[GRASS-SVN] r64266 - grass-addons/grass7/imagery/i.spec.unmix
Tue Jan 20 14:33:06 PST 2015
Author: neteler
Date: 2015-01-20 14:33:06 -0800 (Tue, 20 Jan 2015)
New Revision: 64266
Removed:
   grass-addons/grass7/imagery/i.spec.unmix/la_extra.c
   grass-addons/grass7/imagery/i.spec.unmix/la_extra.h
   grass-addons/grass7/imagery/i.spec.unmix/main.c
   grass-addons/grass7/imagery/i.spec.unmix/open.c
i.spec.unmix Addon: lapack matrix/vector functions moved to libgmath (r64265)
Deleted: grass-addons/grass7/imagery/i.spec.unmix/la_extra.c
--- grass-addons/grass7/imagery/i.spec.unmix/la_extra.c	2015-01-20 22:31:51 UTC (rev 64265)
+++ grass-addons/grass7/imagery/i.spec.unmix/la_extra.c	2015-01-20 22:33:06 UTC (rev 64266)
@@ -1,175 +0,0 @@
-/* TODO: move to GMATHLIB */
-#include <stdio.h>		/* needed here for ifdef/else */
-#include <stdlib.h>
-#include <string.h>
-#include <math.h>
-#include <grass/config.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/la.h>
-#include "la_extra.h"
-mat_struct *G_matrix_resize(mat_struct * in, int rows, int cols)
-  mat_struct *matrix;
-  matrix = G_matrix_init(rows, cols, rows);
-  int i, j, p, index = 0;
-  for (i = 0; i < rows; i++)
-    for (j = 0; j < cols; j++)
-     G_matrix_set_element(matrix, i, j,	 G_matrix_get_element(in, i, j));
-/*    matrix->vals[index++] = in->vals[i + j * cols];*/
-  int old_size = in->rows * in->cols;
-  int new_size = rows * cols;
-  if (new_size > old_size)
-    for (p = old_size; p < new_size; p++)
-      G_matrix_set_element(matrix, i, j, 0.0);
-  return (matrix);
-mat_struct *G_matrix_scalar_mul(double scalar, mat_struct * matrix, mat_struct * out)
-  int m, n, i, j;
-  int index = 0;
-  if (matrix == NULL)
-    G_warning (_("Input matrix is uninitialized"));
-    return NULL;
-  if (out == NULL)
-	  out = G_matrix_init(matrix->rows, matrix->cols, matrix->rows);
-  if (out->rows != matrix->rows || out->cols != matrix->cols)
-	  out = G_matrix_resize(out, matrix->rows, matrix->cols);
-  m = matrix->rows;
-  n = matrix->cols;
-  for (i = 0; i < m; i++)
-  	for (j = 0; j < n; j++)
-  	  doublereal value = scalar * G_matrix_get_element(matrix, i, j);
-	    G_matrix_set_element (out, i,j, value);
-  return (out);
-vec_struct* G_mat_vector_product(mat_struct * A, vec_struct * b,vec_struct *out)
-  unsigned int i, m, n, j;
-  register doublereal sum;
-//G_message("A=%d,%d,%d", A->cols, A->rows, A->ldim);
-//G_message("B=%d,%d,%d", b->cols, b->rows, b->ldim);
-  if (A->cols != b->cols) {
-    G_warning (_("Input matrix and vector have differing dimensions1"));
-    return NULL;
-  if (!out) {
-    G_warning (_("Output vector is uninitialized"));
-    return NULL;
-/*  if (out->ldim != A->rows) {*/
-/*    G_warning (_("Output vector has incorrect dimension"));*/
-/*    exit(1);*/
-/*    return NULL;*/
-  m = A->rows;
-  n = A->cols;
-  for (i = 0; i < m; i++) {
-    sum = 0.0;
-    int width = A->rows;
-    for (j = 0; j < n; j++) {
-        sum +=G_matrix_get_element(A, i, j) * G_matrix_get_element(b, 0, j);
-        /*sum += A->vals[i + j * width] * b->vals[j];*/
-	    out->vals[i] = sum;
-  return (out);
-vec_struct *
-G_vector_product (vec_struct *v1, vec_struct *v2, vec_struct *out)
-    int idx1, idx2, idx0;
-    int i;
-    if (!out->is_init) {
-        return NULL;
-    if (v1->type != v2->type) {
-        G_warning (_("Vectors are not of the same type"));
-        return NULL;
-    if (v1->type != out->type) {
-        G_warning (_("Output vector is of incorrect type"));
-        return NULL;
-    if (v1->type == MATRIX_) {
-        G_warning (_("Matrices not allowed"));
-        return NULL;
-    if ((v1->type == ROWVEC_ && v1->cols != v2->cols) ||
-        (v1->type == COLVEC_ && v1->rows != v2->rows))
-        G_warning (_("Vectors have differing dimensions"));
-        return NULL;
-    if ((v1->type == ROWVEC_ && v1->cols != out->cols) ||
-        (v1->type == COLVEC_ && v1->rows != out->rows))
-        G_warning (_("Output vector has incorrect dimension"));
