[GRASS-SVN] r63975 - grass-addons/grass7/display/d.vect.thematic2
Wed Jan 7 01:24:06 PST 2015
Author: martinl
Date: 2015-01-07 01:24:06 -0800 (Wed, 07 Jan 2015)
New Revision: 63975
Added:
   grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic2.html
   grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic2.py
Removed:
   grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.html
   grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.py
   grass-addons/grass7/display/d.vect.thematic2/Makefile
move d.vect.thematic to addons as d.vect.thematic2 (part 2)
Modified: grass-addons/grass7/display/d.vect.thematic2/Makefile
--- grass-addons/grass7/display/d.vect.thematic2/Makefile	2015-01-07 09:22:24 UTC (rev 63974)
+++ grass-addons/grass7/display/d.vect.thematic2/Makefile	2015-01-07 09:24:06 UTC (rev 63975)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM=d.vect.thematic
+PGM=d.vect.thematic2
 include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.html
--- grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.html	2015-01-07 09:22:24 UTC (rev 63974)
+++ grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.html	2015-01-07 09:24:06 UTC (rev 63975)
@@ -1,124 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>d.vect.thematic</em> creates thematic maps from vector features of
-all types and numeric attributes stored in the attribute table connected to a vector
-map.
-<p>
-Thematic maps can be displayed by either a <i>graduated color
-scheme</i> (for all vector types), as <i>graduated icon sizes</i> (for
-point and centroid types), or <i>graduated line widths</i> (for lines
-and boundaries with associated attributes), see <b>themetype</b>
-option for details. The user selects the vector <b>map</b> to be
-mapped and attribute <b>column</b> from which to derive mapping
-intervals, and (optionally) the <b>layer</b> for attribute data.
-<p>In thematic maps, the color or point size changes for each range of
-attribute values. Value ranges for thematic mapping can be set at
-<i>regular intervals</i>, <i>standard deviation</i> units on either side of the
-<i>mean</i>, <i>quartiles</i>, or delimited by <i>user-defined
-breakpoints</i>, see <b>themecalc</b> option.  User-defined
-breakpoints (<b>themecalc=custom_breaks</b>) can be entered
-via <b>breakpoints</b> option.
-<h2>NOTES</h2>
-<p>There is option <b>colorscheme</b> to define the color scheme
-(graduated colors) and range of point sizes (graduated points) for
-thematic maps.
-<p>
-Optionally, a simple text legend is printed when <b>-l</b> flag is
-given. A graphic legend can be drawn in the selected display monitor.
-<p>
-Thematic colors can be uploaded by <b>rgb_column</b> option
-to a specified attribute column (which is created automatically if
-doesn't exist in the table) for later display
-via <em><a href="d.vect.html">d.vect</a></em> and <b>rgb_column</b>
-option.
-<p>When the <b>psmap</b> option is set to 'name', two psmap instruction files are
-created (in the current directory if no path is given), one for the map
-('name.psmap') and one for the legend ('name_legend.psmap'). The map file also
-contains 'label' commands which allow to create a legend directly in the map by
-adding a 'vlegend' command. See the <em><a href="ps.map">ps.map</a></em> manual
-page for more details.
-<p>
-The algorithm currently uses the <em><a href="v.univar.html">v.univar</a></em> to calculate basic
-descriptive statistics needed for thematic mapping (minimum, maximum, mean,
-standard deviation, and quartiles).
-<h2>EXAMPLES</h2>
-Earthquake points with color gradient:
-<div class="code"><pre>
-d.vect.thematic -l recent_earthquakes column=magnitude type=point
-</pre></div>
-<p>Earthquake points with different sizes:
-d.vect.thematic -l recent_earthquakes column=magnitude type=point \
-                themetype=graduated_points maxsize=15
-</pre></div>
-<center>
-<img src="d_vect_thematic_equake.png"><br>
-Example for earthquake map rendering
-(<a href="https://trac.osgeo.org/grass/browser/grass-promo/tutorials/batch_processing/earthquakes">script code</a>)
-</center>
-<p>North Carolina: differences between 'elevation' (10m) and 'elev_state_500m':
-# random sampling of elevation points:
-g.region raster=elevation -p
-v.random random npoints=200
-v.db.addtable random column="el10 double precision"
-# transfer elevations to attribute table of random points map:
-v.what.rast random rast=elevation column=el10
-v.db.select random
-# comparative sampling of second map, incl. differences:
-v.sample input=random column=el10 raster=elev_state_500m output=elev_sample
-v.db.select elev_sample
-# univariate statistics:
-v.univar -e elev_sample column=diff type=point
-# thematic map:
-d.mon wx0
-d.vect.thematic -l elev_sample column=diff type=point
-</pre></div>
-<p>
-North Carolina sample dataset example:
-g.region vector=nc_state
-d.vect.thematic -l precip_30ynormals column=annual type=point
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="d.vect.html">d.vect</a>,
-<a href="d.vect.chart.html">d.vect.chart</a>,
-<a href="v.univar.html">v.univar</a>
-</em>
-<h2>AUTHORS</h2>
-Michael Barton, Arizona State University
-<p>
-Various updates by:<br>
-Daniel Cavelo Aros,<br>
-Martin Landa,<br>
-Jachym Cepicky.
-<p>
-  <i>Last changed: $Date: 2008-08-15 08:16:42 +0200 (Fri, 15 Aug 2008)$</i>
Deleted: grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.py
--- grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.py	2015-01-07 09:22:24 UTC (rev 63974)
+++ grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.py	2015-01-07 09:24:06 UTC (rev 63975)
@@ -1,1131 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       d.vect.thematic
-# AUTHOR(S):	Michael Barton, Arizona State University with contributions
-#               by Martin Landa, Jachym Cepicky, Daniel Calvelo Aros and Moritz Lennert
-# PURPOSE:	    Displays thematic vector map with graduated colors
-#               or graduated points and line thickneses
-# COPYRIGHT:	(C) 2006-2014 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
-#%module
-#% description: Displays thematic map created from vector features and numeric attributes.
-#% keyword: display
-#% keyword: cartography
-#% keyword: vector
-#% keyword: thematic
-#% keyword: legend
-#%end
-#%option G_OPT_V_MAP
-#%end
-#%option G_OPT_V_FIELD
-#%end
-#%option G_OPT_DB_COLUMN
-#% description: Name of attribute column to use for thematic display (must be numeric)
-#% required: yes
-#%end
-#%option G_OPT_V_TYPE
-#%answer: point,line,area
-#%end
-#%option G_OPT_DB_WHERE
-#% guisection: Theme
-#%end
-#%option
-#% key: themetype
-#% type: string
-#% options: graduated_colors,graduated_points,graduated_lines
-#% answer: graduated_colors
-#% description: Type of thematic display
-#% required: yes
-#%end
-#%option
-#% key: themecalc
-#% type: string
-#% options: interval,std_deviation,quartiles,custom_breaks
-#% answer: interval
-#% description: Thematic divisions of data for display
-#% required: yes
-#%end
-#%option
-#% key: breakpoints
-#% type: string
-#% label: Break points for custom breaks option
-#% description: Separate values by spaces (0 10 20 30 ...)
-#% required: no
-#%end
-#%option
-#% key: icon
-#% type: string
-#% description: Vector point icon for point data
-#% options: basic/box,basic/circle,basic/cross2,basic/diamond,basic/star,basic/cross1,basic/x
-#% answer: basic/circle
-#% required: no
-#% guisection: Points
-#%end
-#%option
-#% key: size
-#% type: double
-#% label: Icon size for point data
-#% description: Minimum icon size/line width for graduated points/lines)
-#% answer: 5
-#% required: no
-#%end
-#%option
-#% key: maxsize
-#% type: double
-#% description: Maximum icon size/line width for graduated points and lines
-#% answer: 20
-#% required: no
-#%end
-#%option
-#% key: nint
-#% type: integer
-#% description: Number of classes for interval theme (integer)
-#% answer: 4
-#% required: no
-#%end
-#%option
-#% key: colorscheme
-#% type: string
-#% label: Color scheme for graduated color mapping
-#% description: Select 'single_color' for graduated point/line display
-#% options: blue-red,red-blue,green-red,red-green,blue-green,green-blue,cyan-yellow,yellow-cyan,custom_gradient,single_color
-#% answer: blue-red
-#% required: yes
-#% guisection: Color
-#%end
-#% option
-#% key: point_color
-#% type: string
-#% label: Color for graduated points map
-#% description: GRASS named color or R:G:B triplet. Set color scheme to single color
-#% answer: 255:0:0
-#% required: no
-#%end
-#% option
-#% key: line_color
-#% type: string
-#% label: Color for graduated lines or point/area outlines
-#% description: GRASS named color or R:G:B triplet. Set color scheme to single color.
-#% answer: 0:0:0
-#% required: no
-#%end
-#% option
-#% key: start_color
-#% type: string
-#% label: Beginning color for custom color gradient
-#% description: Must be expressed as R:G:B triplet
-#% answer: 255:0:0
-#% required: no
-#%end
-#% option
-#% key: end_color
-#% type: string
-#% label: Ending color for custom color gradient
-#% answer: 0:0:255
-#% required: no
-#%end
-#% option
-#% key: monitor
-#% type: string
-#% description: Select WXGUI display monitor for legend
-#% options: wx0,wx1,wx2,wx3,wx4,wx5,wx6,none
-#% answer: wx1
-#% required: no
-#% guisection: Misc
-#%end
-#%flag
-#% guisection: Files
-#% key: g
-#%description: Save thematic map commands to group file for GIS Manager
-#%end
-#%option
-#% key: psmap
-#% type: string
-#% label: Root for the name of psmap instruction files to be in current directory
-#% description: If not set, no psmap instruction files will be created)
-#% required: no
-#%end
-#%option G_OPT_I_GROUP
-#% description: Name of group file where thematic map commands will be saved
-#% required: no
-#%end
-#% key: rgb_column
-#% description: Name of color column to populate RGB values
-#%end
-#%flag
-#%key: l
-#%description: Create graphic legend in x11 display monitor
-#%end
-#%flag
-#% key: f
-#% description: Only draw fills (no outlines) for areas and points
-#%end
-#%flag
-#%key: s
-#%description: Output legend for GIS Manager (for scripting use only)
-#%end
-#%flag
-#%key: m
-#%description: Use math notation brackets in legend
-#%end
-import sys
-import os
-import string
-import shutil
-import atexit
-import grass.script as grass
-tmp_graph = None
-tmp_group = None
-tmp_psmap = None
-tmp_psleg = None
-tmp_gisleg = None
-def cleanup():
-    for file in [tmp_graph, tmp_group, tmp_psmap, tmp_psleg, tmp_gisleg]:
-	if file:
-	    grass.try_remove(file)
-# hard-coded parameter: the maximum number of legend items before
-# we strip them using a middle ellipsis
-max_leg_items = 18
-def subs(vars, tmpl):
-    return string.Template(tmpl).substitute(vars)
-def msg(vars, tmpl, verbose=False):
-    if not verbose:
-        grass.message(subs(vars, tmpl))
-    else:
-        grass.verbose(subs(vars, tmpl))
-def out(fh, vars, tmpl):
-    fh.write(subs(vars, tmpl))
-def main():
-    global tmp_graph, tmp_group, tmp_psmap, tmp_psleg, tmp_gisleg
-    breakpoints = options['breakpoints']
-    colorscheme = options['colorscheme']
-    column = options['column']
-    endcolor = options['end_color']
-    group = options['group']
-    layer = options['layer']
-    linecolor = options['line_color']
-    map = options['map']
-    maxsize = options['maxsize']
-    monitor = options['monitor']
-    nint = options['nint']
-    pointcolor = options['point_color']
-    psmap = options['psmap']
-    size = options['size']
-    startcolor = options['start_color']
-    themecalc = options['themecalc']
-    themetype = options['themetype']
-    type = options['type']
-    where = options['where']
-    icon = options['icon']
-    rgb_column = options['rgb_column']
-    flag_f = flags['f']
-    flag_g = flags['g']
-    flag_l = flags['l']
-    flag_m = flags['m']
-    flag_s = flags['s']
-    layer = int(layer)
-    nint = int(nint)
-    size = float(size)
-    maxsize = float(maxsize)
-    if 'MONITOR' not in grass.gisenv().keys() and \
-       'GRASS_RENDER_IMMEDIATE' not in os.environ:
-       grass.fatal(_("Neither MONITOR (managed by d.mon command) nor GRASS_RENDER_IMMEDIATE "
-                     "(used for direct rendering) defined)"))
-    mapset = grass.find_file(map, element='vector')['mapset']
-    if not mapset:
-        grass.fatal(_("Vector map <%s> not found") % map)
-    if rgb_column and mapset != grass.gisenv()['MAPSET']:
-        grass.warning(_("Vector map <%s> not found in the current mapset. "
-                        "Updating RGB values <%s> skipped.") % (map, "rgb_column"))
-        rgb_column = None
-    # check column type
-    inf = grass.vector_columns(map, layer)
-    if column not in inf:
-	grass.fatal(_("No such column <%s>") % column)
-    coltype = inf[column]['type'].lower()
-    if coltype not in ["integer", "double precision"]:
-	grass.fatal(_("Column <%s> is of type <%s> which is not numeric.") % (column, coltype))
-    # create temporary file to hold d.graph commands for legend
-    tmp_graph = grass.tempfile()
-    # Create temporary file to commands for GIS Manager group
-    tmp_group = grass.tempfile()
-    # Create temporary file for commands for ps.map map file
-    tmp_psmap = grass.tempfile()
-    # Create temporary file for commands for ps.map legend file
-    tmp_psleg = grass.tempfile()
-    # create file to hold elements for GIS Manager legend
-    tmp_gisleg = grass.tempfile()
-    # Set display variables for group
-    atype = int(type == "area")
-    ptype = int(type == "point")
-    ctype = int(type == "centroid")
-    ltype = int(type == "line")
-    btype = int(type == "boundary")
-    # if running in the GUI, do not create a graphic legend in an xmon
-    if flag_s:
-        flag_l = False
-        # if running in GUI, turn off immediate mode rendering so that the
-        # iterated d.vect commands will composite using the display driver
-        os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
-        os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
-    db = grass.vector_db(map)[1]
-    if not db or not db['table']:
-        grass.fatal(_("No table connected or layer <%s> does not exist.") % layer)
-    table = db['table']
-    database = db['database']
-    driver = db['driver']
-    # update color values to the table?
-    if rgb_column:
-        # test, if the rgb column is in the table
-        s = grass.read_command('db.columns', table = table, database = database, driver = driver)
-        if rgb_column not in s.splitlines():
-            msg(locals(), _("Creating column <$rgb_column> in table <$table>"))
-            sql = "ALTER TABLE %s ADD COLUMN %s varchar(11)" % (table, rgb_column)
-            grass.write_command('db.execute', database = database, driver = driver, input = '-', stdin = sql)
-    # Group name
-    if not group:
-        group = "themes"
-    f_group = file(tmp_group, 'w')
-    f_group.write("Group %s\n" % group)
-    # Calculate statistics for thematic intervals
-    if type == "line":
-        stype = "line"
-    else:
-        stype = ["point", "centroid"]
-    grass.message(_("Calculating statistics..."))
-    stats = grass.read_command('v.univar', flags = 'eg', map = map, type = stype, column = column, where = where, layer = layer)
-    if not stats:
-        grass.fatal(_("Unable to calculate statistics for vector map <%s>" % map))
-    stats = grass.parse_key_val(stats)
-    if 'min' not in stats:
-        grass.fatal(_("Unable to calculate statistics for vector map <%s> "
-                      "(missing minimum/maximum value)" % map))
-    min  = float(stats['min'])
-    max  = float(stats['max'])
-    mean = float(stats['mean'])
-    sd   = float(stats['population_stddev'])
-    q1   = float(stats['first_quartile'])
-    q2   = float(stats['median'])
-    q3   = float(stats['third_quartile'])
-    q4   = max
-    ptsize = size
-    if breakpoints and themecalc != "custom_breaks":
-        grass.warning(_("Custom breakpoints ignored due to themecalc setting."))
-    # set interval for each thematic map calculation type
-    if themecalc == "interval":
-        numint = nint
-        step = float(max - min) / numint
-        breakpoints = [min + i * step for i in xrange(numint + 1)]
-        annotations = ""
-    elif themecalc == "std_deviation":
-        # 2 standard deviation units on either side of mean,
-        # plus min to -2 sd units and +2 sd units to max, if applicable
-        breakpoints = [min] + [i for i in [(mean + i * sd) for i in [-2,-1,0,1,2]] if min < i < max] + [max]
-        annotations = [""] + [("%dsd" % i) for (i, j) in [(i, mean + i * sd) for i in [-2,-1,0,1,2]] if (min < j < max)] + [""]
-        annotations = ";".join(annotations)
-        numint = len(breakpoints) - 1
-    elif themecalc == "quartiles":
-        numint=4
-        # one for each quartile
-        breakpoints = [min, q1, q2, q3, max]
-        annotations = " %f; %f; %f; %f" % (q1, q2, q3, q4)
-    elif themecalc == "custom_breaks":
-        if not breakpoints:
-            grass.fatal(_("Required parameter <%s> not set") % "breakpoints")
-        breakpoints = [int(x) for x in breakpoints.split()]
-        annotations = ""
-    else:
-        grass.fatal(_("Unknown themecalc type <%s>") % themecalc)
-    pointstep = (maxsize - ptsize) / (numint - 1)
-    # Prepare legend cuts for too large numint
-    if numint > max_leg_items:
-        xupper = int(numint - max_leg_items / 2) + 1
-        xlower = int(max_leg_items / 2) + 1
-    else:
-        xupper = 0
-        xlower = 0
-    # legend title
-    f_graph = file(tmp_graph, 'w')
-    out(f_graph, locals(), """\
-color 0:0:0
-size 2 2
-move 1 95
-text Thematic map legend for column $column of map $map
-size 1.5 1.8
-move 4 90
-text Value range: $min - $max
-    f_gisleg = file(tmp_gisleg, 'w')
-    out(f_gisleg, locals(), """\
-title - - - {Thematic map legend for column $column of map $map}
-    f_psleg = file(tmp_psleg, 'w')
-    out(f_psleg, locals(), """\
-text 1% 95% Thematic map legend for column $column of map $map
-  ref bottom left
-end
-text 4% 90% Value range: $min - $max
-  ref bottom left
-end
-    msg(locals(), _("Thematic map legend for column <$column> of map <$map>"), verbose=True)
-    msg(locals(), _("Value range: $min - $max"))
-    colorschemes = {
-        "blue-red":		("0:0:255",	"255:0:0"),
-        "red-blue":		("255:0:0",	"0:0:255"),
-        "green-red":	("0:255:0",	"255:0:0"),
-        "red-green":	("255:0:0",	"0:255:0"),
-        "blue-green":	("0:0:255",	"0:255:0"),
-        "green-blue":	("0:255:0",	"0:0:255"),
-        "cyan-yellow":	("0:255:255",	"255:255:0"),
-        "yellow-cyan":	("255:255:0",	"0:255:255"),
-        "custom_gradient":	(startcolor,	endcolor)
-    # open file for psmap instructions
-    f_psmap = file(tmp_psmap, 'w')
-    # graduated color thematic mapping
-    if themetype == "graduated_colors":
-        if colorscheme in colorschemes:
-            startc, endc = colorschemes[colorscheme]
-        # set color schemes for graduated color maps
-        elif colorscheme == "single_color":
-            if themetype == "graduated_points":
-                startc = endc = linecolor
-            else:
-                startc = endc = pointcolor
-        else:
-            grass.fatal(_("This should not happen: parser error. Unknown color scheme %s") % colorscheme)
-        color = __builtins__.map(int, startc.split(":"))
-        endcolor = __builtins__.map(int, endc.split(":"))
-        #The number of color steps is one less then the number of classes
-        nclrstep = numint - 1
-        clrstep = [(a - b) / nclrstep for a, b in zip(color, endcolor)]
-        themecolor = startc
-        # display graduated color themes
-move 4 87
-text Mapped by $numint intervals of $step
-subtitle - - - {Mapped by $numint intervals of $step}
-text 4% 87% Mapped by $numint intervals of $step
-  ref bottom left
-end
-            msg(locals(), _("Mapped by $numint intervals of $step"))
-        # display graduated color themes for standard deviation units
-        if themecalc == "std_deviation":
-move 4 87
-text Mapped by standard deviation units of $sd (mean = $mean)
-subtitle - - - {Mapped by standard deviation units of $sd (mean = $mean)}
-text 4% 87% Mapped by standard deviation units of $sd (mean = $mean)
-  ref bottom left
-end
-            msg(locals(), _("Mapped by standard deviation units of $sd (mean = $mean)"))
-        # display graduated color themes for quartiles
-        if themecalc == "quartiles":
-move 4 87
-text Mapped by quartiles (median = $q2)
-subtitle - - - {Mapped by quartiles (median = $q2)}
-text 4% 87% Mapped by quartiles (median = $q2)
-  ref bottom left
-end
-            msg(locals(), _("Mapped by quartiles (median = $q2)"))
-        f_graph.write("""\
-move 4 83
-text Color
-move 14 83
-text Value
-move 4 80
-text =====
-move 14 80
-text ============
-        f_psleg.write("""\
-text 4% 83% Color
-  ref bottom left
-end
-text 14% 83% Value
-  ref bottom left
-end
-text 4% 80% =====
-  ref bottom left
-end
-text 14% 80% ============
-  ref bottom left
-end
-        grass.message("")
-        grass.message(_("Color(R:G:B)\tValue"))
-        grass.message("============\t==========")
-        line1 = 78
-        line2 = 76
-        line3 = 75
-        i = 0
-        first = True
-        while i < numint:
-            if flag_m:
-                # math notation
-                if first:
-                    closebracket = "]"
-                    openbracket = "["
-                    mincomparison = ">="
-                    first = False
-                else:
-                    openbracket = "["
-                    mincomparison = ">"
-            else:
-                closebracket = ""
-                openbracket = ""
-                if first:
-                    first = False
-                else:
-            themecolor = ":".join(__builtins__.map(str,color))
-            if flag_f:
-                linecolor = "none"
-            else:
-                if type in ["line", "boundary"]:
-                    linecolor = themecolor
-                else:
-                    linecolor = linecolor
-            ### rangemin = __builtins__.min(breakpoints)
-            ### rangemax = __builtins__.max(breakpoints)
-            rangemin = breakpoints[i]
-            rangemax = breakpoints[i+1]
-            if not annotations:
-                extranote = ""
-            else:
-                extranote = annotations[i]
-            if i < xlower or i >= xupper:
-                xline1 = line2 + 2
-                xline3 = line2 - 1
-color $themecolor
-polygon
-5 $xline1
-8 $xline1
-8 $xline3
-5 $xline3
-color $linecolor
-move 5 $xline1
-draw 8 $xline1
-draw 8 $xline3
-draw 5 $xline3
-draw 5 $xline1
-move 14 $line2
-color 0:0:0
-text $openbracket$rangemin - $rangemax$closebracket $extranote
-            else:
-                if i == xlower:
-color 0:0:0
-move 10 $line2
-text ...
-                else:
-                    #undo next increment
-                    line2 += 4
-area $themecolor $linecolor - {$openbracket$rangemin - $rangemax$closebracket $extranote}
-line 5% $xline1% 8% $xline1%
-  color $linecolor
-end
-text 14% $xline1% $openbracket$rangemin - $rangemax$closebracket $extranote
-  ref center left
-end
-                elif type in ["point", "centroid"]:
-point 8% $xline1%
-  color $linecolor
-  fcolor $themecolor
-  size $size
-  symbol $icon
-end
-  ref center left
-end
-                else:
-rectangle 5% $xline1% 8% $xline3%
-  color 0:0:0
-end
-text 14% $xline3% $openbracket$rangemin - $rangemax$closebracket DCADCA $extranote
-  ref bottom left
-end
-            else:
-                if i == xlower:
-color 0:0:0
-text 14% $xline3% ...
