[GRASS-SVN] r64443 - grass/trunk/display/d.mon
Tue Feb 3 12:59:16 PST 2015
Author: martinl
Date: 2015-02-03 12:59:16 -0800 (Tue, 03 Feb 2015)
New Revision: 64443
   grass/trunk/display/d.mon/start.c
d.mon: partly revert r64437, another attempt to fix launching wx-monitors
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c	2015-02-03 20:52:19 UTC (rev 64442)
+++ grass/trunk/display/d.mon/start.c	2015-02-03 20:59:16 UTC (rev 64443)
@@ -75,7 +75,7 @@
 /* start wxGUI display monitor */
 char *start_wx(const char *name, const char *element, int width, int height, int x_only)
-    char progname[GPATH_MAX];
+    char progname[GPATH_MAX], mon_path[GPATH_MAX];
     char str_width[1024], str_height[1024], *str_x_only;
     char *mapfile;
@@ -97,9 +97,10 @@
         str_x_only = "1";
     else
         str_x_only = "0";
+    G_file_name(mon_path, element, NULL, G_mapset());
     G_spawn_ex(getenv("GRASS_PYTHON"), progname, progname,
-	       name, element, str_width, str_height, str_x_only, SF_BACKGROUND, NULL);
+               name, mon_path, str_width, str_height, str_x_only, SF_BACKGROUND, NULL);
     G_file_name(mapfile, element, "map.ppm", G_mapset());
@@ -190,13 +191,10 @@
     close(fd);
     /* start monitor */
-    if (strncmp(name, "wx", 2) == 0) {
-        G_file_name(file_path, mon_path, NULL, G_mapset());
-        out_file = start_wx(name, file_path, width, height, x_only);
-    else {
+    if (strncmp(name, "wx", 2) == 0)
+        out_file = start_wx(name, mon_path, width, height, x_only);
+    else
         out_file = start(name, output, update);
     /* create env file (environmental variables used for rendering) */
     G_debug(1, "Monitor name=%s, envfile=%s", name, env_file);
