[GRASS-SVN] r65468 - grass/trunk
Sun Jun 14 13:19:39 PDT 2015
Author: neteler
Date: 2015-06-14 13:19:39 -0700 (Sun, 14 Jun 2015)
New Revision: 65468
   grass/trunk/config.guess
   grass/trunk/config.sub
config.guess + config.sub: updated from http://git.savannah.gnu.org/cgit/config.git/plain/
Modified: grass/trunk/config.guess
--- grass/trunk/config.guess	2015-06-14 20:19:10 UTC (rev 65467)
+++ grass/trunk/config.guess	2015-06-14 20:19:39 UTC (rev 65468)
@@ -2,7 +2,7 @@
 # Attempt to guess a canonical system name.
 #   Copyright 1992-2015 Free Software Foundation, Inc.
-timestamp='2015-01-01'
+timestamp='2015-03-04'
 # This file is free software; you can redistribute it and/or modify it
 # under the terms of the GNU General Public License as published by
@@ -168,20 +168,27 @@
 	# Note: NetBSD doesn't particularly care about the vendor
 	# portion of the name.  We always set it to "unknown".
 	sysctl="sysctl -n hw.machine_arch"
-	UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
-	    /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
+	UNAME_MACHINE_ARCH=`(uname -p 2>/dev/null || \
+	    /sbin/$sysctl 2>/dev/null || \
+	    /usr/sbin/$sysctl 2>/dev/null || \
+	    echo unknown)`
 	case "${UNAME_MACHINE_ARCH}" in
 	    armeb) machine=armeb-unknown ;;
 	    arm*) machine=arm-unknown ;;
 	    sh3el) machine=shl-unknown ;;
 	    sh3eb) machine=sh-unknown ;;
 	    sh5el) machine=sh5le-unknown ;;
+	    earmv*)
+		arch=`echo ${UNAME_MACHINE_ARCH} | sed -e 's,^e\(armv[0-9]\).*$,\1,'`
+		endian=`echo ${UNAME_MACHINE_ARCH} | sed -ne 's,^.*\(eb\)$,\1,p'`
+		machine=${arch}${endian}-unknown
 	    *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
 	esac
 	# The Operating System including object format, if it has switched
 	# to ELF recently, or will in the future.
-	    arm*|i386|m68k|ns32k|sh3*|sparc|vax)
+	    arm*|earm*|i386|m68k|ns32k|sh3*|sparc|vax)
 		eval $set_cc_for_build
 		if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
 			| grep -q __ELF__
@@ -197,6 +204,13 @@
 		os=netbsd
 	esac
+	# Determine ABI tags.
+	case "${UNAME_MACHINE_ARCH}" in
+	    earm*)
+		expr='s/^earmv[0-9]/-eabi/;s/eb$//'
+		abi=`echo ${UNAME_MACHINE_ARCH} | sed -e "$expr"`
+	esac
 	# The OS release
 	# Debian GNU/NetBSD machines have a different userland, and
 	# thus, need a distinct triplet. However, they do not need
@@ -213,7 +227,7 @@
 	# Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
 	# contains redundant information, the shorter form:
 	# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
-	echo "${machine}-${os}${release}"
+	echo "${machine}-${os}${release}${abi}"
 	exit ;;
     *:Bitrig:*:*)
 	UNAME_MACHINE_ARCH=`arch | sed 's/Bitrig.//'`
@@ -933,6 +947,9 @@
     crisv32:Linux:*:*)
 	echo ${UNAME_MACHINE}-axis-linux-${LIBC}
 	exit ;;
+    e2k:Linux:*:*)
+	echo ${UNAME_MACHINE}-unknown-linux-${LIBC}
+	exit ;;
     frv:Linux:*:*)
 	exit ;;
Modified: grass/trunk/config.sub
--- grass/trunk/config.sub	2015-06-14 20:19:10 UTC (rev 65467)
+++ grass/trunk/config.sub	2015-06-14 20:19:39 UTC (rev 65468)
@@ -2,7 +2,7 @@
 # Configuration validation subroutine script.
+timestamp='2015-03-08'
@@ -117,7 +117,7 @@
 case $maybe_os in
   nto-qnx* | linux-gnu* | linux-android* | linux-dietlibc | linux-newlib* | \
   linux-musl* | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | kfreebsd*-gnu* | \
-  knetbsd*-gnu* | netbsd*-gnu* | \
+  knetbsd*-gnu* | netbsd*-gnu* | netbsd*-eabi* | \
   kopensolaris*-gnu* | \
   storm-chaos* | os2-emx* | rtmk-nova*)
     os=-$maybe_os
@@ -259,7 +259,7 @@
 	| bfin \
 	| c4x | c8051 | clipper \
 	| d10v | d30v | dlx | dsp16xx \
-	| epiphany \
+	| e2k | epiphany \
 	| fido | fr30 | frv | ft32 \
 	| h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
 	| hexagon \
@@ -381,7 +381,7 @@
 	| c[123]* | c30-* | [cjt]90-* | c4x-* \
 	| c8051-* | clipper-* | craynv-* | cydra-* \
 	| d10v-* | d30v-* | dlx-* \
-	| elxsi-* \
+	| e2k-* | elxsi-* \
 	| f30[01]-* | f700-* | fido-* | fr30-* | frv-* | fx80-* \
 	| h8300-* | h8500-* \
 	| hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
@@ -518,6 +518,9 @@
 		basic_machine=i386-pc
 		os=-aros
+        asmjs)
+		basic_machine=asmjs-unknown
 	aux)
 		basic_machine=m68k-apple
 		os=-aux
@@ -1373,7 +1376,7 @@
 	      | -hpux* | -unos* | -osf* | -luna* | -dgux* | -auroraux* | -solaris* \
 	      | -sym* | -kopensolaris* | -plan9* \
 	      | -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
-	      | -aos* | -aros* \
+	      | -aos* | -aros* | -cloudabi* \
 	      | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
 	      | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
 	      | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* \
