[GRASS-SVN] r64943 - in grass-promo/grassposter/2015_EGU_G7_Python: . listings
Mon Mar 30 12:55:16 PDT 2015
Author: wenzeslaus
Date: 2015-03-30 12:55:16 -0700 (Mon, 30 Mar 2015)
New Revision: 64943
Removed:
   grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_ipython_cli.tex
   grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_doc_sc_syntax.tex
   grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_doc_syntax.tex
   grass-promo/grassposter/2015_EGU_G7_Python/main.tex
finish basic script and pygrass boxes, merge R, A and I sections, reorganize boxes
Modified: grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_doc_sc_syntax.tex
--- grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_doc_sc_syntax.tex	2015-03-30 19:29:19 UTC (rev 64942)
+++ grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_doc_sc_syntax.tex	2015-03-30 19:55:16 UTC (rev 64943)
@@ -13,7 +13,8 @@
 \begin{document}
 \begin{lstlisting}[language=Python,linewidth=34.2em]
-r_neighbors = r.neighbors(input='elevation', output='elevation_smooth',
-                          method='median', flags='c')
+r_neighbors = r.neighbors(
+    input='elevation', output='elevation_smooth',
+    method='median', flags='c')
 \end{lstlisting}
 \end{document}
\ No newline at end of file
Modified: grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_doc_syntax.tex
--- grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_doc_syntax.tex	2015-03-30 19:29:19 UTC (rev 64942)
+++ grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_doc_syntax.tex	2015-03-30 19:55:16 UTC (rev 64943)
@@ -16,5 +16,9 @@
 r_neighbors = Module('r.neighbors', input='elevation',
+# get result with alternative method
+r_neighbors.inputs.method = 'mode'
+r_neighbors.outputs.output = 'elevation_smooth_2'
+r_neighbors.run()
 \end{lstlisting}
 \end{document}
Deleted: grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_ipython_cli.tex
--- grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_ipython_cli.tex	2015-03-30 19:29:19 UTC (rev 64942)
+++ grass-promo/grassposter/2015_EGU_G7_Python/listings/pygrass_ipython_cli.tex	2015-03-30 19:55:16 UTC (rev 64943)
@@ -1,18 +0,0 @@
-% taken from grass-promo/grassposter, written by me I think
-\documentclass{standalone}
-\usepackage[active,tightpage]{preview}
-\usepackage{listings}
-\PreviewEnvironment{lstlisting}
-\usepackage[usenames,dvipsnames,svgnames,table]{xcolor}
-\input{listings_settings}
-\begin{document}
-\begin{lstlisting}[linewidth=34.2em]
-ipython notebook
-\end{lstlisting}
-\end{document}
Modified: grass-promo/grassposter/2015_EGU_G7_Python/main.tex
--- grass-promo/grassposter/2015_EGU_G7_Python/main.tex	2015-03-30 19:29:19 UTC (rev 64942)
+++ grass-promo/grassposter/2015_EGU_G7_Python/main.tex	2015-03-30 19:55:16 UTC (rev 64943)
@@ -197,54 +197,25 @@
 % \end{itemize}
-\block{\blocktitlewrap{GRASS GIS Addons}}{
-The GRASS GIS Addons ensure long-term preservation of the code.
-Well maintained modules in Addons can be moved to GRASS GIS core.
-\block{\blocktitlewrap{Alternatives to Python}}{
-GRASS GIS modules are command line tools, so they can be used in shell scripting (e.g. Bash)
-and as subprocesses virtually any language as long as proper environment is set.
+\block{\blocktitlewrap{Automatic creation of GUI and CLI}}{
-The GRASS GIS library povides a C API which is commonly used to create GRASS modules in C and C++.
+The g.parser module provides full parser support for GRASS GIS scripts.
+It provides the creation of help page template, and command line option
+checking. Each command and scripts which uses the GRASS GIS parser can
+publish its parameter and flags description in XML. Through the included
+XML parser this description can be turned into a graphical user interface with
+standardized styling.
-GRASS GIS modules can be used within R using the \pkg{rgrass7} package.
