[GRASS-SVN] r64056 - in grass/trunk: imagery/i.evapo.pt lib/gis raster/r.sun
Sun Jan 11 06:14:13 PST 2015
Author: neteler
Date: 2015-01-11 06:14:13 -0800 (Sun, 11 Jan 2015)
New Revision: 64056
   grass/trunk/imagery/i.evapo.pt/main.c
   grass/trunk/lib/gis/renamed_options
   grass/trunk/raster/r.sun/main.c
   grass/trunk/raster/r.sun/r.sun.html
renamed_options: alphabetical order, fixed dupes and typos; sync coeff abbreviation
Modified: grass/trunk/imagery/i.evapo.pt/main.c
--- grass/trunk/imagery/i.evapo.pt/main.c	2015-01-11 04:46:59 UTC (rev 64055)
+++ grass/trunk/imagery/i.evapo.pt/main.c	2015-01-11 14:14:13 UTC (rev 64056)
@@ -87,7 +87,7 @@
     input_PATM->description = _("Name of input atmospheric pressure raster map [millibars]");
     input_PT = G_define_option();
-    input_PT->key = "priestley_taylor_coef";
+    input_PT->key = "priestley_taylor_coeff";
     input_PT->type = TYPE_DOUBLE;
     input_PT->required = YES;
     input_PT->description = _("Priestley-Taylor coefficient");
Modified: grass/trunk/lib/gis/renamed_options
--- grass/trunk/lib/gis/renamed_options	2015-01-11 04:46:59 UTC (rev 64055)
+++ grass/trunk/lib/gis/renamed_options	2015-01-11 14:14:13 UTC (rev 64056)
@@ -1,7 +1,9 @@
 ### Renamed options in GRASS 7.0
+# Entries in alphabetical order
 ### Global
 fs:separator
 nv:null_value
 dt:dtime
@@ -11,105 +13,24 @@
 # d.barscale
 d.barscale|background_color:bgcolor
+# d.colortable
+d.colortable|cols:columns
 # d.correlate
 d.correlate|layers:map
 # d.erase
 d.erase|background:bgcolor
-# d.legend
-d.legend|map:rast
-# d.his
-d.his|h_map:hue
-d.his|i_map:intensity
-d.his|s_map:saturation
-# d.rast
-d.rast|catlist:values
-d.rast|vallist:values
-# d.rast.leg
-d.rast.leg|rast:raster
-# d.vect
-d.vect|wcolumn:width_column
-d.vect|wscale:width_scale
-d.vect|rot_column:rotation_column
-d.vect|attrcolumn:attribute_column
-# d.colortable
-d.colortable|cols:columns
 # d.geodesic
 d.geodesic|lcolor:line_color
 d.geodesic|tcolor:text_color
 # d.grid
 d.grid|bordercolor:border_color
 d.grid|textcolor:text_color
-# d.path
-d.path|hcolor:highlight_color
-d.path|type:arc_type
-d.path|alayer:arc_layer
-d.path|nlayer:node_layer
-d.path|afcolumn:arc_column
-d.path|abcolumn:arc_backward_column
-d.path|ncolumn:node_column
-# d.polar
-d.polar|eps:output
-# d.profile
-d.profile|input:map
-d.profile|profile:coordinates
-# d.rast.arrow
-d.rast.arrow|arrow_color:color
-d.rast.arrow|x_color:null_color
-# d.rhumbline
-d.rhumbline|coord:coordinates
-d.rhumbline|lcolor:line_color
-d.rhumbline|tcolor:text_color
-# d.vect
-d.vect|fcolor:fill_color
-d.vect|llayer:label_layer
-d.vect|lcolor:label_color
-d.vect|bgcolor:label_bgcolor
-d.vect|bcolor:label_boundary_color
-d.vect|lsize:label_size
-# d.vect.thematic
-d.vect.thematic|bcolor:boundary_color
-d.vect.thematic|bwidth:boundary_width
-### Renamed options in GRASS 7.0
-### Global
-fs:separator
-nv:null_value
-dt:dtime
-dp:precision
-### Display module changes
