cc -mieee" works" >&5
+echo "configure:1069: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1063 "configure"
+#line 1073 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1070: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1080: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1082,7 +1092,7 @@
 else
-#line 1086 "configure"
+#line 1096 "configure"
 #include <float.h>
@@ -1096,7 +1106,7 @@
 EOF
-if { (eval echo configure:1100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1109,14 +1119,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1113: checking for full floating-point support with -mieee" >&5
+echo "configure:1123: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1120 "configure"
+#line 1130 "configure"
 #include <float.h>
@@ -1130,7 +1140,7 @@
 EOF
-if { (eval echo configure:1134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1167,7 +1177,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1171: checking for $ac_word" >&5
+echo "configure:1181: checking for $ac_word" >&5
 case "$pwd" in
@@ -1205,7 +1215,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1209: checking for source directory" >&5
+echo "configure:1219: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1216,7 +1226,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1220: checking for build directory" >&5
+echo "configure:1230: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1284,7 +1294,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
-echo "configure:1288: checking for $ac_word" >&5
+echo "configure:1298: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1343,7 +1353,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1347: checking for MacOSX App" >&5
+echo "configure:1357: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1355,7 +1365,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1359: checking for MacOSX architectures" >&5
+echo "configure:1369: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1384,7 +1394,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1388: checking for MacOSX SDK" >&5
+echo "configure:1398: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1394,7 +1404,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1398: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1408: checking for $with_macosx_sdk/SDKSettings.plist" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1438,7 +1448,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1442: checking how to build libraries" >&5
+echo "configure:1452: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1901,6 +1911,24 @@
 fi
+# Check whether --with-pdal or --without-pdal was given.
+if test "${with_pdal+set}" = set; then
+  withval="$with_pdal"
+else
+  with_pdal="no"
+fi
+# Check whether --with-wxwidgets or --without-wxwidgets was given.
+if test "${with_wxwidgets+set}" = set; then
+  withval="$with_wxwidgets"
+else
+  with_wxwidgets="no"
+fi
 # Check whether --with-netcdf or --without-netcdf was given.
 if test "${with_netcdf+set}" = set; then
   withval="$with_netcdf"
@@ -2326,7 +2354,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2330: checking for additional include dirs" >&5
+echo "configure:2358: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2349,7 +2377,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2353: checking for additional library dirs" >&5
+echo "configure:2381: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2383,7 +2411,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2387: checking for a BSD compatible install" >&5
+echo "configure:2415: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2436,7 +2464,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:2440: checking for $ac_word" >&5
+echo "configure:2468: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2467,13 +2495,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2471: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2499: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-l$ac_lib  $LIBS"
-#line 2477 "configure"
+#line 2505 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -2484,7 +2512,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -2509,7 +2537,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2513: checking for $ac_word" >&5
+echo "configure:2541: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2549,7 +2577,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2553: checking for $ac_word" >&5
+echo "configure:2581: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2580,7 +2608,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2584: checking for $ac_word" >&5
+echo "configure:2612: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2618,7 +2646,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2622: checking for $ac_word" >&5
+echo "configure:2650: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2647,7 +2675,7 @@
-echo "configure:2651: checking for $ac_word" >&5
+echo "configure:2679: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2678,7 +2706,7 @@
-echo "configure:2682: checking for $ac_word" >&5
+echo "configure:2710: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2707,7 +2735,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2711: checking for $ac_word" >&5
+echo "configure:2739: checking for $ac_word" >&5
 case "$PERL" in
@@ -2738,7 +2766,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2742: checking how to run the C preprocessor" >&5
+echo "configure:2770: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2751,13 +2779,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2755 "configure"
+#line 2783 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2761: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2789: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2768,13 +2796,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2772 "configure"
+#line 2800 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2778: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2806: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2785,13 +2813,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2789 "configure"
+#line 2817 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2795: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2823: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2815,10 +2843,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2819: checking for ANSI C header files" >&5
+echo "configure:2847: checking for ANSI C header files" >&5
-#line 2822 "configure"
+#line 2850 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2826,7 +2854,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2830: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2858: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2843,7 +2871,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2847 "configure"
+#line 2875 "configure"
 #include <string.h>
 EOF
@@ -2861,7 +2889,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2865 "configure"
+#line 2893 "configure"
 #include <stdlib.h>
 EOF
@@ -2882,7 +2910,7 @@
 else
-#line 2886 "configure"
+#line 2914 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2893,7 +2921,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2920,15 +2948,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2924: checking for $ac_hdr" >&5
+echo "configure:2952: checking for $ac_hdr" >&5
-#line 2927 "configure"
+#line 2955 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2932: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2957,15 +2985,15 @@
 do
-echo "configure:2961: checking for $ac_hdr" >&5
+echo "configure:2989: checking for $ac_hdr" >&5
-#line 2964 "configure"
+#line 2992 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2969: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2997: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2994,15 +3022,15 @@
 do
-echo "configure:2998: checking for $ac_hdr" >&5
+echo "configure:3026: checking for $ac_hdr" >&5
-#line 3001 "configure"
+#line 3029 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3006: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3034: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3031,15 +3059,15 @@
 do
-echo "configure:3035: checking for $ac_hdr" >&5
+echo "configure:3063: checking for $ac_hdr" >&5
-#line 3038 "configure"
+#line 3066 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3043: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3071: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3068,15 +3096,15 @@
 do
-echo "configure:3072: checking for $ac_hdr" >&5
+echo "configure:3100: checking for $ac_hdr" >&5
-#line 3075 "configure"
+#line 3103 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3080: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3108: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3102,10 +3130,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3106: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3134: checking whether time.h and sys/time.h may both be included" >&5
-#line 3109 "configure"
+#line 3137 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3114,7 +3142,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3118: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3146: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3134,10 +3162,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3138: checking for off_t" >&5
+echo "configure:3166: checking for off_t" >&5
-#line 3141 "configure"
+#line 3169 "configure"
 #if STDC_HEADERS
@@ -3164,10 +3192,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3168: checking for uid_t in sys/types.h" >&5
+echo "configure:3196: checking for uid_t in sys/types.h" >&5
-#line 3171 "configure"
+#line 3199 "configure"
 EOF
@@ -3195,10 +3223,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3199: checking return type of signal handlers" >&5
+echo "configure:3227: checking return type of signal handlers" >&5
-#line 3202 "configure"
+#line 3230 "configure"
 #include <signal.h>
@@ -3215,7 +3243,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3219: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3247: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3233,10 +3261,10 @@
-echo "configure:3237: checking for Cygwin environment" >&5
+echo "configure:3265: checking for Cygwin environment" >&5
-#line 3240 "configure"
+#line 3268 "configure"
 int main() {
@@ -3247,7 +3275,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3251: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3279: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3265,10 +3293,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3269: checking for $ac_func" >&5
+echo "configure:3297: checking for $ac_func" >&5
-#line 3272 "configure"
+#line 3300 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3291,7 +3319,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3317,10 +3345,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3321: checking for $ac_func" >&5
+echo "configure:3349: checking for $ac_func" >&5
-#line 3324 "configure"
+#line 3352 "configure"
@@ -3343,7 +3371,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3369,10 +3397,10 @@
 for ac_func in drand48
 do
-echo "configure:3373: checking for $ac_func" >&5
+echo "configure:3401: checking for $ac_func" >&5
-#line 3376 "configure"
+#line 3404 "configure"
@@ -3395,7 +3423,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3421,10 +3449,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3425: checking for $ac_func" >&5
+echo "configure:3453: checking for $ac_func" >&5
-#line 3428 "configure"
+#line 3456 "configure"
@@ -3447,7 +3475,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3473,10 +3501,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3477: checking for $ac_func" >&5
+echo "configure:3505: checking for $ac_func" >&5
-#line 3480 "configure"
+#line 3508 "configure"
@@ -3499,7 +3527,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3524,13 +3552,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3528: checking whether setpgrp takes no argument" >&5
+echo "configure:3556: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3534 "configure"
+#line 3562 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3550,7 +3578,7 @@
 EOF
-if { (eval echo configure:3554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3578,16 +3606,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3582: checking for long long int" >&5
+echo "configure:3610: checking for long long int" >&5
-#line 3584 "configure"
+#line 3612 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3591: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3619: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -3607,7 +3635,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3611: checking for W11" >&5
+echo "configure:3639: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3635,7 +3663,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3639: checking for X" >&5
+echo "configure:3667: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3695,12 +3723,12 @@