-        return NULL;
-#if defined(HAVE_LAPACK) && defined(HAVE_LIBBLAS)
-    f77_dhad (v1->cols, 1.0, v1->vals, 1, v2->vals, 1, 0.0, out->vals, 1.0);
-#else
-    idx1 = (v1->v_indx > 0) ? v1->v_indx : 0;
-    idx2 = (v2->v_indx > 0) ? v2->v_indx : 0;
-    idx0 = (out->v_indx > 0) ? out->v_indx : 0;
-    if (v1->type == ROWVEC_) {
-        for (i = 0; i < v1->cols; i++)
-            G_matrix_set_element(out, idx0, i,
-			   G_matrix_get_element(v1, idx1, i) *
-			   G_matrix_get_element(v2, idx2, i));
-    } else {
-        for (i = 0; i < v1->rows; i++)
-            G_matrix_set_element(out, i, idx0,
-			   G_matrix_get_element(v1, i, idx1) *
-			   G_matrix_get_element(v2, i, idx2));
-#endif
-    return out;
Deleted: grass-addons/grass7/imagery/i.spec.unmix/la_extra.h
--- grass-addons/grass7/imagery/i.spec.unmix/la_extra.h	2015-01-20 22:31:51 UTC (rev 64265)
+++ grass-addons/grass7/imagery/i.spec.unmix/la_extra.h	2015-01-20 22:33:06 UTC (rev 64266)
@@ -1,11 +0,0 @@
-#include <stdio.h>
-#include <grass/blas.h>
-#include <grass/lapack.h>
-mat_struct *G_matrix_scalar_mul(double scalar, mat_struct * matrix, mat_struct * out);
-vec_struct* G_vector_product (vec_struct *v1, vec_struct *v2, vec_struct *out);
-vec_struct* G_mat_vector_product(mat_struct * A, vec_struct * b,vec_struct *out);
Modified: grass-addons/grass7/imagery/i.spec.unmix/main.c
--- grass-addons/grass7/imagery/i.spec.unmix/main.c	2015-01-20 22:31:51 UTC (rev 64265)
+++ grass-addons/grass7/imagery/i.spec.unmix/main.c	2015-01-20 22:33:06 UTC (rev 64266)
@@ -3,15 +3,15 @@
  * MODULE:       i.spec.unmix
- * AUTHOR(S):    Markus Neteler  <neteler osgeo.org>: Original GRASS 5 version
- *               Mohammed Rashad <rashadkm gmail.com> (update to GRASS 7)
+ * AUTHOR(S):    Markus Neteler  <neteler osgeo.org>: 1998, Original GRASS 5 version
+ *               Mohammed Rashad <rashadkm gmail.com>: 2012, update to GRASS 7
  * PURPOSE:      Spectral mixture analysis of satellite/aerial images
  * Notes:        The original version was implemented with MESCHACH, the actual
  *               version is instead using BLAS/LAPACK via GMATHLIB.
  *               An error minimization approach is used instead of Single Value
- *               Decomposition (SVD) which is numerically unstable. See the
+ *               Decomposition (SVD) which is numerically unstable. See MN's
  *               related journal publication from 2005 for details.
  * COPYRIGHT:    (C) 1999-2012 by the GRASS Development Team
@@ -46,9 +46,7 @@
 #include "global.h"
 #define GAMMA 10		/* last row value in Matrix and last b vector element
 				 * for constraint Sum xi = 1 (GAMMA=weight)
@@ -346,7 +344,7 @@
 	    /* solve with iterative solution: */
 	    while (fabs(change) > 0.0001) {
-		G_mat_vector_product(A_tilde, startvector,
+		G_matvect_product(A_tilde, startvector,
 				     A_times_startvector);
 		G_vector_sub(A_times_startvector, b_gamma, errorvector);
@@ -354,7 +352,7 @@
 		A_tilde_trans_mu =
 		    G_matrix_scalar_mul(mu, A_tilde_trans, A_tilde_trans_mu);
-		G_mat_vector_product(A_tilde_trans_mu, errorvector, temp);
+		G_matvect_product(A_tilde_trans_mu, errorvector, temp);
 		G_vector_sub(startvector, temp, startvector);	/* update startvector */
 		for (k = 0; k < A_tilde->cols; k++)
@@ -417,6 +415,7 @@
 	Rast_close(resultfd[i]);
+/* TODO: avoid system calls, use modern approach for setting colors */
 	/* make grey scale color table */
 	sprintf(result_name, "%s.%d", parm.result->answer, (i + 1));
 	sprintf(command, "r.colors map=%s color=rules <<EOF\n"
Modified: grass-addons/grass7/imagery/i.spec.unmix/open.c
--- grass-addons/grass7/imagery/i.spec.unmix/open.c	2015-01-20 22:31:51 UTC (rev 64265)
+++ grass-addons/grass7/imagery/i.spec.unmix/open.c	2015-01-20 22:33:06 UTC (rev 64266)
@@ -14,7 +14,6 @@
 #include <grass/gmath.h>
 #include "global.h"
 int G_matrix_read2(FILE * fp, mat_struct * out); /* Modified version of G_matrix_read(..). */
