[GRASS-SVN] r67301 - in grass/branches/releasebranch_7_0/raster/r.watershed: ram seg
Mon Dec 21 05:55:00 PST 2015
Author: mmetz
Date: 2015-12-21 05:55:00 -0800 (Mon, 21 Dec 2015)
New Revision: 67301
   grass/branches/releasebranch_7_0/raster/r.watershed/ram/do_astar.c
   grass/branches/releasebranch_7_0/raster/r.watershed/ram/do_cum.c
   grass/branches/releasebranch_7_0/raster/r.watershed/seg/do_astar.c
   grass/branches/releasebranch_7_0/raster/r.watershed/seg/do_cum.c
r.watershed: fix correction for diagonal flow bias
Modified: grass/branches/releasebranch_7_0/raster/r.watershed/ram/do_astar.c
--- grass/branches/releasebranch_7_0/raster/r.watershed/ram/do_astar.c	2015-12-21 10:07:59 UTC (rev 67300)
+++ grass/branches/releasebranch_7_0/raster/r.watershed/ram/do_astar.c	2015-12-21 13:55:00 UTC (rev 67301)
@@ -133,8 +133,8 @@
 			get_slope2(alt_val, alt_nbr[ct_dir],
 				   dist_to_nbr[ct_dir]);
-		if (!is_worked) {
-		    if (ct_dir > 3 && slope[ct_dir] >= 0) {
+		if (!is_in_list || (!is_worked && asp[index_up] < 0)) {
+		    if (ct_dir > 3 && slope[ct_dir] > 0) {
 			if (slope[nbr_ew[ct_dir]] >= 0) {
 			    /* slope to ew nbr > slope to center */
 			    if (slope[ct_dir] <
@@ -154,14 +154,14 @@
 		if (!skip_diag) {
 		    /* add neighbour as new point if not in the list */
-		    if (is_in_list == 0) {
+		    if (!is_in_list) {
 			add_pt(upr, upc, alt_nbr[ct_dir]);
 			/* set flow direction */
 			asp[index_up] = drain[upr - r + 1][upc - c + 1];
-		    else if (is_in_list && is_worked == 0 && slope[ct_dir] > 0) {
+		    else if (!is_worked) {
 			/* neighbour is edge in list, not yet worked */
-			if (asp[index_up] < 0) {
+			if (asp[index_up] < 0 && slope[ct_dir] > 0) {
 			    /* adjust flow direction for edge cell */
Modified: grass/branches/releasebranch_7_0/raster/r.watershed/ram/do_cum.c
--- grass/branches/releasebranch_7_0/raster/r.watershed/ram/do_cum.c	2015-12-21 10:07:59 UTC (rev 67300)
+++ grass/branches/releasebranch_7_0/raster/r.watershed/ram/do_cum.c	2015-12-21 13:55:00 UTC (rev 67301)
@@ -173,6 +173,8 @@
 		    aspect = -1 * drain[r - r_nbr + 1][c - c_nbr + 1];
 		    asp[this_index] = aspect;
+		if (valued > 0)
+		    wat[down_index] = -valued;
 		continue;
@@ -357,6 +359,8 @@
 			    if (dr == r_nbr && dc == c_nbr) {
 				astar_not_set = 0;
+			    if (value < 0 && valued > 0)
+				wat[nbr_index] = -valued;
Modified: grass/branches/releasebranch_7_0/raster/r.watershed/seg/do_astar.c
--- grass/branches/releasebranch_7_0/raster/r.watershed/seg/do_astar.c	2015-12-21 10:07:59 UTC (rev 67300)
+++ grass/branches/releasebranch_7_0/raster/r.watershed/seg/do_astar.c	2015-12-21 13:55:00 UTC (rev 67301)
@@ -86,8 +86,8 @@
-		if (!is_worked) {
+		if (!is_in_list || (!is_worked && af.asp < 0)) {
 			    if (slope[ct_dir] <
@@ -107,16 +107,16 @@
 		if (!skip_diag) {
 			af.asp = drain[upr - r + 1][upc - c + 1];
 			FLAG_SET(af.flag, INLISTFLAG);
 			seg_put(&aspflag, (char *)&af, upr, upc);
-			if (af.asp < 0) {
+			if (af.asp < 0 && slope[ct_dir] > 0) {
Modified: grass/branches/releasebranch_7_0/raster/r.watershed/seg/do_cum.c
--- grass/branches/releasebranch_7_0/raster/r.watershed/seg/do_cum.c	2015-12-21 10:07:59 UTC (rev 67300)
+++ grass/branches/releasebranch_7_0/raster/r.watershed/seg/do_cum.c	2015-12-21 13:55:00 UTC (rev 67301)
@@ -162,6 +162,12 @@
 		    af.asp = -1 * drain[r - dr + 1][c - dc + 1];
 		seg_put(&aspflag, (char *)&af, r, c);
+		seg_get(&watalt, (char *)&wadown, dr, dc);
+		valued = wadown.wat;
+		if (valued > 0) {
+		    wadown.wat = -valued;
+		    seg_put(&watalt, (char *)&wadown, dr, dc);
 		continue;
@@ -384,6 +390,10 @@
 				astar_not_set = 0;
+			    if (value < 0 && wat_nbr[ct_dir] > 0) {
+				wa.wat = -wat_nbr[ct_dir];
+				seg_put(&watalt, (char *)&wa, r_nbr, c_nbr);
