[GRASS-SVN] r67317 - grass/trunk/vector/v.in.lidar
Mon Dec 21 19:49:07 PST 2015
Author: wenzeslaus
Date: 2015-12-21 19:49:07 -0800 (Mon, 21 Dec 2015)
New Revision: 67317
   grass/trunk/vector/v.in.lidar/count_decimation.h
v.in.lidar: use long ints for counts (finish r67316)
Modified: grass/trunk/vector/v.in.lidar/count_decimation.h
--- grass/trunk/vector/v.in.lidar/count_decimation.h	2015-12-22 02:02:07 UTC (rev 67316)
+++ grass/trunk/vector/v.in.lidar/count_decimation.h	2015-12-22 03:49:07 UTC (rev 67317)
@@ -19,14 +19,25 @@
 /* TODO: revise names (now partially on some vars in v.in.lidar code) */
 struct CountDecimationControl {
-    int offset_n;
-    int offset_n_counter;
-    int skip_every;
-    int preserve_every;
-    int every_counter;
-    int n_count_filtered;
-    int limit_n;
-    int limit_n_counter;
+#ifdef HAVE_LONG_LONG_INT
+    unsigned long long offset_n;
+    unsigned long long offset_n_counter;
+    unsigned long long skip_every;
+    unsigned long long preserve_every;
+    unsigned long long every_counter;
+    unsigned long long n_count_filtered;
+    unsigned long long limit_n;
+    unsigned long long limit_n_counter;
+#else
+    unsigned long offset_n;
+    unsigned long offset_n_counter;
+    unsigned long skip_every;
+    unsigned long preserve_every;
+    unsigned long every_counter;
+    unsigned long n_count_filtered;
+    unsigned long limit_n;
+    unsigned long limit_n_counter;
+#endif
 void count_decimation_init(struct CountDecimationControl *control,