-  ref bottom left
-end
-                f_gisleg.write("text - - - {...}\n")
-            grass.message("%-15s %s%.3f - %.3f%s %s" % (themecolor, openbracket, rangemin, rangemax, closebracket, extranote))
-            if not where:
-                sqlwhere = subs(locals(), "$column $mincomparison $rangemin AND $column <= $rangemax")
-            else:
-                sqlwhere = subs(locals(), "$column $mincomparison $rangemin AND $column <= $rangemax AND $where")
-            # update color to database?
-            if rgb_column:
-                sql = subs(locals(), "UPDATE $table SET $rgb_column = '$themecolor' WHERE $sqlwhere")
-            # Create group for GIS Manager
-            if flag_g:
-                # change rgb colors to hex
-                xthemecolor = "#%02X%02X%02X" % tuple(__builtins__.map(int, themecolor.split(":")))
-                #xlinecolor=`echo $linecolor | awk -F: '{printf("#%02X%02X%02X\n",$1,$2,$3)}'`
-                if "$linecolor" == "black":
-                    xlinecolor = "#000000"
-                else:
-                    xlinecolor = xthemecolor
-                # create group entry
-                out(f_group, locals(), """\
-  _check 1
-  Vector $column = $rangemin - $rangemax
-    _check 1
-    map $map
-    display_shape 1
-    display_cat 0
-    display_topo 0
-    display_dir 0
-    display_attr 0
-    type_point $ptype
-    type_line $ltype
-    type_boundary $btype
-    type_centroid $ctype
-    type_area $atype
-    type_face 0
-    color $xlinecolor
-    fcolor $xthemecolor
-    width $ptsize
-    _use_fcolor 1
-    lcolor #000000
-    sqlcolor 0
-    icon $icon
-    size $ptsize
-    field $layer
-    lfield $layer
-    attribute
-    xref left
-    yref center
-    lsize 8
-    cat
-    where $sqlwhere
-    _query_text 0
-    _query_edit 1
-    _use_where 1
-    minreg
-    maxreg
-    _width 0.1
-  End
-            # display theme vector map
-            grass.run_command('d.vect', map = map, type = type, layer = layer,
-                              where = sqlwhere,
-                              color = linecolor, fcolor = themecolor, icon = icon, size = ptsize,
-                              quiet = True)
-                out(f_psmap, locals(), """\
-vlines $map
-  type $type
-  layer $layer
-  where $sqlwhere
-  color $linecolor
-  label $rangemin - $rangemax
-end
-vpoints $map
-  type $type
-  layer $layer
-  where $sqlwhere
-  color $linecolor
-  symbol $icon
-end
-            else:
-vareas $map
-  layer $layer
-  where $sqlwhere
-  color $linecolor
-end
-            # increment for next theme
-            i += 1
-            if i == numint:
-                color = endcolor
-            else:
-                color = [__builtins__.min(a - b, 255) for a, b in zip(color, clrstep)]
-            line1 -= 4
-            line2 -= 4
-            line3 -= 4
-    #graduated points and line widths thematic mapping
-    if themetype in ["graduated_points", "graduated_lines"]:
-        #display graduated points/lines by intervals
-move 4 87
-  ref bottom left
-end
-        # display graduated points/lines for standard deviation units
-move 4 87
-  ref bottom left
-end
-        # display graduated points/lines for quartiles
-move 4 87
-  ref bottom left
-end
-        line1 = 76
-        line2 = 75
-move 4 83
-text Size/width
-move 25 83
-text Value
-move 4 80
-text ==============
-move 25 80
-text 4% 83% Icon size
-  ref bottom left
-end
-text 25% 83% Value
-  ref bottom left
-end
-text 4% 80% ============
-  ref bottom left
-end
-text 25% 80% ============
-  ref bottom left
-end
-        grass.message("")
-        grass.message(_("Size/width\tValue"))
-        grass.message("==========\t=====")
-        themecolor = pointcolor
-        if flag_f:
-        i = numint
-        ptsize = maxsize
-        while i >= 1:
-            if flag_m:
-                # math notation
-                if i == 1:
-                    openbracket = "["
-                else:
-                    openbracket = "]"
-            else:
-                closebracket = ""
-                openbracket = ""
-                if i == 1:
-                else:
-            if flag_f:
-            rangemin = breakpoints[i-1]
-            rangemax = breakpoints[i]
-                extranote = ""
-            else:
-            iconsize = int(ptsize / 2)
-            lineht = int(ptsize / 4)
-            if lineht < 4:
-                lineht = 4
-                if themetype == "graduated_lines":
-color $linecolor
-line $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}
-                else:
-color $themecolor
-point $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}
-icon + $iconsize 5 $line1
-color 0:0:0
-move 10 $line2
-text $ptsize pts
-move 25 $line2
-            else:
-                if i == xlower:
-color 0:0:0
-move 10 $line2
-text ...
-text - - - ...
-                else:
-                    # undo future line increment
-                    line2 += lineht
-point 8% $line1%
-  color $linecolor
-  size $iconsize
-  symbol $icon
-end
-text 25% $line1% $openbracket$rangemin - $rangemax$closebracket $extranote
-  ref center left
-end
-            else:
-                if i == xlower:
-text 25% $xline1% ...
-   ref center left
-end
-            grass.message("%-15d %s%.3f - %.3f%s %s" % \
-                          (ptsize, openbracket, rangemin, rangemax, closebracket, extranote))
-            if not where:
-            else:
-            if rgb_column:
-            if flag_g:
-                xthemecolor = "#%02X%02X%02X" % tuple(__builtins__.map(int,themecolor.split(":")))
-  _check 1
-    _check 1
-    map $map
-    display_shape 1
-    display_cat 0
-    display_topo 0
-    display_dir 0
-    display_attr 0
-    type_point $ptype
-    type_line $ltype
-    type_area $atype
-    type_face 0
-    color $xlinecolor
-    width $ptsize
-    _use_fcolor 1
-    lcolor #000000
-    sqlcolor 0
-    icon $icon
-    size $ptsize
-    field $layer
-    lfield $layer
-    attribute
-    xref left
-    yref center
-    lsize 8
-    cat
-    where $sqlwhere
-    _query_text 0
-    _query_edit 1
-    _use_where 1
-    minreg
-    maxreg
-    _width 0.1
-  End
-            #graduates line widths or point sizes
-            kwargs = {}
-                kwargs['width'] = ptsize
-                              where = sqlwhere,
-                              size = ptsize, quiet = True, **kwargs)
-            if themetype != "graduated_lines":
-vpoints $map
-  type $type
-  layer $layer
-  where $sqlwhere
-  color $linecolor
-  symbol $icon
-  size $ptsize
-end
-            ptsize -= pointstep
-            line1 -= lineht
-            line2 -= lineht
-            i -= 1
-    # Create graphic legend
-    f_graph.close()
-    if flag_l:
-        grass.run_command('d.erase')
-        grass.run_command('d.graph', input = tmp_graph)
-    # Create group file for GIS Manager
-    f_group.write("End\n")
-    f_group.close()
-    if flag_g:
-        shutil.copyfile(tmp_group, "%s.dm" % group)
-    # Create ps.map map file
-    f_psmap.write("end\n")
-    f_psmap.close()
-    if psmap:
-        shutil.copyfile(tmp_psmap, "%s.psmap" % psmap)
-    # Create ps.map legend file
-    f_psleg.write("end\n")
-    f_psleg.close()
-    if psmap:
-        shutil.copyfile(tmp_psleg, "%s_legend.psmap" % psmap)
-    # Create text file to use with d.graph in GIS Manager
-    f_gisleg.close()
-    if flag_s:
-        tmpdir = os.path.dirname(tmp_gisleg)
-        tlegfile = os.path.join(tmpdir, "gismlegend.txt")
-        shutil.copyfile(tmp_gisleg, tlegfile)
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    atexit.register(cleanup)
-    main()
Copied: grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic2.html (from rev 63974, grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.html)
--- grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic2.html	                        (rev 0)
+++ grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic2.html	2015-01-07 09:24:06 UTC (rev 63975)
@@ -0,0 +1,124 @@
+<h2>DESCRIPTION</h2>
+<em>d.vect.thematic2</em> creates thematic maps from vector features of
+all types and numeric attributes stored in the attribute table connected to a vector
+map.