   # First, try using that file with no special directory specified.
-#line 3699 "configure"
+#line 3727 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3704: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3732: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3769,14 +3797,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3773 "configure"
+#line 3801 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3881,17 +3909,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3885: checking whether -R must be followed by a space" >&5
+echo "configure:3913: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3888 "configure"
+#line 3916 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3907,14 +3935,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3911 "configure"
+#line 3939 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3946,13 +3974,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3950: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3978: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3956 "configure"
+#line 3984 "configure"
@@ -3963,7 +3991,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3984,13 +4012,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3988: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4016: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 3994 "configure"
+#line 4022 "configure"
@@ -4001,7 +4029,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4029,10 +4057,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4033: checking for gethostbyname" >&5
+echo "configure:4061: checking for gethostbyname" >&5
-#line 4036 "configure"
+#line 4064 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -4055,7 +4083,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -4075,13 +4103,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4079: checking for gethostbyname in -lnsl" >&5
+echo "configure:4107: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4085 "configure"
+#line 4113 "configure"
@@ -4092,7 +4120,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4121,10 +4149,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4125: checking for connect" >&5
+echo "configure:4153: checking for connect" >&5
-#line 4128 "configure"
+#line 4156 "configure"
     which can conflict with char connect(); below.  */
@@ -4147,7 +4175,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4151: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4167,13 +4195,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4171: checking for connect in -lsocket" >&5
+echo "configure:4199: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4177 "configure"
+#line 4205 "configure"
@@ -4184,7 +4212,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4207,10 +4235,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4211: checking for remove" >&5
+echo "configure:4239: checking for remove" >&5
-#line 4214 "configure"
+#line 4242 "configure"
     which can conflict with char remove(); below.  */
@@ -4233,7 +4261,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4253,13 +4281,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4257: checking for remove in -lposix" >&5
+echo "configure:4285: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4263 "configure"
+#line 4291 "configure"
@@ -4270,7 +4298,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4293,10 +4321,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4297: checking for shmat" >&5
+echo "configure:4325: checking for shmat" >&5
-#line 4300 "configure"
+#line 4328 "configure"
     which can conflict with char shmat(); below.  */
@@ -4319,7 +4347,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4339,13 +4367,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4343: checking for shmat in -lipc" >&5
+echo "configure:4371: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4349 "configure"
+#line 4377 "configure"
@@ -4356,7 +4384,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4388,13 +4416,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4392: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4420: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4398 "configure"
+#line 4426 "configure"
@@ -4405,7 +4433,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4445,12 +4473,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4449: checking for library containing cuserid" >&5
+echo "configure:4477: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4454 "configure"
+#line 4482 "configure"
@@ -4461,7 +4489,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4472,7 +4500,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4476 "configure"
+#line 4504 "configure"
@@ -4483,7 +4511,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4509,10 +4537,10 @@
 for ac_func in asprintf
 do
-echo "configure:4513: checking for $ac_func" >&5
+echo "configure:4541: checking for $ac_func" >&5
-#line 4516 "configure"
+#line 4544 "configure"
@@ -4535,7 +4563,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4562,10 +4590,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4566: checking for atan" >&5
+echo "configure:4594: checking for atan" >&5
-#line 4569 "configure"
+#line 4597 "configure"
     which can conflict with char atan(); below.  */
@@ -4588,7 +4616,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4606,13 +4634,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4610: checking for atan in -lm" >&5
+echo "configure:4638: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4616 "configure"
+#line 4644 "configure"
@@ -4623,7 +4651,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4655: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4650,10 +4678,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4654: checking for dlsym" >&5
+echo "configure:4682: checking for dlsym" >&5
-#line 4657 "configure"
+#line 4685 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4676,7 +4704,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4694,13 +4722,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4698: checking for dlsym in -ldl" >&5
+echo "configure:4726: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4704 "configure"
+#line 4732 "configure"
@@ -4711,7 +4739,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4738,10 +4766,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4742: checking for iconv" >&5
+echo "configure:4770: checking for iconv" >&5
-#line 4745 "configure"
+#line 4773 "configure"
     which can conflict with char iconv(); below.  */
@@ -4764,7 +4792,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4782,13 +4810,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4786: checking for iconv in -liconv" >&5
+echo "configure:4814: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4792 "configure"
+#line 4820 "configure"
@@ -4799,7 +4827,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4818,13 +4846,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4822: checking for iconv in -lgiconv" >&5
+echo "configure:4850: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4828 "configure"
+#line 4856 "configure"
@@ -4835,7 +4863,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4854,10 +4882,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4858: checking for libiconv" >&5
+echo "configure:4886: checking for libiconv" >&5
-#line 4861 "configure"
+#line 4889 "configure"
     which can conflict with char libiconv(); below.  */
@@ -4880,7 +4908,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -4898,13 +4926,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4902: checking for libiconv in -liconv" >&5
+echo "configure:4930: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4908 "configure"
+#line 4936 "configure"
@@ -4915,7 +4943,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4934,13 +4962,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4938: checking for libiconv in -lgiconv" >&5
+echo "configure:4966: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4944 "configure"
+#line 4972 "configure"
@@ -4951,7 +4979,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4988,10 +5016,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4992: checking for socket" >&5
+echo "configure:5020: checking for socket" >&5
-#line 4995 "configure"
+#line 5023 "configure"
     which can conflict with char socket(); below.  */
@@ -5014,7 +5042,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -5032,13 +5060,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5036: checking for socket in -lsocket" >&5
+echo "configure:5064: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5042 "configure"
+#line 5070 "configure"
@@ -5049,7 +5077,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5097,7 +5125,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5101: checking for location of zlib includes" >&5
+echo "configure:5129: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5123,15 +5151,15 @@
 do
-echo "configure:5127: checking for $ac_hdr" >&5
+echo "configure:5155: checking for $ac_hdr" >&5
-#line 5130 "configure"
+#line 5158 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5135: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5163: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5165,7 +5193,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5169: checking for location of zlib library" >&5
+echo "configure:5197: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5190,13 +5218,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5194: checking for deflate in -lz" >&5
+echo "configure:5222: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5200 "configure"
+#line 5228 "configure"
