[GRASS-SVN] r64130 - grass-addons/grass7/raster/r.meb
Tue Jan 13 05:34:41 PST 2015
Author: pvanbosgeo
Date: 2015-01-13 05:34:41 -0800 (Tue, 13 Jan 2015)
New Revision: 64130
   grass-addons/grass7/raster/r.meb/r.meb.py
minor change
Modified: grass-addons/grass7/raster/r.meb/r.meb.py
--- grass-addons/grass7/raster/r.meb/r.meb.py	2015-01-13 13:21:14 UTC (rev 64129)
+++ grass-addons/grass7/raster/r.meb/r.meb.py	2015-01-13 13:34:41 UTC (rev 64130)
@@ -5,12 +5,12 @@
 # MODULE:       r.meb
 # AUTHOR(S):    Paulo van Breugel <p.vanbreugel AT gmail.com>
-# PURPOSE:      Compute the multivariate envirionmental bias (EB). If A
-#               is an areas within a larger region B, the EB represents
-#               how much envirionmental conditions in A deviate from
-#               median conditions in B. The first step is to compute the
-#               multi-envirionmental similarity (MES) for B, using all
-#               raster cells in B as reference points. The MES of a
+# PURPOSE:      Compute the multivariate envirionmental bias (MEB). If A
+#               is an areas within a larger region B, the EB represents
+#               how much envirionmental conditions in A deviate from
+#               median conditions in B. The first step is to compute the
+#               multi-envirionmental similarity (MES) for B, using all
+#               raster cells in B as reference points. The MES of a
 #               raster cell thus represent how much conditions deviate
 #               from median conditions in B. The EB is then computed as the
 #               absolute difference of the median of MES values in A (MESa)
@@ -106,6 +106,12 @@
 #%end
+#Test
+#options = {"env":"bio_1 at climate,bio_2 at climate,bio_3 at climate", "file":"test.txt", "ref":"PAs2", "output":"AA1", "digits":"5"}
+#flags = {"m":True, "n":True, "o":True, "i":True}
 # Standard
@@ -230,10 +236,6 @@
     # Variables
-#Test
-#options = {"env":"bio_1 at climate,bio_2 at climate,bio_3 at climate", "file":"test.txt", "ref":"PAs2", "output":"AA1", "digits":"5"}
-#flags = {"m":True, "n":True, "o":True, "i":True}
     # variables
     ipl = options['env']
     ipl = ipl.split(',')
@@ -265,12 +267,15 @@
         # Calculate the frequency distribution
         tmpf1 = tmpname('reb1')
-        # todo - check if layer is integer. If so, skip step below
-        grass.mapcalc("$tmpf1 = int($dignum * $inplay)",
-                      tmpf1=tmpf1,
-                      inplay=ipl[j],
-                      dignum=digits2,
-                      quiet=True)
+        laytype = grass.raster_info(ipl[j])['datatype']
+        if laytype == 'CELL':
+            grass.run_command("g.copy", quiet=True, raster=(ipl[j], tmpf1))
+        else:
+            grass.mapcalc("$tmpf1 = int($dignum * $inplay)",
+                          tmpf1=tmpf1,
+                          inplay=ipl[j],
+                          dignum=digits2,
+                          quiet=True)
         p = grass.pipe_command('r.stats', quiet=True, flags='cn', input=tmpf1, sort='asc', sep=';')
         stval = {}
         for line in p.stdout:
