[GRASS-SVN] r65534 - grass/trunk/tools
Thu Jul 2 00:43:19 PDT 2015
Author: zarch
Date: 2015-07-02 00:43:19 -0700 (Thu, 02 Jul 2015)
New Revision: 65534
Added:
   grass/trunk/tools/parser_standard_options.py
Add tool to generate a csv/html table from lib/gis/parser_standard_options.c file
Added: grass/trunk/tools/parser_standard_options.py
--- grass/trunk/tools/parser_standard_options.py	                        (rev 0)
+++ grass/trunk/tools/parser_standard_options.py	2015-07-02 07:43:19 UTC (rev 65534)
@@ -0,0 +1,159 @@
+# -*- coding: utf-8 -*-
+Created on Fri Jun 26 19:10:58 2015
+ at author: pietro
+from __future__ import print_function
+import argparse
+from pprint import pprint
+import sys
+from urllib import urlopen
+def parse_options(lines, startswith='Opt'):
+    def split_in_groups(lines):
+        def count_par_diff(line):
+            open_par = line.count('(')
+            close_par = line.count(')')
+            return open_par - close_par
+        res = None
+        diff = 0
+        for line in lines:
+            if line.startswith('case'):
+                optname = line.split()[1][:-1]
+                res = []
+#                if optname == 'G_OPT_R_BASENAME_INPUT':
+#                    import ipdb; ipdb.set_trace()
+            elif line == 'break;':
+                diff = 0
+                yield optname, res
+            elif line.startswith('G_'):
+                diff = count_par_diff(line)
+            elif diff > 0:
+                diff -= count_par_diff(line)
+            else:
+                res.append(line) if res is not None else None
+    def split_opt_line(line):
+        index = line.index('=')
+        key = line[:index].strip()
+        default = line[index + 1:].strip()
+        if default.startswith('_('):
+            default = default[2:]
+        return key, default
+    def parse_glines(glines):
+        res = {}
+        key = None
+        for line in glines:
+            if line.startswith('/*'):
+                continue
+            if line.startswith(startswith) and line.endswith(';'):
+                key, default = [w.strip() for w in split_opt_line(line[5:])]
+                res[key] = default
+            elif line.startswith(startswith):
+                key, default = split_opt_line(line[5:])
+                res[key] = [default, ]
+            else:
+                if key is not None:
+                    if key not in res:
+                        res[key] = []
+                    start, end = 0, -1
+                    if line.startswith('_('):
+                        start = 2
+                    if line.endswith(');'):
+                        end = -3
+                    elif line.endswith(';'):
+                        end = -2
+                    res[key].append(line[start:end])
+        # pprint(glines)
+        # pprint(res)
+        return res
+    def clean_value(val):
+        if isinstance(val, list):
+            val = ' '.join(val)
+        return (val.replace('"', '').replace("\'", "'").strip().strip(';')
+                ).strip().strip('_(').strip().strip(')').strip()
+    # with open(optionfile, mode='r') as optfile:
+    lines = [line.strip() for line in lines]
+    result = []
+    for optname, glines in split_in_groups(lines):
+        if glines:
+            res = parse_glines(glines)
+            if res:
+                for key, val in res.items():
+                    res[key] = clean_value(val)
+                result.append((optname, res))
+    return result
+class OptTable(object):
+    def __init__(self, list_of_dict):
+        self.options = list_of_dict
+        self.columns = sorted(set([key for _, d in self.options
+                                   for key in d.keys()]))
+    def csv(self, delimiter=';', endline='\n'):
+        """Return a CSV string with the options"""
+        csv = []
+        csv.append(delimiter.join(self.columns))
+        for optname, options in self.options:
+            opts = [options.get(col, '') for col in self.columns]
+            csv.append(delimiter.join([optname, ] + opts))
+        return endline.join(csv)
+    def html(self, endline='\n', indent='  ', toptions='border=1'):
+        """Return a HTML table with the options"""
+        html = ["<table{}>".format(' ' + toptions if toptions else '')]
+        # write headers
+        html.append(indent + "<tr>")
+        html.append(indent * 2 + "<td>{0}</td>".format('option'))
+        for col in self.columns:
+            html.append(indent * 2 + "<td>{0}</td>".format(col))
+        html.append(indent + "</tr>")
+            html.append(indent * 2 + "<td>{0}</td>".format(optname))
+                            "<td>{0}</td>".format(options.get(col, '')))
+        html.append("</table>")
+        return endline.join(html)
+    def _repr_html_(self):
+        """Method used by IPython notebook"""
+        return self.html()
+if __name__ == "__main__":
+    URL = ('https://trac.osgeo.org/grass/browser/grass/'
+           'trunk/lib/gis/parser_standard_options.c?format=txt')
+    parser = argparse.ArgumentParser(description='Extract GRASS default '
+                                                 'options from link.')
+    parser.add_argument('-f', '--format', default='html', dest='format',
+                        choices=['html', 'csv'],
+                        help='Define the output format')
+    parser.add_argument('-l', '--link', default=URL, dest='url', type=str,
+                        help='Provide the url with the file to parse')
+    parser.add_argument('-t', '--text', default='', dest='text',
+                        type=argparse.FileType('r'),
+                        help='Provide the file to parse')
+    parser.add_argument('-o', '--output', default=sys.stdout, dest='output',
+                        type=argparse.FileType('w'),
+    parser.add_argument('-s', '--starts-with', default='Opt',
+                        dest='startswith', type=str,
+                        help='Extract only the options that starts with this')
+    args = parser.parse_args()
+    cfile = args.text if args.text else urlopen(args.url, proxies=None)
+    options = OptTable(parse_options(cfile.readlines(),
+                                     startswith=args.startswith))
+    print(getattr(options, args.format)(), file=args.output)
+    args.output.close()
Property changes on: grass/trunk/tools/parser_standard_options.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
