[GRASS-SVN] r67397 - in grass/branches/releasebranch_7_0/raster: r.external r.grow.distance r.mode r.param.scale r.quant r.region r.ros r.sim/r.sim.sediment r.sim/r.sim.water r.spread r.statistics r.stats.zonal r.topidx r.topmodel
Sun Dec 27 10:29:24 PST 2015
Author: neteler
Date: 2015-12-27 10:29:24 -0800 (Sun, 27 Dec 2015)
New Revision: 67397
   grass/branches/releasebranch_7_0/raster/r.external/main.c
   grass/branches/releasebranch_7_0/raster/r.grow.distance/main.c
   grass/branches/releasebranch_7_0/raster/r.mode/main.c
   grass/branches/releasebranch_7_0/raster/r.param.scale/interface.c
   grass/branches/releasebranch_7_0/raster/r.quant/main.c
   grass/branches/releasebranch_7_0/raster/r.region/r.region.html
   grass/branches/releasebranch_7_0/raster/r.ros/main.c
   grass/branches/releasebranch_7_0/raster/r.sim/r.sim.sediment/main.c
   grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/main.c
   grass/branches/releasebranch_7_0/raster/r.spread/main.c
   grass/branches/releasebranch_7_0/raster/r.statistics/main.c
   grass/branches/releasebranch_7_0/raster/r.stats.zonal/main.c
   grass/branches/releasebranch_7_0/raster/r.topidx/main.c
   grass/branches/releasebranch_7_0/raster/r.topmodel/main.c
various commands: keywords sync to trunk; module description sync; HTML cosmetics sync
Modified: grass/branches/releasebranch_7_0/raster/r.external/main.c
--- grass/branches/releasebranch_7_0/raster/r.external/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.external/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -98,8 +98,10 @@
     flag.o = G_define_flag();
     flag.o->key = 'o';
+    flag.o->label =
+	_("Override projection check (use current location's projection)");
     flag.o->description =
-	_("Override projection (use location's projection)");
+	_("Assume that the dataset has same projection as the current location");
     flag.e = G_define_flag();
     flag.e->key = 'e';
Modified: grass/branches/releasebranch_7_0/raster/r.grow.distance/main.c
--- grass/branches/releasebranch_7_0/raster/r.grow.distance/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.grow.distance/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -150,6 +150,7 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("distance"));
+    G_add_keyword(_("proximity"));
     module->description =
 	_("Generates a raster map containing distances to nearest raster features.");
Modified: grass/branches/releasebranch_7_0/raster/r.mode/main.c
--- grass/branches/releasebranch_7_0/raster/r.mode/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.mode/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -52,8 +52,8 @@
+    G_add_keyword(_("statistics"));
     G_add_keyword(_("algebra"));
-    G_add_keyword(_("statistics"));
 	_("Finds the mode of values in a cover map within "
 	  "areas assigned the same category value in a "
Modified: grass/branches/releasebranch_7_0/raster/r.param.scale/interface.c
--- grass/branches/releasebranch_7_0/raster/r.param.scale/interface.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.param.scale/interface.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -53,6 +53,9 @@
     G_add_keyword(_("geomorphology"));
+    G_add_keyword(_("terrain"));
+    G_add_keyword(_("elevation"));
+    G_add_keyword(_("landform"));
     module->label = _("Extracts terrain parameters from a DEM.");
     module->description = _("Uses a multi-scale approach"
 			    " by taking fitting quadratic parameters to any size window (via least squares).");
Modified: grass/branches/releasebranch_7_0/raster/r.quant/main.c
--- grass/branches/releasebranch_7_0/raster/r.quant/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.quant/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -45,8 +45,8 @@
     G_add_keyword(_("quantization"));
 	_("Produces the quantization file for a floating-point map.");
Modified: grass/branches/releasebranch_7_0/raster/r.region/r.region.html
--- grass/branches/releasebranch_7_0/raster/r.region/r.region.html	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.region/r.region.html	2015-12-27 18:29:24 UTC (rev 67397)
@@ -42,8 +42,11 @@
 <h2>SEE ALSO</h2>
-<em><a href="r.support.html">r.support</a></em><br>
-<em><a href="g.region.html">g.region</a></em>
+<em>
+<a href="r.support.html">r.support</a>,
+<a href="g.region.html">g.region</a>,
+<a href="v.transform.html">v.transform</a>
+</em>
 <h2>AUTHOR</h2>
Modified: grass/branches/releasebranch_7_0/raster/r.ros/main.c
--- grass/branches/releasebranch_7_0/raster/r.ros/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.ros/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -214,6 +214,7 @@
     G_add_keyword(_("spread"));
     G_add_keyword(_("rate of spread"));
     G_add_keyword(_("hazard"));
+    G_add_keyword(_("model"));
     module->label = _("Generates rate of spread raster maps.");
 	_("Generates three, or four raster map layers showing the base "
Modified: grass/branches/releasebranch_7_0/raster/r.sim/r.sim.sediment/main.c
--- grass/branches/releasebranch_7_0/raster/r.sim/r.sim.sediment/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.sim/r.sim.sediment/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -112,6 +112,7 @@
     G_add_keyword(_("sediment flow"));
     G_add_keyword(_("erosion"));
     G_add_keyword(_("deposition"));
 	_("Sediment transport and erosion/deposition simulation "
 	  "using path sampling method (SIMWE).");
Modified: grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/main.c
--- grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.sim/r.sim.water/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -111,6 +111,7 @@
     G_add_keyword(_("soil"));
     G_add_keyword(_("flow"));
     G_add_keyword(_("overland flow"));
 	_("Overland flow hydrologic simulation using "
 	  "path sampling method (SIMWE).");
Modified: grass/branches/releasebranch_7_0/raster/r.spread/main.c
--- grass/branches/releasebranch_7_0/raster/r.spread/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.spread/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -106,6 +106,7 @@
     G_add_keyword(_("fire"));
     module->label =
 	_("Simulates elliptically anisotropic spread.");
Modified: grass/branches/releasebranch_7_0/raster/r.statistics/main.c
--- grass/branches/releasebranch_7_0/raster/r.statistics/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.statistics/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -54,6 +54,7 @@
+    G_add_keyword(_("zonal statistics"));
 	_("Calculates category or object oriented statistics.");
Modified: grass/branches/releasebranch_7_0/raster/r.stats.zonal/main.c
--- grass/branches/releasebranch_7_0/raster/r.stats.zonal/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.stats.zonal/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -100,6 +100,7 @@
 	_("Calculates category or object oriented statistics (accumulator-based statistics).");
Modified: grass/branches/releasebranch_7_0/raster/r.topidx/main.c
--- grass/branches/releasebranch_7_0/raster/r.topidx/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.topidx/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -38,8 +38,9 @@
     G_add_keyword(_("hydrology"));
+    G_add_keyword(_("wetness"));
-	_("Creates a topographic index raster map from an elevation raster map.");
+	_("Creates a topographic index (wetness index) raster map from an elevation raster map.");
     params.input = G_define_standard_option(G_OPT_R_ELEV);
     params.input->key = "input";
Modified: grass/branches/releasebranch_7_0/raster/r.topmodel/main.c
--- grass/branches/releasebranch_7_0/raster/r.topmodel/main.c	2015-12-27 18:19:23 UTC (rev 67396)
+++ grass/branches/releasebranch_7_0/raster/r.topmodel/main.c	2015-12-27 18:29:24 UTC (rev 67397)
@@ -50,6 +50,7 @@
 	_("Simulates TOPMODEL which is a physically based hydrologic model.");
