[GRASS-SVN] r64404 - grass/trunk/lib/python/script
Mon Feb 2 10:23:12 PST 2015
Author: martinl
Date: 2015-02-02 10:23:12 -0800 (Mon, 02 Feb 2015)
New Revision: 64404
   grass/trunk/lib/python/script/task.py
   grass/trunk/lib/python/script/utils.py
libpython: move cmd list <-> tuple from wxGUI
Modified: grass/trunk/lib/python/script/task.py
--- grass/trunk/lib/python/script/task.py	2015-02-02 17:28:42 UTC (rev 64403)
+++ grass/trunk/lib/python/script/task.py	2015-02-02 18:23:12 UTC (rev 64404)
@@ -25,7 +25,7 @@
 except ImportError:
     import elementtree.ElementTree as etree # Python <= 2.4
-from utils import decode
+from utils import decode, split
 from core import *
@@ -581,3 +581,68 @@
     cmdinfo['usage'] = usage
     return cmdinfo
+def cmdtuple_to_list(cmd):
+    """Convert command tuple to list.
+    :param tuple cmd: GRASS command to be converted
+    :return: command in list
+    cmdList = []
+    if not cmd:
+        return cmdList
+    cmdList.append(cmd[0])
+    if 'flags' in cmd[1]:
+        for flag in cmd[1]['flags']:
+            cmdList.append('-' + flag)
+    for flag in ('help', 'verbose', 'quiet', 'overwrite'):
+        if flag in cmd[1] and cmd[1][flag] is True:
+            cmdList.append('--' + flag)
+    for k, v in cmd[1].iteritems():
+        if k in ('flags', 'help', 'verbose', 'quiet', 'overwrite'):
+            continue
+        cmdList.append('%s=%s' % (k, v))
+    return cmdList
+def cmdlist_to_tuple(cmd):
+    """Convert command list to tuple for run_command() and others
+    :param list cmd: GRASS command to be converted
+    :return: command as tuple
+    if len(cmd) < 1:
+        return None
+    dcmd = {}
+    for item in cmd[1:]:
+        if '=' in item: # params
+            key, value = item.split('=', 1)
+            dcmd[str(key)] = str(value).replace('"', '')
+        elif item[:2] == '--': # long flags
+            flag = item[2:]
+            if flag in ('help', 'verbose', 'quiet', 'overwrite'):
+                dcmd[str(flag)] = True
+        elif len(item) == 2 and item[0] == '-': # -> flags
+            if 'flags' not in dcmd:
+                dcmd['flags'] = ''
+            dcmd['flags'] += item[1]
+        else: # unnamed parameter
+            module = gtask.parse_interface(cmd[0])
+            dcmd[module.define_first()] = item
+    return (cmd[0], dcmd)
+def cmdstring_to_tuple(cmd):
+    """Convert command string to tuple for run_command() and others
+    :param str cmd: command to be converted
+    return cmdlist_to_tuple(split(cmd))
Modified: grass/trunk/lib/python/script/utils.py
--- grass/trunk/lib/python/script/utils.py	2015-02-02 17:28:42 UTC (rev 64403)
+++ grass/trunk/lib/python/script/utils.py	2015-02-02 18:23:12 UTC (rev 64404)
@@ -18,10 +18,11 @@
 import os
+import sys
 import shutil
 import locale
+import shlex
 def float_or_dms(s):
     """Convert DMS to float.
@@ -235,3 +236,12 @@
     return '{number:0{width}d}'.format(width=len(str(max_number)),
                                        number=number)
+def split(s):
+    """!Platform specific shlex.split"""
+    if sys.version_info >= (2, 6):
+        return shlex.split(s, posix = (sys.platform != "win32"))
+    elif sys.platform == "win32":
+        return shlex.split(s.replace('\\', r'\\'))
+    else:
+        return shlex.split(s)
