[GRASS-SVN] r65712 - grass/trunk/vector/v.buffer
Mon Jul 20 09:19:31 PDT 2015
Author: neteler
Date: 2015-07-20 09:19:31 -0700 (Mon, 20 Jul 2015)
New Revision: 65712
Added:
   grass/trunk/vector/v.buffer/v_buffer_no_cap.png
   grass/trunk/vector/v.buffer/v_buffer_rounded_cap.png
   grass/trunk/vector/v.buffer/v_buffer_square_cap.png
   grass/trunk/vector/v.buffer/v.buffer.html
   grass/trunk/vector/v.buffer/v_buffer_area.png
   grass/trunk/vector/v.buffer/v_buffer_area_s.png
   grass/trunk/vector/v.buffer/v_buffer_line.png
   grass/trunk/vector/v.buffer/v_buffer_line_c.png
   grass/trunk/vector/v.buffer/v_buffer_line_s.png
v.buffer manual: explain corners (caps) with screenshots
Property changes on: grass/trunk/vector/v.buffer
___________________________________________________________________
Modified: svn:ignore
   - OBJ.*
   + OBJ.*
*.tmp.html
Modified: grass/trunk/vector/v.buffer/v.buffer.html
--- grass/trunk/vector/v.buffer/v.buffer.html	2015-07-20 16:16:28 UTC (rev 65711)
+++ grass/trunk/vector/v.buffer/v.buffer.html	2015-07-20 16:19:31 UTC (rev 65712)
@@ -31,6 +31,13 @@
 <h3>Corner settings</h3>
+The following corners (also called "cap") exist:
+<ul>
+<li>no cap:       <img src="v_buffer_no_cap.png" valign="middle" alt="line buffer: no cap"></li>
+<li>rounded cap: <img src="v_buffer_rounded_cap.png" valign="middle" alt="line buffer: rounded cap"></li>
+<li>square cap: <img src="v_buffer_square_cap.png" valign="middle" alt="line buffer: square cap"></li>
+</ul>
 By default <em>v.buffer</em> creates rounded buffers (blue color on
 figure below):
Property changes on: grass/trunk/vector/v.buffer/v_buffer_area.png
Modified: svn:mime-type
   - application/octet-stream
   + image/png
Property changes on: grass/trunk/vector/v.buffer/v_buffer_area_s.png
   + image/png
Property changes on: grass/trunk/vector/v.buffer/v_buffer_line.png
   + image/png
Property changes on: grass/trunk/vector/v.buffer/v_buffer_line_c.png
   + image/png
Property changes on: grass/trunk/vector/v.buffer/v_buffer_line_s.png
   + image/png
Added: grass/trunk/vector/v.buffer/v_buffer_no_cap.png
(Binary files differ)
Property changes on: grass/trunk/vector/v.buffer/v_buffer_no_cap.png
Added: svn:mime-type
   + image/png
Added: grass/trunk/vector/v.buffer/v_buffer_rounded_cap.png
Property changes on: grass/trunk/vector/v.buffer/v_buffer_rounded_cap.png
   + image/png
Added: grass/trunk/vector/v.buffer/v_buffer_square_cap.png
Property changes on: grass/trunk/vector/v.buffer/v_buffer_square_cap.png
   + image/png
