[GRASS-SVN] r67381 - grass-addons/grass7/raster/r.subdayprecip.design
Sat Dec 26 04:45:21 PST 2015
Author: martinl
Date: 2015-12-26 04:45:20 -0800 (Sat, 26 Dec 2015)
New Revision: 67381
   grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
   grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
r.subdayprecip.design: add support for points
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html	2015-12-26 12:35:21 UTC (rev 67380)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html	2015-12-26 12:45:20 UTC (rev 67381)
@@ -58,8 +58,6 @@
   computational region resolution),
   see <a href="https://trac.osgeo.org/grass/ticket/2768">related bug
       report</a></li>
-  <li><em>r.subdayprecip.design</em> currently supports only vector
-  <i>area</i> input, <i>points</i> are not supported</li>
 </ul>
 <h2>REFERENCES</h2>
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py	2015-12-26 12:35:21 UTC (rev 67380)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py	2015-12-26 12:45:20 UTC (rev 67381)
@@ -121,6 +121,11 @@
         return 1
     allowed_rasters = ('H_002', 'H_005', 'H_010', 'H_020', 'H_050', 'H_100')
+    # test input feature type
+    vinfo = grass.vector_info_topo(opt['map'])
+    if vinfo['areas'] < 1 and vinfo['points'] < 1:
+        grass.fatal(_("No points or areas found in input vector map <{}>").format(opt['map']))
     # extract multi values to points
     for rast in opt['raster'].split(','):
@@ -138,8 +143,12 @@
         # perform zonal statistics
         grass.message('Processing <{}>...'.format(rast))
         table = '{}_table'.format(name)
-        Module('v.rast.stats', flags='c', map=opt['map'], raster=rast,
-               column_prefix=name, method='average', quiet=True)
+        if vinfo['areas'] > 0:
+            Module('v.rast.stats', flags='c', map=opt['map'], raster=rast,
+                   column_prefix=name, method='average', quiet=True)
+        else: # -> points
+            Module('v.what.rast', map=opt['map'], raster=rast,
+                   column='{}_average'.format(name), quiet=True)
         # TODO: handle null values (very small areas)
         # Module('v.what.rast', map=opt['map'], raster=rast, type='centroid',
         #       column='{}_average'.format(name),