+\includegraphics[width=\linewidth, clip, trim=0 0 0 0]{grass_module}
-\block{\blocktitlewrap{More information}}{
-\newcommand{\qrcodewidth}{1\linewidth}
-\hspace{-0.02\linewidth}
-\begin{tabular}{lll}
-\begin{minipage}{0.1\linewidth}
-\includegraphics[height=\qrcodewidth]{grass_osgeo_org}
-\end{minipage}
-\begin{minipage}{0.27\linewidth}
-GRASS GIS website
-\end{minipage}
-\includegraphics[height=\qrcodewidth]{python_doc}
-\end{minipage}
-\begin{minipage}{0.45\linewidth}
-GRASS GIS Python libraries documentation
-\end{minipage}
-% http://grass.osgeo.org/
-\url{grass.osgeo.org}
-% http://grass.osgeo.org/grass71/manuals/libpython/
-\url{grass.osgeo.org/grass71/manuals/libpython}
-\end{tabular}
+\includegraphics[width=0.5\linewidth, clip, trim=0 0 0 0]{grass_module_gui}
+\includegraphics[width=0.5\linewidth, clip, trim=0 0 0 0]{grass_module_cli}
-% qrcode -t EPS -o grass-user.eps "http://lists.osgeo.org/listinfo/grass-user"
-% epstopdf grass-user.eps
-% rm grass-user.eps
@@ -254,7 +225,7 @@
 \block{\blocktitlewrap{GRASS Scripting library interface to GRASS GIS modules}}{
-The same applies to \pkg{grass.pygrass} syntax:
+The \pkg{grass.script} package offers simple and straightforward syntax to call GRASS GIS modules:
 \includegraphics[width=\linewidth, clip, trim=0 0 0 0]{script_doc_syntax}
@@ -263,10 +234,14 @@
 \block{\blocktitlewrap{PyGRASS interface to GRASS GIS modules}}{
+The \pkg{grass.pygrass} package provides a object-oriented way to work with GRASS GIS modules and their parameters:
 \includegraphics[width=\linewidth, clip, trim=0 0 0 0]{pygrass_doc_syntax}
+Additionally, the \pkg{grass.pygrass} package offers simpler, Python oriented, way of accessing modules:
 \includegraphics[width=\linewidth, clip, trim=0 0 0 0]{pygrass_doc_sc_syntax}
@@ -278,34 +253,28 @@
 r.neighbors input=elevation output=elevation\_smooth method=median -c
 \end{alltt}
-This can be easily rewritten to \pkg{grass.script} syntax:
+These can be easily rewritten to \pkg{grass.script} or \pkg{grass.pygrass} syntax shown above.
-\includegraphics[width=\linewidth, clip, trim=0 0 0 0]{script_doc_syntax}
-The same applies to \pkg{grass.script} syntax:
-\includegraphics[width=\linewidth, clip, trim=0 0 0 0]{pygrass_doc_syntax}
+% This can be easily rewritten to \pkg{grass.script} syntax:
+% \includegraphics[width=\linewidth, clip, trim=0 0 0 0]{script_doc_syntax}
+% The same applies to \pkg{grass.script} syntax:
+% \includegraphics[width=\linewidth, clip, trim=0 0 0 0]{pygrass_doc_syntax}
-\block{\blocktitlewrap{ctypes interface to C libraries}}{
-\block{\blocktitlewrap{Using NumPy}}{
 \block{\blocktitlewrap{Using IPython Notebook}}{
 	IPython Notebook is a web-based application that provides a tool to: developing, documenting, and executing code, as well as communicating the results.
 	One great tool to process and visualize your data/maps, integrating formulas and explanatory text, interacting with remote server and clusters.
+	\bigskip
 	%\includegraphics[width=0.5\linewidth, clip, trim=0 0 0 0]{pygrass_ipython_cli}
-	\includegraphics[width=0.8\linewidth, clip, trim=0 0 0 0]{ipython_nb}
+	\centering
+	\includegraphics[width=0.95\linewidth, clip, trim=0 120 0 0]{ipython_nb}
@@ -315,23 +284,6 @@
 \column{0.25}
-\block{\blocktitlewrap{Automatic creation of GUI and CLI}}{
-The g.parser module provides full parser support for GRASS GIS scripts.
-It provides the creation of help page template, and command line option
-checking. Each command and scripts which uses the GRASS GIS parser can
-publish its parameter and flags description in XML. Through the included
-XML parser this description can be turned into a graphical user interface with
-standardized styling.
-\includegraphics[width=\linewidth, clip, trim=0 0 0 0]{grass_module}
-\includegraphics[width=0.5\linewidth, clip, trim=0 0 0 0]{grass_module_gui}
-\includegraphics[width=0.5\linewidth, clip, trim=0 0 0 0]{grass_module_cli}
 \block{\blocktitlewrap{PyGRASS interface to C libraries}}{
 Some API examples to convert a raster map to a numpy array and then back to a raster.
@@ -350,9 +302,37 @@
+\block{\blocktitlewrap{GRASS GIS Addons}}{
+The GRASS GIS Addons ensure long-term preservation of the code.
+Well maintained modules in Addons can be moved to GRASS GIS core.
+\block{\blocktitlewrap{ctypes interface to C libraries}}{
+\block{\blocktitlewrap{Using NumPy}}{
+\block{\blocktitlewrap{Alternatives to Python}}{
+GRASS GIS modules are command line tools, so they can be used in shell scripting (e.g. Bash)
+and as subprocesses virtually any language as long as proper environment is set.
