[GRASS-SVN] r64589 - in grass-addons/grass7/raster: . r.exdet
Thu Feb 12 11:07:17 PST 2015
Author: pvanbosgeo
Date: 2015-02-12 11:07:17 -0800 (Thu, 12 Feb 2015)
New Revision: 64589
Added:
   grass-addons/grass7/raster/r.exdet/
   grass-addons/grass7/raster/r.exdet/Makefile
   grass-addons/grass7/raster/r.exdet/r.exdet.html
   grass-addons/grass7/raster/r.exdet/r.exdet.py
Tool for the Detection and quantification of novel uni- and multi-variate environments. Based on Mesgaran et al. (2014)
Added: grass-addons/grass7/raster/r.exdet/Makefile
--- grass-addons/grass7/raster/r.exdet/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.exdet/Makefile	2015-02-12 19:07:17 UTC (rev 64589)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.exdet
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.exdet/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/raster/r.exdet/r.exdet.html
--- grass-addons/grass7/raster/r.exdet/r.exdet.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.html	2015-02-12 19:07:17 UTC (rev 64589)
@@ -0,0 +1,107 @@
+<h2>DESCRIPTION</h2>
+<p>Correlative species distribution models (SDMs) often involve some
+degree of projection into conditions non-analogous to those under
+which it has been calibrated. This projection into areas with novel
+environmental condtions is risky as it may be ecologically and
+statistically invalid. However, depending on the research question
+it may be difficult to avoid or indeed the objective of research to
+do so. An example is the prediction of potential distribution of
+species under future climates. The latter may include conditions
+hitherto not encountered in the area of interest. It is important to
+identify such areas and to interpret model results with care.
+<p>The <em>r.exdet</em> function allows you to identify areas with
+novel conditions, following methods developed by Mesgaran et al.
+(2014) [1][2]. This includes areas where conditions fall outside the
+range of values observed in the reference / callibration data set
+(Type 1 novelty) or areas with novel combinations between the
+envirionmental variables (Type 2 novelty). It furthermore compute
+the most dissimilar variable for areas where conditions of at least
+one of the variables fall outside the range of values observed in
+the reference data set.
+<p>The type 1 (<em>NT1</em>) similarity is similar to how the
+multi-environmental similarity messure (MESS) computes novel
+climates [3]. In both cases if a point is outside the range of a
+given covariate, it gets a negative value based on its distance to
+the minimum/maximum of that covariate. The difference is that the
+MESS is based on the most negative value amongst these covariates.
+The NT1 on the other hand is the sum of all these distances. The NT1
+thus accounts for all variables [2]. The <em>NT1</em> can have
+infinite negative values to zero where zero indicates no
+extrapolation beyond the univariate coverage of reference data.
+<p>The type 2 (<em>NT2</em>) similarity is based on the Mahalanobis
+distance and is used to identify areas where conditions are within
+the range of univariate variation but which exhibits novel
+combinations between covariates. <em>NT2</em> can range from zero up
+to infinite positive values. Values ranging from 0 to 1 indicate
+similarity (in terms of both univariate range and multivariate
+combination), with values closer to zero being more similar. Values
+larger than one are indicative of novel combinations.[1]
+<p>The function essentially compares the environmental conditions in
+one area (the reference set) with those of another area (the
+projected set). For the reference set, the function respects the
+region and the mask, if any. The projection data can be of the same
+region (e.g., when comparing current and future climates; see
+example 1 below), or another region (e.g., when comparing conditions
+in one country with those in another country; see example 2 below).
+In the second case, the projected data can be defined by raster
+layers covering a different region. One can also use a <a href=
+"http://grass.osgeo.org/grass64/manuals/g.region.html">region</a> to
+define the projected area (see example 3 below).
+<h2>EXAMPLES</h2>
+<h3>Example 1</h3>
+todo
+<h3>Example 2</h3>
+<p>Download a sample data set from <a href=
+"http://www.climond.org/ExDet.aspx">http://www.climond.org/ExDet</a>
+. The sample data contains 4 clipped Bioclim variable layers for
+Australia and South Africa sourced from the CliMond dataset. In this
+example we will use the Australia data as reference and the South
+Africa data as projected or test. In the example below I will assume
+you have downloaded the data and imported it in the currently open
+location/mapset (the coordinate system is latlon, EPSG 4326).
+<div class="code"><pre>
+g.region raster=AusBio13
+r.exdet -o reference=AusBio13 at example,AusBio14 at example,AusBio5 at example,AusBio6 at example projection=SaBio13 at example,SaBio14 at example,SaBio5 at example,SaBio6 at example output=ExDet2
+</pre></div>
+<h3>Example 3</h3>
+todo
+<h2>CITATION</h2>
+<p>When using this tool, please use the citation to the original paper describing the method in your publications or other derived products:
+<p><em>Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.</em>
+<p>If, in addition, you want to cite this addon, you can use:
+<p><em>van Breugel, P. (2015) r.exdet. http://grasswiki.osgeo.org/wiki/AddOns/GRASS_7</em>
+<h2>REFERENCES</h2>
+<p>[1] Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity &  Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
+<p>[2] ExDet: An stand alone extrapolation detection tool for the modelling of species distributions. URL: <a href="http://www.climond.org/ExDet.aspx">http://www.climond.org/ExDet.aspx</a>
+<p>[3] Elith, J., Kearney, M. and Phillips, S. 2010. The art of modelling range-shifting species. Methods in Ecology and Evolution 1:330-342.
+<h2>SEE ALSO</h2>
+<em><a href="r.mess.html">r.mess</a></em>
+<h2>AUTHOR</h2>
+Paulo van Breugel, paulo at ecodiv.org
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.exdet/r.exdet.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/raster/r.exdet/r.exdet.py
--- grass-addons/grass7/raster/r.exdet/r.exdet.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.py	2015-02-12 19:07:17 UTC (rev 64589)
@@ -0,0 +1,461 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:       r.exdet
+# AUTHOR(S):    paulo van Breugel <paulo at ecodiv.org>
+# PURPOSE:      Detection and quantification of novel environments, with
+#               points / locations being novel because they are outside
+#               the range of individual covariates (NT1) and points/locations
+#               that are within the univariate range but constitute novel
+#               combinations between covariates (NT2).
+#               Based on Mesgaran et al.2014 [1]
+# COPYRIGHT:    (C) 2015 Paulo van Breugel
+#               http://ecodiv.org
+#               http://pvanb.wordpress.com/
+# NOTE:         Requires Numpy >= 1.8, GRASS >=7.0
+#        This program is free software under the GNU General Public
+#        License (>=v2). Read the file COPYING that comes with GRASS
+#        for details.
+# [1] Mesgaran, M.B., Cousens, R.D. & Webber, B.L. (2014) Here be dragons: a
+# tool for quantifying novelty due to covariate range and correlation change
+# when projecting species distribution models. Diversity & Distributions,
+# 20: 1147–1159, DOI: 10.1111/ddi.12209.
+#%module
+#% description: Detection and quantification of novel uni- and multi-variate environments
+#% keywords: mahalanobis distance
+#% keywords: novel environment
+#% keywords: dissimilarity
+#% keywords: similarity,
+#%end
+#%option
+#% key: reference
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Reference environmental raster layers
+#% key_desc: raster
+#% required: yes
+#% multiple: yes
+#% guisection: Input
+#%end
+#%option
+#% key: projection
+#% type: string
+#% description: Projected environmental raster layers
+#% required: yes
+#% multiple: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Output layer
+#% required: yes
+#% multiple: no
+#% guisection: Output
+#%end
+#%option
+#% key: region
+#% type: string
+#% gisprompt: new,region
+#% description: Region defining the projected area
+#% key_desc: region
+#% required: no
+#% multiple: no
+#%end
+#%flag
+#% key: o
+#% description: Most influential covariate (MIC) for NT1
+#%end
+## Not implemented yet
+##%flag
+##% key: p
+##% description: Most influential covariate (MIC) for NT2
+##% guisection: Output
+##%end
+#%flag
+#% key: d
+#% description: Keep layer mahalanobis distance?
+#%end
+#%flag
+#% key: m
+#% description: Restore mask?
+#%end
+#%flag
+#% key: r
+#% description: Restore region?
+#%end
+# Dependencies
+# Numpy >= 1.8, Scipy, grass >= 7.0
+# Standard
+# import libraries
+import os
+import sys
+import atexit
+import numpy as np
+import grass.script as grass
+import grass.script.array as garray
+import tempfile
+import uuid
+import string
+if not os.environ.has_key("GISBASE"):
+    grass.message("You must be in GRASS GIS to run this program.")