-# d.barscale
-d.barscale|background_color:bgcolor
-# d.correlate
-d.correlate|layers:map
-# d.erase
-d.erase|background:bgcolor
 # d.legend
 d.legend|map:rast
 # d.his
 d.his|h_map:hue
-# d.rast
-# d.rast.leg
-# d.vect
-# d.colortable
-# d.geodesic
-d.geodesic|lcolor:line_color
-d.geodesic|tcolor:text_color
-# d.grid
-d.grid|bordercolor:border_color
-d.grid|textcolor:text_color
 # d.path
@@ -123,28 +44,37 @@
 # d.profile
 d.profile|input:map
+# d.rast
+d.rast|catlist:values
+d.rast|vallist:values
 # d.rast.arrow
+# d.rast.leg
+d.rast.leg|rast:raster
 # d.rhumbline
 # d.vect
+d.vect|attrcolumn:attribute_column
-# d.vect.thematic
-d.vect.thematic|nbclasses:nclasses
+d.vect|rot_column:rotation_column
+d.vect|wcolumn:width_column
+d.vect|wscale:width_scale
 # d.vect.chart
 d.vect.chart|ctype:chart_type
 d.vect.chart|ocolor:outline_color
 d.vect.chart|sizecol:size_column
+# d.vect.thematic
+d.vect.thematic|bcolor:boundary_color
+d.vect.thematic|bwidth:boundary_width
+d.vect.thematic|nbclasses:nclasses
 ### Database management module changes
@@ -155,14 +85,14 @@
 ### General map management module changes
+# g.mapset
+g.mapset|gisdbase:dbase
 # g.mapsets
 g.mapsets|addmapset:operation
 g.mapsets|removemapset:operation
 g.mapsets|measure:method
 # g.pnmcomp
 g.pnmcomp|background:bgcolor
-# g.mapset
-g.mapset|gisdbase:dbase
 ### Image processing module changes
@@ -174,7 +104,6 @@
 i.atcorr|icnd:parameters
 i.atcorr|oimg:output
 i.atcorr|oscl:rescale
-i.atcorr|input:map
 # i.biomass
 i.biomass|lightuseefficiency:lightuse_efficiency
 i.biomass|transmissivitysingleway:transmissivity_singleway
@@ -191,12 +120,32 @@
 i.evapo.pt|atmosphericpressure:atmospheric_pressure
 i.evapo.pt|netradiation:net_radiation
 i.evapo.pt|soilheatflux:soil_heatflux
-i.evapo.pt|priestley_taylor_coef:priestley_taylor_coef
+i.evapo.pt|priestley_taylor_coef:priestley_taylor_coeff
+# i.fft
+i.fft|input_image:input
+i.fft|real_image:real
+i.fft|imaginary_image:imaginary
+# i.his.rgb
+i.his.rgb|hue_input:hue
+i.his.rgb|intensity_input:intensity
+i.his.rgb|saturation_input:saturation
+i.his.rgb|red_output:red
+i.his.rgb|green_output:green
+i.his.rgb|blue_output:blue
+# i.ifft
+i.ifft|real_image:real
+i.ifft|imaginary_image:imaginary
+i.ifft|output_image:output
 # i.image.mosaic
 i.image.mosaic|images:input
 # i.in.spotvgt
 i.in.spotvgt|file:input
 i.in.spotvgt|rast:output
+# i.landsat.acca
+i.landsat.acca|input_prefix:input
+# i.landsat.toar
+i.landsat.toar|input_prefix:input
+i.landsat.toar|output_prefix:output
 # i.maxlik
 i.maxlik|sigfile:signaturefile
 i.maxlik|class:output
@@ -211,26 +160,6 @@
 i.pansharpen|ms3:red
 i.pansharpen|output_prefix:output
 i.pansharpen|sharpen:method
-# i.fft
-i.fft|input_image:input
-i.fft|real_image:real
-i.fft|imaginary_image:imaginary
-# i.his.rgb
-i.his.rgb|hue_input:hue
-i.his.rgb|intensity_input:intensity
-i.his.rgb|saturation_input:saturation
-i.his.rgb|red_output:red
-i.his.rgb|green_output:green
-i.his.rgb|blue_output:blue
-# i.fft
-i.fft|output_image:output
-# i.landsat.acca
-i.landsat.acca|input_prefix:input
-# i.landsat.toar
-i.landsat.toar|input_prefix:input
-i.landsat.toar|output_prefix:output
 # i.pca
 i.pca|output_prefix:output
 # i.rectify
@@ -243,10 +172,19 @@
 i.rgb.his|intensity_output:intensity
 i.rgb.his|saturation_output:saturation
 # i.tasscap
-i.tasscap|sattelite:sensor
+i.tasscap|satellite:sensor
 # i.vi
 i.vi|chan5:band5
 i.vi|chan7:band7
+### Miscellaneous module changes
+# m.measure
+m.measure|coords:coordinates
+# m.cogo
+m.cogo|coords:coordinates
+# m.transform
+m.transform|coords:input
 ### Raster module changes
@@ -255,20 +193,33 @@
 r.basins.fill|t_map:tnetwork
 r.basins.fill|result:output
 # r.blend
-r.blend|output:output_prefix
+r.blend|output_prefix:output
+# r.category
+r.category|vals:values
+# r.circle
+r.circle|coordinate:coordinates
+r.circle|mult:multiplier
+# r.coin
+r.coin|map1:first
+r.coin|map2:second
 # r.colors
 r.colors|volume:raster_3d
 # r.colors.stddev
 r.colors.stddev|input:map
+# r.composite
+r.composite|lev_red:level_red
+r.composite|lev_green:level_green
+r.composite|lev_blue:level_blue
 # r.cost
 r.cost|coordinate:start_coordinates
 r.cost|start_rast:start_raster
 # r.distance
 r.distance|maps:map
 # r.drain
-r.drain|voutput:vector_output
 r.drain|coordinates:start_coordinates
+r.drain|indir:direction
 r.drain|vector_points:start_points
+r.drain|voutput:vector_output
 # r.fill.dir
 r.fill.dir|elevation:input
 r.fill.dir|depressionless:output
@@ -289,8 +240,11 @@
 r.his|g_map:green
 r.his|b_map:blue
 # r.horizon
+r.horizon|basename:output
+r.horizon|coordinate:coordinates
 r.horizon|elevin:elevation
 r.horizon|horizonstep:step
+r.horizon|output:file
 # r.in.wms
 r.in.wms|mapserver:url
 # r.lake
@@ -313,11 +267,41 @@
 r.li.renyi|map:input
 r.li.shannon|map:input
 r.li.simpson|map:input
+# r.out.mpeg
+r.out.mpeg|qual:quality
+# r.out.vrml
+r.out.vrml|elev:elevation
+r.out.vrml|exag:exaggeration
+# r.out.vtk
+r.out.vtk|elevscale:zscale
+# r.param.scale
+r.param.scale|s_tol:slope_tolerance
+r.param.scale|c_tol:curvature_tolerance
+r.param.scale|exp:exponent
 # r.plane
 r.plane|name:output
+# r.profile
+r.profile|null:null_value
+# r.random
+r.random|raster_output:raster
+r.random|vector_output:vector
+# r.reclass.area
+r.reclass.area|lesser,greater:value, mode
+# r.report
+r.report|pl:page_length
+r.report|pw:page_width
+r.report|null:null_value
 # r.resamp.bspline
 r.resamp.bspline|se:ew_step
 r.resamp.bspline|sn:ns_step
+# r.resamp.rst
+r.resamp.rst|elev:elevation
+r.resamp.rst|pcurv:pcurvature
+r.resamp.rst|mcurv:mcurvature
+r.resamp.rst|tcurv:tcurvature
+r.resamp.rst|zmult:zscale
+# r.rgb
+r.rgb:|output_prefix:output
 # r.sim.sediment
 r.sim.sediment|elevin:elevation
 r.sim.sediment|dxin:dx
@@ -355,6 +339,13 @@
 r.sim.water|niter:niterations
 r.sim.water|outiter:output_step
 r.sim.water|diffc:diffusion_coeff
+# r.slope.aspect
+r.slope.aspect|pcurv:pcurvature