@@ -5207,7 +5235,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5249,7 +5277,7 @@
 echo $ac_n "checking whether to use bzlib""... $ac_c" 1>&6
-echo "configure:5253: checking whether to use bzlib" >&5
+echo "configure:5281: checking whether to use bzlib" >&5
 echo "$ac_t"""$with_bzlib"" 1>&6
 case "$with_bzlib" in
 	"no")	USE_BZIP2=	;;
@@ -5269,7 +5297,7 @@
 echo $ac_n "checking for location of bzlib includes""... $ac_c" 1>&6
-echo "configure:5273: checking for location of bzlib includes" >&5
+echo "configure:5301: checking for location of bzlib includes" >&5
 case "$with_bzlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-bzlib-includes." 1>&2; exit 1; }
@@ -5295,15 +5323,15 @@
 do
-echo "configure:5299: checking for $ac_hdr" >&5
+echo "configure:5327: checking for $ac_hdr" >&5
-#line 5302 "configure"
+#line 5330 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5307: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5335: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5337,7 +5365,7 @@
 echo $ac_n "checking for location of bzlib library""... $ac_c" 1>&6
-echo "configure:5341: checking for location of bzlib library" >&5
+echo "configure:5369: checking for location of bzlib library" >&5
 case "$with_bzlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-bzlib-libs." 1>&2; exit 1; }
@@ -5362,13 +5390,13 @@
 echo $ac_n "checking for BZ2_bzBuffToBuffCompress in -lbz2""... $ac_c" 1>&6
-echo "configure:5366: checking for BZ2_bzBuffToBuffCompress in -lbz2" >&5
+echo "configure:5394: checking for BZ2_bzBuffToBuffCompress in -lbz2" >&5
 ac_lib_var=`echo bz2'_'BZ2_bzBuffToBuffCompress | sed 'y%./+-%__p_%'`
 LIBS="-lbz2  $LIBS"
-#line 5372 "configure"
+#line 5400 "configure"
@@ -5379,7 +5407,7 @@
 BZ2_bzBuffToBuffCompress()
 ; return 0; }
 EOF
-if { (eval echo configure:5383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5429,7 +5457,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5433: checking for location of External PROJ.4 includes" >&5
+echo "configure:5461: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5455,15 +5483,15 @@
 do
-echo "configure:5459: checking for $ac_hdr" >&5
+echo "configure:5487: checking for $ac_hdr" >&5
-#line 5462 "configure"
+#line 5490 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5467: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5495: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5500,7 +5528,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5504: checking External PROJ.4 version" >&5
+echo "configure:5532: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5508,7 +5536,7 @@
 else
-#line 5512 "configure"
+#line 5540 "configure"
 #include <stdio.h>
@@ -5520,7 +5548,7 @@
 EOF
-if { (eval echo configure:5524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5545,7 +5573,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5549: checking for location of External PROJ.4 library" >&5
+echo "configure:5577: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5570,13 +5598,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5574: checking for pj_get_def in -lproj" >&5
+echo "configure:5602: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5580 "configure"
+#line 5608 "configure"
@@ -5587,7 +5615,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5621,7 +5649,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5625: checking for location of External PROJ.4 data files" >&5
+echo "configure:5653: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5645,14 +5673,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5649: checking for epsg" >&5
+echo "configure:5677: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5656: checking for $PROJSHARE/epsg" >&5
+echo "configure:5684: checking for $PROJSHARE/epsg" >&5
@@ -5684,7 +5712,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5688: checking for $ac_word" >&5
+echo "configure:5716: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5724,7 +5752,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5728: checking whether to use regex" >&5
+echo "configure:5756: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5744,7 +5772,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5748: checking for location of regex includes" >&5
+echo "configure:5776: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5770,15 +5798,15 @@
 do
-echo "configure:5774: checking for $ac_hdr" >&5
+echo "configure:5802: checking for $ac_hdr" >&5
-#line 5777 "configure"
+#line 5805 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5782: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5812,7 +5840,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5816: checking for location of regex library" >&5
+echo "configure:5844: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5837,10 +5865,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5841: checking for regcomp" >&5
+echo "configure:5869: checking for regcomp" >&5
-#line 5844 "configure"
+#line 5872 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5863,7 +5891,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5890,13 +5918,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5894: checking for regcomp in -lregex" >&5
+echo "configure:5922: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5900 "configure"
+#line 5928 "configure"
@@ -5907,7 +5935,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5957,7 +5985,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5961: checking whether to use Readline" >&5
+echo "configure:5989: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5978,7 +6006,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5982: checking for location of Readline includes" >&5
+echo "configure:6010: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -6004,15 +6032,15 @@
 do
-echo "configure:6008: checking for $ac_hdr" >&5
+echo "configure:6036: checking for $ac_hdr" >&5
-#line 6011 "configure"
+#line 6039 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6016: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6044: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6048,15 +6076,15 @@
 do
-echo "configure:6052: checking for $ac_hdr" >&5
+echo "configure:6080: checking for $ac_hdr" >&5
-#line 6055 "configure"
+#line 6083 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6090,7 +6118,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6094: checking for location of Readline library" >&5
+echo "configure:6122: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6115,13 +6143,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6119: checking for readline in -lreadline" >&5
+echo "configure:6147: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 6125 "configure"
+#line 6153 "configure"
@@ -6132,7 +6160,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:6136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6167,13 +6195,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6171: checking for add_history in -lhistory" >&5
+echo "configure:6199: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6177 "configure"
+#line 6205 "configure"
@@ -6184,7 +6212,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6226,7 +6254,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6230: checking whether to use GDAL" >&5
+echo "configure:6258: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6244,7 +6272,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6248: checking for $ac_word" >&5
+echo "configure:6276: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6299,14 +6327,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6303 "configure"
+#line 6331 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6310: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -6315,14 +6343,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6319 "configure"
+#line 6347 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6354,7 +6382,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6358: checking whether to use libLAS" >&5
+echo "configure:6386: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6371,7 +6399,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6375: checking for $ac_word" >&5
+echo "configure:6403: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6421,14 +6449,14 @@
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
   CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
-#line 6425 "configure"
+#line 6453 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6436,14 +6464,14 @@
   rm -rf conftest*
-#line 6440 "configure"
+#line 6468 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6473,10 +6501,160 @@
+# PDAL option
+echo $ac_n "checking whether to use PDAL""... $ac_c" 1>&6
+echo "configure:6508: checking whether to use PDAL" >&5
+# new and currently used way to switch language to C++
+# AC_LANG_PUSH(C++)
+ac_ext=C
+# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='${CXX-g++} -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext 1>&5'
+ac_link='${CXX-g++} -o conftest${ac_exeext} $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS 1>&5'
+cross_compiling=$ac_cv_prog_cxx_cross
+PDAL_LIBS=
+PDAL_CPPFLAGS=
+USE_PDAL=
+if test "`basename xx/$with_pdal`" = "pdal-config" ; then
+  PDAL_CONFIG="$with_pdal"
+fi
+if test "$with_pdal" = "no" ; then
+  echo "$ac_t""no" 1>&6
+else
+  echo "$ac_t""yes" 1>&6
+  # Extract the first word of "pdal-config", so it can be a program name with args.
+set dummy pdal-config; ac_word=$2
+echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
+echo "configure:6536: checking for $ac_word" >&5
+case "$PDAL_CONFIG" in
+  ac_cv_path_PDAL_CONFIG="$PDAL_CONFIG" # Let the user override the test with a path.