+    sys.exit(1)
+# create set to store names of temporary maps to be deleted upon exit
+clean_rast = set()
+def cleanup():
+    for rast in clean_rast:
+        grass.run_command("g.remove", type="rast", name=rast, quiet=True)
+# Functions
+def tmpname(name):
+    tmpf = name + "_" + str(uuid.uuid4())
+    tmpf = string.replace(tmpf, '-', '_')
+    clean_rast.add(tmpf)
+    return tmpf
+def tmpregion():
+    regionname = tmpname("mahal")
+    k = 0
+    ffile = grass.find_file(regionname, element = 'region',
+                            mapset=grass.gisenv()['MAPSET'])
+    while ffile['fullname'] != '':
+        regionname = regionname + k
+        k = k + 1
+    grass.region(save=regionname)
+    grass.run_command("g.region", save=regionname)
+    return regionname
+def tmpmask():
+    maskname = tmpname("mask")
+    k = 0
+    ffile = grass.find_file(maskname, element = 'cell',
+        maskname = maskname + k
+        k = k + 1
+    return maskname
+def checkmask():
+    ffile = grass.find_file("MASK", element = 'cell',
+    mask_presence = ffile['fullname'] != ''
+    return mask_presence
+def icovar(input):
+    tmpcov = tempfile.mkstemp()[1]
+    text_file = open(tmpcov, "w")
+    text_file.write(grass.read_command("r.covar", quiet=True, map=input))
+    text_file.close()
+    covar = np.loadtxt(tmpcov, skiprows=1)
+    VI = np.linalg.inv(covar)
+    os.remove(tmpcov)
+    return VI
+def mahal(v, m, VI):
+    delta = v - m[:,None,None]
+    mahdist = np.sum(np.sum(delta[None,:,:,:] * VI[:,:,None,None],axis=1) * delta, axis=0)
+    stat_mahal = garray.array()
+    stat_mahal[...] = mahdist
+    return stat_mahal
+def main():
+    # Variables
+    ref = options['reference']
+    ref = ref.split(',')
+    pro = options['projection']
+    pro = pro.split(',')
+    opn = [z.split('@')[0] for z in pro]
+    opn = [x.lower() for x in opn]
+    out = options['output']
+    region = options['region']
+    flag_r = flags['r']
+    flag_m = flags['m']
+    flag_d = flags['d']
+    flag_o = flags['o']
+    # flag_p = flags['p'] # not implemented yet
+    if ref == pro and checkmask() == False and region == '':
+        grass.warning("1) reference and projected layers are the same, 2) you \
+        did not define a mask, 3) and you did not define a region to delimit \
+        the region for projection. Was that intentional?")
+    if len(ref) != len(pro):
+        grass.fatal("the number of reference and test layers should be the same")
+    # Create covariance table
+    VI = icovar(input=ref)
+    # Import reference data & compute univar stats per reference layer
+    s = len(ref)
+    dat_ref = stat_mean = stat_min = stat_max = None
+    layer = garray.array()
+    for i, map in enumerate(ref):
+        layer.read(map, null=np.nan)
+        r, c = layer.shape
+        if dat_ref is None:
+            dat_ref = np.empty((s, r, c), dtype=np.double)
+        if stat_mean is None:
+            stat_mean = np.empty((s), dtype=np.double)
+        if stat_min is None:
+            stat_min = np.empty((s), dtype=np.double)
+        if stat_max is None:
+            stat_max = np.empty((s), dtype=np.double)
+        stat_min[i] = np.nanmin(layer)
+        stat_mean[i] = np.nanmean(layer)
+        stat_max[i] = np.nanmax(layer)
+        dat_ref[i,:,:] = layer
+    del layer
+    # Compute mahalanobis over reference layers
+    # Compute mahalanobis over full set of layers
+    mahal_ref = mahal(v=dat_ref, m=stat_mean, VI=VI)
+    mahal_ref_max = max(mahal_ref[np.isfinite(mahal_ref)])
+    del mahal_ref
+    # Compute mahalanobis over projected layers
+    # Remove mask (and optionally backup the MASK)
+    if checkmask():
+        if flag_m:
+            mask_backup = tmpmask()
+            grass.mapcalc("$mask = MASK", mask=mask_backup, quiet=True)
+        grass.run_command("r.mask", flags="r")
+    # Make backup of region if required
+    if flag_r:
+        region_backup = tmpregion()
+    # Set new region based on user-defined region or otherwise based on
+    # projected layers
+    if region != '':
+        ffile = grass.find_file(region, element = 'region',
+        if ffile != '':
+            grass.run_command("g.region", region=region)
+            grass.info("Region is set to the region. Please note that the function" + region)
+            grass.info("does not check if projected layers fall within this region")
+        else:
+            grass.fatal("the region you selected does not exist")
+    else:
+        grass.run_command("g.region", raster=pro[0])
+    if flag_r:
+        grass.info("The original region was saved as " + region_backup)
+    # Import projected layers
+    s = len(pro)
+    dat_pro = None
+    for i, map in enumerate(pro):
+        s = len(pro)
