[GRASS-SVN] r64765 - grass/branches/releasebranch_7_0/imagery/i.eb.soilheatflux
Fri Feb 27 03:04:43 PST 2015
Author: neteler
Date: 2015-02-27 03:04:43 -0800 (Fri, 27 Feb 2015)
New Revision: 64765
   grass/branches/releasebranch_7_0/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
i.eb.soilheatflux manual: more explanations about overpass time maps
Modified: grass/branches/releasebranch_7_0/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
--- grass/branches/releasebranch_7_0/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html	2015-02-27 11:03:54 UTC (rev 64764)
+++ grass/branches/releasebranch_7_0/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html	2015-02-27 11:04:43 UTC (rev 64765)
@@ -2,10 +2,40 @@
 <em>i.eb.soilheatflux</em> calculates the soil heat flux approximation (g0)
 after Bastiaanssen (1995). The main reference for implementation is Alexandridis, 2009.
 It takes input of Albedo, NDVI, Surface Skin temperature, Net Radiation (see
-<em>r.sun</em>), time of satellite overpass, and a flag for the Roerink empirical
-modification from the HAPEX-Sahel experiment.
+<em>r.sun</em>), time of satellite overpass, and a flag for the Roerink empirical modification from the HAPEX-Sahel experiment.
+The "time of satellite overpass" map can be obtained as follows:
+<ul>
+<li>MODIS: a related sub dataset is included in each HDF file, and simply
+    to be imported as a raster map;</li>
+<li>Landsat: to be generated as map from the overpass time stored in
+    the metadata file (given in Greenwich Mean Time - GMT), see below.</li>
+</ul>
+For Landsat, the overpass map can be computed by using a two-step method:
+<div class="code"><pre>
+# 1) extract the overpass time in GMT from metadata file
+i.landsat.toar -p input=dummy output=dummy2 \
+   metfile=LC81250452013338LGN00_MTL.txt lsatmet=time
+# ... in this example approx. 03:12am GMT
+# 2) create map for computational region of Landsat scene
+g.region rast=LC81250452013338LGN00_B4 -p
+r.mapcalc "overpasstime = 3.211328"
+</pre></div>
+<h2>EXAMPLE</h2>
+i.eb.soilheatflux ...
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
@@ -14,6 +44,7 @@
 <a href="i.emissivity.html">i.emissivity</a>,
 <a href="i.eb.hsebal01.html">i.eb.hsebal01</a>,
 <a href="i.eb.evapfr.html">i.eb.evapfr</a>
+<a href="i.landsat.toar.html">i.landsat.toar</a>
 </em>
 <h2>REFERENCES</h2>
