[GRASS-SVN] r64487 - grass/trunk/vector/v.cluster
Fri Feb 6 14:52:51 PST 2015
Author: mmetz
Date: 2015-02-06 14:52:51 -0800 (Fri, 06 Feb 2015)
New Revision: 64487
   grass/trunk/vector/v.cluster/main.c
v.cluster: fix cluster id assignment
Modified: grass/trunk/vector/v.cluster/main.c
--- grass/trunk/vector/v.cluster/main.c	2015-02-06 20:34:03 UTC (rev 64486)
+++ grass/trunk/vector/v.cluster/main.c	2015-02-06 22:52:51 UTC (rev 64487)
@@ -239,7 +239,8 @@
     noutliers = nclusters = 0;
     if (clmethod == CL_DBSCAN) {
 	/* DBSCAN
-	 * the neighbors of each point with at least minpnts neighbors
+	 * the neighbors of each point
+	 * with at least minpnts neighbors within distance (epsilon)
 	 * are added to a cluster */
 	/* get epsilon */
@@ -315,18 +316,31 @@
 	    G_percent(i++, npoints, 4);
 	    /* radius search */
+	    /* TODO: use knn search */
 	    kdfound = kdtree_dnn(kdt, c, &kduid, &kddist, eps, &uid);
 	    /* must have min neighbors within radius */
 	    if (kdfound >= minpnts) {
-		cat = idx[cid[uid]];
+		OLD = cid[uid];
+		NEW = idx[OLD];
+		while (OLD != NEW) {
+		    OLD = NEW;
+		    NEW = idx[OLD];
+		cat = NEW;
 		/* find latest cluster */
 		for (j = 0; j < kdfound; j++) {
-		    if (cat < idx[cid[kduid[j]]]) {
-			cat = idx[cid[kduid[j]]];
+		    OLD = cid[kduid[j]];
+		    NEW = idx[OLD];
+			OLD = NEW;
+			NEW = idx[OLD];
+		    if (cat < NEW) {
+			cat = NEW;
 		if (cat == 0) {
@@ -342,7 +356,13 @@
 		/* set or update cluster ids */
 		if (cid[uid] != 0) {
 		    /* relabel */
-		    idx[cid[uid]] = cat;
+		    OLD = cid[uid];
+		    NEW = idx[OLD];
+			OLD = NEW;
+			NEW = idx[OLD];
+		    idx[NEW] = cat;
 		else {
 		    cid[uid] = cat;
@@ -351,7 +371,13 @@
 		    if (cid[kduid[j]] != 0) {
 			/* relabel */
-			idx[cid[kduid[j]]] = cat;
+			NEW = idx[OLD];
+			    OLD = NEW;
+			    NEW = idx[OLD];
+			idx[NEW] = cat;
 		    else {
 		       cid[kduid[j]] = cat;
@@ -486,9 +512,6 @@
 	/* create clusters */
 	G_message(_("Building clusters ..."));
-	clcnt = G_malloc((nlines + 1) * sizeof(int));
-	for (i = 0; i <= nlines; i++)
-	    clcnt[i] = 0;
 	nclusters = 0;
 	kdtree_init_trav(&trav, kdt);
 	c[2] = 0.0;
@@ -503,13 +526,25 @@
 	    /* any neighbor within radius */
 	    if (kdfound > 0) {
+		OLD = cid[uid];
+		NEW = idx[OLD];
+		    OLD = NEW;
+		    NEW = idx[OLD];
+		cat = NEW;
+		    NEW = idx[OLD];
+			OLD = NEW;
+			NEW = idx[OLD];
+		    if (cat < NEW) {
+			cat = NEW;
 		if (cat == 0) {
@@ -520,27 +555,36 @@
 			G_fatal_error(_("nlines: %d, nclusters: %d"), nlines, nclusters);
 		    idx[nclusters] = nclusters;
 		    cid[uid] = nclusters;
-		    clcnt[cat] = 1;
 		    /* relabel */
+		    OLD = cid[uid];
+		    NEW = idx[OLD];
+			OLD = NEW;
+			NEW = idx[OLD];
+		    idx[NEW] = cat;
 		else {
 		    cid[uid] = cat;
-		    clcnt[cat]++;
+			NEW = idx[OLD];
+			    OLD = NEW;
+			    NEW = idx[OLD];
 			/* relabel */
+			idx[NEW] = cat;
 		    else {
-			clcnt[cat]++;
 		G_free(kddist);
@@ -560,6 +604,9 @@
 	/* generate a renumbering scheme */
 	G_message(_("Generating renumbering scheme..."));
 	G_debug(1, "%d initial clusters", nclusters);
+	clcnt = G_malloc((nlines + 1) * sizeof(int));
+	for (i = 0; i <= nlines; i++)
+	    clcnt[i] = 0;
 	/* allocate final clump ID */
 	renumber = (int *) G_malloc((nclusters + 1) * sizeof(int));
 	renumber[0] = 0;
@@ -576,7 +623,7 @@
 		    NEW = idx[OLD];
 		idx[i] = NEW;
-		clcnt[NEW] += clcnt[i];
+		clcnt[NEW]++;
 	for (i = 1; i <= nclusters; i++) {
