[GRASS-SVN] r64756 - grass-addons/grass7/raster/r.flexure
Thu Feb 26 13:11:53 PST 2015
Author: awickert
Date: 2015-02-26 13:11:53 -0800 (Thu, 26 Feb 2015)
New Revision: 64756
   grass-addons/grass7/raster/r.flexure/r.flexure.html
   grass-addons/grass7/raster/r.flexure/r.flexure.py
Modernize GRASS parser interface
Modified: grass-addons/grass7/raster/r.flexure/r.flexure.html
--- grass-addons/grass7/raster/r.flexure/r.flexure.html	2015-02-26 20:46:48 UTC (rev 64755)
+++ grass-addons/grass7/raster/r.flexure/r.flexure.html	2015-02-26 21:11:53 UTC (rev 64756)
@@ -11,7 +11,7 @@
 The flexural solution is generated for the current computational region, so be sure to check <em>g.region</em> before running the model!
 <p>
 <!--Add equation or a link to paper, etc.-->
-<b>q0</b> is a 2-D array of loads in a GRASS raster. These are in units of stress, and equal the density of the material times the acceleration due to gravity times the thickness of the column. This is not affected by what you choose for <b>g</b>, later: it is pre-calculated by the user.
+<b>input</b> is a 2-D array of loads in a GRASS raster. These are in units of stress, and equal the density of the material times the acceleration due to gravity times the thickness of the column. This is not affected by what you choose for <b>g</b>, later: it is pre-calculated by the user.
 <p>
 <b>te</b>, written in standard text as T<sub>e</sub> is the lithospheric elastic thickness.
 <p>
Modified: grass-addons/grass7/raster/r.flexure/r.flexure.py
--- grass-addons/grass7/raster/r.flexure/r.flexure.py	2015-02-26 20:46:48 UTC (rev 64755)
+++ grass-addons/grass7/raster/r.flexure/r.flexure.py	2015-02-26 21:11:53 UTC (rev 64756)
@@ -32,10 +32,12 @@
 #% keyword: raster
 #% keyword: geophysics
 #%end
 #%flag
 #%  key: l
 #%  description: Allows running in lat/lon: dx is f(lat) at grid N-S midpoint
 #%end
 #%option
 #%  key: method
 #%  type: string
@@ -43,20 +45,21 @@
 #%  options: FD, SAS
 #%  required : yes
 #%end
-#%option
-#%  key: q0
+#%option G_OPT_R_INPUT
+#%  key: input
 #%  type: string
-#%  gisprompt: old,cell,raster
 #%  description: Raster map of loads (thickness * density * g) [Pa]
 #%  required : yes
 #%end
-#%option
 #%  key: te
 #%  type: string
 #%  description: Elastic thicnkess: scalar or raster; unis chosen in "te_units"
 #%  required : yes
 #%end
 #%option
 #%  key: te_units
 #%  type: string
@@ -64,13 +67,14 @@
 #%  options: m, km
 #%  required : yes
 #%end
-#%option
+#%option G_OPT_R_OUTPUT
 #%  key: output
 #%  type: string
 #%  description: Output raster map of vertical deflections [m]
 #%  required : yes
 #%end
 #%option
 #%  key: solver
 #%  type: string
@@ -79,6 +83,7 @@
 #%  answer: direct
 #%  required : no
 #%end
 #%option
 #%  key: tolerance
 #%  type: double
@@ -86,6 +91,7 @@
 #%  answer: 1E-3
 #%  required : no
 #%end
 #%option
 #%  key: northbc
 #%  type: string
@@ -94,6 +100,7 @@
 #%  answer: NoOutsideLoads
 #%  required : no
 #%end
 #%option
 #%  key: southbc
 #%  type: string
@@ -102,6 +109,7 @@
 #%  required : no
 #%end
 #%option
 #%  key: westbc
 #%  type: string
@@ -110,6 +118,7 @@
 #%  required : no
 #%end
 #%option
 #%  key: eastbc
 #%  type: string
@@ -118,6 +127,7 @@
 #%  required : no
 #%end
 #%option
 #%  key: g
 #%  type: double
@@ -125,6 +135,7 @@
 #%  answer: 9.8
 #%  required : no
 #%end
 #%option
 #%  key: ym
 #%  type: double
@@ -132,6 +143,7 @@
 #%  answer: 65E9
 #%  required : no
 #%end
 #%option
 #%  key: nu
 #%  type: double
@@ -139,6 +151,7 @@
 #%  answer: 0.25
 #%  required : no
 #%end
 #%option
 #%  key: rho_fill
 #%  type: double
@@ -146,6 +159,7 @@
 #%  answer: 0
 #%  required : no
 #%end
 #%option
 #%  key: rho_m
 #%  type: double
@@ -210,7 +224,7 @@
         # It is the best.
         flex.PlateSolutionType = 'vWC1994'
     # Parameters that are often changed for the solution
-    qs = options['q0']
+    qs = options['input']
     flex.qs = garray.array()
     flex.qs.read(qs)
     # Elastic thickness