+        if dat_pro is None:
+            dat_pro = np.empty((s, r, c), dtype=np.double)
+        dat_pro[i,:,:] = layer
+    del layer
+    # Compute mahalanobis distance
+    mahal_pro = mahal(v=dat_pro, m=stat_mean, VI=VI)
+    if flag_d:
+        mapname = out + "_mahalanobis"
+        mahal_pro.write(mapname=mapname)
+        grass.info("Mahalanobis distance map saved: " + mapname)
+    # Compute NT2
+    nt2map = garray.array()
+    nt2map[...] = mahal_pro / mahal_ref_max
+    nt2 = out + "_NT2"
+    clean_rast.add(nt2)
+    nt2map.write(mapname=nt2)
+    # Compute NT1
+    tmplay = tmpname(out)
+    mnames = [None] * len(ref)
+    for i in xrange(len(ref)):
+        tmpout = out + "_" + opn[i]
+        clean_rast.add(tmpout)
+        grass.mapcalc("$Dij = min(($prolay - $refmin), ($refmax - $prolay), 0) / ($refmax - $refmin)",
+                      Dij=tmpout,
+                      prolay=pro[i],
+                      refmin=stat_min[i],
+                      refmax=stat_max[i],
+                      quiet=True)
+        mnames[i] = tmpout
+    nt1 = out + "_NT1"
+    grass.run_command("r.series", quiet=True, input=mnames, output=nt1, method="sum")
+    # Compute exdet novelty map
+    grass.mapcalc("$final = if($nt1<0,$nt1,$nt2)",
+                      final=out,
+                      nt1=nt1,
+                      nt2=nt2,
+                      quiet=True, overwrite=True)
+    # Color table
+    tmpcol = tempfile.mkstemp()
+    text_file = open(tmpcol[1], "w")
+    text_file.write("0% 255:0:0\n")
+    text_file.write("0 255:200:200\n")
+    text_file.write("0.000001 200:255:200\n")
+    text_file.write("1 50:210:150\n")
+    text_file.write("1.000001 200:200:255\n")
+    text_file.write("100% 0:0:255\n")
+    text_file.close()
+    grass.run_command("r.colors", quiet=True, map=out, rules=tmpcol[1])
+    os.remove(tmpcol[1])
+    # Compute  most influential covariate (MIC) metric for NT1
+    if flag_o:
+        mod = out + "_MIC1"
+        grass.run_command("r.series", quiet=True, output=mod, input=mnames, method="min_raster")
+        tmpcat = tempfile.mkstemp()
+        text_file = open(tmpcat[1], "w")
+        for cats in xrange(len(opn)):
+            text_file.write(str(cats) + ":" + opn[cats] + "\n")
+        text_file.close()
+        grass.run_command("r.category", quiet=True, map=mod, rules=tmpcat[1], separator=":")
+        os.remove(tmpcat[1])
+    # Compute  most influential covariate (MIC) metric for NT2
+    # Not implemented yet
+#    if flag_p:
+#        laylist = []
+#        layer = garray.array()
+#        # compute ICp values
+#        for i, map in enumerate(pro):
+#            VItmp = array(VI)
+#            VItmp[:,i] = 0
+#            VItmp[i,:] = 0
+#            ymap = mahal(v=dat_pro, m=stat_mean, VI=VItmp)
+#            icp = (mahal_pro - ymap) / mahal_pro * 100
+#            layer[:,:] = icp
+#            layer.write(mapname=out + "_icp_" + opn[i])
+#            laylist.append(out + "_icp_" + opn[i])
+#        # Combine ICp layers
+#        icpname = out + "_MIC2"
+#        icptemp = tmpname(name="icp")
+#        grass.run_command("r.series", quiet=True, output=icptemp,
+#                          input=laylist, method="max_raster")
+#        # ICp values apply only to parts where NT2 > 1 and NT1 = 0
+#        grass.mapcalc("$icpname = if($nt1<0,-888,if($nt2>1,$icptemp,-999))",
+#                      nt1=nt1, nt2=nt2, icpname=icpname, icptemp=icptemp,
+#                      quiet=True)
+#        # Write categories
+#        tmpcat = tempfile.mkstemp()
+#        text_file = open(tmpcat[1], "w")
+#        text_file.write(str(-999) + ":None\n")
+#        text_file.write(str(-888) + ":NT1 range\n")
+#        for cats in xrange(len(opn)):
+#           text_file.write(str(cats) + ":" + opn[cats] + "\n")
+#        text_file.close()
+#        grass.run_command("r.category", quiet=True, map=icpname,
+#                          rules=tmpcat[1], separator=":")
+#        os.remove(tmpcat[1])
+#        grass.run_command("g.remove", quiet=True, type="raster", name=icptemp, flags="f")
+    ## Clean up
+    grass.run_command("g.remove", type="raster", flags="f",
+                      quiet=True, pattern=tmplay + "*")
+    grass.run_command("g.remove", quiet=True, type="raster",
+                      name=mnames, flags="f")
+    if flag_m:
+        grass.run_command("g.rename", raster=[mask_backup,"MASK"])
+        grass.info("Note, the original mask was restored")
+    grass.info("Done....")
+    if flag_r:
+        grass.info("Original region is restored")
+    else:
+        grass.info("Region is set to match the projected/test layers")
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.exdet/r.exdet.py
Added: svn:executable
   + text/x-python
   + native
