[GRASS-SVN] r64157 - in grass/branches/releasebranch_7_0: . temporal/t.connect/testsuite testsuite/raster
Tue Jan 13 22:08:03 PST 2015
Author: wenzeslaus
Date: 2015-01-13 22:08:03 -0800 (Tue, 13 Jan 2015)
New Revision: 64157
   grass/branches/releasebranch_7_0/REQUIREMENTS.html
   grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
   grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
   grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
   grass/branches/releasebranch_7_0/testsuite/raster/raster_md5test.sh
   grass/branches/releasebranch_7_0/testsuite/raster/rhemisphere.sh
remove minor differences to r64155 trunk (probably due to improper backports)
Modified: grass/branches/releasebranch_7_0/REQUIREMENTS.html
--- grass/branches/releasebranch_7_0/REQUIREMENTS.html	2015-01-14 06:06:28 UTC (rev 64156)
+++ grass/branches/releasebranch_7_0/REQUIREMENTS.html	2015-01-14 06:08:03 UTC (rev 64157)
@@ -149,7 +149,7 @@
 <a href="http://labix.org/python-dateutil">http://labix.org/python-dateutil</a>
 </li>
-<li><b>Python PLY Library</b> ("python-ply", needed for the temporal algebra in tgis)<br>
+<li><b>Python PLY Library (Python Lex-Yacc)</b> ("python-ply", needed for the temporal algebra in tgis)<br>
 <a href="http://www.dabeaz.com/ply">http://www.dabeaz.com/ply</a>
 </li>
Modified: grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
--- grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py	2015-01-14 06:06:28 UTC (rev 64156)
+++ grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py	2015-01-14 06:08:03 UTC (rev 64157)
@@ -215,7 +215,6 @@
         tinfo_string="""id=a1 at test1
                                 name=a1
                                 mapset=test1
-                                creator=soeren
                                 temporal_type=absolute
                                 start_time=2001-01-01 00:00:00
                                 end_time=2001-02-01 00:00:00 """
@@ -226,7 +225,6 @@
         tinfo_string="""id=a1 at test2
                                 name=a1
                                 mapset=test2
-                                creator=soeren
                                 end_time=2001-03-01 00:00:00 """
@@ -237,7 +235,6 @@
         tinfo_string="""id=a1 at test3
                                 name=a1
                                 mapset=test3
-                                creator=soeren
                                 end_time=2001-04-01 00:00:00 """
@@ -248,7 +245,6 @@
         tinfo_string="""id=a1 at test4
                                 name=a1
                                 mapset=test4
-                                creator=soeren
                                 end_time=2001-05-01 00:00:00 """
Modified: grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
--- grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py	2015-01-14 06:06:28 UTC (rev 64156)
+++ grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py	2015-01-14 06:08:03 UTC (rev 64157)
@@ -161,7 +161,6 @@
         tinfo_string="""id=a1 at test3d1
                                 name=a1
                                 mapset=test3d1
-                                creator=soeren
@@ -172,7 +171,6 @@
         tinfo_string="""id=a1 at test3d2
                                 name=a1
                                 mapset=test3d2
-                                creator=soeren
@@ -183,7 +181,6 @@
         tinfo_string="""id=a1 at test3d3
                                 name=a1
                                 mapset=test3d3
-                                creator=soeren
@@ -194,7 +191,6 @@
         tinfo_string="""id=a1 at test3d4
                                 name=a1
                                 mapset=test3d4
-                                creator=soeren
Modified: grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
--- grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py	2015-01-14 06:06:28 UTC (rev 64156)
+++ grass/branches/releasebranch_7_0/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py	2015-01-14 06:08:03 UTC (rev 64157)
@@ -171,7 +171,6 @@
         tinfo_string="""id=a1 at testvect1
                                 name=a1
                                 mapset=testvect1
-                                creator=soeren
@@ -182,7 +181,6 @@
         tinfo_string="""id=a1 at testvect2
                                 name=a1
                                 mapset=testvect2
-                                creator=soeren
@@ -193,7 +191,6 @@
         tinfo_string="""id=a1 at testvect3
                                 name=a1
                                 mapset=testvect3
-                                creator=soeren
@@ -204,7 +201,6 @@
         tinfo_string="""id=a1 at testvect4
                                 name=a1
                                 mapset=testvect4
-                                creator=soeren
Modified: grass/branches/releasebranch_7_0/testsuite/raster/raster_md5test.sh
--- grass/branches/releasebranch_7_0/testsuite/raster/raster_md5test.sh	2015-01-14 06:06:28 UTC (rev 64156)
+++ grass/branches/releasebranch_7_0/testsuite/raster/raster_md5test.sh	2015-01-14 06:08:03 UTC (rev 64157)
@@ -48,7 +48,7 @@
 cleanup()
  echo "Removing temporary map"
- g.remove -f type=rast name=$TMPNAME > /dev/null
+ g.remove -f type=raster name=$TMPNAME > /dev/null
 # check if a MASK is already present:
@@ -68,7 +68,7 @@
  #restore user mask if present:
  if test -f $LOCATION/cell/$USERMASK ; then
   echo "Restoring user MASK"
-  g.remove -f type=rast name=MASK > /dev/null
+  g.remove -f type=raster name=MASK > /dev/null
   g.rename raster=$USERMASK,MASK > /dev/null
  fi
Modified: grass/branches/releasebranch_7_0/testsuite/raster/rhemisphere.sh
--- grass/branches/releasebranch_7_0/testsuite/raster/rhemisphere.sh	2015-01-14 06:06:28 UTC (rev 64156)
+++ grass/branches/releasebranch_7_0/testsuite/raster/rhemisphere.sh	2015-01-14 06:08:03 UTC (rev 64157)
@@ -24,7 +24,7 @@
 cleanup()
- g.remove --q -f type=rast name=$TMP > /dev/null
+ g.remove --q -f type=raster name=$TMP > /dev/null