+<p>
+Thematic maps can be displayed by either a <i>graduated color
+scheme</i> (for all vector types), as <i>graduated icon sizes</i> (for
+point and centroid types), or <i>graduated line widths</i> (for lines
+and boundaries with associated attributes), see <b>themetype</b>
+option for details. The user selects the vector <b>map</b> to be
+mapped and attribute <b>column</b> from which to derive mapping
+intervals, and (optionally) the <b>layer</b> for attribute data.
+<p>In thematic maps, the color or point size changes for each range of
+attribute values. Value ranges for thematic mapping can be set at
+<i>regular intervals</i>, <i>standard deviation</i> units on either side of the
+<i>mean</i>, <i>quartiles</i>, or delimited by <i>user-defined
+breakpoints</i>, see <b>themecalc</b> option.  User-defined
+breakpoints (<b>themecalc=custom_breaks</b>) can be entered
+via <b>breakpoints</b> option.
+<h2>NOTES</h2>
+<p>There is option <b>colorscheme</b> to define the color scheme
+(graduated colors) and range of point sizes (graduated points) for
+thematic maps.
+<p>
+Optionally, a simple text legend is printed when <b>-l</b> flag is
+given. A graphic legend can be drawn in the selected display monitor.
+<p>
+Thematic colors can be uploaded by <b>rgb_column</b> option
+to a specified attribute column (which is created automatically if
+doesn't exist in the table) for later display
+via <em><a href="d.vect.html">d.vect</a></em> and <b>rgb_column</b>
+option.
+<p>When the <b>psmap</b> option is set to 'name', two psmap instruction files are
+created (in the current directory if no path is given), one for the map
+('name.psmap') and one for the legend ('name_legend.psmap'). The map file also
+contains 'label' commands which allow to create a legend directly in the map by
+adding a 'vlegend' command. See the <em><a href="ps.map">ps.map</a></em> manual
+page for more details.
+<p>
+The algorithm currently uses the <em><a href="v.univar.html">v.univar</a></em> to calculate basic
+descriptive statistics needed for thematic mapping (minimum, maximum, mean,
+standard deviation, and quartiles).
+<h2>EXAMPLES</h2>
+Earthquake points with color gradient:
+<div class="code"><pre>
+d.vect.thematic2 -l recent_earthquakes column=magnitude type=point
+</pre></div>
+<p>Earthquake points with different sizes:
+d.vect.thematic2 -l recent_earthquakes column=magnitude type=point \
+                themetype=graduated_points maxsize=15
+</pre></div>
+<center>
+<img src="d_vect_thematic_equake.png"><br>
+Example for earthquake map rendering
+(<a href="https://trac.osgeo.org/grass/browser/grass-promo/tutorials/batch_processing/earthquakes">script code</a>)
+</center>
+<p>North Carolina: differences between 'elevation' (10m) and 'elev_state_500m':
+# random sampling of elevation points:
+g.region raster=elevation -p
+v.random random npoints=200
+v.db.addtable random column="el10 double precision"
+# transfer elevations to attribute table of random points map:
+v.what.rast random rast=elevation column=el10
+v.db.select random
+# comparative sampling of second map, incl. differences:
+v.sample input=random column=el10 raster=elev_state_500m output=elev_sample
+v.db.select elev_sample
+# univariate statistics:
+v.univar -e elev_sample column=diff type=point
+# thematic map:
+d.mon wx0
+d.vect.thematic2 -l elev_sample column=diff type=point
+</pre></div>
+<p>
+North Carolina sample dataset example:
+g.region vector=nc_state
+d.vect.thematic2 -l precip_30ynormals column=annual type=point
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="d.vect.html">d.vect</a>,
+<a href="d.vect.chart.html">d.vect.chart</a>,
+<a href="v.univar.html">v.univar</a>
+</em>
+<h2>AUTHORS</h2>
+Michael Barton, Arizona State University
+<p>
+Various updates by:<br>
+Daniel Cavelo Aros,<br>
+Martin Landa,<br>
+Jachym Cepicky.
+<p>
+  <i>Last changed: $Date: 2008-08-15 08:16:42 +0200 (Fri, 15 Aug 2008)$</i>
Copied: grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic2.py (from rev 63974, grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic.py)
--- grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic2.py	                        (rev 0)
+++ grass-addons/grass7/display/d.vect.thematic2/d.vect.thematic2.py	2015-01-07 09:24:06 UTC (rev 63975)
@@ -0,0 +1,1131 @@
+#!/usr/bin/env python
+# MODULE:       d.vect.thematic2
+# AUTHOR(S):	Michael Barton, Arizona State University with contributions
+#               by Martin Landa, Jachym Cepicky, Daniel Calvelo Aros and Moritz Lennert
+# PURPOSE:	    Displays thematic vector map with graduated colors
+#               or graduated points and line thickneses
+# COPYRIGHT:	(C) 2006-2014 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%module
+#% description: Displays thematic map created from vector features and numeric attributes.
+#% keyword: display
+#% keyword: cartography
+#% keyword: vector
+#% keyword: thematic
+#% keyword: legend
+#%end
+#%option G_OPT_V_MAP
+#%end
+#%option G_OPT_V_FIELD
+#%end
+#%option G_OPT_DB_COLUMN
+#% description: Name of attribute column to use for thematic display (must be numeric)
+#% required: yes
+#%end
+#%option G_OPT_V_TYPE
+#%answer: point,line,area
+#%end
+#%option G_OPT_DB_WHERE
+#% guisection: Theme
+#%end
+#%option
+#% key: themetype
+#% type: string
+#% options: graduated_colors,graduated_points,graduated_lines
+#% answer: graduated_colors
+#% description: Type of thematic display
+#% required: yes
+#%end
+#%option
+#% key: themecalc
+#% type: string
+#% options: interval,std_deviation,quartiles,custom_breaks
+#% answer: interval
+#% description: Thematic divisions of data for display
+#% required: yes
+#%end
+#%option
+#% key: breakpoints
+#% type: string
+#% label: Break points for custom breaks option
+#% description: Separate values by spaces (0 10 20 30 ...)
+#% required: no
+#%end
+#%option
+#% key: icon
+#% type: string
+#% description: Vector point icon for point data
+#% options: basic/box,basic/circle,basic/cross2,basic/diamond,basic/star,basic/cross1,basic/x
+#% answer: basic/circle
+#% required: no
+#% guisection: Points
+#%end
+#%option
+#% key: size
+#% type: double
+#% label: Icon size for point data
+#% description: Minimum icon size/line width for graduated points/lines)
+#% answer: 5
+#% required: no
+#%end
+#%option
+#% key: maxsize
+#% type: double
+#% description: Maximum icon size/line width for graduated points and lines
+#% answer: 20
+#% required: no
+#%end
+#%option
+#% key: nint
+#% type: integer
+#% description: Number of classes for interval theme (integer)
+#% answer: 4
+#% required: no
+#%end
+#%option
+#% key: colorscheme
+#% type: string
+#% label: Color scheme for graduated color mapping
+#% description: Select 'single_color' for graduated point/line display
+#% options: blue-red,red-blue,green-red,red-green,blue-green,green-blue,cyan-yellow,yellow-cyan,custom_gradient,single_color
+#% answer: blue-red
+#% required: yes
+#% guisection: Color
+#%end
+#% option
+#% key: point_color
+#% type: string
+#% label: Color for graduated points map
+#% description: GRASS named color or R:G:B triplet. Set color scheme to single color
+#% answer: 255:0:0
+#% required: no
+#%end
+#% option
+#% key: line_color
+#% type: string
+#% label: Color for graduated lines or point/area outlines
+#% description: GRASS named color or R:G:B triplet. Set color scheme to single color.