+  ac_cv_path_PDAL_CONFIG="$PDAL_CONFIG" # Let the user override the test with a dos path.
+  IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS=":"
+  ac_dummy="$PATH"
+  for ac_dir in $ac_dummy; do
+    test -z "$ac_dir" && ac_dir=.
+    if test -f $ac_dir/$ac_word; then
+      ac_cv_path_PDAL_CONFIG="$ac_dir/$ac_word"
+      break
+    fi
+  done
+  IFS="$ac_save_ifs"
+  test -z "$ac_cv_path_PDAL_CONFIG" && ac_cv_path_PDAL_CONFIG="no"
+esac
+PDAL_CONFIG="$ac_cv_path_PDAL_CONFIG"
+if test -n "$PDAL_CONFIG"; then
+  echo "$ac_t""$PDAL_CONFIG" 1>&6
+else
+fi
+  if test "$PDAL_CONFIG" = "no" ; then
+    { echo "configure: error: *** could not find pdal-config" 1>&2; exit 1; }
+  fi
+  if test "$PDAL_CONFIG" != "" ; then
+    PDAL_LIBS=`"$PDAL_CONFIG" --libs`
+    PDAL_CPPFLAGS=`"$PDAL_CONFIG" --cxxflags`
+    PDAL_INC=`"$PDAL_CONFIG" --includes`
+    USE_PDAL=1
+  fi
+  PDAL=
+  ac_save_libs="$LIBS"
+  ac_save_cflags="$CFLAGS"
+  ac_save_cppflags="$CPPFLAGS"
+  LIBS="$LIBS $PDAL_LIBS"
+  CFLAGS="$CFLAGS $PDAL_CFLAGS"
+  CPPFLAGS="$CPPFLAGS $PDAL_CPPFLAGS $PDAL_INC"
+  cat > conftest.$ac_ext <<EOF
+#line 6586 "configure"
+#include "confdefs.h"
+#include <pdal/PointTable.hpp>
+int main() {
+pdal::PointTable table;
+; return 0; }
+EOF
+if { (eval echo configure:6593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+#line 6601 "configure"
+int main() {
+; return 0; }
+EOF
+if { (eval echo configure:6608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  PDAL_LIBS="$PDAL_LIBS"
+else
+  rm -rf conftest*
+  { echo "configure: error: *** Unable to locate PDAL library." 1>&2; exit 1; }
+fi
+rm -f conftest*
+fi
+rm -f conftest*
+  LIBS=${ac_save_libs}
+  CFLAGS=${ac_save_cflags}
+  CPPFLAGS=${ac_save_cppflags}
+  cat >> confdefs.h <<\EOF
+#define HAVE_PDAL 1
+EOF
+fi
+# new and currently used way to switch language back to C
+# AC_LANG_POP(C++)
+ac_ext=c
+# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='${CC-cc} -c $CFLAGS $CPPFLAGS conftest.$ac_ext 1>&5'
+ac_link='${CC-cc} -o conftest${ac_exeext} $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS 1>&5'
+cross_compiling=$ac_cv_prog_cc_cross
+ac_ext=c
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6480: checking whether to use NetCDF" >&5
+echo "configure:6658: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6493,7 +6671,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6497: checking for $ac_word" >&5
+echo "configure:6675: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6540,14 +6718,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6544 "configure"
+#line 6722 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6555,14 +6733,14 @@
   rm -rf conftest*
-#line 6559 "configure"
+#line 6737 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6593,7 +6771,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6597: checking whether to use GEOS" >&5
+echo "configure:6775: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6611,7 +6789,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6615: checking for $ac_word" >&5
+echo "configure:6793: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6659,15 +6837,15 @@
 do
-echo "configure:6663: checking for $ac_hdr" >&5
+echo "configure:6841: checking for $ac_hdr" >&5
-#line 6666 "configure"
+#line 6844 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6849: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6706,13 +6884,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6710: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6888: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6716 "configure"
+#line 6894 "configure"
@@ -6723,7 +6901,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6767,7 +6945,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6771: checking whether to use TIFF" >&5
+echo "configure:6949: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6787,7 +6965,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6791: checking for location of TIFF includes" >&5
+echo "configure:6969: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6813,15 +6991,15 @@
 do
-echo "configure:6817: checking for $ac_hdr" >&5
+echo "configure:6995: checking for $ac_hdr" >&5
-#line 6820 "configure"
+#line 6998 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6825: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7003: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6855,7 +7033,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6859: checking for location of TIFF library" >&5
+echo "configure:7037: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6886,13 +7064,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6890: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7068: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6896 "configure"
+#line 7074 "configure"
@@ -6903,7 +7081,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6922,13 +7100,13 @@
-echo "configure:6926: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7104: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6932 "configure"
+#line 7110 "configure"
@@ -6939,7 +7117,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6958,13 +7136,13 @@
-echo "configure:6962: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7140: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6968 "configure"
+#line 7146 "configure"
@@ -6975,7 +7153,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6994,13 +7172,13 @@
-echo "configure:6998: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7176: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7004 "configure"
+#line 7182 "configure"
@@ -7011,7 +7189,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7030,13 +7208,13 @@
-echo "configure:7034: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7212: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 7040 "configure"
+#line 7218 "configure"
@@ -7047,7 +7225,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7066,13 +7244,13 @@
-echo "configure:7070: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7248: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7076 "configure"
+#line 7254 "configure"
@@ -7083,7 +7261,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7102,13 +7280,13 @@
-echo "configure:7106: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7284: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7112 "configure"
+#line 7290 "configure"
@@ -7119,7 +7297,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7138,13 +7316,13 @@
-echo "configure:7142: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7320: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7148 "configure"
+#line 7326 "configure"
@@ -7155,7 +7333,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7253,7 +7431,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7257: checking whether to use PNG" >&5
+echo "configure:7435: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7272,7 +7450,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7276: checking for location of PNG includes" >&5
+echo "configure:7454: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7298,15 +7476,15 @@
 do
-echo "configure:7302: checking for $ac_hdr" >&5
+echo "configure:7480: checking for $ac_hdr" >&5
-#line 7305 "configure"
+#line 7483 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7310: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7340,7 +7518,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7344: checking for location of PNG library" >&5
+echo "configure:7522: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7365,13 +7543,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7369: checking for png_read_image in -lpng" >&5
+echo "configure:7547: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7375 "configure"
+#line 7553 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7382,7 +7560,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7424,7 +7602,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7428: checking whether to use PostgreSQL" >&5
+echo "configure:7606: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7451,7 +7629,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7455: checking for location of PostgreSQL includes" >&5
+echo "configure:7633: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7477,15 +7655,15 @@
 do
-echo "configure:7481: checking for $ac_hdr" >&5
+echo "configure:7659: checking for $ac_hdr" >&5
-#line 7484 "configure"
+#line 7662 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7667: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7523,7 +7701,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7527: checking for location of PostgreSQL library" >&5
+echo "configure:7705: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7552,13 +7730,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7556: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7734: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7562 "configure"
+#line 7740 "configure"
@@ -7569,7 +7747,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7588,13 +7766,13 @@
-echo "configure:7592: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7770: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7598 "configure"
+#line 7776 "configure"
@@ -7605,7 +7783,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7624,13 +7802,13 @@
-echo "configure:7628: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7806: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7634 "configure"
+#line 7812 "configure"
@@ -7641,7 +7819,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7660,13 +7838,13 @@
-echo "configure:7664: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7842: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7670 "configure"
+#line 7848 "configure"
@@ -7677,7 +7855,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7734,13 +7912,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7738: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7916: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7744 "configure"
+#line 7922 "configure"
@@ -7751,7 +7929,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7773,13 +7951,13 @@
-echo "configure:7777: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7955: checking for PQcmdTuples in -lpq" >&5
-#line 7783 "configure"
+#line 7961 "configure"
@@ -7790,7 +7968,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7833,7 +8011,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7837: checking whether to use MySQL" >&5
+echo "configure:8015: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7853,7 +8031,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7857: checking for location of MySQL includes" >&5
+echo "configure:8035: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7879,15 +8057,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7883: checking for $ac_hdr" >&5
+echo "configure:8061: checking for $ac_hdr" >&5
-#line 7886 "configure"
+#line 8064 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7924,7 +8102,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7928: checking for location of MySQL library" >&5
+echo "configure:8106: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7955,13 +8133,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7959: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8137: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7965 "configure"
+#line 8143 "configure"
@@ -7972,7 +8150,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7991,13 +8169,13 @@
-echo "configure:7995: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8173: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8001 "configure"
+#line 8179 "configure"
@@ -8008,7 +8186,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8027,13 +8205,13 @@
-echo "configure:8031: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8209: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8037 "configure"
+#line 8215 "configure"
@@ -8044,7 +8222,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8063,13 +8241,13 @@
-echo "configure:8067: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8245: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8073 "configure"
+#line 8251 "configure"
@@ -8080,7 +8258,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8084: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8099,13 +8277,13 @@
-echo "configure:8103: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8281: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8109 "configure"
+#line 8287 "configure"
@@ -8116,7 +8294,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8135,13 +8313,13 @@
-echo "configure:8139: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8317: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8145 "configure"
+#line 8323 "configure"
@@ -8152,7 +8330,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8171,13 +8349,13 @@
-echo "configure:8175: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8353: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8181 "configure"
+#line 8359 "configure"
@@ -8188,7 +8366,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8207,13 +8385,13 @@
-echo "configure:8211: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8389: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8217 "configure"
+#line 8395 "configure"
@@ -8224,7 +8402,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8314,7 +8492,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8318: checking for $ac_word" >&5
+echo "configure:8496: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8363,10 +8541,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8367: checking for mysql_server_init" >&5
+echo "configure:8545: checking for mysql_server_init" >&5
-#line 8370 "configure"
+#line 8548 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -8392,7 +8570,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8444,7 +8622,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8448: checking whether to use SQLite" >&5
+echo "configure:8626: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8464,7 +8642,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8468: checking for location of SQLite includes" >&5
+echo "configure:8646: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8490,15 +8668,15 @@
 do
-echo "configure:8494: checking for $ac_hdr" >&5
+echo "configure:8672: checking for $ac_hdr" >&5
-#line 8497 "configure"
+#line 8675 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8680: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8541,7 +8719,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8545: checking for location of SQLite library" >&5
+echo "configure:8723: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8570,13 +8748,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8574: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8752: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8580 "configure"
+#line 8758 "configure"
@@ -8587,7 +8765,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8606,13 +8784,13 @@
-echo "configure:8610: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8788: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8616 "configure"
+#line 8794 "configure"
@@ -8623,7 +8801,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8642,13 +8820,13 @@
-echo "configure:8646: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8824: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8652 "configure"
+#line 8830 "configure"
@@ -8659,7 +8837,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8678,13 +8856,13 @@
-echo "configure:8682: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8860: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8688 "configure"
+#line 8866 "configure"
@@ -8695,7 +8873,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8770,7 +8948,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:8774: checking whether to use OpenGL" >&5
+echo "configure:8952: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -8804,7 +8982,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:8808: checking for location of OpenGL includes" >&5
+echo "configure:8986: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -8830,15 +9008,15 @@
 do
-echo "configure:8834: checking for $ac_hdr" >&5
+echo "configure:9012: checking for $ac_hdr" >&5
-#line 8837 "configure"
+#line 9015 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8842: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8872,7 +9050,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:8876: checking for location of OpenGL library" >&5
+echo "configure:9054: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -8901,13 +9079,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:8905: checking for glBegin in -lGL" >&5
+echo "configure:9083: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 8911 "configure"
+#line 9089 "configure"
@@ -8918,7 +9096,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:8922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8937,13 +9115,13 @@
-echo "configure:8941: checking for glBegin in -lGL" >&5
+echo "configure:9119: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 8947 "configure"
+#line 9125 "configure"
@@ -8954,7 +9132,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:8958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8973,13 +9151,13 @@
-echo "configure:8977: checking for glBegin in -lGL" >&5
+echo "configure:9155: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 8983 "configure"
+#line 9161 "configure"
@@ -8990,7 +9168,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:8994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9009,13 +9187,13 @@
-echo "configure:9013: checking for glBegin in -lGL" >&5
+echo "configure:9191: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9019 "configure"
+#line 9197 "configure"
@@ -9026,7 +9204,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9088,13 +9266,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9092: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9270: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9098 "configure"
+#line 9276 "configure"
@@ -9105,7 +9283,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9124,13 +9302,13 @@
-echo "configure:9128: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9306: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9134 "configure"
+#line 9312 "configure"
@@ -9141,7 +9319,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9188,10 +9366,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9192: checking for glXCreatePbuffer" >&5
+echo "configure:9370: checking for glXCreatePbuffer" >&5
-#line 9195 "configure"
+#line 9373 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9214,7 +9392,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9251,10 +9429,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9255: checking for glXCreateGLXPixmap" >&5
+echo "configure:9433: checking for glXCreateGLXPixmap" >&5
-#line 9258 "configure"
+#line 9436 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9277,7 +9455,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9320,7 +9498,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9324: checking for location of OpenGL framework" >&5
+echo "configure:9502: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9344,15 +9522,15 @@
 do
-echo "configure:9348: checking for $ac_hdr" >&5
+echo "configure:9526: checking for $ac_hdr" >&5
-#line 9351 "configure"
+#line 9529 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9356: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9388,10 +9566,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9392: checking for glBegin" >&5
+echo "configure:9570: checking for glBegin" >&5
-#line 9395 "configure"
+#line 9573 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9414,7 +9592,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9451,10 +9629,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9455: checking for gluBeginCurve" >&5
+echo "configure:9633: checking for gluBeginCurve" >&5
-#line 9458 "configure"
+#line 9636 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9477,7 +9655,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9525,7 +9703,7 @@
-echo "configure:9529: checking for location of OpenGL includes" >&5
+echo "configure:9707: checking for location of OpenGL includes" >&5
@@ -9551,15 +9729,15 @@
 do
-echo "configure:9555: checking for $ac_hdr" >&5
+echo "configure:9733: checking for $ac_hdr" >&5
-#line 9558 "configure"
+#line 9736 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9563: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9593,7 +9771,7 @@
-echo "configure:9597: checking for location of OpenGL library" >&5
+echo "configure:9775: checking for location of OpenGL library" >&5
@@ -9618,18 +9796,18 @@
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9622: checking for OpenGL library" >&5
+echo "configure:9800: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9626 "configure"
+#line 9804 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -9653,18 +9831,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9657: checking for GLU library" >&5
+echo "configure:9835: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 9661 "configure"
+#line 9839 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:9668: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -9713,7 +9891,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:9717: checking whether to use ODBC" >&5
+echo "configure:9895: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -9732,7 +9910,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:9736: checking for location of ODBC includes" >&5
+echo "configure:9914: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -9758,15 +9936,15 @@
 do
-echo "configure:9762: checking for $ac_hdr" >&5
+echo "configure:9940: checking for $ac_hdr" >&5
-#line 9765 "configure"
+#line 9943 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9770: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9948: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9800,7 +9978,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:9804: checking for location of ODBC library" >&5
+echo "configure:9982: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -9825,13 +10003,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:9829: checking for SQLConnect in -lodbc" >&5
+echo "configure:10007: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 9835 "configure"
+#line 10013 "configure"
@@ -9842,7 +10020,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9867,13 +10045,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:9871: checking for SQLConnect in -liodbc" >&5
+echo "configure:10049: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 9877 "configure"
+#line 10055 "configure"
@@ -9884,7 +10062,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:9888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9909,11 +10087,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:9913: checking for ODBC library" >&5
+echo "configure:10091: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 9917 "configure"
+#line 10095 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -9921,7 +10099,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:9925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -9970,7 +10148,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:9974: checking whether to use FFTW" >&5
+echo "configure:10152: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -9989,7 +10167,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:9993: checking for location of FFTW includes" >&5
+echo "configure:10171: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10015,15 +10193,15 @@
 do
-echo "configure:10019: checking for $ac_hdr" >&5
+echo "configure:10197: checking for $ac_hdr" >&5
-#line 10022 "configure"
+#line 10200 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10205: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10051,15 +10229,15 @@
 do
-echo "configure:10055: checking for $ac_hdr" >&5
+echo "configure:10233: checking for $ac_hdr" >&5
-#line 10058 "configure"
+#line 10236 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10063: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10087,15 +10265,15 @@
 do
-echo "configure:10091: checking for $ac_hdr" >&5
+echo "configure:10269: checking for $ac_hdr" >&5
-#line 10094 "configure"
+#line 10272 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10099: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10277: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10141,7 +10319,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10145: checking for location of FFTW library" >&5
+echo "configure:10323: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10166,13 +10344,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10170: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10348: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10176 "configure"
+#line 10354 "configure"
@@ -10183,7 +10361,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10208,13 +10386,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10212: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10390: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10218 "configure"
+#line 10396 "configure"
@@ -10225,7 +10403,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10250,13 +10428,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10254: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10432: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10260 "configure"
+#line 10438 "configure"
@@ -10267,7 +10445,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10324,7 +10502,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10328: checking whether to use BLAS" >&5
+echo "configure:10506: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10345,7 +10523,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10349: checking for location of BLAS includes" >&5
+echo "configure:10527: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10365,7 +10543,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10369: checking for location of BLAS library" >&5
+echo "configure:10547: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10391,15 +10569,15 @@
 do
-echo "configure:10395: checking for $ac_hdr" >&5
+echo "configure:10573: checking for $ac_hdr" >&5
-#line 10398 "configure"
+#line 10576 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10403: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10434,13 +10612,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10438: checking for dnrm2_ in -lblas" >&5
+echo "configure:10616: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10444 "configure"
+#line 10622 "configure"
@@ -10451,7 +10629,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10470,13 +10648,13 @@
-echo "configure:10474: checking for dnrm2_ in -lblas" >&5
+echo "configure:10652: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10480 "configure"
+#line 10658 "configure"
@@ -10487,7 +10665,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10531,13 +10709,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10535: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10713: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10541 "configure"
+#line 10719 "configure"
@@ -10548,7 +10726,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10563,13 +10741,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10567: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10745: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 10573 "configure"
+#line 10751 "configure"
@@ -10580,7 +10758,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10595,13 +10773,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10599: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10777: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10605 "configure"
+#line 10783 "configure"
@@ -10612,7 +10790,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:10616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10658,16 +10836,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10662: checking for sgemm in $vlib_flags" >&5
+echo "configure:10840: checking for sgemm in $vlib_flags" >&5
-#line 10664 "configure"
+#line 10842 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -10685,13 +10863,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10689: checking for sgemm_ in -lblas" >&5
+echo "configure:10867: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 10695 "configure"
+#line 10873 "configure"
@@ -10702,7 +10880,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10717,13 +10895,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:10721: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10899: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 10727 "configure"
+#line 10905 "configure"
@@ -10734,7 +10912,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10749,13 +10927,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:10753: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10931: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 10759 "configure"
+#line 10937 "configure"
@@ -10766,7 +10944,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10800,13 +10978,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:10804: checking for acosp in -lsunmath" >&5
+echo "configure:10982: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 10810 "configure"
+#line 10988 "configure"
@@ -10817,7 +10995,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:10821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10832,13 +11010,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:10836: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11014: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 10842 "configure"
+#line 11020 "configure"
@@ -10849,7 +11027,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10879,13 +11057,13 @@
 # Generic BLAS library
-echo "configure:10883: checking for sgemm_ in -lblas" >&5
+echo "configure:11061: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 10889 "configure"
+#line 11067 "configure"
@@ -10896,7 +11074,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10935,7 +11113,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:10939: checking whether to use LAPACK" >&5
+echo "configure:11117: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -10960,7 +11138,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:10964: checking for location of LAPACK includes" >&5
+echo "configure:11142: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -10980,7 +11158,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:10984: checking for location of LAPACK library" >&5
+echo "configure:11162: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11006,15 +11184,15 @@
 do
-echo "configure:11010: checking for $ac_hdr" >&5
+echo "configure:11188: checking for $ac_hdr" >&5
-#line 11013 "configure"
+#line 11191 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11046,10 +11224,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11050: checking for dsegv_" >&5
+echo "configure:11228: checking for dsegv_" >&5
-#line 11053 "configure"
+#line 11231 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -11072,7 +11250,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11099,13 +11277,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11103: checking for desgv_ in -llapack" >&5
+echo "configure:11281: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11109 "configure"
+#line 11287 "configure"
@@ -11116,7 +11294,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11148,13 +11326,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11152: checking for dgesv_ in -llapack" >&5
+echo "configure:11330: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11158 "configure"
+#line 11336 "configure"
@@ -11165,7 +11343,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11184,13 +11362,13 @@
-echo "configure:11188: checking for dgesv_ in -llapack" >&5
+echo "configure:11366: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11194 "configure"
+#line 11372 "configure"
@@ -11201,7 +11379,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11257,7 +11435,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11261: checking whether to use Cairo" >&5
+echo "configure:11439: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11289,7 +11467,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11293: checking for location of cairo includes" >&5
+echo "configure:11471: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11315,15 +11493,15 @@
 do
-echo "configure:11319: checking for $ac_hdr" >&5
+echo "configure:11497: checking for $ac_hdr" >&5
-#line 11322 "configure"
+#line 11500 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11327: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11359,7 +11537,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11363: checking for location of cairo library" >&5
+echo "configure:11541: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11379,7 +11557,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11383: checking for cairo linking flags" >&5
+echo "configure:11561: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11395,10 +11573,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11399: checking for cairo_create" >&5
+echo "configure:11577: checking for cairo_create" >&5
 cat > conftest.$ac_ext <<EOF
-#line 11402 "configure"
+#line 11580 "configure"
 #include "confdefs.h"
     which can conflict with char cairo_create(); below.  */
@@ -11421,7 +11599,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11455,10 +11633,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11459: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11637: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11462 "configure"
+#line 11640 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11481,7 +11659,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11514,10 +11692,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11518: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11696: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11521 "configure"
+#line 11699 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11540,7 +11718,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -11582,7 +11760,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11586: checking whether to use FreeType" >&5
+echo "configure:11764: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -11601,7 +11779,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11605: checking for location of FreeType includes" >&5
+echo "configure:11783: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11627,15 +11805,15 @@
 do
-echo "configure:11631: checking for $ac_hdr" >&5
+echo "configure:11809: checking for $ac_hdr" >&5
-#line 11634 "configure"
+#line 11812 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11639: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11669,7 +11847,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11673: checking for location of FreeType library" >&5
+echo "configure:11851: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11694,13 +11872,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11698: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11876: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 11704 "configure"
+#line 11882 "configure"
@@ -11711,7 +11889,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:11715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11752,7 +11930,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:11756: checking whether to use NLS" >&5
+echo "configure:11934: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -11772,10 +11950,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:11776: checking for gettext" >&5
+echo "configure:11954: checking for gettext" >&5
-#line 11779 "configure"
+#line 11957 "configure"
     which can conflict with char gettext(); below.  */
@@ -11798,7 +11976,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -11816,13 +11994,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:11820: checking for gettext in -lintl" >&5
+echo "configure:11998: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 11826 "configure"
+#line 12004 "configure"
@@ -11833,7 +12011,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11868,7 +12046,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:11872: checking whether to use C++" >&5
+echo "configure:12050: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -11884,7 +12062,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:11888: checking for $ac_word" >&5
+echo "configure:12066: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -11913,7 +12091,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:11917: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12095: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -11924,12 +12102,12 @@
 cat > conftest.$ac_ext << EOF
-#line 11928 "configure"
+#line 12106 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:11933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -11955,19 +12133,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:11959: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12137: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:11964: checking whether we are using GNU C++" >&5
+echo "configure:12142: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:11971: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -11985,7 +12163,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:11989: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12167: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12013,58 +12191,7 @@
   fi
 fi
-for ac_declaration in \
-   '#include <stdlib.h>' \
-   'extern "C" void std::exit (int) throw (); using std::exit;' \
-   'extern "C" void std::exit (int); using std::exit;' \
-   'extern "C" void exit (int) throw ();' \
-   'extern "C" void exit (int);' \
-   'void exit (int);'
-do
-  cat > conftest.$ac_ext <<EOF
-#line 12027 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12035: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  continue
-fi
-rm -f conftest*
-#line 12045 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
-  rm -rf conftest*
-  break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
-  echo '#ifdef __cplusplus' >>confdefs.h
-  echo $ac_declaration      >>confdefs.h
-  echo '#endif'             >>confdefs.h
-fi
-else
 	CXX=
 	CXXFLAGS=
@@ -12077,7 +12204,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12081: checking whether to use openDWG" >&5
+echo "configure:12208: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12097,7 +12224,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12101: checking for location of openDGW includes" >&5
+echo "configure:12228: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12123,15 +12250,15 @@
 do
-echo "configure:12127: checking for $ac_hdr" >&5
+echo "configure:12254: checking for $ac_hdr" >&5
-#line 12130 "configure"
+#line 12257 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12135: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12165,7 +12292,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12169: checking for location of openDWG library" >&5
+echo "configure:12296: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12206,7 +12333,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12210: checking whether to use POSIX threads" >&5
+echo "configure:12337: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12226,7 +12353,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12230: checking for location of POSIX threads includes" >&5
+echo "configure:12357: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12252,15 +12379,15 @@
 do
-echo "configure:12256: checking for $ac_hdr" >&5
+echo "configure:12383: checking for $ac_hdr" >&5
-#line 12259 "configure"
+#line 12386 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12264: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12294,7 +12421,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12298: checking for location of POSIX threads library" >&5
+echo "configure:12425: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12319,10 +12446,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12323: checking for pthread_create" >&5
+echo "configure:12450: checking for pthread_create" >&5
-#line 12326 "configure"
+#line 12453 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12345,7 +12472,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12372,13 +12499,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12376: checking for pthread_create in -lpthread" >&5
+echo "configure:12503: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpthread  $LIBS"
-#line 12382 "configure"
+#line 12509 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12389,7 +12516,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12439,7 +12566,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12443: checking whether to use OpenMP" >&5
+echo "configure:12570: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12460,7 +12587,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12464: checking for location of OpenMP includes" >&5
+echo "configure:12591: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12486,15 +12613,15 @@
 do
-echo "configure:12490: checking for $ac_hdr" >&5
+echo "configure:12617: checking for $ac_hdr" >&5
-#line 12493 "configure"
+#line 12620 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12498: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12625: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12532,7 +12659,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12536: checking for location of OpenMP library" >&5
+echo "configure:12663: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12557,10 +12684,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12561: checking for GOMP_parallel_start" >&5
+echo "configure:12688: checking for GOMP_parallel_start" >&5
-#line 12564 "configure"
+#line 12691 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12583,7 +12710,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12610,13 +12737,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12614: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12741: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12620 "configure"