+r.slope.aspect|tcurv:tcurvature
+r.slope.aspect|zfactor:zscale
+r.slope.aspect|min_slp_allowed:min_slope
+# r.spreadpath
+r.spreadpath|coordinate:coordinates
 # r.stream.extract
 r.stream.extract|stream_rast:stream_raster
 r.stream.extract|stream_vect:stream_vector
@@ -368,8 +359,8 @@
 r.sun|alb:albedo_value
 r.sun|latin:lat
 r.sun|longin:long
-r.sun|coefbh:coef_bh
-r.sun|coefdh:coef_dh
+r.sun|coefbh:coeff_bh
+r.sun|coefdh:coeff_dh
 r.sun|horizonstep:horizon_step
 r.sun|declin:declination
 r.sun|dist:distance_step
@@ -377,6 +368,8 @@
 r.sun|civiltime:civil_time
 # r.surf.area
 r.surf.area|input:map
+# r.terraflow
+r.terraflow|stream_dir:directory
 # r.texture
 r.texture|measure:method
 # r.to.vect
@@ -407,68 +400,6 @@
 r.watershed|max.slope.length:max_slope_length
 # r.what
 r.what|east_north:coordinates
-# r.rgb:
-r.rgb:|output_prefix:output
-# r.blend
-r.blend|output_prefix:output
-# r.category
-r.category|vals:values
-# r.circle
-r.circle|coordinate:coordinates
-r.circle|mult:multiplier
-# r.coin
-r.coin|map1:first
-r.coin|map2:second
-# r.composite
-r.composite|lev_red:level_red
-r.composite|lev_green:level_green
-r.composite|lev_blue:level_blue
-# r.drain
-r.drain|indir:direction
-r.drain|vector_output:drain
-# r.fill.dir
-r.fill.dir|outdir:direction
-# r.horizon
-r.horizon|output:file
-r.horizon|basename:output
-r.horizon|coordinate:coordinates
-# r.out.mpeg
-r.out.mpeg|qual:quality
-# r.out.vrml
-r.out.vrml|elev:elevation
-r.out.vrml|exag:exaggeration
-# r.param.scale
-r.param.scale|s_tol:slope_tolerance
-r.param.scale|c_tol:curvature_tolerance
-r.param.scale|exp:exponent
-# r.profile
-r.profile|null:null_value
-# r.random
-r.random|raster_output:raster
-r.random|vector_output:vector
-# r.reclass.area
-r.reclass.area|lesser,greater:value, mode
-# r.report
-r.report|pl:page_length
-r.report|pw:page_width
-r.report|null:null_value
-# r.resamp.rst
-r.resamp.rst|elev:elevation
-r.resamp.rst|pcurv:pcurvature
-r.resamp.rst|mcurv:mcurvature
-r.resamp.rst|tcurv:trucravture
-r.resamp.rst|zmult:zscale
-# r.slope.aspect
-r.slope.aspect|pcurv:pcurvature
-r.slope.aspect|tcurv:tcurvature
-r.slope.aspect|zfactor:zscale
-r.slope.aspect|min_slp_allowed:min_slope
-# r.spreadpath
-r.spreadpath|coordinate:coordinates
-# r.terraflow
-r.terraflow|stream_dir:directory
-# r.out.vtk
-r.out.vtk|elevscale:zscale
 # r.viewshed
 r.viewshed|obs_elev:observer_elevation
 r.viewshed|tgt_elev:target_elevation
@@ -503,27 +434,56 @@
 ### Vector module changes
+# v.buffer
+v.buffer|bufcolumn:column
 # v.clean
 v.clean|thresh:threshold
 # v.colors
 v.colors|volume:raster_3d
 # v.drape
+# v.db.join
+v.db.join|otable:other_table
+v.db.join|ocolumn:other_column
+v.db.join|scolumns:subset_columns
+# v.db.select
+v.db.select|vs:vertical separator
+# v.db.update
+v.db.update|qcolumn:query_column
 v.drape|rast:elevation
 # v.edit
 v.edit|measure:method
 v.edit|thresh:threshold
+# v.external
+v.external|dsn:input
 # v.extract
 v.extract|list:cats