+The GRASS GIS library povides a C API which is commonly used to create GRASS modules in C and C++.
+GRASS GIS modules can be used within R using the \pkg{rgrass7} package.
 \column{0.25}
@@ -365,11 +345,39 @@
-\block{\blocktitlewrap{Acknowledgements}}{
+\block{\blocktitlewrap{References and Acknowledgements}}{
+\newcommand{\blocksectiontitle}[1]{\bigskip\textbf{\textcolor{gray}{\textsf{#1}}}}
+% disable the title
+\renewcommand{\section}[2]{}
+\begin{thebibliography}{9}
+\bibitem{Neteler2012}
+  Neteler, M., Bowman, M. H., Landa, M., Metz, M., 2012.
+  \emph{GRASS GIS: A multi-purpose open source GIS.}
+  Environmental Modelling \& Software, 31, 124--130.
+\bibitem{Gebbert2014}
+  Gebbert, S., Pebesma, E., 2014. A temporal GIS for field based environmental modeling. Environmental
+  Modelling \& Software 53, 1--12.
+\bibitem{Petras2014}
+  Petras, V., Gebbert, S., 2014. Testing framework for GRASS GIS: ensuring reproducibility of scientific
+  geospatial computing. Poster presented at: AGU Fall Meeting, December 15-19, 2014, San Francisco, USA.
+\bibitem{Zambelli2013}
+  Zambelli, P., Gebbert, S., Ciolli, M., 2013. Pygrass: An Object Oriented Python Application Programming
+  Interface (API) for Geographic Resources Analysis Support System (GRASS) Geographic Information System
+  (GIS). ISPRS International Journal of Geo-Information 2, 201--219.
+\end{thebibliography}
+\blocksectiontitle{Acknowledgements}
 \newcommand{\listhspace}{\hspace{0.005\linewidth}}
-\newcommand{\listlogowidth}{0.22\linewidth}
-\newcommand{\listtextwidth}{0.76\linewidth}
+\newcommand{\listlogowidth}{0.15\linewidth}
+\newcommand{\listtextwidth}{0.82\linewidth}
 \begin{minipage}{\listlogowidth}
 \includegraphics[width=\linewidth]{osgeo}
@@ -395,35 +403,36 @@
 Luca Delucchi, Italy, contributed significantly to development of Python interfaces for GRASS GIS 7
 through extensive testing in early stages of development, documenting the APIs
 and general contributions to the code itself.
+\blocksectiontitle{More information}
-\block{\blocktitlewrap{References}}{
+\newcommand{\qrcodewidth}{1\linewidth}
+\hspace{-0.02\linewidth}
+\begin{tabular}{lll}
+\begin{minipage}{0.1\linewidth}
+\includegraphics[height=\qrcodewidth]{grass_osgeo_org}
+\end{minipage}
+\begin{minipage}{0.27\linewidth}
+GRASS GIS website\newline
+% http://grass.osgeo.org/
+\url{grass.osgeo.org}
+\end{minipage}
+\includegraphics[height=\qrcodewidth]{python_doc}
+\end{minipage}
+\begin{minipage}{0.45\linewidth}
+GRASS GIS Python libraries documentation\newline
+% http://grass.osgeo.org/grass71/manuals/libpython/
+\url{grass.osgeo.org/grass71/manuals}
+\end{minipage}
-% disable the title
-\renewcommand{\section}[2]{}
-\begin{thebibliography}{9}
+\end{tabular}
-\bibitem{Neteler2012}
-  Neteler, M., Bowman, M. H., Landa, M., Metz, M., 2012.
-  \emph{GRASS GIS: A multi-purpose open source GIS.}
-  Environmental Modelling \& Software, 31, 124--130.
+% qrcode -t EPS -o grass-user.eps "http://lists.osgeo.org/listinfo/grass-user"
+% epstopdf grass-user.eps
+% rm grass-user.eps
-\bibitem{Gebbert2014}
-  Gebbert, S., Pebesma, E., 2014. A temporal GIS for field based environmental modeling. Environmental
-  Modelling \& Software 53, 1--12.
-\bibitem{Petras2014}
-  Petras, V., Gebbert, S., 2014. Testing framework for GRASS GIS: ensuring reproducibility of scientific
-  geospatial computing. Poster presented at: AGU Fall Meeting, December 15-19, 2014, San Francisco, USA.
-\bibitem{Zambelli2013}
-  Zambelli, P., Gebbert, S., Ciolli, M., 2013. Pygrass: An Object Oriented Python Application Programming
-  Interface (API) for Geographic Resources Analysis Support System (GRASS) Geographic Information System
-  (GIS). ISPRS International Journal of Geo-Information 2, 201--219.
-\end{thebibliography}
 \end{columns}