+#line 12747 "configure"
@@ -12627,7 +12754,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12758: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12700,7 +12827,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12704: checking whether to use OpenCL" >&5
+echo "configure:12831: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -12720,7 +12847,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12724: checking for location of OpenCL includes" >&5
+echo "configure:12851: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12747,15 +12874,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12751: checking for $ac_hdr" >&5
+echo "configure:12878: checking for $ac_hdr" >&5
-#line 12754 "configure"
+#line 12881 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12759: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12886: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12795,10 +12922,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:12799: checking for clGetPlatformInfo" >&5
+echo "configure:12926: checking for clGetPlatformInfo" >&5
-#line 12802 "configure"
+#line 12929 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -12821,7 +12948,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -12860,15 +12987,15 @@
 do
-echo "configure:12864: checking for $ac_hdr" >&5
+echo "configure:12991: checking for $ac_hdr" >&5
-#line 12867 "configure"
+#line 12994 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12872: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12999: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12901,7 +13028,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:12905: checking for location of OpenCL library" >&5
+echo "configure:13032: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -12925,13 +13052,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:12929: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13056: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 12935 "configure"
+#line 13062 "configure"
@@ -12942,7 +13069,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:12946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13002,7 +13129,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13006: checking for special C compiler options needed for large files" >&5
+echo "configure:13133: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13010,7 +13137,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13014 "configure"
+#line 13141 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13026,7 +13153,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13030: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13157: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13035,7 +13162,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13039 "configure"
+#line 13166 "configure"
@@ -13051,7 +13178,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13055: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13182: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13078,11 +13205,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13082: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13209: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13086 "configure"
+#line 13213 "configure"
@@ -13098,14 +13225,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13102: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13229: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13109 "configure"
+#line 13236 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13123,7 +13250,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13127: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13254: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13149,11 +13276,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13153: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13280: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13157 "configure"
+#line 13284 "configure"
@@ -13169,14 +13296,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13173: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13300: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13180 "configure"
+#line 13307 "configure"
 #define _LARGE_FILES 1
@@ -13194,7 +13321,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13198: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13325: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13220,25 +13347,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13224: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13351: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13228 "configure"
+#line 13355 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13235: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13362: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13242 "configure"
+#line 13369 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13247,7 +13374,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13251: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13378: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13279,25 +13406,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13283: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13410: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13287 "configure"
+#line 13414 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13294: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13421: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13301 "configure"
+#line 13428 "configure"
 #include <stdio.h>
@@ -13306,7 +13433,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13310: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13437: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13336,18 +13463,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13340: checking for fseeko" >&5
+echo "configure:13467: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13344 "configure"
+#line 13471 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13364,10 +13491,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13368: checking if system supports Large Files at all" >&5
+echo "configure:13495: checking if system supports Large Files at all" >&5
-#line 13371 "configure"
+#line 13498 "configure"
 #include <stdio.h>
@@ -13399,7 +13526,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13403: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13530: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13619,6 +13746,11 @@
 s%@LIBLAS_CFLAGS@%$LIBLAS_CFLAGS%g
 s%@LIBLAS_INC@%$LIBLAS_INC%g
 s%@USE_LIBLAS@%$USE_LIBLAS%g
+s%@PDAL_CONFIG@%$PDAL_CONFIG%g
+s%@PDAL_LIBS@%$PDAL_LIBS%g
+s%@PDAL_CPPFLAGS@%$PDAL_CPPFLAGS%g
+s%@PDAL_INC@%$PDAL_INC%g
+s%@USE_PDAL@%$USE_PDAL%g
 s%@NETCDF_CONFIG@%$NETCDF_CONFIG%g
 s%@NETCDF_LIBS@%$NETCDF_LIBS%g
 s%@NETCDF_CFLAGS@%$NETCDF_CFLAGS%g
@@ -14009,6 +14141,8 @@
 echo "  OpenMP support:             `if test -n "${USE_OPENMP}" ; then echo yes ; else echo no ; fi`"
+echo "  PDAL support:               `if test -n "${USE_PDAL}" ; then echo yes ; else echo no ; fi`"
 echo "  PNG support:                `if test -n "${USE_PNG}" ; then echo yes ; else echo no ; fi`"
 echo "  POSIX thread support:       `if test -n "${USE_PTHREAD}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2015-12-20 22:59:54 UTC (rev 67292)
+++ grass/trunk/configure.in	2015-12-21 02:50:05 UTC (rev 67293)
@@ -278,6 +278,18 @@
                           e.g. '--with-liblas=/usr/local/bin/liblas-config',
                           default: no)],, with_liblas="no")
+AC_ARG_WITH(pdal,
+[  --with-pdal[=path/pdal-config]
+                          enable PDAL support (pdal-config with path,
+                          e.g. '--with-pdal=/usr/local/bin/pdal-config',
+                          default: no)],, with_pdal="no")
+AC_ARG_WITH(wxwidgets,
+[  --with-wxwidgets[=path/wx-config]
+                          enable wxWidgets support (wx-config with path,
+                          e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
+                          default: no)],, with_wxwidgets="no")
 AC_ARG_WITH(netcdf,
 [  --with-netcdf[=path/nc-config]
                           enable NetCDF support (nc-config with path,
@@ -853,6 +865,69 @@
 AC_SUBST(LIBLAS_INC)
 AC_SUBST(USE_LIBLAS)
+# PDAL option
+AC_MSG_CHECKING(whether to use PDAL)
+# new and currently used way to switch language to C++
+# AC_LANG_PUSH(C++)
+AC_LANG_SAVE
+AC_LANG_CPLUSPLUS
+PDAL_LIBS=
+PDAL_CPPFLAGS=
+USE_PDAL=
+if test "`basename xx/$with_pdal`" = "pdal-config" ; then
+  PDAL_CONFIG="$with_pdal"
+fi
+if test "$with_pdal" = "no" ; then
+  AC_MSG_RESULT(no)
+else
+  AC_MSG_RESULT(yes)
+  AC_PATH_PROG(PDAL_CONFIG, pdal-config, no)
+  if test "$PDAL_CONFIG" = "no" ; then
+    AC_MSG_ERROR([*** could not find pdal-config])
+  fi
+  if test "$PDAL_CONFIG" != "" ; then
+    PDAL_LIBS=`"$PDAL_CONFIG" --libs`
+    PDAL_CPPFLAGS=`"$PDAL_CONFIG" --cxxflags`
+    PDAL_INC=`"$PDAL_CONFIG" --includes`
+    USE_PDAL=1
+  fi
+  PDAL=
+  ac_save_libs="$LIBS"
+  ac_save_cflags="$CFLAGS"
+  ac_save_cppflags="$CPPFLAGS"
+  LIBS="$LIBS $PDAL_LIBS"
+  CFLAGS="$CFLAGS $PDAL_CFLAGS"
+  CPPFLAGS="$CPPFLAGS $PDAL_CPPFLAGS $PDAL_INC"
+  AC_TRY_LINK([#include <pdal/PointTable.hpp>],[pdal::PointTable table;],,[
+  AC_TRY_LINK([#include <pdal/PointTable.hpp>],[pdal::PointTable table;],PDAL_LIBS="$PDAL_LIBS",[
+  AC_MSG_ERROR([*** Unable to locate PDAL library.])
+  LIBS=${ac_save_libs}
+  CFLAGS=${ac_save_cflags}
+  CPPFLAGS=${ac_save_cppflags}
+  AC_DEFINE(HAVE_PDAL)
+fi
+AC_SUBST(PDAL_LIBS)
+AC_SUBST(PDAL_CPPFLAGS)
+AC_SUBST(PDAL_INC)
+AC_SUBST(USE_PDAL)
+# new and currently used way to switch language back to C
+# AC_LANG_POP(C++)
+AC_LANG_C
+AC_LANG_RESTORE
 # NetCDF option
 AC_MSG_CHECKING(whether to use NetCDF)
@@ -1850,6 +1925,7 @@
 LOC_MSG_USE(OpenCL support,USE_OPENCL)
 LOC_MSG_USE(OpenGL support,USE_OPENGL)
 LOC_MSG_USE(OpenMP support,USE_OPENMP)
+LOC_MSG_USE(PDAL support,USE_PDAL)
 LOC_MSG_USE(PNG support,USE_PNG)
 LOC_MSG_USE(POSIX thread support,USE_PTHREAD)
 LOC_MSG_USE(PostgreSQL support,USE_POSTGRES)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2015-12-20 22:59:54 UTC (rev 67292)
+++ grass/trunk/include/Make/Platform.make.in	2015-12-21 02:50:05 UTC (rev 67293)
@@ -173,6 +173,12 @@
 LASINC              = @LIBLAS_INC@
 USE_LIBLAS          = @USE_LIBLAS@
+#LAS LiDAR through PDAL
+PDALLIBS             = @PDAL_LIBS@
+PDALCPPFLAGS         = @PDAL_CPPFLAGS@
+PDALINC              = @PDAL_INC@
+USE_PDAL             = @USE_PDAL@
 #GEOS
 GEOSLIBS            = @GEOS_LIBS@
 GEOSCFLAGS          = @GEOS_CFLAGS@