+# v.extrude
+v.extrude|hcolumn:height_column
 # v.in.e00
 v.in.e00|file:input
 v.in.e00|vect:output
+# v.in.ogr
+v.in.ogr|dsn:input
+v.in.ogr|cnames:columns
 # v.in.wfs
 v.in.wfs|wfs:url
 v.in.wfs|input:map
+# v.label
+v.label|background:bgcolor
+v.label|hcolor:highlight_color
+v.label|hwidth:highlight_width
 # v.lrs.create
 v.lrs.create|thresh:threshold
+# v.lrs.label
+v.lrs.label|background:bgcolor
+v.lrs.label|hcolor:highlight_color
+v.lrs.label|hwidth:highlight_width
 # v.lrs.where
 v.lrs.where|thresh:threshold
+# v.kcv
+v.kcv|k:npartitions
+# v.kernel
+v.kernel|mult:multiplier
 # v.mkgrid
 v.mkgrid|coor:coordinates
 # v.net
@@ -633,57 +593,6 @@
 # v.net.visibility
 v.net.visibility|coordinate|coordinates
 v.net.visibility|vis|visibility
-# v.outlier
-v.outlier|soe:ew_step
-v.outlier|son:ns_step
-# v.rast.stats
-v.rast.stats|colprefix:column_prefix
-v.rast.stats|input:map
-# v.support
-v.support|thresh:threshold
-# v.surf.bspline
-v.surf.bspline|sie:ew_step
-v.surf.bspline|sin:ns_step
-# v.surf.rst
-v.surf.rst|devi:deviations
-v.surf.rst|maskmap:mask
-v.surf.rst|treefile:treeseg
-v.surf.rst|overfile:overwin
-v.surf.rst|elev:elevation
-# v.what.vect
-v.what.vect|vector:map
-v.what.vect|qvector:query_map
-v.what.vect|qlayer:query_layer
-v.what.vect|qcolumn:query_column
-# v.label
-v.label|background:bgcolor
-v.label|hcolor:highlight_color
-v.label|hwidth:highlight_width
-# v.lrs.label
-v.lrs.label|background:bgcolor
-v.lrs.label|hcolor:highlight_color
-v.lrs.label|hwidth:highlight_width
-# v.buffer
-v.buffer|bufcolumn:column
-# v.db.join
-v.db.join|otable:other_table
-v.db.join|ocolumn:other_column
-v.db.join|scolumns:subset_columns
-# v.db.select
-v.db.select|vs:vertical separator
-# v.db.update
-v.db.update|qcolumn:query_column
-# v.external
-v.external|dsn:input
-# v.extrude
-v.extrude|hcolumn:height_column
-# v.in.ogr
-v.in.ogr|dsn:input
-v.in.ogr|cnames:columns
-# v.kcv
-v.kcv|k:npartitions
-# v.kernel
-v.kernel|mult:multiplier
 # v.out.ogr
 v.out.ogr|dsn:output
 v.out.ogr|olayer:output_layer
@@ -694,18 +603,34 @@
 v.out.postgis|olink:output_link
 # v.out.vtk
 v.out.vtk|scale:zscale
+# v.outlier
+v.outlier|soe:ew_step
+v.outlier|son:ns_step
 # v.qcount
 v.qcount|n:nquadrants
 v.qcount|r:radius
+# v.rast.stats
+v.rast.stats|colprefix:column_prefix
+v.rast.stats|input:map
 # v.sample
 v.sample|z:zscale
 # v.segment
 v.segment|file:segments
+# v.support
+v.support|thresh:threshold
+# v.surf.bspline
+v.surf.bspline|sie:ew_step
+v.surf.bspline|sin:ns_step
 # v.surf.rst
-v.surf.rst|pcurv:pcurvature
-v.surf.rst|tcurv:tcurvature
+v.surf.rst|devi:deviations
+v.surf.rst|elev:elevation
+v.surf.rst|maskmap:mask
 v.surf.rst|mcurv:mcurvature
+v.surf.rst|overfile:overwin
+v.surf.rst|pcurv:pcurvature
 v.surf.rst|scolumn:smooth_column
+v.surf.rst|tcurv:tcurvature
+v.surf.rst|treefile:treeseg
 v.surf.rst|zmulti:zscale
 # v.to.db
 v.to.db|qlayer:query_layer
@@ -714,39 +639,34 @@
 v.to.points|llayer:layer