+#% answer: 0:0:0
+#% required: no
+#%end
+#% option
+#% key: start_color
+#% type: string
+#% label: Beginning color for custom color gradient
+#% description: Must be expressed as R:G:B triplet
+#% answer: 255:0:0
+#% required: no
+#%end
+#% option
+#% key: end_color
+#% type: string
+#% label: Ending color for custom color gradient
+#% answer: 0:0:255
+#% required: no
+#%end
+#% option
+#% key: monitor
+#% type: string
+#% description: Select WXGUI display monitor for legend
+#% options: wx0,wx1,wx2,wx3,wx4,wx5,wx6,none
+#% answer: wx1
+#% required: no
+#% guisection: Misc
+#%end
+#%flag
+#% guisection: Files
+#% key: g
+#%description: Save thematic map commands to group file for GIS Manager
+#%end
+#%option
+#% key: psmap
+#% type: string
+#% label: Root for the name of psmap instruction files to be in current directory
+#% description: If not set, no psmap instruction files will be created)
+#% required: no
+#%end
+#%option G_OPT_I_GROUP
+#% description: Name of group file where thematic map commands will be saved
+#% required: no
+#%end
+#% key: rgb_column
+#% description: Name of color column to populate RGB values
+#%end
+#%flag
+#%key: l
+#%description: Create graphic legend in x11 display monitor
+#%end
+#%flag
+#% key: f
+#% description: Only draw fills (no outlines) for areas and points
+#%end
+#%flag
+#%key: s
+#%description: Output legend for GIS Manager (for scripting use only)
+#%end
+#%flag
+#%key: m
+#%description: Use math notation brackets in legend
+#%end
+import sys
+import os
+import string
+import shutil
+import atexit
+import grass.script as grass
+tmp_graph = None
+tmp_group = None
+tmp_psmap = None
+tmp_psleg = None
+tmp_gisleg = None
+def cleanup():
+    for file in [tmp_graph, tmp_group, tmp_psmap, tmp_psleg, tmp_gisleg]:
+	if file:
+	    grass.try_remove(file)
+# hard-coded parameter: the maximum number of legend items before
+# we strip them using a middle ellipsis
+max_leg_items = 18
+def subs(vars, tmpl):
+    return string.Template(tmpl).substitute(vars)
+def msg(vars, tmpl, verbose=False):
+    if not verbose:
+        grass.message(subs(vars, tmpl))
+    else:
+        grass.verbose(subs(vars, tmpl))
+def out(fh, vars, tmpl):
+    fh.write(subs(vars, tmpl))
+def main():
+    global tmp_graph, tmp_group, tmp_psmap, tmp_psleg, tmp_gisleg
+    breakpoints = options['breakpoints']
+    colorscheme = options['colorscheme']
+    column = options['column']
+    endcolor = options['end_color']
+    group = options['group']
+    layer = options['layer']
+    linecolor = options['line_color']
+    map = options['map']
+    maxsize = options['maxsize']
+    monitor = options['monitor']
+    nint = options['nint']
+    pointcolor = options['point_color']
+    psmap = options['psmap']
+    size = options['size']
+    startcolor = options['start_color']
+    themecalc = options['themecalc']
+    themetype = options['themetype']
+    type = options['type']
+    where = options['where']
+    icon = options['icon']
+    rgb_column = options['rgb_column']
+    flag_f = flags['f']
+    flag_g = flags['g']
+    flag_l = flags['l']
+    flag_m = flags['m']
+    flag_s = flags['s']
+    layer = int(layer)
+    nint = int(nint)
+    size = float(size)
+    maxsize = float(maxsize)
+    if 'MONITOR' not in grass.gisenv().keys() and \
+       'GRASS_RENDER_IMMEDIATE' not in os.environ:
+       grass.fatal(_("Neither MONITOR (managed by d.mon command) nor GRASS_RENDER_IMMEDIATE "
+                     "(used for direct rendering) defined)"))
+    mapset = grass.find_file(map, element='vector')['mapset']
+    if not mapset:
+        grass.fatal(_("Vector map <%s> not found") % map)
+    if rgb_column and mapset != grass.gisenv()['MAPSET']:
+        grass.warning(_("Vector map <%s> not found in the current mapset. "
+                        "Updating RGB values <%s> skipped.") % (map, "rgb_column"))
+        rgb_column = None
+    # check column type
+    inf = grass.vector_columns(map, layer)
+    if column not in inf:
+	grass.fatal(_("No such column <%s>") % column)
+    coltype = inf[column]['type'].lower()
+    if coltype not in ["integer", "double precision"]:
+	grass.fatal(_("Column <%s> is of type <%s> which is not numeric.") % (column, coltype))
+    # create temporary file to hold d.graph commands for legend
+    tmp_graph = grass.tempfile()
+    # Create temporary file to commands for GIS Manager group
+    tmp_group = grass.tempfile()
+    # Create temporary file for commands for ps.map map file
+    tmp_psmap = grass.tempfile()
+    # Create temporary file for commands for ps.map legend file
+    tmp_psleg = grass.tempfile()
+    # create file to hold elements for GIS Manager legend
+    tmp_gisleg = grass.tempfile()
+    # Set display variables for group
+    atype = int(type == "area")
+    ptype = int(type == "point")
+    ctype = int(type == "centroid")
+    ltype = int(type == "line")
+    btype = int(type == "boundary")
+    # if running in the GUI, do not create a graphic legend in an xmon
+    if flag_s:
+        flag_l = False
+        # if running in GUI, turn off immediate mode rendering so that the
+        # iterated d.vect commands will composite using the display driver
+        os.environ['GRASS_RENDER_FILE_READ'] = 'TRUE'
+        os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
+    db = grass.vector_db(map)[1]
+    if not db or not db['table']:
+        grass.fatal(_("No table connected or layer <%s> does not exist.") % layer)
+    table = db['table']
+    database = db['database']
+    driver = db['driver']
+    # update color values to the table?
+    if rgb_column:
+        # test, if the rgb column is in the table
+        s = grass.read_command('db.columns', table = table, database = database, driver = driver)
+        if rgb_column not in s.splitlines():
+            msg(locals(), _("Creating column <$rgb_column> in table <$table>"))
+            sql = "ALTER TABLE %s ADD COLUMN %s varchar(11)" % (table, rgb_column)
+            grass.write_command('db.execute', database = database, driver = driver, input = '-', stdin = sql)
+    # Group name
+    if not group:
+        group = "themes"
+    f_group = file(tmp_group, 'w')
+    f_group.write("Group %s\n" % group)
+    # Calculate statistics for thematic intervals
+    if type == "line":
+        stype = "line"
+    else:
+        stype = ["point", "centroid"]
+    grass.message(_("Calculating statistics..."))
+    stats = grass.read_command('v.univar', flags = 'eg', map = map, type = stype, column = column, where = where, layer = layer)
+    if not stats:
+        grass.fatal(_("Unable to calculate statistics for vector map <%s>" % map))
+    stats = grass.parse_key_val(stats)
+    if 'min' not in stats:
+        grass.fatal(_("Unable to calculate statistics for vector map <%s> "
+                      "(missing minimum/maximum value)" % map))
+    min  = float(stats['min'])
+    max  = float(stats['max'])
+    mean = float(stats['mean'])
+    sd   = float(stats['population_stddev'])
+    q1   = float(stats['first_quartile'])
+    q2   = float(stats['median'])
+    q3   = float(stats['third_quartile'])
+    q4   = max
+    ptsize = size
+    if breakpoints and themecalc != "custom_breaks":
+        grass.warning(_("Custom breakpoints ignored due to themecalc setting."))
