[GRASS-SVN] r67393 - grass/branches/releasebranch_7_0/vector/v.buffer
Sun Dec 27 10:10:10 PST 2015
Author: neteler
Date: 2015-12-27 10:10:10 -0800 (Sun, 27 Dec 2015)
New Revision: 67393
   grass/branches/releasebranch_7_0/vector/v.buffer/v.buffer.html
v.buffer manual: enhanced explanation of -t flag (trunk, r67143)
Modified: grass/branches/releasebranch_7_0/vector/v.buffer/v.buffer.html
--- grass/branches/releasebranch_7_0/vector/v.buffer/v.buffer.html	2015-12-27 18:05:13 UTC (rev 67392)
+++ grass/branches/releasebranch_7_0/vector/v.buffer/v.buffer.html	2015-12-27 18:10:10 UTC (rev 67393)
@@ -11,11 +11,18 @@
 Internal buffers for areas can be generated with negative distance
 values ("inward buffer" or "negative buffer").
 <p>
-Categories and attributes can be transferred with the <b>t</b> flag.
-The resulting buffer areas can have multiple categories, and multiple
-buffer areas can have the same category. The buffer for the input
-feature with category X can thus be retrieved by selecting all buffer
-areas with category X (see example below).
+<em>v.buffer</em> fusions the geometries of buffers by default.
+Categories and attribute table will not be transferred (this would
+not make sense as one buffer geometry can be the result of many
+different input geometries). To transfer the categories and
+attributes the user can set the <b>t</b> flag. This will result in
+buffers being cut up where buffers of individual input geometries
+overlap.  Each part that is the result of overlapping buffers of
+multiple geometries will have multiple categories corresponding to
+those geometries, and multiple buffer areas can have the same
+category. The buffer for the input feature with category X can thus
+be retrieved by selecting all buffer areas with category X (see
+example below).
 <p>
 Buffers for lines and areas are generated using the algorithms from
