[GRASS-SVN] r65588 - grass/trunk/raster/r.proj
Tue Jul 14 08:50:20 PDT 2015
Author: martinl
Date: 2015-07-14 08:50:20 -0700 (Tue, 14 Jul 2015)
New Revision: 65588
   grass/trunk/raster/r.proj/main.c
r.proj: reorder options to avoid user confusion
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c	2015-07-14 15:49:11 UTC (rev 65587)
+++ grass/trunk/raster/r.proj/main.c	2015-07-14 15:50:20 UTC (rev 65588)
@@ -147,11 +147,6 @@
     module->description =
 	_("Re-projects a raster map from given location to the current location.");
-    inmap = G_define_standard_option(G_OPT_R_INPUT);
-    inmap->description = _("Name of input raster map to re-project");
-    inmap->required = NO;
-    inmap->guisection = _("Source");
     inlocation = G_define_standard_option(G_OPT_M_LOCATION);
     inlocation->required = YES;
     inlocation->label = _("Location containing input raster map");
@@ -162,9 +157,13 @@
     imapset->description = _("Default: name of current mapset");
     imapset->guisection = _("Source");
+    inmap = G_define_standard_option(G_OPT_R_INPUT);
+    inmap->description = _("Name of input raster map to re-project");
+    inmap->required = NO;
+    inmap->guisection = _("Source");
     indbase = G_define_standard_option(G_OPT_M_DBASE);
     indbase->label = _("Path to GRASS database of input location");
-    indbase->guisection = _("Source");
     outmap = G_define_standard_option(G_OPT_R_OUTPUT);
     outmap->required = NO;
