[GRASS-SVN] r64527 - grass/trunk/gui/wxpython
Mon Feb 9 06:43:59 PST 2015
Author: martinl
Date: 2015-02-09 06:43:59 -0800 (Mon, 09 Feb 2015)
New Revision: 64527
   grass/trunk/gui/wxpython/wxgui.py
wxgui.py: go back to old version of splash screen (r64455)
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2015-02-09 12:44:14 UTC (rev 64526)
+++ grass/trunk/gui/wxpython/wxgui.py	2015-02-09 14:43:59 UTC (rev 64527)
@@ -5,9 +5,9 @@
 Classes:
  - wxgui::GMApp
- - wxgui::GSplashScreen
+ - wxgui::Usage
-(C) 2006-2015 by the GRASS Development Team
+(C) 2006-2011 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -21,19 +21,22 @@
 import os
 import sys
 import getopt
-import time
 from core import globalvar
 from core.utils import _
-from core.debug import Debug
 from grass.exceptions import Usage
 from grass.script.core import set_raise_on_error
 import wx
+try:
+    import wx.lib.agw.advancedsplash as SC
+except ImportError:
+    SC = None
 from lmgr.frame import GMFrame
 class GMApp(wx.App):
     def __init__(self, workspace = None):
         """ Main GUI class.
@@ -55,38 +58,36 @@
         if not globalvar.CheckWxVersion([2, 9]):
             wx.InitAllImageHandlers()
-        splash = GSplashScreen(app=self, workspace=self.workspaceFile)
-        splash.Show()
-        return True
+        # create splash screen
+        introImagePath = os.path.join(globalvar.IMGDIR, "splash_screen.png")
+        introImage     = wx.Image(introImagePath, wx.BITMAP_TYPE_PNG)
+        introBmp       = introImage.ConvertToBitmap()
+        if SC and sys.platform != 'darwin':
+            # AdvancedSplash is buggy on the Mac as of 2.8.12.1
+            # and raises annoying (though seemingly harmless) errors everytime the GUI is started
+            splash = SC.AdvancedSplash(bitmap = introBmp,
+                                       timeout = 2000, parent = None, id = wx.ID_ANY)
+            splash.SetText(_('Starting GRASS GUI...'))
+            splash.SetTextColour(wx.Colour(45, 52, 27))
+            splash.SetTextFont(wx.Font(pointSize = 15, family = wx.DEFAULT, style = wx.NORMAL,
+                                       weight = wx.BOLD))
+            splash.SetTextPosition((150, 430))
+        else:
+            wx.SplashScreen (bitmap = introBmp, splashStyle = wx.SPLASH_CENTRE_ON_SCREEN | wx.SPLASH_TIMEOUT,
+                             milliseconds = 2000, parent = None, id = wx.ID_ANY)
-class GSplashScreen(wx.SplashScreen):
-    """Create a splash screen widget
-    def __init__(self, parent=None, app=None, workspace=None):
-        self.workspaceFile = workspace
-        self.parent = parent
-        self.app = app
-        bitmap = wx.Image(name=os.path.join(globalvar.IMGDIR, "splash_screen.png")).ConvertToBitmap()
-        wx.SplashScreen.__init__(self, bitmap=bitmap,
-                                 splashStyle=wx.SPLASH_CENTRE_ON_SCREEN | wx.SPLASH_TIMEOUT,
-                                 milliseconds=1000, parent=parent)
-        self.Bind(wx.EVT_CLOSE, self.OnExit)
         wx.Yield()
-    def OnExit(self, event):
         # create and show main frame
-        frame = GMFrame(parent = None, id = wx.ID_ANY,
-                        workspace = self.workspaceFile)
-        self.app.SetTopWindow(frame)
-        self.Hide()
-        frame.Show()
-        event.Skip()  # make sure the default handler runs too
+        mainframe = GMFrame(parent = None, id = wx.ID_ANY,
+                            workspace = self.workspaceFile)
+        mainframe.Show()
+        self.SetTopWindow(mainframe)
+        return True
 def printHelp():
     """ Print program help"""
     print >> sys.stderr, "Usage:"
@@ -113,6 +114,7 @@
 def main(argv = None):
     if argv is None:
         argv = sys.argv
     try:
@@ -128,16 +130,12 @@
         printHelp()
     workspaceFile = process_opt(opts, args)[0]
-    start = time.time()
     app = GMApp(workspaceFile)
     # suppress wxPython logs
     q = wx.LogNull()
     set_raise_on_error(True)
-    Debug.msg(1, "wxGUI started in %.6f sec" % (time.time() - start))
     app.MainLoop()
 if __name__ == "__main__":
