[GRASS-SVN] r64352 - grass-addons/grass7/raster/r.in.proj
Thu Jan 29 00:47:25 PST 2015
Author: mmetz
Date: 2015-01-29 00:47:24 -0800 (Thu, 29 Jan 2015)
New Revision: 64352
   grass-addons/grass7/raster/r.in.proj/r.in.proj.html
   grass-addons/grass7/raster/r.in.proj/r.in.proj.py
r.in.proj: fix extents=input
Modified: grass-addons/grass7/raster/r.in.proj/r.in.proj.html
--- grass-addons/grass7/raster/r.in.proj/r.in.proj.html	2015-01-28 23:05:18 UTC (rev 64351)
+++ grass-addons/grass7/raster/r.in.proj/r.in.proj.html	2015-01-29 08:47:24 UTC (rev 64352)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
-<em>r.in.proj</em> imports selected bands froma GDAL raster datasouce
+<em>r.in.proj</em> imports selected bands from a GDAL raster datasouce
 into the current location and mapset. If the projection of the input
 does not match the projection of the location, the input is reprojected
 into the current location. If the projection of the input does match
Modified: grass-addons/grass7/raster/r.in.proj/r.in.proj.py
--- grass-addons/grass7/raster/r.in.proj/r.in.proj.py	2015-01-28 23:05:18 UTC (rev 64351)
+++ grass-addons/grass7/raster/r.in.proj/r.in.proj.py	2015-01-29 08:47:24 UTC (rev 64352)
@@ -55,10 +55,10 @@
 #% answer: 300
 #%end
 #%option G_OPT_R_OUTPUT
-#% required: no
+#% required: yes
 #% multiple: no
 #% key_desc: name
-#% description: Name for output raster map (default: same as 'input')
+#% description: Name for output raster map
 #% guisection: Output
 #%end
 #%option
@@ -94,6 +94,11 @@
 #% description: Import and reproject (default: estimate resolution only)
 #%end
+#%flag
+#% key: n
+#% description: Do not perform region cropping optimization
+#% guisection: Output
+#%end
 import sys
@@ -188,7 +193,7 @@
     # if it fails, return
     if returncode != 0:
         grass.fatal(_("Unable to import GDAL dataset <%s>") % GDALdatasource)
-        sys.exit(0)
+        sys.exit(1)
     f = open(srcgisrc, 'w')
     f.write('DEBUG: 0\n')
@@ -231,7 +236,7 @@
         outres = (region['ewres'] + region['nsres']) / 2.0
     rflags = None
-    if options['extents'] == 'input':
+    if flags['n']:
         rflags = 'n'
     for outfile in outfiles:
@@ -241,33 +246,33 @@
         e = region['e']
         w = region['w']
+        grass.use_temp_region()
             # r.proj -g
             try:
                 tgtextents = grass.read_command('r.proj', location = tmploc,
                                                 mapset = 'PERMANENT',
                                                 input = outfile, flags = 'g',
-                                                memory = memory)
+                                                memory = memory, quiet = True)
             except:
                 grass.fatal(_("Unable to get reprojected map extents"))
                 sys.exit(1)
-            srcregion = grass.parse_key_val(tgtextents, vsep = ' ')
+            srcregion = grass.parse_key_val(tgtextents, val_type = float, vsep = ' ')
             n = srcregion['n']
             s = srcregion['s']
             e = srcregion['e']
             w = srcregion['w']
-        grass.use_temp_region()
-        grass.run_command('g.region', n = n, s = s, e = e, w = w)
+            grass.run_command('g.region', n = n, s = s, e = e, w = w)
         # v.in.region in tgt
         vreg = 'vreg_' + str(os.getpid())
         grass.run_command('v.in.region', output = vreg, quiet = True)
+        grass.del_temp_region()
-        grass.del_temp_region()
         # reproject to src
         # switch to temp location
         os.environ['GISRC'] = str(srcgisrc)
@@ -275,7 +280,7 @@
                           location = tgtloc, mapset = tgtmapset, quiet = True)
         returncode = ps.wait()
         if returncode != 0:
-            grass.fatal(_("Unable to to reproject to source location"))
+            grass.fatal(_("Unable to reproject to source location"))
             sys.exit(1)
         # set region from region vector
@@ -297,6 +302,12 @@
         grass.message(_("Specified target resolution: %g") % outres)
         if do_import:
+            if options['extents'] == 'input':
             # r.proj
             grass.message(_("Reprojecting <%s>...") % outfile)
             ps = grass.start_command('r.proj', location = tmploc,
@@ -312,6 +323,8 @@
                 grass.fatal(_("The reprojected raster <%s> is empty") % outfile)
                 sys.exit(1)
     if do_import:
         if group:
