[GRASS-SVN] r64545 - grass/trunk/scripts/v.what.vect
Tue Feb 10 20:40:09 PST 2015
Author: annakrat
Date: 2015-02-10 20:40:09 -0800 (Tue, 10 Feb 2015)
New Revision: 64545
   grass/trunk/scripts/v.what.vect/v.what.vect.py
v.what.vect: fix after renaming v.distance options
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.py
--- grass/trunk/scripts/v.what.vect/v.what.vect.py	2015-02-11 04:27:11 UTC (rev 64544)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.py	2015-02-11 04:40:09 UTC (rev 64545)
@@ -62,13 +62,13 @@
     try:
         grass.run_command('v.distance',
                           from_=options['map'],
-                          to=options['qmap'],
+                          to=options['query_map'],
                           column=options['column'],
-                          to_column=options['qcolumn'],
+                          to_column=options['query_column'],
                           upload='to_attr',
                           dmax=options['dmax'],
                           from_layer=options['layer'],
-                          to_layer=options['qlayer'])
+                          to_layer=options['query_layer'])
     except CalledModuleError:
         return 1
     else:
