[GRASS-SVN] r64407 - grass/trunk/gui/wxpython
Markus Neteler neteler at osgeo.org
Fri Feb 6 06:08:15 PST 2015
On Fri, Feb 6, 2015 at 2:07 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2015-02-03 3:08 GMT+01:00  <svn_grass at osgeo.org>:
>> Author: wenzeslaus
>> Date: 2015-02-02 18:08:29 -0800 (Mon, 02 Feb 2015)
>> New Revision: 64407
>> Modified:
>>    grass/trunk/gui/wxpython/gis_set.py
>> Log:
>> wxGUI/startup: make warnings, hints and infos show the same; number boxes
> thanks for improvements, unfortunately the window is behaving strange
> when resizing. When I enlarge original screen (grass71_welcome.png)
> and than resize to minimum size I get (grass71_welcome_resized.png).
> It seems to be related only to wxPython 3.0 (tested on GNU/Linux). It
> works perfectly with wxPython 2.8.
I checked here with
GRASS 7.1.svn (eu_laea):~ > g.version -ge
version=7.1.svn
date=2015
revision=64482
build_date=2015-01-06
build_platform=x86_64-unknown-linux-gnu
proj4=4.8.0
gdal=1.11.1
geos=3.4.2
sqlite=3.8.8
rpm -qa | grep wxPython
wxPython-2.8.12.0-8.fc21.x86_64
and all is fine (just to confirm).
I dunno at which stage the wxPython 3 integration is in Fedora:
https://fedoraproject.org/wiki/Changes/wxPython3
Perhaps there is a docker image around for quick testing?
Markus
