[GRASS-SVN] r64281 - grass/trunk/vector/v.overlay
Thu Jan 22 02:26:46 PST 2015
Author: mmetz
Date: 2015-01-22 02:26:46 -0800 (Thu, 22 Jan 2015)
New Revision: 64281
   grass/trunk/vector/v.overlay/main.c
v.overlay: accommodate SQLite
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c	2015-01-22 09:50:42 UTC (rev 64280)
+++ grass/trunk/vector/v.overlay/main.c	2015-01-22 10:26:46 UTC (rev 64281)
@@ -237,8 +237,6 @@
 			  Fi->database, Fi->driver);
         db_set_error_handler_driver(driver);
-	db_begin_transaction(driver);
     else {
 	driver = NULL;
@@ -392,12 +390,20 @@
 		continue;
-	    in_driver =
-		db_start_driver_open_database(inFi->driver, inFi->database);
-	    if (in_driver == NULL) {
-		G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
-			      inFi->database, inFi->driver);
+	    /* Open input driver and database */
+	    if (strcmp(inFi->driver, Fi->driver) == 0
+		&& strcmp(inFi->database, Vect_subst_var(Fi->database, &Out)) == 0) {
+		G_debug(3, "Use the same driver");
+		in_driver = driver;
+	    else {
+		in_driver =
+		    db_start_driver_open_database(inFi->driver, inFi->database);
+		if (in_driver == NULL) {
+		    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+				  inFi->database, inFi->driver);
 	    sprintf(buf, "select * from %s", inFi->table);
 	    db_set_string(&sql, buf);
@@ -538,7 +544,8 @@
 	    db_table_to_sql(Table, &sql);
-	    db_close_database_shutdown_driver(in_driver);
+	    if (in_driver != driver)
+		db_close_database_shutdown_driver(in_driver);
@@ -583,6 +590,8 @@
 	/* Table created, now we can write dblink */
 	Vect_map_add_dblink(&Out, ofield[0], NULL, Fi->table, GV_KEY_COLUMN,
+	db_begin_transaction(driver);
     /* AREA x AREA */