 # v.transform
 v.transform|attrcolumn:attribute_column
-v.transform|rgbcolumn:rgb_column
 v.transform|labelcolumn:label_column
-# v.transform
+v.transform|rgbcolumn:rgb_column
 v.transform|zrot:zrotation
 # v.vect.stats
-v.vect.stats|player:points_layer
 v.vect.stats|alayer:areas_layer
-v.vect.stats|pcolumn:points_column
 v.vect.stats|ccolumn:count_column
+v.vect.stats|pcolumn:points_column
+v.vect.stats|player:points_layer
 v.vect.stats|scolumn:stats_column
 # v.vol.rst
+v.vol.rst|aspect1:aspect_horizontal
+v.vol.rst|aspect2:aspect_vertical
 v.vol.rst|cellinp:cross_input
-v.vol.rst|devi:deviations
-v.vol.rst|scolumn:smooth_column
-v.vol.rst|wmulti:wscale
-v.vol.rst|zmulti:zscale
 v.vol.rst|cellout:cross_output
+v.vol.rst|devi:deviations
 v.vol.rst|elev:elevation
-v.vol.rst|aspect1:aspect_horizontal
-v.vol.rst|aspect2:aspect_vertical
-v.vol.rst|ncurv:ncurvature
 v.vol.rst|gcurv:gcurvature
 v.vol.rst|mcurv:mcurvature
+v.vol.rst|ncurv:ncurvature
+v.vol.rst|scolumn:smooth_column
+v.vol.rst|wmulti:wscale
+v.vol.rst|zmulti:zscale
 # v.what.vect
+v.what.vect|qcolumn:query_column
+v.what.vect|qlayer:query_layer
 v.what.vect|qmap:query_map
+# v.what.vect
+v.what.vect|qvector:query_map
-### Miscellaneous module changes
-# m.measure
-m.measure|coords:coordinates
-# m.cogo
-m.cogo|coords:coordinates
-# m.transform
-m.transform|coords:input
+v.what.vect|vector:map
Modified: grass/trunk/raster/r.sun/main.c
--- grass/trunk/raster/r.sun/main.c	2015-01-11 04:46:59 UTC (rev 64055)
+++ grass/trunk/raster/r.sun/main.c	2015-01-11 14:14:13 UTC (rev 64056)
@@ -349,7 +349,7 @@
     parm.longin->guisection = _("Input");
     parm.coefbh = G_define_option();
-    parm.coefbh->key = "coef_bh";
+    parm.coefbh->key = "coeff_bh";
     parm.coefbh->type = TYPE_STRING;
     parm.coefbh->required = NO;
     parm.coefbh->gisprompt = "old,cell,raster";
@@ -358,7 +358,7 @@
     parm.coefbh->guisection = _("Input");
     parm.coefdh = G_define_option();
-    parm.coefdh->key = "coef_dh";
+    parm.coefdh->key = "coeff_dh";
     parm.coefdh->type = TYPE_STRING;
     parm.coefdh->required = NO;
     parm.coefdh->gisprompt = "old,cell,raster";
Modified: grass/trunk/raster/r.sun/r.sun.html
--- grass/trunk/raster/r.sun/r.sun.html	2015-01-11 04:46:59 UTC (rev 64055)
+++ grass/trunk/raster/r.sun/r.sun.html	2015-01-11 14:14:13 UTC (rev 64056)
@@ -73,7 +73,7 @@
 In similar principle the Linke turbidity factor (<i>linke</i>, <i>lin</i>
 ) and ground albedo (<i>albedo</i>, <i>alb</i>) can be set.
 <p>Besides clear-sky radiations, the user can compute a real-sky radiation (beam,
-diffuse) using <i>coef_bh</i> and <i>coef_dh</i> input raster maps defining
+diffuse) using <i>coeff_bh</i> and <i>coeff_dh</i> input raster maps defining
 the fraction of the respective clear-sky radiations reduced by atmospheric
 factors (e.g. cloudiness). The value is between 0-1. Usually these
 coefficients can be obtained from a long-terms meteorological measurements
