[GRASS-SVN] r65753 - grass/branches/releasebranch_7_0
Tue Jul 21 04:14:50 PDT 2015
Author: martinl
Date: 2015-07-21 04:14:50 -0700 (Tue, 21 Jul 2015)
New Revision: 65753
Added:
   grass/branches/releasebranch_7_0/README.debian
Removed:
   grass/branches/releasebranch_7_0/debian/
move README.debian to root directory, remove debian directory to simplify debian packaging
Copied: grass/branches/releasebranch_7_0/README.debian (from rev 65752, grass/branches/releasebranch_7_0/debian/README.debian)
--- grass/branches/releasebranch_7_0/README.debian	                        (rev 0)
+++ grass/branches/releasebranch_7_0/README.debian	2015-07-21 11:14:50 UTC (rev 65753)
@@ -0,0 +1,78 @@
+# For preparing GRASS Debian package you should download the packaging
+# rules from DebianGIS's git repository, then use the Debian build scripts
+# to construct the .deb files.
+# Make sure git and the debian build scripts are installed:
+  sudo apt-get install git subversion devscripts
+# and download the latest svn copy of GRASS:
+  cd src/grass/
+  svn checkout https://svn.osgeo.org/grass/grass/trunk g7_trunk
+# From the grass source dir download the packaging rules (the contents
+#  of debiangis/grass/ can be ignored, only the debian/ dir is needed):
+  git clone git://git.debian.org/git/pkg-grass/grass.git debiangis
+  ln -s debiangis/grass/debian debian
+# If you haven't built GRASS from source on this machine before, you'll
+# have to install a bunch of -dev packages. Look at the debian/control
+# file and install the packages on the "Build-depends" lines.
+  sudo apt-get install flex bison libreadline-dev libncurses5-dev # ... etc.
+# You can take care of this pretty much automatically by running
+ dpkg-checkbuilddeps
+# in the main grass source directory, or with:
+ sudo apt-get build-dep grass
+# (for that to work, make sure the 'deb-src' lines are active in
+# your /etc/apt/sources.list file)
+# Once all of the build dependencies are installed, in your favorite text
+# editor open debian/changelog and adjust the version number on the top
+# line to reflect the GRASS SVN checkout number.
+# e.g. for r50539: grass (7.0+svn50539-0) unstable; urgency=low
+  nano debian/changelog
+# After that, you can build the current version of GRASS with
+  cd g7_trunk
+  ln -s ../debian .
+  svn up
+  debuild -i -uc -us -b
+#TODO: does 'debuild -i -uc -us -b -j4' work for parallel build??
+#      it works for debuild'ing qgis; need to test with grass
+# run from the main GRASS source directory. After the packages are
+# generated, you can install them with:
+  sudo dpkg -i ../grass*.deb
+# (make sure to move away older grass*.deb files first)
+# to try again, first clean out the old build by running:
+#  (from the main source dir)
+  debuild clean
+# then repeat the build process
+FIXME: how to download just the grass/debian/ directory from git
+       and not the whole thing?
+H.Bowman
+Last changed: $Date$