+    # set interval for each thematic map calculation type
+    if themecalc == "interval":
+        numint = nint
+        step = float(max - min) / numint
+        breakpoints = [min + i * step for i in xrange(numint + 1)]
+        annotations = ""
+    elif themecalc == "std_deviation":
+        # 2 standard deviation units on either side of mean,
+        # plus min to -2 sd units and +2 sd units to max, if applicable
+        breakpoints = [min] + [i for i in [(mean + i * sd) for i in [-2,-1,0,1,2]] if min < i < max] + [max]
+        annotations = [""] + [("%dsd" % i) for (i, j) in [(i, mean + i * sd) for i in [-2,-1,0,1,2]] if (min < j < max)] + [""]
+        annotations = ";".join(annotations)
+        numint = len(breakpoints) - 1
+    elif themecalc == "quartiles":
+        numint=4
+        # one for each quartile
+        breakpoints = [min, q1, q2, q3, max]
+        annotations = " %f; %f; %f; %f" % (q1, q2, q3, q4)
+    elif themecalc == "custom_breaks":
+        if not breakpoints:
+            grass.fatal(_("Required parameter <%s> not set") % "breakpoints")
+        breakpoints = [int(x) for x in breakpoints.split()]
+        annotations = ""
+    else:
+        grass.fatal(_("Unknown themecalc type <%s>") % themecalc)
+    pointstep = (maxsize - ptsize) / (numint - 1)
+    # Prepare legend cuts for too large numint
+    if numint > max_leg_items:
+        xupper = int(numint - max_leg_items / 2) + 1
+        xlower = int(max_leg_items / 2) + 1
+    else:
+        xupper = 0
+        xlower = 0
+    # legend title
+    f_graph = file(tmp_graph, 'w')
+    out(f_graph, locals(), """\
+color 0:0:0
+size 2 2
+move 1 95
+text Thematic map legend for column $column of map $map
+size 1.5 1.8
+move 4 90
+text Value range: $min - $max
+    f_gisleg = file(tmp_gisleg, 'w')
+    out(f_gisleg, locals(), """\
+title - - - {Thematic map legend for column $column of map $map}
+    f_psleg = file(tmp_psleg, 'w')
+    out(f_psleg, locals(), """\
+text 1% 95% Thematic map legend for column $column of map $map
+  ref bottom left
+end
+text 4% 90% Value range: $min - $max
+  ref bottom left
+end
+    msg(locals(), _("Thematic map legend for column <$column> of map <$map>"), verbose=True)
+    msg(locals(), _("Value range: $min - $max"))
+    colorschemes = {
+        "blue-red":		("0:0:255",	"255:0:0"),
+        "red-blue":		("255:0:0",	"0:0:255"),
+        "green-red":	("0:255:0",	"255:0:0"),
+        "red-green":	("255:0:0",	"0:255:0"),
+        "blue-green":	("0:0:255",	"0:255:0"),
+        "green-blue":	("0:255:0",	"0:0:255"),
+        "cyan-yellow":	("0:255:255",	"255:255:0"),
+        "yellow-cyan":	("255:255:0",	"0:255:255"),
+        "custom_gradient":	(startcolor,	endcolor)
+    # open file for psmap instructions
+    f_psmap = file(tmp_psmap, 'w')
+    # graduated color thematic mapping
+    if themetype == "graduated_colors":
+        if colorscheme in colorschemes:
+            startc, endc = colorschemes[colorscheme]
+        # set color schemes for graduated color maps
+        elif colorscheme == "single_color":
+            if themetype == "graduated_points":
+                startc = endc = linecolor
+            else:
+                startc = endc = pointcolor
+        else:
+            grass.fatal(_("This should not happen: parser error. Unknown color scheme %s") % colorscheme)
+        color = __builtins__.map(int, startc.split(":"))
+        endcolor = __builtins__.map(int, endc.split(":"))
+        #The number of color steps is one less then the number of classes
+        nclrstep = numint - 1
+        clrstep = [(a - b) / nclrstep for a, b in zip(color, endcolor)]
+        themecolor = startc
+        # display graduated color themes
+move 4 87
+text Mapped by $numint intervals of $step
+subtitle - - - {Mapped by $numint intervals of $step}
+text 4% 87% Mapped by $numint intervals of $step
+  ref bottom left
+end
+            msg(locals(), _("Mapped by $numint intervals of $step"))
+        # display graduated color themes for standard deviation units
+        if themecalc == "std_deviation":
+move 4 87
+text Mapped by standard deviation units of $sd (mean = $mean)
+subtitle - - - {Mapped by standard deviation units of $sd (mean = $mean)}
+text 4% 87% Mapped by standard deviation units of $sd (mean = $mean)
+  ref bottom left
+end
+            msg(locals(), _("Mapped by standard deviation units of $sd (mean = $mean)"))
+        # display graduated color themes for quartiles
+        if themecalc == "quartiles":
+move 4 87
+text Mapped by quartiles (median = $q2)
+subtitle - - - {Mapped by quartiles (median = $q2)}
+text 4% 87% Mapped by quartiles (median = $q2)
+  ref bottom left
+end
+            msg(locals(), _("Mapped by quartiles (median = $q2)"))
+        f_graph.write("""\
+move 4 83
+text Color
+move 14 83
+text Value
+move 4 80
+text =====
+move 14 80
+text ============
+        f_psleg.write("""\
+text 4% 83% Color
+  ref bottom left
+end
+text 14% 83% Value
+  ref bottom left
+end
+text 4% 80% =====
+  ref bottom left
+end
+text 14% 80% ============
+  ref bottom left
+end
+        grass.message("")
+        grass.message(_("Color(R:G:B)\tValue"))
+        grass.message("============\t==========")
+        line1 = 78
+        line2 = 76
+        line3 = 75
+        i = 0
+        first = True
+        while i < numint:
+            if flag_m:
+                # math notation
+                if first:
+                    closebracket = "]"
+                    openbracket = "["
+                    mincomparison = ">="
+                    first = False
+                else:
+                    openbracket = "["
+                    mincomparison = ">"
+            else:
+                closebracket = ""
+                openbracket = ""
+                if first:
+                    first = False
+                else:
+            themecolor = ":".join(__builtins__.map(str,color))
+            if flag_f:
+                linecolor = "none"
+            else:
+                if type in ["line", "boundary"]:
+                    linecolor = themecolor
+                else:
+                    linecolor = linecolor
+            ### rangemin = __builtins__.min(breakpoints)
+            ### rangemax = __builtins__.max(breakpoints)
+            rangemin = breakpoints[i]
+            rangemax = breakpoints[i+1]
+            if not annotations:
+                extranote = ""
+            else:
+                extranote = annotations[i]
+            if i < xlower or i >= xupper:
+                xline1 = line2 + 2
+                xline3 = line2 - 1
+color $themecolor
+polygon
+5 $xline1
+8 $xline1
+8 $xline3
+5 $xline3
+color $linecolor
+move 5 $xline1
+draw 8 $xline1
+draw 8 $xline3
+draw 5 $xline3
+draw 5 $xline1
+move 14 $line2
+color 0:0:0
+text $openbracket$rangemin - $rangemax$closebracket $extranote
+            else:
+                if i == xlower:
+color 0:0:0
+move 10 $line2
+text ...
+                else:
+                    #undo next increment
+                    line2 += 4
+area $themecolor $linecolor - {$openbracket$rangemin - $rangemax$closebracket $extranote}
+line 5% $xline1% 8% $xline1%
+  color $linecolor
+end
+text 14% $xline1% $openbracket$rangemin - $rangemax$closebracket $extranote
+  ref center left
+end
+                elif type in ["point", "centroid"]:
+point 8% $xline1%
+  color $linecolor
+  fcolor $themecolor
+  size $size
+  symbol $icon
+end
+  ref center left
+end
+                else:
+rectangle 5% $xline1% 8% $xline3%
+  color 0:0:0
+end
+text 14% $xline3% $openbracket$rangemin - $rangemax$closebracket DCADCA $extranote
+  ref bottom left
+end
+            else:
+                if i == xlower:
+color 0:0:0
+text 14% $xline3% ...
+  ref bottom left
+end
+                f_gisleg.write("text - - - {...}\n")
+            grass.message("%-15s %s%.3f - %.3f%s %s" % (themecolor, openbracket, rangemin, rangemax, closebracket, extranote))
+            if not where:
+                sqlwhere = subs(locals(), "$column $mincomparison $rangemin AND $column <= $rangemax")
+            else:
+                sqlwhere = subs(locals(), "$column $mincomparison $rangemin AND $column <= $rangemax AND $where")
+            # update color to database?
+            if rgb_column:
+                sql = subs(locals(), "UPDATE $table SET $rgb_column = '$themecolor' WHERE $sqlwhere")
+            # Create group for GIS Manager
+            if flag_g:
+                # change rgb colors to hex
+                xthemecolor = "#%02X%02X%02X" % tuple(__builtins__.map(int, themecolor.split(":")))
+                #xlinecolor=`echo $linecolor | awk -F: '{printf("#%02X%02X%02X\n",$1,$2,$3)}'`
+                if "$linecolor" == "black":
+                    xlinecolor = "#000000"
+                else:
+                    xlinecolor = xthemecolor
+                # create group entry
+                out(f_group, locals(), """\
+  _check 1
+  Vector $column = $rangemin - $rangemax
+    _check 1
+    map $map
+    display_shape 1
+    display_cat 0
+    display_topo 0
+    display_dir 0
+    display_attr 0
+    type_point $ptype
+    type_line $ltype
+    type_boundary $btype
+    type_centroid $ctype
+    type_area $atype
+    type_face 0
+    color $xlinecolor
+    fcolor $xthemecolor
+    width $ptsize
+    _use_fcolor 1
+    lcolor #000000
+    sqlcolor 0
+    icon $icon
+    size $ptsize
+    field $layer
+    lfield $layer
+    attribute
+    xref left
+    yref center
+    lsize 8
+    cat
+    where $sqlwhere
+    _query_text 0
+    _query_edit 1
+    _use_where 1
+    minreg
+    maxreg
+    _width 0.1
+  End
+            # display theme vector map
+            grass.run_command('d.vect', map = map, type = type, layer = layer,
+                              where = sqlwhere,
+                              color = linecolor, fcolor = themecolor, icon = icon, size = ptsize,
+                              quiet = True)
+                out(f_psmap, locals(), """\
+vlines $map
+  type $type
+  layer $layer
+  where $sqlwhere
+  color $linecolor
+  label $rangemin - $rangemax
+end
+vpoints $map
+  type $type
+  layer $layer
+  where $sqlwhere
+  color $linecolor
+  symbol $icon
+end
+            else:
+vareas $map
+  layer $layer
+  where $sqlwhere
+  color $linecolor
+end
+            # increment for next theme
+            i += 1
+            if i == numint:
+                color = endcolor
+            else:
+                color = [__builtins__.min(a - b, 255) for a, b in zip(color, clrstep)]
+            line1 -= 4
+            line2 -= 4
+            line3 -= 4
+    #graduated points and line widths thematic mapping
+    if themetype in ["graduated_points", "graduated_lines"]:
+        #display graduated points/lines by intervals
+move 4 87
+  ref bottom left
+end
+        # display graduated points/lines for standard deviation units
+move 4 87
+  ref bottom left
+end
+        # display graduated points/lines for quartiles
+move 4 87
+  ref bottom left
+end
+        line1 = 76
+        line2 = 75
+move 4 83
+text Size/width
+move 25 83
+text Value
+move 4 80
+text ==============
+move 25 80
+text 4% 83% Icon size
+  ref bottom left
+end
+text 25% 83% Value
+  ref bottom left
+end
+text 4% 80% ============
+  ref bottom left
+end
+text 25% 80% ============
+  ref bottom left
+end
+        grass.message("")
+        grass.message(_("Size/width\tValue"))
+        grass.message("==========\t=====")
+        themecolor = pointcolor
+        if flag_f:
+        i = numint
+        ptsize = maxsize
+        while i >= 1:
+            if flag_m:
+                # math notation
+                if i == 1:
+                    openbracket = "["
+                else:
+                    openbracket = "]"
+            else:
+                closebracket = ""
+                openbracket = ""
+                if i == 1:
+                else:
+            if flag_f:
+            rangemin = breakpoints[i-1]
+            rangemax = breakpoints[i]
+                extranote = ""
+            else:
+            iconsize = int(ptsize / 2)
+            lineht = int(ptsize / 4)
+            if lineht < 4:
+                lineht = 4
+                if themetype == "graduated_lines":
+color $linecolor
+line $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}
+                else:
+color $themecolor
+point $themecolor $linecolor $ptsize {$openbracket$rangemin - $rangemax$closebracket $extranote}
+icon + $iconsize 5 $line1
+color 0:0:0
+move 10 $line2
+text $ptsize pts
+move 25 $line2
+            else:
+                if i == xlower:
+color 0:0:0
+move 10 $line2
+text ...
+text - - - ...
+                else:
+                    # undo future line increment
+                    line2 += lineht
+point 8% $line1%
+  color $linecolor
+  size $iconsize
+  symbol $icon
+end
+text 25% $line1% $openbracket$rangemin - $rangemax$closebracket $extranote
+  ref center left
+end
+            else:
+                if i == xlower:
+text 25% $xline1% ...
+   ref center left
+end
+            grass.message("%-15d %s%.3f - %.3f%s %s" % \
+                          (ptsize, openbracket, rangemin, rangemax, closebracket, extranote))
+            if not where:
+            else:
+            if rgb_column:
+            if flag_g:
+                xthemecolor = "#%02X%02X%02X" % tuple(__builtins__.map(int,themecolor.split(":")))
+  _check 1
+    _check 1
+    map $map
+    display_shape 1
+    display_cat 0
+    display_topo 0
+    display_dir 0
+    display_attr 0
+    type_point $ptype
+    type_line $ltype
+    type_area $atype
+    type_face 0
+    color $xlinecolor
+    width $ptsize
+    _use_fcolor 1
+    lcolor #000000
+    sqlcolor 0
+    icon $icon
+    size $ptsize
+    field $layer
+    lfield $layer
+    attribute
+    xref left
+    yref center
+    lsize 8
+    cat
+    where $sqlwhere
+    _query_text 0
+    _query_edit 1
+    _use_where 1
+    minreg
+    maxreg
+    _width 0.1
+  End
+            #graduates line widths or point sizes
+            kwargs = {}
+                kwargs['width'] = ptsize
+                              where = sqlwhere,
+                              size = ptsize, quiet = True, **kwargs)
+            if themetype != "graduated_lines":
+vpoints $map
+  type $type
+  layer $layer
+  where $sqlwhere
+  color $linecolor
+  symbol $icon
+  size $ptsize
+end
+            ptsize -= pointstep
+            line1 -= lineht
+            line2 -= lineht
+            i -= 1
+    # Create graphic legend
+    f_graph.close()
+    if flag_l:
+        grass.run_command('d.erase')
+        grass.run_command('d.graph', input = tmp_graph)
+    # Create group file for GIS Manager
+    f_group.write("End\n")
+    f_group.close()
+    if flag_g:
+        shutil.copyfile(tmp_group, "%s.dm" % group)
+    # Create ps.map map file
+    f_psmap.write("end\n")
+    f_psmap.close()
+    if psmap:
+        shutil.copyfile(tmp_psmap, "%s.psmap" % psmap)
+    # Create ps.map legend file
+    f_psleg.write("end\n")
+    f_psleg.close()
+    if psmap:
+        shutil.copyfile(tmp_psleg, "%s_legend.psmap" % psmap)
+    # Create text file to use with d.graph in GIS Manager
+    f_gisleg.close()
+    if flag_s:
+        tmpdir = os.path.dirname(tmp_gisleg)
+        tlegfile = os.path.join(tmpdir, "gismlegend.txt")
+        shutil.copyfile(tmp_gisleg, tlegfile)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    main()
